516-120-000-411
    516 SERIES RACK & PANEL CONNECTO
516-120-000-411 数据手册
516 SERIES Rack And Panel Connectors Features: • • • • • • • • • • • 0.150” (3.81mm) contact spacing x 0.130” (3.30mm) or 0.150” (3.81mm) row spacing with staggered grid Plug and receptacle in 20, 38, 56, 90 and 120 contact sizes Edacon hermaphroditic contact mating design Contact termination options include crimp, P.C. tail, wire hole and wire wrap Mating and unmating simplified with use of actuating screws Optional covers with side or top entry cable clamp in plastic or metal material available for all connector sizes Versatile metal cover design permits assembly or disassembly after cabling is complete plus cable entry style flexibility Actuating screws, locknuts, polarizing hardware, covers and contacts suitable for either plug or receptacle Polarizing hardware adjustable for 288 mating combinations Tools available for contact installation, removal, crimping and polarizing changes RoHS Compliant & UL Certified Specifications: Insulator Material Diallyl Phthalate, Thermoplastic Polyester or Polycarbonate UL 94V- 0 Color Green or Grey (For 120 Pin Only) Contact Material Copper Alloy Contact Plating Gold Plating over Nickel over entire contact Current Rating 8.5 amps Contact Resistance 10 milliohms maximum Dielectric Withstanding Voltage 2000 V AC rms at sea level Insulation Resistance 5000 megaohms minimum Operating Temperature -40°C to +125°C (Diallyl Phthalate Only) Operating Temperature -40°C to +105°C Insertion & Withdrawal Force 2 to 16 oz (0.56 to 4.45N) per contact position Example Part Number: 516-038-500-212 Series Total Number of Contacts Contact Code Style and Material Cover Code Hardware Code Series: Cover Code: Description: 516 0 No Cover Assembly Total Number of Contacts: 1 Plastic Cover, Top Entry Standard Clamp 020, 038, 056, 090 or 120 2 Plastic Cover, Side Entry Standard Clamp Contact Code: Description: Tail Size: Tail Length "G": 3 Plastic Cover, Top Entry Large Clamp 000 No Contacts Assembled ------------ ------------ 4 Plastic Cover, Side Entry Large Clamp 500 Wire Hole .110 x .024 (2.79 x 0.61) .245 (6.22) 5 Metal Cover, Side Entry 501 Taper Tail .110 x .024 (2.79 x 0.61) .245 (6.22) 6 Metal Cover, Top Entry 520 P.C. Tail .025 x .024 (0.64 x 0.61) .215 (5.46) Hardware Code: Description: 540 Wire Wrap .050 x .024 (1.27 x 0.61) .600 (15.24) 0 No Hardware 541 Wire Wrap .026 x .024 (0.66 x 0.61) .620 (15.70) 1 Actuating Screw & Polarizing Hardware 542 Wire Wrap .050 x .024 (1.27 x 0.61) .790 (20.07) 2 Locknut & Polarizing Hardware Style & Material: Style: Insulator Material: 5 Actuating Screw with No Polarizing Hardware 1 Plug Green Diallyl Phthalate 6 Locknut with No Polarizing Hardware 2 Receptacle Green Diallyl Phthalate 3 Plug Grey Polycarbonate 4 Receptacle Grey Polycarbonate 5 Plug Green Polyester 6 Receptacle Green Polyester www.edac.net customerservice@edac.net 516 SERIES Rack And Panel Connectors Ordering Code Notes: 1) Crimp contacts are also available for 516 series connectors. Contacts may be ordered separately for pre-wired or select position assembly. Part Number Description Silhouette 516-290-500 Wire Hole 516-290-501 Taper Tail 516-290-520 P.C. Tail 516-290-540 Wire Wrap 516-290-541 Wire Wrap 516-290-542 Wire Wrap 516-290-590 Crimp (Loose) 516-294-571 Crimp - 1800 Contact Per Reel 2) For contact installation, removal and crimping tools, please contact EDAC. 3) Grey Polycarbonate and Polyester insulator material is not available for 120 pin size connector. 120 pin size connector can only be supplied in DAP (Green and Grey). 120 pin part number ends with 3XX or 4XX are supplied in grey DAP. 4) 20 pin connector cover will not accept the length of the wire wrap contacts 5) Plastic covers with large clamps are only available for 38 and 56 pin sizes only 6) Metal covers with side entry may be converted to top entry by removing side plate and changing clamp orientation 7) Covers may be ordered separately 8) Insulator design prevents improper mating of individual plug and receptacle. Polarizing hardware enables specific plug and receptacle combinations Crimp Characteristics • Contacts and Crimp Tool Accommodate from 28AWG to 18AWG, Solid or Stranded Conductor Diameters from .012 (0.30) to .049 (1.25) and an Insulation diameter up to 0.074 (1.88) • Multiple Smaller Gauge Wires may be Crimped Together • Crimp Resistance from 0.5 Milliohms (18AWG) to 1.5 Milliohms(28AWG) • Crimp Tensile Strength for Wire Sizes: 18AWG - 40 lbs (178 N) 20AWG - 25 lbs (111 N) 22AWG - 15 lbs (67 N) 24AWG - 10 lbs (44 N) 26AWG - 5 lbs (22 N) 28AWG - 3 lbs (13 N) Polarizing Codes • Polarizing Hardware Changes allow 288 Mating Combinations • Standard Code Supplied for Plugs PG1G1, for Receptacle RS1S1. • Connectors with Special Polarizing Codes Available upon Special Request Example Polarizing Code: P G 4 S 2 Type of Connector P - Plug, R - Receptacle Large Diameter Hardware G - Guidepin (at Contact Position "A" end) H - Guidepin (at Last Contact Position end) S - Socket (at Contact Position "A" end) T - Socket (at Last Contact Position end) Position of large Diameter Keyway - 1 Through 6 Small Diameter Hardware (Opposite end From Large Diameter) G - Guidepin, S - Socket Position of Small Diameter Keyway - 1 Through 6 This Example mates with Code RS4G2 www.edac.net customerservice@edac.net 516 SERIES Rack And Panel Connectors www.edac.net customerservice@edac.net
516-120-000-411
物料型号:516-038-500-212
器件简介:EDAC 516系列为机架和面板连接器,具有多种接触尺寸和配置选项。
引脚分配:文档提供了不同引脚配置的示例,例如500(线孔)、501(锥形尾)、520(PC尾)、540(线绕)等。
参数特性:包括绝缘材料、颜色、接触材料、接触镀层、电流额定值、接触电阻、介质耐电压、绝缘电阻、操作温度范围、插入和拔出力等。
功能详解:文档描述了EDAC 516系列连接器的特点,如EDAC同型接触配对设计、接触终止选项、简化的配对和解锁使用操作螺钉、可选的塑料或金属盖、多功能金属盖设计等。
应用信息:文档提供了有关如何订购516系列连接器的说明,包括订购代码注释、压接特性、极化代码等。
封装信息:文档提供了不同封装选项的描述,包括插头和插座的不同材料和颜色,以及不同尺寸的塑料和金属盖。
516-120-000-411 价格&库存
很抱歉,暂时无法提供与“516-120-000-411”相匹配的价格&库存,您可以联系我们找货
    • 1+763.95960
    • 200+304.83000
    • 500+294.64560
    • 1000+289.61280
    • 25+362.4764025+45.10638
