627-3WK3224-5TA
627-3WK3224-5TA
    CONN D-SUB PLUG 3P PNL MNT SLDR
627-3WK3224-5TA 数据手册
TOLERANCE UNLESS OTHERWISE SPECIFIED .X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 1 ORIGINAL ±0.25 ±0.13 ±0.05 39.15 25.25 8.36 12.60 33.30 6.10 10° 11.00 NOTES: MATERIAL: HOUSING: THERMOPLASTIC POLYESTER, UL94V-0 SHELL: STEEL, Sn or Ni PLATED CONTACT: COPPER ALLOY SEE ORDERING GUIDE FOR PLATING OPERATING TEMPERATURE: -55 C ~ 125 C SIGNAL CONTACT CURRENT RATING: 5A PER CONTACT SIGNAL CONTACT RESISTANCE: 10mΩ MAX. INSULATOR RESISTANCE: 5000MΩ min. DIELECTRIC WITHSTANDING VOLTAGE: 1000V AC rms 627 COMBO ASSEMBLY SW REFERENCE NO.: COMBINATION D-SUB C.B DRAWN: DATE: DATE: CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: JAN. 01/2019 (IN C.A.D. 1:1) SHEET 1 OF 4 DRAWING NUMBER: 627-3WK3224-5TA ISSUE PART NUMBER: 627-3WK3224-5TA 1 TOLERANCE UNLESS OTHERWISE SPECIFIED .X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ±0.25 ±0.13 ±0.05 SW REFERENCE NO.: COMBINATION D-SUB C.B DRAWN: CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. 1 ORIGINAL YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: N.T.S 627 COMBO ASSEMBLY DATE: JAN. 01/2019 DATE: SHEET 2 OF 6 DRAWING NUMBER: 627-3WK3224-5TA ISSUE PART NUMBER: 627-3WK3224-5TA 1 TOLERANCE UNLESS OTHERWISE SPECIFIED .X .XX .XXX CURRENT RATING / 10A / 2.2 20A / 3.3 30A / 3.7 40A / 4.2 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ±0.25 ±0.13 ±0.05 A SW REFERENCE NO.: COMBINATION D-SUB C.B DRAWN: CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. 1 ORIGINAL YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: N.T.S 627 COMBO ASSEMBLY DATE: JAN. 01/2019 DATE: SHEET 3 OF 4 DRAWING NUMBER: 627-3WK3224-5TA ISSUE PART NUMBER: 627-3WK3224-5TA 1 TOLERANCE UNLESS OTHERWISE SPECIFIED .X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ±0.25 ±0.13 ±0.05 SW REFERENCE NO.: COMBINATION D-SUB C.B DRAWN: CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. 1 ORIGINAL YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: N.T.S 627 COMBO ASSEMBLY DATE: JAN. 01/2019 DATE: SHEET 4 OF 4 DRAWING NUMBER: 627-3WK3224-5TA ISSUE PART NUMBER: 627-3WK3224-5TA 1
627-3WK3224-5TA 价格&库存
很抱歉,暂时无法提供与“627-3WK3224-5TA”相匹配的价格&库存,您可以联系我们找货
627-3WK3224-5TA
  • 2400+62.602282400+8.10214
