305-084-556-508
305-084-556-508
    305 SERIES (.156 (3.96MM) CONTA
305-084-556-508 数据手册
Mounting Option 08-#4-40 Unified Threaded Inserts Contact Detail 556-Extender Board Bend (Code 520 Contacts) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.500 12.70 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 6.716 170.59 0.330 8.38 Card Slot 6.862 174.29 7.148 181.56 SECTION A-A 0.460 11.68 A A 0.125 3.18 Point of Contact 7.458 189.43 305 / 315 / 355 Card Edge Connector Part Number: 305-084-556-508 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-084-556-508
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一种通用型晶体管输出光电耦合器,具有较高的输入电流驱动能力和高速响应特性。 3. 引脚分配:EL817共有6个引脚,分别为1脚阳极(Anode),2脚阴极(Cathode),3脚输出晶体管集电极(Collector),4脚输出晶体管发射极(Emitter),5脚输出晶体管基极(Base),6脚Vcc。 4. 参数特性:主要参数包括正向电流IF=50mA,反向电压VR=5V,输出晶体管的低电平电流IL和高电平电流IH分别为1mA和15mA。 5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于开关电源、测量设备等需要电气隔离的场合。 6. 应用信息:广泛应用于工业控制系统、医疗设备、通信设备等领域。 7. 封装信息:采用DIP-6封装形式,尺寸为9.1mm×3.6mm×3.9mm。
305-084-556-508 价格&库存
很抱歉,暂时无法提供与“305-084-556-508”相匹配的价格&库存,您可以联系我们找货
  • 25+160.9408125+20.86100
