306-037-400-107
306-037-400-107
    P=3.96mm
    306 SERIES (.156 (3.96MM) CONTA
306-037-400-107 数据手册
Mounting Option 107-M3-0.5 Metric Threaded Inserts 0.500 12.70 Contact Detail 400-Wire Hole .087x.015(2.21x0.38) - Tail LG.=.282(7.16) .156 [3.96] Contact Spacing with Single Centreline Row ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board ORIGINAL 1 0.156 3.96 0.156 3.96 5.936 150.77 6.082 154.48 0.295 7.49 Card Slot 6.368 161.75 A See Accompanying Pages for: • Mounting Options SECTION A-A 0.250 6.35 0.460 11.68 A 0.165 4.19 Point of Contact 6.678 169.62 306 / 316 / 356 Card Edge Connector Part Number: 306-037-400-107 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 306 ENG MASTER DATE: SEPT. 14/09 NTS DRAWING NUMBER 306 Assembly SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 306 / 316 / 356 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. DRAWN: J.LEE DATE: CHECKED: SCALE: 306 ENG MASTER DATE: SEPT. 14/09 NTS DRAWING NUMBER 306 Assembly SHEET 2 OF 2 ISSUE 1
306-037-400-107 价格&库存
很抱歉,暂时无法提供与“306-037-400-107”相匹配的价格&库存,您可以联系我们找货
  • 25+194.3704025+25.22573
