629-27W2640-7TA
629-27W2640-7TA
    CONN D-SUB PLUG 27POS R/A SLDR
629-27W2640-7TA 数据手册
TOLERANCE UNLESS OTHERWISE SPECIFIED .X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 1 ORIGINAL ±0.25 ±0.13 ±0.05 63.50 8.30 12.50 69.40 55.40 6.10 10° 11.00 NOTES: MATERIAL: HOUSING: SHELL: CONTACT: THERMOPLASTIC POLYESTER, UL94V-0 STEEL, TIN PLATED COPPER ALLOY, 30μ" GOLD PLATED OPERATING TEMPERATURE: -55 C ~ 125 C 75Ω (IMPEDANCE) POWER/CO-AX CONTACT RATING: (IF PRESENT) SIGNAL CONTACT CURRENT RATING: 5A PER CONTACT 10mΩ MAX. SIGNAL CONTACT RESISTANCE: INSULATOR RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: 5000MΩ min. 1000V AC rms 629 COMBO ASSEMBLY SW REFERENCE NO.: COMBINATION D-SUB C.B DRAWN: DATE: DATE: CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: JAN. 01/2019 (IN C.A.D. 1:1) SHEET 1 OF 2 DRAWING NUMBER: 629-27W2640-7TA ISSUE PART NUMBER: 629-27W2640-7TA 1 TOLERANCE UNLESS OTHERWISE SPECIFIED .X .XX .XXX ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ±0.25 ±0.13 ±0.05 SW REFERENCE NO.: COMBINATION D-SUB C.B DRAWN: CHECKED: COMPLIANT THIS SERIES FULLY CONFORMS TO EDAC INC THE EUROPEAN UNION DIRECTIVES TORONTO, ONTARIO CANADA 2011/65/EU FOR RoHS COMPLIANCY. 1 ORIGINAL YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SCALE: N.T.S 629 COMBO ASSEMBLY DATE: JAN. 01/2019 DATE: SHEET 2 OF 2 DRAWING NUMBER: 629-27W2640-7TA ISSUE PART NUMBER: 629-27W2640-7TA 1
629-27W2640-7TA 价格&库存
很抱歉,暂时无法提供与“629-27W2640-7TA”相匹配的价格&库存,您可以联系我们找货
