630-21W4650-4TA
630-21W4650-4TA
    弯插
    630 SERIES RIGHT ANGLE COMBO D-
630-21W4650-4TA 数据手册
629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Features: • • • • • Signal, along with power or coaxial contacts within one connector Space saving on the PCB and I/O designs Available in various pin out configurations Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization • • Specifications: Power/Coaxial Only Combination Insulator Material Thermoplastic Polyester, UL 94V-0, Color: Black Contact Material Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material and Plating Steel, Sn or Ni Plated Shell Material Nickel Plated Steel Current Rating (Power Contacts) 10 amps, 20 amps, 30 amps, 40 amps Current Rating (Signal Contacts) 5 amps Voltage Rating 125 V Contact Resistance (Power Contacts) 1 Milliohms maximum Contact Resistance (Signal Contacts) 10 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +125°C Mating Cycle 500 For 30 Microinches Gold Plating, 50 For Gold Flash Plating Ordering Code: SERIES: 629: PLUG (PIN) 630: RECEPTACLE (SOCKET) LAYOUT: POWER/CO-AX ONLY SIZE 9 CONTACT SHELL 2WK2 5W1 3WK3 7W2 11W1 9W4 13W3 17W2 21W1 SIZE 15 CONTACT SHELL 3W3 SIZE 25 CONTACT SHELL 5W5 SIZE 37 CONTACT SHELL 8W8 13W6 17W5 25W3 27W2 21W4 24W7 36W4 43W2 47W1 SIZE 50 CONTACT SHELL 8W8 COMBINATION 2W2 2WK2 TOTAL NO.OF POWER OR CO-AXCONTACT TOTAL NO.OF CONTACT MALE FEMALE COMBINATION CONTACT PLATING THICKNESS: 2 - GOLD FLASH PLATING 6 - 30 MICROINCHES OF GOLD PLATING TAIL TYPE: 40 - PC TAIL 50 - PC TAIL 20.33mm FOOTPRINT (POWER CONTACT ONLY) www.edac.net MOUNTING OPTIONS: 1 - THROUGH HOLE 2 - #4-40 UNC THREADED HOLE ONLY 3 - #4-40 UNC THREADED HOLE, MOUNTING BRACKET, BOARDLOCK 4 - #4-40 UNC THREADED HOLE, MOUNTING BRACKET 5 - #4-40 UNC THREADED STANDOFF, MOUNTING BRACKET, BOARDLOCK 6 - #4-40 UNC THREADED STANDOFF, MOUNTING BRACKET A - M3 THREADED HOLE ONLY B - M3 THREADED HOLE, MOUNTING BRACKET, BOARDLOCK C - M3 THREADED HOLE, MOUNTING BRACKET D - M3 THREADED STANDOFF, MOUNTING BRACKET, BOARDLOCK E - M3 THREADED STANDOFF, MOUNTING BRACKET SHELL PLATING: N - NICKEL T - TIN RATING: POWER CONTACT CURRENT RATING: 1 - 10A 2 - 20A 3 - 30A 4 - 40A COAXIAL CONTACT IMPEDANCE RATING: 5 - 50 OHMS 7 - 75 OHMS customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Layout: Layout: POWER/COAXIAL D-SUB ONLY COMBINATION SIZE 9 2W2 2WK2 3W3 3WK3 5W1 SIZE 15 SIZE 25 7W2 11W1 9W4 13W3 17W2 21W1 5W5 13W6 17W5 25W3 27W2 SIZE 37 8W8 21W4 24W7 36W4 43W2 47W1 SIZE 50 www.edac.net customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Power/Coaxial Power/Coaxial D-SUB: D-SUB: R/A PCB SOLDER TYPE MALE FEMALE POWER-DUB POWER D-SUB COAXIAL D-SUB COAXIAL D-SUB POWER D-SUB POWER D-SUB CONTACT SHELL SIZE DIMA DIMB DIMC DIMD DIME(POWER/COAXIAL) RATING ØF SIZE 9 30.80 25.00 16.90 12.50 7.90/8.30 10A 1.7 SIZE 15 39.20 33.30 25.25 12.50 7.90/8.30 20A 2.8 SIZE 25 53.05 47.05 38.95 12.50 7.90/8.30 30A 3.2 SIZE 37 69.40 63.50 55.40 12.50 7.90/8.30 40A 3.75 CONTACT SHELL SIZE DIMA DIMB DIMC(POWER/COAXIAL) DIMD SIZE 9 30.80 25.00 SIZE 15 39.20 SIZE 25 53.05 SIZE 37 69.40 DIME RATING ØF 16.90/16.30 12.50 7.90 10A 1.7 33.30 25.25/24.60 12.50 7.90 20A 2.8 47.05 38.95/38.40 12.50 7.90 30A 3.2 63.50 55.40/54.80 12.50 7.90 40A 3.75 COAXIAL D-SUB COAXIAL D-SUB MOUNTING OPTION MALE CODE:1 CODE:3/B CODE:5/D www.edac.net FEMALE CODE:2/A CODE:4/C CODE:6/E customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Power D-SUB: PCB LAYOUT FOR POWER D-SUB MALE AND FEMALE CONNECTOR CODE:3W3/3WK3 CODE:2W2/2WK2 CODE:8W8 MALE CODE:5W5 MALE CODE:8W8 FEMALE CODE:5W5 FEMALE CURRENT RATING ØA(mm) www.edac.net 10A 2.2 20A 30A 40A 3.3 3.7 4.2 customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Coaxial D-SUB: PCB LAYOUT FOR COAXIAL D-SUB MALE AND FEMALE CONNECTOR CODE:2W2/2WK2 MALE/FEMALE CODE:3W3/3WK3 MALE/FEMALE CODE:5W5 MALE CODE:8W8 MALE CODE:5W5 FEMALE CODE:8W8 FEMALE www.edac.net customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Power Combo& Coaxial Combo D-SUB: RA PCB SOLDER TYPE MALE FEMALE POWER COMBO D-SUB POWER COMBO D-SUB COAXIAL COMBO D-SUB COAXIAL COMBO D-SUB POWER D-SUB POWER D-SUB CONTACT SHELL SIZE DIMA DIMB DIMC DIMD DIME RATING ØF SIZE 9 30.80 25.00 16.90 12.50 8.30 10A 1.7 CONTACT SHELL SIZE SIZE 9 SIZE 15 39.20 33.30 25.25 12.50 8.30 20A 2.8 SIZE 25 SIZE 37 SIZE 50 53.05 69.40 67.00 47.05 63.50 61.00 38.95 55.40 52.80 12.50 12.50 15.30 8.30 8.30 11.15 30A 40A 3.2 3.75 COAXIAL D-SUB DIMA 30.80 DIMB 25.00 SIZE 15 39.20 SIZE 25 53.05 SIZE 37 SIZE 37 DIMD 12.50 DIME 7.90 RATING 10A ØF 1.7 33.30 24.60 12.50 7.90 20A 2.8 47.05 38.40 12.50 7.90 30A 3.2 69.40 63.50 55.40 12.50 7.90 40A 3.75 67.00 61.00 52.20 15.30 10.90 COAXIAL D-SUB R/A PCB SOLDER TYPE MOUNTING OPTION www.edac.net DIMC 16.30 CODE:1 CODE:2/A CODE:3/B CODE:4/C CODE:5/D CODE:6/E customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Power Combo D-SUB: PCB LAYOUT FOR MALE AND FEMALE CONNECTOR CODE:24W7 MALE/FEMALE CODE:5W1 MALE/FEMALE www.edac.net CODE:7W2 MALE/FEMALE CODE:21W4 MALE/FEMALE CODE:11W1 MALE/FEMALE CODE:27W2 MALE/FEMALE CODE:17W2 MALE/FEMALE CODE:21W1 MALE/FEMALE CUREENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Power Combo D-SUB: PCB LAYOUT FOR MALE CONNECTOR CODE:25W3 MALE CODE:9W4 MALE CODE:36W4 MALE CODE:13W3 MALE CODE:43W2 MALE CODE:13W6 MALE CODE:47W1 MALE CODE:17W5 MALE www.edac.net CUREENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Power Combo D-SUB: PCB LAYOUT FOR FEMALE CONNECTOR CODE:25W3 FEMALE CODE:9W4 FEMALE CODE:36W4 FEMALE CODE:13W3 FEMALE CODE:43W2 FEMALE CODE:13W6 FEMALE CODE:47W1 FEMALE CODE:17W5 FEMALE www.edac.net CUREENT RATING 10A 20A 30A 40A ØA(mm) 2.2 3.3 3.7 4.2 customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Coaxial Combo D-SUB: PCB LAYOUT FOR MALE AND FEMALE CONNECTOR CODE:5W1 MALE/FEMALE www.edac.net CODE:24W7 MALE/FEMALE CODE:7W2 MALE/FEMALE CODE:21W4 MALE/FEMALE CODE:11W1 MALE/FEMALE CODE:27W2 MALE/FEMALE CODE:17W2 MALE/FEMALE CODE:21W1 MALE/FEMALE customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Coaxial Combo D-SUB: PCB LAYOUT FOR MALE CONNECTOR CODE:25W3 MALE CODE:9W4 MALE CODE:36W4 MALE CODE:13W3 MALE CODE:43W2 MALE CODE:13W6 MALE SERIES: 629: PLUG (PIN) 630: RECEPTACLE (SOCKET) LAYOUT: POWER/CO-AX ONLY SIZE 9 CONTACT SHELL 2WK2 5W1 3WK3 7W2 11W1 9W4 CODE:17W5 13W3 17W2 21W1 SIZE 15 CONTACT SHELL 3W3 SIZE 25 CONTACT SHELL 5W5 SIZE 37 CONTACT SHELL 8W8 MALE 13W6 17W5 25W3 27W2 21W4 24W7 36W4 43W2 47W1 SIZE 50 CONTACT SHELL 8W8 COMBINATION 2W2 2WK2 TOTAL NO.OF POWER OR CO-AXCONTACT TOTAL NO.OF CONTACT MALE FEMALE COMBINATION CONTACT PLATING THICKNESS: 2 - GOLD FLASH PLATING 6 - 30 MICROINCHES OF GOLD PLATING TAIL TYPE: 40 - PC TAIL 50 - PC TAIL 20.33mm FOOTPRINT (POWER CONTACT ONLY) www.edac.net MOUNTING OPTIONS: 1 - THROUGH HOLE 2 - #4-40 UNC THREADED HOLE ONLY 3 - #4-40 UNC THREADED HOLE, MOUNTING BRACKET, BOARDLOCK 4 - #4-40 UNC THREADED HOLE, MOUNTING BRACKET 5 - #4-40 UNC THREADED STANDOFF, MOUNTING BRACKET, BOARDLOCK 6 - #4-40 UNC THREADED STANDOFF, MOUNTING BRACKET A - M3 THREADED HOLE ONLY B - M3 THREADED HOLE, MOUNTING BRACKET, BOARDLOCK CODE:47W1 C - M3 THREADED HOLE, MOUNTING BRACKET MALE D - M3 THREADED STANDOFF, MOUNTING BRACKET, BOARDLOCK E - M3 THREADED STANDOFF, MOUNTING BRACKET SHELL PLATING: N - NICKEL T - TIN RATING: POWER CONTACT CURRENT RATING: 1 - 10A 2 - 20A 3 - 30A 4 - 40A COAXIAL CONTACT IMPEDANCE RATING: 5 - 50 OHMS 7 - 75 OHMS customerservice@edac.net 629C/630C SERIES Power Combo D-Sub Connectors: Right Angle Coaxial Combo D-SUB: PCB LAYOUT FOR FEMALE CONNECTOR CODE:9W4 FEMALE CODE:13W3 FEMALE CODE:13W6 FEMALE CODE:17W5 FEMALE www.edac.net CODE:25W3 FEMALE CODE:36W4 FEMALE CODE:43W2 FEMALE CODE:47W1 FEMALE customerservice@edac.net
630-21W4650-4TA
1. 物料型号:629C/630C系列,具体型号为629-2W2-220-1N2。 2. 器件简介:EDAC D-SUB+ Power Combo D-Sub Connectors,具有直角布局,可在一个连接器内同时传输信号、电源或同轴接触。节省PCB和I/O设计空间,提供EMI/RFI屏蔽,多种引脚配置可选。 3. 引脚分配:文档中提供了不同尺寸的接触壳(如SIZE9、SIZE15、SIZE25、SIZE37和SIZE50)的引脚分配信息,包括二维尺寸和电流等级。 4. 参数特性:绝缘材料为UL 94V-0的热塑性聚酯,黑色;接触材料为铜合金;接触镀金选择性金层(根据订购代码);壳体材料和镀层为钢,锡或镍镀;工作温度范围为-55°C至+125°C;额定电流包括10A、20A、30A和40A;电压等级为125V。 5. 功能详解:金属壳体提供EMI/RFI屏蔽,插头壳体凹槽提供接地和额外的配对保持力;D形连接器配对轮廓提供极化;多种安装选项,包括通孔、螺纹孔和螺纹支架。 6. 应用信息:适用于需要同时传输信号和电源的应用场景,节省空间。 7. 封装信息:提供不同尺寸的接触壳,包括9针、15针、25针、37针和50针等配置,以及不同的安装选项和尾类型(PC尾)。
630-21W4650-4TA 价格&库存
很抱歉,暂时无法提供与“630-21W4650-4TA”相匹配的价格&库存,您可以联系我们找货
630-21W4650-4TA
  • 2000+196.822592000+25.24646
