DEVKIT1207
DEVKIT1207
    IMBEST(英蓓特)
DEVKIT1207 数据手册
DevKit1207 Evaluation Kit         120MHz STM32F207IGT6 ARM Cortex-M3 32-bit Flash Microcontroller CPU Internal 1MBytes of Flash and 128 (system) +4 (backup) KBytes of SRAM 1 USB2.0 OTG Full-speed Port and 1 USB2.0 OTG High-speed Port 3.5-inch TFT LCD and 4-wire Resistive Touch Screen 10/100 Ethernet with IEEE 1588v2, CAN2.0B, IrDA, TF, Audio, JTAG… G-sensor 3-Axis Acceleration Sensor Optional 1.3 megapixel Digital Camera Module Supports for uC/OS-II and FreeRTOS Real-time Operating Systems Figure 1-1 DevKit1207 Evaluation Board with 3.5” LCD and Touch Screen Overview The STMicroelectronics’ STM32F207IGT6 flash microcontroller is among STM32F207xx family, which is based on the high-performance ARM Cortex-M3 32-bit RISC core operating at a frequency of up to 120MHz, with high-speed embedded memories (1Mbytes of flash memory and 128Kbytes of system SRAM), 4Kbytes of backup SRAM, and powerful peripheral functions, including digital camera module interface, High-speed USB OTG, Full-speed USB OTG, Ethernet MAC, CAN2.0B, multiple timers, ADCs and DACs, I2C, I2S, SPI, UARTs/USARTs, SDIO, LCD interface, RTC and programmable IOs. Embest DevKit1207 Evaluation Kit is a complete development platform for STM32F207IGT6 devices which enables engineers to easily and rapidly evaluate, prototype and test designs built around the STMicroelectronics STM32F207xx series microcontrollers. The DevKit1207 board has on-board 2Kbits EEPROM and exposed a full range of hardware peripherals to support HS/FS USB OTG, Ethernet, CAN, Serial port, IrDA, TF card, LCD, Touch screen, Audio, G-sensor, RTC, JTAG, etc. The kit is provided with an industrial-level 3.5 inch LCD with resistive 1 touch screen. A digital camera module CAM1207 is also offered as an option to customers. Embest has ported uC/OS-II and FreeRTOS real-time operating systems on this board and the software also features the GUI support on uC/OS-II and LwIP_v1.3.2 protocal support on FreeRTOS. Embest provides the uC/OS-II BSP, FreeRTOS source tree and plenty of software examples, board schematic and user manual to help customer better understanding this board and develop your own applications. Hardware Features Processor  STMicroelectronics STM32F207IGT6 Flash Microcontroller - ARM 32-bit Cortex-M3 CPU with ART accelerator, frequency up to 120MHz - Onchip 1Mbytes of Flash memory and 128+4Kbytes of SRAM - Flexible static memory controller that supports Compact Flash, SRAM, PSRAM, Nor and Nand memories - LCD parallel interface, 8080/6800 modes - USB 2.0 HS/FS Device/Host/OTG - 10/100 Ethernet MAC, supports IEEE 1588v2 hardware, MII/RMII - 2 CAN 2.0B interfaces, 4 USARTs and 2 UARTs, 2 with muxed I2S, 3 SPI (30Mbit/s) - 8- to 14-bit parallel camera interface (up to 48Mbytes/s) - 1-/4-/8-bit SD/MMC/SDIO interface, supports up to 32Gbytes storage - Up to 140 I/O ports up to 60MHz - Up to 17 timers (two 32-bit timers), up to 120MHz - 3 x 12-bit A/D converters, 2 x 12-bit D/A converters - Analog true random number generator - Low power, supports Sleep, Stop and Standby modes - Supports booting from Flash, System memory or SRAM - Supports ISP and IAP programming External Memory  Onboard I2C compatible serial interface 2Kbits EEPROM  Micro SD card slot Audio interfaces  1-channel stereo headphone output jack  1-channel speaker output jack  1-channel audio DAC output jack LCD/Touch Screen  3.5 inch TFT color LCD (240 x 320-pixel RGB resolution, 262000 colors, 16-bit 8080 parallel interface, brightness control via PWM)  4-wire resistive touch screen Data Transfer Interfaces  1-channel 5-wire RS232 Serial Port  1 x USB2.0 OTG/Device/Host, High-speed, 480Mbps  1 x USB2.0 OTG/Device/Host, Full-speed, 12Mbps    10/100 Ethernet with IEEE 1588v2 (RJ45 connector) 1 x CAN2.0B interface IrDA transceiver 2 Input Interface and Other Facilities  1 x Potentiometer (A/D converter)  2 x USER buttons  1 x RESET button  1 x WAKEUP button  20-pin standard JTAG interface  RTC battery socket (User needs to prepare battery, CR1220 model is recommended)  1 x LED for Power indicator  2 x LEDs for USB OTG FS indicators  2 x LEDs for USB OTG HS indicators  4 x User LEDs  140 GPIO pins are all brought out Mechanical Parameters  Dimensions: 160 mm x 115 mm  Input Voltage: +5V  Power consumption: 0.4A@5V  Working Temp.: -10 ℃ ~ 70 ℃  Humidity Range: 20% ~ 90% Camera Interface USB OTG_FS USB OTG_HS RTC battery LCD/Touch Screen Interface GPIO pins IrDA Potentiometer IrDA User Keys Configuration G-sensor Module STM32F207IGT6 TF card Configuration Wakeup TF card slot Reset JTAG Interface Bootloader Configuration Power In Ethernet Serial port Configuration Serial port CAN Speaker Audio Out Note: RTC battery is not provided in default deliveries, user needs to prepare it yourself, Type model CR1220 is recommended. Some functions need to use Jumpers to configure before using. Figure 1-2 DevKit1207 Evalution Board 3 Optional Digital Camera Module CAM1207 The CAM1207 Digital Camera Module is designed specially for using on Embest DevKit1207 products connecting via 30-pin FPC connector. It uses a CMOS image sensor which is a 1.3 megapixel Digital Camera. CAM1207 Digital Camera Module CAM1207 connects to DevKit1207 board Dimension 47.8mm * 37.6mm * 6mm Signal system CMOS 1.3 megapixel Resolution up to 1280 * 1024 Frame rate 15 fps for SXGA 30 fps for VGA, CIF Interface 30-pin FPC connector Power supply From board Working Temp. -10 ~ +70°C Board Support DevKit1207 Supports photo taking Supports photo saving Functions 4 DCMI ADC 1 Channel 12bit IrDA USART RTC RTC LCD (RGB) and Touch DP83848C MAC CAN 2.0B TAJ1040 CAN 1 Audio Out I2C1 G-Sensor IO LIS33DE I2C1 LEDS SDIO AT24C02 DAC Out GPIO USB USB2.0 OTG_HS TF Card Speaker USB USB2.0 OTG_FS EEPROM STM32F207IGT6 120MHz Ethernet CSC2L52 COM 5 line RS232 I2S2 DEBUG Camera LCD Function Block Diagram Extented Interface Figure 1-3 DevKit1207 Function Block Diagram 5 Software Features The DevKit1207 Evaluation Kit software mainly features as below:  Supports for uC/OS-II_v2.86 and FreeRTOS_v6.1.0 real-time operating systems  Supports UCGUI_v3.90a  Supports FatFs_vR0.08a file system  Supports LWIP _v1.3.2 protocol stack  Provided with plenty of source code Boot Modes The DevKit1207 Evaluation Board is able to boot from CPU internal system memory or embedded SRAm, user needs to configure the boot pins to select the mode. The boot loader is located in system memory. It is used to reprogram the Flash memory by using Serial port or USB OTG FS in Device mode through DFU (device firmware upgrade). Drivers and Software examples Embest has provided complete drivers and software examples for this kit. User can demonstrate and test each software example and observe the result from LCD which would be easy to understand. The software examples mainly include following parts:  Examples for Basic peripherals drivers (see Table 1-1 below) Table 1-1 ADC3_DMA ADC Transfer ADC3 converted data to to the memory using DMA DualADC_Interleaved_ Cross access dual-channel ADC converted data using DMAmode3 DMA mode 3 DualADC_RegulSimu_ Synchronization access dual-channel ADC converted DMAmode1 data using DMA mode 1 TripleADC_Interleaved Cross access three-channel ADC converted data using _DMAmode2 DMA mode 2 LoopBack CAN loopback testing example Networking CAN communication testing example CRC_Example CRC verify testing example DAC_SignalsGeneratio DAC signal generator (can get various wave signals) n testing example DMA FLASH_RAM Transfer data from Flash to RAM using DMA EXTI EXTI_Example Configure external interrupt of EXTI FLASH Program Programming Flash, block erase, read and write CAN CRC DAC 6 Write_Protection Write protection on Flash IOToggle Configure voltage of specified pins via GPIOs JTAG_Remap Remap JTAG pins as general IOs EEPROM Read and write on EEPROM using I2C GSensor-LIS33DE 3-Axis Acceleration Sensor testing example I2S Audio Play audio testing example through I2S IWDG IWDG_Example Single watchdog reset function example LCD-Touch STMPE811QTR LCD and Touch screen application testing example Lib-DEBUG Lib_DEBUG_Example DEBUG testing example GPIO I2C DMA_WFIMode NVIC Wakeup system from WFI mode using DMA data stream interrupt IRQ_Priority Set interrupt using interrupt priority VectorTable_Relocation Relocate interrupt using interrupt table BOR Power-Off Reset testing example CurrentConsumption Current testing example PVD Programmable voltage detection testing example STANDBY Standby mode testing example STOP Stop mode testing example RCC RCC_Example Configure different system clock frequency via RCC RNG RNG_MultiRNG PWR BKP_Domain RTC HW_Calendar TimeStamp SDIO uSDCard SysTick SysTick_Example TIM Multi-channel random number generator testing example Implement using perpetual calender through BKP_Domain Implement using RTC Alarm through RTC controller Implement time-stamping function through RTC controller Read and write SD card using FatFs_vR0.08a Implement delay through tick interrupt, light up LED with flick 6Steps 6-phase PWM output testing example InputCapture TIM input capture mode testing example OCActive TIM output active mode testing example 7 OCInactive TIM output inactive mode testing example OCToggle TIM output trigger mode testing example OnePulse TIM single pulse mode testing example Parallel_Synchro Several TIM parallel and synchronization testing example PWM_Input PWM input mode testing example PWM_Output PWM output mode testing example TIM1_Synchro TIM1, 3 and 4 parallel and synchronization testing example TIM9_OCToggle TIM9 output trigger mode testing example TIM10_PWMOutput Timer 10 PWM output testing example TimeBase Timer basic function testing example USART_IRDA IrDA transmitting and receiving testing example USART_Printf Hyper-terminal input and output testing example WWDG_Example Watchdog reset testing example USART WWDG  Example for IrDA driver  Example for I2S Audio driver  Application example for G-sensor  Application example for SD card supporting FatFs_vR0.08a file system  Application example for USB Host/Device/OTG (see Table 1-2 below) Table 1-2 USB Device application examples AUDIO DFU Use board as audio device, similar to USB acoustics, user can play music on PC and output sound through board Use board as DFU device, user can use it for system firmware updating. Dual-USB channel testing example. Use HS-USB as MSC device and DualCore FS-USB as HID device. HID Use board as HID (Human Interaction Device) to implement USB mouse operation. 8 Use board as MSC (Mass Storage Device) to implement data exchange MSC between USB Host and board. Use board as VCP (Virtual COM Port), user can regard board as a VCP USB-to-COM module USB OTG application examples DRD DevKit1207 board can be used as either USB Host or USB Device USB Host application examples Dual-USB channel testing example, use HS-USB as MSC (Mass Storage DualCore Device) host and FS-USB as HID (Human Interaction Device) host. Use board as HID HID (Human Interaction Device) host and can recognize USB mouse and USB keyboard. Use board as MSC (Mass Storage Device) and can recognize U disk and MSC other mobile storage devices.  Application example for Ethernet on FreeRTOS/Non-OS/LWIP v1.3.2 protocol stack (see Table 1-3 below) Table 1-3 Application example for Ethernet on FreeRTOS and LWIP v1.3.2 protocol stack httpserver_netconn Webserver application example based on netconn httpserver_socket Webserver application example based on socket udptcp_echo_server_netcon TCP/UDP Echo application example based on netconn 的 n TCP/UDP Application example for Ethernet on Non-OS and LWIP v1.3.2 protocol stack httpserver Webserver application example tcp_echo_client Simple Echo application example of Tcp client tcp_echo_server Simple Echo application example of Tcp server tftpserver Tftpserver application example udp_echo_client Simple Echo application example of dup client udp_echo_server Simple Echo application example of server  Application example for OS porting on UCOSII_v2.86 and UCGUI_v3.90a 9 Function Demonstrations GUI3.90A Function Demonstration (see Figure 1-1) Figure 1-1 2-channel USB Host Function Demonstration (see Figure 1-2) Figure 1-2 10 Httpserver Network Function Demonstration 1) Input http://192.168.0.163 in browser and you can visit the webpage on DevKit1207. Figure 1-3 Click “LED control” to get into LED control interface, select or cancel LED1, LED2, LED3, LED4 and press “Send”, the LEDs on board will work relatively. 2) Figure 1-4 11 3) Click “ADCstatus bar” to get the voltage of potentiometer on board. Figure 1-5 Application cases (Remote Control System Solution) 12 Order Information Order No. T6010169 Item DevKit1207 Evaluation Kit Deliveries  One DevKit1207 Evaluation board  One 3.5 inch LCD with Touch screen  One 5V Power adapter  One cross serial cable (DB9 to DB9)  One cross net cable  One USB cable (Type A Male to Type Mini-B Male)  One USB cable (Type A Female to Type Mini-A Male)  One Product CD (including user manual, schematic in PDF format, datasheet, uC/OS-II BSP, FreeRTOS source tree, software examples) Option  Price Please contact us. CAM1207 Digital Camera Module More information about this product can be found at: http://www.embedinfo.com/english/Product/devkit1207.asp http://www.armkits.com/Product/devkit1207.asp Embest Technology Co., LTD. Room 509, Luohu Science&Technology Building, #85 Taining Rd., Shenzhen, Guangdong, China 518020 Tel: +86-755-25635656/25636285 Fax: +86-755-25616057 Email: market@embedinfo.com http://www.embedinfo.com/english http://www.armkits.com 13
DEVKIT1207 价格&库存
很抱歉,暂时无法提供与“DEVKIT1207”相匹配的价格&库存,您可以联系我们找货
