COLINKEX
COLINKEX
    IMBEST(英蓓特)
COLINKEX 数据手册
10/09/2012 Free and open ARM Cortex MCU SW/JTAG debugging adapter ᳈ᤶ䇁㿔˖ English Home › CoLinkEx Home Cookie CoLinkEx CoLinkEx Guide CoIDE CooCox CoLinkEx is a hardware debugging adapter which supports SW debugging and supports CoOS ARM Cortex M devices, it supports debugging in CooCox software and Keil Realview MDK. Colink / CoLinkEx CooCox CoLinkEx is open, you can Do It Yourself or Buy from Newark.Element14. CoFlash CoSmart Note: If you want to use CoLinkEx with CoIDE 1.4.0(or higher), CoFlash 1.4.0(or higher), CoMDKPlugin 1.4.0(or higher), you need to upgrade the firm ware and install CoLinkEx Driv er CoAssistant 1.2.0 or 1.2.1 at first. Hardware DIY Use in C oIDE Software Plugin for MDK How to use How to use C oLinkEx_LPC 1114 kit CoX Features: Components CoLinkEx Updates Free Supports Cortex M devices Supports SW debugging Forum C oLinkEx plugin for MDK V1.4.2 C oLinkEx firmware and driver updated Supports JTAG debugging Supports CoFlash, CoIDE, MDK and IAR Contact us Supported Devices: Follow CooCox JTAG debugging Atmel CooCox Market NXP AT91SAM3U4E AT91SAM3U2E AT91SAM3U1E Tech Support ST TI AT91SAM3U4C AT91SAM3U2C AT91SAM3U1C SW debugging Atmel Energy Micro AT91SAM3U4E AT91SAM3U2E AT91SAM3U1E Holtek NXP Nuvoton ST AT91SAM3U4C AT91SAM3U2C AT91SAM3U1C Downloads: Before you use CooCox CoLinkEx, you need to update CoLinkEx firmware and install CoLinkEx Driver first. CoLinkEx Firmware | How to update Choose ColinkExUsbDriver Vesion Version 1.2.0 Version 1.2.1 windows XP (32bit WHQL) windows 7 (32bit WHQL) windows 7 (64bit) windows vista (32bit) windows vista (64bit) Download Note C olinkExUsbDriver Version 1.2.0 C olinkExUsbDriver Version 1.2.1 If you're using the 32 bit windows system, please use this version. This version doesn't have WHQL, please connect C oLinkEx to the computer before you start installing this driver. You can modify the "C olinkEx.inf" file to make it support 64 bit system.Do like this : C olinkex driver on Win7 / 64 CoLinkEx support is available in: Keil RealView MDK 4.03 or higher (not include 4.13a) IAR Embedded Workbench 5.xx or higher CooCox CoFlash CooCox CoIDE CoLinkEx Software: CoLinkEx Plugin for Keil RealView MDK CoLinkEx Plugin for IAR Embedded Workbench www.coocox.org/Colinkex.htm 1/2
COLINKEX
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为Anode、Cathode、Gate、Collector、Emitter和Base。
4. 参数特性:工作电压范围为3V-15V,隔离电压为2500Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装。
COLINKEX 价格&库存
很抱歉,暂时无法提供与“COLINKEX”相匹配的价格&库存,您可以联系我们找货
