1410F110P1F1W14QE4 1A
    ETA(钰泰半导体)
    ETA - 1410F110P1F1W14QE4 1A - Thermal Circuit Breaker, 1410, 1 A, 1 Pole, 48 VDC, 240 VAC, Panel
1410F110P1F1W14QE4 1A 数据手册
Thermal Overcurrent Circuit Breaker 1410-F1... Description Miniaturised single pole rocker switch/thermal circuit breaker combining ON/OFF switching and extremely fast overload performance in a single component (S-type TO CBE to EN 60934/IEC 934). Under overload conditions an internal neon (filament bulb for low voltages) illuminates to give a clear signal of the tripped status of the mechanism and thereby the cause of power interruption, suffix -B. Alternatively the illumination can be conventionally wired to indicate the ON status of the device, suffix -E. Returning the rocker switch through the OFF position and back ON will reset the mechanism and restore the supply. Largely temperature-insensitive. Complies with CBE standard EN 60934 (IEC 60934). 1 Typical applications 1410-F1.. Motors, transformers, solenoids, PCBs, hand-held machines, appliances, instrumentation. Ordering information Technical data Type No. 1410 snap-in panel mounting type Mounting F snap-in panel mounting Size of frame 1 to fit mounting cut-out 28 x 12.7 mm (1.1 x .5 in) Number of poles 1 single pole, thermally protected Accessories 0 without accessories Terminal design P1 blade terminals 2.8-0.8 (QC .110/2x.110)silver-plated Characteristic curve F1 fast acting Actuator style W rocker, rounded profile Actuator colour 14 red translucent Actuator markings Q I and O Trip/ON illumination (optional) B illuminated when tripped E illuminated when ON Illumination voltage range (optional) 2 20-28V marked 24V 35mA 3 90-140V marked 115V
1410F110P1F1W14QE4 1A 价格&库存
很抱歉,暂时无法提供与“1410F110P1F1W14QE4 1A”相匹配的价格&库存,您可以联系我们找货
