1658-G21-02-P10-15A
1658-G21-02-P10-15A
    ETA(钰泰半导体)
1658-G21-02-P10-15A 数据手册
Thermal Overcurrent Circuit Breaker 1658-... Description Very cost effective design to meet international requirements. No exposed metal parts which are, or could become, current-carrying except for terminals. R-type TO CBE to EN 60934.  Manual reset, cycling trip free mechanism  Extremely small and lightweight  UL, CSA, VDE and EN 60934 (IEC 60934) approved 1 Typical applications Battery chargers, consumer products, power supplies, motors. 1658-... Ordering information Technical data Type No. 1658 single pole thermal circuit breaker Threadneck design G21 manual reset type, 3/8"-27 threadneck G41 manual reset type, 7/16"-28 threadneck A21 auto reset type, 3/8"-27 threadneck A41 auto reset type, 7/16"-28 threadneck A00 auto reset type, without threadneck F01 snap in Hardware 00 no hardware 01 one PAL nut, bulk 02 one PAL nut, one knurled nut, bulk 03 one PAL nut mounted 04 one PAL nut, one knurled nut, mounted 05 one PAL nut mounted, one knurled nut, bulk 06 one knurled nut, bulk 07 one hex nut, bulk 08 two hex nuts, bulk Terminals P10 blade terminals A6.3-0.8 (QC .250) P13 blade terminals A6.3-0.8 (QC .250), 90° S80 straight screw terminals* S83 90° bent screw terminals* Current ratings 5 ...30 A 1658 - G21 - 02 - P10 - 5 A For further details please Voltage rating Current ratings Typical life AC + DC 5...16 A 17...25 A Ambient temperature Insulation co-ordination (IEC 60664 and 60664 A) test voltage AC 3,000 V > 100 MΩ (DC 500 V) 5...7 A 180 A 8...30 A 200 A Interrupting capacity IN UN (UL 1077/EN 60934 PC1) 5...16 A AC 240 V 2,000 A 18...30 A AC 120 V 2,000 A 5...30 A DC 28 V 2,000 A Degree of protection operating area IP40 (IEC 60529/DIN 40050) terminal area IP00 Vibration 8 g (57-500 Hz) ±0.61 mm (10-57 Hz), to IEC 60068-2-6, test Fc, 10 frequency cycles/axis Shock 30 g (11 ms) to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to IEC 60068-2-78, test Cab Mass approx. 16 g Ordering example Approvals Standard current ratings and typical voltage drop values 05/06(280405) Voltage drop (mV) ≤ 150 ≤ 150 ≤ 150 ≤ 150 ≤ 150 ≤ 140 Current rating (A) 12 15 16 20 25 30 1,000 operations at 2 x IN, inductive 1,000 operations at 2 x IN, resistive -20...+60 °C (-4...+140 °F), ≤ 7 A max. +40 °C (+104 °F) rated impulse pollution withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength (IEC 60664 and 60664A) operating area Insulation resistance Interrupting capacity Icn * Screws and lock washers bulk shipped Current rating (A) 5 6 7 8 9 10 see chapter: Technical Information AC 240 V; DC 28 V 5...30 A Voltage drop (mV)) ≤ 140 ≤ 240 ≤ 240 ≤ 240 ≤ 240 ≤ 240 Authority VDE (EN 60934) UL www.e-t-a.com Voltage rating AC 240 V; DC 28 V AC 240 V AC 120 V AC 120 V DC 28 V Current ratings 5...25 A 5...16 A 1658-G... 20...30 A 1658-G... 5...30 A 1658-A... 5...30 A 1658-G... Thermal Overcurrent Circuit Breaker 1658-... Terminal design P10 1 1 2 27 1.06 8.5 .335 blade terminals DIN 46244-A6.3-0.8 (QC .250) 2 12 .472 1 2 12 .472 0.7 .028 12.7 .500 6 .236 0.5 .020 1 S83 3 .118 ø6 .236 ON OFF Dimensions P13 terminal screw 6-32 UNC lock washer P10-S83 3 .118 17.5 .689 1 2 1 8.5 .335 13.6 .535 14 .551 15.7 .618 lock washer terminal screw 6-32 UNC blade terminals DIN 46244-A6.3-0.8 (QC .250) angled 90° 32 1.26 2 blade terminals DIN 46244-A6.3-0.8 (QC .250) S80 A00 A21 tightening torque max. 0.8 Nm 3/8-27UNS-2A mounting hole terminal screw 6-32 UNC 8.9 -0.1 .350 -.004 9.6 -0.1 .378 -.004 G21 2 12 .472 1 tightening torque max. 0.8 Nm 3/8-27UNS-2A lock washer Installation drawing 4 .157 7 .276 operating area 1 34 1.34 mounting hole 10.2 ±0.1 .402 ±.004 10 .394 A41 2 5 .197 5 .197 4 .157 4 .157 7/16-28UNS-2A double “D” tightening torque max. 0.8 Nm G41 11.2 ±0.1 .441 ±.004 mounting area 10 .394 ø6 .236 Caution: Please keep a tight grip on the unit while removing the female connectors. mounting hole 16 ±0.15 .630 ±.006 12.7 .500 ON 6 .236 1 .039 OFF F01 +0.1 - 0.2 +.004 .543 - .008 13.8 thickness 1- 3 mm .039 - .118 in. See ordering information for mounting hardware. This is a metric design and millimeter dimensions take precedence ( mm ) inch www.e-t-a.com 05/06(280405) Thermal Overcurrent Circuit Breaker 1658-... Internal connection diagram Accessories Mounting nut 3/8", 27-thread Y306 671 01 1 14.3 .563 0.5 .020 Mounting nut 7/16", 28-thread Y303 200 01 2.5 .098 16 .630 0.5 .020 3 .118 1 2 10000 +60 °C +140 °F +23 °C +73.4 °F -20 °C -4 °F 1000 Trip time in seconds 7/16-28UNEF-2B 3/8-27UNS-2B Typical time/current characteristics Knurled nut 3/8", 27-thread plastic (standard) Y307 117 02 Knurled nut 7/16", 28-thread nickel-plated brass Y302 294 03 ø15 .591 3 .118 ø16 .630 3.2 .126 100 7/16-28UNEF-2B 3/8-27UNS-2B Knurled nut 3/8", 27-thread nickel-plated brass Y300 190 03 10 ø13 .512 1 2.5 .098 0.1 2 4 6 8 10 … times rated current 20 40 3/8-27UNS-2B The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section 9 – Technical information. Ambient temperature °F -4 +14 +32 +73.4 +104 +122 +140 °C -20 -10 0 +23 +40 +50 +60 Derating factor IN > 7A 0.83 0.85 0.9 1 1.1 1.18 1.25 0.74 0.76 0.82 1 1.23 IN ≤ 7A Hex nut 3/8", 27-thread nickel-plated brass Y300 192 01 3/8-27UNS-2B Hex nut 7/16", 28-thread nickel-plated brass Y302 295 01 2.5 .098 7/16-28UNEF-2B SW14 .551 Press to Reset Plate for 3/8" thread, aluminium Y 301 059 02 ø21.4 .843 SE E-T - T T E- T - www.e-t-a.com BR E A R E 05/06(280405) A 0.4 .016 KE TO RE SS E SS PR PR This is a metric design and millimeter dimensions take precedence ( mm ) inch ø24 .945 ® R KE BREA ø9.9 .390 Press to Reset Plate for 7/16" thread, aluminium Y 302 732 01 0.4 .016 A ® 2.5 .098 SW14 .551 SE 1 E TO R ø11.2+0.7 .441+.028 Thermal Overcurrent Circuit Breaker 1658-... Accessories Reset button seal for 3/8", 27-thread, short long X201 285 01 X200 799 01 1 3/8-27 UNS-2B 3/8-27 UNS-2B Reset button seal for 7/16", 28-thread, short long X222 119 01 X222 119 02 7/16-28 UNS-2B 7/16-28 UNS-2B This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. www.e-t-a.com 05/06(280405)
1658-G21-02-P10-15A 价格&库存
很抱歉,暂时无法提供与“1658-G21-02-P10-15A”相匹配的价格&库存,您可以联系我们找货
1658-G21-02-P10-15A
  • 1+56.69293
  • 50+55.12044
  • 100+53.52713
  • 250+51.78802
库存:56
