1180-01-4A
1180-01-4A
    ETA(钰泰半导体)
1180-01-4A 数据手册
Thermal Automotive Circuit Breaker 1180-... Description Miniaturised single pole thermal circuit breaker with switching function optional (push-push actuation). Reliable snap-acting and trip-free mechanism. Approved to CBE standard EN/IEC 60934. S type, TO. Blade terminals fitting into sockets for rail mounting. 1 Typical applications Protection of loads in power distribution systems in control cabinets and process control. 1180-... Ordering information Technical data Type No. 1180 single pole thermal circuit breaker, plug-in mounting Versions 01 with switching function, without label 02 reset function only, without label Current rating range 0,1...10 A Voltage rating Current ratings Typical life Ambient temperature Insulation co-ordination (IEC 60664 and 60664 A) 1180 - 01 - 1 A ordering example Standard current ratings and typical internal resistance values Current rating (A) 0.1 0.2 0.25 0.3 0.4 0.5 0.6 0.7 0.8 1 1.5 Internal resistance (Ω) 81 22 14 8.7 5.5 3.4 2.5 1.7 1.5 0.9 0.4 Current rating (A) 2 2.5 3 3.5 4 5 6 7 8 10 Internal resistance (Ω) 0.25 0.18 0.11 0.08 0.07 ≤ 0.05 ≤ 0.05 ≤ 0.05 ≤ 0.05 ≤ 0.05 Dielectric strength (IEC 60664 and 60664A) operating area installation area Insulation resistance Interrupting capacity Icn Interrupting capacity (UL 1077) Degree of protection (IEC 60529/DIN 40050) Vibration without terminal block AC 250 V; DC 65 V 0.1...10 A 6,000 operations at 1 x IN (low-inductance) 3,000 operations at 1 x IN (inductive) 500 operations at 2 x IN (inductive) -20...+60 °C (T 60) -4...+140 °F rated impulse pollution withstand voltage degree 2.5 kV 2 reinforced insulation in operating area test voltage AC 3,000 V AC 1,500 V > 100 MΩ (DC 500 V) 0.1...5 A 6 x IN 6...10 A 8 x IN AC 250 V: 2,000 A DC 65 V: 200 A operating area IP40 terminal area IP00 5 g (57-500 Hz) ±0.38mm (10-57 Hz) to IEC 60068-2-6, test Fc, 10 frequency cycles/axis and to EN 50155 Shock without terminal block Corrosion Humidity Mass 25 g (11 ms) to IEC 60068-2-27, test Ea 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka 240 hours at 95 % RH to IEC 60068-2-3, test Ca approx. 15 g Approvals Authority VDE UL UL, Canada Issue G Voltage rating AC 250 V; DC 65 V AC 250 V; DC 65 V AC 250 V; DC 65 V ☎ Current ratings 0.1...10 A 0.1...10 A 0.1...10 A Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 55 Thermal Automotive Circuit Breaker 1180-... Typical time/current characteristics at +23°C7+73.4°F Dimensions 24.4 .961 10000 0.1 - 5 A 6 - 10 A 48.6 ON 1.91 48.8 1.92 52.3 OFF 2.06 1 2.3° 6.4 8.2 .252 .323 1.5 .059 8.6 .339 1.1 .043 Trip time in seconds 1000 100 5.2 .205 14.5 .571 16.6 .654 18.2 .717 19,8 .780 1.9 .075 10 3.1 .122 0.6 .024 1 3.6 .142 0.1 1 8.2 .323 slot for fitting labels (see accessory 1) Internal connection diagram 1 2 4 6 8 10 … times rated current 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section 9 – Technical information. Ambient temperature °F -22 -4 +14 +32 +73.4 +104 +122 +140 °C -30 -20 -10 0 +23 +40 +50 +60 Derating factor 0.8 0.76 0.84 0.92 1 1.08 1.16 1.24 Note: When several devices are mounted together, each device should only carry 80 % of its rating or it must be overrated accordingly. 2 Shock directions 3 2 4 1 6 5 current rating This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 56 ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com Issue G Thermal Automotive Circuit Breaker 1180-... Accessories - Terminal block with screw terminals Dimensions X 222 233 02 14.5 4 1 42.7 1.68 36.4 1.43 33.8 1.33 1 8 .315 64.3 2.53 LED 5 6 Vibration with terminal block X 222 233 01 and X 222 233 02 5 g (57-500 Hz), ± 0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc, 10 frequency cycles/axis and EN 50155 Shock with terminal block X 222 233 01 and X 222 233 02 25 g (11 ms) to IEC 60068-2-27, test Ea 2 3 1 Label for circuit breaker 1180, surface for marking 4.5x5 mm (packaging quantity 120 pcs) Y 307 374 01 2 Terminal block for DIN rail mounting, with screw terminals up to 6 mm2 conductor, width 8.2 mm, dimensions 64x42.5x8.2 mm, headroom over the upper rail edge with circuit breaker fitted (OFF position) 84 mm. Approvals: UL 300 V/ 30 A / AWG 26-8 X 222 233 01 3 Terminal block for DIN rail mounting see item 2, but with LED DC24V (lighted after tripping); current rating LED 2 mA X 222 233 02 4 Bus connection for potential bridging of several terminal blocks see item 2 and 3 (10pole, separable, mounting hardware included), max. current rating 34 A X 222 232 01 5 Insulation barriers for insertion between two circuits (packaging quantity 10 pcs) Y 307 373 01 6 Label for terminal block, see item 2 and 3, surface for marking 4.5 x 5 mm (packaging quantity 120 pcs) Y 307 375 01 Issue G ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 57 Thermal Automotive Circuit Breaker 1180-... Accessories - Terminal block with spring-loaded terminals 1 Dimensions X 222 316 01 9 42.2 1.66 1 86.5 3.41 8.2 .323 13 7 8 Vibration with terminal blocks X 222 316 01 and X 222 315 02 vibration axis 3-4: 3 g (57-500 Hz), ± 0.38 mm (10-57 Hz) other axes: 5 g (57-500 Hz), ± 0.38 mm (10-57 Hz) to IEC 60068-2-6, test Fc, 10 frequency cycles/axis and EN 50155 Shock with terminal blocks X 222 316 01 and X 222 315 02 25 g (11 ms) to IEC 60068-2-27, test Ea 11 12 1 Label for circuit breaker 1180, surface for marking 4.5x5 mm (packaging quantity 120 pcs) Y 307 374 01 7 Terminal block for DIN rail mounting, with spring-loaded terminals up to 4 mm2 conductor, width 8.2 mm, dimensions 68.5x36.5x8.2 mm, headroom over the upper rail edge with circuit breaker fitted (OFF position) 82 mm. UL approval pending. X 222 316 01 8 Terminal block for DIN rail mounting see item 7, but with LED DC24V (lighted after tripping); current rating LED 2 mA X 222 315 02 9 Jumper 2pole, max. current rating 32 A for terminal blocks items 7 and 8 and feed supply terminal item 11. X 222 318 01 10 Jumper 3pole, max. current rating 32 A for terminal blocks items 7 and 8 and feed supply terminal item 11. X 222 318 02 11 Feed supply terminal with spring-loaded terminals up to 6 mm2 conductor, width 8.2 mm, suitable for use with jumpers items 9 and 10 (power distribution). X 222 317 01 12 Cover for feed supply terminal item 11 for closing the open side at the end of an assembly. Y 307 507 01 13 Label for terminal block items 7 and 8, and feed supply terminal item 11, surface for marking 7.5 x 5 mm (packaging quantity 50 pcs) Y 307 508 01 58 ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com Issue G
1180-01-4A 价格&库存
很抱歉,暂时无法提供与“1180-01-4A”相匹配的价格&库存,您可以联系我们找货
1180-01-4A
    • 1+117.88464
    • 50+114.46890
    • 100+111.93834
    • 200+110.29295
    库存:21
    1180-01-4A
      库存:21
