EM12D-TIO-000-DC24V-40A
    ETA(钰泰半导体)
    ETA - EM12D-TIO-000-DC24V-40A - Circuit Breaker Accessory, REX12D Electronic Circuit Protector, Supp...
EM12D-TIO-000-DC24V-40A 数据手册
REX12D Electronic Circuit Protector Description The compact and flexible all-in-one solution REX consists of several perfectly matched components. It comprises the EM12D-T / EM12-T supply module for the plus and minus potential via a single or double channel REX12D-T electronic circuit protector which can be mounted side by side in any number and the PM12-T potential extension module for plus and minus multiplication. The requirements regarding modern machinery and equipment are constantly growing. System transparency, remote maintenance and remote access are getting more and more important in international competition. Early notification in the event of any disturbances and a fast response to current problems will increase system availability, save costs and improve the overall stability of the production process. E-T-A provides the ideal solution for machine and panel builders with the intelligent protection system comprising the REX12D circuit protector and the EM12D interface module. The system combines the well-proven quality of DC24V overcurrent protection with the communication options of the IO link system. It allows complete transparency of the DC24V power supply and provides all necessary information for a reliable production process in this plant sector. The new generation of REX12D electronic overcurrent protection consists of the intelligent EM12-TIO supply module and the single or double channel REX12D-Telectronic circuit protector which allows modular side-by-side mounting. The modules with a width of only 12.5 mm feature push-in technology including press release buttons and allow time-saving and maintenance-free wiring without tools. Benefits l l l l l Increases machine availability through high transparency and remote diagnosis Saves cost – no further accessories required S  aves 50 % time through innovative and flexible mounting and connection technology S  aves space – with a width of only 12.5 mm per channel Provides flexibility through ease of mounting, disassembly and modular design And what is more: no additional accessories are required when connecting the individual components electrically and mechanically. This helps save time and money! Features l l l l l l l l l l Control, diagnosis and monitoring via IO link Combination of supply modules, overcurrent protection and power distribution Double channel selective load protection by means of electronic trip curve No accessories required for connecting the components Width per channel only 6.25 mm (2-channel) Fixed current ratings: 1 A, 2 A, 3 A, 4 A, 6 A, 8 A and 10 A Integral fail-safe element, adjusted to current rating Switching capacitive loads up to 20,000 µF Manual ON/OFF/reset momentary switch Connection via push-in terminals including press release buttons Approval logos and markings Data sheet The current data sheet is available on our website: www.e-t-a.de/d751 NEC Class2 7 1802 www.e-t-a.de 1 REX12D Electronic Circuit Protector Technical data (Tamb = +23 °C, UB = DC 24 V) REX12D-TAx-xxx circuit protectors REX12D-TA1-100-DC24V-xA 1-channel REX12D-TA2-100-DC24V-xA/xA 2-channel Operating voltage UB DC 24 V (18...30 V) Closed current I0 REX12D-TA1 1-channel in ON condition: typically 7 mA REX12D-TA2 2-channal in ON condition: typically 10 mA Reverse polarity protection yes Power failure buffering time up to 10 ms Current ratings IN fixed ratings: REX12D-TA1 8 A, 10 A REX12D-TA2 1 A/1 A, 2 A/2 A, 3 A/3 A, 4 A/4 A, 6 A/6 A Visual status indication green: - load circuit connected of operating condition by multicoloured green/orange LED: blinking: - load current warning limit reached 50 % – 100 % orange: - overload or short circuit until disconnection - circuit protector was switched off by the superordinate control unit LED is permanently orange red: Load circuit Load output Load current – warning limit (IWLimit) hysteresis Overload current disconnection (IOL) with trip times (tOL) short circuit trip time (tSC)  - after disconnection due to overload or short circuit - after undervoltage release of operating voltage in ON condition with autoreset OFF: Device was switched off via ON/ OFF momentary switch, or due to lacking operating voltage or faulty initialisation of the circuit protector power MOSFET switching output (plus switching) typically 0.5 – 1.0 x IN (parameterisable) typically 5 % typically IOL: IN x 1.05 tOL: 3s typically IOL: IN x 1.35 tOL: 0.5,5s typically IOL: IN x 2.00 tOL: 0.1s typically IOL: IN x 2.50 tOL: 0.012 s typically at short circuit (ISC) tSC: 0.002 s1) see time/current characteristic 1) depending on the power source  ote: Selection of current rating of the circuit protector N ≤ rating of power supply Influence of ambient see temperature factor table temperature on overload disconnection and load current – warning limit Continuous Current IC typically 0.8 x IN (Fail Safe Element is protected by REX12) 7 Fail-safe element IN: (integral IN: blade fuse IN: adjusted to IN: related current rating IN) IN: IN: IN: IN: IN: 1 A/1 A 2 A/2 A 3 A/3 A 3A/3A-CL2 4 A/4 A 4A/4A-CL2 6 A/6 A 8 A 10 A fail-safe IN: 1 A / 1 A fail-safe IN: 2 A / 2 A fail-safe IN: 3.15 A / 3.15 A fail-safe IN: 4 A / 4 A fail-safe IN: 4 A / 4 A fail-safe IN: 4 A / 4 A fail-safe IN: 6.3 A / 6.3 A fail-safe IN: 8 A fail-safe IN: 10 A Technical data (Tamb = +23 °C, UB = DC 24 V) Voltage drop in load circuit at IN and at IN 70 % LINE+ and LOAD+ typically 180 mV IN: 70 % typically 125 mV IN: 1 A typically 110 mV IN: 70 % typically 80 mV IN: 2 A typically 120 mV IN: 70 % typically 85 mV IN: 3 A typically 130 mV IN: 70 % typically 90 mV IN: 3A-CL2 typically 115 mV IN: 70 % typically 80 mV IN: 4 A typically 180 mV IN: 70 % typically 120 mV IN: 4A-CL2 typically 170 mV IN: 70 % typically 110 mV IN: 6 A typically 160 mV IN: 70 % typically 105 mV IN: 8 A typically 180 mV IN: 70 % typically 120 mV IN: 10 A Operating voltage OFF at typically UB < 16.0 V monitoring ON at typically UB > 19 V hysteresis typically 2 V with regard to low voltage with automatic ON and OFF switching Switch-on delay - with power ON channel 1: channel 2: typically 100 ms typically 200 ms - when switching on via channel 1: ON/OFF momentary switch or channel 2: typically 5 ms - after undervoltage typically 5 ms typically 5 ms channel 1: channel 2: typically 100 ms Disconnection of load circuit - manually on the device with the ON/OFF momentary switch - remote control via the superordinate control unit - after an overload / short circuit disconnection with storage (no automatic reset) - temporarily at undervoltage - at no operating voltage Switch on of load circuit - momentary switch ON/OFF The circuit protector can be switched on by the superordinate control unit or otherwise directly on the device. These two options are linked with AND. Switchon is only possible if switched on from both positions. If the circuit protector was switched off either by the control unit or by the momentary switch directly on the device, switch-on has to be effected also from the corresponding position. - Apply For switch-on the device has to be supplied operating voltage with operating voltage. The device restarts with the last stored condition. Reset function  A blocked load output (blocked by overload / short circuit) can be reset by the ON/OFF momentary switch or by the superordinate control unit. Leakage current in load circuit in OFF condition typically
EM12D-TIO-000-DC24V-40A 价格&库存
很抱歉,暂时无法提供与“EM12D-TIO-000-DC24V-40A”相匹配的价格&库存,您可以联系我们找货
  • 1+1166.89127
库存:1
