4130-G211-K4M1 50A
4130-G211-K4M1 50A
    ETA(钰泰半导体)
    ETA - 4130-G211-K4M1 50A - Thermal Circuit Breaker, 4130, 50 A, 1 Pole, 50 VDC, 240 VAC, Panel
4130-G211-K4M1 50A 数据手册
High Performance Thermal Circuit Breaker 4130-... Description Single pole high performance thermal circuit breaker, with push-toreset tease free, trip-free snap action mechanism (R-type TO CBE to EN 60934). Designed for threadneck panel mounting and for applications with a high fault current switching requirement. Approved to CBE standard EN 60934 (IEC 60934). 1 Typical applications Motors, transformers, solenoids, battery chargers, power supplies, appliances, machinery, extra low voltage systems. 4130-... Ordering information Technical data Type No. 4130 single pole thermal circuit breaker Mounting G threadneck panel mounting Threadneck design 2 M 12x1, knurled nut (bulk shipped) 4 M 12x1, hex nut and knurled nut (bulk shipped) Number of poles 1 single pole, thermally protected Actuator configuration 1 black push button Terminal design K4 terminal M6x8 screw and washer bulk shipped Characteristic curve M1 medium delay Current ratings 20... 70 A 4130 - G 2 1 1 - K4 M1 - 20 A Voltage rating Current rating range Typical life Ambient temperature Insulation co-ordination (IEC 60664) (reinforced insulation in the mounting area) Dielectric strength operating area Insulation resistance Interrupting capacity Icn Interrupting capacity (UL 1077) ordering example Degree of protection (IEC 60529/DIN 40050) Vibration Standard current ratings and typical internal resistance values Current rating (A) 20 25 30 35 Internal resistance (Ω) < 0.02 < 0.02 < 0.02 < 0.02 Current rating (A) 40 50 60 70 Internal resistance (Ω) < 0.01 < 0.01 < 0.01 < 0.01 AC 240 V; DC 50 V 20... 70 A 300 operations at 2 x IN (DC 50 V) 500 operations at 2 x IN (DC 28 V) -30...+60 °C (-22...+140 °F) rated impulse pollution withstand voltage degree 2.5 kV 2 Shock Corrosion Humidity Mass test voltage AC 3,000 V > 100 MΩ (DC 500 V) 800 A IN UN 20...70 A AC 240 V 1,000 A 20...60 A AC 120 V 3,500 A 70 A AC 120 V 2,000 A 20...50 A DC 50 V 3,500 A 60...70 A DC 50 V 2,000 A operating area IP40 terminal area IP00 8 g (57-500 Hz) ±0.61 mm (10-57 Hz) to IEC 60068-2-6, test Fc 10 frequency cycles/axis 25 g (11 ms) to IEC 60068-27, test Ea 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka 240 hours at 95 % RH to IEC 60068-2-3, test Ca approx. 55 g Approvals Authority VDE (EN 60934) UL Issue G Voltage ratings AC 240 V; DC 50 V AC 240 V; DC 50 V ☎ Current ratings 20...70 A 20...70 A Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 101 High Performance Thermal Circuit Breaker 4130-... Typical time/current characteristics ON ø6.6 .260 23 °C -30 °C 0.6±0.2 .024±.008 Trip time in seconds 10.3 .406 1000 LINE 64 2.52 50 1.97 1 60 °C 10000 tightening torque max. 1.5 Nm M12x1 black 23.8±0.5 .937±.020 17.2±0.5 .677±.020 OFF Dimensions I 10 2 13.5 .531 22.3 .878 screw M6x8 with washer tightening torque max. 2.5 Nm 1 0,1 11.5 -0.1 .453 -.004 32 1.26 12 .472 17 .669 0,8 1 mounting hole 18 .709 D-shaped threadneck 12.2 -0.1 .480 -.004 max. 3.5 max .138 100 3 4 5 6 8 10 ... times rated current 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section 9 – Technical information. Ambient temperature °F -22 -4 +14 +32 +73.4 +104 +122 +140 °C -30 -20 -10 0 +23 +40 +50 +60 Derating factor 0.68 0.76 0.84 0.92 1 1.08 1.16 1.24 Hex nut with splash cover, black X 201 296 01 without O ring (IP64) X 200 801 03 with O ring (IP66) Hex nut with splash cover, transparent X 200 801 08 with O ring (IP66) LINE 5 .197 operating area Water splash cover, transparent with knurled nut and O ring (IP64) X 210 663 01 M12x1 M12x1 2 Separate hardware Hex nut Y 300 116 02 30 1.18 20 Accessories Intstallation drawing I 2 6 .236 Knurled nut Y 302 065 01 mounting area M12x1 Internal connection diagram SW14 .551 M12x1 2.5 .098 ø17 .669 3.2 .126 0.5 x 45° .020 x 45° line 1 This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 102 ☎ All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com Issue G
4130-G211-K4M1 50A 价格&库存
很抱歉,暂时无法提供与“4130-G211-K4M1 50A”相匹配的价格&库存,您可以联系我们找货
