1610-21-15A.
1610-21-15A.
    ETA(钰泰半导体)
    ETA - 1610-21-15A. - Thermal Circuit Breaker, 1610, 15 A, 1 Pole, 28 VDC, Auto Fuse Holder
1610-21-15A. 数据手册
Thermal Automotive Circuit Breaker 1610-... Description Miniaturised single pole press-to-reset thermal circuit breaker designed for automotive fuse block installation. Extends the benefits of circuit breaker performance and convenience to applications which are cost critical. Manual release option. 1 Typical applications Extra low voltage wiring systems on all types of vehicles and marine craft. Type No. 1610 single pole automotive circuit breaker Voltage rating 22 DC 12 V H1 DC 12 V, with manual release facility 21 DC 24 V H2 DC 24 V, with manual release facility Current ratings 6 8 10 15 20 25 A 21 - 8 A Voltage rating Current ratings Service short-circuit breaking capacity Ambient temperature Degree of protection (IEC 529/DIN 40050) Ultimate short-circuit breaking capacity ordering example Please enquire for packaging quantities. Current ratings, typical voltage drop values and actuator colours Current rating (A) Voltage drop (mV) 1610-22 1610-H1 Technical data Ordering information 1610 - 1610-21 Actuator colour (manual release) 6 < 200 mossy-green 8 < 200 honey (approximating RAL 1005) 10 < 200 red (approximating RAL 3020) 15 < 200 blue (approximating RAL 5012) 20 < 200 yellow (approximating RAL 1018) 25 < 200 pearl (approximating RAL 1013) Vibration (with mounting socket) (approximating RAL 6005) Shock (with mounting socket) Corrosion Humidity Mass 1610-22/1610-H1: DC 12 V 1610-21/1610-H2: DC 24 V 6...25 A 1610-22/1610-H1: 500 operations at ≤ 50 A 1610-21/1610-H2: 300 operations at ≤ 50 A -30...+60 °C operating area IP 30 terminal area IP 00 1610-22/1610-H1:: ≥ 3 break operations at 200 A, or ≥ 1 break operation at 2,000 A 1610-21/1610-H2: ≥ 3 break operations at 150 A, or ≥ 1 break operation at 2,000 A 5 g (57-500 Hz),±0.38 mm (10-57 Hz) to IEC 68-2-6, Test Fc 10 frequency cycles/axis 25 g (ll ms) to IEC 68-2-27, Test Ea 96 hours at 5 % salt mist, to IEC 68-2-11, Test Ka 240 hours at 95 % RH, to IEC 68-2-3, Test Ca approx. 5 g N.B. It is good practice to switch off the vehicle's ignition system before resetting the circuit breaker. Free travel of the actuator must be ensured. Issue E ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 57 Thermal Automotive Circuit Breaker 1610-... Dimensions 1610-22 1610-H1 20.3 6 2.7 3.4 3 Please leave space for button travel 6 4 4 Please leave space for button travel 3.4 0.8 ON 20.3 4 OFF 7.3 29.5 6.4 6.4 7.5 7.5 24 24 1 5.2 0.6 5.2 14.5 16.6 0.6 3.3 14.5 3.3 3.9 16.6 3.9 18.8 18.8 1610-21 1610-H2 6 0.7 5 29.5 0.6 5.2 14.5 16.6 5.2 0.6 3.3 14.5 3.3 3.9 16.6 3.9 18.8 18.8 58 7.5 6.4 6.4 7.5 28.8 4.5 24 28.8 24 2.7 0.8 ON 20.3 4 OFF 0.8 ON 3.8 OFF 20.3 9.8 6 ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com Issue E Internal connection diagram 1 1 2 Typical time/current characteristic curve 10000 +60°C +23°C -30°C Trip time in seconds 1000 100 10 1 0.1 1 2 4 6 8 10 … times rated current 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below.See also section 9 - Technical information. Ambient temperature °C -20 -10 0 +23 +40 +50 +60 Multiplication factor 0.76 0.84 0.92 1 1.08 1.16 1.24 Issue E ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 59 Thermal Automotive Circuit Breaker 1610-... Accessories Ordering information Mounting socket 12 Socket 12-P10 30.3 25.4 Weidmüller style label (not supplied) 3.5 1 43 47 blade terminal DIN 46244-A6.3-0.8 Type No. 12 Mounting socket Terminal design P10 blade terminals A 6.3-0.8 J20 screw terminals 6-32 UNC A10 1 blade terminal A6.3-0.8 / 1 screw terminal 6-32 UNC Version ... blank: single socket 20 two-way 30 three-way 40 four-way 60 six-way 58 12 - P10 - 20 ordering example ø3.9 12.7 symmetrical hat rail EN 50022-35x7.5 48.4 Accessories for mounting socket 12 Socket 12-J20 30.3 25.4 Weidmüller style label (not supplied) terminal screw 6-32 UNC 3.5 100 quick-connect tabs 6.3 DIN 46247 tinned brass, insulated 58 symmetrical hat rail EN 50022-35x7.5 ø3.9 12.7 ~70 47 43 spring washer Connector bus links -P10 X 210 588 01/1.5 mm2 (brown), up to 13 A max. load X 210 588 02/2.5 mm2 (black), up to 20 A max. load X 210 588 03/2.5 mm2 (red), up to 20 A max. load X 210 588 04/2.5 mm2 (blue), up to 20 A max. load Socket 12-A10 30.3 terminal screw 6-32 UNC 25.4 Weidmüller style label (not supplied) Bus bar X 210 588 02 (up to 100 A max. load) X 211 157 01 with terminal X 211 157 02 without terminal Phoenix terminal AKG 35 max.cross section 35 mm2 cylinder head screw ISO1207-M4x4 nickel plated 3.5 43 47 blade terminal DIN 46244-A6.3-0.8 washer A 4.3 DIN 125 nickel plated 2 48.4 Cu rail, tin-plated 58 symmetrical hat rail EN 50022-35x7.5 spring washer 7 12.8 fusible link (1.1 thick constriction) ø3.9 12.7 154.8 10 M4 48.4 Dimensions for surface mounting 60 7 13 ø4 48.4 Other sockets available to special order Labels: Weidmüller, D-33102 Paderborn 60 ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com Issue E
1610-21-15A. 价格&库存
很抱歉,暂时无法提供与“1610-21-15A.”相匹配的价格&库存,您可以联系我们找货
