Thermal Overcurrent Circuit Breaker 1110-...
Description
Single pole switch/thermal circuit breaker (S-type TO CBE to EN 60934)
with tease-free, trip-free, snap action mechanism. Designed for snapin panel mounting utilising round hole or industry standard fuseholder cut-out dimensions. Featuring an ergonomically styled two
colour actuator with indicator band clearly showing the tripped/OFF
position.
Approved to CBE standard EN 60934 (IEC 60934).
1
Typical applications
Motors, transformers, solenoids, extra low voltage systems,
household and office machines, instrumentation, marine
applications, mobile homes.
1110-F1..
Ordering information
Technical data
Type No.
1110
snap in panel mounting
Mounting
F1 panel thickness 0.8...1.6 mm (.031 -.063 in)
F2 panel thickness 1.8...3 mm (.071-.118 in)
Number of poles
1 1 pole protected
Actuator style
2
black push button/white indicator ring, standard
Other indicator ring colours are available to special order
Terminal design
P1 blade terminals A6.3-0.8 (QC .250)
Characteristic curve
M1 medium delay
Current ratings
0.05...16A
1110 - F1 1 2 - P1 M1 - 0.05 A = ordering example
Standard current ratings and typical internal resistance values
Current
rating (A)
0.05
0.08
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.8
1
1.2
1.5
1.8
Internal
resistance (Ω)
442
173
110
27.8
12.4
7.0
4.5
3.1
2.3
1.7
1.1
0.71
0.41
0.38
Current
rating (A)
2
2.5
3
3.5
4
5
6
7
8
10
12
15
16
Internal
resistance (Ω)
0.25
0.19
0.12
0.09
0.07
0.05
0.04
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
≤ 0.02
For further details please see chapter: Technical Information
Voltage rating
AC 250 V; DC 28 V
(UL: AC 250 V; DC 50 V)
Current rating
0.05...16 A
Typical life
AC + DC
0.05...10 A 10,000 operations at 1 x IN, inductive
12...16 A 6,000 operations at 1 x IN, inductive
Ambient temperature
-20...+60 °C (-4...+140 °F)
Insulation co-ordination
rated impulse
pollution
(IEC 60664 and 60664 A) withstand voltage
degree
2.5 kV
2
reinforced insulation in operating area
Dielectric strength
(IEC 60664 and 60664A) test voltage
operating area
AC 3,000 V
Insulation resistance
> 100 MΩ (DC 500 V)
Interrupting capacity Icn
AC 250 V:
0.05...16 A
8 x IN
DC 28 V:
0.05...6 A
10 x IN
7...10 A
200 A
12...16 A
300 A
IN
UN
(UL 1077/EN60934 PC 1) 0.05...6 A
AC 250 V
1,000 A
7...16 A
AC 125 V
1,000 A
0.05...16 A DC 50 V
1,000 A
Degree of protection
operating area IP40
(IEC 60529/DIN 40050)
terminal area IP00
Vibration
8 g (57-500 Hz)±0.61 mm (10-57 Hz),
to IEC 60068-2-6, test Fc,
10 frequency cycles/axis
Shock
30 g (11 ms)
to IEC 60068-2-27, test Ea
Corrosion
96 hours at 5 % salt mist,
to IEC 60068-2-11, test Ka
Humidity
240 hours at 95 % RH
to IEC 60068-2-3, test Ca
Mass
approx. 12 g
Approvals
Authority
BV
UL
CSA
VDE
05/06(280405)
Voltage ratings
AC 250 V; DC 28 V
AC 250 V
AC 125 V
DC 50 V
AC 250 V; DC 50 V
AC 250 V
Current ratings
0.05...16 A
0.05...6 A
7...16 A
0.05...16 A
0.05...16 A
0.05...10 A
www.e-t-a.com
Dimensions
Internal connection diagram
1
1110-F1.. / -F2..
When installing the circuit breaker apply pressure on bezel only.
19
.748
10
.394
black
white
2.4
.094
15
.591
9.5
.374
ON
OFF
1
19
.748
10
.394
2
51
2.01
47.5
1.85
Typical time/current characteristics at +23°C/+73.4°F
10000
12.5
.492
9
.354
0.05 - 6 A
7 - 16 A
12.1
13.2
.476
15.6
1000
.61
blade terminals DIN 46244-A6.3-0.8
(QC .250)
Panel cut out
1110-F1..-P.M1-...A
1110-F2..-P.M1-...A
Trip time in seconds
.520
100
+0.2
- 0.4
+.008
- .016
.531 ±.004
±0.05
±.002
13.5
±0.1
±0.1
13.5
.531 ±.004
10
+0.2
- 0.4
+.008
- .016
±0.05
±.002
installation
side
16 ±0.15
.630 ±.006
0.8 … 1.6
.031 … .063
insertion force ≤ 20 N, removal force ≥ 120 N
1
installation
side
16 ±0.15
.630 ±.006
1.8 … 3
.071 … .118
insertion force ≤ 40 N, removal force ≥ 120 N
Installation drawing
operating area
0.1
6 8 10
2
4
… times rated current
0.6 0.8 1
The time/current characteristic curve depends on the ambient temperature
prevailing. In order to eliminate nuisance tripping, please multiply the circuit
breaker current ratings by the derating factor shown below. See also
section 9 – Technical information.
Ambient temperature °F
-4
+14 +32 +73.4 +104 +122 +140
°C
-20 -10 0
+23 +40 +50 +60
Derating factors
0.76 0.84 0.92 1
1.08 1.16 1.24
Accessories - Water splash covers (transparent)
Push button splash cover
transparent
Y 304 745 01 (IP64)
Terminal shroud
Y 305 602 01 (IP64)
ø14.5
.571
25
.984
When using
splash cover
please note
that the max.
panel thickness
is reduced by
0.5 mm/0.02 in.
14
.551
60
2.36
25
.984
17.8
3
.118
mounting area
.701
3
.118
1.25
.049
20.5
.807
ø4
.157
This is a metric design and millimeter dimensions take precedence ( mm )
inch
www.e-t-a.com
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved.Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
05/06(280405)
很抱歉,暂时无法提供与“1110-F112-P1M1-2A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+175.50440
- 50+172.04701
- 100+170.78693
- 200+168.39175
