3120-F521-H7T1-W01X-5A
    ETA(钰泰半导体)
    ETA - 3120-F521-H7T1-W01X-5A - Thermal Circuit Breaker, 5 A, 2 Pole, 50 VDC, 250 VAC, Panel
3120-F521-H7T1-W01X-5A 数据手册
Thermal Circuit Breaker 3120-F... Description The 3120 circuit breaker/switch combination is an ON/OFF switch with integral overcurrent protection (S-type TO CBE to EN/IEC 60934). The trip element is a bimetal. Type 3120 is ideally suited for overload protection of motors, pumps, transformers and cables. The 3120 circuit breaker is also available as a switch-only version in accordance with the IEC/EN 61058 (see data sheet switch 3120-F-..Q1). Product characteristics: l rocker or push button actuation l single pole and double pole versions l reliable switching behaviour (positively trip-free) l convenient snap-in mounting l international approvals ced by Will be repla nd of 2020! 3120-N by e Options and add-on modules: illumination l water splash protection l auxiliary contacts l under voltage trip l remote trip l magnetic trip l push-in terminals l appliance inlet module 1 l Technical data For further details please see: www.e-t-a.de/ti_e Medical and laboratory equipment, apparatus and machine construction, professional tools, household and garden appliances, offices machines, audio equipment, machine tools Current ratings and internal resistance values Current rating (A) Internal resistance per pole (Ω) Current rating (A) Internal resistance per pole (Ω) 0.1 94 4 0.0435 0.2 24 4.5 0.0435 0.3 12 5 0.0325 0.4 5.30 6 0.0215 0.5 4.20 7 0.0165 0.6 2.90 8 0.0165 0.8 1.50 10 < 0.02 1 0.9 12 < 0.02 1.2 0.80 14 < 0.02 1.5 0.45 15 < 0.02 2 0.27 16 < 0.02 2.5 0.0785 18 < 0.02 3 0.0595 20 < 0.02 3.5 0.0565 Current consumption of illumination Current rating range 0.1...20 A (up to 30A upon request for single pole units) operations operations operations operations at at at at 1 1 1 1 x x x x IN, IN, IN, IN, inductive inductive resistive inductive AC 240 V: 0.1...16 A 50,000 operations 17...20 A 30,000 operations DC 50 V: 0.1...16 A 50,000 operations 17...20 A 10,000 operations Ambient temperature -30 … 60 °C at at at at 1 1 1 1 x x x x IN, IN, IN, IN, inductive inductive inductive inductive AC 240 V: 0.1...20 A DC 50 V: 0.1...4 A 4.5...16 A DC 28 V: 0.1...20 A Typical life 2-pole Insulation coordination (IEC 60664) Dielectric strength Y R G 5.2 mA 2 mA 1.4 mA DC 24 V 4.5 mA 2.2 mA 1.6 mA DC 48 V 4.5 mA 2 mA 1.6 mA AC 115 V 2.8 mA 1.1 mA 1 mA AC 230 V 2.2 mA 0.9 mA 0.9 mA 2.5 kV /2 reinforced insulation at operating area test voltage AC 3,000 V test voltage AC 1,500 V > 100 MΩ (DC 500 V) 0.1...2 A 10 x IN 2.5...20 A 1-pole 150 A 2-pole 250 A Interrupting capacity (UL 1077) IN UN 1-pole, 2- pole 0.1...20 A AC 250 V 5000 A, C, 1 1-pole, 2- pole 0.1...20 A DC 50 V 1000 A, C, 1 Degree of protection (IEC 60529) Vibration Corrosion Current consumption 30,000 30,000 30,000 30,000 Operating area pole to pole (2-pole) Insulation resistance Interrupting capacity Icn Shock DC 12 V 2051 AC 240 V, DC 50 V Typical life 1-pole Typical applications Operating voltage Rated voltage Humidity Mass www.e-t-a.de Inc operating area IP40 terminal area IP00 with water splash cover IP54 or IP66 8 g (57-500 Hz), ± 0.61 mm (10-57 Hz) test to IEC 60068-2-6, test Fc 10 frequency cycles/axis 30 g (11 ms) test to IEC 60068-2-27, test Ea 96 hours at 5 % salt mist, test to IEC 60068-2-11, test Ka 240 hrs in 95 % RH test to IEC 60068-2-78, test Cab approx. 33 g (2-pole) approx. 27 g (1-pole) approx. 42 g (2-pole with PT terminals) 1 Thermal Circuit Breaker 3120-F... Order numbering code 1 Order numbering code Type No. 3120 thermal rocker-actuated circuit breaker Mounting method F flange mounting snap-in frame Size of frame 3 standard, to fit mounting cut-out 50.5 x 21.5 mm 5 standard, to fit mounting cut-out 44.5 x 22 mm 7 special style, to fit mounting cut-out 44.5 x 22 mm Number of poles 1 1-pole, thermally protected 2 2-pole, thermally protected 5 2-pole, 1-pole thermally protected Mounting frame design (F3 & F5) 1 collar height 1 mm 3 collar height 9 mm 4 collar height 2 mm with water splash protection (IP54) Mounting frame design (F7) R black T black with snap-on water splash cover Terminal configuration PT push-in terminals P7 blade terminals H7 as P7, terminals 11 and 21 with flat head screws M3.5 - standard for units with undervoltage release module N7 as P7, with additional shunt terminals 12(i) and 22(i) G7 as N7, terminals 11 and 21 with flat head screws M3.5 Characteristic curve T1 thermal trip Actuator style W rocker for frame size F3 & F5 A rocker for frame size F7 Colour and illumination 01. rocker black opaque 02. rocker white opaque 04. rocker red opaque 14. R rocker red translucent with LED illumination 15. Y rocker orange translucent with LED illumination 19. G rocker green translucent with LED illumination Marking for rocker style W A D Q: 0 and 1 F moulded in Q X A D F X Marking for rocker style A Q »I« and »O« moulded in Illumination voltage range (= operating voltage) 1 DC 12 V 2 DC 24 V 3 AC 115 V 4 AC 230 V 5 DC 48 V 3120 -F 7 2 R - P7 T1 -A 14 QR 4 Current ratings 0.1...20 A 0 I ON 0 OFF I 3120 -F 7 2 R - P7 T1 -A 14 QR 4 - 10 A 2 Type No. 3120 thermal circuit breaker with push button actuation Mounting F flange mounting snap-in frame Size 2 special frame for fitting splash cover 3 mounting cut-out 50.5 x 21.5 mm (panel thickness 1-6.35 mm) Number of poles 1 1-pole, thermally protected 2 2-pole, thermally protected 5 2-pole, 1-pole thermally protected Style F frame with 2 push buttons G frame with one push button (reset only) Terminal configuration PT push-in terminals P7 blade terminals H7 as P7, terminals 11 and 21 with flat head screws M3.5 - standard for units with undervoltage release module N7 as P7, with additional shunt terminals 12(i) and 22(i) G7 as N7, terminals 11 and 21 with flat head screws M3.5 Characteristic curve T1 thermal trip Actuators / colour / illumination D01X 1 push button* black opaque D02X 1 push button* white opaque D04X 1 push button* red opaque D19XG 1 push button* green translucent with LED illumination SGRX 2 push buttons green/red opaque without illumination SGRXG 2 push buttons green/red translucent with LED illumination Illumination voltage range (= operating voltage) 1 DC 12 V 2 DC 24 V 3 AC 115 V 4 AC 230 V 5 DC 48 V Current ratings 0.1...20 A 3120- F 3 2 F - P7 T1- S GRXG 4-10 A ordering example *reset only Please be informed that we have minimum ordering quantities to be observed. Note Important: 3120-F series is replaced by 3120-N Please refer to E-T-A homepage for further details: https://global.e-t-a.com/news/news_from_e_t_a/thermal_ circuit_breaker_3120_n_all_in_one_solution/ ordering example www.e-t-a.de 2051 Thermal Circuit Breaker 3120-F... Preferred types preferred ratings (A) 0.5 1 1.5 2 3 4 5 6 8 10 12 15 16 20 3120-F72R-P7T1A14QR4preferred type F3 1-pole protected x x x x x x x x x x x x x x x x x x x 10000 x x x x x x x x x x x x x 0.5 1 2 3 4 5 6 8 10 12 15 16 20 3120-F521-P7T1W01D- x x x x x x x x x x x 1 100 10 x 1 Standard VDE IEC/EN 60934 AC 240 V DC 50 V DC 50 V DC 28 V AC 250 V UL 1077 DC 50 V AC 250 V CSA C22.2 No 235 CQC GB 17701 Rated voltage AC 250 V DC 50 V AC 250 V AC 240 V DC 50 V Current rating range 0.1 0.1 A…20 A 0.1...20A (2-pole) 0.1...4 A (1-pole) 0.1 A…20 A 0,1 A…20 A 0,1 A…20 A 30 A (2 poles in parallel) 0,1 A…20 A 0,1 A…20 A 30 A (2 poles in parallel) 0.1 A…20 A 0.1 A…20 A 1 line 21 4 6 8 10 … times rated current 20 40 10000 +60 °C +140 °F +23 °C +73.4 °F -30 °C -22 °F 1000 Schematic diagrams 2-pole, thermally protected on both poles 2 2.5…20 A Trip time in seconds Approval authority 11 -30 °C -22 °F 1000 Approvals UL +60 °C +140 °F +23 °C +73.4 °F x 0.5 1 2 3 4 5 6 8 10 12 15 16 20 3120-F321-P7T1W01Dpreferred type F5 2-pole protected x 0.5 1 2 3 4 5 6 8 10 12 15 16 20 3120-F311-P7T1W02Dpreferred type F3 2-pole protected x single or double pole load 0.1…2 A Trip time in seconds preferred type F7 2-pole protected Time/current characteristics 100 10 2-pole, thermally protected on one pole only 11 line 1 21 0.1 12(i) 12(k) load 22(i) 12(i) 22(k) 12(k) 1-pole, thermally protected 11 1 22(i) load 2 4 6 8 10 … times rated current 20 40 The time/current characteristic depends on the ambient temperature. In order to eliminate nuisance tripping, please multiply the current rating by a derating factor (see chapter Technical Information) line 12(i) 22(i) ambient temperature [°C] -30 -20 -10 0 23 40 50 Temperature factor 0.8 0.84 0.88 0.92 1 1.08 1.14 60 1.23 12(k) load 2051 www.e-t-a.de 3 Thermal Circuit Breaker 3120-F... Dimensions 3120-F2.F-… 3120-F2.F-PT... 12.65 12.65 5.5 water splash cover (see accessories) retaining clip 10.7 panel cover 16.1 10.2 3.5 10.2 10 hole for screw ø 4 mm e.g.: EJOT PT 14.1 screw K40 9 60±0.1 14 74 16.2 4.5 PT-screw type K40 ø4 mm 10.7 49 33 ø3.2 12(i) 12(k) ø 3.2 12(i) 11 12(k) 11 10 15 1 35.4 3 3.5 21 21 15.5 42.5 41 blade terminal EN 60934 – 6.3 x 0.8 flat head screw M3.5x6 tightening torque max. 0.8 Nm 3120-F3.1-PT 25 OFF position 5.5 25 16 7 12.65 12.65 10.7 3120-F3.1 16 54 48 33 35 9 54 12(k) 12(i) 11 12(k) 11 10 12(i) 3.5 10.7 3 21 15.5 21 42.5 41 blade terminal EN 60934 – 6.3 x 0.8 flat head screw M3.5x6 tightening torque max. 0.8 Nm 3120-F 3.4 with water splash protection (IP54) 54 27 35 19.5 3.8 12(i) 12(k) 11 11 10.7 3 3.5 21 blade terminal EN 60934 – 6.3 x 0.8 10.7 3.5 21 15.5 41 blade terminal EN 60934 – 6.3 x 0.8 flat head screw M3.5x6 tightening torque max. 0.8 Nm 4 10 10 12(i) 12(k) 56 35 33 10 25 19.5 33 35 9 3120-F 3.3 collar height 9 mm 3 15.5 41 flat head screw M3.5x6 tightening torque max. 0.8 Nm www.e-t-a.de 2051 Thermal Circuit Breaker 3120-F... Dimensions 3120-F3.G-...-D... 3120-F3.F-…-S… optional illumination in ON position OFF position OFF position 54 25 54 25 16.2 16.2 14.2 1 33 33 10 15 14.2 10 15 optional illumination in ON position 11 12(i) 12(k) 11 10 12(k) 10 12(i) 10.7 3.5 21 10.7 3 41 blade terminal EN 60934 – 6.3 x 0.8 3 15.5 41 blade terminal EN 60934 – 6.3 x 0.8 flat head screw M3.5x6 tightening torque max. 0.8 Nm flat head screw M3.5x6 tightening torque max. 0.8 Nm 3120-F 5.1 12.65 12.65 5.5 10.7 3120-F5.1-PT 25 optional illumination 16 25 48 16 48 48 33 35 9 7 3.5 21 15.5 10 12(i) 10.,7 3.5 21 12(k) 11 3 15.5 42.5 21 41 blade terminal EN 60934 – 6.3 x 0.8 flat head screw M3.5x6 tightening torque max. 0.8 Nm 3120-F5.4 3120-F5.3 25 48 19.5 35 35 33 33 11 2 11 2 25 48 19.5 12(i) 10.7 3 3.5 21 10.7 15.5 11 3 15.5 41 blade terminal EN 60934 – 6.3 x 0.8 flat head screw M3.5x6 tightening torque max. 0.8 Nm blade terminal EN 60934 – 6.3 x 0.8 flat head screw M3.5x6 tightening torque max. 0.8 Nm 2051 3.5 21 41 12(k) www.e-t-a.de 5 - 0.4 -.016 - 0.2 -.008 min. 2.5 min .098 1-6.35 .039-.250 Thermal Circuit Breaker 3120-F... 50.5+0.3 1.99+.012 max. R0.3 Cut-out dimensions max .012 60±0.15 2.36+.006 50.5+0.5 1.99+.020 26+0.2 1.02+.008 LINE 11 12(k) Edges of working parts: ISO 13715 10 .394 12(i) t: metal min. 2 mm (.079 in.) plastic min. 3 mm (.118 in.) R2 .079 ø4.3+0.2 3 .118 48±0.2 1.89±.008 44.2-0.2 1.74-.008 33 1.30 8.9 .350 25 .984 15.5 .610 t 3120-F2… Style F7.R 1 max.R2 max .079 .169+.008 Dimensions ±0.05 ±.002 21.5+0.2 .846+.008 3120-F3… 3 .118 15.5 .610 Cut-out for mounting style -F3 with rocker and push button 41 1.61 blade terminals EN60934 - 6,3 x 0,8 - 0.4 -.016 - 0.2 -.008 21.5+0.2 0.42 10.7 3120-F7.R-PT max. R2 max .079 ±0.05 ±.002 50.5+0.3 1.99+.012 - 0.2 -.008 min. 2.5 min .098 max. R0.3 max .012 .846+.008 1-6.35 .039-.250 flat head screw M3.5x6 tightening torque max. 0.8 Nm Cut-out for mounting style -F5/-F7 - 0.4 with rocker -.016 min. 2 min .079 max. R1.5 max .059 ±0.05 ±.002 44.5+0.2 1.75+.008 max. R0.3 max .012 22+0.3 3.5 .138 .866+.012 10.7 .421 1-4 mm .039-.157 in. 21 .827 Edges of working parts: ISO 13715 12.65 12.65 25 .984 15.5 .610 0.49 5.5 0.49 0.22 Cable cross sections PT terminals cable cross section with direct push-in wiring rigid 1…4 mm2 (stripping length: 10 mm) flexible with wire end ferrule (with or without plastic sleeve) 0.5…2.5 mm2 cable cross section when opening the push-in terminals rigid 0.5…4 mm2 (stripping length: 10 mm) flexible without wire end ferrule 0.5…2.5 mm2 48 1,89 9.4 0.37 48 1.89 12(i) 12(k) 11 21 42.5 .827 1.67 Style F7.T 34 1.34 18.6 .732 33 1.30 11.5 .453 60 2.36 44.8 1.76 LINE 11 12(k) 10 .394 12(i) 21 .827 10.7 .421 3.5 .138 blade terminals EN60934 - 6,3 x 0,8 flat head screw M3.5x6 tightening torque max. 0.8 Nm 6 15.5 .610 3 .118 41 1.61 www.e-t-a.de 2051 Thermal Circuit Breaker 3120-F... Installation drawing Terminal types 3120-F521-G7 3120 with blade terminals 3120-F551-G7 When installing the circuit breaker apply pressure on bezel only. operating area 15.5 10 7 8 7 1 7 10 mounting area 3120 with push-in terminals 3120-F521-N7 3120-F551-N7 3120-F521-H7 3120-F551-H7 3120-F521-P7 3120-F551-P7 When installing the circuit breaker apply pressure on bezel only. 25 30.5 operating area 7 8 7 7 10 mounting area 2051 www.e-t-a.de 7 Thermal Circuit Breaker 3120-F... Accessories Insulated cover Y 303 068 01 Rear terminal shroud black (IP64) Y 304 275 01 40.5 1.59 +0.5 1.75 -0.25 .069 +.020 -.010 20.5 .807 70+5 50 1.97 2.76+.197 1 10 .394 20 .787 0.9 .035 9 .354 2.5 .098 R3 4 .5 . .157 138 3.7 .146 Terminal adapter Y 303 862 01 ø8 .315 13.5 .531 4 .157 Water splash cover, transparent (IP66) for mounting style -F2.. X 221 619 01 48 1.89 25 .984 blade terminal DIN 46244-C-Ms-S (QC 2x.110) 16.5 .650 25 .984 16.5 .650 ø4.4 .173 35 1.38 matt finish 3.4 .134 54 2.13 31 1.22 ø8 .315 33 1.30 36 1.42 1 .039 Blanking piece in -F3 frame Y 303 885 31 41 1.61 60 2.36 73 2.87 21 .827 Mounting of X221 619 01 All dimensions without tolerances are for reference only. E-T-A reserves the right change specifications at any time in the interest of improved design, performance and cost effectiveness, the right to make changes in these specifications without notice is reserved. Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 8 www.e-t-a.de 2051 Thermal Circuit Breaker 3120-F... Accessories Plug-in connector Y 31214001 Connecting cables can be pre-wired. Two retaining clips ensure a tight fit. 1 12 24 4,5 5,5 42 21,2 Benefits: • Reduced installation time and costs for final assembly • Quick replacement of devices Note: Delivery without receptacles. Dimensions of receptacles (width 6.3 mm) are in accordance with DIN 46340 part 3, shape A. Examples of suitable receptacles: Stocko RSB 7916 F6,3-1 / Klaucke type 2730 / Vogt type 3832d.67 / TE FASTON Terminals 250 Series / Delphi Packard 58 Series 24 33 Plug-in connector mounted on circuit breaker: 42 2051 21,2 www.e-t-a.de 9 Thermal Circuit Breaker 3120-F... Description - Appliance inlet module X3120-A/-B The appliance inlet module X3120 with circuit breaker type 3120-F5/ -F7/-F8 combines up to four functions within a single component: A C14/C20 appliance inlet, a rocker-actuated or push button switch and resettable overcurrent protection and a filter. Screw-type mounting from the front or from the rear. Typical applications 1 Electrical medical apparatus, laboratory equipment, professional audio equipment and office machines. X3120-A Approvals X3120-A – C14 inlet Authority Standard ENEC IEC/EN 60320-1 Voltage ratings AC 240 V Max. current 10 A UL/CSA UL 498 AC 250 V 15 A CQC CCC AC 250 V 10 A X3120-B Order numbering code Current rating circuit breaker Minimum current rating of the filter 0,1...1 A 1A 1,2...3 A 3A 3,5...6 A 6A 7...8A 8A Type No. X3120 Appliance inlet module for circuit breaker type 3120 Module A appliance inlet C14 (with filter) B appliance inlet C20 (without filter) Mounting 04 screw-type mounting Filter 00 without filter 01 general performance IEC inlet filter 03 general performance IEC inlet filter, medical version 06 high performance IEC inlet filter, medical version Filter rating (for module A only) 00 without filter 01 1 A 03 3 A 06 6 A 08 8 A 10 10 A 12 12 A 15 15 A Version 01 not wired; mounting position 3120: OFF position to connector 11 wired; mounting position 3120: OFF position to connector Assembly status M module supplied with circuit breaker 3120 and filter (module A) fitted 9...10 A 10 A X3120- A 04 01 08 01 M 12 A 12 A 14...15 A 15 A Approvals X3120-A – filter Design coresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 X3120-B – C20 inlet Authority Standard ENEC IEC/EN 60320-1 Voltage ratings AC 240 V Max. current 16 A UL/CSA AC 240 V 20 A UL 498 Selection current rating of the filter ordering example Circuit breaker type 3120 with thermal release protects the filter in case of overloads. For the protection of the filter in the event of higher overcurrents we recommend circuit breaker type 3120 with thermal-magnetic release (3120...M1...). Further technical information upon request. All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved. Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 10 www.e-t-a.de 2051 Thermal Circuit Breaker 3120-F... Technical Data (type X3120-B, without filter) Technical Data (type X3120-A with filter) Rated voltage AC 240 V Rated voltage AC 250 V Current rating (inlet) Ambient temperature 16 A (IEC) 20 A (UL/CSA) -25°C ...+60°C Current rating (inlet) Number of poles L, N + earth Current rating (filter) Ambient temperature 10 A (IEC) 15 A (UL/CSA) 1 A, 3 A, 6 A, 8 A, 10 A, 12 A, 15 A -25°C ...+60°C Protection class: I Number of poles screw-type mounting (front or rear) blade terminals DIN 46244 6.3 mm x 0.8 mm thermoplastics, black UL94V-0 Protection class: I Mounting method: C20 according to IEC/EN 60320-1, UL498 Circuit breaker 3120-F5/-F7/-F8 (3120-F8 with push button actuation: technical data upon request) Housing material: screw-type mounting (front or rear) blade terminals DIN 46244 6.3 mm x 0.8 mm thermoplastics, black UL94V-0 Connection: Housing material: Appliance inlet: Mains switch: Connection: Appliance inlet: Mains switch: C14 according to IEC/EN 60320-1, UL498 Circuit breaker 3120-F5/-F7/-F8 (3120-F8 with push button actuation: technical data upon request) Dimensions (type X3120-A) Dimensions (type X3120-B) 5.5 40 11.8 0.21 1.57 .465 80 3.15 91.5 3.60 90 3.54 100 3.9 circuit breaker 3120 37 1 26 Ø 3.3 Ø .130 47 1.0 1.85 1.457 Ø 3.3 36.2 Ø .130 49.3 1.43 1.94 Cut-out dimensions (type X3120-A) Cut-out dimensions (type X3120-B) R3.0 (4x) .12 (4x) 72.0 2.834 32.5 0.137 Ø3.3 Ø0.129 Ø 3.6 (2x) Ø .14 (2x) 79.5 3.129 29.0 1.141 Mounting method: L, N + earth 80.0 90 3.15 3.543 2051 www.e-t-a.de 11 Thermal Circuit Breaker 3120-F... Electrical schematics X3120-A X3120-A0401 General performance filter Cx 2xL 2xCy N' 11 N 12 (K) PE PE P 1 3120 22 (K) Line P' 21 Load X3120-A0403 und X3120-A0406 High-performance filters for medical version Cx R N N' 11 PE PE P 2xL Line P' 21 Load 12 (K) 3120 22 (K) X3120-A0401 and X3120-A0403 - General performance filter Typical filter attenuation: Per CISPR 17 A = 50 Ω / 50 Ω sym; B = 50 Ω / 50 Ω asym; C = 0.1 Ω / 100 Ω sym; D = 100 Ω / 0.1 Ω sym 1 and 3 A types 6 to 10 A types 12 and 15 A types X3120-A0406 - High performance filter Typical filter attenuation: Per CISPR 17 A = 50 Ω / 50 Ω sym; B = 50 Ω / 50 Ω asym; C = 0.1 Ω / 100 Ω sym; D = 100 Ω / 0.1 Ω sym 1 and 3 A types 12 6 to 10 A types www.e-t-a.de 12 and 15 A types 2051 Thermal Circuit Breaker 3120-F... Filter selection table Filter X3120-A040101..M Rated current 50°C (25°C) Leakage current 250VAC/50 Hz A µA Inductance L Capacitance Cx Capacitance Cy Resistance R mH µF nF kΩ 1 (1.2) 373 12 0.1 2.2 X3120-A040103..M 3 (3.5) 373 2.5 0.1 2.2 X3120-A040106..M 6 (7.2) 373 0.78 0.1 2.2 X3120-A040108..M 8 (10.6) 373 0.5 0.1 2.2 X3120-A040110..M 10 (11.6) 373 0.225 0.1 2.2 X3120-A040112..M 12 (12) 373 0.11 0.1 2.2 X3120-A040115..M 15 (15) 373 0.075 0.1 2.2 X3120-A040301..M 1 (1.2) 2 12 0.1 1000 X3120-A040303..M 3 (3.5) 2 2.5 0.1 1000 X3120-A040306..M 6 (7.2) 2 0.78 0.1 1000 X3120-A040308..M 8 (10.6) 2 0.5 0.1 1000 X3120-A040310..M 10 (11.6) 2 0.225 0.1 1000 X3120-A040312..M 12 (12) 2 0.11 0.1 1000 X3120-A040315..M 15 (15) 2 0.075 0.1 1000 X3120-A040601..M 1 (1.2) 2 59.53 0.1 1000 X3120-A040603..M 3 (3.5) 2 13.45 0.1 1000 X3120-A040606..M 6 (7.2) 2 4.1 0.1 1000 X3120-A040608..M 8 (10.6) 2 2.3 0.1 1000 X3120-A040610..M 10 (11.6) 2 1.02 0.1 1000 X3120-A040612..M 12 (12) 2 0.58 0.1 1000 X3120-A040615..M 15 (15) 2 0.4 0.1 1000 2051 www.e-t-a.de 1 13 Thermal Circuit Breaker 3120-F... Description undervoltage release module X3120-U Dimensions Add-on module for circuit breaker type 3120. The undervoltage release module trips the 3120 circuit breaker/switch combination in the event of a voltage drop or power failure. When the voltage is restored, the 3120 must be reset to reconnect the load, thereby avoiding the safety hazards associated with automatic re-start of machinery. Note: Basic unit 3120-...-H7 or -G7 requires screw terminals. Not possible in combination with PT terminals. 41 +0.1 - 0.2 1.61+.004 - .008 33.5 1.32 All machines and devices where automatic re-start after restoration of power could be dangerous, e.g. drilling machines, electric saws, sausage slicers etc. 15 ° 7.6 .299 Typical applications 1 flat head screw M3.5x6 for mains connection tightening torque max. 0.8 Nm 6.6 .260 21 .827 22 .866 23.5 .925 Order numbering code Type No. X3120 module for type 3120 Module U undervoltage release module Design 00 standard (without separate connections) 01 1 blade terminals 2.8x0.8 02 2 blade terminals 2.8x0.8 Rated voltage 00 AC 230/240 V 50/60 Hz 01 AC 120 V 50/60 Hz Assembly status M module mounted to circuit breaker 3120 21 .827 blade terminal DIN 46244-A2.8-0.8 (QC .110) 1 terminal X3120-U01… Without separate terminal(s): X3120-U00… Schematic diagrams X3120-U00… line 21 11 X3120-U01… line 11 load line line 11 A1 A2 21 22(i) 12(i) 22(k) 12(k) load U< 12(k) line 21 U< U< 12(i) X3120- U 00 00 M ordering example A2 X3120-U02… 22(i) 12(i) 22(k) 12(k) 22(i) load 22(k) Technical data Voltage ratings AC 100 V; 120 V; 230/240 V (50/60 Hz); DC 24 V Voltage tolerances + 10 % / - 15 % Typical life 20,000 cycles Current consumption approx. 2.5 mA Release values 0.2 x UN < U < 0.7 x UN (at a rated voltage of AC 100 V the device can trip at 70 V and must trip at 20 V) Release delay < 20 ms Latch-in values ≥ 85 % UN Ambient temperature -30 … 60 °C Vibration 8 g (57-500 Hz), ± 0.61 mm (10-57 Hz) test to IEC 60068-2-6, test Fc 10 frequency cycles/axis Shock 30 g (11 ms) test to IEC 60068-2-27, test Ea Corrosion 48 hours at 5 % salt mist, test to IEC 60068-2-11, test Ka Humidity 240 hrs in 95 % RH test to IEC 60068-2-78, test Cab Mass approx. 53 g (including base unit) All dimensions without tolerances are for reference only. E-T-A reserves the right change specifications at any time in the interest of improved design, performance and cost effectiveness, the right to make changes in these specifications without notice is reserved. Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 14 www.e-t-a.de 2051 Thermal Circuit Breaker 3120-F... Description auxiliary contact module X3120-S Dimensions 25.5 1.00 Add-on module for circuit breaker type 3120-F. The auxiliary contact module has a change-over contact as signal contact and is operated with actuation of the CBE. Not possible in combination with PT terminals. Typical applications Status monitoring of CBE and/or the connected loads. 10 .394 21 .827 8.5 .335 7.5 7.5 .295 .295 Dimensional drawings of the standard version of 3120-N please see page 6-8 (QC .110), silver-plated A 10 V - 250 V 0.1...4 A 5 ...100 B 5 V - 250 V mA DC voltage rated voltage 12 V 24 V 60 V 110 V 220 V 5 V - 250 V 2 .079 19.8 .780 Schematic diagram line rated current 0.1...4 A 0.1...4 A 0.1...1 A 0.1...0.5 A 0.1...0.25 A 5...100 mA Assembly status M module mounted to circuit breaker 3120 X3120- S 0 1 A M 1 blade terminals 2.8x0.5 plated Order numbering code Type No. X3120 module for types 3120 and 3140 Module S auxiliary contact module Contact configuration 0 change-over contact Terminal design 1 blade terminals 2.8 x 0.5 Contact rating AC voltage rated voltage rated current 14 .551 11 21 34 32 module mounted 12(i) 12(k) 22(i) load 31 22(k) Technical data ordering example * without approval mark Rated voltage AC 250 V, DC 220 V Current ratings 0.1...4 A / 5...100 mA Typical life 50,000 cycles Ambient temperature -30…60 °C Dielectric strength between main and auxiliary circuit test voltage AC 3,000 V Insulation resistance > 100 MOhm (DC 500 V) Vibration 6g (57-500 Hz), ± 0.46 mm (10-57 Hz) test to IEC 60068-2-6, test Fc 10 frequency cycles/axis Shock 15 g (11 ms) test to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, test to IEC 60068-2-11, test Ka Humidity 240 hrs in 95 % RH test to IEC 60068-2-78, test Cab Mass approx. 38 g (including base unit) All dimensions without tolerances are for reference only. E-T-A reserves the right change specifications at any time in the interest of improved design, performance and cost effectiveness, the right to make changes in these specifications without notice is reserved. Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2051 www.e-t-a.de 15 Thermal Circuit Breaker 3120-F... Description remote trip module X3120-M Dimensions A module which adds remote trip capability to all versions of type 3120-F. A voltage applied across the coil, by means of an external sensor for example, will cause disconnection of the main switch/ circuit breaker mechanism. Not possible in combination with PT terminals. 30 1.18 Typical applications 1 9 .354 Electrical remote trip of safety systems. Order numbering code blade terminals 6.3 x 0.8 Type No. X3120 module for type 3120 Module M magnetic relay trip module Style 2 magnetic remote trip coil Terminal design P7 blade terminals DIN 46244-A6.3-0.8 Assembly status M module mounted to circuit breaker 3120 Rated voltage AC 120, 230 V DC 12, 24 V 10.7 .421 21 .827 18 .709 14 .551 Dimensional drawings of the standard version of 3120-N please see page 6-8 Schematic diagram line 21 11 12(i) X3120- M 2 P7 M -12 V ordering example 12(k) Standard voltage ratings and typical internal resistance values voltage rating module mounted internal internal resistance (Ω) 22(i) load FA 22(k) 12(n) remote trip 12 internal internal resistance (Ω) voltage rating DC 12 V 0.78 AC 120 V 71.0 Voltage ratings AC 120...230 V; DC 12...24 V DC 24 V 3.3 AC 230 V 312 Power consumption approx. 200 Watt Technical data Pulse operation 20 ms < tON < 100 ms / tOFF > 10 sec Trip time < 20 ms Typical life 50,000 operations at UN Ambient temperature -30…60 °C Dielectric strength between main and trip current circuit test voltage AC 3,000 V Insulation resistance > 100 MOhm (DC 500 V) Vibration 8 g (57-500 Hz), ± 0.61 mm (10-57 Hz) test to IEC 60068-2-6, test Fc 10 frequency cycles/axis Shock 30 g (11 ms) test to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, test to IEC 60068-2-11, test Ka Humidity 240 hrs in 95 % RH test to IEC 60068-2-78, test Cab Mass approx. 53 g (including base unit) All dimensions without tolerances are for reference only. E-T-A reserves the right change specifications at any time in the interest of improved design, performance and cost effectiveness, the right to make changes in these specifications without notice is reserved. Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 16 www.e-t-a.de 2051
3120-F521-H7T1-W01X-5A 价格&库存
很抱歉,暂时无法提供与“3120-F521-H7T1-W01X-5A”相匹配的价格&库存,您可以联系我们找货
