2-5700-IG1-P10-DD-000040 7A
    ETA(钰泰半导体)
    ETA - 2-5700-IG1-P10-DD-000040 7A - Thermal Circuit Breaker, 5700-02-01, 7 A, 1 Pole, 28 VDC, 250 VA...
2-5700-IG1-P10-DD-000040 7A 数据手册
Thermal Overcurrent Circuit Breakers 2-5000/2-5700-... Description Single pole thermal circuit breaker with press-to-reset, tease-free, trip-free, snap action mechanism. Type 2-5000 is available with optional manual release (-H), type 2-5700 can be supplied as a pushpush switch/circuit breaker (R-type TO CBE to EN 60934 in press-toreset configuration; M-type when fitted with manual release -H; Stype with push-push operation). Fitted with flange or threadneck for panel mounting. Options include an additional unprotected circuit tap (-A3). Approved to CBE standard EN 60934 (IEC 60934). 1 Typical applications Motors, transformers, solenoids, battery chargers, power supplies, appliances, machinery, extra low voltage systems. Ordering information Voltage rating Current rating range Typical life Ambient temperature Insulation co-ordination (IEC 60664 and 60664 A) Dielectric strength (IEC 60664 and 60664A) operating area Insulation resistance Interrupting capacity Icn ordering example The exact part number required can be built up from the table of choices shown above. Ordering references for optional features should be omitted if not required. Standard current ratings and typical internal resistance values Interrupting capacity (UL 1077) Shock Corrosion Issue G Internal resistance (Ω) 280 100 110 29 14 7 4.9 3.4 2.5 1.8 1.2 0.8 0.6 0.4 0.3 0.2 ☎ Current rating (A) 3 3.5 4 4.5 5 6 7 8 10 12 13 15 16 20 22 25 Internal resistance (Ω) 0.1 0.06 0.06 0.05 0.05 0.02 0.02 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 < 0.02 AC 250 V; DC 28 V (UL: AC 250 V; DC 50 V) 0.05...25 A 5,000 operations at 2 x IN -20...+60 °C (-4...+140 °F) rated impulse pollution withstand voltage degree 2.5 kV 2 reinforced insulation in operating area test voltage AC 3,000 V > 100 MΩ (DC 500 V) 0.05...2.5 A 8 x IN 3... 5 A 20 x IN 6...12 A 200 A (higher interrupting capacity available to special order) Degree of protection (IEC 60529/DIN 40050) Vibration Current rating (A) 0.05 0.08 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 1 1.2 1.5 1.8 2 2.5 2-5700-... Technical data Type No. 2-5000 flange mounting 2-5700 threadneck panel mounting (hardware bulk shipped) Threadneck design – type 2-5700 only iG1 moulded threadneck 3/8"-27UNS-2A iG2 moulded threadneck M12x1 Terminal design P10 blade terminals 6.3-0.8 mm (QC .250) K10 screw terminals M4x6 Shunt terminal (optional) -P10 only A3 shunt terminal (up to IN 2.5 A/6 A max. load) Manual release (optional) H manual release facility (type 2-5000 only) DD push to release/push to reset (type 2-5700 only) Current ratings 0.05...25 A 2-5700 - iG1 - P10 - .. - DD - 8 A 2-5000-... Humidity Mass 13...25 A 400 A IN UN 0.05...20 A AC 250 V 2,000 A 0.05...25 A DC 50 V 2,000 A operating area IP40 terminal area IP00 8 g (57-500 Hz) ±0.61 mm (10-57 Hz), to IEC 60068-2-6, test Fc, 10 frequency cycles/axis 25 g (11 ms) to IEC 60068-2-27, test Ea 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka 240 hours at 95 % RH to IEC 60068-2-3, test Ca approx. 29 g Approvals Authority VDE (EN 60934) CSA/ UL Semko (EN 60934) SEV Type 2-5700 only: LRoS BV Voltage ratings AC 250 V; DC 28 AC 250 V; DC 50 AC 250 V; DC 28 AC 250 V; DC 28 V V V V AC 250 V; DC 28 V AC 250 V; DC 28 V Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com Current ratings 0.05...25 A 0.05...20 A 0,05...25 A 0,05...25 A 0.1 ...25 A 0.2 ...25 A 103 Thermal Overcurrent Circuit Breakers 2-5000/2-5700-... Dimensions Terminal design 2-5000-P10 -P10-A3 0.05...2.5 A OFF 1 3 1 2 13 .512 7 .276 2 flat head screw M4x6 ISO1580 tightening torque 1.2 Nm 3 Installation drawings 2 19.8 .780 31 1.22 2-5000-P10 blade terminal DIN 46244-A6.3-0.8 (QC .250) 18.5 current rating in A 14.5 .571 0.05...2.5 A 1 ø4.5 .177 5 40 1.57 50 1.97 operating area 2-5000-P10-A3 4 3 2 13 .512 A 1 4 3 2 2-5700-P10 mounting area ø6.5 .256 operating area max. 2.5 max .098 2-5700-P10 10 .394 .650 iG1=3/8-27UNS-2A tightening torque max. 1 Nm iG2=M12x1 tightening torque max. 1.5 Nm A 4 25 .984 3 2 10.4 .409 1 25 .984 A 46.5 1.83 ON .886 16.5 max. 2.5 max .098 4 .728 1 22.5 3 10.4 .409 A OFF 4 10.4 .409 4 44 1.73 .197 5 1 ø13.5 .531 18.2 .717 12.2 .480 ON ø9.5 .374 -K10 19.8 .780 29 1.14 D-shaped threadneck 1 blade terminal DIN 46244-A6.3-0.8 (QC .250) 14.5 .571 4 3 2 mounting area 1 .039 1 .039 current rating in A for standard (-DD version without push button marking) mounting hole iG1=ø9.6 -0.1 iG2=ø12.2 -0.1 iG1=.378 -.004 iG2=.480 -.004 iG1=.350 -.004 iG2=. 453 -.004 SW 14 .551 iG1=8.9 -0.1 iG2=11.5 -0.1 iG1=8.8 iG2=11.3 iG1=.346 iG2=.445 5 This is a metric design and millimeter dimensions take precedence ( mm ) inch 104 ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com Issue G Thermal Overcurrent Circuit Breakers 2-5000/2-5700-... Internal connection diagrams 0.05 ... 2.5 A (with or without shunt terminal) 3 ... 25 A (without shunt terminal) 1 1 (3) 1 (-A3) 2 2 Typical time/current characteristics at +23°C/+73.4°F 10000 0.05 - 2.5 A 3 - 25 A Trip time in seconds 1000 100 10 1 0.1 1 2 4 6 8 10 … times rated current 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section 9 – Technical information. Ambient temperature °F -4 +14 +32 +73.4 +104 +122 +140 °C -20 -10 0 +23 +40 +50 +60 Derating factor 0.76 0.84 0.92 1 1.08 1.16 1.24 This is a metric design and millimeter dimensions take precedence ( mm ) inch Issue G ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 105 Thermal Overcurrent Circuit Breakers 2-5000/2-5700-... Accessories for types 2-5000 and 2-5700 with screw terminals -K10 176 6.93 Bus bar Y 303 563 01 X 60° 2 .079 X 1.1 .043 1 162 6.38 18 .709 M4 10 .394 7 .276 Accessories for type 2-5000-... Accessories for type 2-5700-... Water splash cover, transparent for push button (IP64) Y 300 728 01 With 3/8" threadneck (-iG1) Fixing plate Y 3012 056 02 19.2 .756 1.5 .059 2.3 .091 0.5 .020 Water splash cover, transparent Y 300 538 01 and knurled nut Y 300 628 01 X 200 799 01 (IP64) 31.5 1.24 18.5 .728 4.5 .177 50 1.97 40 1.57 14.5 .571 18 .709 3/8-27 UNS-2B Water splash cover, transparent with special knurled nut X 200 798 02 (IP64) 40 1.57 50 1.97 Hex nut with splash cover black with O ring X 210 739 01 (IP64) transparent splash cover X 201 296 03 (IP64) Rear terminal shroud, transparent (IP64) Y 300 476 01 12.5 .492 29 1.14 3/8-27 UNS-2B 3/8-27 UNS-2B 49 1.93 E-T-A Separate hardware Hex nut Y 300 192 01 Knurled nut Y 307 117 02 3/8-27 UNS-2B 3/8-27 UNS-2B ø12 .472 ø6 .236 SW14 .551 2.5 .098 ø15 .591 3 .118 With M12 threadneck (-iG2) Hex nut with splash cover, black X 201 296 01 without O ring (IP64) X 200 801 03 with O ring (IP66) Hex nut with splash cover, transparent X 200 801 08 with O ring (IP66) Water splash cover, transparent with knurled nut and O ring X 210 663 01 (IP64) M12x1 M12x1 Hex nut Y 300 116 02 Knurled nut Y 302 065 01 M12x1 M12x1 3.2 .126 This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 106 ☎ SW14 .551 2.5 .098 ø17 .669 Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 0.5 x 45° .020 x 45° Issue G
2-5700-IG1-P10-DD-000040 7A 价格&库存
很抱歉,暂时无法提供与“2-5700-IG1-P10-DD-000040 7A”相匹配的价格&库存,您可以联系我们找货
