106-P10-10A
106-P10-10A
    ETA(钰泰半导体)
106-P10-10A 数据手册
Thermal Overcurrent Circuit Breakers 104/105/106-... Description Miniaturised single pole thermal circuit breaker with push-to-reset, tease- free, trip-free, snap action mechanism (R-type TO CBE to EN 60934). Available in versions for PCB or panel mounting, snap-in or threadneck, or as an integral type. Approved to CBE standard EN 60934 (IEC 60934). For higher current ratings see type 1140. Typical applications Motors, transformers, solenoids, printed circuit boards, hand-held machines and appliances, marine applications, caravans. 104-... Ordering information Type No. 104 PCB mounting type (-PR), or integral type (-P30/P10) 105 snap-in panel mounting 106 threadneck panel mounting with hex and knurled nut (hardware bulk shipped with 5 pcs plus) 106-M2 threadneck panel mounting 3/8-27UNS with collar, hex nut and knurled nut (hardware bulk shipped with 5 pcs plus) Terminal design P10 blade terminals A6.3-0.8 (QC .250) P30 blade terminals A2.8-0.8 (QC .110) PR solder terminal pins for PCB mounting (type 104 only) PR3 PCB mounting (vertical), type 104 only Current ratings 0.05...10 A 106 - P30 - 5 A ordering example Preferred types Preferred types Standard current ratings (A) 0.5 0.8 1 1.2 1.5 2 3 4 5 6 8 10 x x x x x x x x x x x x x x x x x x x x x x x x Standard current ratings and typical internal resistance values Current rating (A) Internal resistance (Ω) Current rating (A) Internal resistance (Ω) 0.05 285 1.8 0.28 0.08 134 2 0.25 0.1 81 2.5 0.18 0.2 22 3 0.11 0.3 8.7 3.5 0.076 0.4 5.5 4 0.067 0.5 3.3 4.5 0.051 0.6 2.45 5 ≤ 0.05 0.7 1.6 6 ≤ 0.05 0.8 1.45 7 ≤ 0.05 1 0.9 8 ≤ 0.05 1.2 0.6 10 ≤ 0.05 1.5 0.4 2013/14 105-... 106-... 2 Technical data The exact part number required can be built up from the table of choices shown above. Ordering references for optional features should be omitted if not required. 106-P10106-P30- For further details please see chapter: Technical Information Voltage rating AC 240 V; DC 48 V (UL: AC 250 V; DC 48 V) Current ratings 0.05...10 A Auxiliary circuit 0.5 A, AC 240 V, DC 28 V Typical life 0.05...5 A 1,000 operations at 2 x IN, inductive DC 28 V: 3,000 operations at 2 x IN, inductive 6...8 A 500 operations at 2 x IN, inductive 10 A 50 operations at 2 x IN, inductive Ambient temperature -20...+60 °C (-4...+140 °F) T 60 Insulation co-ordination rated impulse pollution (IEC 60664 and 60664 A) withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength test voltage (IEC 60664 and 60664A) operating area AC 3,000 V Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity Icn 0.05...8 A 6 x IN AC 0.05...10 A 6 x IN DC Interrupting capacity IN UN (UL 1077) 0.05...10 A AC 250 V 2,000 A 0.05...10 A DC 48 V 200 A Degree of protection operating area IP40 (IEC 60529/DIN 40050) terminal area IP00 Vibration 10 g (57-500 Hz) ± 0.76 mm (10-57 Hz), to IEC 60068-2-6, test Fc, 10 frequency cycles/axis Shock 25 g (11 ms) to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH, to IEC 60068-2-78, test Cab Mass approx. 10 g Approvals Authority Voltage ratings Current ratings VDE, SEV, AC 240 V DC 48 V 0.05...8 A 0.05...10 A CSA, UL AC 250 V; DC 48 V 0.05...10 A www.e-t-a.de 2 - 15 Thermal Overcurrent Circuit Breakers 104/105/106-... Dimensions 104-P30 9.1 .358 ø4 .157 ON OFF 1 8±0.2 .315±.008 17.5 .689 19.2 .756 21 .827 3 27.6 1.09 29.6 1.16 6.5 .256 9.5 .374 ø1.5 .059 Ø 2.2 .087 7.3 .287 9 .354 1 blade terminals DIN 46244-A2.8-0.8 (QC .110) cut-out dimensions 6.5 .256 11 .433 6.5 .256 ø1.5 .059 2 9.5 .374 17.5 .689 1.2 .047 hole for mounting screw M2 usable depth 4.5 mm (.177 in.) 30 1.18 30 1.18 11 .433 0.8 .031 4.5 .177 terminal design for correct stand-off distances 1 .039 max. 3 max .118 PCB mounting holes 104-PR 104-PR 104-PR-A3 7...10 A 0.05...6 A 0.5 0.5 .020 .020 ø1.5 .059 2 29.6 1.16 27.6 1.09 3.5 .138 1.2 .047 max. 3 max .118 ø7 .276 9.5 .374 ON ø4 .157 6.5 .256 9.5 OFF .374 104-PR 19 .748 2 104-P30 7...10 A 9.5 .374 8±0.2 .315±.008 104-PR3 0.9 .035 19.2 .756 15.4 .606 4 .157 0.9 .035 5.4 .213 4 .157 2 .079 27.6 1.09 29.6 1.16 9.5 .374 d mm inch 0.8 .031 1.0 .039 1.5 .059 2-3 .079-.118 blade terminals DIN 46244-A2.8-0.8 (QC .110) panel cut-out a b 25 .984 b a mm 21.9 22 22.1 22.2 11 .433 inch .862 .866 .870 .874 11.3 +0.3 .445 +.012 105-P3 07...10 A 7...10 A 7...10 A ø7 .276 d 7.7 .303 11 .433 9.1 .358 12 .472 PCB mounting holes 0.05...6 A 6.5 .256 6.5 .256 0.9 .035 1.2 .047 hole for mounting screw M2x5 1.2 .047 6.2 .244 19 .748 1.2 .047 14 .551 15.4 .606 ø4 .157 9.5 .374 4 .157 2.1 .083 0.8 .031 max. 3 max .118 10 .394 1.2 .047 27.6 1.09 29.6 1.17 max. 3 max. 118 ON ø4 .157 ON OFF 105-P30 ø7 .276 6.5 .256 9.5 OFF .374 0.05...6 A 5.4 .213 7.7 .303 This is a metric design and millimeter dimensions take precedence ( mm ) inch 2 - 16 www.e-t-a.de 2013/14 Thermal Overcurrent Circuit Breakers 104/105/106-... Installation drawings 106-P30 104-… 3/8-27UNS-2A tightening torque max. 0.8 Nm 1.2 .047 8 .315 8 .315 0.7 .028 27.6 1.09 7 .276 10.5 .413 13.5 .531 max. 3 max .118 operating area ø4 .157 ON OFF Dimensions 9.5 .374 8 .315 105-… 8.9 - 0.1 11 blade terminals .433 DIN 46244-A2.8-0.8 (QC .110) mounting hole 2 operating area 8.8 .346 15.7 .618 SW14 .551 8 .315 .350 - .004 19 .748 mounting area 9.6- 0.1 9 .354 .378 - .004 8 .315 8 .315 106-P30 7...10 A 8 .315 106-… mounting hole 8.9 - 0.1 3/8-27UNS-2A tightening torque max. 0.8 Nm 8 .315 operating area .350 - .004 106-M2 mounting area 8 .315 8 .315 9.6- 0.1 .378 - .004 8 .315 Terminal design 104/105/106-P10 0.05...6 A blade terminals DIN 46244-A6.3-0.8 (QC .250) 10 .394 8 .315 Internal connection diagrams 7...10 A 6.3 .248 mounting area polarizing tooth Types 104 105 106 1 2 This is a metric design and millimeter dimensions take precedence ( mm ) inch 2013/14 www.e-t-a.de 2 - 17 Thermal Overcurrent Circuit Breakers 104/105/106-... Typical time/current characteristics at +23 °C/+73.4 °F 10000 0.05 - 6 A 7 - 10 A Accessories Water splash cover (transparent)/knurled nut assembly (type 106-... only) X 201 285 01 (IP64) Trip time in seconds 1000 100 Knurled nut 3/8", plastic (standard) Y 307 117 02 10 2 ø15 .591 3 .118 1 0.1 1 2 6 8 10 4 … times rated current 20 3/8-27UNS-2B 30 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section Technical information. Ambient temperature °F °C -4 -20 +14 -10 +32 0 +73.4 +23 +104 +40 +122 +50 +140 +60 Derating factor 0.76 0.84 0.92 1 1.08 1.16 1.24 Hex nut 3/8", nickel-plated brass Y 300 192 01 3/8-27UNS-2B 2.5 .098 SW14 .551 This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 2 - 18 www.e-t-a.de 2013/14
106-P10-10A 价格&库存
很抱歉,暂时无法提供与“106-P10-10A”相匹配的价格&库存,您可以联系我们找货
