Thermal Overcurrent Circuit Breaker 1110-...
Description
Tease-free, trip-free, snap action mechanism. Designed for snap-in
panel mounting utilising round hole or industry standard fuse-holder
cut-out dimensions. Featuring an ergonomically styled two colour
actuator with indicator band clearly showing the tripped/OFF position.
Approved to CBE standard EN 60934 (IEC 60934): S-type TO CBE
Typical applications
Motors, transformers, solenoids, extra low voltage systems, household
and office machines, instrumentation, marine applications, mobile homes.
1110-F1..
Ordering information
Type No.
1110
snap in panel mounting
Mounting
F1 panel thickness 0.8...1.6 mm (.031 -.063 in)
F2 panel thickness 1.8...3 mm (.071-.118 in)
Number of poles
1 1-pole protected
Actuator style
2
black push button/white indicator ring,
push-push function
Terminal design
P1 blade terminals A6.3-0.8 (QC .250)
Characteristic curve
M1 medium delay
Current ratings
0.05...16A
2
Technical data
For further details please see chapter: Technical Information
Voltage rating
AC 250 V; DC 50 V
Current rating
0.05...16 A
Typical life
In
operations
Un
I
0.05...10 A
10,000
AC 250 V
1xIn
0.05...10 A
10,000
DC 28 V
1xIn
0.05...10 A
6,000
DC 50 V
1xIn
12...16 A
2,000
DC 50 V
1xIn
Ambient temperature
Insulation co-ordination
(IEC 60664 and 60664 A)
1110 - F1 1 2 - P1 M1 - 0.05 A = ordering example
Preferred types
Preferred types
Standard current ratings (A)
1 1.5 2
3 3.5 4
5
6
7
8 10 15 16
x
x
x
x
x
x
x
x
x
x
x
x
x
x
1110-F112-P1M11110-F212-P1M1-
x
x
x
x
x
x
x
x
Standard current ratings and typical internal resistance values
Dielectric strength
(IEC 60664 and 60664A)
operating area
Insulation resistance
Interrupting capacity Icn
(UL 1077/EN60934 PC 1)
Current
rating (A)
Internal
resistance (Ω)
Current
rating (A)
Internal
resistance (Ω)
0.05
442
2
0.25
0.08
173
2.5
0.19
0.1
110
3
0.12
0.2
27.8
3.5
0.09
0.3
12.4
4
0.07
0.4
7.0
5
0.05
Humidity
0.5
4.5
6
0.04
Mass
0.6
3.1
7
≤ 0.02
0.7
2.3
8
≤ 0.02
0.8
1.7
10
≤ 0.02
1
1.1
12
≤ 0.02
1.2
0.71
15
≤ 0.02
1.5
0.41
16
≤ 0.02
1.8
0.38
Degree of protection
(IEC 60529/DIN 40050)
Vibration
Shock
Corrosion
2013/14
-20...+60 °C (-4...+140 °F)
rated impulse
pollution
withstand voltage
degree
2.5 kV
2
reinforced insulation in operating area
test voltage
AC 3,000 V
> 100 MΩ (DC 500 V)
AC 250 V: 0,05...10 A 8 x IN
DC 50 V:
0,05...6.5 A 65 A
7...16 A
130 A
DC 28 V:
7...10 A
200 A
UN
IN
0.05...6 A
AC 250 V
1,000 A
7...16 A
AC 125 V
1,000 A
0.05...16 A DC 50 V
1,000 A
operating area IP40
terminal area IP00
8 g (57-500 Hz) ± 0.61 mm (10-57 Hz),
to IEC 60068-2-6, test Fc,
10 frequency cycles/axis
30 g (11 ms)
to IEC 60068-2-27, test Ea
96 hours at 5 % salt mist,
to IEC 60068-2-11, test Ka
240 hours at 95 % RH
to IEC 60068-2-78, test Cab
approx. 12 g
Approvals
Authority
Voltage ratings
Current ratings
VDE
AC 250 V;
DC 50 V
0.05...10 A
0.05...16 A
UL/CSA
AC 250 V
AC 125 V
DC 50 V
0.05...6 A
0.05...16 A
0.05...16 A
www.e-t-a.de
2 - 29
Dimensions
Internal connection diagram
1
1110-F1.. / -F2..
19
.748
10
.394
19
.748
10
.394
black
white
2.4
.094
15
.591
9.5
.374
ON
OFF
When installing the circuit breaker apply pressure on bezel only.
2
51
2.01
47.5
1.85
Typical time/current characteristics at +23 °C/+73.4 °F
2
10000
0.05 - 6 A
12.5
.492
9
.354
7 - 16 A
1000
12.1
.476
15.6
.520
.614
blade terminals DIN 46244-A6.3-0.8
(QC .250)
10
+0.2
- 0.4
+.008
- .016
±0.05
±.002
0.8 … 1.6
.031 … .063
insertion force ≤ 20 N,
removal force ≥ 120 N
1
+0.2
- 0.4
+.008
- .016
installation
side
installation
side
16±0.15
.630±.006
100
1110-F2..-P1M1-...A
13.5±0.1
.531±.004
.531±.004
13.5±0.1
Panel cut out
1110-F1..-P1M1-...A
±0.05
±.002
Trip time in seconds
13.2
16±0.15
.630±.006
insertion force ≤ 40 N,
Installation drawing
0.1
1.8 … 3
.071 … .118
0.6 0.8 1
2
4
6 8 10
… times rated current
The time/current characteristic curve depends on the ambient temperature
prevailing. In order to eliminate nuisance tripping, please multiply the
circuit breaker current ratings by the derating factor shown below. See also
section Technical information.
Ambient temperature °F
°C
-4
-20
+14
-10
+32
+23
+104
+40
+122
+50
+140
+60
Derating factor
0.76
0.84
0.92
1
1.08
1.16
1.24
Accessories – Water splash covers (transparent)
operating area
Push button splash cover
tansparent
Y 304 745 01 (IP64)
3
.118
3
.118
mounting area
25
.984
25
.984
ø14.5
.571
1.25
.049
14
60
2.36
17.8
.551
.701
When using
splash cover
please note
that the max.
panel thickness
is reduced by
0.5 mm/0.02 in.
Terminal shroud
Y 305 602 01 (IP64)
20.5
.807
ø4
.157
This is a metric design and millimeter dimensions take precedence ( mm )
inch
All dimensions without tolerances are for reference only. In the interest of improved design,
performance and cost effectiveness the right to make changes in these specifications
without notice is reserved. Product markings may not be exactly as the ordering codes.
Errors and omissions excepted.
2 - 30
www.e-t-a.de
2013/14
很抱歉,暂时无法提供与“1110-F112-P1M1-3A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+195.55104
- 50+192.79137
- 100+188.78204
- 200+185.54334
