1170-01-15A
1170-01-15A
    ETA(钰泰半导体)
1170-01-15A 数据手册
Thermal Automotive Circuit Breaker 1170-... Description Compact single pole thermal circuit breaker with push-to-reset, tease free, trip free, snap action mechanism and separate (colour coded) manual release. Combining full feature circuit breaker protection and convenience with low cost of ownership benefits. Fitted with blade terminals for plug-in mounting. Typical applications 1 Extra low voltage wiring systems on all types of vehicles and marine craft. 1170-... Ordering information Technical data Type No. 1170 plug-in Design standard 01 blade terminals for automotive fuse blocks (standard) with retaining clips 02 blade terminals for automotive fuse blocks, without retaining clips 21 as design 01 but with higher interrupting capacity 22 as design 02 but with higher interrupting capacity 31 blade terminals for automotive fuse blocks with retaining clips and ribs for higher pull-out force Current ratings 3...25 A 1170 - 01 - 15 A ordering example Please enquire for packaging quantities. Standard current ratings, typical voltage drop values and actuator colours (manual release) Current rating (A) Voltage rating DC 28 V (AC to special order) Current ratings 3...25 A Typical life 6,000 operations at IN 3,000 operations at 2 x IN ≤ 20 A 1,000 operations at 2 x IN 25 A Ambient temperature -30...+60 °C Interrupting capacity Icn 3...15 A 200 A (1170-01/-02/-31) 3...15 A 400 A (1170-21/-22) 20...25 A 400 A Ultimate short-circuit breaking capacity ≥ 1 break operation at 2000 A Degree of protection (IEC 529/DIN 40050) operating area IP 40 terminal area IP 00 Vibration 3 or 4 A: 5...25 A: 8 g (57-500 Hz) ±0.65mm (10-57 Hz) 10 g (57-500 Hz)±0.76 mm (10-57 Hz), to IEC 68-2-6, Test Fc, 10 frequency cycles/axis Shock 3 or 4 A: 5...25 A: 35 g (11 ms) 50 g (11 ms) to IEC 68-2-27, test Ea Voltage drop (mV) Actuator colour Corrosion 96 hours at 5 % salt mist, to IEC 68-2-11, test Ka 3 < 300 violet (approximating RAL 4008) Humidity 4 < 300 pink (approximating RAL 3015) 240 hours at 95 % RH to IEC 68-2-3, test Ca 5 < 150 orange-brown (approximating RAL 8023) Mass approx. 13 g 6 < 150 mossy-green (approximating RAL 6005) 7.5 < 150 hazel (approximating RAL 8011) 8 < 150 honey (approximating RAL 1005) (approximating RAL 3020) 10 < 150 red 15 < 150 blue (approximating RAL 5012) 20 < 150 yellow (approximating RAL 1018) 25 < 150 pearl (approximating RAL 1013) Issue E ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 49 Thermal Automotive Circuit Breaker 1170-... Dimensions Internal connection diagram 1 3 ON ø4 3 7 OFF 1170-01/-21 2 38 1 6.4 7.6 Typical time/current characteristics at +23 °C 10000 1000 20 Trip time in seconds max. 9.8 -30 °C 4.2 terminal area to DIN 72581 part 3 22 1170-02/-22 3 ø4 ON +23 °C 3.6 current rating without A 100 10 3 7 OFF +60 °C 0.6 5.2 14.5 18.8 38 1 7.6 0,1 6.4 1 0.6 5.2 3.6 14.5 max. 9.8 18.8 4.2 terminal area to DIN 72581 part 3 4 6 8 10 ... times rated current 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below.See also section 9 - Technical information. Ambient temperature °C Multiplication factor -30 -20 -10 0 +23 +40 0.8 0.84 0.88 0.92 1 1.08 +50 +60 1.16 1.24 20 22 2 current rating without A ON ø4 3 3 7 OFF 1170-31 38 18.8 16.6 4.2 7.6 6.4 0.6 15.2 max. 9.8 5.2 14.5 18 terminal area to DIN 72581 part 3 20 22 0.6 3.6 5.3 current rating without A 50 ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com Issue E Thermal Automotive Circuit Breaker 1170-... Accessories Ordering information Mounting socket 12 Socket 12-P10 30.3 Weidmüller style label (not supplied) 25.4 3.5 47 43 blade terminal DIN 46244-A6.3-0.8 Type No. 12 Mounting socket Terminal design P10 blade terminals A 6.3-0.8 J20 screw terminals 6-32 UNC A10 1 blade terminal A6.3-0.8 / 1 screw terminal 6-32 UNC Version ... blank: single socket 20 two-way 30 three-way 40 four-way 60 six-way 1 58 12 - P10 - 20 ordering example ø3.9 12.7 symmetrical hat rail EN 50022-35x7.5 48.4 Accessories for mounting socket 12 Socket 12-J20 30.3 Weidmüller style label (not supplied) terminal screw 6-32 UNC 25.4 Connector bus links -P10 X 210 588 01/1.5 mm2 (brown), up to 13 A max. load X 210 588 02/2.5 mm2 (black), up to 20 A max. load X 210 588 03/2.5 mm2 (red), up to 20 A max. load X 210 588 04/2.5 mm2 (blue), up to 20 A max. load 3.5 43 47 spring washer 100 quick-connect tabs 6.3 DIN 46247 tinned brass, insulated 58 ø3.9 12.7 ~70 symmetrical hat rail EN 50022-35x7.5 Socket 12-A10 30.3 terminal screw 6-32 UNC Weidmüller style label (not supplied) 25.4 Bus bar (up to 100 A max. load) X 211 157 01 with terminal X 211 157 02 without terminal Phoenix terminal AKG 35 max.cross section 35 mm2 cylinder head screw ISO1207-M4x4 nickel plated blade terminal DIN 46244-A6.3-0.8 3.5 43 47 washer A 4.3 DIN 125 nickel plated 2 48.4 Cu rail, tin-plated 58 symmetrical hat rail EN 50022-35x7.5 spring washer 7 12.8 fusible link (1.1 thick constriction) ø3.9 12.7 154.8 10 M4 48.4 Dimensions for surface mounting 60 7 13 ø4 48.4 Other sockets available to special order Labels: Weidmüller, D-33102 Paderborn Issue E ☎ Germany (0 91 87) 10-0 - USA (847) 827-7600 - UK (01296) 420336 - www.e-t-a.com 51
1170-01-15A 价格&库存
很抱歉,暂时无法提供与“1170-01-15A”相匹配的价格&库存,您可以联系我们找货
