1110-F112-P1M1-16A
1110-F112-P1M1-16A
    ETA(钰泰半导体)
1110-F112-P1M1-16A 数据手册
Thermal Overcurrent Circuit Breaker 1110-... Description Single pole switch/thermal circuit breaker (S-type TO CBE to EN 60934) with tease-free, trip-free, snap action mechanism. Designed for snapin panel mounting utilising round hole or industry standard fuseholder cut-out dimensions. Featuring an ergonomically styled two colour actuator with indicator band clearly showing the tripped/OFF position. Approved to CBE standard EN 60934 (IEC 60934). 1 Typical applications Motors, transformers, solenoids, extra low voltage systems, household and office machines, instrumentation, marine applications, mobile homes. 1110-F1.. Ordering information Technical data Type No. 1110 snap in panel mounting Mounting F1 panel thickness 0.8...1.6 mm (.031 -.063 in) F2 panel thickness 1.8...3 mm (.071-.118 in) Number of poles 1 1 pole protected Actuator style 2 black push button/white indicator ring, standard Other indicator ring colours are available to special order Terminal design P1 blade terminals A6.3-0.8 (QC .250) Characteristic curve M1 medium delay Current ratings 0.05...16A 1110 - F1 1 2 - P1 M1 - 0.05 A = ordering example Standard current ratings and typical internal resistance values Current rating (A) 0.05 0.08 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 1 1.2 1.5 1.8 Internal resistance (Ω) 442 173 110 27.8 12.4 7.0 4.5 3.1 2.3 1.7 1.1 0.71 0.41 0.38 Current rating (A) 2 2.5 3 3.5 4 5 6 7 8 10 12 15 16 Internal resistance (Ω) 0.25 0.19 0.12 0.09 0.07 0.05 0.04 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 ≤ 0.02 For further details please see chapter: Technical Information Voltage rating AC 250 V; DC 28 V (UL: AC 250 V; DC 50 V) Current rating 0.05...16 A Typical life AC + DC 0.05...10 A 10,000 operations at 1 x IN, inductive 12...16 A 6,000 operations at 1 x IN, inductive Ambient temperature -20...+60 °C (-4...+140 °F) Insulation co-ordination rated impulse pollution (IEC 60664 and 60664 A) withstand voltage degree 2.5 kV 2 reinforced insulation in operating area Dielectric strength (IEC 60664 and 60664A) test voltage operating area AC 3,000 V Insulation resistance > 100 MΩ (DC 500 V) Interrupting capacity Icn AC 250 V: 0.05...16 A 8 x IN DC 28 V: 0.05...6 A 10 x IN 7...10 A 200 A 12...16 A 300 A Interrupting capacity IN UN (UL 1077/EN60934 PC 1) 0.05...6 A AC 250 V 1,000 A 7...16 A AC 125 V 1,000 A 0.05...16 A DC 50 V 1,000 A Degree of protection operating area IP40 (IEC 60529/DIN 40050) terminal area IP00 Vibration 8 g (57-500 Hz)±0.61 mm (10-57 Hz), to IEC 60068-2-6, test Fc, 10 frequency cycles/axis Shock 30 g (11 ms) to IEC 60068-2-27, test Ea Corrosion 96 hours at 5 % salt mist, to IEC 60068-2-11, test Ka Humidity 240 hours at 95 % RH to IEC 60068-2-3, test Ca Mass approx. 12 g Approvals Authority BV UL CSA VDE 05/06(280405) Voltage ratings AC 250 V; DC 28 V AC 250 V AC 125 V DC 50 V AC 250 V; DC 50 V AC 250 V Current ratings 0.05...16 A 0.05...6 A 7...16 A 0.05...16 A 0.05...16 A 0.05...10 A www.e-t-a.com Thermal Overcurrent Circuit Breaker 1110-... Dimensions Internal connection diagram 1 1110-F1.. / -F2.. When installing the circuit breaker apply pressure on bezel only. 19 .748 10 .394 black white 2.4 .094 15 .591 9.5 .374 ON OFF 1 19 .748 10 .394 2 51 2.01 47.5 1.85 Typical time/current characteristics at +23°C/+73.4°F 10000 12.5 .492 9 .354 0.05 - 6 A 7 - 16 A 12.1 13.2 .476 15.6 1000 .61 blade terminals DIN 46244-A6.3-0.8 (QC .250) Panel cut out 1110-F1..-P.M1-...A 1110-F2..-P.M1-...A Trip time in seconds .520 100 +0.2 - 0.4 +.008 - .016 .531 ±.004 ±0.05 ±.002 13.5 ±0.1 ±0.1 13.5 .531 ±.004 10 +0.2 - 0.4 +.008 - .016 ±0.05 ±.002 installation side 16 ±0.15 .630 ±.006 0.8 … 1.6 .031 … .063 insertion force ≤ 20 N, removal force ≥ 120 N 1 installation side 16 ±0.15 .630 ±.006 1.8 … 3 .071 … .118 insertion force ≤ 40 N, removal force ≥ 120 N Installation drawing When installing the circuit breaker apply pressure on bezel only. operating area 0.1 6 8 10 2 4 … times rated current 0.6 0.8 1 20 40 The time/current characteristic curve depends on the ambient temperature prevailing. In order to eliminate nuisance tripping, please multiply the circuit breaker current ratings by the derating factor shown below. See also section 9 – Technical information. Ambient temperature °F -4 +14 +32 +73.4 +104 +122 +140 °C -20 -10 0 +23 +40 +50 +60 Derating factors 0.76 0.84 0.92 1 1.08 1.16 1.24 Accessories - Water splash covers (transparent) Push button splash cover transparent Y 304 745 01 (IP64) Terminal shroud Y 305 602 01 (IP64) ø14.5 .571 25 .984 When using splash cover please note that the max. panel thickness is reduced by 0.5 mm/0.02 in. 14 .551 60 2.36 25 .984 17.8 3 .118 mounting area .701 3 .118 1.25 .049 20.5 .807 ø4 .157 This is a metric design and millimeter dimensions take precedence ( mm ) inch www.e-t-a.com All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved.Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 05/06(280405)
1110-F112-P1M1-16A 价格&库存
很抱歉,暂时无法提供与“1110-F112-P1M1-16A”相匹配的价格&库存,您可以联系我们找货
1110-F112-P1M1-16A
  • 1+167.20457
  • 50+163.27856
  • 100+157.59260
  • 200+153.08341
库存:125
