EB1550
EB1550
    RITTAL(威图)
EB1550 数据手册
E-Box EB F1 G1 H1 T1 B 1.1 E-Box EB B1 Material: Sheet steel Enclosure: 1.25 mm 1.38 mm for EB 1555.500, EB 1556.500, EB 1577.500 to EB 1579.500 Protection category: IP 66 to EN 60 529/10.91 Approvals, see page 23. Supply includes: Enclosure with mounting plate, door including 180° hinges and cam lock with double-bit insert. Detailed drawing, see page 1082. Surface finish: Enclosure and door: Dipcoat-primed, powder-coated on the outside in textured RAL 7035 Mounting plate: Zinc-plated Depth 80 mm Width (B1) in mm 150 150 200 200 200 Height (H1) in mm Packs of 150 300 200 300 400 Depth (T1) in mm 80 80 80 80 80 Mounting plate width (F1) in mm 125 125 175 175 175 Mounting plate height (G1) in mm Model No. EB 1 135 285 185 285 385 1551.500 1545.500 1546.500 1552.500 1547.500 1.7 2.6 2.4 3.2 4.4 Weight (kg) Depth 120 mm Width (B1) in mm 150 150 200 200 200 300 300 200 Height (H1) in mm 150 300 200 300 400 300 400 500 Depth (T1) in mm 120 120 120 120 120 120 120 120 Mounting plate width (F1) in mm 125 125 175 175 175 275 275 175 Mounting plate height (G1) in mm 135 285 185 285 385 285 385 485 1553.500 1548.500 1549.500 1554.500 1550.500 1555.500 1556.500 1557.500 2.0 3.0 2.8 3.6 5.0 5.0 6.4 6.2 Model No. EB Packs of 1 Weight (kg) Depth 155 mm Width (B1) in mm 300 300 300 Height (H1) in mm 400 600 800 Depth (T1) in mm 155 155 155 Mounting plate width (F1) in mm 275 275 275 Mounting plate height (G1) in mm 385 585 785 1577.500 1578.500 1579.500 7.1 11.0 13.2 Model No. EB Packs of 1 Weight (kg) Lock systems Standard double-bit lock insert may be exchanged for lock inserts, type A, see page 888, lock cylinder inserts, plastic handles and T handles, type B, see page 886 – 889. To order terminal boxes in textured RAL 7032 please add extension .600 to the Model No., and for primed terminal boxes use extension .310. Delivery times available on request. Accessories Page 832 E-Box, EMC-shielded Page 290 110 Rittal Catalogue 31/Industrial enclosures
EB1550 价格&库存
很抱歉,暂时无法提供与“EB1550”相匹配的价格&库存,您可以联系我们找货
