1034000
1034000
    RITTAL(威图)
    RITTAL - 1034000 - Metal Enclosure, Multipurpose, Sheet Steel, 400 mm, 300 mm, 210 mm, IP66
1034000 数据手册
Compact enclosure AX Basic enclosure AX, sheet steel – AX 1034.000 Date : Apr 23, 2022 Compact enclosure AX Basic enclosure AX, sheet steel – AX 1034.000 created: 23.04.2022 build on www.rittal.com/uk-en Product description Material: Enclosure: Sheet steel Door: Sheet steel, all-round foamed-in PU seal Surface finish: Enclosure and door: Dipcoat primed, powder-coated on the outside, textured paint Mounting plate: Zinc-plated Colour: RAL 7035 Protection category IP to IEC 60 529: IP 66 Protection category NEMA: NEMA 1, 3R, 4, 12 Type rating to UL 50E: Type 1, 3R, 4, 12 IK Code: IK10 Supply includes: Enclosure with door(s) Gland plate(s) in enclosure base Mounting plate Perforated door strip Lock: 3 mm double-bit Basic material: Sheet steel Product description Dimensions: © Rittal 2022 Width: 300 mm Height: 400 mm 1 Depth: 210 mm Material thickness: Enclosure: 1.25 mm Door: 1.5 mm Mounting plate: 2 mm Mounting plate: Width: 250 mm Height: 375 mm Number of doors: 1 Door hinged on the right, may be swapped to the left: yes Number of cam locks: 1 Lock version: Cam Number of locks: 1 Lock insert: 3 mm double-bit Gland plate, size: 1 Gland plate, qty.: 1 Packs of: 1 pc(s). Weight/pack: 8.38 kg EAN: 4028177813441 Customs tariff number: 94032080 ETIM 7.0: EC000261 ETIM 6.0: EC000261 eCl@ss 8.0/8.1: 27180101 eCl@ss 6.0/6.1: 27180101 Product description: AX Compact enclosure, WHD: 300x400x210 mm, sheet steel, with mounting plate, single-door, with one cam lock Approvals Approvals: © Rittal 2022 Bureau Veritas 2 DNV-GL Lloyds Register of Shipping UL + C-UL Certificates: Certificate of manufacturer according to RMRS Protection category Declarations: Declaration of conformity © Rittal 2022 3
1034000 价格&库存
很抱歉,暂时无法提供与“1034000”相匹配的价格&库存,您可以联系我们找货
