AE1032
AE1032
    RITTAL(威图)
AE1032 数据手册
Compact enclosures AE Width: 200 – 600, height: 300 – 400 F1 F1 T1 B1 H1 H1 G1 G1 B1 B Compact enclosures AE 1.2 Material: Sheet steel Surface finish: Enclosure and door: Dipcoat-primed, powder-coated on the outside in textured RAL 7035 Mounting plate: Zinc-plated Width (B1) in mm Protection category: IP 66 to EN 60 529/10.91, Complies with NEMA 12 (AE 1032.500, AE 1035.500), Complies with NEMA 4 (AE 1030.500, AE 1031.500, AE 1380.500, AE 1039.500, AE 1339.500). Approvals, see page 26. Detailed drawing, see page 1083. 200 200 300 300 380 380 380 600 600 Height (H1) in mm 300 300 300 400 300 300 380 380 380 Depth (T1) in mm 120 155 210 210 155 210 210 210 350 Mounting plate width (F1) in mm 162 162 254 254 334 334 334 549 549 Mounting plate height (G1) in mm 275 275 275 375 275 275 355 355 355 Mounting plate thickness in mm 2.0 2.0 2.0 2.0 2,.0 2.0 2.0 2.5 2.5 1032.500 1035.500 1033.500 1034.500 1030.500 1031.500 1380.500 1039.500 1339.500 4.0 4.5 7.0 8.8 7.4 7.5 9.8 15.4 20.0 Model No. AE Weight (kg) Packs of Supply includes: Enclosure of all-round solid construction, single door, 1 gland plate in the enclosure base, r/h door hinge, may be swapped to opposite side (except with AE 1032.500 and AE 1035.600), with one cam lock, foamed-in door seal, mounting plate. 1 Lock systems Standard double-bit lock insert may be exchanged for 27 mm lock inserts, type A, see page 888, lock cylinder, plastic handles and T handles, type B, see page 886 – 889. To order enclosures in textured RAL 7032 please add extension .600 to the Model No., and for primed enclosures use extension .800. Delivery times available on request. Cable glands made from polyamide, brass, and multi-seal inserts, Model No. see page 972/973. Dust guard trim for the gap between the door and the enclosure, Model No. see page 899. Accessories Page 832 AE stainless steel Page 273 AE IP 69K Page 121 AE EMC shielded Page 290 AE Ex-proof Page 287 118 Rittal Catalogue 31/Industrial enclosures
AE1032 价格&库存
很抱歉,暂时无法提供与“AE1032”相匹配的价格&库存,您可以联系我们找货
