EL2243
EL2243
    RITTAL(威图)
EL2243 数据手册
EMC enclosures EMC instrument case Vario-Case iS Instrument case for slide-in equipment, 482.6 mm (19″) and modular assemblies. Width: 534 mm Material: Side panels: Extruded aluminium section, chromated on the inside, painted on the outside Cover trays: Plastic to UL 94-V0 (self-extinguishing), with a conductive coating on the inside Rear panel: 2 mm aluminium, clear-chromated Front panel: 2 mm aluminium, clear-chromated B EMC enclosures 1.8 HP U Height mm Depth mm Model No. VC 84 4 208.10 300 3743.700 84 7 341.40 400 3774.700 84 3 163.65 300 3733.700 84 3 163.65 400 3734.700 84 6 297.00 400 3764.700 84 6 297.00 500 3765.700 84 9 430.50 500 3795.700 Delivery times available on request. EMC diagram, see page 293. Surface finish: Clear-chromated/spray-finished, RAL 7030/7035 Supply includes: 2 plastic cover trays, 8 enclosure feet (12 with 400 mm depth), 2 side panels, 1 rear panel, 1 front panel, 4 mounting flanges, 482.6 mm (19″), 4 tapped strips, 4 untapped strips, assembly parts. EMC electronic Kombi system EL, 3-part Material: Wall unit and centre part: 1.5 mm sheet steel, yellow-passivated on the inside Mounting plate: 2.75 mm sheet steel Front door: Extruded aluminium section, die-cast aluminium corner connectors, 4 mm safety glass, with EMC mesh. Surface finish: Textured stove enamel, enclosure RAL 7035, interior surfaces zinc-plated and passivated, door frame RAL 7033. U Width mm Height mm Depth mm Model No. EL 3 600 212 415 2243.705 6 600 345 415 2246.705 9 600 478 415 2249.705 6 600 345 515 2256.705 9 600 478 515 2259.705 15 600 746 515 2265.705 21 600 1012 515 2271.705 Delivery times available on request. Approvals, see page 293. EMC diagram, see page 293. Protection category: IP 55 to EN 60 529/10.91 Supply includes: 1 wall unit, solid, 2 gland plates, solid, 1 centre part, vertically hinged, 2 mounting angles, 482.6 mm (19″), fitted, 1 mounting plate, zinc-plated, 1 front door with EMC safety glass. 292 Rittal Catalogue 31/Industrial enclosures
EL2243 价格&库存
很抱歉,暂时无法提供与“EL2243”相匹配的价格&库存,您可以联系我们找货
