AE1004
AE1004
    RITTAL(威图)
AE1004 数据手册
Stainless steel Compact enclosures AE F1 F1 T1 T1 B1 G1 H1 G1 B1 H1 B Stainless steel 1.6 Material: Stainless steel 1.4301 Enclosure and door: Stainless steel Mounting plate: Sheet steel Cam lock: Die-cast zinc, nickel-plated Protection category: IP 66 to EN 60 529/10.91 for AE 1002.600 – AE 1017.600, complies with NEMA 4x. IP 55 to EN 60 529/10.91 for AE 1018.600/AE 1019.600, complies with NEMA 12. Supply includes: Enclosure, door(s) with foamedin PU seal, mounting plate. Approvals, see page 26. Detailed drawing, see page 1120. Surface finish: Enclosure and door: Brushed, grain 180 Mounting plate: Zinc-plated Width (B1) in mm 200 380 300 380 500 500 380 Height (H1) in mm Packs of 300 300 380 380 500 500 600 Depth (T1) in mm 155 155 210 210 210 300 210 Mounting plate width (F1) in mm – 334 334 334 449 449 334 Mounting plate height (G1) in mm – 275 275 355 470 470 570 1002.600 1004.600 1005.600 1006.600 1007.600 1013.600 1008.600 1 Model No. AE Door(s) Weight (kg) 1 1 1 1 1 1 1 4.5 8.8 8.7 12.0 18.4 18.9 17.0 Page Accessories Rain canopy 1 2470.000 2471.000 2361.000 2472.000 2362.000 – 2472.000 Wall mounting bracket 4 2433.000 2433.000 2433.000 2433.000 2433.000 2433.000 2433.000 905 Wall angle 1 2583.000 2583.000 2583.000 2583.000 2583.000 2583.000 2583.000 906 Pole clamp 1 2584.000 2584.000 2584.000 2584.000 2584.000 2584.000 2584.000 906 Cam lock made from 1.4301 1 2304.000 2304.000 2304.000 2304.000 2304.000 2304.000 2304.000 887 Width (B1) in mm 600 600 600 760 800 800 1000 1000 Height (H1) in mm Packs of 380 600 760 760 1000 1200 1000 1200 Depth (T1) in mm 210 210 210 300 300 300 300 300 Mounting plate width (F1) in mm 549 549 549 704 739 – 939 – Mounting plate height (G1) in mm 355 570 730 730 955 – 955 – 1009.600 1010.600 1012.600 1014.600 1016.600 1017.600 1018.600 1019.600 Model No. AE 1 Door(s) Weight (kg) 1 1 1 1 1 1 2 2 17.0 25.0 31.7 42.5 52.9 70.0 71.0 85.0 899 Page Accessories Rain canopy 1 2473.000 2473.000 2473.000 2474.000 2475.000 2475.000 2363.000 2363.000 Wall mounting bracket 4 2433.000 2433.000 2433.000 2433.000 2433.000 2433.000 2433.000 2433.000 899 905 Wall angle 1 2583.000 2583.000 2583.000 2583.000 2583.000 2583.000 2583.000 2583.000 906 Pole clamp 1 2584.000 2584.000 2584.000 – – – – – 906 Cam lock made from 1.4301 1 2304.000 2304.000 2304.000 2304.000 2304.000 – – – 887 Lock systems Standard double-bit lock insert may be exchanged in enclosures with cam (except AE 1018.600/AE 1019.600) for lock inserts 41 mm, lock cylinder insert, plastic handles, T-handles, type C, see page 886 – 889. With AE 1018.600, may only be exchanged for 41 mm lock inserts, see page 888. For enclosures with locking rod, may be exchanged for 27 mm lock inserts, type A, see page 888 and Ergoform-S lock system, see page 885. To order compact enclosures in 1.4404 (AISI 316L), please add extension .500 to the Model No. Delivery times available on request. Accessories Page 832 Compact enclosures AE sheet steel Page 118 Compact enclosures AE, IP 69K Page 121 Rittal Catalogue 31/Industrial enclosures 273
AE1004 价格&库存
很抱歉,暂时无法提供与“AE1004”相匹配的价格&库存,您可以联系我们找货
