1611000
1611000
    RITTAL(威图)
    RITTAL - 1611000 - Metal Enclosure, Wall Mount, Sheet Steel, 300 mm, 400 mm, 155 mm, IP65
1611000 数据手册
SYSTEM CATALOGUE 36 Complex made simple Eplan and Rittal are powerful partners in the game plan to optimise and streamline value chains. Our solutions speed up your processes and boost your productivity. Your value chain is optimised and streamlined at every stage in the process, from engineering, purchasing and manufacturing, through to operations and IT. We support you to emerge as a winner through process streamlining in the goal to achieve the new Industry 4.0 standard. Our approach is simple: The solutions our customers need tomorrow have been developed by us yesterday and are already in stock today. Our thinking is in sync with your processes. Sourcing Operations Engineering Manufacturing 2 Rittal System Catalogue 36 Rittal System Catalogue 36 3 1 Engineering Digitisation and prototyping boost productivity The key to greater productivity in enclosure manufacturing lies in digital integration and end-to-end data transfer across the entire value chain. Digital protoyping from the outset, with the digital twin at its heart, provides the basis for rapid links between processes, systems and beyond. The complete range of Eplan and Rittal tools is available to you for every aspect of engineering. Up-to-date product data from Rittal and other manufacturers can be accessed quickly via the EPLAN Data Portal. With EPLAN Pro Panel, you are ideally equipped for the future with 3D-assisted design. Technical Specs Mechanical Infrastructure Technical Consulting & Design Digital Twin Product Functions Design Thermal Design & Dimensioning Checking & Correcting Find your solution from page 18 onwards. 4 Rittal System Catalogue 36 Rittal System Catalogue 36 5 2 Sourcing Do it faster, with configuration aids and our online shop The Rittal Configuration System allows you to select your racks and enclosures quickly and easily at the click of a button, and then order them directly from the online shop. What’s more, you benefit from error-free product & accessory configurations and detailed mechanical plans. It’s never been easier to configure and order your perfect solution! As an innovative and technological leader, Rittal uses automated production techniques based on Industry 4.0 principles to manufacture its world-leading products. Our mission is to manufacture rack and enclosure systems as efficiently and perfectly as possible, as at the digitally integrated Rittal plant in Haiger, for example. Standard products are delivered within 24/48 hours in Germany/Europe, in line with our brand promise: “Rittal – The System. Faster, better, everywhere.” Ordering Manufacturing Documents Logistics Kitting Find your solution from page 1160 onwards. 6 Rittal System Catalogue 36 Rittal System Catalogue 36 7 3 Manufacturing Do it better with Industry 4.0 and automation For customised machining of racks and enclosures with the same standards of precision and quality of volume production, Rittal offers fully automated machines for machining, component mounting and wire processing. EPLAN Smart Wiring makes wiring easier than ever before. All work stations are interlinked into one seamless, efficient process using data from the virtual prototype. Rittal Automation Systems supplies all the automation support you need for faster, easier and more accurate panel building that can be duplicated time and again – your ideal workflow from a single source. Cutting Labeling Devices Panel Modification Wire Fabrication Terminal Strip Assembly Wiring Mechanical Installation Testing Find your solution from page 560 onwards. 8 Rittal System Catalogue 36 Rittal System Catalogue 36 9 4 Operations Do it more reliably with our smart, global service We’re there for you, whether you are looking to replace vital cooling unit components or your systems need an efficiency check. After commissioning, machines and systems must ensure reliable long-term operation as the key to efficient, high-performance production. Keep an eye on the status of your current project data, from any location, with the cloud-based solution EPLAN eVIEW. And use the Rittal global service to minimise downtime and boost efficiency. We think ahead: With IoT links to our cooling units and chillers, for example, predictive maintenance is already a reality. Operations Service Find your solution from page 1132 onwards. 10 Rittal System Catalogue 36 Rittal System Catalogue 36 11 Become more future-proofed With the IT platform and edge cloud technology The latest IT technologies and applications – from cloud and edge computing, to analytics and AI, through to 5G – will shape the production of the future. Processing production data in real time, while ensuring data sovereignty and value creation, is a breeze with the turnkey edge cloud data centre ONCITE. What is more, the Rittal IT platform with its modular system design will help you to master all IT scenarios quickly and easily, from rack installations through to edge and hyperscale data centres. Monitoring Data Analysis Find your solution from page 834/661 onwards. 12 Rittal System Catalogue 36 Rittal System Catalogue 36 13 Be more competitive With know-how and interplay Combining engineering solutions from Eplan with system and automation expertise from Rittal will help to optimise and streamline your panel building and switchgear manufacturing processes across the entire value chain. Invest in your future with Eplan and Rittal. The future has arrived. Technical Consulting & Design Operations Technical Specs Engineering Operations Service Testing Wiring Wire Fabrication 14 Rittal System Catalogue 36 Sourcing Thermal Design & Dimensioning Ordering Digital Twin Manufacturing Documents Mechanical Infrastructure Checking & Correcting Logistics Product Functions Design Kitting Manufacturing Cutting Panel Modification Terminal Strip Assembly Labeling Devices Mechanical Installation Rittal System Catalogue 36 15 16 Rittal System Catalogue 36 Engineering from page 18 Eplan............................................................................... 18 Enclosures from page 39 Small enclosures ............................................................. 43 Compact enclosures ....................................................... 73 Enclosure systems .......................................................... 99 Console systems/PC enclosure systems/IW.................. 149 Operating housings/support arm/stand systems ........... 169 Support arm systems .................................................... 183 Hygienic Design ............................................................ 217 Stainless steel ............................................................... 227 Ex enclosures................................................................ 257 Outdoor ........................................................................ 263 Power distribution from page 277 Busbar systems ............................................................ 281 RiLine............................................................................ 299 VX25 Ri4Power ............................................................. 361 VX25 Ri4Power ISV distribution enclosures ................... 419 Climate control from page 449 Air cooling ..................................................................... 453 Cooling units ................................................................. 473 Liquid cooling................................................................ 509 Enclosure heaters ......................................................... 530 Climate control accessories........................................... 532 Rittal Automation Systems from page 561 Tools............................................................................. 564 Handling........................................................................ 606 Wire processing and wiring ........................................... 632 Machining ..................................................................... 638 Machines for machining, wire processing and assembly ...................................... 650 IT infrastructure from page 661 IT rack systems/racks ................................................... 673 IT power........................................................................ 723 IT cooling ...................................................................... 757 IT monitoring ................................................................. 799 IT security solutions....................................................... 833 System accessories Service & quality from page 877 from page 1133 International service..................................................... 1134 Rittal Manufacturer’s Service ....................................... 1140 Smart Service.............................................................. 1150 Quality management ................................................... 1154 Software & services..................................................... 1156 Rittal System Catalogue 36 17 18 Rittal System Catalogue 36/Engineering Engineering Engineering The Eplan process at a glance ......................................................................20 EPLAN Solutions – Your Gateway to Greater Efficiency .................................22 Engineering with its finger on the pulse .........................................................24 The EPLAN solutions EPLAN Cogineer ..........................................................................................26 EPLAN Engineering Configuration (EEC) .......................................................27 EPLAN Preplanning ......................................................................................28 EPLAN Fluid .................................................................................................29 EPLAN Electric P8 ........................................................................................30 EPLAN Pro Panel..........................................................................................31 EPLAN Smart Wiring ....................................................................................32 EPLAN Harness proD ...................................................................................33 EPLAN ERP/PDM Integration Suite ...............................................................34 EPLAN Data Portal .......................................................................................35 EPLAN eBUILD ............................................................................................36 EPLAN eVIEW ..............................................................................................37 Eplan delivers software and service in all fields of electrical engineering, automation and mechatronics. We have developed one of the world’s leading software solutions for mechanical & plant engineering and enclosure manufacturing. “Efficient engineering” is our motto. When it comes to streamlining challenging engineering processes, Eplan is your ideal partner. Whether you are a small or a large company, we can help you deploy your expertise more efficiently. Rittal System Catalogue 36/Engineering 19 THE EPLAN PROCESS AT A GLANCE When it comes to your design, engineering and manufacturing tasks, having the correct expert systems is one thing. But what about the connections between the systems? And the single source of truth (SSOT)? 20 Rittal System Catalogue 36/Engineering Engineering We examine your process, across the full range of different operations to optimise greater efficiency and data continuity: ◾ Interdisciplinary communication ◾ Macros and configuration ◾ Two-way data exchange ◾ Interfaces to ERP/PDM ◾ Data forwarding to enclosure manufacturing ◾ Efficiency via cloud solutions From engineering to production One thing is clear: the greatest potential for efficiency improvements lies in the process. Smooth interactions between all systems, from engineering through to production, are the key to creating more value. Aim for reuse Similarly, structuring your projects and templates correctly will significantly enhance the opportunities to reuse them. We can help you! A standardised database for your project At the start of any project, you should ask yourself: Which components do we need for planning? The EPLAN Data Portal can supply these components and complete your data in a logical fashion. Rittal System Catalogue 36/Engineering 21 EPLAN SOLUTIONS – YOUR GATEWAY TO GREATER EFFICIENCY EPLAN helps you to develop a cross-disciplinary approach to your engineering. The EPLAN platform provides the basis for this, by linking our software solutions together. For you, this translates into significant efficiency gains when working on your EPLAN project, because your digital data flows seamlessly from solution to solution, becoming further augmented with every process step. EPLAN ePULSE additionally provides access to an innovative cloud system, genuinely adding value to multi-location projects, for example. The EPLAN platform and EPLAN ePULSE combine to create EPLAN Solutions, your key to cutting-edge advanced engineering. 22 Rittal System Catalogue 36/Engineering Engineering “By digitizing your processes and standardizing your data, you will retain a long-term competitive edge. We can support you, with open systems and professional advice to safeguard your efficient engineering for the future.” Bernd Schewior, Vice President Professional Services EPLAN Rittal System Catalogue 36/Engineering 23 ENGINEERING WITH ITS FINGER ON THE PULSE EPLAN platform The EPLAN platform combines software solutions for every engineering discipline, from pre-planning, to project management, through to the construction of switchgear and cable harnesses. It comprises: ◾ Automated Engineering: EPLAN Engineering Configuration (EEC) provides you with a versatile tool for the design and use of configuration interfaces. EPLAN Cogineer provides you with the basis for automated generation of wiring schematics. ◾ EPLAN Preplanning helps you to record engineering data even at the preplanning stage. ◾ EPLAN Fluid is your engineering tool specifically designed for the project management and automatic documentation of circuits for fluid engineering systems. ◾ EPLAN Electric P8 helps you project-plan your electrical design for machinery and equipment in an engineering solution at the heart of the EPLAN platform. ◾ With EPLAN Pro Panel you devise and design control cabinets, switchgear and power distribution systems for energy supply in 3D. ◾ Use EPLAN Harness proD for efficient design and documentation of cables and cable harnesses in 3D and 2D. EPLAN ePULSE Mechanical Engineering Automated Engineering EPLAN Preplanning EPLAN Fluid EPLAN Electric P8 EPLAN Pro Panel EPLAN Harness proD Software Engineering ERP/PDM 24 Rittal System Catalogue 36/Engineering Engineering Rittal System Catalogue 36/Engineering 25 EPLAN solutions EPLAN Cogineer Maximise the potential of your engineering in next to no time with EPLAN Cogineer and boost the quality of your electrical and fluid documentation. Use your existing circuit templates to build a macro-library, and generate wiring schematics automatically at the click of a button with EPLAN Cogineer. What is more, you will benefit from the innovative techniques and add value to your engineering without a lengthy implementation process, across all industries and in companies of all sizes. With EPLAN Cogineer you can now compile circuit diagrams from a template library with just a few clicks directly from your Web browser. Users of EPLAN ePULSE have automatic access to a free premium version of EPLAN Cogineer if already working with the Eplan platform. FAQs ◾ How will EPLAN Cogineer improve the quality of my projects? EPLAN Cogineer is based on the standardised reuse of Eplan macros. Once correctly created, they work like a high-quality library, thus avoiding typical copy-and-paste errors. This saves time and money. ◾ Do I need extensive prior knowledge to be able to work with EPLAN Cogineer? You do not need expert knowledge of Eplan to be able to generate wiring schematics to the customer’s specifications; training is fast and straightforward. Nor do you need any knowledge of advanced programming languages. ◾ Can I benefit from EPLAN Cogineer even at the implementation phase? Yes, because with EPLAN Cogineer you have the option of gradually phasing in versions of automated wiring schematics. www.eplan-software.com/solutions 26 Rittal System Catalogue 36/Engineering EPLAN Engineering Configuration (EEC) With EPLAN Engineering Configuration (EEC), you map your product portfolio in a modular system with interdisciplinary functional units. As a result, EEC is your go-to tool for the design and application of configuration interfaces and the automatic generation of documents. This multi-disciplinary approach integrates sales, order processing, mechanical engineering, electrical and control engineering as well as production and documentation. Standardised, recognizable structures also make the commissioning and servicing of your products easier. Your benefits ◾ Benefit from automated data reuse with simple product structuring and the creation of modules. ◾ Save time and money, and optimise the quality of your documentation. ◾ Significantly shorten your production and delivery times, which in turn will cut project throughput times at your company. ◾ A wide range of distinct and varied specification parameters are supported and enable the handling of customer-specific requirements. ◾ EEC can be seamlessly integrated into existing system structures and supports consistent workflows. www.eplan-software.com/solutions Rittal System Catalogue 36/Engineering 27 Engineering EPLAN solutions EPLAN solutions EPLAN Preplanning EPLAN Preplanning helps you to log your engineering data even at the preplanning stage. For example, this might include the actuators and sensors in a system, machine or building. You can import data from external spreadsheets as well as making a graphical record of plant and machine overviews and process and instrumentation diagrams. This allows you to generate the initial data sheets and specifications for material procurement quickly. Downstream engineering planning phases can also access the collated and augmented data from EPLAN Preplanning. Your benefits ◾ You have a clearly structured overview of all plant, machine and building data at all times. ◾ Engineering data logged early on in the project remains readily accessible to anyone working on the project for its entire duration. ◾ Preplan basic information such as signal, pipeline and cable data in a graphical format to guide you more easily through the project. ◾ By using EPLAN Preplanning at the quote preparation phase and seamlessly transferring this information to engineering, you can boost the quality of your data throughout the entire planning process. www.eplan-software.com/solutions 28 Rittal System Catalogue 36/Engineering EPLAN Fluid EPLAN Fluid is your engineering tool specifically designed for the project planning and automatic documentation of fluid circuits in hydraulics, pneumatics, cooling and lubrication. The direct link to the EPLAN platform also allows you to implement tasks from other engineering disciplines in parallel. Planning and production documents are derived from the same source. Good to know ◾ Fluid engineering planning with EPLAN Fluid is compliant with the latest standard ISO 1219 or IEC 81346 with a mechatronic approach. ◾ Standards and expertise are stored in the system as macros for reuse. www.eplan-software.com/solutions Rittal System Catalogue 36/Engineering 29 Engineering EPLAN solutions EPLAN solutions EPLAN Electric P8 EPLAN Electric P8 allows consistent, seamless, fast project planning of your electrical machinery and equipment designs in one engineering system. The software supports a range of engineering techniques, from manual generation through to standardised and template-based approaches. Once recorded in the circuit diagram, the machinery and equipment documentation is auto-completed using the project data. EPLAN Electric P8 automatically generates detailed evaluations on your behalf as an integral part of the project documentation. This can be supplied continuously or bundled at the end of the project, as you prefer. This allows you to supply all downstream process stages with the necessary engineering information: from seamless planning through to production, commissioning, maintenance and repair. Your benefits ◾ Switch symbols are logically autoconnected in a flash. ◾ Choose between a graphical, logical or equipment-based project planning approach to support a variety of work processes. ◾ Evaluations such as terminal and cable plans or parts lists are generated automatically for you. ◾ Functions for processing mass data such as “search and replace” or “process in Excel” will accelerate your project planning while at the same time improving quality. www.eplan-software.com/solutions 30 Rittal System Catalogue 36/Engineering EPLAN Pro Panel EPLAN Pro Panel Professional allows you to devise and design control cabinets, switchgear and power distribution systems for energy supply in 3D. This means you can solve a wide range of engineering tasks with just one software package: from the creation of electrical circuit diagrams, to planning the installation layout in 3D, through to the virtual laying of connections. What is more, EPLAN Pro Panel Professional allows for comprehensive improvements of the production processes in enclosure and switchgear manufacturing: A wide range of manufacturing data and information is supplied automatically, from component labelling through to support of the manual wiring process. In short, EPLAN Pro Panel Professional provides a solid foundation for the automation and streamlining of your enclosure manufacturing. Your benefits ◾ From the creation of circuit diagrams to assembly layout to production integration, a single software package does it all. ◾ For more automated enclosure production, order information and comprehensive manufacturing documentation can be provided. ◾ Shorten throughput times and cut costs while maintaining a high standard of quality. ◾ Work profitably on any unit volume, from specific projects with a batch size of just 1 through to mass production. www.eplan-software.com/solutions Rittal System Catalogue 36/Engineering 31 Engineering EPLAN solutions EPLAN solutions EPLAN Smart Wiring EPLAN Smart Wiring is your virtual assistant for manual wiring in enclosure production. From the connection point through to the precise cable route, the software provides wiring experts with all the information they need in digital form, in 3D if required. You decide whether to wire the displayed connections individually or in a preset sequence. Wiring status can be indicated with the traffic-light principle. If you need confirmation, you can call up the electrical wiring plan to cross-check, starting from each individual connection. Any anomalies can be forwarded directly to the planning department by email. Project data is made available on a central server, allowing you to produce multiple identical enclosures in parallel or collaborate with several wiring experts. Your benefits ◾ As a wiring expert, you receive detailed step-by-step instructions for simple usage. ◾ Wiring without a wiring plan is also possible, this is stored in the assistant. ◾ Assembly layout, operating equipment, connections, connection setups and cable routes are clearly and comprehensively visualised. ◾ For any last minute changes, an automatic project adjustment capability helps to prevent errors. ◾ Status information supports the transfer of the project to several different employees and enables you to monitor the project. www.eplan-software.com/solutions 32 Rittal System Catalogue 36/Engineering EPLAN Harness proD EPLAN Harness proD is used for the efficient design and documentation of cables and cable harnesses in 3D and 2D. The software allows you to automate typical work operations in cable and cable harness design – from transferring the connection information from the EPLAN platform, to intuitive cable laying, through to generation of the production documents. The software is open to MCAD systems and is therefore seamlessly integrated into existing system landscapes. The cable and cable harness design does not depend on the availability of a mechanical prototype. You can upgrade the digital twin with the relevant electrical information even during the engineering process. Your benefits ◾ The intuitive 3D environment makes it easier for you to design cables and cable harnesses. ◾ The required production documents including pinboard drawing and cable drawing can be derived automatically. This saves you time and money and enhances the quality of your documentation. ◾ Electrical pathways are more easily distinguished and wires and cables can be routed automatically. www.eplan-software.com/solutions Rittal System Catalogue 36/Engineering 33 Engineering EPLAN solutions EPLAN solutions EPLAN ERP/PDM Integration Suite Seamless data flows ensure transparency in the product development process. The EPLAN Integration Suite supports integration into existing ERP, PDM and PLM system protocols. This helps you to optimise your work processes, from the circuit diagram through to the master data. Fast, specific data is supplied in a two-way exchange with the systems without needing to leave your work space within the EPLAN platform. www.eplan-software.com/solutions 34 Rittal System Catalogue 36/Engineering EPLAN Data Portal The EPLAN Data Portal gives you direct online access to high-quality product catalogues from a host of component manufacturers. All products within the EPLAN platform have equal access to this Web service. By dragging and dropping the available components into the EPLAN documentation, you can reduce project planning work and upgrade the quality of machine and system documentation. The time savings achieved with the EPLAN Data Portal at the start of project planning extend right through to commissioning: The representation of a device in various system plans is always based on a uniform source. Your benefits ◾ Quickly and easily located standardised, intelligent, globally valid device data. ◾ Minimise the effort required for master data maintenance. ◾ Benefit from significant project planning time savings compared with manual generation. ◾ Significantly enhance the quality of your documentation. www.eplan-software.com/eplan-data-portal Rittal System Catalogue 36/Engineering 35 Engineering EPLAN solutions EPLAN solutions EPLAN eBUILD EPLAN eBUILD is a member of the EPLAN ePULSE family, which brings together open and cloud-based data and projects, disciplines and engineers worldwide. The automated creation of wiring schematics helps users to take their first steps towards automated engineering. Your benefits ◾ Free template libraries, including logic and variance, are available to use. ◾ Readily available in the Eplan platform (from version 2.8, hotfix 3). ◾ New template libraries from well-known manufacturers are continuously being added to EPLAN ePULSE as cloud-based options. ◾ This tool is suitable for universal use across all industries and is international. www.eplan-software.com/solutions 36 Rittal System Catalogue 36/Engineering EPLAN eVIEW With EPLAN eVIEW, your Eplan project is uploaded to the cloud for you. This means that any data created and added to in the EPLAN platform is evident to everyone involved in the project throughout the entire value chain, from engineering, production and assembly, through to maintenance and servicing. EPLAN eVIEW allows you to view project data from any location via your browser and comment on any amendments. The software guides you easily and intuitively through the redlining process. This enables simple communication and collaboration across different projects, departments and companies, so you can collaborate securely and transparently with different teams, suppliers and service-providers. Everything is paperless, using data directly from the cloud. Good to know ◾ EPLAN eVIEW allows you to access and view the status of a distinct EPLAN project at any time. ◾ Clearly definable access rights ensure data privacy. ◾ A consistent redlining process supports communication between the engineering team and the local commissioning and servicing teams. ◾ Cloud-to-cloud: EPLAN eVIEW can also be linked to your own in-house cloud solutions. www.eplan-software.com/solutions Rittal System Catalogue 36/Engineering 37 Engineering EPLAN solutions 38 Rittal System Catalogue 36/Enclosures ENCLOSURES Small enclosures from page 43 Compact enclosures Enclosures Polycarbonate enclosures PK .......................................................................44 Cast aluminium enclosures GA .....................................................................48 Terminal boxes KX........................................................................................56 E-Box KX......................................................................................................64 Bus enclosures KX .......................................................................................70 from page 73 Compact enclosures AX ...............................................................................84 Plastic enclosures AX ...................................................................................94 Enclosure systems from page 99 Baying enclosure system VX25...................................................................116 Free-standing enclosure system VX SE.......................................................142 Console systems/PC enclosure systems/ Industrial Workstations from page 149 TopConsole system TP...............................................................................156 One-piece consoles TP ..............................................................................161 Universal consoles TP.................................................................................162 PC enclosure systems ................................................................................164 Industrial Workstations................................................................................166 Operating housings/support arm/ stand systems from page 169 Comfort Panel ............................................................................................172 Optipanel....................................................................................................174 Operating housings AX ...............................................................................178 Compact Panel...........................................................................................181 Support arm systems .................................................................................183 Stand systems............................................................................................211 Hygienic Design from page 217 Terminal boxes HD .....................................................................................220 Compact enclosures HD.............................................................................221 Stainless steel from page 227 Support arm system CP 40 ........................................................................188 Small enclosures KX ...................................................................................230 Compact enclosures AX .............................................................................236 Enclosure systems VX ................................................................................242 Console systems ........................................................................................251 PC enclosure systems ................................................................................252 Operating housings ....................................................................................253 Ex enclosures from page 257 Ex enclosures, stainless steel......................................................................258 Ex enclosures, plastic .................................................................................260 Outdoor from page 263 Outdoor enclosures ....................................................................................268 Outdoor project solutions ...........................................................................270 Software for enclosures from page 272 Configurators/tools/CAD data.....................................................................272 Rittal System Catalogue 36/Enclosures 39 Enclosures Product group Small enclosures Compact enclosures Tough enough to take it all – there are practically no limits to the scope of applications for these especially robust small and compact enclosures. Electrical, electronic and pneumatic components are securely encapsulated with a high IK impact resistance. Enclosure systems Ingeniously simple, fully symmetrical, and patented worldwide – this is the successful formula which has established the VX25/ VX SE as a global standard. Plastic ◾ ◾ – Aluminium ◾ – – Sheet steel ◾ ◾ ◾ ◾ ◾ Material Stainless steel Free-standing and bayed enclosures in more than 140 variants for controlgear production and plant manufacturing. Exceptionally robust and with a high IP and IK protection class, Rittal small and compact enclosures are compliant with all major international approvals and standards. Infinite installation opportunities, simple assembly, uncompromising baying and tested quality are the distinguishing features of these enclosure systems. QR codes on all machinable components. Dimension variants Product characteristics From page 40 ◾ More than 145 small enclosures and 190 compact enclosures in a range of individual materials and designs. 43, 227 73, 227 99, 227 Rittal System Catalogue 36/Enclosures Enclosures Enclosures Console systems PC enclosure systems Industrial Workstations Versatility through modularity – essential for meeting individual customer requirements for machine and plant operation perfectly and cost-effectively. Operating housings Support arm systems Stand systems Always exactly the right position: Different viewing angles of the machine, tall or short operating staff – your ergonomic solution at the human/machine interface can be found here. Hygienic Design Hygienic Design (HD) enclosures are key elements in the design of open processes for the food industry and clean rooms, due to their ease of cleaning. – – – – – – – – – – ◾ – – – ◾ ◾ ◾ ◾ ◾ ◾ – ◾ ◾ – ◾ ◾ – ◾ Choose from console systems in over 30 combination variants, 8 PC enclosure systems and 13 variants of Industrial Workstations. With over 30 operating housings, 5 support arm systems with a wide range of combination options and 8 stand systems, there is a solution for every requirement. 18 different enclosure types and sizes. Robust and modular, especially designed for tough industrial environments where a high protection category and good accessibility are key. Flexibility, stability, simple assembly and tremendous versatility with product combinations mean that every requirement is catered for. The range is based on common European standards, directives and regulations in the food and luxury goods industry. 169, 227 217 149, 227 Rittal System Catalogue 36/Enclosures 41 42 Rittal System Catalogue 36/Enclosures Small enclosures Polycarbonate enclosures PK Enclosures Without knockout .........................................................................................44 With knockout ..............................................................................................46 Accessories ..................................................................................................47 Cast aluminium enclosures GA Cast aluminium enclosures GA .................................................................... 48 Accessories ..................................................................................................49 Small enclosures KX Product comparison .....................................................................................50 Product overview..........................................................................................52 Terminal boxes KX Product advantages .....................................................................................54 Without gland plate.......................................................................................56 With gland plate............................................................................................59 E-Box KX Product advantages .....................................................................................62 Depth 80 mm ...............................................................................................64 Depth 120 mm .............................................................................................66 Depth 155 mm .............................................................................................67 Bus enclosures KX Product advantages .....................................................................................68 Bus enclosures KX .......................................................................................70 Rittal System Catalogue 36/Enclosures 43 Polycarbonate enclosures PK PK accessories Page 47  System accessories Page 877  Cable gland, polyamide Page 1056   Applications: – Ambient temperature range: -35 °C...+80 °C – The specified temperatures may be limited by the installed equipment Material: – Enclosure: Fibreglassreinforced polycarbonate – Cover grey: Fibreglass-reinforced polycarbonate, all-round foamed-in PU seal – Cover transparent: Polycarbonate, all-round foamed-in PU seal – Cover screws: Polyamide – Insulating bungs: Polyethylene Supply includes: – Enclosure with cover – Cover screws – Insulating bungs for wall mounting screws Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 66 Protection category NEMA: – NEMA 4X Approvals: – UL – cUL – DNV-GL without knockouts Width mm 65 94 94 94 110 110 Height mm 65 65 94 94 110 110 Depth mm 57 57 57 81 66 90 Model No. 9500.000 9502.000 9504.000 9505.000 9506.000 9507.000 12 pc(s). 8 pc(s). 6 pc(s). 6 pc(s). 6 pc(s). 6 pc(s). ◾ ◾ ◾ ◾ ◾ ◾ Packs of Cover grey Page Accessories Mounting plate – – – – – – Hinge – – – – – – 9583.000 9583.000 9583.000 9583.000 9583.000 9583.000 47 Width mm 130 130 130 130 180 180 Page Height mm 94 94 130 130 94 94 Wall mounting bracket 40 pc(s). without knockouts Depth mm 57 81 75 99 57 81 Model No. 9508.000 9509.000 9510.000 9511.000 9512.000 9513.000 4 pc(s). 4 pc(s). 4 pc(s). 4 pc(s). 2 pc(s). 2 pc(s). ◾ ◾ ◾ ◾ ◾ ◾ Packs of Cover grey Accessories Mounting plate – – – – – – Hinge – – – – – – 9583.000 9583.000 9583.000 9583.000 9583.000 9583.000 Wall mounting bracket 44 40 pc(s). Further technical information available on the Internet. 47 Rittal System Catalogue 36/Enclosures Polycarbonate enclosures PK without knockouts Packs of Height mm Depth mm Model No. Cover 2 pc(s). 180 180 180 180 180 180 110 110 110 110 110 110 90 90 111 111 165 165 9514.000 9514.100 9515.000 9515.100 9516.000 9516.100 grey ◾ – ◾ – ◾ – transparent – ◾ – ◾ – ◾ Page Enclosures Width mm Accessories Mounting plate – – – – – – Hinge 20 pc(s). 9581.000 9581.000 9581.000 9581.000 9581.000 9581.000 47 Wall mounting bracket 40 pc(s). 9583.000 9583.000 9583.000 9583.000 9583.000 9583.000 47 Packs of 182 182 182 182 182 182 Page 180 180 180 180 180 180 without knockouts Width mm Height mm Depth mm Model No. Cover 1 pc(s). 90 90 111 111 165 165 9517.000 9517.100 9518.000 9518.100 9519.000 9519.100 grey ◾ – ◾ – ◾ – transparent – ◾ – ◾ – ◾ Accessories Mounting plate 10 pc(s). 9548.000 9548.000 9548.000 9548.000 9548.000 9548.000 47 Hinge 20 pc(s). 9581.000 9581.000 9581.000 9581.000 9581.000 9581.000 47 Wall mounting bracket 40 pc(s). 9583.000 9583.000 9583.000 9583.000 9583.000 9583.000 47 Packs of 254 254 254 254 254 254 Page 180 180 180 180 180 180 without knockouts Width mm Height mm Depth mm Model No. Cover 1 pc(s). 90 90 111 111 165 165 9520.000 9520.100 9521.000 9521.100 9522.000 9522.100 grey ◾ – ◾ – ◾ – transparent – ◾ – ◾ – ◾ Accessories Mounting plate 8 pc(s). 9549.000 9549.000 9549.000 9549.000 9549.000 9549.000 47 Hinge 20 pc(s). 9581.000 9581.000 9581.000 9581.000 9581.000 9581.000 47 Wall mounting bracket 40 pc(s). 9583.000 9583.000 9583.000 9583.000 9583.000 9583.000 47 without knockouts Width mm Packs of Height mm Depth mm Model No. Cover 1 pc(s). 360 360 360 360 254 254 254 254 111 111 165 165 9523.000 9523.100 9524.000 9524.100 grey ◾ – ◾ – transparent – ◾ – ◾ Page Accessories Mounting plate 4 pc(s). 9550.000 9550.000 9550.000 9550.000 Hinge 20 pc(s). 9581.000 9581.000 9581.000 9581.000 47 Wall mounting bracket 40 pc(s). 9583.000 9583.000 9583.000 9583.000 47 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 47 45 Polycarbonate enclosures PK PK accessories Page 47  System accessories Page 877  Cable gland, polyamide Page 1056   Applications: – Ambient temperature range: -35 °C...+80 °C – The specified temperatures may be limited by the installed equipment Material: – Enclosure: Fibreglassreinforced polycarbonate – Cover: Fibreglass-reinforced polycarbonate, all-round foamed-in PU seal – Cover screws: Polyamide – Insulating bungs: Polyethylene Protection category IP to IEC 60 529: – IP 66 Protection category NEMA: – NEMA 4X Approvals: – UL – cUL – DNV-GL Supply includes: – Enclosure with cover – Cover screws – Insulating bungs for wall mounting screws Colour: – RAL 7035 with knockouts Width mm 130 180 254 Height mm 94 110 180 Depth mm 57 90 111 Model No. 9508.050 9514.050 9521.050 4 pc(s). 2 pc(s). 1 pc(s). ◾ ◾ ◾ 10 x M16/M20 16 x M20 2 x M20/M25 2 x M32/M40 24 x M20 4 x M25/M32 4 x M32/M40 Packs of Cover grey No. of metric knockouts Page Accessories Mounting plate 8 pc(s). – – 9549.000 47 Wall mounting bracket 40 pc(s). 9583.000 9583.000 9583.000 47 46 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Polycarbonate enclosures PK Accessories Mounting plate Enclosures for PK For individual interior installation. Material: – 2.5 mm melamine phenol-coated laminated paper Colour: – RAL 7035 Supply includes: – Mounting plate – Self-tapping assembly screws Mounting plate width mm Mounting plate height mm For enclosure width mm For enclosure height mm Packs of Model No. 150 150 182 180 10 pc(s). 9548.000 220 150 254 180 8 pc(s). 9549.000 331 220 360 254 4 pc(s). 9550.000 Hinge for PK For hinged attachment of covers. The supplied drilling template ensures problem-free assembly. For For enclosure enclosure width mm height mm ≥ 180 ≥ 110 Material Polystyrene Packs of Model No. 20 pc(s). 9581.000 Material: – Polystyrene Colour: – Similar to RAL 7035 Supply includes: – 20 hinges – Assembly parts Wall mounting bracket Packs of Model No. for PK The enclosure can be screwed to the wall using four wall mounting brackets. The bracket is securely attached to the enclosure by means of pins. 40 pc(s). 9583.000 Applications: – For all PK enclosures Material: – Polyamide, grey Colour: – Similar to RAL 7035 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 47 Cast aluminium enclosures GA GA accessories Page 49  System accessories Page 877   Material: – Enclosure: Cast aluminium – Cover: Cast aluminium, allround CR cellular rubber cord seal Surface finish: – Textured paint Colour: – RAL 7001 Protection category IP to IEC 60 529: – IP 66 Protection category NEMA: – NEMA 4 Supply includes: – Enclosure with cover – Cover screws, captive – Screws for attaching support rails – Screw for connection of the PE conductor Width mm 58 98 75 125 175 250 122 220 Height mm 64 64 80 80 80 80 120 120 Depth mm 36 36 58 58 58 58 82 93 Model No. 9101.210 9102.210 9104.210 9105.210 9106.210 9107.210 9108.210 9110.210 5 pc(s). 3 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). Packs of Page Accessories Mounting plate Wall mounting bracket – – – 9105.700 – – 9108.700 9110.700 Packs of – – – 10 pc(s). – – 2 pc(s). 2 pc(s). – 2 pc(s). – – – – – – 9121.122 9121.122 49 see page see page see page see page see page see page see page see page 997 – – – – – – 9123.000 9123.000 49 see page see page see page see page see page see page see page see page 1033 Support rail Hinge, exterior 2 pc(s). Earth straps 49 Cable gland, brass see page see page see page see page see page see page see page see page 1056 Cable gland, polyamide see page see page see page see page see page see page see page see page 1056 360 160 260 360 202 280 330 330 Page 120 160 160 160 232 232 230 230 Width mm Packs of Height mm Depth mm Model No. 1 pc(s). 84 93 93 93 113 113 113 183 9111.210 9112.210 9113.210 9114.210 9116.210 9117.210 9118.210 9119.210 Accessories Mounting plate Wall mounting bracket – 9112.700 9113.700 – 9116.700 9117.700 9118.700 9118.700 Packs of – 2 pc(s). 2 pc(s). – 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). – 2 pc(s). 9121.122 9121.160 9121.160 9121.160 9121.230 9121.230 9121.230 9121.230 49 see page see page see page see page see page see page see page see page 997 2 pc(s). 9123.000 9123.000 9123.000 9123.000 9123.000 9123.000 9123.000 9123.000 49 see page see page see page see page see page see page see page see page 1033 Support rail Hinge, exterior Earth straps 49 Cable gland, brass see page see page see page see page see page see page see page see page 1056 Cable gland, polyamide see page see page see page see page see page see page see page see page 1056 48 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Cast aluminium enclosures GA Accessories Mounting plate Enclosures for GA For universal interior installation, with mounting holes. Material: – Sheet steel Surface finish: – Zinc-plated Mounting plate width mm Mounting plate height mm For enclosure width mm For enclosure height mm Packs of Model No. 114 69 125 80 10 pc(s). 9105.700 109 107 122 120 2 pc(s). 9108.700 207 107 220 120 2 pc(s). 9110.700 145 142 160 160 2 pc(s). 9112.700 245 142 260 160 2 pc(s). 9113.700 183 214 202 232 1 pc(s). 9116.700 264 214 280 232 1 pc(s). 9117.700 314 214 330 230 1 pc(s). 9118.700 Wall mounting bracket For enclosure height mm Packs of Model No. 120 2 pc(s). 9121.122 160 2 pc(s). 9121.160 ≥ 230 2 pc(s). 9121.230 for GA For external mounting on surfaces – no need to remove the cover if pre-assembled. Material: – Sheet steel Surface finish: – Zinc-plated Hinge, exterior for GA For attaching the cover to the enclosure base. For enclosure height mm For enclosure depth mm Packs of Model No. ≥ 120 ≥ 80 2 pc(s). 9123.000 Material: – Die-cast aluminium Colour: – RAL 7001 Supply includes: – 2 hinges – 8 screws Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 49 Small enclosures KX – Product comparison Terminal boxes KX, sheet steel Terminal boxes KX, stainless steel E-Box KX, sheet steel All enclosure panels may be taken directly from the packaging, without dismantling, and machined The support rails may optionally be fitted on the integral perforated mounting strip or, to maximise the enclosure depth, directly onto the rear wall of the enclosure The mounting plate is simply attached from the front and secured to the integral perforated mounting strip in a space-saving solution The wall mounting brackets are easily secured from the outside with a selftapping screw The wall mounting brackets are easily secured from the outside with a selftapping screw There is no opening to the wall mounting for hygiene reasons, but the position is prepunched and can be drilled without having to measure and mark out A QR code on the enclosure, door or cover and mounting plate allows seamless monitoring, from receipt of the incoming goods through to delivery of the finished product Earthing points accessible from the front facilitate fast, secure mounting of the earth straps The mini cam lock may be fitted without using tools, and ensures that the cover is securely seated and centred when latching The 180° hinges are already prefitted on the door and ready to use, the cam locks may be attached without the use of tools, and the door is easily fitted The three-phase surface treatment provides optimum protection against corrosion and is resistant to mineral oils, lubricants, machining emulsions and many solvents Stainless steel 1.4301 (AISI 304) complies with maximum hygiene and corrosion protection requirements The three-phase surface treatment provides optimum protection against corrosion and is resistant to mineral oils, lubricants, machining emulsions and many solvents from page 56 from page 230 from page 64 50 Rittal System Catalogue 36/Enclosures Enclosures Small enclosures KX – Product comparison E-Box KX, stainless steel Bus enclosures KX, sheet steel Bus enclosures KX, stainless steel All enclosure panels may be taken directly from the packaging, without dismantling, and machined The mounting plate is simply attached from the front and secured to the integral perforated mounting strip in a space-saving solution The support rails may optionally be fitted on the integral perforated mounting strip or, to maximise the enclosure depth, directly onto the rear wall of the enclosure There is no opening to the wall mounting for hygiene reasons, but the position is prepunched and can be drilled without having to measure and mark out The wall mounting brackets are easily secured from the outside with a selftapping screw There is no opening to the wall mounting for hygiene reasons, but the position is prepunched and can be drilled without having to measure and mark out A QR code on the enclosure, door or cover and mounting plate allows seamless monitoring, from receipt of the incoming goods through to delivery of the finished product Earthing points accessible from the front facilitate fast, secure mounting of the earth straps The 180° hinges are prefitted on the door/cover and ready to use, the cam locks may be attached without the use of tools, and the door/cover is easily fitted Stainless steel 1.4301 (AISI 304) and stainless steel 1.4404 (AISI 316L), meets maximum hygiene and corrosion protection requirements The three-phase surface treatment provides optimum protection against corrosion and is resistant to mineral oils, lubricants, machining emulsions and many solvents Stainless steel 1.4301 (AISI 304) meets maximum hygiene and corrosion protection requirements from page 232 from page 70 from page 234 Rittal System Catalogue 36/Enclosures 51 Small enclosures KX – Product overview Terminal boxes KX Height x depth mm Width mm Model No. Material Sheet steel Sheet steel Stainless steel Version Without gland plate With gland plate Without gland plate 1514.000 – 1560.000 1528.000 – – 1515.000 – 1561.000 150 1500.000 – 1564.000 200 1529.000 – – 1501.000 1530.000 – 150 200 150 x 80 300 300 150 x 120 400 1589.000 – – 200 1516.000 – 1562.000 1563.000 300 200 x 80 1517.000 – 400 1518.000 – – 200 1502.000 – 1565.000 300 1503.000 1531.000 1566.000 400 1504.000 1532.000 1568.000 – 500 200 x 120 1505.000 1533.000 600 1506.000 – – 800 1527.000 – – 400 150 200 200 x 155 300 x 80 150 – – – – – – – – – – – – 200 – – – 300 1507.000 1535.000 1567.000 400 300 x 120 1508.000 1536.000 1569.000 500 1509.000 1537.000 – 600 1510.000 1538.000 – 200 – – – 300 – – – 380 – – – – – – – – – – – – – – – 400 300 x 155 600 800 200 400 x 80 200 – – – 300 – – – 1511.000 1539.000 – 1512.000 1540.000 – 400 400 x 120 600 800 1513.000 1541.000 – 300 400 x 155 – – – 200 500 x 120 – – – 300 600 x 155 – – – 300 800 x 155 from page 52 Model No. – – – 56 59 230 Rittal System Catalogue 36/Enclosures Enclosures Small enclosures KX – Product overview E-Box KX Bus enclosures KX Model No. Model No. Width mm Sheet steel – – – – – 150 1551.000 – – – – Stainless steel 1.4301 (AISI 304) Stainless steel 1.4404 (AISI 316L) Sheet steel Stainless steel 200 – – – – – 300 – – – – – 150 1553.000 – – – – 200 – – – – – 300 – – – – – 400 – – – – – 200 1546.000 – – – – 300 – – – – – 400 – – – – – 200 1549.000 – – – – 300 – – – – – 400 – – – – 1585.000 500 – – – – – 600 – – – – 1586.000 800 – – – – – – – 1610.000 – 400 150 1545.000 – – – – 200 1552.000 – – – 1583.000 – – – 1584.000 – – – 150 1548.000 200 1554.000 300 1555.000 – – – – 400 – – – – – 500 – – – – – 600 – – – – – 200 1574.000 1587.000 1301.000 – – 300 1575.000 – – – – 380 1576.000 1588.000 – – – 400 – – – 1611.000 – 600 – – – 1612.000 – 800 – – – 1613.000 – 200 1547.000 – – – – 200 1550.000 – – – – 300 1556.000 – – – – 400 – – – – – 600 – – – – – 800 – – – – – 300 1577.000 – – – – 200 1557.000 – – – – 300 1578.000 – – – – 300 1579.000 – – – – 64 232 232 70 234 Rittal System Catalogue 36/Enclosures 53 Terminal boxes boxes KX Terminal KX – Added precision 54 Rittal System Catalogue 36/Enclosures Precision Enclosures ◾ The mini cam lock is very simple to operate. A quarter of a turn is sufficient to correctly centre the cover while locking; this ensures all-round air-tight positioning. Ease of assembly ◾ The standard eyelet in the rear panel allows rapid screw-fastening of the wall mounting bracket from the outside with a self-tapping screw; no need for a lock nut on the inside. The high protection category is retained in full. Space utilisation ◾ The support rails may optionally be fitted on the front of the integral perforated mounting strip or, to maximise the enclosure depth, directly onto the rear wall of the enclosure. Potential equalisation ◾ Installation of the gland plate includes automatic potential equalisation. Contact is made by two self-tapping screws guided through special holes. Rittal System Catalogue 36/Enclosures 55 Small enclosures KX System accessories Page 877 Terminal boxes KX, stainless steel Page 230 Ex enclosures Page 257 Hygienic Design Page 217 Material: – Enclosure: Sheet steel – Cover: Sheet steel, all-round foamed-in PU seal Surface finish: – Enclosure and cover: Dipcoat primed, powder-coated on the outside, textured paint Protection category IP to IEC 60 529: – IP 66 NEMA protection category: – NEMA 4 Approvals: – UL – cUL Further approvals can be found on the Internet. Supply includes: – Enclosure with cover – Mini cam locks Colour: – RAL 7035 Terminal boxes KX, sheet steel, without gland plate Width mm Packs of Height mm Depth mm Material thickness of enclosure mm Material thickness of cover mm Model No. 1 pc(s). Weight kg Mini cam lock 150 200 200 300 300 400 150 150 200 150 200 200 80 80 80 80 80 80 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1514.000 1528.000 1516.000 1515.000 1517.000 1518.000 1.40 1.45 1.80 1.90 2.39 3.01 4 4 4 4 4 4 Page Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Mounting plates 1 pc(s). 1560.800 1575.800 1562.800 1561.800 1563.800 1564.800 970 Support rails TS 35/7.5 10 pc(s). 2314.000 2315.000 2315.000 2316.000 2316.000 2317.000 997 – – – – – – Support rails TS 35/15 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2365.000 2365.000 2365.000 2365.000 2365.000 2365.000 1002 Mounting claw for second mounting level 20 pc(s). 2309.100 2309.100 2309.100 2309.100 2309.100 2309.100 998 Cover hinge 6 pc(s). 1592.200 1592.200 1592.200 1592.200 1592.200 1592.200 951 Earth straps 5 pc(s). 2565.100 2565.100 2565.100 2565.100 2565.100 2565.100 1033 – – – – – – Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 1047 Baying kit Self-tapping screws Connector gland, small 56 Further technical information available on the Internet. 997 900 Rittal System Catalogue 36/Enclosures Small enclosures KX Terminal boxes KX, sheet steel, without gland plate Packs of Height mm 150 200 200 300 300 150 150 200 150 200 Depth mm 120 120 120 120 120 Material thickness of enclosure mm 1.25 1.25 1.25 1.25 1.25 Material thickness of cover mm Model No. 1 pc(s). Weight kg 1.25 1.25 1.25 1.25 1.25 1500.000 1529.000 1502.000 1501.000 1503.000 1.46 1.75 2.13 2.32 2.69 4 4 4 4 4 Mini cam lock Page Enclosures Width mm Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 968 Mounting plates 1 pc(s). 1560.800 1575.800 1562.800 1561.800 1563.800 970 Support rails TS 35/7.5 10 pc(s). 2314.000 2315.000 2315.000 2316.000 2316.000 997 – – – – – Support rails TS 35/15 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 2309.000 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2366.000 2366.000 2366.000 2366.000 2366.000 1002 Mounting claw for second mounting level 20 pc(s). 2309.100 2309.100 2309.100 2309.100 2309.100 998 Cover hinge 6 pc(s). 1592.200 1592.200 1592.200 1592.200 1592.200 951 Earth straps 5 pc(s). 2565.050 2565.050 2565.050 2565.050 2565.050 1033 Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 916 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 2400.500 1047 Self-tapping screws Connector gland, small 997 Terminal boxes KX, sheet steel, without gland plate Width mm Packs of Height mm 300 400 400 400 400 500 300 150 200 300 400 200 Depth mm 120 120 120 120 120 120 Material thickness of enclosure mm 1.25 1.25 1.25 1.25 1.25 1.25 Material thickness of cover mm Model No. 1 pc(s). Weight kg Mini cam lock 1.25 1.25 1.25 1.25 1.25 1.25 1507.000 1589.000 1504.000 1508.000 1511.000 1505.000 3.78 2.98 3.42 4.70 5.67 4.18 4 4 4 4 4 4 Page Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Mounting plates 1 pc(s). 1567.800 1576.800 1564.800 1568.800 1571.800 1565.800 970 Support rails TS 35/7.5 10 pc(s). 2316.000 2317.000 2317.000 2317.000 2317.000 – 997 Support rails TS 35/15 10 pc(s). – – – – – 2318.000 997 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 997 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2366.000 2366.000 2366.000 2366.000 2366.000 2366.000 1002 Mounting claw for second mounting level 20 pc(s). 2309.100 2309.100 2309.100 2309.100 2309.100 2309.100 998 Cover hinge 6 pc(s). 1592.200 1592.200 1592.200 1592.200 1592.200 1592.200 951 Earth straps 5 pc(s). 2565.050 2565.050 2565.050 2565.050 2565.050 2565.050 1033 Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 1047 Self-tapping screws Connector gland, small Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 57 Small enclosures KX Terminal boxes KX, sheet steel, without gland plate Width mm Packs of Height mm 500 600 600 600 800 800 300 200 300 400 200 400 Depth mm 120 120 120 120 120 120 Material thickness of enclosure mm 1.25 1.25 1.25 1.25 1.25 1.25 Material thickness of cover mm Model No. 1 pc(s). Weight kg Mini cam lock 1.25 1.25 1.25 1.25 1.25 1.25 1509.000 1506.000 1510.000 1512.000 1527.000 1513.000 5.57 4.92 6.28 8.35 6.45 11.00 4 6 6 6 6 6 Page Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Mounting plates 1 pc(s). 1569.800 1566.800 1570.800 1572.800 1574.800 1573.800 970 – – – – – – Support rails TS 35/7.5 Support rails TS 35/15 10 pc(s). 2318.000 2319.000 2319.000 2319.000 – – 997 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 997 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2366.000 2366.000 2366.000 2366.000 2366.000 2366.000 1002 Mounting claw for second mounting level 20 pc(s). 2309.100 2309.100 2309.100 2309.100 2309.100 2309.100 998 Cover hinge 6 pc(s). 1592.200 1592.200 1592.200 1592.200 1592.200 1592.200 951 Earth straps 5 pc(s). 2565.050 2565.050 2565.050 2565.050 2565.050 2565.050 1033 Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 1047 Self-tapping screws Rittal – The System. Connector gland, small 58 Perforex BC milling centre see page 652 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Enclosures Small enclosures KX System accessories Page 877 Terminal boxes KX, stainless steel Page 230 Ex enclosures Page 257 Hygienic Design Page 217 Material: – Enclosure: Sheet steel – Cover: Sheet steel, all-round foamed-in PU seal Surface finish: – Enclosure and cover: Dipcoat primed, powder-coated on the outside, textured paint Supply includes: – Enclosure with cover – Mini cam locks – Sheet steel gland plates with seals and assembly parts Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Approvals: – UL – cUL Further approvals can be found on the Internet. NEMA protection category: – NEMA 12 Terminal boxes KX, sheet steel, with gland plate Width mm Packs of Height mm 300 300 300 400 400 400 500 150 200 300 200 300 400 200 Depth mm 120 120 120 120 120 120 120 Material thickness of enclosure mm 1.25 1.25 1.25 1.25 1.25 1.25 1.25 Material thickness of cover mm Model No. 1 pc(s). Weight kg Mini cam lock Gland plate (top + bottom), quantity Gland plate (left + right), quantity 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1530.000 1531.000 1535.000 1532.000 1536.000 1539.000 1533.000 2.62 3.12 4.47 3.82 5.40 6.61 4.73 4 4 4 4 4 4 4 1+1 1+1 1+1 1+1 1+1 1+1 2+2 – – 1+1 – 1+1 1+1 – Page Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Mounting plates 1 pc(s). 1561.800 1563.800 1567.800 1564.800 1568.800 1571.800 1565.800 970 Support rails TS 35/7.5 10 pc(s). 2316.000 2316.000 2316.000 2317.000 2317.000 2317.000 – 997 – – – – – – – Support rails TS 35/15 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2366.000 2366.000 2366.000 2366.000 2366.000 2366.000 2366.000 1002 Mounting claw for second mounting level 20 pc(s). 2309.100 2309.100 2309.100 2309.100 2309.100 2309.100 2309.100 998 Cover hinge 6 pc(s). 1592.200 1592.200 1592.200 1592.200 1592.200 1592.200 1592.200 951 Metal gland plates 1 pc(s). 1581.200 1581.200 1581.200 1581.200 1581.200 1581.200 1581.200 1054 Earth straps 5 pc(s). 2565.050 2565.050 2565.050 2565.050 2565.050 2565.050 2565.050 1033 Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 1047 Self-tapping screws Connector gland, small Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 997 59 Small enclosures KX Terminal boxes KX, sheet steel, with gland plate Width mm Packs of Height mm 500 600 600 800 300 300 400 400 Depth mm 120 120 120 120 Material thickness of enclosure mm 1.25 1.25 1.25 1.25 Material thickness of cover mm 1.25 1.25 1.25 1.25 1537.000 1538.000 1540.000 1541.000 6.01 7.02 9.32 11.10 4 6 6 6 Gland plate (top + bottom), quantity 2+2 2+2 2+2 3+3 Gland plate (left + right), quantity 1+1 1+1 1+1 1+1 Model No. 1 pc(s). Weight kg Mini cam lock Page Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 968 Mounting plates 1 pc(s). 1569.800 1570.800 1572.800 1573.800 970 – – – – Support rails TS 35/7.5 Support rails TS 35/15 10 pc(s). 2318.000 2319.000 2319.000 – 997 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 997 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2366.000 2366.000 2366.000 2366.000 1002 Mounting claw for second mounting level 20 pc(s). 2309.100 2309.100 2309.100 2309.100 998 Cover hinge 6 pc(s). 1592.200 1592.200 1592.200 1592.200 951 Metal gland plates 1 pc(s). 1581.200 1581.200 1581.200 1581.200 1054 Earth straps 5 pc(s). 2565.050 2565.050 2565.050 2565.050 1033 Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 916 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 1047 Self-tapping screws Rittal – The System. Connector gland, small 60 Wall mounting bracket see page 966 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures UL conformity Enclosures Guaranteed when Rittal accessory components are used Rittal System Catalogue 36/Enclosures 61 E-Box KX E-Box KX – Added time savings 62 Rittal System Catalogue 36/Enclosures Protection Enclosures ◾ The deliberately slimline enclosure edge fold provides broad, secure contact with the seamless PU foam seal and helps preserve the protection category of IP 66. Space ◾ The 180° door hinges create more space and improve access to the enclosure interior. Ease of assembly ◾ The standard eyelet in the rear panel allows rapid screw-fastening of the wall mounting bracket from the outside with a self-tapping screw; no need for a lock nut on the inside. The high protection category is retained in full. Speed ◾ The mounting plate and door may be taken straight from the packet and are ready for processing. Rittal System Catalogue 36/Enclosures 63 Small enclosures KX System accessories Page 877 E-Box KX, stainless steel Page 232 Ex enclosures Page 257 Colour: – RAL 7035 64 F T Protection category NEMA: – NEMA 4 Supply includes: – Enclosure with door – Mounting plate – Cam lock with 3 mm double-bit insert Approvals: – UL – cUL Further approvals can be found on the Internet. Further technical information available on the Internet. G Surface finish: – Enclosure and door: Dipcoatprimed, powder-coated on the outside, textured paint – Mounting plate: Zinc-plated Protection category IP to IEC 60 529: – IP 66 H Material: – Enclosure: Sheet steel – Door: Sheet steel, all-round foamed-in PU seal B Rittal System Catalogue 36/Enclosures Small enclosures KX E-Box KX, sheet steel, depth 80 mm Packs of Height (H) mm 150 150 200 200 200 150 300 200 300 400 Depth (T) mm 80 80 80 80 80 Mounting plate width (F) mm 125 125 175 175 175 Mounting plate height (G) mm 135 285 185 285 385 Material thickness – enclosure mm 1.25 1.25 1.25 1.25 1.25 Material thickness – door mm 1.25 1.25 1.25 1.25 1.25 Material thickness – mounting plate mm 2.0 2.0 2.0 2.0 2.0 1551.000 1545.000 1546.000 1552.000 1547.000 1.49 2.54 2.26 3.18 4.15 Model No. 1 pc(s). Weight kg Page Enclosures Width (B) mm Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 968 Support rails TS 35/7.5 10 pc(s). 2314.000 2314.000 2315.000 2315.000 2315.000 997 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 2309.000 997 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2365.000 2365.000 2365.000 2365.000 2365.000 1002 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 2537.100 2537.100 940 Mini-comfort handle AX for padlocks and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 2537.300 2537.300 940 Lock insert 7 mm square 1 pc(s). 2460.000 2460.000 2460.000 2460.000 2460.000 941 Lock insert 8 mm square 1 pc(s). 2461.000 2461.000 2461.000 2461.000 2461.000 941 Lock insert 7 mm triangular 1 pc(s). 2462.000 2462.000 2462.000 2462.000 2462.000 941 Lock insert 8 mm triangular 1 pc(s). 2463.000 2463.000 2463.000 2463.000 2463.000 941 Lock insert, screwdriver 1 pc(s). 2464.000 2464.000 2464.000 2464.000 2464.000 941 Lock insert Daimler 1 pc(s). 2465.000 2465.000 2465.000 2465.000 2465.000 941 Lock insert 3 mm double-bit 1 pc(s). 2466.000 2466.000 2466.000 2466.000 2466.000 941 Lock insert Fiat 1 pc(s). 2307.000 2307.000 2307.000 2307.000 2307.000 941 Lock insert 6.5 mm triangular 1 pc(s). 2460.650 2460.650 2460.650 2460.650 2460.650 941 Earth straps 5 pc(s). 2565.100 2565.100 2565.100 2565.100 2565.100 1033 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 2400.500 1047 Self-tapping screws Rittal – The System. Connector gland, small Rittal System Catalogue 36/Enclosures Mini-comfort handle AX see page 940 Further technical information available on the Internet. 65 Small enclosures KX E-Box KX, sheet steel, depth 120 mm Width (B) mm 150 150 200 200 200 200 300 300 Height (H) mm Packs of 150 300 200 300 400 500 300 400 Depth (T) mm 120 120 120 120 120 120 120 120 Mounting plate width (F) mm 125 125 175 175 175 175 275 275 Mounting plate height (G) mm 135 285 185 285 385 485 285 385 Material thickness – enclosure mm 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 Material thickness – door mm 1.25 1.25 1.25 1.25 1.25 1.25 1.25 1.25 Material thickness – mounting plate mm 2.0 2.0 2.0 2.0 2.0 2.0 2.0 2.0 Model No. 1 pc(s). Weight kg Page 1553.000 1548.000 1549.000 1554.000 1550.000 1557.000 1555.000 1556.000 1.72 2.93 2.64 3.63 4.62 5.57 5.14 6.38 Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Support rails TS 35/7.5 10 pc(s). 2314.000 2314.000 2315.000 2315.000 2315.000 2315.000 2316.000 2316.000 997 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 997 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2366.000 2366.000 2366.000 2366.000 2366.000 2366.000 2366.000 2366.000 1002 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 2537.100 2537.100 2537.100 2537.100 2537.100 940 Mini-comfort handle AX for padlocks and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 2537.300 2537.300 2537.300 2537.300 2537.300 940 Lock insert 7 mm square 1 pc(s). 2460.000 2460.000 2460.000 2460.000 2460.000 2460.000 2460.000 2460.000 941 Lock insert 8 mm square 1 pc(s). 2461.000 2461.000 2461.000 2461.000 2461.000 2461.000 2461.000 2461.000 941 Lock insert 7 mm triangular 1 pc(s). 2462.000 2462.000 2462.000 2462.000 2462.000 2462.000 2462.000 2462.000 941 Lock insert 8 mm triangular 1 pc(s). 2463.000 2463.000 2463.000 2463.000 2463.000 2463.000 2463.000 2463.000 941 Lock insert, screwdriver 1 pc(s). 2464.000 2464.000 2464.000 2464.000 2464.000 2464.000 2464.000 2464.000 941 Lock insert Daimler 1 pc(s). 2465.000 2465.000 2465.000 2465.000 2465.000 2465.000 2465.000 2465.000 941 Lock insert 3 mm double-bit 1 pc(s). 2466.000 2466.000 2466.000 2466.000 2466.000 2466.000 2466.000 2466.000 941 Lock insert Fiat 1 pc(s). 2307.000 2307.000 2307.000 2307.000 2307.000 2307.000 2307.000 2307.000 941 Lock insert 6.5 mm triangular 1 pc(s). 2460.650 2460.650 2460.650 2460.650 2460.650 2460.650 2460.650 2460.650 941 Earth straps 5 pc(s). 2565.050 2565.050 2565.050 2565.050 2565.050 2565.050 2565.050 2565.050 1033 Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 1004 Self-tapping screws 5 pc(s). 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 Rittal – The System. Connector gland, small 66 1047 Wall mounting bracket see page 966 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Small enclosures KX E-Box KX, sheet steel, depth 155 mm 200 300 300 300 300 380 Height (H) mm 300 300 400 600 800 300 Depth (T) mm 155 155 155 155 155 155 Mounting plate width (F) mm 175 275 275 275 275 365 Mounting plate height (G) mm 285 285 385 585 785 275 Material thickness – enclosure mm 1.25 1.25 1.25 1.25 1.25 1.25 Material thickness – door mm 1.25 1.25 1.25 1.25 1.25 1.25 Material thickness – mounting plate mm 2.0 2.0 2.0 2.0 2.0 2.0 1574.000 1575.000 1577.000 1578.000 1579.000 1576.000 3.98 5.50 6.98 10.30 12.80 6.64 Model No. Packs of 1 pc(s). Weight kg Page Enclosures Width (B) mm Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Support rails TS 35/7.5 10 pc(s). 2315.000 2316.000 2316.000 2316.000 2316.000 2317.0001) 997 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 2309.000 2309.000 997 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2366.000 2366.000 2366.000 2366.000 2366.000 2366.000 1002 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 2537.100 2537.100 2537.100 940 Mini-comfort handle AX for padlocks and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 2537.300 2537.300 2537.300 940 Lock insert 7 mm square 1 pc(s). 2460.000 2460.000 2460.000 2460.000 2460.000 2460.000 941 Lock insert 8 mm square 1 pc(s). 2461.000 2461.000 2461.000 2461.000 2461.000 2461.000 941 Lock insert 7 mm triangular 1 pc(s). 2462.000 2462.000 2462.000 2462.000 2462.000 2462.000 941 Lock insert 8 mm triangular 1 pc(s). 2463.000 2463.000 2463.000 2463.000 2463.000 2463.000 941 Lock insert, screwdriver 1 pc(s). 2464.000 2464.000 2464.000 2464.000 2464.000 2464.000 941 Lock insert Daimler 1 pc(s). 2465.000 2465.000 2465.000 2465.000 2465.000 2465.000 941 Lock insert 3 mm double-bit 1 pc(s). 2466.000 2466.000 2466.000 2466.000 2466.000 2466.000 941 Lock insert Fiat 1 pc(s). 2307.000 2307.000 2307.000 2307.000 2307.000 2307.000 941 Lock insert 6.5 mm triangular 1 pc(s). 2460.650 2460.650 2460.650 2460.650 2460.650 2460.650 941 Earth straps 5 pc(s). 2565.050 2565.050 2565.050 2565.050 2565.050 2565.050 1033 Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 2459.000 2459.000 900 300 pc(s). 2487.000 2487.000 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 2400.500 2400.500 1047 Self-tapping screws Connector gland, small Must be cut to length accordingly Rittal – The System. 1) Rittal System Catalogue 36/Enclosures Sealing frame, modular see page 1048 Further technical information available on the Internet. 67 Bus enclosures KX Bus enclosures KX – Added clarity 68 Rittal System Catalogue 36/Enclosures Flexibility ◾ Depending on requirements, the enclosures may be fitted with support rails or mounting plates. Enclosures ◾ The support rails may optionally be fitted on the front of the integral perforated mounting strip or, to maximise the enclosure depth, directly onto the rear wall of the enclosure. Precision ◾ The quick-release fastener is very simple to operate. A quarter of a turn is sufficient to correctly centre the cover while locking; this ensures all-round air-tight positioning. Access ◾ The wide door opening angle of up to 180° gives you plenty of space to fit and replace modules quickly and easily. The large viewing window is convenient for continuously monitoring the components inside the enclosure. Ease of assembly ◾ The standard eyelet in the rear panel allows rapid screw-fastening of the wall mounting bracket from the outside with a self-tapping screw; no need for a lock nut on the inside. The high protection category is retained in full. Rittal System Catalogue 36/Enclosures 69 Small enclosures KX System accessories Page 877 Bus enclosures KX, stainless steel Page 234 Material: – Enclosure: Sheet steel – Cover: Sheet steel, all-round foamed-in PU seal – Viewing window: Polycarbonate, 4 mm Surface finish: – Enclosure and cover: Dipcoatprimed, powder-coated on the outside, textured paint Protection category IP to IEC 60 529: – IP 65 Protection category NEMA: – NEMA 12 Approvals: – UL – cUL Further approvals can be found on the Internet. Supply includes: – Enclosure with hinged cover – Viewing window in cover – Mini cam lock Colour: – RAL 7035 Bus enclosures KX, sheet steel Width mm Packs of Height mm 400 400 600 800 200 300 300 300 Depth mm 155 155 155 155 Material thickness – enclosure mm 1.25 1.25 1.25 1.25 Material thickness – cover mm Model No. 1 pc(s). Weight kg 1.25 1.25 1.25 1.25 1610.000 1611.000 1612.000 1613.000 2.36 4.72 5.47 7.78 Page Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel 4 pc(s). 1590.010 1590.010 1590.010 1590.010 965 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 968 Mounting plates 1 pc(s). 1564.800 1568.800 1570.800 1570.810 970 Support rails TS 35/7.5 10 pc(s). 2317.000 2317.000 2319.000 2317.000 997 Mounting clip for support rails 30 pc(s). 2309.000 2309.000 2309.000 2309.000 997 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 999 Rail mounting bracket 20 pc(s). 2366.000 2366.000 2366.000 2366.000 1002 Mounting claw for second mounting level 20 pc(s). 2309.100 2309.100 2309.100 2309.100 998 Pressure relief stopper 5 pc(s). 2459.500 2459.500 2459.500 2459.500 900 Condensate discharge 6 pc(s). 2459.000 2459.000 2459.000 2459.000 900 Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 916 Earth straps 5 pc(s). 2565.050 2565.050 2565.050 2565.050 1033 300 pc(s). 2487.000 2487.000 2487.000 2487.000 1004 5 pc(s). 2400.500 2400.500 2400.500 2400.500 1047 Self-tapping screws Connector gland, small 70 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Rittal Configuration System Enclosures Plausibility-checked configuration of products and accessories, see page 272 Configure online at www.rittal.com/configurators Rittal System Catalogue 36/Enclosures 71 72 Rittal System Catalogue 36/Enclosures Enclosures Compact enclosures Compact enclosures AX Product comparison .....................................................................................74 Product overview..........................................................................................76 Product advantages .....................................................................................78 Basic enclosures AX .....................................................................................84 Plastic enclosures AX Product comparison .....................................................................................74 Product overview..........................................................................................76 Product advantages .....................................................................................92 Without viewing window ...............................................................................94 With viewing window ....................................................................................95 Accessories ..................................................................................................96 Rittal System Catalogue 36/Enclosures 73 Compact enclosures AX – Product comparison Basic enclosure AX, single-door, sheet steel Basic enclosure AX, single door, stainless steel Basic enclosure AX, two-door, sheet steel All enclosure panels may be taken directly from the packaging, without dismantling, and machined Interior installation on a 25 mm pitch pattern; no machining required Wall mounting brackets are easily secured from the outside with a selftapping screw while retaining the UL There is no opening to the wall mounting for hygiene reasons, but the position is prepunched and can be drilled without having to measure and mark out Wall mounting brackets are easily secured from the outside with a selftapping screw while retaining the UL A QR code on the enclosure, door and mounting plate allows seamless monitoring, from receipt of the incoming goods through to delivery of the finished product Simple earthing, even retrospectively, using machined keyholes in the mounting plate, and in the case of sheet steel enclosures, in the perforated door strip For enclosures with a cam lock, the door and cam locks are rapidly fitted with no need for tools. For enclosures with 3-point locking system, the doors and locks are fully assembled. The locked door is easily relocated without machining the enclosure. Up to 33% larger gland plates support cable entry with ever-higher packing densities The fully sealed base ensures a high protection category of up to IP 66 Up to 33% larger gland plates support cable entry with ever-higher packing densities The three-phase surface treatment provides optimum protection against corrosion and is resistant to mineral oils, lubricants, machining emulsions and many solvents Stainless steel 1.4301 (AISI 304) and stainless steel 1.4404 (AISI 316L) meet maximum hygiene and corrosion protection requirements The three-phase surface treatment provides optimum protection against corrosion and is resistant to mineral oils, lubricants, machining emulsions and many solvents from page 84 from page 236 from page 84 74 Rittal System Catalogue 36/Enclosures Enclosures Compact enclosures AX – Product comparison Basic enclosure AX, two-door, sheet steel Plastic enclosure AX, without viewing window Plastic enclosure AX, with viewing window All enclosure panels may be taken directly from the packaging, without dismantling, and machined Fully preassembled enclosure Interior installation on a 25 mm pitch pattern; no machining required Numerous mounting lugs for direct mounting of punched sections and rails for interior installation on a 25 mm pitch pattern There is no opening to the wall mounting for hygiene reasons, but the position is prepunched and can be drilled without having to measure and mark out The wall mounting brackets are easily secured from the outside while retaining the UL A QR code on the enclosure, door and mounting plate allows seamless monitoring, from receipt of the incoming goods through to delivery of the finished product Simple earthing, even retrospectively, using machined keyholes in the mounting plate and perforated door strip Simple earthing of the mounting plate, even retrospectively, using machined keyholes The cam locks are rapidly fitted with no need for tools. For enclosures with a locking rod, the doors and locks are fully assembled. The door hinge is easily swapped from right to left. The integral rain protection strip on the top and bottom of the door provides a double sealing level. The standard double-bit lock insert is easily exchanged for type A lock inserts. The fully sealed base ensures a high protection category of up to IP 55 All-round cable entry is supported with the modular sealing frame and cable glands Stainless steel 1.4301 (AISI 304) and stainless steel 1.4404 (AISI 316L) meet maximum hygiene and corrosion protection requirements The enclosure is made from fibreglass-reinforced, UL-certified plastic with a high level of chemical and UV resistance, all-insulated and suitable for outdoor applications from page 236 Page 94 Rittal System Catalogue 36/Enclosures Page 95 75 Compact enclosures AX – Product overview Basic enclosures AX Height x depth mm Width mm Model No. Doors 300 380 250 1 1 – 1/◽ 1/◽ – 1033.000 1031.000 – Stainless steel 1.4301 (AISI 304) 1003.000 1011.000 – 300 380 600 600 1 1 1 1 1/◽ 1/◽ 1/◽ 1/◽ – 1380.000 1039.000 1339.000 1005.000 1006.000 1009.000 – 1302.000 1303.000 – – 300 400 300 – – – – 1 1/◽ – – 1034.000 – – – – – – 400 500 500 1 1 1 2/◽ 2/◽ 2/◽ 1045.000 1050.000 1350.000 1015.000 1007.000 1013.000 – – – 400 600 380 600 600 – – 1 1 1 – – 2/◽ 2/◽ 2/◽ – – 1038.000 1060.000 1054.000 – – 1008.000 1010.000 – – – – 1304.000 – 800 1 2/◽ 1055.000 – – 380 600 500 1 1 1 2/◽ 2/◽ 2/◽ 1338.000 1360.000 1057.000 – – – – – – 600 760 1000 760 1000 600 1 1 2 1 2 1 2/◽ 2/◽ 2/◽ 2/◽ 2/◽ 2/◽ 1076.000 1077.000 1100.000 1073.000 1130.000 1376.000 1012.000 – 1014.000 – – – – – – – – 600 1 2/◽ 1058.000 – – 400 600 600 1 – 1 2/◽ – 2/◽ 1037.000 – 1059.000 – – – – – – 600 1 2/◽ 1090.000 – – 800 1000 600 800 600 800 1000 600 800 1000 1200 1000 1 2 1 1 1 1 2 1 1 2 2 2 2/◽ 2/◽ 2/◽ 2/◽ ◾ ◾ ◾ ◾ ◾ ◾ ◾ ◾ 1180.000 1110.000 1091.000 1181.000 1260.000 1280.000 1213.000 1261.000 1281.000 1214.000 1116.000 1114.000 1016.000 1018.000 – – – 1017.000 1019.000 – – – – – – – – – – – 1305.000 – – – – – 1000 2 ◾ 1115.000 – – 84 236 236 Material Sheet steel 300 x 210 350 x 150 380 x 210 380 x 350 400 x 200 400 x 210 500 x 210 500 x 300 600 x 200 600 x 210 600 x 250 600 x 300 600 x 350 700 x 250 760 x 210 760 x 300 760 x 350 800 x 250 800 x 300 800 x 400 1000 x 250 1000 x 300 1000 x 400 1200 x 300 1200 x 400 1400 x 300 1400 x 400 Model No. Lock system from page Stainless steel 1.4404 (AISI 316L) – – – ◽ Cam lock ◾ 3-point locking system 76 Rittal System Catalogue 36/Enclosures Enclosures Compact enclosures AX – Product overview Width mm Plastic enclosures AX, without viewing window Plastic enclosures AX, with viewing window Model No. Model No. Doors Lock system Fibreglass-reinforced unsaturated polyester Fibreglass-reinforced unsaturated polyester 300 380 250 – – 1 – – 1/◽ – – 1432.000 – – – 300 380 600 600 – – – – – – – – – – – – – – – – 300 400 300 1 1 2/◽ 2/◽ 1434.000 1444.000 – 1448.000 – – – – 400 500 500 – – 1 – – 2/◽ – – 1453.000 – – 1454.000 400 600 380 600 600 1 1 – – – 2/◽ 2/◽ – – – 1446.000 1466.000 – – – 1449.000 1467.000 – – – 800 – – – – 380 600 500 – – – – – – – – – – – – 600 760 1000 760 1000 600 – – – – – – – – – – – – – – – – – – – – – – – – 600 – – – – 400 600 600 – 1 – – 2/◽ – – 1468.000 – – 1469.000 – 600 – – – – 800 1000 600 800 600 800 1000 600 800 1000 1200 1000 1 – – – – – – – – – – – 3/◽ – – – – – – – – – – – 1480.000 – – – – – – – – – – – 1479.000 – – – – – – – – – – – 1000 – – – – 94 95 ◽ Cam lock ◾ 3-point locking system Rittal System Catalogue 36/Enclosures 77 Compact enclosures AX Compact enclosures AX – Added protection 78 Rittal System Catalogue 36/Enclosures Flexibility/stability ◾ The integrated locators in the enclosure support the use of an interior installation rail for time-saving, precise installation with Rittal punched sections with mounting flanges and accessories. Enclosures ◾ The height-flexible, form-fit rail used in the continuous pattern of locators for interior installation increases stability, especially with dynamic loads. Protection ◾ The deliberately slimline enlcosure edge fold provides broad, secure contact with the seamless PU foam seal and helps preserve the protection category (up to IP 66) and protection class IK 10. Potential equalisation ◾ Special drilled holes in the gland plate ensure automatic potential equalisation during screw-fastening, which saves time and materials as well as enhancing safety. Ease of assembly ◾ The standard eyelet in the rear panel allows rapid screw-fastening of the wall mounting bracket from the outside with a self-tapping screw; no need for a lock nut on the inside. The high protection category is retained in full. Rittal System Catalogue 36/Enclosures 79 Compact enclosures AX Compact enclosures AX – Added efficiency 80 Rittal System Catalogue 36/Enclosures Ease of installation/flexibility ◾ Tool-free installation of the doors saves extra time. Simply position the door, press down on the hinge pin, and it’s done. Enclosures ◾ The AX door hinge allows you to swap the hinge to the opposite side, even with twodoor enclosures, without any machining of the enclosure. This allows simple, fast relocation of the lockable door while the space-saving door population translates into extra space gains. Area extension ◾ The perforated door strip with U extrusion and system punchings on a flexible 25 mm pitch pattern allows fast, simple extension of the installation area. Because it is compatible with Rittal system accessories, no door machining is required. Time savings/rapid assembly ◾ Cam locks are supplied loose to allow unobstructed machining of the door. No time-consuming dismantling work is required in advance. ◾ Lock installation is fast and tool-free. Simply insert, lock into place, and voilà! The perfect fit ◾ The runner on the perforated door strip ensures that even heavily populated doors fit precisely and are compliant with the protection category. Rittal System Catalogue 36/Enclosures 81 Compact enclosures AX Compact enclosures AX – Added system benefits 82 Rittal System Catalogue 36/Enclosures Reliable engineering ◾ A wide range of conversion and planning tools are available to Rittal customers to support them with the automated production process and when working with a virtual prototype: Configurators Parts list converters EPLAN Pro Panel 2D/3D CAD data ecl@ss Advanced Technical documentation Data for planners Assembly videos Enclosures – – – – – – – – Digitalization ◾ The QR code on all machinable enclosure panels permits fully automated incorporation into the production workflow, for seamless digital monitoring from the incoming goods right through to the finished product. Diverse industries ◾ The choice of sheet steel or stainless steel allows the AX to be used in any industry, at any location, in any climate, in any environment, and in a wide range of individual applications. Time savings ◾ The process-optimised packaging concept means it can go straight into production, because all panels and cam locks are supplied unfitted, so no dismantling is required. Rittal System Catalogue 36/Enclosures 83 Compact enclosures AX System accessories Page 877 AX stainless steel Page 236 AX plastic Page 92 Hygienic Design Page 217 Outdoor housing Page 958 Supply includes: – Enclosure with door(s) – Gland plate(s) in enclosure base – Mounting plate – Perforated door strip – Lock: 3 mm double-bit Please note the product-specific scope of supply. F T B G Surface finish: – Enclosure and door: Dipcoatprimed, powder-coated on the outside, textured paint – Mounting plate: Zinc-plated Colour: – RAL 7035 H Material: – Enclosure: Sheet steel – Door: Sheet steel, all-round foamed-in PU seal Approvals: – UL – cUL Further approvals can be found on the Internet. 84 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Compact enclosures AX Basic enclosure AX, sheet steel 300 300 Height (H) mm 300 400 Depth (T) mm 210 210 Mounting plate width (F) mm 250 250 Mounting plate height (G) mm 275 375 Material thickness – enclosure mm 1.25 1.25 Material thickness – door mm 1.5 1.5 Material thickness – mounting plate mm 2.0 2.0 1033.000 1034.000 Model No. Packs of 1 pc(s). Weight kg 6.7 8.38 IP 66 IP 66 NEMA 4 NEMA 4 Door(s) 1 1 Door hinged on the right, may be swapped to the left ◾ ◾ Gland plate, size 1 1 Gland plate, qty 1 1 Cam lock 1 1 Protection category IP to IEC 60 529 Protection category NEMA Page Enclosures Width (B) mm Product-specific scope of supply Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 20 mm 4 pc(s). 2508.020 2508.020 966 Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 40 mm 4 pc(s). 2503.020 2503.020 966 Wall angle 4 pc(s). 2505.510 2505.510 967 Pole clamp 2 pc(s). 2584.100 2584.100 968 Plastic gland plate, modular 1 pc(s). 2561.200 2561.200 1050 Plastic gland plate with membranes 1 pc(s). 2561.300 2561.300 1052 Metal gland plate with knockouts 1 pc(s). 2571.100 2571.100 1053 see page see page 1048 4 pc(s). 2393.210 2393.210 989 – – – 8619.700 Sealing frame, modular Rail for interior installation Support strips, installation in the door Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). Punched section with mounting flange 14 x 39 mm, installation in the door – – LED system light – – 990 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 940 – – Comfort handle AX for lock inserts or profile half-cylinders Comfort handle AX for padlock and lock inserts or profile half-cylinders Lock inserts Viewing window, depth 36 mm – – see page see page – – Viewing window, depth 62 mm – – Operating panel – – 941, 942 180° hinge 3 pc(s). 2449.010 2449.010 951 Door stay 1 pc(s). 2519.010 2519.010 956 – – Sheet steel wiring plan pockets, width-variable Plastic wiring plan pockets see page see page 955 Wiring plan pockets with transparent pouch see page see page 955 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm – – Base/plinth trim panels, sides, 100 mm – – Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm – – Base/plinth trim panels, sides, 200 mm – – Eyebolts – – Protective roof 1 pc(s). 2361.010 2361.010 958 Dust guard trim 1 pc(s). 2426.500 2426.500 959 see page see page 1033 1 pc(s). 1199.100 1199.100 916 Cable gland, brass see page see page 1056 Cable gland, polyamide see page see page 1056 Earth straps Baying kit Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 85 Compact enclosures AX Basic enclosure AX, sheet steel Width (B) mm 380 380 380 380 400 400 Height (H) mm Packs of 300 380 600 600 500 800 Depth (T) mm 210 210 210 350 210 300 Mounting plate width (F) mm 330 330 330 330 350 345 Mounting plate height (G) mm 275 355 575 575 475 775 Material thickness – enclosure mm 1.25 1.25 1.25 1.5 1.25 1.5 Material thickness – door mm 1.5 1.5 1.5 1.5 1.5 2.0 Material thickness – mounting plate mm 2.0 2.0 2.5 2.5 2.0 2.5 1031.000 1380.000 1038.000 1338.000 1045.000 1037.000 Model No. 1 pc(s). Weight kg 8.8 9.48 14.4 18.6 12.1 24.9 IP 66 IP 66 IP 66 IP 66 IP 66 IP 66 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 Door(s) 1 1 1 1 1 1 Door hinged on the right, may be swapped to the left ◾ ◾ ◾ ◾ ◾ ◾ Gland plate, size 2 2 2 5 2 5 Gland plate, qty 1 1 1 1 1 1 Cam lock 1 1 2 2 2 2 Protection category IP to IEC 60 529 Protection category NEMA Page Product-specific scope of supply Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 20 mm 4 pc(s). 2508.020 2508.020 2508.020 2508.020 2508.020 2508.020 966 Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 40 mm 4 pc(s). 2503.020 2503.020 2503.020 2503.020 2503.020 2503.020 966 Wall angle 4 pc(s). 2505.510 2505.510 2505.510 2505.510 2505.510 2505.510 967 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Plastic gland plate, modular 1 pc(s). 2562.200 2562.200 2562.200 2565.200 2562.200 2565.200 1050 Plastic gland plate with membranes 1 pc(s). 2562.300 2562.300 2562.300 2565.300 2562.300 2565.300 1052 Metal gland plate with knockouts 1 pc(s). 2572.100 2572.100 2572.100 2575.100 2572.100 2575.100 1053 see page see page see page see page see page see page 1048 Sealing frame, modular Rail for interior installation 4 pc(s). 2393.210 2393.210 2393.210 2393.350 2393.210 2393.300 989 Support strips, installation in the door 20 pc(s). 4599.100 4599.100 4599.100 4599.100 4694.000 4694.000 952 Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). – – – – 8619.710 8619.730 990 Punched section with mounting flange 14 x 39 mm, installation in the door – – – – – – LED system light 1 pc(s). – – – – 2500.100 2500.100 1014 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 2537.100 2537.100 2537.100 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 2537.300 2537.300 2537.300 940 – – – – – – Comfort handle AX for lock inserts or profile half-cylinders Comfort handle AX for padlock and lock inserts or profile half-cylinders Lock inserts Viewing window, depth 36 mm Viewing window, depth 62 mm – – – – – – see page see page see page see page see page see page – – – – – – – 941, 942 – – – – – Operating panel 1 pc(s). 2741.010 2742.010 2743.010 2743.010 – – 931 180° hinge 3 pc(s). 2449.010 2449.010 2449.010 2449.010 2449.010 2449.010 951 Door stay 1 pc(s). 2519.010 2519.010 2519.010 2519.010 2519.010 2519.010 956 Sheet steel wiring plan pockets, width-variable 1 pc(s). – – – – 2515.200 2515.200 954 Plastic wiring plan pockets see page see page see page see page see page see page 955 Wiring plan pockets with transparent pouch see page see page see page see page see page see page 955 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm – – – – – – Base/plinth trim panels, sides, 100 mm – – – – – – Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm – – – – – – Base/plinth trim panels, sides, 200 mm – – – – – – Eyebolts – – – – – – Protective roof 1 pc(s). 2472.010 2472.010 2472.010 – – – Dust guard trim 1 pc(s). 2426.500 2426.500 2426.500 2426.500 2426.500 2426.500 959 see page see page see page see page see page see page 1033 Earth straps Baying kit 1 pc(s). 958 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Cable gland, brass see page see page see page see page see page see page 1056 Cable gland, polyamide see page see page see page see page see page see page 1056 86 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Compact enclosures AX Basic enclosure AX, sheet steel 500 500 500 600 600 600 Height (H) mm 500 500 700 380 380 600 Depth (T) mm 210 300 250 210 350 210 Mounting plate width (F) mm 450 450 450 550 550 550 Mounting plate height (G) mm 475 475 675 355 355 575 Material thickness – enclosure mm 1.25 1.5 1.5 1.25 1.5 1.5 Material thickness – door mm 1.5 1.5 2.0 1.5 1.5 1.5 Material thickness – mounting plate mm 2.5 2.5 2.5 2.5 2.5 2.5 1050.000 1350.000 1057.000 1039.000 1339.000 1060.000 Model No. Packs of 1 pc(s). Weight kg 15.4 19.0 25.0 14.4 8.7 22.3 Protection category IP to IEC 60 529 IP 66 IP 66 IP 66 IP 66 IP 66 IP 66 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 Door(s) 1 1 1 1 1 1 Door hinged on the right, may be swapped to the left ◾ ◾ ◾ ◾ ◾ ◾ Gland plate, size 3 6 3 4 7 4 Gland plate, qty 1 1 1 1 1 1 Cam lock 2 2 2 1 1 2 Protection category NEMA Page Enclosures Width (B) mm Product-specific scope of supply Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 20 mm 4 pc(s). 2508.020 2508.020 2508.020 2508.020 2508.020 2508.020 966 Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 40 mm 4 pc(s). 2503.020 2503.020 2503.020 2503.020 2503.020 2503.020 966 Wall angle 4 pc(s). 2505.510 2505.510 2505.510 2505.510 2505.510 2505.510 967 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Plastic gland plate, modular 1 pc(s). 2563.200 2566.200 2563.200 2564.200 2567.200 2564.200 1050 Plastic gland plate with membranes 1 pc(s). 2563.300 2566.300 2563.300 2564.300 2567.300 2564.300 1052 Metal gland plate with knockouts 1 pc(s). 2573.100 2576.100 2573.100 2574.100 2577.100 2574.100 1053 see page see page see page see page see page see page 1048 Sealing frame, modular Rail for interior installation 4 pc(s). 2393.210 2393.300 2393.250 2393.210 2393.350 2393.210 989 Support strips, installation in the door 20 pc(s). 4695.000 4695.000 4695.000 4696.000 4696.000 4696.000 952 Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). 8619.710 8619.710 8619.760 – – 8619.720 990 – – – – – – LED system light 1 pc(s). 2500.100 2500.100 2500.100 2500.100 2500.100 2500.100 1014 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 2537.100 2537.100 2537.100 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 2537.300 2537.300 2537.300 940 – – – – – – Punched section with mounting flange 14 x 39 mm, installation in the door Comfort handle AX for lock inserts or profile half-cylinders Comfort handle AX for padlock and lock inserts or profile half-cylinders Lock inserts – – – – – – see page see page see page see page see page see page 941, 942 Viewing window, depth 36 mm 1 pc(s). 2733.010 2733.010 – 2730.010 2730.010 2731.010 930 Viewing window, depth 62 mm 1 pc(s). 2763.010 2763.010 – 2760.010 2760.010 2761.010 930 Operating panel 1 pc(s). 2745.010 2745.010 – 2744.010 – 2746.010 931 180° hinge 3 pc(s). 2449.010 2449.010 2449.010 2449.010 2449.010 2449.010 951 Door stay 1 pc(s). 2519.010 2519.010 2519.010 2519.010 2519.010 2519.010 956 Sheet steel wiring plan pockets, width-variable 1 pc(s). 2515.200 2515.200 2515.200 2515.300 2515.300 2515.300 954 Plastic wiring plan pockets see page see page see page see page see page see page 955 Wiring plan pockets with transparent pouch see page see page see page see page see page see page 955 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm – – – – – – Base/plinth trim panels, sides, 100 mm – – – – – – Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm – – – – – – Base/plinth trim panels, sides, 200 mm – – – – – – Eyebolts – – – – – – Protective roof 1 pc(s). 2362.010 – – 2473.010 – 2473.010 958 Dust guard trim 1 pc(s). 2426.500 2426.500 2426.500 2426.500 2426.500 2426.500 959 see page see page see page see page see page see page 1033 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Cable gland, brass see page see page see page see page see page see page 1056 Cable gland, polyamide see page see page see page see page see page see page 1056 Earth straps Baying kit Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 87 Compact enclosures AX Basic enclosure AX, sheet steel Width (B) mm 600 600 600 600 600 600 Height (H) mm Packs of 600 600 760 760 800 800 Depth (T) mm 250 350 210 350 250 400 Mounting plate width (F) mm 550 550 550 550 545 545 Mounting plate height (G) mm 575 575 735 735 775 775 Material thickness – enclosure mm 1.5 1.5 1.5 1.5 1.5 1.5 Material thickness – door mm 1.5 1.5 2.0 2.0 2.0 2.0 Material thickness – mounting plate mm 2.5 2.5 2.5 2.5 2.5 2.5 1054.000 1360.000 1076.000 1376.000 1058.000 1059.000 Model No. 1 pc(s). Weight kg 23.4 26.3 29.5 34.0 32.0 40.0 Protection category IP to IEC 60 529 IP 66 IP 66 IP 66 IP 66 IP 66 IP 66 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 Door(s) 1 1 1 1 1 1 Door hinged on the right, may be swapped to the left ◾ ◾ ◾ ◾ ◾ ◾ Gland plate, size 4 7 4 7 4 7 Gland plate, qty 1 1 1 1 1 1 Cam lock 2 2 2 2 2 2 Protection category NEMA Page Product-specific scope of supply Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 20 mm 4 pc(s). 2508.020 2508.020 2508.020 2508.020 2508.020 2508.020 966 Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 40 mm 4 pc(s). 2503.020 2503.020 2503.020 2503.020 2503.020 2503.020 966 Wall angle 4 pc(s). 2505.510 2505.510 2505.510 2505.510 2505.510 2505.510 967 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Plastic gland plate, modular 1 pc(s). 2564.200 2567.200 2564.200 2567.200 2564.200 2567.200 1050 Plastic gland plate with membranes 1 pc(s). 2564.300 2567.300 2564.300 2567.300 2564.300 2567.300 1052 Metal gland plate with knockouts 1 pc(s). 2574.100 2577.100 2574.100 2577.100 2574.100 2577.100 1053 see page see page see page see page see page see page 1048 Sealing frame, modular Rail for interior installation 4 pc(s). 2393.250 2393.350 2393.210 2393.350 2393.250 2393.400 989 Support strips, installation in the door 20 pc(s). 4696.000 4696.000 4696.000 4696.000 4696.000 4696.000 952 Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). 8619.720 8619.720 8619.790 8619.790 8619.730 8619.730 990 – – – – – – LED system light 1 pc(s). 2500.100 2500.100 2500.100 2500.100 2500.110 2500.110 1014 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 2537.100 2537.100 2537.100 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 2537.300 2537.300 2537.300 940 – – – – – – Punched section with mounting flange 14 x 39 mm, installation in the door Comfort handle AX for lock inserts or profile half-cylinders Comfort handle AX for padlock and lock inserts or profile half-cylinders Lock inserts – – – – – – see page see page see page see page see page see page 941, 942 Viewing window, depth 36 mm 1 pc(s). 2731.010 2731.010 2732.010 2732.010 – – 930 Viewing window, depth 62 mm 1 pc(s). 2761.010 2761.010 2762.010 2762.010 – – 930 Operating panel 1 pc(s). 2746.010 2746.010 – – – – 931 180° hinge 3 pc(s). 2449.010 2449.010 2449.010 2449.010 2449.010 2449.010 951 Door stay 1 pc(s). 2519.010 2519.010 2519.010 2519.010 2519.010 2519.010 956 Sheet steel wiring plan pockets, width-variable 1 pc(s). 2515.300 2515.300 2515.300 2515.300 2515.300 2515.300 954 Plastic wiring plan pockets see page see page see page see page see page see page 955 Wiring plan pockets with transparent pouch see page see page see page see page see page see page 955 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). – – – – – 2820.061 888 Base/plinth trim panels, sides, 100 mm 2 pc(s). – – – – – 2820.410 889 888 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). – – – – – 2820.062 Base/plinth trim panels, sides, 200 mm 2 pc(s). – – – – – 2820.420 889 Eyebolts 2 pc(s). – – – – – 2509.010 964 958 Protective roof 1 pc(s). – 2476.010 2473.010 2476.010 – – Dust guard trim 1 pc(s). 2426.500 2426.500 2426.500 2426.500 2426.500 2426.500 959 see page see page see page see page see page see page 1033 Earth straps Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Cable gland, brass see page see page see page see page see page see page 1056 Cable gland, polyamide see page see page see page see page see page see page 1056 88 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Compact enclosures AX Basic enclosure AX, sheet steel 600 600 600 600 760 760 Height (H) mm 1000 1000 1200 1200 760 760 Depth (T) mm 250 400 300 400 210 300 Mounting plate width (F) mm 545 545 545 545 705 705 Mounting plate height (G) mm 975 975 1175 1175 735 735 Material thickness – enclosure mm 1.5 1.5 1.5 1.5 1.5 1.5 Material thickness – door mm 2.0 2.0 2.0 2.0 2.0 2.0 Material thickness – mounting plate mm 2.5 2.5 2.5 2.5 2.5 2.5 1090.000 1091.000 1260.000 1261.000 1077.000 1073.000 Model No. Packs of 1 pc(s). Page Enclosures Width (B) mm Weight kg 39.5 50.0 50.0 56.0 36.7 42.0 Protection category IP to IEC 60 529 IP 66 IP 66 IP 66 IP 66 IP 66 IP 66 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 Door(s) 1 1 1 1 1 1 Door hinged on the right, may be swapped to the left ◾ ◾ ◾ ◾ ◾ ◾ Gland plate, size 4 7 7 7 2 5 Gland plate, qty 1 1 1 1 2 2 Cam lock 2 2 – – 2 2 3-point lock system – – ◾ ◾ – – 2508.020 2508.020 2508.020 2508.020 2508.020 2508.020 966 Protection category NEMA Product-specific scope of supply Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 20 mm 4 pc(s). Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 40 mm 4 pc(s). 2503.020 2503.020 2503.020 2503.020 2503.020 2503.020 966 Wall angle 4 pc(s). 2505.510 2505.510 2505.510 2505.510 2505.510 2505.510 967 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 – – 968 Plastic gland plate, modular 1 pc(s). 2564.200 2567.200 2567.200 2567.200 2562.200 2565.200 1050 Plastic gland plate with membranes 1 pc(s). 2564.300 2567.300 2567.300 2567.300 2562.300 2565.300 1052 Metal gland plate with knockouts 1 pc(s). 2574.100 2577.100 2577.100 2577.100 2572.100 2575.100 1053 see page see page see page see page see page see page 1048 Sealing frame, modular Rail for interior installation 4 pc(s). 2393.250 2393.400 2393.300 2393.400 2393.210 2393.300 989 Support strips, installation in the door 20 pc(s). 4696.000 4696.000 4596.000 4596.000 4599.200 4599.200 952 Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). 8619.750 8619.750 8619.770 8619.770 8619.790 8619.790 990 Punched section with mounting flange 14 x 39 mm, installation in the door 4 pc(s). – – 8619.720 8619.720 – – 952 LED system light 1 pc(s). 2500.110 2500.110 2500.110 2500.110 2500.110 2500.110 1014 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 – – 2537.100 2537.100 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 – – 2537.300 2537.300 940 Comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). – – 2435.100 2435.100 – – 939 Comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). – – 2435.400 2435.400 – – 939 941, 942 Lock inserts see page see page see page see page see page see page Viewing window, depth 36 mm – – – – – – Viewing window, depth 62 mm – – – – – – Operating panel – – – – – – 180° hinge 3 pc(s). 2449.010 2449.010 2449.010 2449.010 2449.010 2449.010 951 Door stay 1 pc(s). 2519.010 2519.010 2519.010 2519.010 2519.010 2519.010 956 Sheet steel wiring plan pockets, width-variable 1 pc(s). 954 2515.300 2515.300 2515.300 2515.300 2515.400 2515.400 Plastic wiring plan pockets see page see page see page see page see page see page 955 Wiring plan pockets with transparent pouch see page see page see page see page see page see page 955 – 2820.061 2820.061 2820.061 – – 888 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). Base/plinth trim panels, sides, 100 mm 2 pc(s). – 2820.410 2820.310 2820.410 – – 889 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). – 2820.062 2820.062 2820.062 – – 888 Base/plinth trim panels, sides, 200 mm 2 pc(s). – 2820.420 2820.320 2820.420 – – 889 Eyebolts 2 pc(s). – 2509.010 2509.010 2509.010 – – 964 Protective roof 1 pc(s). – – – – – 2474.010 958 Dust guard trim 1 pc(s). 2426.500 2426.500 2426.500 2426.500 2426.500 2426.500 959 see page see page see page see page see page see page 1033 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Cable gland, brass see page see page see page see page see page see page 1056 Cable gland, polyamide see page see page see page see page see page see page 1056 Earth straps Baying kit Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 89 Compact enclosures AX Basic enclosure AX, sheet steel Width (B) mm 800 800 800 800 800 1000 Height (H) mm Packs of 600 1000 1000 1200 1200 760 Depth (T) mm 300 300 400 300 400 210 Mounting plate width (F) mm 750 745 745 745 745 945 Mounting plate height (G) mm 575 975 975 1175 1175 735 Material thickness – enclosure mm 1.5 1.5 1.5 1.5 1.5 1.5 Material thickness – door mm 2.0 2.0 2.0 2.0 2.0 2.0 Material thickness – mounting plate mm 2.5 2.5 2.5 2.5 2.5 2.5 1055.000 1180.000 1181.000 1280.000 1281.000 1100.000 Model No. 1 pc(s). Page Weight kg 34.2 52.0 59.5 63.5 69.0 49.0 Protection category IP to IEC 60 529 IP 66 IP 66 IP 66 IP 66 IP 66 IP 55 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 4 NEMA 12 Door(s) 1 1 1 1 1 2 Door hinged on the right, may be swapped to the left ◾ ◾ ◾ ◾ ◾ ◾ Gland plate, size 5 5 5 5 5 3 Gland plate, qty 2 2 2 2 2 2 Cam lock 2 2 2 – – 2 3-point lock system – – – ◾ ◾ – 2508.020 2508.020 2508.020 2508.020 2508.020 2508.020 966 966 Protection category NEMA Product-specific scope of supply Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 20 mm 4 pc(s). Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 40 mm 4 pc(s). 2503.020 2503.020 2503.020 2503.020 2503.020 2503.020 Wall angle 4 pc(s). 2505.510 2505.510 2505.510 2505.510 2505.510 2505.510 967 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 Plastic gland plate, modular 1 pc(s). 2565.200 2565.200 2565.200 2565.200 2565.200 2562.200 1050 Plastic gland plate with membranes 1 pc(s). 2565.300 2565.300 2565.300 2565.300 2565.300 2563.300 1052 Metal gland plate with knockouts 1 pc(s). 2575.100 2575.100 2575.100 2575.100 2575.100 2573.100 1053 see page see page see page see page see page see page 1048 989 Sealing frame, modular Rail for interior installation 4 pc(s). 2393.300 2393.300 2393.400 2393.300 2393.400 2393.210 Support strips, installation in the door 20 pc(s). 4697.000 4697.000 4697.000 – – 4695.000 952 Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). 8619.720 8619.750 8619.750 8619.770 8619.770 8619.790 990 Punched section with mounting flange 14 x 39 mm, installation in the door1) 4 pc(s). – – – 8619.730 8619.730 8619.710 952 LED system light 1 pc(s). 2500.110 2500.110 2500.110 2500.110 2500.110 2500.110 1014 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 – – 2537.100 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 – – 2537.300 940 Comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). – – – 2435.100 2435.100 – 939 Comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). – – – 2435.400 2435.400 – 939 941, 942 Lock inserts see page see page see page see page see page see page Viewing window, depth 36 mm – – – – – – Viewing window, depth 62 mm – – – – – – Operating panel – – – – – – 180° hinge 3 pc(s). 2449.010 2449.010 2449.010 2449.010 2449.010 2449.010 951 Door stay 1 pc(s). 2519.010 2519.010 2519.010 2519.010 2519.010 2519.010 956 Sheet steel wiring plan pockets, width-variable 1 pc(s). 954 2515.400 2515.400 2515.400 2515.400 2515.400 2515.200 Plastic wiring plan pockets see page see page see page see page see page see page 955 Wiring plan pockets with transparent pouch see page see page see page see page see page see page 955 2820.081 2820.081 2820.081 2820.081 – 888 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 2820.081 Base/plinth trim panels, sides, 100 mm 2 pc(s). 2820.310 2820.310 2820.410 2820.310 2820.410 – 889 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 2820.082 2820.082 2820.082 2820.082 2820.082 – 888 Base/plinth trim panels, sides, 200 mm 2 pc(s). 2820.320 2820.320 2820.420 2820.320 2820.420 – 889 Eyebolts 2 pc(s). – 2509.010 2509.010 2509.010 2509.010 – 964 958 Protective roof 1 pc(s). 2475.010 2475.010 – 2475.010 – – Dust guard trim 1 pc(s). 2426.500 2426.500 2426.500 2426.500 2426.500 2426.500 959 see page see page see page see page see page see page 1033 Earth straps Baying kit 1 pc(s). 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Cable gland, brass see page see page see page see page see page see page 1056 Cable gland, polyamide see page see page see page see page see page see page 1056 1) For two-door enclosures: Installation in the lockable door 90 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Compact enclosures AX Basic enclosure AX, sheet steel 1000 1000 1000 1000 1000 1000 1200 Height (H) mm 760 1000 1200 1200 1,400 1,400 1200 Depth (T) mm 300 300 300 400 300 400 400 Mounting plate width (F) mm 945 945 945 945 945 945 1145 Mounting plate height (G) mm 735 975 1175 1175 1375 1375 1175 Material thickness – enclosure mm 1.5 1.5 1.5 1.5 1.5 1.5 1.5 Material thickness – door mm 2.0 2.0 2.0 2.0 2.0 2.0 2.0 Material thickness – mounting plate mm 2.5 2.5 2.5 2.5 2.5 2.5 2.5 Model No. Packs of 1 pc(s). 1130.000 1110.000 1213.000 1214.000 1114.000 1115.000 1116.000 Weight kg 52.0 63.0 81.0 85.7 88.5 100.0 Protection category IP to IEC 60 529 IP 55 IP 55 IP 55 IP 55 IP 55 IP 55 IP 55 NEMA 12 NEMA 12 NEMA 12 NEMA 12 NEMA 12 NEMA 12 NEMA 12 Door(s) 2 2 2 2 2 2 2 Door hinged on the right, may be swapped to the left ◾ ◾ ◾ ◾ ◾ ◾ ◾ Gland plate, size 6 6 6 6 6 6 7 Gland plate, qty 2 2 2 2 2 2 2 Cam lock 2 2 – – – – – 3-point lock system – – ◾ ◾ ◾ ◾ ◾ Protection category NEMA Page Enclosures Width (B) mm 101.0 Product-specific scope of supply Accessories Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 20 mm 4 pc(s). 2508.020 2508.020 2508.020 2508.020 2508.020 2508.020 2508.020 966 Wall mounting bracket, for AX sheet steel, KX sheet steel, wall distance 40 mm 4 pc(s). 2503.020 2503.020 2503.020 2503.020 2503.020 2503.020 2503.020 966 Wall angle 4 pc(s). 2505.510 2505.510 2505.510 2505.510 2505.510 2505.510 2505.510 967 Pole clamp – – – – – – – Plastic gland plate, modular 1 pc(s). 2566.200 2566.200 2566.200 2566.200 2566.200 2566.200 2567.200 1050 Plastic gland plate with membranes 1 pc(s). 2566.300 2566.300 2566.300 2566.300 2566.300 2566.300 2567.300 1052 Metal gland plate with knockouts 1 pc(s). 2576.100 2576.100 2576.100 2576.100 2576.100 2576.100 2577.100 1053 see page see page 1048 989 Sealing frame, modular see page see page see page see page see page Rail for interior installation 4 pc(s). 2393.300 2393.300 2393.300 2393.400 2393.300 2393.400 2393.400 Support strips, installation in the door 20 pc(s). 4695.000 4695.000 Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). 8619.790 8619.750 8619.770 8619.770 8619.780 8619.780 8619.770 Punched section with mounting flange 14 x 39 mm, installation in the door1) 4 pc(s). 8619.710 8619.710 8619.710 8619.710 8619.710 8619.710 8619.720 952 LED system light 1 pc(s). 2500.110 2500.110 2500.110 2500.110 2500.110 2500.110 2500.110 1014 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 – – – – – 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 – – – – – 940 – – – – – 952 990 Comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). – – 2435.100 2435.100 2435.100 2435.100 2435.100 939 Comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). – – 2435.400 2435.400 2435.400 2435.400 2435.400 939 Lock inserts see page see page see page see page see page see page see page Viewing window, depth 36 mm – – – – – – – Viewing window, depth 62 mm – – – – – – – Operating panel – – – – – – – 941, 942 180° hinge 3 pc(s). 2449.010 2449.010 2449.010 2449.010 2449.010 2449.010 2449.010 951 Door stay 1 pc(s). 2519.010 2519.010 2519.010 2519.010 2519.010 2519.010 2519.010 956 Sheet steel wiring plan pockets, width-variable 1 pc(s). 2515.200 2515.200 2515.200 2515.200 2515.200 2515.200 2515.300 954 Plastic wiring plan pockets see page see page see page see page see page see page see page 955 Wiring plan pockets with transparent pouch see page see page see page see page see page see page see page 955 888 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 2820.101 2820.101 2820.101 2820.101 2820.101 2820.101 2820.121 Base/plinth trim panels, sides, 100 mm 2 pc(s). 2820.310 2820.310 2820.310 2820.410 2820.310 2820.410 2820.410 889 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 2820.102 2820.102 2820.102 2820.102 2820.102 2820.102 2820.122 888 Base/plinth trim panels, sides, 200 mm 2 pc(s). 2820.320 2820.320 2820.320 2820.420 2820.320 2820.420 2820.420 889 Eyebolts 2 pc(s). Protective roof 1 pc(s). 2363.010 2363.010 2363.010 Dust guard trim 1 pc(s). 2426.500 2426.500 2426.500 2426.500 2426.500 2426.500 2426.500 959 see page 1033 Earth straps Baying kit 1 pc(s). – 2509.010 2509.010 2509.010 2509.010 2509.010 2509.010 see page see page – see page 2363.010 see page – see page – see page 964 958 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 1199.100 916 Cable gland, brass see page see page see page see page see page see page see page 1056 Cable gland, polyamide see page see page see page see page see page see page see page 1056 1) For two-door enclosures: Installation in the lockable door Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 91 Plastic enclosures AX Plastic enclosures AX – Added durability 92 Rittal System Catalogue 36/Enclosures Enclosures ◾ 14 different enclosure variants, with or without viewing panel ◾ Symmetrical layout means the enclosure is easily rotated through 180° Enclosures ◾ Double seal with an integral rain protection strip on the top and bottom edge of the door to protect the seal from dust and rainwater ◾ Fibreglass-reinforced plastic with a high level of UV resistance Siting ◾ Wall mounting brackets are easily secured from the outside while retaining the UL approval ◾ The pole clamp may be screw-fastened directly into the external threaded inserts ◾ Ideally suited for outdoor applications Mounting plate ◾ The mounting plate is easily screw-fastened onto the pre-assembled bolts from the front ◾ Simple earthing of the mounting plate, even retrospectively, using machined keyholes ◾ If no mounting plate is used, top hat rails may be mounted directly onto the available mounting bosses Interior installation ◾ Numerous mounting bosses for individual interior installation ◾ Interior installation on a 25 mm pitch pattern with universal bracket for mounting punched sections and rails ◾ Direct door installation with support strips and punched sections with mounting flanges 14 x 39 mm, for use as an additional mounting surface ◾ Door-operated switches may be attached directly to the mounting bosses Rittal System Catalogue 36/Enclosures 93 Plastic enclosures AX System accessories Page 877 Ex enclosures Page 257 Surface finish: – Enclosure and door: Dyed plastic with no after-treatment – Mounting plate: Zinc-plated Colour: – Similar to RAL 7035 Protection class: – II at 1000 V AC Note: – Interior installation screws are required to secure components inside the enclosure – Components such as punched sections with mounting flanges may be attached on a 25 mm pitch pattern using the universal bracket Protection category NEMA: – NEMA 4X Supply includes: – Enclosure with hinged door, of all-round solid construction, 3 mm double-bit lock – Door hinged on the right, may be swapped to the left – Mounting plate – Twin seal on the top and bottom edges of the door as integral rain protection strip Please note the product-specific scope of supply. F T B G Protection category IP to IEC 60 529: – IP 66 Approvals: – UL – cUL Further approvals can be found on the Internet. H Material: – Enclosure and door: Fibreglass-reinforced unsaturated polyester – Fire protection corresponding to UL 94 V-0 – Door: All-round foamed-in PU seal – Mounting plate: Sheet steel without viewing window Width (B) mm 250 300 400 400 500 600 600 800 Height (H) mm Packs of 350 400 400 600 500 600 800 1000 Depth (T) mm 150 200 200 200 300 200 300 300 Mounting plate width (F) mm 155 205 305 305 405 505 505 705 Mounting plate height (G) mm 275 325 325 525 425 525 725 925 Mounting plate thickness mm 2.5 2.5 2.5 3.0 3.0 3.0 3.0 3.0 Model No. 1 pc(s). Weight kg Page 1432.000 1434.000 1444.000 1446.000 1453.000 1466.000 1468.000 1480.000 4.4 6.3 7.8 11.1 13.1 15.5 22.4 34.2 1 2 2 2 2 2 2 3 Product-specific scope of supply Cam lock Accessories Wall mounting bracket 4 pc(s). 1485.400 1485.400 1485.400 1485.400 1485.400 1485.400 1485.400 1485.400 97 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 2584.100 968 – Universal bracket 4 pc(s). 1485.200 1485.200 1485.200 1485.200 1485.200 1485.200 1485.200 1485.200 97 Door stay 2 pc(s). 1485.100 1485.100 1485.100 1485.100 1485.100 1485.100 1485.100 1485.100 96 1 pc(s). 1485.600 1485.600 1485.600 1485.600 1485.600 1485.600 1485.600 1485.600 LED system light – Mini-comfort handle AX Cable gland see page – see page 2500.100 2500.100 2500.100 2500.100 2500.110 2500.110 see page see page see page see page see page see page 1014 96 1056 Screw for interior installation 50 pc(s). 1485.300 1485.300 1485.300 1485.300 1485.300 1485.300 1485.300 1485.300 97 Wiring plan pocket 1 pc(s). 955 Punched section with mounting flange 23 x 64 mm, installation in the height Punched section with mounting flange 23 x 64 mm, installation in the width – – – – – – 4116.500 4116.500 4116.500 8617.110 8617.110 8617.130 8617.120 8617.130 8617.140 8617.150 4 pc(s). 991 – – 8617.110 8617.110 8617.120 8617.130 8617.130 8617.140 Support strips, installation in the door 20 pc(s). – – 4594.000 4594.000 4309.000 4596.000 4596.000 4598.000 952 Punched section with mounting flange 14 x 39 mm, installation in the door 4 pc(s). – – 8619.700 8619.700 8619.710 8619.720 8619.720 8619.730 952 94 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Enclosures Plastic enclosures AX System accessories Page 877 Ex enclosures Page 257 Surface finish: – Enclosure and door: Dyed plastic with no after-treatment – Mounting plate: Zinc-plated Colour: – Similar to RAL 7035 Protection class: – II at 1000 V AC Protection category NEMA: – NEMA 12 Supply includes: – Enclosure with hinged door with viewing window, of allround solid construction, 3 mm double-bit lock – Door hinged on the right, may be swapped to the left – Mounting plate – Twin seal on the top and bottom edges of the door as integral rain protection strip Please note the product-specific scope of supply. Note: – Interior installation screws are required to secure components inside the enclosure – Components such as punched sections with mounting flanges may be attached on a 25 mm pitch pattern using the universal bracket F T B G Protection category IP to IEC 60 529: – IP 56 Approvals: – UL – cUL Further approvals can be found on the Internet. H Material: – Enclosure and door: Fibreglass-reinforced unsaturated polyester – Fire protection corresponding to UL 94 V-0 – Door: All-round foamed-in PU seal – Mounting plate: Sheet steel – Viewing window: Polycarbonate with viewing window Width (B) mm 400 400 500 600 600 800 Height (H) mm 400 600 500 600 800 1000 Depth (T) mm 200 200 300 200 300 300 Mounting plate width (F) mm 305 305 405 505 505 705 Mounting plate height (G) mm 325 525 425 525 725 925 Mounting plate thickness mm 2.5 3.0 3.0 3.0 3.0 3.0 1448.000 1449.000 1454.000 1467.000 1469.000 1479.000 7.7 10.9 12.9 15.2 21.9 33.2 2 2 2 2 2 3 Model No. Packs of 1 pc(s). Weight kg Page Product-specific scope of supply Cam lock Accessories Wall mounting bracket 4 pc(s). 1485.400 1485.400 1485.400 1485.400 1485.400 1485.400 97 Pole clamp 2 pc(s). 2584.100 2584.100 2584.100 2584.100 2584.100 – 968 Universal bracket 4 pc(s). 1485.200 1485.200 1485.200 1485.200 1485.200 1485.200 97 Door stay 2 pc(s). 1485.100 1485.100 1485.100 1485.100 1485.100 1485.100 96 2500.100 2500.100 2500.100 2500.100 2500.110 2500.110 1014 1485.600 1485.600 1485.600 1485.600 1485.600 1485.600 96 see page see page see page see page see page see page 1056 LED system light Mini-comfort handle AX 1 pc(s). Cable gland Screw for interior installation 50 pc(s). 1485.300 1485.300 1485.300 1485.300 1485.300 1485.300 97 Wiring plan pocket 1 pc(s). – – – 4116.500 4116.500 4116.500 955 8617.110 8617.130 8617.120 8617.130 8617.140 8617.150 8617.110 8617.110 8617.120 8617.130 8617.130 8617.140 Punched section with mounting flange 23 x 64 mm, installation in the height Punched section with mounting flange 23 x 64 mm, installation in the width 4 pc(s). 991 Support strips, installation in the door 20 pc(s). 4594.000 4594.000 4309.000 4596.000 4596.000 4598.000 952 Punched section with mounting flange 14 x 39 mm, installation in the door 4 pc(s). 8619.700 8619.700 8619.710 8619.720 8619.720 8619.730 952 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 95 Plastic enclosures AX Accessories Mini-comfort handle AX Packs of Model No. for AX plastic The unlatched handle swivels to open the lock. Prepared for the installation of lock inserts or for the installation of standard commercially available 40 or 45 mm profile half-cylinders, as well as lock and push-button inserts. 1 pc(s). 1485.600 Lock inserts, type A 7 mm square 2460.000 8 mm square 2461.000 7 mm triangular 2462.000 8 mm triangular 2463.000 Screwdriver 2464.000 Daimler insert 2465.000 3 mm double-bit 2466.000 Fiat 2307.000 6.5 mm triangular 2460.650 Lock and push-button inserts Lock insert, lock no. 3524 E1) 2467.000 Push-button insert 2468.000 Push-button and lock insert1) 2469.0002) Profile half-cylinders 9785.0405) To DIN 18 2523) 9785.0424) 1) With 2 keys 2) Lock no. 2123; no other lock is possible 3) With 3 keys for each lock insert 4) Packs of two, simultaneous locking within the same pack, no simultaneous locking for different packs 5) Lock-specific key Door stay AX for AX plastic and Ex enclosure, plastic To secure the door in the open position. May be fitted without machining the enclosure. Assembly Packs of Model No. Top/bottom 2 pc(s). 1485.100 Supply includes: – Assembly parts Installation options: – Installation directly at the top/bottom right – When swapping the door hinge to the opposite side, the prefitted door stay is easily removed and re-installed 96 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Plastic enclosures AX Accessories for AX plastic For attachment to the wall, only possible from the outside of the enclosure. 1) Colour Packs of RAL 7035 4 pc(s). Model No. 1485.400 RAL 9011 4 pc(s). 1485.5001) Enclosures Wall mounting bracket With graphite additive for Ex applications Material: – Fibreglass-reinforced polyamide1) Section A – A Supply includes: – Assembly parts for mounting on the enclosure 32 11 30 15 27 A M8 67 11 38.5 24 90° Ø9 A Universal bracket Packs of Model No. for AX plastic and Ex enclosure, plastic For the interior installation on a 25 mm pitch pattern of – Punched sections with mounting flanges – Door rails – Support strips 4 pc(s). 1485.200 Material: – Sheet steel, zinc-plated Supply includes: – Assembly parts Screw for interior installation for AX plastic For mounting accessories on the mounting bosses of the enclosure frame. Type of screw Packs of Model No. Pan head screw, self-tapping 50 pc(s). 1485.300 Drive: Multi-tooth 25 Dimensions: 5 x 14 mm Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 97 98 Rittal System Catalogue 36/Enclosures Enclosures Rack systems Baying enclosure system VX25 Product comparison ...................................................................................102 Product overview........................................................................................104 Product advantages ...................................................................................106 Basic enclosure, height 1200 mm, depth 500 mm......................................117 Basic enclosure, height 1400 mm, depth 500 mm......................................118 Basic enclosure, height 1600 mm, depth 500 mm......................................119 Basic enclosure, height 1800 mm, depth 400 mm......................................120 Basic enclosure, height 1800 mm, depth 500 mm......................................121 Basic enclosure, height 1800 mm, depth 600 mm......................................122 Basic enclosure, height 2000 mm, depth 400 mm......................................123 Basic enclosure, height 2000 mm, depth 500 mm......................................124 Basic enclosure, height 2000 mm, depth 600 mm......................................125 Basic enclosure, height 2000 mm, depth 800 mm......................................126 Basic enclosure, height 2200 mm, depth 600 mm......................................127 Basic enclosure with glazed door ...............................................................129 Electronic enclosures..................................................................................130 IP 66/NEMA 4 ............................................................................................131 Modular enclosures, height 2000 mm.........................................................132 Modular enclosures, height 2200 mm.........................................................133 Fuse-switch-disconnector enclosures.........................................................134 Distribution enclosures................................................................................135 EMC enclosures .........................................................................................136 Free-standing enclosure system VX SE Product advantages ...................................................................................138 Basic enclosure, width 600 mm..................................................................143 Basic enclosure, width 800 mm..................................................................144 Basic enclosure, width 1000 – 1200 mm ....................................................145 Basic enclosure, width 1600 – 1800 mm ....................................................146 IP 66/NEMA 4 ............................................................................................147 Rittal System Catalogue 36/Enclosures 99 Two powerful models – one accessory range – one system Free-standing enclosure system VX SE For standalone enclosure applications up to 1800 mm wide 100 Rittal System Catalogue 36/Enclosures Enclosures Baying enclosure system VX25 For individual bayed combinations – accessible from all sides Rittal System Catalogue 36/Enclosures 101 Baying enclosure system VX25 – Product comparison Basic enclosure Basic enclosure with glazed door Electronic enclosure IP 66/NEMA 4 Sheet steel ◾ – ◾ ◾ ◾ Stainless steel – ◾ – – – Door, front ◾ ◾ – – ◾ Glazed door, front – – ◾ – – Front frame – – – ◾ – Front trim panels – – – – – Door, rear – – ◾ ◾ – Rear panel ◾ ◾ – – ◾ Roof plate ◾ ◾ ◾ ◾ ◾ Mounting plate ◾ ◾ – ◾ ◾ Punched rails ◾ ◾ – – ◾ Gland plate, solid – – – – ◾ Gland plate, multi-piece ◾ ◾ ◾ ◾ – Locating frame for fuseswitch disconnectors – – – – – Adaptor section, 482.6 mm (19˝), front – – – ◾ – IP 55 IP 55 IP 55 – IP 66 12 12 12 – 4 116 242 128 130 131 Material Cladding Interior installation Protection category from page 102 IP to IEC 60 529 NEMA Rittal System Catalogue 36/Enclosures Enclosures Baying enclosure system VX25 – Product comparison 1) IP 66/NEMA 4X Distribution enclosure Modular enclosure Fuse-switchdisconnector enclosure EMC enclosure – ◾ ◾ ◾ ◾1) ◾ – – – – ◾ ◾ – ◾ ◾ – – – – – – – – – – – – – ◾ – – – – – – ◾ ◾ ◾ ◾ ◾ ◾ ◾ – ◾ ◾ ◾ – – – ◾ ◾ – – – ◾ ◾ – – – – – ◾ ◾ ◾ ◾ – – – ◾ – – – – – – IP 66 IP 55 Up to IP 542) Up to IP 3X2) IP 55 4X 12 – – 12 246 135 132 134 136 Sheet steel with magnesium zinc coating Rittal System Catalogue 36/Enclosures 2) Depending on the cladding 103 Baying enclosure system VX25 – Product overview Basic enclosure Height x depth mm Model No. Model No. Model No. Model No. 1 1 2 1 1 2 1 1 2 Stainless steel – – – – – – – – – Sheet steel – – – – – – – – – Sheet steel – – – – – – – – – Sheet steel – – – – – – – – – 1 – – – 8410.000 – 1 – – – 8418.000 – 1 1 1 2 2 1 1 1 2 2 1 1 1 2 2 1 1 1 1 2 2 2 1 1 1 2 2 1 1 1 1 2 2 2 1 1 1 2 1 1 1 1 2 1 1 1 1 8684.000 8884.000 8084.000 8080.000 8284.000 8485.000 8685.000 8885.000 8880.000 8285.000 8486.000 8686.000 8886.000 8881.000 8286.000 – 8604.000 8804.000 – 8004.000 – 8204.000 8405.000 8605.000 8805.000 8005.000 8205.000 8406.000 8606.000 8806.000 – 8006.000 – 8206.000 – 8608.000 8808.000 8208.000 – 8626.000 8826.000 – 8226.000 – – – – 116 – 8454.000 – – 8456.000 – 8457.000 8455.000 – 8453.000 – – – – – – – – – – – – – – – – – – 8452.000 8450.000 – – – 8451.000 – – – – – – – – – – – – – 242 – – – – – – – – – – – – – – – – – – – – – – – – – – – – 8840.120 8840.100 – – – – – 8840.130 8840.110 – – – – – – – – – – 128 – – – – – – – – – – – – – – – – – – – – – – – – – – – – 8430.000 – – – – – – 8438.000 – – – – – – – – – – – 130 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 8807.000 – – – – – – – – – – – – – – – – – 131 600 800 1200 600 800 1200 600 800 1200 1600 x 600 600 1600 x 800 600 600 800 1000 1000 1200 400 600 800 800 1200 400 600 800 800 1200 400 600 800 850 1000 1100 1200 400 600 800 1000 1200 400 600 800 850 1000 1100 1200 400 600 800 1200 400 600 800 1000 1200 400 600 800 1200 1400 x 500 1600 x 500 1800 x 400 1800 x 500 1800 x 600 2000 x 400 2000 x 500 2000 x 600 2000 x 800 2200 x 600 2200 x 800 from page 1) Glazed door at the front, rear door 104 2) IP 66/NEMA 4 Sheet steel 8615.000 8815.000 8215.000 8645.000 8845.000 8245.000 8665.000 8865.000 8265.000 Doors 1200 x 500 Electronic enclosure2) Model No. Width mm Material Basic enclosure with glazed door1) Rear door Rittal System Catalogue 36/Enclosures Enclosures Baying enclosure system VX25 – Product overview 3) IP 66/NEMA 4X Distribution enclosure Modular enclosure3) Fuse-switchdisconnector enclosure EMC enclosure Model No. Model No. Model No. Model No. Model No. 1 1 2 1 1 2 1 1 2 Stainless steel – – – – – – – – – Sheet steel – – – – – – – – – Sheet steel – – – – – – – – – Sheet steel – – – – – – – – – Sheet steel4) – – – – – – – – – 600 1 – – – – – 600 1 – – – – – 600 800 1000 1000 1200 400 600 800 800 1200 400 600 800 800 1200 400 600 800 850 1000 1100 1200 400 600 800 1000 1200 400 600 800 850 1000 1100 1200 400 600 800 1200 400 600 800 1000 1200 400 600 800 1200 1 1 1 2 2 1 1 1 2 2 1 1 1 2 2 1 1 1 1 2 2 2 1 1 1 2 2 1 1 1 1 1 2 2 1 1 1 1 1 1 1 1 2 1 1 1 1 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 8458.000 – – – – – – – – – – – – – – – – – 246 – – – – – – – – – – – – – – – – – – 9666.956 – 9666.966 – – – – – – – – – 9666.916 – 9666.926 – – – – – – – – – – – – – – 135 – – – – – – – – – – – – – – – – – – – – – – – – – – – 9680.406 9680.606 9680.806 – – – – 9680.408 9680.608 9680.808 – 9680.426 9680.626 9680.826 – – 9680.428 9680.628 9680.828 – 132 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 9680.005 – – – – – 9680.207 – – – 9680.025 – – – – 9680.227 134 – – – – – – – – – – – – – – – – – – – – – – – – – – – – – 8807.010 – – – – – – 8807.020 – – – – – – – – – – 136 Width mm Doors 600 800 1200 600 800 1200 600 800 1200 Without door 4) Sheet steel with magnesium zinc coating Rittal System Catalogue 36/Enclosures 105 Baying enclosure system VX25system Baying enclosure VX25 – Added system benefits System benefits – Rittal’s standards (not to be taken for granted) create additional cross-system benefits 106 Rittal System Catalogue 36/Enclosures Digitalization Enclosures ◾ The QR code on all machinable enclosure panels permits fully automated incorporation into the production workflow, for seamless digital monitoring from the incoming goods right through to the finished product. Material savings ◾ As standard, potential equalisation of the enclosure panels occurs during screwfastening, which saves up to seven earth straps per enclosure and also improves work safety by eliminating sharp-edged protruding parts. System ◾ Automatic potential equalisation of the roof, rear panel and sides acts as earthing when Rittal climate control devices and Rittal fan-and-filter units are installed. Reliable engineering ◾ Rittal’s customers are supported by a wealth of conversion and planning tools in the automated production process and when working with a virtual prototype: – – – – – – – – Rittal System Catalogue 36/Enclosures Configurators Parts list converters EPLAN Pro Panel 2D/3D CAD data ecl@ss Advanced Technical documentation Data for planners Assembly videos 107 Baying enclosure system VX25system Baying enclosure VX25 – Added system benefits Frame and punched sections – Now with added assembly-friendliness plus efficient engineering thanks to a symmetrical frame section on a 25 mm pitch pattern across all levels, accessible from all sides. 108 Rittal System Catalogue 36/Enclosures Accessibility Enclosures ◾ The system offers an outer mounting level in addition to the inner level, making the enclosure readily accessible and configurable from the outside. Installation options ◾ The continuous pattern of square punchings supports the use of M5/M6//M8 cage nuts to create more mounting options at all profile levels. Stability ◾ The corner piece with welded base frame makes it easier to secure to the floor and base and improves stability. ◾ The enclosure is secured to the base/ plinth or subsurface either via the M12 thread in the corner piece or via the stable base structure. Simple cable entry ◾ The blunt edges minimise the risk of cable damage when routing cables underneath the enclosure. ◾ The earthing points pre-labelled as standard provide quick guidance and help to speed up the work process. ◾ The double edge fold of the gland plates is resistant to bending even under heavy loads to ensure compliance with the high protection category. Rittal System Catalogue 36/Enclosures 109 Baying enclosure system VX25system Baying enclosure VX25 – Added time savings Doors and walls – More flexible, assembly-friendly and economical, thanks to an ingenious hinge system, a quick-fit and readily replaceable lock system, and the elimination of avoidable machining processes. 110 Rittal System Catalogue 36/Enclosures Making life easier Enclosures ◾ The new hinge allows doors to be fitted and removed incredibly easily without any tools, and separately locking and unlocking the hinge bolts is a thing of the past. Handling ◾ For one-man assembly, the positioning aid for the side and rear panels allows laboursaving pre-fixing for the ideal fit, which you can screw-fasten later on when you have both hands free. Flexibility ◾ Because the hinges of the main and adjacent doors in two-door enclosures can be swapped to the opposite side if required, this creates greater flexibility when installing cooling units in the enclosure doors and helps to avoid collisions between equipment and doors. Time savings ◾ The tool-free, readily exchangeable lock systems, e.g. on the comfort handle, reduce the amount of assembly time required. Rittal System Catalogue 36/Enclosures 111 Baying enclosure system VX25system Baying enclosure VX25 – Added reductions in complexity Baying – Complexity is further reduced thanks to a simplified, more consistent baying system for all applications. 112 Rittal System Catalogue 36/Enclosures Overview Enclosures ◾ The baying connectors have been designed to cover every potential baying scenario in enclosure production with just a few baying solutions. This allows easier decision-making and relieves the pressure on engineering. Location flexibility ◾ The option of baying from all four sides allows an individual response to every space situation. Clamping force ◾ The baying connectors are screwed into place in the direction of baying to bring the enclosures safely into position and are approved for transportation. Sealing efficiency ◾ The seal, which can be inserted in a flash, allows precise positioning and can be removed at any time. Rittal System Catalogue 36/Enclosures 113 Baying enclosure system VX25system Baying enclosure VX25 – Added assembly-friendliness Mounting plate – More time gains, installation options and assembly-friendliness thanks to improved mounting kits, also suitable for dynamic loads. 114 Rittal System Catalogue 36/Enclosures Space gain Enclosures ◾ The option of fitting the mounting plate 20 mm deeper in the enclosure with a special installation kit creates additional space in the enclosure depth. Process efficiency ◾ The integral clip means that the mounting plate slide block can be dismantled with no need for tools and easily refitted. This helps to streamline the fully automated machining process in every respect. Flexibility ◾ The system divider designed for installation in the enclosure depth divides wide enclosures into two halves, increasing the flexibility of interior installation. Additional benefits ◾ The practical mounting plate slide rail can be removed once the mounting plate has been inserted and used elsewhere in the enclosure as a fully functional punched section. ◾ The grid print facilitates the simple, fast positioning of components on the mounting plate. Rittal System Catalogue 36/Enclosures 115 Baying enclosure system VX25 System accessories Page 877 VX25 basic enclosure with glazed door Page 128 VX25 stainless steel Page 242 VX25 EMC-shielded Page 136 F F B G B H T T G Supply includes: – Enclosure frame – Door(s) (r/h hinge, may be swapped to opposite side) – Roof plate – Rear panel – Gland plates – Mounting plate – 2 punched rails 18 x 39 mm – Lock: 3 mm double-bit H Material and surface finish: – Enclosure frame: Sheet steel, 1.5 mm, dipcoat-primed – Roof: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Door: Sheet steel, 2 mm, dipcoat-primed, powder-coated on the outside, textured paint – Rear panel: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Gland plates: Sheet steel, 1.5 mm, zinc-plated, passivated – Mounting plate: Sheet steel, 3 mm, zinc-plated, passivated Approvals: – UL – cUL – DNV-GL – Lloyds Register of Shipping Further approvals can be found on the Internet. Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Protection category NEMA: – NEMA 12 116 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Baying enclosure system VX25 Basic enclosure, height 1200 mm, depth 500 mm 600 800 1200 Height (H) mm Packs of 1200 1200 1200 Depth (T) mm 500 500 500 Mounting plate width (F) mm 499 699 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1096 1096 1096 8615.000 8815.000 8215.000 66.0 82.4 126.0 1 1 2 8640.002 8640.003 8640.007 Page Enclosures Width (B) mm Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.032 8640.032 8640.032 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.042 8640.042 8640.042 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8115.245 8115.245 8115.245 901 – – – Divider panel Divider panel for module plates – – – Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). – – – Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 937 see page see page see page 941, 942 Lock inserts 912 937 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 951 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.720 8619.730 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4116.500 4118.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4116.000 4118.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 956 – – – Mounting plate infill Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.030 8617.040 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.020 8617.020 8617.020 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.130 8617.140 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.120 8617.120 8617.120 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.710 8617.710 8617.710 993 Support strip for the enclosure depth 20 pc(s). 4695.000 4695.000 4695.000 994 C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4945.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). 8617.800 8617.810 8617.830 996 see page see page see page 1014 LED system light Earth straps Cable entry plates Cable entry grommets see page see page see page 1033 8619.800 8619.801 8619.803 1044 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 1044 8618.800 8618.801 8618.803 1045 2 pc(s). 2 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of 8618.810 8618.811 8618.813 Packs of 2 pc(s). 2 pc(s). 4 pc(s). see page see page see page 1058 2 pc(s). 8619.410 8619.420 8619.440 1059 Cable duct Cable clamp rail, right angle section Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 1045 117 Baying enclosure system VX25 Basic enclosure, height 1400 mm, depth 500 mm Width (B) mm 600 800 1200 Height (H) mm Packs of 1400 1400 1400 Depth (T) mm 500 500 500 Mounting plate width (F) mm 499 699 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1296 1296 1296 8645.000 8845.000 8245.000 73.8 92.2 141.0 1 1 2 8640.002 8640.003 8640.007 Page Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.032 8640.032 8640.032 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.042 8640.042 8640.042 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8145.245 8145.245 8145.245 901 – – – Divider panel Divider panel for module plates – – – Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 912 – – – Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 937 Glazed door 912 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 937 see page see page see page 941, 942 Lock inserts 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 951 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.720 8619.730 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4116.500 4118.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4116.000 4118.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 956 – – – Mounting plate infill Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.030 8617.040 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.020 8617.020 8617.020 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.130 8617.140 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.120 8617.120 8617.120 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.710 8617.710 8617.710 993 Support strip for the enclosure depth 20 pc(s). 4695.000 4695.000 4695.000 994 C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4945.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). 8617.800 8617.810 8617.830 996 see page see page see page 1014 LED system light Earth straps Cable entry plates Cable entry grommets see page see page 1033 8619.801 8619.803 1044 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 1044 8618.800 8618.801 8618.803 1045 2 pc(s). 2 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of 8618.810 8618.811 8618.813 Packs of 2 pc(s). 2 pc(s). 4 pc(s). see page see page see page 1058 2 pc(s). 8619.410 8619.420 8619.440 1059 Cable duct Cable clamp rail, right angle section 118 see page 8619.800 Further technical information available on the Internet. 1045 Rittal System Catalogue 36/Enclosures Baying enclosure system VX25 Basic enclosure, height 1600 mm, depth 500 mm 600 800 1200 Height (H) mm Packs of 1600 1600 1600 Depth (T) mm 500 500 500 Mounting plate width (F) mm 499 699 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1496 1496 1496 8665.000 8865.000 8265.000 81.9 102.0 156.0 1 1 2 8640.002 8640.003 8640.007 Page Enclosures Width (B) mm Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.032 8640.032 8640.032 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.042 8640.042 8640.042 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8165.245 8165.245 8165.245 901 – – – Divider panel Divider panel for module plates – – – Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 912 – – – Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 937 Glazed door 912 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 937 see page see page see page 941, 942 Lock inserts 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 951 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.720 8619.730 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4116.500 4118.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4116.000 4118.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 956 – – – Mounting plate infill Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.030 8617.040 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.020 8617.020 8617.020 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.130 8617.140 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.120 8617.120 8617.120 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.710 8617.710 8617.710 993 Support strip for the enclosure depth 20 pc(s). 4695.000 4695.000 4695.000 994 C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4945.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). 8617.800 8617.810 8617.830 996 see page see page see page 1014 LED system light Earth straps Cable entry plates Cable entry grommets see page see page see page 1033 8619.800 8619.801 8619.803 1044 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 1044 8618.800 8618.801 8618.803 1045 2 pc(s). 2 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of 8618.810 8618.811 8618.813 Packs of 2 pc(s). 2 pc(s). 4 pc(s). see page see page see page 1058 2 pc(s). 8619.410 8619.420 8619.440 1059 Cable duct Cable clamp rail, right angle section Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 1045 119 Baying enclosure system VX25 Basic enclosure, height 1800 mm, depth 400 mm Width (B) mm 600 800 1000 1000 1200 Height (H) mm Packs of 1800 1800 1800 1800 1800 Depth (T) mm 400 400 400 400 400 Mounting plate width (F) mm 499 699 899 899 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1696 1696 1696 1696 1696 8684.000 8884.000 8080.000 8084.000 8284.000 86.9 109.0 138.0 133.0 166.0 1 1 2 1 2 8640.002 8640.003 8640.005 8640.005 8640.007 Page Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.031 8640.031 8640.031 8640.031 8640.031 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.024 8640.024 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.041 8640.041 8640.041 8640.041 8640.041 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8184.245 8184.245 8184.245 8184.245 8184.245 901 Divider panel 1 pc(s). 8609.200 8609.200 8609.200 8609.200 8609.200 905 – – – – – Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 8617.500 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). 8618.000 8618.010 – – – 917 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 8618.230 8618.230 937 Divider panel for module plates 912 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 8618.270 8618.270 937 see page see page see page see page see page 941, 942 8618.330 8618.330 8618.330 8618.330 8618.330 951 Lock inserts 180° hinges 4 pc(s). Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.720 8619.730 8619.710 8619.750 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4116.500 4118.500 4115.500 – 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4116.000 4118.000 4115.000 4124.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 8618.420 8618.420 956 Mounting plate infill 1 pc(s). 4590.700 4590.700 4590.700 4590.700 4590.700 971 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.030 8617.040 8617.050 8617.050 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.010 8617.010 8617.010 8617.010 8617.010 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.130 8617.140 8617.150 8617.150 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.110 8617.110 8617.110 8617.110 8617.110 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.700 8617.700 8617.700 8617.700 8617.700 993 Support strip for the enclosure depth 20 pc(s). 4694.000 4694.000 4694.000 4694.000 4694.000 994 C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4945.000 4946.000 4946.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). 8617.800 8617.810 8617.820 8617.820 8617.830 996 see page see page see page see page see page 1014 LED system light Earth straps see page see page see page see page see page 1033 8619.800 8619.801 8619.802 8619.802 8619.803 1044 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 4316.000 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 4318.000 1044 Cable entry plates Cable entry grommets Connector grommets 10 pc(s). Section for cable entry, centre Section for cable entry, rear Packs of 120 4311.000 4311.000 4311.000 4311.000 4311.000 1044 8618.800 8618.801 8618.802 8618.802 8618.803 1045 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). 4 pc(s). 8618.810 8618.811 8618.812 8618.812 8618.813 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). 4 pc(s). see page see page see page see page see page 1058 2 pc(s). 8619.410 8619.420 8619.430 8619.430 8619.440 1059 Cable duct Cable clamp rail, right angle section 1044 Further technical information available on the Internet. 1045 Rittal System Catalogue 36/Enclosures Baying enclosure system VX25 Basic enclosure, height 1800 mm, depth 500 mm 400 600 800 800 1200 Height (H) mm Packs of 1800 1800 1800 1800 1800 Depth (T) mm 500 500 500 500 500 Mounting plate width (F) mm 299 499 699 699 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1696 1696 1696 1696 1696 8485.000 8685.000 8880.000 8885.000 8285.000 66.4 90.0 119.0 113.0 173.0 1 1 2 1 2 8640.001 8640.002 8640.003 8640.003 8640.007 Page Enclosures Width (B) mm Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.032 8640.032 8640.032 8640.032 8640.032 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.021 8640.022 8640.023 8640.023 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.042 8640.042 8640.042 8640.042 8640.042 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8185.245 8185.245 8185.245 8185.245 8185.245 901 Divider panel 1 pc(s). 8609.201 8609.201 8609.201 8609.201 8609.201 905 Divider panel for module plates 1 pc(s). 8609.210 8609.210 8609.210 8609.210 8609.210 906 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). – 8618.000 – 8618.010 – 917 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 8618.230 8618.230 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 8618.270 8618.270 937 see page see page see page see page see page 941, 942 8618.330 951 Lock inserts 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 8618.330 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.700 8619.720 8619.700 8619.730 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). – 4116.500 – 4118.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4114.000 4116.000 4114.000 4118.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 8618.420 8618.420 956 Mounting plate infill 1 pc(s). 4590.700 4590.700 4590.700 4590.700 4590.700 971 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.010 8617.030 8617.040 8617.040 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.020 8617.020 8617.020 8617.020 8617.020 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.110 8617.130 8617.140 8617.140 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.120 8617.120 8617.120 8617.120 8617.120 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.710 8617.710 8617.710 8617.710 8617.710 993 Support strip for the enclosure depth 20 pc(s). 4695.000 4695.000 4695.000 4695.000 4695.000 994 C rail 30/15, for the enclosure width 6 pc(s). – 4944.000 4945.000 4945.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). – 8617.800 8617.810 8617.810 8617.830 996 LED system light see page see page see page see page see page 1014 Earth straps see page see page see page see page see page 1033 – 8619.800 8619.801 8619.801 8619.803 1044 Cable entry plates Cable entry grommets Packs of – 2 pc(s). 2 pc(s). 2 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 4316.000 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 4311.000 4311.000 1044 – 8618.800 8618.801 8618.801 8618.803 1045 – 2 pc(s). 2 pc(s). 2 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of – 8618.810 8618.811 8618.811 8618.813 Packs of – 2 pc(s). 2 pc(s). 2 pc(s). 4 pc(s). see page see page see page see page see page 1058 2 pc(s). 8619.400 8619.410 8619.420 8619.420 8619.440 1059 Cable duct Cable clamp rail, right angle section Rittal System Catalogue 36/Enclosures 1044 Further technical information available on the Internet. 1045 121 Baying enclosure system VX25 Basic enclosure, height 1800 mm, depth 600 mm Width (B) mm 400 600 800 800 1200 Height (H) mm Packs of 1800 1800 1800 1800 1800 Depth (T) mm 600 600 600 600 600 Mounting plate width (F) mm 299 499 699 699 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1696 1696 1696 1696 1696 8486.000 8686.000 8881.000 8886.000 8286.000 69.6 92.3 121.0 116.0 174.0 1 1 2 1 2 8640.001 8640.002 8640.003 8640.003 8640.007 Page Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.033 8640.033 8640.033 8640.033 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.021 8640.022 8640.023 8640.023 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.043 8640.043 8640.043 8640.043 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8186.245 8186.245 8186.245 8186.245 8186.245 901 Divider panel 1 pc(s). 8609.202 8609.202 8609.202 8609.202 8609.202 905 Divider panel for module plates 1 pc(s). 8609.211 8609.211 8609.211 8609.211 8609.211 906 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). – 8618.000 – 8618.010 – 917 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 8618.230 8618.230 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 8618.270 8618.270 937 see page see page see page see page see page 941, 942 8618.330 951 Lock inserts 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 8618.330 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.700 8619.720 8619.700 8619.730 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). – 4116.500 – 4118.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4114.000 4116.000 4114.000 4118.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 8618.420 8618.420 956 Mounting plate infill 1 pc(s). 4590.700 4590.700 4590.700 4590.700 4590.700 971 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.010 8617.030 8617.040 8617.040 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.030 8617.030 8617.030 8617.030 8617.030 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.110 8617.130 8617.140 8617.140 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.130 8617.130 8617.130 8617.130 8617.130 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.720 8617.720 8617.720 8617.720 8617.720 993 Support strip for the enclosure depth 20 pc(s). 4696.000 4696.000 4696.000 4696.000 4696.000 994 C rail 30/15, for the enclosure width 6 pc(s). – 4944.000 4945.000 4945.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). – 8617.800 8617.810 8617.810 8617.830 996 LED system light see page see page see page see page see page 1014 Earth straps see page see page see page see page see page 1033 – 8619.800 8619.801 8619.801 8619.803 1044 Cable entry plates Cable entry grommets Packs of – 2 pc(s). 2 pc(s). 2 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 4316.000 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 4311.000 4311.000 1044 – 8618.800 8618.801 8618.801 8618.803 1045 – 2 pc(s). 2 pc(s). 2 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of – 8618.810 8618.811 8618.811 8618.813 Packs of – 2 pc(s). 2 pc(s). 2 pc(s). 4 pc(s). see page see page see page see page see page 1058 2 pc(s). 8619.400 8619.410 8619.420 8619.420 8619.440 1059 Cable duct Cable clamp rail, right angle section 122 1044 Further technical information available on the Internet. 1045 Rittal System Catalogue 36/Enclosures Baying enclosure system VX25 Basic enclosure, height 2000 mm, depth 400 mm 600 800 1000 1200 Height (H) mm Packs of 2000 2000 2000 2000 Depth (T) mm 400 400 400 400 Mounting plate width (F) mm 499 699 899 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1896 1896 1896 1896 8604.000 8804.000 8004.000 8204.000 95.4 120.0 152.0 183.0 1 1 2 2 8640.002 8640.003 8640.005 8640.007 Page Enclosures Width (B) mm Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.031 8640.031 8640.031 8640.031 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.024 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.041 8640.041 8640.041 8640.041 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8104.245 8104.245 8104.245 8104.245 901 Divider panel 1 pc(s). 8609.203 8609.203 8609.203 8609.203 905 – – – – Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). 8618.020 8618.030 – – 917 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 8618.230 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 8618.270 937 see page see page see page see page 941, 942 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 8618.330 951 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.720 8619.730 8619.710 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4116.500 4118.500 4115.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4116.000 4118.000 4115.000 4116.000 955 Divider panel for module plates Lock inserts 912 Door stay 1 pc(s). 8618.430 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 8618.420 956 Mounting plate infill 1 pc(s). 4591.700 4591.700 4591.700 4591.700 971 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.030 8617.040 8617.050 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.010 8617.010 8617.010 8617.010 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.130 8617.140 8617.150 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.110 8617.110 8617.110 8617.110 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.700 8617.700 8617.700 8617.700 993 Support strip for the enclosure depth 20 pc(s). 4694.000 4694.000 4694.000 4694.000 994 C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4945.000 4946.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). 8617.800 8617.810 8617.820 8617.830 996 see page see page see page see page 1014 LED system light Earth straps Cable entry plates Cable entry grommets see page see page see page see page 1033 8619.800 8619.801 8619.802 8619.803 1044 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 4311.000 1044 8618.800 8618.801 8618.802 8618.803 1045 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of 8618.810 8618.811 8618.812 8618.813 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). see page see page see page see page 1058 2 pc(s). 8619.410 8619.420 8619.430 8619.440 1059 Cable duct Cable clamp rail, right angle section Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 1045 123 Baying enclosure system VX25 Basic enclosure, height 2000 mm, depth 500 mm Width (B) mm 400 600 800 1000 1200 Height (H) mm Packs of 2000 2000 2000 2000 2000 Depth (T) mm 500 500 500 500 500 Mounting plate width (F) mm 299 499 699 899 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1896 1896 1896 1896 1896 8405.000 8605.000 8805.000 8005.000 8205.000 73.0 98.0 122.0 156.0 187.0 1 1 1 2 2 8640.001 8640.002 8640.003 8640.005 8640.007 Page Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.032 8640.032 8640.032 8640.032 8640.032 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.021 8640.022 8640.023 8640.024 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.042 8640.042 8640.042 8640.042 8640.042 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8105.245 8105.245 8105.245 8105.245 8105.245 901 Divider panel 1 pc(s). 8609.204 8609.204 8609.204 8609.204 8609.204 905 Divider panel for module plates 1 pc(s). 8609.212 8609.212 8609.212 8609.212 8609.212 906 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). – 8618.020 8618.030 – – 917 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 8618.230 8618.230 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 8618.270 8618.270 937 see page see page see page see page see page 941, 942 951 Lock inserts 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 8618.330 8618.330 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.700 8619.720 8619.730 8619.710 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). – 4116.500 4118.500 4115.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4114.000 4116.000 4118.000 4115.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 8618.420 8618.420 956 Mounting plate infill 1 pc(s). 4591.700 4591.700 4591.700 4591.700 4591.700 971 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.010 8617.030 8617.040 8617.050 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.020 8617.020 8617.020 8617.020 8617.020 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.110 8617.130 8617.140 8617.150 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.120 8617.120 8617.120 8617.120 8617.120 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.710 8617.710 8617.710 8617.710 8617.710 993 Support strip for the enclosure depth 20 pc(s). 4695.000 4695.000 4695.000 4695.000 4695.000 994 C rail 30/15, for the enclosure width 6 pc(s). – 4944.000 4945.000 4946.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). – 8617.800 8617.810 8617.820 8617.830 996 LED system light see page see page see page see page see page 1014 Earth straps see page see page see page see page see page 1033 – 8619.800 8619.801 8619.802 8619.803 1044 Cable entry plates Cable entry grommets Packs of – 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 4316.000 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 4311.000 4311.000 1044 – 8618.800 8618.801 8618.802 8618.803 1045 – 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of – 8618.810 8618.811 8618.812 8618.813 Packs of – 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). see page see page see page see page see page 1058 2 pc(s). 8619.400 8619.410 8619.420 8619.430 8619.440 1059 Cable duct Cable clamp rail, right angle section 124 1044 Further technical information available on the Internet. 1045 Rittal System Catalogue 36/Enclosures Baying enclosure system VX25 Basic enclosure, height 2000 mm, depth 600 mm 400 600 800 1000 1200 Height (H) mm Packs of 2000 2000 2000 2000 2000 Depth (T) mm 600 600 600 600 600 Mounting plate width (F) mm 299 499 699 899 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1896 1896 1896 1896 1896 8406.000 8606.000 8806.000 8006.000 8206.000 75.2 101.0 126.0 160.0 191.0 1 1 1 2 2 8640.001 8640.002 8640.003 8640.005 8640.007 Page Enclosures Width (B) mm Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.033 8640.033 8640.033 8640.033 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.021 8640.022 8640.023 8640.024 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.043 8640.043 8640.043 8640.043 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8106.245 8106.245 8106.245 8106.245 8106.245 901 Divider panel 1 pc(s). 8609.205 8609.205 8609.205 8609.205 8609.205 905 Divider panel for module plates 1 pc(s). 8609.213 8609.213 8609.213 8609.213 8609.213 906 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). – 8618.020 8618.030 – – 917 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 8618.230 8618.230 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 8618.270 8618.270 937 see page see page see page see page see page 941, 942 951 Lock inserts 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 8618.330 8618.330 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.700 8619.720 8619.730 8619.710 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). – 4116.500 4118.500 4115.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4114.000 4116.000 4118.000 4115.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 8618.420 8618.420 956 Mounting plate infill 1 pc(s). 4591.700 4591.700 4591.700 4591.700 4591.700 971 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.010 8617.030 8617.040 8617.050 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.030 8617.030 8617.030 8617.030 8617.030 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.110 8617.130 8617.140 8617.150 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.130 8617.130 8617.130 8617.130 8617.130 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.720 8617.720 8617.720 8617.720 8617.720 993 Support strip for the enclosure depth 20 pc(s). 4696.000 4696.000 4696.000 4696.000 4696.000 994 C rail 30/15, for the enclosure width 6 pc(s). – 4944.000 4945.000 4946.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). – 8617.800 8617.810 8617.820 8617.830 996 LED system light see page see page see page see page see page 1014 Earth straps see page see page see page see page see page 1033 – 8619.800 8619.801 8619.802 8619.803 1044 Cable entry plates Cable entry grommets Packs of – 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 4316.000 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 4311.000 4311.000 1044 – 8618.800 8618.801 8618.802 8618.803 1045 – 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of – 8618.810 8618.811 8618.812 8618.813 Packs of – 2 pc(s). 2 pc(s). 4 pc(s). 4 pc(s). see page see page see page see page see page 1058 2 pc(s). 8619.400 8619.410 8619.420 8619.430 8619.440 1059 Cable duct Cable clamp rail, right angle section Rittal System Catalogue 36/Enclosures 1044 Further technical information available on the Internet. 1045 125 Baying enclosure system VX25 Basic enclosure, height 2000 mm, depth 800 mm Width (B) mm 600 800 1200 Height (H) mm Packs of 2000 2000 2000 Depth (T) mm 800 800 800 Mounting plate width (F) mm 499 699 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 1896 1896 1896 8608.000 8808.000 8208.000 106.0 138.0 201.0 1 1 2 8640.002 8640.003 8640.007 Page Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.034 8640.034 8640.034 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.044 8640.044 8640.044 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8108.245 8108.245 8108.245 901 Divider panel 1 pc(s). 8609.206 8609.206 8609.206 905 – – – Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). 8618.020 8618.030 – 917 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 937 Divider panel for module plates 912 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 937 see page see page see page 941, 942 Lock inserts 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 951 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.720 8619.730 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4116.500 4118.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4116.000 4118.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 956 Mounting plate infill 1 pc(s). 4591.700 4591.700 4591.700 971 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.030 8617.040 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.040 8617.040 8617.040 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.130 8617.140 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.140 8617.140 8617.140 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.730 8617.730 8617.730 993 Support strip for the enclosure depth 20 pc(s). 4697.000 4697.000 4697.000 994 C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4945.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). 8617.800 8617.810 8617.830 996 see page see page see page 1014 LED system light Earth straps Cable entry plates Cable entry grommets see page see page 1033 8619.801 8619.803 1044 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 1044 8618.800 8618.801 8618.803 1045 2 pc(s). 2 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of 8618.810 8618.811 8618.813 Packs of 2 pc(s). 2 pc(s). 4 pc(s). see page see page see page 1058 2 pc(s). 8619.410 8619.420 8619.440 1059 Cable duct Cable clamp rail, right angle section 126 see page 8619.800 Further technical information available on the Internet. 1045 Rittal System Catalogue 36/Enclosures Baying enclosure system VX25 Basic enclosure, height 2200 mm, depth 600 mm 600 800 1200 Height (H) mm Packs of 2200 2200 2200 Depth (T) mm 600 600 600 Mounting plate width (F) mm 499 699 1099 Mounting plate height (G) mm Model No. 1 pc(s). Weight kg 2096 2096 2096 8626.000 8826.000 8226.000 106.0 136.0 204.0 1 1 2 8640.002 8640.003 8640.007 Page Enclosures Width (B) mm Product-specific scope of supply Door(s) Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.033 8640.033 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.043 8640.043 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8126.245 8126.245 8126.245 901 Divider panel 1 pc(s). 8609.207 8609.207 8609.207 905 – – – Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 912 Glazed door 1 pc(s). 8618.040 8618.050 – 917 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 937 Divider panel for module plates 912 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 937 see page see page see page 941, 942 Lock inserts 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 951 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.720 8619.730 8619.720 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4116.500 4118.500 4116.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4116.000 4118.000 4116.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 956 Mounting plate infill 1 pc(s). 4592.700 4592.700 4592.700 971 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.030 8617.040 8617.060 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.030 8617.030 8617.030 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.130 8617.140 8617.160 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.130 8617.130 8617.130 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.720 8617.720 8617.720 993 Support strip for the enclosure depth 20 pc(s). 4696.000 4696.000 4696.000 994 C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4945.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). 8617.800 8617.810 8617.830 996 see page see page see page 1014 LED system light Earth straps Cable entry plates Cable entry grommets see page see page see page 1033 8619.800 8619.801 8619.803 1044 Packs of 2 pc(s). 2 pc(s). 4 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 1044 8618.800 8618.801 8618.803 1045 2 pc(s). 2 pc(s). 4 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Packs of 8618.810 8618.811 8618.813 Packs of 2 pc(s). 2 pc(s). 4 pc(s). see page see page see page 1058 2 pc(s). 8619.410 8619.420 8619.440 1059 Cable duct Cable clamp rail, right angle section Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 1045 127 Baying enclosure system VX25 System accessories Page 877 VX25 basic enclosure Page 116 VX25 stainless steel Page 242 VX25 EMC-shielded Page 136 Supply includes: – Enclosure frame – Door(s) (r/h hinge, may be swapped to opposite side) – Roof plate – Glazed door at front – Rear door – Gland plates – Lock: 3 mm double-bit T B H Material and surface finish: – Enclosure frame: Sheet steel, 1.5 mm, dipcoat-primed – Roof: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Glazed door: Extruded aluminium section, powder-coated, single-pane safety glass, 3 mm – Rear door: Sheet steel, 2 mm, dipcoat-primed, powdercoated on the outside, textured paint – Gland plates: Sheet steel, 1.5 mm, zinc-plated, passivated Approvals: – UL – cUL – CSA Further approvals can be found on the Internet. Colour: – Enclosure frame, door frame, corner pieces, panels: RAL 7035 – Viewing window (printed mask on the inside): RAL 9005 Protection category IP to IEC 60 529: – IP 55 Protection category NEMA: – NEMA 12 128 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Baying enclosure system VX25 Basic enclosure with glazed door Packs of Height (H) mm Depth (T) mm Model No. 1 pc(s). Weight kg 600 600 800 800 2000 2000 2000 2000 600 800 600 800 8840.120 8840.130 8840.100 8840.110 71.0 75.4 84.2 90.0 Page Enclosures Width (B) mm Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.002 8640.002 8640.003 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.034 8640.033 8640.034 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.022 8640.023 8640.023 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.044 8640.043 8640.044 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8106.245 8108.245 8106.245 8108.245 901 Divider panel 1 pc(s). 8609.205 8609.206 8609.205 8609.206 905 Divider panel for module plates 1 pc(s). 8609.213 – 8609.213 – 906 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 912 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 8618.230 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 8618.250 937 Comfort handle VX with security lock insert, lock E1 1 pc(s). 8618.240 8618.240 8618.240 8618.240 937 Comfort handle VX for ASSA lock system 1 pc(s). 8618.270 8618.270 8618.270 8618.270 937 see page see page see page see page 941, 942 180° hinges 4 pc(s). 8618.330 8618.330 8618.330 8618.330 951 Punched section with mounting flange, 14 x 39 mm, for tubular door frame 4 pc(s). 8619.720 8619.720 8619.730 8619.730 952 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4116.500 4116.500 4118.500 4118.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4116.000 4116.000 4118.000 4118.000 955 Door stay 1 pc(s). 8618.430 8618.430 8618.430 8618.430 956 Door stay for escape routes 1 pc(s). 8618.425 8618.425 8618.425 8618.425 956 Ride-up roller 10 pc(s). 8618.420 8618.420 8618.420 8618.420 956 Punched section with mounting flange 18 x 64 mm for the outer level, in the width 4 pc(s). 8617.030 8617.030 8617.040 8617.040 990 Punched section with mounting flange 18 x 64 mm for the outer level, in the depth 4 pc(s). 8617.030 8617.040 8617.030 8617.040 990 Punched section with mounting flange 23 x 64 mm for the inner level, in the width 4 pc(s). 8617.130 8617.130 8617.140 8617.140 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth 4 pc(s). 8617.130 8617.140 8617.130 8617.140 991 Punched rail 18 x 39 mm for the enclosure depth 4 pc(s). 8617.720 8617.730 8617.720 8617.730 993 Support strip for the enclosure depth 20 pc(s). 4696.000 4697.000 4696.000 4697.000 994 C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4944.000 4945.000 4945.000 996 Support rail 48 x 26 mm, for the enclosure width 2 pc(s). 8617.800 8617.800 8617.810 8617.810 996 see page see page see page see page 1014 Lock inserts LED system light Earth straps Cable entry plates Cable entry grommets see page see page see page see page 1033 8619.800 8619.800 8619.801 8619.801 1044 Packs of 2 pc(s). 2 pc(s). 2 pc(s). 2 pc(s). 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 1044 10 pc(s). 4311.000 4311.000 4311.000 4311.000 1044 8618.800 8618.800 8618.801 8618.801 1045 2 pc(s). 2 pc(s). 2 pc(s). 2 pc(s). Connector grommets Section for cable entry, centre Section for cable entry, rear Cable clamp rail, right angle section Rittal System Catalogue 36/Enclosures Packs of 8618.810 8618.810 8618.811 8618.811 Packs of 2 pc(s). 2 pc(s). 2 pc(s). 2 pc(s). 2 pc(s). 8619.410 8619.410 8619.420 8619.420 Further technical information available on the Internet. 1045 1059 129 Baying enclosure system VX25 System accessories Page 877 482.6 mm (19") installation accessories Page 1075 482.6 mm (19") climate control Page 466 Material and surface finish: – Enclosure frame: Sheet steel, 1.5 mm, dipcoat-primed – Roof: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Front frame: Extruded aluminium section, powder-coated – Rear door: Sheet steel, 2 mm, dipcoat-primed, powdercoated on the outside, textured paint – Gland plates: Sheet steel, 1.5 mm, zinc-plated, passivated – 482.6 mm (19") adaptor sections: Sheet steel, zinc-plated Supply includes: – Enclosure frame – Front frame (r/h hinge, held on the left via magnetic snap fasteners) – Rear door (r/h hinge, may be swapped to opposite side) – Roof plate – Gland plates – Adaptor sections, 482.6 mm (19"), front Colour: – RAL 7035 Electronic enclosure Height units U 33 33 42 42 Width mm Packs of 600 600 600 600 Height mm 1600 1600 2000 2000 Depth mm 600 800 600 800 8410.000 8418.000 8430.000 8438.000 58.0 63.2 67.8 72.2 8640.002 8640.002 8640.002 8640.002 Model No. 1 pc(s). Weight kg Page Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.034 8640.033 8640.034 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.022 8640.022 8640.022 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.044 8640.043 8640.044 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8166.245 8168.245 8106.245 8108.245 901 Comfort handle VX for lock inserts 1 pc(s). 8618.200 8618.200 8618.200 8618.200 937 Comfort handle VX for lock inserts and padlock 1 pc(s). 8618.230 8618.230 8618.230 8618.230 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 8618.250 8618.250 8618.250 937 see page see page see page see page 941, 942 4 pc(s). 8617.030 8617.040 8617.030 8617.040 990 see page see page see page see page 1014 Section for cable entry, centre 2 pc(s). 8618.800 8618.800 8618.800 8618.800 1045 Section for cable entry, rear 2 pc(s). 8618.810 8618.810 8618.810 8618.810 1045 Cable clamp rail, right angle section 2 pc(s). 8619.410 8619.410 8619.410 8619.410 1059 Adaptor section, 482.6 mm (19") 2 pc(s). 8619.300 8619.300 8619.320 8619.320 1080 Adaptor piece, 482.6 mm (19") 4 pc(s). 8619.330 8619.330 8619.330 8619.330 1081 Lock inserts Punched section with mounting flange 18 x 64 mm for the outer level, in the depth LED system light Slide rail with two-sided mounting 10 pc(s). 8613.161 8613.181 8613.161 8613.181 1089 Slide rail with one-sided mounting 10 pc(s). 4531.001 4531.001 4531.001 4531.001 1089 482.6 mm (19") fastener, 1 U 24 pc(s). 2090.000 2090.000 2090.000 2090.000 1097 130 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Enclosures Baying enclosure system VX25 System accessories Page 877 Cable entry Page 1044 Protection category NEMA: – NEMA 4 Supply includes: – Enclosure frame – Door (r/h hinge, may be swapped to opposite side) – Roof plate – Base – Rear panel – Mounting plate – Lock: 3 mm double-bit – 2 punched rails 18 x 39 mm – Accessory kit for side panels for upgrading to IP 66/NEMA 4 Note: – The standard baying connectors VX for bayed suites may be used while maintaining the protection category IP 66/NEMA 4X F T Approvals: – UL – cUL – DNV-GL B G Protection category IP to IEC 60 529: – IP 66 H Material and surface finish: – Enclosure frame: Sheet steel, 1.5 mm, dipcoat-primed and powder-coated, textured paint – Roof: Sheet steel, 1.5 mm, dipcoat-primed and powdercoated, textured paint – Door: Sheet steel, 2 mm, dipcoat-primed and powdercoated, textured paint – Rear panel: Sheet steel, 1.5 mm, dipcoat-primed and powder-coated, textured paint – Gland plate: Sheet steel, 1.5 mm, dipcoat-primed and powder-coated, textured paint – Mounting plate: Sheet steel, 3 mm, zinc-plated, passivated Colour: – RAL 7035 IP 66/NEMA 4 Width (B) mm Packs of 800 Height (H) mm 2000 Depth (T) mm 600 Mounting plate width (F) mm 699 Mounting plate height (G) mm 1896 Model No. 1 pc(s). Page 8807.000 Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.023 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 882 Levelling feet 4 pc(s). 4612.000 892 Side panels, screw-fastened, sheet steel 2 pc(s). 8106.245 901 Baying bracket, internal 6 pc(s). 8617.500 912 Baying block, internal 6 pc(s). 8617.501 912 Baying connector, external 6 pc(s). 8617.502 912 Comfort handle VX for lock inserts 1 pc(s). 8618.200 937 Comfort handle VX for profile half-cylinders 1 pc(s). 8618.250 937 Wiring plan pocket, sheet steel, depth 35 mm 1 pc(s). 4118.500 955 Wiring plan pocket, sheet steel, depth 90 mm 1 pc(s). 4118.000 955 see page 1014 see page 1058 8619.420 1059 LED system light Cable duct Cable clamp rail, right angle section Rittal System Catalogue 36/Enclosures 2 pc(s). Further technical information available on the Internet. 131 Baying enclosure system VX25 System accessories Page 877  Modular front design Page 925  Compartment configuration Page 410   Material and surface finish: – Enclosure frame: Sheet steel, 1.5 mm, dipcoat-primed – Rear panel: Sheet steel,  1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Gland plates: Sheet steel,  1.5 mm, zinc-plated Colour: – RAL 7035 Protection category IP to IEC 60 529: – Up to IP 54, depending on the panels Basis of test: – IEC 61 439-1/-2 – IEC 61 641 Supply includes: – Enclosure frame – Rear panel – Gland plates Modular enclosure, height 2000 mm Width mm Packs of Height mm Depth mm Model No. 1 pc(s). Weight kg 400 600 800 400 600 800 2000 2000 2000 2000 2000 2000 600 600 600 800 800 800 9680.406 9680.606 9680.806 9680.408 9680.608 9680.808 43.8 51.0 61.0 46.0 53.7 64.2 Page Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.001 8640.002 8640.003 8640.001 8640.002 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.033 8640.033 8640.034 8640.034 8640.034 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.021 8640.022 8640.023 8640.021 8640.022 8640.023 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.043 8640.043 8640.044 8640.044 8640.044 882 Side panel, screw-fastened, sheet steel 2 pc(s). 8106.245 8106.245 8106.245 8106.245 8108.245 8108.245 901 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 8617.502 8617.502 912 Partial door see page see page see page see page see page see page 926 Front trim panel, top, solid see page see page see page see page see page see page 927 Front trim panel, bottom, solid see page see page see page see page see page see page 927 927 Front trim panel, bottom, vented 1 pc(s). 9682.354 9682.356 9682.358 9682.354 9682.356 9682.358 Roof plate IP 55, solid 1 pc(s). 9681.646 9681.666 9681.686 9681.648 9681.668 9681.688 961 Roof plate IP 2X with ventilation hole 1 pc(s). 9681.846 9681.866 9681.886 9681.848 9681.868 9681.888 961 Roof plate for cable entry glands 1 pc(s). 9681.546 9681.566 9681.586 9681.548 9681.568 9681.588 961 see page see page see page see page see page see page 962 Cable entry gland 132 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Baying enclosure system VX25 Modular enclosure, height 2200 mm Packs of Height mm Depth mm Model No. 1 pc(s). Weight kg 400 600 800 400 600 800 2200 2200 2200 2200 2200 2200 600 600 600 800 800 800 9680.426 9680.626 9680.826 9680.428 9680.628 9680.828 43.2 54.0 59.4 46.1 55.8 66.0 Page Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.001 8640.002 8640.003 8640.001 8640.002 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.033 8640.033 8640.034 8640.034 8640.034 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.021 8640.022 8640.023 8640.021 8640.022 8640.023 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.043 8640.043 8640.044 8640.044 8640.044 882 Side panel, screw-fastened, sheet steel 2 pc(s). 8126.245 8126.245 8126.245 8128.245 8128.245 8128.245 901 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 8617.502 8617.502 912 Partial door see page see page see page see page see page see page 926 Front trim panel, top, solid see page see page see page see page see page see page 927 Front trim panel, bottom, solid see page see page see page see page see page see page 927 927 Front trim panel, bottom, vented 1 pc(s). 9682.354 9682.356 9682.358 9682.354 9682.356 9682.358 Roof plate IP 55, solid 1 pc(s). 9681.646 9681.666 9681.686 9681.648 9681.668 9681.688 961 Roof plate IP 2X with ventilation hole 1 pc(s). 9681.846 9681.866 9681.886 9681.848 9681.868 9681.888 961 Roof plate for cable entry glands 1 pc(s). 9681.546 9681.566 9681.586 9681.548 9681.568 9681.588 961 see page see page see page see page see page see page 962 Rittal – The System. Cable entry gland Rittal System Catalogue 36/Enclosures Modular front design see page 925 Further technical information available on the Internet. 133 Enclosures Width mm Baying enclosure system VX25 System accessories Page 877  Compartment configuration Page 410  Fuse-switch disconnector section Page 415   Material and surface finish: – Enclosure frame: Sheet steel, 1.5 mm, dipcoat-primed – Roof: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Door: Sheet steel, 2 mm, dipcoat-primed, powder-coated on the outside, textured paint – Rear panel: Sheet steel,  1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Gland plate: Sheet steel,  1.5 mm, zinc-plated – Front trim panel: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Compartment side panel: Sheet steel, 1.5 mm, zincplated Colour: – RAL 7035 Basis of test: – IEC 61 439-1/-2 – IEC 61 641 Protection category IP to IEC 60 529: – Up to IP 3X, depending on the panels Supply includes: – Enclosure frame – Door – Roof plate – Rear panel – Gland plates – Front trim panels – Lock: 3 mm double-bit – Compartment side panels – Locating frame for disconnectors with fuses (brands ABB SlimLine/Jean Müller SASIL) Fuse-switch-disconnector enclosure, height 2000 – 2200 mm Width mm Packs of Height mm Depth mm Model No. 1 pc(s). Weight kg 1000 1200 1000 1200 2000 2000 2200 2200 600 800 600 800 9680.005 9680.207 9680.025 9680.227 125.3 149,6 135.2 158.9 8640.007 8640.005 8640.007 Page Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.005 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.034 8640.033 8640.034 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.024 8640.025 8640.024 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.044 8640.043 8640.044 882 Side panel, screw-fastened, sheet steel 2 pc(s). 8106.245 8108.245 8126.245 8128.245 901 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 912 Roof plate IP 2X with ventilation hole 1 pc(s). 9681.806 9681.828 9681.806 9681.828 961 134 Further technical information available on the Internet. 881 Rittal System Catalogue 36/Enclosures Enclosures Baying enclosure system VX25 System accessories Page 877  ISV assembly modules Page 421  VX basic enclosure Page 116  Lock systems Page 937   Material and surface finish: – Enclosure frame: Sheet steel, 1.5 mm, dipcoat-primed – Roof: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Door: Sheet steel, 2 mm, dipcoat-primed, powder-coated on the outside, textured paint – Rear panel: Sheet steel,  1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Gland plates: Sheet steel,  1.5 mm, zinc-plated Supply includes: – Enclosure frame – Door(s) (door hinged on the right, may be swapped to the left) – Gland plates – Rear panel – Roof plate – Lock: 3 mm double-bit Please observe the productspecific scope of supply. Colour: – RAL 7035 Basis of test: – IEC 61 439-1/-2 Protection category IP to IEC 60 529: – IP 55 Protection category NEMA: – NEMA 12 Note: – For 600 mm wide distribution enclosures, please use VX basic enclosures – For a base/plinth height of 200 mm, 2 packs each of plinth corner pieces, 100 mm and base/plinth trim panels, 100 mm are required Distribution enclosure Width mm Packs of Height mm Depth mm Model No. 1 pc(s). Weight kg 850 1100 850 1100 2000 2000 2000 2000 400 400 600 600 9666.956 9666.966 9666.916 9666.926 111.0 146.0 117.0 156.0 1 2 1 2 Page Product-specific scope of supply Number of doors Also required ISV installation kit 1 pc(s). 9666.912 9666.922 9666.912 9666.922 420 Mounting angles ISV 2 pc(s). 9666.712 9666.712 9666.712 9666.712 429 Depth stay for installation kit ISV 2 pc(s). – 9666.732 – 9666.732 430 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.004 8640.006 8640.004 8640.006 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.031 8640.031 8640.033 8640.033 882 Side panel, screw-fastened, sheet steel 2 pc(s). 8104.245 8104.245 8106.245 8106.245 901 Baying bracket, internal 6 pc(s). 8617.500 8617.500 8617.500 8617.500 912 Baying block, internal 6 pc(s). 8617.501 8617.501 8617.501 8617.501 912 Baying connector, external 6 pc(s). 8617.502 8617.502 8617.502 8617.502 912 Roof plate for cable entry glands 1 pc(s). 9681.594 9681.514 9681.596 9681.516 961 see page see page see page see page 962 Accessories Cable entry gland Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 135 Baying enclosure system VX25 System accessories Page 877 VX25 basic enclosure Page 116 VX25 stainless steel Page 242 The large enclosures in the VX25 series offer a good level of shielding across a broad frequency range, even in the standard version. For increased EMC requirements, Rittal’s VX25 enclosure is also available in a high RF attenuation version. Material and surface finish: – Enclosure frame: Sheet steel, 1.5 mm, with magnesium zinc coating – Roof: Sheet steel, 1.5 mm, with magnesium zinc coating, spray-finished on the outside and paint-free on the inside – Door: Sheet steel, 2 mm, with magnesium zinc coating, spray-finished on the outside and paint-free on the inside – Rear panel: Sheet steel, 1.5 mm, with magnesium zinc coating, spray-finished on the outside and paint-free on the inside – Gland plates: Sheet steel, 1.5 mm, zinc-plated – Mounting plate: Sheet steel, 3 mm, zinc-plated Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 NEMA protection category: – NEMA 12 Note: – For bayed enclosures, the EMC shielding seal is required Approvals: – UL – cUL Further approvals can be found on the Internet. Supply includes: – Enclosure frame – Door(s) (door hinged on the right, may be swapped to the left) – Rear panel – Roof plate – Gland plates – Mounting plate – Lock: 3 mm double-bit – 2 punched rails 18 x 39 mm EMC enclosure Width mm Packs of Height mm Depth mm Model No. 1 pc(s). Weight kg 800 800 2000 2000 600 800 8807.010 8807.020 130.0 135.0 Page Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.003 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.034 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.023 8640.023 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.044 882 EMC side panels 2 pc(s). 8106.760 8108.760 1028 EMC shielding seal 1 pc(s). 8800.695 8800.695 1028 Divider panel 1 pc(s). 8609.205 8609.206 905 EMC divider panel seal 1 pc(s). 4348.500 4348.500 1028 Rail for EMC shielding bracket 1 pc(s). 2388.850 2388.850 1029 see page see page 1029 1030 EMC shielding bracket EMC shield bus see page see page 8618.821 8618.821 1029 EMC earth clamps see page see page 1030 EMC cable glands see page see page 1030 Cable duct see page see page 1058 LED system light see page see page 1014 Earth strap see page see page 1033 Earthing braid see page see page 1033 Comfort handle VX see page see page 937 EMC gland plates 136 1 pc(s). Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures LED system light Enclosures Innovative LED technology produces even more light, see page 1012 Rittal System Catalogue 36/Enclosures 137 Free-standing enclosure system VX SE system Free-standing enclosure VX SE Added efficiency with planning and assembly 138 Rittal System Catalogue 36/Enclosures Digitalization Enclosures ◾ The QR code on all machinable enclosure panels permits fully automated incorporation into the production workflow, for seamless digital monitoring from the incoming goods right through to the finished product. Reliable engineering ◾ In the automated production process and when working with virtual prototypes, Rittal supports its customers with a host of conversion and planning tools: – Configurators – Parts list converters – EPLAN Pro Panel – 2D/3D CAD data – ecl@ss Advanced – Technical documentation – Data for planners Large variety of sizes ◾ Enclosure widths from 600 – 1800 mm ◾ Widths 1600 and 1800 mm are only available for VX SE. These replace several bayed enclosures. Benefits: – No baying work – One large, continuous mounting plate – Savings on accessories: – Only one base/plinth – Only one handle – No need to use a mounting plate infill – 300 mm deep enclosures are ideal for use in facility management Smart construction ◾ High stability thanks to a self-supporting, integral construction technique, with roof and sides from a single piece with rollformed frame ◾ High protection category up to IP 66 ◾ A wide range of sheet steel and stainless steel versions for almost any application area ◾ 300 mm deep enclosures are ideal for use in facility management Rittal System Catalogue 36/Enclosures 139 Free-standing enclosure system VX SE system Free-standing enclosure VX SE Compatibility with the VX25 for added efficiency in interior installation, even more efficient 140 Rittal System Catalogue 36/Enclosures Compatible interior installation ◾ With the new base assembly and optional adaptor rail, interior installation is compatible with the VX25 Enclosures ◾ All VX25 punched sections and bars for the inner mounting level may be used without restriction ◾ The large swing frame supports full or partial installation for 482.6 mm (19˝) components. It is fully depth-adjustable within the 25 mm pitch pattern, and hinged on the left or right. Two swing frames may also be fitted together in 1200 mm wide enclosures. Optimum installation options ◾ The continuous square holes on the vertical section when using adaptor rail VX support the use of metric screw-fastenings M5, M6, M8 System benefits ◾ The smart enclosure design from a single piece eliminates the need for additional earth straps from the roof and side panels to the frame ◾ Automatic potential equalisation from the rear panel to the enclosure as standard ◾ When using a Rittal climate control device and Rittal fan-and-filter unit in the roof, rear panel and side panels, additional earthing is not required ◾ The smart enclosure design from a single piece ensures good EMC properties Simple cable entry ◾ The blunt edges minimise the risk of cable damage when routing cables underneath the enclosure ◾ The earthing points pre-labelled as standard provide quick guidance and help to accelerate the work process ◾ The double edge fold of the gland plates prevents bending even under heavy loads to ensure compliance with the high protection category Rittal System Catalogue 36/Enclosures 141 Free-standing enclosure system VX SE System accessories Page 877 VX SE stainless steel Page 248 Base/plinth Page 880 142 Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Approvals: – UL – cUL F T B Supply includes: – Enclosure, solid top and sides – Door(s) – R/h door hinge with single-door enclosures, may be swapped to opposite side – Mounting plate – Gland plates – Rear panel, detachable – Lock: 3 mm double-bit – 2 punched rails 18 x 39 mm Please note the product-specific scope of supply. Further technical information available on the Internet. G Protection category NEMA: – NEMA 12 H Material and surface finish: – Enclosure: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Door: Sheet steel, 2 mm, dipcoat-primed, powder-coated on the outside, textured paint – Rear panel: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Mounting plate: Sheet steel, 3 mm, zinc-plated, passivated – Gland plates: Sheet steel, 1.5 mm, zinc-plated, passivated Rittal System Catalogue 36/Enclosures Free-standing enclosure system VX SE Basic enclosure, width 600 mm 600 600 600 Height (H) mm Packs of 1800 1800 2000 Depth (T) mm 300 400 300 Mounting plate width (F) mm 499 499 499 Mounting plate height (G) mm 1696 1696 1896 5820.600 5830.600 5821.600 Rear panel, one-piece ◾ ◾ ◾ Door(s) 1 1 1 8640.002 8640.002 8640.002 Model No. 1 pc(s). Page Enclosures Width (B) mm Product-specific scope of supply Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.030 8640.031 8640.030 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.022 8640.022 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.040 8640.041 8640.040 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 892 Glazed door 1 pc(s). 8610.685 8610.685 8610.605 918 Comfort handle for lock insert 1 pc(s). 8611.020 8611.020 8611.020 938 Comfort handle for lock insert and padlock 1 pc(s). 8611.290 8611.290 8611.290 938 Comfort handle for profile half-cylinders 1 pc(s). 8611.070 8611.070 8611.070 938 see page see page see page 941, 942 Lock inserts 881 180° hinges 4 pc(s). 8800.190 8800.190 8800.190 951 Punched section with mounting flange, 14 x 39 mm, for door 4 pc(s). 8619.720 8619.720 8619.720 952 Wiring plan pocket, depth 35 mm 1 pc(s). 4116.500 4116.500 4116.500 955 Wiring plan pocket, depth 90 mm 1 pc(s). 4116.000 4116.000 4116.000 955 Door stay 5 pc(s). 4583.000 4583.000 4583.000 956 Door stay for escape routes 1 pc(s). 4583.500 4583.500 4583.500 956 Ride-up roller 10 pc(s). 4538.000 4538.000 4538.000 956 Adaptor rail VX to fit enclosure height 4 pc(s). 8617.750 8617.750 8617.751 995 Punched section with mounting flange 17 x 73 mm for the inner level, in the depth 4 pc(s). 8612.030 8612.040 8612.030 992 Punched section with mounting flange 17 x 73 mm for the outer level, in the depth 4 pc(s). 8612.130 8612.140 8612.130 992 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth1) 4 pc(s). 8617.100 8617.110 8617.100 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the width1) 4 pc(s). 8617.130 8617.130 8617.130 991 993 depth1) 4 pc(s). – 8617.700 – Support strip for the outer level for enclosure depth 20 pc(s). – 4694.000 – 994 Support strip for the inner level for enclosure depth 20 pc(s). – 4309.000 – 994 Punched rail 18 x 39 mm for the enclosure C rail 30/15, for the enclosure width 6 pc(s). 4944.000 4944.000 4944.000 996 Support rail 48 x 26 mm, for the enclosure width1) 2 pc(s). 8617.800 8617.800 8617.800 996 LED system light see page see page see page 1014 Earth straps see page see page see page 1033 Cable entry plate 2 pc(s). 8619.800 8619.800 8619.800 1044 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 1044 Connector grommets 10 pc(s). 4311.000 4311.000 4311.000 1044 Section for cable entry, centre 2 pc(s). 8618.800 8618.800 8618.800 1045 Section for cable entry, rear 2 pc(s). 8618.810 8618.810 8618.810 1045 see page see page see page 1058 8619.410 8619.410 8619.410 1059 Cable entry grommets Cable duct Cable clamp rail, right angle section 1) 2 pc(s). The VX adaptor rail is required for installation in the vertical enclosure sections. Overview of VX SE compatible rail systems, see page 986 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 143 Free-standing enclosure system VX SE Basic enclosure, width 800 mm Width (B) mm 800 800 800 800 800 800 Height (H) mm Packs of 1800 1800 2000 2000 2000 2000 Depth (T) mm 300 400 300 400 500 600 Mounting plate width (F) mm 699 699 699 699 699 699 Mounting plate height (G) mm 1696 1696 1896 1896 1896 1896 5822.600 5831.600 5823.600 5832.600 5833.600 5834.600 Rear panel, one-piece ◾ ◾ ◾ ◾ ◾ ◾ Door(s) 1 1 1 1 1 1 Model No. 1 pc(s). Page Product-specific scope of supply Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.003 8640.003 8640.003 8640.003 8640.003 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.030 8640.031 8640.030 8640.031 8640.032 8640.033 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.023 8640.023 8640.023 8640.023 8640.023 8640.023 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.040 8640.041 8640.040 8640.041 8640.042 8640.043 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 4612.000 4612.000 892 Glazed door 1 pc(s). 8610.885 8610.885 8610.805 8610.805 8610.805 8610.805 918 Comfort handle for lock insert 1 pc(s). 8611.020 8611.020 8611.020 8611.020 8611.020 8611.020 938 Comfort handle for lock insert and padlock 1 pc(s). 8611.290 8611.290 8611.290 8611.290 8611.290 8611.290 938 Comfort handle for profile half-cylinders 1 pc(s). 8611.070 8611.070 8611.070 8611.070 8611.070 8611.070 938 see page see page see page see page see page see page 941, 942 Lock inserts 180° hinges 4 pc(s). 8800.190 8800.190 8800.190 8800.190 8800.190 8800.190 951 Punched section with mounting flange, 14 x 39 mm, for door 4 pc(s). 8619.730 8619.730 8619.730 8619.730 8619.730 8619.730 952 Wiring plan pocket, depth 35 mm 1 pc(s). 4118.500 4118.500 4118.500 4118.500 4118.500 4118.500 955 Wiring plan pocket, depth 90 mm 1 pc(s). 4118.000 4118.000 4118.000 4118.000 4118.000 4118.000 955 Door stay 5 pc(s). 4583.000 4583.000 4583.000 4583.000 4583.000 4583.000 956 Door stay for escape routes 1 pc(s). 4583.500 4583.500 4583.500 4583.500 4583.500 4583.500 956 Ride-up roller 10 pc(s). 4538.000 4538.000 4538.000 4538.000 4538.000 4538.000 956 Adaptor rail VX to fit enclosure height 4 pc(s). 8617.750 8617.750 8617.751 8617.751 8617.751 8617.751 995 Punched section with mounting flange 17 x 73 mm for the inner level, in the depth 4 pc(s). 8612.030 8612.040 8612.030 8612.040 8612.050 8612.060 992 Punched section with mounting flange 17 x 73 mm for the outer level, in the depth 4 pc(s). 8612.130 8612.140 8612.130 8612.140 8612.150 8612.160 992 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth1) 4 pc(s). 8617.100 8617.110 8617.100 8617.110 8617.120 8617.130 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the width1) 4 pc(s). 8617.140 8617.140 8617.140 8617.140 8617.140 8617.140 991 993 depth1) 4 pc(s). – 8617.700 – 8617.700 8617.710 8617.720 Support strip for the outer level for enclosure depth 20 pc(s). – 4694.000 – 4694.000 4695.000 4696.000 994 Support strip for the inner level for enclosure depth 20 pc(s). – 4309.000 – 4309.000 4596.000 8800.130 994 Punched rail 18 x 39 mm for the enclosure C rail 30/15, for the enclosure width 6 pc(s). 4945.000 4945.000 4945.000 4945.000 4945.000 4945.000 996 Support rail 48 x 26 mm, for the enclosure width1) 2 pc(s). 8617.810 8617.810 8617.810 8617.810 8617.810 8617.810 996 LED system light see page see page see page see page see page see page 1014 Earth straps see page see page see page see page see page see page 1033 Cable entry plate Cable entry grommets 2 pc(s). 8619.801 8619.801 8619.801 8619.801 8619.801 8619.801 1044 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 4318.000 4318.000 1044 Connector grommets 10 pc(s). 4311.000 4311.000 4311.000 4311.000 4311.000 4311.000 1044 Section for cable entry, centre 2 pc(s). 8618.801 8618.801 8618.801 8618.801 8618.801 8618.801 1045 Section for cable entry, rear 2 pc(s). 8618.811 8618.811 8618.811 8618.811 8618.811 8618.811 1045 see page see page see page see page see page see page 1058 8619.420 8619.420 8619.420 8619.420 8619.420 8619.420 1059 Cable duct Cable clamp rail, right angle section 1) 2 pc(s). The VX adaptor rail is required for installation in the vertical enclosure sections. Overview of VX SE compatible rail systems, see page 986 144 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Free-standing enclosure system VX SE Basic enclosure, width 1000 – 1200 mm 1000 1200 1200 1200 1200 1200 1200 Height (H) mm Packs of 1800 1800 1800 2000 2000 2000 2000 Depth (T) mm 400 300 400 300 400 500 600 Mounting plate width (F) mm 899 1099 1099 1099 1099 1099 1099 1696 1696 1696 1896 1896 1896 1896 Mounting plate height (G) mm Model No. 1 pc(s). Page Enclosures Width (B) mm 5840.600 5824.600 5841.600 5825.600 5843.600 5844.600 5845.600 Product-specific scope of supply Rear panel, one-piece ◾ ◾ ◾ ◾ ◾ ◾ ◾ Door(s) 2 2 2 2 2 2 2 Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.031 8640.030 8640.031 8640.030 8640.031 8640.032 8640.033 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.024 8640.025 8640.025 8640.025 8640.025 8640.025 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.041 8640.040 8640.041 8640.040 8640.041 8640.042 8640.043 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 4612.000 4612.000 4612.000 4612.000 892 Comfort handle for lock insert 1 pc(s). 8611.020 8611.020 8611.020 8611.020 8611.020 8611.020 8611.020 938 Comfort handle for lock insert and padlock 1 pc(s). 8611.290 8611.290 8611.290 8611.290 8611.290 8611.290 8611.290 938 Comfort handle for profile half-cylinders 1 pc(s). 8611.070 8611.070 8611.070 8611.070 8611.070 8611.070 8611.070 938 Glazed door 8640.005 8640.007 8640.007 8640.007 8640.007 8640.007 8640.007 – Lock inserts – see page see page – see page – see page – see page – see page 881 – see page 941, 942 180° hinges 4 pc(s). 8800.190 8800.190 8800.190 8800.190 8800.190 8800.190 8800.190 Punched section with mounting flange, 14 x 39 mm, for door 4 pc(s). 8619.710 8619.720 8619.720 8619.720 8619.720 8619.720 8619.720 952 Wiring plan pocket, depth 35 mm 1 pc(s). 4115.500 4116.500 4116.500 4116.500 4116.500 4116.500 4116.500 955 Wiring plan pocket, depth 90 mm 1 pc(s). 4115.000 4116.000 4116.000 4116.000 4116.000 4116.000 4116.000 955 Door stay 5 pc(s). 4583.000 4583.000 4583.000 4583.000 4583.000 4583.000 4583.000 956 Door stay for escape routes 1 pc(s). 4583.500 4583.500 4583.500 4583.500 4583.500 4583.500 4583.500 956 Ride-up roller 10 pc(s). 4538.000 4538.000 4538.000 4538.000 4538.000 4538.000 4538.000 956 Adaptor rail VX to fit enclosure height 4 pc(s). 8617.750 8617.750 8617.750 8617.751 8617.751 8617.751 8617.751 995 Punched section with mounting flange 17 x 73 mm for the inner level, in the depth 4 pc(s). 8612.040 8612.030 8612.040 8612.030 8612.040 8612.050 8612.060 992 Punched section with mounting flange 17 x 73 mm for the outer level, in the depth 4 pc(s). 8612.140 8612.130 8612.140 8612.130 8612.140 8612.150 8612.160 992 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth1) 4 pc(s). 8617.110 8617.100 8617.110 8617.100 8617.110 8617.120 8617.130 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the width1) 4 pc(s). 8617.150 8617.160 8617.160 8617.160 8617.160 8617.160 8617.160 991 4 pc(s). 993 depth1) 951 8617.700 – 8617.700 – 8617.700 8617.710 8617.720 Support strip for the outer level for enclosure depth 20 pc(s). 4694.000 – 4694.000 – 4694.000 4695.000 4696.000 994 Support strip for the inner level for enclosure depth 20 pc(s). 4309.000 – 4309.000 – 4309.000 4596.000 8800.130 994 Punched rail 18 x 39 mm for the enclosure C rail 30/15, for the enclosure width 6 pc(s). 4946.000 4947.000 4947.000 4947.000 4947.000 4947.000 4947.000 996 Support rail 48 x 26 mm, for the enclosure width1) 2 pc(s). 8617.820 8617.830 8617.830 8617.830 8617.830 8617.830 8617.830 996 LED system light see page see page see page see page see page see page see page 1014 Earth straps see page see page see page see page see page see page see page 1033 Cable entry plate 8619.802 8619.803 8619.803 8619.803 8619.803 8619.803 8619.803 1044 8 cables, max. Ø 13 mm 25 pc(s). 4316.000 4316.000 4316.000 4316.000 4316.000 4316.000 4316.000 1044 3 cables, max. Ø 21 mm 25 pc(s). 4317.000 4317.000 4317.000 4317.000 4317.000 4317.000 4317.000 1044 1 cable, max. Ø 47 mm 25 pc(s). 4318.000 4318.000 4318.000 4318.000 4318.000 4318.000 4318.000 1044 Connector grommets 10 pc(s). 4311.000 4311.000 4311.000 4311.000 4311.000 4311.000 4311.000 1044 Section for cable entry, centre 4 pc(s). 8618.802 8618.803 8618.803 8618.803 8618.803 8618.803 8618.803 1045 Section for cable entry, rear 4 pc(s). 8618.812 8618.813 8618.813 8618.813 8618.813 8618.813 8618.813 1045 see page see page 1058 8619.430 8619.440 8619.440 8619.440 8619.440 8619.440 8619.440 1059 Cable entry grommets 4 pc(s). Cable duct Cable clamp rail, right angle section 1) 2 pc(s). see page see page see page see page see page The VX adaptor rail is required for installation in the vertical enclosure sections. Overview of VX SE compatible rail systems, see page 986 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 145 Free-standing enclosure system VX SE Basic enclosure, width 1600 – 1800 mm Width (B) mm Packs of Height (H) mm 1600 1800 1800 2000 Depth (T) mm 400 500 Mounting plate width (F) mm 1499 1699 Mounting plate height (G) mm 1696 1896 5842.600 5846.600 Rear panel, two-piece ◾ ◾ Door(s) 2 2 8640.009 Model No. 1 pc(s). Page Product-specific scope of supply Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.008 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.031 8640.032 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.026 8640.027 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.041 8640.042 882 Levelling feet 4 pc(s). 4612.000 4612.000 892 – – Comfort handle for lock insert 1 pc(s). 8611.020 8611.020 938 Comfort handle for lock insert and padlock 1 pc(s). 8611.290 8611.290 938 Comfort handle for profile half-cylinders 1 pc(s). 8611.070 8611.070 938 Lock inserts 1 pc(s). see page see page 941, 942 180° hinges 4 pc(s). 8800.190 8800.190 951 Punched section with mounting flange, 14 x 39 mm, for door 4 pc(s). 8619.730 8619.740 952 Wiring plan pocket, depth 35 mm 1 pc(s). 4118.500 – 955 Wiring plan pocket, depth 90 mm 1 pc(s). 4118.000 4123.000 955 Door stay 5 pc(s). 4583.000 4583.000 956 Door stay for escape routes 1 pc(s). 4583.500 4583.500 956 Ride-up roller 10 pc(s). 4538.000 4538.000 956 Adaptor rail VX to fit enclosure height 4 pc(s). 8617.750 8617.751 995 Punched section with mounting flange 17 x 73 mm for the inner level, in the depth 4 pc(s). 8612.040 8612.050 992 Punched section with mounting flange 17 x 73 mm for the outer level, in the depth 4 pc(s). 8612.140 8612.150 992 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth1) 4 pc(s). 8617.110 8617.120 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the width1) 4 pc(s). 8617.180 8617.190 991 Glazed door depth1) 881 4 pc(s). 8617.700 8617.710 993 Support strip for the outer level for enclosure depth 20 pc(s). 4694.000 4695.000 994 Support strip for the inner level for enclosure depth 20 pc(s). 4309.000 4596.000 994 see page see page 1014 Punched rail 18 x 39 mm for the enclosure LED system light Earth straps see page see page 1033 Section for cable entry, centre 2 pc(s). 8618.804 – 1045 Section for cable entry, rear 2 pc(s). 8618.814 – 1045 see page see page 1058 8619.450 8619.460 1059 Cable duct Cable clamp rail, right angle section 1) 2 pc(s). The VX adaptor rail is required for installation in the vertical enclosure sections. Overview of VX SE compatible rail systems, see page 986 146 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Enclosures Free-standing enclosure system VX SE System accessories Page 877 VX SE IP 66/NEMA 4X stainless steel Page 250 Base/plinth Page 880 Protection category IP to IEC 60 529: – IP 66 Protection category NEMA: – NEMA 4 Supply includes: – Enclosure, solid top and sides – Door(s) – Door hinged on the right, may be swapped to the left – Mounting plate – Base, solid – Rear panel, detachable – Lock: 3 mm double-bit – 2 punched rails 18 x 39 mm F T B G Colour: – RAL 7035 H Material and surface finish: – Enclosure: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Door: Sheet steel, 2 mm, dipcoat-primed, powder-coated on the outside, textured paint – Rear panel: Sheet steel, 1.5 mm, dipcoat-primed, powder-coated on the outside, textured paint – Mounting plate: Sheet steel, 3 mm, zinc-plated, passivated – Base: Sheet steel, 1.5 mm, dipcoat-primed and powdercoated, textured paint Approvals: – UL – cUL IP 66/NEMA 4 Width (B) mm 600 800 800 Height (H) mm 1800 1800 2000 Depth (T) mm 400 400 600 Mounting plate width (F) mm 499 699 699 Mounting plate height (G) mm 1696 1696 1896 5830.680 5831.680 5834.680 1 1 1 Model No. Packs of 1 pc(s). Door(s) Page Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.002 8640.003 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.031 8640.031 8640.033 882 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.023 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.041 8640.041 8640.043 882 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 892 Comfort handle for lock insert 1 pc(s). 8611.020 8611.020 8611.020 938 Comfort handle for lock insert and padlock 1 pc(s). 8611.290 8611.290 8611.290 938 Comfort handle for profile half-cylinders 1 pc(s). 8611.070 8611.070 8611.070 938 see page see page see page 941, 942 Lock inserts Punched section with mounting flange, 14 x 39 mm, for door 4 pc(s). 8619.720 8619.730 8619.730 952 Wiring plan pocket, depth 90 mm 1 pc(s). 4116.000 4118.000 4118.000 955 Door stay 5 pc(s). 4583.000 4583.000 4583.000 956 Adaptor rail VX to fit enclosure height 4 pc(s). 8617.750 8617.750 8617.751 995 Punched section with mounting flange 17 x 73 mm for the inner level, in the depth 4 pc(s). 8612.040 8612.040 8612.060 992 Punched section with mounting flange 17 x 73 mm for the outer level, in the depth 4 pc(s). 8612.140 8612.140 8612.160 992 Punched section with mounting flange 23 x 64 mm for the inner level, in the depth1) 4 pc(s). 8617.110 8617.110 8617.130 991 Punched section with mounting flange 23 x 64 mm for the inner level, in the width1) 4 pc(s). 8617.130 8617.140 8617.140 991 see page see page see page 1014 LED system light Earth straps Cable clamp rail, right angle section 1) 2 pc(s). see page see page see page 1033 8619.410 8619.420 8619.420 1059 The VX adaptor rail is required for installation in the vertical enclosure sections. Overview of VX SE compatible rail systems, see page 986 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 147 148 Rittal System Catalogue 36/Enclosures Product comparison ...................................................................................150 TopConsole system TP Overview of installation components .......................................................... 153 Combination options ..................................................................................156 600 mm wide ........................................................................................... 157 800 mm wide ........................................................................................... 158 1200 mm wide ......................................................................................... 159 1600 mm wide ......................................................................................... 160 One-piece consoles TP One-piece consoles TP ..............................................................................161 Universal consoles TP Universal consoles TP.................................................................................162 PC enclosure systems PC enclosure systems ................................................................................164 Industrial Workstations Combination options ..................................................................................166 IW enclosures and worktops...................................................................... 167 Rittal System Catalogue 36/Enclosures 149 Enclosures Console systems/ PC enclosure systems/ Industrial Workstations Console systems/PC enclosure systems/IW – Product comparison TopConsole system One-piece consoles Modular console system for operation and monitoring. The separate modules have independent lock systems. One-piece console for operation and monitoring, with large mounting plate Protection category IP to IEC 60 529 IP 55 IP 55 Protection category NEMA NEMA 12 NEMA 12 From the front and above Service access Console from the front, desk unit from above, pedestal from the front (for a depth of 500 mm from the front and rear) Lock system Lock inserts may be replaced individually Lock inserts may be replaced individually Option for interior installation with bar systems on a 25 mm pitch pattern in all modules plus additional installation with partial mounting plates Option for interior installation with bar systems on a 25 mm pitch patterns plus additional installation with partial mounting plates 153 161 Version Installation options from page 150 Rittal System Catalogue 36/Enclosures Enclosures Console systems/PC enclosure systems/IW – Product comparison Universal consoles PC enclosure systems Industrial Workstations Enclosures with a high level of stability. The standard rear door provides free access to the continuous mounting plate. The mounting plate has a C-fold and is depth-adjustable on a 25 mm pitch pattern. The front may optionally be equipped with a short door and desk section or tall door. Enclosure body folded from a single piece for a high level of stability. Continuous rear door for simple service access from the rear. High level of access protection thanks to an interior lock on the glazed door and lockable keyboard drawer. There are four versions with different operating concepts available to suit individual requirements. Modular enclosure system for operation and monitoring. Five different enclosure variants may be combined into individual workstations with special worktops and command panels. IP 55 IP 55 IP 54/55 NEMA 12 NEMA 12 NEMA 12 From the front and rear From the front and above From the front and above Lock inserts may be replaced individually Lock inserts may be replaced individually Lock inserts may be replaced individually Option for interior installation with bar systems on a 25 mm pitch pattern. The desk unit may be designed as an operator console. Option for interior installation with bar systems on a 25 mm pitch pattern. For the lower area, component shelves are available to accommodate computers, printers etc. plus a paper removal flap allowing the printer to be used without opening the door. For the lower area, component shelves are available to accommodate computers, printers etc. plus a paper removal flap allowing the printer to be used without opening the door. The worktop may be extended with components from support arm system CP 60 and a command panel to create a complete workstation. 162 164 166 Rittal System Catalogue 36/Enclosures 151 1 2 1 2 1 152 Rittal System Catalogue 36/Enclosures TopConsole system TP Overview of installation components  Three-part assembly comprising: Enclosures – Console – Desk unit – Pedestal  Two-part assembly comprising: – Desk unit – Pedestal  One-part assembly comprising: – Cover plate – Pedestal 3 3 Rittal System Catalogue 36/Enclosures 153 TopConsole system TP 154 Rittal System Catalogue 36/Enclosures Fast planning and assembly ◾ Identical covers for the console and desk unit ensure straightforward engineering ◾ Individual installation with bar systems Enclosures ◾ Simple installation of preassembled modules using partial mounting plates Simple handling ◾ Simple one-handed operation and reliable latching of the lid stay in the topmost position ◾ Secure lock mechanism with end stop acknowledgement, suitable for all common lock inserts ◾ Stylishly finished with an aluminium strip (accessory) as a design or handle element on the cover Flexible interior installation ◾ Rapid assembly of the mounting plate, simply insert and clip into place (400 mm construction depth) ◾ Depth-adjustable mounting plate (500 mm construction depth) ◾ Plenty of free space for individual configuration on the mounting plate ◾ Individual installation with bar systems ◾ Two-piece gland plates for simple cable entry Rittal System Catalogue 36/Enclosures 155 TopConsole system TP System accessories Page 877 Monitors, keyboards Page 1109/1110 Climate control Page 449 Surface finish: – Enclosure, cover and door: Dipcoat-primed, powdercoated on the outside, textured paint – Mounting plate: Zinc-plated Colour: – RAL 7035 Supply includes: Console – Enclosure – Cover hinged at bottom, including cover retainer – Open base for individual cable entry B H Protection category NEMA: – NEMA 12 Pedestal – Enclosure open at top – Door or double door with locking rod (with depth 400 mm at the front, with depth 500 mm at the front and rear) – Depth-adjustable mounting plate (with depth 500 mm) – Gland plates H Protection category IP to IEC 60 529: – IP 55 Approvals: – UL – cUL T Desk section – Enclosure – Hinged cover, 2 stays with automatic latching, automatic unlatching on the left and manual unlatching on the right – Opening for cable entry into the enclosure base H Material: – Enclosure: Sheet steel, 1.5 mm – Door and console cover: Sheet steel, 2.0 mm, all-round foamed-in PU seal – Mounting plate: Sheet steel 2.5 mm (depth 500 m), 3.0 mm (depth 400 mm) T T Photo shows a configuration example with equipment not included in the scope of supply Combination options 1-part 2-part 3-part Consoles Centre parts Pedestals Base/plinth 156 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures TopConsole system TP Enclosures 600 mm wide Configuration 3-part Depth of pedestal in mm 2-part 400 500 1-part 400 500 400 500 Consoles Height (H) mm Packs of 720 – – 240 – – 1 pc(s). 6720.500 – – Width 200 mm 1 pc(s). 6730.310 – – 982 Width 500 mm 1 pc(s). 6730.330 – – 982 For width 4 pc(s). 5001.050 – – 995 Packs of 235 235 – Page 730 755 – 1 pc(s). 6714.500 6710.500 – 4 pc(s). 5001.050 5001.050 – 995 Packs of – – 27 Page – – 400 500 – – 5001.130 6730.100 163 675 675 Page Depth (T) mm Model No. Page Accessories Partial mounting plate, locatable Rail for interior installation Centre parts Height (H) mm Depth (T) mm Model No. Accessories Rail for interior installation For width Cover plate Height (H) mm Depth (T) mm Model No. 1 pc(s). Height (H) mm Packs of 675 400 500 400 500 400 500 1 pc(s). 6700.600 6704.600 6700.600 6704.600 6700.600 6704.600 Height 100 mm 2 pc(s). 8640.002 8640.002 8640.002 8640.002 8640.002 8640.002 881 Height 200 mm 2 pc(s). 8640.022 8640.022 8640.022 8640.022 8640.022 8640.022 881 Height 100 mm 2 pc(s). 8640.031 8640.032 8640.031 8640.032 8640.031 8640.032 882 Height 200 mm 2 pc(s). 8640.041 8640.042 8640.041 8640.042 8640.041 8640.042 882 2 pc(s). 8601.450 8601.450 8601.450 8601.450 8601.450 8601.450 891 4 pc(s). 5001.050 5001.050 5001.050 5001.050 5001.050 5001.050 995 Pedestals Depth (T) mm Model No. 675 675 675 Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear Base/plinth trim panels, sides Cross member Rail for interior installation For height Punched section with mounting flange, 17 x 73 mm In the depth 4 pc(s). 8612.140 8612.150 8612.140 8612.150 8612.140 8612.150 992 Support strip In the depth 20 pc(s). 4694.000 4695.000 4694.000 4695.000 4694.000 4695.000 994 Punched section with mounting flange, 17 x 73 mm For door 4 pc(s). 8612.050 8612.050 8612.050 8612.050 8612.050 8612.050 992 Support strip For door 20 pc(s). 4596.000 4596.000 4596.000 4596.000 4596.000 4596.000 952 1 pc(s). 5001.080 5001.080 5001.080 5001.080 5001.080 5001.080 1059 Cable clamp rail Sheet steel wiring plan pockets 1 pc(s). 4116.500 4116.500 4116.500 4116.500 4116.500 4116.500 955 TP aluminium strip 1 pc(s). 6731.120 6731.120 6731.120 6731.120 – – 163 Lock systems from page from page from page from page from page from page 935 LED system light see page see page see page see page see page see page 1014 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 157 TopConsole system TP 800 mm wide Configuration 3-part Depth of pedestal in mm 2-part 400 500 1-part 400 500 400 500 Consoles Height (H) mm Packs of 720 – – 240 – – 1 pc(s). 6721.500 – – Depth (T) mm Model No. Page Accessories Width 200 mm 1 pc(s). 6730.310 – – 982 Partial mounting plate, locatable Width 500 mm 1 pc(s). 6730.330 – – 982 Width 700 mm 1 pc(s). 6730.340 – – 982 For width 4 pc(s). 5001.051 – – 995 Packs of 235 235 – Page 730 755 – 1 pc(s). 6715.500 6711.500 – 4 pc(s). 5001.051 5001.051 – Packs of – – – – 400 500 – – 5001.140 6730.110 163 Page Rail for interior installation Centre parts Height (H) mm Depth (T) mm Model No. Accessories Rail for interior installation For width 995 Cover plate Height (H) mm Depth (T) mm Model No. 1 pc(s). Height (H) mm Packs of 27 Page Pedestals 675 675 675 675 675 675 400 500 400 500 400 500 1 pc(s). 6701.600 6705.600 6701.600 6705.600 6701.600 6705.600 Height 100 mm 2 pc(s). 8640.003 8640.003 8640.003 8640.003 8640.003 8640.003 881 Height 200 mm 2 pc(s). 8640.023 8640.023 8640.023 8640.023 8640.023 8640.023 881 Height 100 mm 2 pc(s). 8640.031 8640.032 8640.031 8640.032 8640.031 8640.032 882 Height 200 mm 2 pc(s). 8640.041 8640.042 8640.041 8640.042 8640.041 8640.042 882 2 pc(s). 8601.450 8601.450 8601.450 8601.450 8601.450 8601.450 891 Depth (T) mm Model No. Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear Base/plinth trim panels, sides Cross member Rail for interior installation For height 4 pc(s). 5001.050 5001.050 5001.050 5001.050 5001.050 5001.050 995 Punched section with mounting flange, 17 x 73 mm In the depth 4 pc(s). 8612.140 8612.150 8612.140 8612.150 8612.140 8612.150 992 Support strip In the depth 20 pc(s). 4694.000 4695.000 4694.000 4695.000 4694.000 4695.000 994 Support strip For door 20 pc(s). 4598.000 4598.000 4598.000 4598.000 4598.000 4598.000 952 Cable clamp rail 1 pc(s). 5001.081 5001.081 5001.081 5001.081 5001.081 5001.081 1059 Sheet steel wiring plan pockets 1 pc(s). 4118.500 4118.500 4118.500 4118.500 4118.500 4118.500 955 TP aluminium strip 1 pc(s). 6731.120 6731.120 6731.120 6731.120 – – 163 Lock systems from page from page from page from page from page from page 935 LED system light see page see page see page see page see page see page 1014 158 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures TopConsole system TP Enclosures 1200 mm wide Configuration 3-part Depth of pedestal in mm 2-part 400 500 1-part 400 500 400 500 Consoles Height (H) mm Packs of 720 – – 240 – – 1 pc(s). 6722.500 – – Depth (T) mm Model No. Page Accessories Width 200 mm 1 pc(s). 6730.310 – – 982 Partial mounting plate, locatable Width 500 mm 1 pc(s). 6730.330 – – 982 Width 700 mm 1 pc(s). 6730.340 – – 982 For width 4 pc(s). 5001.053 – – 995 Packs of 235 235 – Page 730 755 – 1 pc(s). 6716.500 6712.500 – 4 pc(s). 5001.053 5001.053 – Packs of – – – – 400 500 – – 5001.160 6730.120 163 Page Rail for interior installation Centre parts Height (H) mm Depth (T) mm Model No. Accessories Rail for interior installation For width 995 Cover plate Height (H) mm Depth (T) mm Model No. 1 pc(s). Height (H) mm Packs of 27 Page Pedestals 675 675 675 675 675 675 400 500 400 500 400 500 1 pc(s). 6702.600 6706.600 6702.600 6706.600 6702.600 6706.600 Height 100 mm 2 pc(s). 8640.007 8640.007 8640.007 8640.007 8640.007 8640.007 881 Height 200 mm 2 pc(s). 8640.025 8640.025 8640.025 8640.025 8640.025 8640.025 881 Height 100 mm 2 pc(s). 8640.031 8640.032 8640.031 8640.032 8640.031 8640.032 882 Height 200 mm 2 pc(s). 8640.041 8640.042 8640.041 8640.042 8640.041 8640.042 882 2 pc(s). 8601.450 8601.450 8601.450 8601.450 8601.450 8601.450 891 Depth (T) mm Model No. Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear Base/plinth trim panels, sides Cross member Rail for interior installation For height 4 pc(s). 5001.050 5001.050 5001.050 5001.050 5001.050 5001.050 995 Punched section with mounting flange, 17 x 73 mm In the depth 4 pc(s). 8612.140 8612.150 8612.140 8612.150 8612.140 8612.150 992 Support strip In the depth 20 pc(s). 4694.000 4695.000 4694.000 4695.000 4694.000 4695.000 994 Punched section with mounting flange, 17 x 73 mm For door 4 pc(s). 8612.050 8612.050 8612.050 8612.050 8612.050 8612.050 992 Support strip For door 20 pc(s). 4596.000 4596.000 4596.000 4596.000 4596.000 4596.000 952 1 pc(s). 5001.083 5001.083 5001.083 5001.083 5001.083 5001.083 1059 Cable clamp rail Sheet steel wiring plan pockets 1 pc(s). 4116.500 4116.500 4116.500 4116.500 4116.500 4116.500 955 TP aluminium strip 1 pc(s). 6731.120 6731.120 6731.120 6731.120 – – 163 Lock systems from page from page from page from page from page from page 935 LED system light see page see page see page see page see page see page 1014 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 159 TopConsole system TP 1600 mm wide Configuration 3-part Depth of pedestal in mm 2-part 400 500 1-part 400 500 400 500 Consoles Height (H) mm Packs of 720 – – 240 – – 1 pc(s). 6723.500 – – Depth (T) mm Model No. Page Accessories Width 200 mm 1 pc(s). 6730.310 – – 982 Partial mounting plate, locatable Width 500 mm 1 pc(s). 6730.330 – – 982 Width 700 mm 1 pc(s). 6730.340 – – 982 For width 4 pc(s). 5001.054 – – 995 Packs of 235 235 – Page 730 755 – 1 pc(s). 6717.500 6713.500 – 4 pc(s). 5001.054 5001.054 – 995 Packs of – – 27 Page – – 400 500 – – 6730.030 6730.130 163 Page Rail for interior installation Centre parts Height (H) mm Depth (T) mm Model No. Accessories Rail for interior installation For width Trim panel Height (H) mm Depth (T) mm Model No. 1 pc(s). Height (H) mm Packs of Pedestals 675 675 675 675 675 675 400 500 400 500 400 500 1 pc(s). 6703.600 6707.600 6703.600 6707.600 6703.600 6707.600 Height 100 mm 2 pc(s). 8640.008 8640.008 8640.008 8640.008 8640.008 8640.008 881 Height 200 mm 2 pc(s). 8640.026 8640.026 8640.026 8640.026 8640.026 8640.026 881 Height 100 mm 2 pc(s). 8640.031 8640.032 8640.031 8640.032 8640.031 8640.032 882 Height 200 mm 2 pc(s). 8640.041 8640.042 8640.041 8640.042 8640.041 8640.042 882 2 pc(s). 8601.450 8601.450 8601.450 8601.450 8601.450 8601.450 891 Depth (T) mm Model No. Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear Base/plinth trim panels, sides Cross member Rail for interior installation For height 4 pc(s). 5001.050 5001.050 5001.050 5001.050 5001.050 5001.050 995 Punched section with mounting flange, 17 x 73 mm In the depth 4 pc(s). 8612.140 8612.150 8612.140 8612.150 8612.140 8612.150 992 Support strip In the depth 20 pc(s). 4694.000 4695.000 4694.000 4695.000 4694.000 4695.000 994 Support strip For door 20 pc(s). 4598.000 4598.000 4598.000 4598.000 4598.000 4598.000 952 Cable clamp rail Width 800 mm 1059 1 pc(s). 5001.081 5001.081 5001.081 5001.081 5001.081 5001.081 Sheet steel wiring plan pockets 1 pc(s). 4118.500 4118.500 4118.500 4118.500 4118.500 4118.500 955 TP aluminium strip 1 pc(s). 6731.120 6731.120 6731.120 6731.120 – – 163 Lock systems from page from page from page from page from page from page 935 LED system light see page see page see page see page see page see page 1014 160 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Enclosures One-piece consoles TP System accessories P. 877 Monitors, keyboards P. 1109/1110 Climate control P. 449 One-piece consoles, stainless steel P. 251 Surface finish: – Enclosure, cover and door: Dipcoat-primed, powdercoated on the outside, textured paint – Mounting plate: Zinc-plated Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Approvals: – UL – cUL F B Protection category NEMA: – NEMA 12 G T2 Supply includes: – Enclosure, solid back and sides – Door or double door at front, with locking rod – Mounting plate – Cover hinged at rear, 2 stays with automatic locking. Automatic unlocking on the left, manual unlocking on the right – Gland plates Width (B) mm Packs of H Material: – Enclosure: Sheet steel, 1.5 mm – Door and console cover: Sheet steel, 2.0 mm, all-round foamed-in PU seal – Mounting plate: Sheet steel, 3.0 mm T1 600 800 1000 1200 Height (H) mm 975 975 975 975 Depth, bottom (T1) mm 400 400 400 400 Depth, top (T2) mm 520 520 520 520 Mounting plate width (F) mm 530 730 930 1130 Mounting plate height (G) mm Model No. 1 pc(s). Door(s) 900 900 900 900 6746.600 6748.600 6740.600 6742.600 1 1 2 2 Page Accessories Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.002 8640.003 8640.005 8640.007 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.031 8640.031 8640.031 8640.031 882 881 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.023 8640.024 8640.025 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.041 8640.041 8640.041 8640.041 882 Cross member 2 pc(s). 8601.450 8601.450 8601.450 8601.450 891 TP aluminium strip 1 pc(s). 6731.120 6731.120 6731.120 6731.120 163 see page see page see page see page 995 Rail for interior installation Punched section with mounting flange, 17 x 73 mm see page see page see page see page 992 Cable clamp rails 1 pc(s). 5001.080 5001.081 5001.082 5001.083 1059 Sheet steel wiring plan pockets 1 pc(s). 4116.500 4118.500 4115.500 4116.500 955 see page see page see page see page 1014 LED system light Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 161 Universal consoles TP System accessories Page 877 Monitors, keyboards Page 1109/1110 Climate control Page 449 Colour: – RAL 7035 Version Protection category NEMA: – NEMA 12 Approvals: – UL – CSA – TÜV – Russian Maritime Register of Shipping F B T2 Supply includes: – Enclosure with door(s) – Mounting plate – Gland plates G Surface finish: – Enclosure and door: Dipcoatprimed, powder-coated on the outside, textured paint – Mounting plate and gland plates: Zinc-plated Protection category IP to IEC 60 529: – IP 55 H Material: – Enclosure, gland plate: Sheet steel, 1.5 mm – Door: Sheet steel, 2.0 mm – Mounting plate: Sheet steel, 3.0 mm Note: – For universal console with short front door: The desk section should be fitted in order to maintain the protection category Packs of T1 With short front door With tall front door Width (B) mm 600 600 Height (H) mm 1300 1300 Depth, bottom (T1) mm 500 500 417.5 417.5 Depth, top (T2) mm Page Mounting plate width (F) mm 499 499 Mounting plate height (G) mm 1196 1196 2694.500 2695.500 77.0 80.0 1 pc(s). 2696.500 – Base/plinth, complete 1 pc(s). 2807.200 2807.200 890 Cross member 2 pc(s). 8601.450 8601.450 891 Cable clamp rail 2 pc(s). 5001.080 5001.080 1059 from page from page 935 Model No. 1 pc(s). Weight kg Also required Desk section 163 Accessories Lock systems 162 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures TopConsole system TP Accessories Length mm Model No. 1750 6731.120 For retrospective external mounting on TP desk units, consoles and one-piece consoles. Applications: – TP three-part/two-part – One-piece consoles TP – May be mounted on all enclosures/covers with 20 mm fold height (max. metal thickness 2 mm) Enclosures TP aluminium strip Supply includes: – 1 aluminium section – 6 plastic cover caps – Drilling template – Assembly parts Installation options: – Easily cut to length for other sizes – 3 x width 600 mm – 2 x width 800 mm – 1 x width 1000 mm + 1 x width 600 mm – 1 x width 1200 mm – 1 x width 1600 mm Material: – Extruded aluminium section – Cover caps: Plastic Surface finish: – Aluminium extruded section: Natural anodised Colour: – Cover caps: RAL 7035 Cover plate for TP As cover for a TP pedestal. Material: – Sheet steel Surface finish: – Textured paint Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 For enclosure Width mm Depth mm Model No. 600 400 5001.130 800 400 5001.140 1200 400 5001.160 1600 400 6730.030 600 500 6730.100 800 500 6730.110 1200 500 6730.120 1600 500 6730.130 Protection category NEMA: – NEMA 12 Supply includes: – Assembly parts Desk section for TP universal console For installing display and control components and a keyboard. Closed at the side and front. Cover plates for top and bottom. Height mm Model No. 200 2696.500 Material: – Sheet steel Surface finish: – Dipcoat-primed, powder-coated on the outside, textured paint Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Protection category NEMA: – NEMA 12 Supply includes: – Assembly parts Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 163 PC enclosure systems Lock systems Page 934 Climate control Page 449 PC enclosure system, stainless steel Page 252 System accessories Page 877 Secure accommodation of all PC components, from monitors, to PCs, to keyboards. For ultimate ease of operation in a modern design. Perfect protection from humidity and dirt, temperature fluctuations and unauthorised access. Material: – Enclosure, door, rear door, mounting compartment, supports: Sheet steel – Handles, decorative trim panels: Plastic – Door trim panel: Aluminium – Viewing window: Single-pane safety glass Surface finish: – Enclosure and door: Dipcoatprimed, powder-coated on the outside, textured paint – Mounting compartment, support: Powder-coated Colour: – Enclosure, door, decorative trim panels, supports: RAL 7035 – Handle: RAL 7015 – Monitor panel, door centre part: RAL 7015 Protection category IP to IEC 60 529: – IP 55 Protection category NEMA: – NEMA 12 Supply includes: – Enclosure, door, rear door Please note the product-specific scope of supply. Approvals: – UL – cUL Width 600 mm Width mm 600 600 600 600 Height mm Packs of 1600 1600 1600 1600 Depth mm 636 636 636 636 Glazed door, top ◾ ◾ ◾ ◾ Keyboard drawer ◾ – – ◾ Component shelf ◾ ◾ ◾ ◾ Fold-out keyboard tray – ◾ – – Desk section – – ◾ – Mounting compartment, small – – – ◾ Page Product-specific scope of supply Model No. 1 pc(s). Max. keyboard dimensions (W x H x D) mm Weight kg 5366.050 5366.150 5366.250 5366.350 480 x 70 x 260 497 x 50 x 250 497 x 60 x 200 540 x 40 x 175 480 x 70 x 260 101.4 98.0 95.5 95.5 Accessories Base/plinth, stationary 1 pc(s). 8800.920 8800.920 8800.920 8800.920 890 Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.002 8640.002 8640.002 8640.002 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.033 8640.033 8640.033 882 881 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.022 8640.022 8640.022 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.043 8640.043 8640.043 881 Partial mounting plates1) 1 pc(s). 8617.550 8617.550 8617.550 8617.550 975 1007 Component shelf, pull-out 1 pc(s). 6902.960 6902.960 6902.960 6902.960 Drawer tray 1 pc(s). 6902.700 6902.700 6902.700 6902.700 1007 Paper removal flap 1 pc(s). 6903.200 6903.200 6903.200 6903.200 1116 1) The adaptor rail for VX compatibility is required for the installation, see page 995 164 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures PC enclosure systems Width mm 600 600 800 Height mm Packs of 1600 1600 1600 Depth mm 636 836 636 Keyboard drawer ◾ ◾ ◾ Mounting compartment, large ◾ – – Glazed door, top – ◾ ◾ Page Product-specific scope of supply Component shelf Model No. 1 pc(s). Max. keyboard dimensions (W x H x D) mm Weight kg – ◾ ◾ 5366.450 5368.050 5386.050 480 x 70 x 260 480 x 70 x 260 480 x 70 x 260 97.5 111.0 117.6 8800.920 – – 890 Accessories Base/plinth, stationary 1 pc(s). Base/plinth corner pieces with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.002 8640.002 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.034 8640.033 881 881 Base/plinth corner pieces with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.022 8640.022 8640.023 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.044 8640.043 881 Partial mounting plates1) 1 pc(s). 8617.550 8617.550 8617.580 975 1007 Component shelf, pull-out 1 pc(s). 6902.960 6902.980 – Drawer tray 1 pc(s). 6902.700 6902.700 – 1007 Paper removal flap 1 pc(s). 6903.200 6903.200 6903.200 1116 1) The adaptor rail for VX compatibility is required for the installation, see page 995 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 165 Enclosures Width 600 – 800 mm Industrial Workstations System accessories Page 877 Comfort Panel Page 172 Optipanel Page 174 TFT monitor Page 1109 H Farbe: – Enclosure, worktop: RAL 7035 – Worktop edge strip: RAL 7015 – Worktop handle: RAL 9006 Protection category: – See table H Material: – Enclosure, roof, drawer tray, designer door, rear wall and rear door: Sheet steel – Worktop: Chipboard, plasticlaminated on both sides (edging) – Handle: Aluminium, powdercoated B T Supply includes: Available on the Internet B Surface finish: – Enclosure: Dipcoat-primed, powder-coated on the outside, textured paint T Photo shows a configuration example with equipment not included in the scope of supply Combination options Optipanel Custom-manufactured for TFT monitors or other display and input devices Support arm system CP 60 Worktop small, solid Model No. 6902.300 Worktop solid Model No. 6902.100 Worktop prepared for tilting enclosure attachment Model No 6902.310, see page 212. Designer door, rear panel screw-fastened from the inside Height 900 mm Model No. 6900.000 Designer door, rear door Height 900 mm Model No. 6900.100 Drawer section, designer door, rear door Height 900 mm Model No. 6900.400 Drawer section for keyboard and mouse, designer door, rear door Height 900 mm Model No. 6900.410 Worktop, keyboard drawer, designer door, rear door Height 1000 mm Model No. 6901.100 Pedestal Model No. 6141.200 Base/plinth, stationary Model No. 8800.920 Twin castors Model No. 7495.000 166 Further technical information available on the Internet. Twin castors Model No. 7495.000 or 6148.000 Rittal System Catalogue 36/Enclosures Industrial Workstations IW enclosures and worktops Page Designer door, rear panel screw-fastened from the inside Designer door, rear door Width (B) mm 600 600 600 600 600 Height (H) mm 900 900 900 900 1000 645 Version Drawer section, designer door, rear door Drawer section for keyboard and mouse, designer door, rear door Worktop, keyboard drawer, designer door, rear door Depth (T) mm 600 600 600 (890) 600 (890) Weight (kg) 54.9 59.9 73 73 91 Model No. 6900.000 6900.100 6900.400 6900.410 6901.100 Protection category IP to IEC 60 529 Protection category NEMA IP 55 IP 54 NEMA 12 NEMA 12 Enclosures Enclosure Width (B) mm Height (H) mm Depth (T) mm Weight kg 610 38 645 11.6 6902.300 6902.300 – – ◾ 1000 38 895 24 6902.100 6902.100 6902.100 6902.100 – Model No. Worktops Accessories Packs of Base/plinth, stationary 1 pc(s). 8800.920 8800.920 8800.920 8800.920 8800.920 890 Cross member, adjustable 2 pc(s). 8601.680 8601.680 8601.680 8601.680 – 891 Twin castors 4 pc(s). 7495.000 7495.000 7495.000 7495.000 7495.000 893 Handle adaptor for comfort handle 1 pc(s). 8611.300 8611.300 – – – 918 Cable gland 1 pc(s). 6902.770 6902.770 6902.770 6902.770 6902.770 1046 Partial mounting plate VX for enclosure width 600 mm1) 1 pc(s). see page see page see page see page see page 975 Component shelf, static installation 1 pc(s). 8800.900 8800.900 8800.900 8800.900 8800.900 1007 Component shelf, pull-out 1 pc(s). 6902.960 6902.960 6902.960 6902.960 6902.960 1007 Drawer tray 1 pc(s). 6902.700 6902.700 6902.700 6902.700 6902.700 1007 Paper removal flap 1 pc(s). 6903.200 6903.200 6903.200 6903.200 6903.200 1116 Support arm systems see page see page see page see page see page 183 Operating housings see page see page see page see page see page 169 1) The adaptor rail for VX compatibility is required for the installation, see page 995 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 167 168 Rittal System Catalogue 36/Enclosures Comfort Panel Product comparison ...................................................................................170 Comfort Panel ............................................................................................172 Comfort Panel, configuration examples.......................................................173 Optipanel Product comparison ...................................................................................170 Optipanel....................................................................................................174 Optipanel, configuration examples ..............................................................175 Operating housings AX Product comparison ...................................................................................170 Product advantages ...................................................................................176 Operating housings AX with handle strips ...................................................178 Operating housing AX for desktop TFT up to 24" ........................................180 Compact Panel Product comparison ...................................................................................170 Compact Panel...........................................................................................181 Support arm systems Support arm systems, overview..................................................................183 Support arm system CP 40, steel ...............................................................185 Support arm system CP 40, stainless steel.................................................188 Support arm system CP 60 ........................................................................193 Support arm system CP 120 ......................................................................197 Support arm system CP 180 ......................................................................201 Support section, height-adjustable .............................................................205 Accessories ................................................................................................207 Stand systems Pedestal, modular.......................................................................................211 Pedestal, complete.....................................................................................212 Pedestal, open/pillar, small .........................................................................213 Accessories ................................................................................................214 Rittal System Catalogue 36/Enclosures 169 Enclosures Operating housings/ support arm systems/ stand systems Operating housings – Product comparison Comfort Panel Optipanel Enclosure made from extruded aluminium section with cooling fins for optimum passive cooling Enclosure made from extruded aluminium section Protection category IP to IEC 60 529 IP 65 IP 65 Protection category NEMA NEMA 12 NEMA 12 No. of sizes 7 standard sizes available off the shelf 7 standard sizes available off the shelf ▭ 120 x 65 mm up to depth 74 mm, Ø 130 mm from depth 152 mm ▭ 120 x 65 mm depth 100 mm, Ø 130 mm depth 150 mm 1/top Bottom by rotating the enclosure 1/top Bottom by rotating the enclosure From the rear, hinged rear panel Servicing access From the rear, depending on the enclosure, hinged or screw-fastened; with the screw-fastened rear panel, the front flips open Lock system Lock inserts may be replaced individually Lock inserts may be replaced individually Prepared for the direct mounting of standard machine controllers and industrial PCs with corresponding screw clamps; all-round mounting channels integrated into the section for individual mounting of accessory components Prepared for the direct mounting of standard machine controllers and industrial PCs with corresponding screw clamps 172 174 Design Cross-section Support arm connection Quantity/ position Equipment from page 170 Rittal System Catalogue 36/Enclosures Enclosures Operating housings – Product comparison Operating housings AX with handle strips Operating housing AX for desktop TFT Enclosure made from sheet steel and front panel made from aluminium Sheet steel enclosure and viewing panel made from 3 mm single-pane safety glass Roof and base tray made from die-cast zinc, powder-coated, side panels made from extruded aluminium section, powder-coated IP 55 IP 65 IP 65 NEMA 12 NEMA 12 NEMA 12 10 standard sizes available off the shelf 1 standard size available off the shelf 4 standard sizes available off the shelf Ø 130 mm Ø 130 mm ▭ 90 x 71 mm for CP 40, steel, the enclosure may optionally be mounted directly on a rotatable wall mounting 1/top Bottom by rotating the enclosure, optional off-centre support arm connection, pre-formed 1/top Bottom by rotating the enclosure, optional off-centre support arm connection, pre-formed 1/top Bottom by rotating the enclosure Depends on the enclosure, from the front or rear From the rear From the rear, hinged rear panel Lock inserts may be replaced individually Lock inserts may be replaced individually Screw-fastened Interior installation bracket with system punchings for configuration with punched sections with mounting flanges 14 x 39 mm on a 25 mm pitch pattern. Simple machining of the front panel for installing machine controllers, industrial PCs or switches. Retainer for desktop TFT with VESA 75/100 locator up to 24˝ in the formats 16:9/16:10 The customer’s own front panels (2 – 6 mm) are easily inserted from the rear and secured with screw clamps 178 180 181 Rittal System Catalogue 36/Enclosures Compact Panel 171 Comfort Panel System accessories Page 877 Support arm systems Page 183 Stand systems Page 211 Industrial Workstations Page 166 Colour: – Enclosure: Natural anodised – Corner pieces: RAL 7035 – Corner protectors: similar to RAL 7024 Supply includes: – Seals and assembly parts for front panels Note: – The support arm connection may be swapped over by rotating the enclosure Protection category IP to IEC 60 529: – IP 65 Packs of For front panel height (H) mm Installation depth mm Model No. 1 pc(s). Weight kg B Approvals: – UL – cUL Protection category NEMA: – NEMA 12 For front panel width (B) mm H Material: – Enclosure: Extruded aluminium section – Corner pieces: Die-cast zinc – Corner protectors: Plastic 520 520 520 400 500 600 Page 74 152 191 152 191 152 191 6372.541 6372.542 6372.543 6372.552 6372.553 6372.562 6372.563 7.8 11.7 13.8 12.3 15.2 13.5 16.7 Design Support arm connection ▭ 120 x 65 mm ◾ – – – – – – Support arm connection Ø 130 mm – ◾ ◾ ◾ ◾ ◾ ◾ Hinged rear panel on the long side, with screw lock ◾ – – – – – – Hinged rear panel on the hinged long side, with cam1) – ◾ – ◾ – ◾ – Screw-fastened rear panel2) – – ◾ – ◾ – ◾ Accessories Front panel 1 pc(s). 6028.014 6028.014 6028.014 6028.015 6028.015 6028.016 6028.016 1107 Cover plate for support arm connection 1 pc(s). 6505.100 6505.500 6505.500 6505.500 6505.500 6505.500 6505.500 1107 Mounting bracket for interior installation 4 pc(s). 6205.100 6205.100 6205.100 6205.100 6205.100 6205.100 6205.100 1000 Spring nut M5 50 pc(s). 6108.000 6108.000 6108.000 6108.000 6108.000 6108.000 6108.000 1003 Earthing plate 1 pc(s). 2570.500 2570.500 2570.500 2570.500 2570.500 2570.500 2570.500 1034 1) With 3 mm double-bit lock insert, may be exchanged for 41 mm lock inserts, version C, see page 941, plastic handles and T handles, version C, see page 942, 943 2) Enclosure hinged at the front with side double-bit lock insert, may be exchanged for 41 mm lock inserts, version C, see page 941, plastic handles and T handles, version C, see page 942, 943 172 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Comfort Panel Configuration examples Front panel height mm B H 400 7 HE Enclosures Cut-out dimensions 8 HE 53.7 1 B = 484 mm H = 364 mm  = 18 mm all-round for attaching the front panel H B 7 HE 8 HE 9 HE 500 153.7 109.2 65 1 B = 484 mm H = 464 mm  = 18 mm all-round for attaching the front panel H 7 HE 8 HE 7 HE 9 HE 8 HE 9 HE B 3.5 HE 600 253.7 209.2 165 98.7 3.5 HE 3.5 HE 54.2 1 B = 484 mm H = 564 mm  = 18 mm all-round for attaching the front panel Free space, available for individual installed equipment such as rows of switches etc. HE = U Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 173 Optipanel System accessories Page 877 Support arm systems Page 183 Stand systems Page 211 Industrial Workstations Page 166 Colour: – Enclosure: Natural anodised – Corner pieces: RAL 7035 – Corner protectors: similar to RAL 7024 Supply includes: – Seals Note: – The support arm connection may be swapped over by rotating the enclosure Protection category IP to IEC 60 529: – IP 65 Packs of For front panel height (H) mm Installation depth mm B Approvals: – UL – cUL Protection category NEMA: – NEMA 12 For front panel width (B) mm H Material: – Enclosure: Extruded aluminium section – Corner pieces: Die-cast zinc – Corner protector: Plastic 430 482.6 482.6 520 520 520 343 310.3 354.8 400 500 600 100 100 100 100 150 150 150 6380.0201) 6380.000 6380.0401) 6380.400 6380.410 6380.510 6380.610 5.3 6.2 6.6 5.8 7.3 8.3 9.2 Support arm connection ▭ 120 x 65 mm ◾ ◾ ◾ ◾ – – – Support arm connection Ø 130 mm – – – – ◾ ◾ ◾ Hinged rear panel on the hinged long side2) ◾ ◾ ◾ ◾ ◾ ◾ ◾ Seals and assembly parts for front panels – – – ◾ ◾ ◾ ◾ Model No. 1 pc(s). Weight kg Page Design Accessories Front panel 1 pc(s). – 6028.010 – 6028.014 6028.014 6028.015 6028.016 1107 Cover plate for support arm connection 1 pc(s). 6505.100 6505.100 6505.100 6505.100 6505.500 6505.500 6505.500 1107 Handle set, horizontal 1 pc(s). – 6385.010 6385.010 – – – – 1103 Mounting bracket for interior installation 4 pc(s). 6205.100 6205.100 6205.100 6205.100 6205.100 6205.100 6205.100 1000 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 4597.000 999 Earthing plate 1 pc(s). 2570.500 2570.500 2570.500 2570.500 2570.500 2570.500 2570.500 1034 Spring nut M5 50 pc(s). 6108.000 6108.000 6108.000 6108.000 6108.000 6108.000 6108.000 1003 1) To fit TFT monitors, see page 1109 2) With 3 mm double-bit lock insert, may be exchanged for 41 mm lock inserts, version C, see page 941, plastic handles and T handles, version C, see page 942, 943 174 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Optipanel Configuration examples Front panel height mm B H 400 7 HE Enclosures Cut-out dimensions 8 HE 53.7 1 B = 484 mm H = 364 mm  = 18 mm all-round for attaching the front panel H B 7 HE 8 HE 9 HE 500 153.7 109.2 65 1 B = 484 mm H = 464 mm  = 18 mm all-round for attaching the front panel H 7 HE 8 HE 7 HE 9 HE 8 HE 9 HE B 3.5 HE 600 253.7 209.2 165 98.7 3.5 HE 3.5 HE 54.2 1 B = 484 mm H = 564 mm  = 18 mm all-round for attaching the front panel Free space, available for individual installed equipment such as rows of switches etc. HE = U Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 175 Operating housings AX with handle strips 176 Rittal System Catalogue 36/Enclosures Uniform system in design and function Enclosures Modern design, adapted to support arm system CP 60/120/180 Convenience in perfection ◾ Integral interior installation bracket with system punchings, to match system accessories ◾ Fast, safe, simple servicing access from the front or rear ◾ Lock with integral door runners for easy locking Built-in added value ◾ Support arm connection for one-person assembly ◾ Support arm connection Ø 130 mm, pre-formed off-centre in the reinforcement plate, easily drilled out Ergonomic design ◾ Design strip including handle function ◾ Aluminium front panel, easily dismantled for machining Rittal System Catalogue 36/Enclosures 177 Operating housing AX with handle strips System accessories Page 877 Support arm system Page 183 Stand systems Page 211 Operating housings with door, stainless steel Page 254 Surface finish: – Enclosure and door: Dipcoatprimed, powder-coated on the outside, textured paint – Handle strip: Natural anodised – Front panel: Natural anodised Colour: – Enclosure and door: RAL 7035 – Cover caps: similar to RAL 7024 Protection category IP to IEC 60 529: – IP 55 Protection category NEMA: – NEMA 12 178 Supply includes: – Enclosure with door, cut-out and reinforcement for support arm connection Ø 130 mm – Front with maximum cut-out, covered with easily machinable 3 mm aluminium front panel – Side handle strips and cover caps – Integral interior installation bracket with system punchings – Cam lock with 3 mm double-bit insert Note: – The support arm connection and door hinge may be swapped over by rotating the enclosure – Optional: Support arm connection Ø 130 mm, pre-formed offcentre in the reinforcement plate, easily drilled out – Lock systems for servicing access from the rear: Lock insert may be exchanged for mini-comfort handle AX, 27 mm lock inserts, type A – Lock systems for servicing access from the front: Lock insert may be exchanged for 27 mm lock inserts, type A Further technical information available on the Internet. T B B H T H Material: – Enclosure: Sheet steel – Door: Sheet steel, all-round foamed-in PU seal – Handle strips: Aluminium – Front panel: Aluminium – Cover caps: Plastic Approvals: – UL – cUL Rittal System Catalogue 36/Enclosures Operating housing AX with handle strips Packs of Height (H) mm Depth (T) mm Model No. 1 pc(s). Weight, approx. kg Servicing access 300 300 380 380 380 200 300 300 380 380 155 210 210 210 210 6320.050 6315.150 6315.250 6315.350 6320.350 4.5 7.0 7.5 9.8 9.8 from the rear ◾ – – – ◾ from the front – ◾ ◾ ◾ – Page Accessories Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). – – – 8619.700 8619.700 990 Punched section with mounting flange 14 x 39 mm, installation in the width 4 pc(s). 8619.700 8619.700 – – – 990 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 999 Mounting bracket for interior installation 4 pc(s). 6205.100 6205.100 6205.100 6205.100 6205.100 1000 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 2537.100 2537.100 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 2537.300 2537.300 940 Lock inserts see page see page see page see page see page 941, 942 Earth straps see page see page see page see page see page 1033 500 500 600 600 600 Page 500 500 380 600 600 Width (B) mm Packs of Height (H) mm Depth (T) mm Model No. 1 pc(s). Weight, approx. kg Servicing access 210 210 210 210 210 6315.450 6320.450 6320.550 6320.650 6315.650 22.8 16.8 16.8 15.4 18.8 from the rear – ◾ ◾ ◾ – from the front ◾ – – – ◾ Accessories Punched section with mounting flange 14 x 39 mm, installation in the height 4 pc(s). 8619.710 8619.710 8619.700 8619.720 8619.720 990 Punched section with mounting flange 14 x 39 mm, installation in the width 4 pc(s). 8619.720 8619.720 8619.760 8619.760 8619.760 990 Mounting bracket 4 pc(s). 4597.000 4597.000 4597.000 4597.000 4597.000 999 Mounting bracket for interior installation 4 pc(s). 6205.100 6205.100 6205.100 6205.100 6205.100 1000 Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 2537.100 2537.100 2537.100 2537.100 940 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 2537.300 2537.300 2537.300 940 see page see page see page see page see page 941, 942 Earth straps see page see page see page see page see page 1033 Rittal – The System. 2537.300 Lock inserts Rittal System Catalogue 36/Enclosures Support arm system CP 60/120/180 see page 183 Further technical information available on the Internet. 179 Enclosures Width (B) mm Operating housing AX for desktop TFT up to 24" System accessories Page 877 Support arm systems Page 183 Stand systems Page 211 Colour: – Enclosure and door: RAL 7035 – Cover caps: similar to RAL 7024 Material: – Enclosure: Sheet steel – Door: Sheet steel, all-round foamed-in PU seal – Handle strips: Aluminium – Cover caps: Plastic – Viewing window: Single-pane safety glass – TFT holder: Sheet steel Protection category IP to IEC 60 529: – IP 65 Surface finish: – Enclosure and door: Powdercoated on the outside, textured paint – Handle strip: Natural anodised Protection category NEMA: – NEMA 12 Supply includes: – Enclosure with door, cut-out and reinforcement for support arm connection Ø 130 mm – Viewing window, single-pane safety glass – Holder for desktop TFT with VESA 75/100 locator – Side handle strips and cover caps – Rear door with r/h hinge – Cam lock with 3 mm double-bit insert Width (B) mm Packs of Height (H) mm Note: – The support arm connection and door hinge may be swapped over by rotating the enclosure – Optional: Support arm connection Ø 130 mm, pre-formed offcentre in the reinforcement plate, easily drilled out – Lock insert may be exchanged for mini-comfort handle AX, 27 mm lock inserts, type A T B H For the installation of commercially available desktop TFTs with a screen diagonal of up to 24" in the formats 16:9/16:10. Approvals: – UL – cUL 650 Page 450 Depth (T) mm 155 Model No. 1 pc(s). Weight, approx. kg 6321.050 18.0 Cam lock 2 Accessories Mini-comfort handle AX for lock inserts or profile half-cylinders 1 pc(s). 2537.100 Mini-comfort handle AX for padlock and lock inserts or profile half-cylinders 1 pc(s). 2537.300 940 see page 941, 942 Lock inserts 180 Further technical information available on the Internet. 940 Rittal System Catalogue 36/Enclosures Enclosures Compact Panel System accessories Page 877  Support arm systems Page 183  Stand systems Page 211   For small operating units built into front panels. The front panel is inserted from the rear and secured with screw clamps. Special front panels with a material thickness of between 2 and 6 mm are possible. Rear panel optionally hinged on the left or right. Roof tray with cut-out and reinforcement for support arm system CP 40 steel. Width mm Design: – With support arm connection 90 x 71 mm for CP 40, steel Material: – Roof tray, base tray: Die-cast zinc – Rear panel: Aluminium – Side parts: Extruded aluminium section – Screw cover: Plastic Surface finish: – Roof tray, base tray, side parts: Powder-coated – Rear panel: natural anodised Colour: – RAL 7024 Supply includes: – Roof tray – Base tray – Rear panel – Side parts – Screw cover – Seal and screw clamp Protection category IP to IEC 60 529: – IP 65 Protection category NEMA: – NEMA 12 Packs of Height mm 241 241 315 315 238 388 238 388 Depth mm 87 87 87 87 To fit front panel width mm 178 178 252 252 To fit front panel height mm Model No. 1 pc(s). Weight kg 200 350 200 350 6340.000 6340.100 6340.300 6340.400 2.8 3.8 3.4 4.5 Page Accessories Front panel 1 pc(s). 6028.500 6028.510 6028.530 6028.540 Wall mounting bracket 2 pc(s). 6341.000 6341.000 6341.000 6341.000 969 Spring nut M5 50 pc(s). 6108.000 6108.000 6108.000 6108.000 1003 Cover plate 1 pc(s). 6505.200 6505.200 6505.200 6505.200 1107 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 1107 181 182 Support arm systems Support arm system CP 40 Component overview, stainless steel ..........................................................188 Support section CP 40, stainless steel........................................................188 Components CP 40, stainless steel ............................................................189 Support arm system CP 60 Component overview..................................................................................193 Support section CP 60 ...............................................................................194 Components CP 60....................................................................................195 Support arm system CP 120 Component overview..................................................................................197 Support section CP 120 .............................................................................198 Components CP 120..................................................................................199 Support arm system CP 180 Component overview..................................................................................201 Support section CP 180 .............................................................................202 Components CP 180..................................................................................203 Support arm system CP Support section, height-adjustable .............................................................206 Load information Comparison of support arm systems Permissible static load [N] (enclosure and vertical support arm section) 1800 1200 600 0 0 500 Jib length (mm) 1500 2000 2500 3000 CP 40 CP 60 CP 120 CP 180 1000 Support arm configurator The support arm configurator determines the correct support arm system according to user-specific parameters. More detailed information can be found at: www.rittal.com Rittal System Catalogue 36/Enclosures 183 Enclosures Component overview, steel.........................................................................185 Support section CP 40, steel ......................................................................186 Components CP 40, steel...........................................................................187 10 12 8 13 7 9 1 2 8 3 184 4 Support arm system CP 40, steel 11 Component overview  Tilting adaptor +100/-60° for support arm connection ▭ 120 x 65 mm/ ▭ 90 x 71 mm (6206.460) Enclosures  Attachment CP 40, steel, for support arm connection ▭ 90 x 71 mm (6501.070)  Coupling CP 40, steel, for support arm connection ▭ 90 x 71 mm (6501.050)  Coupling CP 40, steel, for support arm connection ▭ 120 x 65 mm (6501.130)  Connection console VESA 75/100 for support arm connection ▭ 120 x 65 mm (6206.480)  Connection console for support arm connection ▭ 120 x 65 mm (6206.490)  Angle coupling 90° CP 40, steel (6501.120) Support section CP 40, steel (6501.000, 6501.020) Angle piece 90° CP 40, steel (6501.140) Wall-mounted hinge CP 40, steel (6501.150) Top-mounted joint CP 40, steel (6501.160)  Wall/base mounting bracket CP 40, steel (6501.110)  Mounting components CP 40, steel, for signal pillar (2375.030) Load information When using support arm system CP 40, steel in conjunction with support arm system CP 60 (in the horizontal run of the system), the load diagram for support arm system CP 60 applies. 800 6 5 Permissible static load [N] (enclosure and vertical support arm section) 600 400 200 0 0 500 1000 1500 Jib length (mm) Rittal System Catalogue 36/Enclosures 185 Support arm system CP 40, steel Comfort Panel Page 172 Optipanel Page 174 Compact Panel Page 181 Operating housings AX with handle strips Page 178 Support section CP 40, steel Attached to the connection components via 2 clamping screws Size: – Outer diameter: 48.3 mm – Wall thickness: 4.0 mm Material: – Steel conduit, powder-coated Supply includes: – Support section, steel Colour: – RAL 7035 Note: – Stainless steel, see page 188 Protection category IP to IEC 60 529: – IP 54 Integral adjustment facility 48.3 Combination with support arm system CP 60 1 Also available in stainless steel version, see page 188 10 7 4 8 11 6 3 2 9 12 2 5 5 13  Support section CP 40, steel, 1000 mm (6501.020)  Support section CP 40, steel, 500 mm (6501.000)  Wall-mounted hinge CP 40, steel (6501.150)  Angle piece 90° CP 40, steel (6501.140)  Coupling CP 40, steel (6501.050)  Wall-mounted hinge CP 60 (6206.740)  Support section CP 60, 1000 mm (6206.100) Angle adaptor 90° for support arm combination CP 60/40 (6206.640) Wall/base mounting bracket, rigid, CP 40, stainless steel (6663.000) Support section CP 40, stainless steel, 1000 mm (6660.010) Angle piece 90° CP 40, stainless steel (6664.300)  Support section CP 40, stainless steel, 500 mm (6660.050)  Housing coupling CP 40, stainless steel (6664.000) 186 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Support arm system CP 40, steel Desk section Wall section Enclosures Colour RAL Weight kg Length mm Rigid Rotating/tilting Enclosure section Model No. Tilting adaptor +100/-60° for support arm connection ▭ 120 x 65 mm/▭ 90 x 71 mm see page 209 ◾ – – 7035/ 7024 6206.460 – – 1.0 7024 6501.070 – – 1.1 7024 6501.050 – – 7024 6501.130 – – 0.8 Attachment CP 40, steel, for support arm connection ▭ 90 x 71 mm – ◾ – Coupling CP 40, steel, for support arm connection ▭ 90 x 71 mm ◾ – – Coupling CP 40, steel, for support arm connection ▭ 120 x 65 mm ◾ – – 1.5 Connection console VESA 75/100 for support arm connection ▭ 120 x 65 mm see page 207 – ◾ – 1.1 7035/ 7024 6206.480 – – 0.7 7035/ 7024 6206.490 – – 6501.120 – – Connection console for support arm connection ▭ 120 x 65 mm see page 207 – ◾ – Angle coupling 90° CP 40, steel, for support arm connection ▭ 90 x 71 mm ◾ – – 1.6 7024 – – 500 1000 2.1 4.2 7035 7035 – ◾ – 1.1 7024 6501.140 – 6501.140 ◾ – – 1.8 7024 – – 6501.160 ◾ – – 2.2 7024 – – 6501.150 – ◾ – 0.7 7024 – – 6501.110 ◾ – 0.3 7024 2375.030 – – Support section CP 40, steel 6501.000 6501.020 Angle piece 90° CP 40, steel Top-mounted joint CP 40, steel Wall-mounted hinge CP 40, steel Wall/base mounting bracket CP 40, steel Mounting component CP 40, steel, for signal pillar see page 1125 – Accessories Angle adaptor 90° for support arm combination CP 60/40 6206.640 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. see page 195 187 Support arm system CP 40, stainless steel Command panel housing with door, stainless steel P. 254 Premium Panel, stainless steel P. 253 Support section CP 40, steel P. 186 Support section CP 40, stainless steel Attached to the connection components via 2 clamping screws Size: – Outer diameter: 48.3 mm – Wall thickness: 3.6 mm 188 Material: – Stainless steel Surface finish: – Brushed, grain size 400 (support section and wall console only) Further technical information available on the Internet. Protection category IP to IEC 60 529: – IP 66 – IP X9 Supply includes: – Support section, stainless steel 48.3 Rittal System Catalogue 36/Enclosures Support arm system CP 40, stainless steel Weight kg Material – ◾ – 0.7 1.4305 (AISI 303) 6664.100 – – – ◾ – 1.3 1.4305 (AISI 303) 6664.500 – – ◾ – – 1.1 1.4305 (AISI 303) 6664.000 – – – ◾ 500 1000 2.0 3.9 1.4301 (AISI 304) – ◾ – 1.3 1.4301 (AISI 304) 6664.300 – 6664.300 1.7 1.430 (AISI 303) – – 6663.000 Enclosures Length mm Wall section Rigid Desk section Rotating/tilting Enclosure section Model No. Tilting adaptor 10° CP 40, stainless steel Attachment CP 40, stainless steel Coupling CP 40, stainless steel Support section CP 40, stainless steel 6660.050 6660.010 Angle piece 90° CP 40, stainless steel Wall/base mounting bracket, rigid, CP 40, stainless steel – ◾ – Wall/base mounting bracket, rotating, CP 40, stainless steel Rear, thread M8 Front, hole Ø 9 mm ◾ – – 3.9 4.5 1.430 (AISI 303) – – 6663.500 6663.400 – ◾ – 1.5 1.8 1.4301 (AISI 304) – – 6665.000 6665.500 Wall console CP 40, stainless steel Rear, thread M8 Front, hole Ø 9 mm Permissible static load [N] (enclosure and vertical support arm section) Load information Permissible load depending on system configuration 800 600 400 200 0 0 500 1000 1500 Jib length (mm) Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 189 Support arm system CP 60/120/180 190 Uniform engineering ◾ All load levels up to 1800 N ◾ One system ◾ Simple system replacement in the vertical axis to cut costs and weight Enclosures ◾ Consistent combination options Multi-functional assembly ◾ Uniform adjustment principle, even retrospectively without dismantling ◾ Perfect limitation of rotation ranges ◾ Simple, one-person installation ◾ Sections are easily cut to the required length Efficient cable management ◾ Cross-section sufficient for large connectors ◾ Supports simple separation between data and power cables ◾ Flexible cable entry and routing options ◾ Automatic, consistent potential equalisation of all support arm components ◾ Open support section for easy upgrade and servicing access Consistent protection category ◾ Consistent protection category of all components, even with adaptations Rittal System Catalogue 36/Enclosures 191 20 18 21 17 22 11 16 12 10 5 13 11 3 6 14 8 15 9 192 Support arm system CP 60 Enclosures Component overview  Tilting adaptor 10° for support arm connection Ø 130 mm (6206.400)  Tilting adaptor 10° for support arm connection ▭ 120 x 65 mm (6206.440)  Tilting adaptor +/-45° for support arm connection Ø 130 mm (6206.420)  Tilting adaptor +100°/-60° for support arm connection ▭ 120 x 65 mm (6206.460)  Connection console VESA 75/100 for support arm connection ▭ 120 x 65 mm (6206.480)  Coupling CP 60 for support arm connection Ø 130 mm (6206.320)  Attachment CP 60 for support arm connection ▭ 120 x 65 mm (6206.360) Coupling CP 60 for support arm connection Ø 130 mm (6206.300) Coupling CP 60 for support arm connection ▭ 120 x 65 mm (6206.340) Angle coupling 90° CP 60 for support arm connection Ø 130 mm (6206.380) 19 Support section CP 60, closed (6206.025, 6206.050, 6206.100, 6206.200)  Support section CP 60, open (6206.110)  Angle adaptor 90° for support arm combination CP 60/40 (6206.640)  Support section CP 40, steel (6501.000)  Coupling CP 40, steel, for support arm connection ▭ 90 x 71 mm (6501.050)  Angle piece 90° CP 60 (6206.600)  Intermediate hinge CP 60 (6206.620)  Top-mounted joint CP 60, horizontal outlet (6206.700)  Wall-mounted hinge CP 60, horizontal outlet (6206.740)  Wall/base mounting bracket CP 60, small (6206.820)  Wall/base mounting bracket CP 60, large (6206.800)  Mounting component CP 60 for signal pillar (6206.900) Load information Permissible static load [N] (enclosure and vertical support arm section) Permissible load depending on system configuration 4 1 2 800 600 400 200 500 1000 1500 2000 Jib length (mm) 1 2 7  System configuration without intermediate hinge 6206.620  System configuration with intermediate hinge 6206.620 Note: – Wall/base mounting bracket, small 6206.820 must not be used in conjunction with intermediate hinge 6206.620! – Intermediate hinge 6206.620 should only be used once per system! 193 Support arm system CP 60 Comfort Panel Page 172 Optipanel Page 174 Compact Panel Page 181 Operating housings AX with handle strips Page 178 Size: – External dimensions: 59 x 85 mm Colour: – Support section: RAL 7035 Protection category IP to IEC 60 529: – IP 54 Material: – Support section: Extruded aluminium section Combination with support arm system CP 40 Supply includes: – Support section 85 Support section CP 60 Attachment to the connection components with 4 self-tapping screws in the screw channel. May be cut to any required length, no thread-tapping required. Closed cable duct with a large cross-section. Open cable duct for easy servicing access and for preassembled cables with connectors; lockable via cover section. 59 Combination with support arm system CP 120 59.5 Roof plate with tilt coupler, see page 210 7 2 8 3 9 1 6 4 10 5 11 12 10  Wall-mounted hinge CP 60, horizontal outlet (6206.740)  Support section CP 60, 1000 mm (6206.100)  Angle adaptor 90° for support arm combination CP 60/40 (6206.640)  Support section CP 40, steel, 500 mm (6501.000)  Coupling CP 40, steel, for support arm connection ▭ 120 x 65 mm (6501.130)  Wall-mounted hinge CP 120, horizontal outlet (6212.740)  Support section CP 120, 1000 mm (6212.100) Angle piece 90° CP 120 (6212.600) Adaptor for support arm combination CP 120/60 (6212.640) Support section CP 60, 500 mm (6206.050) Coupling CP 60 for support arm connection ▭ 120 x 65 mm (6206.340)  Tilt coupler for support arm system CP 60/6206.350 194 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Support arm system CP 60 Centre section CP 60 Wall section CP 60 Enclosures Enclosure section CP 60/40 Colour RAL Weight kg Length mm Rigid Rotating/tilting Enclosure section CP 60 Model No. Tilting adaptor 10° for support arm connection Ø 130 mm ▭ 120 x 65 mm – ◾ – 0.6 0.4 7035 6206.400 – – 6206.440 – – Tilting adaptor +/-45°, tilting adaptor +100°/-60° for support arm connection Ø 130 mm ▭ 120 x 65 mm 1.2 ◾ – – ▭ 90 x 71 mm 0.8 0.8 7024 7035/ 7024 – ◾ – – see page 209 6206.420 – – – 6206.460 6206.460 – – – 6206.460 – Connection console VESA 75/100 for support arm connection ▭ 120 x 65 mm – – see page 207 7035/ 7024 6206.480 – – – 0.7 7035 6206.320 – – – 1.0 7035 6206.360 – – – 1.0 7024 – 6501.070 – – 2.1 7035 6206.300 – – – 1.2 7035 6206.340 6501.130 – – 1.1 7024 – 6501.050 – – 7035/ 7024 6206.380 – – – CP 60 CP 401) CP 60 CP 60 – 6501.000 6501.020 – 6206.025 6206.050 6206.100 6206.200 6206.025 6206.050 6206.100 6206.200 1.1 Attachment CP 60/40 for support arm connection Ø 130 mm ▭ 120 x 65 mm – ◾ – ▭ 90 x 71 mm Coupling CP 60/40 for support arm connection Ø 130 mm ▭ 120 x 65 mm ◾ – – ▭ 90 x 71 mm Angle coupling 90° CP 60/40 for support arm connection Ø 130 mm ◾ – – 1.8 1.25 2.5 5.0 10.0 7035 6206.025 6206.050 6206.100 6206.200 5.6 7035/ 7024 6206.110 – – – Support section CP 60/40 Closed – – 250 500 1000 2000 Open – – 1000 Angle adaptor 90° for support arm combination CP 60/40 – ◾ – 1.0 7035/ 7024 – 6206.640 – – – ◾ – 0.5 7035/ 7024 6206.600 – – 6206.600 – – 2.2 7035/ 7024 – – 6206.620 – – – 2.2 7035/ 7024 – – – 6206.700 – – 2.85 7035/ 7024 – – – 6206.740 0.35 7035 – – – 6206.820 1.4 7035/ 7024 – – – 6206.800 Angle piece 90° CP 60 Intermediate hinge CP 60 ◾ Top-mounted joint CP 60 Horizontal outlet ◾ Wall-mounted hinge CP 60 Horizontal outlet ◾ Wall/base mounting bracket CP 60, small – ◾ – Wall/base mounting bracket CP 60, large – ◾ – Accessories Mounting component for signal pillar, see page 1125/Adaptor CP 120/60 Ø 130 mm to ▭ 120 x 65 mm 6212.500, see page 199 1) Weight information and diagrams for CP 40, see page 187 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 195 19 17 18 14 20 6 12 11 16 6 10 5 7 7 9 1 6 8 2 3 4 196 Support arm system CP 120 Component overview  Adaptor CP 120 from support arm connection Ø 130 mm to ▭ 120 x 65 mm (6212.500) 10 Enclosures  Attachment CP 120 for support arm connection Ø 130 mm (6212.320)  Coupling CP 120 for support arm connection Ø 130 mm (6212.300)  Coupling CP 60 for support arm connection ▭ 120 x 65 mm (6206.340)  Angle coupling 90° CP 120 for support arm connection Ø 130 mm (6212.380)  Support section CP 120, closed (6212.025, 6212.050, 6212.100, 6212.200)  Support section CP 120, open (6212.150, 6212.110, 6212.210) Support section CP 60, closed (6206.025, 6206.050, 6206.100, 6206.200) Adaptor for support arm combination CP 120/60 (6212.640) Angle piece 90° CP 120 (6212.600) Intermediate hinge CP 120, without height offset (6212.680)  Intermediate hinge CP 120, with height offset (6212.620)  Top-mounted joint CP 120, vertical outlet (6212.720)  Top-mounted joint CP 120, horizontal outlet (6212.700)  Wall-mounted hinge CP 120, vertical outlet (6212.760)  Wall-mounted hinge CP 120, horizontal outlet, without height offset 6 (6212.780)  Wall-mounted hinge CP 120, horizontal outlet, with height offset (6212.740) 13 15  Wall/base mounting bracket CP 120, small (6212.820)  Wall/base mounting bracket CP 120, large (6212.800)  Mounting component CP 120/180 for signal pillar (6212.900) Load information Permissible static load [N] (enclosure and vertical support arm section) Permissible load depending on system configuration 1 1200 1100 1000 2 3 800 2 500 300 200 1 500 1000 1500 2000 2500 Jib length (mm)  System configuration without intermediate hinge 6212.620/.680, with closed or open support section  System configuration with intermediate hinge 6212.620/.680 and closed support section  System configuration with intermediate hinge 6212.620/.680 and open support section  Maximum system length 2500 mm for systems with horizontal outlet at the system start  Maximum system length 1500 mm for systems with vertical outlet at the system start. The overall height at the vertical system start must not exceed 500 mm. Note: – Wall/base mounting bracket, small 6212.820 must not be used in conjunction with intermediate hinge 6212.620/.680! – Intermediate hinge 6212.620/.680 should only be used once per system! Rittal System Catalogue 36/Enclosures 197 Support arm system CP 120 Comfort Panel P. 172 Optipanel P. 174 Operating housings AX with handle strips P. 178 Operating housing AX for desktop TFT P. 180 X-shaped profiling for greater load capacity, large cable routing channels. Upper channel adequate for cables with large connectors (e.g. DVI or VGA) and available/usable throughout the entire system. Size: – External dimensions: 75 x 120 mm Material: – Support section: Extruded aluminium section 120 Support section CP 120 Attachment to the connection components with 4 self-tapping screws in the screw channel. May be cut to any required length, no thread-tapping required. Closed cable duct with a large cross-section. Open cable duct for easy servicing access and for preassembled cables with connectors; lockable via cover section. Colour: – Support section: RAL 7035 Protection category IP to IEC 60 529: – IP 54 75 75 Supply includes: – Support section Combination with support section, height adjustable Note: When using an intermediate hinge, the height-adjustable support section should always be inserted in the closest horizontal position to the enclosure. 2 2 3 3 4 7 5 1 6 1 7 8  Wall-mounted hinge CP 120, horizontal outlet (6212.740)  Support section, height-adjustable (6212.120), 9 2 see page 206 3 1 7 8  Angle piece 90° CP 120 (6212.600)  Adaptor for support arm combination CP 120/60 (6212.640)  Support section CP 60, L = 500 mm (6206.050)  Coupling CP 60 for support arm connection ▭ 120 x 65 mm (6206.340)  Support section CP 120, closed, L = 500 mm (6212.050) Coupling CP 120 for support arm connection Ø 130 mm (6212.300) Intermediate hinge CP 120 (6212.620) 198 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Support arm system CP 120 Centre section CP 120 Wall section CP 120 Enclosures Enclosure section CP 120/60 Colour RAL Weight kg Length mm Rigid Rotating/tilting Enclosure section CP 120 Model No. Adaptor CP 120/60 from support arm connection Ø 130 mm to ▭ 120 x 65 mm – ◾ – 0.5 7035 6212.500 6212.500 – – Attachment CP 120/60 for support arm connection Ø 130 mm – ◾ – 0.7 7035 6212.320 6206.320 – – ▭ 120 x 65 mm – ◾ – 0.7 7035 – 6206.360 – – 6212.300 6206.300 – – – 6206.340 – – 6212.380 – – – CP 120 CP 601) CP 120 CP 120 6206.025 6206.050 6206.100 6206.200 6212.025 6212.050 6212.100 6212.200 6212.025 6212.050 6212.100 6212.200 Coupling CP 120/60 for support arm connection Ø 130 mm ◾ – – 2.0 7035 ▭ 120 x 65 mm Angle coupling 90° CP 120 for support arm connection Ø 130 mm ◾ – – 2.1 7035/ 7024 Support section CP 120/60 Closed – – – – – – – – 250 500 1000 2000 2.0 3.9 7.8 15.6 7035 6212.025 6212.050 6212.100 6212.200 Open – – – – – – 500 1000 2000 4.6 9.2 18.4 7035/ 7024 6212.150 6212.110 6212.210 – – – 6212.150 6212.110 6212.210 6212.150 6212.110 6212.210 Adaptor for support arm combination CP 120/60 – ◾ – 0.7 7035 – 6212.640 – – – ◾ – 1.1 7035/ 7024 6212.600 – – 6212.600 Angle piece 90° CP 120 Intermediate hinge CP 120 Without height offset ◾ – – 4.0 7035/ 7024 – – 6212.680 – With height offset ◾ – – 4.4 7035/ 7024 – – 6212.620 – – – 3.8 7035 – – – 6212.720 4.3 7035/ 7024 – – – 6212.700 5.5 7035/ 7024 – – – 6212.760 Top-mounted joint CP 120 Vertical outlet Horizontal outlet ◾ ◾ – – Wall-mounted hinge CP 120, vertical outlet ◾ – – Wall-mounted hinge CP 120, horizontal outlet Without height offset ◾ – – 8.3 7035/ 7024 – – – 6212.780 With height offset ◾ – – 6.1 7035/ 7024 – – – 6212.740 0.5 7035 – – – 6212.820 2.5 7035/ 7024 – – – 6212.800 Wall/base mounting bracket CP 120, small – ◾ – Wall/base mounting bracket CP 120, large – ◾ – Accessories Mounting component for signal pillar, see page 1125/ Tilting adaptor for support arm connection Ø 130 mm and ▭ 120 x 65 mm, see page 209 1) Weight information and diagrams for CP 60, see page 195 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 199 11 12 9 5 13 4 4 8 8 6 5 7 3 1 2 200 Rittal System Catalogue 36/Enclosures Support arm system CP 180 Enclosures 10 Component overview  Attachment CP 120 for support arm connection Ø 130 mm (6212.320)  Coupling CP 120 for support arm connection Ø 130 mm (6212.300)  Coupling CP 180 for support arm connection Ø 130 mm (6218.300)  Support section CPS 180, closed (6218.050, 6218.100, 6218.200)  Support section CP 180, open (6218.150, 6218.110, 6218.210)  Adaptor for support arm combination, CP 180/120 (6218.640)  Support section CP 120, closed (6212.025, 6212.050, 6212.100, 6212.200) Angle piece 90° CP 180 (6218.600) Intermediate hinge CP 180 (6218.620) Top-mounted joint CP 180, horizontal outlet (6218.700) Wall-mounted hinge CP 180, horizontal outlet (6218.740)  Wall/base mounting bracket CP 180, small (6218.820)  Mounting component CP 120/180 for signal pillar (6212.900) Load information Permissible load depending on system configuration 2000 1 Permissible static load [N] (enclosure and vertical support arm section) 1800 2 1500 3 1300 1000 800 500 300 500 1000 1500 2000 2500 3000 Jib length (mm)  System configuration without intermediate hinge 6218.620, with closed or open support section  System configuration with intermediate hinge 6218.620 and closed support section  System configuration with intermediate hinge 6218.620 and open support section Note: – Intermediate hinge 6218.620 should only be used once per system! – Where possible, Rittal recommends that the support section between components 6218.700, 6218.740, 6218.820 and intermediate hinge 6218.620 should be of a closed design Rittal System Catalogue 36/Enclosures 201 Support arm system CP 180 Comfort Panel P. 172 Optipanel P. 174 Operating housings AX with handle strips P. 178 Operating housing AX for desktop TFT P. 180 X-shaped profiling for greater load capacity, large cable routing channels. Upper channel adequate for cables with large connectors (e.g. DVI or VGA) and available/usable throughout the entire system. Size: – External dimensions: 90 x 160 mm Support arm system CP 180 Material: – Support section: Extruded aluminium section Colour: – Support section: RAL 7035 160 Support section CP 180 Attachment to the connection components with 4 self-tapping screws in the screw channel. May be cut to any required length, no thread-tapping required. Closed cable duct with a large cross-section. Open cable duct for easy servicing access and for preassembled cables with connectors; lockable via cover section. Protection category IP to IEC 60 529: – IP 54 90 90 Supply includes: – Support section Combination with support arm system CP 120 2 2 3 3 4 8 1 2 7 5 6  Wall-mounted hinge CP 180, horizontal outlet (6218.740)  Support section CP 180, closed, 1000 mm (6218.100)  Angle piece 90° CP 180 (6218.600)  Adaptor for support arm combination CP 180/120 (6218.640)  Support section CP 120, closed, L = 500 mm (6212.050)  Coupling CP 120 for support arm connection Ø 130 mm (6212.300)  Coupling CP 180 for support arm connection Ø 130 mm (6218.300) Wall/base mounting bracket CP 180, small (6218.820) 202 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Support arm system CP 180 0.6 7035 6212.520 – – – 0.7 7035 6212.320 – – – 5.3 6218.300 – – 6212.300 – – Enclosures Colour RAL Wall section CP 180 Weight kg Centre section CP 180 – Length mm Rigid Rotating/tilting Enclosure section CP 180/120 Model No. Adaptor from support arm connection Ø 180 mm to Ø 130 mm – ◾ Attachment CP 120 for support arm connection Ø 130 mm – ◾ Coupling CP 180/120 for support arm connection Ø 130 mm ◾ – 7035 ◾ – – 2.0 Support section CP 180/120 CP 1201) CP 180 CP 180 7035 6212.025 6212.050 6212.100 6212.200 – 6218.050 6218.100 6218.200 – 6218.050 6218.100 6218.200 5.8 11.6 23.2 7035/ 7024 6212.150 6212.110 6212.210 6218.150 6218.110 6218.210 6218.150 6218.110 6218.210 – 1.5 7035 6218.640 – – ◾ – 3.6 7035/ 7024 6218.600 – 6218.600 ◾ – – 10.3 7035/ 7024 – 6218.620 – ◾ – – 18.0 7035/ 7024 – – 6218.700 ◾ – – 13.0 7035/ 7024 – – 6218.740 – ◾ – 5.0 7035 – – 6218.820 ◾ – 0.1 7024 6212.900 – 6212.900 Closed – – – – – – – – 250 500 1000 2000 2.6 5.2 10.5 21 Open – – – – – – 500 1000 2000 – ◾ – Adaptor for support arm combination CP 180/120 Angle piece 90° CP 180 Intermediate hinge CP 180 Top-mounted joint CP 180 Horizontal outlet Wall-mounted hinge CP 180 Horizontal outlet Wall/base mounting bracket CP 180, small Mounting component CP 120/180 for signal pillar Only for 6218.600, 6218.700, see page 1125 – Accessories Tilting adaptor for support arm connection Ø 130 mm and ▭ 120 x 65 mm, see page 209 1) Weight information and diagrams for CP 120, see page 199 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 203 2 1 5 4 6 13 7 14 8 9 15 16 12 10 11 17 20 18 19 204 Support arm system CP Support arm, height-adjustable 3 Enclosures Component overview  Wall/base mounting bracket CP 120, small (6212.820)  Wall-mounted hinge CP 120, horizontal outlet, with height offset (6212.740)  Top-mounted joint CP 120, horizontal outlet (6212.700)  Wall-mounted hinge CP 120, horizontal outlet, without height offset (6212.780)  Support section, height-adjustable CP 120/CP 60 (6212.060, 6212.065)  Angle piece 90° CP 60 (6206.600)  Angle adaptor 90° for support arm combination CP 60/40 (6206.640) Support section CP 60 (6206.110, 6206.025, 6206.050, 6206.100, 6206.200) Support section CP 40, steel (6501.000, 6501.020) Coupling CP 60 for support arm connection Ø 130 mm (6206.300) Coupling CP 40, steel, for support arm connection ▭ 90 x 71 mm (6501.050)  Angle coupling 90° CP 60 for support arm connection Ø 130 mm (6206.380) 21  Support section, height-adjustable CP 120/CP 120 (6212.120)  Angle piece 90° CP 120 (6212.600)  Adaptor for support arm combination CP 120/60 (6212.640)  Support section CP 120, open (6212.150, 6212.110, 6212.210)  Support section CP 60 (6206.110, 6206.025, 6206.050, 6206.100, 6206.200)  Coupling CP 120 for support arm connection Ø 130 mm (6212.300)  Coupling CP 60 for support arm connection ▭ 120 x 65 mm (6206.340)  Angle coupling 90° CP 120 for support arm connection Ø 130 mm (6212.380) 22  Angle piece 90° CP 120 (6212.600)  Support section CP 120, closed (6212.025, 6212.050, 6212.100, 6212.200)  Top-mounted joint CP 120, vertical outlet (6212.720) 23 Rittal System Catalogue 36/Enclosures Note: In combination with support support section, height adjustable observe: – When using an intermediate hinge, the height-adjustable support section should always be inserted in the closest horizontal position to the enclosure. 205 Support arm system CP Support section, height-adjustable Wall/ machine side Enclosure side Now even more ergonomic, thanks to – Adjustment range for tall and short operators, as well as seated and stand-up workstations: 6212.060/120: 600 mm ± 300 mm 6212.065: 950 mm ± 475 mm – Support arm holds securely in any position – Additional fixing with clamping lever if required – Precise coordination to the suspended load via an adjusting screw at the front of the support section – Adjusting screw can be accessed without dismantling any components – Removable side panel for easy access to cable routing – Tilt angle of the mounted enclosure is identical in every height position – Cables with connectors such as DVI, VGA are easily inserted – Broad weight range from 4 to 60 kg with just two systems CP 120 CP 60 741 4 – 30 6212.060 CP 120 CP 60 1050 4 – 17 6212.065 CP 120 CP 120 790 10 – 60 6212.120 Maximum cross-section for cable entry: – 17 x 41 mm for CP 6212.060/.065 – 17 x 59 mm for CP 6212.120 Weight range Model No. kg1) configured enclosure and vertical support section Cable tray CP 6212.060/.065 30 x 10 mm (W x H) CP 6212.060/.065 41 x 17 mm (W x H) CP 6212.120 59 x 17 mm (W x H) H CP 6212.120 43 x 21 mm (W x H) Maximum connector dimensions H 1) For Overall length mm B B B = Width Colour: – RAL 7035/7024 Protection category IP to IEC 60 529: – IP 54 Supply includes: – Assembly parts Note: For combination with support section, height-adjustable, please note: – When using an intermediate hinge, the heightadjustable support section should always be inserted in the closest horizontal position to the enclosure Support arm configurator for CP 40/60/120/180 and support section, height-adjustable The tool determines the perfect system for your application from key user-specific parameters such as the jib length, enclosure weight or required cable cross-sections. Benefits: – Individual assembly tailored to the requirements of the application – Built-in consistency check – The outcome is a plausibility-checked parts list – Detailed cutting dimensions for the support sections – Free online configurator – Simple, systematic menu prompting – Seamless system solution – Supply of CAD data for the configured system Note: – Configure online at www.rittal.com/configurators 206 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Connection console VESA 75/100 For rear connection of – Slimline operating housings – Commercially available TFTs – Industrial PCs with VESA 75/100 connection Connection to Rittal support arm systems – CP 40 – CP 60 – CP 120 via adaptor from support arm connection Ø 130 mm to ▭ 120 x 65 mm Benefits: – Fast, simple one-person assembly using machined keyholes – More space for installation and servicing – Cables may be routed to devices outside and inside the console – Removable cover for simple cable routing and access to interior device connections – Integral cable clamping facilities – Cover with captive screws Weight kg Model No. 1.1 6206.480 Enclosures Support arm system CP 40/60/120/180 Also required: – Attachment CP 60 for support arm connection ▭ 120 x 65 mm, 6206.360 – Coupling CP 60 for support arm connection ▭ 120 x 65 mm, 6206.340 – Tilting adaptor 10° for support arm connection ▭ 120 x 65 mm, 6206.440 – Coupling CP 40 for support arm connection ▭ 120 x 65 mm, 6501.130 – Tilting adaptor +/-45° for support arm connection ▭ 120 x 65 mm, 6206.460 – Adaptor from support arm connection Ø 130 mm to ▭ 120 x 65 mm, 6212. 500 VESA connection hole pattern 100 75 Material: – Die-cast zinc 75 100 Colour: – Connection console: RAL 7035 – Cover: RAL 7024 Protection category IP to IEC 60 529: – IP 54 Supply includes: – Connection console VESA – Seals – Cable ties for cable clamping – Assembly parts Connection console For rear connection of slimline operating housings. Removable lid for simple cable entry. Connection to Rittal support arm systems – CP 40 – CP 60 – CP 120 via adaptor from support arm connection Ø 130 mm to ▭ 120 x 65 mm Material: – Cast aluminium Protection category IP to IEC 60 529: – IP 54 Colour Weight kg Model No. RAL 7024 0.7 6206.490 Also required: – Coupling CP 40 for support arm connection ▭ 120 x 65 mm, 6501.130 – Attachment CP 60 for support arm connection ▭ 120 x 65 mm, 6206.360 – Coupling CP 60 for support arm connection ▭ 120 x 65 mm, 6206.340 Supply includes: – Connection console – Seals – Assembly parts Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 207 Support arm system CP 40/60/120/180 Adaptor for Siemens Pro-Panel Weight kg Model No. 0.3 6206.500 Weight kg Model No. 1.4 6212.540 For the external mounting of Siemens Simatic – MP 377 Pro – Thin Client 15˝ Pro – Flat-Panel Monitor 15˝, 19˝ Pro – HMI IPC477C Pro – ThinClient Pro Connection to support arm systems – CP 40, steel – CP 60/120 with support arm connection ▭ 120 x 65 mm Material: – Aluminium Colour: – RAL 7035 Supply includes: – Adaptor – Seals – Assembly parts Connection plates with reinforcement plate For easy location of the command panel onto the support arm or pedestal. More space for cable entry. For mounting command panels – Comfort Panel from a front panel width of 247 mm and installation depth of 152 mm – Optipanel from a front panel width of 220 mm and installation depth of 150 mm – Sheet steel from 135 mm installation depth For mounting on support arm system components – Attachment CP 60/120 for support arm connection Ø 130 mm, 6206.320, 6212.320 – Coupling CP 60/120 for support arm connection Ø 130 mm, 6206.300, 6212.300 – Angle coupling 90° CP 60/120 for support arm connection Ø 130 mm, CP 6206.380, 6212.380 – Tilting adaptor 10° CP 60/120 for support arm connection Ø 130 mm, 6206.400 – Tilting adaptor +/-45° CP 60/120 for support arm connection Ø 130 mm, 6206.420 – Coupling CP 180 for support arm connection Ø 130 mm, 6218.300 Material: – Connection plate: Cast aluminium – Reinforcement plate: Sheet steel, 6 mm Colour: – RAL 7035 Supply includes: – Connection plates – Reinforcement plate – Seals – Assembly parts 208 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Support arm system CP 40/60/120/180 Tilting adaptor +/-45° Model No. 1.2 6206.420 Tilting adaptor +100°/-60° Weight kg Model No. for command panels with support arm connection ▭ 120 x 65 mm 0.8 6206.460 Enclosures Weight kg for command panels with support arm connection Ø 130 mm For mounting between: – Coupling CP 60, 6206.300 – Coupling CP 120, 6212.300 – Coupling CP 180, 6218.300 or – Attachment CP 60, 6206.320 – Attachment CP 120, 6212.320 or – Angle coupling 90°, CP 60, 6206.380 – Angle coupling 90°, CP 120, 6212.380 and the command panel Tilt angle: – Adjustable in 7.5° increments Material: – Tilting adaptor: Cast aluminium – Concertina section: Plastic Colour: – RAL 7024 Supply includes: – Tilting adaptor – Concertina section – Seals – Assembly parts For mounting on – IW worktop, prepared for attachment of Ø 130 mm – Surfaces – Attachment/coupling with support arm connection ▭ 120 x 65 mm To fit enclosures up to 20 kg with support arm connection – ▭ 90 x 71 mm – Ø 130 mm – ▭ 120 x 65 mm – VESA Standard 75 With cable tube for protected cable entry. Tilt angle: – Adjustable in 7.2° increments via clamping lever and may be limited to +100°/–15° using the stop screw supplied loose Material: – Tilting adaptor: Sheet steel, spray-finished – Concertina section: Plastic Colour: – Tilting adaptor: RAL 7035 – Concertina section: RAL 7024 Supply includes: – Tilting adaptor – Concertina section – Assembly parts Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 209 Support arm system CP 40/60/120/180 Tilt coupler Packs of Model No. for support arm system CP 60 For mounting two enclosures on a support arm/ stand system. 1 pc(s). 6206.350 Benefits: – Ergonomic adjustment of the screen and keyboard enclosure – Simple, linear adjustment of the required position via the friction brake Accessories: – Adaptor CP 60 to ▭ 120 x 65 mm, see page 210 Material: – Cast aluminium Surface finish: – Textured paint Colour: – Tilt coupler: RAL 7035 – Covers: RAL 7024 Protection category IP to IEC 60 529: – IP 54 Supply includes: – Tilt coupler – Seals – Assembly parts Adaptor for tilt coupler Packs of Model No. CP 60 to support arm connection ▭ 120 x 65 mm 1 pc(s). 6206.550 Material: – Cast aluminium Colour: – RAL 7035 Pivot with/without jib For direct, vertically hinged integration into machines and systems. Jib length mm 200 – Colour Packs of RAL 7024/7035 1 pc(s). RAL 7035 1 pc(s). Model No. 6206.850 6206.870 Applications: – Enclosure suspended or top-mounted Benefits: – With integral rotation range restrictor Installation options: – To fit enclosures with support arm connection Ø 130 mm. Load capacity: – 700 N Rotation range/swivel area: – Approx. 310° – The range of rotation can be limited by inserting the grub screws provided. Protection category IP to IEC 60 529: – IP 54 210 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Enclosures Stand systems Comfort Panel Page 172 Optipanel Page 174 Compact Panel Page 181 Operating housings AX with handle strips Page 178 Pedestal, modular, consisting of: – Pedestal base plate/cross member – Support section – Enclosure connection Colour: – RAL 7035 Photo shows a configuration example with equipment not included in the scope of supply Pedestal, modular 3 2 1 Weight load kg 15 18  Pedestal base plate 351) 351) Pedestal base plate/cross member 6146.100 6106.100 6106.200 6106.400 Width 400 400 490 600 Height 10 108 100 205 Depth 400 400 600 650 6146.200 – – – – 6206.100 6206.1001) 6206.1001) – 6106.110 – Attachment CP 40, steel, for support arm connection ▭ 90 x 71 mm 6501.070 – – – Coupling CP 40, steel, for support arm connection ▭ 90 x 71 mm 6501.050 – – – Coupling CP 40, steel, for support arm connection ▭ 120 x 65 mm 6501.130 – – – – – 6206.320 6206.320 6206.360 Dimensions mm  Support section Height-adjustable (adjustment range 732 – 1122 mm) Closed, length 1000 mm Model No.  Enclosure connection Enclosure reinforcement, rigid Attachment CP 60, for support arm connection Ø 130 mm Page Model No. Model No. – Attachment CP 60, for support arm connection ▭ 120 x 65 mm – – 6206.360 Coupling CP 60, for support arm connection Ø 130 mm – – 6206.300 – Coupling CP 60, for support arm connection ▭ 120 x 65 mm – – 6206.340 – 6146.300 – – – – 6206.650 6206.650 6206.650 214 6148.000 – 6148.000 ◾ 893 Tilt adjustment Accessories Adaptor CP 60 to CP 40 Twin castors Levelling feet – – 4612.000 – 892 Base mounting bracket – – 6147.000 – 214 1) Alternative: Support arm system CP 120 may also be used by simply drilling a hole, weight load 50 kg Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 211 Stand systems Comfort Panel Page 172 Optipanel Page 174 Compact Panel Page 181 Operating housings AX with handle strips Page 178 The right system to suit any application: – Different design variants – Weight load from 15 – 25 kg – Reliable protection of cable management Colour: – RAL 7035 Photo shows a configuration example with equipment not included in the scope of supply Pedestal, complete Weight load kg 25 25 6106.300 6141.200 Width mm 600 600 Height mm 1093 946 Depth mm 660 660 Cross member ◾ ◾ Base plate – – Support section – Vertical aluminium panel ◾ ◾ Worktop attachment – Model No. Page Supply includes ◾ ◾ Accessories Adaptor CP 60 to CP 40 6206.650 – 214 Twin castors 6148.000, 7495.000 6148.000, 7495.000 893 Levelling feet 4612.000 4612.000 892 Base mounting bracket 6147.000 6147.000 214 Attachment CP 60, for support arm connection Ø 130 mm 6206.320 – 195 Attachment CP 60, for support arm connection ▭ 120 x 65 mm 6206.360 – 195 Coupling CP 60, for support arm connection Ø 130 mm 6206.300 – 195 Coupling CP 60, for support arm connection ▭ 120 x 65 mm 6206.340 – 195 – 6902.310 Worktop without handle1) 1) W x H x D 950 x 38 x 600 mm 212 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Enclosures Stand systems Comfort Panel Page 172 Optipanel Page 174 Compact Panel Page 181 Operating housings AX with handle strips Page 178 The welded alternatives to the pedestal, complete – Open pedestal for retrospective cable entry with preassembled connectors – Pillar, small: For heavy installed equipment Material: – Steel Photo shows a configuration example with equipment not included in the scope of supply Surface finish: – Spray-finished Colour: – RAL 7035 Pedestal, open/pillar, small Weight load kg 40 80 6106.500 6112.500 Page Width 380 500 Height 10 12 Depth 380 500 1095 1150 Attachment CP 60, for support arm connection Ø 130 mm 6206.320 – Attachment CP 60, for support arm connection ▭ 120 x 65 mm 6206.360 – 195 Coupling CP 60, for support arm connection Ø 130 mm 6206.300 – 195 Coupling CP 60, for support arm connection ▭ 120 x 65 mm 6206.340 – 195 – 6212.320 199 – 6212.300 199 6206.650 – 214 Supply includes Base plate cross section mm Overall height mm Accessories Attachment CP 120, for support arm connection Ø 130 mm Coupling CP 120, for support arm connection Ø 130 mm Adaptor CP 60 to CP 40 Rittal System Catalogue 36/Enclosures Further technical information available on the Internet. 195 213 Stand systems Accessories Base mounting bracket Packs of Model No. Brackets for screw-fastening from below to the pedestals with posidrive raised countersunk screws M12. Optionally with projection at the front, interior or sides, with Ø 11 mm hole for screw-fastening to the base. 4 pc(s). 6147.000 Material: – Steel Surface finish: – Zinc-plated Supply includes: – Posidrive raised countersunk screws M12 Enclosure reinforcement For external or internal reinforcement of enclosures of a corresponding size. Smaller enclosures may also be mounted directly without reinforcement. 1 Supply includes: – Assembly parts for the enclosure and support section plus 2 seals For enclosure Support arm connection Material Weight kg Model No.  B1 ≥ 300 mm, T1 ≥ 150 mm CP 40, stainless steel Stainless steel 1.4301 0.9 6143.310  B1 ≥ 300 mm, T1 ≥ 150 mm CP 60 Sheet steel 0.9 6106.110 2 Adaptor CP 60 to CP 40 for stand and support arm systems For the transition from support section CP 60 to 48 round pipe. Length mm Weight kg Rigid 300 1.81 ◾ Packs of Model No. 1 pc(s). 6206.650 Material: – Steel Colour: – RAL 7035 Supply includes: – Adaptor – Self-tapping screws for support section attachment – Seal 214 Further technical information available on the Internet. Rittal System Catalogue 36/Enclosures Comfort Panel Enclosures Simple selection with the online configurator, see page 273 Configure online at www.rittal.com/configurators Rittal System Catalogue 36/Enclosures 215 216 Rittal System Catalogue 36/Enclosures Hygienic Design Product advantages ...................................................................................218 Terminal boxes HD .................................................................................... 220 Compact enclosures HD, single-door .........................................................221 Compact enclosures HD, two-door ............................................................222 Accessories ................................................................................................223 Rittal System Catalogue 36/Enclosures 217 Enclosures Small and compact enclosures HD Hygienic Design enclosures – Added cleanliness guaranteed! 218 Rittal System Catalogue 36/Enclosures Silicone seal ◾ All-round external joint-free silicone seal ◾ Easy to replace ◾ Guides and fixes the lid to the screw fasteners Enclosures ◾ All-round tilt for terminal boxes – Enclosure: 3° – Lid: 10° Interior installation ◾ Mounting hole pitch pattern of 6.25 mm for greater flexibility ◾ KX support rails and mounting plates may be directly fitted Hinges and seal ◾ Hinges that are inside the sealing zone create an exceptionally easy-clean design on the outside ◾ The durable all-round, external silicone seal is joint-free ◾ Installed sealing frames are easily replaced ◾ No external cavity between enclosure and door ◾ Seal dyed blue to clearly distinguish it from foodstuffs Screw fastener ◾ Captive ◾ With external seal ◾ Hexagon shape for perfect cleanliness Lock and lock insert ◾ External parts made of stainless steel ◾ Material and shape allow easy and reliable cleaning Roof, tilted ◾ 30° tilt on compact enclosures prevents objects from being deposited on it ◾ Easily inspected ◾ Allows fluids to drain off rapidly Rittal System Catalogue 36/Enclosures 219 Hygienic Design HD accessories Page 223  System accessories Page 877  Terminal boxes KX, stainless steel Page 230   Protection category IP to IEC 60 529: – IP 66 – IP X9 Protection category NEMA: – NEMA 13 – NEMA 3R – NEMA 4X Supply includes: – Enclosure of all-round solid construction – Cover – Mounting bracket (pre-assembled) – Seal and screw plug (supplied loose) T B2 H2 Material: – Enclosure and cover: Stainless steel 1.4301 (AISI 304) 1.5 mm – Mounting bracket: Sheet steel, zinc-plated, passivated, 2.0 mm – Screw plug: Stainless steel – Seal: Silicone, compliant with FDA Guideline 21 CFR 177.2600 Surface finish: – Enclosure and cover: Brushed, grain 400, peak-to-valley height 150 kW) ◾ New Basic, from page 268 ◾ Bus stop ◾ Baying systems VX25, from page 116 Backend/infrastructure ◾ Toptec, from page 270 ◾ New Basic, from page 268 ◾ Baying systems VX25, from page 116 ◾ Toptec, from page 270 ◾ New Basic, from page 268 ◾ Baying systems VX25, from page 116 ◾ Base/plinths, from page 880 ◾ Lock systems, from page 933 ◾ Rain canopies, from page 958 ◾ Interior installation, mounting plates, 482.6 mm (19˝) frame, bar systems, from page 970 ◾ System light, from page 1014 ◾ EMC, from page 1028 ◾ Cable entry/cable management, from page 1044 ◾ Toptec, from page 270 ◾ New Basic, from page 268 ◾ Baying systems VX25, from page 116 Other enclosure variants available on request (emobility@rittal.de) 444 Further technical information available on the Internet. Rittal System Catalogue 36/Power distribution Power distribution Charging infrastructure Climate control Power distribution A charging centre may require various forms Rittal offers a modular system for demand-based power distribution. of climate control. ◾ Distribution and protection of the power supply focussing on ◾ Fans, cooling units and heaters for temperature control of the built-in standardisation and availability equipment. ◾ Power Engineering software is used to plan and design low-voltage ◾ Chillers for water cooling of the charging cable in the HPC sector or switchgear to IEC 61 439 with design verification, from page 446 components with liquid cooling inside the enclosure ◾ Individual design of the required climate control using Therm software ◾ ◾ ◾ ◾ ◾ ◾ ◾ ◾ Heaters, from page 530 Passive cooling: TopTherm fan-and-filter units, from page 456 Protective canopies, from page 958 Active: Thermoelectric coolers, from page 474 Cooling units, from page 473 Liquid cooling, from page 509 Outdoor cooling unit, from page 496 Accessories: IoT interface, from page 554 Rittal System Catalogue 36/Power distribution ◾ Rated current < 125 A RiLine Compact, from page 282 ◾ Rated current < 250 A Mini-PLS, from page 294 ◾ Rated current < 1600 A RiLine PLS, from page 299 ◾ Rated current < 6300 A VX25 Ri4Power, from page 361 Further technical information available on the Internet. 445 Power distribution software Configurators/tools/CAD data Power distribution The VX25 Power Engineering planning software sets brand new standards when planning low-voltage switchgear. The Web-based tool guides users quickly and efficiently through the planning process in simple, logical steps. VX25 Power Engineering Efficient planning of low-voltage switchgear From plant configuration, to calculation of the copper bars, through to generation of the design verification to IEC 61 439. Benefits: – The web-based application ensures that planning data is always up-to-date – Parts list creation and assembly based on a specific set of rules – Automatic calculation and documentation of the copper busbars – Generation of a design verification to IEC 61 439 Note: – Download free at www.rittal.com/software 446 Further technical information available on the Internet. Rittal System Catalogue 36/Power distribution Rittal Automation Systems Power distribution High productivity levels and consistent optimisation of all process steps, from page 561 Rittal System Catalogue 36/Power distribution 447 448 Rittal System Catalogue 36/Climate control CLIMATE CONTROL Overview of climate control type .................................................................450 Cooling with ambient air TopTherm fan-and-filter units......................................................................454 Roof-mounted fans.....................................................................................464 Rack-mounted fans/tangential fans ............................................................466 Air/air heat exchangers ...............................................................................469 Cooling units Thermoelectric coolers ...............................................................................474 Wall-mounted cooling units.........................................................................475 Roof-mounted cooling units........................................................................498 Blue e+ roof-mounted cooling units / VX25 Blue e+ integration solution......504 Modular climate control concept.................................................................506 Liquid cooling Air/water heat exchangers ..........................................................................510 Liquid Cooling Package ..............................................................................518 Chillers .......................................................................................................519 Enclosure heaters Climate control Enclosure heaters .......................................................................................530 Climate control accessories Filter technology .........................................................................................533 Air routing...................................................................................................540 Water distribution .......................................................................................543 Control/regulation .......................................................................................546 Mounting accessories.................................................................................556 Climate control software .............................................................................558 Service Global availability ......................................................................................1134 Services....................................................................................................1140 ......................................................................................................................... UL listing under category FTTA Additional approval under the category "environmental-rated accessories for enclosures (CCN: FTTA)" is particularly beneficial for users. This ensures that the type rating of the application (enclosure protection category) is retained even if the enclosure has a mounting cut-out for installation of a climate control component. This is a clear benefit which facilitates use in the 508A zone and eliminates potential discussions about reducing the type rating. Rittal System Catalogue 36/Climate control 449 Climate control Type of climate control Cooling with ambient air Ambient air cooling units are ideally suited for dissipating heat loads exceptionally costeffectively. The pre-requisite for this is that the ambient air must be relatively clean and at a temperature below the required enclosure internal temperature. Cooling units Cooling units keep the enclosure internal temperature at a constant level, which is independent of the ambient temperature. The air routing meets individual requirements. Two separate circuits prevent the ingress of dust into the enclosure. Air throughput, unimpeded airflow m3/h 20 – 1069 – Specific thermal output W/K 17.5 – 90 – Total cooling output W – 80 – 5800 Continuous thermal output W – – Product characteristics From page 450 Exceptionally energy-efficient, barely discernible loss of space within and outside of the enclosure, and a high protection category of IP 54 as standard. 453 Further technical information available on the Internet. The Rittal Blue e+ series is the world's most efficient cooling unit. With heat pipe technology as standard and speed-controlled components, average energy savings of 75% can be achieved. 473 Rittal System Catalogue 36/Climate control Climate control Climate control Cooling with water Efficient liquid cooling may be used in all situations where a high cooling load is required, such as process and machine cooling or when dissipating heat loss from enclosures via air/water heat exchangers. Liquid cooling allows you to achieve spatial separation between cooling production and process cooling. Enclosure heaters Condensation poses a particular risk for control electronics, especially with outdoor siting. A range of output categories ensures that the correct thermal output is always available. Climate control accessories Perfectly coordinated components allow you to customise the climate control to your specific requirements, whether you need targeted air routing, precise control of the equipment or appropriate consumables. – – – – – – 300 – 25000 – – – 10 – 800 – Energy savings of up to 70% can be achieved with the Blue e+ generation of chillers. They ensure efficient cooling of liquid media with a high degree of control accuracy thanks to innovative DC inverter technology. 509 Rittal System Catalogue 36/Climate control The innovative profile geometry means that heat is distributed evenly inside the enclosure and cold spots are prevented. The tool-free push-in connection technology speeds up the wiring process considerably. 530 With innovative accessories, the efficiency and reliability of climate control components can be additionally enhanced with monitoring, control and individual air routing. 533 Further technical information available on the Internet. 451 452 Rittal System Catalogue 36/Climate control Cooling with ambient air TopTherm fan-and-filter units Product advantages ...................................................................................454 TopTherm fan-and-filter units...................................20 – 55 m3/h ..............456 TopTherm fan-and-filter units...............................105 – 180 m3/h ..............457 TopTherm fan-and-filter units...............................230 – 550 m3/h ..............457 TopTherm fan-and-filter units.........................................700 m3/h ..............458 TopTherm fan-and-filter units, EMC .......................20 – 180 m3/h ..............459 TopTherm fan-and-filter units, EMC .....................230 – 900 m3/h ..............460 TopTherm fan-and-filter units, with EC technology................................................55 – 230 m3/h ..............461 TopTherm fan-and-filter units, with EC technology..............................................550 – 900 m3/h ..............462 TopTherm fan-and-filter units, air throughput and protection category .......................................................463 Roof-mounted fans Roof-mounted fans, roof ventilation .....................500 – 965 m3/h ..............464 Roof-mounted fans with EC technology.......................1069 m3/h ..............465 Rack-mounted climate control Air/air heat exchangers TopTherm, wall-mounted with controller ................17.5 – 90 W/K ..............469 Roof-mounted 66 W/K ...............................................................................470 Rittal System Catalogue 36/Climate control 453 Climate control Rack-mounted fans for 482.6 mm (19˝)................320 – 480 m3/h ..............466 Vario rack-mounted fans for 482.6 mm (19˝) ........320 – 480 m3/h ..............467 Tangential fans for 482.6 mm (19˝).................................320 m3/h ..............468 Fan-and-filter units and roof-mounted fans Efficient climate control with ambient air 454 Rittal System Catalogue 36/Climate control TopTherm fan-and-filter units Tool-free assembly ◾ Straightforward assembly, maintenance and exchange with no need for tools of any kind ◾ The air flow direction is easily reversed by rotating the fan module ◾ The electrical connection is individually positionable using a screwless spring terminal; no tools required ◾ Louvred grille latch mechanism for fast filter mat replacement without tools Efficient technology ◾ New diagonal fan technology for greater pressure stability and constant air throughput in its installed state, even with a contaminated filter mat ◾ Minimum installation depth Climate control ◾ Air flows in a diagonal direction from the fan, for a more even air distribution inside the enclosure ◾ Extended service life of filter mats means longer maintenance intervals ◾ Fan with smart, efficient EC technology Roof-mounted fans Simple to fit and maintain ◾ Innovative clamping attachment supports flexible locking optionally from the outside or inside ◾ Connector terminal for easy electrical connection ◾ Good accessibility permits fast filter mat changes High protection category ◾ IP 55 as standard, thanks to a sophisticated labyrinth system and high-quality foamed-in seal High efficiency ◾ At an air throughput of 1,000 m³/h, smart EC fans ensure maximum energy efficiency ◾ Integral interface for linear speed control and fan monitoring Rittal System Catalogue 36/Climate control 455 TopTherm fan-and-filter units Air throughputs incl. outlet filter and protection categories Page 463  Accessories for climate control Page 533  Therm software Page 558   Colour: – RAL 7035 – Optionally available in RAL 9005 Supply includes: – Complete unit ready to install, including filter mat Note: – With the fan-and-filter unit 3237.XXX, electrical connection is made via two single wires on the unit. For all other fan-and-filter units, a screwless spring terminal is used. Approvals: Available on the Internet T2 T1 Performance diagrams: Available on the Internet H Fan-and-filter units with diagonal fan technology have superior pressure stability and ensure a more constant air throughput. The diagonal direction of outflow ensures more even heat dissipation from the enclosure. B Air throughput 20 – 55 m³/h Model No. Packs of Rated operating voltage V, ~, Hz Air throughput, unimpeded air flow m³/h Rated current A 3237.100 3237.110 3237.124 3238.100 3238.110 3238.124 230, 1~, 50/60 115, 1~, 50/60 24 (DC) 230, 1~, 50/60 115, 1~, 50/60 24 (DC) 20 / 25 20 / 25 20 55 / 66 55 / 66 55 0.24 0.065 / 0.052 0.12 / 0.1 0.125 0.12 / 0.11 0.24 / 0.22 Power consumption W 11 / 9 11 / 9 3 19 / 18 19 / 18 5.5 Width (B) mm 116.5 116.5 116.5 148.5 148.5 148.5 Height (H) mm 116.5 116.5 116.5 148.5 148.5 148.5 Depth (T1) mm 16 16 16 16 16 16 Max. installation depth (T2) mm 43 43 43 58.5 58.5 58.5 92 x 92 92 x 92 92 x 92 124 x 124 124 x 124 124 x 124 Axial, shaded pole motor Axial, shaded pole motor Axial, DC motor Axial, shaded pole motor Axial, shaded pole motor Axial, DC motor Required mounting cut-out (BxH) mm Fan Operating temperature range -15 °C...+55 °C -15 °C...+55 °C -15 °C...+55 °C -15 °C...+55 °C -15 °C...+55 °C -15 °C...+55 °C Storage temperature range -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C Noise level dB(A) Service life of fans (L10, 40 °C) h Weight kg Page 38 / 43 38 / 43 38 46 / 49 46 / 49 46 55000 / 60000 55000 / 60000 70000 68200 / 68200 68200 / 68200 95500 0.46 0.48 0.3 0.8 0.8 0.54 3237.200 3237.200 3237.200 3238.200 3238.200 3238.200 537 see page see page see page see page see page see page 535 Accessories Outlet filter 1 pc(s). Spare filter mat Fine filter mat 5 pc(s). – – – 3238.055 3238.055 3238.055 536 Hose-proof hood 1 pc(s). 3237.080 3237.080 3237.080 3238.080 3238.080 3238.080 538 Blanking cover 2 pc(s). 3237.020 3237.020 3237.020 3238.020 3238.020 3238.020 538 Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 3114.200 3114.200 546 456 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm fan-and-filter units Air throughput 105 – 180 m³/h Model No. Packs of 3239.100 3239.110 3239.124 3240.100 3240.110 3240.124 230, 1~, 50/60 115, 1~, 50/60 24 (DC) 230, 1~, 50/60 115, 1~, 50/60 24 (DC) Air throughput, unimpeded air flow m³/h 105 / 120 105 / 120 105 180 / 160 180 / 160 180 Rated current A 0.12 / 0.11 0.24 / 0.22 0.23 0.21 / 0.19 0.42 / 0.38 0.43 19 / 18 19 / 18 5.5 35 / 34 35 / 34 10 Width (B) mm 204 204 204 255 255 255 Height (H) mm 204 204 204 255 255 255 Depth (T1) mm 24 24 24 25 25 25 Max. installation depth (T2) mm 90 90 90 107 107 107 177 x 177 177 x 177 177 x 177 224 x 224 224 x 224 224 x 224 Axial, shaded pole motor Axial, shaded pole motor Axial, DC motor Diagonal, shaded pole motor Diagonal, shaded pole motor Diagonal, DC motor Rated operating voltage V, ~, Hz Power consumption W Required mounting cut-out (BxH) mm Fan Operating temperature range -15 °C...+55 °C -15 °C...+55 °C -15 °C...+55 °C -30 °C...+55 °C -30 °C...+55 °C -30 °C...+55 °C Storage temperature range -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C Noise level dB(A) Service life of fans (L10, 40 °C) h Weight kg Page 46 / 49 46 / 49 46 51 / 46 51 / 46 51 68200 / 68200 68200 / 68200 95500 72000 / 76000 72000 / 76000 75000 1.04 1.04 0.78 2.26 2.08 1.88 3239.200 3239.200 3239.200 3240.200 3240.200 3240.200 537 see page see page see page see page see page see page 535 Outlet filter 1 pc(s). Spare filter mat Fine filter mat 5 pc(s). 3181.100 3181.100 3181.100 3182.100 3182.100 3182.100 536 Hose-proof hood 1 pc(s). 3239.080 3239.080 3239.080 3240.080 3240.080 3240.080 538 Blanking cover 2 pc(s). 3239.020 3239.020 3239.020 3240.020 3240.020 3240.020 538 Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 3114.200 3114.200 546 Air throughput 230 – 550 m³/h Model No. Packs of Rated operating voltage V, ~, Hz 3241.100 3241.110 3241.124 3243.100 3243.110 230, 1~, 50/60 115, 1~, 50/60 24 (DC) 230, 1~, 50/60 115, 1~, 50/60 Page Air throughput, unimpeded air flow m³/h 230 / 250 230 / 250 230 550 / 600 550 / 600 Rated current A 0.26 / 0.24 0.52 / 0.48 0.8 0.37 / 0.39 0.78 / 0.8 40 / 42 40 / 42 19 70 / 87 75 / 90 Width (B) mm 255 255 255 323 323 Height (H) mm 255 255 255 323 323 Depth (T1) mm 25 25 25 25 25 Max. installation depth (T2) mm 107 107 107 118.5 118.5 224 x 224 224 x 224 224 x 224 292 x 292 292 x 292 Diagonal, shaded pole motor Diagonal, shaded pole motor Diagonal, DC motor Operating temperature range -30 °C...+55 °C -30 °C...+55 °C -30 °C...+55 °C -30 °C...+55 °C -30 °C...+55 °C Storage temperature range -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C 54 / 56 54 / 56 54 59 / 61 59 / 61 61000 / 60000 61000 / 60000 75000 65000 / 61000 61000 / 59000 2.24 2.26 2.04 3.58 3.58 3240.200 3240.200 3240.200 3243.200 3243.200 537 see page see page see page see page see page 535 Power consumption W Required mounting cut-out (BxH) mm Fan Noise level dB(A) Service life of fans (L10, 40 °C) h Weight kg Diagonal, Diagonal, 1~ capacitor motor 1~ capacitor motor Accessories Outlet filter 1 pc(s). Spare filter mat Fine filter mat 5 pc(s). 3182.100 3182.100 3182.100 3183.100 3183.100 536 Hose-proof hood 1 pc(s). 3240.080 3240.080 3240.080 3243.080 3243.080 538 Blanking cover 2 pc(s). 3240.020 3240.020 3240.020 3243.020 3243.020 538 Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 3114.200 546 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 457 Climate control Accessories TopTherm fan-and-filter units Air throughput 700 m³/h Model No. Packs of 3244.100 3244.110 3244.140 230, 1~, 50/60 115, 1~, 50/60 400, 3~, 50/60 460, 3~, 60 Air throughput, unimpeded air flow m³/h 700 / 770 700 / 770 700 / 770 Rated current A 0.43 / 0.6 0.9 / 1.25 0.17 / 0.21 Power consumption W Rated operating voltage V, ~, Hz 95 / 135 100 / 145 93 / 140 Width (B) mm 323 323 323 Height (H) mm 323 323 323 Depth (T1) mm 25 25 25 130.5 130.5 130.5 292 x 292 292 x 292 292 x 292 Max. installation depth (T2) mm Required mounting cut-out (BxH) mm Fan Page Diagonal, 1~ capacitor motor Diagonal, 1~ capacitor motor Diagonal, three-phase motor Operating temperature range -30 °C...+55 °C -30 °C...+55 °C -30 °C...+55 °C Storage temperature range -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C 65 / 66 65 / 66 67 / 70 66000 / 64000 66000 / 62000 66000 / 62000 4.3 4.3 4.1 3243.200 3243.200 3243.200 537 see page see page see page 535 Noise level dB(A) Service life of fans (L10, 40 °C) h Weight kg Accessories Outlet filter 1 pc(s). Spare filter mat Fine filter mat 5 pc(s). 3183.100 3183.100 3183.100 536 Hose-proof hood 1 pc(s). 3243.080 3243.080 3243.080 538 Blanking cover 2 pc(s). 3243.020 3243.020 3243.020 538 Thermostat 1 pc(s). 3110.000 3110.000 – 547 1 pc(s). 3118.000 3118.000 – 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 – 546 Rittal – The System. Hygrostat 458 Spare filter mats see page 535 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm fan-and-filter units Air throughputs incl. outlet filter and protection categories Page 463  Accessories for climate control Page 533  Therm software Page 558   Note: – To improve energy efficiency and extend the service life of the devices, we recommend the use of thermostats or temperature displays Approvals: Available on the Internet T2 T1 Climate control Colour: – RAL 7035 Supply includes: – Complete unit ready to install, including filter mat Performance diagrams: Available on the Internet H EMC fan-and-filter units offer a high shielding/attenuation effect and meet requirement category 2 to EN 61587-3. B Air throughput 20 – 180 m³/h, EMC Model No. Packs of Rated operating voltage V, ~, Hz Air throughput, unimpeded air flow m³/h Rated current A 3237.600 3238.600 3239.600 3240.600 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 20 / 25 55 / 66 105 / 120 180 / 160 0.065 / 0.052 0.12 / 0.11 0.12 / 0.11 0.21 / 0.19 Power consumption W 11 / 9 19 / 18 19 / 18 35 / 34 Width (B) mm 116.5 148.5 204 255 Height (H) mm 116.5 148.5 204 255 Depth (T1) mm 16 16 24 25 Max. installation depth (T2) mm 43 58.5 90 107 92 x 92 124 x 124 177 x 177 224 x 224 Axial, shaded pole motor Axial, shaded pole motor Axial, shaded pole motor Diagonal, shaded pole motor Operating temperature range -15 °C...+55 °C -15 °C...+55 °C -15 °C...+55 °C -30 °C...+55 °C Storage temperature range -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C 38 / 43 46 / 49 46 / 49 51 / 46 55000 / 60000 68200 / 68200 68200 / 68200 72000 / 76000 0.49 2.0 1.2 2.12 Required mounting cut-out (BxH) mm Fan Noise level dB(A) Service life of fans (L10, 40 °C) h Weight kg Page Accessories Outlet filter 1 pc(s). 3237.060 3238.060 3239.060 3240.060 537 Spare filter mat 5 pc(s). 3237.066 3238.066 3239.066 3240.066 535 Fine filter mat 5 pc(s). – 3238.055 3181.100 3182.100 536 Hose-proof hood 1 pc(s). 3237.080 3238.080 3239.080 3240.080 538 Speed control 1 pc(s). 3120.200 3120.200 3120.200 3120.200 549 – – – – EC speed control – Control unit for EC fan EC speed control – Sensor for speed control – – – – Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 546 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 459 TopTherm fan-and-filter units Air throughput 230 – 900 m³/h, EMC Model No. Packs of 3241.600 3243.600 3244.600 3245.600 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 200 - 240, 1~, 50/60 Air throughput, unimpeded air flow m³/h 230 / 250 550 / 600 700 / 770 900 Rated current A 0.26 / 0.24 0.37 / 0.39 0.43 / 0.6 1.33 / 1.33 40 / 42 70 / 87 95 / 135 165 / 165 Width (B) mm 255 323 323 323 Height (H) mm 255 323 323 323 Depth (T1) mm 25 25 25 25 Max. installation depth (T2) mm 107 118.5 130.5 130.5 224 x 224 292 x 292 292 x 292 292 x 292 Diagonal, shaded pole motor Diagonal, 1~ capacitor motor Diagonal, 1~ capacitor motor Diagonal, EC motor Operating temperature range -30 °C...+55 °C -30 °C...+55 °C -30 °C...+55 °C -25 °C...+55 °C Storage temperature range -30 °C...+70 °C -30 °C...+70 °C -30 °C...+70 °C -25 °C...+70 °C 54 / 56 59 / 61 65 / 66 72 61000 / 60000 65000 / 61000 66000 / 64000 59000 2.12 3.56 4.28 3.5 Rated operating voltage V, ~, Hz Power consumption W Required mounting cut-out (BxH) mm Fan Noise level dB(A) Service life of fans (L10, 40 °C) h Weight kg Page Accessories 1 pc(s). 3240.060 3243.060 3243.060 3243.060 537 Spare filter mat 5 pc(s). 3240.066 3243.066 3243.066 3243.066 535 Fine filter mat 5 pc(s). 3182.100 3183.100 3183.100 3183.100 536 Hose-proof hood 1 pc(s). 3240.080 3243.080 3243.080 3245.080 538 Speed control 1 pc(s). 3120.200 3120.200 3120.200 – 549 EC speed control – Control unit for EC fan 1 pc(s). – – – 3235.440 548 EC speed control – Sensor for speed control 1 pc(s). – – – 3235.450 548 Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 546 Rittal – The System. Outlet filter 460 EC speed control see page 548 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm fan-and-filter units Air throughputs incl. outlet filter and protection categories Page 463  Accessories for climate control Page 533  Therm software Page 558   Supply includes: – Complete unit ready to install, including filter mat Note: – For even more efficient operation or for monitoring the fan-and-filter units, we recommend the use of an EC speed control for EC fan-and-filter units T2 T1 Approvals: Available on the Internet Climate control Colour: – RAL 7035 H Energy-efficient version of the TopTherm fan-and-filter units with diagonal fan technology. Fans 3240.500 to 3245.510 may be controlled and monitored. The fan may be activated via the control interface with tacho signal output integrated as standard, and monitoring of the fan speed and function is supported. B Performance diagrams: Available on the Internet Air throughput 55 – 230 m³/h, with EC technology Model No. Packs of Control interface Rated operating voltage V, ~, Hz Air throughput, unimpeded air flow m³/h Rated current A Power consumption W 3238.500 3239.500 3240.500 3241.500 – – ◾ ◾ 200 - 240, 1~, 50/60 200 - 240, 1~, 50/60 200 - 240, 1~, 50/60 200 - 240, 1~, 50/60 55 / 55 105 / 105 180 / 180 230 / 230 0.045 / 0.045 0.045 / 0.045 0.12 / 0.12 0.17 / 0.17 6.1 / 6.1 6.1 / 6.1 11 / 11 16 / 16 Width (B) mm 148.5 204 255 255 Height (H) mm 148.5 204 255 255 Depth (T1) mm 16 24 25 25 58.5 90 107 107 Max. installation depth (T2) mm Required mounting cut-out (BxH) mm Page 124 x 124 177 x 177 224 x 224 224 x 224 Diagonal, EC motor Diagonal, EC motor Diagonal, EC motor Diagonal, EC motor Operating temperature range -20 °C...+55 °C -20 °C...+55 °C -25 °C...+55 °C -25 °C...+55 °C Storage temperature range -30 °C...+70 °C -30 °C...+70 °C -25 °C...+70 °C -25 °C...+70 °C Noise level dB(A) 49 / 49 53 / 53 47 / 47 52 / 52 Service life of fans (L10, 40 °C) h 62500 62500 71000 64000 0.62 0.91 2.01 1.98 3238.200 3239.200 3240.200 3240.200 537 see page see page see page see page 535 Fan Weight kg Accessories Outlet filter 1 pc(s). Spare filter mat Fine filter mat 5 pc(s). 3238.055 3181.100 3182.100 3182.100 536 Hose-proof hood 1 pc(s). 3238.080 3239.080 3240.080 3240.080 538 Blanking cover 2 pc(s). 3238.020 3239.020 3240.020 3240.020 538 EC speed control – Control unit for EC fan 1 pc(s). – – 3235.440 3235.440 548 EC speed control – Sensor for speed control 1 pc(s). – – 3235.450 3235.450 548 Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 546 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 461 TopTherm fan-and-filter units Air throughput 550 – 900 m³/h, with EC technology Model No. Packs of Control interface Rated operating voltage V, ~, Hz Air throughput, unimpeded air flow m³/h 3243.500 3244.500 3245.500 3245.510 ◾ ◾ ◾ ◾ 200 - 240, 1~, 50/60 200 - 240, 1~, 50/60 200 - 240, 1~, 50/60 100 - 130, 1~, 50/60 900 / 900 550 / 550 700 / 700 900 / 900 Rated current A 0.5 / 0.5 0.7 / 0.7 1.33 / 1.33 2.1 / 2.1 Power consumption W 51 / 51 80 / 80 165 / 165 165 / 165 Width (B) mm 323 323 323 323 Height (H) mm 323 323 323 323 Depth (T1) mm 25 25 25 25 118.5 130.5 130.5 130.5 Max. installation depth (T2) mm Required mounting cut-out (BxH) mm Page 292 x 292 292 x 292 292 x 292 292 x 292 Diagonal, EC motor Diagonal, EC motor Diagonal, EC motor Diagonal, EC motor Operating temperature range -25 °C...+55 °C -25 °C...+55 °C -25 °C...+55 °C -25 °C...+55 °C Storage temperature range -25 °C...+70 °C -25 °C...+70 °C -25 °C...+70 °C -25 °C...+70 °C Noise level dB(A) 63 / 63 64 / 64 72 / 72 72 / 72 Service life of fans (L10, 40 °C) h 65000 67000 59000 59000 2.92 2.7 3.46 3.76 3243.200 3243.200 3243.200 3243.200 537 see page see page see page see page 535 Fan Weight kg Accessories Outlet filter 1 pc(s). Spare filter mat 5 pc(s). 3183.100 3183.100 3183.100 3183.100 536 Hose-proof hood 1 pc(s). 3243.080 3243.080 3245.080 3245.080 538 Blanking cover 2 pc(s). 3243.020 3243.020 3243.020 3243.020 538 EC speed control – Control unit for EC fan 1 pc(s). 3235.440 3235.440 3235.440 3235.440 548 EC speed control – Sensor for speed control 1 pc(s). 3235.450 3235.450 3235.450 3235.450 548 Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 546 Rittal – The System. Fine filter mat 462 Therm software see page 558 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm fan-and-filter units Air throughput and protection category TopTherm fan-and-filter units Air throughput m3/h at 50/60 Hz 3237.100 3237.110 3237.124 3238.100 3238.110 3238.124 3239.100 3239.110 3239.124 3240.100 3240.110 3240.124 3241.100 3241.110 3241.124 3243.100 3243.110 Unimpeded air flow 20/25 Protection category IP to IEC 60 529/NEMA protection category Standard filter and additional micro-filter mat Standard filter and hose-proof hood – – IP 56/ Type 3, 3R – IP 54/ Type 12 With outlet filter including filter mat Standard filter 1 x 3237.200 15/18 – 55/66 1 x 3238.200 43/50 2 x 3238.200 46/56 55 1 x 3238.200 43 2 x 3238.200 46 105/120 1 x 3239.200 87/100 2 x 3239.200 93/108 1 x 3240.200 98/111 105 1 x 3239.200 87 2 x 3239.200 93 1 x 3240.200 98 180/160 1 x 3240.200 138/121 2 x 3240.200 165/140 1 x 3243.200 165/140 180 1 x 3240.200 138 2 x 3240.200 165 1 x 3243.200 165 230/250 1 x 3240.200 183/205 2 x 3240.200 203/220 1 x 3243.200 203/230 230 1 x 3240.200 183 2 x 3240.200 203 1 x 3243.200 203 550/600 1 x 3243.200 465/510 2 x 3243.200 508/548 – 700/770 1 x 3243.200 544/587 2 x 3243.200 630/690 – 20 IP 54/ Type 12 IP 56/ Type 3, 3R Type 4, 4X IP 55/ Type 12 Climate control Model No. 3244.100 3244.110 3244.140 TopTherm fan-and-filter units, EMC Air throughput m3/h at 50/60 Hz Model No. Unimpeded air flow 3237.600 20/25 1 x 3237.060 15/18 – 3238.600 55/66 1 x 3238.060 43/50 3239.600 105/120 3240.600 Protection category IP to IEC 60 529/NEMA protection category Standard filter and additional micro-filter mat Standard filter and hose-proof hood – – IP 56/ Type 3, 3R 2 x 3238.060 46/56 – IP 54/ Type 12 1 x 3239.060 87/100 2 x 3239.060 93/108 1 x 3240.060 98/111 180/160 1 x 3240.060 138/121 2 x 3240.060 165/140 1 x 3243.060 165/140 3241.600 230/250 1 x 3240.060 183/205 2 x 3240.060 203/220 1 x 3243.060 203/230 3243.600 550/600 1 x 3243.060 465/510 2 x 3243.060 508/548 – 3244.600 700/770 1 x 3243.060 544/587 2 x 3243.060 630/690 – 3245.600 900 1 x 3243.060 680 2 x 3243.060 820 – With EMC outlet filter including EMC filter mat Standard filter IP 54/ Type 12 IP 55/ Type 12 IP 51 IP 52 IP 56/ Type 3, 3R Type 4, 4X IP 56/ Type 1, 12 Type 3, 3R TopTherm fan-and-filter units with EC technology Air throughput m3/h at 50/60 Hz Protection category IP to IEC 60 529/NEMA protection category Model No. Unimpeded air flow 3238.500 55 1 x 3238.200 43 2 x 3238.200 46 – 3239.500 105 1 x 3239.200 87 2 x 3239.200 93 1 x 3240.200 98 3240.500 180 1 x 3240.200 138 2 x 3240.200 165 1 x 3243.200 165 3241.500 230 1 x 3240.200 183 2 x 3240.200 203 1 x 3243.200 203 3243.500 550 1 x 3243.200 465 2 x 3243.200 508 – 3244.500 700 1 x 3243.200 544 2 x 3243.200 630 – 3245.500 900 1 x 3243.200 680 2 x 3243.200 820 – 900 1 x 3243.200 680 2 x 3243.200 820 – 3245.510 With outlet filter including filter mat Rittal System Catalogue 36/Climate control Standard filter Standard filter and additional micro-filter mat Standard filter and hose-proof hood IP 54/ Type 12 IP 54/ Type 12 IP 51 Further technical information available on the Internet. IP 55/ Type 12 IP 52 IP 56/ Type 3, 3R Type 4, 4X IP 56/ Type 1, 12 Type 3, 3R 463 Roof-mounted fan, roof vent Accessories for climate control Page 533  Therm software Page 558   Roof-mounted fan with a high protection category and flexible installation from the inside or outside. Protection category IP to IEC 60 529: – IP 21 without filter mat – IP 55 including filter mat Colour: – RAL 7035 Protection category NEMA: – NEMA 12 Note: – To improve energy efficiency and extend the service life of the devices, we recommend the use of thermostats or temperature displays Approvals: Available on the Internet Performance diagrams: Available on the Internet Supply includes: – Complete unit ready to install, including filter mat Air throughput, unimpeded air flow 500 – 965 m³/h Model No. Packs of 3138.000 3139.100 3139.110 3140.100 3140.110 3140.140 Rated operating voltage V, ~, Hz – 220 - 240, 1~, 50/60 115, 1~, 60 220 - 240, 1~, 50/60 115, 1~, 60 380 - 415, 3~, 50/60 400 - 480, 3~, 60 Air throughput, unimpeded air flow (without filter mats) m³/h – 500 / 525 525 873 / 965 965 863 / 942 Air throughput, unimpeded air flow (with filter mats) m³/h – 417 / 446 446 725 / 759 759 700 / 749 Rated current A – 0.23 / 0.27 0.56 0.43 / 0.56 1.2 0.17 / 0.2 Power consumption W – 51 / 62 65 99 / 130 138 98 / 130 Width mm 400 400 400 400 400 400 Height mm 133 133 133 133 133 133 Depth mm 400 400 400 400 400 400 Max. installation depth mm 27.5 34.6 34.6 34.6 34.6 34.6 Required mounting cut-out mm 258 x 258 258 x 258 258 x 258 258 x 258 258 x 258 Fan without fan motor Radial, Radial, Radial, Radial, capacitor motor capacitor motor capacitor motor capacitor motor 258 x 258 Radial, rotary current motor Operating temperature range -20 °C...+55 °C -20 °C...+55 °C -20 °C...+55 °C -20 °C...+55 °C -20 °C...+55 °C -20 °C...+55 °C Storage temperature range -40 °C...+70 °C -40 °C...+70 °C -40 °C...+70 °C -40 °C...+70 °C -40 °C...+70 °C -40 °C...+70 °C Service life of fans (L10, 40 °C) h Weight kg Page – 69000 / 67600 69400 / 68000 62800 / 65800 67800 / 66400 63500 / 61500 3.2 5.2 5.2 6.0 6.0 6.0 Accessories Outlet filter 1 pc(s). 3243.200 3243.200 3243.200 3243.200 3243.200 3243.200 537 Spare filter mat 12 pc(s). 3174.100 3174.100 3174.100 3174.100 3174.100 3174.100 535 Speed control 1 pc(s). – 3120.200 3120.200 3120.200 3120.200 – 549 Thermostat 1 pc(s). – 3110.000 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). – 3118.000 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). – 3114.200 3114.200 3114.200 3114.200 3114.200 546 464 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Roof-mounted fans Accessories for climate control Page 533  Therm software Page 558   Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 21 without filter mat – IP 55 including filter mat Protection category NEMA: – NEMA 12 Supply includes: – Complete unit ready to install, including filter mat Note: – For even more efficient operation or for monitoring the fans, we recommend the use of the EC speed controls Approvals: Available on the Internet Climate control Energy-efficient and powerful design of the roof-mounted fans. The fan may be activated via the control interface with tacho signal output integrated as standard, and monitoring of the fan speed and function is supported. Performance diagrams: Available on the Internet Air throughput, unimpeded air flow 1069 m³/h, with EC technology Model No. Packs of Control interface Rated operating voltage V, ~, Hz Air throughput, unimpeded air flow (without filter mats) m³/h Air throughput, unimpeded air flow (with filter mats) m³/h Rated current A Power consumption W 3140.500 3140.510 ◾ ◾ 220 - 240, 1~, 50/60 115, 1~, 60 1069 / 1069 1069 841 / 841 841 1/1 1.51 129 / 129 112 Width mm 400 400 Height mm 133 133 Depth mm 400 400 Max. installation depth mm 34.6 34.6 Required mounting cut-out mm 258 x 258 258 x 258 Fan Radial, EC motor Radial, EC motor Operating temperature range -20 °C...+55 °C -20 °C...+55 °C Storage temperature range -40 °C...+70 °C -40 °C...+70 °C 84000 / 84000 82000 / 82000 5.6 5.6 Service life of fans (L10, 40 °C) h Weight kg Page Accessories Outlet filter 1 pc(s). 3243.200 3243.200 537 Spare filter mat 12 pc(s). 3174.100 3174.100 535 EC speed control – Control unit for EC fan 1 pc(s). 3235.440 3235.440 548 EC speed control – Sensor for speed control 1 pc(s). 3235.450 3235.450 548 Thermostat 1 pc(s). 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 546 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 465 Rack-mounted fans for 482.6 mm (19") Accessories for climate control Page 533   Colour: – RAL 7035 Approvals: Available on the Internet 0 20 Supply includes: – Fully wired unit ready for connection – Terminal strip and assembly parts 0 18 41 0 73 44 Rack-mounted fan for direct installation in the 482.6 mm (19") level. Installation allows air to circulate permanently inside the enclosure, thus preventing the formation of hot spots. 10 0 48 2.6 (19 ˝) Air throughput, unimpeded air flow 320 – 480 m³/h Model No. Packs of With monitoring Rated operating voltage V, ~, Hz Air throughput, unimpeded air flow m³/h 3340.230 3341.115 3341.230 3342.024 3342.230 3342.500 – – – – – ◾ 230, 1~, 50/60 115, 1~, 50/60 230, 1~, 50/60 24 (DC) 230, 1~, 50/60 115 - 230, 1~, 50/60 24 (DC) 480 320 480 480 480 480 No. of fans 2 3 3 3 3 3 Distance between axes mm 85 85 85 105 105 105 0.24 / 0.22 0.69 / 0.69 0.36 / 0.33 0.74 0.36 / 0.33 0.85 482.6 482.6 482.6 482.6 482.6 482.6 Rated current A Width mm Height mm 44 44 44 44 44 44 Depth mm 200 200 200 200 200 200 Operating temperature range Page -10 °C...+55 °C -10 °C...+55 °C -10 °C...+55 °C -10 °C...+55 °C -10 °C...+55 °C -10 °C...+55 °C Noise level dB(A) Weight kg 51 52 51 51 51 51 2.24 2.0 2.74 1.86 2.78 2.0 Accessories Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 3114.200 3114.200 546 Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 3110.000 3110.000 547 Speed control 1 pc(s). 3120.200 3120.200 3120.200 – 3120.200 – 549 466 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Vario rack-mounted fans for 482.6 mm (19") Accessories for climate control Page 533   Colour: – RAL 7035 Supply includes: – Fully wired unit ready for connection – Terminal strip and assembly parts 4 21 6 20 Climate control Benefits: – Guide frame ensures easy maintenance and replacement of the fans 43 2 Approvals: Available on the Internet 48 2.6 42 6 (19 ˝) 44 Rack-mounted fan for direct installation in the 482.6 mm (19") level. Installation allows air to circulate permanently inside the enclosure, thus preventing the formation of hot spots. Air throughput, unimpeded air flow 320 – 480 m³/h Model No. Packs of With monitoring Rated operating voltage V, ~, Hz Air throughput, unimpeded air flow m³/h 3350.230 3351.230 3352.230 3352.500 – – – ◾ 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 115 - 230, 1~, 50/60 24 (DC) 480 320 480 480 No. of fans 2 3 3 3 Distance between axes mm 85 85 105 105 Rated current A 0.24 / 0.22 0.36 / 0.33 0.36 / 0.33 0.85 / 0.85 Width mm 482.6 482.6 482.6 482.6 Height mm 44 44 44 44 Depth mm 200 200 200 200 -10 °C...+55 °C Operating temperature range Page -10 °C...+55 °C -10 °C...+55 °C -10 °C...+55 °C Noise level dB(A) 51 51 51 51 Weight kg 2.0 2.7 2.78 2.04 1 pc(s). 3355.100 3355.100 3355.100 3357.100 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 546 Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 547 Speed control 1 pc(s). 3120.200 3120.200 3120.200 – 549 Also required Guide frame 557 Accessories Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 467 Tangential fan for 482.6 mm (19") Accessories for climate control Page 533   Colour: – RAL 9005 Approvals: Available on the Internet 17 3 16 Supply includes: – Fully wired unit ready for connection – Filter mat 38 0 88 Centrifugal fans for direct installation in the 482.6 mm (19") level provide a wide column of air plus favourable noise characteristics to set them apart from other fans. 48 2.6 (19 ˝) Air throughput, unimpeded air flow 320 m³/h Model No. Packs of Rated operating voltage V, ~, Hz 3144.000 Page 230, 1~, 50/60 Air throughput, unimpeded air flow m³/h 320 Rated current A 0.16 Power consumption W 37 Width mm 482.6 Height mm 88 Depth mm 163 Operating temperature range -10 °C...+55 °C Noise level dB(A) 52 Speed rpm 2245 Maximum static pressure difference Pa 65 - 70 Weight kg 2.02 Accessories Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 546 Thermostat 1 pc(s). 3110.000 547 Filter mat 5 pc(s). 3177.000 533 Front outlet grille 2 U 1 pc(s). 3176.000 539 Speed control 1 pc(s). 3120.200 549 468 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm air/air heat exchangers Accessories for climate control Page 533  Therm software Page 558   Temperature control: – Electronic control with digital display (factory setting +35 °C) Colour: – RAL 7035 Protection category IP to IEC 60 529: – Internal circuit IP 54 – External circuit IP 34 Supply includes: – Complete unit ready for connection – Plug-in terminal strip – Floating fault signal contact in case of overtemperature – Drilling template – Assembly parts Approvals: Available on the Internet Climate control Air/air heat exchangers are particularly well-suited to aggressive ambient conditions, because the internal and external air circuits are completely separate from one another. Performance diagrams: Available on the Internet Specific thermal output 17.5 – 90 W/K, wall-mounted with controller Model No. Packs of Rated operating voltage V, ~, Hz Specific thermal output W/K Rated current A Rated power input W 3126.100 3127.100 3128.100 3129.100 3130.100 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 17.5 30 45 60 90 0.22 / 0.26 0.56 / 0.68 0.6 / 0.8 0.75 / 0.8 1.35 / 1.8 300 / 400 50 / 60 120 / 150 140 / 180 170 / 180 Width mm 280 400 400 400 400 Height mm 550 950 950 950 1580 Depth mm Operating temperature range Weight kg 150 205 205 225 215 -5 °C...+55 °C -5 °C...+55 °C -5 °C...+55 °C -5 °C...+55 °C -5 °C...+55 °C 10.0 18.0 19.0 21.0 34.0 Page Accessories Filter mat 3 pc(s). 3286.300 3286.400 3286.400 3286.400 3286.400 533 Metal filter 1 pc(s). 3286.310 3286.410 3286.410 3286.410 3286.410 534 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 469 Air/air heat exchanger Accessories for climate control Page 533  Therm software Page 558   Air/air heat exchangers are particularly well-suited to aggressive ambient conditions, because the internal and external air circuits are completely separate from one another. Colour: – Cover: RAL 7035 – Enclosure: RAL 7016 Protection category IP to IEC 60 529: – Internal circuit IP 54 – External circuit IP 34 Supply includes: – Complete unit ready for connection – The fans are connected via two 3-wire connection cables, with wire end ferrules – Drilling template – Assembly parts Note: – For precise temperature control inside the enclosure, we recommend the enclosure internal thermostat, the digital enclosure internal temperature display and thermostat or the speed control. Specific thermal output 66 W/K, roof-mounted Model No. Packs of 3248.000 Page Rated operating voltage V, ~, Hz 230, 1~, 50/60 Specific thermal output W/K 66 No. of fans 2 Max. rated current per fan A 0.32 / 0.4 Rated power input W 70 / 90 Width mm 595 Height mm 362 Depth mm 440 Operating temperature range -5 °C...+55 °C Type of electrical connection Connection cable Weight kg 25.0 Accessories Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 546 Thermostat 1 pc(s). 3110.000 547 Hygrostat 1 pc(s). 3118.000 547 Speed control 1 pc(s). 3120.200 549 470 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Roof-mounted fans Climate control Simple installation and a high protection category, from page 464 Rittal System Catalogue 36/Climate control 471 472 Rittal System Catalogue 36/Climate control Cooling units Thermoelectric coolers Thermoelectric coolers ........................................................80 W ..............474 Wall-mounted cooling units TopTherm, horizontal format.............................................. 300 W ..............475 TopTherm..........................................................................300 W ..............476 TopTherm Blue e ............................................................... 500 W ..............478 TopTherm Blue e ............................................................... 750 W ..............478 TopTherm Blue e .............................................................1000 W ..............479 TopTherm Blue e .............................................................1500 W ..............480 TopTherm Blue e .............................................................2000 W ..............481 TopTherm Blue e .............................................................2500 W ..............482 TopTherm Blue e, slimline................................................1500 W ..............483 Product advantages ...................................................................................484 Blue e+............................................................................1600 W ..............487 Blue e+................................................................ 2000 – 5800 W ..............489 TopTherm Blue e, NEMA 4X .................................. 500 – 1500 W ..............490 TopTherm Blue e, NEMA 4X ................................ 2000 – 2500 W ..............491 Product advantages ...................................................................................492 TopTherm Blue e, UL Type 3R/4 ........................... 500 – 2500 W ..............494 Roof-mounted cooling units TopTherm Blue e ............................................................... 500 W ..............498 TopTherm Blue e ............................................................... 750 W ..............499 TopTherm Blue e .............................................................1000 W ..............499 TopTherm Blue e ................................................. 1100 – 1500 W ..............500 TopTherm Blue e .............................................................2000 W ..............500 TopTherm Blue e ................................................. 3000 – 4000 W ..............501 Product advantages ...................................................................................502 Blue e+............................................................................1300 W ..............504 Integration solution Product advantages ...................................................................................502 VX25 Blue e+...................................................................1300 W ..............505 Modular climate control concept Cooling module Blue e......................................... 1500 – 2500 W ..............506 Section doors for installing cooling modules ...............................................507 ......................................................................................................................... The perfect symbiosis of the VX25 baying enclosure system and Blue e+ cooling unit ◾ Integrated all-in-one system The Blue e+ cooling unit is already integrated in the VX25 enclosure ◾ Plug & play Cooling unit, door limit switches and cabling are installed ready to connect ◾ State-of-the-art design No cooling unit built onto the enclosure Rittal System Catalogue 36/Climate control 473 Climate control Product advantages ...................................................................................496 Outdoor cooling unit ........................................................1500 W ..............497 Thermoelectric coolers Accessories for climate control Page 533  Therm software Page 558   Colour: – Cover: RAL 7015 Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 T2 Performance diagrams: Available on the Internet H Material: – Device: Aluminium, anodised Supply includes: – Thermoelectric climate control unit – Fully wired ready for connection (plug-in terminal strip) – Mounting accessories – Filter mat – USB cable A/B – Drilling template H Powerful thermoelectric cooling units in a lightweight design for the climate control of command panels and small enclosures. T1 B T1 B Total cooling output 80/100 W Model No. Packs of Rated operating voltage V, ~, Hz 3201.200 3201.300 100 - 240, 1~, 50/60 24 (DC) Total cooling output L35 L35 W 80 / 80 80 Total cooling output L35 L30 W 100 / 100 100 Thermal output W 80 80 Width (B) mm 125 125 Height (H) mm 400 400 Depth (T1) mm 155 155 Installation depth (T2) mm 100 100 -30 °C...+55 °C -30 °C...+60 °C Operating temperature range Setting range, cooling +5 °C...+55 °C +5 °C...+55 °C Setting range, heating -10 °C...+20 °C -10 °C...+20 °C 0.8 0.9 Refrigeration factor/COP Power pack integrated ◾ – Weight kg 3.3 2.6 Page Accessories Spare filter mat 5 pc(s). 3201.050 3201.050 535 Condensate hose 1 pc(s). 3301.606 3301.606 544 474 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm wall-mounted cooling units, horizontal format Accessories for climate control Page 533  Therm software Page 558   Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 Approvals: Available on the Internet Performance diagrams: Available on the Internet Climate control Temperature control: – Basic controller (factory setting +35 °C) Supply includes: – Nano-coated condenser – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Assembly parts 340 Compact wall-mounted cooling units in horizontal format, with nano-coated condenser. 52 5 98 3 15 55 Output class 300 W Model No. Packs of Material Sheet steel Colour RAL 7035 Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 3302.300 3302.310 ◾ ◾ ◾ ◾ 0.36 – 0.36 / 0.38 0.38 0.21 / 0.22 0.23 230, 1~, 50/60 115, 1~, 60 Width mm 525 525 Height mm 340 340 Depth mm 153 153 Rated operating voltage V, ~, Hz Rated current max. A 1.6 / 1.7 4 Start-up current A 4.3 / 5.3 12 Power consumption Pel 50/60 Hz L35 L35 kW 0.27 / 0.29 0.32 Operating temperature range +10 °C...+55 °C +10 °C...+55 °C Setting range +30 °C...+55 °C +30 °C...+55 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g Weight kg 1.34 / 1.3 1.18 R134a, 100 R134a, 100 13.0 13.0 Page Accessories Filter mat 3 pc(s). 3286.110 3286.110 Metal filter 1 pc(s). 3286.120 3286.120 534 Door-operated switch 1 pc(s). 4127.010 4127.010 1024 Condensate hose 1 pc(s). 3301.608 3301.608 544 Electric condensate evaporator 1 pc(s). 3301.500 3301.500 543 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 533 475 TopTherm wall-mounted cooling units Accessories for climate control Page 533  Therm software Page 558   Temperature control: – Basic controller (factory setting +35 °C) Supply includes: – Nano-coated condenser – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Assembly parts Approvals: Available on the Internet Performance diagrams: Available on the Internet H Compact wall-mounted cooling units, with nano-coated condenser. Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 B T Output class 300 W Model No. Material Colour Packs of Sheet steel 3302.100 3302.110 3302.200 ◾ ◾ – ◾ Stainless steel 1.4301 (AISI 304) – – RAL 7035 ◾ ◾ – RAL 9007 – – ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 0.36 – 0.36 0.36 / 0.38 0.38 0.36 / 0.38 0.21 / 0.23 0.23 0.21 / 0.23 230, 1~, 50/60 115, 1~, 60 230, 1~, 50/60 Width (B) mm 280 280 280 Height (H) mm 550 550 550 Depth (T) mm 140 140 140 1.6 / 1.7 3.3 1.6 / 1.7 Rated operating voltage V, ~, Hz Rated current max. A Start-up current A 3 / 3.4 8 3 / 3.4 0.27 / 0.28 0.32 0.27 / 0.28 Operating temperature range +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C Setting range +30 °C...+55 °C +30 °C...+55 °C +30 °C...+55 °C 1.3 / 1.32 1.18 1.3 / 1.32 R134a, 100 R134a, 100 R134a, 100 13.0 13.0 13.0 Power consumption Pel 50/60 Hz L35 L35 kW Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g Weight kg Page Accessories Filter mat 3 pc(s). 3286.300 3286.300 3286.300 Metal filter 1 pc(s). 3286.310 3286.310 3286.310 533 534 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 1024 Condensate hose 1 pc(s). 3301.610 3301.610 3301.610 544 Electric condensate evaporator 1 pc(s). 3301.500 3301.500 3301.500 543 476 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm wall-mounted cooling units Blue e Accessories for climate control Page 533  Therm software Page 558  RiDiag software Page 559   Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 Supply includes: – Nano-coated condenser – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Assembly parts Approvals: Available on the Internet Climate control Benefits: – May be linked to the IoT interface via the Blue e IoT adaptor Temperature control: – e-Comfort controller (factory setting +35 °C) Performance diagrams: Available on the Internet H Energy-efficient Blue e wallmounted cooling units with integral e-Comfort controller and RiNano coating on the condenser as standard. B T Note: – The technical specifications for the wall-mounted cooling unit 3361.540 apply with an external transformer connected. Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 477 TopTherm wall-mounted cooling units Blue e Output class 500 W Model No. Material Colour Packs of 3303.500 3303.510 3303.600 ◾ ◾ – ◾ Sheet steel Stainless steel 1.4301 (AISI 304) – – RAL 7035 ◾ ◾ – RAL 9007 – – ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 0.55 – 0.55 0.55 / 0.66 0.66 0.55 / 0.66 0.33 / 0.4 0.4 0.33 / 0.4 230, 1~, 50/60 115, 1~, 60 230, 1~, 50/60 Width (B) mm 280 280 280 Height (H) mm 550 550 550 Depth (T) mm 210 210 210 Rated current max. A 2.6 / 2.6 5.7 2.6 / 2.6 Start-up current A 5.1 / 6.4 11.5 5.1 / 6.4 – – – 0.39 / 0.41 0.5 0.39 / 0.41 +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C – – – +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Rated operating voltage V, ~, Hz Toroidal transformer (external) Ø x D Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range Operating temperature (max.) 60 Hz Setting range Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g 1.4 / 1.21 1.31 1.4 R134a, 170 R134a, 170 R134a, 170 17.0 17.0 17.0 Weight kg Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 1024 Filter mat 3 pc(s). 3286.300 3286.300 3286.300 533 Metal filter 1 pc(s). 3286.310 3286.310 3286.310 534 Master/slave cable 1 pc(s). 3124.100 3124.100 3124.100 550 Electric condensate evaporator 1 pc(s). 3301.500 3301.500 3301.500 543 Condensate hose 1 pc(s). 3301.610 3301.610 3301.610 544 RiDiag 1 pc(s). 3159.100 3159.100 3159.100 559 Output class 750 W Model No. Material Colour Packs of Sheet steel 3361.500 3361.510 3361.540 3361.600 ◾ ◾ ◾ – ◾ Stainless steel 1.4301 (AISI 304) – – – RAL 7035 ◾ ◾ ◾ – RAL 9007 – – – ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 0.85 – 0.85 0.85 0.85 / 0.89 0.89 0.85 / 0.89 0.85 / 0.89 0.67 / 0.67 0.67 0.67 / 0.67 0.67 / 0.67 230, 1~, 50/60 115, 1~, 60 400, 2~, 50/60 230, 1~, 50/60 Width (B) mm 280 280 280 280 Height (H) mm 550 550 550 550 Depth (T) mm 280 280 280 280 2.7 / 2.7 5.3 1.2 / 1.4 2.7 / 2.7 6 / 9.6 12 3.1 / 3.3 6 / 9.6 – – 126 x 65 – 0.4 / 0.43 0.55 0.4 / 0.43 0.4 / 0.43 +10 °C...+55 °C +10 °C...+52 °C +10 °C...+55 °C +10 °C...+55 °C +53 °C +52 °C +53 °C +53 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Rated operating voltage V, ~, Hz Rated current max. A Start-up current A Toroidal transformer (external) Ø x D mm Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range Operating temperature (max.) 60 Hz Setting range Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.08 / 2.03 1.59 2.08 / 2.03 2.08 / 2.03 Refrigerant g R134a, 280 R134a, 260 R134a, 280 R134a, 280 22.0 22.0 22.0 22.0 Weight kg Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Filter mat 3 pc(s). 3286.300 3286.300 3286.300 3286.300 533 Metal filter 1 pc(s). 3286.310 3286.310 3286.310 3286.310 534 Master/slave cable 1 pc(s). 3124.100 3124.100 3124.100 3124.100 550 Electric condensate evaporator 1 pc(s). 3301.500 3301.500 3301.500 3301.500 543 Condensate hose 1 pc(s). 3301.610 3301.610 3301.610 3301.610 544 RiDiag 1 pc(s). 3159.100 3159.100 3159.100 3159.100 559 478 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm wall-mounted cooling units Blue e Accessories for climate control Page 533  Therm software Page 558  RiDiag software Page 559   Temperature control: – e-Comfort controller (factory setting +35 °C) Approvals: Available on the Internet Climate control Benefits: – May be linked to the IoT interface via the Blue e IoT adaptor Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 Performance diagrams: Available on the Internet Supply includes: – Nano-coated condenser – Integral electric condensate evaporation – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Assembly parts H Energy-efficient Blue e wallmounted cooling units with integral e-Comfort controller, RiNano coating on the condenser and electrical condensate evaporation as standard. B T Output class 1000 W Model No. Packs of Sheet steel Material Colour 3304.500 3304.510 3304.540 3304.600 3304.640 ◾ ◾ ◾ – – ◾ Stainless steel 1.4301 (AISI 304) – – – ◾ RAL 7035 ◾ ◾ ◾ – – RAL 9007 – – – ◾ ◾ 1.1 1.1 1.1 1.1 1.1 1.1 / 1.26 Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW 1.1 / 1.25 1.1 / 1.25 1.1 / 1.25 1.1 / 1.25 Total cooling output 50/60 Hz L35 L50 kW 0.91 / 0.9 0.91 / 0.9 0.98 / 0.9 0.91 / 0.9 0.98 / 0.9 230, 1~, 50/60 115, 1~, 50/60 400, 3~, 50 460, 3~, 60 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 Width (B) mm 400 400 400 400 400 Height (H) mm 950 950 950 950 950 Depth (T) mm 260 260 260 260 260 3.9 / 4.3 8 / 8.8 2.2 / 2.1 3.9 / 4.3 2.2 / 2.1 12 / 14 26 / 28 11.5 / 12.7 12 / 14 11.5 / 12.7 0.64 / 0.68 0.64 / 0.68 0.64 / 0.79 0.6 / 0.68 0.64 / 0.79 Rated operating voltage V, ~, Hz Rated current max. A Start-up current A Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 1.83 / 1.84 1.83 / 1.84 1.72 / 1.58 1.83 / 1.84 1.72 / 1.59 Refrigerant g R134a, 325 R134a, 325 R134a, 325 R134a, 325 R134a, 325 39.0 44.0 40.0 39.0 40.0 Weight kg Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 3124.300 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 3124.310 554 555 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 4127.010 1024 Filter mat 3 pc(s). 3286.400 3286.400 3286.400 3286.400 3286.400 533 Metal filter 1 pc(s). 3286.410 3286.410 3286.410 3286.410 3286.410 534 Master/slave cable 1 pc(s). 3124.100 3124.100 3124.100 3124.100 3124.100 550 Air diverter 1 pc(s). 3213.310 3213.310 3213.310 3213.310 3213.310 542 Condensate hose 1 pc(s). 3301.612 3301.612 3301.612 3301.612 3301.612 544 RiDiag 1 pc(s). 3159.100 3159.100 3159.100 3159.100 3159.100 559 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 479 TopTherm wall-mounted cooling units Blue e Output class 1500 W Model No. 3305.500 3305.510 3305.540 Material Sheet steel Packs of ◾ ◾ ◾ Colour RAL 7035 ◾ ◾ ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 1.6 1.6 1.6 1.6 / 1.76 1.6 / 1.76 1.6 / 1.61 1.25 / 1.37 1.25 / 1.37 1.33 / 1.35 230, 1~, 50/60 115, 1~, 50/60 400, 3~, 50 460, 3~, 60 Width (B) mm 400 400 400 Height (H) mm 950 950 950 Depth (T) mm 260 260 260 5.5 / 5.8 11.5 / 12.5 2.5 / 2.8 12.2 / 11.3 Rated operating voltage V, ~, Hz Rated current max. A Start-up current A 12 / 14 26 / 28 0.87 / 0.98 0.87 / 0.98 0.9 / 1.08 Operating temperature range +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C Setting range +20 °C...+55 °C Power consumption Pel 50/60 Hz L35 L35 kW +20 °C...+55 °C +20 °C...+55 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 1.83 / 1.79 1.83 / 1.79 1.83 / 1.49 Refrigerant g R134a, 500 R134a, 500 R134a, 500 41.0 46.0 42.0 Weight kg Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 1024 Filter mat 3 pc(s). 3286.400 3286.400 3286.400 533 Metal filter 1 pc(s). 3286.410 3286.410 3286.410 534 Master/slave cable 1 pc(s). 3124.100 3124.100 3124.100 550 Air diverter 1 pc(s). 3213.310 3213.310 3213.310 542 1 pc(s). 3301.612 3301.612 3301.612 544 RiDiag 1 pc(s). 3159.100 3159.100 3159.100 559 Rittal – The System. Condensate hose 480 Rittal Configuration System see page 272 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm wall-mounted cooling units Blue e Accessories for climate control Page 533  Therm software Page 558  RiDiag software Page 559   Temperature control: – e-Comfort controller (factory setting +35 °C) Approvals: Available on the Internet Climate control Benefits: – May be linked to the IoT interface via the Blue e IoT adaptor Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 Performance diagrams: Available on the Internet Supply includes: – Nano-coated condenser – Integral electric condensate evaporation – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Assembly parts H Energy-efficient Blue e wallmounted cooling units with integral e-Comfort controller, RiNano coating on the condenser and electrical condensate evaporation as standard. B T Output class 2000 W Model No. Packs of Material Sheet steel Colour RAL 7035 Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW 3328.500 3328.540 ◾ ◾ ◾ ◾ 2.2 2.2 Total cooling output 50/60 Hz L35 L35 kW 2.2 / 2.56 2.2 / 2.55 Total cooling output 50/60 Hz L35 L50 kW 1.82 / 1.95 1.65 / 1.89 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 Rated operating voltage V, ~, Hz Width (B) mm 400 400 Height (H) mm 1580 1580 Depth (T) mm Rated current max. A Start-up current A 295 295 6.1 / 6.6 2.8 / 3.3 20 / 22 6.8 / 7.8 0.91 / 1.03 0.92 / 1.15 Operating temperature range +10 °C...+55 °C +10 °C...+55 °C Setting range +20 °C...+55 °C +20 °C...+55 °C Power consumption Pel 50/60 Hz L35 L35 kW Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g Weight kg 2.4 / 2.47 2.4 / 2.22 R134a, 950 R134a, 950 66.0 67.0 Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 1024 Filter mat 3 pc(s). 3286.400 3286.400 533 Metal filter 1 pc(s). 3286.410 3286.410 534 Master/slave cable 1 pc(s). 3124.100 3124.100 550 Air diverter 1 pc(s). 3213.320 3213.320 542 Condensate hose 1 pc(s). 3301.612 3301.612 544 RiDiag 1 pc(s). 3159.100 3159.100 559 Eyebolts 4 pc(s). 4568.000 4568.000 964 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 481 TopTherm wall-mounted cooling units Blue e Output class 2500 W Model No. Packs of Material Sheet steel Colour RAL 7035 3329.500 3329.540 ◾ ◾ ◾ ◾ 2.55 2.55 Total cooling output 50/60 Hz L35 L35 kW 2.55 / 2.71 2.55 / 2.75 Total cooling output 50/60 Hz L35 L50 kW 1.8 / 1.8 1.95 / 2 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Rated operating voltage V, ~, Hz Width (B) mm 400 400 Height (H) mm 1580 1580 Depth (T) mm Rated current max. A Start-up current A 295 295 7.9 / 9.3 3.3 / 3.4 25 / 22 6.8 / 7.6 1.21 / 1.35 1.19 / 1.39 Operating temperature range +10 °C...+55 °C +10 °C...+55 °C Setting range +20 °C...+55 °C +20 °C...+55 °C Power consumption Pel 50/60 Hz L35 L35 kW Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.11 / 2.01 2.11 / 1.97 Refrigerant g R134a, 950 R134a, 950 69.0 70.0 Weight kg Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 1024 Filter mat 3 pc(s). 3286.400 3286.400 533 Metal filter 1 pc(s). 3286.410 3286.410 534 Master/slave cable 1 pc(s). 3124.100 3124.100 550 1 pc(s). 3213.320 3213.320 542 Condensate hose 1 pc(s). 3301.612 3301.612 544 RiDiag 1 pc(s). 3159.100 3159.100 559 Eyebolts 4 pc(s). 4568.000 4568.000 964 Rittal – The System. Air diverter 482 Blue e IoT adaptor see page 555 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm wall-mounted cooling units Blue e, slimline Energy-efficient Blue e wallmounted cooling units with e-Comfort controller integrated as standard, RiNano coating on the condenser and electrical condensate evaporation. Slimline design. Benefits: – May be linked to the IoT interface via the Blue e IoT adaptor Temperature control: – e-Comfort controller (factory setting +35 °C) Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 Supply includes: – Nano-coated condenser – Integral electric condensate evaporation – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Assembly parts for internal mounting Note: – For external mounting of the cooling unit, trim frame 3377.000 including assembly parts may be fitted. This gives the cooling unit a closed front appearance. Approvals: Available on the Internet Performance diagrams: Available on the Internet Output class 1500 W Model No. Packs of Material Sheet steel Colour RAL 7035 Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW 3366.500 3366.540 ◾ ◾ ◾ ◾ 1.6 1.6 Total cooling output 50/60 Hz L35 L35 kW 1.6 / 1.6 1.6 / 1.6 Total cooling output 50/60 Hz L35 L50 kW 1.15 / 1.2 1.08 / 1.18 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 Rated operating voltage V, ~, Hz Width mm 435 435 Height mm 1590 1590 Depth mm Rated current max. A Start-up current A 205 205 6.7 / 6.9 2.7 / 2.9 22 / 24 8 / 8.8 0.84 / 0.97 0.9 / 1.05 Operating temperature range +10 °C...+55 °C +10 °C...+55 °C Setting range +20 °C...+55 °C +20 °C...+55 °C Power consumption Pel 50/60 Hz L35 L35 kW Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g Weight kg 1.9 / 1.65 1.9 / 1.52 R134a, 700 R134a, 700 45.0 46.0 Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 1024 Filter mat 3 pc(s). 3286.400 3286.400 533 Metal filter 1 pc(s). 3286.410 3286.410 534 Master/slave cable 1 pc(s). 3124.100 3124.100 550 Trim frame 1 pc(s). 3377.000 3377.000 556 Condensate hose 1 pc(s). 3301.612 3301.612 544 RiDiag 1 pc(s). 3159.100 3159.100 559 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 483 Climate control Accessories for climate control Page 533  Therm software Page 558  RiDiag software Page 559   Wall-mounted cooling units Blue e+ Wall-mounted cooling units Blue e+ The world's most efficient range of cooling units. 484 Rittal System Catalogue 36/Climate control Incredibly efficient ◾ Average 75% energy savings with innovative hybrid technology ◾ Active cooling circuit with speed-regulated components for demand-based cooling ◾ Integral heat pipe for passive cooling dissipates heat from the enclosure as soon as the ambient temperature falls below the setpoint Intelligent networking ◾ In conjunction with the IoT interface, all Blue e+ cooling units can now be networked and digitalised Climate control The benefits for you: – Continuous monitoring of temperature levels – Avoidance of downtime costs and consequential damage – Automatic notification of any cooling unit malfunctions – Asset Management: Localisation and organisation of cooling units – Remote access: Device parameters can be configured remotely Easier to operate ◾ Fast unit analysis using RiDiag III software via USB port ◾ Fast parameterisation, data reading and plain-text system messages via the intelligent, multilingual, industry-grade display ◾ Contactless on-site information sharing and fast, direct analysis via the NFC interface with the Blue e+ app Maximum flexibility ◾ One device for all voltages and networks, suitable for worldwide use thanks to inverter technology: – 110 to 240 V, 1~, 50/60 Hz – 380 to 480 V, 3~, 50/60 Hz ◾ International approvals and certifications ◾ Available in sheet steel or stainless steel ◾ One version for external mounting, partial internal mounting and full internal mounting with identical mounting cut-out Rittal System Catalogue 36/Climate control 485 Wall-mounted cooling units Blue e+ Accessories for climate control Page 533  Therm software Page 558  Blue e+ app Page 559  IoT interface Page 554   Temperature control: – e+ controller (factory setting +35 °C) Protection category IP to IEC 60 529: – Internal circuit IP 55 486 Supply includes: – Nano-coated condenser – Integral electric condensate evaporation – Assembly parts – Fully wired ready for connection (plug-in terminal strip) Optional: – For remote monitoring and networking of cooling units and chillers in the Blue e+ generation, please use the IoT interface (Model No. 3124.300). Increase machine availability and process reliability with remote monitoring of device data, statuses and system messages. Approvals: Available on the Internet Performance diagrams: Available on the Internet H Benefits: – Average 75% energy savings thanks to speed-regulated components and heat pipe technology – Suitable for international use due to a unique multi-voltage capability – Longer service life of the components inside the enclosure and the cooling unit due to component-friendly cooling – Intuitive operation due to touch display and intelligent interfaces B T Note: – Please observe the mounting instructions. – Firmware can be updated using the RiDiag III software (3159.300) Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Wall-mounted cooling units Blue e+ Output class 1600 W Model No. Material Colour 3185.530 3185.830 Sheet steel Packs of – ◾ Stainless steel 1.4301 (AISI 304) ◾ – RAL 7035 – ◾ RAL 9007 ◾ – 1.6 1.6 Total cooling output 50/60 Hz L35 L35 kW 1.6 / 1.6 1.6 / 1.6 Total cooling output 50/60 Hz L35 L50 kW 1.2 / 1.2 1.2 / 1.2 110 - 240, 1~, 50/60 380 - 480, 3~, 50/60 110 - 240, 1~, 50/60 380 - 480, 3~, 50/60 Width (B) mm 400 400 Height (H) mm 950 950 Depth (T) mm 310 310 Rated power input kW 0.62 0.62 Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Rated operating voltage V, ~, Hz Power consumption Pel 50/60 Hz L35 L35 kW 0.54 / 0.54 0.54 / 0.54 Operating temperature range -20 °C...+60 °C -20 °C...+60 °C Setting range +20 °C...+50 °C +20 °C...+50 °C 3.1 / 3.1 3.1 / 3.1 Energy efficiency ratio (EER) 50/60 Hz L35 L35 Seasonal energy efficiency ratio (SEER) 50/60 Hz Refrigerant g Weight kg 6.4 6.4 R134a, 750 R134a, 750 36.3 37.1 Page 1 pc(s). 3124.300 3124.300 554 Door-operated switch 1 pc(s). 4127.010 4127.010 1024 Filter mat 3 pc(s). 3285.800 3285.800 533 Metal filter 1 pc(s). 3285.810 3285.810 534 Temperature sensor 1 pc(s). 3124.400 3124.400 549 Condensate hose 1 pc(s). 3301.612 3301.612 544 Eyebolts 4 pc(s). 4568.000 4568.000 964 RiDiag 1 pc(s). 3159.300 3159.300 559 Rittal – The System. IoT interface Rittal System Catalogue 36/Climate control IoT Interface see page 554 Further technical information available on the Internet. 487 Climate control Accessories Wall-mounted cooling units Blue e+ Accessories for climate control Page 533  Therm software Page 558  Blue e+ app Page 559  IoT interface Page 554   Temperature control: – e+ controller (factory setting +35 °C) Protection category IP to IEC 60 529: – Internal circuit IP 55 488 Supply includes: – Nano-coated condenser – Integral electric condensate evaporation – Assembly parts – Fully wired ready for connection (plug-in terminal strip) Optional: – For remote monitoring and networking of cooling units and chillers in the Blue e+ generation, please use the IoT interface (Model No. 3124.300). Increase machine availability and process reliability with remote monitoring of device data, statuses and system messages. Approvals: Available on the Internet Performance diagrams: Available on the Internet H Benefits: – Average 75% energy savings thanks to speed-regulated components and heat pipe technology – Suitable for international use due to a unique multi-voltage capability – Longer service life of the components inside the enclosure and the cooling unit due to component-friendly cooling – Intuitive operation due to touch display and intelligent interfaces B T Note: – Please observe the mounting instructions. – Firmware can be updated using the RiDiag III software (3159.300) Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Wall-mounted cooling units Blue e+ Output class 2000 – 2600 W Material Colour 3186.630 3186.930 3187.630 3187.930 Sheet steel Packs of – ◾ – ◾ Stainless steel 1.4301 (AISI 304) ◾ – ◾ – RAL 7035 – ◾ – ◾ RAL 9007 ◾ – ◾ – Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 2 2 2.6 2.6 2/2 2/2 2.6 / 2.6 2.6 / 2.6 1.29 / 1.29 1.29 / 1.29 1.82 / 1.82 1.82 / 1.82 Page 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 380 - 480, 3~, 50/60 380 - 480, 3~, 50/60 380 - 480, 3~, 50/60 380 - 480, 3~, 50/60 Rated operating voltage V, ~, Hz Width (B) mm 450 450 450 450 Height (H) mm 1600 1600 1600 1600 Depth (T) mm 294 294 294 294 Rated power input kW 0.73 0.73 1.05 1.05 Power consumption Pel 50/60 Hz L35 L35 kW 0.57 / 0.57 0.57 / 0.57 0.99 / 0.99 0.99 / 0.99 Operating temperature range -20 °C...+60 °C -20 °C...+60 °C -20 °C...+60 °C -20 °C...+60 °C Setting range +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C 3.5 / 3.5 3.5 / 3.5 2.63 / 2.63 2.63 / 2.63 8.1 8.1 6.2 6.2 R134a, 1150 R134a, 1150 R134a, 1150 R134a, 1150 Energy efficiency ratio (EER) 50/60 Hz L35 L35 Seasonal energy efficiency ratio (SEER) 50/60 Hz Refrigerant g Note on Model No. Weight kg – – – – 54.8 55.2 54.8 55.2 Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 554 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Filter mat 3 pc(s). 3285.900 3285.900 3285.900 3285.900 533 Metal filter 1 pc(s). 3285.910 3285.910 3285.910 3285.910 534 Temperature sensor 1 pc(s). 3124.400 3124.400 3124.400 3124.400 549 Condensate hose 1 pc(s). 3301.612 3301.612 3301.612 3301.612 544 Eyebolts 4 pc(s). 4568.000 4568.000 4568.000 4568.000 964 RiDiag 1 pc(s). 3159.300 3159.300 3159.300 3159.300 559 Packs of Page Output class 4200 – 5800 W Model No. Material Colour 3188.640 3188.940 3189.640 3189.940 Sheet steel – ◾ – ◾ Stainless steel 1.4301 (AISI 304) ◾ – ◾ – RAL 7035 – ◾ – ◾ RAL 9007 ◾ – ◾ – 4.2 4.2 5.8 5.8 Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW 4.2 / 4.2 4.2 / 4.2 5.8 / 5.8 5.8 / 5.8 Total cooling output 50/60 Hz L35 L50 kW 3.02 / 3.02 3.02 / 3.02 4.2 / 4.2 4.2 / 4.2 Rated operating voltage V, ~, Hz 380 - 480, 3~, 50/60 380 - 480, 3~, 50/60 380 - 480, 3~, 50/60 380 - 480, 3~, 50/60 Width (B) mm 450 450 450 450 Height (H) mm 1600 1600 1600 1600 Depth (T) mm 393 393 393 393 Rated power input kW 1.3 1.3 2.2 2.2 1.21 / 1.21 1.21 / 1.21 2.2 / 2.2 2.2 / 2.2 Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range -20 °C...+60 °C -20 °C...+60 °C -20 °C...+60 °C -20 °C...+60 °C Setting range +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C 3.46 / 3.46 3.46 / 3.46 2.64 / 2.64 2.64 / 2.64 8.1 8.1 6.2 6.2 R134a, 1750 R134a, 1750 R134a, 1750 R134a, 1750 Full installation not possible Full installation not possible Full installation not possible Full installation not possible 71.2 72.4 71.2 72.4 Energy efficiency ratio (EER) 50/60 Hz L35 L35 Seasonal energy efficiency ratio (SEER) 50/60 Hz Refrigerant g Note on Model No. Weight kg Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 554 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Filter mat 3 pc(s). 3285.900 3285.900 3285.900 3285.900 533 Metal filter 1 pc(s). 3285.910 3285.910 3285.910 3285.910 534 Temperature sensor 1 pc(s). 3124.400 3124.400 3124.400 3124.400 549 Condensate hose 1 pc(s). 3301.612 3301.612 3301.612 3301.612 544 Eyebolts 4 pc(s). 4568.000 4568.000 4568.000 4568.000 964 RiDiag 1 pc(s). 3159.300 3159.300 3159.300 3159.300 559 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 489 Climate control Model No. TopTherm wall-mounted cooling units Blue e, NEMA 4X Accessories for climate control Page 533  Therm software Page 558  RiDiag software Page 559   Energy-efficient Blue e wallmounted cooling units with e-Comfort controller integrated as standard, RiNano coating on the condenser and electrical condensate evaporation. Protection category NEMA 4X. Benefits: – May be linked to the IoT interface via the Blue e IoT adaptor Temperature control: – e-Comfort controller (factory setting +35 °C) Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 55 Supply includes: – Nano-coated condenser – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Assembly parts Please observe the productspecific scope of supply. Approvals: Available on the Internet Performance diagrams: Available on the Internet Protection category NEMA: – NEMA 4X Output class 500 – 1500 W Packs of Model No. 3303.504 3303.514 3304.504 3304.544 3305.504 3305.544 ◾ ◾ ◾ ◾ ◾ ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW 0.55 – 1.1 1.1 1.6 1.6 Total cooling output 50/60 Hz L35 L35 kW 0.55 / 0.66 0.66 1.1 / 1.25 1.1 / 1.26 1.6 / 1.76 1.6 / 1.61 Total cooling output 50/60 Hz L35 L50 kW 0.33 / 0.4 0.4 0.91 / 0.9 0.98 / 1.09 1.25 / 1.37 1.33 / 1.35 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 Material Stainless steel 1.4404 (AISI 316L) Rated operating voltage V, ~, Hz 230, 1~, 50/60 115, 1~, 60 Width mm 285 285 405 405 405 405 Height mm 620 620 1020 1020 1020 1020 Depth mm 298 298 358 358 358 358 Rated current max. A 2.6 / 2.6 5.7 3.9 / 4.3 2.2 / 2.1 5.5 / 5.8 2.5 / 2.8 Start-up current A 5.1 / 6.4 11.5 12 / 14 11.5 / 12.7 12 / 14 12.2 / 11.3 0.39 / 0.41 0.5 0.64 / 0.68 0.64 / 0.79 0.87 / 0.98 0.9 / 1.08 Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C Setting range +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g Weight kg 1.4 1.31 1.83 / 1.84 1.83 / 1.56 1.83 / 1.79 1.83 / 1.49 R134a, 170 R134a, 170 R134a, 325 R134a, 325 R134a, 500 R134a, 500 25.0 25.0 49.0 50.0 51.0 52.0 – – ◾ ◾ ◾ ◾ Page Product-specific scope of supply Integral electric condensate evaporation Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 4127.010 4127.010 1024 Master/slave cable 1 pc(s). 3124.100 3124.100 3124.100 3124.100 3124.100 3124.100 550 Air diverter 1 pc(s). – – 3213.310 3213.310 3213.310 3213.310 542 RiDiag 1 pc(s). 3159.100 3159.100 3159.100 3159.100 3159.100 3159.100 559 490 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm wall-mounted cooling units Blue e, NEMA 4X Output class 2000 – 2500 W 3328.544 3329.544 ◾ ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW 2.2 2.55 Total cooling output 50/60 Hz L35 L35 kW 2.2 / 2.55 2.55 / 2.75 Material Stainless steel 1.4404 (AISI 316L) Total cooling output 50/60 Hz L35 L50 kW 1.45 / 1.69 1.9 / 1.95 Rated operating voltage V, ~, Hz 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 Width mm 405 405 Height mm 1650 1650 Depth mm 388 388 Rated current max. A 2.8 / 3.3 3.3 / 3.4 Start-up current A 6.8 / 7.8 6.8 / 7.6 Power consumption Pel 50/60 Hz L35 L35 kW 0.92 / 1.15 1.19 / 1.39 Operating temperature range +10 °C...+50 °C +10 °C...+50 °C Setting range +20 °C...+50 °C +20 °C...+50 °C 2.4 / 2.22 2.11 / 1.97 R134a, 900 R134a, 900 81.0 84.0 ◾ ◾ Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g Weight kg Page Product-specific scope of supply Integral electric condensate evaporation Accessories 1 pc(s). 3124.300 3124.300 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 1024 Master/slave cable 1 pc(s). 3124.100 3124.100 550 Air diverter 1 pc(s). 3213.320 3213.320 542 RiDiag 1 pc(s). 3159.100 3159.100 559 Rittal – The System. IoT interface Rittal System Catalogue 36/Climate control 554 Therm software see page 558 Further technical information available on the Internet. 491 Climate control Packs of Model No. Wall-mounted cooling unit TopTherm Blue Wall-mounted cooling unite, UL Type 3R/4 TopTherm Blue e, UL Type 3R/4 For indoor and outdoor 492 Rittal System Catalogue 36/Climate control Suitable for outdoor siting ◾ Vandalism-protected (e-Comfort controller on the rear of the cooling unit) ◾ Outdoor paint finish in accordance with UL 1332 ◾ Temperature range: -20 °C to +50 °C (in compressor mode +10 °C to +50 °C) Optimum protection ◾ Protection category: UL Type 3R/4/12 and IP 56 ◾ The cooling units provide protection against damaging influences, e.g. water and external icing ◾ The RiNano coating prevents the accumulation of dirt deposits on the condenser, thereby extending maintenance intervals and ensuring a constant long-term cooling output Benefits of Blue e technology ◾ Energy savings of up to 45% Climate control ◾ Intelligent control with Comfort controller, icing protection and motor monitoring ◾ Eco-mode control: The evaporator coil fan cuts out as necessary, depending on the enclosure internal temperature ◾ Longer service life of components in the enclosure and cooling units, because efficient components such as fans and compressors run at their optimum operating point ◾ The integral electric condensate evaporation system means that condensate evaporates and dissipates to the ambient air via the external fan Worldwide use ◾ International approvals (cULus Listed, cULus FTTA, CE and EAC) ◾ Worldwide service and spare parts availability Intelligent networking ◾ In conjunction with the IoT interface and Blue e IoT adaptor, it is a simple matter to integrate the cooling units into Industry 4.0 environments ◾ Condition monitoring of up to 10 cooling units in a master/slave arrangement Rittal System Catalogue 36/Climate control 493 TopTherm wall-mounted cooling units Blue e, UL Type 3R/4 Accessories for climate control Page 533  Therm software Page 558  RiDiag software Page 559   Benefits: – Suitable for outdoor siting – Blue e technology – May be linked to the IoT interface via the Blue e IoT adaptor Temperature control: – e-Comfort controller (factory setting +35 °C) 494 Material: – Sheet steel Colour: – RAL 7035 Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 56 Protection category NEMA: – UL Type 3R – UL Type 4 – UL Type 12 Note: – Compressor cooling mode from +10 °C ambient temperature. Only the internal fan is active in the temperature range -20 °C to +10 °C. T2 Approvals: Available on the Internet H Energy-efficient Blue e wallmounted cooling units with integral e-Comfort controller, RiNano coating on the condenser and electric condensate evaporation as standard, protection category UL Type 3R/4, 12. T1 Performance diagrams: Available on the Internet B Supply includes: – Nano-coated condenser – Fully wired ready for connection (plug-in terminal strip) – Connection box – Drilling template – Assembly parts Please observe the productspecific scope of supply. Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm wall-mounted cooling units Blue e, UL Type 3R/4 Output class 500 – 2500 W Model No. Packs of 3303.508 3303.518 3304.508 3304.548 3305.548 3329.548 0.46 – 1.1 1.15 1.49 2.55 Total cooling output 50/60 Hz L35 L35 kW 0.46 / 0.55 0.55 1.1 / 1.26 1.15 / 1.3 1.49 / 1.7 2.55 / 2.75 Total cooling output 50/60 Hz L35 L50 kW 0.27 / 0.32 0.32 0.9 / 1.07 0.95 / 1.11 1.04 / 1.17 1.95 / 2.00 230, 1~, 50/60 115, 1~, 60 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 Width (B) mm 285 285 405 405 405 405 Height (H) mm 620 620 1020 1020 1020 1650 Depth (T1) mm 298 298 358 358 358 388 Installation depth of connection box (T2) mm 350 350 410 410 410 440 Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Rated operating voltage V, ~, Hz Rated current max. A 2.6 / 2.6 5.7 3.9 / 4.3 2.2 / 2.1 2.5 / 2.8 3.3 / 3.4 Start-up current A 5.1 / 6.4 11.5 12 / 14 11.5 / 12.7 12.2 / 11.3 6.8 / 7.6 0.35 / 0.42 0.42 0.62 / 0.68 0.75 / 0.78 0.65 / 0.82 1.19 / 1.39 Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range -20 °C...+50 °C -20 °C...+50 °C -20 °C...+50 °C -20 °C...+50 °C -20 °C...+50 °C -20 °C...+50 °C Setting range +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C +20 °C...+50 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g Weight kg 1.31 / 1.3 1.3 1.75 / 1.86 1.53 / 1.67 2.28 / 2.07 2.14 / 1.97 R134a, 170 R134a, 170 R134a, 325 R134a, 325 R134a, 500 R134a, 900 25.0 25.0 49.0 50.0 52.0 84.0 – – ◾ ◾ ◾ ◾ Page Integral electric condensate evaporation Accessories 1 pc(s). 3124.300 3124.300 3124.300 3124.300 3124.300 3124.300 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 3124.310 3124.310 555 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 4127.010 4127.010 1024 RiDiag 1 pc(s). 3159.100 3159.100 3159.100 3159.100 3159.100 3159.100 559 Master/slave cable 1 pc(s). 3124.100 3124.100 3124.100 3124.100 3124.100 3124.100 550 Air diverter 1 pc(s). – – 3213.310 3213.310 3213.310 3213.320 542 Eyebolts 4 pc(s). 4568.000 4568.000 4568.000 4568.000 4568.000 4568.000 964 Rittal – The System. IoT interface Rittal System Catalogue 36/Climate control 554 Machine approvals in North America under the new NEC 2017 www.rittal.com/downloads Further technical information available on the Internet. 495 Climate control Product-specific scope of supply Wall-mounted cooling unit Blue e+ outdoor Energy efficiency for the outdoor sector Suitable for outdoor siting ◾ Vandalism-protected enclosure (e+ controller on the rear of the cooling unit) Benefits of Blue e+ technology ◾ For universal mounting on outdoor enclosures ◾ Efficiency – Average 75% energy savings thanks to speed-controlled components and heat pipe technology ◾ Aluminium enclosure with outdoor spray finish to UL 1332 ◾ Versatility – Unique multi-voltage capability supports global use ◾ Temperature range: -30 °C to +60 °C ◾ Reliability – Componentfriendly cooling helps extend the service life of all components inside the enclosure and the cooling unit Optimum protection ◾ Protection category: UL type 3R/4/12 and IP 56 ◾ User-friendliness – Touch display and smart interfaces support intuitive operation ◾ The cooling units provide protection against damage e.g. from water and external icing Global use ◾ The RiNano coating prevents the accumulation of dirt deposits on the condenser, thereby extending maintenance intervals and ensuring a consistent cooling output for longer ◾ International approvals (cULus Listed, cULus FTTA, CE and EAC) ◾ Worldwide service and spare parts availability Intelligent networking In conjunction with the IoT interface, all Blue e+ cooling units can now be networked and digitalised ◾ Continuous monitoring of temperature levels ◾ Avoidance of downtime costs and consequential damage ◾ Automatic notification of any cooling unit malfunctions ◾ Asset management: Localisation and organisation of cooling units ◾ Remote access: Device parameters can be configured remotely 496 Rittal System Catalogue 36/Climate control Wall-mounted cooling unit Blue e+ outdoor Accessories for climate control Page 533  Toptec Page 270  RiDiag software Page 559   Material: – Aluminium AlMg3 Surface finish: – Powder-coated – UV-resistant pure polyester Colour: – RAL 7035 Protection category IP to IEC 60 529: – Internal circuit IP 56 Protection category NEMA: – UL Type 4/3R/12 Supply includes: – Nano-coated condenser – Integral electric condensate evaporation – Fully wired ready for connection (plug-in terminal strip) – Sealing frame for universal attachment to outdoor enclosures for external, partial internal and full internal mounting. – Assembly parts T B2 B1 Climate control Benefits: – Average 75% energy savings thanks to speed-regulated components and heat pipe technology – Longer service life of the components inside the enclosure and the cooling unit due to component-friendly cooling – Intuitive operation due to touch display and intelligent interfaces Temperature control: – e+ controller (factory setting +35 °C) H1 H2 The energy-efficient wall-mounted cooling unit Blue e+ Outdoor can be used worldwide, thanks to its multi-voltage capability, and is suitable for use with Toptec project solutions, for example. Approvals: Available on the Internet Performance diagrams: Available on the Internet Output class 1500 W Model No. Packs of Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW 3185.330 Page 1.5 Total cooling output 50/60 Hz L35 L35 kW 1.5 / 1.5 Total cooling output 50/60 Hz L35 L50 kW 1.2 / 1.2 110 - 240, 1~, 50/60 380 - 480, 3~, 50/60 Rated operating voltage V, ~, Hz Width (B1) mm 415 Height (H1) mm 990 Depth (T) mm 279 Enclosure dimensions including sealing frame and designer cover (B2 x H2 x T) mm 467 x 1042 x 279 Dimensions to fit enclosure type Toptec with height mm ≥ 1200 with width mm ≥ 600 Rated power input kW 0.62 Power consumption Pel 50/60 Hz L35 L35 kW 0.54 / 0.54 Operating temperature range -30 °C...+60 °C Setting range +20 °C...+50 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 3.1 / 3.1 Seasonal energy efficiency ratio (SEER) 50/60 Hz 6.4 Refrigerant g R134a, 750 Weight kg 37.1 Also required Enclosure heater see page 531 Thermostat 1 pc(s). 3110.000 547 Hygrostat 1 pc(s). 3118.000 547 Accessories IoT interface 1 pc(s). 3124.300 554 Door-operated switch 1 pc(s). 4127.010 1024 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 497 TopTherm roof-mounted cooling units Blue e Accessories for climate control Page 533  Therm software Page 558  RiDiag software Page 559  Air routing Page 540   Energy-efficient Blue e roofmounted cooling units with integral e-Comfort controller, RiNano coating on the condenser and electric condensate evaporation as standard. Benefits: – May be linked to the IoT interface via the Blue e IoT adaptor Temperature control: – e-Comfort controller (factory setting +35 °C) Supply includes: – Nano-coated condenser – Integral electric condensate evaporation – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Assembly parts Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 Note: – The roof-mounted cooling unit 3273.500 is also suitable for office applications, thanks to its low noise level. Approvals: Available on the Internet Performance diagrams: Available on the Internet Output class 500 W Model No. Packs of 3382.500 3382.510 3382.600 ◾ ◾ – ◾ Sheet steel Material Stainless steel 1.4301 (AISI 304) – – RAL 7035 ◾ ◾ – RAL 9007 – – ◾ 0.55 0.55 0.55 Total cooling output 50/60 Hz L35 L35 kW 0.55 / 0.62 0.55 / 0.62 0.55 / 0.62 Total cooling output 50/60 Hz L35 L50 kW 0.42 / 0.48 0.42 / 0.48 0.42 / 0.48 230, 1~, 50/60 115, 1~, 50/60 230, 1~, 50/60 Width mm 597 597 597 Height mm 417 417 417 Depth mm 380 380 380 2.3 / 2.6 4.7 / 5.4 2.3 / 2.6 Colour Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Rated operating voltage V, ~, Hz Rated current max. A Start-up current A Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range 9.1 / 8.8 18.2 / 15.9 9.1 / 8.8 0.27 / 0.31 0.27 / 0.31 0.27 / 0.31 +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C – – – +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Operating temperature (max.) 60 Hz Setting range Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.04 / 1.96 2.04 / 1.96 2.04 / 1.96 Refrigerant g R134a, 300 R134a, 300 R134a, 300 30.0 35.0 30.0 Weight kg Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 554 555 Filter mat 3 pc(s). 3286.500 3286.500 3286.500 533 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 1024 Metal filter 1 pc(s). 3286.510 3286.510 3286.510 534 Air duct system 1 pc(s). 3286.870 3286.870 3286.870 540 Shallow air duct system 1 pc(s). 3286.850 3286.850 3286.850 541 Air duct adaptor 1 pc(s). 3286.840 3286.840 3286.840 540 Stoppers 2 pc(s). 3286.780 3286.780 3286.780 542 498 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm roof-mounted cooling units Blue e Output class 750 W Model No. Material Colour 3359.500 3359.510 3359.540 3359.600 Sheet steel Packs of ◾ ◾ ◾ – Stainless steel 1.4301 (AISI 304) – – – ◾ RAL 7035 ◾ ◾ ◾ – RAL 9007 – – – ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 0.77 0.77 0.77 0.77 0.77 / 0.79 0.77 / 0.79 0.77 / 0.79 0.77 / 0.79 0.52 / 0.47 0.52 / 0.47 0.52 / 0.47 0.52 / 0.47 230, 1~, 50/60 115, 1~, 50/60 400, 2~, 50/60 230, 1~, 50/60 Width mm 597 597 597 597 Height mm 417 417 417 417 Depth mm 380 380 380 380 2.8 / 3.7 5.6 / 7.4 1.6 / 2.1 2.8 / 3.7 Rated operating voltage V, ~, Hz Rated current max. A Start-up current A Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range Operating temperature (max.) 60 Hz Setting range 9.2 / 9 18.4 / 18 5.4 / 5.2 9.2 / 9 0.33 / 0.42 0.33 / 0.43 0.33 / 0.43 0.33 / 0.42 +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C – – – – +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.28 / 1.85 2.28 / 1.82 2.28 / 1.82 2.28 / 1.85 Refrigerant g R134a, 400 R134a, 400 R134a, 400 R134a, 400 32.0 37.0 37.0 32.0 Weight kg Page IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 555 Filter mat 3 pc(s). 3286.500 3286.500 3286.500 3286.500 533 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Metal filter 1 pc(s). 3286.510 3286.510 3286.510 3286.510 534 Air duct system 1 pc(s). 3286.870 3286.870 3286.870 3286.870 540 Shallow air duct system 1 pc(s). 3286.850 3286.850 3286.850 3286.850 541 Air duct adaptor 1 pc(s). 3286.840 3286.840 3286.840 3286.840 540 Stoppers 2 pc(s). 3286.780 3286.780 3286.780 3286.780 542 Packs of Page Output class 1000 W Model No. Material Colour 3383.500 3383.510 3383.540 3383.600 Sheet steel ◾ ◾ ◾ – Stainless steel 1.4301 (AISI 304) – – – ◾ RAL 7035 ◾ ◾ ◾ – RAL 9007 – – – ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 1 1 1 1 1 / 1.09 1 / 1.09 1 / 1.09 1 / 1.09 0.71 / 0.81 0.71 / 0.81 0.71 / 0.81 0.71 / 0.81 230, 1~, 50/60 115, 1~, 50/60 400, 2~, 50/60 230, 1~, 50/60 Width mm 597 597 597 597 Height mm 417 417 417 417 Depth mm 475 475 475 475 2.9 / 3.9 6.2 / 8.4 1.7 / 2.2 2.9 / 3.9 Start-up current A 8.8 / 10.1 14.4 / 15.8 4.6 / 5.7 8.8 / 10.1 Power consumption Pel 50/60 Hz L35 L35 kW 0.38 / 0.47 0.38 / 0.45 0.38 / 0.45 0.38 / 0.47 +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C – – – – +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Rated operating voltage V, ~, Hz Rated current max. A Operating temperature range Operating temperature (max.) 60 Hz Setting range Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.58 / 2.28 2.58 / 2.28 2.58 / 2.28 2.58 / 2.28 Refrigerant g R134a, 650 R134a, 650 R134a, 650 R134a, 650 40.0 46.0 46.0 40.0 Weight kg Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 555 Filter mat 3 pc(s). 3286.500 3286.500 3286.500 3286.500 533 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Metal filter 1 pc(s). 3286.510 3286.510 3286.510 3286.510 534 Air duct system 1 pc(s). 3286.870 3286.870 3286.870 3286.870 540 Shallow air duct system 1 pc(s). 3286.850 3286.850 3286.850 3286.850 541 – – – – 540 2 pc(s). 3286.880 3286.880 3286.880 3286.880 542 Air duct adaptor Stoppers Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 499 Climate control Accessories TopTherm roof-mounted cooling units Blue e Output class 1100 – 1500 W Model No. Material Colour 3273.500 3384.500 3384.510 3384.540 3384.600 Sheet steel Packs of ◾ ◾ ◾ ◾ – Stainless steel 1.4301 (AISI 304) – – – – ◾ RAL 7035 ◾ ◾ ◾ ◾ – RAL 9007 – – – – ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 1.1 1.5 1.5 1.5 1.5 1.1 / 1.2 1.5 / 1.65 1.5 / 1.65 1.5 / 1.65 1.5 / 1.65 0.85 / 0.87 1.15 / 1.3 1.15 / 1.3 1.15 / 1.3 1.15 / 1.3 230, 1~, 50/60 230, 1~, 50/60 115, 1~, 50/60 400, 2~, 50/60 230, 1~, 50/60 Width mm 597 597 597 597 597 Height mm 417 417 417 417 417 Depth mm 475 475 475 475 475 5.2 / 5.4 4.2 / 4.9 8.7 / 10.1 2.5 / 2.9 4.2 / 4.9 Start-up current A 15.5 / 16.5 14.7 / 13.6 27.2 / 23.2 8.7 / 7.6 14.7 / 13.6 Power consumption Pel 50/60 Hz L35 L35 kW 0.51 / 0.53 0.67 / 0.77 0.67 / 0.76 0.67 / 0.76 0.67 / 0.77 Rated operating voltage V, ~, Hz Rated current max. A Operating temperature range Page +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C Operating temperature (max.) 60 Hz +50 °C Setting range – – – – +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.12 / 2.23 2.24 / 2.13 2.24 / 2.13 2.24 / 2.13 2.24 / 2.13 Refrigerant g R134a, 700 R134a, 700 R134a, 700 R134a, 700 R134a, 700 42.0 41.0 47.0 47.0 41.0 Weight kg Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 3124.300 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 3124.310 555 Filter mat 3 pc(s). 3286.500 3286.500 3286.500 3286.500 3286.500 533 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 4127.010 1024 Metal filter 1 pc(s). 3286.510 3286.510 3286.510 3286.510 3286.510 534 Air duct system 1 pc(s). 3286.870 3286.870 3286.870 3286.870 3286.870 540 Shallow air duct system 1 pc(s). 3286.850 3286.850 3286.850 3286.850 3286.850 541 – – – – – 540 2 pc(s). 3286.880 3286.880 3286.880 3286.880 3286.880 542 Packs of Page Air duct adaptor Stoppers 554 Output class 2000 W Model No. Material Colour 3385.500 3385.510 3385.540 3385.600 3385.640 Sheet steel ◾ ◾ ◾ – – Stainless steel 1.4301 (AISI 304) – – – ◾ ◾ RAL 7035 ◾ ◾ ◾ – – RAL 9007 – – – ◾ ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 2 2 2 2 2 2 / 2.14 2 / 2.14 2 / 2.14 2 / 2.14 2 / 2.14 1.41 / 1.51 1.41 / 1.51 1.41 / 1.51 1.41 / 1.51 1.41 / 1.51 230, 1~, 50/60 115, 1~, 50/60 400, 2~, 50/60 230, 1~, 50/60 400, 2~, 50/60 Width mm 597 597 597 597 597 Height mm 417 417 417 417 417 Depth mm 475 475 475 475 475 5.9 / 6.3 13.3 / 13.5 3.5 / 3.7 5.9 / 6.3 3.5 / 3.7 Start-up current A 19.7 / 17.9 42.2 / 31.1 11.7 / 11.7 19.7 / 17.9 11.7 / 11.7 Power consumption Pel 50/60 Hz L35 L35 kW 0.95 / 1.14 0.95 / 1.17 0.95 / 1.17 0.95 / 1.14 0.95 / 1.17 Rated operating voltage V, ~, Hz Rated current max. A Operating temperature range +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C Operating temperature (max.) 60 Hz – Setting range – – – – +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.09 / 1.88 2.09 / 1.88 2.09 / 1.88 2.09 / 1.88 2.09 / 1.88 Refrigerant g R134a, 900 R134a, 900 R134a, 900 R134a, 900 R134a, 900 42.0 48.0 48.0 42.0 48.0 Weight kg Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 3124.300 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 3124.310 555 Filter mat 3 pc(s). 3286.500 3286.500 3286.500 3286.500 3286.500 533 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 4127.010 1024 Metal filter 1 pc(s). 3286.510 3286.510 3286.510 3286.510 3286.510 534 Air duct system 1 pc(s). 3286.870 3286.870 3286.870 3286.870 3286.870 540 Shallow air duct system 1 pc(s). 3286.850 3286.850 3286.850 3286.850 3286.850 541 – – – – – 540 3286.880 3286.880 3286.880 3286.880 3286.880 542 Air duct adaptor Stoppers 500 2 pc(s). Further technical information available on the Internet. 554 Rittal System Catalogue 36/Climate control TopTherm roof-mounted cooling units Blue e Output class 3000 – 4000 W Material Colour 3386.540 3386.640 3387.540 3387.640 Sheet steel Packs of ◾ – ◾ – Stainless steel 1.4301 (AISI 304) – ◾ – ◾ RAL 7035 ◾ – ◾ – RAL 9007 – ◾ – ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW Total cooling output 50/60 Hz L35 L35 kW Total cooling output 50/60 Hz L35 L50 kW 3 3 3.8 3.8 3 / 3.3 3 / 3.3 3.8 / 4 3.8 / 4 2.2 / 2.5 2.2 / 2.5 3.05 / 3.3 3.05 / 3.3 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 Width mm 796 796 796 796 Height mm 470 470 470 470 Depth mm 580 580 580 580 3.4 / 3.4 3.4 / 3.4 3.9 / 3.9 3.9 / 3.9 Rated operating voltage V, ~, Hz Rated current max. A Start-up current A Power consumption Pel 50/60 Hz L35 L35 kW Operating temperature range Operating temperature (max.) 60 Hz Setting range Energy efficiency ratio (EER) 50/60 Hz L35 L35 Refrigerant g Weight kg 8/9 8/9 17 / 19 17 / 19 1.17 / 1.48 1.17 / 1.48 1.59 / 2.03 1.59 / 2.03 +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C – – – – +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C 2.56 / 2.23 2.56 / 2.23 2.38 / 1.97 2.38 / 1.97 R134a, 1600 R134a, 1600 R134a, 1800 R134a, 1800 70.0 70.0 77.0 77.0 Page Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 555 Filter mat 3 pc(s). 3286.600 3286.600 3286.600 3286.600 533 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Metal filter 1 pc(s). 3286.610 3286.610 3286.610 3286.610 534 Air duct system 1 pc(s). 3286.970 3286.970 3286.970 3286.970 540 – – – – 541 Shallow air duct system Air duct adaptor Rittal – The System. Stoppers Rittal System Catalogue 36/Climate control 2 pc(s). – – – – 540 3286.980 3286.980 3286.980 3286.980 542 Blue e IoT adaptor see page 555 Further technical information available on the Internet. 501 Climate control Model No. VX25 BlueBlue e+ integration solution/Blue e+ roof-mounted VX25 e+ integration solution/ cooling units Blue e+ roof-mounted cooling units With revolutionary efficiency 502 Rittal System Catalogue 36/Climate control Time and cost savings ◾ Plug and play: Cooling unit, door limit switches and cabling are pre-installed and ready to connect ◾ The cooling unit pulls forwards easily for maintenance purposes Comfort Climate control ◾ Intuitive operation with touch display Optimum data quality ◾ All cooling solutions are available in duplicate – real and digital. Thanks to the digital twin, planning, ordering, machining and much more can be carried out by the person who knows your company the best: You. Efficiency ◾ High level of energy efficiency, also when used as an autonomous roof-mounted cooling unit Ready for Industry 4.0 ◾ Digitalisation and networking offer huge opportunities for every company. With the IoT interface (optional), Rittal cooling solutions are easily connected to Industry 4.0 environments. Rittal System Catalogue 36/Climate control 503 Blue e+ roof-mounted cooling unit Accessories for climate control Page 533  Therm software Page 558  RiDiag software Page 559  IoT interface Page 554   Benefits: – Average 75% energy savings thanks to speed-regulated components and heat pipe technology – Suitable for international use due to a unique multi-voltage capability – Longer service life of the components inside the enclosure and the cooling unit due to component-friendly cooling – Intuitive operation due to touch display and intelligent interfaces Temperature control: – e+ controller (factory setting +35 °C) Protection category IP to IEC 60 529: – External circuit IP 54 with pleated filter – Internal circuit IP 54 with pleated filter Supply includes: – Blue e+ roof-mounted cooling unit – Pleated filter – Fully wired ready for connection – Assembly parts – Condensate hose (3 m) Optional: – For remote monitoring and networking of cooling units and chillers in the Blue e+ generation, please use the IoT interface (Model No. 3124.300). Increase machine availability and process reliability with remote monitoring of device data, statuses and system messages. Note: – Only suitable for mounting on enclosures with minimum dimensions (W x D) 800 x 600 mm – Operation without a pleated filter is inadmissible – Firmware can be updated using the RiDiag III software (3159.300) Approvals: Available on the Internet Performance diagrams: Available on the Internet Output class 1300 W Model No. Packs of Material Sheet steel Colour RAL 7035 3185.730 Page ◾ ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW 1.3 Total cooling output 50/60 Hz L35 L35 kW 1.3 / 1.3 Total cooling output 50/60 Hz L35 L50 kW 0.76 / 0.76 110 - 240, 1~, 50/60 380 - 480, 3~, 50/60 Rated operating voltage V, ~, Hz Width mm 700 Height mm 308 Depth mm 560 Rated power input kW 0.75 Power consumption Pel 50/60 Hz L35 L35 kW 0.67 / 0.67 Operating temperature range -20 °C...+55 °C Setting range +20 °C...+50 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.04 / 2.04 Seasonal energy efficiency ratio (SEER) 50/60 Hz 5.3 Refrigerant g R134a, 590 Weight kg 38.0 Accessories IoT interface 1 pc(s). 3124.300 554 Door-operated switch 1 pc(s). 4127.010 1024 Pleated filter 3 pc(s). 3285.700 536 Temperature sensor 1 pc(s). 3124.400 549 Display frame 1 pc(s). 3355.700 557 Electrical condensate evaporation 1 pc(s). 3355.720 543 RiDiag 1 pc(s). 3159.300 559 504 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control VX25 Blue e+ integration solution Benefits: – The perfect symbiosis of the VX25 baying enclosure system and Blue e+ cooling unit – The cooling unit is easily pulled out forwards for maintenance purposes – No assembly work required – the cooling unit, door-operated switch and connection cabling are installed ready-to-connect – Cooling unit offers all the benefits of Blue e+ Technology Protection category IP to IEC 60 529: – External circuit IP 54 with pleated filter – Internal circuit IP 54 with pleated filter Supply includes: – Basic enclosure VX25, door, roof, rear panel, side panels, gland plates, mounting plate – Lock: 3 mm double-bit – Integral door-operated switch – Integral Blue e+ cooling unit – Electric condensate evaporator – Pleated filter – Condensate hose (3 m) Temperature control: – e+ controller (factory setting +35 °C) Optional: – For remote monitoring and networking of cooling units and chillers in the Blue e+ generation, please use the IoT interface (Model No. 3124.300). Increase machine availability and process reliability with remote monitoring of device data, statuses and system messages. Note: – Operation without a pleated filter is inadmissible – Firmware can be updated using the RiDiag III software (3159.300) Approvals: Available on the Internet Performance diagrams: Available on the Internet Output class 1300 W Model No. Packs of Material Sheet steel Colour RAL 7035 3185.030 Page ◾ ◾ Total cooling output 50 Hz L35 L35 to DIN EN 14511 kW 1.3 Total cooling output 50/60 Hz L35 L35 kW 1.3 / 1.3 Total cooling output 50/60 Hz L35 L50 kW 0.76 / 0.76 110 - 240, 1~, 50/60 380 - 480, 3~, 50/60 Rated operating voltage V, ~, Hz Width mm 800 Height mm 2200 Depth mm 600 Mounting plate width mm 699 Mounting plate height mm 1696 Rated power input kW 0.75 Power consumption Pel 50/60 Hz L35 L35 kW 0.67 / 0.67 Operating temperature range -20 °C...+55 °C Setting range +20 °C...+50 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 2.04 / 2.04 Seasonal energy efficiency ratio (SEER) 50/60 Hz 5.3 Refrigerant g R134a, 590 Weight kg 180.0 Accessories IoT interface 1 pc(s). 3124.300 Pleated filter 3 pc(s). 3285.700 536 Temperature sensor 1 pc(s). 3124.400 549 Display frame 1 pc(s). 3355.700 557 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 554 505 Climate control Accessories for climate control Page 533  RiDiag software Page 559  Blue e+ roof-mounted cooling unit Page 504  IoT interface Page 554   Modular climate control concept – cooling module Blue e Accessories for climate control Page 533  VX25 enclosures Page 116  Therm software Page 558  RiDiag software Page 559   Note: – A base/plinth with a height of 100 or 200 mm is required for efficient operation All cooling modules may be individually combined with any climate control door. The cooling modules are equipped with energyefficient Blue e technology, with integral e-Comfort controller, RiNano coating on the condenser and electric condensate evaporation as standard. Material: – Sheet steel Benefits: – May be linked to the IoT interface via the Blue e IoT adaptor Supply includes: – Cooling module prepared for installation in climate control door – Nano-coated condenser – Integral electric condensate evaporation – Fully wired ready for connection (plug-in terminal strip) Temperature control: – e-Comfort controller (factory setting +35 °C) Colour: – RAL 7035 Approvals: Available on the Internet Protection category IP to IEC 60 529: – External circuit IP 34 – Internal circuit IP 54 Performance diagrams: Available on the Internet Output class 1500 – 2500 W Model No. Packs of 3307.700 3307.740 3310.700 3310.740 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 230, 1~, 50/60 400, 3~, 50 460, 3~, 60 Total cooling output 50/60 Hz L35 L35 kW 1.5 / 1.55 1.5 / 1.55 2.5 / 2.52 2.5 / 2.5 Total cooling output 50/60 Hz L35 L50 kW 0.85 / 0.9 0.93 / 0.95 1.62 / 1.76 1.76 / 1.8 Rated current max. A 6 / 6.1 2.5 / 2.7 7.6 / 9.4 3.5 / 3.7 Start-up current A 22 / 24 8.5 / 9.2 22 / 24 13 / 14 0.85 / 1.05 0.79 / 1 1.31 / 1.52 1.13 / 1.48 Operating temperature range +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C +10 °C...+55 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Energy efficiency ratio (EER) 50/60 Hz L35 L35 1.76 / 1.48 1.9 / 1.55 1.91 / 1.66 2.21 / 1.69 Refrigerant g R134a, 700 R134a, 700 R134a, 1175 R134a, 1175 68.0 68.0 73.0 72.0 see page see page see page see page Rated operating voltage V, ~, Hz Power consumption Pel 50/60 Hz L35 L35 kW Weight kg Page Also required Modular climate control concept – climate control door VX25 507 Accessories IoT interface 1 pc(s). 3124.300 3124.300 3124.300 3124.300 554 Blue e IoT adaptor 1 pc(s). 3124.310 3124.310 3124.310 3124.310 555 Master/slave cable 1 pc(s). 3124.100 3124.100 3124.100 3124.100 550 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 506 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Modular climate control concept – climate control door VX25 Accessories for climate control Page 533  VX25 enclosures Page 116  Therm software Page 558   Note: – To fit VX enclosures – For 1200 mm wide VX enclosures, the existing hinged door may be used, irrespective of the device position (left or right) Material: – Sheet steel Colour: – RAL 7035 Supply includes: – Climate control door without preconfigured cooling module – 180° hinges, door opening angle approx. 130° Approvals: Available on the Internet Climate control Sheet steel climate control doors for the installation of climate control module types SK 3307.7XX to 3310.7XX. The climate control doors fit perfectly with the overall design of the enclosure. B Model No. Packs of H H H for installing cooling modules B B 3201.800 3201.810 3201.820 3201.830 3201.840 3201.850 VX VX VX VX VX VX with height mm 1800 2000 1800 2000 1800 2000 with width mm 600 1200 600 1200 800 800 600 1200 600 1200 – – – – ◾ ◾ Dimensions to fit enclosure type Unit positioned on the left Note on Model No. Page R/h door hinge R/h door hinge R/h door hinge R/h door hinge L/h door hinge L/h door hinge Weight kg 19.0 20.0 27.0 31.0 19.0 22.0 see page see page see page see page see page see page Also required Modular climate control concept cooling module Blue e 506 Accessories Metal filter 1 pc(s). 3284.210 3284.210 3284.210 3284.210 3284.210 3284.210 534 Comfort handle VX 1 pc(s). 8618.250 8618.250 8618.250 8618.250 8618.250 8618.250 937 Ride-up roller 10 pc(s). – 8618.420 – 8618.420 – 8618.420 956 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 507 508 Rittal System Catalogue 36/Climate control Liquid cooling Air/water heat exchangers Wall-mounted .......................................................... 300 – 600 W ..............510 Wall-mounted ........................................................ 950 – 1250 W ..............511 Wall-mounted ...................................................... 2000 – 2800 W ..............512 Wall-mounted ..................................................................3000 W ..............512 Wall-mounted ...................................................... 4500 – 5000 W ..............513 Wall-mounted ..................................................................7000 W ..............514 Wall-mounted HD .................................................. 600 – 1200 W ..............515 Roof-mounted ..................................................... 1875 – 3000 W ..............516 Roof-mounted .................................................................4000 W ..............517 Liquid Cooling Package LCP Rack Industry.........................................................10000 W ..............518 Chillers TopTherm, roof-mounted .................................... 1000 – 1500 W ..............519 Product advantages ...................................................................................520 Blue e+................................................................ 2500 – 5500 W ..............522 Product advantages ...................................................................................524 Blue e .............................................................. 11000 – 15000 W ..............526 Blue e .............................................................. 20000 – 25000 W ..............527 Climate control VX25 TopTherm ................................................ 8000 – 12000 W ..............528 VX25 TopTherm .............................................. 16000 – 25000 W ..............529 The DGUV test certificate applies to HD air/water heat exchangers. Rittal System Catalogue 36/Climate control 509 Air/water heat exchangers Accessories for climate control Page 533  Chillers Page 519  Therm software Page 558   For use in harsh environments and temperature ranges up to +70 °C. User-friendly assembly plus flexible water connection options. External mounting or full internal mounting are supported. Supply includes: – Fully wired ready for connection – Drilling template – Sealing and assembly parts Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Cooling medium: – Water (see Internet for specifications) Approvals: Available on the Internet Performance diagrams: Available on the Internet Note: – Integral non-return valve for version with e-Comfort controller Output class 300 – 600 W, wall-mounted Model No. 3212.024 3212.230 3363.100 3363.500 3214.100 Water-carrying parts, copper/brass (Cu/CuZn) ◾ ◾ ◾ ◾ ◾ Basic controller (factory setting +35 °C) – – ◾ – – e-Comfort controller (factory setting +35 °C) – – – ◾ – Thermostat-controlled magnetic valve – – – – ◾ Total cooling output L35 W10, 200 l/h kW 0.3 0.3 – – 0.6 Total cooling output L35 W10, 400 l/h kW – – 0.5 0.5 0.7 Power consumption Pel 50/60 Hz W – 23 / 27 37 / 38 37 / 38 36 / 37 Design Temperature control Packs of Power consumption Pel W 26 – – – – Rated operating voltage V 24 (DC) 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 Width mm 150 150 280 280 200 Height mm 300 300 550 550 500 Depth mm 85 85 120 120 100 Rated current max. A 1.2 0.11 / 0.13 0.18 / 0.18 0.18 / 0.18 0.17 / 0.18 +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C – – Operating temperature range Setting range Water inlet temperature +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C ½" connector sleeve – – ◾ ◾ ◾ G ⅜" external thread – – ◾ ◾ – ⅜" connector sleeve ◾ ◾ – – – 1 - 10 1 - 10 1 - 10 1 - 10 1 - 10 Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h – 280 / 310 290 / 345 290 / 345 280 / 310 Air throughput of fans (unimpeded air flow), Internal circuit with DC m³/h 250 – – – – Weight as delivered kg 3.2 3.2 8.0 8.0 7.0 Water connection Permissible operating pressure (p) bar Page Accessories Condensate hose 1 pc(s). 3301.610 3301.610 3301.612 3301.612 3301.612 544 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 4127.010 1024 Toroidal transformer – see page see page see page see page 550 Flow regulator valve see page see page see page see page see page 545 510 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Air/water heat exchangers Output class 950 – 1250 W, wall-mounted 3364.504 3364.100 3364.500 3215.100 Water-carrying parts, copper/brass (Cu/CuZn) – ◾ ◾ ◾ Water-carrying parts, stainless steel (1.4571) ◾ – – – Basic controller (factory setting +35 °C) – ◾ – – e-Comfort controller (factory setting +35 °C) ◾ – ◾ – Thermostat-controlled magnetic valve – – – ◾ Total cooling output L35 W10, 200 l/h kW – – – 1.25 Total cooling output L35 W10, 400 l/h kW 0.95 1 1 1.3 37 / 38 37 / 38 37 / 38 83 / 85 Design Temperature control Packs of Power consumption Pel 50/60 Hz W Power consumption Pel – – – – 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 Width mm 280 280 280 200 Height mm 550 550 550 950 Depth mm 120 120 120 100 0.18 / 0.18 0.18 / 0.18 0.18 / 0.18 0.38 / 0.4 Rated operating voltage V, ~, Hz Rated current max. A Operating temperature range +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Water inlet temperature +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C ½" connector sleeve ◾ ◾ ◾ ◾ G ⅜" external thread ◾ ◾ ◾ – 1 - 10 1 - 10 1 - 10 1 - 10 Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h 290 / 345 290 / 345 290 / 345 680 / 735 Air throughput of fans (unimpeded air flow), Internal circuit with DC – – – – 9.0 9.0 9.0 13.0 Water connection Permissible operating pressure (p) bar Weight as delivered kg Page Climate control Model No. Accessories 1 pc(s). 3301.612 3301.612 3301.612 3301.612 544 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Toroidal transformer see page see page see page see page 550 Flow regulator valve see page see page see page see page 545 Rittal – The System. Condensate hose Rittal System Catalogue 36/Climate control Connection set see page 545 Further technical information available on the Internet. 511 Air/water heat exchangers Output class 2000 – 2800 W, wall-mounted Model No. Design Temperature control 3373.100 3373.140 3373.500 3374.504 Water-carrying parts, copper/brass (Cu/CuZn) Packs of ◾ ◾ ◾ – Water-carrying parts, stainless steel (1.4571) – – – ◾ Basic controller (factory setting +35 °C) ◾ ◾ – – e-Comfort controller (factory setting +35 °C) ◾ – – ◾ Total cooling output L35 W10, 200 l/h – – – – Total cooling output L35 W10, 400 l/h kW 2 2 2 2.8 110 / 140 110 / 140 110 / 140 169 / 232 – – – – 230, 1~, 50/60 400, 2~, 50/60 230, 1~, 50/60 230, 1~, 50/60 Width mm 400 400 400 400 Height mm 950 950 950 950 Depth mm 145 145 145 145 0.49 / 0.61 0.28 / 0.35 0.49 / 0.61 0.76 / 1.01 Power consumption Pel 50/60 Hz W Power consumption Pel Rated operating voltage V, ~, Hz Rated current max. A Operating temperature range +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Water inlet temperature +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C ½" connector sleeve ◾ ◾ ◾ ◾ G ⅜" external thread ◾ ◾ ◾ ◾ 1 - 10 1 - 10 1 - 10 1 - 10 Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h 880 / 950 880 / 950 880 / 950 1150 / 1300 Air throughput of fans (unimpeded air flow), Internal circuit with DC – – – – 20.0 23.0 20.0 23.0 Water connection Permissible operating pressure (p) bar Weight as delivered kg Page Accessories Condensate hose 1 pc(s). 3301.612 3301.612 3301.612 3301.612 544 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Toroidal transformer – – – – 550 Flow regulator valve see page see page see page see page 545 Page Output class 3000 W, wall-mounted Model No. Design Temperature control 3374.100 3374.140 3374.500 3374.540 Water-carrying parts, copper/brass (Cu/CuZn) Packs of ◾ ◾ ◾ ◾ Basic controller (factory setting +35 °C) ◾ ◾ – – e-Comfort controller (factory setting +35 °C) – – ◾ ◾ Total cooling output L35 W10, 200 l/h – – – – Total cooling output L35 W10, 400 l/h kW 3 3 3 3 169 / 232 169 / 232 169 / 232 169 / 232 Power consumption Pel 50/60 Hz W Power consumption Pel – – – – 230, 1~, 50/60 400, 2~, 50/60 230, 1~, 50/60 400, 2~, 50/60 Width mm 400 400 400 400 Height mm 950 950 950 950 Depth mm 145 145 145 145 0.76 / 1.01 0.44 / 0.58 0.76 / 1.01 0.44 / 0.58 Rated operating voltage V, ~, Hz Rated current max. A Operating temperature range +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Water inlet temperature +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C ½" connector sleeve ◾ ◾ ◾ ◾ G ⅜" external thread ◾ ◾ ◾ ◾ 1 - 10 1 - 10 1 - 10 1 - 10 Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h 1150 / 1300 1150 / 1300 1150 / 1300 1150 / 1300 Air throughput of fans (unimpeded air flow), Internal circuit with DC – – – – 23.0 26.0 23.0 26.0 Water connection Permissible operating pressure (p) bar Weight as delivered kg Accessories Condensate hose 1 pc(s). 3301.612 3301.612 3301.612 3301.612 544 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 Toroidal transformer – – – – 550 Flow regulator valve see page see page see page see page 545 512 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Air/water heat exchangers Output class 4500 – 5000 W, wall-mounted Design Temperature control 3375.504 3375.100 3375.500 3375.540 Water carrying parts copper/brass (Cu/CuZn) Packs of – ◾ ◾ ◾ Water-carrying parts, stainless steel (1.4571) ◾ – – – Basic controller (factory setting +35 °C) – ◾ – – e-Comfort controller (factory setting +35 °C) ◾ – ◾ ◾ – – – – 4.5 5 5 5 172 / 172 172 / 172 172 / 172 183 / 183 Total cooling output L35 W10, 200 l/h Total cooling output L35 W10, 400 l/h kW Power consumption Pel 50/60 Hz W Power consumption Pel Rated operating voltage V, ~, Hz – – – – 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 400, 2~, 50/60 Width mm 450 450 450 450 Height mm 1400 1400 1400 1400 Depth mm Rated current max. A 220 220 220 220 1.45 / 1.45 1.45 / 1.45 1.45 / 1.45 0.8 / 0.8 Operating temperature range +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Water inlet temperature +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C ½" connector sleeve ◾ ◾ ◾ ◾ G ⅜" external thread ◾ ◾ ◾ ◾ 1 - 10 1 - 10 1 - 10 1 - 10 Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h 1500 / 1500 1500 / 1500 1500 / 1500 1500 / 1500 Air throughput of fans (unimpeded air flow), Internal circuit with DC – – – – 39.0 39.0 39.0 42.0 Water connection Permissible operating pressure (p) bar Weight as delivered kg Page Accessories Condensate hose 1 pc(s). 3301.612 3301.612 3301.612 3301.612 544 Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 1024 – – – – 550 Flow regulator valve see page see page see page see page 545 Rittal – The System. Toroidal transformer Rittal System Catalogue 36/Climate control Chillers Blue e+ see page 522 Further technical information available on the Internet. 513 Climate control Model No. Air/water heat exchangers Accessories for climate control Page 533  Chillers Page 519  Therm software Page 558   For use in harsh environments and temperature ranges up to +70 °C. With thermostatically controlled magnetic valve. Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Cooling medium: – Water (see Internet for specifications) Supply includes: – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Sealing and assembly parts Note: – Use 3-pole miniature circuitbreaker Approvals: Available on the Internet Performance diagrams: Available on the Internet Output class 7000 W, wall-mounted Model No. Temperature control Packs of Thermostat-controlled magnetic valve 3216.480 ◾ Total cooling output L35 W10, 500 l/h kW 7 Total cooling output L35 W20, 500 l/h kW 4.5 400, 3~, 50/60 480, 3~, 60 Rated operating voltage V, ~, Hz Width mm 450 Height mm 1800 Depth mm 300 Rated current max. A 1.4 / 1.6 Operating temperature range +1 °C...+70 °C Setting range +20 °C...+55 °C Water inlet temperature Water connection Page +1 °C...+30 °C ½" connector sleeve ◾ G ⅜" external thread ◾ Permissible operating pressure (p) bar 1 - 10 Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h 4075 / 4840 Weight as delivered kg 79.0 Accessories Door-operated switch 1 pc(s). 4127.010 1024 Condensate hose 1 pc(s). 3301.612 544 see page 545 Flow regulator valve Connection set 1 pc(s). Cooling medium (ready-mixed) 514 Further technical information available on the Internet. 3201.990 545 see page 545 Rittal System Catalogue 36/Climate control Air/water heat exchangers Air/water heat exchanger for hygienically sensitive production zones in the food and consumables industry – the optimum addition to the Rittal Hygienic Design range. The cleaning-friendly design reduces the risk of contamination and ensures food safety. Benefits: – Easy-to-clean, hygienic design – A roof tilt of 30° prevents objects from being deposited on it, and allows liquids to run off quickly – All-round external, replaceable silicone seal prevents the accumulation of dirt between the enclosure and the air/water heat exchanger Material: – Enclosure: Stainless steel 1.4301 (AISI 304) Surface finish: – Enclosure: Brushed, grain 400, peak-to-valley height < 0.8 μm Protection category IP to IEC 60 529: – IP 56/59 Protection category NEMA: – NEMA 4X Cooling medium: – Water (see Internet for specifications) Supply includes: – Fully wired ready for connection – Drilling template – Sealing and assembly parts Note: – To achieve a protection category of IP 66/69 to IEC 60 529, the ingress of leakage air through the condensate discharge opening must be completely prevented Approvals: Available on the Internet Performance diagrams: Available on the Internet Output class 600 – 1200 W, wall-mounted HD Model No. Temperature control Packs of Thermostat-controlled magnetic valve 3214.700 3215.700 ◾ ◾ Total cooling output L35 W10, 200 l/h kW 0.6 1 Total cooling output L35 W10, 400 l/h kW 0.65 1.2 Power consumption Pel 50/60 Hz W 33 / 34 77 / 104 230, 1~, 50/60 230, 1~, 50/60 Width mm 220 215 Height mm 526 982 Depth mm 100 100 0.16 / 0.14 0.38 / 0.47 Rated operating voltage V, ~, Hz Rated current max. A Operating temperature range +1 °C...+70 °C +1 °C...+70 °C Setting range +20 °C...+60 °C +20 °C...+60 °C +1 °C...+30 °C +1 °C...+30 °C Water inlet temperature Water connection G ⅜" external thread Page ◾ ◾ 1 - 10 1 - 10 280 / 310 680 / 735 6.0 14.0 Toroidal transformer see page see page 550 Cooling medium (ready-mixed) see page see page 545 Permissible operating pressure (p) bar Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h Weight as delivered kg Accessories Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 515 Climate control Accessories for climate control Page 533  Chillers Page 519  Therm software Page 558  Hygienic Design HD Page 217   Air/water heat exchangers Accessories for climate control Page 533  Chillers Page 519  Air routing Page 540   For use in harsh environments and temperature ranges up to +70 °C. The air/water heat exchanger is assembled on the roof of the enclosure using flexible water connection options. Supply includes: – Fully wired ready for connection (plug-in terminal strip) – Drilling template – Sealing mat – Assembly parts Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Approvals: Available on the Internet Performance diagrams: Available on the Internet Cooling medium: – Water (see Internet for specifications) Output class 1875 – 3000 W, roof-mounted Model No. Design Temperature control 3209.504 3209.100 3209.500 3210.504 Water-carrying parts, copper/brass (Cu/CuZn) Packs of – ◾ ◾ – Water-carrying parts, stainless steel (1.4571) ◾ – – ◾ Basic controller (factory setting +35 °C) – ◾ – – e-Comfort controller (factory setting +35 °C) ◾ – ◾ ◾ Total cooling output L35 W10, 400 l/h kW Power consumption Pel 50/60 Hz W Rated operating voltage V, ~, Hz 1.87 2.5 2.5 3 95 / 110 95 / 110 95 / 110 100 / 120 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 230, 1~, 50/60 Width mm 597 597 597 597 Height mm 417 417 417 417 Depth mm 475 475 475 475 0.4 / 0.48 0.4 / 0.48 0.4 / 0.48 0.44 / 0.5 Rated current max. A Operating temperature range +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Water inlet temperature Water connection +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C ½" connector sleeve ◾ ◾ ◾ ◾ G ⅜" external thread ◾ ◾ ◾ ◾ 1 - 10 1 - 10 1 - 10 1 - 10 925 / 1030 925 / 1030 925 / 1030 815 / 925 23.5 23.5 23.5 25.5 Permissible operating pressure (p) bar Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h Weight as delivered kg Page Accessories Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 4127.010 Master/slave cable 1 pc(s). 3124.100 – 3124.100 3124.100 1024 550 Air duct system 1 pc(s). 3286.870 3286.870 3286.870 3286.870 540 Stoppers 2 pc(s). 3286.880 3286.880 3286.880 3286.880 542 Condensate hose 1 pc(s). 3301.612 3301.612 3301.612 3301.612 544 see page see page see page see page 545 Cooling medium (ready-mixed) 516 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Air/water heat exchangers Output class 4000 W, roof-mounted Model No. Design Temperature control 3210.100 3210.500 3210.540 Water-carrying parts, copper/brass (Cu/CuZn) Packs of ◾ ◾ ◾ Basic controller (factory setting +35 °C) ◾ – – e-Comfort controller (factory setting +35 °C) – ◾ ◾ Total cooling output L35 W10, 400 l/h kW Power consumption Pel 50/60 Hz W Rated operating voltage V, ~, Hz 4 4 4 100 / 120 100 / 120 102 / 125 230, 1~, 50/60 230, 1~, 50/60 400, 2~, 50/60 Width mm 597 597 597 Height mm 417 417 417 Depth mm 475 475 475 0.44 / 0.5 0.44 / 0.5 0.25 / 0.3 Rated current max. A Operating temperature range +1 °C...+70 °C +1 °C...+70 °C +1 °C...+70 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +20 °C...+55 °C Water inlet temperature Water connection +1 °C...+30 °C +1 °C...+30 °C +1 °C...+30 °C ½" connector sleeve ◾ ◾ ◾ G ⅜" external thread ◾ ◾ ◾ 1 - 10 1 - 10 1 - 10 815 / 925 815 / 925 815 / 925 25.5 25.5 29.5 Permissible operating pressure (p) bar Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h Weight as delivered kg Page Door-operated switch 1 pc(s). 4127.010 4127.010 4127.010 Master/slave cable 1 pc(s). – 3124.100 3124.100 1024 550 Air duct system 1 pc(s). 3286.870 3286.870 3286.870 540 Stoppers 2 pc(s). 3286.880 3286.880 3286.880 542 Condensate hose 1 pc(s). 3301.612 3301.612 3301.612 544 see page see page see page 545 Rittal – The System. Cooling medium (ready-mixed) Rittal System Catalogue 36/Climate control VX25 TopTherm chillers see page 528 Further technical information available on the Internet. 517 Climate control Accessories Liquid Cooling Package Accessories for climate control Page 533  Chillers Page 519  Therm software Page 558   Air/water heat exchanger in the bayed enclosure system VX25. To fit 600 or 800 mm deep and 2,000 mm high VX25 enclosures. Air outlet either with 5 kW on each side or 10 kW on one side only. Flexible options for water connection on the top or bottom of the unit. Temperature control: – e-Comfort controller (factory setting +35 °C) Cooling medium: – Water (see Internet for specifications) Note: – Bayable by screw-fastening at the sides Colour: – RAL 7035 Supply includes: – Cooling unit ready for connection, wired to terminal strip – Front door with display – Rear panel – Multilingual documentation Approvals: Available on the Internet Protection category IP to IEC 60 529: – IP 55 Performance diagrams: Available on the Internet Output class 10000 W, LCP rack industry Model No. Design Packs of Water-carrying parts, copper/brass (Cu/CuZn) Total cooling output L35 W10, 2000 l/h kW Power consumption Pel 50/60 Hz W Rated operating voltage V, ~, Hz 3378.300 3378.380 ◾ ◾ 9.5 9.5 350 / 350 350 / 350 230, 1~, 50/60 230, 1~, 50/60 Width mm 300 300 Height mm 2000 2000 Depth mm Rated current max. A 600 800 2.65 / 2.62 2.65 / 2.62 Operating temperature range +5 °C...+70 °C +5 °C...+70 °C Setting range +20 °C...+55 °C +20 °C...+55 °C +7 °C...+30 °C +7 °C...+30 °C Water inlet temperature Water connection G ¾" internal thread Permissible operating pressure (p) bar Air throughput of fans (unimpeded air flow), Internal circuit 50/60 Hz m³/h Weight as delivered kg ◾ ◾ 1-6 1-6 1950 / 1950 1950 / 1950 106.0 115.0 Page Accessories Base/plinth corner piece with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.000 8640.000 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.034 882 881 Base/plinth corner piece with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.020 8640.020 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.044 882 Baying connector, external 6 pc(s). 8617.502 8617.502 912 Side panel, screw-fastened, sheet steel 2 pc(s). 8106.245 8108.245 901 Condensate hose 1 pc(s). 3301.612 3301.612 544 EC speed control 1 pc(s). 3235.440 3235.440 548 Comfort handle VX 1 pc(s). 8618.250 8618.250 937 Master/slave cable 1 pc(s). 3124.100 3124.100 550 see page see page 545 Cooling medium (ready-mixed) 518 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control TopTherm chillers Design: – Compact, modular layout of the refrigeration components – Nano-coated condenser – Pump to convey the medium Benefits: – Precise temperature control, based on microprocessor technology – Collective fault signal with floating contact – One version for two frequencies = international compatibility Temperature control: – Microcontroller control (factory setting +20 °C) Colour: – RAL 7035 Characteristic curves of pump: Available on the Internet Protection category IP to IEC 60 529: – IP 44 (electrics) Approvals: Available on the Internet Supply includes: – Complete unit ready for connection – Multilingual documentation including functional diagram and wiring plans Output class 1000 – 1500 W Model No. Packs of Total cooling output at Tw = 10 °C/Tu = 32 °C kW Total cooling output at Tw = 18 °C/Tu = 32 °C kW Power consumption Pel 50/60 Hz kW Rated operating voltage V, ~, Hz 3318.610 3319.610 0.8 / 0.9 1.2 / 1.3 1 / 1.1 1.5 / 1.7 0.69 / 1.07 0.86 / 0.99 230, 1~, 50/60 230, 1~, 50/60 Width mm 600 600 Height mm 400 400 Depth mm 455 455 5.1 / 5.6 5.7 / 5.6 +10 °C...+43 °C +10 °C...+43 °C R134a, 975 R134a, 975 Rated current max. A Operating temperature range Refrigerant g Water connection G ½" internal thread Pump pressure bar Volumetric flow (cooling medium) l/min Air throughput of fans (unimpeded air flow), 50/60 Hz m³/h Temperature hysteresis ◾ ◾ 2.5 2.5 4/6 4/6 900 / 900 900 / 900 ±2K ±2K Temperature of liquid +10 °C...+30 °C +10 °C...+30 °C Water circuit version hermetically open hermetically open PP plastic PP plastic Tank Page Tank capacity l 2.5 2.5 Weight as delivered kg 48.0 51.0 see page see page 545 3286.510 3286.510 534 Also required Cooling medium (ready-mixed) Accessories Metal filter Rittal System Catalogue 36/Climate control 1 pc(s). Further technical information available on the Internet. 519 Climate control Accessories for climate control Page 533  Chiller configurator Page 558   Blue e+ chillers with the principle Chiller Blue e+ 520 Rittal System Catalogue 36/Climate control Forward-looking climate control ◾ Active cooling circuit with speedcontrolled components for demand-based cooling ◾ High control accuracy thanks to DC inverter technology with two regulating modes ◾ Excellent operational reliability thanks to integrated flow sensor, overflow valve and electronic fill level monitoring ◾ Temperature limits from -5 °C to +50 °C ◾ 55% less refrigerant thanks to the use of microchannel technology ◾ Energy savings of up to 70% Intelligent networking ◾ In conjunction with the IoT interface, all Blue e+ chillers can now be networked and digitalised Climate control The benefits for you: – Continuous monitoring of temperature accuracy – Avoidance of downtime costs and consequential damage – Temperature records and energy efficiency analyses – Enhanced process reliability Easier to operate ◾ Fast unit analysis using RiDiag III software via the USB port ◾ Fast parameterisation, data reading and plain-text system messages via the intelligent, multilingual, industry-grade display (21 languages pre-installed) Maximum flexibility with assembly and siting ◾ Simple plug & play assembly ◾ Identical footprint for all performance classes ◾ Eyebolts for easier transportation ◾ Service-friendly thanks to optimum accessibility of all components ◾ Easy replacement of components For global use ◾ One device for all voltages and networks: – 380 to 415 V, 3~, 50 Hz – 440 to 480 V, 3~, 60 Hz ◾ International approvals: cULus Listed, EAC, CB-Report ◾ Pre-configured option packages Rittal System Catalogue 36/Climate control 521 Chillers Blue e+ Accessories for climate control Page 533  Chiller configurator Page 558  IoT interface Page 554   Benefits: – Blue e+ chillers ensure centralised and efficient cooling of liquid media with a high level of temperature accuracy and innovative DC inverter technology – Suitable for international use thanks to its unique multi-voltage capability (without rewiring) and high operating limits – Maximum reliability thanks to integral overflow valve and monitoring sensors – Intuitive operation due to touch display and intelligent interfaces – Compact and modular layout ensures minimum footprint – Pumps with highly efficient IE3 motors 522 Temperature control: – e+ controller (factory setting +20 °C) Colour: – Textured RAL 7035 Protection category IP to IEC 60 529: – IP 24 Supply includes: – Complete unit ready for connection (plug-in terminal strip) – Multilingual documentation Further technical information available on the Internet. Optional: – For remote monitoring and networking of cooling units and chillers in the Blue e+ generation, please use the IoT interface (Model No. 3124.300). Increase machine availability and process reliability with remote monitoring of device data, statuses and system messages. Approvals: Available on the Internet Performance diagrams: Available on the Internet Rittal System Catalogue 36/Climate control Chillers Blue e+ Output class 2500 – 5500 W Model No. Packs of Total cooling output at Tw = 18 °C/Tu = 35 °C to DIN EN 14511 kW Power consumption Pel 50/60 Hz kW 3320.200 3334.300 3334.400 2.5 / 2.4 4 / 3.9 5.5 / 5.4 1.38 / 1.57 2.49 / 2.72 2.49 / 2.72 380 - 415, 3~, 50 440 - 480, 3~, 60 380 - 415, 3~, 50 440 - 480, 3~, 60 380 - 415, 3~, 50 440 - 480, 3~, 60 Width mm 450 450 450 Height mm 820 820 1000 Rated operating voltage V, ~, Hz Depth mm Rated current max. A Operating temperature range Refrigerant g Water connection ¾" internal thread Pump pressure bar Volumetric flow (cooling medium) l/min Temperature hysteresis 710 710 710 2.17 / 1.95 3.95 / 3.47 3.95 / 3.47 -5 °C...+50 °C -5 °C...+50 °C -5 °C...+50 °C R134a, 460 R134a, 760 R134a, 930 ◾ ◾ ◾ 2.4 2.9 2.9 7 / 25 15 / 30 15 / 30 ± 0.5 K ± 0.5 K ± 0.5 K Temperature of liquid +5 °C...+35 °C +5 °C...+35 °C +5 °C...+35 °C Water circuit version hermetically open hermetically open hermetically open PE plastic PE plastic PE plastic 12 12 12 84.0 90.0 96.0 see page see page see page Tank Tank capacity l Weight as delivered kg Page Also required Cooling medium (ready-mixed) 545 Filter mat for cooling units, air/air heat exchangers and chillers 3 pc(s). 3285.920 3285.920 3285.900 533 Filter mat for Blue e+ chillers (inverter housings) 3 pc(s). 3285.940 3285.940 3285.940 533 Metal filter 1 pc(s). 3285.930 3285.930 3285.910 534 IoT interface 1 pc(s). 3124.300 3124.300 3124.300 554 RiDiag 1 pc(s). 3159.300 3159.300 3159.300 559 Temperature sensor 1 pc(s). 3124.400 3124.400 3124.400 549 891 Cross member 2 pc(s). 8601.680 8601.680 8601.680 Levelling feet 4 pc(s). 4612.000 4612.000 4612.000 892 Twin castors 1 pc(s). 6148.000 6148.000 6148.000 893 see page see page see page 545 Rittal – The System. Flow regulator valve Rittal System Catalogue 36/Climate control IoT Interface see page 554 Further technical information available on the Internet. 523 Climate control Accessories Blue e chillers Blue e chillers Targeted cooling output with exceptional efficiency 524 Rittal System Catalogue 36/Climate control Simple user prompting ◾ Fast parameterisation, data reading and plain-text system messages via the intelligent, multilingual, industry-grade touch display ◾ Prioritised error messages with three escalation levels (warning, error, maintenance) Targeted climate control ◾ Central activation of the fan and compressor via a digital controller ◾ Hysteresis with precision controller (HGBP) ± 0.25 K HGBP hysteresis: ± 0.25 K Sustainably eco-friendly ◾ 40% less refrigerant thanks to the use of microchannel technology ◾ No galvanic corrosion, as the microchannel heat exchanger is made from 100% aluminium Simple assembly ◾ Plug & play Climate control ◾ Fully wired ready for connection ◾ Service-friendly thanks to optimum accessibility of all components Integral safety functions ◾ Integral overflow valves ◾ Fill level monitoring ◾ Flow monitor Pre-configured options (also available as add-on packages) ◾ For shorter delivery times and a simplified ordering process        Rittal System Catalogue 36/Climate control Increased-output pump (4 and 6 bar) Pumps: Multi-circuit systems Outdoor (up to -20 °C) Heater Industrial connector Precision controller (HGBP) Special spray finish Water-cooled condenser Laser application 525 Chillers Blue e Accessories for climate control Page 533  Cooling medium Page 545   Design: – Robust industrial standard – Variable air routing is possible via the l/h or r/h side panel – Floating contact for collective fault signal Benefits: – Reduced volume of refrigerant, thanks to microchannel technology – Touch display for simplified user guidance – Intelligent interfaces – Integral safety functions – Pre-configured options Colour: – Enclosure: RAL 7035 – Base/plinth: RAL 7016 Approvals: Available on the Internet Protection category IP to IEC 60 529: – IP 44 (electrics) Supply includes: – Chiller wired ready for connection – Multilingual documentation including functional diagram and wiring plans Output class 11000 – 15000 W Model No. 3336.400 3336.405 3336.410 3336.415 Total cooling output at Tw = 10 °C/Tu = 32 °C kW Packs of 10.2 / 11.7 10.2 / 11.7 12.2 / 12.3 12.2 / 12.3 Total cooling output at Tw = 18 °C/Tu = 32 °C kW 11.8 / 13.2 11.8 / 13.2 14.3 / 14.8 14.3 / 14.8 6.3 / 8.8 6.3 / 8.8 7.02 / 8.75 7.7 / 9.9 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 Power consumption Pel 50/60 Hz kW Rated operating voltage V, ~, Hz Width mm 660 660 660 660 Height mm 1265 1265 1265 1265 Depth mm 1315 1315 1315 1315 10.2 / 11.3 11.1 / 13.1 12.9 / 12.9 13.8 / 14.65 Performance-enhanced pump – ◾ – ◾ Control voltage 24 V DC – ◾ – ◾ Precision controller – ◾ – ◾ +10 °C...+43 °C +10 °C...+43 °C +10 °C...+43 °C +10 °C...+43 °C R410a, 1350 R410a, 1350 R410a, 1350 R410a, 1350 ◾ ◾ ◾ ◾ 2/2 5/7 2/2 5/7 30 / 55 30 / 55 35/ 55 35/ 55 6000 / 7200 6000 / 7200 6000 / 7200 6000 / 7200 ±2K ± 0.25 K ±2K ± 0.25 K +10 °C...+25 °C +10 °C...+25 °C +10 °C...+25 °C +10 °C...+25 °C PE plastic PE plastic PE plastic PE plastic 49 49 49 49 247.0 247.0 253.0 253.0 Rated current max. A Operating temperature range Refrigerant g Water connection R 1" internal thread Pump pressure bar Volumetric flow (cooling medium) l/min Air throughput of fans (unimpeded air flow), 50/60 Hz m³/h Temperature hysteresis Temperature of liquid Tank Tank capacity l Weight as delivered kg Page Accessories Cooling medium (ready-mixed) Metal filter 526 2 pc(s). see page see page see page see page 545 3286.560 3286.560 3286.560 3286.560 534 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Chillers Blue e Output class 20000 – 25000 W Packs of 3336.430 3336.435 3336.450 3336.455 16.3 / 19.2 16.3 / 19.2 19.9 / 22.9 19.9 / 22.9 Total cooling output at Tw = 18 °C/Tu = 32 °C kW 19.3 / 22 19.3 / 22 24.4 / 26.3 24.4 / 26.3 Power consumption Pel 50/60 Hz kW 8.5 / 10.9 8.5 / 10.9 10.6 / 13.3 11.3 / 14.4 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 Total cooling output at Tw = 10 °C/Tu = 32 °C kW Rated operating voltage V, ~, Hz Width mm 760 760 760 760 Height mm 1265 1265 1265 1265 Depth mm 1515 1515 1515 1515 19 / 15.9 19.9 / 17.2 21.7 / 22.4 22.6 / 24.1 Performance-enhanced pump – ◾ – ◾ Control voltage 24 V DC – ◾ – ◾ Precision controller – ◾ – ◾ +10 °C...+43 °C +10 °C...+43 °C +10 °C...+43 °C +10 °C...+43 °C R410a, 1450 R410a, 1450 R410a, 1450 R410a, 1450 ◾ ◾ ◾ ◾ 2/2 4.75 / 6.75 2/2 4.5 / 6.7 Rated current max. A Operating temperature range Refrigerant g Water connection R 1¼" internal thread Pump pressure bar Volumetric flow (cooling medium) l/min Air throughput of fans (unimpeded air flow), 50/60 Hz m³/h Temperature hysteresis Temperature of liquid Tank Tank capacity l Weight as delivered kg 45 / 75 45 / 75 55 / 75 55 / 75 12000 / 14500 12000 / 14500 12000 / 14500 12000 / 14500 ±2K ± 0.25 K ±2K ± 0.25 K +10 °C...+25 °C +10 °C...+25 °C +10 °C...+25 °C +10 °C...+25 °C PE plastic PE plastic PE plastic PE plastic 78 78 78 78 310.0 310.0 326.0 326.0 Page Accessories Cooling medium (ready-mixed) Rittal – The System. Metal filter Rittal System Catalogue 36/Climate control 2 pc(s). see page see page see page see page 545 3286.570 3286.570 3286.570 3286.570 534 Metal filters see page 534 Further technical information available on the Internet. 527 Climate control Model No. VX25 TopTherm chillers Accessories for climate control Page 533  Chiller configurator Page 558   TopTherm chillers in a VX25 enclosure with a small footprint are perfect for integrating into an enclosure suite. Their dual-frequency compatibility makes them extremely flexible. The microchannel technology reduces the volume of refrigerant required. Benefits: – Convenient servicing – High reliability thanks to icing protection – One version for two frequencies = international compatibility – Reduced volume of refrigerant, thanks to microchannel technology – Bayable by screw-fastening at the sides – Integral safety functions Temperature control: – e-controller (factory setting +18 °C) Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 44 (electrics) Supply includes: – Fully wired unit ready for connection with side panels and door Note: – Regular leak tests are not prescribed by law. Characteristic curves of pump: Available on the Internet Approvals: Available on the Internet Output class 8000 – 12000 W Model No. Packs of Total cooling output at Tw = 18 °C/Tu = 32 °C kW 3335.920 3335.930 3335.940 8 / 8.6 8 / 8.6 12 / 13.1 Power consumption Pel 50/60 Hz kW 4.34 / 5.22 4.65 / 5.71 6.35 / 7.31 Rated operating voltage V, ~, Hz 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 Width mm 805 805 805 Height mm 1700 2100 2140 Depth mm 605 605 605 8.4 / 7.5 9 / 8.3 9.9 / 10.8 +10 °C...+43 °C +10 °C...+43 °C +10 °C...+43 °C R410a, 1200 R410a, 1200 R410a, 1400 ◾ ◾ ◾ 2.5 2.5 2.5 Volumetric flow (cooling medium) l/min 30 / 45 30 / 45 35 / 55 Temperature hysteresis ±2K ±2K ±2K +10 °C...+25 °C +10 °C...+25 °C +10 °C...+25 °C Rated current max. A Operating temperature range Refrigerant g Water connection G 1" internal thread Pump pressure bar Temperature of liquid Tank capacity l Weight as delivered kg 75 75 75 242.0 248.0 282.0 3286.630 Page Accessories Metal filter 3286.650 3286.630 Cooling medium (ready-mixed) 1 pc(s). see page see page see page 545 Flow regulator valve see page see page see page 545 Comfort handle VX 1 pc(s). 8618.250 8618.250 8618.250 937 Twin castors 1 pc(s). 7495.000 7495.000 7495.000 893 Base/plinth corner piece with base/plinth trim panels, front and rear, 100 mm 2 pc(s). 8640.003 8640.003 8640.003 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.033 8640.033 882 Base/plinth corner piece with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.023 8640.023 8640.023 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.043 8640.043 882 528 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control VX25 TopTherm chillers Output class 16000 – 25000 W Model No. Packs of Total cooling output at Tw = 18 °C/Tu = 32 °C kW 3335.950 3335.960 3335.970 16 / 17.6 20 / 21.8 25 / 27.6 Power consumption Pel 50/60 Hz kW 7.05 / 8.71 9.21 / 11.75 11.31 / 14.12 Rated operating voltage V, ~, Hz 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 400, 3~, 50 460, 3~, 60 Width mm 805 1205 1205 Height mm 2140 2140 2140 Depth mm 605 605 605 12.6 / 12.3 20.2 / 17.3 22.9 / 23.8 +10 °C...+43 °C +10 °C...+43 °C +10 °C...+43 °C R410a, 1400 R410a, 1550 R410a, 1700 ◾ ◾ ◾ 2.5 2.5 2.5 Volumetric flow (cooling medium) l/min 35 / 65 45 / 75 50 / 85 Temperature hysteresis ±2K ±2K ±2K +10 °C...+25 °C +10 °C...+25 °C +10 °C...+25 °C Rated current max. A Operating temperature range Refrigerant g Water connection G 1" internal thread Pump pressure bar Temperature of liquid Tank capacity l Weight as delivered kg 75 150 150 282.0 360.0 374.0 3286.640 Page Metal filter 3286.630 3286.640 Cooling medium (ready-mixed) 1 pc(s). see page see page see page 545 Flow regulator valve see page see page see page 545 Comfort handle VX 1 pc(s). 8618.250 8618.250 8618.250 937 Twin castors 1 pc(s). 7495.000 7495.000 7495.000 893 2 pc(s). 8640.003 8640.007 8640.007 881 Base/plinth trim panels, sides, 100 mm 2 pc(s). 8640.033 8640.033 8640.033 882 Base/plinth corner piece with base/plinth trim panels, front and rear, 200 mm 2 pc(s). 8640.023 8640.025 8640.025 881 Base/plinth trim panels, sides, 200 mm 2 pc(s). 8640.043 8640.043 8640.043 882 Rittal – The System. Base/plinth corner piece with base/plinth trim panels, front and rear, 100 mm Rittal System Catalogue 36/Climate control Chiller configurator see page 558 Further technical information available on the Internet. 529 Climate control Accessories Enclosure heaters Accessories for climate control Page 533  Therm software Page 558   Material: – Aluminium, anodised Protection category IP to IEC 60 529: – IP 20 Protection class: – II (all-insulated) Supply includes: – PTC heater – Quick-connection terminal – Assembly parts Note: – A thermostat is recommended for precise temperature control inside the enclosure – In order to prevent condensation on assemblies, a hygrostat is recommended to regulate heating – In larger enclosures, even heat distribution is best achieved by installing several low-output heaters B H Enclosure heaters to regulate relative humidity, prevent temperatures from dropping below the dew point and stop condensation forming inside the enclosure. This prevents consequential damage associated with corrosion or electrical short circuits. T Approvals: Available on the Internet Continuous thermal output 10 – 150 W, without fan Model No. 3105.310 3105.320 3105.330 3105.340 3105.350 3105.360 3105.370 Width (B) mm Packs of 45 45 64 64 64 90 90 Height (H) mm 120 120 155 155 230 165 180 Depth (T) mm 46 46 56 56 56 75 75 8 - 10 18 - 20 23 - 30 49 - 50 63 - 75 86 - 100 130 - 150 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 110 - 240, 1~, 50/60 Continuous thermal output at Tu = 10 °C W Rated operating voltage V, ~, Hz Page Accessories Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 3114.200 3114.200 3114.200 546 Bottom-mounted adaptor 1 pc(s). 3110.200 3110.200 3110.200 3110.200 3110.200 3110.200 3110.200 548 530 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Enclosure heaters Accessories for climate control Page 533  Therm software Page 558   Note: – A thermostat is recommended for precise temperature control inside the enclosure – In order to prevent condensation on assemblies, a hygrostat is recommended to regulate heating – In larger enclosures, even heat distribution is best achieved by installing several low-output heaters Protection category IP to IEC 60 529: – IP 20 Protection class: – II (all-insulated) Supply includes: – PTC heater with fan – Assembly parts B Climate control Material: – Plastic H Enclosure heaters to regulate relative humidity, prevent temperatures from dropping below the dew point and stop condensation forming inside the enclosure. This prevents consequential damage associated with corrosion or electrical short circuits. Approvals: Available on the Internet T Continuous thermal output 235 – 800 W, with fan Model No. 3105.410 3105.380 3105.420 3105.390 3105.430 3105.400 Width (B) mm Packs of 103 103 103 103 103 103 Height (H) mm 200 200 200 200 200 200 Depth (T) mm 103 103 103 103 103 103 Continuous thermal output at Tu = 10 °C 50/60 Hz W 235 / 250 250 / 265 355 / 400 400 / 415 710 / 800 800 / 870 Rated operating voltage V, ~, Hz 115, 1~, 50/60 230, 1~, 50/60 115, 1~, 50/60 230, 1~, 50/60 115, 1~, 50/60 230, 1~, 50/60 Page Accessories Thermostat 1 pc(s). 3110.000 3110.000 3110.000 3110.000 3110.000 3110.000 547 Hygrostat 1 pc(s). 3118.000 3118.000 3118.000 3118.000 3118.000 3118.000 547 Digital enclosure internal temperature display and thermostat 1 pc(s). 3114.200 3114.200 3114.200 3114.200 3114.200 3114.200 546 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 531 Innovative climate control accessories Perfectly coordinated components customised to your requirements, from page 533 532 Rittal System Catalogue 36/Climate control Accessories for climate control Filter technology Filter mat For tangential fans/front outlet grilles 2 U for tangential fans Made of chopped-fibre mat with a progressive structure. Temperature-resistant to 100 °C, self-extinguishing category F1 to DIN 53 438. Dust-laden air side: Open structure. Clean-air side: Closed structure. Reliable filtering of virtually all types of dust from a particle size of 10 μm. WxHxD mm Packs of Model No. 425 x 85 x 8 5 pc(s). 3177.000 To fit Model No. 3144.000/ 3145.000/ 3176.000 Material: – Chemical fibres Filter mat Climate control for cooling units, air/air heat exchangers and chillers Rittal cooling units are low-maintenance and are supplied without filter mats. Filter mats may be used for extreme conditions. Benefits: – Temperature-resistant from -40 °C...+80 °C Material: – Open-celled polyurethane foamed plastic for cooling units for air/air heat exchangers for chillers 3320.200/3334.300 – – ◾ 320 x 599 x 8 3 pc(s). 3285.920 3302.300/3303.310 ◾ – – 190 x 95 x 10 3 pc(s). 3286.110 3273..../3382..../3383..../ 3384..../3385..../3359..../ 3301.800 ◾ – – 530 x 255 x 10 3 pc(s). 3286.500 To fit Model No. W x H x D mm Packs of Model No. 3386..../3387.... ◾ – – 720 x 300 x 10 3 pc(s). 3286.600 3185.830/3185.530 ◾ – – 360 x 297 x 10 3 pc(s). 3285.800 3186.930/3187.930/ 3188.940/3189.940/ 3186.630/3187.630/ 3188.640/3189.640/ 3334.400 ◾ – ◾ 390 x 397 x 10 3 pc(s). 3285.900 3302.1xx/3302.200/ 3303.xx0/3361..../ 3126.100/3126.115 ◾ ◾ – 265 x 200 x 10 3 pc(s). 3286.300 3304.xx0/3305.xx0/ 3328.xx0/3329.xx0/ 3332..../3366..../ 3127.100/3127.115/ 3128.100/3128.115/ 3129.100/3129.115/ 3130.100/3130.115 ◾ ◾ – 344 x 268 x 10 3 pc(s). 3286.400 Filter mat for Blue e+ chillers (inverter housings) Flat-pleated filter for Blue e+ chillers made from polyester with all-round frame and V brackets on the end face. For Blue e+ chillers To fit Model No. W x H x D mm Packs of Model No. 3320.200/ 3334.300/ 3334.400 131 x 113 x 13 3 pc(s). 3285.940 Material: – Polyester Filter class to DIN EN 779: – G3 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 533 Accessories for climate control Filter technology Metal filter Particularly when cooling units are used in dusty and oily environments, it is advisable to use washable metal filters. If air or steam condenses on the metal surfaces, any particles present will adhere to the metal, and can easily be washed out with water or grease-dissolving detergents. Material: – Aluminium To fit Model No. 534 for cooling units for air/air heat for chillers exchangers for climate control door/ section door WxHxD mm Packs of Model No. 3185.830/3185.530 ◾ – – – 320 x 280 x 10 1 pc(s). 3285.810 3320.200/3334.300 – – ◾ – 295 x 599 x 15 1 pc(s). 3285.930 3336.400/3336.405/ 3336.410/3336.415 – – ◾ – 700 x 724 x 20 2 pc(s). 3286.560 3336.430/3336.435/ 3336.450/3336.455 – – ◾ – 945 x 765 x 20 2 pc(s). 3286.570 3186.930/3187.930/ 3188.940/3189.940/ 3186.630/3187.630/ 3188.640/3189.640/ 3334.400 ◾ – ◾ – 380 x 358 x 10 1 pc(s). 3285.910 3300.040/3300.050/ 3300.060/3300.070/ 3300.080/3300.090/ 3300.110/3300.120/ 3201.800/3201.810/ 3201.820/3201.830/ 3201.840/3201.850 – – – ◾ 425 x 78 x 10 1 pc(s). 3284.210 3302.300/3302.310 ◾ – – – 190 x 95 x 10 1 pc(s). 3286.120 3302.1xx/3302.200/ 3303.xx0/3361..../ 3126.100/3126.115 ◾ ◾ – – 265 x 200 x 10 1 pc(s). 3286.310 3304.xx0/3305.xx0/ 3328.xx0/3329.xx0/ 3332..../3366.../ 3127.100/3127.115/ 3128.100/3128.115/ 3129.100/3129.115/ 3130.100/3130.115/ 3360.100 ◾ ◾ ◾ – 344 x 268 x 10 1 pc(s). 3286.410 3273..../3382..../3383..../ 3384..../3385..../3359..../ 3318.600/3318.610/ 3319.600/3319.610/ 3334.660 ◾ – ◾ – 530 x 255 x 10 1 pc(s). 3286.510 3320.600/3334.600 – – ◾ – 500 x 558 x 8 1 pc(s). 3286.520 3386..../3387.... ◾ – – – 720 x 300 x 10 1 pc(s). 3286.610 3335.840/3335.850/ 3335.880 – – ◾ – 595 x 1030 x 20 1 pc(s). 3286.530 3335.860/3335.870/ 3335.890 – – ◾ – 1000 x 1035 x 20 1 pc(s). 3286.540 3335.790/3335.830 – – ◾ – Further technical information available on the Internet. 595 x 780 x 20 1 pc(s). 3286.550 Rittal System Catalogue 36/Climate control Accessories for climate control Filter technology Spare filter mat Made of chopped-fibre mat with a progressive structure. Temperature-resistant to 100 °C, self-extinguishing category F1 to DIN 53 438. Dust-laden air side: Open structure. Clean-air side: Closed structure. Reliable filtering of virtually all types of dust from a particle size of 10 μm. Note: – Performance data, protection category and device approvals are only guaranteed when used in conjunction with original Rittal filter mats. For roof-mounted fan To fit Model No. Material W x H x D mm Filter class to DIN EN 779 Packs of Model No. 3138..../3139..../ 3140.... Chemical fibre 264 x 95 x 17 G3 12 pc(s). 3174.100 Material W x H x D mm Filter class to DIN EN 779 Packs of Model No. 3237.6.. Copper-nickel-chrome coated chemical fibres 92 x 92 x 10 G2 5 pc(s). 3237.066 3238.6.. Copper-nickel-chrome coated chemical fibres 125 x 125 x 12 G2 5 pc(s). 3238.066 3239.6.. Copper-nickel-chrome coated chemical fibres 178 x 178 x 17 G3 5 pc(s). 3239.066 3240.6../3241.6.. Copper-nickel-chrome coated chemical fibres 226 x 226 x 17 G3 5 pc(s). 3240.066 3243.6../3244.6../ 3245.6.. Copper-nickel-chrome coated chemical fibres 294 x 294 x 17 G3 5 pc(s). 3243.066 Material W x H x D mm Filter class to DIN EN 779 Packs of Model No. 3237.... Chemical fibre 89 x 89 x 10 G2 5 pc(s). 3321.700 3237.... Chemical fibre 89 x 89 x 10 G2 50 pc(s). 3321.705 3238.... Chemical fibre 120 x 120 x 12 G2 5 pc(s). 3322.700 3238.... Chemical fibre 120 x 120 x 12 G2 50 pc(s). 3322.705 3239.... Chemical fibre 173 x 173 x 17 G3 5 pc(s). 3171.100 3239.... Chemical fibre 173 x 173 x 17 G3 50 pc(s). 3171.105 3240..../3241.... Chemical fibre 221 x 221 x 17 G3 5 pc(s). 3172.100 3240..../3241.... Chemical fibre 221 x 221 x 17 G3 50 pc(s). 3172.105 3243..../3244..../ 3245.... Chemical fibre 289 x 289 x 17 G3 5 pc(s). 3173.100 3243..../3244..../ 3245.... Chemical fibre 289 x 289 x 17 G3 50 pc(s). 3173.105 Material W x H x D mm Filter class to DIN EN 779 Packs of Model No. Chemical fibre 90 x 106 x 8 G2 5 pc(s). 3201.050 To fit Model No. Climate control For EMC fan-and-filter units For fan-and-filter units To fit Model No. For Thermoelectric coolers To fit Model No. 3201.200/3201.300 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 535 Accessories for climate control Filter technology Fine filter mat for fan-and-filter units Made of chopped-fibre mat with a progressive structure. Temperature-resistant to 100 °C, self-extinguishing category F1 to DIN 53 438. Dust-laden air side: Open structure. Clean-air side: Closed structure. Reliable filtering of virtually all types of dust with a particle size of up to 1 μm. Material: – Chemical fibres Note: – Performance data, protection category and device approvals are only guaranteed when used in conjunction with original Rittal filter mats. To fit Model No. W x H x D mm Filter class to DIN EN 779 Packs of Model No. 3238.... 120 x 120 x 12 F5/M5 5 pc(s). 3238.055 3239.... 173 x 173 x 12 F5/M5 5 pc(s). 3181.100 3240..../3241.... 221 x 221 x 12 F5/M5 5 pc(s). 3182.100 3243..../3244..../3245.... 289 x 289 x 12 F5/M5 5 pc(s). 3183.100 Pleated filter To fit Model No. W x H x D mm Packs of for Blue e+ roof-mounted cooling unit and VX25 Blue e+ integration solution To achieve a protection category of IP 54 with roofmounted cooling unit Blue e+ and VX25 Blue e+ integration solution. 3185.030/ 3185.730 652 x 158 x 15 3 pc(s). Model No. 3285.700 Material: – Non-woven fabric Note: – Operation without a pleated filter is inadmissible Filter class to DIN EN 779: – G4 536 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Accessories for climate control Filter technology Outlet filter Standard For ventilation by convection, an outlet filter can be installed in the upper and lower sections of the enclosure. Material: – ABS Accessories: – – – – Spare filter mat, see page 535 Fine filter mat, see page 536 Hose-proof hood, see page 538 Blanking cover, see page 538 Colour: – RAL 7035 – Optionally available in RAL 9005 Protection category IP to IEC 60 529: – IP 54 including filter mat – IP 55 with standard filter and additional fine filter – IP 56 with standard filter and hose-proof hood Protection category NEMA: – NEMA 12 W x H x D mm Required cut-out, width mm Required cut-out, height mm Packs of Model No. 116.5 x 116.5 x 16 92 92 1 pc(s). 3237.200 148.5 x 148.5 x 24 124 124 1 pc(s). 3238.200 204 x 204 x 24 177 177 1 pc(s). 3239.200 255 x 255 x 25 224 224 1 pc(s). 3240.200 323 x 323 x 25 292 292 1 pc(s). 3243.200 Outlet filter EMC For ventilation by convection, an outlet filter can be installed in the upper and lower sections of the enclosure. Climate control Supply includes: – Outlet filter – Filter mat Accessories: – Spare filter mat, see page 535 – Fine filter mat, see page 536 – Hose-proof hood, see page 538 Material: – ABS Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 54 including filter mat – IP 55 with EMC filter mat and additional fine filter – IP 56 with EMC filter mat and hose-proof hood Supply includes: – Outlet filter – Filter mat W x H x D mm Required cut-out, width mm Required cut-out, height mm Packs of Model No. 116.5 x 116.5 x 16 92 92 1 pc(s). 3237.060 148.5 x 148.5 x 24 124 124 1 pc(s). 3238.060 204 x 204 x 24 177 177 1 pc(s). 3239.060 255 x 255 x 25 224 224 1 pc(s). 3240.060 323 x 323 x 25 292 292 1 pc(s). 3243.060 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 537 Accessories for climate control Filter technology Hose-proof hood to increase the protection category For fan-and-filter units/outlet filters. Easy cleaning thanks to exterior silicone coating approved for use with foodstuffs. Material: – Stainless steel – Silicone Protection category IP to IEC 60 529: – IP 56 when fitted over fan-and-filter unit/outlet filter with filter mat To fit Model No. W x H x D mm Protection category Packs of Model No. 150 x 230 x 40 NEMA 1 NEMA 12 NEMA 3 NEMA 3R 1 pc(s). 3237.080 176 x 245 x 55 NEMA 1 NEMA 12 NEMA 3 NEMA 3R NEMA 4 NEMA 4X 1 pc(s). 3238.080 233 x 330 x 55 NEMA 1 NEMA 12 NEMA 3 NEMA 3R NEMA 4 NEMA 4X 1 pc(s). 3239.080 282 x 390 x 85 NEMA 1 NEMA 12 NEMA 3 NEMA 3R NEMA 4 NEMA 4X 1 pc(s). 3240.080 3243..../3244.... 350 x 480 x 110 NEMA 1 NEMA 12 NEMA 3 NEMA 3R NEMA 4 NEMA 4X 1 pc(s). 3243.080 3245.... 350 x 480 x 160 NEMA 1 NEMA 12 NEMA 3 NEMA 3R 1 pc(s). 3245.080 3237.... 3238.... 3239.... 3240..../3241.... Blanking cover To fit Model No. W x H x D mm Packs of for fan-and-filter units / outlet filters If existing mounting cut-outs for fan-and-filter units/ outlet filters need to be closed to achieve a higher protection category, the filter mat of the fan-andfilter unit/outlet filter can simply be replaced with a blanking cover; welding or other mechanical modification of the enclosure is not necessary. 3237.... 81 x 81 x 6 2 pc(s). 3237.020 3238.... 114 x 114 x 8 2 pc(s). 3238.020 3239.... 167 x 167 x 15 2 pc(s). 3239.020 3240..../ 3241.... 214 x 214 x 15 2 pc(s). 3240.020 3243..../ 3244..../ 3245.... 282 x 282 x 15 2 pc(s). 3243.020 Material: – PE, closed-cell Model No. Colour: – Anthracite Protection category IP to IEC 60 529: – IP 54 538 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Accessories for climate control Filter technology Front outlet grille 2 U for tangential fans This front outlet grille is required if a 482.6 mm (19") cross-flow blower (SK 3144.000/SK 3145.000) is used in the lower section of the electronic enclosure and the hot air is to be expelled to the outside from the upper section of the enclosure. The design of the grille matches that of the intake grille in the cross-flow blower. These grilles can also be used as simple inflow and outflow grilles with natural convection. Packs of Model No. 1 pc(s). 3176.000 Accessories: – Filter mat, see page 533 Enclosure internal fan To prevent hot-spots and support the air routing of active enclosure climate control components. Adjustable in two axes. Attached to the frame section. Several fans may be cascaded using the quickrelease clamping strip. Climate control Supply includes: – Complete unit with axial fan ready for connection – Snap-on pivot device – Assembly parts Air throughput (unimpeded air flow) m³/h Rated operating voltage V, ~, Hz Power consumption W Rated current A Packs of Model No. 160 230, 1~, 50/60 19 / 18 0.12 / 0.11 1 pc(s). 3108.100 160 115, 1~, 50/60 19 / 18 0.24 / 0.23 1 pc(s). 3108.115 160 24 (DC) 3.5 0.15 1 pc(s). 3108.024 Mini fan Compact DC fan for enclosure and component cooling in enclosures. Supply includes: – Fan – Assembly screws – Contact hazard protection W x H x D mm Air throughput (unimpeded air flow) m³/h Rated operating voltage V Power consumption W Operating temperature range Noise level dB(A) Packs of Model No. 60 x 60 x 25.4 21 24 (DC) 1 -20 °C...+70 °C 20 1 pc(s). 3236.124 Integrated louvres For ventilation by convection; easily retro-fitted using 4 screws. W x H x D mm Packs of Model No. 160 x 110 x 8 4 pc(s). 2541.235 210 x 100 x 8 4 pc(s). 2542.235 330 x 110 x 8 4 pc(s). 2543.235 Material: – Sheet steel Supply includes: – Assembly parts Rittal System Catalogue 36/Climate control T B H Colour: – RAL 7035 Further technical information available on the Internet. 539 Accessories for climate control Air routing Air duct system To fit Model No. Packs of Model No. for roof-mounted cooling units and roofmounted air/water heat exchangers Cold air may be routed directly to specific areas of the enclosure using the air duct system. The risk of air short circuits due to self-ventilated installed devices is therefore eliminated. The dimensions of the shallow duct are W x H x D 229 x 1500 x 29 mm, and can be shortened to the required length. 3209..../3210..../3273..../ 3359..../3382..../3383..../ 3384..../3385.... 1 pc(s). 3286.870 3386..../3387.... 1 pc(s). 3286.970 Material: – Flame-resistant plastic to DIN 4102/B1 Colour: – RAL 7035 Supply includes: – Shallow duct  – Compensating hose Also required: – Support strip, see page 952 Accessories: – Deflector, 90°, see page 540 – Stoppers, see page 542 – Flat duct extension, see page 541 Note: – Do not direct cold air straight at active components. – When using the ducting system, the performance of the cooling unit may be reduced, depending on the application in question. – For devices 3359..../3382...., the air duct adaptor 3286.840 is additionally required. Air duct adaptor To fit Model No. Packs of Model No. for air duct system and shallow air duct system The adaptor serves as a connection between the roof-mounted cooling unit (air inlet opening) and the air-duct system. 3359..../3382.... 1 pc(s). 3286.840 Material: – ABS Colour: – RAL 9005 Deflector, 90° for air duct system For targeted air deflection at the end of the shallow duct. Packs of Model No. 1 pc(s). 3286.990 Material: – Flame-resistant plastic to DIN 4102/B1 Colour: – RAL 7035 540 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Accessories for climate control Air routing Shallow air duct system To fit Model No. for roof-mounted cooling units and roofmounted air/water heat exchangers Cold air may be routed directly to specific areas of the enclosure using the air duct system. The risk of air short circuits due to self-ventilated installed devices is therefore eliminated. The dimensions of the shallow duct are W x H x D 229 x 1500 x 29 mm, and can be shortened to the required length. 3209..../3210..../3273..../ 3383..../3384..../3385..../ 3359..../3382.... Applications: – Suitable for enclosures with widths of 800 mm or more and depths of 600 mm or more Material: – Flame-resistant plastic to DIN 4102/B1 Colour: – RAL 7035 Supply includes: – Shallow duct  – Adaptor – Compensating piece – Deflector, 90° Packs of Model No. 1 pc(s). 3286.850 Also required: – Air duct adaptor, see page 540 – Support strip, see page 952 Assembly – For devices 3359.XXX and 3382.XXX, the air duct adaptor 3286.840 is required for mounting. Accessories: – Deflector, 90°, see page 540 – Stoppers, see page 542 – Flat duct extension, see page 541 Flat duct extension Climate control Note: – Do not direct cold air straight at active components. – When using the ducting system, the performance of the cooling unit may be reduced, depending on the application in question. – Not suitable for use in conjunction with quickchange frame. Packs of Model No. 1 pc(s). 3286.860 Extension kit for shallow air duct system 3286.850 for length compensation in the width, depth or height in enclosures. Material: – Flame-resistant plastic to DIN 4102/B1 Colour: – RAL 7035 Supply includes: – Shallow duct 1500 mm – Connecting piece Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 541 Accessories for climate control Air routing Stoppers for roof-mounted cooling units and roofmounted air/water heat exchangers To cover any cold air outlets that are not required. Material: – Polyurethane foam To fit Model No. Ø mm Max. no. of stoppers per unit Packs of Model No. 3359..../3382.... 80 1 2 pc(s). 3286.780 3209..../3210..../3273..../ 3383..../3384..../3385.... 100 2 2 pc(s). 3286.880 3386..../3387.... 150 1 2 pc(s). 3286.980 Air diverter For use with wall-mounted cooling units, for targeted routing of cold air in a downward direction. Particularly well-suited for densely-packed electrical components in the lower section of the enclosure. To fit Model No. Installation depth mm Packs of Model No. 3304..../3305.... 65 1 pc(s). 3213.310 3328..../3329.... 65 1 pc(s). 3213.320 ¹) 115 mm for 3213.330 Material: – Sheet steel Colour: – RAL 7035  External air circuit  Internal air circuit 1 2 65 1) 542 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Accessories for climate control Water distribution Electric condensate evaporator For external mounting on the enclosure. For use with all enclosure cooling units and air/water heat exchangers (wall-mounted). Benefits: – Suitable for international use thanks to multivoltage support Colour: – RAL 7035 Supply includes: – Electric condensate evaporator, ready to connect Rated operating voltage V, ~, Hz Operating temperature range Evaporation performance Packs of Model No. 280 x 129 x 105 115 - 230, 1~, 50/60 +5 °C...+60 °C 230 V: 3.5 l/d 115 V: 3.0 l/d 1 pc(s). 3301.500 +5 °C...+60 °C 230 V: 3.5 l/d 115 V: 3.0 l/d 1 pc(s). 3301.505 400 x 129 x 105 115 - 230, 1~, 50/60 Climate control W x H x D mm Electrical condensate evaporator for Blue e+ roof-mounted cooling units Tool-free mounting of the condensate evaporator on the underside of the roof-mounted Blue e+ so that it is not visible from the outside. Any condensation is evaporated and emitted to the ambient air via the air exhaust of the cooling unit. Material: – Plastic Colour: – RAL 9005 Supply includes: – Electrical condensate evaporation – Shipping brace screw – Entry grommet Note: – Power is supplied via the cooling unit To fit Model No. W x H x D mm Rated operating voltage V (DC) Operating temperature range Evaporation performance Packs of Model No. 3185.730 89 x 121 x 158 380 +5 °C...+60 °C 100 ml/h 1 pc(s). 3355.720 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 543 Accessories for climate control Water distribution Condensate collecting bottle Packs of Model No. 1 pc(s). 3301.600 For mounting on the enclosure. For use with all enclosure cooling units and air/water heat exchangers. Safety overflow at the side. Capacity approximately 0.75 l. Supply includes: – Condensate collecting bottle – Bottle holder – Assembly parts 1 2 66 239 3 Ø 73  Condensate discharge tube  Membrane grommet  Max. 70 mm Condensate hose For discharging and transporting condensate. For connection to enclosure cooling units and air/water heat exchangers. Material: – PVC, transparent To fit Model No. 544 Length m Ø mm 3201.... 5 6 1 1 pc(s). 3301.606 3302.300/3302.310 10 8 1.5 1 pc(s). 3301.608 3212..../3303..../3361..../3302.1xx/ 3302.2xx 10 10 1.5 1 pc(s). 3301.610 3209...3210/3214.100/3215.100/ 3216.480/3273..../3304...3305/ 3328...3329/3332..../3359..../ 3363...3364/3366..../3373...3375/ 3377...3378/3382...3385/3386...3387/ 3185.830/3185.530/3186.930/ 3186.630/3187.930/3187.630/ 3188.940/3188.640/3189.940/ 3189.640 10 12 2 1 pc(s). 3301.612 Further technical information available on the Internet. Material thickness mm Packs of Model No. Rittal System Catalogue 36/Climate control Accessories for climate control Water distribution Connection set for air/water heat exchangers For professional laying of water connections and regulation of volumetric flow. The pressure hoses may be cut to length individually, depending on the application. Material: – Water-carrying parts EPDM/brass Supply includes: – Hose for water return – Hose for water inlet including regulator valve for regulating the volumetric flow (setting range 3 to 12 l/min) – Assembly parts Length mm 3209.XX0/3210.XX0/3216.480/ 3363.XX0/3364.XX0/3373.XX0/ 3374.XX0/3375.XX0 Permissible Water connections operating pressure Packs of (p. max.) bar 3600 G ⅜" internal thread 1 - 10 1 pc(s). Model No. 3201.990 Climate control To fit Model No. Flow regulator valve Design For use with air/water heat exchangers, especially if more than one heat exchanger (n > 1) is used in the water cooling circuit. The correctly set valve then ensures the same quantity of cooling medium for all equipment. Setting range Packs of l/min Model No. ¾" x ½" for volumetric flow control 3 - 12 1 pc(s). 3301.930 ¾" x ¾" for volumetric flow control 3 - 12 1 pc(s). 3301.940 Applications: – The valve is used for hydraulic balancing. Material: – Brass Cooling medium (ready-mixed) For chillers and air/water heat exchangers As well as protecting against frost, this cooling medium also serves to inhibit bacterial growth and provide optimum corrosion protection. Application Antifreeze/water mixture Container Contents l Operating temperature range Packs of Model No. Outdoor 1:2 Canister 10 -20 °C...+60 °C 1 pc(s). 3301.950 Outdoor 1:2 Canister 25 -20 °C...+60 °C 1 pc(s). 3301.955 Standard 1:4 Canister 10 -10 °C...+60 °C 1 pc(s). 3301.960 Standard 1:4 Canister 25 -10 °C...+60 °C 1 pc(s). 3301.965 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 545 Accessories for climate control Control/regulation Digital enclosure internal temperature display and thermostat For installation in the enclosure door or wall. Technical specifications: – Three-digit, 7-segment display – Option of switching between °C/°F – Includes 1800 mm long NTC sensor – Two relay outputs as change-over contact and normally open contact (max. contact load 230 V, 6 A) – Freely selectable switching difference Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 54 Rated operating voltage V, ~, Hz Installation depth mm Setting range Operating temperature range Packs of Model No. 100 - 230, 1~, 50/60 24 - 60 (DC) 100 +5 °C...+55 °C +0 °C...+50 °C 1 pc(s). 3114.200 Digital enclosure internal temperature display and thermostat integrated into a patch panel 1 U Including cable attachment for connection cable and label holder. Technical specifications: – Three-digit, 7-segment display – Option of switching between °C/°F – Includes 1800 mm long NTC sensor – Two relay outputs as change-over contact and normally open contact (max. contact load 230 V, 6 A) – Freely selectable switching difference 546 Rated operating voltage V, ~, Hz Installation depth mm Setting range Colour Packs of Model No. 100 - 230, 1~, 50/60 24 - 60 (DC) 100 +5 °C...+55 °C RAL 7035 1 pc(s). 7109.035 100 - 230, 1~, 50/60 24 - 60 (DC) 100 +5 °C...+55 °C RAL 9005 1 pc(s). 5302.041 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Accessories for climate control Control/regulation Thermostat Enclosure internal thermostat Particularly suitable for controlling fans, heaters and heat exchangers, this thermostat can also be used as a signal generator for monitoring the enclosure internal temperature. Accessories: – Bottom-mounted adaptor, see page 548 – Mounting plate, see page 998 Benefits: – Time-saving connection technique using a terminal strip with a screw connection from the outside – Flexible mounting on a vertical or horizontal 35 mm support rail to EN 50 022, and snap fastening in the enclosure section or on the mounting plate using the supplied adaptor Technical specifications: – Bi-metal controller as a temperature-sensitive element with thermal feedback – Contact population: Single-pole change-over contact as a quick-break contact – Permissible contact load: Category 5 – 3 (heating) AC 10 (4) A (inductive load at cos φ = 0.6)/category 5- 4 (cooling): AC 5 (4) A (inductive load at cos φ = 0.6)/DC = max. 30 W – Switching difference: approx. 1 K ± 0.8 K W x H x D mm Rated operating voltage V, ~ Setting range Packs of Model No. 71 x 71 x 33.5 24 - 230, 1~ 24 - 60 (DC) +5 °C...+60 °C 1 pc(s). 3110.000 Hygrostat Activates the heater and/or fan when a preset relative humidity in the enclosure is exceeded. This reduces the relative humidity and prevents condensation on assemblies and electronic components. Benefits: – Time-saving connection technique using a terminal strip with a screw connection from the outside – Flexible mounting on a vertical or horizontal 35 mm support rail to EN 50 022, and snap fastening in the enclosure section or on the mounting plate using the supplied adaptor WxHxD mm Rated operating voltage V, ~ Packs of Model No. 71 x 71 x 33.5 24 - 250, 1~ 24 - 75 (DC) 1 pc(s). 3118.000 Climate control Colour: – RAL 7035 Accessories: – Bottom-mounted adaptor, see page 548 – Mounting plate, see page 998 Technical specifications: – Contact population: Single-pole change-over contact as a quick-break contact – Permissible contact load: AC ~ 5 (0.2) A (inductive load at cos φ = 0.6)/DC = max. 20 W – Setting range: 50 – 100% relative humidity – Switching difference: approx. 4% Colour: – RAL 7035 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 547 Accessories for climate control Control/regulation Bottom-mounted adaptor To fit Model No. for enclosure internal thermostat and hygrostat With mounting option for screwed cable glands, for targeted cable infeed from appropriate equipment such as SK fan-and-filter units and enclosure heaters. In conjunction with screwed cable glands, it also provides strain relief. 3110.000/3118.000 Packs of Model No. 1 pc(s). 3110.200 Colour: – RAL 7035 EC speed control Control unit for EC fan Temperature-dependent speed control for EC fans to reduce noise and save energy. The function of the fan can also be monitored. Functions: – Activation and monitoring of up to 4 EC fan-andfilter units – For mounting on a 35 mm support rail EN 50 022 – External temperature sensor to record the actual temperature – Status LED to display the operating status – Alarm relay for reporting overtemperature, fan defect, cable break and sensor failure Supply includes: – Speed control – NTC sensor, length 1.80 m To fit Model No. 3240.500/3241.500/3243.500/ 3244.500/3245.XXX/3140.500/ 3140.510 Rated operating voltage V Setting range Packs of Model No. 100 - 250 +5 °C...+55 °C 1 pc(s). 3235.440 EC speed control Sensor for speed control NTC sensor for temperature-dependent speed control of EC fans to reduce noise and save energy. Activation and power supply via an EC fan-and-filter unit. Technical specifications: – Control characteristic: fixed setpoint at 35 °C, with linear control range between +35 °C (maximum speed 100%) and +20 °C (minimum speed 10%) Protection category IP to IEC 60 529: – IP 40 Supply includes: – External sensor with connection cable (length 3 m) To fit Model No. 3240.500/3241.500/ 3243.500/3244.500/ 3245.XXX/3140.500/ 3140.510 548 Rated operating voltage V Operating temperature range Packs of Model No. 10 - 12 (DC) -25 °C...+80 °C 1 pc(s). 3235.450 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Accessories for climate control Control/regulation Speed control For fan-and-filter units and air/air heat exchangers Temperature-dependent speed control to minimise noise and save energy in part-load operation. Technical specifications: – For mounting on a 35 mm support rail EN 50 022 – Phase cross-over with microcontroller – Maximum fan output 300 W or 2 A Supply includes: – Speed control – NTC sensor, length 1.80 m Note: – Only suitable for use with single-phase AC motors and equipment – Not suitable for EC motors Accessories: W x H x D mm Rated operating voltage V Setting range Packs of Model No. 105 x 90.5 x 60.2 100 - 230 +20 °C...+55 °C 1 pc(s). 3120.200 Temperature sensor for Blue e+ cooling units, Blue e+ chillers NTC sensor to regulate Blue e+ cooling units according to an individual measurement point within the enclosure (control based on an external sensor), and according to the cold air outlet from the cooling unit inside the enclosure (control based on outlet temperature). For chillers: Differential control is used if it is necessary to regulate the temperature of the medium depending on the ambient temperature (positive or negative). For this, the temperature sensor needs to be positioned near the Blue e+ chiller. Packs of Model No. 1 pc(s). 3124.400 Climate control – Mounting plate, see page 998 Supply includes: – External sensor with connection cable (length 2.5 m) Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 549 Accessories for climate control Control/regulation Master/slave cable for SK BUS system The SK BUS system allows several cooling units and air/water heat exchangers with e-Comfort controller to communicate with one another Masterslave configuration for complex bayed enclosure systems, for optimum operating results. Packs of Model No. 1 pc(s). 3124.100 Technical specifications: – The master-slave layout facilitates common activation and deactivation via door limit switches, parallel activation and deactivation via a temperature setpoint, and common collective fault signals and temperature logging, eliminating the need for intricate wiring. Supply includes: – 3 m shielded interface cable – Operating instructions on programming the cooling units Note: – nB = nK – 1 – nB: Number of order units (SK BUS system) – nK: Number of cooling units to be linked Toroidal transformer Primary connection 115 V/400 V For the power supply of wall-mounted 230 V air/ water heat exchangers. Available with 115 V or 400 V primary connection. Technical specifications: – Output 110 VA – Voltage tolerance ±10% – Primary connection 3500 mm long – Secondary connection 1500 mm long – For mounting on a 35 mm support rail EN 50 022 Supply includes: – Toroidal transformer – Assembly parts 550 To fit Model No. W x H x D mm Rated operating voltage V, ~, Hz Packs of Model No. 3363.X0X/3364.X0X/3212.230/ 3214.100/3214.700/3215.100/ 3215.700 105 x 123 x 55 400 (primary), 2~, 50/60 230 (secondary), 1~, 50/60 1 pc(s). 3201.960 3363.X0X/3364.X0X/3214.100/ 3214.700/3215.100/3215.700 105 x 123 x 55 115 (primary), 1~, 50/60 230 (secondary), 1~, 50/60 1 pc(s). 3201.970 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Industrial Internet of Things Climate control Fast, uninterrupted, automated production, from page 552 Rittal System Catalogue 36/Climate control 551 IoT interface Digitalised and networked 552 Rittal System Catalogue 36/Climate control Industrial Internet of Things ◾ Fast, uninterrupted, automated production ◾ The Industrial Internet of Things (IIoT) makes it possible. Condition monitoring for rack and process cooling ◾ In conjunction with the IoT interface, Rittal cooling solutions can now be networked and digitalised Climate control ◾ Continuous monitoring plays a key role in boosting system availability. Sensors for enclosure monitoring ◾ The use of Rittal sensors allows reliable monitoring of a wide range of switchgear parameters. ◾ Potential failures are identified early on, and operational reliability is increased Rittal Smart Service ◾ Data-based service for visualising the response of your networked cooling solutions ◾ Overview of energy and CO2 consumption ◾ Centralised detection of maintenance requirements and critical errors, including recommended actions ◾ Fast problem analysis and troubleshooting Rittal System Catalogue 36/Climate control 553 Accessories for climate control Control/regulation IoT interface The IoT interface is a central component for the intelligent networking of Rittal cooling solutions or sensors for monitoring physical ambient conditions. Equipped with a wide range of interfaces and protocols, it is used to collate and transmit data to superordinate IT systems or to systems for the local monitoring of machine statuses. Benefits: – Digitalisation and networking offer huge opportunities for every company. With the IoT interface, Rittal cooling solutions and sensors for monitoring physical ambient conditions are easily connected to Industry 4.0 environments without affecting the automation logic. – Plug and run: The IoT interface is quickly and conveniently configured and commissioned via the integral Web server, no programming required. Note: – The IoT interface is only supported by Blue e+ cooling units from firmware version 1.11.0 or above. If applicable, update the firmware using the RiDiag III software (3159.300). – To interlink cooling units in the Blue e series, the Blue e IoT adaptor (3124.310) is additionally required. Assembly – The IoT interface can be secured on a 35 x 7.5 top hat rail to DIN EN 60715 using a spring-loaded metal clip, or to the rear of a Blue e+ cooling unit using the angle bracket. Accessories: – Blue e IoT adaptor, see page 555 Material: – Plastic to UL 94-V0 Colour: – RAL 7016 Protection category IP to IEC 60 529: – IP 20 Supply includes: – IoT interface – USB cable (USB-A connector on micro-USB-B connector) – Angle bracket for Blue e+ cooling unit 554 W x H x D mm 18 x 117 x 120 For TopTherm cooling units with e-Comfort controller Blue e+ cooling units Blue e+ chillers Smart Monitoring System for NH fuse-switch disconnectors Rittal sensors Operating temperature range +0 °C...+70 °C Protocols OPC-UA/SNMPv1/SNMPv2c/SNMPv3/Modbus/TCP/TCP/IPv4/TCP/IPv6/Radius/ Telnet/SSH/FTP/SFTP/HTTP/HTTPS/NTP/DHCP/DNS/SMTP/Syslog/LDAP Interfaces 1 x Micro USB type B (device) for USB 2.0 1 x Micro-SD memory card slot for SD 2.0 1 x USB 2.0 high-speed functions (EHCI) 1 x acknowledgement button 1 x push-in spring connection terminal for NTC sensor 2 x RJ45 jack for RS 485 interface (climate control unit interface) Network interface Ethernet IPv4/IPv6 Ethernet to IEEE 802.3 via 10BASE-T, 100BASE-T and 1000BASE-T Interface bus system 2 x RJ45 CAN bus Type of electrical connection Push-in spring connection terminal (24 V DC) Weight kg 0.278 Packs of 1 pc(s). Model No. 3124.300 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Accessories for climate control Control/regulation Blue e IoT adaptor In conjunction with the IoT interface, the adaptor supports intelligent networking of cooling units in the Blue e series. Benefits: – Digitalisation and networking offer huge opportunities for every company. In conjunction with the IoT interface (3124.300), cooling units in the Blue e series are easily connected to Industry 4.0 environments without affecting the automation logic. – Plug and run: The IoT interface is quickly and conveniently configured and commissioned via the integral Web server, no programming required. – Condition monitoring of up to 10 cooling units in a master/slave arrangement Supply includes: – Blue e IoT adaptor – Installation and Short User's Guide – Mounting bracket – Assembly parts – Sub-D to RJ11 connection cable – Mounting clips for securing top-hat rails Also required: – IoT interface, see page 554 Material: – Plastic – Front: Smooth – Enclosure: Textured Climate control Colour: – Front: RAL 9005 – Enclosure: RAL 7035 Protection category IP to IEC 60 529: – IP 30 To fit Model No. 3303.5/6xx/3304.5/6xx/3305.5/6xx/3328.5/6xx/3329.5/6xx/3332.5/6xx/3361.5/ 6xx/3366.5/6xx/3377.5/6xx/3307.7xx/3310.7xx/3382.5/6xx/3359.5/6xx/3383.5/ 6xx/3273.500/3384.5/6xx/3385.5/6xx/3386.5/6xx/3387.5/6xx/9776.550 W x H x D mm 80 x 30 x 40 For TopTherm cooling units with e-Comfort controller Operating temperature range +0 °C...+55 °C Interfaces 1 x Modbus RTU 1 x cooling unit interface Weight kg 0.201 Packs of 1 pc(s). Model No. 3124.310 Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 555 Accessories for climate control Mounting accessories Trim frame for slimline cooling units Slimline cooling units can be internally or externally mounted on an enclosure door or wall. The trim frame presents a closed front for the cooling unit. To fit Model No. W x H x D mm 3366.... 448 x 1583 x 140 Packs of Model No. 1 pc(s). 3377.000 Material: – Sheet steel Supply includes: – Trim frame – Sealing and assembly parts Baying plate for VX25 Blue e+ integration solution The baying plate guarantees a protection category of IP 54 when baying the VX25 Blue e+ integration solution to a 2,000 mm high, 600 mm deep enclosure. 140 Colour: – RAL 7035 To fit Model No. W x H x D mm 3185.030 600 x 200 x 17 Packs of Model No. 1 pc(s). 3355.710 Material: – Sheet steel Colour: – Textured RAL 7035 Supply includes: – Baying plate – Cross member – Assembly parts and sealing material Quick-change frame To fit Model No. Packs of Model No. for roof-mounted cooling units The quick-change frame is more than just an alternate frame. Together with the seal, the lower part of the frame is screw-fastened to the enclosure. In this way, it is possible to install and remove the connector-ready cooling unit with the upper part of the alternate frame previously mounted on the cooling unit with quick-release fasteners. During servicing work, this means shorter assembly times and hence minimised downtime. What is more, the quickchange frame offers effective protection against the ingress of oil into the enclosure in oily atmospheres, thanks to its integral drainage trough. 3359..../3382.... 1 pc(s). 3286.700 3209..../3210..../3383..../ 3384..../3385.... 1 pc(s). 3286.800 3386..../3387.... 1 pc(s). 3286.900 Material: – Sheet steel Colour: – RAL 7035 Supply includes: – Quick-change frame – Seal – Quick-release fasteners 556 Further technical information available on the Internet. Rittal System Catalogue 36/Climate control Accessories for climate control Mounting accessories Guide frame for Vario rack-mounted fan To fit Model No. 3350.230/3351.230/ 3352.230 3352.500 Suitable for rated operating voltage Length of connection cable m Packs of Model No. 115 V, 50/60 Hz 230 V, 50/60 Hz 3 1 pc(s). 3355.100 24 V DC 115 - 230 V 3 1 pc(s). 3357.100 Display frame for Blue e+ roof-mounted cooling unit and VX25 Blue e+ integration solution The display frame allows the touch display of the roof-mounted cooling unit Blue e+ or the VX25 Blue e+ integration solution to be positioned in the enclosure door. To fit Model No. W x H x D mm Packs of Model No. 3185.030/ 3185.730 316 x 118 x 27.5 1 pc(s). 3355.700 Climate control Supply includes: – Guide frame – Connector and fitted connection cable – Mounting bracket for optional attachment to the 482.6 mm (19") mounting level – Assembly parts Benefits: – For positioning the display at the optimum operator height Material: – Plastic Colour: – RAL 7016 Protection category IP to IEC 60 529: – IP 54 Supply includes: – Display frame – Blanking cover – RJ 12 extension cable (3 m) – Assembly parts and sealing material Rittal System Catalogue 36/Climate control Further technical information available on the Internet. 557 Climate control software Configurators/tools/CAD data Climate control The optimum design, control and monitoring of the installation are crucial to efficient climate control. We support you with user-friendly tools and software for rapid calculation, plus Web-based tools and interfaces to easily control your climate control solution. Chiller configurator The chiller configurator is the cost-effective way to design your required machine and process cooling. Cooling output, volumetric flow and refrigerant temperatures are precisely tailored to your required application. Benefits: – Calculate the heat loss, either mathematically or manually – Comprehensive range of accessories – Drawings downloadable in dwg, pdf, or 3D pdf format – Downloadable specifications/tender texts – Interactive performance diagram: cooling output and pump output – Add option packages and download bill of materials – Transfer order list to shopping basket – Send a quote request Note: – Configure online at www.rittal.com/configurators Chiller app The Rittal Chiller app allows users to make their selections from a mobile device. Alongside the existing online version of the chiller configurator, the app also supports automated calculation of the required cooling output. The matching chiller may be selected interactively in just four steps, with outputs ranging from 1 to 40 kW. Note: – Download free from the App Store iPhone app Therm software Precise, efficient climate control Therm undertakes the time-consuming calculation of the required cooling output and selects suitable products. The calculation provides you with detailed documentation for maximum peace of mind when designing the optimum climate control. Therm is based on the requirements of IEC/TR3 60890 AMD 1 and DIN 3168 for enclosure cooling units. The overtemperature to DIN 61439 is calculated with a single click. Benefits: – Fast, thorough determination of the required climate control measures – Identification of the correct climate control measures can cut costs – Easy calculation of the required actual cooling output, as well as any upgrades or enhancements to the switchgear – Detailed documentation is supplied with the calculation Note: – Configure online at www.rittal.com/software Therm app Note: – Downloaded free from the App Store and from the Google Play Store Android app 558 Further technical information available on the Internet. iPhone app Rittal System Catalogue 36/Climate control Climate control software Configurators/tools/CAD data RiDiag II Packs of Model No. For the diagnosis, maintenance and long-term data capture of TopTherm units with e-Comfort controller. RiDiag logs equipment data and prepares an error list. RiDiag also offers the option of displaying and setting the device's operating parameters. Logged measurement data can be tracked in real time in the form of a diagram. 1 pc(s). 3159.100 Note: – Download free at www.rittal.com/software RiDiag III The following functions may be used in the device and efficiency cockpit: – Quick analysis and setting of all parameters – Display configuration: e.g. NFC, language, PIN – Reading of historical data from the last two years1) – Creation of service enquiries and selection of spare parts – Software and firmware updates for devices Blue e+ app The Blue e+ app supports the contactless exchange of information as well as quick on-site analysis via the NFC interface. Benefits: – Saves time when reading the units – Limit access by requesting a PIN (PIN of cooling unit) – Superior operational reliability, thanks to improved fault and maintenance management – Identical displays and menu prompting as on the Blue e+ device display – Direct link to Rittal Service – Simply send repair, maintenance and spare parts enquiries from your smartphone Rittal System Catalogue 36/Climate control Model No. 1)This additional function can be enabled with a chargeable licence 3159.300 Note: – Download RiDiag III for free at www.rittal.com/ software Climate control Diagnosis software for the analysis and parameterisation of cooling units and chillers in the Blue e+ series. Note: – Download for free from the Google Play Store Android app Further technical information available on the Internet. 559 Boosting efficiency through automation Rittal has all the machines and devices you need – The Rittal Automation Systems division can supply everything you need to make panel building and switchgear manufacturing easier, faster, more accurate and more reproducible through automation. This allows you to link all work operations together into one highly efficient, digitally seamless, automated process. Manual handling aids and a wide selection of hand tools are available from a single source and can be ordered directly from Rittal. Further information, machines and devices can be found in the brochure “Rittal Automation Systems – Automate your panel building and switchgear manufacturing”. 560 Rittal System Catalogue 36/Rittal Automation Systems Manufacturing RITTAL AUTOMATION SYSTEMS Tools Tool bag .....................................................................................................565 Screwdrivers...............................................................................................566 Hex wrenches.............................................................................................570 Bits and bit holders.....................................................................................571 Crimping pliers............................................................................................574 Wire end ferrules.........................................................................................578 Insulation stripping tools .............................................................................583 Cutting tools ...............................................................................................585 Pliers ..........................................................................................................587 Mechanical tools.........................................................................................590 Hole punching tools....................................................................................592 Wiring duct cutter MC 125..........................................................................604 Support rail cutter MC3 ..............................................................................605 Handling Assembly frame..........................................................................................606 Accessories for assembly frame .................................................................608 Storage and transport trolley LT 1000.........................................................611 Functional trolley.........................................................................................612 Smart Lifter.................................................................................................614 Wire Station WS 540 ..................................................................................618 Accessories for Wire Station WS 540..........................................................621 Wire processing and wiring Length-cutting machine C8+ ......................................................................632 Stripping machine S22 ...............................................................................633 Crimping machine R8 E ..............................................................................634 Crimping machine L8..................................................................................635 Crimping machine RC.................................................................................636 Accessories for wire processing machines..................................................637 Machining Automation Systems Busbar machining, static CW 120-S ...........................................................638 Busbar machining, mobile CW 120-M ........................................................639 Accessories for busbar machining CW 120 ................................................643 Machines for machining, wire processing and assembly Cutting centre Secarex AC 18 ....................................................................650 Milling centre Perforex BC ..........................................................................652 Laser centre Perforex LC ............................................................................654 Fully automated wire processing machine Wire Terminal WT ......................656 Terminal block assembly centre Athex TC 80 CS........................................658 Rittal System Catalogue 36/Rittal Automation Systems 561 Harness your potential for greater productivity Rittal offers quality tools made from high-quality materials and semi-automated machines for wire assembly and copper processing for professional industry use. Ergonomic, efficient handling systems for transport and lifting operations round out our standard portfolio. We can supply all the machining and handling technology you need for time-saving and cost-cutting manufacturing processes, all from a single source. 562 Rittal System Catalogue 36/Rittal Automation Systems Perfecting the hand tool High-quality hand tools for professional use in industry and trade, from page 565 Simplify handling Ergonomic, efficient handling systems for transport and lifting operations, from page 606 Systematise wire processing Professional, rational solutions for manual wire machining and processing Crimping tools, from page 574 Semi-automatic machines, from page 632 Streamline wiring To complete the process chain, Rittal Automation Systems are involved in Automation Systems developing pioneering wiring solutions, right through to full automation. Automate machining Fully automated milling or laser machining, plus machining of cable ducts and busbars Busbar machining, from page 638 Make component mounting more flexible Automatic manufacturing and component mounting of terminal strips, from page 658 Rittal System Catalogue 36/Rittal Automation Systems 563 The right tool for every application! All from a single source – Rittal offers a comprehensive range of hand-held tools for professional support with your work operations. All the machining and handling technology you need for timesaving and cost-cutting manufacturing processes, all from a single source. ◾ Screwdrivers, insulated ◾ Screwdrivers, uninsulated ◾ Tools for cable processing ◾ Pliers ◾ Cutting tools ◾ Bits ◾ Bit holders 564 ◾ Manual and electric hand-held hydraulic punches Further technical information available on the Internet. ◾ Hole punches Rittal System Catalogue 36/Rittal Automation Systems Tool bag Tool bag Configured Configured tool bag comprising a selected range of Rittal hand tools, designed especially for electricians. The practical, high-quality shoulder bag may be used either as a tool bag or laptop case. Design: – 19 separate compartments for tools – Cushioned compartment for laptop or tablet – Document wallet – Two additional storage pockets inside Benefits: – Careful storage – Shoulder pad for comfortable carrying – Flexible use Width mm Height mm Depth mm Packs of Model No. 420 340 190 1 pc(s). 4053.500 Width mm Height mm Depth mm Packs of Model No. 420 340 190 1 pc(s). 4053.000 Automation Systems Material: – Polyester Supply includes: – Screwdriver, insulated SL 3.5 x 0.6 (Model No.: 4052.102), SL 6 x 1.2 (Model No.: 4052.107), PZ 2 (Model No.: 4052.122) – Screwdriver, non-insulated PZ 2 (Model No.: 4052.022), SL 6 x 1.2 (Model No.: 4052.011), TX 20 (Model No.: 4052.055), TX 25 (Model No.: 4052.056), TX 30 (Model No.: 4052.058) – Bit holder with handle, magnetic (Model No.: 4053.300) – Bit set with bit holder, 7-piece (Model No.: 4053.420) – Crimping pliers for wire end ferrules, for cross-section 0.5 - 6 mm², square crimp (Model No.: 4054.001) – Wire stripper for wire end ferrules, for cross-section 0.02 - 11 mm² (Model No.: 4054.300) – Stripping tools for cables Ø 2.5 - 11 mm (Model No.: 4054.400), for cables Ø 8 - 13 mm (Model No.: 4054.405) – Side cutter for cables Ø 0.2 - 11 mm (Model No.: 4054.600) – Electrician’s scissors for cables Ø 0.1 - 3.7 mm (Model No.: 4054.700) – Combination pliers with insulated handle (Model No.: 4054.800) – Needle-nose pliers with insulated handle (Model No.: 4054.850) – Tool bag (Model No.: 4053.000) Tool bag Unconfigured The practical, high-quality shoulder bag may be used either as a tool bag or laptop case. Design: – 19 separate compartments for tools – Cushioned compartment for laptop or tablet – Document wallet – Two additional storage pockets inside Benefits: – Careful storage – Shoulder pad for comfortable carrying – Flexible use Material: – Polyester Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 565 Screwdrivers Screwdrivers insulated With a long, slender handle and high-performance tip with non-transfer insulation. Design: – Isolation protection 1000 V Benefits: – Minimal force required, thanks to ergonomically styled handle – Handle head with anti-roll protection and clear screw labelling – Black coated blade tip to preserve precision and accuracy of fit – Handle 30% and insulation up to 50% slimmer than comparable tools – Optimum interconnection of hand and handle supports higher torques and longer, fatigue-free working Material: – Blade: Chrome-molybdenum-vanadium alloy – Handle core: Hard plastic – Handle body: Elastic, highly flexible plastic Colour: – Handle: Anthracite and Rittal Power Pink Standards: – IEC 60 900 Approvals: – VDE – TÜV-tested safety For slot-head screws Blade (width x thickness) mm Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. SL 3 x 0.5 100 3.5 105 25 1 pc(s). 4052.101 SL 3.5 x 0.6 100 3.5 105 25 1 pc(s). 4052.102 SL 4 x 0.8 100 4 105 25 1 pc(s). 4052.104 SL 5.5 x 1 125 5.5 115 27 1 pc(s). 4052.106 SL 6.5 x 1.2 125 6.5 115 27 1 pc(s). 4052.107 Blade tip For Pozidriv screws Blade tip Blade (width x thickness) Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. PZ 1 – 80 4.5 105 25 1 pc(s). 4052.121 PZ 2 – 100 6 115 27 1 pc(s). 4052.122 Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. For Phillips-head screws Blade tip Blade (width x thickness) PH 1 – 80 4.5 105 25 1 pc(s). 4052.131 PH 2 – 100 6 115 27 1 pc(s). 4052.132 Blade (width x thickness) Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. For plus/minus Blade tip 566 Z1 – 80 4.5 105 25 1 pc(s). 4052.141 Z2 – 100 6 115 27 1 pc(s). 4052.142 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Screwdrivers Screwdriver set Blade tip Packs of Model No. insulated Multi-part screwdriver set. With a long, slender handle and high-performance tips with non-transfer insulation. SL 3 x 0.5 mm SL 4 x 0.8 mm SL 5.5 x 1 mm PH 1 PH 2 1 pc(s). 4052.210 Design: – Isolation protection 1000 V SL 3 x 0.5 mm SL 4 x 0.8 mm SL 5.5 x 1 mm PZ 1 PZ 2 1 pc(s). 4052.211 SL 3 x 0.5 mm SL 4 x 0.8 mm PH 1 PH 2 Z2 1 pc(s). 4052.212 Benefits: – Minimal force required, thanks to ergonomically styled handle – Handle head with anti-roll protection and clear screw labelling – Black coated blade tip to preserve precision and accuracy of fit – Handle 30% and insulation up to 50% slimmer than comparable tools Material: – Blade: Chrome-molybdenum-vanadium alloy – Handle core: Hard plastic – Handle body: Elastic, highly flexible plastic Colour: – Handle: Anthracite and Rittal Power Pink Supply includes: – Set with 5 screwdrivers Standards: – IEC 60 900 Automation Systems Approvals: – VDE – TÜV-tested safety Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 567 Screwdrivers Screwdrivers uninsulated Ergonomic screwdriver which adapts perfectly to the hand, thereby minimising the force required. Benefits: – Handle head with anti-roll protection and clear screw labelling – Black coated blade tip to preserve precision and accuracy of fit – Optimum interconnection of hand and handle supports higher torques and longer, fatigue-free working Material: – Blade: Chrome-molybdenum-vanadium alloy – Handle core: Hard plastic – Handle body: Elastic, highly flexible plastic Colour: – Handle: Anthracite and Rittal Power Pink Approvals: – TÜV-tested safety For slot-head screws Blade tip Blade (width x thickness) mm SL SL Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. 2.5 x 0.4 75 2.5 86 25 1 pc(s). 4052.001 3.5 x 0.6 100 3.5 86 25 1 pc(s). 4052.003 SL 4 x 0.8 100 4 94 30 1 pc(s). 4052.004 SL 5.5 x 1 150 5 101 33 1 pc(s). 4052.007 SL 6.5 x 1.2 150 6 106 36 1 pc(s). 4052.011 SL 8 x 1.2 175 7 112 39 1 pc(s). 4052.014 SL 5.5 x 1 25 5 60 21 1 pc(s). 4052.018 Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. For Pozidriv screws Blade tip Blade (width x thickness) PZ 1 – 80 4.5 94 30 1 pc(s). 4052.021 PZ 2 – 100 6 106 36 1 pc(s). 4052.022 For Phillips-head screws Blade tip Blade (width x thickness) Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. PH 1 – 80 4.5 94 30 1 pc(s). 4052.031 PH 2 – 100 6 106 36 1 pc(s). 4052.032 PH 2 – 25 6 60 21 1 pc(s). 4052.038 For multi-tooth screws 568 Blade tip Blade (width x thickness) Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. TX 10 – 100 3.5 86 25 1 pc(s). 4052.053 TX 15 – 100 4 94 30 1 pc(s). 4052.054 TX 20 – 100 5 101 33 1 pc(s). 4052.055 TX 25 – 100 5 106 36 1 pc(s). 4052.056 TX 30 – 115 6 112 39 1 pc(s). 4052.058 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Screwdrivers Screwdriver set uninsulated Multi-part screwdriver set. Benefits: – Minimal force required, thanks to ergonomically styled handle – Handle head with anti-roll protection and clear screw labelling – Black coated blade tip to preserve precision and accuracy of fit Material: – Blade: Chrome-molybdenum-vanadium alloy – Handle core: Hard plastic – Handle body: Elastic, highly flexible plastic Colour: – Handle: Anthracite and Rittal Power Pink Productspecific scope Packs of Model No. of supply Blade tip SL 3.5 x 0.6 mm SL 6.5 x 1.2 mm PZ 1 PZ 2 PH 1 PH 2 6-part set 1 pc(s). 4052.200 PH 1 PH 2 TX 15 TX 20 TX 25 TX 30 6-part set 1 pc(s). 4052.201 TX 10 TX 15 TX 20 TX 25 TX 30 5-part set 1 pc(s). 4052.202 Interchangeable screwdriver set uninsulated 13-piece tool set with comfortable, foldable, lockable handle. Blade length mm Handle length mm Handle dia. mm Packs of Model No. 160 105 39 1 pc(s). 4053.450 Automation Systems Approvals: – TÜV-tested safety Technical specifications: – PH 1 - SL 4 x 0.8 mm – PH 2 - PH 3 – PZ 1 - SL 5 x 0.8 mm – PZ 2 - SL 6 x 1 mm – PZ 3 - SL 7 x 1.2 mm – TX 6 - TX 7 – TX 8 - TX 9 – TX 10 - TX 15 – TX 20 - TX 25 – TX 30 - TX 40 – Hex socket 3 mm - hex socket 4 mm – Hex socket 5 mm - hex socket 6 mm Material: – Blade: Chrome-molybdenum-vanadium alloy – Handle core: Hard plastic – Handle body: Elastic, highly flexible plastic Colour: – Handle: Anthracite and Rittal Power Pink Supply includes: – Combined blade holder: Screwdriver and T handle – 12 blades each with 2 tips – Storage box Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 569 Hex wrenches Hex wrench set for Allen screws Hex wrench with optimum, narrow-tolerance hexagonal profiles and precise ballhead geometry. The extra-long design achieves a greater leverage effect. Packs of Model No. 1 pc(s). 4052.480 Benefits: – Up to 30% more corrosion resistance – Optimum hardness and elasticity – Intensive leverage effect – Special geometry in the critical zone Technical specifications: – For hex socket: 1.27 - 1.5 - 2.0 - 2.5 - 3.0 - 3.5 4.0 - 4.5 - 5.0 - 5.5 - 6.0 - 7.0 - 8.0 - 9.0 10.0 mm Supply includes: – 15 hex wrenches – Storage box 570 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Bits and bit holders Industrial bit for cordless screwdrivers with long shaft Precisely manufactured screwdriver with a long shaft for industrial use. Benefits: – Maximum hardness and torque values Technical specifications: – Tool adaptation E 6.3 (¼") Material: – High-quality special tool steel For slot-head screws Blade tip Blade (width x thickness) mm SL 3.5 x 0.6 73 SL 4 x 0.8 73 Blade tip Blade (width x thickness) Length mm PZ 1 – 73 PZ 2 – Blade tip Length mm Blade dia. mm Packs of Model No. 6.3 3 pc(s). 4053.002 6.3 3 pc(s). 4053.003 Blade dia. mm Packs of Model No. 6.3 3 pc(s). 4053.011 73 6.3 3 pc(s). 4053.012 Blade (width x thickness) Length mm Blade dia. mm Packs of Model No. PH 1 – 73 6.3 3 pc(s). 4053.021 PH 2 – 73 6.3 3 pc(s). 4053.022 Blade tip Blade (width x thickness) Length mm Blade dia. mm Packs of Model No. Z1 – 73 6.3 3 pc(s). 4053.031 Z2 – 73 6.3 3 pc(s). 4053.032 Blade tip Blade (width x thickness) Length mm Blade dia. mm Packs of Model No. TX 10 – 73 6.3 3 pc(s). 4053.041 TX 15 – 73 6.3 3 pc(s). 4053.042 TX 20 – 73 6.3 3 pc(s). 4053.043 TX 25 – 73 6.3 3 pc(s). 4053.044 TX 27 – 73 6.3 3 pc(s). 4053.045 TX 30 – 73 6.3 3 pc(s). 4053.046 TX 40 – 73 6.3 3 pc(s). 4053.047 For Pozidriv screws Automation Systems For Phillips-head screws For plus/minus For multi-tooth screws Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 571 Bits and bit holders Industrial bit set for cordless screwdriver with long shaft Precisely manufactured screwdriver with a long shaft for industrial use. Benefits: – Robust viewing box – Secure storage Technical specifications: – Tool adaptation E 6.3 (¼") Material: – High-quality special tool steel Blade tip Length mm Packs of Model No. SL 3.5 x 0.6 mm SL 4 x 0.8 mm SL 5.5 x 1 mm PH 1 PH 2 PZ 2 73 1 pc(s). 4053.400 TX 10 TX 15 TX 20 TX 25 TX 30 TX 40 73 1 pc(s). 4053.410 Blade tip Length mm Packs of Model No. TX 25 TX 30 TX 40 PH 1 PH 2 PH 3 25 1 pc(s). 4053.420 Supply includes: – Set with 6 bits – Viewing box Bit set with bit holder 7-piece bit set with a practical assortment of quality bits with a short shaft and magnetic holder. Benefits: – One-handed operation – Function as auxiliary screwdriver Technical specifications: – Tool adaptation C 6.3 (¼") Supply includes: – Set with 6 bits – Bit holder Bit holder with handle, magnetic Ergonomic, adaptable bit holder with handle. Benefits: – Extra-strong magnet for optimum retention force – Precise concentricity – Handle for anti-roll protection Technical specifications: – Tool adaptation C 6.3 (¼") – Tool adaptation E 6.3 (¼") Material: – Handle core: Hard plastic – Handle body: Elastic, highly flexible plastic Colour: – Handle: Anthracite and Rittal Power Pink 572 Blade length mm Blade dia. mm Handle length mm Handle dia. mm Packs of Model No. 100 6.3 101 33 1 pc(s). 4053.300 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Bits and bit holders Bit holder magnetic Magnetic holder with hex drive to hold bits securely. Blade length mm Blade dia. mm Packs of Model No. 47 6.3 1 pc(s). 4053.310 Benefits: – Extra-strong magnet for optimum retention force – Precise concentricity Technical specifications: – Tool adaptation E 6.3 (¼") Automation Systems Material: – High-quality special tool steel Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 573 Crimping pliers Flex crimping tool for wire end ferrules For use with wire end ferrules with no insulating collar to DIN 46228, Part 1 and wire end ferrules with insulating collar to DIN 46228, Part 4. Benefits: – Front or side accommodation of the wire end ferrule with a rotatable head – Minimal effort required with large conductor cross-sections – Uniformly high quality compression – Releasable ratchet – Self-adjusting Material: – High-quality special tool steel Surface finish: – Coated, black, matt Colour: – Handle: Anthracite and Rittal Power Pink Accessories: – Wire end ferrules, see page 581 For cross-section mm² AWG Direction of cable entry Compression Length mm Design Packs of Model No. 0.14 - 10 26 - 8 front and side Trapezoid crimp 180 Straight 1 pc(s). 4054.030 Length mm Design Packs of Model No. Crimping pliers for wire end ferrules For use with wire end ferrules with no insulating collar to DIN 46228, Part 1 and wire end ferrules with insulating collar to DIN 46228, Part 4. Benefits: – Minimal effort required with large conductor cross-sections – Uniformly high quality compression – Releasable ratchet – Self-adjusting Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink Accessories: – Wire end ferrules, see page 581 For cross-section mm² 574 AWG Direction of cable entry Compression 0.14 - 10 26 - 8 Side Square crimp 176 Straight 1 pc(s). 4054.002 0.14 - 10 26 - 8 Side Hexagonal crimp 176 Straight 1 pc(s). 4054.003 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Crimping pliers Crimping pliers for wire end ferrules For use with wire end ferrules with no insulating collar to DIN 46228 Part 1 and wire end ferrules with insulating collar to DIN 46228 Part 4. Benefits: – Minimal effort required with large conductor cross-sections – Uniformly high quality compression – Marked die stations for precise machining of the relevant cross-sections – Releasable ratchet Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink Accessories: – Wire end ferrules, see page 581 For cross-section mm² AWG Direction of cable entry Compression Length mm Design Packs of Model No. 24 - 10 Side Trapezoid crimp 198 Angled 1 pc(s). 4054.000 0.5 - 6 22 - 10 Front Square crimp 198 Angled 1 pc(s). 4054.001 10 - 25 8-4 Side WM crimp 256 Straight 1 pc(s). 4054.004 35 - 50 2-1 Side WM crimp 256 Straight 1 pc(s). 4054.008 Automation Systems 0.25 - 6 Crimping pliers for crimp tab terminals For use with non-insulated crimp tab terminals. Benefits: – Releasable ratchet – Marked die stations for precise machining of the relevant cross-sections Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink For cross-section mm² AWG Compression Length mm Design Packs of Model No. 0.1 - 1.5 26 - 16 B-crimp 198 Angled 1 pc(s). 4054.080 0.5 - 6 22 - 10 B-crimp 256 Straight 1 pc(s). 4054.081 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 575 Crimping pliers Crimping pliers for ring terminals For use with non-insulated ring terminals. Benefits: – Releasable ratchet – Optimised lever transmission means that only minimal actuator forces are required, even with large cross-sections Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink 576 For cross-section mm² AWG Compression Length mm Design Packs of Model No. 0.5 - 2.5 20 - 14 Indent crimp 198 Angled 1 pc(s). 4054.020 0.35 - 6 22 - 10 Indent crimp 198 Angled 1 pc(s). 4054.021 4 - 10 12 - 8 Double-indent crimp 256 Straight 1 pc(s). 4054.023 10 - 25 8-4 Indent crimp 256 Straight 1 pc(s). 4054.024 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Crimping pliers Crimping pliers for ring terminals For use with insulated ring terminals and connectors. Benefits: – Clear allocation of cross-sections, thanks to colour coding on the dies – Releasable ratchet – Releases as soon as the required pressure is reached, to prevent underpressing Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink For cross-section mm² Compression Length mm 0.75 - 2.5 22 - 14 Oval crimp 198 0.75 - 6 22 - 10 Oval crimp 256 Design Packs of Model No. Angled 1 pc(s). 4054.140 Straight 1 pc(s). 4054.141 Automation Systems AWG Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 577 Wire end ferrules Wire end ferrules C on a reel With plastic collar. Technical specifications: – Heat-resistant to 105 °C Material: – E-Cu, galvanic tin-plated – Plastic collar: Polypropylene A Note: – UL-certified in conjunction with the relevant tools, such as crimping machines. B Standards: – AEH DIN 46228 A: Length B: Cross-section C: Internal diameter Approvals: – Available on the Internet For cross-section 0.5 mm², delivery form: on a reel Model No. 4051.540 4051.597 4051.548 4050.746 4051.536 4051.598 Packs of 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). For Crimping machine RC Crimping machine R8 Crimping machine RC Crimping machine R8 Crimping machine R8 E Crimping machine RC Crimping machine R8 Crimping machine RC Crimping machine R8 Crimping machine R8 E Crimping machine RC Crimping machine RC For crosssection mm² 0.5 0.5 0.5 0.5 0.5 0.5 AWG 20 20 20 20 20 20 Length mm 8 8 8 8 10 10 Internal diameter mm 2.9 2.6 2.9 2.6 2.9 2.6 Colour Orange Orange White White Orange Orange DIN colour code – – ◾ ◾ – – Rittal colour code ◾ ◾ – – ◾ ◾ Multiple colour codes supported ◾ – ◾ – ◾ – For cross-section 0.5 - 0.75 mm², delivery form: on a reel 578 Model No. 4051.544 4051.695 4051.549 4050.747 4051.541 4051.599 Packs of 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). For Crimping machine RC Crimping machine RC Crimping machine RC Crimping machine R8 Crimping machine RC Crimping machine R8 Crimping machine R8 E Crimping machine RC Crimping machine R8 Crimping machine RC Crimping machine R8 Crimping machine R8 E For crosssection mm² 0.5 0.5 0.75 0.75 0.75 0.75 AWG 20 20 18 18 18 18 Length mm 10 10 8 8 8 8 Internal diameter mm 2.9 2.6 3.4 2.8 3.4 2.8 Colour White White Grey Grey White White DIN colour code ◾ ◾ ◾ ◾ – – Rittal colour code – – – – ◾ ◾ Multiple colour codes supported ◾ – ◾ – ◾ – Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Wire end ferrules For cross-section 0.75 mm², delivery form: on a reel Model No. 4051.545 4051.696 4051.537 4051.600 Packs of 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). For Crimping machine RC Crimping machine RC Crimping machine RC Crimping machine RC For cross-section mm² 0.75 0.75 0.75 0.75 AWG 18 18 18 18 Length mm 10 10 10 10 Internal diameter mm 3.4 2.8 3.4 2.8 White Colour Grey Grey White DIN colour code ◾ ◾ – – Rittal colour code – – ◾ ◾ Multiple colour codes supported ◾ – ◾ – Model No. 4051.542 4051.601 4051.550 4050.748 4051.538 4051.602 Packs of 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). For Crimping machine RC Crimping machine R8 Crimping machine RC Crimping machine R8 Crimping machine R8 E Crimping machine RC Crimping machine R8 Crimping machine RC Crimping machine R8 Crimping machine R8 E Crimping machine RC Crimping machine RC For cross-section mm² 1 1 1 1 1 1 AWG 18 18 18 18 18 18 10 Length mm 8 8 8 8 10 Internal diameter mm 3.5 3 3.5 3 3.5 3 Colour Yellow Yellow Red Red Yellow Yellow DIN colour code – – ◾ ◾ – – Rittal colour code ◾ ◾ – – ◾ ◾ Multiple colour codes supported ◾ – ◾ – ◾ – Automation Systems For cross-section 1 mm², delivery form: on a reel For cross-section 1 - 1.5 mm², delivery form: on a reel Model No. 4051.546 4051.697 4051.543 4051.603 4051.551 4050.749 Packs of 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). Crimping machine RC Crimping machine RC Crimping machine R8 Crimping machine RC Crimping machine R8 Crimping machine R8 E Crimping machine RC Crimping machine R8 Crimping machine RC Crimping machine R8 Crimping machine R8 E For Crimping machine RC For cross-section mm² 1 1 1.5 1.5 1.5 1.5 AWG 18 18 16 16 16 16 Length mm 10 10 8 8 8 8 Internal diameter mm 3.5 3 4 3.5 4 3.5 Colour Red Red Red Red Black Black DIN colour code ◾ ◾ – – ◾ ◾ Rittal colour code – – ◾ ◾ – – Multiple colour codes supported ◾ – ◾ – ◾ – Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 579 Wire end ferrules For cross-section 1.5 mm², delivery form: on a reel Model No. 4051.539 4051.604 4051.547 4051.698 Packs of 4000 pc(s). 5000 pc(s). 4000 pc(s). 5000 pc(s). Crimping machine RC For Crimping machine RC Crimping machine RC Crimping machine RC For cross-section mm² 1.5 1.5 1.5 1.5 AWG 16 16 16 16 Length mm 10 10 10 10 Internal diameter mm 4 3.5 4 3.5 Colour Red Red Black Black DIN colour code – – ◾ ◾ Rittal colour code ◾ ◾ – – Multiple colour codes supported ◾ – ◾ – For cross-section 2.5 mm², delivery form: on a reel 580 Model No. 4050.750 4051.605 Packs of 3000 pc(s). 3000 pc(s). For Crimping machine RC Crimping machine R8 Crimping machine R8 E Crimping machine RC For cross-section mm² 2.5 2.5 AWG 14 14 Length mm 8 10 Internal diameter mm 4.2 4.2 Blue Colour Blue DIN colour code ◾ ◾ Rittal colour code ◾ ◾ Multiple colour codes supported ◾ ◾ Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Wire end ferrules Wire end ferrules C loose With plastic collar. Technical specifications: – Heat-resistant to 105 °C Material: – E-Cu, galvanic tin-plated – Plastic collar: Polypropylene Note: – UL-certified in conjunction with the relevant tools, such as crimping machines. Standards: – AEH DIN 46228 A B A: Length B: Cross-section C: Internal diameter Approvals: – Available on the Internet Model No. 4050.752 4050.754 4050.757 4050.760 4050.730 4050.742 4050.761 Packs of 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). Crimping machine L8 manual wire processing Crimping machine L8 manual wire processing manual wire processing For manual wire processing manual wire processing manual wire processing Crimping machine L8 manual wire processing For crosssection mm² 0.14 0.25 0.34 0.5 0.5 0.5 0.5 AWG 26 24 22 20 20 20 20 Length mm 8 8 8 8 8 8 10 Internal diameter mm 1.5 1.8 2 2.6 2.6 2.9 2.6 Colour Grey Light blue Turquoise Orange White White Orange DIN colour code – – – – ◾ ◾ – Rittal colour code ◾ ◾ ◾ ◾ – – ◾ Automation Systems For cross-section 0.14 - 0.5 mm², delivery form: loose For cross-section 0.75 - 1 mm², delivery form: loose Model No. 4050.731 4050.743 4050.764 4050.766 4050.769 4050.732 4050.744 Packs of 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). For Crimping machine L8 manual wire processing Crimping machine L8 manual wire processing Crimping machine L8 manual wire processing manual wire processing Crimping machine L8 manual wire processing Crimping machine L8 manual wire processing Crimping machine L8 manual wire processing For crosssection mm² 0.75 0.75 0.75 0.75 1 1 1 AWG 18 18 18 18 18 18 18 Length mm 8 8 8 10 8 8 8 Internal diameter mm 2.8 3.4 2.8 2.8 3 3 3.5 Colour Grey Grey White White Yellow Red Red DIN colour code ◾ ◾ – – – ◾ ◾ Rittal colour code – – ◾ ◾ ◾ – – Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 581 Wire end ferrules For cross-section 1 - 2.5 mm², delivery form: loose Model No. 4050.770 4050.773 4050.733 4050.745 4050.774 4050.734 4050.779 Packs of 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). 500 pc(s). For manual wire processing Crimping machine L8 manual wire processing Crimping machine L8 manual wire processing Crimping machine L8 manual wire processing manual wire processing Crimping machine L8 manual wire processing manual wire processing For crosssection mm² 1 1.5 1.5 1.5 1.5 2.5 2.5 AWG 18 16 16 16 16 14 14 Length mm 10 8 8 8 10 8 10 Internal diameter mm 3 3.5 3.5 4 3.5 4.2 4.2 Colour Yellow Red Black Black Red Blue Blue DIN colour code – – ◾ ◾ – ◾ – Rittal colour code ◾ ◾ – – ◾ ◾ ◾ For cross-section 4 - 6 mm², delivery form: loose Model No. 4050.782 4050.735 4050.783 4050.736 Packs of 500 pc(s). 500 pc(s). 500 pc(s). 100 pc(s). 4050.785 100 pc(s). For manual wire processing manual wire processing manual wire processing manual wire processing manual wire processing For cross-section mm² 4 4 4 6 6 AWG 12 12 12 10 10 Length mm 8 10 12 12 12 Internal diameter mm 4.8 4.8 4.8 6.3 6.3 Colour Grey Grey Grey Yellow Black DIN colour code – – ◾ ◾ – Rittal colour code ◾ ◾ – – ◾ For cross-section 0.5 - 1 mm², delivery form: loose (10 packs of 100) Model No. 4051.638 4050.737 4051.641 4050.738 4051.644 4050.739 Packs of 1000 pc(s). 1000 pc(s). 1000 pc(s). 1000 pc(s). 1000 pc(s). 1000 pc(s). For manual wire processing manual wire processing manual wire processing manual wire processing manual wire processing manual wire processing For cross-section mm² 0.5 0.5 0.75 0.75 1 1 AWG 20 20 18 18 18 18 Length mm 10 12 10 12 10 12 Internal diameter mm 2.6 2.6 2.8 2.8 3 3 Colour White White Grey Grey Red Red DIN colour code ◾ ◾ ◾ ◾ ◾ ◾ Rittal colour code – – – – – – For cross-section 1.5 - 2.5 mm², delivery form: loose (10 packs of 100) Model No. 4051.647 4050.740 4051.525 4050.741 Packs of 1000 pc(s). 1000 pc(s). 1000 pc(s). 1000 pc(s). For 582 manual wire processing manual wire processing manual wire processing manual wire processing For cross-section mm² 1.5 1.5 2.5 2.5 AWG 16 16 14 14 Length mm 10 12 10 12 Internal diameter mm 3.5 3.5 4.2 4.2 Colour Black Black Blue Blue DIN colour code ◾ ◾ ◾ ◾ Rittal colour code – – – – Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Insulation stripping tools Wire stripper For stripping cables and conductors. Self-adjusting, with ergonomically styled handle, replaceable insulation stripping blade. Benefits: – Flexible end stop for the insulation stripping length – Practical integrated wire cutter – Automatic adjustment mechanism for a wide range of insulations and conductor diameters – Dies compatible with all types of pliers, may be replaced in a few actions – Two-component handle with anti-slip soft zone Colour: – Handle: Anthracite and Rittal Power Pink Accessories: For cross-section mm² AWG Length mm 0.02 - 10 34 - 8 191 – 0.02 - 10 34 - 8 168 Angled Design Note Packs of Model No. – 1 pc(s). 4054.300 – 1 pc(s). 4054.315 1 pc(s). 4054.310 1 pc(s). 4054.305 0.1 - 4 28 - 12 191 – Also suitable for rubber and silicone insulation 4 - 16 12 - 5 191 – – Stripping tool for cables Ø 2.5 - 11 mm For stripping installation cables and wires. For cable diameters mm Length mm Packs of Model No. 2.5 - 11 90.5 1 pc(s). 4054.400 Automation Systems – Spare blades can be found on the Internet Colour: – Handle: Anthracite and Rittal Power Pink Accessories: – Spare blades can be found on the Internet Stripping tool for cables Ø 8 - 13 mm For stripping single- and multi-wire signal, pilot and fibreglass cables. For cable diameters mm Length mm Packs of Model No. 8 - 13 125 1 pc(s). 4054.405 Colour: – Handle: Anthracite and Rittal Power Pink Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 583 Insulation stripping tools Stripping tool for cables Ø 4.5 - 40 mm For stripping cables. Vertically hinged blade for creating round, longitudinal and spiral cuts. Colour: – Handle: Anthracite and Rittal Power Pink For cable diameters mm Length mm Packs of Model No. 4.5 - 40 167 1 pc(s). 4054.410 Accessories: – Spare blades can be found on the Internet 584 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Cutting tools Side cutter For copper and aluminium conductors. For cable diameters mm Length mm Design 0.2 - 11 160 Straight Packs of Model No. 1 pc(s). 4054.600 Benefits: – Guarantees long-term stable cutting performance and a clean cut – Ergonomically styled handles for fatigue-free, non-slip working Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink Standards: – Isolation protection 1000 V – VDE Electronic side cutter With pointed head, 21° angled blades and small chamfer. Length mm Packs of Model No. 115 1 pc(s). 4054.750 Packs of Model No. Automation Systems Benefits: – Even, smooth-running opening with opening spring – Ergonomically styled handles – Box-joint for permanent stability and optimum force progression Material: – High-quality special tool steel Surface finish: – Polished, oiled Colour: – Handle: Anthracite and Rittal Power Pink Cable cutter For copper and aluminium conductors. Benefits: – Ergonomically styled handles for fatigue-free, non-slip working Material: – High-quality special tool steel Colour: – Handle: Anthracite and Rittal Power Pink Standards: – Isolation protection 1000 V – VDE For cross-section mm² For cable diameters mm Length mm Design 0.5 - 35 12 160 Straight 1 pc(s). 4054.650 0.5 - 50 18 180 Angled 1 pc(s). 4054.660 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 585 Cutting tools Electrician's scissors For cutting copper, aluminium, Kevlar and plastic. For cable diameters mm Length mm Packs of Model No. 0.1 - 3.7 160 1 pc(s). 4054.700 Benefits: – High cutting performance thanks to micro-serration in the cutting zone – Ergonomically styled handles – Two-component handle with anti-slip soft zone – Adjustable screw joint Material: – High-quality special tool steel Surface finish: – Brushed Colour: – Handle: Anthracite and Rittal Power Pink Cross member cutter To create openings by cutting the cross members in compartment side panels and compartment dividers for VX enclosures and for fuse-switch-disconnector enclosures. Benefits: – Cutting of materials without deformation – Clean edge cuts, no reworking of the cut section required – Easy to use – Ergonomically styled handles for fatigue-free, non-slip working To fit Model No. 9683.006/9683.008/ 9683.016/9683.018/ 9683.036/9683.038/ 9680.005/9680.025/ 9680.207/9680.227/ 9683.406/9683.408/ 9683.426/9683.428/ 9683.444/9683.446/ 9683.448/9683.464/ 9683.466/9683.468/ 9683.484/9683.486/ 9683.488 Length Packs Design mm of 280 Straight Model No. 1 4054.870 pc(s). Material: – Tool body: Special tool steel, rolled, oil-hardened Colour: – Handle: Anthracite and Rittal Power Pink Supply includes: – Cross member cutter including swarf deflector 586 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Pliers Combination pliers Length mm Packs of Model No. 180 1 pc(s). 4054.800 Length mm Packs of Model No. 200 1 pc(s). 4054.850 Length mm Packs of Model No. 120 1 pc(s). 4054.860 With serrated gripping surface and integral ring spanner M8 to M10. Benefits: – Ergonomically styled handles for fatigue-free, non-slip working – Favourable transmission ratios for good holding and cutting performance – Minimal force required Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink Standards: – Isolation protection 1000 V – VDE Needle-nose pliers With serrated gripping surface. Benefits: – Ergonomically styled handles for fatigue-free, non-slip working Automation Systems Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink Standards: – Isolation protection 1000 V – VDE Electronic needle-nose pliers With smooth gripping surface. Benefits: – Ergonomically styled handles for fatigue-free, non-slip working – Even, smooth-running opening with opening spring Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 587 Pliers Slip-joint pliers Length mm Packs of Model No. 260 1 pc(s). 4054.900 For width across flats 10 - 36 mm. Benefits: – Ergonomically styled handles for fatigue-free, non-slip working – Smooth cheeks avoid the usual damage caused by wrenches and pipe wrenches on screws/nuts – QuickSnap ratcheting for fast adjustment to the workpiece with no push-button – Robust box-joint Material: – High-quality special tool steel Surface finish: – Matt, plated Colour: – Handle: Anthracite and Rittal Power Pink 588 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Maximum data quality Streamline your workflow with software-based engineering This enclosure is available in duplicate – real and digital. The maximum data quality of the enclosures creates greater flexibility with configuration, manufacturing and assembly. What’s more, the digital twin allows the planning, ordering, processing and much Automation Systems more to be carried out by the person who knows your company the best: you. Rittal System Catalogue 36/Rittal Automation Systems 589 Mechanical tools Deburring blade Universal deburrer, for deburring holes and edges. Design: – Steel blade may be clamped in an axial or radial direction as required – Steel blade brushed on both sides Handle length mm Handle dia. mm Packs of Model No. 110 28 1 pc(s). 4050.722 Accessories: – Steel blade, see page 590 Benefits: – Blade automatically assumes the optimum position – Length of blade support is adjustable – Easy to use – Effortless deburring – Ergonomically styled handle Material: – Handle core: Hard plastic – Handle body: Elastic, highly flexible plastic – Blade holder: Steel – Blade: Hardened steel blade, with PVD TiN (titanium nitride) coating Colour: – Handle: Black and red Supply includes: – Handle – Blade holder – Steel blade Steel blade for deburring blade Spare blade for deburrer. Rotating 360° blades for deburring. To fit Model No. Blade length mm 4050.722 23 Blade dia. Packs of Model No. mm 3 10 pc(s). 4050.723 Design: – Steel blade brushed on both sides Material: – Hardened steel blade, with PVD TiN (titanium nitride) coating Multitool for AX, VX Multifunctional tool. Ideal for handling and mounting AX enclosures and VX doors. Also required: – Deburring blade, see page 590 Packs of Model No. 1 pc(s). 4052.000 Functions: – Cutting of packaging (tapes and foil) – Enclosure key (double-bit) – Installation and dismantling of hinge pins with AX enclosures – Temporary door stay for AX enclosures – Safe installation and removal of VX doors – Magnet for securing drawings and attaching to enclosure surfaces – Bottle opener function Technical specifications: – Load capacity max. 40 kg (lift door) Material: – Door lift function: Stainless steel – Double-bit: Die-cast zinc – Mounting aid for hinge pins: Die-cast zinc – Door stay: Die-cast zinc – Blade: Stainless steel blade – Handle: Plastic Colour: – Handle: Anthracite and Rittal Power Pink 590 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Mechanical tools Lifting aid for mounting plate for AX Lifting tool to support the assembly process of mounting plates for AX enclosures. Allows easy location and positioning of the mounting plate without risk of injury. Packs of Model No. 1 pc(s). 4050.140 Benefits: – Easy location of populated mounting plates – Tool-free mounting on the mounting plate – Loop function for crane use – No risk of fingers or hands becoming trapped Technical specifications: – Load capacity max. 40 kg per cable Material: – Lifting rope and loop: Steel – Handle: Plastic – Mounting plate adaptor: Die-cast zinc Colour: – Handle: Anthracite and Rittal Power pink Supply includes: – 1 set ≙ 4 lifting aids for AX For precise positioning and support when drilling extra holes in AX enclosures. Designed for steel and stainless steel enclosures. Width mm Height mm Depth mm Packs of Model No. 96 30 45 1 pc(s). 4052.500 Automation Systems Drilling template Applications: – Universal bracket 2373.000 – Swing frame installation kit 2034.010 – Door stay 1485.100 – 180° hinges 2449.010 Benefits: – Protects the edge of the enclosure – No measurement or marking out required – Avoids scratches and damage to the enclosure surface Technical specifications: – For holes Ø 4.5 / 5.5 / 6.5 mm Material: – Hard plastic Colour: – RAL 9005 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 591 Hole punching tools Hydraulic punches Manual hydraulic punch Design Packs of Model No. Straight 1 pc(s). 4055.000 For punching round, square and rectangular cut-outs. With 90° angled and 360° rotating cylinder head 1 pc(s). 4055.010 Benefits: – Extend tool life with a built-in overpressure valve Flexible, with hydraulic hose and separate cylinder 1 pc(s). 4055.020 Punching capacity: – Round punch up to Ø 82 mm – Square punch up to 68 x 68 mm – Rectangular punch up to 46 x 86 mm – Punching force 75 kN – Max. operating pressure 680 bar/9850 psi Material: – Aluminium Supply includes: – Manual hydraulic punch – Hydraulic screw Ø 19 mm – Hydraulic screw Ø 9.5 / 19 mm – HSS pilot drill Ø 11 mm – Spacer sleeve set (3-part) – Plastic case Electric hydraulic punch Packs of Model No. 1 pc(s). 4055.041 For punching round, square and rectangular cut-outs. Benefits: – Extend tool life with a built-in overpressure valve – High-performance drive motor with ergonomically styled handle – Slide in the battery packs from two sides to balance the weight Punching capacity: – Round punch up to Ø 82 mm – Square punch up to 68 x 68 mm – Punching force 75 kN – Max. operating pressure 680 bar/9850 psi Material: – Aluminium Supply includes: – Electric hydraulic punch with 2 NiMH batteries, 18 V – Charging device 18 - 28 V – Hydraulic screw Ø 9.5 / 19 mm – Hydraulic screw Ø 19 mm – Spacer sleeve set (3-part) – HSS pilot drill Ø 11 mm – Plastic case 592 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Hole punching tools Hydraulic punches Manual hydraulic punch set, M16 - M63 Manual hydraulic punch in a practical set with hole punches for sheet steel. Maximum machinable material thickness 2 or 3 mm. Benefits: – Extend tool life with a built-in overpressure valve For threads Ø punch mm Packs of Model No. M16 M20 M25 M32 M40 M50 M63 16.2 20.4 25.4 32.5 40.5 50.5 63.5 1 pc(s). 4055.070 For threads Ø punch mm Packs of Model No. M16 M20 M25 M32 M40 16.2 20.4 25.4 32.5 40.5 1 pc(s). 4055.080 For PG Ø punch mm Packs of Model No. 9 11 13 16 21 29 36 42 48 15.2 18.6 20.4 22.5 28.3 37 47 54 60 1 pc(s). 4055.085 Supply includes: – Manual hydraulic punch, straight – 7 splitter hole punches, triple splitting – Hydraulic screw Ø 19 mm – Hydraulic screw Ø 9.5 / 19 mm – HSS pilot drill Ø 10 mm – Spacer sleeve set (3-part) – Plastic case Manual hydraulic punch set, M16 - M40 Manual hydraulic punch in a practical set with hole punches for sheet steel. Maximum machinable material thickness 2 or 3 mm. Design: – With 90° angled and 360° rotating cylinder head Automation Systems Benefits: – Extend tool life with a built-in overpressure valve Supply includes: – Manual hydraulic punch – 5 splitter hole punches, triple splitting – Hydraulic screw Ø 19 mm – Hydraulic screw Ø 9.5 / 19 mm – HSS pilot drill Ø 10 mm – Spacer sleeve set (3-part) – Plastic case Manual hydraulic punch set, PG 9 - PG 48 Manual hydraulic punch in a practical set with hole punches for sheet steel. Maximum machinable material thickness 2 or 3 mm. Design: – With 90° angled and 360° rotating cylinder head Benefits: – Extend tool life with a built-in overpressure valve Supply includes: – Manual hydraulic punch – 9 splitter hole punches, triple splitting – Hydraulic screw Ø 19 mm – Hydraulic screw Ø 9.5 / 19 mm – HSS pilot drill Ø 10 mm – Spacer sleeve set (3-part) – Plastic case Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 593 Hole punching tools Hole punches Hole punch, round for sheet steel For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With 3 cutting points Supply includes: – Female dies – Male dies – Tension screw without ball bearing Note: – When operating with wrenches, tension screws with ball bearings should be used – Other sizes, see splitter hole punch, round, stainless steel Accessories: – Tension screw, see page 602 – Hydraulic tension screw, see page 603 For threads 594 For PG Ø punch mm Tension screw (Ø x L) mm Tension screw with ball bearing Model No. Hydraulic tension screw Ø mm Hydraulic tension screw Model No. Maximum machinable material thickness, sheet steel mm Packs of Model No. M12 7 12.7 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.212 – 9 15.2 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.215 M16 – 16.2 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.216 – 11 18.6 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.218 M20 13 20.4 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.220 – 16 22.5 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.222 M25 – 25.4 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.225 – 21 28.3 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.228 M32 – 32.5 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.232 – 29 37 19 x 55 4055.633 19 4055.663 3 1 pc(s). 4055.237 M40 – 40.5 19 x 55 4055.633 19 4055.663 3 1 pc(s). 4055.240 – 36 47 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.247 M50 – 50.5 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.250 – 42 54 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.254 – 48 60 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.260 M63 – 63.5 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.263 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Hole punching tools Hole punches Hole punch set, metric for sheet steel For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With 3 cutting points Supply includes: – 5 female dies – 5 male dies – Plastic case Note: – When operating with wrenches, tension screws with ball bearings should be used Accessories: – Tension screw, see page 602 – Hydraulic tension screw, see page 603 Ø punch mm Tension screw with ball bearing Model No. Hydraulic tension screw Model No. Maximum machinable material thickness, sheet steel mm Packs of Model No. M16 M20 M25 M32 M40 16.2 20.4 25.4 32.5 40.5 4055.631 4055.631 4055.631 4055.631 4055.633 4055.661 4055.661 4055.661 4055.661 4055.663 2 2 2 2 3 1 pc(s). 4055.480 Automation Systems For threads Hole punch set, PG for sheet steel For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With 3 cutting points Supply includes: – 5 female dies – 5 male dies – 2 tension screws with ball bearing Ø 9.5 x 50 mm – HSS pilot drill Ø 11 mm – 1 tube of lubricant paste – Plastic case Note: – When operating with wrenches, tension screws with ball bearings should be used Accessories: – Hydraulic tension screw, see page 603 For PG Ø punch mm Hydraulic tension screw Model No. Maximum machinable material thickness, sheet steel mm Packs of Model No. 9 11 13 16 21 15.2 18.6 20.4 22.5 28.3 4055.661 2 1 pc(s). 4055.481 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 595 Hole punching tools Hole punches Splitter hole punch, round for sheet steel, with triple splitting For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With triple splitting Supply includes: – Female dies – Male dies Note: – When operating with wrenches, tension screws with ball bearings should be used – Other sizes, see splitter hole punch, round, stainless steel Accessories: – Tension screw, see page 602 – Hydraulic tension screw, see page 603 For threads 596 For PG Ø punch mm Tension screw (Ø x L) mm Tension screw with ball bearing Model No. Hydraulic tension screw Ø mm Hydraulic tension screw Model No. Maximum machinable material thickness, sheet steel mm Packs of Model No. M12 – 12.5 6 x 40 4055.630 6/19 4055.660 1.5 1 pc(s). 4055.512 – 9 15.2 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.515 M16 – 16.2 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.516 – 11 18.6 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.518 M20 13 20.4 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.520 – 16 22.5 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.522 M25 – 25.4 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.525 – 21 28.3 9.5 x 50 4055.631 9.5/19 4055.661 2 1 pc(s). 4055.528 M32 – 32.5 19 x 55 4055.633 19 4055.663 3 1 pc(s). 4055.532 – 29 37 19 x 55 4055.633 19 4055.663 3 1 pc(s). 4055.537 M40 – 40.5 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.540 – 36 47 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.547 M50 – 50.5 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.550 – 42 54 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.554 – 48 60 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.560 M63 – 63.5 19 x 75 4055.634 19 4055.663 3 1 pc(s). 4055.563 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Hole punching tools Hole punches Splitter hole punch set, M16 to M40 for sheet steel, with triple splitting For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With triple splitting Supply includes: – 5 female dies – 5 male dies – Plastic case Note: – When operating with wrenches, tension screws with ball bearings should be used Accessories: – Tension screw, see page 602 – Hydraulic tension screw, see page 603 Ø punch mm Tension screw with ball bearing Model No. Hydraulic tension screw Model No. Maximum machinable material thickness, sheet steel mm Packs of Model No. M16 M20 M25 M32 M40 16.2 20.4 25.4 32.5 40.5 4055.631 4055.631 4055.631 4055.633 4055.634 4055.661 4055.661 4055.661 4055.663 4055.663 2 2 2 3 3 1 pc(s). 4055.580 Automation Systems For threads Splitter hole punch set, M12 to M40 for sheet steel, with triple splitting For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With triple splitting Supply includes: – 6 female dies – 6 male dies – Tension screw with ball bearing Ø 6 x 40 mm – Tension screw with ball bearing Ø 9.5 x 50 mm – Tension screw with ball bearing Ø 19 x 55 mm – HSS pilot drill Ø 10 mm – 1 can of lubricant paste – Plastic case Note: – When operating with wrenches, tension screws with ball bearings should be used Accessories: – Hydraulic tension screw, see page 603 For threads Ø punch mm Hydraulic tension screw Model No. Maximum machinable material thickness, sheet steel mm Packs of Model No. M12 M16 M20 M25 M32 M40 12.5 16.2 20.4 25.4 32.5 40.5 4055.660 4055.661 4055.661 4055.661 4055.663 4055.663 1.5 2 2 2 3 3 1 pc(s). 4055.581 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 597 Hole punching tools Hole punches Splitter hole punch set, PG 9 to PG 21 for sheet steel, with triple splitting For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With triple splitting Supply includes: – 6 female dies – 6 male dies – 2 tension screws with ball bearing Ø 9.5 x 50 mm – HSS pilot drill Ø 10 mm – 1 tube of lubricant paste – Plastic case Note: – When operating with wrenches, tension screws with ball bearings should be used Accessories: – Hydraulic tension screw, see page 603 598 For PG Ø punch mm Hydraulic tension screw Model No. Maximum machinable material thickness, sheet steel mm Packs of Model No. 9 11 13 16 21 15.2 18.6 20.4 22.5 28.3 30.5 4055.661 2 1 pc(s). 4055.582 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Hole punching tools Hole punches Splitter hole punch, round for stainless steel, round, with triple splitting For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With triple splitting Supply includes: – Female dies – Male dies Note: – When operating with wrenches, tension screws with ball bearings should be used Also required: – Tension screw, see page 602 – Hydraulic tension screw, see page 603 – Hydraulic tension screw for higher loads, see page 603 For PG Ø punch mm Tension screw (Ø x L) mm Tension screw with ball bearing Model No. Hydraulic tension screw Ø mm Maximum Hydraulic machinable tension material thickness, Packs of screw stainless steel Model No. mm Model No. – 9 15.2 11.1 x 60 4055.632 11.1/19 4055.665 2 1 pc(s). 4055.115 M16 – 16.2 11.1 x 60 4055.632 11.1/19 4055.665 2 1 pc(s). 4055.116 – 11 18.6 11.1 x 60 4055.632 11.1/19 4055.665 2 1 pc(s). 4055.118 M20 13 20.4 11.1 x 60 4055.632 11.1/19 4055.665 2 1 pc(s). 4055.120 – 16 22.5 11.1 x 60 4055.632 11.1/19 4055.665 2 1 pc(s). 4055.122 M25 – 25.4 11.1 x 60 4055.632 11.1/19 4055.665 2 1 pc(s). 4055.125 – 21 28.3 19 x 55 4055.633 19 4055.663 2.5 1 pc(s). 4055.128 – – 30.5 19 x 55 4055.633 19 4055.663 2.5 1 pc(s). 4055.130 M32 – 32.5 19 x 55 4055.633 19 4055.663 2.5 1 pc(s). 4055.132 – – 34.6 19 x 55 4055.633 19 4055.663 2.5 1 pc(s). 4055.134 – 29 37 19 x 55 4055.633 19 4055.663 2.5 1 pc(s). 4055.137 M40 – 40.5 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.140 – – 43.2 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.143 – 36 47 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.147 – – 49.6 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.149 M50 – 50.5 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.150 – 42 54 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.154 – 48 60 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.160 – – 61.5 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.161 M63 – 63.5 19 x 75 4055.634 19 4055.663 2.5 1 pc(s). 4055.163 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. Automation Systems For threads 599 Hole punching tools Hole punches Splitter hole punch set, metric for stainless steel, round, with triple splitting For punching round cut-outs. The hole punch is operated with a wrench or hydraulic punch. Design: – With triple splitting Supply includes: – 5 female dies – 5 male dies – Plastic case Note: – When operating with wrenches, tension screws with ball bearings should be used Also required: – Tension screw, see page 602 – Hydraulic tension screw, see page 603 – Hydraulic tension screw for higher loads, see page 603 For threads Ø punch mm Tension screw with ball bearing Model No. Hydraulic tension screw Model No. Maximum machinable material thickness, stainless steel mm Packs of Model No. M16 M20 M25 M32 M40 16.2 20.4 25.4 32.5 40.5 4055.632 4055.632 4055.632 4055.633 4055.634 4055.665 4055.665 4055.665 4055.663 4055.663 2 2 2 2.5 2.5 1 pc(s). 4055.180 Operation, Operation, Packs of manual hydraulic Model No. Hole punch, square for sheet steel For punching square cut-outs. The hole punch is operated with a hydraulic punch. Benefits: – With side ejector for the waste – No jamming of the die Supply includes: – Female dies – Male dies – Tension bolts – Lock nut – Plastic case □ punch mm Maximum machinable material thickness, sheet steel mm Product-specific scope of supply 22.2 x 22.2 2 Pressure nut with ball bearing Adaptor for hydraulics ◾ ◾ 1 pc(s). 4055.322 45.5 x 45.5 3 – – ◾ 1 pc(s). 4055.345 46 x 46 3 – – ◾ 1 pc(s). 4055.346 50.8 x 50.8 3 – – ◾ 1 pc(s). 4055.350 68 x 68 3 – – ◾ 1 pc(s). 4055.368 3 Spacer sleeve Special tension bolt – ◾ 1 pc(s). 4055.392 92 x 92 600 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Hole punching tools Hole punches Hole punch, rectangular for sheet steel For punching rectangular cut-outs. The hole punch is operated with a wrench or hydraulic punch. Benefits: – With side ejector for the waste – No jamming of the die ▭ punch mm Maximum machinable material thickness, sheet steel mm Product-specific scope of supply Operation, manual Operation, hydraulic Packs of Model No. 22 x 30 2 Pressure nut with ball bearing Adaptor for hydraulics ◾ ◾ 1 pc(s). 4055.400 22 x 42 2 Pressure nut with ball bearing Adaptor for hydraulics ◾ ◾ 1 pc(s). 4055.401 45 x 92 2 – – ◾ 1 pc(s). 4055.402 46 x 92 2 – – ◾ 1 pc(s). 4055.403 Automation Systems Supply includes: – Female dies – Male dies – Tension bolts – Lock nut – Plastic case 3 Hole punch, special contour 12.7 for sheet steel For punching cut-outs with a special contour. The hole punch is operated with a wrench or hydraulic punch. Benefits: – With side ejector for the waste – No jamming of the die Supply includes: – Female dies – Male dies – Tension bolts – Lock nut – Pressure nut with ball bearing – Adaptor for hydraulics – Plastic case 22.5 4055.440 20.1 .5 22 4055.441 Design Ø punch mm Maximum machinable material thickness, sheet steel mm Packs of Model No. With 3 mm lug 22.5 2 1 pc(s). 4055.440 Flattened to 20.1 mm on 4 sides 22.5 2 1 pc(s). 4055.441 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 601 Hole punching tools Hole punches Hole punch, heavy connectors for sheet steel For punching rectangular cut-outs for connectors. The hole punch is operated with a hydraulic punch. Benefits: – With side ejector for the waste – No jamming of the die – When the die and stamp are compressed, the mounting holes for connectors are marked on the metal sheet between them Supply includes: – Female dies – Male dies – Tension bolts – Lock nut ▭ punch mm No. of poles Maximum machinable material thickness, sheet steel mm Model No. 36 x 52 6-pole 2 1 pc(s). 4055.460 36 x 65 10-pole 2 1 pc(s). 4055.461 36 x 86 16-pole 2 1 pc(s). 4055.463 36 x 112 24-pole 2 1 pc(s). 4055.465 Tension screw Tension screw (Ø x L) mm Packs of Model No. Accessories for hole punches. Required as a connecting part between the die and stamp. 9.5 x 40 1 pc(s). 4055.600 9.5 x 50 1 pc(s). 4055.601 Note: – For operation with wrench 19 x 55 1 pc(s). 4055.602 19 x 75 1 pc(s). 4055.603 Tension screw with ball bearing Accessories for hole punches. Required as a connecting part between the die and stamp. Note: – For operation with wrench 602 Packs of Further technical information available on the Internet. Tension screw (Ø x L) mm Packs of Model No. 6 x 40 1 pc(s). 4055.630 9.5 x 50 1 pc(s). 4055.631 11.1 x 60 1 pc(s). 4055.632 19 x 55 1 pc(s). 4055.633 19 x 75 1 pc(s). 4055.634 Rittal System Catalogue 36/Rittal Automation Systems Hole punching tools Hole punches Hydraulic tension screw Accessories for hole punches. Required as a connecting part between the die and stamp. Note: – For operation via hydraulic punch Hydraulic tension screw Ø mm Product-specific scope of supply Packs of Model No. 6/19 Adaptor for hydraulics 1 pc(s). 4055.660 9.5/19 Adaptor for hydraulics 1 pc(s). 4055.661 11.1/19 Adaptor for hydraulics 1 pc(s). 4055.662 19 – 1 pc(s). 4055.663 Hydraulic tension screw for higher loads Hydraulic tension screw Ø mm Accessories for hole punches. Required as a connecting part between the die and stamp. Packs of Model No. 9.5/19 1 pc(s). 4055.664 11.1/19 1 pc(s). 4055.665 Maximum machinable material thickness, sheet steel mm Packs of Model No. 2 1 pc(s). 4055.690 Benefits: – Hydraulic tension screw made from high-alloy tool steel for higher loads Notching pliers Punches slots quickly and easily. Saves the timeconsuming process of filing the grooves for antitwist protection of push buttons, switches and instruments. Slots in sizes 3.2 mm and 4.8 mm can be created. Automation Systems Note: – For operation via hydraulic punch Benefits: – Long service life – Male and female die made from hardened tool steel – Easy punching with large leverage Material: – Handles: Plastic-coated Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 603 Wiring duct cutter MC 125 For manual cutting of wiring ducts, with adjustable length end stop for the machined material. Anodised contact surface with laser-engraved calibration in millimetres and inches. Integral finger guard ensures safe machining. Intended for mounting on a workbench. Benefits: – Enables inexpensive manual cutting of wiring ducts – Easier for cutting wiring ducts to length compared to sawing by hand Machinable material: – Plastic Model No. Packs of Footprint size (W x H x D) mm 4050.435 Page 1332 x 798 x 405 Max. machinable width of cable duct mm 125 Max. machinable wall thickness of cable duct mm 2.5 Max. insertion height mm 28 Weight kg 15.0 Accessories Spare blade MC 125 604 1 pc(s). Further technical information available on the Internet. 4050.436 Rittal System Catalogue 36/Rittal Automation Systems Support rail cutter MC3 Manual profile cutter for cutting C rails 30/15 and support rails TS 35/7.5 and TS 35/15 to length, burr-free. The desired rail length is set precisely and reproducibly using the ruler (mm/inch) and the adjustable end stop. For mounting on the workbench. – Easier to cut mounting angles and support rails to the correct length than sawing by hand – Burr-free cutting to length with eccentric lever, no major force required – Low-maintenance and with a long service life Benefits: – Inexpensive manual cutting of mounting angles and support rails Machinable material: – Sheet steel – Aluminium – Copper Model No. Maximum machinable material thickness mm Footprint size (W x H x D) mm Weight kg Packs of 4050.437 Page 1.5 1343 x 1162 x 312 14.0 Accessories Support rail TS 35/15 see page 997 Support rail TS 35/7.5 see page 997 C rails 30/15 see page 996 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 605 Automation Systems Support rails Page 996  Mounting angles Page 996   Assembly frames and LT 1000 storage and transport trolley We have the perfect ergonomic solution for you, particularly when it comes to the automation and rationalisation of every stage of the enclosure machining, assembly, wiring and testing process. Our assembly frames are mobile, tiltable and (depending on the version) height-adjustable for machining mounting plates and enclosures. All types offer simple, variable fixing of mounting plates using quick-release fasteners, are independent from the mains power, and take up minimal space when not in use. For easier handling of enclosure panels, we also offer the storage and transport trolley LT 1000. ◾ Tilt-adjustable and optionally height-adjustable for ergonomic, effective, time-saving construction, wiring and testing of mounting plates or complete enclosures Numerous adaptation options available: ◾ Widening to a maximum of 1900 mm ◾ Wire routing ◾ Wire reel holder ◾ Individually adjustable thanks to height-adjustable supports More options, see brochure "Rittal Automation Systems – Automate your panel building and switchgear manufacturing", from page 58 ◾ Four castors including total lock function ensure simple handling ◾ Eight wide fan sections for effortless storage and transportation of enclosure panels ◾ User-friendly transportation through the workshop on castors 606 We reserve the right to make technical modifications. Rittal System Catalogue 36/Rittal Automation Systems Assembly frame Accessories Page 608   Benefits: – For ergonomic, back-friendly working – Individually positionable in the workshop, as it is independent from the power network – Minimum space requirements during non-use – Simple handling due to four castors including total lock function – Variable fixing of mounting plates with a quick-release fastener Model No. Packs of Technical specifications: – Tilt adjustment approx. 0 – 80° Supply includes: – Assembly frame – 1 clamping unit pack, bottom – 1 clamping unit pack, top Please observe the productspecific scope of supply. 4050.200 4050.300 150 MN (manually tilt-adjustable) 200 EN (electrically tilt-adjustable) 300 ENH (electrically tilt- and height-adjustable) Dimensions (W x D) mm 1400 x 1250 1400 x 1250 1400 x 1250 Dimensions of support surface (W x H) min. mm 1110 x 1230 1110 x 1230 1110 x 1230 Dimensions of support surface (W x H) max. mm 1110 x 1900 1110 x 1900 1110 x 1900 150 200 300 100 / 100 90 / 90 80 / 110 138.0 148.0 250.0 Charger unit – ◾ ◾ Battery – ◾ ◾ Design Load capacity kg Working height (min./max.) cm Weight kg 4050.150 Note: – With the assembly frame extension, a maximum machining area of 1900 x 1900 mm can be achieved Page Product-specific scope of supply Accessories Extension 1 pc(s). 4050.210 4050.210 4050.210 Enclosure set 1 pc(s). 4050.211 4050.211 4050.211 608 Wire routing 1 pc(s). 4050.212 4050.212 4050.212 608 see page see page see page 608 Wire reel holder 1 pc(s). 4050.216 4050.216 4050.216 609 Screw adaptor 1 pc(s). 4050.218 4050.218 4050.218 609 Set of brackets 1 pc(s). 4050.221 4050.221 4050.221 610 Roller conveyor 1 pc(s). – – 4050.220 609 Clamping unit 608 Spare battery 1 pc(s). – 4050.217 4050.217 609 Voltage supply 1 pc(s). – 4050.219 4050.219 610 Connection adaptor 1 pc(s). – 4050.222 4050.222 610 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 607 Automation Systems The assembly frames are mobile, tiltable and (depending on the version) height-adjustable frames for assembling plates and enclosures. Accessories for assembly frame Extension for assembly frame For widening assembly frames 150 MN, 200 EN, 300 ENH to a maximum width of 1900 mm. To fit Model No. Packs of Model No. 4050.150/4050.200/ 4050.300/4051.100 1 pc(s). 4050.210 To fit Model No. Packs of Model No. 4050.150/ 4050.200/ 4050.300 1 pc(s). 4050.211 To fit Model No. Packs of Model No. 4050.150/ 4050.200/ 4050.300 1 pc(s). 4050.212 Supply includes: – Extension – Assembly parts Enclosure set for assembly frame For secure attachment of an enclosure such as AX to assembly frame 150 MN, 200 EN, 300 ENH. Supply includes: – Packs of 2 Wire routing for assembly frame For user-friendly handling of wires on assembly frame 150 MN, 200 EN, 300 ENH. Clamping unit for assembly frame For secure attachment of a mounting plate onto the assembly frames 150 MN, 200 EN and 300 ENH. 608 To fit Model No. For Design Product-specific scope of supply Packs of Model No. 4050.150/ 4050.200/ 4050.300 Mounting plate VX/SE Top 1 clamping unit pack, top 2 pc(s). 4050.213 4050.150/ 4050.200/ 4050.300 Mounting plate VX/SE Bottom 1 clamping unit pack, bottom 2 pc(s). 4050.214 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Accessories Wire reel holder for assembly frame For adapting wire reels or drums on assembly frames 150 MN, 200 EN and 300 ENH. Spare battery for assembly frame Battery to fit electrical tilt/height adjuster for assembly frame 200 EN, 300 ENH. Screw adaptor for spindle hoist For operating the assembly frame spindle drive using a cordless screwdriver. To fit assembly frame 150 MN. Roller conveyor for assembly frame For inserting the mounting plate sideways into the enclosure. To fit assembly frame 300 ENH. Rittal System Catalogue 36/Rittal Automation Systems To fit Model No. Packs of Model No. 4050.150/ 4050.200/ 4050.300/ 4051.100 1 pc(s). 4050.216 To fit Model No. Packs of Model No. 4050.200/ 4050.300 1 pc(s). 4050.217 To fit Model No. Packs of Model No. 4050.150 1 pc(s). 4050.218 To fit Model No. Packs of Model No. 4050.300 1 pc(s). 4050.220 Further technical information available on the Internet. Automation Systems for assembly frame 609 Accessories for assembly frame Set of brackets for assembly frame For secure attachment of a mounting plate onto the assembly frames 150 MN, 200 EN, 300 ENH. To fit Model No. For Packs of Model No. 4050.150/ 4050.200/ 4050.300 Mounting plate AX 1 pc(s). 4050.221 Supply includes: – 4 cover caps – 12 handles – 2 holders – 16 washers – 12 sliding blocks Voltage supply for assembly frame Charging station power pack for assembly frame 200 EN and 300 ENH. Suitable for To fit Model No. rated operating Packs of voltage 4050.200/ 4050.300 110 V 1 pc(s). Model No. 4050.219 Also required: – Connection adaptor, see page 610 Connection adaptor for voltage supply Adaptor connector for the power supply to assembly frames 200 EN and 300 ENH. Design: – USA, Canada, Central and South America, Japan 610 Further technical information available on the Internet. To fit Model No. Packs of Model No. 4050.200/4050.300 1 pc(s). 4050.222 Also required: – Voltage supply, see page 610 Rittal System Catalogue 36/Rittal Automation Systems Storage and transport trolley LT 1000 Design: – 2 fan supports each with 8 slots, distance between tubes 100 mm Benefits: – Individually adjustable thanks to height-adjustable supports Model No. Transport dimensions (W x H x D) mm Load capacity kg Weight kg Rittal System Catalogue 36/Rittal Automation Systems Packs of – Effortless storage and transportation of enclosure panels – User-friendly transportation on industrial castors – Fan support, powder-coated, protects enclosure panels such as doors, side panels etc. from scratches and damage Material: – Base plate: Plastic – Fan support: Steel, powdercoated 4050.000 Page 1000 x 1500 x 1000 500 122.0 Further technical information available on the Internet. 611 Automation Systems The LT 1000 warehouse and transport trolley is used for storage and order picking, and ensures easy handling of enclosure panels such as mounting plates, enclosure doors, side panels and rear panels. Functional trolley The functional trolley is a veritable multi-talent: Whether for transporting materials and tools to the installation site or for commissioning, the functional trolley is perfectly suited for assembly technicians and service personnel. The sophisticated fold-out concept is the ideal solution when you are on the road, and its compact dimensions mean that it can be conveniently transported by car. Folds together for space-saving transportation Handcart function ◾ Made from V2A stainless steel for robustness and durability Integral folding chair, e.g. for programming work during commissioning ◾ Computer mouse-friendly surface ◾ Converts from a transport function to a practical desk by simply unfolding 612 We reserve the right to make technical modifications. Rittal System Catalogue 36/Rittal Automation Systems Functional trolley Benefits: – Table surface suitable for computer mouse – Converts from its transport function to a practical desk by simply unfolding – High level of resilience and robustness Model No. Packs of Material: – Functional trolley: Stainless steel 1.4301 (AISI 304) – Work surface: Plastic coating – Seat surface: Woven polyester fabric, coated in PVC 610 x 1000 x 85 Handcart dimensions (W x H x D) mm 300 x 610 x 1000 Table dimensions (W x H x D) mm 1290 x 780 x 610 Rittal System Catalogue 36/Rittal Automation Systems Supply includes: – Functional trolley – Folding chair 4050.130 Transport dimensions (W x H x D) mm Weight kg Load capacity: – Handcart (max. 20 kg) – Table (max. 30 kg) – Folding chair (max. 100 kg) Page 20.0 Further technical information available on the Internet. 613 Automation Systems Whether for transporting essential materials and tools to the installation site or for commissioning, the functional trolley's foldout system is the ideal solution for assembly technicians and service personnel. Smart Lifter enclosure lifting and transportation device Enclosure logistics made easy: the Smart Lifter allows populated and bayed enclosures up to a maximum weight of 1.8 t and a length of 4.8 m to be safely and easily transported. The height adjuster with torque drive can lift to a height of 230 mm, allowing operators to fit the base/plinth and lower onto pallets or square timbers. By using the torque cranks, the entire system can be gently lowered into place. ◾ The steering system with heavy-duty castors allows smooth relocation of the enclosure suite, and even rotation on the spot ◾ Lift function with torque crank handle allows the bayed enclosures to be gently raised and lowered ◾ Simple, safe relocation of the support points with a lock system makes the Smart Lifter a universal lifting tool for different enclosure depths 614 We reserve the right to make technical modifications. ◾ Height adjustment with a lift of 230 mm allows easier fitting of the base/plinth to enclosures Rittal System Catalogue 36/Rittal Automation Systems The Smart Lifter is your flexible, mobile transport system for switchgear manufacturers, logistics specialists and service teams. The Smart Lifter is distinguished by its versatility and industrial design with built-in torque crank handle to protect employees from incorrect operation. The torque crank handle allows bayed enclosures to be raised and lowered with minimal force Steering system for easy manoeuvring Simple base/plinth mounting with lift function up to 230 mm The pick-up forks for different enclosure depths are easily adjusted Transportation of enclosures in various lengths, depths and weights Automation Systems The belt and double-bit key are stored outside of the work zone Rittal System Catalogue 36/Rittal Automation Systems We reserve the right to make technical modifications. 615 Smart Lifter Lifting and transport device for enclosures and enclosure suites up to 4.80 m length. Benefits: – Supports simple mounting of base/plinths beneath enclosures – Easy transportation of bayed enclosures in the workshop or at the installation site – Flexible use for enclosures of different depths, thanks to adjustable forks – Ergonomic working (lifting and lowering) with a torque crank Model No. Functions: – Transportation of bayed enclosures up to a length of 4.80 m – Lifting of bayed enclosures up to a height of 230 mm and a weight of 1800 kg 4050.005 Load capacity kg 1800 Weight kg 70.0 616 Further technical information available on the Internet. Technical specifications: – Dimensions per trolley (W x H x D): 750 x 1100 x 400 mm Supply includes: – 2 transport trolleys Page Rittal System Catalogue 36/Rittal Automation Systems Boost efficiency, cut costs The digital twin engineered using Eplan software tools links together all downstream processes in panel building and switchgear manufacturing 4.0. Panel Modification Terminal Strip Assembly Wire Fabrication Wiring Automation Systems Cutting Smart Wiring The browser-based EPLAN Smart Wiring solution supplies all wiring data in a 100% digital form and visualises your wiring in 3D. Users benefit from a significant reduction in errors and substantial time savings. A digital twin of the enclosure also contains all the information needed for wiring enclosures. See page 32. Rittal System Catalogue 36/Rittal Automation Systems 617 Wire Station WS 540 wiring workstation For flexible, efficient wire assembly and wiring work in the workshop. The wiring workstation is the ideal interface between the fully automated production of wires with the Rittal Wire Terminal and wiring work on mounting plates or in the enclosure. The Wire Station WS 540 is an ergonomic process optimiser for use with all wiring-related activities. ◾ Universal accessories tailored to the application, such as component supports for semi-automatic machines ◾ Optional workstation add-ons help to boost flexibility and efficiency in essential manual process stages EPLAN Smart Wiring: Wiring made easy ◾ Using data from the Digital Twin ◾ Wire lists with filter function ◾ Visualisation of cable routes ◾ Wiring plan revision management ◾ Stocking and processing of pre-produced wires from the Rittal Wire Terminal ◾ Complete project handling with variable arrangement of the wire magazines directly at the workstation Wire management, stocking and production ◾ Automatic cutting with the Rittal C8+ length-cutting machine accelerates and streamlines the manual wiring process Wire Terminal WT fully automated wire processing machine Fully automated wire processing with patented ordering system, see page 656 618 We reserve the right to make technical modifications. Rittal assembly frames Flexible, straightforward handling in the workshop. Ergonomically adjustable assembly frames for building and wiring enclosures and mounting plates, see page 606 Rittal System Catalogue 36/Rittal Automation Systems With the complete modular system surrounding the WS 540, your workstation can be functionally adapted to suit individual panel building and switchgear manufacturing requirements. Assistance is at hand for process-optimised project handling with EPLAN Smart Wiring, the Rittal length-cutting, insulation-stripping and crimping machines, and label printers. Another modular element to boost efficiency in modern panel building and switchgear manufacturing. Integral scale and electrically adjustable operating height Automation Systems Optional monitor support Optional tool/drinks holder Optional Mini-PC holder Optional wire routing for up to 8 different wires Integral socket strip To fit the following products: 4052.058, 4052.141 4052.101, 4052.142 4052.102, 4054.002 4052.104, 4054.004 4052.106, 4054.141 4052.107, 4054.300 4052.121, 4054.410 4052.122, 4054.600 4052.131, 4054.750 4052.132, 4054.850 Integral shadow board to fit Rittal tools such as screwdrivers, side cutters, crimping tools etc., see page 566 Rittal System Catalogue 36/Rittal Automation Systems We reserve the right to make technical modifications. 619 Wire Station WS 540 Accessories for Wire Station WS 540 Page 621  Length-cutting machine C8+ Page 632  Crimping machines From page 634   Mobile wiring workstation, heightadjustable, for flexible use in the workshop. For ergonomic, fatigue-free wire processing work. Benefits: – Electronically adjustable desk for the optimum working height, adjustable from 710 – 1250 mm – Multiplex worktop, washable and scratch-resistant – Ideal solution in conjunction with the length-cutting and crimping machines plus preassembled wires with the Wire Terminal Model No. – Integral scale for quick manual measurements – Prepared to accommodate a monitor for wire processing with EPLAN Smart Wiring – Optionally expandable with shelves for wire boxes, wire reels and holders for tools and small parts – For flexible use in the workshop thanks to rubberised wheels – Drawer with shadow board prepared for tools Packs of Dimensions (W x H x D) mm Supply includes: – Wiring table with electrical height adjuster – Connection cable, 7 m – 7-way socket strip, with rocker switch Note: – The vertical mounting braces, Model No. 4051.106, are required for accessories such as storage box holders, magazine supports etc. 4051.100 Page 900 x 1350 x 781 Working height (min./max.) mm 710 / 1205 Input voltage 230 V AC, 50 Hz Weight kg 95.0 Accessories Shelf 2 pc(s). 4051.101 621 Component support, left 1 pc(s). 4051.102 621 Component support, right 1 pc(s). 4051.103 622 Monitor attachment 1 pc(s). 4051.104 622 LED work light 1 pc(s). 4051.105 623 Mounting braces, vertical 1 pc(s). 4051.106 623 Storage box holder 1 pc(s). 4051.107 624 Adaptor bracket 1 pc(s). 4051.108 624 Waste bin 1 pc(s). 4051.115 624 Socket strip 1 pc(s). 4051.114 625 Magazine support 1 pc(s). 4051.111 625 Wire routing for mounting braces, vertical 1 pc(s). 4051.120 625 Wire routing for component support, left 1 pc(s). 4051.121 626 Wire pack holder see page 626 Wire coil holder see page 627 Wire reel holder 1 pc(s). 4050.216 609 Tool holder, round 1 pc(s). 4051.113 627 Stripping machine console 1 pc(s). 4051.112 628 Universal utility shelf 1 pc(s). 4051.109 628 Mini-PC holder 1 pc(s). 4051.110 628 620 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Accessories for Wire Station WS 540 Shelf for WS 540 Shelf set for mounting below the desktop. Different shelf depths provide ample knee and leg room for seated working at the workstation. Packs of Model No. 2 pc(s). 4051.101 Packs of Model No. 1 pc(s). 4051.102 Benefits: – For optimum use of the space beneath the desktop without restricting legroom – Tool-free mounting of the shelves by simply hanging in place Technical specifications: – Top shelf (W x D): 510 x 335 mm – Bottom shelf (W x D): 510 x 200 mm Material: – Sheet steel Colour: – RAL 7016 Component support, left for WS 540 Component support unit to fit length-cutting machine C8+ and an additional shelf to accommodate most common label printer brands. Mounted on the left of the WS 540 Wire Station. Automation Systems Supply includes: – 2 shelves Benefits: – Additional shelf for universal use – Compact external mounting – Flexibly adjustable in the width and height Technical specifications: – Component support (W x H x D): 360 x 335 x 20 mm, including height adjustment of 480 mm – Support arm (W x H): 500 x 700 mm – Shelf (W x H x D): 417 x 267 x 20 mm Material: – Sheet steel Colour: – RAL 7016 Supply includes: – Component support for the C8+ length-cutting machine – Semi-automated machine support arm, left – Universal shelf for printer/label printer – Assembly parts Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 621 Accessories for Wire Station WS 540 Component support, right Packs of Model No. 1 pc(s). 4051.103 for WS 540 Component support unit to fit crimping machine RC or R8 E, for mounting on the right of the Wire Station WS 540. Benefits: – Compact external mounting – Flexibly adjustable in the width and height Technical specifications: – Component support (W x H x D): 318 x 313 x 20 mm, including conduit for height adjustment of 480 mm – Support arm (W x H): 500 x 700 mm Material: – Sheet steel Colour: – RAL 7016 Supply includes: – Component support for crimping machines – Semi-automated machine support arm, right – Assembly parts Monitor attachment for WS 540 For mounting all commercially available monitors up to screen diagonals of 32" with Vesa 75/100. Load capacity max. kg Packs of Model No. 10 1 pc(s). 4051.104 Benefits: – Stable monitor attachment – Vertically hinged – Height-adjustable Technical specifications: – Height-adjustable up to 285 mm – Extendable up to 430 mm – Swivel range left/right with full extension 90° – Swivel range of ball head 35° all-round – Vesa 75/100 Material: – Aluminium/sheet steel Supply includes: – Monitor attachment – Assembly parts Approvals: – GS-tested 622 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Accessories for Wire Station WS 540 LED work light Width mm 545 for WS 540 For attaching to the table top, with clamping device. Height mm 90 Depth mm 35 Benefits: – Bright, glare- and flicker-free lighting, homogeneous and shadow-free – Selectable colour temperature between warm white, neutral white and daylight white promotes concentration and reduces symptoms of fatigue – Excellent colour fidelity and high contrast – Aluminium spring arm with 3D head joint, swivelling and lockable for free positioning of the light source Luminous flux lm 2930 Light 84 SMD LEDs Rated operating voltage V, ~, Hz 110 - 240, 1~, 50/60 Technical specifications: – Spring arm: Length 970 mm – Colour reproduction: 94 – 98 Ra – Transmission angle: 100° Power consumption W 26 Service life h ≥ 60000 Operating temperature -10 °C...+40 °C Length of connection cable m 3 Connection options Plug-in power supply (CEE 7/16) with AC adaptor Packs of 1 pc(s). Model No. 4051.105 Material: – Light housing: Aluminium – Glare control: Macrolon Protection category IP to IEC 60 529: – IP 40 Protection class: – III (SELV) Mounting braces, vertical for WS 540 For optional attachment of accessories such as wire pack holders, open-fronted storage boxes and shelves. Packs of Model No. 1 pc(s). 4051.106 Automation Systems Supply includes: – LED work light – Assembly parts Benefits: – Individual and functional configuration with component supports, storage box holders, consoles, wire pack holders, etc. – Simple screw-fastening of accessories – Individual height adjustment of the accessories with a rail system Technical specifications: – Dimensions (W x H x D): 85 x 1350 x 50 mm Material: – Sheet steel Colour: – RAL 7016 Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 623 Accessories for Wire Station WS 540 Storage box holder for WS 540 For fastening to the vertical mounting braces of the WS 540 and for storing small parts and accessories. Technical specifications: – Dimensions of storage box holder (W x H x D): 110 x 350 x 15 mm – Dimensions of open-fronted storage box (W x H x D): 100 x 85 x 160 mm Packs of Model No. 1 pc(s). 4051.107 Also required: – Mounting braces, vertical, see page 623 Material: – Support: Sheet steel – Open-fronted storage boxes: Plastic Colour: – Support: RAL 7016 – Open-fronted storage boxes: Yellow Supply includes: – Storage box holder – 3 open-fronted storage boxes – Assembly parts Adaptor bracket for WS 540 For individual configuration and enlargement of the WS 540. The adaptor bracket is required for mounting additional vertical mounting braces and supports a range of width settings from 50 – 400 mm. Technical specifications: – Side dimensions (W x H): 483 x 383 mm Packs of Model No. 1 pc(s). 4051.108 Also required: – Mounting braces, vertical, see page 623 Material: – Sheet steel Colour: – RAL 7016 Waste bin for WS 540 For waste disposal directly at the workstation. Packs of Model No. 1 pc(s). 4051.115 Benefits: – Front mounting without impairing legroom Technical specifications: – Dimensions (W x H x D): 150 x 290 x 320 mm – Capacity: 12 litres Material: – Plastic Colour: – Dark grey Supply includes: – Waste bin – Bracket – Assembly parts 624 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Accessories for Wire Station WS 540 Socket strip for WS 540 For mounting on the worktop of the WS 540. Electrical connection V, Hz Rated current A Packs of Model No. 230, 50 16 1 pc(s). 4051.114 Design: – 5-way, with rocker switch (green) Benefits: – Ergonomic access thanks to the 45° angle on the worktop Material: – Extrusion: Aluminium – Socket inserts: Plastic Supply includes: – Socket strip, connection cable and earthing contact plug – Assembly parts Magazine support for WS 540 To accommodate up to 4 wire rail magazines with pre-assembled wires from the Wire Terminal WT. Benefits: – For universal use on any mounting brace, vertical Packs of Model No. 1 pc(s). 4051.111 Also required: – Mounting braces, vertical, see page 623 Technical specifications: – Dimensions (W x H x D): 330 x 200 x 35 mm Automation Systems Material: – Sheet steel Colour: – RAL 7016 Supply includes: – Magazine support – Assembly parts Wire routing for mounting braces, vertical for WS 540 Targeted wire routing for up to 8 different wires is supported. Mounting on the vertical mounting braces. Benefits: – Individually height-adjustable on the mounting brace – Optimum running characteristics of the wires Packs of Model No. 1 pc(s). 4051.120 Also required: – Mounting braces, vertical, see page 623 Technical specifications: – Dimensions (W x H x D): 130 x 263 x 322 mm – Depth adjustment directly at the wire guide up to 100 mm – Wire routing from 0.5 – 2.5 mm² supported Material: – Holder: Sheet steel – Reel and wire guide: Plastic Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 625 Accessories for Wire Station WS 540 Wire routing for component support, left for WS 540 Targeted wire routing for up to 8 different wires is supported. For mounting on the component support, left. Benefits: – Optimum wire routing to the C8+ length-cutting centre – Optimum running characteristics of the wires Packs of Model No. 1 pc(s). 4051.121 Also required: – Component support, left, see page 621 Technical specifications: – Dimensions (W x H x D): 129 x 190 x 169 mm – Wire routing from 0.5 – 2.5 mm² supported Material: – Holder: Sheet steel – Reel and wire guide: Plastic Wire pack holder To fit Model No. Design Packs of Model No. Shelf for wire packs, to fit assembly frames and WS 540. Attached to the Wire Station on the vertical mounting braces on the left or right. 4051.100/ 4050.150/ 4050.200/ 4050.300 left 1 pc(s). 4051.116 Technical specifications: – Dimensions of wire pack holder (W x H x D): 207 x 105 x 207 mm – Storage space to fit wire packs up to a maximum size of 207 x 207 mm 4051.100/ 4050.150/ 4050.200/ 4050.300 right 1 pc(s). 4051.117 Material: – Sheet steel Colour: – RAL 7016 Also required: – Mounting braces, vertical, see page 623 Supply includes: – Wire pack holder – Assembly parts 626 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Accessories for Wire Station WS 540 Wire coil holder To fit Model No. Design Packs of Model No. Wire coil shelf to fit assembly frames and WS 540. Attached to the Wire Station on the vertical mounting braces on the left or right. 4051.100/ 4050.150/ 4050.200/ 4050.300 left 1 pc(s). 4051.118 Technical specifications: – Storage space (W x H x D): 375 x 20 x 475 mm 4051.100/ 4050.150/ 4050.200/ 4050.300 right 1 pc(s). 4051.119 Colour: – RAL 7016 Supply includes: – Wire coil holder – Assembly parts Tool holder, round for WS 540 For safe storage of hand-held devices or drinks. The tool holder is secured to the desktop. Also required: – Mounting braces, vertical, see page 623 Packs of Model No. 1 pc(s). 4051.113 Automation Systems Material: – Sheet steel Applications: – Holder for hand tools such as cordless screwdrivers, hot-air dryers or beverage bottles – For hand-held tools up to 80 mm in diameter Technical specifications: – Dimensions (W x H x D): 140 x 87 x 200 mm Material: – Sheet steel Colour: – RAL 7016 Supply includes: – Tool holder, round – Assembly parts Rittal System Catalogue 36/Rittal Automation Systems Further technical information available on the Internet. 627 Accessories for Wire Station WS 540 Stripping machine console for WS 540 For positioning the S22 stripping machine on the WS 540. The console may be positioned on either the left or right. Technical specifications: – Console area (W x D): 278 x 178 mm – Height-adjustable up to 480 mm Packs of Model No. 1 pc(s). 4051.112 Assembly instruction: – The stripping machine console is also suitable for component supports 4051.102 and 4051.103 Material: – Sheet steel Colour: – RAL 7016 Universal utility shelf for WS 540 Universal utility shelf for mounting on the vertical mounting braces of the WS 540. Storage for tools or small parts. Technical specifications: – Dimensions (W x H x D): 130 x 15 x 190 mm Packs of Model No. 1 pc(s). 4051.109 Also required: – Mounting braces, vertical, see page 623 Material: – Sheet steel Colour: – RAL 7016 Supply includes: – Universal utility shelf – Assembly parts Mini-PC holder for WS 540 For secure attachment of a mini-PC to the WS 540. The holder is mounted underneath the workbench on the left. Packs of Model No. 1 pc(s). 4051.110 Technical specifications: – Dimensions (W x H x D): 70 x 235 x 200 mm – Individually adjustable up to 60 mm Material: – Sheet steel Colour: – RAL 7016 Supply includes: – Mini-PC holder – Assembly parts 628 Further technical information available on the Internet. Rittal System Catalogue 36/Rittal Automation Systems Length-cutting machine C8+ and stripping machine S22 The length-cutting machine C8+ makes work processes more efficient by cutting wires up to 8 mm diameter or 10 mm² cross-section to individually set lengths. Cutting orders can also be managed, documented and transmitted to the length-cutting machine C8+ from a PC or CAE data interface (EPLAN Pro Panel) via USB. In this way, the C8+ length-cutting machine additionally supports the cable labelling and wiring process by displaying the source/target code. The stripping machine S22 is electrically powered for accurate, careful stripping of the insulation from your wires. ◾ Start/stop function for individual wire production in conjunction with labelling ◾ Rotary knob allows linear adjustment of the stripping length from 3 – 20 mm ◾ Touch display for all wire information ◾ CAE data interface ◾ Linear adjustment of the stripping length from 3 – 20 mm for full or partial stripping via the rotary knob S22 C8+ ◾ Simple insertion of the wires Rittal System Catalogue 36/Rittal Automation Systems ◾ Simple opening of the feed rollers We reserve the right to make technical modifications. ◾ Central insertion of wires with crosssections from 0.05 – 6 mm² ◾ Insertion length 22 mm 629 Automation Systems ◾ Controllable pressing force of the feed rollers ◾ Equipment connection and cross-section setting Stripping and crimping machine R8 E The electrically driven R8 E crimping machine processes insulated wire end ferrules and standard PVC cables in cross-sections ranging from 0.5 to 2.5 mm² (AWG 20 – 14) with a crimping length of 8 mm. For flexible use in the workshop, all you need is a power connection. The machine guarantees UL-certified crimping in conjunction with wire end ferrules from Rittal. ◾ Holder for taped wire end ferrules on a reel R8 E ◾ Easy replacement of consumables ◾ Simple adjustment ◾ Flexible use in the workshop 630 We reserve the right to make technical modifications. Rittal System Catalogue 36/Rittal Automation Systems Stripping and crimping machines L8 and RC Electro-pneumatically driven wire-stripping and crimping machines for safe, fast processing of insulated wire end ferrules. The particular feature of our electro-pneumatic crimping machines is their fully automated detection of the wire cross-section and processing of the wire end ferrules. No tool changes are required. Linear adjustment of the blades and the high forces generated by the pneumatic crimping unit support the processing of all standard cables as well as special ferrules (AWG) in the application range from 0.5 to 2.5 mm² (AWG 20 – 14) with a crimping length of 8 mm. The integrated daily unit counter provides a continuous overview of your project quantities. The crimping machine RC is suitable for processing wire end ferrules in 8 mm and 10 mm lengths with labelling on the underside. The 5-way holder eliminates the need to switch between wire end ferrules for different cross-sections. ◾ User-friendly menu prompting via touch display ◾ Processing of wire cross-sections from 0.5 to 2.5 mm² ◾ Wire infeed ◾ Handling of special wires supported ◾ Crimping length 8 and 10 mm ◾ Simple filling and processing of the loose wire end ferrules RC L8 ◾ Processing of wire crosssections from 0.5 to 2.5 mm² ◾ Wire infeed ◾ Handling of special wires supported ◾ UL-certified crimping in conjunction with wire end ferrules from Rittal ◾ User-friendly menu prompting via touch display ◾ Pre-selection of wire crosssection Note: The wire end ferrules shown here are not included with the supply. Rittal System Catalogue 36/Rittal Automation Systems We reserve the right to make technical modifications. 631 Automation Systems ◾ 5-way holder for taped wire end ferrules on a reel Length-cutting machine C8+ Semi-automated machine for cutting wires to an individually adjustable length. Design: – With command panel – Stop & go function Model No. Benefits: – User-friendly operation – Simple insertion of the wires – Simple opening of the feed rollers – PC compatible – Length-cutting with interface to CAE data supported – Supports the process of labelling cables by showing the connection point on the display – Simply transmit projects and orders to length-cutting machine C8+ Packs of Machine dimensions (W x H x D) mm Technical specifications: – Fine-wire strand 0.08 - 10 mm² (AWG 28 - 8) – Single-wire strand 0.08 - 2.5 mm² (AWG 28 - 14) – For wire lengths 1 - 99999 mm – Feed rate 0 - 1.5 m/s – Controllable pressing force of the feed rollers – DC servo-drive – Insertion length 27 mm  (1.06 in.) 4050.455 Supply includes: – Length-cutting machine C8+ – Connection cable with connector – Software connection, CAE data – Installation CD Page 380 x 470 x 360 Cycle time s 15% loss) Technical specifications Tank: Material/volume l Aluminium / 2 Extinguisher: Type/fill volume l Novec™ 1230 / 1.8 Also required CMC III access sensor VX 1 pc(s). 7030.128 CMC III CAN bus connection cable 1 pc(s). 7030.091 808 818 Sealing kit for VX IT and LCP 1 pc(s). 7338.135 826 Pipe kit 1 pc(s). 7338.130 826 Slide rail, 1 U, depth-variable 2 pc(s). 5302.035 1088 Rittal System Catalogue 36/IT infrastructure Further technical information available on the Internet. 823 Early fire detection system System accessories Page 877  Network/server racks VX IT Page 686  Micro Data Center Page 842   The EFD III early fire detection system includes the smoke extraction system in a 482.6 mm (19") subrack with just 1 U. An integral fan continuously extracts air from the area being protected via a system of pipes. The air drawn in passes two fire detectors. If smoke is detected, the highly sensitive detector will emit a pre-alarm, while the second detector will activate the main alarm. The fire detectors are permanently monitored for correct functioning by the evaluation and control electronics on the control card. Benefits: – Early fire detection – 482.6 mm (19") rack mount with just 1 U – Tested by VdS Schadenverhütung GmbH – CAN bus interface to the CMC III monitoring system – Floating relay outputs (pre-alarm/main alarm/ collective fault) Note: – This system is designed solely for use in closed, non-accessible enclosure systems. Material: – Sheet steel Colour: – Enclosure: RAL 7035 – Front: RAL 9005 Protection category IP to IEC 60 529: – IP 30 EFD III Width mm Packs of 482.6 Height mm Page 44 Depth mm 490 Weight kg 15.0 Model No. 1 pc(s). 7338.221 Operating temperature range +10 °C...+40 °C Storage temperature range without batteries -20 °C...+65 °C Storage temperature range of batteries -15 °C...+40 °C Ambient humidity (non-condensing) % 96 Rated operating voltage V, ~, Hz 100 - 240, 1~, 50/60 Emergency power supply approx. 4 h Airflow monitoring approx. ±10% of total airflow 4 x/3 x relay outputs for alarms and faults (terminals/RJ12 jacks) 1 x/1 x input for door contact switch (terminal/RJ12 jack) 2 x CAN connections for master-slave networking 3 x connection (external alarm/manual call point/tank and fill level) 1 x voltage output for DET-AC slave III (24 V DC max. 500 mA) 1 x USB 2 x CAN bus interfaces to CMC III (max. 16 on PU/4 on PU Compact) Interfaces Sensors Optical smoke detector (sensitivity: approx. 3.5%/m light obscuration) Optical smoke detector HS (sensitivity: approx. 0.25%/m light obscuration) Display Plain-language display with 6 LEDs Also required CMC III CAN bus connection cable 1 pc(s). 7030.091 818 Pipe kit 1 pc(s). 7338.130 826 Slide rail, 1 U, depth-variable 2 pc(s). 5302.035 1088 824 Further technical information available on the Internet. Rittal System Catalogue 36/IT infrastructure Add-on unit System accessories Page 877  Network/server racks VX IT Page 686  Micro Data Center Page 842   This add-on unit to the DET AC III Master includes an additional extinguisher unit. In addition to the DET-AC III unit, a DET-AC III slave unit is used for each additional bayed enclosure and supplies the extinguishing agent for that enclosure. Detection occurs via the DET-AC III master system, even when multiple enclosures are bayed together. If a main alarm is reported, the DET-AC III Master will activate extinguishing in all systems simultaneously. Benefits: – Innovative extinguisher Novec™ 1230: eco-friendly, non-critical for IT components, non-conductive – 482.6 mm (19") rack mount with just 1 U – Tested by VdS Schadenverhütung GmbH – CAN bus interface to the CMC III monitoring system – In conjunction with the DET-AC III Master, extinguishes up to five racks in an enclosure suite – May be used in combination with EFD III – Floating relay outputs (pre-alarm/main alarm/ collective fault) Material: – Sheet steel Colour: – Enclosure: RAL 7035 – Front: RAL 9005 Note: – This system is designed solely for use in closed, non-accessible enclosure systems with a maximum volume of 2.8 m³. Protection category IP to IEC 60 529: – IP 30 DET-AC III slave Packs of Height mm 482.6 Depth mm 660 Weight kg 19.1 Model No. Page 44 1 pc(s). 7338.321 Operating temperature range +10 °C...+40 °C Storage temperature range without batteries -20 °C...+65 °C Storage temperature range of batteries -15 °C...+40 °C Ambient humidity (non-condensing) % IT infrastructure Width mm 96 Rated operating voltage V 24 (DC) Emergency power supply approx. 4 h 4 x/3 x relay outputs for alarms and faults (terminals/RJ12 jacks) 1 x/1 x input for door contact switch (terminal/RJ12 jack) 2 x CAN connections for master-slave networking 2 x connection (external alarm/manual triggering device) 1 x voltage output for DET-AC slave III (24 V DC max. 500 mA) 1 x USB 2 x CAN bus interfaces to CMC III (max. 16 on PU/4 on PU Compact) Interfaces Extinguisher is emitted via a propellant cartridge, with integral electrical activation unit Integral extinguisher monitoring (indication of >15% loss) Technical specifications Tank: Material/volume l Aluminium / 2 Extinguisher: Type/fill volume l Novec™ 1230 / 1.8 Also required CMC III access sensor VX 1 pc(s). 7030.128 Sealing kit for VX IT and LCP 1 pc(s). 7338.135 826 Pipe kit 1 pc(s). 7338.130 826 Slide rail, 1 U, depth-variable 2 pc(s). 5302.035 1088 Rittal System Catalogue 36/IT infrastructure Further technical information available on the Internet. 808 825 Fire alarm and extinguisher system Accessories Pipe kit for DET-AC III/EFD III Non-adhesive plug-in system for connecting to the DET-AC III fire alarm and extinguisher system and the EFD III early fire detection system. Packs of Model No. 1 pc(s). 7338.130 Packs of Model No. 1 pc(s). 7338.135 Functions: – The system fans continuously draw air out of the protected area via this pipe system. Technical specifications: – Diameter of plastic pipe: 18 mm internal, 22 mm external Colour: – Black Supply includes: – 3 plastic pipes @ 1 m – T-piece – 2 connector pieces, straight – 4 connection brackets, 90° – 2 end caps – Assembly parts Sealing kit for VX IT and LCP in conjunction with DET-AC III master/slave For closing openings in VX IT network/server racks and Liquid Cooling Packages when using a DET-AC III fire alarm and extinguisher system. Applications: – Closes the brush strips in two roof plates of the VX IT rack – Closes 1 brush strip in the roof plate of the LCP – Closes the opening in the base of the LCP CW/ LCP DX in the vicinity of the refrigerant/water lines Benefits: – Sealing of cable, hose and pipe glands in the roof and base section without impairing their function Material: – Polythene foam, self-adhesive on one side Colour: – Anthracite Supply includes: – 4 blanks to fit two VX IT roof plates – 1 blank for an LCP 826 Further technical information available on the Internet. Rittal System Catalogue 36/IT infrastructure IT Infrastructure Selector IT infrastructure All data centre product categories at a glance Use it online at www.rittal.com/it-configurator Rittal System Catalogue 36/IT infrastructure 827 RiZone Data centre infrastructure management – RiZone RiZone is Rittal’s DCIM solution for easy, efficient monitoring and control of a data centre’s physical infrastructure. It is designed to help improve the availability and efficiency of the data centre. The high availability demands of data centre users necessitates a comprehensive security management system. This relies on the monitoring of all data centre components and parameters with relevance to security and availability. RiZone is tasked with implementing all messages, sensor values and actuators in the IT infrastructure and server environment into a plausible message chain to ensure transparent operation of the data centre. The formulaic correlation in RiZone Editor transforms individual warnings, data or signals into logical information and actions, to maintain the data centre’s availability. RiZone – Optimum monitoring of IT infrastructure components ◾ Incorporation of the physical IT infrastructure ◾ Automatic detection of Rittal components ◾ Simple configuration of power distribution systems ◾ Workflow editor for user-defined scenarios ◾ Enhanced security and reliability ◾ Improved energy efficiency ◾ Integration of SNMP-compatible third-party equipment 828 Rittal System Catalogue 36/IT infrastructure IT infrastructure in context RiZone is the ideal solution for operating the entire IT infrastructure safely and efficiently. To this end, all processes are viewed in context and all components IT infrastructure are perfectly coordinated with one another. Prevention and reliability ◾ Identify hot spots in servers early on ◾ Continuously monitor individual electricity phases, avoid overloads and safeguard availability ◾ Set optimum climate control parameters Rittal System Catalogue 36/IT infrastructure Trends and resource planning ◾ Identify bottlenecks in the physical supply early on ◾ Transparently plan extensions to the infrastructure Functionality and efficiency ◾ Monitor PUE (power usage effectiveness) values ◾ Optimise energy efficiency in all areas 829 IT management software DCIM – Data Centre Infrastructure Management RiZone – Perfect support of IT infrastructure components Optional support of Rittal components – from server enclosures to power supply and climate control, through to security and monitoring technology – during integration and in the operational phase, with coordinated sensors and control systems. – The physical data centre infrastructure (OT devices) is incorporated into a data centre infrastructure management system. – RiZone supports SNMP V1/V2C and SNMP V3 – Simple configuration – Automatic detection of Rittal components – Workflow editor for user-defined scenarios (what happens if ...) – Enhanced security and reliability thanks to logical representation of the operating concept in RiZone – Energy optimisation in the data centre – Integration of SNMP-compatible third-party equipment ◾ Autodiscovery Detection of all SNMP-compatible IT infrastructure components ◾ Database In-house SQL database or link to external MS-SQL and Oracle databases ◾ Capacity management – Monitoring of data centre capacity utilisation – Redundancy monitoring of the climate control and power supply – Determination of optimum server installation positions – Optimisation of capacity utilisation and data centre availability ◾ Central access control – Central administration of acess data and PINs – One-time PIN function – Emergency PIN function – 2-way authorisation ◾ User administration – Granular user administration within RiZone – Support directory services ◾ Open Virtualization Format (OVF) – The virtual RiZone appliance is supplied in the industry standard OVF ◾ Active Directory – The RiZone server may be a member of a directory service – RiZone users may be a member of a directory service ◾ CMC III access control – Central administration of access control by RiZone – Administration of transponder cards – Centralised administration of access data – Import function RiZone plus Rittal components creates a system solution with maximum energy efficiency. Note: – RiZone Appliance Standard – RiZone IP node licence see page 831 ◾ Off-line project planning – Pre-configuration of RiZone projects – Supports Rittal CMC III components as well as RiMatrix S – Components are easily replaced using drag and drop 830 Further technical information available on the Internet. Rittal System Catalogue 36/IT infrastructure IT management software Rizone Appliance Standard RiZone is supplied as a software appliance. The software appliance is available as a virtual server in Open Virtualization Format (OVF) which is easily used on existing hardware in the data centre. RiZone installer – RiZone is installed on a client server – The software is installed by a Rittal engineer on a Windows server 2012R2 or 2016 Note: – RiZone supports the protocols SNMP V1/V2C and SNMP V3 for monitoring infrastructure components (OT devices) in a data centre. RiZone is manufacturer-neutral and suitable for use in a heterogeneous landscape of OT devices. – Available to download at www.rittal.com/software Also required: – RiZone IP node licence according to the number of IP nodes available Standard version Software appliance1) Model No. Hard drive + Windows RiZone software RiZone graphics tool 7990.103 7990.203 7990.303 – 7990.402 7990.502 Installer 1) All Model Nos. on the same line belong together, and must always be ordered together RiZone Appliance IP node licence The flexible RiZone licence model allows optimum adaptation to any project size, while at the same time being capable of growing with the data centre. RiZone software RiZone graphics tool 25 4 7990.206 7990.306 100 8 7990.208 7990.308 All Model Nos. on the same line belong together, and must always be ordered together Note: – Download available at www.rittal.com/software IT infrastructure The volume licences for the IP nodes are graduated with 25 and 100 nodes and may be adapted precisely to the size of the data centre. One node licence is required for each active component or other SNMP-compatible component to be covered. 1) Model No. Console licences included For no. of IP nodes1) Rittal System Catalogue 36/IT infrastructure Further technical information available on the Internet. 831 3 2 1 A 4 5 A B 832 Decentralised solutions B Centralised solutions Rittal System Catalogue 36/IT infrastructure IT solutions Edge Data Center The ideal solution for your applications .......................................................834 With efficient plug & play solutions and innovative cooling technology.........836 Reliable and redundant with split cooling solutions .....................................838 The modular concept in a security safe or container ...................................840 Micro Data Center High-availability in a security safe ................................................................842 Micro Data Center Level E ..........................................................................844 Micro Data Center Level B ..........................................................................846 RiMatrix S RiMatrix S – The standardised data centre..................................................848 RiMatrix S at a glance .................................................................................850 Data centre container The modular concept for complete IT infrastructures ..................................852 RiMatrix Data Cube ....................................................................................854 RiMatrix Data Cube IT, SME, cloud and edge applications..........................856 RiMatrix Data Cube All-in-One, SME, cloud and edge applications .............860 Security room High-availability for data centres .................................................................862 Basic Protection room and Basic Protection Plus room (GSR) ....................864 High-Availability room (HVR) .......................................................................865 Open Compute Project Open Compute Project (OCP).....................................................................866 Rack design for greater flexibility.................................................................868 Standard R-OCP V2 rack ...........................................................................870 Accessories ................................................................................................871 Software for IT infrastructure IT infrastructure IT infrastructure selector .............................................................................874 RiMatrix S selector......................................................................................874 Micro Data Center configurator...................................................................874 PDU configurator ........................................................................................875 IT cooling calculator....................................................................................875 DCIM – Data Centre Infrastructure Management.........................................875 6 Sample applications  Edge Data Center, see page 834  Micro Data Center, see page 842  Open Compute Project, see page 866  RiMatrix S, see page 848  IT container, see page 852  Security room, see page 862 Rittal System Catalogue 36/IT infrastructure 833 Edge Data Center The ideal solution for your applications 834 Rittal System Catalogue 36/IT infrastructure Edge & cloud solutions – for successful digitalization ◾ Industry 4.0, mobile streaming and selfdriving cars all demand the fastest response times, top-level security, and availability. Rittal edge solutions deliver just that. They allow you to securely store, process and share large quantities of data in real time, wherever it is needed. ◾ Edge computing can significantly reduce storage and transmission costs, because large volumes of data can be pre-processed with only relevant data subsequently being transferred to a cloud or IT infrastructure. In this way, an edge data centre ensures minimal latency combined with maximum reliability and security. Flexibility and reliability ◾ Edge data centres are always based around the local application. They must offer all the features of a “conventional” data centre, such as security and availability, since the availability of a production line depends on all its components, from the robot through to the edge data centre. ◾ Redundancy and fail-safe operation are key: The concept of continuous power & cooling ensures that the IT remains available for a defined period of time following a power failure so that the systems can be made safe. IT infrastructure ◾ Fully redundant edge solutions can also be used to protect highly sensitive applications. Scalability and physical protection ◾ Edge data centres are found across all industries in a wide range of application scenarios. The ability to adapt flexibly to the current situation is vital, as are standardised modular solutions enabling the fast assembly of large-scale edge topologies. ◾ Container solutions and outdoor enclosures facilitate siting outdoors, while micro data centres and security rooms provide bespoke protection in buildings when edge data centres must be protected from physical threats. Of course, the physical protective shield can be tailored precisely to keep pace with your growth plans. Rittal System Catalogue 36/IT infrastructure 835 Edge Data Center With efficient plug & play solutions and innovative cooling technology In industrial operations, building management, the logistics chain and logistics centres, the market for applications with edge data centres is continuously expanding. The emphasis here is on efficiency and reliability. Rittal’s innovative cooling units in the Blue e+ series with integral heatpipe herald a new dimension in efficiency, particularly for edge data centres at the lower end of the output range. 836 Rittal System Catalogue 36/IT infrastructure Your benefits at a glance: ◾ Interfaces to all sensors, machines and devices ◾ Low latency in critical applications ◾ Capture and analysis of unstructured data to avoid unnecessary transmission to the cloud ◾ Interface to other edge data centres and to superimposed services in the cloud ◾ Efficient plug & play cooling solution with no installation work required Example of a rear door-mounted cooling unit application: ◾ Cooling of IT equipment with standalone enclosure solutions ◾ Plug & play cooling solution with no installation work ◾ Rack-based cooling solution combined with 482.6 mm (19˝) rack extinguisher systems ◾ For use in industrial environments IT Infrastructure Product description Packs of Model No. IT rack Network/server enclosure VX IT, IP 55 1 5309.136 IT power PDU metered, 24 x C13/4 x C19, 1~, 16 A 2 7979.215 Wall-mounted-mounted cooling unit Blue e+ IT, up to 3 kW 1 3312.810 Air duct for wall-mounted cooling unit Blue e+ IT 1 3312.820 IoT interface 1 3124.300 Temperature/humidity sensor 1 7030.111 Access sensor 2 7030.120 IT cooling IT monitoring IT security Fire alarm and extinguisher system DET-AC III 1 7338.121 IT accessories IT LED system light, 600 lm 1 7859.000 IT infrastructure All the variants shown are sample configurations. Individually adaptable. Example of a roof-mounted cooling unit application: This edge solution is perfect for production and IoT sensor data capture, and for managing all types of data. IT Infrastructure Product description Packs of Model No. IT rack Network/server enclosure VX IT, IP 55 1 5303.134 IT power PDU metered, 12 x C13/1 x C19, 1~, 16 A 2 7979.210 IT cooling Roof-mounted cooling unit Blue e+ IT, 1.6 kW 1 3312.800 IoT interface 1 3124.300 IT monitoring Temperature/humidity sensor 1 7030.111 Access sensor 2 7030.120 IT security Smoke detector 1 7030.400 IT accessories IT LED system light, 600 lm 1 7859.000 All the variants shown are sample configurations. Individually adaptable. Rittal System Catalogue 36/IT infrastructure 837 Edge Data Center Reliable and redundant with split cooling solutions Edge data centres can handle a wide variety of tasks, not just data capture and condition monitoring. With critical processes, such as controlling traffic flows or monitoring production processes, it is particularly vital for an edge data centre to reflect the availability of the application. Scalable redundancy is the key here. 838 Rittal System Catalogue 36/IT infrastructure Example of an integrated cooling unit application: IT infrastructures comprising just one or two IT racks must still offer the same features as a large data centre. This begins with a reliable power supply and cooling, and extends through to monitoring. Smaller edge data centres are ideally suited for distributed installation across various locations for processing data in real time (for example, traffic monitoring and control). The coolant-based cooling units are designed as split solutions. Depending on the cooling output, the heat exchanger is either built into the server rack or bayed to the server rack. Heat is emitted direct outside of the building. IT Infrastructure Product description Packs of Model No. IT rack Network/server enclosure VX IT, IP 55 2 5309.190 IT power PDU metered, 24 x C13/4 x C19, 1~, 32 A 4 7979.216 IT cooling LCU DX, redundant, 6.5 kW 2 3311.493 IT monitoring CMC III monitoring system 1 7030.000 IT security Fire alarm and extinguisher system DET-AC III 1 7338.121 IT LED system light, 600 lm 2 7859.000 CAT 6, Network Cable Organizer 4 7044.110 IT accessories IT infrastructure All the variants shown are sample configurations. Individually adaptable. Example of a rack-based suite cooling application: Smart cities, interconnected vehicles and streaming services bring with them the challenge of continuous availability of safetyrelevant data. This calls for data centres with a maximum degree of fail-safeness. Edge data centres are the answer, being exceptionally energy-efficient with a small footprint. Rittal System Catalogue 36/IT infrastructure IT Infrastructure Product description IT rack IT power IT cooling IT monitoring IT security IT accessories Packs of Model No. Network/server rack VX IT, IP 55 4 5309.136 PDU metered, 24 x C13/6 x C19, 3~, 16 A 8 7979.236 LCP Rack DX, 12 kW 3 3313.420 Condenser unit for LCP DX 3 3311.360 CMC III monitoring system 1 7030.000 Automatic door opening (ADO) 1 7030.262 Access sensor 2 7030.120 Fire alarm and extinguisher system DET-AC III 1 7338.121 Add-on unit DET-AC III 3 7338.321 IT LED system light, 600 lm 1 7859.000 All the variants shown are sample configurations. Individually adaptable. 839 Edge Data Center The modular concept in a security safe or container Data such as personal patient data is highly sensitive and must be protected from theft, while production data must be protected from physical threats such as dust, fire and splashed water. The Micro Data Center provides the perfect housing for edge data centres. The numerous options available, coupled with the opportunity of baying, permit a high degree of flexibility at the point of use. 840 Rittal System Catalogue 36/IT infrastructure Continuously growing data volumes are having a major impact on IT infrastructure. Demand for CPU and storage capacity is increasing at the same pace, which means that more and more servers and storage systems are needed, while the floorspace available for IT infrastructure has barely changed. Rittal’s data centres in containers offer the perfect solution, because the standardised RiMatrix Data Cubes are installed in a short time and the concept is individually tailored to your requirements. ◾ Customised container solutions on a platform basis ◾ Predefined modules are individually compiled to create a container data centre ◾ Pre-assembled container solutions can be up and running in next to no time. ◾ Project planning by Rittal ◾ Turnkey delivery of a field-tested solution complete with comprehensive documentation. Application examples for Rittal container solutions: ◾ Lack of space, because more IT hardware is needed as data volumes grow ◾ Influence of IoT and Industry 4.0: Data exchange between the machines and data centre must be guaranteed ◾ With edge data centres, the computing performance is provided locally, data volumes are reduced, and pressure on the main company data centre is relieved Example of a security safe application: With its modular layout and option of dismantling and reassembly at any time, your edge data centre expands to accommodate your growing requirements. The security safe provides complete protection from physical threats and ensures the requisite fail-safeness for automated production in Industry 4.0 environments. Rittal System Catalogue 36/IT infrastructure If there is no suitable space available in the office building, factory hall or institution, it may be possible to site the edge data centre outdoors. The modular container from Rittal is the ideal platform for combining predefined solutions of server, power and cooling containers. Numerous options and a choice of redundancy classes mean that solutions are precisely aligned with customer requirements. IT Infrastructure Product description Container IT rack IT power IT cooling Packs of Model No. RiMatrix Data Center Container all-in-one, max. IT output 35 kW 1 RDC-AIO 35/ 3-M-II Server rack 3 5310.009 Network rack 1 5311.009 Low voltage distribution 1 7857.009 UPS, modular, 40 + 20 kW 1 DPA UPScale ST TS 8 PDU metered, 24 x C13/6 x C19, 3~, 16 A 4x2 7979.236 5 3313.430 LCP Inline DX, 12 kW All the variants shown are sample configurations. Individually adaptable. IT infrastructure Benefits of Rittal container solutions: IT Infrastructure Product description Packs of Model No. IT rack Micro Data Center Level E 1 7999.009 IT power PDU metered, 24 x C13/4 x C19, 1~, 32 A 2 7979.216 IT cooling LCU DX, redundant, 6.5 kW 1 3311.493 IT monitoring CMC III monitoring system Compact 1 7030.010 IT security Fire alarm and extinguisher system DET-AC III 1 7338.121 IT LED system light, 600 lm 1 7859.000 CAT 6, Network Cable Organizer 2 7044.110 IT accessories All the variants shown are sample configurations. Individually adaptable. 841 Micro Data Center High availability in a security safe 842 Rittal System Catalogue 36/IT infrastructure Optimum protection from physical threats ◾ Data such as personal patient data can be highly sensitive and must be protected from theft, while production data must be protected from physical threats such as dust, fire and splashed water. ◾ The Micro Data Center provides the perfect housing for data centres. The numerous options available, coupled with the opportunities for baying, make it an extremely flexible solution. ◾ With its modular layout and option of dismantling and reassembly at any time, your data centre can expand as your requirements grow. The security safe offers complete protection from physical threats in even the smallest space. Options for adapting to your needs ◾ The Micro Data Center is available in two variants – Level B (solid basic protection) and Level E (maximum protection). ◾ Level E MDCs are also bayable and can be fitted around your current installed IT racks even while operational. ◾ There are a range of climate control options available, with varying dissipated thermal loads and redundancies. For example, cooling in a security safe may be designed as fully redundant. IT infrastructure ◾ A fire alarm and extinguisher system protects your valuable IT components from threats inside the safe. Simple configuration of tested system solutions ◾ With the Rittal Micro Data Center, your security safe solution can be tailored to your exact application. ◾ System-tested quality means that the entire solution has been tested for fire protection, intruder protection, smoke protection and water/dust-tightness in accordance with the specified standards. ◾ Testing has been carried out by accredited institutes and confirmed with test reports. Rittal System Catalogue 36/IT infrastructure 843 Micro Data Center Level E System accessories Page 877 Material: – Sheet steel, coated Colour: – Enclosure and service door: RAL 7035 – Operator door: RAL 9005 Protection category IP to IEC 60 529: – IP 56 Internal dimensions mm 6 10 B1 T1 60 Supply includes: – Micro Data Center with operator door and service door – Cable entry in both side elements – Both doors with key lock 10 T2 Optional: – Choice of door hinges – Bifold doors – Different cable entry systems and different positions – Cable entry in the top/base unit – Different lock variants – Supporting structure U External dimensions mm 0 T3 B2 Note: – The Micro Data Center is configured on a project-specific basis 42 47 42 47 Width (B1) 1100 1100 1100 1100 Height (H1) 2210 2410 2210 2410 Depth (T1) 1200 1200 1400 1400 Depth (T3) 3320 3320 3520 3520 Width (B2) 920 920 920 920 Height (H2) 2030 2230 2030 2230 Depth (T2) Model No. 1000 1000 1200 1200 7999.009 7999.009 7999.009 7999.009 660 700 730 800 Empty weight excluding cooling unit and excluding rack approx. kg H1 Benefits: – As well as facilitating installation in poorly accessible sites, the modular design also makes it possible to retrospectively enclose existing IT structures. – Extendibility, dismantling and re-assembly mean targeted, future-safe investments – Tested security – testing has been carried out by accredited institutes and confirmed with test reports Protection standards: – Fire protection category F 90 to DIN 4102 Part 2 – Compliance with limit values ΔT < 50 K, rel. humidity < 85% over 30 minutes – Burglary resistance RC 2, optionally RC 3, tool attack analogous to DIN EN 1630/ 2011-09 and optionally WK 4, tool attack analogous to DIN V ENV 1630/ 1999-04/WK 4 – Smoke protection based on DIN 18 095-2: 1991-03 H2 Applications: – A high level of protection against potential physical threats for IT components – Targeted configuration components transform the safe into a complete Micro Data Center Page Accessories Fire alarm and extinguisher system DET-AC/EFD III see page see page see page see page CMC III monitoring system see page see page see page see page 823 800 PSM – Modular Power Distribution Unit see page see page see page see page 744 PDU – Power Distribution Unit see page see page see page see page 732 LCU – Liquid Cooling Unit see page see page see page see page 768 Standard protection from: Fire 844 Extinguishing water Corrosive gases Vandalism Further technical information available on the Internet. Unauthorised access Dust Theft/burglary Rittal System Catalogue 36/IT infrastructure Micro Data Center Level E Level E, options Operator door Service door Cable entry L/h DIN door hinge R/h DIN door hinge Bifold door ◾ ◽ ◽ L/h DIN door hinge R/h DIN door hinge Bifold door ◾ ◽ ◽ Soft duct1) in both side elements Hard duct2) in both side elements Cable box3) in both side elements Hard duct2) in top element Hard duct2) in base element ◾ ◽ ◽ ◽ ◽ 1) Size of soft duct: approx. 267 x 165 mm For fire protection reasons, the duct may be configured up to a max. of 60% with a maximum cable diameter of 15 mm and a maximum conduit diameter of 18 mm. 2) Size of hard duct: 2 panels each 120 x 120 mm Cables up to a diameter of 15 mm may be routed through the hard duct. 3) Size of cable box: Field 1 approx. 210 x 44, field 2 approx. 210 x 25 mm Cables up to a diameter of 15 mm and hoses up to a diameter of 44 mm may be routed through the cable box. No conduits may be routed through the cable box. Other positions are also possible. Locks Electronic combination lock1) Electronic combination lock for activation via an access control system supplied by the customer ◾ ◽ ◽ First code, second code and double code allocation possible. Key-based opening for inspection purposes supported. IT infrastructure 1) Key lock with 2 keys VX IT rack with air baffle plates Width mm 600 800 Height mm 2000 2200 2000 2200 2000 2200 2000 2200 Depth mm 1000 1000 1200 1200 1000 1000 1200 1200 ◽ ◽ ◽ ◽ ◽ ◽ ◽ ◽ Supporting structure Steel supporting structure to compensate for the raised floor height when siting the security safe on the bare floor. The height of the supporting structure is selectable between 100 mm and 1000 mm. Steel supporting structure to compensate for the raised floor height when siting the security safe on the bare floor. The supporting structure has a fire-proof covering. The height of the supporting structure is selectable between 100 mm and 1000 mm. ◽ ◽ ◾ Included with the supply ◽ Optional Rittal System Catalogue 36/IT infrastructure Further technical information available on the Internet. 845 Micro Data Center Level B System accessories Page 877 507 Material: – Sheet steel, coated Colour: – Enclosure and service door: RAL 7035 – Operator door: RAL 9005 Protection category IP to IEC 60 529: – IP 56 Supply includes: Material: – Securityplate safe with integral – Pladur® VX frame Colour: – 482.6 mm (19") mounting – Enclosure and rearfront door: RAL angles, standard, and rear 7035 – Adjusted air baffle plates – Every Operator RALis9005 – sidedoor: element prepared for one cable entry at the Supply includes: bottom and one cable – Safe with integral TS 8 entry frameat the topduct in both side ele– Cable – Operator ments and service door with swing-lever handle and profile – Operator and service door with half-cylinder swing-lever handle and semicylinder Optional: – Choice of door hinges – Bifold doors – Different cable entry systems and different positions – Different lock variants – Supporting structure with fire protection U External dimensions mm Internal dimensions mm T3T3 1 TT1 BB 11 T2T2 BB 22 Note: – The Micro Data Center is configured on a project-specific basis 42 47 42 47 Width (B1) 1115 1115 1115 1115 Height (H1) 2205 2405 2205 2405 Depth (T1) 1377 1377 1577 1577 Depth (T3) 3274 3274 3474 3474 Width (B2) 905 905 905 905 Height (H2) 2000 2200 2000 2200 Depth (T2) Model No. 1060 1060 1260 1260 7999.709 7999.709 7999.709 7999.709 595 630 660 700 Empty weight excluding cooling unit approx. kg H1 H1 Protection Protection standards: standards: – resistance – Fire Fire protection protection –F fire 90 to EN 1363 class EI 90/F to 4102 DIN and based on90 DIN EN 1363-1: 1999RC based on on – Theft protection 2 based DIN 4102-2: 1997 EN 1630 – resistance RC 2 Tool – Burglar Acrid gas-tightness based on attack analogous to DIN EN 1634 EN 1630/2011-09/RC 2 – Protection category IP 56 to IEC – Smoke 60 529 protection based on DIN EN 1634-3: 2005-01 H2 H2 Applications: Applications: – Basic protection against potenBasic protection against potential tial physical for IT comphysical threatsthreats for IT compoponents. nents. Project-specific configura– Targeted configuration compotion components transform the nents thecompact safe into a safe into transform a complete, complete Micro Data Center. data centre. Benefits: Benefits: – layout installation in ◾ Modular TS 8 frame withfor protection hard-to-access locations standards – weight ◾ Lower Modular layoutthan the Level E Data Center ◾ Micro Low weight – security – testing has ◾ Tested Easier cable entry carried out by accredited ◾ been Fast assembly institutes and confirmed with test reports Page Accessories Fire alarm and extinguisher system DET-AC/EFD III see page see page see page see page CMC III monitoring system see page see page see page see page 823 800 PSM – Modular Power Distribution Unit see page see page see page see page 744 PDU – Power Distribution Unit see page see page see page see page 732 LCU – Liquid Cooling Unit see page see page see page see page 768 Standard protection from: Fire 846 Extinguishing water Corrosive gases Vandalism Further technical information available on the Internet. Unauthorised access Dust Theft/burglary Rittal System Catalogue 36/IT infrastructure Micro Data Center Level B Level B, options Operator door Service door Cable entry L/h DIN door hinge R/h DIN door hinge Bifold door ◾ ◽ ◽ L/h DIN door hinge R/h DIN door hinge Bifold door ◾ ◽ ◽ Soft duct1) in both side elements Cable box2) in both side elements ◾ ◽ 1) Locks Supporting structure Swing lever handle with interchangeable profile half-cylinder Swing lever handle with electronic lock for external activation Swing lever handle with electronic lock with combination code ◾ ◽ ◽ IT infrastructure Size of soft duct: approx. 267 x 165 mm For fire protection reasons, the duct may be configured up to a max. of 60% with a maximum cable diameter of 15 mm and a maximum conduit diameter of 18 mm. 2) Size of cable box: Field 1 approx. 210 x 44, field 2 approx. 210 x 25 mm. Cables up to a diameter of 15 mm and hoses up to a diameter of 44 mm may be routed through the cable box. No conduits may be routed through the cable box. Steel supporting structure to compensate for the raised floor height when siting the security safe on the bare floor. The supporting structure has a fire-proof covering. The height of the supporting structure is selectable between 100 mm and 1000 mm. ◽ ◽ ◽ ◾ Included with the supply ◽ Optional Rittal System Catalogue 36/IT infrastructure Further technical information available on the Internet. 847 RiMatrix S RiMatrix S The standardised data centre 848 Rittal System Catalogue 36/IT infrastructure IT infrastructure – Fully operational The RiMatrix S standardised data centre is suitable for all architectures, be it main data centres, small data centres in distributed locations, or edge data centres located outdoors. The local conditions are of secondary importance, because RiMatrix S can be used both in existing properties and in container data centres. The significantly reduced planning times are key, because these highly efficient modules are fully pre-planned, including existing data sheets, implementation diagrams and documentation. In the longer term, another benefit of this system-tested solution is a significant reduction in your electricity bills, with detailed calculations possible even at the planning phase. Save time when planning ◾ Easily select your required modules with just one Model No. ◾ Complete documentation available at the planning phase ◾ Short delivery times and fast commissioning ◾ Pre-assembled modules for the installation of IT equipment, ready to use immediately ◾ Simplified final certification of the finished data centre Efficient technology ◾ Unique, efficient cooling solution ◾ Space-saving climate control in the raised floor ◾ n+1 redundancy in the power supply and cooling ◾ Complete low-voltage distribution system and PDUs pre-installed in the racks, UPS built into selected modules IT infrastructure ◾ Optional packages for comprehensive PUE (power usage effectiveness) monitoring using a prefabricated DCIM solution are available ◾ Documented low PUE (power usage effectiveness) of between 1.5 and 1.15 ◾ Documented system test of the entire data centre module Scalability from the edge to the cloud ◾ Standardised modules for simplified worldwide delivery ◾ Simple, uniform connection to supply infrastructures ◾ Different modules with outputs ranging from 10 kW to 450 kW (scalable) ◾ For use in existing premises in a simple protective cover or robust container structure Rittal System Catalogue 36/IT infrastructure 849 RiMatrix S at a glance Standard room The standardised data centre is assembled Supply includes: at your premises within the context of hot aisle/ – Advice and ROI calculation cold aisle containment. – Delivery and integration into the customer infrastructure Benefits: – Commissioning and handover – Aisle containment is a combination of door – Documentation, training, instruction and roof components which allow consist– Hotline and service/service agreements ent separation of the hot and cold air – Precise-fit aisle containment Model No. Exterior dimensions, width mm Exterior dimensions, height mm Exterior dimensions, depth mm Interior dimensions, width mm Interior dimensions, height mm Interior dimensions, depth mm Fire protection Burglar resistance Acrid gas-tightness Dust- and water-tightness Basic EMC protection Early fire detection Room extinguisher system Humidification and dehumidification system Server rack (600 x 2000 x 1200 mm) Combined network/server rack (800 x 2000 x 1200 mm) Uninterruptible power supply Low-voltage main distribution board (NSHV) PDU basic Climate control (ZUCS) Efficiency package 850 Single 6 7998.106 2807 2750 7067 2750 2722 7000 Double 6 7998.107 4839 2750 7070 4774 2722 7000 Single 9 7998.406 2807 2750 7067 2750 2722 7000 Double 9 7998.407 4839 2750 7070 4774 2722 7000 – – – – – – IP 20 – ◾ optional optional 6 – – IP 20 – ◾ optional optional 12 – – IP 20 – ◾ optional optional 8 – – IP 20 – ◾ optional optional 16 1 2 1 2 60 kW + 20 kW n+1 redundant 1 14 60 kW + 10 kW n+1 redundant 7998.905 2 x (60 kW + 20 kW) n+1 redundant 2 28 120 kW + 20 kW n+2 redundant 7998.906 – – 1 18 90 kW + 10 kW n+1 redundant 7998.907 2 36 180 kW + 20 kW n+2 redundant 7998.908 Rittal System Catalogue 36/IT infrastructure RiMatrix S at a glance Security room Material: – Element core made from thermally effective insulating material – Robust, encapsulated sheet steel cassette panels – Innovative connection system using patented profile technology – Use of temperature- and humidity-resistant seals – Optional use of overpressure control dampers – Dismantling and reassembly are possible at any time Supply includes: – Advice and ROI calculation – Delivery and integration into the customer infrastructure – Commissioning and handover – Documentation, training, instruction – Hotline and service/service agreements The standardised data centre is implemented in a container solution and can due to the robust sheet steel container construction be sited outdoors if required. Supply includes: – Robust sheet steel container with reinforced frame structure for optimum weight distribution – Housed interior wall structure with thermal insulating materials – Advice and ROI calculation – Delivery and integration into the customer infrastructure – Documentation, training, instruction – Hotline and service/service agreements Single 6 7998.306 2950 2800 7420 2750 2700 7220 EI 90 according to EN 1363/F 90 based on DIN 4102 RC III ◾ IP 56 ◾ ◾ optional optional 6 Double 6 7998.307 4976 2800 7420 4776 2700 7220 EI 90 according to EN 1363/F 90 based on DIN 4102 RC III ◾ IP 56 ◾ ◾ optional optional 12 Single 9 7998.606 2950 2800 7420 2750 2700 7220 EI 90 according to EN 1363/F 90 based on DIN 4102 RC III ◾ IP 56 ◾ ◾ optional optional 8 Double 9 7998.607 4976 2800 7420 4776 2700 7220 EI 90 according to EN 1363/F 90 based on DIN 4102 RC III ◾ IP 56 ◾ ◾ optional optional 16 Single 6 7998.206 3000 3000 7250 2750 2700 7000 Single 9 7998.506 3000 3000 7250 2750 2700 7000 – – RC II – IP 55 ◾ ◾ optional optional 6 RC II – IP 55 ◾ ◾ optional optional 8 1 2 1 2 1 1 60 kW + 20 kW n+1 redundant 1 14 60 kW + 10 kW n+1 redundant 7998.905 2 x (60 kW + 20 kW) n+1 redundant 2 28 120 kW + 20 kW n+2 redundant 7998.906 – – 1 18 90 kW + 10 kW n+1 redundant 7998.907 2 36 180 kW + 20 kW n+2 redundant 7998.908 Rittal System Catalogue 36/IT infrastructure 60 kW + 20 kW n+1 redundant 1 14 60 kW + 10 kW n+1 redundant 7998.905 IT infrastructure The standardised data centre at your premises is equipped with an additional security room (room-within-a-room) to provide additional protection from fire, water and smoke. Container – 1 18 90 kW + 10 kW n+1 redundant 7998.907 851 Data centre container The modular concept for complete IT infrastructures 852 Rittal System Catalogue 36/IT infrastructure IT technology plus matching infrastructure equals a complete system Growing data volumes and escalating requirements are creating ever more problems with space. Modular containers suitable for outdoor siting offer a possible solution and are highly scalable. Thanks to the container structure, a data centre can be planned with minimal effort and extended in the future. RiMatrix Data Cubes are a modular system from Rittal which provide the ideal basis for suitable projects and include server, power and cooling modules. There is also an all-in-one (AIO) variant available as a plug & play solution, in which the server zone and technical room are accommodated together in a single module. A scalable, modular system ◾ This flexible solution accommodates the specific requirements of individual applications ◾ Simple selection options help to streamline planning, with detailed planning of individual assemblies specifically for the application in each container ◾ Standardised components with tested and certified safety. ◾ Industrial production of the entire container is very fast, with installation and cabling of the IT hardware on request ◾ Suitable for outdoor siting ◾ Reduced installation phase thanks to the plug & play principle ◾ High level of scalability IT infrastructure ◾ Mobile and future-proof Efficiency and service ◾ Low CO2 emissions: Modern IT cooling units from Rittal support high levels of efficiency in containers compared with conventional data centres ◾ Continuous advice and planning from the Rittal data centre experts ◾ Servicing and preventive maintenance help to safeguard the longevity and maximum availability of your infrastructure Rittal System Catalogue 36/IT infrastructure 853 RiMatrix Data Cube Cooling: Efficient recooling systems in the container frame, ready to connect and system-tested with redundant chillers, free-cooling mode or additional free cooler and network functions Robust container cover: For siting outdoors, standardised dimensions for reduced planning effort Modular raised floor: In a range of application-specific heights 854 RiMatrix Data Cube IT: Ready-to-connect IT infrastructure in a robust container shell, as standardised IT modules in a range of output categories for SME, Cloud and Edge applications. Network racks: Pre-configured type VX IT for installing network technology and structured cabling, with two PDUs for redundant power supply Server racks: Pre-configured type VX IT for server installation, with cable guide rails and two PDUs for redundant power supply in the server exhaust air zone Rittal System Catalogue 36/IT infrastructure RiMatrix Data Cube Modules with maximum scalability From individual all-in-one containers through to large container parks, Rittal offers the maximum possible scalability with its comprehensive portfolio of solutions. For larger applications, uninterruptible power supply and cooling modules in the same container pitch pattern are added to the RiMatrix Data Cubes. For the conventional components of rack, power, cooling and monitoring, Rittal and its strategic partners Innovo Cloud and Lefdal also offer "IT as a Service", together with a location – the Lefdal Mine Datacenter in Norway – which can save up to 40 percent energy costs annually compared with a data centre in Germany. IT infrastructure RiMatrix Data Cube Power: Modular UPS systems with redundancy to supply one or more IT modules Individual equipment: All containers are equipped with the necessary infrastructure (lighting, service sockets, structured cabling etc.) Low-voltage distributor: Complete distributor system with connection point for the main supply and the outgoing feeders from all PDUs IT cooling: Cold water or coolant-based systems for energy-efficient cooling of the entire server inlet air zone, speed-controlled and with redundancy Rittal System Catalogue 36/IT infrastructure 855 RiMatrix Data Cube IT Design Maximum total IT output in kW Maximum IT output per rack in kW Redundancy of cooling system Redundancy of power supply RDC IT 50/10-L-III 50 5 2n 2n RDC IT 60/12-L-II 60 5 n+1 2n Cooling concept LCP systems are positioned between the racks, and depending on the variant, are either flush with or set forward from the enclosure suite. These systems cool the entire cold aisle in front of the servers and have a redundant design in the container variants. The variants with a second set of cold water pipelines also support n+n redundancies. Power concept The container main power supply is split among individual outgoing feeders to the PDUs in the individual enclosures via a low-voltage distributor. Each enclosure has an A supply and a B supply, thereby achieving n+1 redundancy. The main distributor offers separate connections for the A and B supply to which one or two UPS-buffered supply lines may be connected. A RiMatrix Data Cube Power with integral UPS may also be used to supply the containers. The container peripherals are supplied via an additional C-line. Racks Server rack W x H x D mm Network rack W x H x D mm Technical rack W x H x D mm Low-voltage distributor UPS, modular PDU Quantity Cooling Pipe systems Container size L x W x H mm (external dimensions) Current 856 600 x 2000 x 1200 800 x 2000 x 1200 600 x 2000 x 600 600 x 2000 x 1200 10 1 – 1 1 – 11 x 2 6 x LCP CW 2 set(s) 12192 (40 ft.) x 3000 x 3000 12 1 – 1 1 – 13 x 2 4 x LCP CW 1 set(s) 12192 (40 ft.) x 3000 x 3000 Rittal System Catalogue 36/IT infrastructure SME, cloud and Edge applications RDC IT 100/10-L-II 100 10 n+1 2n RDC IT 100/10-L-III 100 10 2n 2n Use of the zero-U-space cooling system (ZUCS) optimises use of the interior space by positioning the cooling units underneath the racks in the raised floor. Efficient EC fans ensure a constant server inlet air temperature in the shielded cold aisle. This system provides a redundancy of n+1. LCP systems are positioned between the racks, and depending on the variant, are either flush with or set forward from the enclosure suite. These systems cool the entire cold aisle in front of the servers and have a redundant design in the container variants. The variants with a second set of cold water pipelines also support n+n redundancies. The container main power supply is split among individual outgoing feeders to the PDUs in the individual enclosures via a low-voltage distributor. Each enclosure has an A supply and a B supply, thereby achieving n+1 redundancy. The main distributor offers separate connections for the A and B supply to which one or two UPS-buffered supply lines may be connected. A RiMatrix Data Cube Power with integral UPS may also be used to supply the containers. The container main power supply is split among individual outgoing feeders to the PDUs in the individual enclosures via a low-voltage distributor. Each enclosure has an A supply and a B supply, thereby achieving n+1 redundancy. The main distributor offers separate connections for the A and B supply to which one or two UPS-buffered supply lines may be connected. A RiMatrix Data Cube Power with integral UPS may also be used to supply the containers. The container peripherals are supplied via an additional C-line. 8 1 1 – 1 – 9x2 9 x ZUCS 1 set(s) 7250 x 3000 x 3000 Rittal System Catalogue 36/IT infrastructure 10 1 – 1 1 – 11 x 2 6 x LCP CW 1 set(s) 12192 (40 ft.) x 3000 x 3000 10 1 – 1 1 – 11 x 2 6 x LCP CW 2 set(s) 12192 (40 ft.) x 3000 x 3000 857 IT infrastructure RDC IT 90/8-M-I 90 10 n+1 2n RiMatrix Data Cube IT Design Maximum total IT output in kW Maximum IT output per rack in kW Redundancy of cooling system Redundancy of power supply RDC IT 200/10-L-II 200 20 n+1 2n Blob arrangement – Cooling concept Energy-efficient LCP systems with a cold water supply are used as cooling systems, and can each produce a cooling output of up to 55 kW. These systems are positioned in the row between the server racks and can easily be set forward into the cold aisle. This brings the cold air directly in front of the servers for cooling without deflection losses. Power concept The container main power supply is split among individual outgoing feeders to the PDUs in the individual enclosures via a low-voltage distributor. Each enclosure has an A supply and a B supply, thereby achieving n+1 redundancy. The main distributor offers separate connections for the A and B supply to which one or two UPS-buffered supply lines may be connected. A RiMatrix Data Cube Power with integral UPS may also be used to supply the high-performance containers. The container peripherals are supplied via an additional C-line. Server rack W x H x D mm Racks Network rack W x H x D mm Technical rack W x H x D mm Low-voltage distributor Current UPS, modular PDU Quantity Cooling Pipe systems Container size L x W x H mm (external dimensions) 858 600 x 2000 x 800 600 x 2000 x 1200 800 x 2000 x 800 800 x 2000 x 1200 600 x 2000 x 1200 – 10 – 1 1 1 – 11 x 2 6 x LCP CW 1 set(s) 12192 (40 ft.) x 3000 x 3000 Rittal System Catalogue 36/IT infrastructure SME, cloud and Edge applications RDC IT 200/10-L-I 200 20 n+1 2n RDC IT 200/10-ISO L-I 200 20 n+1 2n The racks and cooling systems are arranged so that two racks form a unit with one LCP. An additional LCP in the suite ensures redundancy. All racks are cooled evenly and energy-efficiently via the shared cold aisle, even with varying loads. The container main power supply is split among individual outgoing feeders to the PDUs in the individual enclosures via a low-voltage distributor. Each enclosure has an A supply and a B supply, thereby achieving n+1 redundancy. The main distributor offers separate connections for the A and B supply to which one or two UPS-buffered supply lines may be connected. A RiMatrix Data Cube Power with integral UPS may also be used to supply the high-performance containers. The container peripherals are supplied via an additional C-line. – 10 – 1 – 1 – 11 x 2 7 x LCP CW 1 set(s) 12192 (40 ft.) x 3000 x 3000 Rittal System Catalogue 36/IT infrastructure 10 – 1 – – 1 – 11 x 2 7 x LCP CW 1 set(s) 12192 (40 ft.) x 2438 x 2896 (ISO High Cube) 859 IT infrastructure Energy-efficient LCP systems with a cold water supply are used as cooling systems, and can each produce a cooling output of up to 55 kW. These systems are positioned in the row between the server racks and can easily be set forward into the cold aisle. This brings the cold air directly in front of the servers for cooling without deflection losses. RiMatrix Data Cube All-in-One Design Maximum total IT output in kW Maximum IT output per rack in kW Server rack Network rack Redundancy of cooling system Redundancy of power supply RDC AIO 35/3-M-II 35 10 5 n+1 2n RDC AIO 45/8-L-II 45 5 5 n+1 2n Cooling concept LCP systems are positioned between the racks, and depending on the variant, are either flush with or set forward from the enclosure suite. These systems cool the entire cold aisle in front of the servers and have a redundant design in the container variants. Coolant-based DX systems may also be used in the AIO variants, which are linked to the relevant external unit. These may also be optionally secured directly to the outer container sleeve. Power concept The container main power supply is split among individual outgoing feeders to the PDUs in the individual enclosures via a low-voltage distributor. Each enclosure has an A supply and a B supply, thereby achieving n+1 redundancy. The main distributor offers separate connections for the A and B supply; the integral modular UPS is positioned directly at the infeed to the B-line. The container peripherals are supplied via an additional C-line. Racks Server rack W x H x D mm Network rack W x H x D mm Low-voltage distributor UPS, modular PDU 3 1 – – 1 40 + 20 kW 4x2 8 1 – – 1 60 + 20 kW 9x2 Quantity 5 x LCP DX 6 x LCP DX Single Single 7250 x 3000 x 3000 12192 (40 ft.) x 3000 x 3000 Technical rack W x H x D mm Current Cooling Pipe systems Container size L x W x H mm (external dimensions) 860 600 x 2000 x 1200 800 x 2000 x 1200 600 x 2000 x 600 600 x 2000 x 1200 Rittal System Catalogue 36/IT infrastructure SME, cloud and Edge applications RDC AIO 90/8-L-II 90 10 5 n+1 2n RDC AIO 180/16-L-II 180 10 5 n+1 2n RDC AIO 180/16-L-III 180 10 5 2n 2n Use of the zero-U-space cooling system (ZUCS) optimises use of the interior space by positioning the cooling units underneath the racks in the raised floor. Efficient EC fans ensure a constant server inlet air temperature in the shielded cold aisle. This system provides a redundancy of n+1. LCP systems are positioned between the racks, and depending on the variant, are either flush with or set forward from the enclosure suite. These systems cool the entire cold aisle in front of the servers and have a redundant design in the container variants. The variants with a second set of cold water pipelines also support n+n redundancies. The container main power supply is split among individual outgoing feeders to the PDUs in the individual enclosures via a low-voltage distributor. Each enclosure has an A supply and a B supply, thereby achieving n+1 redundancy. A UPS is already integrated into the RDC-AIO 60/6-M-II. The container main power supply is split among individual outgoing feeders to the PDUs in the individual enclosures via a low-voltage distributor. Each enclosure has an A supply and a B supply, thereby achieving n+1 redundancy. The main distributor offers separate connections for the A and B supply; the integral modular UPS is positioned directly at the infeed to the B-line. The container peripherals are supplied via an additional C-line. 6 1 1 – 1 60 + 20 kW 7x2 6 x ZUCS for server zone 1 x ZUCS for UPS zone 1 set(s) 7250 x 3000 x 3000 Rittal System Catalogue 36/IT infrastructure 8 1 – – 1 100 + 20 kW 9x2 2x8 2x1 – – 2x1 2 x (100 + 20 kW) 2 x (9 x 2) 2x8 2x1 – – 2x1 2 x (100 + 20 kW) 2 x (9 x 2) 6 x LCP CW 2 x (6 x LCP CW) 2 x (6 x LCP CW) 1 set(s) 12192 (40 ft.) x 3000 x 3000 2 x 1 set(s) 12192 (40 ft.) x 3000 x 3000 2 x 2 set(s) 12192 (40 ft.) x 3000 x 3000 861 IT infrastructure RDC AIO 60/6-M-I 60 10 – n+1 2n Security room High availability for data centres 862 Rittal System Catalogue 36/IT infrastructure Customised protection from physical threats ◾ Innovative services provided by regional governments and banks, for example, demand the highest standards of security for storing sensitive citizen data and protecting it from manipulation. ◾ This data must be protected from physical threats such as fire, smoke, corrosive gases, dust and water, as well as unauthorised access. ◾ Security rooms are a room-within-a-room solution, in other words, a security room is constructed from base, wall and ceiling elements in an existing building and can be flexibly adapted to suit the local conditions, especially if changes cannot be made to the building’s structure. Adaptation to the building infrastructure and operational IT requirements ◾ The basic protection room/basic protection Plus room provides a high-quality, system-tested solution. The basic protection room is an optimum, modular roomwithin-a-room solution for protecting IT components and creating technical rooms. The flexible modular system allows it to be extended whilst operational. IT infrastructure ◾ The high-availability room offers maximum physical protection for data centres. The system was certified by ECB (European Certification Body GmbH) to ECB·S regulations. The modular concept offers the same benefits as a basic protection room, but with a higher level of protection. Tested system solutions ◾ System-tested quality means that the entire solution has been tested for fire protection, intruder protection, smoke protection and water-/dust-tightness in accordance with the specified standards. ◾ System testing covers the entire structure, comprising the cell structure and built-in modules such as doors, cable shields and ventilation units. ◾ Testing is carried out by accredited institutes and documented in test reports. Rittal System Catalogue 36/IT infrastructure 863 Basic Protection room and Basic Protection Plus room (GSR) Standard protection from: Fire Extinguisher water Corrosive gases Vandalism Unauthorised access Dust Falling debris Theft/ burglary IT power Page 722  IT cooling Page 756  IT monitoring Page 798 Your benefits with GSR, GSR Plus and HVR ◾ System-tested protection ◾ Multi-functional risk coverage ◾ Dust- and noise-reduced installation ◾ Dismantling and reassembly plus extendibility = investment security ◾ Adaptation of the different room systems With HVR only: ◾ System-tested high-availability protection ◾ ECB·S certification ◾ Independent quality monitoring Criterion System testing High security requirements The Basic Protection room provides a system-tested solution for protecting infrastructure components such as extinguisher systems, uninterruptible power supplies and cooling. The Basic Protection Plus room also offers solid basic protection for IT in addition to protection of infrastructure components. Structure of the Basic Protection room ◾ Element core made from thermally effective insulating material ◾ Robust, encapsulated sheet steel cassette panels ◾ Innovative connection system using patented profile technology ◾ Use of temperature- and humidity-resistant seals Standard System testing ECB·S certification to EN 1047-2, 50 K temperature increase and 85% rel. humidity up to 24 hours (post-heating period), 60 minutes flame impingement time Fire protection Corrosive combustion gases Falling debris Water Dust Unauthorised access Explosion EMC 50 K temperature increase and 85% rel. humidity without post-heating period, flame impingement time 30 minutes F 120 to DIN 4102; EI 120 (wall) to EN 1363 (component-tested) F 90 to DIN 4102 EI 90 to EN 1363 Acrid gas-tightness based on DIN 18 095 Impact test 200 kg from a drop height of 1.5 m with impact energy of 3,000 Nm Protection category IP X6 to IEC 60 529 Protection from standing water Protection category IP 5X to IEC 60 529 Resistance class RC4, tool attack analogous to DIN/EN 1630, door system only Resistance class RC3, tool attack analogous to DIN/EN 1630 Resistance class RC2, tool attack analogous to DIN/EN 1630 Detonation test Shield attenuation levels of up to 60 dB in the frequency range from 30 MHz to 3 GHz System-tested structures are tested as a complete unit, comprising the cell structure and built-in modules such as doors, cable shields or ventilation units. By contrast, generic component testing only refers to individual parts. Conventional construction methods refer to room structures made of plasterboard, concrete and other standard construction materials which do not offer sufficient protection for data centre applications. Conventional construction methods are generally unsuitable for use as a fire wall and are only component-tested. 864 Rittal System Catalogue 36/IT infrastructure High-Availability room (HVR) Standard protection from: Fire Extinguisher water Corrosive gases Vandalism Unauthorised access Dust Explosion Falling debris Theft/ burglary Mechanical access IT power Page 722  IT cooling Page 756  IT monitoring Page 798 Basic Protection room Basic Protection Plus room High-Availability room ◾ ◾ ◾ – – ◾ – – ◾ ◾ ◾ ◾ ◾ – ◾ – – ◾ – ◽ ◾ – ◾ ◾ ◾ ◾ ◾ – ◾ – ◽ ◾ – ◽ ◾ ◾ ◾ – ◾ ◾ ◾ ◾ ◾ ◾ ◾ ◾ ◾ ◽ IT infrastructure Structure of the High-Availability room ◾ Complex 4-layer element core made of thermally effective insulation substances ◾ Robust, encapsulated sheet steel cassette panels ◾ ECB·S tested, multiple lock, panic release ◾ Patented connection system ◾ Fireproof floor elements ◾ Use of extremely temperature- and humidity-resistant seals Maximum security The High-Availability room offers maximum physical protection for data centres and IT system locations. The system was certified by ECB (European Certification Body GmbH) to ECB·S regulations. This certification confirms that the High-Availability room meets the requirements of EN 1047-2 without restriction. Moreover, the construction of the security room is subject to continuous quality monitoring by an independent agent. ◾ Standard ◽ Option Rittal System Catalogue 36/IT infrastructure 865 Open Compute Project (OCP) Big data is a subject which is shaking up many areas of industry, commerce and trade. It is not only that data volumes are increasing exponentially. Also important is that efficient and fast data processing will in future be more and more decisive for business success. The OCP community came together to find solutions to this challenge. The prime objective of the Open Compute Project (OCP) is to reduce the investment and operating costs, energy consumption and environmental impact of data centres by way of innovative, fully standardised IT architectures. To this end, the OCP provides an open platform for the sharing of ideas and know-how, as a vehicle for the definition of ground-breaking standards for the data centre of the future. IT infrastructure – Architectures for the future As a leading manufacturer of IT infrastructures, Rittal is proud to be a member of the OCP community. Expertise in the standardization of data centre architectures, in particular, has established Rittal’s reputation as a strong partner when it comes to demanding OCP-related tasks. As well as building application-specific racks, Rittal has also extended its standard portfolio to include the Open Compute Project segment. This means that Rittal can now handle customer-specific enquiries as well as requests for standardised racks based on the latest OCP design. As well as the rack itself, Rittal also offers a comprehensive range of accessories, a special power supply unit, and a cooling system tailored to innovative OCP architecture, reinforcing Rittal's image as an operational technology (OT) portfolio provider to the OCP segment. In a joint collaboration with Bel Power Solutions & Protection, Rittal provides power supplies for OCP racks. These innovative and efficient power distributors are a key element of any OCP architecture. Substantial power savings can be made by transforming the power centrally and distributing it via the busbars that typify an OCP system. 48 V DC/36 kW 866 48 V DC/15 kW 12 V DC/6.6 – 13.2 kW Rittal System Catalogue 36/IT infrastructure IT infrastructure Rittal System Catalogue 36/IT infrastructure 867 Open Compute Project (OCP) Rack design for greater flexibility 868 Rittal System Catalogue 36/IT infrastructure Tried-and-tested rack design ◾ Complies with Open Rack Standards 1.2 and 2.0 ◾ Stable, firmly linked frame structure on castors ◾ Prepared to accommodate special OCP hardware with a system width of 21˝ at the front ◾ Highly efficient power distribution by connecting the hardware directly to the busbar integrated into the rack ◾ UL listed, CE compliant ◾ Variants available for both system voltages 12 V DC and 48 V DC ◾ Potential output range of a rack based on OCP: 13.2 kW – 40 kW More flexibility ◾ Doors available with a broad selection of lock options for keys, magnetic cards or numerical codes ◾ One-piece side panel for the end of row (EOR) rack ◾ Modular configuration of busbars Variable interior ◾ Height units in the Open Compute Design with a variable OpenU pitch pattern (OU) from 1 OU (48 mm) to 3 OU ◾ Preconfigured slide rails for direct installation of servers, height-adjustable on the OpenU (OU) pitch pattern IT infrastructure ◾ 21˝/19˝ adaptor for the additional integration of 482.6 mm (19˝) components optionally available ◾ Standard 1 U 482.6 mm (19˝) adaptor for tool-free installation of 19˝ hardware ◾ Special 482.6 mm (19˝) EIA brackets in various heights to accommodate multiple 19˝ devices Rittal System Catalogue 36/IT infrastructure 869 Standard R-OCP V2 rack OCP rack, 41 OpenU (OU), for use in energy-efficient IT architectures based on the principles of the Open Compute Project. Depending on the variant, with split 12 V DC busbar fitted at the rear, or without busbar for individual configuration. Depending on accessories and the use of power packs, one (single) or two (dual) power zones may be used in the rack. Benefits: – Complies with Open Rack Standards 1.2 and 2.0 – Stable, firmly linked frame structure on castors – Height units in the Open Compute Design with a variable OpenU pitch pattern (OU) of between 1 OU (48 mm) and 3 OU – Pre-assembled slide rails for direct installation of servers, height-adjustable on the OpenU (OU) pitch pattern – Prepared to accommodate special OCP hardware with a system width of 21" at the front – Highly efficient power distribution by connecting the hardware directly to the 12 V DC busbar integrated into the rack – 21"/19" adaptor for the additional integration of 482.6 mm (19") components optionally available – Matching OCP power packs (power shelves) and batteries (back-up units) for central power supply and protection optionally available in the rack – Extendible up to a maximum of 3 busbars Material: – Frame: Sheet steel Colour: – RAL 9005 Supply includes: – Firmly linked frame structure, with fitted castors, without doors, without side panels – 2 pairs of slide rails, 3 OU, pre-assembled – 16 pairs of slide rails, 2 OU, pre-assembled Please observe the productspecific scope of supply. Standards: – Open Rack Standard V2 Approvals: – UL Units OU 41 41 Width mm Packs of 600 600 Height mm 2246 2246 Depth mm 1068 1068 OCP V2 rack, deep, without busbar, for individual configuration OCP V2 rack, deep, incl. preconfigured 12 V DC busbar with 2 power zones Design Load capacity 15,000 N 15,000 N Colour RAL 9005 RAL 9005 Power consumption min./max. kW Model No. 1 pc(s). – 6.6 / 13.2 7100.200 7100.221 – ◾ 7100.312 – Page Product-specific scope of supply 1 x OCP busbar 12 V DC Also required OCP busbar 1 pc(s). 871 Accessories OCP busbar 1 pc(s). – 7100.312 871 OCP adaptor 2 pc(s). 7100.401 7100.401 871 OCP V2 side panel 2 pc(s). 7100.501 7100.501 871 see page see page 872 OCP PDU 870 Further technical information available on the Internet. Rittal System Catalogue 36/IT infrastructure OCP Accessories OCP busbar Design Output range Packs of Model No. 12 V DC 6.6 - 13.2 kW 1 pc(s). 7100.312 OCP busbar 12 V DC for power distribution in a standard R-OCP V2 rack. The busbar is fitted at the rear and is used to supply power to the hardware in the rack. The hardware and busbar make contact via a clip connection at the rear of the hardware. Benefits: – Multiple 12 V DC busbars may be combined – Simple configuration of two to one power zone – Greater energy efficiency with silver-plated contact area Material: – Copper, zinc-plated, silver-plated Supply includes: – Assembly parts OCP V2 side panel Height mm Depth mm Packs of Model No. 2246 1068 2 pc(s). 7100.501 OCP V2 side panel, 1-piece, for finishing off a rack suite with standard R-OCP V2 racks. Material: – Sheet steel Colour: – RAL 9005 OCP adaptor 21"/19" Adaptor for installing 482.6 mm (19") components in the 21" OCP rack system. The adaptor is screwfastened to the enclosure frame. U OU Packs of Model No. 1 2 pc(s). 7100.401 IT infrastructure Supply includes: – Assembly parts Material: – Sheet steel Supply includes: – Assembly parts Rittal System Catalogue 36/IT infrastructure Further technical information available on the Internet. 871 OCP Accessories OCP PDU The OCP PDU installed on the rack is needed to supply power to the OCP power shelves. The OCP PDU distributes power from the data centre to the power shelves fitted in the rack. Material: – Enclosure: Sheet steel Supply includes: – Connection cable Number Rated Type of Overvoltage To fit of voltage electrical protection Model No. outputs A connection Packs of Model No. Input voltage Infeeds Phases per infeed Output voltage 240 / 415 V AC 1 3~ 240 / 415 V AC 2 32 IEC 60 309 ◾ 7100.200/ 7100.221 1 pc(s). 7100.911 277 / 480 V AC 2 3~ 277 / 480 V AC 2 20 L22-20P ◾ 7100.200/ 7100.221 1 pc(s). 7100.912 2 30 L22-30P ◾ 7100.200/ 7100.221 1 pc(s). 7100.913 277 / 480 V AC 1 3~ 277 / 480 V AC 48 V DC 2 – 48 V DC 2 250 – – 7100.200/ 7100.221 1 pc(s). 7100.914 200 / 415 V AC 1 3~ 54.5 V DC 3 – – – 7100.200 1 pc(s). 7100.915 OCP Power Shelf Also required: The power shelf connects the power supply to the busbar of the OCP rack, while at the same time functioning as a rack-mounted frame for the power supply units and the battery back-up units. Depending on the variant, a built-in controller is pre-fitted for monitoring the power supply. Design Number of slots Shelf type: 3 x PSU / AC-DC 3 x UPS 872 Redundancy Output voltage 2+1 12 V DC – OCP PDU, see page 872 – OCP Power Supply Unit, see page 873 Accessories: – OCP Battery Back-up Unit, see page 873 – OCP Power Supply Unit, see page 873 Active Number of power outputs kW 6.6 Shelf type: AC/DC-DC 6 x PSU 3+3 / 5+1 12 V DC 18 Shelf type: AC/DC-DC 6 x PSU 3+3 / 5+1 12 V DC 18 1 Height OU Productspecific scope of supply To fit Packs of Model No. Model No. 3 – 7100.221 1 pc(s). 7100.921 3 1 Built-in controller 7100.200 1 pc(s). 7100.922 1 1 Built-in controller 7100.221 1 pc(s). 7100.923 7100.200 1 pc(s). 7100.924 Shelf type: AC/DC-DC 6 x PSU 3+3 / 5+1 48 V DC 24 1 1 Built-in controller Shelf type: DC-DC 6 x PSU 3+3 / 5+1 12 V DC 15 1 1 Built-in controller 7100.221 1 pc(s). 7100.925 Blanking cover – – – – – 1 – 7100.921 1 pc(s). 7100.961 Blanking cover – – – – – 1 – 7100.921 1 pc(s). 7100.962 Further technical information available on the Internet. Rittal System Catalogue 36/IT infrastructure OCP Accessories OCP Power Supply Unit The power supply unit (PSU) is a power pack which centrally transforms the current or voltage in an OCP rack. The PSUs operate in parallel mode. A power shelf is needed for installation of the power supply units. Depending on the power shelf, up to 6 PSUs may be installed. Benefits: – May be connected with the system operational – Parallel operation with active load distribution Design Input voltage Output voltage Active power kW Power pack To fit Model No. Power Module PM 200 - 277 V AC 12.6 V DC 3.3 AC - DC 7100.921 1 pc(s). 7100.931 Power Module PM 90 - 300 V AC / 240 - 400 V DC 12.3 V DC 3 AC/DC - DC 7100.922/ 7100.923 1 pc(s). 7100.932 Power Module PM 90 - 300 V AC / 192 - 400 V DC 1 pc(s). 7100.933 Power Module 200 - 277 V AC / PM 192 - 400 V DC Power Module PM 40 - 72 V DC Blanking cover – Packs of Model No. 12.3 V DC 3.6 AC/DC - DC 7100.922/ 7100.923 48 V DC 4 AC/DC - DC 7100.924 1 pc(s). 7100.934 12,5 V DC 3 DC - DC 7100.925 1 pc(s). 7100.935 – 7100.922/ 7100.923 1 pc(s). 7100.963 – – OCP Battery Back-up Unit The battery back-up unit is an internal UPS in OCP architecture housed inside the rack, to ensure a controlled shutdown of the hardware and data backup in the event of a power failure. Design Input voltage Active power kW To fit Model No. Packs of Model No. Lithium ion battery back-up unit 52.5 V DC 3.6 7100.921 1 pc(s). 7100.951 Rittal System Catalogue 36/IT infrastructure Further technical information available on the Internet. IT infrastructure Benefits: – May be connected with the system operational – Parallel operation with active load distribution 873 Software for IT infrastructure Configurators/Tools/CAD data IT Infrastructure Security, availability and efficiency are crucial to the productive operation of a data centre. This calls for a comprehensive approach which addresses all the relevant requirements as well as the peripheral conditions in order to devise a suitable solution. As well as personalised advice, Rittal can also provide you with a comprehensive range of tools for selecting, configuring and monitoring all relevant parameters. IT infrastructure selector The selector supports you as partner, system integrator, system engineer or end customer in selecting the right IT products for your specific application. Selector for: – VX IT network/server enclosures – Power Distribution Unit – Liquid Cooling Package DX/CW – Monitoring system CMC III – Monitor/keyboard unit – Fire alarm and extinguisher system DET-AC III RiMatrix S selector Your selector for standardised data centres for SMEs, branch concepts and flexible cloud applications. Your solution is configured on the basis of standardised data centre modules. Benefits: – RiMatrix S at a glance – Explanation of the option packages – Efficiency calculation for your location – As the outcome, you can save your compiled RiMatrix S solution as a PDF file. Micro Data Center configurator Configuration of your security safe, including a range of configuration components. Benefits: – All product segments in the data centre at a glance: Network/server racks, solutions for IT cooling, IT power and IT monitoring – For added value, suitable accessories are suggested in every segment. – The result is an individual IT infrastructure, ready for you to request a quote from Rittal. Note: – Use it online at www.rittal.com/it-configurator Note: – Use it online at www.rittal.com/configurators – Download for free from the Google Play Store or App Store Android app iPhone app Benefits: – Your complete micro data centre in just a few steps – Individual selection of configuration components – When you have finished, you can request a quote for your current configuration Note: – Configure online at www.rittal.com/mdc-configurator 874 Further technical information available on the Internet. Rittal System Catalogue 36/IT infrastructure Software for IT infrastructure Configurators/Tools/CAD data PDU configurator Customise PDUs from the Rittal standard portfolio to suit your specific requirements. Assisted by the Rittal Configuration System (RiCS), you can then visualise your configured solution directly during the selection process. The modular concept: – Adapt existing standard PDUs (built to order), delivery time up to 14 days – Use a modular system comprised of individual system modules – Wide range of accessories – Additional modules, e.g. for overvoltage protection and for measuring differential current IT cooling calculator Simple selection of water-based Liquid Cooling Packages (LCP) for rack and suite cooling for your IT infrastructure. Benefits: – List and visualise your configuration – Delivery times are shown transparently – Get direct pricing information when you log into the online shop Note: – Use it online at www.rittal.com/configurators Benefits: – Calculation of the cooling output of LCPs – Consideration of the various physical parameters – Save your finished calculation as a PDF file Note: – Configure online at www.rittal.com/it-cc DCIM – Data Centre Infrastructure Management Note: – Detailed product description, see page 830 Rittal System Catalogue 36/IT infrastructure IT infrastructure RiZone – Perfect support of IT infrastructure components – Customer-focused and cost-efficient – Optimum monitoring of IT infrastructure components – The physical data centre infrastructure (OT devices) is incorporated into a data centre infrastructure management system. – RiZone supports SNMP V1/V2C and SNMP V3 – Simple configuration – Automatic detection of Rittal components – Workflow editor for user-defined scenarios – Enhanced security and reliability – Enhanced energy efficiency – Integration of SNMP-compatible third-party equipment Further technical information available on the Internet. 875 876 Rittal System Catalogue 36/System accessories SYSTEM ACCESSORIES Base/plinth Base/plinth system VX ................................................................................880 Base/plinth system AX ................................................................................888 Base/plinth .................................................................................................890 Base Base...........................................................................................................892 Walls Side panels.................................................................................................901 Divider panels/partitions..............................................................................904 Isolator door locking ...................................................................................909 Baying system Baying ........................................................................................................911 Doors/locks Door variants ..............................................................................................917 Installation accessories for modular front design .........................................925 Viewing windows/operating panels .............................................................929 Lock systems .............................................................................................933 Hinges ........................................................................................................951 Door, internal ..............................................................................................952 Roof/wall mounting Roof ...........................................................................................................958 Wall mounting.............................................................................................965 Interior installation Mounting plates..........................................................................................970 Rail systems ...............................................................................................983 Assembly components .............................................................................1001 Component shelves..................................................................................1006 System lights ............................................................................................1014 EMC .........................................................................................................1028 Interior installation for areas at risk of earthquakes ....................................1031 Earthing ....................................................................................................1033 Power supply Socket strips ............................................................................................1040 Cable management Cable entry ...............................................................................................1044 Gland plates .............................................................................................1049 Cable glands ............................................................................................1056 Cable routing inside the enclosure ............................................................1058 Cable routing 19"......................................................................................1067 482.6 mm (19") installation system System accessories Swing frames............................................................................................1075 Accessories for Data Rack........................................................................1079 Mounting angles .......................................................................................1080 Slide rails ..................................................................................................1086 482.6 mm (19˝) installation ........................................................................1090 Splicing boxes ..........................................................................................1099 Patch panels.............................................................................................1100 LSA connection system ............................................................................1102 Human/machine interface Handles ....................................................................................................1103 External mounting accessories .................................................................1106 Front assembly .........................................................................................1107 Monitors ...................................................................................................1109 Keyboards, supports and drawers............................................................1110 Interfaces..................................................................................................1117 Signal pillars .............................................................................................1120 Technical information Coating/spray-finishing .............................................................................1128 Protection categories................................................................................1129 Rittal System Catalogue 36/System accessories 877 Base/plinth system VX – More efficiency 878 Rittal System Catalogue 36/System accessories Integral centring aid ◾ The centring aid for base/plinth mounting on the enclosure frame ensures precise positioning of the enclosure on the base/ plinth Enclosure attachment ◾ The nuts integrated into the base/plinth corner piece allow screw-fastening directly from above, through the stable base frame, or from below, into the enclosure corner piece Simple cable management ◾ Secure cable attachment and cable routing via the punched section with mounting flange in the base/plinth Rittal System Catalogue 36/System accessories System accessories ◾ Gain space with simple integration of the cable clamping rail and C rail for secure, user-friendly cable routing 879 Base/plinth Base/plinth system VX Modular base/plinth diversity The innovative base/plinth system VX offers an unprecedented diversity of functions and applications. It combines all existing base/plinth functions in a single solution, as well as opening up many new applications. As if that isn't enough, it is also compatible with existing enclosure solutions TS, TS IT, SE, PC and IW. In short, it is a base/plinth system. The base/plinth system VX comprises the following components: – Base/plinth corner pieces with base/plinth trim panels, front and rear – Base/plinth trim panels, sides All trim panels may optionally be clipped into the corner piece, or securely screw-fastened. Depending on the application, for example, users can dispense with the trim panels between bayed enclosure suites, or a 100 mm high trim panel may be used to stabilise the base/plinth corner pieces. In combination with its extensive range of accessories, and thanks to its compatibility with enclosure accessories, the base/plinth system VX offers almost infinite possibilities in terms of siting, transportation, cable routing, cable attachment and base/plinth configuration. Thanks to fully symmetrical corner pieces, and by using the same base/plinth trim panels in the width and depth, the system opens up many new applications. For example, the vented trim panels and trim panels with brush strips available as accessories may now optionally be attached at the sides, or exchanged for the front/rear trim panels. Base/ plinth height Basic form One Model No. for the base/plinth corner pieces with base/plinth trim panels, front and rear One Model No. for the base/ plinth trim panels, sides One complete base/plinth VX Cable entry options Stabilisation of bayed base/plinths 100 mm 200 mm Configuration examples Order includes Functional benefits 3 packs Base/plinth corner pieces with base/plinth trim panels 1 pack Base/plinth trim panels, sides, 200 mm high Continuous cable chamber 3 packs 1 pack 1 pack 1 pack Base/plinth corner pieces with base/plinth trim panels Base/plinth trim panels, sides, 200 mm high Base/plinth trim panels, sides, 100 mm high Baying brackets, internal (8617.500, packs of 6) 4 pc(s). are required for this solution 3 packs Base/plinth corner pieces with base/plinth trim panels 2 packs Base/plinth trim panels, sides, 200 mm high Additional stability during transportation with base/plinth trim panels rotated through 90° Shielding of the base/plinths from one another Other options: – Cable entry at the side by fitting a 100 mm base/plinth trim panel with brush strip – Cable entry from the rear by dismantling one or more trim panels from the base/plinth corner pieces and replacing them with trim panels with brush strips – Cable routing in the base/plinth by using punched sections with mounting flanges on the base/plinth trim panels 880 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Base/plinth Base/plinth system VX Base/plinth corner pieces with base/plinth trim panels, front and rear Sheet steel for VX, VX IT, VX SE, TE, TopConsole, one-piece console, PC, IW High-load capacity base/plinth corner pieces with moulded self-positioning to the enclosure, may be used with or without trim panels depending on the application. Large openings in the corner piece for optimum access to the screw-fastening point, may be concealed with a plastic corner and baying cover. Material: – Base/plinth corner piece: Sheet steel – Base/plinth trim panel, front/rear: Sheet steel – Corner and baying cover: Plastic Colour: – RAL 9005 100 mm high supply includes: – 4 base/plinth corner pieces, 100 mm high – 4 corner covers – 1 baying cover – 2 base/plinth trim panels, front/rear, 100 mm high – Assembly parts 200 mm high supply includes: – 4 base/plinth corner pieces, 200 mm high – 4 corner covers – 1 baying cover – 1 base/plinth trim panel, front/rear, 200 mm high – 2 base/plinth trim panels, front/rear, 100 mm high – Assembly parts 100 mm high For enclosure width mm Model No. 300 8640.000 400 8640.001 600 8640.002 800 8640.003 850 8640.004 1000 8640.005 1100 8640.006 1200 8640.007 1600 8640.008 1800 8640.009 200 mm high For enclosure width mm Model No. 300 8640.020 400 8640.021 600 8640.022 800 8640.023 1000 8640.024 1200 8640.025 1600 8640.026 1800 8640.027 Also required: – Base/plinth trim panels, sides, to finish off a unit, for additional stabilisation between base/plinths, or for interior configuration, see page 882 Accessories: System accessories – Base/plinth trim panels with brush strip, see page 882 – Base/plinth trim panels, vented, see page 883 – Base/plinth installation bracket, see page 885 – Levelling component for base/plinth, see page 886 – Base mounting plate, see page 885 – Base/plinth adaptor for twin castors and levelling feet, see page 893 – Baying bracket, internal, see page 912 – Transport castors for base/plinth VX, see page 884 – C rails, see page 996 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 881 Base/plinth Base/plinth system VX Base/plinth trim panels, sides Sheet steel for base/plinth VX To finish off a base/plinth unit at the sides and for additional stabilisation or for the interior configuration of bayed base/plinths. One 200 mm high or two 100 mm high trim panels may optionally be fitted on 200 mm high base/plinths. Material: – Sheet steel 100 mm high For enclosure depth mm Model No. 300 8640.030 400 8640.031 500 8640.032 600 8640.033 800 8640.034 1000 8640.035 1200 8640.036 Colour: – RAL 9005 Supply includes: – 2 base/plinth trim panels – Assembly parts 200 mm high For enclosure depth mm Model No. 300 8640.040 400 8640.041 500 8640.042 600 8640.043 800 8640.044 1000 8640.045 1200 8640.046 Accessories: – Base/plinth installation bracket, see page 885 Possible alternative: – Base/plinth trim panels with brush strip, see page 882 – Base/plinth trim panels, vented, see page 883 Base/plinth trim panels with brush strip Sheet steel for base/plinth VX For cable entry in the base/plinth. With a base/plinth height of 200 mm, one or two trim panels with brush strips may optionally be used. Thanks to the complete symmetry of the base/plinth system VX, the trim panels with brush strip may either be fitted at the front, rear or side on the base/plinth corner piece. For enclosure width/depth mm Model No. 600 8620.092 800 8620.093 1000 8620.094 1200 8620.095 Material: – Base/plinth trim panels: Sheet steel – Brush strip: Plastic, self-extinguishing Colour: – RAL 9005 Supply includes: – 2 base/plinth trim panels with brush strip – Assembly parts 882 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Base/plinth Base/plinth system VX Base/plinth trim panels, vented Sheet steel for base/plinth VX For venting the enclosure via the base/plinth. Specifically in applications such as power distribution where the enclosure gland plates are not used, this can be used to achieve a higher air throughput inside the enclosure. Various solutions to raise the roof and special roof plates with vent openings are also available for enclosure venting. With a 200 mm base/plinth height, one or two vented trim panels may optionally be used. Thanks to the complete symmetry of the base/plinth system VX, the vented trim panels may either be fitted at the front, rear or side on the base/plinth corner piece. For enclosure width/depth mm Model No. 600 8620.090 800 8620.091 Accessories: – – – – Filter mat, see page 883 Base/plinth installation bracket, see page 885 Spacers for lifting the roof, see page 964 Roof plate with vent holes, see page 961 Material: – Sheet steel Colour: – RAL 9005 Supply includes: – 2 base/plinth trim panels, vented – Assembly parts for mounting on the base/plinth corner piece Filter mat Packs of Model No. for base/plinth trim panel, vented The filter mat is simply inserted into the trim panel from the rear. 1 pc(s). 8620.100 Supply includes: – 1 pack = 2 rolls, length 2 m each, may be shortened to required length Baying cover for VX base/plinth To neatly close the gap between two bayed base/ plinths and it is required to close the gap at the rear when baying three or more base/plinths. Height mm Packs of Model No. 100 10 pc(s). 8620.010 200 10 pc(s). 8620.011 Material: – Plastic ABS, halogen-free Colour: – RAL 9005 Rittal System Catalogue 36/System accessories System accessories Note: – A baying cover is already included as standard with the supply of base/plinth corner pieces with base/plinth trim panels, front and rear Further technical information available on the Internet. 883 Base/plinth Base/plinth system VX Cable chamber For enclosures Packs of Model No. 500 1 pc(s). 8600.455 600 1 pc(s). 8600.465 600 500 1 pc(s). 8600.655 Material: – Sheet steel 600 600 1 pc(s). 8600.665 800 500 1 pc(s). 8600.855 Colour: – RAL 7035 800 600 1 pc(s). 8600.865 1200 500 1 pc(s). 8600.255 1200 600 1 pc(s). 8600.265 Width mm Depth mm 400 400 Height: 200 mm for VX, VX SE With integral system punchings for individual system accessories. Supply includes: – 1 frame – 2 trim panels front/rear – Assembly parts for mounting on the enclosure Accessories: – Side panels for cable chamber, see page 884 Side panel for cable chamber Height: 200 mm For enclosure depth mm Packs of Model No. 500 2 pc(s). 8600.510 600 2 pc(s). 8600.520 Material: – Sheet steel Colour: – RAL 7035 Supply includes: – 2 side panels – Assembly parts Transport castors for VX base/plinth For locating onto the base/plinth corner piece, 100 or 200 mm high. Load capacity: – Maximum permissible load per twin castor: 750 N Colour: – RAL 9005 Supply includes: – 4 twin castors, 2 x with, 2 x without locks 884 Further technical information available on the Internet. Floor clearance mm Model No. 100 8100.700 Accessories: – Base/plinth trim panels, sides, sheet, for stabilisation, see page 882 – Base/plinth trim panels, sides, stainless steel, for stabilisation, see page 887 Rittal System Catalogue 36/System accessories Base/plinth Base/plinth system VX Base mounting plate Packs of Model No. for base/plinth VX, base/plinth AX and base/plinth, complete For attaching the base/plinth to the floor. For assembly screws up to 12 mm Ø. 10 pc(s). 2817.000 Material: – Sheet steel Surface finish: – Zinc-plated Base/plinth installation bracket for VX base/plinth For configuring the base/plinth with punched sections with mounting flanges or cable clamp rails. To fit 100 and 200 mm high base/plinth trim panels in sheet steel and stainless steel. Material: – Stainless steel 1.4301 (AISI 304) Supply includes: – 2 installation brackets – 2 mounting brackets for cable clamp rail – Assembly parts For base/plinth trim panel Height mm Packs of 100 2 pc(s). 200 2 pc(s). Model No. 8620.400 Accessories: – Punched section with mounting flange, 23 x 64 mm, see page 991 – Punched section with mounting flange, 23 x 89 mm, see page 991 – Cable clamp rail, see page 1059 Note: – For interior installation on upright base/plinth trim panels – For base/plinth trim panels rotated through 90°, the installation bracket is not needed, because in this position, the system punchings of the base/ plinth trim panels may be used directly 2 2 1 1  Installation bracket with mounting bracket for 5 cable clamp rail  Cable clamp rail  Installation bracket  Punched section with mounting flange, 3 3 4 4 23 x 89 mm  Base/plinth trim panel, rotated through 90° System accessories 5 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 885 Base/plinth Base/plinth system VX Levelling component for VX base/plinth For retrospective levelling on uneven floors at the installation site up to a maximum of 15 mm. Installed through the base/plinth corner piece. Adjusted using a hex spanner, width across flats 19 mm. For base/plinth height mm Packs of Model No. 100 4 pc(s). 8100.710 200 4 pc(s). 8100.711 Benefits: – A door offset caused by uneven flooring can be corrected – Installed on the assembled enclosure, i.e. no need to plan levelling in advance Load capacity: – Max. admissible load: 2500 N per levelling component (check the load capacity of the floor) Supply includes: – Assembly parts Base/plinth corner pieces with base/plinth trim panels, front and rear Stainless steel for VX, VX SE, PC High-load capacity base/plinth corner pieces with moulded self-positioning to the enclosure, may be used with or without trim panels depending on the application. Large openings in the corner piece for optimum access to the screw-fastening point, may be concealed with a plastic corner and baying cover. Material: – Base/plinth corner piece: Stainless steel 1.4301 (AISI 304) – Base/plinth trim panel, front/rear: Stainless steel 1.4301 (AISI 304 steel) – Corner and baying cover: Plastic Surface finish: – Trim panel: Grain size 400 100 mm high supply includes: – 4 base/plinth corner pieces, 100 mm high – 4 corner covers – 1 baying cover – 2 base/plinth trim panels, front/rear, 100 mm high – Assembly parts 200 mm high supply includes: – 4 base/plinth corner pieces, 200 mm high – 4 corner covers – 1 baying cover – 1 base/plinth trim panel, front/rear, 200 mm high – 2 base/plinth trim panels, front/rear, 100 mm high – Assembly parts 886 Further technical information available on the Internet. For enclosure width mm Height mm Model No. 600 100 8620.050 800 100 8620.051 1000 100 8620.052 1200 100 8620.053 600 200 8620.060 800 200 8620.061 1000 200 8620.062 1200 200 8620.063 Also required: – Base/plinth trim panels, sides, to finish off a unit, for additional stabilisation between base/plinths, or for interior configuration, see page 887 Accessories: – Base/plinth installation bracket, see page 885 – Levelling component for base/plinth, see page 886 – Base mounting plate, see page 885 – Base/plinth adaptor for twin castors and levelling feet, see page 893 – Transport castors for base/plinth, see page 884 – C rails, see page 996 Rittal System Catalogue 36/System accessories Base/plinth Base/plinth system VX Base/plinth trim panels, sides Stainless steel for base/plinth VX To finish off a base/plinth unit at the sides and for additional stabilisation or for the interior configuration of bayed base/plinths. One 200 mm high or two 100 mm high trim panels may optionally be fitted on 200 mm high base/plinths. Material: – Stainless steel 1.4301 (AISI 304) Surface finish: – Brushed, grain size 400 Height mm Model No. 400 100 8620.070 500 100 8620.071 600 100 8620.072 400 200 8620.080 500 200 8620.081 600 200 8620.082 Accessories: – Base/plinth installation bracket, see page 885 System accessories Supply includes: – 2 base/plinth trim panels – Assembly parts For enclosure depth mm Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 887 Base/plinth Base/plinth system AX Modular base/plinth diversity The innovative base/plinth system AX offers an unprecedented diversity of functions and applications. The base/plinth system AX comprises the following components: – Base/plinth corner pieces with base/plinth trim panels, front and rear – Base/plinth trim panels, sides Base/ plinth height Basic form One Model No. for the base/plinth corner pieces with base/plinth trim panels, front and rear One Model No. for the base/ plinth trim panels, sides One complete base/plinth AX Cable entry options Stabilisation of bayed base/plinths 100 mm 200 mm Base/plinth corner pieces with base/plinth trim panels, front and rear Sheet steel for AX, AX IT Base/plinth corner pieces with large opening for optimum access to the screw-fastening point, may be concealed with a plastic corner cover. Material: – Base/plinth corner piece: Sheet steel – Base/plinth trim panel, front/rear: Sheet steel – Corner cover: Plastic Colour: – RAL 9005 100 mm high supply includes: – 4 base/plinth corner pieces, 100 mm high – 4 corner covers – 2 base/plinth trim panels, front/rear, 100 mm high – Assembly parts 200 mm high supply includes: – 4 base/plinth corner pieces, 200 mm high – 4 corner covers – 1 base/plinth trim panel, front/rear, 200 mm high – 2 base/plinth trim panels, front/rear, 100 mm high – Assembly parts 888 Further technical information available on the Internet. 100 mm high For enclosure width mm Model No. 600 2820.061 800 2820.081 1000 2820.101 1200 2820.121 200 mm high For enclosure width mm Model No. 600 2820.062 800 2820.082 1000 2820.102 1200 2820.122 Also required: – Side base/plinth trim panels, to finish off a base/ plinth unit at the end or for interior configuration of the base/plinth, see page 889 Accessories: – Base mounting plate, see page 885 Rittal System Catalogue 36/System accessories Base/plinth Base/plinth system AX Base/plinth trim panel, sides Sheet steel for base/plinth AX To finish off a base/plinth unit at the sides or for the interior configuration of the base/plinth. One 200 mm high or two 100 mm high trim panels may optionally be fitted on 200 mm high base/ plinths. Material: – Sheet steel Colour: – RAL 9005 100 mm high For enclosure depth mm Model No. 300 2820.310 400 2820.410 200 mm high For enclosure depth mm Model No. 300 2820.320 400 2820.420 System accessories Supply includes: – 2 base/plinth trim panels – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 889 Base/plinth Base/plinth Base/plinth, complete Sheet steel for TP universal console Trim panels, front and rear with fitted corner pieces and side trim panels. For consoles Width mm Depth mm Base/plinth depth mm Model No. 600 500 450 2807.200 Height: 100 mm Material: – Sheet steel Surface finish: – Spray-finished Accessories: – Fastening bolt, see page 891 – Base mounting plate, see page 885 Colour: – RAL 7022 Supply includes: – 4 corner pieces – 2 trim panels, front/rear – 2 trim panels, side – Mounting accessories for mounting on the enclosure Base/plinth, complete Stainless steel for one-piece console, stainless steel Height: 100 mm Where necessary, 2 base/plinths may be installed one above the other. For enclosures / consoles Model No. Width mm Depth mm 600 400 2865.000 800 400 2869.000 1000 400 2867.000 1200 400 2870.000 Material: – Stainless steel 1.4301 (AISI 304) Surface finish: – Brushed Accessories: – Levelling feet HD, see page 223 Supply includes: – 2 trim panels, front/rear – 2 trim panels, side – Mounting accessories for mounting on the enclosure Base/plinth, static for PC, IW Design-coordinated with the enclosures, height 100 mm, with front projection. Material: – Sheet steel, 2.0 mm Colour: – RAL 7035 – Design component, front: RAL 7015 For depth mm Packs of Model No. 600 1 pc(s). 8800.920 Accessories: – Twin castors 7495.000, see page 893 – Levelling feet 4612.000, see page 892 – Fastening bolt 2819.000, see page 891 Supply includes: – 1 design component, front – 1 base/plinth component, rear – 2 base/plinth trim panels, side 890 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Base/plinth Base/plinth Fastening bolts for base/plinth, complete and base/plinth, static For mounting on base/plinth trim panels, side. The lockable fastening bolt allows the installation of cable clamp rails. Tighten with hex spanner, width across flats 19 mm. Material: – Hexagonal steel For base/plinth trim panel Height mm Packs of Model No. 100 10 pc(s). 2819.000 200 10 pc(s). 2819.200 Accessories: – Cable clamp rail, see page 1059 1) Cross member adjustable for VX, VX SE, TP, PC, IW To increase stability, adjustable to the enclosure depth. Material: – Sheet steel 1671) Only for height 200 mm For enclosure depth mm Model No. 400 8601.450 500 600 8601.680 800 Height: 70 mm To increase stability, the cross member is positioned below the base frame of the enclosure and protrudes 138 mm at the front and rear. For deeper enclosures, the rear part may be extended and screw-fastened again. For screw-fastening to the floor and enclosure with mounting hole at the sides, front and rear. The castors and levelling feet may be secured to the welded nuts M12. 1171) 67 Surface finish: – Zinc-plated Accessories: – Twin castors 6148.000, 7495.000, see page 893 – Levelling feet 4612.000, see page 892 Assembly instruction: – Ensure sufficient stability to prevent the enclosure from tipping over Surface finish: – Spray-finished Base/plinth for FlatBox For attachment purposes, the base/plinth may be mounted on the pre-existing thread in the base area of the FlatBox. There is a rear recess provided for cable entry. For base area Height mm Packs of Model No. 600 50 1 pc(s). 7507.750 700 50 1 pc(s). 7507.755 Width mm Depth mm 600 700 System accessories Colour: – RAL 7015 Material: – Sheet steel Surface finish: – Powder-coated Colour: – RAL 7035 Supply includes: – 4 levelling feet – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 891 Base Base Levelling feet For enclosure for VX, VX IT, VX SE, PC, IW To compensate for height differences with floor irregularities. Mounting thread M12. Load capacity: – Max. admissible load: approx. 3000 N per levelling foot Levelling range mm Packs of Model No. Sheet steel 18 – 43 4 pc(s). 4612.000 Stainless steel 55 – 125 4 pc(s). 8100.780 Also required: – For mounting on the base/plinth: Base/plinth adaptor, see page 893 Levelling feet Packs of Model No. with internal adjustment, for VX IT To compensate for floor irregularities. When used in the mounting bracket, the levelling feet are moved inwards to allow convenient operation from inside the enclosure so that the enclosure is easily levelled, even retrospectively. 4 pc(s). 5301.326 Note: – Use levelling foot 4612.000 and base/plinth adaptor 8100.770 for mounting on the VX base/plinth Load capacity: – Max. admissible static load: 6500 N per levelling foot Supply includes: – 4 levelling feet, M12, with TX30 hex socket drive – 4 mounting brackets – Assembly parts Levelling feet Packs of Model No. for FlatBox M10 x 20 mm For screw-fastening onto the enclosure base when used as a floor-standing or desktop enclosure. Width across flats 17, mounting thread multi-tooth 30. 4 pc(s). 7507.740 Load capacity: – Max. admissible static load: 5500 N per levelling foot 700 N per enclosure 892 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Base Base Levelling feet Packs of Model No. for VX, VX SE, PC 85 – 115 mm high For mounting on enclosures, for easier floor cleaning and to compensate for floor irregularities ±15 mm. 4 pc(s). 2859.000 Load capacity: – Max. admissible load: 3,500 N per levelling foot Material: – Stainless steel 1.4301 (AISI 304) Supply includes: – Assembly parts Twin castors Mounting thread M12 x 20. For: – Baying enclosure system VX – Network/server racks VX IT – Free-standing enclosure system VX SE – PC enclosure system – Pedestal base plate – Pedestal 6106.200/6106.300 – TopConsole pedestals – Industrial Workstation – Data Rack Supply includes: – Packs of 4 twin castors, 2 x with, 2 x without locks – Assembly parts Base/plinth adaptor for twin castors and levelling feet For mounting twin castors and levelling feet to the base/plinth. Maximum admissible static load (per castor)  75 kg Floor clearance 85 mm Black with grey running surface Colour Model No. 6148.000 1  Maximum admissible static load (per castor) 120 kg Floor clearance 125 mm Colour Black Model No. 7495.000 Note: For mounting on the VX base/plinth, only twin castors 7495.000 may be used in combination with the base/plinth adaptor for twin castors, see page 893 Material Packs of Model No. Sheet steel 4 pc(s). 8100.770 4 pc(s). 8100.771 2 Also required: System accessories – When fitting twin castors, side trim panels, see page 882/887, are required. Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 893 Base Base Transport kit Packs of Model No. for VX, VX IT empty enclosures To easily transport empty enclosures to the point of use. 1 pc(s). 5301.515 Load capacity: – Max. static load: 2,000 N per set of castors, including enclosure Assembly instruction: – The base area must be open at the mounting points Supply includes: – 4 castors – 4 mounting brackets – Assembly parts Castor module for VX, VX IT For mobile use even with preconfigured enclosures. The castor module is screw-fastened to the structure directly underneath the base frame and is suitable for transporting configured enclosures on flat ground and inside buildings. The castor modules already have pre-integrated levelling feet, allowing the enclosure to be levelled directly on site at the point of installation. The castor module can remain underneath the enclosure. Load capacity: – Max. admissible load: Static 15,000 N – Max. admissible load: Dynamic 10,000 N For enclosure width mm Packs of Model No. 600 2 pc(s). 5301.516 800 2 pc(s). 5301.518 Note: – The maximum admissible load capacity (dynamic) of 10,000 N refers to rolling over flat ground Assembly instruction: – The base area must be open at the mounting points Supply includes: – 1 transport module with 2 castors – 1 transport module with 2 castors, fixed – Assembly parts Stabiliser Packs of Model No. for VX IT If required, the optional stabiliser for the VX IT may be retrofitted in situ at any time. With the front door open, simply snap onto the vertical sections of the enclosure frame and level to match the enclosure height. This enlarges the enclosure’s footprint and makes it less likely to tip over when installed components are withdrawn from the enclosure or fitted in the front. It can be used as an alternative if the enclosures cannot be screw-fastened to the floor or secured in an enclosure suite. After installation, simply remove the stabiliser again. The stabiliser may be used on the enclosure frame without bottommounting and in combination with levelling feet or a base/plinth up to 200 mm high. The striking signalred spray-finish draws attention to this trip hazard. 2 pc(s). 5301.325 Load capacity: – Max. extension weight: 200 kg, point of gravity 250 mm from the enclosure front Material: – Sheet steel, spray finished in RAL 3001 (signal red) Supply includes: – 2 levelling stabilisers with fast, tool-free installation 1 200 kg  Max. distance to the front edge of the enclosure 250 mm 894 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Base Base Transport castors for TE The castors may be screw-fastened in the corner areas of the base frame in place of the levelling feet. Floor clearance: 58 mm, mounting thread M10 x 20 Max. load capacity (static) per enclosure N Packs of Model No. 3000 4 pc(s). 7000.672 Supply includes: – Assembly parts System divider for VX, VX SE Divides the enclosure width into two zones. For example, this allows mounting plates, cable clamp rails or swing frames from 600 mm wide enclosures to be fitted in 1200 mm wide enclosures. Material: – Sheet steel Surface finish: – Zinc-plated Depth mm Packs of Model No. 500 2 pc(s). 8620.900 600 2 pc(s). 8620.901 Accessories: – Swing frame mounting kit, see page 1078 – Cable clamp rail, see page 1059 – Support rails 48 x 26 mm, see page 996 System accessories Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 895 Base Base Gland plates For enclosure width 600 mm for VX, VX IT, VX SE For individual configuration of the floor space. Potential equalisation is provided via assembly components and earthing points. Material: – Sheet steel Surface finish: – Zinc-plated Depth mm Packs of Model No. 75 1 pc(s). 8001.210 175 1 pc(s). 8001.214 237.5 1 pc(s). 8001.218 275 1 pc(s). 8001.222 For enclosure width 800 mm Supply includes: – Assembly parts Note: – At least one sliding plate is required to fully seal a base opening – For two-door enclosures, one pack is sufficient for one half of the enclosure Example with enclosure depth 600 mm T1 (600 mm) - 148 = T2 (452 mm)  Sliding plate T1 Depth mm Packs of Model No. 75 1 pc(s). 8001.211 175 1 pc(s). 8001.215 237.5 1 pc(s). 8001.219 275 1 pc(s). 8001.223 For enclosure width 1000 mm Depth mm Packs of Model No. 75 1 pc(s). 8001.212 175 1 pc(s). 8001.216 237.5 1 pc(s). 8001.220 275 1 pc(s). 8001.224 For enclosure width 1200 mm 1 275 75 Depth mm Packs of Model No. 75 1 pc(s). 8001.213 175 1 pc(s). 8001.217 237.5 1 pc(s). 8001.221 275 1 pc(s). 8001.225 T2 Accessories: – Sliding plate, see page 896 Sliding plate for VX, VX IT, VX SE For variable compensation as well as a flexible opening in the base area. May be combined with gland plates. For enclosure width mm Packs of Model No. 600 1 pc(s). 8001.239 800 1 pc(s). 8001.241 1000 1 pc(s). 8001.242 1200 1 pc(s). 8001.243 Sliding plate depth: – 65 – 115 mm Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts 896 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Base Base Gland plate set, multi-piece, solid for VX IT Multi-piece gland plate set consisting of solid base plate modules and a sliding plate for cable entry. The solid gland plate module, depth 237.5 mm, may optionally be exchanged for gland plate module variants for cable entry. Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Gland plate set – Sealing tape – Assembly parts Benefit: – The sequence of individual modules may be freely selected For enclosure width mm For enclosure depth mm Gland plate module, solid Depth 75 mm Depth 175 mm Depth 237.5 mm Depth 275 mm Sliding plate depth 115 mm Packs of Model No. 600 1000 – – 2 1 1 1 pc(s). 5301.338 600 1200 – – 4 – 1 1 pc(s). 5301.341 800 600 1 1 – – 2 1 pc(s). 5301.336 800 800 1 – 2 – 1 1 pc(s). 5301.337 800 1000 – – 2 1 1 1 pc(s). 5301.344 800 1200 – – 4 – 1 1 pc(s). 5301.347 Gland plate module, vented for VX IT For closing the base Benefit: – Large perforated section to support passive climate control of the enclosure – Filter mat slides in from above for easy replacement Gland plate depth: – 237.5 mm Material: – Sheet steel For enclosure width mm Packs of Model No. 600 1 pc(s). 5301.330 800 1 pc(s). 5301.331 Assembly instruction: – Several gland module plates must be combined to seal the base completely in the VX IT – The gland plate module may be combined in exchange with other base modules with a depth of 237.5 mm Surface finish: – Zinc-plated Gland plate module, one-piece, with brush strip for VX IT For targeted cable entry from below. Gland plate depth: – 237.5 mm Material: – Module plate: Sheet steel – Brush strip: Plastic, UL 94 HB, halogen-free Surface finish: – Module plate: Zinc-plated Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories For enclosure width mm Packs of Model No. 600 1 pc(s). 5301.332 800 1 pc(s). 5301.333 System accessories Supply includes: – Gland plate module, vented – Filter mat – Assembly parts Note: – Gland plate modules with brush strip not suitable for applications with a protection category to IEC 60 529 Assembly instruction: – Several gland module plates must be combined to seal the base completely in the VX IT – The gland plate module may be combined in exchange with other base modules with a depth of 237.5 mm Further technical information available on the Internet. 897 Base Base Gland plate module, multi-piece, with brush strip, super-airtight for VX IT For targeted cable entry from below. With correct cable entry, special brush strips with alternating offset brushes provide a more effective seal from the environment to support climate control. The twopiece design even allows retrospective fitting of the base module with the cables already installed. Gland plate depth: – 237.5 mm Material: – Module plate: Sheet steel – Brush strip: Plastic, UL 94 HB, halogen-free Surface finish: – Module plate: Zinc-plated For enclosure width mm Packs of Model No. 600 1 pc(s). 5301.334 800 1 pc(s). 5301.335 Note: – Gland plate modules with brush strip not suitable for applications with a protection category to IEC 60 529 Assembly instruction: – Several gland module plates must be combined to seal the base completely in the VX IT – The gland plate module may be combined in exchange with other base modules with a depth of 237.5 mm. Supply includes: – Assembly parts Gland plate module for side cable entry for VX IT With adjustable opening and brush strips on both sides. The version which is open at the side even allows the base plate module to be retro-fitted with the cables already installed. Gland plate depth: – 237.5 mm Material: – Module plate: Sheet steel – Brush strip: Plastic, UL 94 HB, halogen-free Surface finish: – Module plate: Zinc-plated For enclosure width mm Packs of Model No. 800 1 pc(s). 5301.348 Note: – Gland plate modules with brush strip not suitable for applications with a protection category to IEC 60 529 Assembly instruction: – Several gland module plates must be combined to seal the base completely in the VX IT – The gland plate module may be combined in exchange with other base modules with a depth of 237.5 mm. Supply includes: – Assembly parts 898 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Base Base Module plates for TE The base area of the TE may be varied as required using the module plates. Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Compensating panel design Width B1 mm Depth T1 mm For enclosure width mm Model No. 450 50 600 7526.750 450 150 600 7526.755 650 50 800 7526.790 650 150 800 7526.795 Width B1 mm Depth T1 mm For enclosure width mm Model No. 450 200 600 7526.829 650 200 800 7526.834 Width B1 mm Depth T1 mm For enclosure width mm Model No. 450 200 600 7526.760 450 550 600 7526.770 450 750 600 7526.780 650 200 800 7526.800 650 550 800 7526.785 650 750 800 7526.820 Vented design Solid design Design with brush strip Width B1 mm Depth T1 mm For enclosure width mm Model No. 450 200 600 7526.850 650 200 800 7526.860 T B1 B T1 System accessories Please note the following when selecting suitable module plates: B1 = Enclosure width (B) - 150 mm T1 = Enclosure depth (T) - 50 mm Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 899 Base Base Base mounting bracket Packs of Model No. for VX, VX IT To anchor the enclosure to the floor, particularly if it is top-heavy and inclined to tilt or cannot be incorporated into a suite of enclosures. 2 pc(s). 5301.350 Material: – Sheet steel, zinc-plated Supply includes: – Assembly parts Assembly instruction: – The base area must be open at the mounting points – Additional holes in the false base are required for mounting – The assembly parts for connecting the enclosure to the substructure will vary according to its specific properties and are not included with the supply Pressure relief stopper Packs of Model No. Especially when enclosures are exposed to changing climatic conditions, pressure differences may cause condensation to form in sealed enclosures. The integral sealing membrane in the pressure relief stopper largely prevents such pressure differences and hence eliminates condensation; additionally, it also prevents the ingress of moisture from the outside. Installed in vertical surfaces to protect against dirt. 5 pc(s). 2459.500 Technical specifications: – Air permeability up to 120 litres/hour with a pressure difference of 70 mbar – Connection thread M12 x 1.5 – For fitting in wall thicknesses up to 4 mm Material: – Polyamide Colour: – Similar to RAL 9005 Protection category IP to IEC 60 529: – IP X8 Protection category IP to DIN 40 040-9: – IP 69K Supply includes: – Lock nut Condensate discharge Packs of Model No. For reliable condensate discharge from the inside and protection against splashed water from the outside (labyrinth effect). A hole diameter of 16 mm is required (with AX sheet steel, the holes are already provided in the base). 6 pc(s). 2459.000 Material: – Polyamide Colour: – Similar to RAL 7035 Protection category: – Protection from splashed water, when correctly installed at the bottom 900 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Walls Side panels Side panel, screw-fastened, sheet steel For enclosures Height mm Depth mm Packs of Model No. 800 600 2 pc(s). 8173.245 1200 500 2 pc(s). 8115.245 1200 600 2 pc(s). 8170.245 1200 800 2 pc(s). 8175.245 1200 1000 2 pc(s). 8176.245 1400 500 2 pc(s). 8145.245 1600 500 2 pc(s). 8165.245 1600 600 2 pc(s). 8166.245 1600 800 2 pc(s). 8168.245 1800 400 2 pc(s). 8184.245 Material: – Sheet steel, 1.5 mm 1800 500 2 pc(s). 8185.245 1800 600 2 pc(s). 8186.245 Surface finish: – Dipcoat-primed, powder-coated on the outside 1800 800 2 pc(s). 8188.245 2000 400 2 pc(s). 8104.245 Colour: – RAL 7035 2000 500 2 pc(s). 8105.245 2000 600 2 pc(s). 8106.245 Protection category IP to IEC 60 529: – IP 55 (in conjunction with enclosures from the VX, VX IT series) 2000 800 2 pc(s). 8108.245 2000 1000 2 pc(s). 8100.245 2000 1200 2 pc(s). 8102.245 2200 600 2 pc(s). 8126.245 2200 800 2 pc(s). 8128.245 2200 1000 2 pc(s). 8120.245 2200 1200 2 pc(s). 8122.245 for VX, VX IT – Time-saving assembly thanks to clip-in side panel holders – Automatic potential equalisation and higher EMC protection, thanks to enclosure panel holders with earthing inserts located on the inside – Easy positioning in the height and depth with the location aid – Simple assembly – Earthing bolts with large, paint-free contact surface for optimum contact Protection category NEMA: – NEMA 12 (in conjunction with enclosures from the VX, VX IT series) Supply includes: – Assembly parts Accessories: – Hinge for side panel, screw-fastened, sheet steel, see page 902 for VX – Time-saving assembly thanks to clip-in side panel holders – Automatic potential equalisation and higher EMC protection, thanks to enclosure panel holders with earthing inserts located on the inside – Easy positioning in the height and depth with the location aid – Simple assembly – Earthing bolts with large, paint-free contact surface for optimum contact For enclosures Packs of Model No. 400 2 pc(s). 8700.030 500 2 pc(s). 8700.040 600 2 pc(s). 8700.050 Height mm Depth mm 1800 1800 2000 System accessories Side panel, screw-fastened, stainless steel Material: – Stainless steel 1.4301 (AISI 304), 1.5 mm Surface finish: – Brushed, grain size 400 Protection category IP to IEC 60 529: – IP 55 (in conjunction with enclosures from the VX series) Protection category NEMA: – NEMA 12 (in conjunction with enclosures from the VX series) Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 901 Walls Side panels Hinge Packs of Model No. for side panel, screw-fastened, sheet steel The 180° opening angle allows unhindered access from the side. 6 pc(s). 8106.260 Material: – Die-cast zinc Colour: – RAL 7035 Note: – Hinge mounting (red) is only possible in the vicinity of the rear panel (blue) – Only for use with a side panel depth of 800 mm or less Protection category IP to IEC 60 529: – IP 55 (in conjunction with enclosures from the VX, VX IT series) Supply includes: – Assembly parts Internal latch Packs of Model No. for side panel, screw-fastened, sheet steel Additional security is achieved via the option of latching the side panel from the inside. The side panels on the frame section are screw-fastened from the inside with latching brackets. 2 pc(s). 5301.235 Surface finish: – Sheet steel, zinc-plated Assembly instruction: – Access via the front and rear doors must be guaranteed Protection category IP to IEC 60 529: – IP 55 (in conjunction with enclosures from the VX, VX IT series) Supply includes: – 2 mounting brackets – Assembly parts Side panel, horizontally divided for VX IT For sealing IT enclosure systems, both stand-alone and baying arrangements. Benefits: – Simple handling – Supports tool-free installation and removal of the side wall – Locked using security lock 3524 E – Integral internal latch For enclosure height mm For enclosure depth mm 2000 1000 1 pc(s). 5301.250 2000 1200 1 pc(s). 5301.254 2200 1000 1 pc(s). 5301.257 2200 1200 1 pc(s). 5301.261 2450 1000 1 pc(s). 5301.264 2450 1200 1 pc(s). 5301.265 Packs of Model No. Material: – Sheet steel Surface finish: – Powder-coated Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 20 Supply includes: – Top piece – Bottom piece – 6 mounting brackets – 2 lock components – Assembly parts 902 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Walls Side panels Side panel, vertically divided for VX IT Benefits: – Simple handling – Easy to close with snap fasteners – Optimum access to all installed components – Opening is only possible via internal locking elements, which requires free access via the doors, but significantly increases access security – Individual side parts may be completely dismantled at any time without the need for tools Material: – Sheet steel Surface finish: – Powder-coated Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 20 Side panel for TE 8000 Simple assembly with insertion aid at the bottom and lock at the top. Earthing bolt with contact lug. Material: – Sheet steel Surface finish: – Powder-coated Colour: – RAL 7035 For enclosure height mm Packs of Model No. 2000 800 1 pc(s). 5301.246 2000 1000 1 pc(s). 5301.236 2000 1200 1 pc(s). 5301.242 2200 800 1 pc(s). 5301.243 2200 1000 1 pc(s). 5301.244 2200 1200 1 pc(s). 5301.245 Supply includes: – 2 side parts – Punched rail – 6 hinges – 4 quick-release fasteners – Assembly parts Assembly instruction: – Access via the front and rear doors must be guaranteed For enclosure height mm For enclosure depth mm Packs of Model No. 2000 800 2 pc(s). 7888.652 2000 1000 2 pc(s). 7888.653 Protection category IP to IEC 60 529: – IP 20 Supply includes: – 4 cam locks including security lock 3524 E Corrosion protection primer The one-component primer is suitable as corrosion protection on paint-free spots which occur due to cut-outs etc. Used to renew corrosion protection of paint-free spots in accordance with the standard IEC 61439 for low-voltage and switchgear assemblies. For enclosure depth mm Contents ml Packs of Model No. 12 1 pc(s). 2436.800 Paint pen System accessories Benefits: – Exceptional bonding – Passive protection from corrosion – Very high filling force Colour: – Dark grey Paint For touching up and repairing powder-coated and wet-painted surfaces, air-drying. Colour Model No. Touch-up pen 12 ml RAL 7035 2436.735 Tin 1000 ml RAL 7035 2438.735 RAL 7035 2440.735 RAL 9005 2440.905 Spray can 150 ml Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 903 Walls Divider panels/partitions Partition, one-piece, for slide-in fixing for VX IT For rack mounting, suspended between two bayed enclosures. With one Ø 40 mm hole in the left-hand and right-hand corner areas for inserting cables, conduits etc. These drilled holes may be sealed with the enclosed cover caps. Benefits: – Simply slides into position Material: – Sheet steel, zinc-plated Protection category: – IP 20 (with fitted cover caps) Supply includes: – Partition – 2 cover caps For enclosure height mm For enclosure depth mm 2000 1000 1 pc(s). 5301.270 2000 1200 1 pc(s). 5301.281 2200 1000 1 pc(s). 5301.287 2200 1200 1 pc(s). 5301.300 2450 1000 1 pc(s). 5301.315 2450 1200 1 pc(s). 5301.317 Packs of Model No. Assembly instruction: – A baying gap of 3 mm is required to insert the partition Accessories: – Baying connector, external, 3 mm, see page 914 Note: – Use baying connector, external, 3 mm – Not suitable for use in conjunction with a baying seal – Any baying seal that may be present must be removed prior to installation Partition, vertically divided, for screw fastening for VX IT For retrospective installation/dismantling of bayed enclosures. The integrated sealing profile supports enclosure sealing for climate control or for applications with extinguisher gas. It may be fitted from the outside prior to baying the enclosure, or from the inside after baying the enclosure. As the partition is located inside the frame structure, it may be retrofitted at any time. There are no specific required baying distances between the enclosures. Material: – Sheet steel, zinc-plated Supply includes: – 2 partitioning plates – 4 cover caps – Punched rail – Seal – Assembly parts 904 Further technical information available on the Internet. For enclosure height mm For enclosure depth mm 2000 1000 1 pc(s). 5301.274 2000 1200 1 pc(s). 5301.284 2200 1000 1 pc(s). 5301.291 2200 1200 1 pc(s). 5301.303 2450 1000 1 pc(s). 5301.319 2450 1200 1 pc(s). 5301.321 Packs of Model No. Assembly instruction: – Assembly/removal only supported for enclosures without interior installation Accessories: – Baying connector, external, see page 912 – Baying connector, external, 3 mm, see page 914 Rittal System Catalogue 36/System accessories Walls Divider panels/partitions Divider panel for VX For shielding individual enclosure cells. Thanks to the symmetry of the frame system, the divider panel can also be used at the rear. All-round, double fold for stability and to hold the seal. Material: – Sheet steel, 1.5 mm Surface finish: – Zinc-plated Protection category IP to IEC 60 529: – IP 54 (in conjunction with enclosures from the VX series) Supply includes: – Assembly parts Also required: For enclosures Model No. Height mm Depth mm 1800 400 8609.200 1800 500 8609.201 1800 600 8609.202 2000 400 8609.203 2000 500 8609.204 2000 600 8609.205 2000 800 8609.206 2200 600 8609.207 302/402/502/702 266/366/466/666 291/391/491/691 – When baying in conjunction with a divider panel: Baying bracket, internal 8617.500, see page 912 or baying connector, external 8617.502/ 8617.503, see page 912 Accessories: System accessories 1702/1902/2102 – Cover with door, see page 908 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 905 Walls Divider panels/partitions Divider panel 402/502 99/105 318 188 144 for module plates for VX With cut-outs for the installation of module plates for connectors or for cable entry, and also for the entry of busbar systems and other installed equipment. All-round, double fold for stability and to hold the seal. The symmetry of the enclosure frame means that divider panels may also be fitted at the rear, dimensions permitting. Material: – Sheet steel, 2 mm 8 x 188 (1504)/9 x 188 (1692) Supply includes: – Seal and assembly parts Also required: – When baying in conjunction with a divider panel: Baying bracket, internal 8617.500, see page 912 or baying connector, external 8617.502/ 8617.503, see page 912 1702/1902 Surface finish: – Zinc-plated Accessories: – Module plates, see page 907 – Cover with door, see page 908 – Baying bracket, internal, see page 912 For enclosures 906 Number of cut-outs Model No. 500 9 8609.210 600 9 8609.211 2000 500 10 8609.212 2000 600 10 8609.213 Height mm Depth mm 1800 1800 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Walls Divider panels/partitions Module plates Version Cut-outs Packs of Model No. Material: – Sheet steel, 2 mm Solid – 1 pc(s). 8609.160 For 16-pole connectors 4 1 pc(s). 8609.150 For 24-pole connectors 4 1 pc(s). 8609.140 Surface finish: – Zinc-plated Supply includes: – Seal For cable entry 1 1 pc(s). 8609.170 With cable sleeve 1 1 pc(s). 8609.390 Solid For sealing unused cut-outs. Easily machined for individual cut-outs. For 16/24-pole connectors With cut-outs to accommodate connectors. Accessories: – Adaptor, cover plate, see page 908 – Connector gland for connector cut-outs, see page 1046 – Sealing frame, modular, see page 1048 For cable entry For the entry of pre-assembled cables. Sealed, secure routing is achieved via adjustable angle brackets with inserted foam cable clamp strip. Fixed bracket, punched, for cable clamping. Accessories: – Cable tie for fast assembly 2597.000, see page 1061 System accessories With cable sleeve For cable diameters from 10 to 65 mm. The flexible grommet adapts to the cable's bending radius Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 907 Walls Divider panels/partitions Adaptor For reduction Packs of Model No. for connector cut-outs For using connectors with varying numbers of poles. From 24 to 16 poles 5 pc(s). 2479.000 From 24 to 10 poles 5 pc(s). 2480.000 Material: – Sheet steel From 24 to 6 poles 5 pc(s). 2481.000 From 16 to 10 poles 5 pc(s). 2401.000 From 16 to 6 poles 5 pc(s). 2402.000 Surface finish: – Zinc-plated Supply includes: – Seal and assembly parts Cover plate for connector cut-outs For unused cut-outs. For Packs of Model No. 24-pole cut-outs 20 pc(s). 2477.000 16-pole cut-outs 20 pc(s). 2478.000 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Seal and assembly parts Cover with door for VX – To protect and finish off connectors or other installed equipment. – Optional cable entry from above or below Material: – Cover: Sheet steel, 1.5 mm – Door: Sheet steel, 2.0 mm Surface finish: – Dipcoat-primed, powder-coated on the outside Colour: – RAL 7035 For enclosures Height mm Depth mm Model No. 2000 500 8609.220 2000 600 8609.230 Accessories: – Lock inserts, type G, see page 941 – Comfort handle VX, see page 937 – 180° hinge, see page 951 Protection category IP to IEC 60 529: – IP 55 (in conjunction with enclosures from the VX series) Protection category to NEMA: – NEMA 12 (in conjunction with enclosures from the VX series) Supply includes: – Cover – Door with locking rod and double-bit lock insert – 2 trim panels for top and bottom 908 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Walls Isolator door locking Isolator door cover for VX Including main door latch for safety locking of enclosures and bayed enclosure suites in accordance with UL regulations. Tested in conjunction with actuator lever for master switch from the following companies: – Allen Bradley – Square D – General Electric – Eaton – Siemens A detailed overview of types can be found on the Internet, together with the product description. Benefits: – Meets the requirements of UL 508 A – In conjunction with the operating mechanism, adjacent door lock and interconnecting rods, these requirements are also met for bayed combinations – Optional mounting on the left or right of the enclosure. With this cover, all single-door bayed enclosures may be configured as isolator door enclosures. The complete installation surface of the enclosure is retained. – In conjunction with the integrated mounting plate infill, the mounting surface of the main enclosure can be enlarged by up to 14%. – Two cut-outs for actuator levers on the front, for internal mounting at varying heights Also required: For bayed suites: – Operating mechanism 4912.000, for enclosure with isolator door cover and additionally in every fourth adjacent enclosure, see page 910 – Adjacent door latch 4911.000, 4911.100, for every adjacent enclosure, see page 910 – Interconnecting rods, for every adjacent enclosure in the appropriate enclosure width, see page 910 – Side panel, screw-fastened, see page 901 Accessories: – Mounting plate infill, see page 971 Isolator door lock  Operating mechanism  Adjacent door latch (single-door)  Interconnecting rod  Connection component  Main door latch  Adjacent door latch (two-door)  Side panel, screw-fastened Installation to the right of the enclosure Protection category IP to IEC 60 529: – IP 55 (in conjunction with enclosures from the VX series) 3 Protection category to NEMA: – NEMA 12 (in conjunction with enclosures from the VX series) Supply includes: – Main door lock, cover plate and assembly parts 6 4 6 4 3 3 2 2 5 7 7 Note: – Cover may only be mounted on a single-door enclosure with tubular door frame Height mm Depth mm Material thickness mm 125 Model No. Surface finish Colour Sheet steel Stainless steel 1.4301 (AISI 304) 103 1800 400 1.5 Powder-coated RAL 7035 8951.020 – 103 1800 400 1.5 Brushed, grain size 400 – – 8952.020 103 1800 500 1.5 Powder-coated RAL 7035 8951.030 – 103 1800 500 1.5 Brushed, grain size 400 – – 8952.030 103 2000 500 1.5 Powder-coated RAL 7035 8951.000 – 103 2000 500 1.5 Brushed, grain size 400 – – 8952.000 103 2000 600 1.5 Powder-coated RAL 7035 8951.010 – 103 2000 600 1.5 Brushed, grain size 400 – – 8952.010 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories Width mm 1 909 Walls Isolator door locking Door latch for bayed enclosure suites 2 1 In conjunction with the isolator door cover, the requirements of UL 508 A are also met for bayed enclosure suites. Depending on the baying combination, different components will be required; refer to the assembly sketch on page 909. Note: – The door latch for bayed enclosure suites can also be used without the isolator door cover and in combination with commercially available master switches. In this way, adjacent doors cannot be opened until the main door has been opened. 3  Operating mechanism Fitted in the enclosure with main switch and additionally in every fourth adjacent enclosure  Adjacent door latch Installation in adjacent enclosure  Interconnecting rods To extend locking from the main enclosure to the adjacent enclosures of a bayed suite. One interconnecting rod corresponding to the width of the enclosure is required for each adjacent enclosure. 910 Further technical information available on the Internet. Packs of Model No. Operating mechanism 1 pc(s). 4912.000 Adjacent door latch for Packs of Model No. Single-door enclosures 1 pc(s). 4911.000 Two-door enclosures 1 pc(s). 4911.100 For enclosure width mm Packs of Model No. 600 10 pc(s). 4916.000 800 10 pc(s). 4918.000 1200 10 pc(s). 4920.000 Rittal System Catalogue 36/System accessories Baying system Baying Bayable on all sides Whether around corners, forwards, backwards, to the left or right or even upwards if required, the baying options are unlimited. Overview of bayed VX/VX IT  Baying bracket, internal, for VX/VX IT  Baying block, internal, for VX  Baying connectors, external, for VX/VX IT  Quick-fit baying clamp for VX  Angular baying bracket for VX  Combination angle for VX  Baying connector, external, 3 mm for VX IT Baying connector for VX IT/TS IT Notes on the transportation of bayed VX enclosures, see page 915. VX IT System accessories VX Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 911 Baying system Baying Baying bracket, internal Packs of Model No. for VX, VX IT – Fast, secure installation either from the front or from the side – For all-round installation on the baying point – May be flexibly positioned to avoid collisions with installed equipment – Also suitable for baying base/plinth components 6 pc(s). 8617.500 Material: – Sheet steel Surface finish: – Zinc-plated Note: – 1 pack is sufficient for one baying joint – Transportation of bayed enclosures, see page 915 Possible alternative: – Baying block, internal, see page 912 – Baying connector, external 8617.502, see page 912 Supply includes: – Baying bracket, internal – Baying seal – Assembly parts Baying block, internal Packs of Model No. for VX, VX IT – Side mounting creates a flush surface to the profile, suitable for top mounting, thus avoiding collisions with installed equipment – For all-round installation on the baying point 6 pc(s). 8617.501 Material: – Die-cast zinc Supply includes: – Baying block, internal – Baying seal – Assembly parts Baying connector, external for VX, VX IT For mounting on the vertical enclosure sections from the outside. Supply includes: – Baying connector, external – Baying seal – Assembly parts Note: – 1 pack is sufficient for one baying joint Possible alternative: – Baying bracket, internal, see page 912 – Baying connector, external 8617.502, see page 912 Material Packs of Model No. Sheet steel, zinc-plated 6 pc(s). 8617.502 Stainless steel 1.4301 (AISI 304) 6 pc(s). 8617.503 Note: – 1 pack is sufficient for one baying joint Possible alternative: – Baying bracket, internal, see page 912 – Baying block, internal, see page 912 912 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Baying system Baying Quick-fit baying clamps Packs of Model No. for VX – For all-round installation on the baying point – May be flexibly positioned to avoid collisions with installed equipment – Simply tighten the screws, tap in the quick-fit baying clamp, pull the enclosures together and secure – Additional mounting level between bayed enclosures, e.g. for mounting cable ducts 6 pc(s). 8617.506 Note: – 1 pack is sufficient for one baying joint Accessories: – Baying seal 8617.507, see page 914 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Angular baying bracket Packs of Model No. for VX For stable connection in the corners of bayed enclosures. Perfectly suited for aligning enclosures with one another on uneven floors 4 pc(s). 8617.508 Material: – Sheet steel Surface finish: – Zinc-plated Note: – 1 pack is sufficient for one baying joint – To achieve the required protection category and transportation stability, further baying connectors should be used halfway up the enclosure Baying connector, external, 9 mm Packs of Model No. 4 pc(s). 7824.540 System accessories Supply includes: – Assembly parts for VX IT/VX IT with side panels For retrospective baying of enclosures with side panels. Material: – Sheet steel Colour: – RAL 7035 Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 913 Baying system Baying Baying connector, external, 3 mm Packs of Model No. 1 pc(s). 5301.310 for VX IT Applications: – For retrospectively exchanging racks or LCP devices – For retroactive installation/removal of partitions, one-piece, slide-in Note: – Within a bayed enclosure suite, the external dimension is increased by 2 mm per baying point – The maximum achievable IP protection category to IEC 60 529 is IP 20. Benefits: – Supports retroactive exchange of racks or LCP devices – Guarantees the required baying distance of 3 mm for carrying out retrospective modifications Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – 4 baying connectors, external, 3 mm – Baying seal, 8 m – Assembly parts Baying clamp Packs of Model No. for VX IT/TS IT For baying enclosures in the VX IT series to TS IT. 1 pc(s). 5301.312 Material: – Sheet steel Surface finish: – Zinc-plated Note: – The maximum achievable IP protection category to IEC 60 529 is IP 54 Supply includes: – 4 baying connectors, external – 2 baying connectors, internal – Baying seal, 8 m – Assembly parts Baying seal Packs of Model No. for VX May be used individually for baying on all existing enclosure sizes. The seal sits securely around the section edge, and is easily removed at any time without leaving any residues. It is also reusable. 1 pc(s). 8617.507 Material: – EPDM Supply includes: – 8m 914 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Baying system Baying Notes on the transportation of bayed VX enclosures When transporting bayed enclosures, for example, the baying bracket, internal (8617.500), the baying block, internal (8617.501) or the baying connector, external (8617.502 and 8617.503) may be used in conjunction with the combination angle (4540.000). The load capacity with a cable pull angle of 60° is as follows: for the left-hand enclosure 7000 N, for the central enclosure 14000 N, for the right-hand enclosure 7000 N. The cable pull angle between the roof plate and the cable has a significant influence on the total permissible load. The cable pull angle must not be less than 45°, and ideally not less than 60°. Combination angle Packs of Model No. for VX For optimum distribution of tensile forces during transportation of bayed enclosures by crane. 4 pc(s). 4540.000 Material: – Sheet steel Accessories: – Baying cover, top, see page 915 Surface finish: – Zinc-plated Supply includes: – Assembly parts for VX, VX IT A cover with two end caps may additionally be clipped over the seal between the two enclosures. This prevents dirt and liquid from accumulating on the baying seal. Supply includes: – Assembly parts Note: – May also be fitted in the width with enclosure suites bayed back-to-back – May be cut to required length, if necessary. – May also be used in conjunction with dust guard trim, see page 959 Rittal System Catalogue 36/System accessories For enclosure depth mm Packs of Plastic RAL 7035 Stainless steel Model No. 1.4301 (AISI 304) 400 1 pc(s). ◾ – 8800.845 500 1 pc(s). ◾ – 8800.855 600 1 pc(s). ◾ – 8800.865 800 1 pc(s). ◾ – 8800.885 400 1 pc(s). – ◾ 8700.140 500 1 pc(s). – ◾ 8700.150 600 1 pc(s). – ◾ 8700.160 1000 – 1200 1 pc(s). ◾ – 8800.825 Further technical information available on the Internet. System accessories Baying cover, top 915 Baying system Baying Baying cover, vertical Packs of Model No. for VX To balance out the gap between the side panels when baying back-to-back. For enclosure height 2200 mm, or may be cut to length individually for lower heights. 2 pc(s). 8800.875 Material: – Cover section: Plastic Also required: – Baying connector, external, 8617.502, see page 912 Colour: – RAL 7035 Supply includes: – Assembly parts Baying kit, VX25 to TS 8 Packs of Model No. For extending existing TS 8 bayed enclosure suites with VX25 enclosures. 1 pc(s). 8617.505 Material: – Baying connector: Sheet steel Supply includes: – 8 baying connectors – 1 seal – Assembly parts Baying kit for TE/TE For connecting individual enclosures into bayed suites at the sides. The enclosures are connected between the base and roof frame. Benefits: – Baying of TE 8000 to TE 7000 enclosures is supported Width mm Packs of Model No. 55 4 pc(s). 7888.640 Material: – Sheet steel, spray-finished Colour: – RAL 7035 Supply includes: – Assembly parts Baying kit Packs of Model No. for AX, KX For baying AX/KX enclosures. The additional cut-outs are to be provided by the customer. 1 pc(s). 1199.100 Special screws and nuts – For fast, simple assembly without thread-tapping – Compression of the seal is limited to a predefined level, to ensure a long-lasting, permanent seal between enclosures Supply includes: – Special screws and nuts – Sealing elements, self-adhesive Seal, self-adhesive – Comprised of bayable sealing elements and corner pieces, for individual adaptation to various enclosure sizes One pack is sufficient for a baying joint up to H x D = 800 x 350 mm. 916 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Door variants Glazed door For enclosures Width mm Height mm Model No. 600 1800 8618.000 800 1800 8618.010 600 2000 8618.020 Surface finish: – Powder-coated 800 2000 8618.030 600 2200 8618.040 Colour: – Frame and corner pieces: RAL 7035 – Viewing window (printed mask on the inside): RAL 9005 800 2200 8618.050 for VX Instead of a sheet steel door or rear panel. Material: – Frame: Extruded aluminium section – Viewing window: Single-pane safety glass, 3 mm Protection category IP to IEC 60 529: – IP 55 Supply includes: – Glazed door – Locking rod with double-bit lock insert and lock plate – 180° hinges, 4 pc(s). Also required: – When mounting instead of the rear panel or double door: Lock components for frame 8618.110, see page 917 Accessories: – Comfort handle VX, see page 937 – Lock inserts, type G, see page 941 Lock components Packs of Model No. For retrofitting a glazed door or sheet steel door in place of a rear panel. 4 pc(s). 8618.110 Material: – Die-cast zinc Supply includes: – Assembly parts Lockable and adjacent door Material: – Sheet steel Surface finish: – Dipcoat-primed, powder-coated on the outside For enclosures Width mm Height mm 800 2000 Model No. 8618.120 Accessories: System accessories for VX For example, if two 400 mm doors are used instead of one 800 mm wide door in order to comply with escape routes. May also be fitted instead of an 800 mm wide rear panel. – Comfort handle VX, see page 937 – Lock inserts, type G, see page 941 Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Supply includes: – 2 doors, including tubular door frame, hinges and lock components Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 917 Doors/locks Door variants Glazed door for VX SE Instead of a sheet steel door. Material: – Frame: Extruded aluminium section – Corner pieces: Die-cast zinc – Viewing window: Single-pane safety glass, 3 mm For enclosures Width mm Height mm Model No. 600 1800 8610.685 800 1800 8610.885 600 2000 8610.605 800 2000 8610.805 Surface finish: – Powder-coated Colour: – Frame and corner pieces: RAL 7035 – Viewing window (printed mask on the inside): RAL 9005 Accessories: – Comfort handle, see page 938 – Lock inserts, version F, see page 941 Protection category IP to IEC 60 529: – IP 55 Supply includes: – Glazed door – Locking rod with double-bit lock insert and lock plate – 180° hinges, 4 pc(s). Handle adaptor The handle adaptor compensates for the design chamfer in the door profile to enable installation of the comfort handle. Material: – Plastic Supply includes: – 1 adaptor plate – 1 bolt to extend the screw-on dome – 2 assembly screws 918 Further technical information available on the Internet. For glazed door VX SE Colour Model No. RAL 7035 8611.080 For designer door IW and PC, bottom door Colour Model No. RAL 7035 8611.300 Rittal System Catalogue 36/System accessories Doors/locks Door variants Glazed door VX IT for Automatic Door Opening (ADO) With integral vent valves for automated opening function in the event of an alarm or power failure. The glazed door for the Automatic Door Opening System replaces the standard VX IT door. Benefits: – Supports remote control via the CMC III system – Tinted single-pane safety glass ensures a high standard of safety – Combining the vent flaps with a tubular door frame creates exceptional stability – The vent flaps only protrude into the escape route by 200 mm – No adjustment to the lock systems system required – Manual opening of the door without any effect on the vent flaps – Automatic opening of the vent valves in the event of a power failure Functional principle: – Activation via CMC III door control module (DCM) – Automatic, mechanical opening of the integral vertical ventilation flaps in an emergency if the cooling system fails or an extinguishing system is activated – Depending on the room volume and temperature, the air inside the room is used for emergency cooling, or the extinguisher gas may flow directly into the IT enclosures Technical specifications: – Rated voltage: 24 V DC – Rated current: 780 mA – External projection of the vent flap: 200 mm (when opened) – Internal projection of the mechanism: 52.5 mm – Connection cable from door catch: 2.5 m – Door hinged on the right, may be swapped to the left – Spring damper for flap opening – Magnets for fixing the flaps – Valves are open at zero current Protection category IP to IEC 60 529: – IP 20 for solid vent flaps Supply includes: – Glazed door with comfort handle VX for profile half-cylinders – Connection cable Note: – Other colours (RAL 9005) and sizes (H = 2200 mm) available on request Also required: – Door control module, see page 817 – CMC III power pack, see page 818 Accessories: – CMC III Processing Unit/Compact with connection, power supply and mounting accessories, from page 804 – Lock inserts, see page 942 Dimensions Material One-part, with vent flaps Frame: Extruded aluminium section Viewing window: Single-pane safety glass, tinted One-part, with vent flaps Frame: Sheet steel Viewing window: Single-pane safety glass, tinted Two-part, vertically divided, with vent flaps Frame: Sheet steel Viewing window: Single-pane safety glass, tinted Colour – RAL 7035 RAL 7035 Width mm Height mm Packs of Model No. 600 2000 1 pc(s). 7030.262 800 2000 1 pc(s). 7030.263 600 2000 1 pc(s). 7030.272 800 2000 1 pc(s). 7030.273 600 2000 1 pc(s). 7030.282 800 2000 1 pc(s). 7030.283 System accessories Design Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 919 Doors/locks Door variants Glazed aluminium door, one-piece for VX IT To replace existing doors. Material/surface finish: – Frame: Extruded aluminium section – Vertical extrusion: Aluminium, anodised – Horizontal extrusion: Aluminium, spray finished – Viewing window: Single-pane safety glass, 3 mm For enclosures Width mm Height mm Packs of Model No. 800 2000 1 pc(s). 5301.423 Assembly instruction: – For a door opening angle of 180° when baying, a 180° baying hinge is required, see page 951 Colour: – Comfort handle VX, hinges, horizontal extrusion: RAL 9005 – Vertical profile: silver coloured Protection category IP to IEC 60 529: – IP 55 Supply includes: – Door with comfort handle VX for profile halfcylinders with security lock 3524 E – 3 x 180° hinges, fitted – Assembly parts Note: – Door opening angle for stand-alone siting: max. 240° – Door opening angle when baying: max. 105° Glazed sheet steel door, vertically divided for VX IT To replace existing doors. With underlaid viewing panel and 4-point locking rod. The divided design allows room-optimised siting of the enclosures coupled with the best possible access, thanks to a reduced distance between the individual bayed enclosure suites. Material: – Frame: Sheet steel – Viewing window: Single-pane safety glass, 3 mm For enclosures Width mm Height mm Packs of Model No. 800 2000 1 pc(s). 5301.437 800 2200 1 pc(s). 5301.438 Assembly instruction: – For a door opening angle of 180° when baying, a 180° baying hinge is required, see page 951 Surface finish: – Powder-coated Colour: – Frame: RAL 7035 – Comfort handle VX, hinges: RAL 9005 Protection category IP to IEC 60 529: – IP 55 Supply includes: – Door, vertically divided, with comfort handle VX for profile half-cylinders with security lock 3524 E, right – 4 x 180° hinges, fitted on each half of the door – Assembly parts Note: – Door opening angle for stand-alone siting: max. 240° – Door opening angle when baying: max. 160° 920 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Door variants Sheet steel door, one-piece, solid for VX IT To replace existing doors. Material: – Sheet steel Surface finish: – Spray-finished Colour: – Door: RAL 7035 – Comfort handle VX: RAL 9005 For enclosures Width mm Height mm Packs of Model No. 800 2000 1 pc(s). 5301.540 800 2200 1 pc(s). 5301.542 Assembly instruction: – For a door opening angle of 180° when baying, a 180° baying hinge is required, see page 951 Protection category IP to IEC 60 529: – IP 55 Supply includes: – Door with comfort handle VX for profile halfcylinders with security lock 3524 E – 4 x 130° hinges, inside – Assembly parts Note: – Door opening angle for stand-alone siting: max. 165° – Door opening angle when baying: max. 110° Sheet steel door, vertically divided, solid for VX IT To replace existing doors. Thanks to the minimal rotation radius of the individual doors, the distance between individual bayed enclosure suites may be reduced. Material: – Sheet steel Surface finish: – Spray-finished For enclosures Width mm Height mm Packs of Model No. 600 2000 1 pc(s). 5301.602 800 2000 1 pc(s). 5301.612 Assembly instruction: – For a door opening angle of 180° when baying, a 180° baying hinge is required, see page 951 Colour: – Door: RAL 7035 – Comfort handle VX, hinges: RAL 9005 Protection category IP to IEC 60 529: – IP 20 System accessories Supply includes: – Door, vertically divided, with comfort handle VX for profile half-cylinders with security lock 3524 E, right – 3 x 180° hinges, fitted on each half of the door – Assembly parts Note: – Door opening angle for stand-alone siting: max. 240° – Door opening angle when baying: max. 160° Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 921 Doors/locks Door variants Aluminium/sheet steel door, vented for VX IT To replace existing doors. The vented surface area is approx. 85% perforated. Material/surface finish: – Frame: Extruded aluminium section – Vent grille: Sheet steel – Vertical extrusion: Aluminium, anodised – Horizontal extrusion: Aluminium, spray finished Colour: – Comfort handle VX, hinges, horizontal extrusion, vent grille: RAL 9005 – Vertical profile: silver coloured For enclosures Width mm Height mm Packs of Model No. 600 2200 1 pc(s). 5301.450 800 2000 1 pc(s). 5301.446 800 2200 1 pc(s). 5301.453 Assembly instruction: – For a door opening angle of 180° when baying, a 180° baying hinge is required, see page 951 Supply includes: – Door with comfort handle VX for profile halfcylinders with security lock 3524 E – 3 x 180° hinges, fitted – Assembly parts Note: – Door opening angle for stand-alone siting: max. 240° – Door opening angle when baying: max. 105° Sheet steel door, one-piece, vented for VX IT To replace existing doors. The vented surface area is approx. 85% perforated. Material: – Sheet steel Surface finish: – Spray-finished Colour: – Door: RAL 7035 – Comfort handle VX: RAL 9005 For enclosures Width mm Height mm Packs of Model No. 600 2000 1 pc(s). 5301.561 800 2000 1 pc(s). 5301.571 Assembly instruction: – For a door opening angle of 180° when baying, a 180° baying hinge is required, see page 951 Protection category IP to IEC 60 529: – IP 20 Supply includes: – Door with comfort handle VX for profile halfcylinders with security lock 3524 E – 3 x 130° hinges, fitted on the inside – Assembly parts Note: – Door opening angle for stand-alone siting: max. 165° – Door opening angle when baying: max. 110° 922 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Door variants Sheet steel door, vertically divided, vented for VX IT To replace existing doors. The vented surface area is approx. 85% perforated. Material: – Sheet steel Surface finish: – Spray-finished For enclosures Width mm Height mm Packs of Model No. 800 2000 1 pc(s). 5301.652 Assembly instruction: – For a door opening angle of 180° when baying, a 180° baying hinge is required, see page 951 Colour: – Door: RAL 7035 – Comfort handle VX, hinges: RAL 9005 Protection category IP to IEC 60 529: – IP 20 Supply includes: – Door, vertically divided, with comfort handle VX for profile half-cylinders with security lock 3524 E, right – 3 x 180° hinges, fitted on each half of the door – Assembly parts System accessories Note: – Door opening angle for stand-alone siting: max. 240° – Door opening angle when baying: max. 160° Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 923 Doors/locks Door variants Protective bar As an alternative to a door, e.g. in sealed switch rooms. Prevents people from falling into the open enclosure frame. Easily removable for maintenance purposes. For 1200 mm enclosure width; may be shortened or divided for other sizes. Material: – Wood, spray-finished, RAL 3000 For enclosure width mm Length mm Packs of Model No. 1200 1090 1 pc(s). 8801.010 Enclosure width mm L 65 60 x 40 1) 40 B3 Clearance between the enclosure frame (B3) mm Length of protective bar (L) mm 400 311 2901) 600 511 4901) 800 711 6901) 1000 911 8901) 1200 1111 1090 The protective bar 8801.010 (1090 mm) will need to be shortened Also required: – Holder 8801.000, see page 924 Holder Packs of Model No. for protective bar For mounting on the vertical section. The protective bar is simply inserted. 2 pc(s). 8801.000 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly screws Variable modular climate control concept Instead of an enclosure door in a 600 mm/800 mm/ 1200 mm wide and 1800 mm/2000 mm high VX enclosure, section doors with integral cooling module may be retrofitted without major assembly work. 924 Further technical information available on the Internet. Possible alternative: – Modular climate control concept, see page 506/507 Rittal System Catalogue 36/System accessories Doors/locks Installation accessories for modular front design Modular front design Suitable for 400 to 1200 mm wide enclosures instead of a door or rear panel. The partial doors with and without viewing panels for the baying enclosure system VX25, see page 132/133, may be combined with one another as required. A trim panel is required at the top and bottom in each case. The requirements for your individual front design and the considerations which must be taken into account are illustrated on the sample configuration opposite. Note: Installation accessories for modular front design, see page 926 – 927 1 3 4  Front trim panel, top  Front trim panel, bottom  Partial door with viewing window  Partial door 4 System accessories 2 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 925 Doors/locks Installation accessories for modular front design Partial door For enclosure width 400 mm for VX The door may be optionally hinged on the right or left. The partial door is attached to the enclosure with no drilling required. Standard double-bit lock insert may be exchanged for lock inserts, type A. Height mm With viewing window Number of locks Packs of Model No. 200 – 1 1 pc(s). 9682.142 300 – 1 1 pc(s). 9682.143 Material: – Partial door: Sheet steel, 2 mm – Viewing window: 3 mm single-pane safety glass 400 – 2 1 pc(s). 9682.144 600 – 2 1 pc(s). 9682.146 800 – 2 1 pc(s). 9682.148 Surface finish: – Textured paint 1000 – 3 1 pc(s). 9682.140 1200 – 3 1 pc(s). 9682.152 Colour: – RAL 7035 1400 – 3 1 pc(s). 9682.154 1600 – 4 1 pc(s). 9682.156 Protection category IP to IEC 60 529: – IP 54 1800 – 4 1 pc(s). 9682.158 2000 – 4 1 pc(s). 9682.150 Supply includes: – Cross member, hinges and lock components – Assembly parts Note: – Opening angle of partial doors max. 130° Also required: – Front trim panel, top, see page 927 or top-hinged trim panel, see page 928 – Front trim panel, bottom, see page 927 Accessories: – Mini-comfort handle AX for partial door from a height of 200 mm, see page 940 – Lock inserts, type A, see page 941 – Perforated mounting strip, see page 927 For enclosure width 600 mm Height mm With viewing window Number of locks Packs of Model No. 150 – 1 1 pc(s). 9682.161 200 – 1 1 pc(s). 9682.162 300 – 1 1 pc(s). 9682.163 400 – 2 1 pc(s). 9682.164 600 – 2 1 pc(s). 9682.166 600 ◾ 2 1 pc(s). 9682.167 800 – 2 1 pc(s). 9682.168 800 ◾ 2 1 pc(s). 9682.169 1000 – 3 1 pc(s). 9682.160 1200 – 3 1 pc(s). 9682.172 1400 – 3 1 pc(s). 9682.174 1600 – 4 1 pc(s). 9682.176 1800 – 4 1 pc(s). 9682.178 2000 – 4 1 pc(s). 9682.170 For enclosure width 800 mm Height mm With viewing window Number of locks Packs of Model No. 150 – 1 1 pc(s). 9682.181 200 – 1 1 pc(s). 9682.182 300 – 1 1 pc(s). 9682.183 400 – 2 1 pc(s). 9682.184 600 – 2 1 pc(s). 9682.186 600 ◾ 2 1 pc(s). 9682.187 800 – 2 1 pc(s). 9682.188 1000 – 3 1 pc(s). 9682.180 1200 – 3 1 pc(s). 9682.192 1400 – 3 1 pc(s). 9682.194 1600 – 4 1 pc(s). 9682.196 1800 – 4 1 pc(s). 9682.198 2000 – 4 1 pc(s). 9682.190 For enclosure width 1000 mm Height mm With viewing window Number of locks Packs of Model No. 400 – 2 1 pc(s). 9682.104 600 – 2 1 pc(s). 9682.106 800 – 2 1 pc(s). 9682.108 For enclosure width 1200 mm 926 Further technical information available on the Internet. Height mm With viewing window Number of locks Packs of Model No. 400 – 2 1 pc(s). 9682.124 600 – 2 1 pc(s). 9682.126 800 – 2 1 pc(s). 9682.128 Rittal System Catalogue 36/System accessories Doors/locks Installation accessories for modular front design Perforated mounting strip for partial door For retrospective external mounting. The perforated mounting strips have a 25 mm pitch pattern of holes and may be used for mounting individual accessories such as cable ducts, conduit holders etc. on the rear of the door. For enclosure width mm Length mm For partial door height mm Packs of Model No. 400 198 200 – 800 10 pc(s). 9681.204 600 398 150 – 800 10 pc(s). 9681.206 800 598 150 – 800 10 pc(s). 9681.208 Hole diameter of perforated mounting strip: 4.5 mm Material: – Sheet steel, 1 mm Surface finish: – Zinc-plated Note: – For enclosure width 1000 mm you will need: 1 x 9681.204 and 1 x 9681.206 – For enclosure width 1200 mm you will need: 2 x 9681.206 Supply includes: – Assembly parts Front trim panel, top Solid, protection category IP 54 For enclosure width mm Height mm Packs of Model No. 400 100 1 pc(s). 9682.314 400 300 1 pc(s). 9682.324 600 100 1 pc(s). 9682.316 Material: – Sheet steel, 1.5 mm 600 300 1 pc(s). 9682.326 800 100 1 pc(s). 9682.318 Surface finish: – Textured paint 800 300 1 pc(s). 9682.328 1000 300 1 pc(s). 9682.320 1200 300 1 pc(s). 9682.322 for VX To finish off the modular front design at the top when using partial doors. The front trim panels may be removed from the outside by unscrewing. The cross member required for mounting is included with the supply of the mounted partial door. Colour: – RAL 7035 Supply includes: – Front trim panel – Assembly parts Solid, protection category IP 54 For enclosure width mm Height mm Packs of Model No. 400 100 1 pc(s). 9682.334 400 300 1 pc(s). 9682.344 600 100 1 pc(s). 9682.336 Material: – Sheet steel, 1.5 mm 600 300 1 pc(s). 9682.346 800 100 1 pc(s). 9682.338 Surface finish: – Textured paint 800 300 1 pc(s). 9682.348 1000 100 1 pc(s). 9682.330 Colour: – RAL 7035 1000 300 1 pc(s). 9682.340 1200 100 1 pc(s). 9682.332 Supply includes: – Front trim panel including cross member – Assembly parts 1200 300 1 pc(s). 9682.342 for VX To finish off the modular front design at the bottom when using partial doors. If version IP 2X is chosen, a roof plate with protection category IP 2X should be selected for top ventilation. The front trim panels may be removed from the outside by unscrewing. System accessories Front trim panel, bottom Vented, protection category IP 2X For enclosure width mm Height mm Packs of Model No. 400 300 1 pc(s). 9682.354 600 300 1 pc(s). 9682.356 800 300 1 pc(s). 9682.358 1000 300 1 pc(s). 9682.350 1200 300 1 pc(s). 9682.352 Also required: Roof plate IP 2X, see page 961 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 927 Doors/locks Installation accessories for modular front design Trim panel, hinged at the top For the installation of control and display components, in conjunction with – Modular front design – Protective bar Width mm Height mm Packs of Model No. 600 300 1 pc(s). 8620.500 800 300 1 pc(s). 8620.501 1200 300 1 pc(s). 8620.502 Material: – Sheet steel, 2 mm Surface finish: – Textured paint Colour: – RAL 7035 Accessories: – Stay for trim panel, hinged at the top, see page 928 – Lock inserts, type A, see page 941 Supply includes: – Hinges, cam locks with double-bit insert and assembly parts Drawer For mouse and keyboard with a maximum width of 500/700 mm. A high level of protection is retained, even with the flap open. Height mm Width mm Model No. 200 600 8620.520 200 800 8620.521 Material: – Sheet steel Colour: – RAL 7035 Accessories: – Lock inserts, type A, see page 941 Supply includes: – Flap and assembly parts – Cross member Support stay Packs of Model No. for trim panel, hinged at the top 5 pitch pattern positions up to a maximum opening angle of approx. 85°. 2 pc(s). 8801.260 Material: – Sheet steel Surface finish: – Zinc-plated 928 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Viewing window/operating panel 30 section System window To cover display and operating elements or cutouts, and to protect against dirt and liquids as well as unauthorised access. To fit enclosure width mm Window dimensions, external mm W Model No. H Consisting of the following 2 components: 270 2735.500 1. Base frame: – Easily screw-fastened to the door thanks to modified dimensions (tubular door frame may be used as a drilling template) – Readily height-adjustable – Stabilises the door cut-out – Conceals the cut edge – The rain canopy – prevents dirt from landing on the seal – protects the glass from being lifted out – prevents the ingress of dirt, and prevents moisture from running behind the window when opened – Frame section height 30 mm or 60 mm 370 2735.510 470 2735.520 570 2735.530 670 2735.540 270 2735.560 370 2735.570 470 2735.580 570 2735.590 670 2735.250 2. Viewing window: – Made from single-pane safety glass: – High level of resistance to solvents and scratches – Anti-static – Reduced risk of injury if broken – Cam lock with double-bit insert, may be exchanged for lock inserts, type A, see page 941 – Hinge with 180° opening angle, easily inserted Material: – Extruded aluminium sections with die-cast zinc corner pieces and single-pane safety glass Surface finish: – Base frame: Powder-coated in RAL 7035 – Hinge and lock section: Natural-anodised 600 500 800 700 60 section To fit enclosure width mm Window dimensions, external mm W 600 500 800 700 Model No. H 370 2736.510 470 2736.520 570 2736.530 670 2736.540 670 2736.500 Note: – Not suitable for outdoor siting Protection category IP to IEC 60 529: – IP 54 B 85 B – 137 52 47 77 View X for section height 30 System accessories X h – 70 h – 72 H b – 70 View Y for section height 60 63 33 Y Viewing area (B–137) offset by 16.5 mm towards the hinge side Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 929 Doors/locks Viewing window/operating panel Viewing window Depth 36 mm For mounting on – AX enclosures instead of the door – Surfaces For use as door variant with Width mm Height mm Model No. 1050.000, 1350.000, 1007.000, 1013.000 497 497 2733.010 Max. installation depth: Depth - 4 mm Visible area: (Width - 60 mm) x (Height - 60 mm) 1039.000, 1339.000, 1009.000 597 377 2730.010 Material: – Frame: Aluminium, natural anodised – Glazed panel: Acrylic 1010.000, 1054.000, 1060.000, 1360.000 597 597 2731.010 1012.000, 1076.000, 1376.000 597 757 2732.010 Width mm Height mm Model No. 1050.000, 1350.000, 1007.000 497 497 2763.010 1039.000, 1339.000, 1009.000 597 377 2760.010 1010.000, 1054.000, 1060.000, 1360.000 597 597 2761.010 1012.000, 1076.000, 1376.000 597 757 2762.010 Protection category IP to IEC 60 529: – IP 54 Supply includes: – Plastic handle with lock insert no. 3524 E Acrylic glazed cover With security lock, lock no. 3524 E. Material: – Frame: Extruded aluminium sections with die-cast corner pieces – Glazed panel: Smoked acrylic Protection category IP to IEC 60 529: – IP 54 Depth 62 mm For use as door variant with Acrylic glazed covers, 482.6 mm (19") U Width mm Height mm Depth mm Model No. 3 320 158 47.5 2780.000 3 534 158 47.5 2781.000 6 534 291.5 47.5 2782.000 9 534 425 47.5 2796.000 Max. installation depth: 43 mm Visible area: (Width - 40 mm) x (Height - 20.5 mm) Metric acrylic glazed covers Width mm Height mm Depth mm Model No. 400 200 47.5 2784.000 400 400 47.5 2785.000 500 200 47.5 2786.000 500 400 47.5 2787.000 600 200 47.5 2788.000 600 400 47.5 2789.000 Max. installation depth: 43 mm Visible area: (Width - 40 mm) x (Height - 20.5 mm) 930 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Viewing window/operating panel Stainless steel Fitted as standard with internal 130° hinges and allround seal. The double-bit lock insert may be exchanged for 27 mm lock inserts, type A. Material: – Stainless steel 1.4301 (AISI 304) – Single-pane safety glass Width mm Height mm Depth mm Model No. 522 600 38 2793.560 Accessories: – Lock inserts 27 mm, type A, see page 941 Protection category IP to IEC 60 529: – IP 54 522 37.5 Viewing window 408 Supply includes: – Assembly parts 525 475 285 543 600 25.5 For mounting on – AX enclosures instead of the door – Surfaces Frame construction with a 3 mm aluminium plate secured from the inside. Material: – Aluminium, natural anodised Protection category IP to IEC 60 529: – IP 54 Supply includes: – Aluminium frame – Display panel – Hinges – Brackets For use as door variant for AX Width mm Height mm Depth mm Model No. 1004.000 1011.000 1031.000 377 297 36 2741.010 1006.000 1303.000 1380.000 377 377 36 2742.010 1008.000 1038.000 1338.000 377 597 36 2743.010 1007.000 1013.000 1050.000 1350.000 497 497 36 2745.010 1009.000 1039.000 1339.000 597 377 36 2744.010 1010.000 1060.000 1304.000 1360.000 597 597 36 2746.010 For surfaces 197 297 36 2740.010 System accessories Operating panel 31 38 25 Area available for population: (Width - 70 mm) x (Height - 70 mm) Dimensions of aluminium plate: (Width - 54 mm) x (Height - 54 mm) Accessories: – Cam lock 2749.100, see page 932 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 931 Doors/locks Viewing window/operating panel Cam lock Packs of Model No. for operating panel May be retrofitted to the operating area or enclosure wall of operating panels. Standard double-bit insert may be exchanged for lock inserts, type C. 1 pc(s). 2749.100 Accessories: – Lock inserts, type C, see page 941 Identification strip For individual field identifiers on the door, including transparent cover and assembly parts. For enclosure width mm Model No. 600 8618.450 800 8618.451 For labels: Width: Enclosure width - 150 mm Height: 29 mm Thickness: 0.75 mm Colour: – RAL 7035 932 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Allocation of lock systems Small enclosures, compact enclosures and operating housings AX, sheet steel Enclosure series Lock inserts for handle systems With 3-point lock With cam With cam 3 – 15 U Lock and push-button inserts DIN 18 252 Type A Type F Lock and push-button inserts Lock inserts With cam Profile half-cylinders 65 85 89 179 94 715 942 942 941 941 942 Application from page EL 3-part With cam Operating housings Plastic Compact enclosure with enclosure E-Box KX AX/AX IT handle AX strips AX Handle systems for enclosures Comfort handle AX For lock inserts or profile half-cylinders 939 – – ◾ – – – ◾ ◾ ◾ – – With security lock insert E1 939 – – ◾ – – – – – – – – For padlock and lock inserts or profile half-cylinders 939 – – ◾ – – – ◾ ◾ ◾ – – For lock inserts or profile half-cylinders 940 ◾ ◾ – ◾ – – ◾ ◾ ◾ – – For padlock and lock inserts or profile half-cylinders 940 ◾ ◾ – ◾ – – ◾ ◾ ◾ – – – – – – ◾ – ◾ ◾ ◾ – – Mini-comfort handle AX Mini-comfort handle for AX plastic For lock inserts or profile half-cylinders 941 Mini-comfort handle for 3-part EL enclosures For lock inserts 949 – – – – – ◾ ◾ – – ◾ – For profile half-cylinders 949 – – – – – ◾ ◾ ◾ – – – ◾ ◾ – Lock inserts for enclosures Lock inserts 941 ◾ ◾ ◾ System accessories Type A Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 933 Doors/locks Allocation of lock systems Large enclosures and PC enclosures, sheet steel Enclosure series Lock inserts for handle systems VX partial doors for modular front design TE Door For keyboard drawer or fold-out tray Lock and push-button inserts DIN 18 252 Type A Type F Version G Lock and push-button inserts 926 704 164 164 942 942 941 941 941 942 VX/VX IT 117/ 687 Lock inserts 143 Application from page Profile halfcylinders VX SE PC enclosure Handle systems for enclosures Comfort handle VX For lock inserts 937 ◾ – – – – – – – – – ◾ ◾ For padlock and lock inserts 937 ◾ – – – – – – – – – ◾ ◾ With security lock insert E1 937 ◾ – – – – – – – – – – – For profile half-cylinders 937 ◾ – – – – – ◾ ◾ – – – – Prepared for ASSA lock system 937 ◾ – – – – – – – – – – – With code 946 ◾ – – – – – – ◾ – – – – 946 ◾ – – – – – – ◾ – – – – 947 ◾ – – – – – – – – – – – CMC III online comfort handle VX With master key function Radio comfort handle VX With card reader Comfort handle for VX SE, PC, IW, EL For lock inserts 938 – ◾ – – ◾1) – – – – ◾ – ◾ For padlock and lock inserts 938 – ◾ – – ◾1) – – – – ◾ – ◾ For profile half-cylinders 938 – ◾ – – ◾1) – ◾ ◾ – – – – For lock inserts or profile half-cylinders 939 – – – ◾ – – ◾ ◾ ◾ – – – With security lock insert E1 939 – – – ◾ – – – – – – – – For padlock and lock inserts or profile half-cylinders 939 – – – ◾ – – – – ◾ – – – For lock inserts or profile half-cylinders 940 – – ◾ – – – ◾ ◾ ◾ – – – For padlock and lock inserts or profile half-cylinders 940 – – ◾ – – – ◾ ◾ ◾ – – – Comfort handle AX Mini-comfort handle AX Ergoform-S handle With code 949 – – – ◾ – – – ◾ ◾ – – – Electromagnetic 950 – – – ◾ – – – ◾ ◾ – – – ◾ Lock inserts for enclosures Lock inserts Type A 941 – – ◾ ◾ – Type F 941 – ◾ – – ◾ – Version G 941 ◾ – – – – – 1) Only in conjunction with the handle adaptor for comfort handle 8611.300, see page 918 934 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Allocation of lock systems Console systems, industrial workstation, Comfort Panel and Optipanel, sheet steel Enclosure series Console door Universal console TP IW Comfort Panel Optipanel Lock and push-button inserts DIN 18 252 Type A Type F Lock and push-button inserts Lock inserts Console cover from page Profile halfcylinders Pedestal Application Lock inserts for handle systems One-piece console TP Desk section and console TopConsole TP 157 157 161 161 162 167 172 174 942 942 941 941 942 Handle systems for enclosures Comfort handle for VX SE, PC, IW, EL For lock inserts 938 – – – – – ◾ – – – – – ◾ ◾ For padlock and lock inserts 938 – – – – – ◾ – – – – – ◾ ◾ For profile half-cylinders 938 – – – – – ◾ – – ◾ ◾ – – – For lock inserts or profile half-cylinders 939 – ◾ – ◾ ◾ – – – ◾ ◾ ◾ – – With lock insert, lock E1 939 – ◾ – ◾ ◾ – – – – – – – – For padlock and lock inserts or profile half-cylinders 939 – ◾ – ◾ ◾ – – – ◾ ◾ ◾ – – Type B 943 ◾ – ◾ – – – – – Type C 943 – – – – – – ◾ ◾ Type B 942 ◾ – ◾ – – – – – Type C 942 – – – – – – ◾ ◾ Comfort handle AX T handles Plastic handles Lock inserts for enclosures Lock inserts Type A 941 ◾ ◾ ◾ ◾ ◾ – – – Type F 941 – – – – – ◾ – – 943 – – – – – ◾ – – Lock cylinder inserts System accessories Type B Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 935 Doors/locks Allocation of lock systems Enclosures and cases, stainless steel Enclosure series With 3-point lock Console cover VX VX SE Lock and push-button inserts DIN 18 252 Type A Type F Type G Lock and push-button inserts Lock inserts With cam Page Profile halfcylinders E-Box KX AX Application Lock inserts for handle systems Onepiece console TP 233 237 240 251 243 249 942 942 941 941 941 942 Handle systems for enclosures Comfort handle VX For lock inserts, stainless steel, precision-cast 937 – – – – ◾ – – – – – ◾ ◾ For profile half-cylinders, stainless steel, precision-cast 937 – – – – ◾ – ◾ ◾ – – – – For lock inserts, matt chrome 938 – – – – – ◾ – – – ◾ – ◾ For profile half-cylinders, matt chrome 938 – – – – – ◾ ◾ ◾ – – – – 939 – – ◾ – – – ◾ ◾ ◾ – – – For lock inserts or profile half-cylinders 940 ◾ ◾ – – – – ◾ ◾ ◾ – – – For padlock and lock inserts or profile half-cylinders 940 ◾ ◾ – – – – ◾ ◾ ◾ – – – 942 – – – ◾ – – 943 – – – ◾ – – – Comfort handle for VX SE, PC, IW, EL Comfort handle AX For lock inserts or profile half-cylinders, stainless steel, precision-cast Mini-comfort handle AX Plastic handle Type C T handle Type C Lock inserts for enclosures Lock inserts Type A 941 ◾ ◾ ◾ – – Type C 941 – – – ◾ – – Type F 941 – – – – – ◾ Type G 941 – – – – ◾ – 943 ◾ ◾ – – – – 943 – – – ◾ – – Cam lock, stainless steel With double-bit insert, stainless steel 1.4404 (AISI 316L) Lock cylinder inserts Type C 936 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Lock systems Comfort handle VX for VX, VX IT As the handle does not take up any swing space, due to its folding action, the door surface area available for installed equipment is maximised. Simple assembly, thanks to the snap-mounted handle system. Prepared for the installation of lock inserts, lock and push-button inserts or for the installation of standard commercially available 40 or 45 mm profile halfcylinders. For profile half-cylinders Prepared for ASSA lock system 8618.240 8618.250 8618.270 – 8618.251 – – – 8618.280 – 8618.300 8618.300 – – – 8618.301 8618.301 – – – 7 mm triangular 8618.302 8618.302 – – – 8 mm triangular 8618.303 8618.303 – – – Screwdriver 8618.304 8618.304 – – – Daimler insert 8618.305 8618.305 – – – 3 mm double-bit 8618.306 8618.306 – – – Fiat 8618.307 8618.307 – – – 6.5 mm triangular 8618.308 8618.308 – – – Lock insert, lock no. 3524 E2) 8611.180 8611.180 – 2467.000 – Push-button insert 8611.190 8611.190 – 2468.000 – Push-button and lock insert2) 8611.2003) 8611.2003) – 2469.0004) – – – – 9785.0407) – – – – 9785.0426) – For lock inserts For padlock and lock inserts Die-cast zinc RAL 7035 8618.200 8618.230 Die-cast zinc RAL 9005 8618.201 8618.231 Precision-cast stainless steel 8618.220 7 mm square 8 mm square With security lock insert E11) Model No. Lock inserts, type G Lock and push-button inserts Profile half-cylinders To DIN 18 2525) 1) 2) Locking bar latch to CNOMO¹) Packs of Model No. for VX To fit all locking bars in doors and glazed doors with standard lock or comfort handle VX. The latch prevents the locking bars from moving when the door is open. 10 pc(s). 8618.460 1) CNOMO is a French automobile industry standard. For safety reasons, it must not be possible to lock the handle whilst the door is open. Rittal System Catalogue 36/System accessories System accessories Only for use with VW, Audi, SEAT, SkodaAuto, supplied without key With 2 keys 3) Lock no. 12321, no other lock is possible 4) Lock no. 2123, no other lock is possible 5) With 3 keys for each lock insert 6) Packs of two, simultaneous locking within the same pack, no simultaneous locking for different packs 7) Lock-specific key Also required: – For CNOMO1) lock inserts, type G, 6.5 mm triangular insert 8618.308, see page 941 Further technical information available on the Internet. 937 Doors/locks Lock systems Comfort handle for VX SE, PC, IW, EL As the handle does not take up any swing space, due to its folding action, the door surface area available for installed equipment is maximised. Prepared for the installation of lock inserts, lock and push-button inserts or for the installation of standard commercially available 40 or 45 mm profile halfcylinders. Also required: – Handle adaptor, see page 918, for mounting on glazed door for VX SE , PC bottom door, IW designer door Note: – When replacing the comfort handle in the wallmounted enclosure EL, 3-part with 21 U, please note that the handle can only be replaced as a complete system (handle including lock insert) – The comfort handle 8611.020 is included with the supply of the enclosure For lock inserts For padlock and lock inserts For profile half-cylinders Model No. Die-cast zinc RAL 7035 8611.020 8611.290 8611.070 Matt chrome 8611.330 – 8611.340 7 mm square 8611.100 8611.100 – 8 mm square 8611.110 8611.110 – 7 mm triangular 8611.120 8611.120 – 8 mm triangular 8611.130 8611.130 – Screwdriver 8611.140 8611.140 – Daimler insert 8611.150 8611.150 – 3 mm double-bit 8611.160 8611.160 – Fiat 8611.170 8611.170 – 6.5 mm triangular 8611.220 8611.220 – 2467.000 Lock inserts, type F Lock and push-button inserts Lock insert, lock no. 3524 E1) 8611.180 8611.180 Push-button insert 8611.190 8611.190 2468.000 Push-button and lock insert1) 8611.2002) 8611.2002) 2469.0003) – – 9785.0406) – – 9785.0425) Profile half-cylinders to DIN 18 2524) 1) With 2 keys 2) Lock no. 12321, no other lock is possible 3) Lock no. 2123, no other lock is possible 4) With 3 keys for each lock insert 5) Packs of two, simultaneous locking within the same pack, no simultaneous locking for different packs 6) Lock-specific key 938 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Lock systems Comfort handle AX for compact enclosures AX with 3-point lock system, TE, TP, swing frame, large The unlocked handle folds out forwards, and the lock is opened by swivelling. Prepared for the installation of lock inserts or for the installation of standard commercially available 40 or 45 mm profile half-cylinders, as well as lock and push-button inserts. For lock inserts or profile half-cylinders With security lock insert E11) For padlocks and lock inserts or profile half-cylinders Model No. Die-cast zinc RAL 7035 2435.100 2435.200 2435.400 Precision-cast stainless steel 2435.300 – – 7 mm square 2460.000 – 2460.000 8 mm square 2461.000 – 2461.000 7 mm triangular 2462.000 – 2462.000 8 mm triangular 2463.000 – 2463.000 Screwdriver 2464.000 – 2464.000 Daimler insert 2465.000 – 2465.000 3 mm double-bit 2466.000 – 2466.000 Fiat 2307.000 – 2307.000 6.5 mm triangular 2460.650 – 2460.650 2467.000 Lock inserts, type A Lock and push-button inserts Lock insert, lock no. 3524 E2) 2467.000 – Push-button insert 2468.000 – 2468.000 Push-button and lock insert2) 2469.0003) – 2469.0003) 9785.0406) – 9785.0406) 9785.0425) – 9785.0425) Profile half-cylinders to DIN 18 2524) 1) 2) Only for use with VW, Audi, SEAT, SkodaAuto, supplied without key With 2 keys. Lock no. 2123; no other lock is possible 4) With 3 keys for each lock insert 5) Packs of two, simultaneous locking within the same pack, no simultaneous locking for different packs 6) Lock-specific key System accessories 3) Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 939 Doors/locks Lock systems Mini-comfort handle AX for AX/AX IT with cam lock, KX with cam lock, partial doors for modular front design The lock is opened by swivelling the unlocked handle. Prepared for the installation of lock inserts or for the installation of standard commercially available 40 or 45 mm profile half-cylinders, as well as lock and push-button inserts. For lock inserts or profile half-cylinders For padlocks and lock inserts or profile half-cylinders Model No. Die-cast zinc RAL 7035 2537.100 2537.300 7 mm square 2460.000 2460.000 8 mm square 2461.000 2461.000 7 mm triangular 2462.000 2462.000 8 mm triangular 2463.000 2463.000 Screwdriver 2464.000 2464.000 Daimler insert 2465.000 2465.000 3 mm double-bit 2466.000 2466.000 Fiat 2307.000 2307.000 6.5 mm triangular 2460.650 2460.650 2467.000 Lock inserts, type A Lock and push-button inserts Lock insert, lock no. 3524 E1) 2467.000 Push-button insert 2468.000 2468.000 Push-button and lock insert1) 2469.0002) 2469.0002) 9785.0405) 9785.0405) 9785.0424) 9785.0424) Profile half-cylinders to DIN 18 2523) 1) With 2 keys. 2) Lock no. 2123; no other lock is possible 3) With 3 keys for each lock insert 4) Packs of two, simultaneous locking within the same pack, no simultaneous locking for different packs 5) Lock-specific key 940 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Lock systems Mini-comfort handle AX Packs of Model No. for AX plastic The lock is opened by swivelling the unlocked handle. Prepared for the installation of lock inserts or for the installation of standard commercially available 40 or 45 mm profile half-cylinders, as well as lock and push-button inserts. 1 pc(s). 1485.600 Lock inserts, type A 7 mm square 2460.000 8 mm square 2461.000 7 mm triangular 2462.000 8 mm triangular 2463.000 Screwdriver 2464.000 Daimler insert 2465.000 3 mm double-bit 2466.000 Fiat 2307.000 6.5 mm triangular 2460.650 Lock and push-button inserts Lock insert, lock no. 3524 E1) 2467.000 Push-button insert 2468.000 Push-button and lock insert1) 2469.0002) Profile half-cylinders 9785.0405) to DIN 18 2523) 9785.0424) 1) With 2 keys. Lock no. 2123; no other lock is possible With 3 keys for each lock insert 4) Packs of two, simultaneous locking within the same pack, no simultaneous locking for different packs 5) Lock-specific key 2) 3) Lock inserts Accessories: for handles and enclosures – Enclosure key, see page 945 Type A C F G Material Die-cast zinc Die-cast zinc Die-cast zinc Die-cast zinc Length 27 mm 41 mm 7 mm square 2460.000 2523.000 8611.100 8618.300 8 mm square 2461.000 2526.000 8611.110 8618.301 7 mm triangular 2462.000 2527.000 8611.120 8618.302 8 mm triangular 2463.000 2528.000 8611.130 8618.303 Screwdriver 2464.000 – 8611.140 8618.304 Daimler insert 2465.000 2522.000 8611.150 8618.305 3 mm double-bit 2466.000 2483.000 8611.160 8618.306 Fiat 2307.000 – 8611.170 8618.307 6.5 mm triangular 2460.650 – 8611.220 8618.308 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories Model No. 941 Doors/locks Lock systems Lock inserts for installation in comfort handle, mini-comfort handle Lock and push-button inserts Model No. Installation options: – In comfort handle VX for lock inserts – In comfort handle for VX SE, IW, PC for lock inserts – In mini-comfort handle for EL for lock inserts Security lock insert, lock no. 3524 E1) 8611.190 Push-button and lock insert1) 1) 2) Lock and push-button inserts and profile half-cylinders 8611.180 Push-button insert 8611.2002) With two keys Lock no. 12321; no other lock is possible Model No. Installation options: – In comfort handle VX for profile half-cylinders – In comfort handle AX – In mini-comfort handle AX – In mini-comfort handle AX for AX plastic – In mini-comfort handle for EL for profile half-cylinder Security lock insert, lock no. 3524 E1) 2467.000 Push-button insert 2468.000 Push-button and lock insert1) 2469.0002) Profile half-cylinders to DIN 18 2523) 9785.0405) 9785.0424) 1) With two keys 2) Lock no. 2123; no other lock is possible 3) With 3 keys for each lock insert 4) Packs of two, simultaneous locking within the same pack, no simultaneous locking for different packs 5) Lock-specific key Plastic handles With or without lock cylinder insert. Supply includes: – Assembly parts and seal Type B With lock cylinder insert, lock no. 3524 E1) Installation in C Without lock cylinder insert With lock cylinder insert, lock no. 3524 E1) Without lock cylinder insert Console lid TP, stainless steel Comfort Panel Optipanel Console lid TP, sheet steel Model No. RAL 9011 1) 942 2576.000 2533.000 2485.000 2485.100 With two keys Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Lock systems T handles With or without lock cylinder insert. Supply includes: – Seal Type B C With lock cylinder insert1) Installation in Without lock cylinder insert With lock cylinder insert1) Without lock cylinder insert Console lid TP, stainless steel Comfort Panel Optipanel Console lid TP, sheet steel Model No. 2575.0002) 2535.0002) 2572.000 2536.000 1) With 2 keys 2) Lock no. 3524 E Cam lock, stainless steel For Packs of Model No. for AX, KX E-Box With double-bit insert. AX 1 pc(s). 2304.100 KX E-Box 1 pc(s). 2309.110 Material: – Made entirely from stainless steel 1.4404 (AISI 316L) Accessories: – Lock inserts, type A, see page 941 Lock cylinder inserts B With lock no. 3524 E1) With lock no. 3524 E1) IW Console lid TP, stainless steel Installation in Material C Die-cast zinc System accessories Type Die-cast zinc Model No. 2571.000 1) 2525.000 With two keys Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 943 Doors/locks Lock systems Multiple lock Packs of Model No. for 6 padlocks The ideal solution in cases where several people need individual access for maintenance and repair purposes. 2 pc(s). 2493.500 Lock cover Packs of Model No. for AX/AX IT, prepared for a lead seal For retrospective mounting on all compact enclosures AX, sheet steel, with cam lock. 2 pc(s). 2476.100 Material: – Sheet steel Surface finish: – Zinc-plated Material: – Polyamide Colour: – RAL 7035 Safety lock Fitted to doors, to protect against contact with live electrical equipment whilst the master switch is ON. Function: – Locks the door when the master switch is ON. – Mains power (voltage) is only enabled whilst the door is closed. – Monitoring of the lock magnet via an additional closing contact. Supply includes: – Lock – Actuator – Angle bracket – Assembly parts 944 Further technical information available on the Internet. Connection voltage for lock magnet Model No. 230 V AC 11 VA 2416.000 24 V DC 8 W 2418.000 120 V AC 8 VA 2419.000 Also required: – For twin-door enclosures (for the overlapping door, to indicate "enclosure door closed"): Door-operated switch 4127.010, see page 1024 Rittal System Catalogue 36/System accessories Doors/locks Lock systems Enclosure key For lock inserts. Enclosure, case and lock systems are supplied as standard with matching keys. Model No. – – 2549.000 2549.5002)3) 2531.000 – ◾ ◾ – 2532.0001) – – 7 mm triangular 2545.000 – – ◾ 8 mm triangular 2546.000 – ◾ ◾ 7 mm square 2547.000 – – ◾ 8 mm square 2548.000 – ◾ ◾ For HD locks 2549.600 – – – For Daimler 2521.000 – – – For Fiat 2308.000 – – – Double-bit no. 5 Security lock no. 3524 E 1) 2) System accessories Packs of 2 With bit adaptor and reversible bit for: Multi-tooth size 25 and 30 3) Bit 2549.510 for HD lock insert, see page 224 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 945 Doors/locks Lock systems Comfort handle VX Packs of Model No. with numerical code, for VX, VX IT Flexible access opportunities with individual 4-digit code. 1 pc(s). 7030.601 Benefits: – Enhanced security by automatically wiping the code after use – Emergency opening and overwriting of the code is possible with a 40 mm profile half-cylinder to DIN 18 252 Functional principle: – The 4-digit code may be set individually by the user – Programming mode can only be accessed via the set code – Once the code has been entered or used, it is automatically reset to the digits "0000" and thus cannot be read by a third person once the handle has been opened – May be opened in an emergency situation or if the code is forgotten using the master key function with key Supply includes: – Comfort handle for profile half-cylinders – Handle adaptor for VX IT aluminium glazed door and VX IT aluminium sheet steel door, vented (door hinge on right/left) – Assembly parts Also required: – Profile half-cylinders, see page 942 Accessories: – Mounting adaptor for TS 8 doors, see page 948 Dimensions: – W x H x D: 41 x 386 x 46 mm, door-mounted Material: – Die-cast zinc – Plastic Colour: – RAL 9005 Protection category IP to IEC 60 529: – IP 30 CMC III online comfort handle VX with master key function for VX, VX IT For door locking, handle lever monitoring and status display. It can be opened directly via a 24 V DC supply voltage or connected to the CMC III via the CMC III Access Control. Benefits: – Remote control and an extensive range of functions for automated access control by linking to the CMC III, e.g. activation via an optional coded lock or transponder reader – Optical LED status display of the handle or superordinate CMC III system in the rack – Individual activation and colour selection configurable via the CMC III – Prepared for use of a 40 mm profile half-cylinder to DIN 18 252 Technical specifications: – Rated voltage: 24 V DC – Rated current: 100 mA Packs of Model No. 1 pc(s). 7030.611 Supply includes: – Comfort handle for profile half-cylinders – Connection cable RJ12, 2.9 m – Handle adaptor for VX IT aluminium glazed door and VX IT aluminium sheet steel door, vented (door hinge on right/left) – Assembly parts Also required: – Profile half-cylinders, see page 942 Accessories: – – – – CMC III access control, see page 812 CMC III Processing Unit/Compact, from page 804 CMC III coded lock VX, see page 813 CMC III transponder reader VX, see page 813 Dimensions: – W x H x D: 41 x 386 x 42 mm, door-mounted Material: – Die-cast zinc – Plastic Colour: – RAL 9005 Protection category IP to IEC 60 529: – IP 30 946 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Lock systems Radio comfort handle VX Packs of Model No. with card reader for VX, VX IT Battery operated radio handle for door locking, handle lever/rack door monitoring and status display. 1 pc(s). 7030.621 Benefits: – Supports remote control via radio by linking to CMC III – Stand-alone operation supported – Easily retrofitted without any machining thanks to radio technology – Optical LED status display of the handle or superordinate CMC III system in the rack – Individual activation and colour selection configurable via CMC III – Service life of the integral batteries is up to 2 years. – Supports use of the handle without radio technology, connection to CMC III via optional online adapter – High standard of security thanks to encrypted radio transmission of security-relevant signals using Advanced Encryption Standard 128 Bit (AES 128) Functional principle: – Battery operation: EnOcean 868 MHz radio technology with encryption – Operation with CMC III: Up to 128 radio handles on one CMC III system – Stand-alone operation: Handle settings via master card or Android app “Access Control VX” with NFC-enabled smartphone – Supports emergency opening via an integral USB-C-slot, transponder handle and external power supply – Integral transponder card reader for Legic Advant, HID, FeliCa and NFC via Android app (Legic Prime available on request) – Integral monitoring of lever handle – Integral rack door monitoring of the handle position with a compass signal or infrared sensor Max. number of radio comfort handles/sensors Wireless Units Processing Unit Compact Processing Unit 16 0 128 Operating modes/transponder cards Setting of user cards Max. number of user cards per handle Stand-Alone Master card 10 Stand-Alone Android App + Master card 50 CMC III via radio CMC III 1000 Operating mode Also required: – Only for remote control via the CMC III: CMC III Wireless Unit, see page 815 CMC III Processing Unit/-Compact, from page 804 Accessories: – Transponder card, see page 814 – Online adaptor for radio comfort handle, see page 948 – VX mounting adaptor for TS 8 doors, see page 948 Dimensions: – W x H x D: 41 x 377 x 27 mm, door-mounted Material: – Die-cast zinc – Plastic Colour: – RAL 9005 Protection category IP to IEC 60 529: – IP 30 System accessories Supply includes: – Handle – 2 batteries, type CR123A – Handle adaptor for VX IT aluminium glazed door and VX IT aluminium sheet steel door, vented (door hinge on right/left) – 1 Mifare classic transponder card – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 947 Doors/locks Lock systems Mounting adaptor for comfort handle VX with numerical code, radio comfort handle VX For mounting VX handles on doors To fit enclosure type Packs of Model No. TS 8 1 pc(s). 7030.692 Colours: – RAL 9005 Supply includes: – Adaptor – Coupling element – Adaptor for TS glazed aluminium door – Assembly parts Online adaptor Packs of Model No. for radio comfort handle VX For converting the VX radio comfort handle to a wired solution. The adaptor is inserted into the VX radio comfort handle instead of the batteries. 1 pc(s). 7030.624 Application: – Deactivation of radio technology Functional principle: – Control via connection cable and 24 V DC power supply instead of batteries – Connection to CMC III access control system is also optionally supported Also required: – Radio comfort handle VX, see page 947 Accessories: – CMC III access control, see page 812 – CMC III Processing Unit/Compact, from page 804 Technical specifications: – Rated voltage: 24 V DC – Rated current: 100 mA Dimensions: – W x H x D: 34 x 33 x 21 mm Material: – Plastic Supply includes: – Connection cable RJ12, 2.9 m Cable routing kit for doors Packs of Model No. VX, VX IT For optimised cable routing on the inside of the VX enclosure system doors when using a CMC III handle. 1 pc(s). 7030.695 Benefits: – The duct cover and the ring cable holder may be shortened to any desired length Supply includes: – Duct cover, 2 m – 4 ring cable holders, 0.5 m – Assembly parts Functional principle: – When installing handles or reader units with cables, these will need to be laid close to the inside of the door. The cables are routed in the aluminium extrusion of the doors. – To close the duct, the duct cover simply snaps onto the profile. – For cable routing with ventilated or sheet steel doors, the ring cable holder is glued to the inside of the door. Material: – Plastic Colour: – Pale grey 948 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Lock systems Mini-comfort handle for EL 3-part, , 3 – 15 U Prepared for the installation of lock inserts or for the installation of standard commercially available 40 or 45 mm profile half-cylinders, as well as lock and push-button inserts. For lock inserts For profile half-cylinders Model No. Die-cast zinc RAL 7035 7705.110 7705.120 7 mm square 8611.100 – 8 mm square 8611.110 – 7 mm triangular 8611.120 – 8 mm triangular 8611.130 – Screwdriver 8611.140 – Daimler insert 8611.150 – 3 mm double-bit 8611.160 – Fiat 8611.170 – 6.5 mm triangular 8611.220 – 2467.000 Lock inserts, type F6) Lock and push-button inserts Lock insert, lock no. 3524 E1) 8611.180 Push-button insert 8611.190 2468.000 Push-button and lock insert1) 8611.2002) 2469.0003) Profile half-cylinders to DIN 18 2524) – 9785.0407) – 9785.0425) 1) With 2 keys Lock no. 12321, no other lock is possible Lock no. 2123, no other lock is possible 4) With 3 keys for each lock insert 5) Packs of two, simultaneous locking within the same pack, no simultaneous locking for different packs 6) Replacement of the complete system only (handle including lock inserts) 7) Lock-specific key 2) 3) Ergoform-S handle Colour Packs of Model No. RAL 7035 1 pc(s). 7200.810 Accessories: – Profile half-cylinders, see page 942 – Lock inserts, type A, see page 941 System accessories with numerical code, for TE Flexible access options thanks to individual 3-digit numerical code without key, or via the master key function with the additional use of 40 or 45 mm profile half-cylinders to DIN 18 252, independently of the code. Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 949 Doors/locks Lock systems Ergoform-S handle electromagnetic, for TE For door locking and handle lever monitoring. If the 24 V DC voltage supply is applied, the handle cannot be opened with the push-button insert. The handle may be connected to the CMC III via the CMC III access control and activated in this way. The push-button insert may be replaced with a lock insert or a profile half-cylinder, 40 or 45 mm to DIN 18 252. Colour Packs of Model No. RAL 7035 1 pc(s). 7320.700 Accessories: – – – – Profile half-cylinders, see page 942 Lock inserts, type A, see page 941 CMC III access control, see page 812 CMC III Processing Unit/Compact, see page 804 Technical specifications: – Rated voltage: 24 V DC – Rated current: 100 mA Supply includes: – Handle including cable 0.4 m – Push-button insert – Connection cable RJ12, 3 m 950 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Hinges 180° hinges Supply includes: – Assembly parts Note: – The protection category of the enclosure may be reduced – Door hinge remains the same within a bayed enclosure suite Enclosure type Door variant Material Colour Packs of 180° Model No. Sheet steel door Steel/precision-cast Stainless steel door Stainless steel/ precision-cast VX SE Sheet steel door Die-cast zinc VX SE Doors with high dynamic loads, door installations up to 900 N VX IT bayed enclosure suites with comfort handle Sheet steel doors AX/AX IT VX25 RAL 7035 4 pc(s). 8618.3301) RAL 9005 4 pc(s). 8618.3351) – 4 pc(s). 8618.3401) RAL 7035 1) 8800.190 Matt nickel-plated 4 pc(s). Precision casting/ die-cast zinc RAL 7035 4 pc(s). 8800.710 Die-cast zinc RAL 7035 RAL 9005 4 pc(s). 5301.400 5301.401 Aluminium doors Die-cast zinc RAL 9005 Sheet steel door Die-cast zinc – 8701.180 5301.403 3 pc(s). 2449.010 May be mounted without machining the door, suitable for door installations up to 900 N Cover hinge for terminal boxes KX The cover hinge is simply screw-fastened to the enclosure protection channel and to the edge fold. The position of the installation holes is prepunched, so no need to measure and mark out. Material Packs of Model No. Die-cast zinc 6 pc(s). 1592.200 Stainless steel 1.4404 (AISI 316L) 2 pc(s). 1592.210 System accessories Supply includes: – Cover hinge – Stoppers – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 951 Doors/locks Door, internal Support strip For attachment of – Cable ducts – Cable conduit holders – Contact hazard protection covers – Equipment installed on the door – Cable clamping and attachment 4.5 mm diameter hole on a 25 mm DIN pitch pattern Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Accessories: – Screws and self-tapping screws M5, see page 1004 For VX, VX SE, AX plastic, TP, PC, IW Installation options: – In VX, VX SE, PC, IW on tubular door frame – TP on perforated door strip – In AX plastic on mounting boss in the door For AX Installation options: – In AX sheet steel in the enclosure door with cam lock – In AX stainless steel in enclosure door with cam lock in conjunction with perforated door strip For door width mm Distance between attachment points mm Packs of Model No. 400 275 20 pc(s). 4594.000 500 375 20 pc(s). 4309.000 600 475 20 pc(s). 4596.000 800 675 20 pc(s). 4598.000 900 775 20 pc(s). 4579.000 1000 875 20 pc(s). 4599.000 For door width mm Distance between attachment points mm Packs of Model No. 380 305 20 pc(s). 4599.100 400 325 20 pc(s). 4694.000 500 425 20 pc(s). 4695.000 600 525 20 pc(s). 4696.000 760 685 20 pc(s). 4599.200 800 725 20 pc(s). 4697.000 Also required: – For installation in AX stainless steel: AX perforated door strip, stainless steel, see page 953 Punched section with mounting flange, 14 x 39 mm For door width mm Distance between attachment points mm Packs of Model No. for door installation, for VX, VX SE, AX, AX plastic, PC, IW Secure location and fast mounting on the tubular door frame. 400 275 4 pc(s). 8619.700 500 375 4 pc(s). 8619.710 600 475 4 pc(s). 8619.720 800 675 4 pc(s). 8619.730 900 775 4 pc(s). 8619.740 1000 875 4 pc(s). 8619.750 For attaching – Cable ducts – Cable conduit holders – Equipment installed on the door, etc. Installation options: – In VX, VX SE, PC, IW on tubular door frame – In AX sheet steel in the enclosure door with 3-point lock system in the lockable door – In AX stainless steel in enclosure door with 3-point lock system in the lockable door in conjunction with perforated door strip – In AX plastic on mounting boss in the door Material: – Sheet steel Surface finish: – Zinc-plated Also required: – For installation in AX stainless steel: AX perforated door strip, stainless steel, see page 953 Accessories: – Screws and self-tapping screws M5 for configuring the customer's own components on the punched section with mounting flange, see page 1004 Supply includes: – Assembly parts 952 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Door, internal Spacers The universal assembly component for all situations where a distance from the mounting level is required. With self-tapping thread for 4.5 mm diameter holes. The following components may be attached to the rear using 5.5 x 13 mm screws: – Top-hat / cross rails – Contact hazard protection covers – Master switch trim panels – Cable clamp rails etc. Length mm Packs of Model No. 25 12 pc(s). 2311.225 50 12 pc(s). 2311.250 25 Material: – Hexagonal steel (SW8) Surface finish: – Zinc-plated Accessories: 50 – Screws 5.5 x 13 mm, see page 1004 for AX stainless steel For vertical mounting on the threaded bolts of the door. For attaching – Support strips – Punched section with mounting flange, 14 x 39 mm – Door stay Material: – Sheet steel Surface finish: – Zinc-plated Utility lectern for VX, VX SE, TP, PC For programming units etc., prepared for mounting on the tubular door frame. When required for servicing, it folds out quickly with a maximum support area, and after use is lowered between the tubular door frames in a space-saving design. For door height mm Packs of Model No. 760 2 pc(s). 2311.076 1000 2 pc(s). 2311.100 1200 2 pc(s). 2311.120 Accessories: – Support strip, see page 952 – Punched section with mounting flange, 14 x 39 mm, see page 952 – Door stay, see page 956 – Screws, see page 1004 Support area Width mm Depth mm For door width mm Model No. 413 400 600 4638.600 613 400 800 4638.800 System accessories Perforated door strip Load capacity: – Max. 300 N Material: – Sheet steel Colour: – RAL 7035 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 953 Doors/locks Door, internal Wiring plan lectern Packs of Model No. for VX, VX SE, TP, PC Holds wiring plans during fault-finding and maintenance work. Wiring plan lecterns may be bayed in line with the door width. For mounting on the tubular door frame. 1 pc(s). 4120.000 Required/possible number of wiring plan lecterns For door width mm min. max. 400 1 1 500 1 1 Colour: – Similar to RAL 7035 600 2 2 800 2 3 Supply includes: – Wiring plan lectern (width 210 mm) – Assembly parts 1000 3 3 Storage box Packs of Model No. For fixing to all flat, clean surfaces with double-sided adhesive tape. Secure storage of CDs/DVDs, small parts such as fuses etc. 1 pc(s). 2446.000 Material: – Utility lectern: Polypropylene – Mounting bracket: Die-cast zinc Capacity: – Max. 10 CDs/DVDs Material: – Polyamide Colour: – RAL 7035 Wiring plan pocket, sheet steel width-variable, for AX For fastening to the perforated door strip at any height. Variable and easily adjustable in the width. Depth: 35 mm To fit door width mm Clearance opening mm Model No. Width Height 400, 500 325 – 425 210 2515.200 600 475 – 575 210 2515.300 760, 800 625 – 725 210 2515.400 Colour: – RAL 7035 Supply includes: – Assembly screws 954 Further technical information available on the Internet. Also required: – For installation in AX stainless steel: AX perforated door strip, stainless steel, see page 953 Rittal System Catalogue 36/System accessories Doors/locks Door, internal Wiring plan pocket, sheet steel for VX, VX SE, TP pedestal, PC For fastening to tubular door frames at any height. D = 90 mm Clearance opening mm To fit door width mm W H Model No. Colour: – RAL 7035 400 255 210 4114.000 Supply includes: – Assembly parts 500 355 210 4115.000 600 455 210 4116.000 800 655 210 4118.000 900 755 210 4123.000 1000 855 210 4124.000 D = 35 mm Clearance opening mm To fit door width mm H 500 355 210 4115.500 600 455 210 4116.500 800 655 210 4118.500 Clearance opening mm Model No. Plastic wiring plan pocket For adhering to surfaces. Model No. W For format W H D Material: – Polystyrene with self-adhesive fastening strips A3 landscape 438 286 45 2513.000 A4 portrait 228 254 17 2514.000 Colour: – Similar to RAL 7035 A5 landscape 228 174 17 2515.000 For format Model No. A4 2510.000 With welded-on transparent pouch and self-adhesive backing. A3 2512.000 System accessories Wiring plan pocket with transparent pouch Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 955 Doors/locks Door, internal Door stay For To secure the door in the open position. May be fitted without machining the enclosure/housing. VX bottom 1 pc(s). 8618.430 VX SE, TP universal console, PC bottom 5 pc(s). 4583.000 Supply includes: – Assembly parts Mounting Packs of Model No. TP top 2 pc(s). 2519.200 AX sheet steel AX stainless steel top 1 pc(s). 2519.010 Also required: – For installation in AX sheet steel: AX rail for interior installation in the appropriate depth, see page 989 – For installation in AX stainless steel: AX perforated door strip, stainless steel, see page 953 1 Door stay for escape routes For In an emergency situation, conventional door stays could block the escape route. The stay is activated automatically by pressure, releasing the door in both directions. In conjunction with 180° hinges, this ensures that no escape routes are blocked by open doors in the event of an emergency.   Supply includes: – Assembly parts Packs of Model No. VX 1 pc(s). 8618.425 VX SE, PC 1 pc(s). 4583.500 Accessories: – 180° hinge, see page 951 2 2 2 Ride-up roller For for door VX, VX SE, PC Lifts up the door when there is heavy installed equipment (e.g. cooling unit) as a closing aid. For attaching to the tubular door frame.   Packs of Model No. VX 10 pc(s). 8618.420 VX SE, PC 10 pc(s). 4538.000 1 2 956 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Doors/locks Door, internal Shipping brace Packs of Model No. for door VX To stabilise the door when transporting from an additional weight load of 15 kg. 10 pc(s). 8618.410 Transport and mounting handle Packs of Model No. for doors VX, VX SE For safe installation and removal of the door and during relocation in the workshop. 1 pc(s). 2415.100 Document clip, magnetic Packs of Model No. For simple attachment of installation documentation as a reminder or for flexible accommodation of a wide range of documents, measurement records, test reports etc. May be attached to any magnetcompatible surface via a permanent magnet. 2 pc(s). 7950.200 Alternate frame, magnetic Packs of Model No. For individual marking or labelling of the existing network infrastructure. The magnetic surface facilitates flexible mounting on all magnet compatible surfaces. Adhesive strips are supplied for non-magnetic surfaces. The maximum size of the labels is 130 x 50 mm. 10 pc(s). 7950.150 Material: – Plastic Colour: – RAL 7035 Supply includes: – Assembly parts Material: – Plastic Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories Colour: – Clip: Transparent – Handle pieces: Black 957 Roof/wall mounting Roof Outdoor housing for compact enclosures AX – For use outdoors – For creating an enclosure-within-an-enclosure concept – Cut-out at the bottom and integrated louvres in the side and base for optimum enclosure ventilation Housing W x H x D mm For AX enclosures W x H x D mm Packs Model No. of 421 x 550 x 308 300 x 400 x 210 1 pc(s). 9792.055 621 x 650 x 308 500 x 500 x 210 1 pc(s). 9792.065 721 x 750 x 448 600 x 600 x 350 1 pc(s). 9792.075 Also required: Material: – Aluminium AlMg3 Surface finish: – Powder-coated – Wall mounting bracket for AX, sheet steel, see page 966 or wall mounting bracket for AX, stainless steel, see page 967 Note: – Depending on the application/environment, a sheet steel or stainless steel enclosure may be built into the housing – Pole clamp, see page 968 Accessories: Protective roof For H mm Model No. 210 37 2361.010 210 37 2472.010 500 210 37 2362.010 600 210 37 2473.010 Surface finish: – Brushed, grain size 240 600 350 47 2476.010 760 300 43 2474.010 Supply includes: – Assembly parts 800 300 43 2475.010 1000 300 43 2363.010 Enclosure width mm Enclosure depth T mm 300 380 Material: – Stainless steel 1.4301 (AISI 304) for AX The sloping protective roof reliably protects the enclosure from standing moisture and other soiling from above. Rear view 22 H Side view 1 5 T T1 8 1  Recess for wall mounting bracket T1 = Enclosure depth T + 13 mm 958 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Roof/wall mounting Roof Dust guard trim For enclosure AX Length mm 1200 KX A mm Model No. 21.5 2426.500 21 60 A 6 for AX, KX To protect against deposits on the upper edge of the door and between the enclosure and the door/ cover. Cut the dust guard trim to length according to the enclosure width. Drill the enclosure and fit the dust guard trim using the adhesive strips and screws. Material: – Plastic, UV-resistant Colour: – Similar to RAL 7024 Ø5 Supply includes: – Assembly parts Dust guard trim for VX, VX SE To protect against dust deposits on the upper edge of the door and between the door and upper horizontal enclosure section. The dust guard trim provides space for texts or company logos. Colour: – RAL 7035 Model No. 600 2424.100 800 2425.100 1000 2427.100 1200 2426.100 Note: – Also suitable for use in conjunction with top baying cover, see page 915 System accessories Supply includes: – Clear plastic strip for text labels (height 29.5 mm) – Assembly parts Length mm Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 959 Roof/wall mounting Roof Top-mounting module For enclosures As a cable chamber for cable infeed from above, or for power distribution with busbar systems across bayed enclosures. The cover plate supplied as standard is used to finish off at the top. The enclosure height is increased by 200 mm with the topmounting module fitted. Installation accessories for top and bottom, see diagram and explanations below. Width (B) mm Depth mm Packs of Model No. 600 600 1 pc(s). 8618.501 800 600 1 pc(s). 8618.511 1000 600 1 pc(s). 8618.521 1200 600 1 pc(s). 8618.531 Supply includes: – 1 frame module – 2 trim panels (front and rear) – 8 retainers with automatic potential equalisation – Assembly parts Material: – Sheet steel, 1.5 mm Surface finish: – Spray-finished, textured paint Colour: – RAL 7035 Also required: Protection category IP to IEC 60 529: – IP 55 B- 6 Protection category NEMA: – NEMA 12 3 150 200 60 – Side panel for top-mounting module 8618.541, see page 960 B- 88 2 51 Accessories: Description Page  Punched section with mounting flange 991 23 x 64 mm (for the inner level)  Punched rail 18 x 39 mm  Support rail 75 x 20 mm  Support rail 48 x 26 mm  C rail 30/15  Cable clamp rail 2 3 4 5 6 993 996 996 996 1059 1 1 2 3 4 5 6 Side panel Packs of Model No. for top-mounting module To finish off the side of a top-mounting module or bayed suite. 2 pc(s). 8618.541 Material: – Sheet steel, 1.5 mm Surface finish: – Spray-finished, textured paint Colour: – RAL 7035 Supply includes: – Assembly parts 960 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Roof/wall mounting Roof Roof plate IP 55, solid For enclosures Width mm Depth mm Packs of Model No. 400 600 1 pc(s). 9681.646 Material: – Sheet steel, 1.5 mm 400 800 1 pc(s). 9681.648 600 600 1 pc(s). 9681.666 Surface finish: – Textured paint 600 800 1 pc(s). 9681.668 600 1000 1 pc(s). 9681.660 Colour: – RAL 7035 600 1200 1 pc(s). 9681.662 800 600 1 pc(s). 9681.686 800 800 1 pc(s). 9681.688 800 1000 1 pc(s). 9681.680 800 1200 1 pc(s). 9681.682 for VX, VX IT For enclosures without roof plate and in exchange for the standard roof. Protection category IP to IEC 60 529: – IP 55 Supply includes: – Assembly parts Accessories: – Pressure stoppers, see page 962 – Eyebolt, see page 964 Roof plate IP 2X with ventilation hole for VX, VX IT For enclosures without roof plate and in exchange for the standard roof. Material: – Sheet steel, 1.5 mm Surface finish: – Textured paint Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 2X For enclosures Width mm Depth mm Build height mm Packs of Model No. 400 600 72 1 pc(s). 9681.846 400 800 72 1 pc(s). 9681.848 600 600 72 1 pc(s). 9681.866 600 800 72 1 pc(s). 9681.868 800 600 72 1 pc(s). 9681.886 800 800 72 1 pc(s). 9681.888 1000 600 72 1 pc(s). 9681.806 1000 800 72 1 pc(s). 9681.808 1200 600 72 1 pc(s). 9681.826 1200 800 72 1 pc(s). 9681.828 Required no. of glands Packs of Model No. Roof plate for cable entry glands for VX, VX IT For enclosures without roof plate and in exchange for the standard roof. Material: – Sheet steel, 1.5 mm Surface finish: – Textured paint Colour: – RAL 7035 Supply includes: – Assembly parts For enclosures Width mm Depth mm 400 600 3 1 pc(s). 9681.546 400 800 4 1 pc(s). 9681.548 600 400 2 1 pc(s). 9681.564 600 600 4 1 pc(s). 9681.566 600 800 8 1 pc(s). 9681.568 800 600 8 1 pc(s). 9681.586 800 800 8 1 pc(s). 9681.588 850 400 3 1 pc(s). 9681.594 850 600 6 1 pc(s). 9681.596 1100 400 4 1 pc(s). 9681.514 1100 600 8 1 pc(s). 9681.516 System accessories Supply includes: – Assembly parts Also required: – Cable entry gland, see page 962 – Eyebolt, see page 964 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 961 Roof/wall mounting Roof Pressure stoppers for roof plate For converting the IP 55 roof plate into a roof plate with pressure relief function. The pressure relief function is essential for compliance with health and safety regulations for arc-proofing to IEC/TR 61 641. After fitting the pressure stopper, a protection category of IP 54 is achieved. Packs of Model No. 4 pc(s). 9674.790 Material: – Polyamide Supply includes: – 2 warning stickers Note: – 2 pressure stoppers and 1 warning sticker are required for one roof plate – The arc-proofing compliance limits are dependent on the busbar system used Ø Cable entry gland 223 4. 5 135 Colour: – RAL 7035 138 for roof plate For simple, secure cable entry in the roof zone. Protection category IP to IEC 60 529: – IP 55 R2 Supply includes: – Seal 5 226 Cut-out dimensions for 9665.750 to 9665.785 962 Version Material Width mm Depth mm Packs of Model No. 14 x M25/32 Insulating material 250 160 1 pc(s). 9665.750 2 x M25/32/40, 1 x M32/40/50, 2 x M40/50/63 Insulating material 250 160 1 pc(s). 9665.760 With sealing membranes 32 x Ø 7 – 16 mm, 4 x Ø 10 – 20 mm, 3 x Ø 14 – 26 mm Insulating material 250 160 1 pc(s). 9665.770 With entry fittings up to Ø 66 mm Insulating material 250 160 1 pc(s). 9665.780 Solid Sheet steel, spray-finished 250 160 4 pc(s). 9665.785 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Roof/wall mounting Roof Roof plate, two-piece For enclosures for cable entry for VX, VX IT In exchange for the standard roof. Equipped with a sliding angular bracket in the rear section. Rubber cable clamp strip on both sides for attaching cable bundles and bunched cables. Due to the symmetrical design of the VX frame, side cable entry can also be achieved by rotating the roof plate. The two-piece design allows convenient retrofitting. Material: – Sheet steel Width mm Depth mm Packs of Model No. 600 600 1 pc(s). 7826.665 600 800 1 pc(s). 7826.685 600 1000 1 pc(s). 7826.605 800 600 1 pc(s). 7826.865 800 800 1 pc(s). 7826.885 800 1000 1 pc(s). 7826.805 800 1200 1 pc(s). 7826.825 Protection category IP to IEC 60 529: – IP 20 Colour: – RAL 7035 Supply includes: – Assembly parts Brush kit for cable entry in the roof for TE For cable entry in the roof plate. Benefits: – For simple top-mounting on the cut-out edge Material: – Plastic support with brushes – Brush strip: Plastic UL 94-V0 – Bristles: Plastic UL 94-HB For enclosure width mm Bristle length mm Width mm Length mm Packs of Model No. 600 30 19 390 2 pc(s). 7888.610 800 30 19 590 2 pc(s). 7888.612 Cable organiser Packs of Model No. for TE open Cable routing plate for targeted routing of cables. 4 pc(s). 7888.950 Applications: – Optionally on the roof plate of the TE open System accessories Material: – Sheet steel, spray-finished Colour: – RAL 7035 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 963 Roof/wall mounting Roof Spacers for roof plate To raise the roof for ventilation purposes, in three different heights. Thread: M12 Height mm Packs of Model No. 10 4 pc(s). 2422.000 20 4 pc(s). 2423.000 50 4 pc(s). 7967.000 Material: – Hexagonal sectional steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Eyebolt for VX, VX SE For transporting enclosures by crane. Material Packs of Model No. Sheet steel, zinc-plated, C 15E 4 pc(s). 4568.000 Stainless steel 1.4301 (AISI 304) 4 pc(s). 4568.500 Thread: M12 Supply includes: – 4 eyebolts M12 – 4 serrated sealing washers A 12.5 Eyebolt Packs of Model No. for AX For crane transportation of enclosures, with reinforcement plate to be inserted underneath. 2 pc(s). 2509.010 Thread: M12 Supply includes: – 2 eyebolts – 2 reinforcement plates 964 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Roof/wall mounting Wall mounting Wall mounting bracket for AX sheet steel, KX sheet steel, AX IT, EL For the attachment of sheet steel enclosures. Material Wall distance mm Packs of Model No. Sheet steel, zinc-plated 10 4 pc(s). 1590.010 Material Wall distance mm Packs of Model No. Stainless steel 1.4301 (AISI 304) 10 4 pc(s). 1594.010 Benefits: – Screw-fastened directly from the rear with a selftapping screw in the enclosure eyelet Supply includes: – Assembly parts Wall mounting bracket for AX stainless steel, KX stainless steel, stainless steel switch housing For the attachment of stainless steel enclosures. Supply includes: – Assembly parts System accessories Note: – For hygiene reasons, and in view of the protection category, the stainless steel enclosures do not have any drilled holes for the wall mounting bracket. Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 965 Roof/wall mounting Wall mounting Wall mounting bracket for AX sheet steel, KX sheet steel, AX IT, EL Ideal for convenient one-person assembly of wallmounted enclosures, even in confined spaces. Material Sheet steel, zinc-plated Wall distance mm Packs of Model No. 20 4 pc(s). 2508.020 40 4 pc(s). 2503.020 Benefits: – Screw-fastened directly from the rear with a selftapping screw in the enclosure eyelet – Simply suspend the wall mounting bracket 2508.020, which is equipped with an additional suspension contour, from a screw in the wall – Different mounting positions allow the wall mounting bracket to be tailored to local conditions on site – If necessary, the support may be finished with a stylish cover cap – Additional option of attaching with a nut for dynamic applications Supply includes: – Wall mounting bracket – Cover cap – Assembly parts Sample applications Attachment with self-tapping screw 966 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Roof/wall mounting Wall mounting Wall mounting bracket for AX stainless steel, KX stainless steel For the attachment of AX and KX stainless steel enclosures. Benefits: – Simply suspend the wall-mounted bracket from a screw in the wall – Different mounting positions allow the wall mounting bracket to be tailored to local conditions on site – If necessary, the support may be finished with a stylish cover cap Material Wall distance mm Packs of Model No. Stainless steel 1.4301 (AISI 304) 20 4 pc(s). 2433.010 Stainless steel 1.4404 (AISI 316L) 20 4 pc(s). 2433.510 Supply includes: – Wall mounting bracket – Cover cap – Assembly parts Note: – For hygiene reasons, and in view of the protection category, the stainless steel enclosures do not have any drilled holes for the wall mounting brackets for AX, KX, AX IT For the attachment of sheet steel and stainless steel enclosures. Supply includes: – Assembly parts for mounting on the enclosure Material Colour Packs of Sheet steel RAL 7035 4 pc(s). 2505.510 Stainless steel 1.4301 (AISI 304) – 4 pc(s). 2583.010 20 Note: – Additional holes required in the enclosure Model No. 35 Wall angle 13 System accessories R4 34 6.5 26 2 90 70 Wall bracket Packs of Model No. for VX, VX SE, VX IT For attaching enclosures with a shallow depth and e.g. heavy components on the door or a built-in swing frame, to a wall at the top. 4 pc(s). 4595.000 Material: – Sheet steel Surface finish: – Zinc-plated Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 967 Roof/wall mounting Wall mounting Pole clamp Packs of Model No. for AX, KX, AX plastic, AX IT For reliable, convenient fastening to round or square poles. 2 pc(s). 2584.100 For pole diameter / size: – Ø from 40 to 170 mm – □ from 50 to 150 mm Note: – The pole clamp cannot be used in conjunction with a protective roof for AX Material: – Mounting angles, clamping section: Sheet steel – Clamping strap: Stainless steel 1.4301 (AISI 304) Surface finish: – Mounting angle, clamping section: Zinc-plated Supply includes: – 2 mounting angles, 600 mm long – 4 clamping sections – 2 clamping straps – 4 clamping brackets – Assembly parts Enclosure connectors Packs of Model No. Adjustable Between command panels, terminal boxes, compact enclosures and horizontal or vertical surfaces. Pre-mount the connector halves on both sides, screw together and secure with a locking screw, and/or adjust the angle of rotation. 2 pc(s). 6016.200 Note: – The locking screws may be exchanged for standard, commercially available clamping levers (M10 x 50 mm) Rotation range: – ±105° adjustable in 7.5° stepped increments Supply includes: – Assembly parts for both sides 968 Further technical information available on the Internet. 10 54 54 Colour: – RAL 7035 5° Surface finish: – Powder-coated 10 5° Material: – Die-cast zinc Rittal System Catalogue 36/System accessories Roof/wall mounting Wall mounting Frame connector, adjustable Packs of Model No. for Comfort Panel Between the command panel and keyboard housing and horizontal or vertical surfaces. 2 pc(s). 6005.500 Rotation range: – Adjustable in 8° stepped increments, see drawing –14°/+178° Material: – Die-cast zinc 12 0° 64 Supply includes: – Assembly parts and clamping levers for both sides 32° Colour: – RAL 7024 47.5 Surface finish: – Powder-coated 104° Wall mounting Packs of Model No. Vertically hinged Between the Compact Panel and horizontal or vertical surfaces. 2 pc(s). 6341.000 Rotation range: – 180° adjustable on a 7.2° pitch pattern Material: – Wall mounting: Sheet steel – Knurled screw: Steel with plastic knurled handle System accessories Supply includes: – Knurled screw and assembly parts for mounting on the Compact Panel Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 969 Interior installation Mounting plates Mounting plate for terminal boxes KX, bus enclosures KX, terminal boxes HD, Ex enclosures For component installation outside of the enclosure. Assembly screws included as accessories with the enclosure. Accessories: – Self-tapping screws 2487.000, see page 1004 Possible alternative: – Support rail, see page 997 Material: – Sheet steel, 2 mm Surface finish: – Zinc-plated For size mm 970 For Model No. Model No. 150 x 150 1500.000, 1514.000, 1560.000, 1564.000, 1670.600, 1671.600, 9301.000 1560.800 200 x 150 1528.000, 1529.000 1575.800 300 x 150 1501.000, 1515.000, 1530.000, 1561.000, 9302.000 1561.800 400 x 150 1589.000 1576.800 200 x 200 1502.000, 1516.000, 1562.000, 1565.000, 1672.600, 9303.000 1562.800 300 x 200 1503.000, 1517.000, 1531.000, 1563.000, 1566.000, 1674.600, 1583.000, 9304.000 1563.800 400 x 200 1504.000, 1518.000, 1532.000, 1568.000, 1585.000, 1610.000, 1675.600, 9305.000 1564.800 500 x 200 1505.000, 1533.000 1565.800 600 x 200 1506.000, 1586.000 1566.800 800 x 200 1527.000 1574.800 300 x 300 1507.000, 1535.000, 1567.000, 9306.000 1567.800 400 x 300 1508.000, 1536.000, 1569.000, 1611.000, 1676.600 1568.800 500 x 300 1509.000, 1537.000 1569.800 600 x 300 1510.000, 1538.000, 1612.000 1570.800 800 x 300 1613.000 1570.810 400 x 400 1511.000, 1539.000 1571.800 600 x 400 1512.000, 1540.000 1572.800 800 x 400 1513.000, 1541.000 1573.800 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Mounting plates Mounting plate infill for VX For a continuous mounting surface in bayed suites where the mounting plate is set forward. For enclosure height mm Packs of Model No. 1800 1 pc(s). 4590.700 2000 1 pc(s). 4591.700 2200 1 pc(s). 4592.700 Material: – Sheet steel, 2 mm Surface finish: – Zinc-plated Supply includes: – Assembly parts Detail Mounting position of mounting plate Benefits Set forward from the enclosure frame on a 25 mm pitch pattern The usable mounting width is enlarged by up to 25%, depending on the enclosure selection. Position: -25 mm -50 mm -75 mm etc. Mounting plate attachment Packs of Model No. Type A, for VX To reduce vibrations in the mounting plate, e.g. in dynamic applications and when transporting with heavy assemblies. Simple mounting directly on the enclosure frame. During installation, the mounting plate latches automatically into the mounting plate attachment. The mounting plate attachment type A keeps the front of the mounting plate completely free for unrestricted use. Populated mounting plates may be mounted from the front without dismantling the rear panel. 5 pc(s). 8617.353 Detail Material: – Spring steel Supply includes: – Safety clip – Assembly parts Attachment to the mounting plate Mounting position of mounting plate Installation option Flush with the enclosure frame Fitted on the left and right of the mounting plate Latched home Fitted on the left and right of the mounting plate at half height Latched home Flush with the enclosure frame Position: ± 0 mm, fitted at the front Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories Position: ± 0 mm, fitted at the rear 971 Interior installation Mounting plates Mounting plate attachment Packs of Model No. Type B, for VX To reduce vibrations in the mounting plate, e.g. in dynamic applications and when transporting with heavy assemblies. Simple mounting directly on the enclosure frame or on the punched section with mounting flange 23 x 64 mm. The mounting plate may optionally be screw-fastened with the mounting plate attachment, or form-fit connected. Depending on the installation situation, the mounting plate attachment type B either minimally surrounds the mounting plate, or keeps the front of the mounting plate completely free for unrestricted use. May be mounted from the front or the rear, depending on the situation. 10 pc(s). 8617.351 Material: – Sheet steel Surface finish: – Zinc-plated, passivated Supply includes: – Assembly parts Accessories: – Punched section with mounting flange 23 x 64 mm for the inner level, see page 991 Mounting position of mounting plate Detail Set forward from the enclosure frame 1 -50 -50 Position: -50 mm Set forward from the enclosure frame Position: -50 mm 2 Set forward from the enclosure frame 1 -75 -75 Position: -75 mm Set forward from the enclosure frame Position: -75 mm 2 Set forward from the enclosure frame  Position: -100 mm or larger 1 972 -25 -100  Position: -25 mm or larger Installation option Attachment to the mounting plate  2 pc(s). per enclosure/ Screw-fastened  All-round between Connected  2 pc(s). per enclosure/ Screw-fastened  All-round between Connected All-round between the enclosure and mounting plate in any quantity. One punched section with mounting flange 23 x 64 mm to match the enclosure depth is required for each mounting plate attachment. Connected mounting plate, at the side, half-way up the mounting plate the enclosure and mounting plate in any quantity mounting plate, at the side, half-way up the mounting plate the enclosure and mounting plate in any quantity 2 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Mounting plates Mounting plate attachment Packs of Model No. Type C, for VX To reduce vibrations in the mounting plate, e.g. in dynamic applications and when transporting with heavy assemblies. Simple mounting directly on the enclosure frame. The mounting plate may be form-fit connected and clamped with the mounting plate attachment. The mounting plate attachment type C keeps the front of the mounting plate completely free for unrestricted use. With the mounting plate installed and the rear panel dismantled, it can be fitted from the rear. 10 pc(s). 8617.352 Mounting position of mounting plate Detail Flush with the enclosure frame Surface finish: – Zinc-plated, passivated Supply includes: – Assembly parts Installation option Attachment to the mounting plate All-round between the enclosure and mounting plate in any quantity Connected, clamped All-round between the enclosure and mounting plate in any quantity Connected, clamped ±0 Position: ± 0 mm Material: – Sheet steel Set forward from the enclosure frame -25 Position: -25 mm VX installation kit Packs of Model No. for back-to-back mounting plates The minimum spacing between the mounting plates facilitates maximum assemblies on both mounting plates. 1 pc(s). 8617.360 Material: – Sheet steel Surface finish: – Zinc-plated, passivated Also required: – Second mounting plate, to fit the enclosure dimensions, refer to Rittal list of spares at www.rittal.com Accessories: Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories – For enclosures with a rear panel, following may be used for optimum access to the rear mounting plate: Glazed door instead of rear panel, see page 917 Lockable and adjacent door 8618.120, for enclosure dimensions W x H = 800 x 2000 mm, see page 917 973 Interior installation Mounting plates Multi-function mounting kit VX Packs of Model No. for mounting plate 1 pc(s). 8617.370 For installing the mounting plate from the rear of the enclosure – Mounting position flush with the enclosure frame, position ± 0 mm – The mounting plate is removable from the front and rear for servicing – For 20 mm more installation depth in the enclosure – Mounting position set back behind the enclosure frame, position ±20 mm Material: – Sheet steel Surface finish: – Zinc-plated, passivated Supply includes: – Assembly parts For additional screw-fastening of the mounting plate – For all mounting positions Slide rail for mounting plates, for VX, VX SE For sliding the mounting plate in from the side. For mounting in a set-forward position. For enclosure width mm Packs of Model No. 600 2 pc(s). 8617.400 800 2 pc(s). 8617.401 1200 2 pc(s). 8617.402 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Cross-brace for mounting plates, for VX, VX SE Additional horizontal rigidity for vibration damping and/or retrospective stabilisation of wide mounting plates. This brace may also be used as an attachment aid for heavy components. For enclosure width mm Model No. 1200 4333.120 1600 4333.160 1800 4333.180 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – 2 sections – 4 clamping sections – 4 grub screws M10 x 16 mm 974 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Mounting plates Partial mounting plate VX for VX, VX SE, PC, IW To accommodate additional components inside the enclosure. Partial mounting plates are extremely versatile, providing a platform for a diverse range of applications. For optional installation either upright as a vertical mounting surface, or flat as a horizontal base. For attachment either directly to the enclosure section or, with a set-forward construction, for example, to any mounting level in the enclosure using punched sections with mounting flanges. For multi-level installation one behind the other, partial mounting plates may be vertically hinged, via hinge attachment 8617.650, to allow rapid access to the levels behind. Also required: – For the installation in VX SE, PC, IW: Adaptor rail VX, see page 995 Accessories: – Punched section with mounting flange 18 x 64 mm for the outer level, see page 990 – Punched section with mounting flange 23 x 64 mm for the inner level, see page 991 – Hinge attachment 8617.650, see page 977 Installation examples: See page 976 Material: – Sheet steel, 2.5 mm Surface finish: – Zinc-plated Supply includes: – Assembly parts Note: – Depending on the mounting situation, additional parts such as punched sections with mounting flanges may be required, see installation example on page 976 For installation in Enclosure width mm Enclosure depth (side) mm Door width mm Dimensions mm Packs of Model No. 500 x 300 1 pc(s). 8617.510 500 x 400 1 pc(s). 8617.520 500 x 500 1 pc(s). 8617.530 600 500 x 700 1 pc(s). 8617.540 – 600 500 x 775 1 pc(s). 8617.550 – ◾ 800 700 x 300 1 pc(s). 8617.560 ◾ – ◾ 800 700 x 400 1 pc(s). 8617.570 – – – ◾ 800 700 x 700 1 pc(s). 8617.580 – ◾ – – – 1000 900 x 300 1 pc(s). 8617.590 ◾ – – ◾ – – 1000 900 x 400 1 pc(s). 8617.600 – ◾ – – – ◾ – 1000 900 x 500 1 pc(s). 8617.610 – – – ◾ ◾ – – – – 1100 x 300 1 pc(s). 8617.620 – – – – ◾ – ◾ – – – 1100 x 400 1 pc(s). 8617.630 – ◾ – – ◾ – – ◾ – – 1100 x 500 1 pc(s). 8617.640 600 800 1000 1200 400 500 600 ◾ ◾ – – – – ◾ – – – – ◾ – – – ◾ ◾ – ◾ ◾ 800 ◾ – ◾ – 600 – ◾ ◾ – 600 – – – ◾ – 600 – – – – ◾ ◾ – – – – – ◾ – ◾ – – ◾ – – – ◾ – – – – – ◾ – – ◾ – – ◾ – – – – ◾ ◾ System accessories 400 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 975 Interior installation Mounting plates Partial mounting plates VX, installation examples 800 500 700 500 600 700 Full installation in the width/depth Choose a partial mounting plate 100 mm smaller than the nominal size of the enclosure. For example, a partial mounting plate with dimensions 500 x 700 mm can be installed in enclosures with nominal dimensions of 600 and 800 mm. 900 1100 2000 2000 500 700 Full installation in the height The sum total of partial mounting plates 100 mm should be smaller than the nominal size of the enclosure. For example, in a 2000 mm high enclosure, the sum total of partial mounting plates should not exceed 1900 mm. 500 Full installation, set forward in the width/depth For set-forward installation, punched sections with mounting flanges are required for the inner or outer mounting level, according to the enclosure depth. Partial installation 800 976 Further technical information available on the Internet. 700 A 500 700 700 500 B A A 600 500 700 Door installation Choose a partial mounting plate 100 mm smaller than the nominal size of the enclosure. For example, a partial mounting plate with dimensions 500 x 700 mm can be installed on the tubular door frame of enclosures with a nominal size of 600 mm. 800 500 Also required: – Punched section with mounting flange 23 x 64 mm (A) to match the enclosure width or depth, see page 991 – Punched section with mounting flange 23 x 64 mm (B) to match the enclosure height, see page 991 800 Rittal System Catalogue 36/System accessories Interior installation Mounting plates Hinge attachment Packs of Model No. for partial mounting plate VX In conjunction with the mounting kit for swing frames, small, the partial mounting plate VX can be hinged to allow access to the components behind it for servicing. 1 pc(s). 8617.650 Installation options: – At the front, on the frame section – Set back, in the enclosure depth – At the side, in conjunction with the hinged side panel Also required: – Installation kit for swing frame, small, for enclosure width 600 mm (8619.600) or 800 mm (8619.610), see page 1076 – Punched section with mounting flange 23 x 64 mm according to the enclosure depth, see page 991 Material: – Steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Examples In the highest or lowest position Front  Installation kit for swing frame, small  Punched section with mounting flange Set back 23 x 64 mm in accordance with the enclosure depth 1 1 2 1 2 1 In a central position Front Set back 2 2 1 2 2 1 1 System accessories 1 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 977 Interior installation Mounting plates Partial mounting plate holder Packs of Model No. for partial mounting plate VX The partial mounting plate may be fitted set back by 20 mm behind the enclosure frame using the partial mounting plate holder, and also fastened directly to the frame from the outside. The partial mounting plate is also removable from the inside for servicing. 4 pc(s). 8617.655 Material: – Sheet steel Surface finish: – Zinc-plated, passivated Supply includes: – Assembly parts 978 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Partial mounting plate VX System accessories Provides flexible and individual interior installation, see page 980 Rittal System Catalogue 36/System accessories 979 Interior installation Mounting plates Partial mounting plate VX for VX, VX SE To accommodate additional components inside the enclosure. Partial mounting plates are extremely versatile, providing a platform for a diverse range of applications. They are attached directly to the enclosure section. For individual interior installation, system punchings are additionally provided in the edge fold. Dimensions mm Packs of Model No. 500 x 400 1 pc(s). 8617.660 500 x 600 1 pc(s). 8617.661 600 x 400 1 pc(s). 8617.662 600 x 600 1 pc(s). 8617.663 800 x 400 1 pc(s). 8617.664 800 x 600 1 pc(s). 8617.665 Material: – Sheet steel, 1.5 mm Also required: Surface finish: – Zinc-plated – For the installation in VX SE: Adaptor rail VX, see page 995 Supply includes: – Assembly parts Outer mounting level 1 1 Inner mounting level 1 2 1  Partial assembly plate  Punched section with mounting flange, 23 x 64 mm 980 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Mounting plates Transport handle Packs of Model No. for mounting plate, for VX, VX SE For use at any given position in the side C-fold. Benefits include: – Adapts to users of different heights – Optimised force transmission – Simple handling 2 pc(s). 2415.500 Mounting plate for Outdoor Basic enclosure For the configuration of mounting levels. The mounting plates are depth-adjustable on a 25 mm pitch pattern. For enclosure Width mm Height mm F mm G mm Model No. 600 1200 499 1096 9765.092 800 1200 699 1096 9765.095 1200 1200 1099 1096 9765.191 Material: – Aluminium, 3 mm Note: – For an enclosure width of 1200 mm, partial installation with one or two 600 mm wide mounting plates is possible Mounting plate attachment for TP one-piece console, TP pedestal for high dynamic loads To reduce vibrations in the mounting plate. 24.5 48 23 73 F 23 23 42 17 G Supply includes: – Assembly parts Packs of Model No. 1 pc(s). 5001.075 Applications: – During transportation with heavy assemblies – For dynamic applications, if a direct connection between the mounting plate and the enclosure is required for mobile use (e.g. with accompanying enclosures in crane systems, etc.) Tested as per DIN EN 60 721 Severity 3 M4, with a weight of 150 kg evenly distributed over the mounting plate. Simply screw-fasten to the existing holes in the mounting plate to pre-assemble for:  Wall mounting from the inside 1 System accessories Direct using a bracket and wall / support mounted enclosure.  Wall mounting from the outside Screws for wall mounting brackets can easily be screwed into the square nut from the outside Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories 2 Further technical information available on the Internet. 981 Interior installation Mounting plates for TP For installation in – Console and desk unit on the interior installation system rails – Punched sections with mounting flanges or support strips fitted to the side of the pedestal in the depth For easy mounting on pre-fitted assembly screws. Bayable by screw-fastening at the sides. Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Width mm Height mm Packs of Model No. 200 437 1 pc(s). 6730.310 500 437 1 pc(s). 6730.330 700 437 1 pc(s). 6730.340 For console/desk unit width mm Max. partial mounting plates that may be installed 600 1 x 6730.330 800 1 x 6730.340 1200 2 x 6730.310 1 x 6730.340 1600 1 x 6730.330 1 x 6730.340  From width 200/500/700 500 mm 150/450/650 6.5 1 Ø 425 425 350 5 10 Further technical information available on the Internet. 5 Ø 982 6. 6. 437 Ø 6.5 10 Partial mounting plate, locatable 1 Rittal System Catalogue 36/System accessories Interior installation Rail systems AX installation examples with system rails Preparing for installation For enclosure depth mm  Rail for interior installation AX Packs of Model No. 4 pc(s). 2393.210 2393.250 2393.300 2393.350 2393.400 210 250 300 350 400 Page 989 Installation of support strip and punched section with mounting flange 14 x 39 mm in enclosure height/width For enclosure height/width mm A1) mm 400 500 1)  Punched section with mounting flange, 14 x 39 mm  Support strip Page Page Packs of Model No. Packs of Model No. 275 4 pc(s). 8619.700 20 pc(s). 4594.000 375 4 pc(s). 8619.710 20 pc(s). 4309.000 600 475 4 pc(s). 8619.720 20 pc(s). 4596.000 700 575 4 pc(s). 8619.760 20 pc(s). 8800.130 760 635 4 pc(s). 8619.790 800 675 4 pc(s). 8619.730 990 20 pc(s). – 20 pc(s). 4598.000 994 1000 875 4 pc(s). 8619.750 20 pc(s). 4599.000 1200 1075 4 pc(s). 8619.770 20 pc(s). – 1,400 1275 4 pc(s). 8619.780 20 pc(s). – 1 A = Rail mounting distance X X A A Installation of support strip and punched section with mounting flange 14 x 39 mm in enclosure width A1) mm 300 400 1)  Punched section with mounting flange, 14 x 39 mm  Support strip Page Packs of Model No. Packs of Model No. 275 4 pc(s). 8619.700 20 pc(s). 4594.000 375 4 pc(s). 8619.710 20 pc(s). 4309.000 500 475 4 pc(s). 8619.720 20 pc(s). 4596.000 600 575 4 pc(s). 8619.760 20 pc(s). 8800.130 700 675 4 pc(s). 8619.730 20 pc(s). 4598.000 800 775 4 pc(s). 8619.740 20 pc(s). 4579.000 990 Page 994 System accessories For enclosure width mm A = Rail mounting distance X A Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 983 Interior installation Rail systems TP pedestal/one-piece console Installation examples with system rails Preparing for installation  Rail for interior installation Packs of Model No. 4 pc(s). For enclosure height mm 675 960 5001.050 5001.051 Page 995 Installation in the width Packs of Model No. For enclosure width mm 600 800 1000 1200 1600 A1) mm 575 775 975 1175 1575 – – – – 992 – – – 994  Punched section with mounting flange, 4 pc(s). 8612.060  Support strip 20 pc(s). 8800.130 4579.000 17 x 73 mm Installation in the depth 1 For enclosure depth mm A1) mm Packs of 400 325 4 pc(s). 8612.140 8612.140 8612.140 8612.140 8612.140 500 425 4 pc(s). 8612.150 8612.150 8612.150 8612.150 8612.150 400 325 20 pc(s). 4694.000 4694.000 4694.000 4694.000 4694.000 500 425 20 pc(s). 4695.000 4695.000 4695.000 4695.000 4695.000  Punched section with mounting flange 17 x 73 mm  Support strip Model No. 992 994 Installation in the height (individual installation e.g. with) Punched section with mounting flange, 17 x 73 mm see page 992 Support strip see page 994 1) A = Rail mounting distance A X 5 1 4 1 2 3 X 4 984 Further technical information available on the Internet. A Rittal System Catalogue 36/System accessories Interior installation Rail systems TP console Installation examples with system rails Preparing for installation  Rail for interior installation Packs of Model No. 4 pc(s). For enclosure width mm 600 800 1200 1600 5001.050 5001.051 5001.053 5001.054 600 800 Page 995 Installation in the height A1) mm Packs of For enclosure width mm Model No. 1200 1600 1  Punched section with mounting flange, 17 x 73 mm For cover 375 4 pc(s). 8612.040 8612.040 8612.040 8612.040 992 For enclosure 425 4 pc(s). 8612.150 8612.150 8612.150 8612.150 992  Support strip For cover 375 20 pc(s). 4309.000 4309.000 4309.000 4309.000 994 For enclosure 425 20 pc(s). 4695.000 4695.000 4695.000 4695.000 994 8619.710 – – – 990  Punched section with mounting flange 14 x 39 mm For enclosure 1) 375 4 pc(s). A = Rail mounting distance 1 Console/console lid 4 1 2 A X 3 A 1 System accessories X Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 985 Interior installation Rail systems VX/ VX SE installation examples with system rails Inner level VX SE VX A A A VX VX SE A A A A Outer level VX SE A A VX Installation between vertical sections in the width/depth A Installation in the roof and base frame in the width/depth Punched section with mounting flange 18 x 64 mm, installation in VX For enclosure width/height/depth Packs of mm A1) mm Model No.2) Model No. Model No.2) 300 4 pc(s). 225 8617.000 – – 8617.000 – 400 4 pc(s). 325 8617.010 – – 8617.010 – 500 4 pc(s). 425 8617.020 – – 8617.020 – 600 4 pc(s). 525 8617.030 – – 8617.030 – 800 4 pc(s). 725 8617.040 – – 8617.040 – 1000 4 pc(s). 925 8617.050 – – 8617.050 – 1200 4 pc(s). 1125 8617.060 – – 8617.060 – Page 990 1) A = Rail mounting distance 2) Only suitable for installation in the roof Punched section with mounting flange 23 x 64 mm, installation in VX, VX SE For enclosure width/height/depth Packs of mm A1) mm Model No.2) Model No.2) Model No. 300 4 pc(s). 225 8617.100 8617.100 – 400 4 pc(s). 325 8617.110 8617.110 – 500 4 pc(s). 425 8617.120 8617.120 – 600 4 pc(s). 525 8617.130 8617.130 – 800 4 pc(s). 725 8617.140 8617.140 – 1000 4 pc(s). 925 8617.150 8617.150 – 1200 4 pc(s). 1125 8617.160 8617.160 – 1,400 4 pc(s). 1325 8617.170 8617.170 – 1600 4 pc(s). 1525 8617.180 8617.180 – 1800 4 pc(s). 1725 8617.190 8617.190 – 2000 4 pc(s). 1925 8617.200 8617.200 – 2200 4 pc(s). 2125 8617.210 8617.210 – Page 991 1) A = Rail mounting distance 2) For the installation on the vertical section of the VX SE, the adaptor rail VX is required, see page 995 986 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Rail systems VX/VX SE installation examples with system rails Inner level VX A A VX VX SE A A A A Outer level VX SE A A VX SE A VX Installation between vertical sections in the width/depth A Installation in the roof and base frame in the width/depth Punched section with mounting flange 23 x 89 mm, stainless steel, installation in VX, VX SE For enclosure width/depth mm Packs of A1) mm Model No.2) Model No.2) Model No. 400 2 pc(s). 325 8100.730 8100.730 – 500 2 pc(s). 425 8100.731 8100.731 – 600 2 pc(s). 525 8100.732 8100.732 – 800 2 pc(s). 725 8100.733 8100.733 – Page 991 1) A = Rail mounting distance 2) For the installation on the vertical section of the VX SE, the adaptor rail VX is required, see page 995 Punched section without mounting flange 23 x 64 mm, installation in VX, VX SE For enclosure width/height/depth Packs of mm A1) mm Model No.2) Model No.2) Model No. 400 2 pc(s). 325 8100.740 8100.740 – 500 2 pc(s). 425 8100.741 8100.741 – 600 2 pc(s). 525 8100.742 8100.742 – 800 2 pc(s). 725 8100.743 8100.743 – 1200 2 pc(s). 1125 8100.745 8100.745 – Page 993 1) System accessories A = Rail mounting distance 2) For the installation on the vertical section of the VX SE, the adaptor rail VX is required, see page 995 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 987 Interior installation Rail systems VX/VX SE installation examples with system rails Inner level VX A A VX VX SE A A A A Outer level VX SE A A VX SE A VX Installation between vertical sections in the width/depth A Installation in the roof and base frame in the width/depth Punched rail 23 x 23 mm, installation in VX, VX SE For enclosure width/height/depth Packs of mm A1) mm Model No.2) 3) Model No.2) 3) Model No. 400 12 pc(s). 325 4169.000 4169.000 – 500 12 pc(s). 425 4170.000 4170.000 – 600 12 pc(s). 525 4171.000 4171.000 – 800 12 pc(s). 725 4172.000 4172.000 – 1000 12 pc(s). 925 4173.000 4173.000 – 1200 6 pc(s). 1125 4174.000 4174.000 – 1400 6 pc(s). 1325 4393.000 4393.000 – 1600 6 pc(s). 1525 4175.000 4175.000 – 1800 6 pc(s). 1725 4176.000 4176.000 – 2000 6 pc(s). 1925 4177.000 4177.000 – 2200 6 pc(s). 2125 4178.000 4178.000 – Page 994 1) A = Rail mounting distance 2) For the installation on the vertical section of the VX SE, the adaptor rail VX is required, see page 995 3) For the installation in VX and VX SE, the mounting bracket 4182.000 and a U nut are required, see page 1002/1003 Punched rail 18 x 39 mm, installation in VX, VX SE For enclosure width/depth mm Packs of A1) mm Model No.2) Model No.2) Model No. 400 4 pc(s). 325 8617.700 8617.700 – 500 4 pc(s). 425 8617.710 8617.710 – 600 4 pc(s). 525 8617.720 8617.720 – 800 4 pc(s). 725 8617.730 8617.730 – Page 993 1) A = Rail mounting distance 2) For the installation on the vertical section of the VX SE, the adaptor rail VX is required, see page 995 988 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Rail systems Rail for interior installation AX For mounting in the enclosure, no machining required. Suitable for mounting on the side, base and roof using the locators integrated into the enclosure. Variable with 2 rows of system punchings, creates additional mounting space e.g. for: – Punched section with mounting flange, 14 x 39 mm – Enclosure lights – Door-operated switch – Door stay – Cable conduit holder For enclosure depth mm Packs of Model No. 210 4 pc(s). 2393.210 250 4 pc(s). 2393.250 300 4 pc(s). 2393.300 350 4 pc(s). 2393.350 400 4 pc(s). 2393.400 Configuration examples: Benefits: – Only one screw for attaching the rail inside the enclosure – Including adaptor for door-operated switch – Compatibility with VX25 accessories – Enclosure protection category is retained (no machining required) – Automatic potential equalisation – May be retro-fitted even with the mounting plate in situ, suitable for installation via gland plates Material: – Sheet steel Surface finish: – Zinc-plated Also required: X A – For installing LED system light: Mounting bracket for interior installation, see page 1000 System accessories A = Rail mounting distance Mounting of LED system light Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 989 Interior installation Rail systems Punched section with mounting flange, 14 x 39 mm For enclosure height/width mm Distance between attachment points mm 400 275 4 pc(s). 8619.700 500 375 4 pc(s). 8619.710 For the attachment of – Cable ducts – Cable conduit holder 600 475 4 pc(s). 8619.720 700 575 4 pc(s). 8619.760 760 635 4 pc(s). 8619.790 Material: – Sheet steel 800 675 4 pc(s). 8619.730 1000 875 4 pc(s). 8619.750 1200 1075 4 pc(s). 8619.770 1400 1275 4 pc(s). 8619.780 for AX Interior installation in the enclosure height and width Locates securely onto the interior installation rail AX. Surface finish: – Zinc-plated Packs of Model No. Supply includes: – Assembly parts Also required: – Interior installation rail AX for configuration in the enclosure height and width, see page 989 Accessories: – Screws and self-tapping screws M5 for configuring the customer’s own components on the punched section with mounting flange, see page 1004 Punched section with mounting flange, 18 x 64 mm for VX For variable, individual interior installation of the enclosure frame on the outer mounting level. Simply locate into the system punchings from the outside and screw-fasten. System punchings on all four sides. With bayed enclosures, the punched sections with mounting flanges may also be fitted from the inside of the enclosure. Installation options: – On the outer mounting level, on the enclosure section – On the outer mounting level, between two punched sections with mounting flanges 23 x 64 mm For enclosure width/height/depth mm Packs of Model No. 300 4 pc(s). 8617.000 400 4 pc(s). 8617.010 500 4 pc(s). 8617.020 600 4 pc(s). 8617.030 800 4 pc(s). 8617.040 1000 4 pc(s). 8617.050 1200 4 pc(s). 8617.060 Accessories: – Screws, see page 1004 – Cable tie 2597.000, see page 1061 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts 990 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Rail systems Punched section with mounting flange, 23 x 64 mm For enclosure width/height/depth mm Packs of Model No. for VX, VX IT, VX SE, AX plastic For variable and individual interior installation. Simply locate into punchings and screw-fasten. System punchings on all four sides. With slots at the top and bottom for cage nuts, for attaching your own components via metric screws. 300 4 pc(s). 8617.100 400 4 pc(s). 8617.110 500 4 pc(s). 8617.120 600 4 pc(s). 8617.130 800 4 pc(s). 8617.140 Installation options: VX/VX IT – On the inner mounting level, on the enclosure section VX 1000 4 pc(s). 8617.150 1200 4 pc(s). 8617.160 1400 4 pc(s). 8617.170 1600 4 pc(s). 8617.180 VX SE – On the vertical section of the VX SE with adaptor rail VX 1800 4 pc(s). 8617.190 2000 4 pc(s). 8617.200 2200 4 pc(s). 8617.210 AX plastic – In the width and height of the enclosure in conjuction with universal bracket System accessories – On identical punched sections with mounting flanges – In the base/plinth system VX in the width and depth, combined with a base/plinth installation bracket Material: – Sheet steel Surface finish: – Zinc-plated Also required: – For VX SE: Adaptor rail VX, see page 995 – For AX plastic: Universal bracket 1485.200, see page 97 Accessories: – – – – Screws, see page 1004 Cable tie 2597.000, see page 1061 Cage nut, see page 1002 Base/plinth installation bracket, see page 885 Supply includes: – Assembly parts Stainless steel for VX, VX SE For variable, individual interior installation of the enclosure frame on the inner mounting level. Simply locate into punchings and screw-fasten. System punchings on all four sides. With slots at the top and bottom for cage nuts, for attaching your own components via metric screws. Especially for cable routing in the base/plinth system VX, stainless steel and for the installation of busbar supports (nonmagnetic stainless steel). Installation options: VX – On the inner mounting level, on the enclosure section VX VX SE – On the vertical section of the VX SE with adaptor rail VX For enclosure width/depth mm Packs of Model No. 400 2 pc(s). 8100.730 500 2 pc(s). 8100.731 600 2 pc(s). 8100.732 800 2 pc(s). 8100.733 Also required: – For VX SE: Adaptor rail VX, see page 995 Accessories: – – – – Screws, see page 1004 Cable tie 2597.000, see page 1061 Cage nut, see page 1002 Base/plinth installation bracket, see page 885 System accessories Punched section with mounting flange, 23 x 89 mm System accessories – On identical punched sections with mounting flanges – In the base/plinth system VX, stainless steel, in the width and depth, combined with a base/plinth installation bracket Material: – Stainless steel Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 991 Interior installation Rail systems Punched section with mounting flange, 17 x 73 mm for VX SE, TP, PC, IW For universal skeleton structures or partial assembly. Simply locate onto the punchings and secure. Installation options: VX SE, PC, IW – On the vertical enclosure section – On the outer mounting level, all-round, at the same height – On the inner mounting level, all-round, height-offset VX SE, PC – On the horizontal enclosure extrusion – May be mounted on the top horizontal section in the depth TP – Via rail for interior installation – In the depth, for outer mounting level – In the width, for inner mounting level For the outer mounting level For enclosure width/depth mm Packs of Model No. 300 4 pc(s). 8612.130 400 4 pc(s). 8612.140 500 4 pc(s). 8612.150 600 4 pc(s). 8612.160 For the inner mounting level For enclosure width/depth mm Length mm Packs of Model No. 300 290 4 pc(s). 8612.030 400 390 4 pc(s). 8612.040 500 490 4 pc(s). 8612.050 600 590 4 pc(s). 8612.060 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly screws Also required: – For installation in TP: Rail for interior installation, see page 995 Accessories: – Screws, see page 1004 – Cable tie for fast assembly 2597.000, see page 1061. 992 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Rail systems Punched section without mounting flanges, 23 x 64 mm for VX, VX SE For variable, individual interior installation of the enclosure frame on the inner mounting level. Mounted flush with enclosure frame The additional mounting brackets mean it can also be used with a pre-installed mounting plate, and is also prepared for cutting to any required length. System punchings on all four sides. With slots at the top and bottom for cage nuts, for attaching your own components via metric screws. Installation options: VX – On the inner mounting level, on the enclosure section For enclosure width/height/depth mm Packs of Model No. 400 2 pc(s). 8100.740 500 2 pc(s). 8100.741 600 2 pc(s). 8100.742 800 2 pc(s). 8100.743 1200 2 pc(s). 8100.745 Also required: – For VX SE: Adaptor rail VX, see page 995 VX SE – On the vertical section of the VX SE with adaptor rail VX System accessories – Between two punched sections with mounting flanges for the inner mounting level – As installation kit for component shelves Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – 1 pack = 2 punched sections without mounting flanges 23 x 64 mm 4 mounting brackets for VX, VX SE For variable, individual interior installation of the enclosure frame on the inner mounting level, may also be used in conjunction with other punched sections. Prepared at the rear to accommodate cable clamps for optimum cable routing inside the enclosure Installation options: VX – On the inner mounting level, on the enclosure section VX SE – On the vertical section of the VX SE with adaptor rail VX Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories For enclosure width/depth mm Packs of Model No. 400 4 pc(s). 8617.700 500 4 pc(s). 8617.710 600 4 pc(s). 8617.720 800 4 pc(s). 8617.730 Note: – In enclosures with a mounting plate, two punched rails (as mounting plate slide rails) are already included with the supply Also required: – For VX SE: Adaptor rail VX, see page 995 Accessories: – Screws, see page 1004 – Cable tie 2597.000, see page 1061 – Cable clamps, see page 1060 Further technical information available on the Internet. System accessories Punched rail 18 x 39 mm 993 Interior installation Rail systems Punched rail 23 x 23 mm Length mm For WHD mm Packs of Model No. for VX, VX SE 295 400 12 pc(s). 4169.000 Installation options: VX – To the vertical and horizontal enclosure sections via mounting brackets 395 500 12 pc(s). 4170.000 495 600 12 pc(s). 4171.000 695 800 12 pc(s). 4172.000 895 1000 12 pc(s). 4173.000 VX SE – To the vertical enclosure section via mounting brackets in conjunction with adaptor rail VX – To the horizontal section/in roof via mounting brackets in conjunction with adaptor rail VX in the depth 1095 1200 6 pc(s). 4174.000 1295 1400 6 pc(s). 4393.000 1495 1600 6 pc(s). 4175.000 1695 1800 6 pc(s). 4176.000 1895 2000 6 pc(s). 4177.000 Material: – Sheet steel 2095 2200 6 pc(s). 4178.000 Surface finish: – Zinc-plated Also required: – For VX SE: Adaptor rail VX, see page 995 – U nuts, see page 1003 – Mounting bracket 4182.000, see page 1002 Accessories: – Cable attachment, see page 1061 – Screws, see page 1004 – Cable tie for fast assembly 2597.000, see page 1061 Support strip Material: – Sheet steel for VX, VX SE For simple cable routing from the mounting plate to the door. Surface finish: – Zinc-plated Supply includes: – Assembly parts Installation options: – On the inner and outer mounting level, on the enclosure section Note: – Installation options for TP interior installation, see page 984/985 – VX, VX SE, AX, TP, PC, IW door installation, see page 952 Accessories: – Screws, see page 1004 – Cable tie 2597.000, see page 1061 For For enclosure system, For enclosure system, Rail mounting distance Packs of enclosure width/depth inner level outer level mm mm 400 500 600 800 994 Model No. VX VX, VX SE 325 20 pc(s). 4694.000 VX SE – 375 20 pc(s). 4309.000 VX VX, VX SE 425 20 pc(s). 4695.000 VX SE – 475 20 pc(s). 4596.000 VX VX, VX SE 525 20 pc(s). 4696.000 VX SE – 575 20 pc(s). 8800.130 VX VX, VX SE 725 20 pc(s). 4697.000 VX SE – 775 20 pc(s). 4579.000 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Rail systems Adaptor rail VX for VX compatibility for VX SE To create compatibility of the interior installation between VX SE and VX25. The adaptor rail VX can be cut to length for customised configurations. For enclosure height mm Length mm Packs of Model No. – 200 4 pc(s). 8617.760 1800 – 4 pc(s). 8617.750 2000 – 4 pc(s). 8617.751 Installation options: – On the vertical enclosure section of the VX SE (over the full installation height or in sub-sections) – On the horizontal roof section of the VX SE, in the width Supply includes: – 4 adaptor rails – Assembly parts Rail for interior installation for TP, compact enclosures HD For mounting on the existing threaded bolts. With system punchings on three sides. For For For enclosure enclosure enclosure height Packs of height width mm mm mm Model No. TP1) TP2) HD 600 675 650 4 pc(s). 5001.050 800 960 – 4 pc(s). 5001.051 Surface finish: – Zinc-plated 1000 – 1050 4 pc(s). 5001.052 1200 – 1250 4 pc(s). 5001.053 Supply includes: – Assembly parts 1600 – – 4 pc(s). 5001.054 Material: – Sheet steel 1) Only with TP console and desk unit (cover or rear panel/base), one-piece console in cover 2) Only with TP pedestal/one-piece console Note: – Installation options TP, see page 984/985 – Installation options HD, see page 225 Base configuration rail for TP For mounting in the enclosure depth, on the existing threaded bolts, no machining required. System punchings on 2 sides. Creates additional installation options. For enclosure depth mm Packs of Model No. 400 2 pc(s). 5001.370 Material: – Sheet steel Surface finish: – Zinc-plated Rittal System Catalogue 36/System accessories System accessories Supply includes: – Assembly parts Further technical information available on the Internet. 995 Interior installation Rail systems C rail 30/15 to EN 60 715, for VX, VX SE Installation options: – On the inner mounting level, on the enclosure section – In the base/plinth VX Material: – Sheet steel Surface finish: – Zinc-plated For enclosure width/depth mm Length mm 500 455 6 pc(s). 4943.000 600 555 6 pc(s). 4944.000 800 755 6 pc(s). 4945.000 1000 955 6 pc(s). 4946.000 1200 1155 6 pc(s). 4947.000 Packs of Model No. Accessories: – Cable clamps, see page 1060 – Support bracket or spacer, see page 1001 – Quick-assembly block, see page 1001 Possible alternative: – Rail for EMC shielding bracket and strain relief, see page 1029 Support rail 48 x 26 mm for VX, VX SE For heavy installed equipment such as transformers. T-head screw and slots in the support rail accommodate all mounting dimensions. Installation options: VX – On the inner mounting level, on the enclosure section VX SE – On the inner mounting level, on the enclosure section in conjunction with adaptor rail VX Material: – Sheet steel Surface finish: – Zinc-plated For enclosure width mm Packs of Model No. 600 2 pc(s). 8617.800 800 2 pc(s). 8617.810 1000 2 pc(s). 8617.820 1200 2 pc(s). 8617.830 Also required: – For VX SE: Adaptor rail VX, see page 995 Accessories: – Punched section with mounting flange 23 x 64 mm for height-offset installation, see page 991 Supply includes: – Assembly parts Support rail 75 x 20 mm for VX, VX SE For heavy installed equipment such as base isolators or transformers. Installation options: VX – On the inner mounting level, on the enclosure section VX SE – On the inner mounting level, on the enclosure section in conjunction with adaptor rail VX Model No. Model No. For enclosure width/depth mm Packs of Slotted Unslotted 400 4 pc(s). 4394.000 – 500 4 pc(s). 4395.000 – 600 4 pc(s). 4396.000 4396.500 800 4 pc(s). 4398.000 4398.500 Also required: – For VX SE: Adaptor rail VX, see page 995 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts 996 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Rail systems Support rail 65 x 42 mm for VX, VX SE For heavy installed equipment such as base isolators or transformers. Installation options: VX – On the inner mounting level, on the enclosure section VX SE – On the inner mounting level, on the enclosure section in conjunction with adaptor rail VX For enclosure width mm Packs of Model No. 600 2 pc(s). 8612.960 800 2 pc(s). 8612.980 Also required: – For VX SE: Adaptor rail VX, see page 995 Material: – Steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Support rails TS 35/15 to EN 60 715 for VX, VX SE Mounting on the vertical section via – threaded block M8, 4163.000, see page 1003 Support rails TS 35/7.5 and TS 35/15 to EN 60 715 for KX, AX, terminal box HD For enclosure width/depth mm Support rail length mm 500 455 6 pc(s). 4933.000 600 555 6 pc(s). 4934.000 800 755 6 pc(s). 4935.000 1200 1155 6 pc(s). 4937.000 – 2000 6 pc(s). 2313.150 For enclosure width mm Support rail length mm Version Packs of Model No. Packs of Model No. 150 137 10 pc(s). 2314.000 200 187 10 pc(s). 2315.000 300 287 TS 35/7.5 10 pc(s). 2316.000 400 387 10 pc(s). 2317.000 – 2000 6 pc(s). 2313.750 500 487 10 pc(s). 2318.000 600 587 10 pc(s). 2319.000 TS 35/15 Packs of Model No. For fast, secure attachment of: – Cable ducts – Mounting plates – Mounting angles on support rail TS 35/7.5 and 35/15 to EN 60 715. Simply pre-assemble the mounting clip on the part to be installed, then snap into position on the support rail. 30 pc(s). 2309.000 Rittal System Catalogue 36/System accessories System accessories Mounting clip Further technical information available on the Internet. 997 Interior installation Rail systems Mounting claw for second mounting level for terminal boxes KX, bus enclosures KX For fixing top hat rails directly onto the rear panel of KX terminal boxes and KX bus enclosures. Creates an additional mounting level with an extra 10 mm of installation depth without having to machine the enclosure. Packs of Model No. 20 pc(s). 2309.100 Accessories: – Support rails TS 35/7.5 to EN 60 715, see page 997 Mounting plate Packs of Model No. Locatable for AX, VX, VX SE 4 pc(s). 8612.400 Installation options: – On the inner and outer mounting level, on the enclosure section – On punched sections with mounting flanges – On rail for interior installation AX – On the perforated door strip AX Accessories: – Screws, see page 1004 – Cable tie 2597.000, see page 1061 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly screws Mounting plate Packs of Model No. Screw-fastened, large for AX, VX, VX SE, AX plastic 4 pc(s). 8612.410 Installation options: – On all enclosures and mounting parts with system punchings on a 25 mm pitch pattern – On the perforated door strip AX Accessories: – Screws, see page 1004 – Cable tie 2597.000, see page 1061 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly screws 998 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Rail systems Mounting plate Packs of Model No. Screw-fastened, small for AX, VX, VX SE, AX plastic 4 pc(s). 4532.000 Installation options: – On all enclosures and mounting parts with system punchings on a 25 mm pitch pattern – On the perforated door strip AX Accessories: – Screws, see page 1004 – Cable tie 2597.000, see page 1061 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly screws Mounting plate Packs of Model No. with integral top hat rail for AX, VX, VX SE, AX IT, VX IT, TE For direct snap-mounting of components such as speed control, enclosure internal thermostat and hygrostat. 1 pc(s). 7526.964 Mounting bracket Packs of Model No. Installation options: – On all enclosures and mounting parts with system punchings on a 25 mm pitch pattern 4 pc(s). 4597.000 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Material: – Sheet steel Surface finish: – Zinc-plated Accessories: – Screws, see page 1004 – Cable tie 2597.000, see page 1061 System accessories Supply includes: – Assembly screws Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 999 Interior installation Rail systems Mounting bracket for interior installation For installing punched sections with mounting flanges and support strips in – Comfort Panel horizontal/vertical from 74 mm installation depth or for installing in: – Optipanel from an installation depth of 100 mm Packs of Model No. 4 pc(s). 6205.100 For installing the LED system light in – compact enclosures AX in conjunction with the rail for interior installation AX, see page 989, without machining and without the use of tools Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Mounting options in Comfort Panel/Optipanel Punched section with mounting flange Support strips 1000 Further technical information available on the Internet. Horizontal Vertical Horizontal Vertical Front panel width 482.6 mm (19") Page 8612.150 992 4695.000 994 Rittal System Catalogue 36/System accessories Interior installation Assembly components Bracket/spacer Packs of Model No. For flexible attachment of C rails, punched rails or cable clamp rails (angle piece). On the sides, to accommodate square sections or tubes (Ø 20 mm). Attachment points with M8 thread. 6 pc(s). 4199.000 Installation options: – On vertical and horizontal VX, VX SE enclosure section – On punched sections with mounting flanges for the inner mounting level – On enclosures and rails with rectangular system punching 12.5 x 11 mm Also required: – For VX SE: Adaptor rail VX, see page 995 Accessories: – Angle piece 4134.000, see page 1001 Material: – Die-cast zinc Supply includes: – 1 pc(s). = 1 bracket/spacer 2 screws M8 x 16 mm 2 spring lock washers 2 cage nuts M8 2 screws Quick-assembly block Packs of Model No. for a variety of installation options. 12 pc(s). 4133.000 Installation options: – On vertical and horizontal VX, VX SE enclosure section – On punched sections with mounting flanges for the inner mounting level – On enclosures and rails with rectangular system punching 12.5 x 11 mm Material: – Die-cast zinc Also required: – For VX SE: Adaptor rail VX, see page 995 Accessories: – Angle piece 4134.000, see page 1001 Supply includes: – 12 quick-assembly blocks – 12 threaded blocks M8 – 24 screws M8 x 12 mm – 24 square nuts M8 Angle piece Packs of Model No. For assembling mounting surfaces with a 45° incline. Optimum positioning of cable clamp rails, etc. 12 pc(s). 4134.000 With two mounting options as standard: – Conductively connected to the subsurface – Insulated from the mounting surface Also required: – For VX SE: Adaptor rail VX, see page 995 System accessories Installation options: – On vertical and horizontal VX, VX SE enclosure section – On punched sections with mounting flanges for the inner mounting level – On the bracket/spacer – On the quick-assembly block – On enclosures and rails with rectangular system punching 12.5 x 11 mm Material: – Angle pieces: Die-cast zinc – Insulating pieces: Plastic Supply includes: – 1 pc(s). = 1 angle piece 1 insulating piece 1 insulating screw 2 assembly screws 1 threaded block M8 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1001 Interior installation Assembly components Mounting bracket Packs of Model No. for VX, VX SE For variable attachment of punched rail 23 x 23 mm. 24 pc(s). 4182.000 Installation options: – Optionally flush with the outer edge of the enclosure or the enclosure clearance width – On the vertical VX, VX SE enclosure section – On the horizontal VX enclosure section – On the horizontal VX SE enclosure section, bottom – On the horizontal VX SE enclosure section, top in the width and depth – On enclosures and rails with rectangular system punching 12.5 x 11 mm Also required: – U nut (recommended: M6), see page 1003 – Multi-tooth screws M6 x 12 mm, see page 1004 – For VX SE: Adaptor rail VX, see page 995 Material: – Die-cast zinc Supply includes: – 1 pc(s). = 1 mounting bracket 1 screw M6 x 12 mm, 1 cage nut M6 Rail mounting bracket For individual mounting of rails at a distance from the mounting surface. Rail mounting bracket Packs of Model No. Flat 20 pc(s). 2365.000 Inclined 20 pc(s). 2366.000 Material: – Sheet steel, zinc-plated 35 M5 47 35° 30 M6 Ø7 Ø7 60 60 73 81 Cage nut Thread Packs of Model No. For all-round metric mounting on the enclosure section. M5 20 pc(s). 4166.500 M6 20 pc(s). 4164.500 Benefits: – For all-round mounting on the enclosure section – The compression spring, designed as an insertion aid, ensures reliable mechanical and electrical connection in the system punchings. – Simply slides in from the side – Safely and easily released with a screwdriver M8 20 pc(s). 4165.500 Also required: – For VX SE: Adaptor rail VX, see page 995 Installation options: – On vertical and horizontal VX, VX SE enclosure section – On punched sections with mounting flanges, 23 x 64 mm – On punched sections with mounting flanges, 23 x 89 mm, stainless steel – On punched rails 23 x 23 mm – On punched section without mounting flanges, 23 x 64 mm – On enclosures and rails with rectangular system punching 12.5 x 11 mm 1002 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Assembly components U nut for punched rail 23 x 23 mm For mounting punched rails and punched sections without mounting flanges on mounting brackets, we recommend U nuts with M6 thread 4179.000. Thread Packs of Model No. M4 20 pc(s). 4119.000 M5 20 pc(s). 4157.000 M6 20 pc(s). 4179.000 M8 20 pc(s). 4180.000 Accessories: – Multi-tooth screws M6 x 12 mm, for 4179.000, see page 1004 Threaded block For all-round metric mounting in the enclosure section. With snap-off insertion aid, made from die-cast zinc. Installation options: – On vertical and horizontal VX, VX SE enclosure section – On punched sections with mounting flanges, 23 x 64 mm – On punched sections with mounting flanges, 23 x 89 mm, stainless steel – On punched rails 23 x 23 mm – On punched section without mounting flanges, 23 x 64 mm – On enclosures and rails with rectangular system punching 12.5 x 11 mm Thread Packs of Model No. M6 50 pc(s). 4162.000 M8 50 pc(s). 4163.000 Also required: – For VX SE: Adaptor rail VX, see page 995 Spring nut M5 Packs of Model No. For – Comfort Panel from an installation depth of 74 mm – Optipanel from an installation depth of 100 mm – Compact Panel 50 pc(s). 6108.000 The spring ensures reliable protection against unintentional displacement. System accessories Other interior installation, e.g. with – Mounting bracket 4597.000, see page 999 or – mounting bracket components for interior installation 6205.100, see page 1000 Material: – Steel, zinc-plated Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1003 Interior installation Assembly components Universal bracket Packs of Model No. For the installation of – Enclosure lights in – Compact enclosures AX – Door-operated switches in – Compact enclosures AX – TopConsole system TP – Cable conduit holders 2593.000 and 2591.000 in – Compact enclosures AX – Support rails for terminals in – Operating housings and operating housings with door 6 pc(s). 2373.000 Ø 4.2 8 28 Mounting screws are concealed when the door is closed. Offers variable mounting options in compact enclosures, command panels and consoles. Material: – Sheet steel, zinc-plated Supply includes: – Assembly parts 45 Multi-tooth screw M6 x 12 to fit: – Cage nuts 4164.500 – U nuts 4179.000 – Threaded blocks 4162.000 M8 x 12 to fit: – Cage nuts 4165.500 – U nuts 4180.000 – Threaded blocks 4163.000 Metal multi-tooth screw For the round holes Ø 4.5 mm in the enclosure section, punched rails and punched sections without mounting flanges. Self-tapping screw For the round holes Ø 4.5 mm in the enclosure section, punched rails and punched sections without mounting flanges. Multi-tooth drive for optimum transmission of torques, an extended tool life and increased safety and reliability when tightening and loosening screw connections. Dimensions mm Packs of Model No. Multi-tooth screws M6 x 12 M8 x 12 300 pc(s). 2504.500 300 pc(s). 2504.800 Metal multi-tooth screws 5.5 x 13 300 pc(s). 2486.600 Metal multi-tooth screws for stainless steel 5 x 13 300 pc(s). 2486.400 M5 x 10 M5 x 12 500 pc(s). 2504.000 500 pc(s). 2488.000 M5 x 12 500 pc(s). 2489.000 M5 x 12 500 pc(s). 2489.500 Type of screw Self-tapping screws – Hex screws – Posidrive raised countersunk screws – Pan-head screws, posidrive – Multi-tooth pan-head screws Self-tapping screws ST 4.8 x 16 300 pc(s). 2487.000 Self-tapping screw Mark, drill and tighten in a single operation using electric or pneumatic tools. For metal thickness: 0.8 – 3 mm Length: 16 mm Usable length: 9.5 mm Width across flats: 8 mm 1004 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Assembly components Connection kit Packs of Model No. for separated frame VX IT Every VX IT frame is easily converted to a rack suitable for dismantling. To this end, the frame sections in the roof and base frame must be separated, optionally in the width or depth. The four connection components are inserted into the frame section and screw-fastened. The external dimensions of the frame remain unchanged. 4 pc(s). 5302.037 Supply includes: – 4 connection components, internal – 4 connection components, external – Earth strap – Assembly parts System accessories Note: – The maximum achievable IP protection category is restricted by separation of the frame – The static load capacity of the frame structure is reduced to 8000 N Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1005 Interior installation Component shelves for frame attachment Component shelf for frame attachment Material: – Sheet steel for empty enclosures VX and VX IT with enclosure width 600 and 800 mm For installation in enclosures without 482.6 mm (19") accommodation. Max. depth of component shelves = Enclosure depth - 100 mm. Colour: – RAL 7035 Surface finish: – Spray-finished Technical specifications: – Mounting bolts or mounting rails may be installed on a 25 mm pitch pattern in the enclosure depth – Mounting hole for handles provided. – Component shelf, vented 2 1 Enclosure width 600 mm Load capacity N (static surface load) 500 500 500 500 1000 1000 1000 1000 Component shelf width mm 471 471 471 471 471 471 471 471 Component shelf depth mm 400 500 600 700 400 500 600 700 Component shelf height mm 29 29 29 29 45 45 45 45 Model No.  Assembly bolts  Mounting rails  Punched sections without mounting flanges  Telescopic slides 1000 N version supply includes: – Component shelf, vented – 2 mounting rails Installation options: – Static installation: Component shelf, 50 kg with fixing bolts on punched section without mounting flange – Static installation: Component shelf, 100 kg with mounting rails on punched sections without mounting flange – Depth variable: Component shelf with telescopic slides on punched sections without mounting flange 4 3 500 N version supply includes: – Component shelf, vented – 4 fixing bolts 7164.035 7165.035 7166.035 7166.735 7464.035 7465.035 7466.035 7466.735 Enclosure width 800 mm Load capacity N (static surface load) 500 500 500 500 1000 1000 1000 1000 Component shelf width mm 671 671 671 671 671 671 671 671 Component shelf depth mm 400 500 600 700 400 500 600 700 Component shelf height mm 29 29 29 29 45 45 45 45 Model No. 7184.035 7185.035 7186.035 7186.735 7484.035 7485.035 7486.035 7486.735 Accessories: Model No. Telescopic slides 7061.000 7081.000 7161.000 7161.700 7064.000 7065.000 7066.000 7066.700 Handles for component shelves 5501.730 5501.730 5501.730 5501.730 5501.730 5501.730 5501.730 5501.730 Cable support, hinged, with anti-kink device and clamp for enclosure depth mm ≤ 600 7163.560 7163.560 7163.560 7163.560 7163.560 7163.560 7163.560 7163.560 > 600 7163.565 7163.565 7163.565 7163.565 7163.565 7163.565 7163.565 7163.565 Also required: Model No. Punched section without mounting flange, 23 x 64 mm, as installation kit for enclosure depth, see page 993 1006 500 8100.741 600 8100.742 800 8100.743 1000/1200 8100.745 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Component shelves for frame attachment Component shelf, pull-out For enclosures1) for VX SE, PC, IW For direct mounting on the vertical enclosure section. Width mm Load capacity: – 300 N surface load, static 1) 2) Material: – Sheet steel Depth mm Support area Width mm Depth mm Model No. 600 600 465 545 6902.9602) 600 800 465 745 6902.980 For enclosures without a mounting plate May also be installed in 800 mm deep enclosures (pull-out rear attachment) Colour: – RAL 7015 Supply includes: – 2 telescopic slides Component shelf, static installation for VX SE, PC, IW prepared for fan expansion kit For direct mounting on the vertical enclosure section. Simply locate into 4 pre-fitted screws and secure. Load capacity: – 400 N surface load, static Material: – Sheet steel For enclosures1) 1) Support area Width mm Depth mm Width mm Depth mm Model No. 600 600 507 550 8800.900 600 800 507 750 8800.910 For enclosures without a mounting plate Accessories: – Fan expansion kit 7980.XXX, see page 790 Colour: – RAL 7015 Supply includes: – Assembly parts Packs of Model No. for IW, PC pull-out Width 600 mm and depth 600 – 800 mm Tray height: 800 mm 1 pc(s). 6902.700 System accessories Drawer tray Load capacity: – 400 N surface load, static Material: – Sheet steel Colour: – RAL 7035 Supply includes: – 2 telescopic slides Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1007 Interior installation Component shelves for attachment to the 482.6 mm (19") system Component shelf, static installation 482.6 mm (19"), depth-variable for VX IT, TE For static installation between two 482.6 mm (19") mounting levels. – Contact width: 489 mm – Depth-variable to adapt to individual distances between levels – Tool-free, time-saving one-man assembly Distance between levels mm Load capacity, static kg 400 – 600 50 ½ 1 pc(s). 5501.655 600 – 900 50 ½ 1 pc(s). 5501.665 400 – 600 100 1 1 pc(s). 5501.695 600 – 900 100 1 1 pc(s). 5501.705 Height Packs of Model No. U Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – Assembly parts Component shelf, static installation for TE The component shelf is attached directly at the side to the front and rear 482.6 mm (19") mounting frames for TE. Contact surface, width mm 505 Contact surface, depth mm 410 Distance between 482.6 mm (19") levels mm 495 Load capacity (static) N 300 Material: – Sheet steel Packs of 1 pc(s). Model No. 7000.620 Colour: – RAL 7035 Supply includes: – Assembly parts Note: – Not suitable for combination with telescopic slides Component shelf, pull-out 482.6 mm (19") for VX IT, TE For mounting between two 482.6 mm (19") mounting levels. – Contact width: 419 mm – Depth-variable to adapt to individual distances between levels – Tool-free, time-saving one-man assembly from the enclosure front – Self-locking – Full withdrawal Material: – Sheet steel Distance between levels mm Load capacity, Height Depth Packs Model No. static U mm of kg 400 – 600 50 1 500 1 pc(s). 5501.675 600 – 900 50 1 700 1 pc(s). 5501.685 400 – 600 100 1½ 500 1 pc(s). 5501.715 600 – 900 100 1½ 700 1 pc(s). 5501.725 Accessories: – Handle for component shelf 5501.730, see page 1011 Surface finish: – Component shelf: Spray-finished – Mounting kit/telescopic slides: Zinc-plated Colour: – Component shelf: RAL 9005 Supply includes: – Component shelf, slotted – Telescopic slide with mounting kit – Assembly parts 1008 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Component shelves for attachment to the 482.6 mm (19") system Component shelf, pull-out Contact surface, width mm 409 for TE For mounting between two 482.6 mm (19") mounting levels. Contact surface, depth mm 500 Distance between 482.6 mm (19") levels mm 395 – 645 Benefits: – Depth-variable to adjust to the distance between 482.6 mm (19") levels in a 25 mm pitch pattern – Full withdrawal Load capacity (static) N 500 Packs of 1 pc(s). Model No. 7000.625 Material: – Base: Sheet steel Surface finish: – Base: Spray-finished – Mounting kit/telescopic slides: Zinc-plated Colour: – RAL 7035 Supply includes: – Component shelf, vented – Telescopic slides with mounting kit Component shelf 1 U, static installation 482.6 mm (19") for one 482.6 mm (19") mounting level The ideal support surface for small active components such as modems or mini-hubs. Load capacity: – 10 kg surface load, static Component shelf depth mm Packs of Model No. 140 1 pc(s). 7119.140 Also required: – Cage nuts, see page 1002 – Screws, see page 1004 Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 7035 System accessories Note: – Usable height inside the U approx. 35 mm Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1009 Interior installation Component shelves for attachment to the 482.6 mm (19") system Component shelf 2 U, static installation Component shelf depth mm 482.6 mm (19") for one 482.6 mm (19") mounting level The ideal support surface for small active components such as modems or mini-hubs. 250 400 Colour Packs of Model No. RAL 7035 1 pc(s). 7119.250 RAL 9005 1 pc(s). 5501.615 RAL 7035 1 pc(s). 7119.400 RAL 9005 1 pc(s). 5501.625 Load capacity: – 25 kg surface load, static Material: – Sheet steel Surface finish: – Spray-finished Component shelf, pull-out, 2 U for one 482.6 mm (19") mounting level For simple, front installation of wall-mounted or floor-standing enclosures with at least one 482.6 mm (19") mounting level. This complete set comprises the pre-configured variant including telescopic slides, moulded handle, flange and locking pins. Also required: – Cage nuts, see page 1002 – Screws, see page 1004 Contact surface, width mm Contact surface, depth mm Load capacity (static) N 430 300 250 Packs of Model No. 1 pc(s). 5501.635 Benefits: – Simple tool-free assembly – Full withdrawal – Self-locking Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – Component shelf, pre-configured – Assembly parts 1010 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Accessories for component shelves Telescopic slide Load capacity 50 kg for component shelf for frame attachment Static component shelves are easily converted to full withdrawal by exchanging the existing assembly bolts or mounting rails (heavy-duty version) for telescopic slides. For component shelf depth mm Packs of Model No. 400 2 pc(s). 7061.000 500 2 pc(s). 7081.000 Technical specifications: – For installation and locking on a 25 mm pitch pattern in the enclosure depth 600 2 pc(s). 7161.000 700 2 pc(s). 7161.700 Material: – Sheet steel Surface finish: – Zinc-plated Load capacity 100 kg 3 For component shelf depth mm Packs of Model No. 400 2 pc(s). 7064.000 500 2 pc(s). 7065.000 600 2 pc(s). 7066.000 700 2 pc(s). 7066.700 For enclosure depth mm Packs of Model No. ≤ 600 1 pc(s). 7163.560 > 600 1 pc(s). 7163.565 2 1  Assembly bolts  Mounting rails  Telescopic slides Cable support Hinged, with anti-kink device and quickrelease fastener For secure routing of connection cables from the component shelves with telescopic pull-out to the clamping point. Kink-free cable routing in the central part via mobile chain links. The attachment may be released on both sides, thanks to the quickrelease fastener. Note: – Max. depth of component shelves = Enclosure depth - 200 mm Material: – Sheet steel, zinc-plated – Central part: Plastic Supply includes: – Cable support – 2 mounting brackets – Assembly parts Handle Packs of Model No. for pull-out component shelves The component shelves are prepared for the attachment of handles. 2 pc(s). 5501.730 Surface finish: – Spray-finished Colour: – Silver grey Supply includes: – Assembly parts Fastening bolts Packs of Model No. for slotted component shelves For non-slip attachment of your components. The bolts are screwed into the longitudinal slots of the component shelf support surface. Consequently, they are infinitely adjustable and can be adapted to suit any appliance. 4 pc(s). 7115.000 Rittal System Catalogue 36/System accessories System accessories Material: – Die-cast zinc Material: – Steel Surface finish: – Clear-chromated Further technical information available on the Internet. 1011 LED system light – Sensationally bright 1012 Rittal System Catalogue 36/System accessories Optimum illumination ◾ Innovative LED technology for even more light into the very last corner ◾ Intelligent lighting, tailored to the geometry of the enclosure, thanks to a special optical cover with Fresnel structure ◾ Optical cover with two different Fresnel structures ◾ The cover is easily rotated – to adapt the light distribution to the current installation situation ◾ Enormous luminous intensity up to 1200 lumens, directed selectively into the enclosure Simple assembly ◾ Fast, tool-free assembly thanks to a latching hook system on a 25 mm pitch pattern of holes; simply latch and secure ◾ Optional screw-fastening also available, or opt for complete flexibility with a magnetic attachment freely positionable inside the enclosure ◾ May be fitted horizontally and vertically with no loss of space in the enclosure; existing rails and sections can simply be covered ◾ Lights with motion detectors are equipped with a rotating LED board as standard, allowing the direction of light to be perfectly adapted to any installation situation Flexible connection ◾ Rotating connectors support installation in the most confined spaces ◾ Simple through-wiring based on the plug & play system ◾ Variants with integral motion detectors eliminate the need for installing separate door-operated switches ◾ If additionally equipped with a socket, electricity will be available whenever it is needed for maintenance work ◾ Suitable for immediate, global use with wide-range voltage 100 – 240 V (AC) and 24 V (DC) New – socket box as a plug-in system ◾ The alternative to the LED system light with integrated socket System accessories ◾ Easier planning for international projects – same light, but with a country-specific socket ◾ No additional wiring required, thanks to simple connection technology and integration of the LED system light into the circuit ◾ Socket modules can be easily replaced to suit the user market via plug and play Rittal System Catalogue 36/System accessories 1013 LED system light Baying enclosure system VX25 Page 116 Free-standing enclosure system VX SE Page 142 Compact enclosures AX Page 84 Benefits: – Optimum illumination of the entire enclosure – Optionally with clip, screw or magnetic attachment – Equipment to suit every application Material: – Plastic – Aluminium Light colour: – 4000 K (neutral white) Note: – Connection accessories should be ordered separately Supply includes: – Assembly screws Colour: – Enclosure: RAL 7016 Protection class: – II (all-insulated) Model No. 2500.300 2500.310 2500.311 2500.312 2500.313 Output (lumens) 1200 1200 1200 1200 1200 Length (mm) 437 437 437 437 437 ◾ ◾ ◾ ◾ ◾ 100 – 240 V AC ◾ ◾ ◾ ◾ ◾ 24 V DC – – – – – Socket – D, earthing-pin GB F/B CH 90° rotating connector ◾ ◾ ◾ ◾ ◾ Adjustable light direction ◾ ◾ ◾ ◾ ◾ Adjustable light distribution ◾ ◾ ◾ ◾ ◾ UL/cUL ◾ – – – – CSA ◾ – – – – CCC ◾ – – – – ENEC ◾ ◾ ◾ ◾ ◾ Screw-fastening ◾ ◾ ◾ ◾ ◾ Clip attachment ◾ ◾ ◾ ◾ ◾ Magnetic attachment to surfaces (accessory) ◾ – – – – 3-pole 3-pole 3-pole 3-pole 3-pole 3-pole 3-pole 3-pole 3-pole 3-pole – – – – – Directly on the profile Directly on the profile Directly on the profile Directly on the profile Directly on the profile Motion sensor Rated operating voltage Equipment Approvals Installation type Infeed Connection options Through-wiring Door-operated switch (accessory) Mounting options1) Enclosures with a 25 mm pitch pattern Screw fastening/clip Page Accessories Rail for interior installation AX see page see page see page see page see page 989 Mounting bracket 6205.100 6205.100 6205.100 6205.100 6205.100 1000 Mounting kit magnet 2500.490 – – – – 1024 Door-operated switch – – – – – Door-operated switch, UL – – – – – Infeed, 2-pole – – – – – Infeed, 2-pole, UL – – – – – Infeed, 3-pole 2500.400 2500.400 2500.400 2500.400 2500.400 1023 Infeed, 3-pole, UL 2500.500 – – – – 1023 – – – – – Connection accessories Through-wiring, 2-pole Through-wiring, 2-pole, UL – – – – – Through-wiring, 3-pole 2500.430 2500.430 2500.430 2500.430 2500.430 1023 Through-wiring, 3-pole, UL 2500.530 – – – – 1023 1) The internal mounting rail AX and the mounting bracket are required when installing in compact enclosures AX 1014 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories LED system light Model No. 2500.314 2500.320 2500.200 2500.210 2500.211 Output (lumens) 1200 1200 900 900 900 Length (mm) 437 437 437 437 437 ◾ ◾ – – – 100 – 125 V AC – ◾ ◾ ◾ Motion sensor Rated operating voltage 100 – 240 V AC 24 V DC – ◾ – – – USA / CDN – – D, earthing-pin GB 90° rotating connector ◾ ◾ ◾ ◾ ◾ Adjustable light direction ◾ ◾ – – – Adjustable light distribution ◾ ◾ ◾ ◾ ◾ UL/cUL ◾ ◾ ◾ – – CSA ◾ – ◾ – – CCC – ◾ ◾ – – ENEC ◾ – ◾ ◾ ◾ Screw-fastening ◾ ◾ ◾ ◾ ◾ Clip attachment ◾ ◾ ◾ ◾ ◾ Magnetic attachment to surfaces (accessory) – ◾ ◾ – – 3-pole 2-pole 3-pole 3-pole 3-pole 3-pole 2-pole 3-pole 3-pole 3-pole – – ◾ ◾ ◾ Directly on the profile Directly on the profile Directly on the profile Directly on the profile Directly on the profile Socket Equipment Approvals Installation type Infeed Connection options Through-wiring Door-operated switch (accessory) Mounting options1) Enclosures with a 25 mm pitch pattern Screw fastening/clip Page Accessories Rail for interior installation AX see page see page see page see page see page 989 Mounting bracket 6205.100 6205.100 6205.100 6205.100 6205.100 1000 Mounting kit magnet – 2500.490 2500.490 – – 1024 Door-operated switch – – 2500.460 2500.460 2500.460 1024 Door-operated switch, UL – – 2500.470 – – 1024 Connection accessories Infeed, 2-pole – – – – – Infeed, 2-pole, UL – 2500.410 – – – 1023 Infeed, 3-pole – – 2500.400 2500.400 2500.400 1023 2500.500 – 2500.500 – – 1023 Through-wiring, 2-pole – – – – – Through-wiring, 2-pole, UL – 2500.440 – – – 1023 Through-wiring, 3-pole – – 2500.430 2500.430 2500.430 1023 2500.530 – 2500.530 – – 1023 Infeed, 3-pole, UL Through-wiring, 3-pole, UL Rittal System Catalogue 36/System accessories System accessories The internal mounting rail AX and the mounting bracket are required when installing in compact enclosures AX Rittal – The System. 1) Connection accessories see page 1023 Further technical information available on the Internet. 1015 LED system light Model No. 2500.212 2500.213 2500.214 2500.220 Output (lumens) 900 900 900 900 Length (mm) 437 437 437 437 – – – – 100 – 240 V AC ◾ ◾ 100 – 125 V AC – 24 V DC – – – ◾ F/B CH USA / CDN – ◾ ◾ ◾ ◾ Motion sensor Rated operating voltage Socket Equipment Approvals Installation type 90° rotating connector Adjustable light direction – – – – Adjustable light distribution ◾ ◾ ◾ ◾ UL/cUL – – ◾ ◾ CSA – – ◾ ◾ CCC – – – ◾ ENEC ◾ ◾ ◾ ◾ Screw-fastening ◾ ◾ ◾ ◾ Clip attachment ◾ ◾ ◾ ◾ Magnetic attachment to surfaces (accessory) – – – ◾ 3-pole 3-pole 3-pole 2-pole 3-pole 3-pole 3-pole 2-pole ◾ ◾ ◾ ◾ Directly on the profile Directly on the profile Directly on the profile Directly on the profile Infeed Connection options Through-wiring Door-operated switch (accessory) Mounting options1) Enclosures with a 25 mm pitch pattern Screw fastening/clip Page Accessories Rail for interior installation AX see page see page see page see page 989 Mounting bracket 6205.100 6205.100 6205.100 6205.100 1000 Mounting kit magnet – – – 2500.490 1024 Door-operated switch 2500.460 2500.460 2500.460 2500.460 1024 – – 2500.470 2500.470 1024 Infeed, 2-pole – – – – Infeed, 2-pole, UL – – – 2500.410 2500.400 2500.400 – – 1023 Infeed, 3-pole, UL – – 2500.500 – 1023 Through-wiring, 2-pole – – – – Through-wiring, 2-pole, UL – – – 2500.440 2500.430 2500.430 – – 1023 – – 2500.530 – 1023 Door-operated switch, UL Connection accessories Infeed, 3-pole Through-wiring, 3-pole Through-wiring, 3-pole, UL 1023 The internal mounting rail AX and the mounting bracket are required when installing in compact enclosures AX Rittal – The System. 1) 1023 1016 Socket box see page 1022 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories LED system light Model No. 2500.100 2500.104 2500.110 2500.114 Output (lumens) 400 400 600 600 Length (mm) 262 262 337 337 – – – – 100 – 240 V AC ◾ ◾ ◾ ◾ 24 V DC – – – – Socket – – – – 90° rotating connector – – – – Adjustable light direction – – – – Adjustable light distribution – – – – UL/cUL – ◾ – ◾ CSA – ◾ – ◾ CCC ◾ ◾ ◾ ◾ ENEC ◾ ◾ ◾ ◾ Screw-fastening ◾ ◾ ◾ ◾ Clip attachment ◾ ◾ ◾ ◾ Magnetic attachment to surfaces (accessory) ◾ ◾ ◾ ◾ 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole ◾ ◾ ◾ ◾ Directly on the profile Directly on the profile Directly on the profile Directly on the profile Motion sensor Rated operating voltage Equipment Approvals Installation type Infeed Connection options Through-wiring Door-operated switch (accessory) Mounting options1) Enclosures with a 25 mm pitch pattern Screw fastening/clip Page Accessories Rail for interior installation AX see page see page see page see page 989 Mounting bracket 6205.100 6205.100 6205.100 6205.100 1000 Mounting kit magnet 2500.490 2500.490 2500.490 2500.490 1024 Door-operated switch 2500.460 – 2500.460 – 1024 – 2500.470 – 2500.470 1024 Door-operated switch, UL Connection accessories Infeed, 2-pole 2500.420 – 2500.420 – 1023 Infeed, 2-pole, UL – 2500.520 – 2500.520 1023 Infeed, 3-pole – – – – Infeed, 3-pole, UL – – – – 2500.450 – 2500.450 – 1023 Through-wiring, 2-pole, UL – 2500.550 – 2500.550 1023 Through-wiring, 3-pole – – – – Through-wiring, 3-pole, UL – – – – Through-wiring, 2-pole Rittal System Catalogue 36/System accessories System accessories The internal mounting rail AX and the mounting bracket are required when installing in compact enclosures AX Rittal – The System. 1) IT LED system light see page 1027 Further technical information available on the Internet. 1017 Socket box – The plug-in system 1018 Rittal System Catalogue 36/System accessories A global player ◾ Socket modules in all standard, countryspecific variants ◾ UL variant for the North American market ◾ Socket modules can be easily replaced to suit the user market via plug and play Simple assembly ◾ Easy to screw securely to the round holes in the enclosure profile ◾ No loss of space thanks to perfect integration into the profile ◾ No obstruction when installing and removing the mounting plate ◾ Supports flexible installation throughout the entire enclosure and on the tubular door frame Fast connection ◾ Connection ready to plug in without any wiring work ◾ Direct integration of the LED system light into the circuit System accessories ◾ Same connection accessories as for LED system light ◾ Multiple socket boxes can be cascaded with numerous LED system lights Rittal System Catalogue 36/System accessories 1019 Interior installation LED system light The optimum system solution for improved flexibility The socket box turns the LED system light into an all-in-one system, making it possible to easily install additional sockets in six country-specific variants anywhere in the enclosure. A key advantage of this solution is that the appropriate socket for the end user's particular country can be easily installed via plug and play when the system is delivered. There is no need to replace the LED system light with one that has a suitable socket. All components are ready to plug in and can be installed without manual wiring. Configuration examples Free-standing enclosure LED system light with socket and motion detector 4 Free-standing enclosure LED system light with socket and additional door-operated switch 6 1 4 1 Free-standing enclosure LED system light without socket or motion sensor, but with additional door-operated switch and additional socket box 6 3 4 2 1 Free-standing enclosure LED system light fastened to the side with motion detector and additional socket box 4 3 2 1 1020 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation LED system light Free-standing enclosure LED system light with motion detector and additional socket box 3 4 2 1 Bayed enclosure with through-wiring via socket box Enclosure 1: LED system light with motion detector and additional socket boxes Enclosure 2: LED system light without socket or motion detector, but with additional door-operated switch and additional socket box 6 3 4 4 2 2 2 1 Bayed enclosure with through-wiring via T distributor Enclosure 1: LED system light with motion detector and additional socket boxes Enclosure 2: LED system light without socket or motion detector, but with additional door-operated switch and additional socket box 6 2 4 4 5 2 System accessories 3 2 1  Infeed  Socket box  Through-wiring  LED system light (various types)  T distributor  Door-operated switch with connection cable Rittal System Catalogue 36/System accessories Completely UL-compliant construction The entire system can be constructed in full compliance with UL requirements if UL-approved components (infeed, LED system light, through-wiring and socket box) are used. Further technical information available on the Internet. 1021 Interior installation LED system light Socket box for LED system light In combination with the LED system light, the socket box creates a flexible modular system for international use. Socket UL Packs of Model No. D, earthing-pin – 1 pc(s). 2500.710 GB – 1 pc(s). 2500.711 F/B – 1 pc(s). 2500.712 CH – 1 pc(s). 2500.713 US ◾ 1 pc(s). 2500.714 CN – 1 pc(s). 2500.715 Benefits: – Identical connection accessories as for LED system light – Cascadable with LED system light – Supports flexible installation throughout the entire enclosure and on the tubular door frame – No additional wiring required, thanks to simple connection technology and integration of the LED system light into the circuit Material: – Plastic Colour: – RAL 7016 Supply includes: – Assembly parts Configuration examples: See from page 1020. Also required: – Depending on the application, through-wiring or a 3-pole infeed may be required, see page 1023 Accessories: – T distributor, see page 1023 – Through-wiring, 3-pole, see page 1023 – Infeed, 3-pole, see page 1023  Infeed  Socket box  Through-wiring  LED system light  T distributor 3 2 4 5 4 2 2 1 1022 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation LED system light Connection accessories Accessories: for LED system light The following components can be used for timesaving, easy installation of the lights: – Cable ties for quick assembly, see page 1061 1 ENEC UL Length mm Packs of Infeed, 3-pole, 100 – 240 V AC ◾ ◾ 3000 Infeed, 3-pole, 100 – 240 V AC ◾ – Infeed, 2-pole, 100 – 240 V AC – Infeed, 2-pole, 100 – 240 V AC Connection cable for Model No. orange black 1 pc(s). 2500.500 – 3000 5 pc(s). 2500.400 – ◾ 3000 1 pc(s). 2500.520 – ◾ – 3000 5 pc(s). 2500.420 – Infeed, 2-pole, 24 V DC ◾ ◾ 3000 5 pc(s). – 2500.410 Through-wiring, 3-pole, 100 – 240 V AC ◾ – 200 1 pc(s). 2500.435 – Through-wiring, 3-pole, 100 – 240 V AC ◾ ◾ 1000 1 pc(s). 2500.530 – Through-wiring, 3-pole, 100 – 240 V AC ◾ – 1000 5 pc(s). 2500.430 –  Through-wiring, 2-pole, 100 – 240 V AC – ◾ 3000 1 pc(s). 2500.550 – Through-wiring, 2-pole, 100 – 240 V AC ◾ – 1000 5 pc(s). 2500.450 –  Through-wiring, 2-pole, 24 V DC ◾ ◾ 1000 5 pc(s). – 2500.440     2 A Connection cable for infeed 3 4 5 B Connection cable for through-wiring C Door-operated switch with connection cable (not required for LED system light with integral motion sensor) C 6 B T distributor Packs of Model No. with two sockets and one connector For creating safe, shock-hazard-protected junctions when wiring LED system lights and socket boxes. 5 pc(s). 2500.680 Connection accessories for self-assembly for LED system light For individual wiring with commercially available cables. Rittal System Catalogue 36/System accessories System accessories A Connector/jack Type Input voltage UL Packs of Model No. Jack, 3-pole 100 – 240 V ◾ 5 pc(s). 2500.600 Jack, 2-pole 24 V DC ◾ 5 pc(s). 2500.610 Jack, 2-pole 100 – 240 V ◾ 5 pc(s). 2500.620 Connector, 3-pole 100 – 240 V ◾ 5 pc(s). 2500.630 Connector, 2-pole 24 V DC ◾ 5 pc(s). 2500.640 Connector, 2-pole 100 – 240 V ◾ 5 pc(s). 2500.650 Further technical information available on the Internet. 1023 Interior installation LED system light Door-operated switch with connection cable for LED system light Supply includes: – Assembly parts ENEC UL Length mm ◾ – 800 – ◾ 800 Connection cable Door-operated switch without connection cable for self-assembly – With normally closed contact and normally open contact – Custom wiring of the LED system light when combined with the connection cable for dooroperated switch – Can be used to control the various Rittal climate control solutions when combined with standard cables Connection cable for door-operated switch for LED system light Model No. To fit Packs of 230 V AC/24 V DC, 1A 1 pc(s). 2500.460 1 pc(s). 2500.470 Black Technical specifications UL Packs of Model No. 240 V, 6 A 125 V DC, 8 A 24 V, 6 A 24 V DC, 6 A ◾ 1 pc(s). 4127.010 Also required: – For the installation in TE: Mounting kit 7888.615 Length mm UL Packs of Model No. 3000 – 1 pc(s). 2500.660 3000 ◾ 1 pc(s). 2500.670 Connection cable with pre-assembled connector for simple, fast connection of the LED system light. With open end for cutting the connection cable to the required individual length. 1024 Mounting kit magnet Packs of Model No. for LED system light For sticking onto the rear of lights without a socket. 2 pc(s). 2500.490 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation LED compact system light LED compact system light in 24 V (DC) version – Max. EMC compatibility – Protected, as it operates within the safety extralow voltage range – Door operated switch connection supported – Integral through-wiring – Vertically hinged light cone Material: – Light body: Extruded aluminium – Light cover: Polycarbonate (halogen-free) – Light ends: PC-ABS Colour: – Similar to RAL 7035 Protection category IP to IEC 60 529: – IP 20 Supply includes: – LED compact system light with clip and screw mounting kits, assembly parts Model No. 4140.810 Rated voltage 4140.820 4140.830 4140.840 24 V (DC) (±10%) Number of LEDs 10 20 Degree of protection 30 40 530 III (SELV) Width (B1) mm 230 330 430 Mounting distance CLIP (B2) mm 175 275 375 475 Mounting distance, screw attachment (B3) mm 250 350 450 550 Rated current A1) 0.04 0.08 0.12 0.16 Switch 1) Integral on/off/door-operated switch mode Maximum baying up to a total rated current strength of 2 amps Also required: – LED connection cable, see page 1026 or – Door-operated switch with LED connection cable, see page 1026 Note: – Only intended for use in enclosures and sealed cases! – When using on customer-supplied power packs, it is important to obtain the requisite approvals depending on the application. Accessories: – Mounting kit magnet for LED compact system light, see page 1025 – Door-operated switch with LED connection cable, see page 1026 – LED connection cable, see page 1026 – Adaptor power pack, see page 1026 20.64 B2 8.2 32.8 B3 Mounting kit magnet Packs of Model No. for LED compact system light For reliable adhesion on all sheet steel surfaces. 2 pc(s). 4140.000 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories B1 1025 Interior installation LED compact system light Connection accessories for LED compact system light Length mm Packs of Model No. 3000 1 pc(s). 4315.800 Length mm Packs of Model No. With LED connection cable 3000 1 pc(s). 4315.810 With LED interconnecting cable 1000 1 pc(s). 4315.820 Length mm Packs of Model No. Connection cable  LED connection cable 1 Door-operated switch   Interconnecting cable 2 3  LED interconnecting cable Adaptor power pack  4 Adaptor power pack 600 1 pc(s). 4315.830 1000 1 pc(s). 4315.840 3000 1 pc(s). 4315.850 Technical specifications Packs of Model No. 100 – 230 V/24 V (DC), 1 A 1 pc(s). 4315.860 Layout diagram for LED compact system light 24 V (DC):  Connection cable  Door-operated switch with LED connection cable (open end/cable bush)  Door-operated switch with LED interconnecting cable  LED interconnecting cable for through-wiring 1 3 5 2 4 +U GND 1026 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories IT LED system light Network/server racks VX IT Page 686 Network racks TE 8000 Page 704 Wall-mounted enclosures AX/EL from page 715 Benefits: – Plug and play compatibility system – Optimum illumination of the entire IT rack – Optionally with clip, screw or magnetic attachment – Equipment to suit every application – Ready to use immediately, thanks to plug-in connection cable – Attachment with no loss of U in the rack Type: – All-insulated, with internal fuse (T 2A) for operation with Europlug (to CEE 7/16) and IEC 320 connector Material: – Plastic – Aluminium Colour: – Enclosure: RAL 7016 Protection class: – II (all-insulated) Light colour: – 4000 K (neutral white) Supply includes: – Mounting kit magnet – Assembly screws Note: – Connection accessories should be ordered separately – The two plug-in connection cables should only be used with the IT LED system light. Use with all other Rittal system lights or external products is inadmissible. – Cascading of multiple IT LED system lights is not possible Model No. 7859.000 Output (lumens) 600 Length (mm) 337 Motion sensor Page – 100 – 240 V AC, 50/60 Hz Equipment Approvals Installation type ◾ Socket – 90° rotating connector ◾ Adjustable light direction ◾ Adjustable light distribution ◾ UL/cUL ◾ CSA ◾ CCC ◾ Screw-fastening ◾ Clip attachment ◾ Magnetic attachment to surfaces ◾ Infeed Connection options 2-pole Door-operated switch (accessory) Installation options ◾ Enclosures with a 25 mm pitch pattern Screw fastening/clip Directly on the profile TE 8000, IT enclosure based on AX/EL Mounting kit magnet ◾ Accessories Door-operated switch 2500.460 1024 Door-operated switch, UL 2500.470 1024 Also required: Connection accessories  Connection cable with Europlug EN 50075, CEE 7/16, type: H05VV-F, 2 x 0.75 mm², ready for connection, black, length 2 m, packs of 1 7859.010  Connection cable with IEC 60 320 C18 connector, UL version, to fit IEC 60 320 C13 sockets type: SJT 2 x 18 60D, ready for connection, black, length 2 m, packs of 1 7859.020 Connection cable with Europlug EN 50075 1 Rittal System Catalogue 36/System accessories Connection cable with IEC 60 320 C18 connector 2 Further technical information available on the Internet. 1027 System accessories Rated operating voltage Interior installation EMC EMC side panel for VX Automatic potential equalisation via assembly components, and a high level of EMC protection thanks to a special EMC seal. For enclosures Packs of Model No. 600 2 pc(s). 8106.760 800 2 pc(s). 8108.760 Height mm Depth mm 2000 2000 Material: – Sheet steel, 1.5 mm Surface finish: – Magnesium zinc coated, powder-coated on the outside Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 Supply includes: – Assembly parts EMC shielding seal Packs of Model No. for VX For EMC-compliant shielding of the baying point in conjunction with external baying connector. 1 pc(s). 8800.695 Protection category IP to IEC 60 529: – IP 55 in conjunction with external baying connector Also required: – Baying connector, external, page 912 Supply includes: – 8m EMC divider panel seal Packs of Model No. for VX With bayed EMC enclosure systems and when using a zinc-plated divider panel, this seal ensures optimum contact and shield attenuation. 1 pc(s). 4348.500 Material: – PU foam with electrically conductive sheathing Supply includes: – 6m 1028 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation EMC Rail for EMC shielding bracket and strain relief Combined rail for strain relief and EMC contacting of inserted cables. Design: – C rail to accommodate cable clamps – T-head cut-outs on a 40 mm pitch pattern for cable clamping using cable ties Benefits: – Additional contacting on the left or right of the rail via existing holes (9 mm diameter) – Prepared for tool-free mounting of EMC shielding brackets Installation options: – On the horizontal/vertical VX, VX SE, PC enclosure section – On the mounting plate, may also be fitted without a retaining bracket Material: – Extruded aluminium section Surface finish: – Chrome-free passivated For enclosure width mm Length mm Packs of Model No. 600 553 1 pc(s). 2388.650 800 753 1 pc(s). 2388.850 1000 953 1 pc(s). 2388.050 1200 1153 1 pc(s). 2388.125 Also required: – EMC shielding bracket, see page 1029 – Cable clamps, see page 1060 Accessories: – – – – – Support bracket or spacer, see page 1001 Quick-assembly block, see page 1001 Angle piece, see page 1001 Earth straps, see page 1033 Earthing braid, see page 1033 Possible alternative: – C rails 30/15, see page 996 Supply includes: – 1 rail – 2 retaining brackets – Assembly parts EMC shielding bracket Quick assembly without the use of tools: Press the EMC shielding bracket against the cable shield and clip into the rail. Diameter changes are compensated in full by the spring of the EMC shielding bracket. For shield diameter mm Packs of Model No. 3 – 10 10 pc(s). 2388.100 4 – 15 10 pc(s). 2388.150 10 – 20 10 pc(s). 2388.200 15 – 28 10 pc(s). 2388.280 Width mm Packs of Model No. 600 1 pc(s). 8618.820 800 1 pc(s). 8618.821 1000 1 pc(s). 8618.8221) 1200 1 pc(s). 8618.8231) Material: – Sheet steel EMC gland plate for VX, VX SE For shielded cables with a maximum diameter of 20 mm. Combined EMC/IP seal provides low-resistance contact between cable shield and gland plate. For all 400, 500, 600 and 800 mm deep enclosures in conjunction with standard gland plates. 1) System accessories Surface finish: – Zinc-plated For one enclosure half only Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – 1 gland plate with twin hammer-head punching – 1 sliding base plate – 2 EMC/IP seals Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1029 Interior installation EMC EMC cable gland Cable gland, metric The cable sheathing may optionally be interrupted at the contact point or removed completely inside the enclosure. The cable shielding in the enclosure is retained. The supplied lock nut cuts automatically into the paint when screwed down, thus creating a conductive connection. Protection category IP to IEC 60 529: – IP 68 Possible alternative: – Cable gland Hygienic Design, see page 1057 1) EMC shield bus Supply includes: – Assembly parts EMC earth clamp The clamps may be used directly on the device or operating equipment on the mounting plate for cable shield contact. Material: – Sheet steel Surface finish: – Zinc-plated 1) Contact cutter The contact cutter enables EMC-compatible preparation of the contact point e.g. for earthing braids. Plastic-bound abrasive with guide pin for round system punchings. With location point for drill, grinder etc. Size M16 4.5 – 10 3 5 pc(s). 2843.160 M20 6 – 12 5 5 pc(s). 2843.200 M25 11 – 17 8 5 pc(s). 2843.250 M32 15 – 21 10 1 pc(s). 2843.320 M40 19 – 28 15 1 pc(s). 2843.400 M50 27 – 38 19 1 pc(s). 2843.500 M63 34 – 44 30 1 pc(s). 2843.630 Connections Packs of Model No. 375 10 1 pc(s). 2413.375 550 16 1 pc(s). 2413.550 Size mm Packs of Model No. 4 50 pc(s). 2367.040 6 50 pc(s). 2367.060 8 50 pc(s). 2367.080 12 50 pc(s). 2367.120 16 50 pc(s). 2367.160 20 25 pc(s). 2367.2001) 2 mounting brackets For 1) Packs of Model No. Minimum shield diameter = cable diameter minus cable sheathing Rail length mm Made of corrosion-proof steel strip, 75 mm2 cross section, for cable shield contact. Minimum1) shield diameter mm Cable diameter mm Model No. Frame section 2414.000 Earthing bolts1) 2414.500 Not necessary with VX, VX SE Contact paint Packs of Model No. Contact paint prevents the corrosion of conductive, unprotected contact points. 1 pc(s). 2415.000 Contents: – 12 ml 1030 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation VX25 for areas at risk of earthquakes The versions listed have been tested and meet the requirements to Telcordia GR 63-CORE. They should be seen as a comparative variable to the customer's own plant, since empty enclosures cannot be certified. Note: – Further information can be found in the white paper “Earthquake protection for switchgear systems” on the Internet VX25 for earthquake zone 3 to Telcordia GR 63-CORE VX 8806.000: W x H x D: 800 x 2000 x 600 mm, see page 125 VX25 for earthquake zone 4 to Telcordia GR 63-CORE VX 8806.000: W x H x D: 800 x 2000 x 600 mm, see page 125 Fitted with: – Side panels, see page 901 – Base/plinth VX (corner pieces with base/plinth trim panels, front and rear and side base/plinth trim panels, 100 mm high), see page 881/882 Fitted with: – Side panels, see page 901 – Comfort handle VX, see page 937 – Earthquake base/plinth, see page 1032 Fitted with: – Side panels, see page 901 – Comfort handle VX, see page 937 – Earthquake base/plinth, see page 1032 – Earthquake kit, see page 1032 System accessories VX25 for earthquake zone 1 and 2 to Telcordia GR 63-CORE VX 8806.000: W x H x D: 800 x 2000 x 600 mm, see page 125 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1031 Interior installation VX25 for areas at risk of earthquakes Earthquake base/plinth for VX Height 100 mm For enclosures WxD mm Packs of Model No. 800 x 600 1 pc(s). 8601.860 – For stable attachment of the earthquake-resistant enclosure to the subsurface. – External metric M6 thread for a stable connection to the subsurface from the outside Material: – Corner piece: Sheet steel, 5 mm – Trim panels: Sheet steel, 2 mm Surface finish: – Powder-coated Colour: – RAL 7022 Supply includes: – 1 pc(s). = 4 corner pieces, 2 depth stays, 1 trim panel each front and rear Fully assembled. Earthquake kit for VX Material: – Sheet steel For enclosures WxHxD mm Packs of Model No. 800 x 2000 x 600 1 pc(s). 8618.600 Surface finish: – Zinc-plated Supply includes: – 1 pc(s) = 2 side reinforcements, bottom 4 bracing struts, sides 6 gusset plates 2 door safety brackets 4 punched sections with mounting flanges 23 x 64 mm 2 mounting rails 18 x 39 mm 8 angle plates Mounting plate attachment Assembly parts 1032 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Earthing Earth straps For configuring a reliable earthing connection with perfect contact – With ring terminals in M6 and M8 to match the earthing screws – Length-optimised and ready to install Connection option Enclosure Door/cover Enclosure Mounting plate KX M6 M6 M6 AX M8 M8 M8 VX M8 M8 M8 Ex M8 M8 M8 TP M6 M8 M8 VX SE M8 M8 M8 PC M8 M8 – Crosssection mm2 Connection Length mm Packs of Model No. M8 – M8 4 170 5 pc(s). 2564.000 M8 – M8 16 170 5 pc(s). 2565.000 M8 – M8 25 170 5 pc(s). 2566.000 M6 – M6 10 200 5 pc(s). 2565.100 M8 – M8 4 300 5 pc(s). 2567.000 M6 – M8 10 300 5 pc(s). 2565.110 M8 – M8 10 300 5 pc(s). 2565.120 M8 – M8 16 300 5 pc(s). 2568.000 M8 – M8 25 300 5 pc(s). 2569.000 M6 – M6 10 350 5 pc(s). 2565.050 Also required: – Assembly parts for earth straps, see page 1033 Earthing braid Tin-plated copper, in various lengths and cross-sections with press-fitted contact rings. Earthing braids counteract the current displacement effect at high frequencies, whilst at the same time offering highly flexible connection opportunities. Approvals: – UR, cUR For Crosssection mm2 Length mm Packs of Model No. M6 10 200 10 pc(s). 2412.210 M8 16 200 10 pc(s). 2412.216 M8 25 200 10 pc(s). 2412.225 M6 10 300 10 pc(s). 2412.310 M8 16 300 10 pc(s). 2412.316 M8 25 300 10 pc(s). 2412.325 Also required: – Assembly parts for earth straps, see page 1033 for earth straps For fastening the earth straps and earthing braids to: – Horizontal and vertical enclosure sections – Punched section with mounting flange, 23 x 64 mm – Punched section without mounting flanges, 23 x 64 mm – Gland plates Size Packs of Model No. M6 10 pc(s). 2570.000 M8 10 pc(s). 2559.000 Also required: – For mounting on horizontal and vertical enclosure sections: Cage nuts, see page 1002 Contact washer Size Packs of Model No. Serrated contact washers facilitate the secure connection of PE conductors, so there is no need to manually strip paint in the connection area. M5 100 pc(s). 2343.000 M6 100 pc(s). 2334.000 M8 100 pc(s). 2335.000 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories Assembly parts 1033 Interior installation Earthing Earthing plate Packs of Model No. For installation in – Comfort Panel – Optipanel – VX – VX SE – PC 1 pc(s). 2570.500 Supply includes: – Assembly parts One earthing cable can be screw-fastened to the threaded bolt and connected to up to 8 components with earth straps via 6.3 mm flat-pin connectors. Central earthing point Packs of Model No. For connecting – Earth straps – Earthing braids to the vertical and horizontal enclosure sections. The connection bracket is connected to the enclosure frame with 2 screws and is securely contacted. Earth connection is via the threaded bolt M8 x 20 mm. 1 pc(s). 7829.200 Material: – Sheet steel Supply includes: – 1 connection bracket – 2 assembly screws for mounting on the enclosure section – 2 serrated washers – 1 nut M8 – 1 contact washer M8 – 1 washer Surface finish: – Zinc-plated 1034 Potential equalisation star Packs of Model No. for 8 mm earthing bolt The earthing connector is used for simple potential equalisation on an 8 mm earthing bolt, or in conjunction with central earthing point 7829.200. Up to five flat-pin connectors (6.3 mm) may be contacted on one earthing point. 10 pc(s). 7548.210 Further technical information available on the Internet. Supply includes: – 10 earthing connectors – Assembly parts Rittal System Catalogue 36/System accessories Interior installation Earthing Potential equalisation kit Packs of Model No. for VX IT Central earthing point on the enclosure frame for simple connection of the enclosure to the earthing/ potential equalisation network (rack bonding conductor (RBC) connection point). 1 pc(s). 5302.027 Application: – To create seamless central potential equalisation between all installed components and/or to ensure functional earthing to EN 50 310 Note: – If a risk assessment of the ultimate application has been carried out by a qualified electrician and no extended risk potential has been identified, no protective earthing measures are required Functional principle: – Contact between all enclosure panels and the enclosure frame as central earthing point plus contact with all installed components to the same potential, via a conductive attachment or separate earth strap Supply includes: – 7 earth straps (4 mm²), for doors and optional side panels – Central earthing point – Assembly parts Earthing extension kits Packs of Model No. To supplement the existing earthing or potential equalisation sets for integrating additional installation components into the potential equalisation system. For targeted contact of installation components with the enclosure frame. The earth conductors are pre-assembled with connectors ready for connection and cut to the correct length. 1 pc(s). 7829.150 Potential equalisation kit, Plus version for VX IT For improved EMC. Benefits: – All enclosure elements are connected via earthing braids to a central, vertical potential equalisation rail (rack bonding busbar, RBB) via the frame structure as central consolidation point Application: – Ensures continuous potential equalisation and/or functional earthing – Improved protection from high-frequency interfering radiation to EN 50 310 Functional principle: – Potential equalisation rail for central potential equalisation of all installed equipment on the enclosure and components connected to the potential equalisation Supply includes: – 6 earthing braids (M8), 10 mm², for sheet steel doors, side panels, potential equalisation rail – Potential equalisation rail, length 1545 mm, for height 1800 – 2000 mm – Assembly parts Rittal System Catalogue 36/System accessories Approvals: – UL Packs of Model No. 1 pc(s). 5302.028 Note: – If a risk assessment of the ultimate application has been carried out by a qualified electrician and no extended risk potential has been identified, no protective earthing measures are required – To ensure an increased shielding effect of the enclosure, use of an enclosure with an all-round sealed body is advisable, similar to that used in IP enclosure variants with a solid sheet steel door at the front (as configuration only), solid roof plate, screw-fastened side panels and solid base System accessories Application: – For extending the existing potential equalisation set Supply includes: – 8 earth straps, UL style 1015 AWG 12 – Connection accessories Assembly instruction: – The specific connection cables between the installed equipment and the potential equalisation rail must be supplied by the user Accessories: – Conductor connection clamp, see page 349 Further technical information available on the Internet. 1035 Interior installation Earthing Complete earthing kit Packs of Model No. for TE For system-compatible earthing of all housing parts on the housing frame. The earth conductors are pre-assembled with connectors ready for connection and cut to the correct length. 1 pc(s). 7000.675 Supply includes: – 4 earth straps, 300 mm – 4 earth straps, 350 mm – Assembly parts Note: – If a risk assessment of the ultimate application has been carried out by a qualified electrician and no extended risk potential has been identified, no protective earthing measures are required PE busbar Packs of Model No. 699 mm long PE busbar with 42 pre-fitted screws, including terminal clamps up to 6 mm2 (fine wire conductors), 10 mm2 (single wire or multi-wire conductors) and main terminal clamp up to 35 mm2. 1 pc(s). 2364.000 Accessories: – Cable retainer, see page 1002 Earth rail, horizontal for VX, VX SE, VX IT Supply includes: – Earth rail made from E-Cu 57 to DIN EN 12 163, DIN EN 13 601, 15 x 5 mm – 20 connection points with M5 screws – 2 earth connections 25 mm2 – 2 isolators – Assembly parts Earth rail, vertical for VX, VX IT Easily fitted to the 25 mm DIN pitch pattern of distributors or to the 482.6 mm (19˝) mounting angles. The supplied earth conductors facilitate star earthing of the cable clamp straps in the patch panels. The earth terminals are fully adjustable. Current carrying capacity of rail approx. 200 A. Supply includes: – Earth rail made from E-Cu 57 to DIN EN 12 163, DIN EN 13 601, 15 x 5 mm – 16 push-in conductor connection clamps, 1.5 – 16 mm2 – 15 earthing leads 6 mm2, L = 500 mm – Assembly parts 1036 Further technical information available on the Internet. For enclosure width mm Width mm 600, 800 15 For enclosure height mm Height Length Packs Model No. mm mm of 5 Length mm 450 1 pc(s). 7113.000 Packs of Model No. 800 545 1 pc(s). 7541.000 1000 745 1 pc(s). 7542.000 1200 945 1 pc(s). 7543.000 1400 1145 1 pc(s). 7544.000 1600 1345 1 pc(s). 7545.000 1800 1545 1 pc(s). 7546.000 2000 1745 1 pc(s). 7547.000 2200 1945 1 pc(s). 7548.000 Rittal System Catalogue 36/System accessories Interior installation Earthing Extension kit Packs of Model No. for earth rail, vertical For system-compatible expansion of the star earthing on the vertical potential equalisation rail. 10 pc(s). 7549.000 ESD connection point Packs of Model No. Dangerously high potential differences can occur during maintenance or conversion work on the enclosure. To protect sensitive electronic components, this standardised connection point (pushbutton) provides potential equalisation between service engineer and enclosure. The connection point is directly conductively connected to the enclosure frame via two screws. 1 pc(s). 7752.950 Supply includes: – Earthing leads 6 mm2, L = 500 mm – Preassembled, with ring terminal and wire end ferrule – Push-in conductor connection clamps 1.5 – 16 mm2 – Assembly parts Material: – Sheet steel Surface finish: – Zinc-plated System accessories Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1037 Interior installation Earthing PE/PEN busbar E-Cu for VX With integral punchings. Accessories: – PE/PEN angle bracket, see page 1038 – PE/PEN baying bracket E-Cu, see page 1039 Material: – E-Cu Standards: – DIN EN 13601 Dimension 30 x 5 mm For enclosure width mm Length mm Hole Ø mm Packs of Model No. 400 300 11.5 2 pc(s). 9686.524 600 500 11.5 2 pc(s). 9686.526 800 700 11.5 2 pc(s). 9686.528 1000 900 11.5 2 pc(s). 9686.520 1200 1100 11.5 2 pc(s). 9686.522 For enclosure width mm Length mm Hole Ø mm Packs of Model No. 400 300 11.5 2 pc(s). 9686.534 600 500 11.5 2 pc(s). 9686.536 800 700 11.5 2 pc(s). 9686.538 1000 900 11.5 2 pc(s). 9686.530 1200 1100 11.5 2 pc(s). 9686.532 For enclosure width mm Length mm Hole Ø mm Packs of Model No. 400 300 11.5 2 pc(s). 9686.544 600 500 11.5 2 pc(s). 9686.546 800 700 11.5 2 pc(s). 9686.548 1000 900 11.5 2 pc(s). 9686.540 1200 1100 11.5 2 pc(s). 9686.542 For enclosure width mm Length mm Hole Ø mm Packs of Model No. 400 300 11.5 2 pc(s). 9686.584 600 500 11.5 2 pc(s). 9686.586 800 700 11.5 2 pc(s). 9686.588 1000 900 11.5 2 pc(s). 9686.580 1200 1100 11.5 2 pc(s). 9686.582 Dimension 30 x 10 mm Dimension 40 x 10 mm Dimension 80 x 10 mm PE/PEN angle bracket for VX For attaching the PE/PEN busbar to the enclosure section. For busbar mm Packs of Model No. 30 x 5 30 x 10 40 x 10 80 x 10 2 pc(s). 9686.350 Material: – Sheet steel, 3.0 mm Supply includes: – Assembly parts 1038 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interior installation Earthing PE/PEN baying bracket E-Cu Size mm Length mm Packs of Model No. for VX For connecting the busbars from enclosure to enclosure. 30 x 5 180 2 pc(s). 9686.529 30 x 10 180 2 pc(s). 9686.539 40 x 10 180 2 pc(s). 9686.549 80 x 10 180 2 pc(s). 9686.589 Material: – E-Cu Standards: – DIN EN 13601 Busbar support N conductor For assembling 1-pole neutral or PEN conductors. The busbar holder is mounted onto the enclosure section. Material: – Polyamide – Fire protection corresponding to UL 94-HB Colour: – Similar to RAL 7016 Supply includes: – Assembly parts For busbar mm Packs of Model No. 50 x 10 2 pc(s). 9686.300 Also required: – Busbars E-Cu, see page 342. Assembly instruction: – For the installation of max. 4 busbars (sub-conductors) per phase Accessories: – Longitudinal connector E-Cu, see page 397 Inserted screw nut M12 Packs of Model No. Self-holding nuts with knurled ring for busbars E-Cu. 30 pc(s). 3591.060 System accessories Hole diameter: 14.5 mm Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1039 Power supply Socket strips Socket strips 1 2 Technical specifications: Earthing-pin socket strips – Connector type F (CEE 7/3) – Rated operating voltage: 250 V – Connection cable: 2 m long H05VV-F3G1.5 without connector,  with connector in an aluminium duct The socket strips are available in various lengths with different functional elements. Special attention has been devoted to practical, universal fastening: Variable attachment facilities have been created with an angle bracket which may be inserted in four positions. Hence, for example, the 482 mm long socket strip may optionally be mounted on 482.6 mm (19") mounting angles, the 482.6 mm (19") mounting frame, on the enclosure frame, or in the rear section of the wall-mounted distributor. Without additional mounting accessories, the socket strip may be inserted into all sections with a 25 mm hole pattern. This makes selection much easier, as well as providing additional flexibility and saving on warehousing. Provision has also been made for cable routing of the infeed, and when mounting in the 482.6 mm (19") section there is adequate space to route the infeed between the socket strip and the profile rail without kinks. The arrangement of the IEC 320 sockets at a 45° angle allows unrestricted use of angular connectors. Belgium/France (UTE) socket strips – Connector type E (CEE 7/5) – Rated operating voltage: 250 V – Connection cable: 2 m long H05VV-F3G1.5 with wire end ferrules Equipment connector strips (IEC 60 320-1/C13) socket strips – Rated operating voltage: 250 V – Input: With C14 connector (H05VV-F3G1.0) or without connector (H05VV-F3G1.5), depending on the variant Material: – Aluminium section: Natural anodised – Socket inserts: Polycarbonate Supply includes: – Socket strip – 2 mounting brackets – Assembly parts Standards: – Earthing-pin socket: DIN 49 440 – IEC 320 socket: EN 60 320-2-2 – Overvoltage protection: DIN EN 61 643-11 (VDE 0675 Part 6-11) 3 T2 Approvals: – CE – RoHS T1 44 Note: – Depending on the application, we recommend use of a charging current reserve to prevent incorrect activation due to starting-current spikes 44 31 .75 4 Earthing-pin connector type Version  Without rocker switch Attachment Mounting WallRated Length Con- No. of dimenmounted current (T1) nection sockets Frame distribu- 482.6 mm sion A (19") level mm (T2) tor, horimm1) zontal 16 Cable 5  With rocker switch  Overvoltage protection, type3 and interference suppressor filter 16 Cable Packs of Model No. 3 ◾ – – 262.6 232.5 1 pc(s). 7240.110 7 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.210 12 ◾ – – 658.6 628.5 1 pc(s). 7240.310 3 ◾ – – 306.6 276.5 1 pc(s). 7240.120 7 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.220 5 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.230 9 ◾ – – 658.6 628.5 1 pc(s). 7240.330 16 Cable 16 Cable 5 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.240 10 C14 7 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.260  FI switch, 0.03 A, 2-pole, 16 Cable 5 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.280 UTE sockets, type E with earthing pin (Belgium/France) 16 Cable 7 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.510  Circuit-breaker, type B, 16 A, 2-pole  UPS strip, connection cable with 10 A IEC 320 connector, type E, with G fuse, 10 A 6 type A 1) Variable attachment distance within a range of 25 mm, the distance given is hole centre – hole centre of mounting bracket C13 connector type Version Packs of Model No. For IEC 320 connectors 16 Cable 12 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.200 For IEC 320 connectors with IEC 320 input 10 C14 9 ◾ ◾ ◾ 482.6 452.5 1 pc(s). 7240.201 1) 1040 Attachment Mounting WallLength Rated dimenCon- No. of mounted (T1) current 482.6 mm sion nection sockets Frame distribuA (19") level mm (T2) tor, horimm1) zontal Variable attachment distance within a range of 25 mm, the distance given is hole centre – hole centre of mounting bracket Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Power supply Socket strips Socket strip Earthing-pin, with plastic housing Robust 8-way earthing-pin socket strip in a plastic housing. The strip may be mounted vertically on the enclosure frame or in the 482.6 mm (19") section. 2.5 U are required for 482.6 mm (19") installation The earthing-pin inserts are arranged at an angle of 45° so that angular connectors are also easily used. The connection cable is attached to a terminal connection (behind a removable cover) in the socket strip. The socket strip has a terminal for an external earthing connection. Socket strip Packs of Model No. 8-way, earthing-pin 1 pc(s). 7000.630 Supply includes: – Socket strip – Assembly parts Material: – Plastic (grey/black) Approvals: – CE – RoHS Technical specifications: – Connector type F (CEE 7/3) – Rated operating voltage: 230 V – Rated current: 16 A – Connection cable: Type H05VV-F3G1.5 (black) with wire end ferrules – Length: 2 m – Dimensions: W x H x D: 483 x 74 x 45 mm Socket strip Functions: – Measurement of current, voltage, frequency, active power, active energy and phase shift with power measurement The socket strip 7x CEE 7/3 (type F - earthing-pin socket) with integrated display measures the power consumed by all connected equipment. The 482.6 mm (19") long socket strip may optionally be mounted on the 482.6 mm (19") mounting angles, on the enclosure frame or in the rear section of wall-mounted distributors. The installation bracket may be mounted in four different positions for variable mounting. Without additional mounting accessories, the socket strip may be inserted into all sections with a 25 mm hole pattern. Material: – Aluminium section: Natural anodised – Socket inserts: Polycarbonate Colour: – Socket: RAL 7035 Supply includes: – Socket strip – 2 mounting brackets – 3 m connection cable with wire end ferrules – Assembly parts Installation options: – Components with a 25 mm pitch pattern – 482.6 mm (19") level – Enclosure frame – IT rack, at the rear, horizontal (adequate width provided) Benefits: – Measurement accuracy of ± 5 % No. of sockets Socket/jack (type) Height mm Length mm Depth mm Mounting dimension mm Rated voltage Phase current A With display 7 D, earthing-pin (type F, CEE 7/3) 45 482.6 50 464.1 230 V AC 16 Rittal System Catalogue 36/System accessories Packs Model No. of System accessories Version 1 pc(s). 7240.301 Further technical information available on the Internet. 1041 Power supply Socket strips Junction box Packs of Model No. with multi-functional bracket The angle bracket can be installed in all network enclosures in a system-compatible design. The junction box serves as a transfer point for the power supply to all equipment (fans, lights and socket strips). As well as being used as a junction box or interchange point, the bracket can also accommodate the enclosure internal thermostat 3110.000 or the hygrostat 3118.000, thanks to its integral holes. 1 pc(s). 7280.035 Material: – Sheet steel Colour: – RAL 7035 Supply includes: – Junction box – Bracket – 6 m connection cable 3 x 1.5 mm2 (flexible) Socket – For mounting on support rails TS 35/7.5 and TS 35/15 to EN 60 715 – Uniform screw terminals from one side – Enclosure width: 45 mm Version Packs of Model No. Earthing-pin/CEE 7/3 2 pc(s). 2506.120 Technical specifications: – Rated voltage: 250 V AC – Rated current: 16 A Material: – Polyamide Colour: – Grey Approvals: – VDE Service socket Packs of Model No. for enclosure frame attachment/16 A Integration of a service socket within a separate supply circuit, independently of the IT network and UPS. Simple installation via an angle bracket for attaching to the enclosure frame. 1 pc(s). 7280.100 Type: Earthing contact/CEE 7/3 Material: – Angle bracket: Sheet steel – Socket: Plastic Surface finish: – Angle bracket: Zinc-plated Supply includes: – Service socket – Angle bracket – Damp-proof socket (IP 44) – Assembly parts 1042 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Power supply Socket strips Energy-Box, 3 U, 482.6 mm (19") Technical specifications: – Depth-adjustable top hat rail for installed equipment to DIN 43 880, sizes 1 – 3 (e.g. to accommodate built-in sockets, circuit-breakers etc.) – Cable clamping at the rear, one N and one PE rail on an insulated plinth. – Plastic hood including extension cover (UL 94-V0) – Maximum accommodation capacity of 22 HP (22 x 18 mm = 396 mm). – Enclosure height: 3 U – Enclosure depth: 155 mm – Overall installation depth with C rail: 155 mm – Dimensions: W x H x D: 483 x 132.5 x 155 mm U Packs of Model No. 3 1 pc(s). 7480.035 Photo shows a configuration example with equipment not included in the scope of supply Colour: – RAL 7035 Supply includes: – Energy-Box with fitted N and PE rails and brush strip – 4 connection clamps, 35 mm2 – 18 connection clamps, 16 mm2 – 2 blanking covers – 12 clips for cable strain relief – Identification strips, self-adhesive Energy-Box, 3 U, 482.6 mm (19") U Packs of Model No. 3 1 pc(s). 7480.300 Pull-out Photo shows a configuration example with equipment not included in the scope of supply System accessories Technical specifications: – Depth-adjustable top hat rail for snap-in attachment of installed equipment to DIN 43 880 in sizes 1 – 3 (e.g. to accommodate built-in sockets, circuit-breakers etc.) or entire installation assemblies. – Cable clamping at rear – Two power distribution rails with connection clamps on insulated base/plinth – Plastic hood including extension cover – Maximum accommodation capacity of 22 HP (22 x 18 mm = 396 mm). – Enclosure height: 3 U – Enclosure depth: 223 mm – Maximum extension: 220 mm – Dimensions: W x H x D: 483.5 x 132 x 223 mm Colour: – RAL 7035 Supply includes: – Energy-Box with fitted N and PE rails and brush strip – 4 connection clamps, 35 mm2 – 18 connection clamps, 16 mm2 – 2 blanking covers – 12 clips for cable strain relief – Identification strips, self-adhesive Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1043 Cable management Cable entry Cable entry plate for VX, VX SE – Cable entry grommet – Connector grommet instead of segments from the standard divided gland plates Material: – Sheet steel Surface finish: – Zinc-plated Protection category IP to IEC 60 529: – IP 55 in conjunction with cable entry grommets or connector grommets Enclosure width mm Cut-outs per plate Packs of Model No. 600 6 2 pc(s). 8619.800 800 8 2 pc(s). 8619.801 1000 5 4 pc(s). 8619.802 1200 6 4 pc(s). 8619.803 Also required: – Cable entry grommet, see page 1044 or – Connector grommet, see page 1044 Supply includes: – Assembly parts Three examples from a wide range of possibilities The diagrams show three examples for positioning cable entry plates instead of segments from the three-piece gland plates supplied as standard. In this way, they can be positioned to fit the mounting plate. Thanks to the enclosure symmetry, where dimensions permit, cable entry plates may also be inserted in the enclosure depth, right and left, analogous to the gland plates. Cable entry grommet In conjunction with the cable entry plate, supports simple, fast sealing of cables inserted into the base area of enclosures. Material: – Body: Polypropylene – Cover: Thermoplastic elastomer Cables per grommet Max. Ø mm Packs of Model No. 8 13 25 pc(s). 4316.000 3 21 25 pc(s). 4317.000 1 47 25 pc(s). 4318.000 Protection category IP to IEC 60 529: – IP 55 if installed correctly Connector grommets Packs of Model No. Suitable for cable diameters from 8 to 36 mm. 10 pc(s). 4311.000 Material: – Outer cover: Polypropylene covered with thermoplastic elastomer – Seal: Cellular rubber Protection category IP to IEC 60 529: – IP 55 if installed correctly 1044 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable entry Section for cable entry, centre for VX, VX SE For top-mounting on gland plates. Material: – Extruded aluminium section – Seal: PU foam – Cross-section: 30 x 25 mm Protection category IP to IEC 60 529: – IP 55 if installed correctly Supply includes: – Plug-in sections, incl. foam rubber clamp strips For enclosure width mm Packs of Model No. 600 2 pc(s). 8618.800 800 2 pc(s). 8618.801 1000 4 pc(s). 8618.802 1200 4 pc(s). 8618.803 1600 4 pc(s). 8618.804 Accessories: – Cable clamp rail, see page 1059 Note: – You will need two pieces per cable entry point. – From an enclosure width of 1000 mm, the base assembly is divided into two sections in the width. Two cable entry points (left/right) may be used. Section for cable entry, rear for VX, VX SE For top-mounting on the gland plate and enclosure frame. Material: – Extruded aluminium section – Seal: PU foam – Cross-section: 30 x 25 mm Protection category IP to IEC 60 529: – IP 55 if installed correctly Supply includes: – Plug-in sections, incl. foam rubber clamp strips For enclosure width mm Packs of Model No. 600 2 pc(s). 8618.810 800 2 pc(s). 8618.811 1000 4 pc(s). 8618.812 1200 4 pc(s). 8618.813 1600 4 pc(s). 8618.814 Accessories: – Cable clamp rail, see page 1059 Foam rubber cable clamp strip Packs of Model No. For sealing the cable entry between the gland plates. Particularly suitable for identical cable crosssections. 3m 2573.000 System accessories Note: – You will need two pieces per cable entry point. – From an enclosure width of 1000 mm, the base assembly is divided into two sections in the width. Two cable entry points (left/right) may be used. Material: – PU foam – Cross-section: 30 x 30 mm Protection category IP to IEC 60 529: – IP 55 if installed correctly Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1045 Cable management Cable entry EMC gland plates see page 1029 Connector gland Packs of Model No. for connector cut-outs (24-pole) For inserting 2 pre-assembled cables through the connector cut-out, without dismantling the cable connector. 1 pc(s). 2400.000 Cable gland Packs of Model No. for IW worktops To fit drilled holes Ø 60 mm. For the entry of cables with pre-assembled connectors, the rotating flap and cover are easily removed. 1 pc(s). 6902.770 Cable diameters: 8 – 36 mm Material: – Enclosure: Plastic – Clamps: Sheet steel Surface finish: – Clamps: Zinc-plated Colour: – RAL 7035 25 Material: – Plastic 22 Supply includes: – 1 pc(s). = 2 half-shells, including seals, with fastening clamp Ø 54 Ø 60 71.5 1046 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable entry Edge protection For covering sharp edges of cut-outs. Provides protection of injuries and prevents damage to inserted cables. The edge protector is suitable for material thicknesses of approx. 1.0 – 2.0 mm, and may be cut to length individually. Packs of Model No. 10 m 7072.100 Material: – Plastic PVC Colour: – Black Connector gland, small For pre-assembled cables with connectors. For use with material thickness of up to 4 mm. Strain relief of the pre-assembled cables can be achieved with cable ties. To fit Packs of Model No. 2 cables Ø 6 – 8 mm 1 pc(s). 2400.300 3 cables Ø 4 – 6 mm 5 pc(s). 2400.500 Material: – Plastic Colour: – RAL 9005 Protection category IP to IEC 60 529: – IP 65 if installed correctly Supply includes: – Assembly parts 36 55 55 11 8 6 35 21.5 Ø 35 Ø 2400.300 3 25 2400.500 41.5 41.5 4 4 22 Mounting cut-out System accessories 42 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1047 Cable management Cable entry Cable gland module Packs of Model No. for support arm connection Ø 130 mm Use of the mounting cut-out for support arm connection Ø 130 mm, round, with enclosures mounted on the wall, for sealed cable entry. May also be mounted retrospectively with the cables already inserted. Fitted with T-heads for cable clamping. Particularly well-suited to cables with identical crosssections. 1 pc(s). 6052.500 10 – 39 100 Surface finish: – Zinc-plated Ø 82 35 100 – 134 Material: – Sheet steel 120 25 70 38.5 Supply includes: – Assembly parts Protection category IP to IEC 60 529: – IP 55 with correct installation and cable entry 66 Stepped collar Sealing range Packs of mm For hole for wall thicknesses from 1.5 to 4.5 mm For cable entry, simply cut off at the required level to match the cable diameter. M20 Material: – Plastic to UL 94-HB M25 M32 M40 13 – 34 Protection category IP to IEC 60 529: – IP 54 with careful cable entry Sealing frame, modular For the universal use on all surfaces and walls, for feeding through pre-fabricated cables with connectors. Can also be mounted onto 24-pole or 16-pole connector cut-outs. Model No. 100 pc(s). 2899.200 5 – 21 50 pc(s). 2899.250 13 – 26.5 25 pc(s). 2899.320 20 pc(s). 2899.400 5 – 16 Number of small seal inserts For cut-out mm Model No. 10 113.5 x 46 (24-pole) 2583.100 8 91 x 46 (16-pole) 2583.080 Material: – Plastic Colour: – Black Protection category IP to IEC 60 529: – IP 66 Also required: – Inlay for plastic gland plate, modular and sealing frame, modular, see page 1051 – Seal inserts for cable gland plates, modular and sealing frame, modular, see page 1051 Supply includes: – Sealing frame – Locking frame 1048 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Gland plates Plastic gland plate, modular and sealing frame, modular The plastic gland plate, modular and the sealing frame, modular, offer extensive flexibility with the entry of assembled and unassembled cables, with or without connectors. Depending on the cable cross-section, suitable modules may be selected to retain the high protection category of IP 66 after cable entry. Plastic gland plate, modular for AX The gland plate design also supports mixed use with standard cable glands and inlays with seal inserts. In this way, cables prefitted with connectors may be safely inserted into the enclosure retrospectively. Seven different gland plate sizes are available. The sealing frame design may be used on any sufficiently large surface. Sealing frame, modular for AX, KX  Rectangular cut-outs for inlays and seal inserts, see page 1051  Metric knockouts for cable glands, see page 1056  Plastic gland plates, modular, see page 1050 2 2 1 System accessories 3 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1049 Cable management Gland plates Plastic gland plate, modular Colour: – RAL 7035 with metric knockouts, for AX Simply pierce the plastic knockouts, and pull through the cable. Additional rectangular cut-outs and reinforcement frame allow the inlays and seal inserts to be installed directly. Protection category IP to IEC 60 529: – IP 66 if installed correctly Note: – The applicable size may be taken from the relevant product ordering page Temperature range: – Suitable for use from -40 °C…+80 °C Accessories: Material: – Plastic to UL 94-V0 – Inlay, see page 1051 – Seal inserts, see page 1051 – Cable glands, see page 1056 Model No. 2561.200 2562.200 2563.200 2564.200 2565.200 2566.200 2567.200 Packs of 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). Gland plate Size 1 Size 2 Size 3 Size 4 Size 5 Size 6 Size 7 256 x 149 339 x 149 447 x 149 534 x 149 301 x 221 401 x 221 436 x 221 M12 2 3 4 5 4 4 4 M16 1 2 3 4 4 5 5 M20 2 3 5 6 4 5 5 M25 1 3 3 5 3 4 4 M32 2 2 1 1 1 1 4 M40 – – 1 1 1 1 1 M50 – – – – – 1 1 2 3 4 6 5 6 6 Dimensions W x D mm Diameter mm Number of cable entries Rectangular cut-outs 149 133 Size 2 133 149 Size 1 60 41.5 240 323 256 339 133 149 Size 3 41.5 120 431 447 Size 5 285 534 301 100 73.5 221 41.5 205 Size 7 73.5 221 41.5 518 Size 6 205 73.5 220 39 1050 205 221 133 149 Size 4 41.5 112 385 420 401 436 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Gland plates Inlay for plastic gland plate, modular and sealing frame, modular Individual inserts to subdivide the cut-outs in the modular plastic gland plate and the modular sealing frame. Version Packs of Model No. 1 slot 5 pc(s). 2582.100 2 slots 5 pc(s). 2582.200 4 slots 5 pc(s). 2582.400 6 slots 5 pc(s). 2582.600 Material: – Plastic Colour: – Black Seal inserts Seal inserts, small For cable diameter Packs of Model No. Solid 10 pc(s). 2580.000 3 mm 10 pc(s). 2580.003 4 mm 10 pc(s). 2580.004 5 mm 10 pc(s). 2580.005 Material: – Plastic 6 mm 10 pc(s). 2580.006 7 mm 10 pc(s). 2580.007 Colour: – RAL 7035 8 mm 10 pc(s). 2580.008 9 mm 10 pc(s). 2580.009 10 mm 10 pc(s). 2580.010 11 mm 10 pc(s). 2580.011 12 mm 10 pc(s). 2580.012 13 mm 10 pc(s). 2580.013 14 mm 10 pc(s). 2580.014 For cable diameter Packs of Model No. Solid 5 pc(s). 2580.100 15 mm 5 pc(s). 2580.115 16 mm 5 pc(s). 2580.116 17 mm 5 pc(s). 2580.117 18 mm 5 pc(s). 2580.118 19 mm 5 pc(s). 2580.119 20 mm 5 pc(s). 2580.120 21 mm 5 pc(s). 2580.121 22 mm 5 pc(s). 2580.122 23 mm 5 pc(s). 2580.123 24 mm 5 pc(s). 2580.124 25 mm 5 pc(s). 2580.125 for plastic gland plate, modular and sealing frame, modular In conjunction with the inlays, the seal inserts allow individual cable entry, even with preassembled cables. Accessories: – When using as a gland plate, modular: Locking clip for seal inserts, see page 1051 Locking clip Packs of Model No. for seal inserts In conjunction with the plastic gland plate, modular, the locking clips ensure the seal inserts are held securely and cannot be accidentally pushed into the enclosure. 10 pc(s). 2583.120 System accessories Seal inserts, large Material: – Plastic Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1051 Cable management Gland plates Plastic gland plate with membranes, for AX Simply pierce the plastic with a sharp object, and pull through the cable. Note: – The applicable size may be taken from the relevant product ordering page Material: – Plastic to UL 94-V0 Colour: – Similar to RAL 7035 Protection category IP to IEC 60 529: – IP 66 if installed correctly Model No. 2561.300 2562.300 2563.300 2564.300 2565.300 2566.300 2567.300 Packs of 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). Gland plate Size 1 Size 2 Size 3 Size 4 Size 5 Size 6 Size 7 256 x 149 339 x 149 447 x 149 534 x 149 301 x 221 401 x 221 436 x 221 5 – 11 15 24 36 28 30 30 30 10 – 15 22 44 46 48 40 50 52 15 – 25 8 6 8 8 5 8 8 19 – 34 4 2 2 2 2 2 6 26 – 35 – – 4 2 – 2 4 26 – 54 1 2 2 2 2 2 2 50 – 110 – – – 1 1 1 1 Dimensions W x D mm Diameter mm Number of cable entries Size 1 Size 2 339 256 41.5 149 120 120 133 120 133 149 68 Size 3 447 149 120 120 120 133 41.5 Size 5 301 41.5 Size 4 101 101 534 110 110 110 133 149 221 110 205 39 Size 6 Size 7 401 100 436 100 1052 Further technical information available on the Internet. 41.5 112 112 112 221 205 100 221 205 41.5 Rittal System Catalogue 36/System accessories Cable management Gland plates Metal gland plate Note: – The applicable size may be taken from the relevant product ordering page with metric knockouts, for AX Simply knock out the holes for the cable glands using a screwdriver. Accessories: Material: – Sheet steel – Cable glands made from polyamide or brass, see page 1056 Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 66 if installed correctly Model No. 2571.100 2572.100 2573.100 2574.100 2575.100 2576.100 2577.100 Packs of 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). 1 pc(s). Gland plate Size 1 Size 2 Size 3 Size 4 Size 5 Size 6 Size 7 256 x 149 339 x 149 447 x 149 534 x 149 301 x 221 401 x 221 436 x 221 M12 2 – 4 1 2 2 6 M16 2 6 4 6 10 10 10 M20 9 4 7 8 8 8 8 M25 5 10 15 11 10 18 20 M32 1 2 2 6 2 4 4 M40 1 2 2 4 4 4 4 Dimensions W x D mm Diameter Number of cable entries 149 68 133 Size 2 133 149 Size 1 120 41.5 120 120 240 323 256 339 149 133 Size 3 41.5 113,5 120 113,5 431 447 Size 5 110 110 110 110 41.5 101 101 518 285 534 301 Size 6 System accessories 39 221 41.5 100 100 100 205 Size 7 205 221 205 133 149 221 Size 4 41.5 112 112 385 420 401 436 Rittal System Catalogue 36/System accessories 112 Further technical information available on the Internet. 1053 Cable management Gland plates Gland plate with foam rubber cable clamp strip, for AX For feeding through pre-fabricated cables when the gland plate has already been fitted to the enclosure. Split gland plates can be sealed using movable plates with a foam rubber cable clamp strip. Gland plate size Dimensions mm 5 301 x 221 1 pc(s). 2565.400 6 401 x 221 1 pc(s). 2566.400 7 436 x 221 1 pc(s). 2567.400 Packs of Model No. Material: – Gland plate: Sheet steel Colour: – RAL 7035 Metal gland plate with metric knockouts, for KX Simply knock out the holes for the cable glands using a screwdriver. Material: – Sheet steel Colour: – RAL 7035 Diameter Packs of Model No. M20 1 pc(s). 1581.200 Accessories: – Cable glands made from polyamide or brass, see page 1056 Protection category IP to IEC 60 529: – IP 55 if installed correctly 220 for metric cable glands, for EL Folded gland plate with foamed-in seal and prepunched, knock-out holes for metric cable glands M12, M20, M25, M32, M40. Depth mm Cable entry (quantity x Ø) Packs of Model No. 599 133.5 4 x M12 7 x M20 5 x M25 2 x M32 2 x M40 1 pc(s). 7705.235 Material: – Sheet steel, 1.5 mm 599 19 Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 55 27 133.5 20.5 (7 x) 40.5 (2 x) 1054 Further technical information available on the Internet. 90 Width mm 12.5 (4 x) 32.5 (2 x) 28 Gland plate 76 72 202 25.5 (5 x) Rittal System Catalogue 36/System accessories Cable management Gland plates Packs of Model No. with brush insert, for EL Folded gland plate with foamed-in seal and plastic brush inserts for simple cable entry. 1 pc(s). 7705.035 Colour: – RAL 7035 40 Material: – Sheet steel, 1.5 mm 133.5 Gland plate 390 19 599 Brush strip For individual installation of enclosure panels, gland plates and panels. Cut-outs for cable routing at any given positions in the side panel, rear panel, doors, roof and base plate may be finished off attractively by simply attaching the brush strip. Material: – Plastic, UL 94-HB Packs of Model No. 2m 7072.200 Technical specifications: – For metal thickness: 0.6 – 1.5 mm – Bristle length: 30 mm – Plastic sheath: 18 mm – Snap-on surface: 10 mm – Maximum cut-out height: 38 mm Brush strip, super-airtight Packs of Model No. For individual installation of enclosure panels, gland plates and panels. Cut-outs for cable routing at any position in the side panel, rear panel, doors, roof and base plate. These special brush strips may be used to create airtight entries for cable sections and conductors. The brush strips arranged in an offset configuration ensure good sealing from the routed cables even with large quantities of cables. In this way, unwanted flow losses may be reduced to a minimum. 2x1m 7825.375 Technical specifications: – For metal thickness: 1.5 – 2 mm – Bristle length: 58 mm – Plastic sheath: 14 mm – Snap-on surface: 11.5 mm – Cut-out width: 88 – 90 mm Material: – Plastic, fire protection to UL 94-HB System accessories Supply includes: – 1 brush strip right-hand version – 1 brush strip left-hand version Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1055 Cable management Cable glands Cable gland, brass Benefits: – Because the gland and lock nut are sold together in a single pack, this saves additional ordering and storage – Clamping membranes for even tightening and strain relief to protect the cables Material: – Brass – Seal: CR/NBR Surface finish: – Nickel-plated Protection category IP to IEC 60 529: – IP 68 (5 bar, 30 min.) Size Packs of Model No. M12 x 1.5 15 pc(s). 2411.801 M16 x 1.5 15 pc(s). 2411.811 M20 x 1.5 10 pc(s). 2411.821 M25 x 1.5 10 pc(s). 2411.831 M32 x 1.5 5 pc(s). 2411.841 M40 x 1.5 4 pc(s). 2411.851 M50 x 1.5 2 pc(s). 2411.861 M63 x 1.5 1 pc(s). 2411.871 Possible alternative: – Cable gland Hygienic Design, see page 1057 Approvals: – VDE, UR, cUR Cable gland, polyamide Benefits: – Because the gland and lock nut are sold together in a single pack, this saves additional ordering and storage – Clamping membranes for even tightening and strain relief to protect the cables Material: – Polyamide 6 – Seal: CR Size Packs of Model No. M12 x 1.5 50 pc(s). 2411.601 M16 x 1.5 50 pc(s). 2411.611 M20 x 1.5 50 pc(s). 2411.621 M25 x 1.5 25 pc(s). 2411.631 M32 x 1.5 15 pc(s). 2411.641 M40 x 1.5 5 pc(s). 2411.651 M50 x 1.5 5 pc(s). 2411.661 M63 x 1.5 3 pc(s). 2411.671 Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 68 (5 bar, 30 min.) Approvals: – VDE, UL, cUL, CSA EMC cable gland see page 1030 1056 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable glands Cable gland HD Standard version More compact design and the lock nut is included with the supply. Applications: – Manufacturing and packaging of foodstuffs etc. – Clean room technology (e.g. pharmaceuticals) – Biotechnology – Chemical industry Benefits: – Smooth, solid exterior surfaces effectively prevent the depositing of harmful micro-organisms – Much easier, therefore cheaper, cleaning compared with conventional cable glands Material: – Cap nut: Stainless steel 1.4305 (AISI 303) – Seal: Compliant with FDA 21 CFR 177.2600 Size Cable diameter mm Packs of Model No. M12 x 1.5 3 – 6.5 5 pc(s). 2410.001 M16 x 1.5 5 – 10 5 pc(s). 2410.011 M20 x 1.5 6 – 12 5 pc(s). 2410.021 M25 x 1.5 12 – 17 5 pc(s). 2410.031 Size Cable diameter mm Packs of Model No. M16 x 1.5 5 – 10 5 pc(s). 2410.111 1 M20 x 1.5 6 – 12 5 pc(s). 2410.121 2 M25 x 1.5 12 – 17 5 pc(s). 2410.131 3 EMC version 4 Protection category IP to IEC 60 529: – IP 69 – IP X8 (5 bar, 30 min.) 5 Supply includes: – HD cable gland – Lock nut 7 6  Seal  Cap nut  Gripper jaws  Shield spring Why use hygienic cable glands? Critical points with conventional solutions  Cable entry in front Hygienic design features 1 1 2 of seal 2  No minimum radii on the hexagon  External threads  Gap caused by O-ring on the enclosure surface  Seal directly at the cable entry  Compliance with (EMC version only)  Clamping ring  Enclosure seal  Base with locator for assembly tool minimum radii on the hexagon 3 3 4  No external threads  Flush termination between the cap nut and the enclosure 4 Packs of Model No. for cable gland HD For attaching HD cable glands in an internal thread or using lock nuts. This can be achieved either from the inside or from the outside using an Allen key. 1 pc(s). 2410.290 System accessories Assembly tool Supply includes: – 1 pc(s). = Adaptor for sizes from M12 – M25 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1057 Cable management Cable routing inside the enclosure Cable duct – With special DIN punchings for direct mounting on the enclosure section or on surfaces such as mounting plates. – If the mounting plate is installed flush with the enclosure frame at the rear (installation position ±0 mm), the horizontally mounted cable ducts are aligned with the cable ducts mounted on the enclosure section. – Cable duct 50 mm wide for individually sited VX25 enclosures with side panel on the vertical section, on the left and right adjacent to the mounting plate. – Cable duct 100 mm for mounting on the vertical enclosure frame with bayed enclosures. B Model No. 24 pc(s). 8800.750 40 20 pc(s). 8800.751 50 18 pc(s). 8800.755 60 18 pc(s). 8800.752 80 12 pc(s). 8800.753 100 12 pc(s). 8800.754 Accessories: – Metal multi-tooth screw 5.5 x 13 mm, see page 1004 – Isolator cap, see page 1058 Material: – Hard PVC – Flame-resistant, self-extinguishing – Temperature resistant to +60 °C 3 Packs of 30 Colour: – Similar to RAL 7030 Technical specifications: – Depth: 80 mm – Length: 2000 mm, may be cut to length – Bar width: 5.5 mm – Slot width: 4.5 mm 1 Width (B) mm  = W 50 mm  = W 100 mm  = W 30 to 100 mm 2 3 1 B B Isolator cap Packs of Model No. for screw head To isolate screw heads within the cable duct. 100 pc(s). 8800.770 Material: – Plastic 1058 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable routing inside the enclosure Cable clamp rail Enclosure width mm Packs of Model No. 400 2 pc(s). 8619.400 600 2 pc(s). 8619.410 800 2 pc(s). 8619.420 1000 2 pc(s). 8619.430 Material: – Steel 1200 2 pc(s). 8619.440 1600 2 pc(s). 8619.450 Surface finish: – Zinc-plated 1800 2 pc(s). 8619.460 Right-angle section for VX, VX SE, PC, TP, VX base/plinth For strain relief with cable entry. Depth-variable mounting on a 25 mm pitch pattern on the horizontal enclosure section or in the base/plinth. Supply includes: – Assembly parts Accessories: – Base/plinth installation bracket, see page 885 Cable clamp for cable clamp rails For fastening the cables to the cable clamp rails. For cable diameter mm Packs of Model No. 6 – 12 25 pc(s). 2350.000 Material: – Sheet steel 12 – 16 25 pc(s). 2351.000 14 – 18 25 pc(s). 2352.000 Surface finish: – Zinc-plated 18 – 22 25 pc(s). 2353.000 22 – 26 25 pc(s). 2354.000 Supply includes: – Plastic insert 26 – 30 25 pc(s). 2355.000 30 – 34 25 pc(s). 2356.000 34 – 38 25 pc(s). 2357.000 38 – 42 25 pc(s). 2358.000 42 – 46 25 pc(s). 2359.000 46 – 50 25 pc(s). 2360.000 Possible alternative: – Rail for EMC shielding bracket and strain relief, see page 1029 Cable clamp rail C rail, for mounting plates for VX, VX SE, TP For strain relief with cable entry. The length of the cable clamp rail is tailored to the width of the mounting plate. The mounting bracket included with the supply supports three different installation situations on the mounting plate: For enclosure width mm Length mm Packs of Model No. 600 499 1 pc(s). 5001.080 800 699 1 pc(s). 5001.081 1000 899 1 pc(s). 5001.082 1200 1099 1 pc(s). 5001.083 mounting plate  Straight, at a distance of 10 mm from the mounting plate System accessories  Straight, at a distance of 23 mm from the Accessories: – Cable clamp for C rails, see page 1060  Tilted towards the mounting plate Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Two mounting brackets and assembly screws  Rittal System Catalogue 36/System accessories   Further technical information available on the Internet. 1059 Cable management Cable routing inside the enclosure Cable clamping bracket Packs of Model No. For installation in command panels with mounting cut-out ▭ 120 x 65 mm and Ø 130 mm. Cable clamping optionally via: – Cable clamps or – Cable ties 2597.000 – Standard commercially available cable ties 1 pc(s). 6052.000 Accessories: – Cable clamp, see page 1060 – Cable ties, see page 1061 Bracket height = 25 mm with fitted C rail 40 mm Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – C rail and assembly screws Cable clamp for C rail, combination rail For attaching cables to the C rail. Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Plastic insert For cable diameter mm Packs of Model No. 6 – 14 25 pc(s). 7077.000 12 – 18 25 pc(s). 7078.000 18 – 22 25 pc(s). 7097.000 22 – 26 25 pc(s). 7097.220 26 – 30 25 pc(s). 7097.260 30 – 34 25 pc(s). 7097.300 34 – 38 25 pc(s). 7097.340 38 – 42 25 pc(s). 7098.000 42 – 56 25 pc(s). 7098.100 56 – 64 25 pc(s). 7099.000 Accessories: – C rail, see from page 996 – Combination rail, see page 1063 Cable conduit and cable conduit holder For secure cable routing e.g. from the enclosure or mounting plate to the door. An attachment facility for standard commercially available cable ties is provided on the cable conduit holder, so that cables may be attached upon entry to/exit from the cable conduit. Material: – Cable conduit: Polyethylene – Cable conduit holder: Polyamide Cable conduit Internal Ø mm Packs of Model No. 16 25 m 2595.000 29 25 m 2589.000 36 25 m 2596.000 48 25 m 2590.000 For cable conduit Ø mm Packs of Model No. 16 20 pc(s). 2593.000 29 20 pc(s). 2591.000 36 20 pc(s). 2594.000 48 20 pc(s). 2592.000 Cable conduit holder Also required: – For the installation in AX: Rail for interior installation AX, see page 989 or punched section with mounting flange 14 x 39 mm, see page 952/990 1060 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable routing inside the enclosure Cable attachment For professional, secure fastening of cables and conduits. For cable diameter from – to mm For fastening: – Slide into the punched rail 23 x 23 mm, – Screw-fasten onto the round punchings of the enclosures, as well as all punched rails and punched sections Material: – Polyamide Note: – As the attachments are bayable, several attachments, even those of different sizes, can be assembled using just 2 screws Packs of Model No. 6–9 50 pc(s). 4319.090 9 – 12 50 pc(s). 4319.120 12 – 16 50 pc(s). 4319.160 16 – 20 50 pc(s). 4319.200 Also required: – Posidrive raised countersunk screw M5 x 12 mm, 2488.000, for screw-fastening to the round system punchings, see page 1004 Accessories: – Punched rail 23 x 23 mm, see page 994 Cable tie The super-fast solution for fastening cables to the enclosure profile or mounting system parts. Simply clip into the round system punchings. With the nylon loop, secured cables are easily released, allowing individual cables to be added or removed. Ideal for sensitive data cables (fibre-optic/Cu), as it avoids indentations on the cable sheathing. In addition, the nylon loop may be screw-fastened to the round system punchings or attached using a quick-release fastener. Colour: – Black Supply includes: – Quick-release fasteners Nylon tape For tidy cable routing. Supplied on a reel for cutting to the required length. Packs of Model No. 150 100 pc(s). 2597.000 Width mm Length mm Max. cable diameter mm 20 130 30 10 pc(s). 7072.220 20 200 50 10 pc(s). 7072.230 20 300 90 10 pc(s). 7072.240 Packs of Model No. Also required: – Screw 2486.600 for screw-fastening to the round system punchings, see page 1004 Length mm Width mm Packs of Model No. 5000 16 1 pc(s). 2203.400 System accessories Nylon loop Length mm Unlike cable ties, nylon tape – protects the cable sheathing – is easily reopened and – is reusable Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1061 Cable management Cable routing inside the enclosure Nylon tape holder Packs of Model No. – For simple, fast cable attachment – Tool-free mounting in the system punchings with 10.5 x 12.5 mm, with a quarter rotation – Direct use on the horizontal VX frame section, on the support strips and mounting angles of the VX IT 482.6 mm (19") interior installation, on the cable route or on punched sections with mounting flanges – Length of nylon tape: 400 mm 10 pc(s). 5502.155 Material: – Plastic Supply includes: – 10 nylon tapes – 10 holders Nylon loop cable holder Self-adhesive Universally suitable for use in all network enclosures and server racks, wall-mounted enclosures, mounting plates and gland plates. Size length x width mm Packs of Model No. 70 x 16 10 pc(s). 7111.350 Material: – Woven polyamide 6.6 Colour: – Black Snap-in cable routing Version Packs of Model No. for clipping into the system punchings Cable routing suitable for universal use, for tool-free, fast assembly, in two variants: For locking, for system punchings 6.2 mm 10 pc(s). 7111.300 For twisting, for system punchings 4.7 mm 10 pc(s). 7111.310 For locking – User-friendly opening for cable management via locating points – For cable diameters 14 – 19 mm – For system punchings 6.2 mm For twisting – User-friendly opening for cable management – For cable diameters 10.2 – 12.7 mm – For system punchings 4.7 mm Material: – Polyamide 6.6, self-extinguishing to UL 94-V2 Colour: – Natural 1062 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable routing inside the enclosure Combination rail For enclosures for VX IT Combination of a C rail for cable clamping with cable clamps and a cable guide rail with T-heads for cable routing. The cables can optionally be secured to the combination rail with cable clamps, cable ties or velcro fasteners to be relieved of strain. Applications: – For cable routing and strain relief of routed cables on the VX frame structure Benefits: – May be installed on either the outside or inside of the enclosure frame Packs of Model No. 600 4 pc(s). 5302.020 800 4 pc(s). 5302.021 1000 1000 4 pc(s). 5302.022 1200 1200 4 pc(s). 5302.025 Width mm Depth mm 600 800 Accessories: – Cable ties, see page 1061 – Nylon loop, see page 1061 – Angle bracket for combination rail, see page 1063 Installation options: – Direct screw-fastening between the vertical uprights of the enclosure frame Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Angle bracket Packs of Model No. for combination rail For variable mounting of combination rails between two punched sections with mounting flanges in the enclosure interior. 8 pc(s). 5302.038 Applications: – Cascaded cable routing Benefits: – Simple clip attachment or optionally screw-fastened Cable clamp rail, depth-variable 1) Packs of Model No. 325 – 575 1 pc(s). 5302.044 Mounting dimensions + 152 mm = distance between 482.6 mm (19") levels Accessories: – Cable ties, see page 1061 – Nylon loop, see page 1061 System accessories for VX IT, TE For cable routing on the enclosure frame and for strain relief of the routed cables. The cables can be attached to the cable clamp rails with cable ties or velcro fasteners. The cable clamp rails can be located horizontally at the rear directly onto a 482.6 mm (19") mounting level or in the enclosure depth between two mounting levels. An additional screw fastening secures the unit. The depth variability of the rails allows their length to be flexibly adapted to the given mounting distance between the two 482.6 mm (19") mounting levels. Mounting dimension1) mm Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1063 Cable management Cable routing inside the enclosure Cable manager Applications: – For vertical cable routing and strain relief with network and server applications Maxi-kit Packs of Model No. 20 pc(s). 5502.405 50 75 Benefits: – Simple assembly with tool-free quick-release fastening – Alternatively suitable for screw-fastening – Integral multifunctional punching for attaching cable routing components – Integral mounting holes for fixing the PDUs in a 7 U pitch pattern via a keyhole recess Material: – Plastic, UL 94-V0 Colour: – RAL 9005 Supply includes: – Mounting clips and assembly parts Cable shunting ring For flexible, system-compatible cable routing at the side of the 482.6 mm (19") mounting angles. Material: – Steel 50 44 75 Dimensions mm Packs of Model No. 125 x 85 10 pc(s). 7111.900 125 x 65 10 pc(s). 7111.000 85 x 43 10 pc(s). 7112.000 Dimensions mm Packs of Model No. 330 x 90/70 4 pc(s). 7220.600 Surface finish: – Zinc-plated Supply includes: – Assembly parts Shunting ring To accommodate large quantities of cables. Shunting ring for side attachment to 482.6 mm (19") sections in 800 mm wide network enclosures. The ring is attached asymmetrically providing approx. 110 mm free space in front of the 482.6 mm (19") level. This allows even large quantities of cables to be effectively managed. Material: – Steel Surface finish: – Zinc-plated Supply includes: – Assembly parts 1064 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable routing inside the enclosure Fibre-optic shunting rings Packs of Model No. Fibre-optic shunting or jumper cables can be inserted into the grooves of the inner body. A rubber ring holds different fibre-optic cables up to Ø 4.5 mm. Strain relief and bending radius are ensured. 2 pc(s). 7116.500 Length: 120 mm Possible alternative: – Fibre-optic cable management panel, 1 U, see page 1065 Material: – 2K plastic Colour: – Exterior: RAL 7035 – Interior: Black Supply includes: – 2 rubber rings – Baying kit – Assembly parts 1 2 3 4 Assembly: The supplied mounting brackets are suitable for universal use; the fibre-optic cables can be routed to the patch panel in all directions in various mounting positions:  At the side, directly on the patch panel  In front of the patch panel  At the side next to the patch panel  Behind the patch panel Fibre-optic cable management panel , 1 U 482.6 mm (19") The four fibre-optic cable shunting rings integrated into the front permit optimum management of individual fibres while allowing for minimum baying radii. Material: – Panel: Sheet steel – Ring: 2K plastic U Packs of Model No. 1 1 pc(s). 5302.203 Possible alternative: – Fibre-optic cable shunting ring, see page 1065 System supports for cable routes for VX, VX IT The depth-variable support system may be attached to all 800 – 1200 mm deep VX enclosures with external screw-fastening of the roof plate. The integral system punchings, for screws or captive nuts, support the attachment of most common cable route systems. Packs of Model No. 2 pc(s). 7831.472 System accessories Colour: – Panel: RAL 9005 – Cable shunting rings on the outside: RAL 7035, Body: RAL 9005 Accessories: – Metal multi-tooth screws 5.5 x 13 mm, 2486.600, see page 1004 – May be combined with VX IT fan mounting plate – In combination with punched rail, suitable for accommodating additional cable routing rails or pipelines. – Support height: 102 mm Material: – Sheet steel Surface finish: – Powder-coated Colour: – RAL 7035 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1065 Cable management Cable routing inside the enclosure Cable route Width mm Height mm Packs of Model No. for VX, VX IT 145 2000 1 pc(s). 5302.120 Applications: – For vertical cable routing and strain relief with network and server applications 145 2200 1 pc(s). 5302.122 265 2000 – 2200 1 pc(s). 5302.322 Installation options: – On the VX IT frame between the roof and base frames, all-round – In 800 mm wide VX IT racks, alternatively, screwfastening between the upper and lower depth stays is supported Benefits: – Simple assembly with tool-free quick-release fastening – Alternatively suitable for screw-fastening – Integral multifunctional punching for attaching cable routing components – Integral mounting holes for fixing the PDUs in a 7 U pitch pattern via a keyhole recess Accessories: – – – – – Cable ties, see page 1061 Nylon tape, see page 1061 Nylon tape holder, see page 1062 Wall-mounted enclosures, see page 1064 Cable routing bars, see page 1067 Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – Assembly parts Cable route for TE For vertical cable entry at the side of the 482.6 mm (19") mounting frame for TE, independently from the enclosure frame. Width mm Height mm Packs of Model No. 100 1700 1 pc(s). 7000.685 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Surplus cable holder W x H x D mm Packs of Model No. For fastening at the rear area of the enclosure, or at the side of network enclosures. The surplus cable holder can be attached to all depth stays or to punched sections and rails with a 25 mm pitch pattern – mounting dimension 150 mm. 280 x 151 x 75 1 pc(s). 7220.500 Material: – Sheet steel Surface finish: – Zinc-plated Colour: – RAL 7035 Supply includes: – Assembly parts 1066 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable routing 19" Cable routing bars, 482.6 mm (19") attachment For structured routing of entire cable bundles, the cable bars may be secured to a variety of different positions inside the enclosure. Units U Number of connection combs 4 1 Packs of Model No. 2 4 pc(s). 7111.224 8 10 pc(s). 7111.214 Units U Number of connection combs Packs of Model No. 4 2 4 pc(s). 7111.222 1 5 10 pc(s). 7111.212 Applications: – For horizontal cable routing within the distributor level. Thanks to their open mounting holes, they can also be retrospectively slotted onto the 482.6 mm (19") system punchings of the mounting level at any time and secured with the existing mounting screws of the installed components. Material: – Support: Sheet steel – Cable routing bars, connection combs: Plastic UL 94-V0 Colour: – RAL 9005 Supply includes: – Cable routing bars – Connection combs Note: – Size of individual chambers (WxD) approx. 34 x 100 mm Cable routing bars for universal use For structured routing of entire cable bundles, the cable bars may be secured to a variety of different positions inside the enclosure. Applications: – All-round attachment for universal use for vertical and horizontal cable routing inside the enclosure or within the distributor level. Material: – Support: Sheet steel – Cable routing bars, connection combs: Plastic UL 94-V0 Colour: – RAL 9005 Supply includes: – Cable routing bars – Connection combs Rittal System Catalogue 36/System accessories System accessories Note: – Size of individual chambers (WxD) approx. 34 x 100 mm Further technical information available on the Internet. 1067 Cable management Cable routing 19" Cable duct for VX IT, TE Cable duct for concealed cable routing. Convenient access to the cabling at any time via the hinged duct cover, optionally removable. The duct has cable entry options to the enclosure interior and through the rear panel of the duct. The cable retaining bars enclosed with the duct are snap-mounted onto the cable fingers of the duct with variable depth to support cable routing. Alternatively, the cable duct may also be screw-fastened. For optimum air routing, it may be combined with the brush kit for VX IT. Benefits: – Simple assembly with tool-free quick-release fastening – High packing density due to U-based cable routing – Suitable for back-to-back baying – Cable duct may be used as a shielding element to prevent air short-circuits within cold aisle containment – Lockable cable glands, may be fitted with installation components on the 1 U mounting standard Material: – Sheet steel – Plastic to UL 94-HB Colour: – RAL 9005 Supply includes: – Cable duct – 2 covers – 14 cable fingers , 6 U – 10 cable retaining bars – Assembly parts Accessories: – Brush kit, see page 1068 – Cable management panel with brush strip, see page 1074 – Blanking panel, 482.6 mm (19"), see page 1093 For enclosure width mm For enclosure height mm Units U Packs of Model No. VX IT TE 8000 Data Rack 800 1800 2000 1900 38 1 pc(s). 5302.051 VX IT Data Rack 800 2000 2122 42 1 pc(s). 5302.052 VX IT 800 2200 47 1 pc(s). 5302.053 For enclosure Brush kit for cable duct VX IT For all-round shielding of the 482.6 mm (19") mounting level and targeted routing of the cold air flow to the installed equipment. Applications: – The brush kit is designed for combining two vertical cable ducts on both sides of the 482.6 mm (19") mounting level. The brush kit may be combined with a cable duct and used as an alternative to the air baffle plate. – A combination with air baffle plate and cable duct is also possible as partial installation Benefits: – Simple assembly with tool-free quick-release fastening – Alternatively suitable for screw-fastening – Tailored to the maximum enclosure height 47 U for cutting to the required individual length Functions: – The brush kit consists of vertical brush strips for the area between the cable duct and side panel as well as horizontal air baffle plates with brush strips for sealing in the roof and floor area on the 482.6 mm (19") mounting level Installation options: – 482.6 mm (19") mounting angles, standard – 482.6 mm (19") mounting angles, dynamic For enclosure width mm Bristle length mm Packs of Model No. 800 48 1 pc(s). 5302.036 Colour: – RAL 9005 Supply includes: – 2 brush strips, vertical – 2 air baffle plates, horizontal, including brush strip – Assembly parts Also required: – Blanking panel, 482.6 mm (19"), see page 1093 Assembly instruction: – When using the cable duct combined with the brush kit as an air routing component, the cable entry openings in the cable duct must be closed or covered with a cable management panel with brush strip Accessories: – Cable management panel with brush strip, see page 1074 Material: – Brush strip: Plastic, UL 94-V0 – Bristles: Plastic, UL 94-HB – Air baffle plates: Sheet steel, spray finished 1068 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable routing 19" Cable finger for VX IT For structured cable routing on the 482.6 mm (19") mounting level in 1 U increments. Benefits: – Simple, tool-free installation by snap-mounting directly into the 482.6 mm (19") mounting angle Units U Design Packs of Model No. 6 for VX IT 482.6 mm (19") mounting angles, dynamic 14 pc(s). 5302.046 6 for VX IT 482.6 mm (19") mounting angles, standard 14 pc(s). 5502.115 Installation options: – Installation is possible both on the front and on the side of the mounting angles at the front and rear Material: – Plastic to UL 94-V0 Colour: – RAL 9005 Note: – Cable routing in conjunction with air baffle plates is supported Complete CAT 6 system for Network Cable Organizer Modern network infrastructures rely on maximum performance and the greatest possible flexibility in cabling. A useful component here is the Network Cable Organizer (NCO). The robust 1 U mounting frame is pre-configured with 24 cable cassettes and revolutionises conventional structured cabling with 8 times faster installation. Applications: – For use in all network racks from a depth of 800 mm. Benefits: – Minimise cable chaos – Prevent obstructions to the air circulation in the vicinity of network switches – Always the right length: Surplus cable lengths – whether CAT 6 or fibre-optic – are simply withdrawn with a spring balancer – Every cable is 100% tested and supplied with a corresponding measurement record – Front access – Ideal for retrofitting into racks with a depth of 800 mm or more Material: – Mounting frame: Sheet steel – Cassettes: Stainless steel, plastic (POM) Colour: – Mounting frame: RAL 9005 Supply includes: – Complete CAT 6 system – 24 CAT 6 cassettes – Installation kit – Assembly parts Accessories: – Mounting frame, see page 1070 – Blanking cover, see page 1071 – Identification labels, see page 1071 Functions: – Attachment to the front and rear 482.6 mm (19") level Units U Width mm Height mm Depth mm Colour Operating temperature range 1 450 44 600 Cable: black 1 450 44 600 Cable: blue 1 450 44 600 Cable: red 1 450 44 600 1 450 44 1 450 1 450 Packs of Model No. +10 °C...+45 °C 1 pc(s). 7044.110 +10 °C...+45 °C 1 pc(s). 7044.120 +10 °C...+45 °C 1 pc(s). 7044.130 Cable: yellow +10 °C...+45 °C 1 pc(s). 7044.140 600 Cable: green +10 °C...+45 °C 1 pc(s). 7044.150 44 600 Cable: violet +10 °C...+45 °C 1 pc(s). 7044.160 44 600 Cable: white +10 °C...+45 °C 1 pc(s). 7044.170 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories Technical specifications: – CAT 6 cable STP – 2 x RJ 45 connectors per cable – Shielded RJ 45 connector with gold-coated pins – Usable cable length per cassette: 1.6 m – ISO/IEC 11801:2002, AWG 36, 100% copper, 250 MHz 1069 Cable management Cable routing 19" Mounting frame for Network Cable Organizer Robust 1 U mounting frame for 24 cable cassettes. For individual configuration of the Network Cable Organizer. Applications: – For use in all network racks from a depth of 800 mm. – Attachment to the front and rear 482.6 mm (19") level Accessories: – – – – Blanking cover, see page 1071 Identification labels, see page 1071 CAT 6 cassettes, see page 1070 Fibre-optic cassettes, see page 1071 Benefits: – Minimise cable chaos – Prevent obstructions to the air circulation in the vicinity of network switches – Always the right length: Surplus cable lengths – whether CAT 6 or fibre-optic – are simply withdrawn with a spring balancer – Front access – Ideal for retrofitting into racks with a depth of 800 mm or more Material: – Mounting frame: Sheet steel Colour: – Mounting frame: RAL 9005 Supply includes: – Robust, 1 U sheet steel mounting frame for 24 cable cassettes – Installation kit – Assembly parts Units U Width mm Height mm Depth mm Design Operating temperature range Packs of Model No. 1 450 44 600 Item is configurable, options available for selection +10 °C...+45 °C 1 pc(s). 7044.010 CAT 6 cassettes for Network Cable Organizer CAT 6 cassettes for self-configuration in the complete Network Cable Organizer system and for independent assembly in the Network Cable Organizer mounting frame. Applications: – Network Cable Organizer – Mounting frame Colour Packs of Model No. Cable: black 3 pc(s). 7044.113 Cable: blue 3 pc(s). 7044.123 Cable: red 3 pc(s). 7044.133 Cable: yellow 3 pc(s). 7044.143 Cable: green 3 pc(s). 7044.153 Cable: violet 3 pc(s). 7044.163 Cable: white 3 pc(s). 7044.173 Material: – Cassettes: Stainless steel, plastic (POM) 1070 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable routing 19" Fibre-optic cassettes for Network Cable Organizer Fibre-optic cassettes for Network Cable Organizer mounting frame. Benefits: – Always the right length: Surplus cable lengths – whether CAT 6 or fibre-optic – are simply withdrawn with a spring balancer – Every cable is 100% tested and supplied with a corresponding measurement record – Secure locking – Each cable cassette has a cable attachment to avoid mechanical strain on the cable Material: – Cassettes: Stainless steel, plastic (POM) Cable version Colour Packs of Model No. Connector type 1: LC duplex / connector type 2: LC duplex Fibre-optic cable, OS2 RBS 9 μ/125 μ Single mode, ISO/IEC 11801 EN 50173 Cable: yellow 3 pc(s). 7044.210 Connector type 1: LC duplex / connector type 2: SC duplex Fibre-optic cable, OS2 RBS 9 μ/125 μ Single mode, ISO/IEC 11801 EN 50173 Cable: yellow 3 pc(s). 7044.211 Connector type 1: LC duplex / connector type 2: LC duplex Fibre-optic cable, OM3 RBS 50 μ/125 μ Multi mode, ISO/IEC 11801 EN 50173 Cable: aqua 3 pc(s). 7044.230 Connector type 1: LC duplex / connector type 2: SC duplex Fibre-optic cable, OM3 RBS 50 μ/125 μ Multi mode, ISO/IEC 11801 EN 50173 Cable: aqua 3 pc(s). 7044.231 Connector type 1: LC duplex / connector type 2: LC duplex Fibre-optic cable, OM4 RBS 50 μ/125 μ Multi mode, ISO/IEC 11801 EN 50173 Cable: violet 3 pc(s). 7044.240 Connector type 1: LC duplex / connector type 2: SC duplex Fibre-optic cable, OM4 RBS 50 μ/125 μ Multi mode, ISO/IEC 11801 EN 50173 Cable: violet 3 pc(s). 7044.241 Blanking cover Packs of Model No. for Network Cable Organizer For covering unused slots in the Network Cable Organizer. 10 pc(s). 7044.020 Identification labels for Network Cable Organizer Identification labels for Network Cable Organizer. Design Packs of Model No. White, on DIN A5 sheet 1 pc(s). 7044.178 System accessories Material: – Plastic POM Supply includes: – 2 DIN A5 sheets of 48 labels Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1071 Cable management Cable routing 19" Drawer 482.6 mm (19") to accommodate surplus cables The 1 U drawer offers a convenient opportunity for storing surplus cables in an organised, compact and secure way within the 482.6 mm (19") levels. Units U Distance between levels mm Packs of Model No. 1 435 - 750 1 pc(s). 7063.200 Applications: – May be fitted between two 482.6 mm (19") levels – For mounting on L-shaped mounting angles, cranked mounting angles or mounting frames Benefits: – With brush strip at the front for cable entry – T-head rail in the rear section for cable clamping – Ring-shaped kink-free routing of the conductors on adjustable elements in the interior Material: – Sheet steel Colour: – RAL 7035 Supply includes: – Drawer – Telescopic slides – Assembly parts Cable management panel with plastic rings For horizontal management of the patch cables, with 5 cable shunting rings. Units U Ring size mm Colour 1 70 x 44 RAL 9005 Packs of Model No. 1 pc(s). 7159.017 Width: – 482.6 mm Material: – Panel: Sheet steel – Ring: Plastic UL 94-V0 Supply includes: – Cable management panel – Cable shunting rings (supplied loose) Note: – The sizes given are external dimensions. Cable management panel Units U Ring size mm Colour Packs of Model No. 1 105 x 43 RAL 7035 1 pc(s). 7257.035 1 55 x 43 RAL 7035 1 pc(s). 7257.200 Width: – 482.6 mm 2 125 x 85 RAL 7035 1 pc(s). 7257.100 1 105 x 43 RAL 9005 1 pc(s). 7257.005 Material: – Panel: Sheet steel – Ring: Steel 1 55 x 43 RAL 9005 1 pc(s). 5502.205 2 125 x 85 RAL 9005 1 pc(s). 7257.105 with steel rings For horizontal management of the patch cables, with 5 cable shunting rings. Surface finish: – Panel: Spray-finished – Ring: Zinc-plated Note: – The sizes given are external dimensions. 1072 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Cable management Cable routing 19" Cable management panel with cable routing bars For horizontal management of the patch cables with 5 cable routing bars. Opening the individual cable routing bars allows user-friendly modification and extension of the cabling. Units U Bar depth mm No. of bars/ U 1 100 5 Colour Packs Model No. of RAL 9005 1 pc(s). 5502.225 Width: – 482.6 mm Material: – Panel: Sheet steel, spray finished – Cable routing bars: Plastic Cable management panel with front flap The cable routing chamber has cut-outs from above, into which the patch cables can be inserted. The cable management panel is equipped with a flap and quick-release fasteners at the front, for optimum access to the cables. From the rear, the cables can be inserted via a cut-out with brush strips. Surface finish Units U Bar depth mm Sprayfinished 2 100 Colour Packs Model No. of RAL 9005 1 pc(s). 5502.235 Accessories: – Cable clamp rail, see page 1063 Width: – 482.6 mm Material: – Sheet steel Surface finish: – Spray-finished Cable routing channel 482.6 mm (19") To hold the patching cables. Surface finish Units U Depth mm Sprayfinished 1 85 Colour Packs Model No. of RAL 9005 1 pc(s). 5502.245 Width: – 482.6 mm System accessories Material: – Sheet steel Surface finish: – Spray-finished Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1073 Cable management Cable routing 19" Cable management panel with brush strip 482.6 mm (19") For convenient, simple cable routing between two areas separated by a 482.6 mm (19") mounting level, for example, between the front and rear areas of the 482.6 mm (19") mounting level. Units U Packs of Model No. 1 1 pc(s). 5302.202 Accessories: – Cable clamp rail, see page 1063 Applications: – For locking and simultaneous cable routing in installation zones to the 1 U, 482.6 mm (19") mounting standard Benefits: – To make the cable entry larger, two panels are easily combined with one another Width: – 482.6 mm Material: – Sheet steel – Brush strip: Plastic, UL 94-HB Surface finish: – Spray-finished Colour: – RAL 9005 Cable tray, depth-variable for VX IT, TE 8000 For protected cable routing between the front and rear installation area. Surface finish Mounting dimensions mm Packs of Model No. Spray-finished 350 - 550 1 pc(s). 5302.043 Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – Assembly parts Combination rails for 482.6 mm (19") The combination rail offers a functional combination of a C rail for cable clamping with cable clamps and a cable guide rail with T-heads for cable routing using cable ties or nylon loops in a rail system. Applications: – For cable routing and strain relief on the 482.6 mm (19") level Material: – Sheet steel Height U Packs of Model No. 1 4 pc(s). 5302.026 Accessories: – 482.6 mm (19") fastener, 1 U, see page 1097 – Cable clip, see page 1060 – Cable ties, see page 1061 – Nylon loop, see page 1061 Surface finish: – Zinc-plated Supply includes: – Assembly parts for the combination rail, without assembly parts for fixing the cables 1074 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system Swing frames Swing frame, small For From enclosure/ enclosure height Packs of Model No. housing mm U for VX, VX SE, AX for 600 and 800 mm wide enclosures For mounting 482.6 mm (19") equipment. 3 VX, VX SE, AX 6 Material: – Sheet steel 9 12 Surface finish: – Zinc-plated 15 VX, VX SE 18 Supply includes: – 1 cam with double-bit lock insert – 2 x 130° hinges – Assembly parts 380 1 pc(s). 8619.500 600 1 pc(s). 8619.510 600 1 pc(s). 8619.520 760 1 pc(s). 8619.530 – 1 pc(s). 8619.540 – 1 pc(s). 8619.550 Note: – For the installation in baying enclosure system VX, VX SE, see page 1076 Also required: – The swing frame stay is required to lock the open swing frame 8619.270, see page 1078 Accessories: – 482.6 mm (19") fastener, 1 U, 2090.000, see page 1097 For mounting in compact enclosures AX, the following components are also required: 1 2 For enclosure width mm Page  Installation kit 1 pc(s). 600 8619.600 8619.610 1076  Mounting kit AX 4 pc(s). 2034.010 2034.010 1076 800 50 A = max. installation depth mm with internal mounting Width Depth Centre Side 600 210 130 – 600 250 170 – 600 350 220 – 600 400 220 – 600 500 – – 600 600 – – 600 800 – – 800 300 210 210 800 400 310 310 800 500 – – 800 600 – – 800 800 – – Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories Enclosure dimensions mm A 50 A Max. installation depth for compact enclosures AX 1075 482.6 mm (19") installation system Swing frames Swing frame, small for VX, VX SE, AX for 600 and 800 mm wide enclosures For the installation in baying enclosure system VX, VX SE, the following components are also required: Installation1) Front, top/bottom Set back, top/bottom Set back/front, centre 1 1 1 2 1 2 1 2 2 1 For enclosure width mm  Installation kit  Punched section 1 pc(s). 800 8619.600 8619.610 1076 For enclosure depth mm with mounting flange 23 x 64 mm, 2 or 4 pc(s). required 1) Page 600 400 4 pc(s). 8617.110 991 500 4 pc(s). 8617.120 991 600 4 pc(s). 8617.130 991 800 4 pc(s). 8617.140 991 For the installation in VX SE, the adaptor rail VX is required, see page 995 Note: Product information, see page 1075 Installation kit for swing frame, small, and partial mounting plate For mounting the small swing frame in AX, VX, VX SE or a partial mounting plate (in conjunction with a hinge for partial mounting plates). Installation options: – In VX, VX SE – Directly on the enclosure section in the foremost position – In conjunction with punched section with mounting flange 23 x 64 mm, offset in the depth For enclosure width mm Packs of Model No. 600 1 pc(s). 8619.600 800 1 pc(s). 8619.610 Also required: – For the installation in compact enclosures AX: Mounting kit AX, see page 1076 – For the installation in standalone rack VX SE: Adaptor rail VX, see page 995 Load capacity: – Up to 1500 N Material: – Sheet steel Surface finish: – Nickel-plated Supply includes: – Assembly parts Mounting kit AX Packs of Model No. for installation kit for swing frame, small For mounting the small swing frame in compact enclosures AX. 1 pc(s). 2034.010 Supply includes: – 4 mounting brackets Note: – 1 pack is sufficient for mounting one small swing frame 1076 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system Swing frames Swing frame, large Supply includes: – Lock system, 130° hinge and parts for attaching to the installation kit for VX, VX SE for 600, 800 and 1200 mm wide enclosures For mounting 482.6 mm (19") equipment. Note: – The swing frame stay is required to lock the open swing frame 8619.270, see page 1078 Material: – Sheet steel Surface finish: – Frame: Zinc-plated – Trim panels: Spray finished Accessories: – 482.6 mm (19") fastener, 1 U, 2090.000, see page 1097 Colour: – Trim panels: RAL 7035 Installation options Full installation, front/set back Partial installation, top, front/set back1) Partial installation, centre, front/set back1) 1 1 Full installation, front Full installation, front 1 1 1 2 1 2 2 1 1 Trim panel For enclosure width mm 1 1 Without One side Both sides 600 800 800 U For min. enclosure height mm Packs of 22 1200 1 pc(s). 8619.010 8619.020 31 1600 1 pc(s). 8619.011 8619.021 – 35 1800 1 pc(s). 8619.012 8619.022 8619.032 40 2000 1 pc(s). 8619.013 8619.023 8619.033 44 2200 1 pc(s). 8619.014 8619.024 8619.034 Cam lock ◾ – – Locking rod – ◾ ◾ Lock system Page Model No. 8619.030 Also required For enclosure width Packs of mm  Punched section with mounting flange 23 x 64 mm, 2 or 4 pc(s). required 600 1 pc(s). 8619.040 – – 1078 800 1 pc(s). 8619.041 8619.041 8619.041 1078 1200 1 pc(s). 8619.042 8619.042 8619.042 1078 Installation in enclosure depth Packs of mm 400 4 pc(s). 8617.110 8617.110 8617.110 991 500 4 pc(s). 8617.120 8617.120 8617.120 991 600 4 pc(s). 8617.130 8617.130 8617.130 991 800 4 pc(s). 8617.140 8617.140 8617.140 991 Comfort handle AX – see page see page 939 Lock inserts, type A – see page see page 939 8619.050 8619.050 8619.050 1078 System accessories  Installation kit Accessories 180° hinges for VX2) 1) 2) 1 pc(s). For the installation in VX SE, the adaptor rail VX is required, see page 995 Only in conjunction with 800 mm wide installation kit Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1077 482.6 mm (19") installation system Swing frames Installation kit for swing frame, large For mounting – Directly on the enclosure section when installed across the entire enclosure height – In conjunction with punched section with mounting flange 23 x 64 mm, for partial installation in the enclosure height For enclosure width mm Load capacity Packs of Model No. N 600 3500 1 pc(s). 8619.040 800 3500 1 pc(s). 8619.041 1200 1500 1 pc(s). 8619.042 Material: – Sheet steel, 3 mm Surface finish: – Spray-finished Colour: – RAL 7035 Supply includes: – Assembly parts Swing frame stay Packs of Model No. Secures the swing frame in the open position. For 130° hinge 1 pc(s). 8619.270 For mounting on swing frame, large – 8619.270 at the top of the enclosure – 1980.200 at the bottom of the enclosure (with safety stop at 160°) For 180° hinge 1 pc(s). 1980.200 For mounting on swing frame, small – 8619.270, may be mounted at the top or bottom on the installation kit 180° hinge Packs of Model No. for swing frame, large, for VX To extend the opening angle from 130° to 180° in the foremost installation position. Provides optimum access to the components and 482.6 mm (19") components located behind the swing frame. 1 pc(s). 8619.050 Load capacity: – Up to 1500 N Material: – Die-cast Note: – Only suitable for installation in VX Slide rail for swing frames To support heavy slide-in 482.6 mm (19") electronic equipment in the swing frame. For slide-in equipment with max. installation depth Packs of Model No. < 190 mm 10 pc(s). 1962.200 > 190 mm 10 pc(s). 1963.200 Material: – Sheet steel Surface finish: – Zinc-plated 1078 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system Accessories for Data Rack Second pair of mounting angles for Data Rack To accommodate 482.6 mm (19") network components or for the attachment of component shelves and slide rails. 482.6 mm (19") punched profile at the front, hole centre distance 465 mm (470 mm at the rear), tailored to the attachment of patch panels and cable routing rails. The mounting level may be positioned on a 50 mm pitch pattern. Minimum distance between levels 150 mm, maximum distance between levels 350 mm. Units U Packs of Model No. 31 1 pc(s). 7296.000 36 1 pc(s). 7297.000 40 1 pc(s). 7298.000 45 1 pc(s). 7299.000 Accessories: – Depth stays, see page 1079 Material: – Sheet steel, 2 mm Surface finish: – Spray-finished Colour: – Profile frame: RAL 7035 – Trim panel: RAL 5018 50 mm pitch pattern min. 150 – max. 350 Supply includes: – Torsionally stiff profile frame with 482.6 mm (19") punchings – Mounting accessories Baying connector for Data Rack For assembling rows of distributor frames, or for cable routing between data racks. Material: – Sheet steel Surface finish: – Spray-finished Depth stays for Data Rack For securing and stabilising two pairs of 482.6 mm (19") mounting angles in the Data Rack. The length of the depth stays is adjustable, and can accommodate the following spacings of mounting angles: 250, 300 and 350 mm. Material: – Sheet steel Length mm Packs of Model No. 53 3 pc(s). 7494.000 Colour: – RAL 7035 Supply includes: – Assembly parts Packs of Model No. 2 pc(s). 7401.000 Colour: – RAL 7035 Supply includes: – Assembly parts Slide rail, 2 U, static installation, continuous for two pairs of 482.6 mm (19") mounting angles To support heavy equipment in the Data Rack. The mounting dimensions of the slide rails were selected to enable them to be combined with 500 mm deep, 482.6 mm (19") component shelves. The mounting distance of the 482.6 mm (19") mounting angles is 350 mm. Material: – Sheet steel Packs of Model No. 2 pc(s). 7402.000 System accessories Surface finish: – Spray-finished Also required: – Second pair of mounting angles, see page 1079 Accessories: – 482.6 mm (19") fastener, 1 U, see page 1097 – Component shelf for frame attachment, see page 1006 Surface finish: – Zinc-plated Load capacity: – 500 N, static Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1079 482.6 mm (19") installation system Mounting angles Adaptor section, 482.6 mm (19") For enclosure height mm for VX, VX SE, enclosure width 600 mm For mounting electronic components, subracks and other 482.6 mm (19") equipment. Adaptor sections are easily shortened for partial assemblies. 1) U Packs of Model No. 8619.3001) 1600 33 2 pc(s). 1800 38 2 pc(s). 8619.310 2000 42 2 pc(s). 8619.3201) For the rear of electronic enclosures, see page 130 Material: – Sheet steel, 2 mm Supply includes: – Assembly parts Accessories: Note: – The 482.6 mm (19") measurement applies when mounting on the frame – Depth-offset installation is possible using punched sections with mounting flanges, 18 x 64 mm – 482.6 mm (19") fastener, 1 U, see page 1097 – Slide rail VX for adaptor section 482.6 mm (19") with attachment on one side, see page 1089 – Slide rail VX for adaptor section 482.6 mm (19") with attachment on both sides, see page 1089 – Punched section with mounting flange, 18 x 64 mm, see page 990 – Multi-tooth screws, see page 1004 – Metal multi-tooth screws, see page 1004 – Self-tapping screws, see page 1004 Installation examples for VX Offset installation position May be depth-mounted on a 25 mm pitch pattern on punched sections with mounting flanges In conjunction with a glazed door 25 25 Foremost installation position In conjunction with a sheet steel door 46 25 59 46 26 3 Installation examples for VX SE Foremost installation position On adaptor rail VX in conjunction with a sheet steel door On adaptor rail VX in conjunction with a glazed door  Adaptor sections 482.6 mm (19")  Adaptor rail VX  Punched section with mounting flange 18 x 64 mm 46 59 26 46 1 2 1080 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system Mounting angles Adaptor pieces, 482.6 mm (19") for VX, VX SE The 1 U sub-section of adaptor sections. For the installation of subracks and other 482.6 mm (19") equipment. Material: – Sheet steel, 2 mm Supply includes: – Assembly parts Note: – The 482.6 mm (19") measurement applies when mounting on the frame of 600 mm wide enclosures – Depth-offset installation in 600 mm wide enclosures is possible using punched sections with mounting flanges, 18 x 64 mm 482.6 mm (19") mounting angles, standard for VX IT Suitable for assembling a 482.6 mm (19") mounting level or for 482.6 mm (19") partial installation. The L-shaped design directly accommodates all commercially available installation kits for server systems, which are fastened directly to the 482.6 mm (19") system punchings. Applications: – For mounting a 482.6 mm (19") mounting level within the VX IT rack system Benefits: – Integral, bidirectional U labelling – Integral system punchings on a U pitch pattern on the front and sides, allows U-specific mounting of cable routing components for structured cabling Installation options: – Alternative installation widths from 21" – 24", depending on the mounting variant and rack dimensions selected Technical specifications: – Side punchings, round and square, on a U pitch pattern – Potential equalisation within the mounting level and with the locating frame is achieved via the assembly components – 482.6 mm (19") mounting hole including U centre fixing attachment to standard EIA 310 E Units U Packs of Model No. 1 4 pc(s). 8619.330 Accessories: – 482.6 mm (19") fastener, 1 U, see page 1097 – Punched section with mounting flange, 18 x 64 mm, see page 990 – Multi-tooth screws, see page 1004 – Metal multi-tooth screws, see page 1004 – Self-tapping screws, see page 1004 For enclosure height U Installation position Packs of Model No. 15 front 2 pc(s). 5302.100 15 rear 2 pc(s). 5302.101 24 front 2 pc(s). 5302.102 24 rear 2 pc(s). 5302.103 38 front 2 pc(s). 5302.104 38 rear 2 pc(s). 5302.105 42 front 2 pc(s). 5302.106 42 rear 2 pc(s). 5302.107 47 front 2 pc(s). 5302.108 47 rear 2 pc(s). 5302.109 Assembly instruction: – A combination with cross-member, depth stays or mounting bracket is required for attachment – Use of the different mounting options depends on the relevant enclosure dimensions Accessories: – Cross member, see page 1083 – Mounting bracket, see page 1082 – Depth stays, see page 1083 System accessories Material: – Sheet steel, 2 mm Surface finish: – Primed Colour: – RAL 9005 Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1081 482.6 mm (19") installation system Mounting angles 482.6 mm (19") mounting angles, dynamic for VX IT Suitable for assembling a 482.6 mm (19") mounting level or for 482.6 mm (19") partial installation. The L-shaped design can directly accommodate all commercially available mounting kits for server systems, which are fastened directly to the 482.6 mm (19") system punchings. Applications: – For mounting a 482.6 mm (19") mounting level within the VX IT rack system Benefits: – Integral, bidirectional U labelling – Integral system punchings on a U pitch pattern on the front and sides, allows U-specific mounting of cable routing components for structured cabling Installation options: – Alternative installation widths from 21" – 24", depending on the mounting variant and rack dimensions selected For enclosure height U Installation position Packs of Model No. 38 front 2 pc(s). 5302.152 38 rear 2 pc(s). 5302.153 42 front 2 pc(s). 5302.154 42 rear 2 pc(s). 5302.155 47 front 2 pc(s). 5302.156 47 rear 2 pc(s). 5302.157 Assembly instruction: – A combination with cross-member, depth stays or mounting bracket is required for attachment – Use of the different mounting options depends on the relevant enclosure dimensions Accessories: – Mounting bracket, see page 1082 – Cross member, see page 1083 – Depth stays, see page 1083 Technical specifications: – Side punchings, round and square, on a U pitch pattern – Potential equalisation within the mounting level and with the locating frame is achieved via the assembly components – 482.6 mm (19") mounting hole including U centre fixing attachment to standard EIA 310 E Material: – Sheet steel, 2.5 mm Surface finish: – Primed Colour: – RAL 9005 Supply includes: – Assembly parts Mounting bracket for VX IT 482.6 mm (19") mounting angles For mounting 482.6 mm (19") mounting angles in VX IT network/server racks. For racks with a width of 600 mm, they are attached directly to the frame and for racks with a width of 800 mm to the crossmember. Benefits: – Direct potential equalisation of the mounting angles via the attachment For enclosure width mm Packs of Model No. for VX IT 482.6 mm (19") mounting angles, standard 600 4 pc(s). 5302.110 for VX IT 482.6 mm (19") mounting angles, dynamic 600 4 pc(s). 5302.160 for cross member 800 4 pc(s). 5302.169 Design Material: – Sheet steel Surface finish: – Clear-chromated Accessories: – Cross member, see page 1083 Colour: – RAL 9005 Supply includes: – Assembly parts 1082 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system Mounting angles Cross member for VX IT mounting angles, 482.6 mm (19"), standard For width-variable mounting of standard 482.6 mm (19") mounting angles in 800 mm wide VX IT network/server enclosures. Benefits: – Symmetrical or asymmetrical installation supported – More space for cable routing or integration of a Liquid Cooling Unit (LCU) with one-sided, asymmetrical (laterally offset) installation – Ideal for integrating 482.6 mm (19") mounting angles for alternative installation with 21", 23", or 24" components – To boost the energy efficiency of an integral rack climate control system, the surrounding area around the 482.6 mm (19") mounting level can be covered with air baffle plates, enabling the more selective use of the cooling airflow and minimising exhaust airflows Material: – Sheet steel For enclosure width mm Packs of Model No. 800 2 pc(s). 5302.167 Note: – The maximum load capacity of one mounting level on a cross member is 4000 N per mounting level. Also required: – Mounting bracket, see page 1082 Assembly instruction: – It is attached directly onto the enclosure frame – A cross member mounting bracket is needed to screw-fasten the mounting angles to the cross member Accessories: – Air baffle plate, see page 1094 Surface finish: – Spray-finished Colour: – RAL 9005 Load capacity: – 4000 N Depth stays for 482.6 mm (19") mounting angles To accommodate 19" mounting angles. Benefits: – Particularly high load capacity up to 15,000 N – Enhanced stability thanks to improved load distribution – Symmetrical or asymmetrical installation supported – More space for cable routing or integration of a Liquid Cooling Unit (LCU) with one-sided, asymmetrical (laterally offset) installation – Ideal for integrating 482.6 mm (19") mounting angles for alternative installation with 21", 23", or 24" components Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – 2 depth stays each for top and bottom for enclosure width > 600 mm – Assembly parts For enclosure depth mm For enclosure width mm Packs of Model No. for VX IT 482.6 mm (19") mounting angles, standard 1000 > 600 1 pc(s). 5302.111 for VX IT 482.6 mm (19") mounting angles, standard 1200 > 600 1 pc(s). 5302.112 for VX IT 482.6 mm (19") mounting angles, dynamic 1000 > 600 1 pc(s). 5302.161 for VX IT 482.6 mm (19") mounting angles, dynamic 1200 > 600 1 pc(s). 5302.164 for VX IT 482.6 mm (19") mounting angles, standard for VX IT 482.6 mm (19") mounting angles, dynamic 1200 600 2 pc(s). 5302.166 Design System accessories Supply includes: – Assembly parts Also required: – Support rail, see page 1084 – Mounting bracket, see page 1082 Assembly instruction: – For the attachment of mounting angles in enclosures that are greater than 1000 mm deep and greater than 600 mm wide, additional mounting brackets are required – For the attachment of mounting angles in enclosures that are greater than 1000 mm deep and greater than 600 mm wide, an additional support rail for VX IT is required Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1083 482.6 mm (19") installation system Mounting angles Support rail for VX IT For the attachment of mounting angles in enclosures > 1000 mm deep and 600 mm or 800 mm wide when using depth stays. The support rail improves load distribution in network/server racks. Technical specifications: – Side round and square punchings Packs of Model No. 1 pc(s). 5302.170 Assembly instruction: – The support rail is screw-fastened onto the centre of the frame structure at right-angles below the depth stays Material: – Sheet steel Supply includes: – Assembly parts Mounting angles additional fastening attachment for VX IT 482.6 mm (19") mounting angles, standard Prevents the mounting angles from twisting in case of unevenly distributed loads. Secured directly between the mounting angle and a mounting section on the outer mounting level of the VX frame structure. Applications: – For fixing the 482.6 mm (19") mounting angle, standard, onto the outer mounting level For enclosure width mm Packs of Model No. 600 2 pc(s). 5302.123 800 2 pc(s). 5302.124 Also required: – Punched section with mounting flange, 18 x 64 mm, see page 990 Benefits: – Can also be used as individual fastening with 482.6 mm (19") partial installation Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – Assembly parts Mounting kit, 2 U for 482.6 mm (19") equipment Facilitates fast, simple integration of additional 2 U mounting space within an enclosure by attaching to the enclosure frame or to the existing mounting angles at the sides. The flexible slot fastening of the brackets means that the distance between the two installation brackets may be freely selected, so that other 482.6 mm (19˝) attachment dimensions may be implemented. The second row of holes is used for the optional configuration of additional mounting surfaces. Units U Packs of Model No. 2 2 pc(s). 7246.420 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts 1084 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system Mounting angles Mounting angles, 482.6 mm (19") Units U Packs of Model No. 6 2 pc(s). 7507.706 9 2 pc(s). 7507.709 12 2 pc(s). 7507.712 Material: – Sheet steel, spray-finished 15 2 pc(s). 7507.715 18 2 pc(s). 7507.718 Colour: – RAL 7035 21 2 pc(s). 7507.721 for FlatBox L-shaped bracket as 2nd attachment level Supply includes: – Assembly parts for fast, tool-free assembly. Note: – The 2nd attachment level should always be ordered in the same height as the basic enclosure – Partial configuration is not possible Adhesive measurement strip, 482.6 mm (19") With numerical labelling on a 482.6 mm (19") pitch pattern for clear identification of the various height units. Design Width mm Packs of Model No. Labelling range 1 – 56 U 6 1 pc(s). 7950.100 Applications: – For retrofitting to existing 482.6 mm (19") sections – For sticking onto the side adjacent to the system punchings Benefits: – Double-sided labelling allows the counting direction to be freely selected – Clear documentation of the various installed components Material: – Sheet steel, spray-finished Cover, magnetic for VX IT For optionally covering the front system punchings with complete air blocking of the front, or in the absence of installed cable fingers. With additional labelling strips for bidirectional U labelling. Design Labelling range 1 – 56 U Length Width m mm 5 15 Packs of Model No. 1 pc(s). 5501.895 System accessories Applications: – For retrofitting to existing 482.6 mm (19") sections Benefits: – Double-sided labelling allows the counting direction to be freely selected – Clear documentation of the various installed components Material: – Cover: PVC – Adhesive measurement strips: Plastic Supply includes: – Cover (front) – 2 adhesive measurement strips, self-adhesive, bi-directional Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1085 482.6 mm (19") installation system Slide rails Slide rail, 2 U, static installation for VX IT System punchings for mounting accessories and cooling active components. Units U Length mm Packs of Model No. 2 150 2 pc(s). 5501.400 Applications: – For mounting on a 482.6 mm (19") mounting level Installation options: – for 482.6 mm (19") mounting angles, standard – for 482.6 mm (19") mounting angles, dynamic Material: – Sheet steel Surface finish: – Zinc-plated Load capacity: – 300 N, static Supply includes: – Assembly parts Slide rail, 1 U, static installation Units U Length mm Distance between 482.6 mm (19") levels mm Applications: – For mounting on the front mounting level – To support heavy installed equipment 1 275 345 2 pc(s). 5501.410 1 375 445 2 pc(s). 5501.420 1 475 545 2 pc(s). 5501.430 Benefits: – Simply locate into the system punchings of the 482.6 mm (19") mounting brackets after adjusting the required 482.6 mm (19") distance between levels 1 575 645 2 pc(s). 5501.440 1 675 745 2 pc(s). 5501.450 for VX IT Side system punchings for mounting accessories and cooling components that expel to the side. Installation options: – for 482.6 mm (19") mounting angles, standard Material: – Sheet steel Packs of Model No. Assembly instruction: – The 482.6 mm (19") spacing between levels in the VX IT must be adjusted accordingly prior to installation Surface finish: – Zinc-plated Load capacity: – 800 N, static Supply includes: – Assembly parts Note: – Effective contact surface 35 mm per side 1086 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system Slide rails Slide rail, 2 U, static installation, heavy duty for VX IT Side system punchings for mounting accessories and cooling components that expel to the side. 482.6 mm (19") 482.6 mm (19") distance distance between levels, between levels, dynamic standard mm mm Packs of Model No. 320 325 2 pc(s). 5302.030 Applications: – For mounting on the front mounting level – To support heavy installed equipment 420 425 2 pc(s). 5302.031 520 525 2 pc(s). 5302.032 620 625 2 pc(s). 5302.033 Benefits: – Simply locate into the system punchings of the 482.6 mm (19") mounting brackets after adjusting the required 482.6 mm (19") distance between levels 720 725 2 pc(s). 5302.034 Installation options: – 482.6 mm (19") mounting angles, standard – 482.6 mm (19") mounting angles, dynamic Material: – Sheet steel Surface finish: – Zinc-plated Load capacity: – 2000 N, static Supply includes: – Assembly parts Note: – Effective contact surface 35 mm per side Slide rail, heavy-duty for TE For L-shaped mounting angles with a preconfigured clearance between levels of 740 mm. Easily and quickly installed due to locating brackets for the rear level. Distance between 482.6 mm (19") levels mm Contact surface, width mm Contact surface, depth mm 745 50 734 Packs of Model No. 2 pc(s). 7063.740 Material: – Sheet steel Surface finish: – Zinc-plated Load capacity (static): – 1000 N System accessories Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1087 482.6 mm (19") installation system Slide rails Slide rail for TE For mounting between the front and rear 482.6 mm (19") mounting levels. The slide rails can be used to support heavy 482.6 mm (19") components. Distance between 482.6 mm (19") levels mm Contact surface, width mm Contact surface, Packs of Model No. depth mm 395 85 324 2 pc(s). 7963.310 Material: – Sheet steel 495 85 424 2 pc(s). 7963.410 595 85 524 2 pc(s). 7963.510 Surface finish: – Zinc-plated 695 85 624 2 pc(s). 7963.610 795 85 724 2 pc(s). 7963.710 Load capacity (static): – 800 N Supply includes: – Assembly parts Slide rail, 1 U, depth-variable for VX IT, TE Applications: – For mounting on the front mounting level – To support heavy installed equipment – To adapt to individual distances between 482.6 mm (19") levels Distance between 482.6 mm (19") levels mm Load capacity (static) Packs of Model No. 600 - 900 800 N 2 pc(s). 5302.035 400 - 600 800 N 2 pc(s). 5501.460 Benefits: – Tool-free, time-saving one-man assembly from the enclosure front – All three mounting holes in the EIA system punchings are available for screw-fastening the equipment. – Alternatively, direct screw fastening in the TE 8000 to the 482.6 mm (19") system punchings is also possible Installation options: – 482.6 mm (19") L mounting angles, front and rear – 482.6 mm (19") mounting frames front and rear – for VX IT 482.6 mm (19") mounting angles, standard – for VX IT 482.6 mm (19") mounting angles, dynamic Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Note: – Effective contact surface 25 mm per side 1088 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system Slide rails Slide rail, 1 U, depth-variable for VX IT, TE For direct attachment to the 482.6 mm (19") system punchings on the mounting angles. The slide rails are pulled out to the required length and secured between the front and rear mounting level on the 482.6 mm (19") pitch pattern. Applications: – For mounting on the front mounting level Benefits: – No loss of U – Thanks to the thin support surface of only around 0.8 mm thickness, exceeding the U pitch pattern is generally avoided, provided the components do not exceed a maximum height of 43.5 mm. In this way, several units may be easily arranged on top of one another without offset. Distance between 482.6 mm (19") levels mm Packs of Model No. 390 - 550 2 pc(s). 7063.750 550 - 750 2 pc(s). 7063.752 Material: – Sheet steel Surface finish: – Zinc-plated Load capacity: – 20 kg static load Supply includes: – Assembly parts Note: – Effective contact surface 30 mm per side Installation options: – For attachment between the front and rear 482.6 mm (19") mounting level Slide rail VX for adaptor section 482.6 mm (19") with attachment on both sides Mounting between the 482.6 mm (19") front and rear adaptor sections or 482.6 mm (19") adaptor pieces. For enclosure depth mm Packs of Model No. 500 10 pc(s). 8613.151 600 10 pc(s). 8613.161 800 10 pc(s). 8613.181 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts for adaptor section 482.6 mm (19") with attachment on one side Mounted on the adaptor section , 482.6 mm (19"). Length mm Packs of Model No. 270 10 pc(s). 4531.001 System accessories Slide rail VX Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1089 482.6 mm (19") installation system 482.6 mm (19") installation Server telescopic slides Facilitate optimum accessibility to the servers, even when built-in. For servers with a maximum width of 426 mm. Material: – Sheet steel Load capacity: – 30 kg Supply includes: – Telescopic slide with mounting kit – Assembly parts Design Extension length mm For enclosure depth mm For 468.6 - 687.4 mm distance between levels 511.2 600 2 pc(s). 3659.180 For 559.0 - 789.0 mm distance between levels 596.4 800 2 pc(s). 3659.190 Packs of Model No. Note: – Only in conjunction with L-shaped mounting angles Adaptor kit, 3 U for 800 mm wide VX enclosures For fastening individual 482.6 mm (19") components, or as an additional mounting facility at the rear of the enclosure. The mounting level in the adaptor angle can be adjusted in 25 mm increments by up to 100 mm in the depth, leaving sufficient space for baying where patch panels or splicing boxes are used. Attachment is on the inner mounting level of the frame section or a suitable chassis in the enclosure depth. Units U Design Packs of Model No. 3 Installation position, centre 2 pc(s). 7246.100 Material: – Sheet steel Colour: – RAL 7035 Adaptor, 3 U Depth offset 100 mm This adaptor is used to recess 482.6 mm (19") mounting of equipment inside enclosures with 482.6 mm (19") installation in the foremost position, such as server or electronic enclosures. In this way, sufficient space can be gained in front of the mounting equipment to integrate patch panels or switches, whilst at the same time exploiting the maximum enclosure depth. Units U Packs of Model No. 3 2 pc(s). 7246.400 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts 1090 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system 482.6 mm (19") installation Adaptor, metric to 21"/19" Units U Height SU Packs of Model No. 1 2 2 pc(s). 7246.010 3 6 2 pc(s). 7246.030 6 11 2 pc(s). 7246.060 With this adaptor, 482.6 mm (19˝) assemblies may be fastened to metric (535 mm) mounting angles, or combined systems may be configured. Material: – Extruded aluminium section Drawer for one 482.6 mm (19") mounting level For front attachment to mounting angles, 482.6 mm (19"). With cover and telescopic slides to accommodate assignment lists, operating manuals and small parts. The small version of the 2 U variant is also suitable for mounting inside a swing frame. Material: – Sheet steel Supply includes: – Fully assembled – Security lock 12321 – Assembly parts Units U Width Clearance openings, width mm Clearance openings, depth mm Installation depth mm Colour Packs of Model No. 2 19" 411 419 427 RAL 7035 1 pc(s). 7282.035 2 19" 411 244 250 RAL 7035 1 pc(s). 7282.135 3 19" 411 419 427 RAL 7035 1 pc(s). 7283.035 2 19" 411 419 427 RAL 9005 1 pc(s). 5502.305 3 19" 411 419 427 RAL 9005 1 pc(s). 5502.325 Load capacity: – 200 N surface load, static for one 482.6 mm (19") mounting level For accommodation of small equipment and other accessories within a partitioned 482.6 mm (19") installation level. The small equipment box contains an adjustable mounting base which can be used to further sub-divide the box. Supply includes: – Small equipment box with brush strip – 1 shelf System accessories Small equipment box, 4 U, shielded Material: – Sheet steel – Brush strip: Plastic, UL 94-HB Surface finish: – Spray-finished Colour: – RAL 9005 Contact surface, width mm Contact surface, depth mm Height mm Width mm Depth mm Packs of Model No. 405 300 170 427 400 1 pc(s). 5501.900 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1091 482.6 mm (19") installation system 482.6 mm (19") installation 482.6 mm (19") installation aid Packs of Model No. 1 pc(s). 5502.110 for Network Cable Organizer For easier mounting of 482.6 mm (19") installed components within the mounting level. Applications: – To support heavy installed equipment Installation options: – For mounting on the front mounting level Material: – Sheet steel Colour: – RAL 9005 Load capacity: – max. 150 N Supply includes: – Assembly parts Note: – Effective contact surface 35 mm per side Blanking plate, 482.6 mm (19") Units U Packs of Model No. 1 3 pc(s). 1931.200 For installation in electronic enclosures or housings. 2 3 pc(s). 1932.200 Benefits: – To neatly finish off free locations within the mounting level. 3 3 pc(s). 1933.200 4 3 pc(s). 1934.200 6 3 pc(s). 1936.200 Material: – Aluminium, 3 mm 7 3 pc(s). 1935.200 9 3 pc(s). 1939.200 Surface finish: – Natural anodised 12 3 pc(s). 1937.200 Hinge for blanking plates Packs of Model No. 2 pc(s). 1950.000 Material: – Die-cast zinc Surface finish: – Zinc-plated Supply includes: – Assembly parts 1092 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system 482.6 mm (19") installation Blanking panel, 482.6 mm (19") As an extension cover or for population as required. Width: – 482.6 mm Material: – Sheet steel Colour RAL 7035 Units U Installation height mm Width Packs of Model No. 1 44 19" 2 pc(s). 7151.035 1.5 66 19" 2 pc(s). 7157.035 2 88 19" 2 pc(s). 7152.035 3 132.5 19" 2 pc(s). 7153.035 6 266 19" 2 pc(s). 7156.035 Colour RAL 9005 Blanking panel, 482.6 mm (19") Tool-free attachment The blanking panel is used to seal unused areas within the 482.6 mm (19") mounting level. Quick tool-free attachment means that it is easily integrated anywhere, and can also be removed again if necessary. The consistent use of blanking panels ensures targeted air routing in partially populated racks. Model No. Units U Installation height mm Width 1 44 19" 2 88 19" 2 pc(s). 7152.005 3 132.5 19" 2 pc(s). 7153.005 6 266 19" 2 pc(s). 7156.005 Packs of 2 pc(s). 7151.005 Installation height U Width Packs of Model No. 1 19" 10 pc(s). 5302.200 Material: – Plastic – Fire protection: Self-extinguishing , to UL 94 HB, halogen-free Colour: – RAL 9005 Supply includes: – Blanking panel, 1 U, with integral quick-fastening Vent trim panel, 482.6 mm (19") Units U Packs of Model No. 1 1 pc(s). 5302.201 For targeted air infeed from the front zone into the 482.6 mm (19") level. Also required: System accessories Applications: – Targeted routing of cold air from the raised floor via the front to the rear for cooling separate components – 482.6 mm (19") fastener, 1 U, see page 1097 – Multi-tooth screws, see page 1098 Benefits: – Vented surface area approx.  85 % perforated Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 9005 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1093 482.6 mm (19") installation system 482.6 mm (19") installation Ventilated front panels Units U Packs of Model No. Width 482.6 mm (19") For venting enclosures and housings. 1 3 pc(s). 2231.000 2 3 pc(s). 2232.000 Material: – Aluminium 3 3 pc(s). 2233.000 Surface finish: – Natural anodised Air baffle plate Assembly instruction: for VX IT 482.6 mm (19") mounting angles, standard Applications: – To separate the hot/cold zones within an enclosure with aisle containment or when using an LCP system. Benefits: – For selectively boosting the energy efficiency of a climate control system – Vertical brush strip for collision-free shielding with installed rail systems on the outer mounting level Material: – Sheet steel – Blanking panel: Plastic, UL 94-HB, halogen-free – Brush strip: Plastic, UL 94-HB – The vertical trim panels with brush strip may be fitted on both the front and rear 482.6 mm (19") mounting angles for partitioning. – The horizontal trim panels with brush strips can only be mounted on the front 482.6 mm (19") mounting angles. – 482.6 mm (19") mounting cut-outs integrated within the partitioning areas may optionally be sealed with the supplied blanking panels, or used to install additional components or for cable routing. Please see the product-specific scope of supply. Accessories: – 482.6 mm (19") fastener, 1 U, see page 1097 Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – 2 vertical trim panels – 2 horizontal trim panels – 4 brush strips – 4 cellular PU foam pieces – Assembly parts For enclosure width mm 1094 For enclosure height mm Product-specific scope of supply Packs of Model No. 600 1200 – 1 pc(s). 5302.010 800 1200 4 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.011 600 1800 – 1 pc(s). 5302.012 800 1800 6 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.013 600 2000 – 1 pc(s). 5302.016 800 2000 6 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.014 600 2200 – 1 pc(s). 5302.017 800 2200 6 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.015 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system 482.6 mm (19") installation Air baffle plate for VX IT 482.6 mm (19") mounting angles, dynamic For selectively boosting the energy efficiency of a climate control system. Applications: – To separate the hot/cold zones within an enclosure with aisle containment or when using an LCP system. Benefits: – Vertical brush strip for collision-free shielding with installed rail systems on the outer mounting level Material: – Sheet steel – Blanking panel: Plastic, UL 94-HB, halogen-free – Brush strip: Plastic, UL 94-HB Assembly instruction: – The vertical trim panels with brush strip may be fitted on both the front and rear 482.6 mm (19") mounting angles for partitioning. – The horizontal trim panels with brush strips can only be mounted on the front 482.6 mm (19") mounting angles. – 482.6 mm (19") mounting cut-outs integrated within the partitioning areas may optionally be sealed with the supplied blanking panels, or used to install additional components or for cable routing. Please see the product-specific scope of supply. Accessories: – 482.6 mm (19") fastener, 1 U, see page 1097 Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – 2 vertical trim panels – 2 horizontal trim panels – 4 brush strips – 4 cellular PU foam pieces – Assembly parts For enclosure width mm For enclosure height mm Product-specific scope of supply Packs of Model No. 600 1200 – 1 pc(s). 5302.000 800 1200 4 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.001 600 1800 – 1 pc(s). 5302.002 800 1800 6 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.003 600 2000 – 1 pc(s). 5302.004 800 2000 6 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.005 600 2200 – 1 pc(s). 5302.006 800 2200 6 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.007 600 2450 – 1 pc(s). 5302.008 800 2450 6 blanking panels, 482.6 mm (19"), 1 U 1 pc(s). 5302.009 482.6 mm (19") air duct for horizontal air routing Air duct, passive, for cold air supply to 482.6 mm (19") IT equipment installed at the rear of server racks; air is drawn in from the front. Width mm Height U Depth mm Packs of Model No. 482.6 1 223 - 356 1 pc(s). 3301.391 System accessories Benefits: – For superior air infeed to the rear 482.6 mm (19") components – Integral brush strip for cable entry of 482.6 mm (19") IT equipment – Supports front-to-back air routing – Depth-variable Material: – Sheet steel, spray-finished – Brush strip: Plastic, UL 94-HB Colour: – RAL 9005 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1095 482.6 mm (19") installation system 482.6 mm (19") installation Air duct for side air routing Air duct, passive, for cold air intake to 482.6 mm (19") IT equipment with side air inlet. Suitable for use in conjunction with all-round partitioning around the mounting level via air baffle plates and targeted management of the airflow through the air duct. Benefits: – For superior air infeed to the rear 482.6 mm (19") equipment with side air routing – Integral membrane cover allows cable entry to the rear – Depth-variable Installation options: – for 482.6 mm (19") mounting angles, standard Height U Depth mm For enclosure width mm 2 275 - 418 800 Packs of Model No. 1 pc(s). 3301.392 Also required: – Air baffle plate, see page 1094 Assembly instruction: – Only suitable for fitting on the front 482.6 mm (19") installation level – Can only be mounted in the area of the vertical 19" openings of the air baffle plate Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 9005 Supply includes: – Air duct – Adaptor for attaching to 482.6 mm (19") mounting angles – Magnetic strip to cover the remaining vertical openings in the air baffle plate Brush strip, vertical for VX IT Within the network distributor, this serves as a flexible infill panel which stylishly conceals the cable management area to the side of the 482.6 mm (19") mounting level. The brush strip facilitates convenient cable routing from the side and rear distributor area to the front connection level. The clearance required in front of the mounting level is at least 75 mm. The brush strip is mounted at the side on the vertical frame section, on horizontal or vertical punched sections. Length mm Bristle length mm For enclosure height mm Packs of Model No. 950 95 2000 4 pc(s). 7827.544 Assembly instruction: – The brush strip will need to be shortened when mounting on 482.6 mm (19”) mounting angles. Material: – Aluminium section, natural anodised – Brush strip: Plastic, UL 94-HB 1096 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system 482.6 mm (19") installation Mounting panel, 482.6 mm (19") Also required: For fast integration of smaller mounting units within the 482.6 mm (19") level, such as potential equalisation rails, distributor boxes, small electrical components etc. Simple screw-fastening of the components to the integral 25 mm system punchings. – 482.6 mm (19") fastener, 1 U, see page 1097 – Multi-tooth screws, see page 1098 Accessories: – 482.6 mm (19") fastener, 1 U, see page 1097 Material: – Sheet steel Units U Mounting surface width mm 2 450 – 1 450 RAL 9005 Colour for small appliances For secure attachment of non-482.6 mm (19")-conforming small appliances such as modems, power packs, routers etc. Angular support for mounting in the free space at the side between the 482.6 mm (19") level and the side panel on mounting angles or punched sections. Attachment of the components and connection cables can be achieved quickly and easily using nylon tape or cable ties. Also suitable for cable routing in the enclosure depth. 482.6 mm (19") fastener, 1 U with contact For simple screw connection of installation components within the 482.6 mm (19") mounting level. Simply slide onto the mounting angle from the inside and lock home. Benefits: – Fast positioning and installation instead of using individual cage nuts – Integral contacting for potential equalisation – Preconfigured 1 U support with 3 cage nuts, including centre attachment to standard EIA 310 – Supports multiple dismantling and reuse Packs of Model No. Zinc-plated 1 pc(s). 7151.300 Spray-finished 1 pc(s). 5302.204 Height mm Width mm Depth mm Packs of Model No. 150 350 97 1 pc(s). 7246.500 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Thread Packs of Model No. M5 24 pc(s). 2090.000 Note: – All enclosures in the Rittal range have already been tested within their tolerances for the use of 482.6 mm (19") fasteners. Suitability for use in enclosures from other manufacturers cannot be guaranteed. System accessories Support Surface finish Also required: – Multi-tooth screws, see page 1098 Material: – Sheet steel Surface finish: – Zinc-plated Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1097 482.6 mm (19") installation system 482.6 mm (19") installation Captive nuts For the attachment of rack-mounted electronic equipment, 482.6 mm (19") installed equipment and blanking plates to mounting angles, 482.6 mm (19"). For use with metal thickness from 0.8 – 2.5 mm. Optionally with or without contact of the installed equipment to the 482.6 mm (19") section/enclosure. Thread Design For metal thickness mm Packs of Model No. M5 without contact 0.8 - 2.5 50 pc(s). 2092.500 M5 with contact 0.8 - 2.5 50 pc(s). 2094.500 M6 without contact 0.8 - 2.5 50 pc(s). 2092.200 M6 with contact 0.8 - 2.5 50 pc(s). 2094.200 Possible alternative: – 482.6 mm (19") fastener, 1 U, see page 1097 Assembly screws For electronic equipment, 482.6 mm (19") installed components and blanking plates. Supply includes: – Plastic washers Thread Thread length mm Design M5 16 M5 Packs of Model No. Phillips-head screw 50 pc(s). 7094.120 16 Multi-tooth 25 50 pc(s). 7094.130 M6 16 Phillips-head screw 50 pc(s). 7094.100 M6 16 Slot-head screw 50 pc(s). 7094.110 M6 16 Multi-tooth 30 50 pc(s). 7094.140 Assembly instruction: – Max. tightening torque 3 Nm Front-mounting cage nut, 482.6 mm (19") The cage nut consists of an expanding nut which is simply inserted into the square attachment hole at the front and then secured with the assembly screw. When tightening the screw, the cage expands and thus secures the required components. Clamping range from 1.2 – 4.5 mm. Multi-tooth screw head, bit size T 30. Thread Thread length mm Design M6 16 Size of mounting hole 9.5 x 9.5 mm Packs of Model No. 50 pc(s). 2094.400 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Pan-head screws – Expanding nuts – Plastic washers 1098 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system 482.6 mm (19") installation Spring nuts with screws for T-slot mounting angle The spring nuts ensure flexible, secure mounting of accessory components on the T-slot mounting angles. Thread Thread length mm Design Packs of Model No. M6 10 Phillips-head screw 50 pc(s). 7000.990 Supply includes: – Spring nuts – Screws, self-locking Fibre-optic splicing box, depth-variable The 482.6 mm (19") splicing box is designed to accommodate splicing cassettes and can be installed in any network distributor with 482.6 mm (19") accommodation and used as a fibre-optic termination or distributor. The variable cassette fixture permits twist-proof installation of all standard splicing cassettes. The rear section of the splicing box is completely open for cable entry; a rubber cable clamp strip provides protection against dust. The fibre-optic cables can be secured with cable ties or cable clamps. The splicing box is infinitely depthadjustable up to 100 mm within the 482.6 mm (19") flanges. In addition, the splicing box may be fully withdrawn from the 482.6 mm (19") flanges. Two strain relief clips and cable routing clips for the fibre stock provide a solution to suit any fibre-optic wiring system. Units U Maximum no. of splicing cassettes 1 2 Installation Packs depth mm of 302 Model No. 1 pc(s). 7241.005 Also required: – Patch panels, see page 1100 Material: – Sheet steel Colour: – RAL 7035 Supply includes: – Splicing box – Cable routing clips – Cassette cover – Mounting accessories for patch panel System accessories Note: – Supplied without patch panels and splicing cassettes Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1099 482.6 mm (19") installation system 482.6 mm (19") installation Patch panels for fibre-optic splicing box, depth-variable, and fibre-optic breakout box, 1 U With cut-outs for population with fibre-optic couplings. Applications: – for fibre-optic splicing box, depth-variable, and fibre-optic breakout box, 1 U Material: – Sheet steel Colour: – RAL 7035 Units U For couplings Number of locations Packs of Model No. 1 E-2000 E-2000 duplex SC LC duplex 24 1 pc(s). 7241.024 1 SC duplex LC quad 12 1 pc(s). 7241.045 Fibre-optic splicing box with telescopic pull-out lockable The 482.6 mm (19") splicing box is designed to accommodate splicing cassettes and can be installed in any network distributor with 482.6 mm (19") accommodation and used as a fibre-optic termination or distributor. The rear section of the splicing box is completely open for cable entry; a rubber cable clamp strip provides protection against dust. The fibre-optic cables can be secured with cable ties or cable clamps; two strain relief clips and cable routing clips for the fibre stock provide a solution to suit any fibre-optic wiring system. Units U Maximum no. Installation of splicing Packs of Model No. depth mm cassettes 1 2 363 1 pc(s). 7170.535 2 4 363 1 pc(s). 7470.535 Also required: – Patch panel, see page 1101 Benefits: – The telescopic pull-out provides optimum access to the splicing cassettes and cable clamp – The variable cassette fixture permits twist-proof installation of all standard splicing cassettes – The security lock fitted at the front protects against unauthorised access Material: – Sheet steel Colour: – RAL 7035 Supply includes: – Splicing box – Cable routing clips – Security lock – Cassette cover – Mounting accessories for patch panel Note: – Supplied without patch panels and splicing cassettes 1100 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories 482.6 mm (19") installation system 482.6 mm (19") installation Patch panel for fibre-optic splicing box, lockable For splicing boxes, there is a choice of multiple panels with corresponding cut-outs for the installation of single or duplex fibre-optic couplings. Material: – Sheet steel Colour: – RAL 7035 Units U For couplings Number of locations Packs of Model No. 2 E-2000 E-2000 duplex SC LC duplex 24 1 pc(s). 7478.535 1 E-2000 E-2000 duplex SC LC LC duplex 20 1 pc(s). 7178.535 1 SC duplex LC quad 12 1 pc(s). 7169.535 2 ST 24 1 pc(s). 7474.535 Patch panels for small fibre-optic distributors Various patch panels with different connector types are available for individual configuration of small fibre-optic distributors. Material: – Sheet steel Colour: – RAL 7035 For couplings Number of locations single/duplex Max. no. of patch panels per housing Packs of Model No. ST 12 2 2 pc(s). 7462.000 SC E-2000 E-2000 duplex 12 / 6 2 2 pc(s). 7463.100 SC duplex 6 2 2 pc(s). 7463.200 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. System accessories Supply includes: – Patch panel – Assembly parts 1101 482.6 mm (19") installation system LSA connection system Support unit, 3 U Units U Model No. 3 7050.100 for LSA-Plus strips, max. 150 paired wires To accommodate a maximum of 15 LSA-Plus strips (each with 10 paired wires). 3 x 5 LSA-Plus connection strips 2/10, series 2, may be installed horizontally. Strip length 124 mm, height pitch pattern 22.5 mm. The support unit may be integrated in all 482.6 mm (19") mounting levels. The mounting level is recessed 75 mm behind the 482.6 mm (19") flanges. Integral shunting rings enable tidy routing and distribution of the telecommunication cables. Material: – Stainless steel Supply includes: – Support unit, 8 shunting rings Accommodation system, 2 U for LSA installation kit To accommodate LSA support systems within the 482.6 mm (19") mounting level. Units U Depth mm Packs of Model No. 2 98.5 2 pc(s). 7050.035 Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 7035 Supply includes: – Assembly parts 1102 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Handles Handle set for Comfort Panel For external mounting on corner pieces, also suitable for retro-fitting. Material: – Handle tube: Aluminium – Handle holder: Die-cast zinc – Covers: Polyamide Surface finish: – Handle tube: Natural anodised – Handle holder: Powder-coated Colour: – Handle holder: RAL 7024 – Covers: Similar to RAL 7024 Supply includes: – Handle tube, Ø 20 mm – 2 handle holders – 2 covers – Assembly parts Handle set for Optipanel For external mounting on corner pieces, also suitable for retro-fitting. Material: – Handle tube: Aluminium – Handle holder: Die-cast zinc – Covers: Polyamide Surface finish: – Handle tube: Natural anodised – Handle holder: Powder-coated Colour: – Handle holder: RAL 7035 – Covers: RAL 7024 For horizontal mounting With front panel width Packs of Model No. 482.6 mm (19") 1 pc(s). 6375.010 Note: – Shorter heights and widths can be achieved by cutting the handle tube to length – For enclosures with 74 mm installation depth, cannot be mounted on the same side as the support arm connection Accessories: – Clipboard, see page 1106 – Display board, see page 1106 For horizontal mounting With front panel width Packs of Model No. 482.6 mm (19") 1 pc(s). 6385.010 Note: – Shorter heights and widths can be achieved by cutting the handle tube to length – For enclosures with 100 mm installation depth, cannot be mounted on the same side as the support arm connection Accessories: – Clipboard, see page 1106 – Display board, see page 1106 Rittal System Catalogue 36/System accessories System accessories Supply includes: – Handle tube, Ø 25 mm – 2 handle holders – 2 covers – Assembly parts Further technical information available on the Internet. 1103 Handles Handle set Packs of Model No. For vertical and horizontal mounting on all surfaces. 1 pc(s). 2389.000 Overall length: 420 mm Material: – Handle tube: Aluminium – Tube holder: Die-cast zinc Surface finish: – Handle tube: Natural anodised Accessories: – Clipboard, see page 1106 – Display board, see page 1106 Colour: – Tube holder: RAL 7035 Supply includes: – 4 tube holders – 2 handle tubes TP aluminium strip For retrofitting externally on: – TP three-part/two-part – TP one-piece console – May be mounted on all enclosures/covers with 20 mm fold height (max. metal thickness 2 mm) Length: 1750 mm (easily cut to length for other dimensions) Sufficient for desk sections and consoles: – 3 x width 600 mm – 2 x width 800 mm – 1 x width 1000 mm + 1 x width 600 mm – 1 x width 1200 mm – 1 x width 1600 mm 1104 Further technical information available on the Internet. Length mm Model No. 1750 6731.120 Material: – Aluminium strip: Extruded aluminium section – Cover caps: Plastic Surface finish: – Aluminium strip: Natural anodised Colour: – Cover caps: RAL 7035 Supply includes: – 1 aluminium section – 6 plastic cover caps – Drilling template – Assembly parts Rittal System Catalogue 36/System accessories Handles Handles For horizontal or vertical attachment to the enclosure panel of: – Comfort Panel – Optipanel – Other enclosures or – Surfaces Mounting holes and surfaces without fins are required for assembly purposes. For the Comfort Panel version with fins, selectable via configurators at www.rittal.com/configurators, corresponding milling work may be carried out. To this end, please specify "Prepared for handle set 6107.XXX" for the command panel. Material: – Handle holder: Die-cast zinc – Cover bungs: Plastic – Handle tube: Aluminium Surface finish: – Handle tube: Powder-coated Colour: – Handle holder: RAL 7035 – Cover bungs: Similar to RAL 7035 – Handle tube: Similar to RAL 9006 Corner handle Packs of Model No. Supply includes: – 4 handle holders – 2 handle tubes – Assembly parts 2 pc(s). 6107.000 Mounting on enclosure corner External mounting on straight surface (90° rotation of handle holder) 163 153 131.5 Ø 6.5 45° 45 ° 92 (85) 131.5 217 Ø 6.5 25 132 163 25 U handle Supply includes: – 2 handle holders – 1 handle tube – Assembly parts For front panel size Packs of Model No. ≥7U 1 pc(s). 6107.100 482.6 mm (19") 1 pc(s). 6107.200 Accessories: 240 (75) 395 (230) System accessories 45° 92 Ø 25 – For 6107.200: Clipboard, see page 1106 – For 6107.200: Display board, see page 1106 25 458 (293) Ø 6.5 Note: – Dimensions in brackets for front size 7 U Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1105 External mounting accessories Clipboard For securing operating instructions or plans (A4 size) at eye level. Prepared for mounting on the righthand side; mounting on the left is also possible by unscrewing and moving the clip part. For mounting purposes, a straight tube length of ≥ 200 mm, Ø 20 mm or Ø 25 mm is required. Material: – Clipboard: Sheet steel – Clip part: Aluminium Surface finish: – Clip part: Natural anodised Colour: – RAL 7035 Height mm Packs of Model No. 225 315 1 pc(s). 6013.000 Also required: – Handle set 2389.000, see page 1104 or – Handle set for Comfort Panel, see page 1103 or – Handle set for Optipanel, see page 1103 or – U handle 6107.200, see page 1105 Display board Packs of Model No. with wall bracket To accommodate test plans, documents etc. in A4 format. 1 pc(s). 6013.100 Mounting – On surfaces – On a 25 mm pitch pattern of the enclosure frame or rail system – On handle set Ø 20 mm or Ø 25 mm Supply includes: – Display board – Wall bracket – Assembly parts 1106 Width mm Further technical information available on the Internet. Accessories: – Handle set 2389.000, see page 1104 or – Handle set for Comfort Panel, see page 1103 or – Handle set for Optipanel, see page 1103 or – U handle 6107.200, see page 1105 Rittal System Catalogue 36/System accessories Front assembly Front panel With threaded bolts M5 Width mm Height mm Model No. Material: – Aluminium, 3 mm 482.6 (19") 155.0 (3.5 U) 6027.010 482.6 (19") 310.3 (7 U) 6028.010 Surface finish: – Natural anodised 520 400 6028.014 520 500 6028.015 Note: – Mounting kits included with the supply of 520 mm wide standard enclosures. 520 600 6028.016 for Comfort Panel and Optipanel Also required: – Mounting kit for Comfort Panel 6053.800, see page 1108 – Mounting kit for Optipanel 6053.000/.500, see page 1108 Front panel Size WxH mm To fit Compact Panel Model No. Material: – Aluminium, 3 mm 178 x 200 6340.000 6028.500 178 x 350 6340.100 6028.510 Surface finish: – Natural anodised 252 x 200 6340.300 6028.530 252 x 350 6340.400 6028.540 Cover plate Support arm connection Surface finish Model No. ▭ 90 x 71 mm Spray finished in RAL 7024 6505.200 Ø 130 mm Zinc-plated, passivated 6505.500 ▭ 120 x 65 mm Zinc-plated, passivated 6505.100 for Compact Panel for support arm connection For secure sealing of an unrequired support arm connection in the enclosure. Material: – Sheet steel Supply includes: – Seal and assembly parts Rittal System Catalogue 36/System accessories System accessories Note: With – Comfort Panel – Optipanel – Compact Panel If there are already 2 support arm cut-outs provided, a cover plate is included with the supply of the enclosure Further technical information available on the Internet. 1107 Front assembly Mounting kit for Optipanel For installation of – Aluminium front panels – Command panels – Keyboards for drilled holes For front panels Thread Model No. Supply includes: – Packs of 30 retaining claws, cage nuts, screws and sealing washers Other M4 6058.000 Rittal and others M5 6053.000 for threaded bolts For front panels Thread Model No. Other M4 6058.500 Rittal and others M5 6053.5001) Supply includes: – Packs of 10 retaining claws and cap screws 1) For the installation of TFT monitors 15", 17" and 19" for screw clamp For direct installation of Supply includes: – Packs of 4 pressure plates, 4 attachment strips Siemens Sinumerik: OP 010, OP 010C, OP 012, OP 015, OP 019, MCP 483, PP 012, Qwerty 19˝, KB 483C, TP 015A Note: – The command panels MP 377 12" Touch, MP 377 15" Touch are installed using an adaptor plate Siemens Simatic: Panel PC 477C, 577C, 677C: 12.1"-Touch, 15.1˝-Touch, 12.1"-Key, 15.1"-Key, 19"-Touch1), 22"-Touch1), Flat Panel1) 12", 15", 19" Model No. 6053.210 Industrial Flat Panel: IFP 1200 Touch, IFP 1500 Touch, IFP 1200 Key, IFP 1500 Key, IFP 1900 Touch, IFP 2200 Touch Industrial Thin Client: ITC 1200, ITC 1500, ITC 1900, ITC 2200 The mounting set can only be installed vertically 2 packs are required 1) Mounting kit for Comfort Panel For the installation of aluminium front panels, command panels and keyboards. 1 Supply includes: – 6053.800: 20 each of retaining claws, cage nuts, screws, nuts and sealing washers – 6053.300: 8 medium retaining claws, 8 short retaining claws, 4 long retaining claws. Note: – The command panels listed are merely a reduced selection of standard units from various manufacturers which support direct installation into the Comfort Panel. 2  6053.800  6053.300 For drilled holes/bolts/front panel mounting from behind Thread Model No. M5 6053.800 For direct installation of e.g. operating fronts, monitors, panel PCs For installation of Model No. Siemens Sinumerik: OP 010, OP 010 C, OP 012, OP 015, OP 015 A, OP 019, MCP 483 C, MCP 483, PP 012, PP 012 Erweiterung, MCP, KB 483 C, Qwerty 19" Siemens Simatic: TP 1500 Comfort, TP 1900 Comfort, TP 2200 Comfort, KP 900 Comfort, KP 1200 Comfort, KTP 1000 Basic, KTP 1500 Basic Panel PC 477C, 577C, 677C: 12.1" Key, 12.1" Touch, 15.1" Key, 15.1" Touch, 19" Touch, 22" Touch1) 6053.300 MP 377 12" Touch, MP 377 15" Touch, MP 377 19" Touch Industrial Flat Panel: IFP 1200 Touch, IFP 1500 Touch, IFP 1200 Key, IFP 1500 Key, IFP 1900 Touch, IFP 2200 Touch Industrial Thin Client: ITC 1200, ITC 1500, ITC 1900, ITC 2200 B & R: Automation Panel, Panel PC 1) 1108 Further technical information available on the Internet. 2 packs are required Rittal System Catalogue 36/System accessories Monitors TFT monitor Model No. Installation variant for surfaces and command panels. Width mm Size Benefits: – High-quality industrial design – Reduced installation work thanks to integral front frame – No additional ventilation required – Very small installation depth (45 mm) 1) Material: – Front frame: Aluminium Height mm Touch Without1) resistive, USB 15" 430 343 6450.010 6450.070 17" 482.6 354.8 6450.020 – 19" 482.6 399.3 6450.170 – With anti-reflection coated safety glass screen Note: – Other variants as resistive touchscreen with serial or USB interface are also possible Surface finish: – Powder-coated Colour: – RAL 7035 Also required: Protection category IP to IEC 60 529: – IP 65 (at the front) – Mounting kit 6053.800 (when installing in Comfort Panel), see page 1108 – Mounting kit 6053.500 (when installing in Optipanel), see page 1108 – Power pack 6450.050, see page 1109 and – Connection cable 6450.060, see page 1109 Supply includes: – Seal, hex nuts (for installation in surfaces), VGA cables, threaded bolts M5 for rear mounting. Touch variants additionally with integral connection cable and driver CD-ROM. Technical specifications 15" 17" 19" Resolution of display (max. pixels) 1024 x 768 1280 x 1024 1280 x 1024 Resolution of controller/million colours VGA-XGA/16.71) VGA-SXGA/16.7 VGA-SXGA/16.7 Brightness cd/m2 400 350 350 Contrast ratio 700:1 1000:1 1000:1 H-Sync. kHz/V-Sync. Hz 31.4 – 80/60 – 75 31.4 – 80/60 – 75 31.5 – 80/60 – 75 Reading angle horizontal (right/left) 80°/80° 85°/85° 85°/85° Reading angle vertical (top/bottom) 70°/70° 80°/80° 85°/85° Backlight/operating time h LED/min. 50000 On-screen display (OSD) Operating buttons on the rear VGA input/DVI-D VGA (D-SUB HD 15-pole)/DVI-D jack Rated voltage V (DC) 12 Power consumption (W) 15 20 20 Operating temperature/storage temperature 0 °C…+50 °C/ -40 °C…+85 °C 0 °C…+50 °C/ -30 °C…+85 °C 0 °C…+50 °C/ -20 °C…+60 °C Max. humidity during operation and storage, non-condensing 90% relative humidity for 240 h 80% rel. humidity for 300 h at 50 °C 80 % relative humidity 1) For 6450.070: 16.2 Power pack Packs of Model No. for TFT monitor – With IEC 60 320 connector C14 for C13 connection – Integral cable (1.5 m) for connecting to the TFT monitor 1 pc(s). 6450.050 System accessories Material: – Enclosure: Plastic Dimensions, W x H x D: 112 x 31 x 47 mm Technical specifications: – Input voltage: 100 – 240 V – Output voltage: 12 V (DC) – Operating temperature: +10 °C...+40 °C – Storage temperature: -10 °C...+80 °C Connection cable Packs of Model No. for power pack With IEC 320 socket C13 at one end for C14 connectors. 1 pc(s). 6450.060 Length: 1.5 m Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1109 Keyboards, supports and drawers TFT holder Suitable for mounting TFTs with VESA 75/100 adaptation up to 21" on – Attachment CP 40, 6501.070, see page 187 – Attachment CP 60 for support arm connection ▭ 120 x 65 mm, 6206.360, see page 195 – Vertical support arm via tilting adaptor +100°/-60°, 6206.460, see page 209 Dimensions mm Packs of Model No. 477 x 372 x 110.5 1 pc(s). 2383.030 Keyboard layout Packs of Model No. German 1 pc(s). 6002.130 Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 7024 Keyboard, pull-out with integral trackball Super-slimline keyboard with cursor keys and trackball. The handle also serves as a hand rest. The 10° angled pullout ensures ergonomic working. For installation in: – Any sufficiently large surface (e.g. door, side panel) – Front panels – Directly in a suitably sized Comfort Panel and Optipanel, selectable via configurators at www.rittal.com/configurators Material: – Sheet steel Surface finish: – Front panel: Powder-coated Colour: – RAL 7035 Protection category IP to IEC 60 529: – IP 65 (at the front, sealed) Technical specifications: Keyboard: – 84 short-stroke keys, IBM-AT compatible (MF2), incl. cursor keys – With integral trackball – Interface: 2 x USB – Operating temperature: +5 °C...+50 °C – Storage temperature: -10 °C...+60 °C – Humidity: max. 95 % (non-condensing) ca. 155 8.5 16.5 (55) ° (71) 10 88 482.6 8.5 16.5 150 12.5 420 Mounting cut-out 155 465 ± 0.3 71 5 62 Ø M4 5 155 3 8.5 450 465 1110 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Keyboards, supports and drawers Built-in keyboard 482.6 mm (19")/4 U with integral touchpad The integral touchpad eliminates the need to install an additional, correct protection category mouse, which in turn reduces cabling. The short stroke keys are easily identified by edge embossing, less force is required to operate them, and they have a good tactile action Keyboard layout Packs of Model No. German 1 pc(s). 6446.030 Also required: – Mounting kit 6053.800 (when installing in Comfort Panel), see page 1108 – Mounting kit 6053.500 (when installing in Optipanel), see page 1108 Benefits: – The separate number pad enables the parameters to be entered quickly – Sealed, wipeable surface finish – High level of mechanical and chemical resistance as per DIN 42 115. 10 1 Technical specifications: – Number of keys: 105 – Front panel dimensions: 482.6 x 177.0 mm (19" x 4 U) – Keyboard depth: 30 mm – Installation depth: 27 mm – 12 M5 x 20 threaded bolts at the rear – Actuation travel/force: 0.3 mm/2.6 N – Service life: 3 million switching cycles – Operating temperature: -40 °C...+90 °C – Touchpad resolution, capacitive: 40 pixels/mm – Interface: USB Ø 7 101.6 145 177 10 165 420 451 482.6  Support surface Material: – Front panel: Aluminium Protection category IP to IEC 60 529: – IP 65 (at the front) Supply includes: – USB connection cable, length 1.8 m – Seal – Drilling template – Assembly parts for surfaces Fold-out tray Accessories: for keyboard and mouse For installation in – 600 and 800 mm wide doors – 482.6 mm (19") swing frames and enclosures – Mousepad support, pull-out, see page 1112 Mounting cut-out Standard double-bit lock insert may be exchanged for 41 mm lock inserts, type C, see page 941 482.6 (682.6) 454 (654) 195 (295) Surface finish: – Flap, side parts: Textured paint – Tray: Natural anodised Colour: – Flap, side parts: RAL 7035 Ø 5. 5 1 Protection category IP to IEC 60 529: – IP 55 System accessories 305 195 (295) 324 32 355 (8 U) Material: – Flap: Sheet steel – Side parts: Cast aluminium – Tray: Extruded aluminium section – Double-bit lock insert: Stainless steel (6 x)  Support surface Protection category NEMA: – NEMA 12 1) For door width mm External dimensions WxHxD mm Installation depth mm Max. keyboard dimensions WxHxD mm Model No. 600 482.6 (19") x 355 (8 U) x 126 93 405 x 45 x 245 405 x 45 x 1901) 2379.600 800 682.6 x 355 (8 U) x 126 93 605 x 45 x 245 605 x 45 x 1901) 4751) x 45 x 245 2379.800 Maximum keyboard size with holder for mouse Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1111 Keyboards, supports and drawers Support for mousepad, pull-out Packs of Model No. with mouse holder For screw-fastening into the fold-out tray 2379.600/ 2379.800, see page 1111. To fit all standard mousepads up to 250 x 205 mm. 1 pc(s). 2379.900 Utility bar, vertically hinged Packs of Model No. To support standard keyboards during programming and servicing work. Mounting distance of utility bars for problem-free insertion: at least 300 mm. Depth adequate for keyboards up to max. 210 mm. 2 pc(s). 6514.200 Colour: – RAL 7035 Supply includes: – Assembly parts For mounting beneath – Comfort Panel1) – Optipanel2) – Any sufficiently large surface, such as: – Worktops IW – Command panel AX with handle strips Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts on – Vertical surfaces (doors/side panels) Min. front panel width 1) 385 mm 2) 405 mm After use, the utility bars fit securely and neatly under the mounting surface, thus giving the operator more space to move around. 1112 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Keyboards, supports and drawers Drawer 482.6 mm (19")/2 U for keyboard and mouse For installation in: – Any sufficiently large surface (e.g. door, side panel) – 482.6 mm (19") system punchings – Front panels – Directly in a suitably sized Comfort Panel and Optipanel, selectable via configurators at www.rittal.com/configurators Suitable for – Accommodation of keyboards up to max. 390 x 32 x 139 mm – Support of standard commercially-available mouse or trackball Version: – Drawer: With stay – Front panel: With security lock (lock no. 12321) and handle strip Width mm U Depth mm Model No. 482.6 (19") 2 150 6002.000 Material: – Drawer housing: Sheet steel – Drawer and front panel: Aluminium Surface finish: – Drawer housing: Zinc-plated – Drawer and front panel: Natural anodised Protection category IP to IEC 60 529: – IP 54 Supply includes: – Assembly parts for installation in Comfort Panel/ Optipanel command panels 482.6 2 465 284 148.5 139 46 75 60 88 71.4 31 106 4.5 441 Mounting cut-out (for installation in surfaces) 390 79 77 90 139 71.4 Ø 4.5/M4 450 System accessories 465 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1113 Keyboards, supports and drawers Drawer for keyboard and mouse Packs of Model No. 1 pc(s). 6003.000 with mousepad support For installation in: – Any sufficiently large surface (e.g. door, side panel) – Front panels Suitable for accommodating – Keyboards up to a maximum of 460 x 42 x 170 mm – Standard mouse and mousepad Material: – Drawer and housing: Sheet steel – Front panel: Aluminium Surface finish: – Drawer and housing: Spray-finished – Front panel: Natural anodised Protection category IP to IEC 60 529: – IP 54 Version: – Drawer and housing: With side pull-out mousepad support and tray – Front panel: With 3 mm double-bit lock insert, folds out as handrest Supply includes: – Assembly parts Accessories: – Standard double-bit lock insert may be exchanged for 27 mm lock inserts, type A, see page 941 260 270 472 260 Mounting cut-out for installation in surfaces 80 Ø 5.5/M5 133 475 141 206 467 1 482.6 Keyboard drawer 1 U for two 482.6 mm (19") mounting levels This space-saving keyboard drawer is screw-fastened to the front and rear 482.6 mm (19") mounting angles. The installation spacing is infinitely adjustable from 460 – 750 mm. It is fully extendible, lockable, with strain relief and hinged cable support. The drawer is suitable for accommodating 482.6 mm (19") keyboards.  Front trim panel Distance between levels mm Model No. 460 – 750 7281.200 Interior dimensions: – W x H x D: approx. 420 x 40 x 220 mm Material: – Sheet steel Colour: – RAL 7035 Supply includes: – Assembly parts, excluding keyboard Note: – Monitor/keyboard unit, 1 U, see page 822 1114 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Keyboards, supports and drawers Keyboard drawer 2 U for one 482.6 mm (19") mounting level For keyboards up to 430 mm wide and 250 mm deep with the front panel folded over. Colour Packs of Model No. RAL 7035 1 pc(s). 7281.035 RAL 9005 1 pc(s). 5302.205 Installation depth: 390 mm Height: 2 U Material: – Sheet steel with aluminium front Surface finish: – Spray-finished Supply includes: – Lockable drawer with handles – Folding front – Pull-out mousepad – Mouse support – Practical cable entry and strain relief Support for mousepad for command panels and surfaces The angle of the mousepad support is individually adjustable. Two holes are needed on the enclosure for attachment purposes. Material: – Sheet steel Weight kg Packs of Model No. 1.0 1 pc(s). 2381.000 Accessories: – Holder for mouse, see page 1116 Surface finish: – Zinc-plated Supply includes: – Assembly parts for command panels or surfaces Benefits: – Adjustable to different keyboard depths via a simple slide function – Connection to command panels with support arm connection at the top or bottom – Easily adjustable tilt angle – Open support at the side prevents dirt from being deposited Installation options: – Operating housing AX with handle strips – Operating housing AX for desktop TFT up to 24" – External mounting on vertical surfaces and beneath horizontal surfaces Width mm Weight kg Packs of Model No. 430 3.0 1 pc(s). 6321.010 Supply includes: – Support fully preassembled – Nylon tape for attaching the keyboard – Assembly parts Accessories: – Mousepad support, vertically hinged, see page 1116 Technical specifications: – Support surface fully depth adjustable from 128 – 228 mm System accessories Keyboard support 21 2.5 12 8 Material: – Sheet steel – Hand rest: Extruded aluminium section Surface finish: – Textured paint – Handrest: Natural anodised 50 Colour: – RAL 7035 31 2.5 22 8 40 0° – 200° Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1115 Keyboards, supports and drawers Mousepad support, vertically hinged For mounting on the left/right, beneath the keyboard support. Latches home automatically, both when retracted and extended. With mounting holes for holder for mouse 2382.000. Material: – Sheet steel Packs of Model No. 1 pc(s). 2383.020 Accessories: – Holder for mouse, see page 1116 44 23 Surface finish: – Zinc-plated Supply includes: – Assembly parts and mousepad, stuck on with adhesive 211 20 312 30 Holder for mouse Packs of Model No. To fit mousepad support and for secure accommodation of a standard mouse. 1 pc(s). 2382.000 Material: – Sheet steel Surface finish: – Zinc-plated Supply includes: – Assembly parts Paper removal flap For installation in surfaces Facilitates easy removal of pages from the printer without opening the enclosure door. Acrylic glazed flap with magnetic lock. Base for tubular door frame The space-saving alternative to component shelves for accommodating tower PCs (maximum 20 kg). For screw-fastening to the tubular door frame of 600 mm wide enclosures. Load capacity: – 20 kg Paper removal flap Colour Packs of Model No. A4 RAL 7015 1 pc(s). 6903.200 Width x height x depth mm Packs of Model No. 445 x 159 x 230 1 pc(s). 6902.950 Also required: – Support strip for direct screw-fastening to the tubular door frame, see page 952 Material: – Sheet steel Surface finish: – Spray-finished Colour: – RAL 7015 Supply includes: – Retaining strap and assembly parts 1116 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Interfaces Interface extension with wall connection and built-in RJ45 module Surface finish: – Housing: Nickel-plated – Cover: Natural anodised Protection category IP to IEC 60 529: – IP 66/67 (with protective cap closed) For extending the internal enclosure interfaces – e.g. of industrial PCs and switches – up to the outside of the enclosure. The wall connection only needs the same space as a switch. Anti-twist guard Benefits: – Rapid access for maintenance work – The protection category of the enclosure is preserved – The lock nut cuts automatically into the spray-finish or eloxal layer, thereby creating a conductive connection – Captive protective cap Material: – Housing: Brass – Cover: Aluminium – Seal: Polyamide 20.8 with (USB only) Ø 22.3 Ø 22.3 Material thickness: 1 – 6 mm Wall connection Inside Type A jack Type A connector USB 2.0 RJ45 Jack RJ45 Connector Jack Jack Interface flap for RC circuit-breakers According to standard EN 60 204-1, all circuits with a rated current of ≤ 20 A that supply sockets in or on machine enclosures must be fused with a residual-current circuit-breaker with a rated differential current of ≤ 30 mA. Prepared for the installation of standard, 2-pole RCBO circuit-breakers. Applications: – As programming interface for controllers – As maintenance access for networks – For temporary connection of additional equipment – For quick connection to existing network structures – For programming and maintenance of integral components Version: – Spring-action terminals max. 2 x 2.5 mm, connection at rear Length m Packs of Model No. 0.5 1 pc(s). 2482.210 1.0 1 pc(s). 2482.220 2.0 1 pc(s). 2482.230 0.5 1 pc(s). 2482.700 1.0 1 pc(s). 2482.710 2.0 1 pc(s). 2482.720 – 1 pc(s). 2482.730 Functions: – A snap fastener ensures reliable sealing. This may be locked if required. Material: – Mounting frame: Plastic PBT (black) – Plastic flap: Polycarbonate (semi-transparent) Protection category IP to IEC 60 529: – IP 65 Supply includes: – Interface flap, complete, consisting of plastic frame, socket (VDE), RJ45 (jack/jack, Cat 5e) and cut-out for RC circuit-breaker – Knockout provided for USB A (jack/jack) – 3 mm double-bit with slot-in rotary knob Note: – Interface flap may only be used with fitted RC circuit-breaker System accessories Version without (USB/RJ45) Benefits: – Protection against fault currents and overload – Standard-compliant fuse to EN 60 204 – The RC switch may be reset without opening the enclosure – Spring mechanism raises the unlocked cover by 30°, ensuring that you do not forget to close the cover Width mm Height mm Required mounting cut-out mm Installation depth mm Rated operating voltage V, ~, Hz Rated current A Packs of Model No. 131 127 117 x 91 70 250, 1~, 50/60 10 - 16 1 pc(s). 2482.600 Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1117 Interfaces Interface flap, modular The mounting frame has a flap which snaps into position at various opening angles from 90 to 180°. A snap fastener ensures reliable sealing. This may be locked if required. For universal use in all situations where rapid access to interfaces and sockets is needed. The affected enclosure remains closed and is therefore protected from ambient influences and unauthorised access. Space-saving installation e.g. – in small enclosures and compact enclosures as a programming interface for controllers – in IT and industrial distributors as maintenance access for networks – in PC enclosures and console systems for the temporary connection of additional equipment – in mobile industrial workstations for rapid connection to existing network structures – in command panel systems for programming and maintenance of integral components. 1 Material: – Mounting frame and metal flap: Die-cast zinc – Plastic flap: Polycarbonate (semi-transparent) – Lock: Polycarbonate, RAL 7024 Surface finish: – Mounting frame and metal flap: Matt nickel-plated Colour: – Lock: RAL 7024 Protection category IP to IEC 60 529: – IP 65 (with sealed flap and proper assembly) 2 Description Mounting 3 4 cUR UR Packs of Model No. frame1)  Single, with plastic flap (semi-transparent) – – 1 pc(s). 2482.300 Double, with plastic flap (semi-transparent) – – 1 pc(s). 2482.310  Single, with metal flap  Double, with metal flap ◾ ◾ 1 pc(s). 2482.320 ◾ ◾ 1 pc(s). 2482.330 – – 1 pc(s). 2482.4003) – – 1 pc(s). 2482.4103) Socket modules  Germany (VDE), spring-action terminals max. 2 x 2.5 mm2, connection at rear  Germany (VDE), screw terminals max. 6 mm2, connection at rear, colour: yellow (RAL 1016), for installation in front of master switch Interface inserts 5 6  2 x SUB-D9 (jack/pin)  SUB-D9 (jack/jack) 2 x USB A (jack/jack) RJ45 (jack/jack, Cat. 5e), SUB-D9 (jack/jack), SUB-D9 (pin/pin) 2 x RJ45 (jack/jack, Cat. 5e) USB A (jack/jack), RJ45 (jack/jack, Cat. 5e), SUB-D9 (jack/pin)  Blanking plate (slimline), for individual population, usable area: 45 x 75 mm ◾ ◾ 1 pc(s). 2482.500 ◾ ◾ 1 pc(s). 2482.510 ◾ ◾ 1 pc(s). 2482.5402) ◾ ◾ 1 pc(s). ◾ ◾ 1 pc(s). 2482.5602) 2482.550 ◾ ◾ 1 pc(s). 2482.5702) ◾ ◾ 1 pc(s). 2482.590 1) Electrically conductive 2) Conductively linked to mounting frame 3) Rated voltage: 250 V, Rated current: 10 – 16 A All SUB-D interfaces may be rotated while in use 8 Interface flap, single approx. 16 7 approx. 65 Mounting cut-out 91 A approx. 12 approx. 116 approx. 120 max. R2 Permissible material thickness: 1 – 5 mm open lock 9 52 10 approx. 21 approx. 7 A Contact surface approx. 7 approx. 38 approx. 16 Interface flap, double approx. 130 Mounting cut-out open open lock lock approx. 61 approx. 61 approx. 21 91 A approx. 12 approx. 12 12 approx. 116 11 approx. 120 max. R2 117 approx. 7 approx. 7 approx. 35 1118 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Signal pillars System accessories For real-time display of operating statuses Rittal System Catalogue 36/System accessories 1119 Signal pillars at a glance Plug-and-play system Signal pillar, 3-way LED For wall/base mounting For conduit mounting Model No. 2372.102 2372.101  LED steady light component 24 V AC/DC, Acoustic component 230 V, 102 dB  Mounting component for < 35 mA  LED steady light component 230 V, < 35 mA  LED flashing light component 24 V AC/DC  LED flashing light component 230 V  Stroboscopic light component 24 V (DC), < 35 mA  Acoustic component 24 V AC/DC, 95 – 105 dB (continuous tone or pulsating) (adjustable volume and choice of 8 sounds) Mounting component for support arm system CP 40, steel – angle piece 90° 6501.140  Mounting component for support arm system CP 60 – Angle adaptor 90° for support arm combination CP 60 to CP 40 6206.640 – Angle coupling 90° 6206.380 – Angle piece 90° 6206.600 – Intermediate hinge 6206.620 – Wall-mounted hinge 6206.740 – Top-mounted joint 6206.700 support arm system CP 120 – Angle coupling 90° 6212.380 – Angle piece 90° 6212.600 – Intermediate hinge 6212.620 – Wall-mounted hinge 6212.740 – Top-mounted joint 6212.700  Mounting component for support arm system CP 180 – Angle piece 90° 6218.600 – Top-mounted joint 6218.700 Acoustic component 24 V AC/DC, 102 dB (adjustable volume and choice of 8 sounds) Acoustic component 230 V, 95 – 105 dB (continuous tone or pulsating) Mounting component for conduit mounting Label panel Base with integral conduit, Ø 25 mm, 110 mm long Individual base Model No. 2374.150 1120 Individual conduit, 250 mm long Individual conduit, 400 mm long Angle bracket for conduit mounting 2374.030 2374.050 Model No. 2374.000 2374.010 2374.020 Rittal System Catalogue 36/System Accessories Modular system Acoustic component Optical component for signal pillar, modular Red Green Yellow Clear Blue 1 2372.001 2372.011 2372.021 2372.031 2372.041 2 2370.151 2370.161 2370.171 – 3 2370.501 2370.511 2370.521 2370.531 4 2370.551 – 2370.571 – – 5 2371.001 – 2371.021 – – Model No. Model No. 6 2376.001 – 7 2376.011 2370.541 8 2376.021 9 2376.031 Connection component for signal pillar, modular For conduit mounting For wall/base mounting Model No. 2368.001 Mounting component for support arm systems 11 Mounting component for wall/base mounting 12 Bracket for connection component 6206.900 For side cable outlet Model No. Model No. 2375.030 System accessories 10 2368.002 6212.900 Rittal System Catalogue 36/System Accessories 2374.040 2374.080 1121 Signal pillars Benefits: – Complete plug-and-pay solution – Extremely long service life of the LEDs (max. 100,000 hours, therefore maintenance-free) – Minimal assembly work and warehousing costs Technical specifications: – 3-stage: red, yellow and green – Operating voltage: 24 V AC/DC – Electrical connection: Screwless spring terminals – Lamp: LED – Transmission angle: 3 x 120° – Operating temperature: -20 °C...+50 °C – Flashing function: Controllable via PLC – Cable entry: Metric screwed cable gland M12 x 1.5 for cable diameter 3.0 – 6.5 mm H mm Model No. 1 pc(s). 210.5 2372.101 1 pc(s). 212.0 2372.102 Design Packs of for conduit mounting for base mounting Accessories: – Mounting component, see page 1125/1126 – Label panel, see page 1127 Ø 70 16 Signal pillar, 3-way LED 56 H 56 56 Protection category IP to IEC 60 529: – IP 65 1122 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Signal pillars Signal pillar, modular Benefits: – Simple assembly and contact using bayonet fastener – Configuration of up to five components with the same voltage – Flashing and stroboscopic light component including lamp, for direct use – Components available in a range of colours and voltages For modular configuration of – Connection components – Optical components – Acoustic components – Label panel Connection component Connection component for signal pillar, modular – Optionally for conduit or wall/base mounting – Screwless spring terminals in the connection component – With cover for optical components – Contact hazard protection to VDE – 12 – 230 V AC/DC for conduit mounting 2368.001 for wall/base mounting 2368.002 Model No. Accessories: – Mounting component, see page 1125/1126 Material: – Polyamide enclosure Colour: – Black Protection category IP to IEC 60 529: – IP 65 16 Connection component for conduit mounting 2368.001 Ø 70 6.1 ±0.2 25 36 3.5 ±0.5 Ø 65 16 System accessories Connection component for wall/base mounting Ø 70 1 6.1 ±0.2 37.5 26.5 Ø 65  Seal Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1123 Signal pillars 65.5 for signal pillar, modular – With 360° signal transmission thanks to optimised prism system – No. of potential stages = 5 components, with identical voltage 56 Optical component Material: – Enclosure: Polyamide – Spherical cap: Transparent polycarbonate Ø 70 Protection category IP to IEC 60 529: – IP 65, provided a cover or acoustic component is fitted at the top LED steady light component 24 V AC/DC, < 35 mA Model No. Red Green Yellow Clear Blue 2372.001 2372.011 2372.021 2372.031 2372.041 LED steady light component 230 V, < 35 mA Model No. Red Green Yellow Clear Blue 2370.151 2370.161 2370.171 – – LED flashing light component 24 V AC/DC, < 30 mA Model No. Red Green Yellow Clear Blue 2370.501 2370.511 2370.521 2370.531 2370.541 LED flashing light component 230 V, < 35 mA Model No. Red Green Yellow Clear Blue 2370.551 – 2370.571 – – Stroboscopic light component 24 V (DC), < 35 mA Model No. 1124 Red Green Yellow Clear Blue 2371.001 – 2371.021 – – Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Signal pillars Mounting component for wall/base mounting Fig.   Mounting component Colour Model No. Bracket for connection component Black 2374.040 For side cable outlet Black 2374.080 1 Also required: – With the modular system for wall/base mounting: Connection component 2368.002, see page 1123 2 Bracket for connection component For side cable outlet Ø 70 Ø Ø 42 Ø 70 54 15 A 2 4. Ø 5.5 1.5 Ø 10.5 Ø 5.5 Ø 70 Ø 54 B M16 x 1.5 15 A Seal B Flat seal Mounting component for support arm systems For external mounting of a signal pillar on the plastic cover of support arm components. Colour Model No.  For support arm system CP 40, steel – Angle piece 90° 6501.140 RAL 7024 (graphite grey) 2375.030  For support arm system CP 60 – Angle adaptor 90° for support arm combination CP 60 to CP 40 6206.640 – Angle coupling 90° 6206.380 – Angle piece 90° 6206.600 – Intermediate hinge 6206.620 – Wall mounted hinge 6206.740 – Top mounted joint 6206.700 RAL 7024 (graphite grey) 6206.900 For support arm system CP 120 – Angle coupling 90° 6212.380 – Angle piece 90° 6212.600 – Intermediate hinge 6212.620 – Wall-mounted hinge 6212.740 – Top-mounted joint 6212.700 RAL 7024 (graphite grey) 6212.900 For support arm system CP 180 – Angle piece 90° 6218.700, – Top-mounted joint 6218.700 RAL 7024 (graphite grey) 6212.900  Mounting component 3 System accessories Fig. 4 Also required: – With the modular system for conduit mounting: Connection component 2368.001, see page 1123 Rittal System Catalogue 36/System accessories 5 Further technical information available on the Internet. 1125 Signal pillars Mounting component for conduit mounting 6 Fig. Mounting component Colour Model No.   Base with integral conduit, Ø 25 mm, 110 mm long Black 2374.000 Individual base Black 2374.010 Individual conduit, 250 mm long Aluminium 2374.020 Individual conduit, 400 mm long Aluminium 2374.030 Angle bracket for conduit mounting Black 2374.050 Also required: – With the modular system for conduit mounting: Connection component 2368.001, see page 1123 7 Base with integral conduit 8 Individual conduit Ø 25 Individual base, plastic Ø 21.7 Ø 25 110 250 (400) 17 37 Ø 10.5 Ø 5.5 Ø 70 Ø 54 Ø 10.5 A Ø 70 A Seal Ø 5.5 9 A A Seal Angle bracket for conduit mounting Ø 70 36 .2 19 1126 9 52.5 18 Ø6 57 38 Ø 12 87.5 Further technical information available on the Internet. Rittal System Catalogue 36/System accessories Signal pillars Acoustic component 24 V AC/DC for signal pillar, modular To indicate warnings or malfunctions. Acoustic components Packs of Model No. 105 dB1) 1 pc(s). 2376.001 Material: – Enclosure: Polyamide 102 dB2) 1 pc(s). 2376.011 Colour: – Black Protection category IP to IEC 60 529: – IP 65 Note: – For mounting only on the upper end of the optical components or directly onto the connection component Label panel for signal pillar, 3-way LED and signal pillar, modular For adding texts on up to 5 optical components, with break point for any fields that are not required (50 x 150 mm), including clamping section for base / conduit with Ø 25 mm. 1) Continuous tone or pulsating 2) Adjustable volume and choice of 8 sounds 230 V Acoustic components Packs of Model No. 105 dB1) 1 pc(s). 2376.021 102 dB2) 1 pc(s). 2376.031 1) 2) Continuous tone or pulsating Adjustable volume and choice of 8 sounds Label panel Model No. for 5 optical components 2374.150 System accessories Material: – Acrylic, transparent Rittal System Catalogue 36/System accessories Further technical information available on the Internet. 1127 Technical information The 3-phase coating procedure Coating procedure Technical properties Technical specifications Surface pretreatment Used as corrosion protection and to improve paint adhesion. Degreasing, nanoceramic conversion layer Anodic dipcoat priming Even layer formation on all surfaces, edges and in cavities, which produces a high level of corrosion protection even at the assembly stage. Erichsen cupping test to DIN EN ISO 1520 ≥ 4 mm Buchholz hardness to DIN EN ISO 2815 ≥ 80 Cross cutting to DIN EN ISO 2409 Gt 0 The primer is readily overpainted and free from heavy metals, chromate and silicone. Stove enamelling Textured powder coating Powder-coating is distinguished by a high level of mechanical resistance, excellent corrosion protection, good resistance to chemicals and temperature, and its facility for decontamination. Erichsen cupping test to DIN EN ISO 1520 ≥ 3.5 mm Buchholz hardness to DIN EN ISO 2815 ≥ 85 Cross cutting to DIN EN ISO 2409 GT 0-1 Salt spray test to DIN EN ISO 9227 NSS Test period: 168 hrs Condensate test to DIN EN ISO 6270-2 CH Test period: 500 hrs Condensate test to DIN EN ISO 6270-2 AHT Test period: 20 cycles The powder coating is readily overpainted and is free from heavy metals, chromate, silicone and solvents. Stove enamelling The coating is resistant to: ◾ Mineral oils ◾ Lubricants ◾ Machine emulsions ◾ Alcohol-based solvents (briefly, e.g. during cleaning) ◾ Weak acids and alkalines Primer or powder coating suitable for overpainting After careful cleaning of the surface, the standard coating may be overpainted with ◾ DD gloss paints ◾ Single and dual-component gloss paints ◾ Car repair paints ◾ Powder paints ◾ Water-based paints Outdoor use of enclosures In order to guarantee satisfactory long-term function of enclosures in outdoor use, the relevant environmental factors must be taken into account. These include: ◾ UV radiation, the corrosive action of air pollution, rain, icing, snow, wind or other factors in special climatic conditions. 1128 Further technical information available on the Internet. If in doubt, perform a compatibility test. Always follow the paint manufacturer’s instructions. When overpainting, take care not to exceed 180 °C and a baking time of 15 minutes. Condensation inside the enclosure Condensation must be prevented by means of appropriate measures, e.g. by venting or heating the enclosure. Protection category The enclosure may be exposed to extreme weather conditions during outdoor use. Long periods of rain, snow, ice, high winds and temperature fluctuations place particularly high demands on the enclosure sealing. The protection category IP X3 as envisaged for external weather conditions in DIN VDE 0100, part 737, point 5.2 is often insufficient to provide permanent protection for electrical equipment. Rittal System Catalogue 36/Technical information Technical information Protection categories to IEC 60 529 (EN 60 529) The IP protection category is characterised by 2 numerals. Example of a protection category, e.g. IP 43: Code letters IP First numeral Second numeral   Degrees of protection for protection against contact and foreign bodies: First numeral Second numeral Degree of protection Description Explanation The object probe, a sphere 50 mm in diameter, must not penetrate fully.1)  Protected against vertically falling water drops Vertically falling drops shall have no harmful effects.  Protected against solid foreign objects with a diameter of 12.5 mm and greater The object probe, a sphere 12.5 mm in diameter, must not penetrate fully.1) The articulated test finger may penetrate up to its length of 80 mm, but adequate distance from hazardous parts must be adhered to.  Protected against vertically falling water drops when the enclosure is tilted up to 15° Vertically falling drops shall not have any harmful effects when the enclosure is tilted up to 15° on either side of the vertical.  Protected against solid foreign objects with a diameter of 2.5 mm and greater The object probe, a sphere 2.5 mm in diameter, must not penetrate at all.1)  Protected against sprayed water Water sprayed at an angle of up to 60° on either side of the vertical shall have no harmful effects.  Protected against solid foreign objects with a diameter of 1.0 mm and greater The object probe, a sphere of 1.0 mm in diameter, must not penetrate at all.1)  Protected against splashed water Water splashed on the enclosure from any direction shall have no harmful effects.  Dust-protected The ingress of dust is not fully prevented, but dust shall not enter to such an extent as to impair satisfactory operation of the device or safety.  Protected against water jets Water directed at the enclosure from any direction in a jet shall have no harmful effects.  Dust-tight No ingress of dust at a partial vacuum of 20 mbar inside the enclosure.  Protected against powerful water jets Water directed at the enclosure from any direction in a powerful jet shall have no harmful effects.  Protected against temporary immersion in water Water must not ingress to such an extent as to cause harmful effects when the enclosure is temporarily immersed in water under standardised pressure and time conditions. Protected against continuous immersion in water Ingress of water in quantities causing harmful effects shall not be possible when the enclosure is continuously immersed under conditions to be agreed between the manufacturer and the user. However, the conditions must be more difficult than for numeral 7. Water projected at high pressure and Protected against highhigh temperature against the enclopressure and high-temperasure from any direction shall not have ture water jets harmful effects. First numeral Degree of protection Degrees of protection for protection against water: Second numeral Description Explanation  Protected against solid foreign objects with a diameter of 50 mm and greater 1) The full diameter of the object probe must not pass through an opening of the enclosure. System accessories Automatic potential equalisation via the mounting components (while observing DIN EN 62 208) Rittal System Catalogue 36/Technical information Further technical information available on the Internet. 1129 Technical information UL type rating UL (Underwriters Laboratories) is an independent organisation based in Chicago which safety-tests products for the North American market. A key aspect for enclosures is the protection of individuals from unintentional contact with equipment and the protection of installed equipment from external factors. Protection categories are classified by UL type ratings. Further information on protection categories may be found on the Internet at: www.rittal.com UL/NEMA Type Intended use and description 1 Enclosures for use indoors Protection against the penetration of foreign bodies 3 Enclosures for use indoors and outdoors Protection from rain, hail, dust, icing and the damage caused by icing 3R Enclosures for use predominantly outdoors Protection from rain, hail, icing and the damage caused by icing 3S Enclosures for use predominantly outdoors Protection from rain, hail and dust External mechanisms remain usable despite being coated in ice 4 Enclosures for indoor or outdoor use Protection against rain, foreign bodies, splashed water and hosed water and against damage caused by icing on the exterior of the enclosure 4X Enclosures for indoor or outdoor use Protection against rain, foreign bodies, splashed water and hosed water and against damage caused by icing on the exterior of the enclosure Increased protection from corrosion 12, 12K Enclosures for use indoors Protection against dust deposits, foreign bodies, oil and non-corrosive dripping refrigerants 13 Enclosures for use predominantly indoors Protection against dust deposits, sprayed water, oil, and non-corrosive refrigerants The UL/NEMA classifications are not directly comparable with IP protection categories, since both the test conditions and the evaluation of the test results are different Approvals and permits Product certifications and approvals are pivotal to the global acceptance of industrial products. Rittal products meet the highest internationally recognised quality yardsticks. All components are subjected to the most stringent testing in accordance with international standards and regulations. The consistently high product quality is ensured by a comprehensive quality management system. Regular production inspections by external test institutes also guarantee compliance with global standards A precise allocation of products to marks of conformity can be found on our product and service pages on the Internet: www.rittal.com Earthing The PE conductor connection must be designed by the manufacturer of switchgear in accordance with the relevant VDE and/or local regulations. The enclosure packs generally contain earthing materials (screws, nuts, washers). The assembly instructions contain recommendations on installing a PE conductor. The pre-assembled earth straps, available as accessories in various cross-sections and lengths, are intended to make assembly of a PE conductor easier. 1130 Further technical information available on the Internet. Rittal System Catalogue 36/Technical information Technical information Stainless steel, rust-proof Rust-proof stainless steel is a collective term for more than 120 different types of steel, all of which are alloyed with at least 10.5% chromium and are resistant to corrosion without any protective coating. They form an invisible passive layer under the influence of oxygen. Short name Material number x 5 CrNi 1810 x 2 CrNiMo 17-12-2 1.4301 1.4404 Principal property easy to weld corrosion-resistant malleable weldable highly corrosion-resistant Typical uses Foodstuffs industry Dairies Chemical industry Construction sector Paper industry Chemical composition/mass content in % Carbon C Chromium Cr Molybdenum Mo Nickel Ni < 0.07 < 0.07 17.5/19.5 16.5/18.5 – 2.0/2.5 8.0/10.5 10.0/13.0 System accessories Benefits ◾ Highly resistant to corrosion and chemical substances ◾ Outstanding hygiene properties and minimal cleaning effort, thanks to the smooth surface ◾ No need to treat the surface with enamel or paint ◾ Environmentally friendly, as 100% recyclable ◾ Good material properties (tensile strength, expansion, abrasion) Rittal System Catalogue 36/Technical information Further technical information available on the Internet. 1131 1132 Rittal System Catalogue 36/Services & quality SERVICE & QUALITY International service Global availability ......................................................................................1134 Our service portfolio..................................................................................1136 Rittal Manufacturer’s Service Service for industrial applications ..............................................................1140 Service for machines ................................................................................1144 Service for IT infrastructure .......................................................................1146 Smart Service Smart Service – Predictive and efficient ....................................................1150 Smart Service – Bespoke and demand-driven ..........................................1152 Quality management Quality management.................................................................................1154 Software & services Services Value chain ...............................................................................................1156 Optimum value creation for all target groups.............................................1158 Software and tools for industry .................................................................1160 Software and tools for IT infrastructure .....................................................1161 Rittal System Catalogue 36/Services & quality 1133 Competent. Globally present. A one-stop service. Use our service to minimise downtimes, boost efficiency and benefit from the following advantages: ◾ ◾ ◾ ◾ ◾ ◾ ◾ ◾ Around 1,000 service specialists worldwide Highly qualified service technicians and infrastructure specialists Solid expert knowledge with manufacturer expertise Ready availability of original spare parts Maximum system availability Short response times Professional lifecycle management 24-hour availability Whenever, wherever and however you need us, we are always on hand to assist you! Rittal service addresses worldwide Headquarters/Europe Tel. +49 (0) 2772 505-1855 Email: service@rittal.de Middle East Tel.: +971 4 3416855 Email: service@rittal-middle-east.com USA Tel.: +1 800-477-4000 Email: rittal@rittal.us Singapore Tel.: +65 6309 7315 Email: service@rittal.com.sg Mexico Tel. +52 (55) 5559 5369 Email: servicemx@rittal.com.mx India Tel.: +91 (80) 33720783 Email: service@rittal-india.com Chile Tel.: +56 (2) 2 94 77 400 Email: info@rittal.cl China Tel. +86 800 820 0866 Email: service@rittal.cn Your requirements Enhanced system availability Cost and resource savings What we offer Assembly, installation, commissioning 1134 Fast troubleshooting Inspection Professional maintenance Rittal System Catalogue 36/Services & quality International service – Global availability Value retention and maintenance Bespoke service agreements Modernisation Efficiency and system advice Individual optimisation and sustainability Services Original spare parts Rapid access to spare parts Rittal System Catalogue 36/Services & quality 1135 Installation and commissioning Correctly installed equipment is less susceptible to errors and operates more efficiently. You can be sure that the manufacturer’s expertise is applied to the installation and commissioning of your Rittal components. The benefits for you: ◾ Reliability from the outset ◾ Less susceptible to errors ◾ More efficient operation of your systems Maintenance and inspection The remaining service life of the installed components can be significantly extended with professional maintenance by the Rittal service team. This ensures efficient operation and associated cost savings. The additional inspection and leak test by certified service engineers guarantees compliance with statutory regulations, such as the F-gas regulation (EU) No. 517/2014, which in turn ensures the efficient operation of your equipment. Visual inspection and assessment of the general condition of your equipment Measurement and documentation of system parameters Basic cleaning of the equipment Inspection of fans, air routing and system parameters The benefits for you: ◾ Downtime is prevented, to minimise your risks ◾ Improved value retention for your systems ◾ The remaining service life of installed components is extended ◾ Efficiency is increased by up to 30%, with associated cost savings 1136 Rittal System Catalogue 36/Services & quality Services International service – What we offer Rittal System Catalogue 36/Services & quality 1137 Repairs and troubleshooting Rittal service engineers are continuously trained to provide top-quality, on-site troubleshooting. The result? 90% of Rittal’s service deployments are resolved with just one on-site visit and include a detailed service report with further recommendations. Alternatively, you may opt to send your equipment to our factory for repair. The benefits for you: ◾ Fast, professional troubleshooting ◾ Minimised downtimes ◾ Reliable service performance Spare parts – any time, anywhere Global availability of individual parts adds value Professional spare parts management ensures maximum availability of spares, because optimum stocking ensures that repairs can be carried out without delay. Original spare parts Express shipment with 24h delivery promise (working days only) Our Global Distribution Centre has over 2,000 different standard spare parts in stock Local availability, with stocks held by Rittal subsidiaries worldwide Customer-specific stocking of spare parts, either at Rittal or at your premises Predictive replacement of worn parts thanks to professional life cycle management Life cycle management Knowing the age and condition of installed equipment enables predictive replacement of worn parts. This reduces downtimes and also allows you to plan costs. Here, too, you can rely on the support of Rittal’s after sales service team. 1138 Rittal System Catalogue 36/Services & quality Services International service – What we offer Rittal System Catalogue 36/Services & quality 1139 Efficiency and service check Regular checks of your Rittal components will ensure maximum performance of all cooling units while keeping consumption levels to a minimum. During the efficiency check, Rittal will analyse your installed equipment for current performance and energy costs. Based on the findings, Rittal will advise you on potential savings and efficiency enhancements and will calculate the amortisation periods of any investments that may be required. The service check is more comprehensive than the efficiency check and includes an analysis of the current status of your equipment, highlighting any maintenance requirements, and incorporating this into your investment calculation. The benefits for you: ◾ Performance analysis of installed equipment ◾ Presentation of energy costs and potential savings ◾ Reduction of unscheduled production stoppages and associated costs ◾ Specific energy-saving approaches ◾ The value of your equipment is preserved Receipt of the equipment The current status is ascertained by the Rittal Service team Presentation of the results and advice Analysis ◾ Potential energy savings ◾ CO2 reductions ◾ Amortisation period of required investments (ROI) Dismantling, installation and commissioning of the products and solutions ◾ Project coordination ◾ Logistics from a single source Assistance with applying for government subsidies Regular maintenance for continued problem-free operation Note: Please contact your local ASM or customer service team to discuss the scope and availability of this service in your region. 1140 Rittal System Catalogue 36/Services & quality Services Rittal Manufacturer’s Service – Service for industrial applications Rittal System Catalogue 36/Services & quality 1141 Service agreements – Individual and combinable Rittal service agreements allow you to tailor the scope of services to your specific requirements and combine various modules – with fixed, transparent terms and conditions. The benefits for you: ◾ Maximum uptime ◾ Plannable costs ◾ Guaranteed response times ◾ Warranty extension ◾ Individual stocking of spares Maintenance Availability On-site service Warranty extension Stocking of spare parts Inspection Scope of services included in standard agreement Optional modules 1 x per year 2 x per year Working days (Mon – Fri) 7 am – 5 pm Next working day (Mon – Fri) 7 am – 5 pm Working days (Mon – Fri) 24 hours Next week day (Mon – Sat) 7 am – 5 pm Within 8 hours Every day of the week (Mon – Sun) 24 hours Within 4 hours No contract commitment, separate agreement Contract extension +12/+24/+36 months Preventive replacement of worn parts +12/+24/+36 months At Rittal At Rittal and delivered within 24 hours Individually agreed 1 x per year 4 x per year 12 x per year Note: Please contact your local ASM or customer service team to discuss the scope and availability of this service in your region. 1142 Rittal System Catalogue 36/Services & quality Services Rittal Manufacturer’s Service – Service agreements for industrial applications Rittal System Catalogue 36/Services & quality 1143 Rittal Automation Systems – Professional service for your machines No-one knows your machines better than the manufacturer. Our Manufacturer's Service specialists safeguard the availability and performance of your machines. Regular maintenance of your machines ensures a long service life and a high degree of fail-safe operation. With our service, you can benefit from consistently high quality and rely on your machines operating exactly as expected. Service agreements – Individual and combinable Rittal service agreements allow you to tailor the scope of services to your specific requirements and combine various modules – with fixed, transparent terms and conditions. Scope of services included in standard agreement Optional modules 1 x per year 2 x per year Availability Working days (Mon – Fri) 7 am – 5 pm Every day of the week (Mon – Sun) 24 hours On-site service Within 72 hours, incl. reduced hourly rate Within 48 hours, incl. reduced hourly rate Warranty of the machine No warranty extension + 12 months Maintenance Individual stocking of spares DXF remote training Software update On request One training session As necessary (but excluding hardware/PC or operating system replacement) Note: Please contact your local ASM or customer service team to discuss the scope and availability of this service in your region. 1144 Rittal System Catalogue 36/Services & quality Services Rittal Manufacturer’s Service – Service for machines Rittal System Catalogue 36/Services & quality 1145 Maintenance and troubleshooting Modern IT systems are the lifeblood of many companies. As data volumes grow ever larger and more complex, today it is more important than ever before to rely on a functioning digital infrastructure which is always available. Detailed expert knowledge, short response times and exceptional support quality are basic requirements for every Rittal service. Put your trust in our proven abilities. IT Health Check Exceptional performance and early risk detection by servicing your IT infrastructure. The IT Health Check provides an insight into the maintenance status of your cooling systems and any leaks, as well as energy efficiency and sustainability, the capacity utilisation and scalability of your systems, any obsolescence risks, alarm chains, redundancy circuits, and compliance with statutory requirements, guidelines and standards. As the outcome of the IT Health Check you will receive an assessment report containing individual optimisation and organisation options including identified cost drivers, potential savings and risk minimisation associated with the optional, predictive replacement of wearing parts. The benefits for you: ◾ Individual optimisation and modernisation options ◾ A list of identified cost drivers and potential savings ◾ Risk management with predictive replacement of wearing parts Note: Please contact your local ASM or customer service team to discuss the scope and availability of this service in your region. 1146 Rittal System Catalogue 36/Services & quality Services Rittal Manufacturer’s Service – Service for IT infrastructure Rittal System Catalogue 36/Services & quality 1147 Service agreements – Individual and combinable Rittal service agreements allow you to tailor the scope of services to your specific requirements and combine various modules – with fixed, transparent terms and conditions. The benefits for you: ◾ Maximum uptime ◾ Plannable costs ◾ Guaranteed response times ◾ Individual stocking of spares ◾ Warranty extension Maintenance Availability On-site service Warranty extension Stocking of spare parts Inspection Leakage test Replacement of wearing parts Scope of services included in standard agreement Optional modules 1 x per year 2 x per year Working days (Mon – Fri) 7 am – 5 pm Next working day (Mon – Fri) 7 am – 5 pm Working days (Mon – Fri) 24 hours Next week day (Mon – Sat) 7 am – 5 pm +12/+24/+36 months, includes defined spare parts and repairs Within 8 hours Every day of the week (Mon – Sun) 24 hours Within 4 hours +12 /+24 /+36 months, includes defined spare parts, repairs and predictive replacement of wearing parts At Rittal At Rittal and delivered within 24 hours Individually agreed 1 x per year 4 x per year 12 x per year 1 × per year from 5 t CO2 equivalent 2 × per year from 50 t CO2 equivalent 4 × per year from 500 t CO2 equivalent By operating hours Note: Please contact your local ASM or customer service team to discuss the scope and availability of this service in your region. 1148 Rittal System Catalogue 36/Services & quality Services Rittal Manufacturer’s Service – Service agreements for IT infrastructure Rittal System Catalogue 36/Services & quality 1149 Smart Service Increased machine availability and optimised service processes for Rittal components in the Blue e+ generation. Rittal Smart Service visualises the operational performance of Blue e+ cooling units and transfers data in real time for prompt identification of maintenance requirements and critical errors. The automated processing of device data allows fast, efficient troubleshooting. In the event of a malfunction, you receive situation-specific recommendations and can generate energy efficiency reports via the Rittal Smart Service portal. Benefit from a combination of event-related recommendations and manufacturer expertise, remote diagnosis and advice from Rittal service experts as the basis for your predictive maintenance. The advantages to you: ◾ Asset management and control of maintenance measures ◾ Visualisation of device data via Web portal including monitoring (condition monitoring) ◾ Access to operating and temperature characteristics ◾ Energy efficiency reports and efficiency analyses ◾ Situational recommendations based on manufacturer expertise How you benefit: ◾ Enhanced machine availability ◾ Increased service efficiency and lower servicing costs, thanks to requirement-driven maintenance ◾ Fast problem analysis and troubleshooting with remote diagnosis Note: Please contact your local ASM or customer service team to discuss the scope and availability of this service in your region. Blue e+ generation 1150 Rittal System Catalogue 36/Services & quality Smart Service – Predictive and efficient Smart Service Cloud Unidirectional, encrypted data transmission Certified Cloud in Germany Data analyses Based on manufacturer expertise Development of intelligent algorithms The basis for preventive maintenance Smart Service Portal Overview of networked devices (asset management) Access to operating data The latest messages and recommended actions Energy consumption Monitoring by Rittal service experts Continuous monitoring of device statuses in real time Remote diagnosis with manufacturer know-how IoT interface Situational advice on optimum measures Service engineers Respond on demand Ensure fast, efficient on-site troubleshooting Automated handling Identification of the correct spare part Services Initiation of service measures Rittal System Catalogue 36/Services & quality 1151 Smart Service – Bespoke and demand-driven You can opt into our Smart Service at any time and flexibly adapt it to suit your requirements. In this way, we tailor the appropriate service level and range of services to each individual customer. Rittal Smart Service offers various different service levels, which build on one another to become ever more comprehensive. Level 3 Smart Maintenance Agreement Smart Monitoring Modular service agreement Automated service handling This level combines the advantages of our Remote Diagnostic Service and Smart Monitoring with a conventional service agreement. Individual maintenance measures need not be ordered separately, as they are agreed in your individual service agreement. Level 2 Smart Monitoring Remote Diagnostic Service Equipment monitoring/service management by Rittal Rittal service experts monitor your networked devices connected to the smart service and proactively notify you of any critical faults and essential measures for maintaining availability. Any essential maintenance measures are ordered separately by you, so you remain in full control of the measures implemented and the associated costs at all times. Remote Diagnostic Service Level 1 Access to your personal dashboard Asset management Situational recommendations based on manufacturer expertise Visualisation of device data, including monitoring Energy efficiency reports and efficiency analyses Advice and error diagnosis from the Rittal Service team You can access the Smart Service Portal including the visualisation of all your networked devices and device statuses, and generate energy efficiency analyses. You can also consult Rittal service experts for fast, remote diagnosis, and receive optimum, bespoke advice in addition to situational recommendations. Note: Please contact your local ASM or customer service team to discuss the scope and availability of this service in your region. 1152 Rittal System Catalogue 36/Services & quality Rittal Service Rittal System Catalogue 36/Services & quality Services Please contact us with any questions you may have relating to our service portfolio; we will be happy to issue quotes and provide practical assistance. www.rittal.com/service-worldwide 1153 Quality management is a must. Quality philosophy is an attitude. “Rittal – The System.” stands for consistent quality management and on-going refinements to products, services and internal processes. Rittal quality management ensures that regulations and standards are observed, and individual customer requirements are met. In addition to this, we also define our exacting product quality demands in supplementary Rittal standards. The consistent Rittal quality philosophy guarantees perpetually high standards and ensures the global usability of all products with countless international approvals and licences. Alongside product quality, we also focus on process and service quality. All internal processes are continuously refined by quality control groups, and reviewed during in-house audits. Each year, our improvements and high standards are verified by countless successful external system and customer audits. Rittal offers support from day one ◾ Project planning of technical specifications ◾ Prototype assembly, testing and simulations ◾ Manufacturing and assembly ◾ Warehousing service and on-time delivery ◾ Your own personal point of contact throughout the entire project Accredited Rittal test laboratory ◾ Simulation of climatic conditions ◾ Dynamic and static load tests ◾ 3D measurement ◾ Testing of IP/IK protection categories and NEMA type ratings ◾ Corrosion testing ◾ Electrical safety and function tests ◾ Software tests ◾ Performance testing of chillers, cooling units and heat exchangers ◾ Material testing 1154 Rittal System Catalogue 36/Services & quality Services Quality management Rittal System Catalogue 36/Services & quality 1155 Project handling with Rittal and Eplan tools Software and services spanning the entire value chain 1156 Rittal System Catalogue 36/Services & quality Boost your efficiency everywhere – with individual software and service modules from Rittal and Eplan From small businesses and medium-sized companies to fully automated large-volume producers, our comprehensive portfolio provides every rack and controlgear manufacturer with a suitable selection of software and service modules tailored precisely to their individual production process. Optimum compatibility between all tools, even those that are not currently required or used, ensures maximum continuity and efficiency in both manual, semi-automated and fully automated production. Services The benefits for you: ◾ Efficient software tools ◾ Plausibility-checked product and accessory configurations ◾ Plan cut-outs and drilled holes ◾ Generate tested manufacturing documents for the configured racks ◾ Transfer data into Eplan tools ◾ Enquire about configured products or order directly online ◾ Transfer data into Rittal machining centres ◾ Service modules tailored to individual requirements Rittal System Catalogue 36/Services & quality 1157 Optimum value creation for all target groups Tools that guide users simply and efficiently to their individual product configuration provide the starting-point for successful project planning. These are not complex engineering solutions but user-friendly software tools which in just a few minutes can help you to find the right product or simply redefine the parameters for a cooling unit. Technical Consulting & Design Technical Specs Operations Engineering Operations Service Testing Wiring Wire Fabrication 1158 Rittal System Catalogue 36/Services & quality Sourcing Thermal Design & Dimensioning Ordering Digital Twin Manufacturing Documents Mechanical Infrastructure Checking & Correcting Logistics Product Functions Design Kitting Manufacturing Cutting Panel Modification Terminal Strip Assembly Mechanical Installation Services Labeling Devices Rittal System Catalogue 36/Services & quality 1159 Software and tools for industry Enclosure Climate Control General Rittal Configuration System Chiller configurator CAD data Select, plan and order plausibilitychecked enclosures and components easily. See page 272 The chiller configurator is a costeffective way of selecting your required machine and process cooling. See page 558 Command panel configurators Therm software for aluminium command panels The online configurators for Comfort Panel and Optipanel help you to configure individual, perfectly coordinated panel solutions. See page 273 Clever climate control planning Therm takes care of the timeconsuming calculation of your climate control requirements and proposes a suitable selection of products. See page 558 Greater efficiency in plant design 2D and 3D CAD data for all Rittal components in more than 70 different formats, for use in all standard commercially available CAD systems. Fast online access to original files in all common CAD formats. See page 274 Support arm configurator RiDiag for CP 40/60/120/180, support section, height-adjustable Plausibility-checked planning of support arm systems. See page 273 RiDiag is a software package for the diagnosis and analysis of cooling units and chillers to ensure proper operation and to simplify maintenance and the diagnosis of system messages. See page 559 Online conversion assistant for small enclosures KX and compact enclosures AX Convert quickly and easily with the parts list converter. See page 274 Power Distribution Blue e+ app The Blue e+ app supports the contactless exchange of information as well as rapid on-site analysis via the NFC interface. See page 559 VX25 Power Engineering Rittal Automation Systems The Web-based tool guides users quickly and efficiently through the entire switchgear planning process in simple, logical steps. See page 446 Take value creation to the next level by working more efficiently with the latest tools and new automation solutions. See page 560 Product scan app All product information in a single scan Fast access to all relevant product information by scanning the QR code on the product. See page 274 Eplan Engineering solutions from Eplan help companies to optimise their controlgear and switchgear manufacturing processes. At its heart is the digital twin, which uses seamless data to link all value creation processes together. See page 14 Further configurators may be found on the Internet at www.rittal.com/configurators 1160 Rittal System Catalogue 36/Services & quality Software and tools for IT infrastructure Racks and enclosures IT power General Rittal Configuration System PDU configurator CAD data Easily select plausibility-checked enclosures and components, plan machining and place your order. See page 272 The PDU configurator helps you to configure and equip customised PDUs. The PDU portfolio allows you to generate the optimum product for your application. See page 875 Greater efficiency in plant design 2D and 3D CAD data for all Rittal components in more than 70 different formats, for use in all standard commercially available CAD systems. Fast online access to original files in all common CAD formats. See page 274 IT cooling Product scan app IT infrastructure selector The selector supports partners, system integrators, system engineers and end clients in selecting the right IT products for their specific application. See page 874 RiMatrix S Selector Your standardised data centre selector for SMEs, branch concepts and flexible cloud applications. Your solution is configured on the basis of standardised data centre modules. See page 874 Micro Data Center configurator Easily select water-based Liquid Cooling Packages (LCP) for rack and suite cooling for your IT infrastructure. See page 875 Blue e+ app The Blue e+ app supports the contactless exchange of information as well as rapid on-site analysis via the NFC interface. See page 559 DCIM – Data Centre Infrastructure Management RiZone provides perfect support for your IT infrastructure components. Customer-centric and cost-efficient See page 828 Services Configuration of your security safe, including a range of configuration components. See page 874 IT cooling calculator All product information in a single scan Fast access to all relevant product information by scanning the QR code on the product. See page 274 Rittal System Catalogue 36/Services & quality 1161 List of model numbers 1003.000 to 2360.000 Model No. 1003.000 AX Page Model No. 237 1320.600 HD Page Model No. 221 1551.000 KX Page 65 Model No. 1934.200 Page EL 1092 1005.000 AX 237 1338.000 AX 86 1552.000 KX 65 1935.200 EL 1092 1006.000 AX 238 1339.000 AX 87 1553.000 KX 66 1936.200 EL 1092 1007.000 AX 239 1350.000 AX 87 1554.000 KX 66 1937.200 EL 1092 1008.000 AX 238 1360.000 AX 88 1555.000 KX 66 1939.200 EL 1092 1009.000 AX 239 1376.000 AX 88 1556.000 KX 66 1950.000 EL 1092 1010.000 AX 239 1380.000 AX 86 1557.000 KX 66 1962.200 SR 1078 1011.000 AX 238 1432.000 AX 94 1560.000 KX 230 1963.200 SR 1078 1012.000 AX 239 1434.000 AX 94 1560.800 KX 970 1980.200 SR 1078 1013.000 AX 239 1444.000 AX 94 1561.000 KX 230 2034.010 AX 1076 1014.000 AX 240 1446.000 AX 94 1561.800 KX 970 2090.000 DK 1097 1015.000 AX 238 1448.000 AX 95 1562.000 KX 230 2092.200 EL 1098 1016.000 AX 240 1449.000 AX 95 1562.800 KX 970 2092.500 EL 1098 1017.000 AX 240 1453.000 AX 94 1563.000 KX 231 2094.200 EL 1098 1018.000 AX 240 1454.000 AX 95 1563.800 KX 970 2094.400 DK 1098 1019.000 AX 240 1466.000 AX 94 1564.000 KX 230 2094.500 EL 1098 1031.000 AX 86 1467.000 AX 95 1564.800 KX 970 2203.400 IN 1061 1033.000 AX 85 1468.000 AX 94 1565.000 KX 230 2231.000 EL 1094 1034.000 AX 85 1469.000 AX 95 1565.800 KX 970 2232.000 EL 1094 1037.000 AX 86 1479.000 AX 95 1566.000 KX 231 2233.000 EL 1094 1038.000 AX 86 1480.000 AX 94 1566.800 KX 970 2243.605 EL 717 1039.000 AX 87 1485.100 AX 96 1567.000 KX 231 2246.605 EL 717 1045.000 AX 86 1485.200 AX 97 1567.800 KX 970 2249.605 EL 717 1050.000 AX 87 1485.300 AX 97, 261 1568.000 KX 231 2252.605 EL 718 1054.000 AX 88 1485.400 AX 97, 261 1568.800 KX 970 2253.605 EL 717 1055.000 AX 90 1485.500 KE 97, 261 1569.000 KX 231 2255.605 EL 718 1057.000 AX 87 1485.600 AX 96, 941 1569.800 KX 970 2256.605 EL 717 1058.000 AX 88 1500.000 KX 57 1570.800 KX 970 2259.605 EL 717 1059.000 AX 88 1501.000 KX 57 1570.810 KX 970 2261.605 EL 718 1060.000 AX 87 1502.000 KX 57 1571.800 KX 970 2262.605 EL 718 1073.000 AX 89 1503.000 KX 57 1572.800 KX 970 2265.605 EL 718 1076.000 AX 88 1504.000 KX 57 1573.800 KX 970 2271.605 EL 718 1077.000 AX 89 1505.000 KX 57 1574.000 KX 67 2304.010 HD 224 1090.000 AX 89 1506.000 KX 58 1574.800 KX 970 2304.100 SZ 943 1091.000 AX 89 1507.000 KX 57 1575.000 KX 67 2307.000 SZ 941 1100.000 AX 90 1508.000 KX 57 1575.800 KX 970 2308.000 SZ 945 1110.000 AX 91 1509.000 KX 58 1576.000 KX 67 2309.000 SZ 997 1114.000 AX 91 1510.000 KX 58 1576.800 KX 970 2309.100 KX 998 1115.000 AX 91 1511.000 KX 57 1577.000 KX 67 2309.110 SZ 943 1116.000 AX 91 1512.000 KX 58 1578.000 KX 67 2311.076 AX 953 1130.000 AX 91 1513.000 KX 58 1579.000 KX 67 2311.100 AX 953 1180.000 AX 90 1514.000 KX 56 1581.200 SZ 1054 2311.120 AX 953 1181.000 AX 90 1515.000 KX 56 1583.000 KX 234 2311.225 SZ 953 1199.100 SZ 916 1516.000 KX 56 1584.000 KX 233 2311.250 SZ 953 1213.000 AX 91 1517.000 KX 56 1585.000 KX 234 2313.150 SZ 997 1214.000 AX 91 1518.000 KX 56 1586.000 KX 234 2313.750 SZ 997 1260.000 AX 89 1527.000 KX 58 1587.000 KX 233 2314.000 SZ 997 1261.000 AX 89 1528.000 KX 56 1588.000 KX 233 2315.000 SZ 997 1280.000 AX 90 1529.000 KX 57 1589.000 KX 57 2316.000 SZ 997 1281.000 AX 90 1530.000 KX 59 1590.010 KX 965 2317.000 SZ 997 1301.000 KX 233 1531.000 KX 59 1592.200 KX 951 2318.000 SZ 997 1302.000 AX 238 1532.000 KX 59 1592.210 KX 951 2319.000 SZ 997 1302.600 HD 221 1533.000 KX 59 1594.010 KX 965 2334.000 SZ 1033 1303.000 AX 238 1535.000 KX 59 1610.000 KX 70 2335.000 SZ 1033 1304.000 AX 239 1536.000 KX 59 1611.000 KX 70 2343.000 SZ 1033 1305.000 AX 240 1537.000 KX 60 1612.000 KX 70 2350.000 SZ 1059 1306.600 HD 221 1538.000 KX 60 1613.000 KX 70 2351.000 SZ 1059 1307.600 HD 221 1539.000 KX 59 1670.600 HD 220 2352.000 SZ 1059 1308.600 HD 221 1540.000 KX 60 1671.600 HD 220 2353.000 SZ 1059 1310.600 HD 221 1541.000 KX 60 1672.600 HD 220 2354.000 SZ 1059 1314.600 HD 221 1545.000 KX 65 1674.600 HD 220 2355.000 SZ 1059 1315.600 HD 221 1546.000 KX 65 1675.600 HD 220 2356.000 SZ 1059 1316.600 HD 221 1547.000 KX 65 1676.600 HD 220 2357.000 SZ 1059 1317.600 HD 221 1548.000 KX 66 1931.200 EL 1092 2358.000 SZ 1059 1318.600 HD 222 1549.000 KX 66 1932.200 EL 1092 2359.000 SZ 1059 1319.600 HD 222 1550.000 KX 66 1933.200 EL 1092 2360.000 SZ 1059 1162 Rittal System Catalogue 36 List of model numbers 2361.010 to 2527.000 Model No. 2361.010 AX Page Model No. 958 2389.000 SZ Page Model No. Page Model No. 1104 2436.800 SZ 903 2500.210 Page SZ 1015 2362.010 AX 958 2393.210 AX 989 2438.735 SZ 903 2500.211 SZ 1015 2363.010 AX 958 2393.250 AX 989 2440.735 SZ 903 2500.212 SZ 1016 2364.000 SZ 1036 2393.300 AX 989 2440.905 SZ 903 2500.213 SZ 1016 2365.000 SZ 1002 2393.350 AX 989 2446.000 SZ 954 2500.214 SZ 1016 2366.000 SZ 1002 2393.400 AX 989 2449.010 AX 951 2500.220 SZ 1016 2367.040 SZ 1030 2400.000 SZ 1046 2459.000 SZ 900 2500.300 SZ 1014 2367.060 SZ 1030 2400.300 SZ 1047 2459.500 SZ 900 2500.310 SZ 1014 2367.080 SZ 1030 2400.500 SZ 1047 2460.000 SZ 941 2500.311 SZ 1014 2367.120 SZ 1030 2401.000 SZ 908 2460.650 SZ 941 2500.312 SZ 1014 2367.160 SZ 1030 2402.000 SZ 908 2461.000 SZ 941 2500.313 SZ 1014 2367.200 SZ 1030 2410.001 HD 1057 2462.000 SZ 941 2500.314 SZ 1015 2368.001 SG 1123 2410.011 HD 1057 2463.000 SZ 941 2500.320 SZ 1015 2368.002 SG 1123 2410.021 HD 1057 2464.000 SZ 941 2500.400 SZ 1023 2370.151 SG 1124 2410.031 HD 1057 2465.000 SZ 941 2500.410 SZ 1023 2370.161 SG 1124 2410.111 HD 1057 2466.000 SZ 941 2500.420 SZ 1023 2370.171 SG 1124 2410.121 HD 1057 2467.000 SZ 942 2500.430 SZ 1023 2370.501 SG 1124 2410.131 HD 1057 2468.000 SZ 942 2500.435 SZ 1023 2370.511 SG 1124 2410.290 HD 1057 2469.000 SZ 942 2500.440 SZ 1023 2370.521 SG 1124 2411.601 SZ 1056 2472.010 AX 958 2500.450 SZ 1023 2370.531 SG 1124 2411.611 SZ 1056 2473.010 AX 958 2500.460 SZ 1024 2370.541 SG 1124 2411.621 SZ 1056 2474.010 AX 958 2500.470 SZ 1024 2370.551 SG 1124 2411.631 SZ 1056 2475.010 AX 958 2500.490 SZ 1024 2370.571 SG 1124 2411.641 SZ 1056 2476.010 AX 958 2500.500 SZ 1023 2371.001 SG 1124 2411.651 SZ 1056 2476.100 SZ 944 2500.520 SZ 1023 2371.021 SG 1124 2411.661 SZ 1056 2477.000 SZ 908 2500.530 SZ 1023 2372.001 SG 1124 2411.671 SZ 1056 2478.000 SZ 908 2500.550 SZ 1023 2372.011 SG 1124 2411.801 SZ 1056 2479.000 SZ 908 2500.600 SZ 1023 2372.021 SG 1124 2411.811 SZ 1056 2480.000 SZ 908 2500.610 SZ 1023 2372.031 SG 1124 2411.821 SZ 1056 2481.000 SZ 908 2500.620 SZ 1023 2372.041 SG 1124 2411.831 SZ 1056 2482.210 SZ 1117 2500.630 SZ 1023 2372.101 SG 1122 2411.841 SZ 1056 2482.220 SZ 1117 2500.640 SZ 1023 2372.102 SG 1122 2411.851 SZ 1056 2482.230 SZ 1117 2500.650 SZ 1023 2373.000 SZ 1004 2411.861 SZ 1056 2482.300 SZ 1118 2500.660 SZ 1024 2374.000 SG 1126 2411.871 SZ 1056 2482.310 SZ 1118 2500.670 SZ 1024 2374.010 SG 1126 2412.210 SZ 1033 2482.320 SZ 1118 2500.680 SZ 1023 2374.020 SG 1126 2412.216 SZ 1033 2482.330 SZ 1118 2500.710 SZ 1022 2374.030 SG 1126 2412.225 SZ 1033 2482.400 SZ 1118 2500.711 SZ 1022 2374.040 SG 1125 2412.310 SZ 1033 2482.410 SZ 1118 2500.712 SZ 1022 2374.050 SG 1126 2412.316 SZ 1033 2482.500 SZ 1118 2500.713 SZ 1022 2374.080 SG 1125 2412.325 SZ 1033 2482.510 SZ 1118 2500.714 SZ 1022 1022 2374.150 SG 1127 2413.375 PS 1030 2482.540 SZ 1118 2500.715 SZ 2375.030 SG 1125 2413.550 PS 1030 2482.550 SZ 1118 2503.020 AX 966 2376.001 SG 1127 2414.000 SM 1030 2482.560 SZ 1118 2504.000 SZ 1004 2376.011 SG 1127 2414.500 SM 1030 2482.570 SZ 1118 2504.500 SZ 1004 2376.021 SG 1127 2415.000 SZ 1030 2482.590 SZ 1118 2504.800 SZ 1004 2376.031 SG 1127 2415.100 SM 957 2482.600 SZ 1117 2505.510 SZ 967 2379.600 SZ 1111 2415.500 SM 981 2482.700 SZ 1117 2506.120 SZ 1042 2379.800 SZ 1111 2416.000 SZ 944 2482.710 SZ 1117 2508.020 AX 966 2379.900 SZ 1112 2418.000 SZ 944 2482.720 SZ 1117 2509.010 AX 964 2381.000 SM 1115 2419.000 SZ 944 2482.730 SZ 1117 2510.000 SZ 955 2382.000 SM 1116 2422.000 SZ 964 2483.000 SZ 941 2512.000 SZ 955 2383.020 SM 1116 2423.000 SZ 964 2485.000 SZ 942 2513.000 SZ 955 2383.030 SM 1110 2424.100 SZ 959 2485.100 SZ 942 2514.000 SZ 955 2384.010 SM 235 2425.100 SZ 959 2486.400 SZ 1004 2515.000 SZ 955 2384.020 SM 235 2426.100 SZ 959 2486.600 SZ 1004 2515.200 AX 954 2384.030 SM 235 2426.500 SZ 959 2487.000 SZ 1004 2515.300 AX 954 2384.040 SM 235 2427.100 SZ 959 2488.000 SZ 1004 2515.400 AX 954 2388.050 SZ 1029 2433.000 SZ 261 2489.000 SZ 1004 2519.010 SZ 956 2388.100 SZ 1029 2433.010 AX 967 2489.500 SZ 1004 2519.200 CM 956 2388.125 SZ 1029 2433.510 AX 967 2493.500 SZ 944 2521.000 SZ 945 2388.150 SZ 1029 2435.100 AX 939 2500.100 SZ 1017 2522.000 SZ 941 2388.200 SZ 1029 2435.200 AX 939 2500.104 SZ 1017 2523.000 SZ 941 2388.280 SZ 1029 2435.300 AX 939 2500.110 SZ 1017 2525.000 SZ 943 2388.650 SZ 1029 2435.400 AX 939 2500.114 SZ 1017 2526.000 SZ 941 2388.850 SZ 1029 2436.735 SZ 903 2500.200 SZ 1015 2527.000 SZ 941 Rittal System Catalogue 36 1163 List of model numbers 2528.000 to 3185.030 Model No. Page Model No. Page Model No. Page Model No. 2528.000 SZ 941 2580.007 AX 1051 2742.010 AX 931 3083.000 SV Page 2531.000 SZ 945 2580.008 AX 1051 2743.010 AX 931 3085.000 SV 343 2532.000 SZ 945 2580.009 AX 1051 2744.010 AX 931 3086.000 SV 350 389 2533.000 SZ 942 2580.010 AX 1051 2745.010 AX 931 3087.000 SV 350 2535.000 SZ 943 2580.011 AX 1051 2746.010 AX 931 3088.000 SV 350 2536.000 SZ 943 2580.012 AX 1051 2749.100 AX 932 3090.000 SV 350 2537.100 AX 940 2580.013 AX 1051 2760.010 AX 930 3091.000 SV 350 2537.300 AX 940 2580.014 AX 1051 2761.010 AX 930 3092.000 SV 343 2541.235 SK 539 2580.100 AX 1051 2762.010 AX 930 3093.010 SV 356 2542.235 SK 539 2580.115 AX 1051 2763.010 AX 930 3093.020 SV 356 2543.235 SK 539 2580.116 AX 1051 2780.000 FT 930 3105.310 SK 530 2545.000 SZ 945 2580.117 AX 1051 2781.000 FT 930 3105.320 SK 530 2546.000 SZ 945 2580.118 AX 1051 2782.000 FT 930 3105.330 SK 530 2547.000 SZ 945 2580.119 AX 1051 2784.000 FT 930 3105.340 SK 530 2548.000 SZ 945 2580.120 AX 1051 2785.000 FT 930 3105.350 SK 530 2549.000 SZ 945 2580.121 AX 1051 2786.000 FT 930 3105.360 SK 530 2549.500 SZ 945 2580.122 AX 1051 2787.000 FT 930 3105.370 SK 530 2549.510 HD 224 2580.123 AX 1051 2788.000 FT 930 3105.380 SK 531 2549.600 HD 224 2580.124 AX 1051 2789.000 FT 930 3105.390 SK 531 2559.000 SZ 1033 2580.125 AX 1051 2793.560 FT 931 3105.400 SK 531 2561.200 AX 1050 2582.100 AX 1051 2796.000 FT 930 3105.410 SK 531 2561.300 AX 1052 2582.200 AX 1051 2807.200 PS 890 3105.420 SK 531 2562.200 AX 1050 2582.400 AX 1051 2817.000 SO 885 3105.430 SK 531 2562.300 AX 1052 2582.600 AX 1051 2819.000 SZ 891 3108.024 SK 539 2563.200 AX 1050 2583.010 SZ 967 2819.200 SZ 891 3108.100 SK 539 2563.300 AX 1052 2583.080 AX 1048 2820.061 AX 888 3108.115 SK 539 2564.000 SZ 1033 2583.100 AX 1048 2820.062 AX 888 3110.000 SK 547 2564.200 AX 1050 2583.120 AX 1051 2820.081 AX 888 3110.200 SK 548 2564.300 AX 1052 2584.100 AX 968 2820.082 AX 888 3114.200 SK 546 2565.000 SZ 1033 2589.000 SZ 1060 2820.101 AX 888 3118.000 SK 547 2565.050 SZ 1033 2590.000 SZ 1060 2820.102 AX 888 3120.200 SK 549 2565.100 SZ 1033 2591.000 SZ 1060 2820.121 AX 888 3124.100 SK 550 2565.110 SZ 1033 2592.000 SZ 1060 2820.122 AX 888 3124.300 SK 554 2565.120 SZ 1033 2593.000 SZ 1060 2820.310 AX 889 3124.310 SK 555 2565.200 AX 1050 2594.000 SZ 1060 2820.320 AX 889 3124.400 SK 549 2565.300 AX 1052 2595.000 SZ 1060 2820.410 AX 889 3126.100 SK 469 2565.400 AX 1054 2596.000 SZ 1060 2820.420 AX 889 3127.100 SK 469 2566.000 SZ 1033 2597.000 SZ 1061 2843.160 SZ 1030 3128.100 SK 469 2566.200 AX 1050 2683.600 TP 251 2843.200 SZ 1030 3129.100 SK 469 2566.300 AX 1052 2684.600 TP 251 2843.250 SZ 1030 3130.100 SK 469 2566.400 AX 1054 2685.600 TP 251 2843.320 SZ 1030 3138.000 SK 464 2567.000 SZ 1033 2686.600 TP 251 2843.400 SZ 1030 3139.100 SK 464 2567.200 AX 1050 2694.500 TP 162 2843.500 SZ 1030 3139.110 SK 464 2567.300 AX 1052 2695.500 TP 162 2843.630 SZ 1030 3140.100 SK 464 2567.400 AX 1054 2696.500 TP 163 2859.000 SO 893 3140.110 SK 464 2568.000 SZ 1033 2730.010 AX 930 2865.000 TP 890 3140.140 SK 464 2569.000 SZ 1033 2731.010 AX 930 2867.000 TP 890 3140.500 SK 465 2570.000 SZ 1033 2732.010 AX 930 2869.000 TP 890 3140.510 SK 465 2570.500 SZ 1034 2733.010 AX 930 2870.000 TP 890 3144.000 SK 468 2571.000 SZ 943 2735.250 FT 929 2899.200 SZ 1048 3159.100 SK 559 2571.100 AX 1053 2735.500 FT 929 2899.250 SZ 1048 3159.300 SK 559 2572.000 SZ 943 2735.510 FT 929 2899.320 SZ 1048 3164.230 SK 789 2572.100 AX 1053 2735.520 FT 929 2899.400 SZ 1048 3164.620 SK 789 2573.000 SZ 1045 2735.530 FT 929 3031.000 SV 341 3171.100 SK 535 2573.100 AX 1053 2735.540 FT 929 3032.000 SV 341 3171.105 SK 535 2574.100 AX 1053 2735.560 FT 929 3052.000 SV 388 3172.100 SK 535 2575.000 SZ 943 2735.570 FT 929 3055.000 SV 388 3172.105 SK 535 2575.100 AX 1053 2735.580 FT 929 3056.000 SV 388 3173.100 SK 535 2576.000 SZ 942 2735.590 FT 929 3057.000 SV 388 3173.105 SK 535 2576.100 AX 1053 2736.500 FT 929 3071.000 SV 358 3174.100 SK 535 2577.100 AX 1053 2736.510 FT 929 3073.000 SV 388 3176.000 SK 539 2580.000 AX 1051 2736.520 FT 929 3074.000 SV 388 3177.000 SK 533 2580.003 AX 1051 2736.530 FT 929 3075.000 SV 388 3181.100 SK 536 2580.004 AX 1051 2736.540 FT 929 3076.000 SV 388 3182.100 SK 536 2580.005 AX 1051 2740.010 AX 931 3079.000 SV 346 3183.100 SK 536 2580.006 AX 1051 2741.010 AX 931 3079.010 SV 346 3185.030 SK 505 1164 Rittal System Catalogue 36 List of model numbers 3185.330 to 3335.930 Model No. Page Model No. Page Model No. Page Model No. 3185.330 SK 497 3239.080 SK 538 3286.610 SK 534 3311.163 SK Page 3185.530 SK 487 3239.100 SK 457 3286.700 SK 556 3311.170 SK 788 3185.730 SK 504 3239.110 SK 457 3286.780 SK 542 3311.180 SK 788 788 3185.830 SK 487 3239.124 SK 457 3286.800 SK 556 3311.190 SK 788 3186.630 SK 489 3239.200 SK 537 3286.840 SK 540 3311.200 SK 788 3186.930 SK 489 3239.500 SK 461 3286.850 SK 541 3311.210 SK 788 3187.630 SK 489 3239.600 SK 459 3286.860 SK 541 3311.270 SK 788 3187.930 SK 489 3240.020 SK 538 3286.870 SK 540 3311.280 SK 788 3188.640 SK 489 3240.060 SK 537 3286.880 SK 542 3311.360 SK 785 3188.940 SK 489 3240.066 SK 535 3286.900 SK 556 3311.363 SK 785 3189.640 SK 489 3240.080 SK 538 3286.970 SK 540 3311.370 SK 785 3189.940 SK 489 3240.100 SK 457 3286.980 SK 542 3311.380 SK 785 3201.050 SK 535 3240.110 SK 457 3286.990 SK 540 3311.490 SK 768 3201.200 SK 474 3240.124 SK 457 3301.320 SK 786 3311.491 SK 770 3201.300 SK 474 3240.200 SK 537 3301.370 SK 786 3311.492 SK 768 3201.800 SK 507 3240.500 SK 461 3301.380 SK 786 3311.493 SK 770 3201.810 SK 507 3240.600 SK 459 3301.390 SK 786 3311.495 SK 785 3201.820 SK 507 3241.100 SK 457 3301.391 SK 1095 3311.496 SK 785 3201.830 SK 507 3241.110 SK 457 3301.392 SK 1096 3312.012 SK 786 3201.840 SK 507 3241.124 SK 457 3301.500 SK 543 3312.081 SK 786 3201.850 SK 507 3241.500 SK 461 3301.505 SK 543 3312.800 SK 764 3201.960 SK 550 3241.600 SK 460 3301.600 SK 544 3312.805 SK 784 3201.970 SK 550 3243.020 SK 538 3301.606 SK 544 3312.806 SK 784 3201.990 SK 545 3243.060 SK 537 3301.608 SK 544 3312.807 SK 784 3209.100 SK 516 3243.066 SK 535 3301.610 SK 544 3312.810 SK 765 3209.500 SK 516 3243.080 SK 538 3301.612 SK 544 3312.815 SK 784 3209.504 SK 516 3243.100 SK 457 3301.930 SK 545 3312.816 SK 784 3210.100 SK 517 3243.110 SK 457 3301.940 SK 545 3312.820 IT 784 3210.500 SK 517 3243.200 SK 537 3301.950 SK 545 3313.016 SK 787 3210.504 SK 516 3243.500 SK 462 3301.955 SK 545 3313.130 SK 781 3210.540 SK 517 3243.600 SK 460 3301.960 SK 545 3313.230 SK 781 3212.024 SK 510 3244.100 SK 458 3301.965 SK 545 3313.250 SK 781 3212.230 SK 510 3244.110 SK 458 3302.100 SK 476 3313.260 SK 781 3213.310 SK 542 3244.140 SK 458 3302.110 SK 476 3313.290 SK 774 3213.320 SK 542 3244.500 SK 462 3302.200 SK 476 3313.390 SK 775 3214.100 SK 510 3244.600 SK 460 3302.300 SK 475 3313.410 SK 774 3214.700 SK 515 3245.080 SK 538 3302.310 SK 475 3313.420 SK 774 3215.100 SK 511 3245.500 SK 462 3303.500 SK 478 3313.430 SK 775 3215.700 SK 515 3245.510 SK 462 3303.504 SK 490 3313.440 SK 775 3216.480 SK 514 3245.600 SK 460 3303.508 SK 495 3313.450 SK 775 3235.440 SK 548 3248.000 SK 470 3303.510 SK 478 3313.460 SK 776 3235.450 SK 548 3273.500 SK 500 3303.514 SK 490 3313.470 SK 776 3236.124 SK 539 3284.210 SK 534 3303.518 SK 495 3313.480 SK 776 3237.020 SK 538 3285.700 SK 536 3303.600 SK 478 3313.530 SK 783 3237.060 SK 537 3285.800 SK 533 3304.500 SK 479 3313.540 SK 783 3237.066 SK 535 3285.810 SK 534 3304.504 SK 490 3313.550 SK 783 3237.080 SK 538 3285.900 SK 533 3304.508 SK 495 3313.560 SK 783 3237.100 SK 456 3285.910 SK 534 3304.510 SK 479 3313.570 SK 783 3237.110 SK 456 3285.920 SK 533 3304.540 SK 479 3318.610 SK 519 3237.124 SK 456 3285.930 SK 534 3304.544 SK 490 3319.610 SK 519 3237.200 SK 537 3285.940 SK 533 3304.548 SK 495 3320.200 SK 523 3237.600 SK 459 3286.110 SK 533 3304.600 SK 479 3321.700 SK 535 3238.020 SK 538 3286.120 SK 534 3304.640 SK 479 3321.705 SK 535 3238.055 SK 536 3286.300 SK 533 3305.500 SK 480 3322.700 SK 535 3238.060 SK 537 3286.310 SK 534 3305.504 SK 490 3322.705 SK 535 3238.066 SK 535 3286.400 SK 533 3305.510 SK 480 3328.500 SK 481 3238.080 SK 538 3286.410 SK 534 3305.540 SK 480 3328.540 SK 481 3238.100 SK 456 3286.500 SK 533 3305.544 SK 490 3328.544 SK 491 3238.110 SK 456 3286.510 SK 534 3305.548 SK 495 3329.500 SK 482 3238.124 SK 456 3286.520 SK 534 3307.700 SK 506 3329.540 SK 482 3238.200 SK 537 3286.530 SK 534 3307.740 SK 506 3329.544 SK 491 3238.500 SK 461 3286.540 SK 534 3310.700 SK 506 3329.548 SK 495 3238.600 SK 459 3286.550 SK 534 3310.740 SK 506 3334.300 SK 523 3239.020 SK 538 3286.560 SK 534 3311.030 SK 785 3334.400 SK 523 3239.060 SK 537 3286.570 SK 534 3311.040 SK 786 3335.920 SK 528 3239.066 SK 535 3286.600 SK 533 3311.161 SK 788 3335.930 SK 528 Rittal System Catalogue 36 1165 List of model numbers 3335.940 to 4051.536 Model No. Page Model No. Page Model No. Page Model No. 3335.940 SK 528 3384.540 SK 500 3565.005 SV 346 4050.456 AS Page 3335.950 SK 529 3384.600 SK 500 3568.005 SV 346 4050.463 AS 637 3335.960 SK 529 3385.500 SK 500 3569.005 SV 346 4050.467 AS 637 636 3335.970 SK 529 3385.510 SK 500 3570.005 SV 346 4050.468 AS 637 3336.400 SK 526 3385.540 SK 500 3571.005 SV 346 4050.722 AS 590 3336.405 SK 526 3385.600 SK 500 3572.005 SV 346 4050.723 AS 590 3336.410 SK 526 3385.640 SK 500 3573.005 SV 346 4050.730 AS 581 3336.415 SK 526 3386.540 SK 501 3574.005 SV 346 4050.731 AS 581 3336.430 SK 527 3386.640 SK 501 3575.005 SV 346 4050.732 AS 581 3336.435 SK 527 3387.540 SK 501 3576.005 SV 346 4050.733 AS 582 3336.450 SK 527 3387.640 SK 501 3577.005 SV 346 4050.734 AS 582 3336.455 SK 527 3418.010 SV 323 3578.005 SV 346 4050.735 AS 582 3340.230 SK 466 3418.020 SV 356 3579.005 SV 346 4050.736 AS 582 3341.115 SK 466 3418.030 SV 356 3580.000 SV 342 4050.737 AS 582 3341.230 SK 466 3418.040 SV 323 3580.100 SV 342 4050.738 AS 582 3342.024 SK 466 3427.010 SV 323 3581.000 SV 342 4050.739 AS 582 3342.230 SK 466 3427.020 SV 356 3581.100 SV 342 4050.740 AS 582 3342.500 SK 466 3427.030 SV 356 3582.000 SV 342 4050.741 AS 582 3350.230 SK 467 3427.040 SV 323 3582.020 SV 342 4050.742 AS 581 3351.230 SK 467 3431.000 SV 325 3583.000 SV 342 4050.743 AS 581 3352.230 SK 467 3431.020 SV 326 3584.000 SV 342 4050.744 AS 581 3352.500 SK 467 3431.030 SV 326 3584.020 SV 342 4050.745 AS 582 3355.100 SK 557 3431.035 SV 326 3585.005 SV 342 4050.746 AS 578 3355.700 SK 557 3433.010 SV 323 3585.020 SV 342 4050.747 AS 578 3355.710 SK 556 3433.020 SV 356 3586.005 SV 342 4050.748 AS 579 3355.720 SK 543 3433.030 SV 356 3586.020 SV 342 4050.749 AS 579 3357.100 SK 557 3433.040 SV 323 3587.000 SV 342 4050.750 AS 580 3359.500 SK 499 3439.010 SV 305 3588.005 SV 342 4050.752 AS 581 3359.510 SK 499 3450.500 SV 349 3589.005 SV 342 4050.754 AS 581 3359.540 SK 499 3450.505 SV 349 3590.005 SV 342 4050.757 AS 581 3359.600 SK 499 3451.500 SV 349 3590.015 SV 342 4050.760 AS 581 3361.500 SK 478 3451.505 SV 349 3590.020 SV 342 4050.761 AS 581 3361.510 SK 478 3452.500 SV 349 3591.060 SV 1039 4050.764 AS 581 3361.540 SK 478 3453.500 SV 349 3592.010 SV 358 4050.766 AS 581 3361.600 SK 478 3454.500 SV 349 3659.180 TS 1090 4050.769 AS 581 3363.100 SK 510 3455.500 SV 349 3659.190 TS 1090 4050.770 AS 582 3363.500 SK 510 3455.505 SV 349 4000.065 HD 223 4050.773 AS 582 3364.100 SK 511 3456.500 SV 349 4000.100 HD 223 4050.774 AS 582 3364.500 SK 511 3456.505 SV 349 4000.240 HD 223 4050.779 AS 582 3364.504 SK 511 3457.500 SV 349 4000.250 HD 223 4050.782 AS 582 3366.500 SK 483 3458.500 SV 349 4050.000 AS 611 4050.783 AS 582 3366.540 SK 483 3459.500 SV 349 4050.005 AS 616 4050.785 AS 582 3373.100 SK 512 3460.500 SV 350 4050.130 AS 613 4051.100 AS 620 3373.140 SK 512 3504.000 SV 344 4050.140 AS 591 4051.101 AS 621 3373.500 SK 512 3505.000 SV 344 4050.150 AS 607 4051.102 AS 621 3374.100 SK 512 3509.000 SV 344 4050.200 AS 607 4051.103 AS 622 3374.140 SK 512 3514.000 SV 344 4050.210 AS 608 4051.104 AS 622 3374.500 SK 512 3515.000 SV 344 4050.211 AS 608 4051.105 AS 623 3374.504 SK 512 3516.000 SV 344 4050.212 AS 608 4051.106 AS 623 3374.540 SK 512 3524.000 SV 344 4050.213 AS 608 4051.107 AS 624 3375.100 SK 513 3525.000 SV 344 4050.214 AS 608 4051.108 AS 624 3375.500 SK 513 3525.010 SV 344 4050.216 AS 609 4051.109 AS 628 3375.504 SK 513 3526.000 SV 344 4050.217 AS 609 4051.110 AS 628 3375.540 SK 513 3527.000 SV 344 4050.218 AS 609 4051.111 AS 625 3377.000 SK 556 3528.000 SV 344 4050.219 AS 610 4051.112 AS 628 3378.300 SK 518 3528.010 SV 344 4050.220 AS 609 4051.113 AS 627 3378.380 SK 518 3529.000 SV 344 4050.221 AS 610 4051.114 AS 625 3382.500 SK 498 3548.000 SV 352 4050.222 AS 610 4051.115 AS 624 3382.510 SK 498 3550.000 SV 349 4050.300 AS 607 4051.116 AS 626 3382.600 SK 498 3554.000 SV 350 4050.435 AS 604 4051.117 AS 626 3383.500 SK 499 3555.000 SV 349 4050.436 AS 604 4051.118 AS 627 3383.510 SK 499 3559.000 SV 350 4050.437 AS 605 4051.119 AS 627 3383.540 SK 499 3560.000 SV 350 4050.451 AS 633 4051.120 AS 625 3383.600 SK 499 3561.000 SV 350 4050.452 AS 635 4051.121 AS 626 3384.500 SK 500 3562.000 SV 350 4050.454 AS 634 4051.525 AS 582 3384.510 SK 500 3563.000 SV 350 4050.455 AS 632 4051.536 AS 578 1166 Rittal System Catalogue 36 List of model numbers 4051.537 to 4127.010 Model No. Page Model No. Page Model No. Page Model No. 4051.537 AS 579 4052.212 AS 567 4055.116 AS 599 4055.550 AS Page 4051.538 AS 579 4052.480 AS 570 4055.118 AS 599 4055.554 AS 596 4051.539 AS 580 4052.500 AS 591 4055.120 AS 599 4055.560 AS 596 596 4051.540 AS 578 4053.000 AS 565 4055.122 AS 599 4055.563 AS 596 4051.541 AS 578 4053.002 AS 571 4055.125 AS 599 4055.580 AS 597 4051.542 AS 579 4053.003 AS 571 4055.128 AS 599 4055.581 AS 597 4051.543 AS 579 4053.011 AS 571 4055.130 AS 599 4055.582 AS 598 4051.544 AS 578 4053.012 AS 571 4055.132 AS 599 4055.600 AS 602 4051.545 AS 579 4053.021 AS 571 4055.134 AS 599 4055.601 AS 602 4051.546 AS 579 4053.022 AS 571 4055.137 AS 599 4055.602 AS 602 4051.547 AS 580 4053.031 AS 571 4055.140 AS 599 4055.603 AS 602 4051.548 AS 578 4053.032 AS 571 4055.143 AS 599 4055.630 AS 602 4051.549 AS 578 4053.041 AS 571 4055.147 AS 599 4055.631 AS 602 4051.550 AS 579 4053.042 AS 571 4055.149 AS 599 4055.632 AS 602 4051.551 AS 579 4053.043 AS 571 4055.150 AS 599 4055.633 AS 602 4051.597 AS 578 4053.044 AS 571 4055.154 AS 599 4055.634 AS 602 4051.598 AS 578 4053.045 AS 571 4055.160 AS 599 4055.660 AS 603 4051.599 AS 578 4053.046 AS 571 4055.161 AS 599 4055.661 AS 603 4051.600 AS 579 4053.047 AS 571 4055.163 AS 599 4055.662 AS 603 4051.601 AS 579 4053.300 AS 572 4055.180 AS 600 4055.663 AS 603 4051.602 AS 579 4053.310 AS 573 4055.212 AS 594 4055.664 AS 603 4051.603 AS 579 4053.400 AS 572 4055.215 AS 594 4055.665 AS 603 4051.604 AS 580 4053.410 AS 572 4055.216 AS 594 4055.690 AS 603 4051.605 AS 580 4053.420 AS 572 4055.218 AS 594 4055.700 AS 640 4051.638 AS 582 4053.450 AS 569 4055.220 AS 594 4055.710 AS 641 4051.641 AS 582 4053.500 AS 565 4055.222 AS 594 4055.712 AS 644 4051.644 AS 582 4054.000 AS 575 4055.225 AS 594 4055.714 AS 645 4051.647 AS 582 4054.001 AS 575 4055.228 AS 594 4055.720 AS 644 4051.695 AS 578 4054.002 AS 574 4055.232 AS 594 4055.740 AS 643 4051.696 AS 579 4054.003 AS 574 4055.237 AS 594 4055.741 AS 643 4051.697 AS 579 4054.004 AS 575 4055.240 AS 594 4055.742 AS 643 4051.698 AS 580 4054.008 AS 575 4055.247 AS 594 4055.743 AS 643 4052.000 AS 590 4054.020 AS 576 4055.250 AS 594 4055.744 AS 643 4052.001 AS 568 4054.021 AS 576 4055.254 AS 594 4055.745 AS 643 4052.003 AS 568 4054.023 AS 576 4055.260 AS 594 4055.746 AS 643 4052.004 AS 568 4054.024 AS 576 4055.263 AS 594 4055.747 AS 643 4052.007 AS 568 4054.030 AS 574 4055.322 AS 600 4055.748 AS 643 4052.011 AS 568 4054.080 AS 575 4055.345 AS 600 4055.749 AS 643 4052.014 AS 568 4054.081 AS 575 4055.346 AS 600 4055.750 AS 643 4052.018 AS 568 4054.140 AS 577 4055.350 AS 600 4055.770 AS 643 4052.021 AS 568 4054.141 AS 577 4055.368 AS 600 4055.771 AS 643 4052.022 AS 568 4054.300 AS 583 4055.392 AS 600 4055.772 AS 643 4052.031 AS 568 4054.305 AS 583 4055.400 AS 601 4055.773 AS 643 4052.032 AS 568 4054.310 AS 583 4055.401 AS 601 4055.774 AS 643 4052.038 AS 568 4054.315 AS 583 4055.402 AS 601 4055.775 AS 643 4052.053 AS 568 4054.400 AS 583 4055.403 AS 601 4055.776 AS 643 4052.054 AS 568 4054.405 AS 583 4055.440 AS 601 4055.777 AS 643 4052.055 AS 568 4054.410 AS 584 4055.441 AS 601 4055.778 AS 643 4052.056 AS 568 4054.600 AS 585 4055.460 AS 602 4055.779 AS 643 4052.058 AS 568 4054.650 AS 585 4055.461 AS 602 4055.780 AS 643 4052.101 AS 566 4054.660 AS 585 4055.463 AS 602 4055.791 AS 644 4052.102 AS 566 4054.700 AS 586 4055.465 AS 602 4055.800 AS 642 4052.104 AS 566 4054.750 AS 585 4055.480 AS 595 4055.806 AS 645 4052.106 AS 566 4054.800 AS 587 4055.481 AS 595 4055.807 AS 645 4052.107 AS 566 4054.850 AS 587 4055.512 AS 596 4114.000 PS 955 4052.121 AS 566 4054.860 AS 587 4055.515 AS 596 4115.000 PS 955 4052.122 AS 566 4054.870 AS 586 4055.516 AS 596 4115.500 CM 955 4052.131 AS 566 4054.900 AS 588 4055.518 AS 596 4116.000 PS 955 4052.132 AS 566 4055.000 AS 592 4055.520 AS 596 4116.500 CM 955 4052.141 AS 566 4055.010 AS 592 4055.522 AS 596 4118.000 PS 955 4052.142 AS 566 4055.020 AS 592 4055.525 AS 596 4118.500 CM 955 4052.200 AS 569 4055.041 AS 592 4055.528 AS 596 4119.000 PS 1003 4052.201 AS 569 4055.070 AS 593 4055.532 AS 596 4120.000 PS 954 4052.202 AS 569 4055.080 AS 593 4055.537 AS 596 4123.000 PS 955 4052.210 AS 567 4055.085 AS 593 4055.540 AS 596 4124.000 PS 955 4052.211 AS 567 4055.115 AS 599 4055.547 AS 596 4127.010 SZ 1024 Rittal System Catalogue 36 1167 List of model numbers 4133.000 to 5307.154 Model No. 4133.000 TS Page Model No. 1001 4594.000 TS Page Model No. 952 5301.310 Page Model No. VX 914 5302.030 Page VX 1087 4134.000 TS 1001 4595.000 TS 967 5301.312 VX 914 5302.031 VX 1087 4140.000 SZ 1025 4596.000 TS 994 5301.315 VX IT 904 5302.032 VX 1087 4140.810 SZ 1025 4597.000 SZ 999 5301.317 VX IT 904 5302.033 VX 1087 4140.820 SZ 1025 4598.000 TS 952 5301.319 VX IT 904 5302.034 VX 1087 4140.830 SZ 1025 4599.000 TS 952 5301.321 VX IT 904 5302.035 DK 1088 4140.840 SZ 1025 4599.100 TS 952 5301.325 VX 894 5302.036 VX 1068 4157.000 SZ 1003 4599.200 TS 952 5301.326 VX 892 5302.037 VX 1005 4162.000 TS 1003 4612.000 PS 892 5301.330 VX 897 5302.038 VX 1063 4163.000 TS 1003 4638.600 PS 953 5301.331 VX 897 5302.041 SK 546 4164.500 VX 1002 4638.800 PS 953 5301.332 VX 897 5302.043 DK 1074 1063 4165.500 VX 1002 4650.150 PC 252 5301.333 VX 897 5302.044 DK 4166.500 VX 1002 4694.000 TS 952, 994 5301.334 VX 898 5302.046 DK 1069 4169.000 SZ 994 4695.000 TS 952, 994 5301.335 VX 898 5302.051 DK 1068 4170.000 SZ 994 4696.000 TS 952, 994 5301.336 VX 897 5302.052 DK 1068 4171.000 SZ 994 4697.000 TS 952, 994 5301.337 VX 897 5302.053 DK 1068 4172.000 SZ 994 4911.000 TS 910 5301.338 VX 897 5302.100 VX IT 1081 4173.000 SZ 994 4911.100 TS 910 5301.341 VX 897 5302.101 VX IT 1081 4174.000 SZ 994 4912.000 TS 910 5301.344 VX 897 5302.102 VX IT 1081 4175.000 SZ 994 4916.000 TS 910 5301.347 VX 897 5302.103 VX IT 1081 4176.000 SZ 994 4918.000 TS 910 5301.348 VX 898 5302.104 VX IT 1081 4177.000 SZ 994 4920.000 TS 910 5301.350 TS 900 5302.105 VX IT 1081 4178.000 SZ 994 4933.000 SZ 997 5301.400 VX 951 5302.106 VX IT 1081 4179.000 SZ 1003 4934.000 SZ 997 5301.401 VX 951 5302.107 VX IT 1081 4180.000 SZ 1003 4935.000 SZ 997 5301.403 VX 951 5302.108 VX IT 1081 4182.000 SZ 1002 4937.000 SZ 997 5301.423 VX IT 920 5302.109 VX IT 1081 4199.000 TS 1001 4943.000 SZ 996 5301.437 DK 920 5302.110 VX IT 1082 4309.000 TS 994 4944.000 SZ 996 5301.438 DK 920 5302.111 VX IT 1083 4311.000 SZ 1044 4945.000 SZ 996 5301.446 DK 922 5302.112 VX IT 1083 4315.800 SZ 1026 4946.000 SZ 996 5301.450 DK 922 5302.120 VX 1066 4315.810 SZ 1026 4947.000 SZ 996 5301.453 DK 922 5302.122 VX 1066 4315.820 SZ 1026 5001.050 CM 995 5301.515 VX 894 5302.123 IT 1084 4315.830 SZ 1026 5001.051 CM 995 5301.516 VX 894 5302.124 IT 1084 4315.840 SZ 1026 5001.052 CM 995 5301.518 VX 894 5302.152 VX IT 1082 4315.850 SZ 1026 5001.053 CM 995 5301.540 DK 921 5302.153 VX IT 1082 4315.860 SZ 1026 5001.054 CM 995 5301.542 DK 921 5302.154 VX IT 1082 4316.000 SZ 1044 5001.075 CM 981 5301.561 DK 922 5302.155 VX IT 1082 4317.000 SZ 1044 5001.080 CM 1059 5301.571 DK 922 5302.156 VX IT 1082 4318.000 SZ 1044 5001.081 CM 1059 5301.602 DK 921 5302.157 VX IT 1082 4319.090 SZ 1061 5001.082 CM 1059 5301.612 DK 921 5302.160 VX IT 1082 4319.120 SZ 1061 5001.083 CM 1059 5301.652 DK 923 5302.161 VX IT 1083 4319.160 SZ 1061 5001.130 CM 157, 163 5302.000 DK 1095 5302.164 VX IT 1083 4319.200 SZ 1061 5001.140 CM 158, 163 5302.001 DK 1095 5302.166 VX IT 1083 4333.120 TS 974 5001.160 CM 159, 163 5302.002 DK 1095 5302.167 VX IT 1083 4333.160 TS 974 5001.370 CM 995 5302.003 DK 1095 5302.169 VX IT 1082 4333.180 TS 974 5301.235 VX 902 5302.004 DK 1095 5302.170 VX IT 1084 4348.500 VX 1028 5301.236 VX 903 5302.005 DK 1095 5302.200 DK 1093 4393.000 SZ 994 5301.242 VX 903 5302.006 DK 1095 5302.201 IT 1093 4394.000 TS 996 5301.243 VX 903 5302.007 DK 1095 5302.202 DK 1074 1065 4395.000 TS 996 5301.244 VX 903 5302.008 DK 1095 5302.203 DK 4396.000 TS 996 5301.245 VX 903 5302.009 DK 1095 5302.204 DK 1097 4396.500 TS 996 5301.246 VX 903 5302.010 DK 1094 5302.205 DK 1115 4398.000 TS 996 5301.250 VX 902 5302.011 DK 1094 5302.322 VX 1066 4398.500 TS 996 5301.254 VX 902 5302.012 DK 1094 5303.114 VX 687 4531.001 VX 1089 5301.257 VX 902 5302.013 DK 1094 5303.124 VX 692 4532.000 SZ 999 5301.261 VX 902 5302.014 DK 1094 5303.134 VX 696 4538.000 TS 956 5301.264 VX 902 5302.015 DK 1094 5303.154 VX 697 4540.000 TS 915 5301.265 VX 902 5302.016 DK 1094 5304.116 VX 687 4568.000 SZ 964 5301.270 VX IT 904 5302.017 DK 1094 5304.126 VX 692 4568.500 SZ 964 5301.274 VX IT 904 5302.020 VX 1063 5305.124 VX 693 4579.000 TS 994 5301.281 VX IT 904 5302.021 VX 1063 5306.122 VX 693 4583.000 SZ 956 5301.284 VX IT 904 5302.022 VX 1063 5306.190 VX 699 4583.500 TS 956 5301.287 VX IT 904 5302.025 VX 1063 5307.114 VX 687 4590.700 TS 971 5301.291 VX IT 904 5302.026 IT 1074 5307.124 VX 693 4591.700 TS 971 5301.300 VX IT 904 5302.027 DK 1035 5307.134 VX 696 4592.700 TS 971 5301.303 VX IT 904 5302.028 VX 1035 5307.154 VX 697 1168 Rittal System Catalogue 36 List of model numbers 5307.157 to 6372.552 Model No. Page Model No. Page Model No. Page Model No. 5307.157 VX 698 5501.410 DK 1086 6013.000 CP 1106 6206.820 CP Page 5307.190 VX 699 5501.420 DK 1086 6013.100 CP 1106 6206.850 CP 210 5308.113 VX 687 5501.430 DK 1086 6016.200 CP 968 6206.870 CP 210 195 5308.123 VX 693 5501.440 DK 1086 6027.010 CP 1107 6206.900 CP 1125 5308.190 VX 699 5501.450 DK 1086 6028.010 CP 1107 6212.025 CP 199 5308.813 VX 689 5501.460 DK 1088 6028.014 CP 1107 6212.050 CP 199 5308.823 VX 695 5501.615 DK 1010 6028.015 CP 1107 6212.060 CP 206 5309.116 VX 687 5501.625 DK 1010 6028.016 CP 1107 6212.065 CP 206 5309.126 VX 694 5501.635 DK 1010 6028.500 CP 1107 6212.100 CP 199 5309.136 VX 696 5501.655 DK 1008 6028.510 CP 1107 6212.110 CP 199 5309.156 VX 697 5501.665 DK 1008 6028.530 CP 1107 6212.120 CP 206 5309.166 VX 691 5501.675 DK 1008 6028.540 CP 1107 6212.150 CP 199 5309.190 VX 699 5501.685 DK 1008 6052.000 CP 1060 6212.200 CP 199 5309.816 VX 689 5501.695 DK 1008 6052.500 CP 1048 6212.210 CP 199 5309.826 VX 695 5501.705 DK 1008 6053.000 CP 1108 6212.300 CP 199 5310.118 VX 687 5501.715 DK 1008 6053.210 CP 1108 6212.320 CP 199 5310.128 VX 693 5501.725 DK 1008 6053.300 CP 1108 6212.380 CP 199 5310.818 VX 689 5501.730 DK 1011 6053.500 CP 1108 6212.500 CP 199 5311.116 VX 687 5501.895 DK 1085 6053.800 CP 1108 6212.520 CP 203 5311.126 VX 694 5501.900 DK 1091 6058.000 CP 1108 6212.540 CP 208 5311.816 VX 689 5502.010 DK 790 6058.500 CP 1108 6212.600 CP 199 5311.826 VX 695 5502.020 DK 790 6106.100 CP 211 6212.620 CP 199 5312.114 VX 688 5502.110 DK 1092 6106.110 CP 214 6212.640 CP 199 5312.124 VX 694 5502.115 DK 1069 6106.200 CP 211 6212.680 CP 199 5313.113 VX 688 5502.155 DK 1062 6106.300 CP 212 6212.700 CP 199 5313.813 VX 690 5502.205 DK 1072 6106.400 CP 211 6212.720 CP 199 5314.116 VX 688 5502.225 DK 1073 6106.500 CP 213 6212.740 CP 199 5314.126 VX 694 5502.235 DK 1073 6107.000 CP 1105 6212.760 CP 199 5314.816 VX 690 5502.245 DK 1073 6107.100 CP 1105 6212.780 CP 199 5315.118 VX 688 5502.305 DK 1091 6107.200 CP 1105 6212.800 CP 199 5315.818 VX 690 5502.325 DK 1091 6108.000 CP 1003 6212.820 CP 199 5316.116 VX 688 5502.405 DK 1064 6112.500 CP 213 6212.900 CP 1125 5316.816 VX 690 5820.600 SE 143 6141.200 IW 212 6218.050 CP 203 5325.121 VX 692 5821.600 SE 143 6143.310 CP 214 6218.100 CP 203 5325.190 VX 699 5822.600 SE 144 6146.100 CP 211 6218.110 CP 203 5326.121 VX 692 5823.600 SE 144 6146.200 CP 211 6218.150 CP 203 5326.131 VX 696 5824.600 SE 145 6146.300 CP 211 6218.200 CP 203 5326.190 VX 699 5825.600 SE 145 6147.000 CP 214 6218.210 CP 203 5327.121 VX 692 5830.600 SE 143 6148.000 CP 893 6218.300 CP 203 5327.190 VX 699 5830.680 SE 147 6205.100 CP 1000 6218.600 CP 203 5328.123 VX 693 5831.600 SE 144 6206.025 CP 195 6218.620 CP 203 5328.190 VX 699 5831.680 SE 147 6206.050 CP 195 6218.640 CP 203 5329.111 VX 687 5832.600 SE 144 6206.100 CP 195 6218.700 CP 203 5329.121 VX 693 5833.600 SE 144 6206.110 CP 195 6218.740 CP 203 5329.131 VX 696 5834.600 SE 144 6206.200 CP 195 6218.820 CP 203 5329.190 VX 699 5834.680 SE 147 6206.300 CP 195 6315.150 AX 179 5330.113 VX 687 5840.600 SE 145 6206.320 CP 195 6315.250 AX 179 5330.123 VX 693 5841.600 SE 145 6206.340 CP 195 6315.350 AX 179 5330.133 VX 696 5842.600 SE 146 6206.350 CP 210 6315.450 AX 179 5330.190 VX 699 5843.600 SE 145 6206.360 CP 195 6315.650 AX 179 5331.113 VX 687 5844.600 SE 145 6206.380 CP 195 6320.050 AX 179 5331.190 VX 699 5845.600 SE 145 6206.400 CP 195 6320.350 AX 179 5332.818 VX 690 5846.600 SE 146 6206.420 CP 209 6320.450 AX 179 5333.816 VX 690 5850.600 SE 249 6206.440 CP 195 6320.550 AX 179 5334.813 VX 690 5850.680 SE 250 6206.460 CP 209 6320.650 AX 179 5335.816 VX 690 5851.600 SE 249 6206.480 CP 207 6321.010 SM 1115 5366.050 PC 164 5852.600 SE 249 6206.490 CP 207 6321.050 AX 180 5366.150 PC 164 5852.680 SE 250 6206.500 CP 208 6340.000 CP 181 5366.250 PC 164 5853.600 SE 249 6206.550 CP 210 6340.100 CP 181 5366.350 PC 164 5853.680 SE 250 6206.600 CP 195 6340.300 CP 181 5366.450 PC 165 5854.600 SE 249 6206.620 CP 195 6340.400 CP 181 5368.050 PC 165 5855.600 SE 249 6206.640 CP 195 6341.000 CP 969 5380.830 VX 701 6002.000 CP 1113 6206.650 CP 214 6372.541 CP 172 5381.830 VX 701 6002.130 SM 1110 6206.700 CP 195 6372.542 CP 172 5386.050 PC 165 6003.000 CP 1114 6206.740 CP 195 6372.543 CP 172 5501.400 DK 1086 6005.500 CP 969 6206.800 CP 195 6372.552 CP 172 Rittal System Catalogue 36 1169 List of model numbers 6372.553 to 7161.700 Model No. 6372.553 CP Page Model No. 172 6721.500 Page Model No. TP 158 7030.233 IT Page Model No. 813 7094.110 Page DK 1098 1098 6372.562 CP 172 6722.500 TP 159 7030.262 VX IT 817, 919 7094.120 DK 6372.563 CP 172 6723.500 TP 160 7030.263 VX IT 817, 919 7094.130 DK 1098 6375.010 CP 1103 6730.030 TP 160, 163 7030.272 VX IT 817, 919 7094.140 DK 1098 6380.000 CP 174 6730.100 TP 157, 163 7030.273 VX IT 817, 919 7097.000 DK 1060 6380.020 CP 174 6730.110 TP 158, 163 7030.282 VX IT 817, 919 7097.220 DK 1060 6380.040 CP 174 6730.120 TP 159, 163 7030.283 VX IT 817, 919 7097.260 DK 1060 6380.400 CP 174 6730.130 TP 160, 163 7030.400 DK 807 7097.300 DK 1060 6380.410 CP 174 6730.310 TP 982 7030.430 DK 807 7097.340 DK 1060 6380.510 CP 174 6730.330 TP 982 7030.440 DK 807 7098.000 DK 1060 6380.610 CP 174 6730.340 TP 982 7030.480 DK 818 7098.100 DK 1060 6385.010 CP 1103 6731.120 TP 163 7030.490 DK 818 7099.000 DK 1060 6446.030 SM 1111 6740.600 TP 161 7030.501 DK 817 7100.200 IT 870 6450.010 SM 1109 6742.600 TP 161 7030.571 DK 820 7100.221 IT 870 6450.020 SM 1109 6746.600 TP 161 7030.601 IT 946 7100.312 DK 871 6450.050 SM 1109 6748.600 TP 161 7030.611 IT 946 7100.401 IT 871 6450.060 SM 1109 6900.000 IW 167 7030.621 IT 815, 947 7100.501 IT 871 6450.070 SM 1109 6900.100 IW 167 7030.624 IT 948 7100.911 IT 872 6450.170 SM 1109 6900.400 IW 167 7030.628 IT 814 7100.912 IT 872 6501.000 CP 187 6900.410 IW 167 7030.690 DK 815 7100.913 IT 872 6501.020 CP 187 6901.100 IW 167 7030.692 IT 948 7100.914 IT 872 6501.050 CP 187 6902.100 IW 167 7030.695 IT 948 7100.915 IT 872 6501.070 CP 187 6902.300 IW 167 7030.950 IT 821 7100.921 IT 872 6501.110 CP 187 6902.310 IW 212 7044.010 DK 1070 7100.922 IT 872 6501.120 CP 187 6902.700 IW 1007 7044.020 DK 1071 7100.923 IT 872 6501.130 CP 187 6902.770 IW 1046 7044.110 DK 1069 7100.924 IT 872 6501.140 CP 187 6902.950 IW 1116 7044.113 DK 1070 7100.925 IT 872 6501.150 CP 187 6902.960 IW 1007 7044.120 DK 1069 7100.931 IT 873 6501.160 CP 187 6902.980 IW 1007 7044.123 DK 1070 7100.932 IT 873 6505.100 CP 1107 6903.200 IW 1116 7044.130 DK 1069 7100.933 IT 873 6505.200 CP 1107 7000.620 TE 1008 7044.133 DK 1070 7100.934 IT 873 6505.500 CP 1107 7000.625 DK 1009 7044.140 DK 1069 7100.935 IT 873 6514.200 CP 1112 7000.630 DK 1041 7044.143 DK 1070 7100.951 IT 873 6535.010 CP 254 7000.672 TE 895 7044.150 DK 1069 7100.961 IT 872 6536.010 CP 254 7000.675 TE 1036 7044.153 DK 1070 7100.962 IT 872 6538.010 CP 254 7000.684 TE 751 7044.160 DK 1069 7100.963 IT 873 6539.010 CP 254 7000.685 DK 1066 7044.163 DK 1070 7109.035 SK 546 1064 6660.010 CP 189 7000.688 DK 752 7044.170 DK 1069 7111.000 DK 6660.050 CP 189 7000.990 DK 1099 7044.173 DK 1070 7111.212 DK 1067 6663.000 CP 189 7030.000 DK 805 7044.178 DK 1071 7111.214 DK 1067 6663.400 CP 189 7030.010 DK 805 7044.210 DK 1071 7111.222 DK 1067 6663.500 CP 189 7030.040 DK 806 7044.211 DK 1071 7111.224 DK 1067 6664.000 CP 189 7030.050 DK 806 7044.230 DK 1071 7111.300 DK 1062 6664.100 CP 189 7030.051 DK 820 7044.231 DK 1071 7111.310 DK 1062 6664.300 CP 189 7030.060 DK 818 7044.240 DK 1071 7111.350 DK 1062 6664.500 CP 189 7030.071 DK 820 7044.241 DK 1071 7111.900 DK 1064 6665.000 CP 189 7030.080 DK 818 7050.035 DK 1102 7112.000 DK 1064 6665.500 CP 189 7030.087 DK 819 7050.100 DK 1102 7113.000 DK 1036 6681.000 CP 253 7030.088 DK 819 7061.000 DK 1011 7115.000 DK 1011 6700.600 TP 157 7030.090 DK 818 7063.200 DK 1072 7116.500 DK 1065 6701.600 TP 158 7030.091 DK 818 7063.740 DK 1087 7119.140 DK 1009 6702.600 TP 159 7030.092 DK 818 7063.750 IT 1089 7119.250 DK 1010 6703.600 TP 160 7030.093 DK 818 7063.752 IT 1089 7119.400 DK 1010 6704.600 TP 157 7030.094 DK 818 7064.000 DK 1011 7151.005 DK 1093 6705.600 TP 158 7030.095 DK 818 7065.000 DK 1011 7151.035 DK 1093 6706.600 TP 159 7030.100 DK 808 7066.000 DK 1011 7151.300 DK 1097 6707.600 TP 160 7030.110 DK 807 7066.700 DK 1011 7152.005 DK 1093 6710.500 TP 157 7030.111 DK 807 7072.100 DK 1047 7152.035 DK 1093 6711.500 TP 158 7030.120 DK 807 7072.200 DK 1055 7153.005 DK 1093 6712.500 TP 159 7030.128 DK 808 7072.220 DK 1061 7153.035 DK 1093 6713.500 TP 160 7030.130 DK 807 7072.230 DK 1061 7156.005 DK 1093 6714.500 TP 157 7030.140 DK 807 7072.240 DK 1061 7156.035 DK 1093 6715.500 TP 158 7030.150 DK 807 7077.000 DK 1060 7157.035 DK 1093 6716.500 TP 159 7030.190 DK 807 7078.000 DK 1060 7159.017 DK 1072 6717.500 TP 160 7030.202 DK 812 7081.000 DK 1011 7161.000 DK 1011 6720.500 TP 157 7030.223 DK 813 7094.100 DK 1098 7161.700 DK 1011 1170 Rittal System Catalogue 36 List of model numbers 7163.560 to 7979.131 Model No. Page Model No. Page Model No. Page Model No. 7163.560 DK 1011 7338.221 DK 824 7544.000 DK 1036 7856.321 DK 745 7163.565 DK 1011 7338.321 DK 825 7545.000 DK 1036 7856.323 DK 745 7164.035 DK 1006 7391.000 DK 709 7546.000 DK 1036 7859.000 DK 1027 7165.035 DK 1006 7396.000 DK 709 7547.000 DK 1036 7859.010 DK 1027 7166.035 DK 1006 7400.000 DK 709 7548.000 DK 1036 7859.020 DK 1027 7166.735 DK 1006 7401.000 DK 1079 7548.210 IT 1034 7859.050 DK 747 7169.535 DK 1101 7402.000 DK 1079 7549.000 DK 1037 7859.053 DK 747 7170.535 DK 1100 7445.000 DK 709 7641.350 AX IT 719 7859.060 DK 751 7178.535 DK 1101 7451.000 DK 720 7643.350 AX IT 719 7859.065 DK 751 7184.035 DK 1006 7462.000 DK 1101 7645.350 AX IT 719 7859.080 DK 746 7185.035 DK 1006 7463.100 DK 1101 7646.400 AX IT 719 7859.081 DK 746 7186.035 DK 1006 7463.200 DK 1101 7688.000 DK 268 7859.090 DK 746 7186.735 DK 1006 7464.035 DK 1006 7696.000 DK 268 7859.120 DK 748 7200.210 DK 819 7465.035 DK 1006 7698.000 DK 268 7859.130 DK 748 7200.215 DK 819 7466.035 DK 1006 7705.035 DK 1055 7859.410 DK 750 7200.216 DK 819 7466.735 DK 1006 7705.110 DK 949 7859.420 DK 750 7200.217 DK 819 7470.535 DK 1100 7705.120 DK 949 7859.430 DK 750 7200.810 DK 949 7474.535 DK 1101 7705.235 EL 1054 7888.390 TE 704 7220.500 DK 1066 7478.535 DK 1101 7706.135 DK 716 7888.410 TE 704 7220.600 DK 1064 7480.035 DK 1043 7709.135 DK 716 7888.430 TE 704 7240.110 DK 1040 7480.300 DK 1043 7709.535 DK 715 7888.440 TE 704 7240.120 DK 1040 7484.035 DK 1006 7709.735 DK 715 7888.460 TE 705 7240.200 DK 1040 7485.035 DK 1006 7712.135 DK 716 7888.500 TE 704 7240.201 DK 1040 7486.035 DK 1006 7715.135 DK 716 7888.510 TE 704 7240.210 DK 1040 7486.735 DK 1006 7715.535 DK 715 7888.520 TE 705 7240.220 DK 1040 7494.000 DK 1079 7715.735 DK 715 7888.530 TE 705 7240.230 DK 1040 7495.000 DK 893 7721.135 DK 716 7888.532 TE 705 7240.240 DK 1040 7501.000 DK 712 7721.535 DK 715 7888.610 DK 963 7240.260 DK 1040 7507.000 DK 713 7721.735 DK 715 7888.612 DK 963 7240.280 DK 1040 7507.010 DK 713 7752.950 DK 1037 7888.615 TE 1024 7240.301 DK 1041 7507.020 DK 714 7824.540 DK 913 7888.640 TE 916 7240.310 DK 1040 7507.030 DK 714 7825.375 DK 1055 7888.652 TE 903 7240.330 DK 1040 7507.100 DK 713 7826.605 DK 963 7888.653 TE 903 7240.510 DK 1040 7507.110 DK 713 7826.665 DK 963 7888.840 TE 706 7241.005 DK 1099 7507.120 DK 714 7826.685 DK 963 7888.850 TE 706 7241.024 DK 1100 7507.200 DK 714 7826.750 DK 791 7888.875 TE 707 7241.045 DK 1100 7507.210 DK 714 7826.805 DK 963 7888.882 TE 707 7246.010 DK 1091 7507.220 DK 714 7826.825 TS 963 7888.892 TE 707 7246.030 DK 1091 7507.706 DK 1085 7826.865 DK 963 7888.940 TE 708 7246.060 DK 1091 7507.709 DK 1085 7826.885 DK 963 7888.944 TE 708 7246.100 DK 1090 7507.712 DK 1085 7827.544 DK 1096 7888.950 DK 963 7246.400 DK 1090 7507.715 DK 1085 7829.150 DK 1035 7950.100 DK 1085 7246.420 DK 1084 7507.718 DK 1085 7829.200 DK 1034 7950.150 DK 957 7246.500 DK 1097 7507.721 DK 1085 7831.472 TS 1065 7950.200 DK 957 7257.005 DK 1072 7507.740 DK 892 7856.005 DK 745 7955.010 DK 752 7257.035 DK 1072 7507.750 DK 891 7856.006 DK 745 7955.015 DK 752 7257.100 DK 1072 7507.755 DK 891 7856.008 DK 745 7963.310 DK 1088 7257.105 DK 1072 7507.760 SK 791 7856.010 DK 745 7963.410 DK 1088 7257.200 DK 1072 7526.750 TE 899 7856.013 DK 752 7963.510 DK 1088 7280.035 DK 1042 7526.755 TE 899 7856.014 DK 751 7963.610 DK 1088 7280.100 DK 1042 7526.760 TE 899 7856.020 DK 745 7963.710 DK 1088 7281.035 DK 1115 7526.770 TE 899 7856.025 DK 751 7967.000 DK 964 7281.200 DK 1114 7526.780 TE 899 7856.026 DK 751 7979.001 7282.035 DK 1091 7526.785 TE 899 7856.027 DK 751 7979.020 DK 752 7282.135 DK 1091 7526.790 TE 899 7856.030 DK 751 7979.102 DK 733 7283.035 DK 1091 7526.795 TE 899 7856.070 DK 748 7979.103 DK 733 7296.000 DK 1079 7526.800 TE 899 7856.080 DK 748 7979.104 DK 733 7297.000 DK 1079 7526.820 TE 899 7856.082 DK 748 7979.110 DK 733 7298.000 DK 1079 7526.829 TE 899 7856.090 DK 748 7979.111 DK 733 7299.000 DK 1079 7526.834 TE 899 7856.100 DK 748 7979.112 DK 733 7320.570 DK 808 7526.850 TE 899 7856.120 DK 748 7979.113 DK 733 7320.700 DK 812, 950 7526.860 TE 899 7856.170 DK 751 7979.114 DK 733 7320.814 DK 819 7526.964 TS 999 7856.191 DK 748 7979.115 DK 733 7338.121 DK 823 7541.000 DK 1036 7856.220 DK 748 7979.116 DK 733 7338.130 DK 826 7542.000 DK 1036 7856.230 DK 748 7979.130 DK 733 7338.135 DK 826 7543.000 DK 1036 7856.240 DK 748 7979.131 DK 733 Rittal System Catalogue 36 Page 736 1171 List of model numbers 7979.132 to 8609.203 Model No. Page Model No. Page Model No. Page Model No. 7979.132 DK 733 7979.430 DK 735 7998.306 DK 851 8128.245 VX Page 7979.133 DK 733 7979.431 DK 735 7998.307 DK 851 8145.245 VX 901 7979.134 DK 733 7979.432 DK 735 7998.406 DK 850 8165.245 VX 901 7979.135 DK 733 7979.433 DK 735 7998.407 DK 850 8166.245 VX 901 7979.136 DK 733 7979.434 DK 735 7998.506 DK 851 8168.245 VX 901 7979.137 DK 733 7979.435 DK 735 7998.606 DK 851 8170.245 VX 901 7979.138 DK 733 7979.436 DK 735 7998.607 DK 851 8173.245 VX 901 7979.139 DK 733 7979.437 DK 735 7998.905 DK 850, 851 8175.245 VX 901 7979.140 DK 733 7979.438 DK 735 7998.906 DK 850, 851 8176.245 VX 901 7979.141 DK 733 7979.439 DK 735 7998.907 DK 850, 851 8184.245 VX 901 7979.142 DK 733 7979.440 DK 735 7998.908 DK 850, 851 8185.245 VX 901 7979.143 DK 733 7979.442 DK 735 7999.009 DK 844 8186.245 VX 901 7979.202 DK 733 7979.502 DK 734 7999.709 DK 846 8188.245 VX 901 7979.203 DK 733 7979.503 DK 734 8001.210 VX 896 8204.000 VX 123 7979.204 DK 733 7979.504 DK 734 8001.211 VX 896 8205.000 VX 124 7979.210 DK 733 7979.510 DK 734 8001.212 VX 896 8206.000 VX 125 7979.211 DK 733 7979.511 DK 734 8001.213 VX 896 8208.000 VX 126 7979.212 DK 733 7979.512 DK 734 8001.214 VX 896 8215.000 VX 117 7979.213 DK 733 7979.513 DK 734 8001.215 VX 896 8226.000 VX 127 7979.214 DK 733 7979.514 DK 734 8001.216 VX 896 8245.000 VX 118 7979.215 DK 733 7979.515 DK 734 8001.217 VX 896 8265.000 VX 119 7979.216 DK 733 7979.516 DK 734 8001.218 VX 896 8284.000 VX 120 7979.230 DK 733 7979.530 DK 734 8001.219 VX 896 8285.000 VX 121 7979.231 DK 733 7979.531 DK 734 8001.220 VX 896 8286.000 VX 122 7979.232 DK 733 7979.532 DK 734 8001.221 VX 896 8405.000 VX 124 7979.233 DK 733 7979.533 DK 734 8001.222 VX 896 8406.000 VX 125 7979.234 DK 733 7979.534 DK 734 8001.223 VX 896 8410.000 VX 130 7979.235 DK 733 7979.535 DK 734 8001.224 VX 896 8418.000 VX 130 7979.236 DK 733 7979.536 DK 734 8001.225 VX 896 8430.000 VX 130 7979.237 DK 733 7979.537 DK 734 8001.239 VX 896 8438.000 VX 130 7979.238 DK 733 7979.538 DK 734 8001.241 VX 896 8450.000 VX 245 7979.239 DK 733 7979.539 DK 734 8001.242 VX 896 8451.000 VX 245 7979.240 DK 733 7979.540 DK 734 8001.243 VX 896 8452.000 VX 245 7979.242 DK 733 7979.542 DK 734 8004.000 VX 123 8453.000 VX 244 7979.302 DK 734 7979.711 DK 753 8005.000 VX 124 8454.000 VX 243 7979.303 DK 734 7979.712 DK 753 8006.000 VX 125 8455.000 VX 244 7979.304 DK 734 7979.713 DK 753 8080.000 VX 120 8456.000 VX 243 7979.310 DK 734 7979.714 DK 753 8084.000 VX 120 8457.000 VX 244 7979.311 DK 734 7979.721 DK 754 8100.245 VX 901 8458.000 VX 246 7979.312 DK 734 7979.722 DK 754 8100.700 VX 884 8485.000 VX 121 7979.313 DK 734 7979.723 DK 754 8100.710 VX 886 8486.000 VX 122 7979.314 DK 734 7979.724 DK 754 8100.711 VX 886 8600.255 TS 884 7979.315 DK 734 7979.801 DK 735 8100.730 VX 991 8600.265 TS 884 7979.316 DK 734 7979.811 DK 735 8100.731 VX 991 8600.455 TS 884 7979.330 DK 734 7979.812 DK 735 8100.732 VX 991 8600.465 TS 884 7979.331 DK 734 7979.813 DK 735 8100.733 VX 991 8600.510 TS 884 7979.332 DK 734 7979.814 DK 735 8100.740 VX 993 8600.520 TS 884 7979.333 DK 734 7979.815 DK 735 8100.741 VX 993 8600.655 TS 884 7979.334 DK 734 7979.821 DK 735 8100.742 VX 993 8600.665 TS 884 7979.335 DK 734 7979.822 DK 735 8100.743 VX 993 8600.855 TS 884 7979.336 DK 734 7979.823 DK 735 8100.745 VX 993 8600.865 TS 884 7979.337 DK 734 7980.000 DK 790 8100.770 VX 893 8601.450 TS 891 7979.338 DK 734 7980.100 DK 790 8100.771 VX 893 8601.680 TS 891 901 7979.339 DK 734 7980.148 DK 790 8100.780 VX 892 8601.860 TS 1032 7979.340 DK 734 7990.103 DK 831 8102.245 VX 901 8604.000 VX 123 7979.342 DK 734 7990.203 DK 831 8104.245 VX 901 8605.000 VX 124 7979.402 DK 735 7990.206 DK 831 8105.245 VX 901 8606.000 VX 125 7979.403 DK 735 7990.208 DK 831 8106.245 VX 901 8608.000 VX 126 7979.404 DK 735 7990.303 DK 831 8106.260 VX 902 8609.140 TS 907 7979.410 DK 735 7990.306 DK 831 8106.760 VX 1028 8609.150 TS 907 7979.411 DK 735 7990.308 DK 831 8108.245 VX 901 8609.160 TS 907 7979.412 DK 735 7990.402 DK 831 8108.760 VX 1028 8609.170 TS 907 7979.413 DK 735 7990.502 DK 831 8115.245 VX 901 8609.200 VX 905 7979.414 DK 735 7998.106 DK 850 8120.245 VX 901 8609.201 VX 905 7979.415 DK 735 7998.107 DK 850 8122.245 VX 901 8609.202 VX 905 7979.416 DK 735 7998.206 DK 851 8126.245 VX 901 8609.203 VX 905 1172 Rittal System Catalogue 36 List of model numbers 8609.204 to 8640.004 Model No. 8609.204 VX Page Model No. 905 8617.190 VX Page Model No. Page Model No. 991 8618.250 VX 937 8619.400 Page VX 1059 8609.205 VX 905 8617.200 VX 991 8618.251 VX 937 8619.410 VX 1059 8609.206 VX 905 8617.210 VX 991 8618.270 VX 937 8619.420 VX 1059 8609.207 VX 905 8617.351 VX 972 8618.280 VX 937 8619.430 VX 1059 8609.210 VX 906 8617.352 VX 973 8618.300 VX 941 8619.440 VX 1059 8609.211 VX 906 8617.353 VX 971 8618.301 VX 941 8619.450 VX 1059 8609.212 VX 906 8617.360 VX 973 8618.302 VX 941 8619.460 VX 1059 8609.213 VX 906 8617.370 VX 974 8618.303 VX 941 8619.500 VX 1075 8609.220 VX 908 8617.400 VX 974 8618.304 VX 941 8619.510 VX 1075 8609.230 VX 908 8617.401 VX 974 8618.305 VX 941 8619.520 VX 1075 8609.390 TS 907 8617.402 VX 974 8618.306 VX 941 8619.530 VX 1075 8610.605 TS 918 8617.500 VX 912 8618.307 VX 941 8619.540 VX 1075 8610.685 TS 918 8617.501 VX 912 8618.308 VX 941 8619.550 VX 1075 8610.805 TS 918 8617.502 VX 912 8618.330 VX 951 8619.600 VX 1076 8610.885 TS 918 8617.503 VX 912 8618.335 VX 951 8619.610 VX 1076 8611.020 TS 938 8617.505 VX 916 8618.340 VX 951 8619.700 VX 952, 990 8611.070 TS 938 8617.506 VX 913 8618.410 VX 957 8619.710 VX 952, 990 8611.080 TS 918 8617.507 VX 914 8618.420 VX 956 8619.720 VX 952, 990 8611.100 TS 941 8617.508 VX 913 8618.425 VX 956 8619.730 VX 952, 990 8611.110 TS 941 8617.510 VX 975 8618.430 VX 956 8619.740 VX 952 8611.120 TS 941 8617.520 VX 975 8618.450 VX 932 8619.750 VX 952, 990 8611.130 TS 941 8617.530 VX 975 8618.451 VX 932 8619.760 VX 990 8611.140 TS 941 8617.540 VX 975 8618.460 VX 937 8619.770 VX 990 8611.150 TS 941 8617.550 VX 975 8618.501 VX 960 8619.780 VX 990 8611.160 TS 941 8617.560 VX 975 8618.511 VX 960 8619.790 VX 990 8611.170 TS 941 8617.570 VX 975 8618.521 VX 960 8619.800 VX 1044 8611.180 TS 942 8617.580 VX 975 8618.531 VX 960 8619.801 VX 1044 8611.190 TS 942 8617.590 VX 975 8618.541 VX 960 8619.802 VX 1044 8611.200 TS 942 8617.600 VX 975 8618.600 VX 1032 8619.803 VX 1044 8611.220 TS 941 8617.610 VX 975 8618.800 VX 1045 8620.010 VX 883 8611.290 TS 938 8617.620 VX 975 8618.801 VX 1045 8620.011 VX 883 8611.300 PC 918 8617.630 VX 975 8618.802 VX 1045 8620.050 VX 886 8611.330 TS 938 8617.640 VX 975 8618.803 VX 1045 8620.051 VX 886 8611.340 TS 938 8617.650 VX 977 8618.804 VX 1045 8620.052 VX 886 8612.030 TS 992 8617.655 VX 978 8618.810 VX 1045 8620.053 VX 886 8612.040 TS 992 8617.660 VX 980 8618.811 VX 1045 8620.060 VX 886 8612.050 TS 992 8617.661 VX 980 8618.812 VX 1045 8620.061 VX 886 8612.060 TS 992 8617.662 VX 980 8618.813 VX 1045 8620.062 VX 886 8612.130 TS 992 8617.663 VX 980 8618.814 VX 1045 8620.063 VX 886 8612.140 TS 992 8617.664 VX 980 8618.820 VX 1029 8620.070 VX 887 8612.150 TS 992 8617.665 VX 980 8618.821 VX 1029 8620.071 VX 887 8612.160 TS 992 8617.700 VX 993 8618.822 VX 1029 8620.072 VX 887 8612.400 TS 998 8617.710 VX 993 8618.823 VX 1029 8620.080 VX 887 8612.410 TS 998 8617.720 VX 993 8619.010 VX 1077 8620.081 VX 887 8612.960 TS 997 8617.730 VX 993 8619.011 VX 1077 8620.082 VX 887 8612.980 TS 997 8617.750 SZ 995 8619.012 VX 1077 8620.090 VX 883 8613.151 VX 1089 8617.751 SZ 995 8619.013 VX 1077 8620.091 VX 883 8613.161 VX 1089 8617.760 SZ 995 8619.014 VX 1077 8620.092 VX 882 8613.181 VX 1089 8617.800 VX 996 8619.020 VX 1077 8620.093 VX 882 8615.000 VX 117 8617.810 VX 996 8619.021 VX 1077 8620.094 VX 882 8617.000 VX 990 8617.820 VX 996 8619.022 VX 1077 8620.095 VX 882 8617.010 VX 990 8617.830 VX 996 8619.023 VX 1077 8620.100 VX 883 8617.020 VX 990 8618.000 VX 917 8619.024 VX 1077 8620.400 VX 885 8617.030 VX 990 8618.010 VX 917 8619.030 VX 1077 8620.500 VX 928 8617.040 VX 990 8618.020 VX 917 8619.032 VX 1077 8620.501 VX 928 8617.050 VX 990 8618.030 VX 917 8619.033 VX 1077 8620.502 VX 928 8617.060 VX 990 8618.040 VX 917 8619.034 VX 1077 8620.520 VX 928 8617.100 VX 991 8618.050 VX 917 8619.040 VX 1078 8620.521 VX 928 8617.110 VX 991 8618.110 VX 917 8619.041 VX 1078 8620.900 VX 895 8617.120 VX 991 8618.120 VX 917 8619.042 VX 1078 8620.901 VX 895 8617.130 VX 991 8618.200 VX 937 8619.050 VX 1078 8626.000 VX 127 8617.140 VX 991 8618.201 VX 937 8619.270 VX 1078 8640.000 VX 881 8617.150 VX 991 8618.220 VX 937 8619.300 VX 1080 8640.001 VX 881 8617.160 VX 991 8618.230 VX 937 8619.310 VX 1080 8640.002 VX 881 8617.170 VX 991 8618.231 VX 937 8619.320 VX 1080 8640.003 VX 881 8617.180 VX 991 8618.240 VX 937 8619.330 VX 1081 8640.004 VX 881 Rittal System Catalogue 36 1173 List of model numbers 8640.005 to 9342.720 Model No. Page Model No. Page Model No. Page Model No. 8640.005 VX 881 8807.010 VX 136 9303.000 KE 258 9340.760 SV Page 8640.006 VX 881 8807.020 VX 136 9304.000 KE 258 9340.770 SV 308 8640.007 VX 881 8808.000 VX 126 9305.000 KE 258 9340.780 SV 307 307 8640.008 VX 881 8815.000 VX 117 9306.000 KE 258 9340.790 SV 308 8640.009 VX 881 8826.000 VX 127 9320.020 SV 343 9340.820 SV 355 8640.020 VX 881 8840.100 VX 129 9320.030 SV 343 9340.830 SV 355 8640.021 VX 881 8840.110 VX 129 9320.060 SV 345 9340.850 SV 354 8640.022 VX 881 8840.120 VX 129 9320.070 SV 345 9340.860 SV 354 8640.023 VX 881 8840.130 VX 129 9320.120 SV 353 9340.870 SV 354 8640.024 VX 881 8845.000 VX 118 9320.150 SV 352 9340.880 SV 354 8640.025 VX 881 8865.000 VX 119 9340.000 SV 300 9340.890 SV 354 8640.026 VX 881 8880.000 VX 121 9340.004 SV 300 9340.905 SV 356 8640.027 VX 881 8881.000 VX 122 9340.010 SV 300 9340.910 SV 312 8640.030 VX 882 8884.000 VX 120 9340.030 SV 340 9340.930 SV 312 8640.031 VX 882 8885.000 VX 121 9340.040 SV 340 9340.950 SV 324 8640.032 VX 882 8886.000 VX 122 9340.050 SV 300 9341.000 SV 302 8640.033 VX 882 8951.000 VX 909 9340.070 SV 301 9341.050 SV 302 8640.034 VX 882 8951.010 VX 909 9340.074 SV 301 9341.070 SV 303 8640.035 VX 882 8951.020 VX 909 9340.090 SV 341 9341.100 SV 347 8640.036 VX 882 8951.030 VX 909 9340.100 SV 347 9341.110 SV 347 8640.040 VX 882 8952.000 VX 909 9340.110 SV 347 9341.120 SV 347 8640.041 VX 882 8952.010 VX 909 9340.120 SV 347 9341.130 SV 347 8640.042 VX 882 8952.020 VX 909 9340.130 SV 347 9341.140 SV 347 8640.043 VX 882 8952.030 VX 909 9340.134 SV 347 9341.170 SV 347 8640.044 VX 882 9055.310 DK 822 9340.140 SV 347 9342.000 SV 302 8640.045 VX 882 9055.312 DK 822 9340.170 SV 347 9342.004 SV 302 8640.046 VX 882 9055.410 DK 822 9340.200 SV 348 9342.030 SV 340 8645.000 VX 118 9055.412 DK 822 9340.210 SV 348 9342.050 SV 302 8665.000 VX 119 9101.210 GA 48 9340.214 SV 348 9342.070 SV 303 8684.000 VX 120 9102.210 GA 48 9340.220 SV 348 9342.074 SV 303 8685.000 VX 121 9104.210 GA 48 9340.224 SV 348 9342.100 SV 347 8686.000 VX 122 9105.210 GA 48 9340.230 SV 348 9342.110 SV 347 8700.030 VX 901 9105.700 GA 49 9340.260 SV 313 9342.120 SV 347 8700.040 VX 901 9106.210 GA 48 9340.270 SV 313 9342.130 SV 347 8700.050 VX 901 9107.210 GA 48 9340.280 SV 354 9342.134 SV 347 8700.140 TS 915 9108.210 GA 48 9340.290 SV 353 9342.140 SV 347 8700.150 TS 915 9108.700 GA 49 9340.300 SV 313 9342.170 SV 347 8700.160 TS 915 9110.210 GA 48 9340.310 SV 308 9342.200 SV 304 8701.180 TS 951 9110.700 GA 49 9340.320 SV 308 9342.210 SV 304 8800.130 TS 994 9111.210 GA 48 9340.340 SV 308 9342.220 SV 304 8800.190 TS 951 9112.210 GA 48 9340.350 SV 308 9342.224 SV 304 8800.695 VX 1028 9112.700 GA 49 9340.370 SV 308 9342.240 SV 304 8800.710 TS 951 9113.210 GA 48 9340.380 SV 308 9342.250 SV 305 8800.750 TS 1058 9113.700 GA 49 9340.390 SV 308 9342.254 SV 305 8800.751 TS 1058 9114.210 GA 48 9340.400 SV 308 9342.270 SV 305 8800.752 TS 1058 9116.210 GA 48 9340.410 SV 309 9342.280 SV 305 8800.753 TS 1058 9116.700 GA 49 9340.430 SV 309 9342.300 SV 305 8800.754 TS 1058 9117.210 GA 48 9340.450 SV 309 9342.310 SV 305 8800.755 VX 1058 9117.700 GA 49 9340.460 SV 308 9342.311 SV 351 8800.770 VX 1058 9118.210 GA 48 9340.470 SV 308 9342.314 SV 306 8800.825 TS 915 9118.700 GA 49 9340.510 SV 310 9342.320 SV 305 8800.845 TS 915 9119.210 GA 48 9340.520 SV 310 9342.321 SV 351 8800.855 TS 915 9121.122 GA 49 9340.530 SV 310 9342.324 SV 306 8800.865 TS 915 9121.160 GA 49 9340.550 SV 310 9342.400 SV 314 8800.875 VX 916 9121.230 GA 49 9340.560 SV 310 9342.410 SV 314 8800.885 TS 915 9123.000 GA 49 9340.610 SV 311 9342.500 SV 315 8800.900 PC 1007 9202.100 KE 260 9340.620 SV 311 9342.504 SV 317 8800.910 PC 1007 9203.100 KE 260 9340.630 SV 311 9342.510 SV 315 8800.920 PC 890 9204.100 KE 260 9340.650 SV 311 9342.514 SV 317 8801.000 TS 924 9205.100 KE 260 9340.660 SV 310 9342.540 SV 314 8801.010 TS 924 9206.100 KE 260 9340.700 SV 309 9342.550 SV 314 8801.260 TS 928 9207.100 KE 260 9340.710 SV 309 9342.560 SV 355 8804.000 VX 123 9208.100 KE 260 9340.720 SV 309 9342.570 SV 355 8805.000 VX 124 9209.100 KE 260 9340.730 SV 309 9342.610 SV 315 8806.000 VX 125 9301.000 KE 258 9340.740 SV 309 9342.640 SV 355 8807.000 VX 131 9302.000 KE 258 9340.750 SV 309 9342.720 SV 353 1174 Rittal System Catalogue 36 List of model numbers 9342.800 to 9666.060 Model No. Page Model No. Page Model No. 9342.800 SV 354 9345.100 SV 339 9522.000 PK Page 45 Model No. 9635.600 SV Page 9342.810 SV 354 9345.200 SV 339 9522.100 PK 45 9635.610 SV 293 9342.820 SV 354 9345.400 SV 339 9523.000 PK 45 9635.620 SV 293 293 9342.850 SV 352 9345.600 SV 315 9523.100 PK 45 9635.630 SV 293 9342.860 SV 352 9345.604 SV 317 9524.000 PK 45 9635.640 SV 293 9342.870 SV 352 9345.610 SV 315 9524.100 PK 45 9635.700 SV 290 9342.880 SV 352 9345.614 SV 317 9548.000 PK 47 9635.800 SV 292 9342.920 SV 352 9345.700 SV 316 9549.000 PK 47 9640.202 SV 401 9342.930 SV 352 9345.704 SV 318 9550.000 PK 47 9640.207 SV 401 9342.940 SV 352 9345.710 SV 316 9581.000 PK 47 9640.232 SV 401 9342.950 SV 352 9345.714 SV 318 9583.000 PK 47 9640.237 SV 401 9342.980 SV 352 9345.720 SV 316 9600.000 SV 294 9640.262 SV 401 9343.000 SV 327 9345.724 SV 318 9600.005 SV 340 9640.267 SV 401 9343.010 SV 327 9345.730 SV 316 9601.000 SV 294 9640.292 SV 401 9343.020 SV 329 9345.734 SV 318 9602.000 SV 294 9640.297 SV 401 9343.030 SV 329 9346.000 SV 335 9603.000 SV 294 9640.325 SV 403 9343.040 SV 331 9346.010 SV 335 9605.000 SV 294 9640.330 SV 403 9343.050 SV 331 9346.015 SV 336 9606.000 SV 294 9640.340 SV 403 9343.070 SV 333 9346.020 SV 335 9607.000 SV 294 9640.350 SV 403 9343.100 SV 328 9346.030 SV 335 9608.000 SV 294 9640.360 SV 401 9343.110 SV 328 9346.060 SV 335 9609.000 SV 294 9640.365 SV 401 9343.120 SV 330 9346.400 SV 358 9610.000 SV 294 9640.370 SV 403 9343.130 SV 330 9346.460 SV 357 9611.000 SV 294 9640.380 SV 403 9343.140 SV 332 9350.010 SV 343 9612.000 SV 294 9640.900 SV 404 9343.150 SV 332 9350.060 SV 343 9613.000 SV 294 9640.910 SV 404 9343.170 SV 333 9350.075 SV 343 9614.000 SV 296 9640.920 SV 404 9343.200 SV 328 9401.600 KE 259 9614.100 SV 296 9640.930 SV 404 9343.210 SV 328 9402.600 KE 259 9614.110 SV 296 9640.940 SV 404 9343.230 SV 330 9403.600 KE 259 9615.000 SV 296 9640.970 SV 403 9343.250 SV 332 9404.600 KE 259 9615.100 SV 296 9640.980 SV 403 9343.270 SV 333 9405.600 KE 259 9616.000 SV 297 9649.010 SV 401 9343.300 SV 328 9406.600 KE 259 9617.000 SV 297 9649.360 SV 401 9343.310 SV 328 9407.600 KE 259 9623.000 SV 353 9650.202 SV 402 9343.330 SV 330 9408.600 KE 259 9624.000 SV 294 9650.232 SV 402 9343.350 SV 332 9409.600 KE 259 9625.000 SV 296 9650.262 SV 402 9343.370 SV 333 9500.000 PK 44 9627.000 SV 297 9650.292 SV 402 9343.400 SV 334 9502.000 PK 44 9629.000 SV 297 9650.325 SV 403 9343.410 SV 334 9504.000 PK 44 9629.010 SV 296 9650.330 SV 403 9344.000 SV 327 9505.000 PK 44 9629.100 SV 295 9650.340 SV 403 9344.010 SV 327 9506.000 PK 44 9630.000 SV 295 9650.360 SV 402 9344.020 SV 329 9507.000 PK 44 9630.005 SV 295 9650.370 SV 403 9344.030 SV 329 9508.000 PK 44 9635.000 SV 284 9650.380 SV 403 9344.040 SV 331 9508.050 PK 46 9635.010 SV 284 9650.900 SV 404 9344.050 SV 331 9509.000 PK 44 9635.100 SV 289 9650.905 SV 404 9344.100 SV 328 9510.000 PK 44 9635.110 SV 289 9650.910 SV 404 9344.110 SV 328 9511.000 PK 44 9635.200 SV 285 9650.920 SV 404 9344.130 SV 330 9512.000 PK 44 9635.210 SV 285 9650.980 SV 403 9344.150 SV 332 9513.000 PK 44 9635.300 SV 287 9650.990 SV 403 9344.210 SV 328 9514.000 PK 45 9635.310 SV 287 9659.010 SV 401 9344.230 SV 330 9514.050 PK 46 9635.320 SV 287 9659.360 SV 402 9344.250 SV 332 9514.100 PK 45 9635.330 SV 287 9660.090 SV 408 9344.310 SV 328 9515.000 PK 45 9635.340 SV 287 9660.205 SV 405 9344.330 SV 330 9515.100 PK 45 9635.350 SV 287 9660.980 SV 404 9344.350 SV 332 9516.000 PK 45 9635.360 SV 287 9665.750 SV 962 9344.510 SV 358 9516.100 PK 45 9635.371 SV 286 9665.760 SV 962 9344.520 SV 357 9517.000 PK 45 9635.372 SV 286 9665.770 SV 962 9344.530 SV 357 9517.100 PK 45 9635.373 SV 286 9665.780 SV 962 9344.540 SV 357 9518.000 PK 45 9635.381 SV 286 9665.785 SV 962 9344.550 SV 357 9518.100 PK 45 9635.382 SV 286 9666.000 SV 421 9344.610 SV 357 9519.000 PK 45 9635.383 SV 286 9666.010 SV 421 9344.620 SV 357 9519.100 PK 45 9635.390 SV 288 9666.020 SV 421 9344.680 SV 357 9520.000 PK 45 9635.400 SV 291 9666.030 SV 421 9345.005 SV 338 9520.100 PK 45 9635.410 SV 291 9666.040 SV 421 9345.015 SV 338 9521.000 PK 45 9635.415 SV 291 9666.050 SV 421 9345.035 SV 338 9521.050 PK 46 9635.420 SV 291 9666.053 SV 421 9345.040 SV 337 9521.100 PK 45 9635.425 SV 291 9666.060 SV 421 Rittal System Catalogue 36 1175 List of model numbers 9666.063 to 9681.682 Model No. Page Model No. Page Model No. Page Model No. 9666.063 SV 421 9666.712 SV 429 9676.977 SV 404 9677.640 SV Page 9666.070 SV 421 9666.722 SV 429 9676.981 SV 404 9677.650 SV 381 9666.073 SV 421 9666.723 SV 429 9676.982 SV 404 9677.700 SV 372 381 9666.080 SV 421 9666.724 SV 429 9676.983 SV 404 9677.705 SV 373 9666.090 SV 421 9666.732 SV 430 9676.986 SV 404 9677.710 SV 372 9666.100 SV 421 9666.740 SV 430 9676.987 SV 404 9677.715 SV 373 9666.110 SV 421 9666.753 SV 429 9677.000 SV 375 9677.730 SV 382 9666.120 SV 421 9666.754 SV 429 9677.010 SV 374 9677.740 SV 382 9666.130 SV 421 9666.756 SV 429 9677.015 SV 376 9677.750 SV 382 9666.133 SV 421 9666.757 SV 429 9677.025 SV 375 9677.760 SV 382 9666.140 SV 421 9666.801 SV 420 9677.060 SV 377 9677.770 SV 372 9666.143 SV 421 9666.811 SV 420 9677.065 SV 377 9677.780 SV 373 9666.150 SV 421 9666.821 SV 420 9677.070 SV 377 9677.790 SV 382 9666.160 SV 422 9666.831 SV 420 9677.075 SV 377 9677.792 SV 382 9666.170 SV 422 9666.841 SV 420 9677.080 SV 379 9677.794 SV 382 9666.180 SV 422 9666.851 SV 420 9677.085 SV 379 9677.796 SV 382 9666.190 SV 422 9666.902 SV 420 9677.100 SV 375 9677.798 SV 382 9666.200 SV 422 9666.912 SV 420 9677.110 SV 374 9677.810 SV 385 9666.210 SV 422 9666.916 VX 135 9677.115 SV 376 9677.840 SV 385 9666.213 SV 422 9666.922 SV 420 9677.160 SV 378 9677.860 SV 385 9666.220 SV 422 9666.926 VX 135 9677.165 SV 378 9677.870 SV 385 9666.223 SV 422 9666.932 SV 420 9677.180 SV 379 9677.880 SV 385 9666.230 SV 422 9666.956 VX 135 9677.200 SV 375 9677.900 SV 370 9666.240 SV 422 9666.966 VX 135 9677.210 SV 374 9677.905 SV 370 9666.250 SV 422 9674.380 SV 415 9677.215 SV 376 9677.910 SV 371 9666.260 SV 422 9674.381 SV 416 9677.260 SV 378 9677.915 SV 371 9666.270 SV 422 9674.410 SV 415 9677.265 SV 378 9677.920 SV 371 9666.280 SV 422 9674.416 SV 415 9677.280 SV 379 9677.925 SV 382 9666.290 SV 422 9674.418 SV 415 9677.300 SV 375 9680.005 VX 134 9666.293 SV 422 9674.430 SV 415 9677.310 SV 374 9680.025 VX 134 9666.300 SV 422 9674.436 SV 415 9677.315 SV 376 9680.207 VX 134 9666.303 SV 422 9674.438 SV 415 9677.340 SV 375 9680.227 VX 134 9666.310 SV 423 9674.790 SV 962 9677.360 SV 378 9680.406 VX 132 9666.340 SV 423 9674.990 SV 408 9677.365 SV 378 9680.408 VX 132 9666.350 SV 423 9676.017 SV 398 9677.380 SV 379 9680.426 VX 133 9666.380 SV 424 9676.019 SV 398 9677.400 SV 383 9680.428 VX 133 9666.390 SV 424 9676.503 SV 417 9677.402 SV 386 9680.606 VX 132 9666.400 SV 424 9676.504 SV 417 9677.405 SV 383 9680.608 VX 132 9666.410 SV 424 9676.505 SV 417 9677.407 SV 386 9680.626 VX 133 9666.420 SV 424 9676.700 SV 399 9677.410 SV 383 9680.628 VX 133 9666.430 SV 425 9676.710 SV 399 9677.412 SV 386 9680.806 VX 132 9666.440 SV 425 9676.730 SV 398 9677.415 SV 385 9680.808 VX 132 9666.520 SV 427 9676.747 SV 399 9677.418 SV 387 9680.826 VX 133 9666.530 SV 427 9676.748 SV 399 9677.420 SV 384 9680.828 VX 133 9666.533 SV 427 9676.749 SV 399 9677.425 SV 386 9681.204 SV 927 9666.550 SV 425 9676.806 SV 400 9677.430 SV 384 9681.206 SV 927 9666.560 SV 425 9676.807 SV 400 9677.435 SV 387 9681.208 SV 927 9666.570 SV 425 9676.808 SV 400 9677.440 SV 384 9681.514 SV 961 9666.580 SV 425 9676.809 SV 400 9677.445 SV 387 9681.516 SV 961 9666.583 SV 425 9676.810 SV 400 9677.450 SV 383 9681.546 SV 961 9666.590 SV 426 9676.811 SV 400 9677.460 SV 383 9681.548 SV 961 9666.600 SV 426 9676.812 SV 400 9677.470 SV 384 9681.564 SV 961 9666.603 SV 426 9676.813 SV 400 9677.480 SV 384 9681.566 SV 961 9666.640 SV 426 9676.814 SV 400 9677.485 SV 387 9681.568 SV 961 9666.650 SV 428 9676.815 SV 400 9677.500 SV 368 9681.586 SV 961 9666.660 SV 428 9676.816 SV 400 9677.511 SV 380 9681.588 SV 961 9666.665 SV 428 9676.817 SV 400 9677.521 SV 380 9681.594 SV 961 9666.670 SV 428 9676.819 SV 400 9677.531 SV 380 9681.596 SV 961 9666.680 SV 429 9676.832 SV 398 9677.541 SV 380 9681.646 SV 961 9666.702 SV 429 9676.966 SV 405 9677.550 SV 381 9681.648 SV 961 9666.703 SV 429 9676.967 SV 405 9677.560 SV 381 9681.660 SV 961 9666.704 SV 429 9676.968 SV 405 9677.570 SV 381 9681.662 SV 961 9666.705 SV 429 9676.971 SV 404 9677.580 SV 381 9681.666 SV 961 9666.706 SV 429 9676.972 SV 404 9677.600 SV 380 9681.668 SV 961 9666.707 SV 429 9676.973 SV 404 9677.610 SV 380 9681.680 SV 961 9666.711 SV 429 9676.976 SV 404 9677.620 SV 380 9681.682 SV 961 1176 Rittal System Catalogue 36 List of model numbers 9681.686 to 9792.075 Model No. 9681.686 SV Page Model No. 961 9682.334 Page Model No. Page Model No. SV 927 9683.666 SV 413 9686.589 Page SV 1039 9681.688 SV 961 9682.336 SV 927 9683.668 SV 413 9686.800 SV 400 9681.806 SV 961 9682.338 SV 927 9683.680 SV 413 9686.810 SV 400 9681.808 SV 961 9682.340 SV 927 9683.681 SV 413 9686.820 SV 400 9681.826 SV 961 9682.342 SV 927 9683.682 SV 413 9686.845 SV 405 9681.828 SV 961 9682.344 SV 927 9683.683 SV 413 9686.865 SV 405 9681.846 SV 961 9682.346 SV 927 9683.684 SV 413 9686.912 SV 406 9681.848 SV 961 9682.348 SV 927 9683.686 SV 413 9686.924 SV 406 9681.866 SV 961 9682.350 SV 927 9683.688 SV 413 9765.092 CS 981 9681.868 SV 961 9682.352 SV 927 9683.701 SV 411 9765.095 CS 981 9681.886 SV 961 9682.354 SV 927 9683.702 SV 411 9765.191 CS 981 9681.888 SV 961 9682.356 SV 927 9683.703 SV 411 9783.530 CS 268 9682.104 SV 926 9682.358 SV 927 9683.704 SV 411 9783.610 CS 268 9682.106 SV 926 9683.006 SV 410 9683.706 SV 411 9784.540 CS 268 9682.108 SV 926 9683.008 SV 410 9683.736 SV 417 9785.040 CS 942 9682.124 SV 926 9683.016 SV 410 9683.738 SV 417 9785.042 CS 942 9682.126 SV 926 9683.018 SV 410 9683.763 SV 414 9791.015 CS 269 9682.128 SV 926 9683.036 SV 410 9683.783 SV 414 9791.025 CS 269 9682.140 SV 926 9683.038 SV 410 9684.004 SV 396 9791.035 CS 269 9682.142 SV 926 9683.040 SV 410 9684.006 SV 396 9791.045 CS 269 9682.143 SV 926 9683.200 SV 410 9684.008 SV 396 9792.055 AX 958 9682.144 SV 926 9683.210 SV 410 9684.010 SV 396 9792.065 AX 958 9682.146 SV 926 9683.304 SV 412 9684.012 SV 396 9792.075 AX 958 409 9682.148 SV 926 9683.306 SV 412 9684.900 SV 9682.150 SV 926 9683.308 SV 412 9684.920 SV 409 9682.152 SV 926 9683.310 SV 412 9684.960 SV 409 9682.154 SV 926 9683.312 SV 412 9684.980 SV 409 9682.156 SV 926 9683.326 SV 412 9684.990 SV 409 9682.158 SV 926 9683.328 SV 412 9686.000 SV 395 9682.160 SV 926 9683.406 SV 411 9686.010 SV 394 9682.161 SV 926 9683.408 SV 411 9686.030 SV 395 9682.162 SV 926 9683.426 SV 411 9686.040 SV 394 9682.163 SV 926 9683.428 SV 411 9686.060 SV 396 9682.164 SV 926 9683.444 SV 411 9686.070 SV 395 9682.166 SV 926 9683.446 SV 411 9686.080 SV 396 9682.167 SV 926 9683.448 SV 411 9686.100 SV 394 9682.168 SV 926 9683.464 SV 411 9686.200 SV 397 9682.169 SV 926 9683.466 SV 411 9686.210 SV 397 9682.170 SV 926 9683.468 SV 411 9686.250 SV 397 9682.172 SV 926 9683.484 SV 411 9686.260 SV 397 9682.174 SV 926 9683.486 SV 411 9686.300 SV 1039 9682.176 SV 926 9683.488 SV 411 9686.350 SV 1038 9682.178 SV 926 9683.500 SV 412 9686.495 SV 405 9682.180 SV 926 9683.504 SV 412 9686.520 SV 1038 9682.181 SV 926 9683.506 SV 412 9686.522 SV 1038 9682.182 SV 926 9683.508 SV 412 9686.524 SV 1038 9682.183 SV 926 9683.561 SV 413 9686.526 SV 1038 9682.184 SV 926 9683.562 SV 413 9686.528 SV 1038 9682.186 SV 926 9683.563 SV 413 9686.529 SV 1039 9682.187 SV 926 9683.564 SV 413 9686.530 SV 1038 9682.188 SV 926 9683.604 SV 413 9686.532 SV 1038 9682.190 SV 926 9683.606 SV 413 9686.534 SV 1038 9682.192 SV 926 9683.608 SV 413 9686.536 SV 1038 9682.194 SV 926 9683.624 SV 413 9686.538 SV 1038 9682.196 SV 926 9683.626 SV 413 9686.539 SV 1039 9682.198 SV 926 9683.628 SV 413 9686.540 SV 1038 9682.314 SV 927 9683.642 SV 413 9686.542 SV 1038 9682.316 SV 927 9683.643 SV 413 9686.544 SV 1038 9682.318 SV 927 9683.644 SV 413 9686.546 SV 1038 9682.320 SV 927 9683.646 SV 413 9686.548 SV 1038 9682.322 SV 927 9683.648 SV 413 9686.549 SV 1039 9682.324 SV 927 9683.660 SV 413 9686.580 SV 1038 9682.326 SV 927 9683.661 SV 413 9686.582 SV 1038 9682.328 SV 927 9683.662 SV 413 9686.584 SV 1038 9682.330 SV 927 9683.663 SV 413 9686.586 SV 1038 9682.332 SV 927 9683.664 SV 413 9686.588 SV 1038 Rittal System Catalogue 36 1177 Index A Accessories – Data Rack 1079 – for assembly frame 608 – 610 – for LCP DX 785 – for Wiring Station 621 – 628 – Hole punches 602, 603 – Hole punching tools 603 – Hygienic Design 223 – 225 – OCP 871 – 873 Accessories – busbar machining – Electro-hydraulic pump 644 – Hydraulic cylinder 645 – Hydraulic hose 645 – Ride-up roller 645 Accessories for IT cooling – Connection hose 786 – Fan module 787 – Rear adaptor for LCP Inline CW 786 Accessories for LCP CW/DX – Condensate pump 786 – Shielding, vertical 786 – Touchscreen display, colour 785 Accommodation system, 2 U – for LSA installation kit 1102 Acoustic component – for signal pillar, modular 1127 Acrylic glazed cover 930 Adaptors – 3U 1090 – 3-pole (185 mm) 372, 373 – Blue e IoT adaptor 555 – Circuit-breaker, 3-pole 314 – Circuit-breaker, 4-pole 317 – for air duct system 540 – for connector cut-outs 908 – for LCP Inline CW 786 – for NH disconnectors, size 000 295 – for spindle hoist 609 – for support arm system 208 – for tilt coupler 210 – for twin castors and levelling feet 893 – Metric to 482.6 mm (19˝) 1091 – OM 307, 310, 312 – RiLine Compact 286, 287, 289 Adaptor bracket – for WS 540 624 Adaptor kit, 3 U 1090 Adaptor pieces, 482.6 mm (19") 1081 Adaptor power pack for LED system light 1026 Adaptor section, 482.6 mm (19") 1080 Adhesive measurement strip, 482.6 mm (19") 1085 Air baffle plates – for VX IT 482.6 mm (19") mounting angles, dynamic 1095 – for VX IT 482.6 mm (19") mounting angles, standard 1094 Air circuit-breaker support bar 412 Air diverter 542 Air duct 1096 – for 482.6 mm (19") mounting level 1095 – for wall-mounted cooling unit Blue e+ IT 784 Air duct adaptor 540 Air duct system – for air/water heat exchanger, roof-mounted 540 – for roof-mounted cooling units 540 Air routing – horizontal air routing 1095 – side air routing 1096 1178 Air/air heat exchangers – Roof-mounted 470 – TopTherm 469 Air/water heat exchangers – Baying enclosure system VX25 518 – Hygienic Design 515 – Roof-mounted 516 – Wall-mounted 510 – 514 Aisle containment 788 Allocation of lock systems 933 – 936 Alternate frame, magnetic 957 Aluminium strip TP 163, 1104 Aluminium/sheet steel door, vented – for VX IT 922 Angle bracket 405 – for combination rail 1063 – PE/PEN busbar system 1038 Angle piece 1001 Angular baying bracket 913 Arcing chamber – for NH fuse-switch disconnectors 357 Assembly components 1001 Assembly frame – Mounting device 607 Assembly parts – for earth straps 1033 Assembly screws 1098 Assembly tool – for cable gland HD 1057 Attachment – Pole clamp, AX, AX IT 968 Automatic door opener 817 AX IT – Wall-mounted enclosures IT 719 B Base configuration rail for TP 995 Base isolator 341 Base mounting – Base mounting plate for base/plinth VX, base/plinth AX, base/plinth, complete 885 – with base mounting bracket for VX, VX IT 900 Base mounting bracket – for pedestal 214 Base trays – for Mini-PLS 294 – Infill 347 – RiLine 347 Base/plinth – for areas at risk from earthquakes 1032 – for FlatBox 891 Base/plinth adaptor – for twin castors and levelling feet 893 Base/plinth corner pieces with base/plinth trim panels, front and rear – Sheet steel, for AX, AX IT 888 – Sheet steel, for VX 881 – Stainless steel, for VX 886 Base/plinth installation bracket – for base/plinth VX 885 Base/plinth trim panels, sides – Sheet steel, for base/plinth AX 889 – Sheet steel, for base/plinth VX 882 – Stainless steel, for base/plinth VX 887 Base/plinth trim panels, vented – Sheet steel, for base/plinth VX 883 Base/plinth trim panels, with brush strip – Sheet steel, for base/plinth VX 882 Base/plinth, complete – Sheet steel, for TP universal console 890 – Stainless steel, for one-piece console 890 Base/plinth, static – for PC, IW 890 Basic enclosure with glazed door VX25 128 Basic enclosures, outdoor 268 Basic modules – CMC III Processing Unit 803 – CMC III Processing Unit Compact 802 Baying block, internal 912 Baying bracket E-Cu 1039 Baying bracket, internal 912 Baying connector – for Data Rack 1079 – for TS IT 913, 914 – for VX 914 – for VX IT 914 Baying connector, external 912, 914 Baying cover – for base/plinth VX 883 Baying enclosure system VX25 – Basic enclosure with glazed door 128 – Distribution enclosure 135 – Electronic enclosure 130 – EMC enclosure 136 – Fuse-switch-disconnector enclosure 134 – IP 66/NEMA 4 131 – IP 66/NEMA 4X 246 – Modular enclosure 132 – Sheet steel 116 – Stainless steel 242 – VX25 Blue e+ integration solution 505 Baying enclosures – VX25, EMC enclosure 136 Baying kit – for AX, KX 916 – for TE/TE 916 – VX25 to TS 8 916 Baying plate – Blue e+ 556 Baying seal 914 Baying system 911 Bit for cordless screwdrivers 571 Bit HD – Hygienic Design 224 Bit holder – Magnetic 573 – with handle, magnetic 572 Bit set – with bit holder 572 Bit set for cordless screwdrivers – Industry 572 Blanking cover – for fan-and-filter units / outlet filters 538 – for Network Cable Organizer 1071 – Form 2b 409 – ISV 428 Blanking panel – Tool-free attachment, 482.6 mm (19") 1093 Blanking panel, 482.6 mm (19") – Extension cover 1093 Blanking plate, 482.6 mm (19") 1092 Blue e – Chillers 526 Blue e+ – Chillers 522 – Display frame 557 – Electric condensate evaporator 543 – Roof-mounted cooling units 504, 764 – VX25 Blue e+ integration solution 505 – Wall-mounted cooling units 486 – 489, 765 Blue e+ app 559 Board – RiLine Compact 284 Bolts – for Maxi-PLS 403, 404 Rittal System Catalogue 36 Index Bottom-mounted adaptor – for enclosure internal thermostat 548 – for hygrostat 548 Box – for modular outgoing section 411 Box terminal – for NH fuse-switch disconnectors 357 – for NH slimline switch-disconnectors 387 Bracket – Wall bracket AX 97, 261 Bracket/spacer 1001 Brush kit – for cable entry 1068 – for TE 963 – for VX IT, TE 1068 Brush strip 1055 – for cable entry 963 – Super-airtight 1055 – Vertical 1096 Built-in keyboard 19"/4 U 1111 Bus enclosures KX – Sheet steel 70 – Stainless steel 234 Busbar claw 398 Busbar connection adaptors – Mini-PLS 294 Busbar connectors – for busbars 343, 380 – for Mini-PLS 294 – PLS 344 Busbar machining CW 120 – Accessories 643 – 645 – Busbar bending and hole-punching unit CW 120-S 640 – Busbar cutting unit CW 120-S 641 – Foot-switch 644 – Mobile CW 120-M 642 – Stationary CW 120-S 640, 641 Busbar module – ISV 427 – N/PE 426 Busbar supports – 1-pole 340 – 2-pole 340 – 40 mm busbar systems 294 – 60 mm busbar systems 300, 302 – Distribution busbar system 394 – Flat copper busbars 300 – for 100/150/185 mm bar systems 388 – for 185 mm busbar system 368 – for busbar baying (rear section) 396 – for busbar baying (roof section) 395 – for busbar entry (rear section) 395 – for flat copper busbars 388 – for fuse-switch disconnector section 415 – for Maxi-PLS 401 – Mini-PLS 294 – N conductor 1039 – PLS 302, 340 Busbar system 388 – 185 mm 369 – Connection components 406, 407 – Flat-PLS 394 – 397 – Maxi-PLS 401 – 403 – Mini-PLS 294 – RiLine 300, 302 – RiLine Compact 284 Busbar terminal – for NH slimline fuse-switch disconnectors 384 Rittal System Catalogue 36 Busbars – Cover section – CUPONAL – E-Cu – Maxi-PLS – Mini-PLS – PLS – with integral punchings Bus-mounting fuse base – for 60 mm busbar system – for Mini-PLS 343 342 342 401, 402 294 344 1038 323, 324 295 C C rail – 30/15 996 Cable attachment 1061 Cable chamber for VX, VX SE 884 Cable clamp – for C rails 1060 – for cable clamp rails 1059 Cable clamp rail – C-section 1059 – Right angle section 1059 Cable clamp rail, depth-variable – for VX, VX IT, TE 1063 Cable clamp strap 819 Cable clamp strip, foam rubber 1045 Cable clamping bracket 1060 Cable clamping, vertical 1066 Cable conduit/cable conduit holder 1060 Cable cutter 585 Cable duct 1058 – for VX IT, TE 1068 Cable entry gland – for roof plates 962 Cable entry grommet 1044 Cable entry module, round 1048 Cable entry panel – 482.6 mm (19") 1074 Cable entry plate 1044 Cable finger – for VX IT 1069 Cable gland – Brass 1056 – EMC 1030 – for IW worktops 1046 – Polyamide 1056 – Stainless steel, HD 1057 Cable gland plate – Metal 1053, 1054 – Plastic 1050, 1052 Cable holder 1062 Cable lock PSM 752 Cable management enclosure – VX IT 701 Cable management panel – with cable routing bars 1073 – with front flap 1073 – with plastic rings 1072 – with steel rings 1072 Cable manager 1064 Cable organiser 963 Cable route – for TE 1066 – for VX, VX IT 1066 Cable routing – Snap-in 1062 Cable routing bars – 482.6 mm (19") attachment – for universal use Cable routing channel – 482.6 mm (19") Cable routing kit for doors Cable set – for OM adaptors Cable shunting ring Cable support, hinged Cable ties Cable tray – Depth-variable CAD data Cage nut Cam lock – for operating panel – Hygienic Design Cam lock, stainless steel – for AX, KX E-Box Captive nuts – 482.6 mm (19") fastener, 1 U Cast aluminium enclosures GA Castor module – for VX, VX IT Castors CAT 6 cassettes – for Network Cable Organizer Central earthing point Chiller app Chiller configurator Chillers – Blue e – Blue e+ – TopTherm Circuit-breaker component adaptors – 3-pole – 4-pole – RiLine Compact Circuit-breaker module ISV Clamp rail for cables Clamping unit – for assembly frame Clamp-type terminal – for NH slimline switch-disconnectors Clamp-type terminal connection – for NH slimline fuse-switch disconnectors Claw with threaded insert Claws – for busbars Climate control – Configurators Climate control doors Clipboard CMC III – Accessories – Automatic Door Opening (ADO) – CAN bus connection cable – CAN bus unit – I/O unit – LTE unit – Online comfort handle VX – Power unit – Processing Unit/Compact – Wireless Unit Coded lock Combination angle Combination pliers Combination rails – for 482.6 mm (19") – for VX, VX IT 1067 1067 1073 948 354 1064 1011 1061 1074 274 1002 932 224 943 1098 1097 48 894 893 1070 1034 558 558 526 522 519 314 317 289 425 1059 608 386 358 398 398 558 507 1106 806 816 818 802 803 820 946 803 804 815 813 915 587 1074 1063 1179 Index Comfort handle 938 – AX 939 – AX Mini 940 – VX 937 – VX with code 946 Comfort Panel 172, 173 Command panel housing with door – Stainless steel 254 Command panels – Comfort Panel 172 – Command panel housing with door 254 – Compact Panel 181 – Configurator 273 – Optipanel 174 – Premium Panel 253 – Stainless steel 253, 254 Compact enclosures – AX 94 – Hygienic Design 222 – Plastic enclosures AX, with viewing window 95 Compact enclosures AX – Basic enclosure AX, sheet steel 84 – 91 – Basic enclosure AX, stainless steel 236 – 240 – Operating housing AX for desktop TFT up to 24" 180 – Operating housings AX with handle strips 178, 179 – with support arm connection and handle strips 178, 179 – with support arm connection and TFT holder for desktop TFT up to 24" 180 Compact infeed – for Maxi-PLS 404 Compact Panel 181 – Wall mounting bracket 969 Compartment divider – for VX 411 Compartment side panel – for VX 410 Complete CAT 6 system – for Network Cable Organizer 1069 Complete earthing kits – for TE 1036 Component adaptors – 3-pole 314 – 3-pole (185 mm) 372, 373 – 4-pole 317 – Mini-PLS 296 – RiLine Compact 286, 287, 289 – with connection cables 307 – with plug-in cable outlet 312 – with spring terminals 310 – without contact system 288 Component shelf – 1 U, static installation, 482.6 mm (19") 1009 – 2 U, pull-out, 482.6 mm (19") 1010 – 2 U, static installation, 482.6 mm (19") 1010 – for frame attachment 1006 – Pull-out for TE 1009 – Pull-out, 482.6 mm (19") 1008 – Pull-out, VX SE, PC, IW 1007 – Static installation for TE 1008 – Static installation, 482.6 mm (19") 1008 – Static installation, VX SE, PC, IW 1007 Component support – RiLine Compact 288 Component support, left – for WS 540 621 Component support, right – for WS 540 622 Computer Room Air Conditioner (CRAC) 793 Condensate collecting bottle 544 Condensate discharge 900 Condensate evaporator – Electrical 543 Condensate hose 544 1180 Condensate pump – for LCP Rack/Inline CW 786 Condenser for LCP CW/DX 785 Conductor connection clamps 349 – Push-in 349 Configurators – Chiller 558 – Command panel 273 – DCIM 875 – IT cooling 875 – IT infrastructure 874 – Micro Data Center 874 – PDU 875 – RiMatrix S 874 – Rittal Configuration System 272 – Support arm 273 – VX25 Power Engineering 446 Connection accessories – for LED compact system light 1026 – for LED system light 1023 – for self-assembly 1023 Connection adaptors 208 – 3-pole (185 mm) 370 – for 60 mm busbar system 304 – for voltage supply 610 – RiLine Compact 285 Connection adaptor expansion set – for 60 mm busbar system 306 Connection block 351, 371 Connection bracket – for circuit-breaker component adaptors 355 Connection cable 819 – CAN bus 818 – for power pack, TFT monitor 1109 – for PSM busbars 751 – for SK BUS system 550 – Master/slave cable 550 Connection cable for door-operated switch – for LED system light 1024 Connection cable PSM – 3-phase 751 – single-phase 751 Connection cable/extension 819 Connection cables – for LED system lights 1026 – for OM adaptors 354, 355 Connection clamp 349, 398 – for laminated copper bars 350 – for Maxi-PLS 403 – for NH slimline fuse-switch disconnectors 384 – for NH slimline switch-disconnectors 386, 387 – Push-in 349 Connection component – for signal pillar, modular 1123 Connection components – for air circuit-breakers and busbar connections 406, 407 Connection console 207 – VESA 75/100 207 Connection hose – for LCP CW 786 Connection kit for separated frame 1005 Connection pin – for OM adaptor/support 354 Connection plate 208 – for laminated copper bars 399 – for Maxi-PLS 403 – for ring terminal 399 Connection set – for air/water heat exchangers 545 – for Flat-PLS 400 Connection space cover – for NH fuse-switch disconnectors 357 – for NH slimline fuse-switch disconnectors 357, 383 – for NH slimline switch-disconnectors 383 Connection space cover, rear – for NH slimline switch-disconnectors 386 Connection space extender – for bus-mounting fuse bases 356 Connection terminal block ISV 423 Connector – E-Cu 397 – for busbars 343, 380 – for enclosures 968 – for frame 969 Connector gland 1046, 1047 Connector grommets 1044 Connector kit – for component adaptors 382 – for Flat-PLS/Maxi-PLS 406, 407 Connector lock – for C14 and C20 connectors 752 Consoles – One-piece consoles TP 161 – Universal consoles 162 Contact cutter 1030 Contact hazard protection – RiLine 347, 348 Contact hazard protection cover plate – for 185 mm busbar system 381 – for bus-mounting fuse bases 356 – for component adaptors 382 – for connection block 382 – Form 2b 409 Contact hazard protection module ISV 421 Contact paint 1030 Contact terminal – for NH slimline fuse-switch disconnectors 383 – for NH slimline fuse-switch disconnectors/connection adaptors 384 – for NH slimline switch-disconnectors 387 Contact washer 1033 Container 856 – 861 Cooling medium – for air/water heat exchangers 545 – for chillers 545 Cooling units – for Micro Data Center 768, 769 – for network/server racks VX IT 768, 769 – for refrigerant-based rack and suite cooling 774, 775 – for water-based rack and suite cooling 780 – 783 – Roof-mounted, Blue e 498 – Roof-mounted, Blue e+ 504, 764 – Thermoelectric cooler 474 – UL Type 3R/4 494 – Wall-mounted 475, 476 – Wall-mounted, Blue e 477 – 483 – Wall-mounted, Blue e+ 486 – 489, 765 – Wall-mounted, NEMA 4X 490 Cooling units for cooling IT equipment – Blue e+ 764, 765 Copper bar – with integral punchings 1038 Copper busbars – E-Cu 342 – Laminated 346 – Mini-PLS 294 – PLS 344 Copper spacer roll 417 Corner handle 1105 Corrosion protection primer 903 Rittal System Catalogue 36 Index Cover – Acrylic glazed 930 – Baying, top 915 – Baying, vertical 916 – Blanking panel, 482.6 mm (19") 1093 – for 185 mm busbar system 381 – for busbar supports 396 – for bus-mounting fuse bases 356 – for component adaptors 382 – for connection block 382 – for connection clamps 350 – for NH slimline fuse-switch disconnectors 385 – for NH slimline switch-disconnectors 386 – Form 1 408 – Form 2b 409 – Magnetic 1085 – Tool-free attachment, 482.6 mm (19") 1093 Cover hinge – for terminal boxes KX 951 Cover plate – for connector cut-outs 908 – for support arm connection 1107 Cover plates – Slotted 408 Cover plates for fan panels – for FlatBox 791 Cover section – Busbars 343 – Mini-PLS 294 – RiLine 348 Cover strip – for contact hazard protection cover 381 – ISV 428 Cover with door – for VX 908 Crane bracket 915 Crimping machine L8 – Stripping machine 635 Crimping machine R8 E – Stripping machine 634 Crimping machine RC – Stripping machine 636 Crimping pliers 575 – 577 – for crimp tab terminals 575 – for ring terminals 576 – for wire end ferrules 574, 575 Cross member cutter 586 Cross member for support panel 348 Cross member for VX IT 1083 Cross member, adjustable – for VX, VX SE TP, PC, IW 891 Cross rail ISV 429 Cross-brace – for mounting plate for VX, VX SE 974 CUPONAL busbars 342 Current converter – for NH slimline fuse-switch disconnectors 385 – for NH slimline switch-disconnectors 385 Cutting centre – Secarex AC 18 650 Cutting machine – Length-cutting machine C8+ 632 Cutting tools 585, 586 Rittal System Catalogue 36 D Data Rack 709 – Accessories 1079 DCIM Data Centre Infrastructure Management 830 Deburring blade – for Perforex machining centres BC 590 – Steel blade 590 Deflector, 90° – for air duct system 540 Depth extension frame – for NH fuse-switch disconnectors 429 Depth stays – for Data Rack 1079 – for VX IT 1083 – ISV 430 Desk section – for TP universal console 163 Digital enclosure internal temperature display and thermostat 546 DIN rail mounted device module ISV 422 Direct connection terminal 398 Disconnector cross-member ISV 424 Disconnectors – ISV module 424 – RiLine Compact 290 – Size 000 295, 325, 326 – Sizes 00 to 3 327 – with electromechanical fuse monitoring 331 – with electronic fuse monitoring 329 Display – for LCP Rack/Inline CW 785 – Smart monitoring system 334 Display board with wall bracket 1106 Display frame – Blue e+ roof-mounted cooling unit 557 – VX25 Blue e+ integration solution 557 Distribution busbar cover 416 – for fuse-switch disconnector section 415 Distribution enclosures 135 – Fibre optic, polycarbonate 720 Distributor racks – Data Rack 709, 1079 – TE 8000 708 Divider panel 905 – for module plates 906 Divider panel seal, EMC for VX 1028 Document clip, magnetic 957 Door control – Module 817 Door latch – for bayed suites 910 Door stay AX 96 Door stay for escape routes 956 Door variants VX IT – Aluminium/sheet steel door, vented 922 – Automatic Door Opening (ADO) 919 – Glazed aluminium door, one-piece 920 – Glazed sheet steel door, vertically divided 920 – Sheet steel door, one-piece, solid 921 – Sheet steel door, one-piece, vented 922 – Sheet steel door, vertically divided, solid 921 – Sheet steel door, vertically divided, vented 923 Door-operated switch 1026 – for LED system light 1024 – for self-assembly 1024 Drawers – 1U – 482.6 mm (19") – 482.6 mm (19")/2 U for keyboard and mouse – 482.6 mm (19") to accommodate excess cable length – for keyboard and mouse, with support for mousepad – for VX – Tray Drilling template – for AX D-Switch bus-mounting fuse base Dust guard trim – for AX, KX – for VX, VX SE 1114 1091 1113 1072 1114 928 1007 591 324 959 959 E Earth clamp, EMC 1030 Earth rail 1036 Earth straps 1033 Earthing 1035 Earthing braid 1033 Earthing kit – Earthing extension kit for potential equalisation 1035 – for earth rail 1037 Earthing plate 1034 Earthing point, central 1034 Earthquake base/plinth for VX 1032 Earthquake kit for VX 1032 E-Box KX – Sheet steel 64 – 67 – Stainless steel 232, 233 EC speed control – for EC fan-and-filter units 548 Edge protection 1047 EL wall-mounted enclosures, 3-part 715 – 718 Electric condensate evaporator 543 – Blue e+ 543 Electric hydraulic punch 592 Electrician's scissors 586 Electro-hydraulic pump – for CW 120 644 Electronic enclosure VX25 130 Electronic needle-nose pliers 587 Electronic side cutter 585 EMC – Cable gland 1030 – Earth clamp 1030 – Mounting plate for VX, VX SE 1029 – Shield bus 1029, 1030 – Shielding bracket 1029 – Side panel for VX 1028 – TopTherm fan-and-filter units 459 EMC seal – Divider panel seal for VX 1028 – Shielding seal for VX 1028 Empty enclosures 701 Enclosure connector, adjustable 968 Enclosure flange 214 Enclosure heater – with fan 531 – without fan 530 Enclosure internal fan 539 Enclosure internal thermostat 547 Enclosure key – Hygienic Design 224 1181 Index Enclosure reinforcement 214 Enclosure set – for assembly frame 608 Enclosure systems – Baying enclosure system VX25, sheet steel 116 – Baying enclosure system VX25, stainless steel 242 – Distribution enclosure 135 – Fuse-switch-disconnector enclosure 134 – Modular enclosure 132 – PC enclosure systems 164 – VX IT network/server racks 686 – 699 – VX SE stainless steel, IP 66/NEMA 4X 250 – VX SE, IP 66/NEMA 4 147 – VX SE, sheet steel 142 – VX SE, stainless steel 248 – VX25 Blue e+ integration solution 505 – VX25 electronic enclosure 130 – VX25 with glazed door 128 – VX25, EMC enclosure 136 – VX25, IP 66/NEMA 4 131 – VX25, IP 66/NEMA 4X 246 Enclosures – Configurators 272 – Distribution enclosure 135 – Door latch 910 – Fuse-switch-disconnector enclosure 134 – Internal temperature display and thermostat, digital 546 – Isolator door cover 909 – Key 945 – Modular enclosure 132 – TE 8000 network racks 704 – 707 – VX IT network/server racks 686 – 699 – VX SE stainless steel, IP 66/NEMA 4X 250 – VX SE, sheet steel 142 – VX SE, stainless steel 248 – VX25 electronic enclosure 130 – VX25 with glazed door 128 – VX25, EMC enclosure 136 – VX25, IP 66/NEMA 4 131 – VX25, IP 66/NEMA 4X 246 – VX25, sheet steel 116 – VX25, stainless steel 242 End cover – for 100 mm busbar system 389 – for 185 mm busbar system 380 – for busbar supports 396 – for Mini-PLS 294 – for PLS 303 – for RiLine 301 End support – for fuse-switch disconnector section 415 End supports – for Maxi-PLS 401 Energy-Box 1043 Entry grommets – for cables 1044 – for connectors 1044 Equipment support connectors – ISV 430 Ergoform-S handle electromagnetic – for TE 950 Ergoform-S handle with numerical code – for TE 949 ESD connection point 1037 Ex enclosures 260 – Stainless steel 258, 259 Expansion connector PLS 345 Extension 608 Extension cable 819 Extension kit – for Comfort component adaptor 293 – for earth rail, vertical 1037 Extension module – for Comfort component adaptor 293 1182 Eyebolt – for AX – for VX, VX SE 964 964 F Fan expansion kit 790 Fan module – for LCP Rack/Inline CW 787 Fan mounting plate – for VX IT, TE 790 Fan-and-filter units – TopTherm 456 – TopTherm EMC 459 – TopTherm with EC technology 461 Fastening bolts – for base/plinth, complete and base/plinth, static 891 Fastening bolts for component shelves 1011 Feet 892, 893 Female dies – Busbar machining CW 120-M 643 – for copper processing 643 Fibre-optic – Patch panels 1100, 1101 – Shunting ring 1065 – Small distributor, polycarbonate 720 – Splicing boxes and accessories 1099, 1100 Fibre-optic cable management panel 1065 Fibre-optic cassettes – for Network Cable Organizer 1071 Fibre-optic splicing box – with telescopic pull-out 1100 Filler piece – for connection set 400 Filter mats – for air/air heat exchangers 533 – for base/plinth VX 883 – for chillers 533 – for cooling units 533 – for tangential fans/front outlet grilles 533 Fine filter mat – for fan-and-filter units 536 Fire alarm and extinguisher system DET-AC III 823 – 825 – Pipe kit 826 – Sealing kit for VX IT and LCP 826 Flat copper busbar system – 100/150/185 mm 388 – 185 mm 369 – 60 mm 300 Flat duct extension 541 Flat screen 1109 FlatBox 713 FlatBox base/plinth 891 Flex crimping tool – for wire end ferrules 574 Flow regulator valve 545 Foam rubber cable clamp strip 1045 Fold-out tray 1111 – for keyboard and mouse 1111 Foot-switch – Stationary CW 120-S 644 Frame connector – for Comfort Panel 969 Free-standing enclosure system VX SE – IP 66/NEMA 4 147 – IP 66/NEMA 4X 250 – Sheet steel 142 – Stainless steel 248 Front outlet grille 2 U – for tangential fans 539 Front panel – for Comfort Panel and Optipanel 1107 – for Compact Panel 1107 Front trim panel – Bottom 927 – Top 927 Front-mounting cage nut, 482.6 mm (19") 1098 Fully automated wire processing machine – Wire Terminal WT 656 Functional trolley 613 Fuse elements – for 60 mm busbar system 323, 324 – Mini-PLS 295 Fuse holders 337 – 339 Fuse-switch disconnector section 415, 416 Fuse-switch disconnectors – ISV module 424 – RiLine Compact 290 – Size 00 335 – Size 000 295, 325, 326 – Sizes 00 to 3 327 – Sizes 00 to 3, 185 mm 374 – with electromechanical fuse monitoring 331 – with electronic fuse monitoring 329, 336 – with fuse monitoring, 185 mm 376 Fuse-switch-disconnector enclosure 134 G Gland plate – for cable entry 962 – for compartment side panel 410 – for EL 1054 – for TE 899 – Metal 1053 – Metal, for KX 1054 – Plastic 1052 – Plastic gland plate, modular 1050 – with brush strip, for EL 1055 – with foam rubber cable clamp strip 1054 – with membranes, plastic 1052 – with metric knockouts, plastic 1050 Gland plates – for compartment divider 412 – for VX, VX IT, VX SE 896 Glazed door – for VX 917 – for VX IT 920 – for VX SE 918 Glazed door VX IT – Automatic Door Opening (ADO) 919 Glazed sheet steel door, vertically divided – for VX IT 920 Grommets – for cable entry 1044 – for connector entry 1044 Guide – for mounting plate 974 Guide frame – for Vario rack-mounted fan 557 Rittal System Catalogue 36 Index H Handle set 1104 – for Comfort Panel 1103 – for Optipanel 1103 Handles – Comfort handle AX 939 – Comfort handle VX 937 – Corner handle 1105 – for component shelves 1011 – for mounting plate 981 – Handle adaptor 918 – Mini-comfort handle AX 96, 940, 941 – Plastic handles 942 – T handles 943 – U handle 1105 Handling – Functional trolley 613 Heat exchangers – Air/air, roof-mounted 470 – Air/water, HD 515 – Air/water, in VX25 518 – Air/water, roof-mounted 516 – Air/water, wall-mounted 510 – 514 – Wall-mounted, TopTherm 469 Heaters – for enclosures 530, 531 Hex wrench set 570 Hinge – for blanking plates 1092 – for side panel, screw-fastened, sheet steel 902 Hinge attachment – for partial mounting plate VX 977 Hinged cable support 1011 Hinged lid for interfaces 1118 Hinges – 180° 951 – for cast aluminium enclosures 49 – for polycarbonate enclosures 47 Holder for mouse 1116 Holders – 1-pole 340 – 2-pole 340 – Distribution busbar system 394 – for 185 mm busbar system 368 – for busbar baying (rear section) 396 – for busbar baying (roof section) 395 – for busbar entry (rear section) 395 – for busbar entry (roof section) 394 – for cable conduit 1060 – for fuse-switch disconnector section 415 – for laminated copper bars 346 – for Maxi-PLS 401 – for protective bar 924 – for TFT 1110 – PLS 340 Hole punch set – for sheet steel, metric 595 – for sheet steel, PG 595 – for sheet steel, with triple splitting, M12 - M40 597 – for sheet steel, with triple splitting, M16 - M40 597 – for sheet steel, with triple splitting, PG 9 - PG 21 598 – for stainless steel, round, with triple splitting 600 Rittal System Catalogue 36 Hole punches – for sheet steel, heavy connectors 602 – for sheet steel, rectangular 601 – for sheet steel, round 594 – for sheet steel, special contour 601 – for sheet steel, square 600 – for sheet steel, round, with triple splitting 596 – for stainless steel, round, with triple splitting 599 Hole punching tools 592 – 603 Hose-proof hood – for fan-and-filter units / outlet filters 538 Human/machine interface – Configurators 273 Hydraulic cylinder 645 Hydraulic hose 645 Hydraulic punch 592 Hydraulic punch set – Manual 593 Hydraulic tension screw 603 Hygienic Design – Accessories 223 – 225 – Air/water heat exchangers 515 – Bit HD 224 – Cable gland HD 1057 – Compact enclosures HD 221, 222 – Levelling feet HD 223 – Rails for interior installation HD 225 – T handle HD 223 – Terminal box HD 220 Hygrostat 547 I Identification labels – for Network Cable Organizer 1071 Identification strip 932 Industrial bit for cordless screwdrivers – with long shaft 571 Industrial bit set for cordless screwdriver – with long shaft 572 Industrial Workstations 166, 167 Inlay for plastic gland plate, modular and sealing frame, modular 1051 Insert strip – for circuit-breaker component adaptors 353 – for Mini-PLS component adaptors 353 – for OM adaptor/support 353 Inserted screw nut M12 1039 Inserts for busbar supports 388 Installation kit – for swing frame, large 1078 – for swing frame, small, and partial mounting plate 1076 Installation kit VX – for back-to-back mounting plates 973 Installation module ISV 426 Insulation stripping machines – Crimping machine L8 635 – Crimping machine R8 E 634 – Crimping machine RC 636 – Stripping machine S22 633 Integrated louvres 539 Interchangeable screwdriver set 569 Interconnecting cables – for lights 1026 Interface extension with wall connection and built-in RJ45 module 1117 Interface flaps – for RC circuit-breaker 1117 – Modular 1118 Interference suppressor for fans 820 Interior installation – Rail for AX 989 – Rail for TP, HD 995 Internal latch – for side panel, screw-fastened, sheet steel 902 IoT interface 554 – Blue e IoT adaptor 555 IP 66/NEMA 4 – Baying enclosure system VX25 131 – Free-standing enclosure system VX SE 147 IP 66/NEMA 4X – Baying enclosure system VX25 246 – Free-standing enclosure system VX SE 250 Isolator cap for screw head 1058 Isolator door cover – Sheet steel 909 – Stainless steel 909 ISV distribution enclosures 135 ISV installation kit – for AX 420 – for VX 420 ISV module 425, 426 IT cooling calculator 875 IT enclosures – FlatBox 713 – Small fibre-optic distributor 720 – VerticalBox 712 – Wall-mounted enclosures AX IT 719 – Wall-mounted enclosures EL, 3-part 715 – 718 IT infrastructure – Configurators 874 IT infrastructure selector 874 IT LED system light 1027 IT power distribution 744, 1040, 1041 IT power supply 744, 871, 1040, 1041 IT rack systems – 482.6 mm (19") fastener, 1 U 1097 – TE 8000 704 – 707 – VX IT 686 – 699 J Junction box – with multi-functional bracket 1042 1183 Index K Keyboard – Built-in keyboard with touchpad 1111 – pull-out 1110 Keyboard drawer 1113, 1114 – 1 U for two 482.6 mm (19") mounting levels 1114 – 2 U for one 482.6 mm (19") mounting level 1115 Keyboard support 1115 L Label panel – for signal pillar, 3-way LED and signal pillar, modular 1127 Laminated copper bar 346 Large enclosures – Baying enclosure system VX25, sheet steel 116 – Baying enclosure system VX25, stainless steel 242 – Free-standing enclosure system VX SE, sheet steel 142 – Free-standing enclosure system VX SE, stainless steel 248 – VX25 electronic enclosure 130 – VX25 with glazed door 128 – VX25, IP 66/NEMA 4 131 – VX25, IP 66/NEMA 4X 246 Laser centre – Perforex LC 654 LCD display 334 LED compact system light 1025 LED light strip 821 LED system light 1014 LED system light for IT 1027 LED work light – for WS 540 623 Length-cutting machine C8+ – Support rail cutting machine 632 Levelling component – for base/plinth VX 886 Levelling feet 892, 893 – Hygienic Design 223 – with internal adjustment 892 Lifting aid for mounting plate – for AX 591 Lights – IT LED system light 1027 – LED compact 1025 – LED system light 1014 Liquid Cooling Package – Adaptor 786 – for industry 518 – LCP Inline CW 782 – LCP Inline DX 775 – LCP Rack CW 780 – LCP Rack DX 774 Liquid Cooling Unit – LCU DX, redundant 769 – LCU DX, single 768 Lock and push-button inserts 942 Lock components 917 Lock cover 944 1184 Lock cylinder inserts 943 Lock inserts 941, 942 Lock systems – for console systems and industrial workstation, sheet steel 935 – for enclosures and cases, stainless steel 936 – for large enclosures and PC enclosures, sheet steel 934 – for small enclosures, compact enclosures and operating housings AX, sheet steel 933 Lockable and adjacent door 917 Locking bar latch 937 Locking clip for seal inserts 1051 Longitudinal connector E-Cu 397 LT 1000 – Storage and transport trolley 611 M Magazine support – for WS 540 625 Male and female dies for slots 644 Male dies – for busbars 643 – for copper processing 643 Manual hydraulic punch 592 Manual hydraulic punch set – 90°, M16 - M40 593 – 90°, PG 9 - PG 48 593 – straight, M16 - M63 593 Master/slave cable – for SK BUS system 550 Maxi-PLS – Busbars 401, 402 Measurement module – for NH fuse-switch disconnectors 333 Membrane gland plate 1052 Metal filter – for air/air heat exchangers 534 – for chillers 534 – for climate control door/section door 534 – for cooling units 534 Metal gland plate 1053, 1054 Meter mounting board module 426 Micro Data Center – Level B 846 – Level E 844 Micro Data Center configurator 874 Micro-switch – for NH fuse-switch disconnectors 358 – for NH slimline fuse-switch disconnectors 358 – for NH slimline switch-disconnectors 387 Milling centre – Perforex BC 652 Mini fan 539 Mini-comfort handle AX 96, 940, 941 Mini-comfort handle EL 949 Mini-PC holder – for WS 540 628 Mini-PLS busbar adaptor – for NH fuse-switch disconnectors size 000 295 Mini-PLS busbar systems 294 Modular climate control concept – Climate control doors 507 – Cooling module 506 Modular enclosure 132 Modular front design 925 Module plates 907 – for TE 899 Monitor attachment – for WS 540 622 Monitor housings AX – for desktop TFT up to 24" 180 – with handle strips 178, 179 Monitor, flat 1109 Monitor/keyboard unit, 1 U 822 Motor controller – RiLine Compact 291 Mounting adaptor 948 Mounting adaptor PDU 752 Mounting angles – C rail 996 – for FlatBox 1085 – for VX IT 1081, 1082 Mounting angles additional fastening attachment 1084 Mounting angles ISV 429 Mounting braces, vertical – for WS 540 623 Mounting bracket 999, 1002 – for air circuit-breaker support rail 412 – for contact hazard protection cover 408 – for interior installation 1000 – for VX IT 1082 Mounting claw for second mounting level 998 Mounting clip 997 Mounting component – for signal pillar 1125, 1126 – for wall/base mounting 1125 Mounting frame – for Network Cable Organizer 1070 Mounting kit – for Comfort Panel 1108 – for door-operated switch 1024 – for LED system light 1024 – for Optipanel 1108 – Magnet 1024, 1025 Mounting kit AX – for installation kit for swing frame, small 1076 Mounting kit magnet – for LED compact system light 1025 Mounting kit PSM – for busbar 751 Mounting kit, 2 U 1084 Mounting panel, 482.6 mm (19") 1097 Mounting plate – Accessories 971 – 974, 981 – Attachment for TP one-piece console, TP pedestal 981 – Cross-brace for VX, VX SE 974 – EMC for VX, VX SE 1029 – for bus enclosures KX 970 – for compartment side panel 413 – for EX enclosures 970 – for outdoor Basic enclosure 981 – for terminal boxes HD 970 – for terminal boxes KX 970 – Locatable 998 – Screw-fastened, large 998 – Screw-fastened, small 999 – Slide rail 974 – Transport handle for VX, VX SE 981 – with integral top-hat rail 999 Mounting plate attachment – Type A, for VX 971 – Type B, for VX 972 – Type C, for VX 973 Mounting plate infill for VX 971 Mounting plate module 421 Rittal System Catalogue 36 Index Mounting plates – for cast aluminium enclosures 49 – for polycarbonate enclosures 47 – ISV module 421 Mounting rail – Interior installation AX 989 Mounting set – for connection terminal block ISV 423 Mounting unit 819, 820 Mouse holder 1116 Mousepad – Support 1112, 1115, 1116 Multifunction mounting kit VX, for mounting plate 974 Multifunctional enclosures 271 Multiple lock 944 Multitool – for AX, VX 590 Multi-tooth screw 1004 N N/PE support – 2-pole 340 Needle-nose pliers 587 NEMA 4X – Baying enclosure system VX25 246 – Bus enclosures KX 234 – Compact enclosures AX 236 – 240 – E-Box KX 232, 233 – Ex enclosures 259 – Free-standing enclosure system VX SE 250 – Plastic enclosures AX 94 – Terminal boxes KX 230, 231 – Wall-mounted cooling units Blue e, slimline 490 Network racks – TE 8000 704 – 707 Network/server racks VX IT 686 – 699 NH fuse-switch disconnectors – ISV module 424 – RiLine Compact 290 – Size 000 295, 325, 326 – Sizes 00 to 3 327 – with electromechanical fuse monitoring 331 – with electronic fuse monitoring 329 NH measurement module – for NH fuse-switch disconnectors 333 NH slimline fuse-switch disconnectors – Size 00 335 – Sizes 00 to 3, 185 mm 374 – with electronic fuse monitoring 336 – with fuse monitoring, 185 mm 376 NH slimline fuse-switch-disconnector module 425 NH slimline switch-disconnectors – Sizes 00 to 3, 185 mm 377 – with fuse monitoring, 185 mm 379 Notching pliers 603 Nut 1002, 1003 Nylon loop 1061 Nylon loop cable holder 1062 Nylon tape 1061 Nylon tape holder 1062 Rittal System Catalogue 36 O OCP adaptor 871 OCP Battery Back-up Unit 873 OCP busbar 871 OCP PDU 872 OCP Power 873 OCP Power Shelf 872 OCP Power Supply Unit 873 OCP Rack 870 OCP V2 side panel 871 OM adaptors – with connection cables 307 – with plug-in cable outlet 312 – with spring terminals 310 OM supports – without contact system 313 One-piece consoles – Stainless steel 251 One-piece consoles TP 161 Online adaptor 948 Online conversion assistant for small enclosures KX and compact enclosures AX 274 Operating housings AX – for desktop TFT up to 24" 180 – with handle strips 178, 179 Operating panel 931 Optical component – for signal pillar, modular 1124 Optipanel 174, 175 Oscillating conveyor – Insulation stripping and crimping machine 637 Outdoor 263 – Basic enclosures 268 – Cooling units 497 – Multifunctional enclosures 271 – Project solutions 270, 271 – Toptec 270 – Wall-mounted enclosures 269 Outdoor cooling unit – Toptec 497 Outdoor housing 958 Outlet filter – EMC 537 – Standard 537 Overvoltage protection module Type 3 754 Overvoltage protection PSM 751 P Paint Paper removal flap Partial door – for VX Partial mounting plate holder Partial mounting plate VX – for VX, VX SE – for VX, VX SE, PC, IW Partial mounting plate, locatable – for TP Partial mounting plates – for compartment side panel 903 1116 926 978 980 975 982 413 Partition, horizontally divided, fastened – for VX IT 904 Partition, one-piece, for slide-in fixing – for VX IT 904 Patch panels – for fibre-optic splicing box, depth-variable, and fibre-optic breakout box, 1 U 1100 – for fibre-optic splicing box, lockable 1101 – for small fibre-optic distributors 1101 PC enclosure system – Sheet steel 164 – Stainless steel 252 PDU 732 – 740 – Accessories 752 PDU configurator 875 PDU mounting adaptor – for TE 752 PE busbar 1036 PE/PEN angle bracket 1038 PE/PEN baying bracket E-Cu 1039 PE/PEN busbar E-Cu 1038 Pedestal – Complete 212 – Modular 211 – Open 213 PEN/N/PE support 340 Perforated door strip – for AX stainless steel 953 Perforated mounting strip – for partial door 927 Perforex BC – Deburring blade 590 Perforex BC milling centre 652 Perforex LC laser centre 654 Pillar, small 213 PinBlock – for starters with increased contactor attachment 354 – for support frames (OM adaptor) 354 Pipe kit – for DET-AC III/EFD III 826 Pivot 210 Plastic – Enclosures AX 94 – Enclosures AX, with viewing window 95 – Gland plates 1050, 1052 – Handles 942 Plastic enclosures AX – with viewing window 95 – without viewing 94 Plastic gland plate – for compartment side panel 410 Plastic gland plate, modular and sealing frame, modular 1049 Plate – for base mounting 885 – for cable connection space 410 Plate clamps – for laminated copper bars 350 Pleated filter – Blue e+ roof-mounted cooling unit 536 – VX25 Blue e+ integration solution 536 Pliers 575 – 577, 583, 587, 588, 603 PLS busbar connectors 344 PLS busbar systems 302 PLS expansion connectors 345 PLS special busbars 344 Pole clamp – for AX, KX, AX plastic 968 Polycarbonate enclosures PK 44 – 46 Positioner – RiLine Compact 293 Potential equalisation kit 1035 Potential equalisation kit, Plus version 1035 Potential equalisation rail 1036 Potential equalisation star 1034 Power distribution – Configurators 446 1185 Index Power Distribution Unit PDU 732 – 740 – Accessories 752 Power measurement 753 Power pack – for CMC III monitoring system 818 – for LCD display 334 – for TFT monitor 1109 – RiLine Compact 292 Power supply 1040 Premium Panel 253 Pressure relief stopper 900 Pressure stoppers – for roof plates, for pressure relief 962 Primer/paint – Contact paint 1030 Prism terminal – for NH slimline fuse-switch disconnectors 384 Processing Unit Compact, CMC III 804 Processing Unit, CMC III 804 Product Scan app 274 Profile half-cylinders 942 Programming cable 818 Protective bar 924 Protective roof – for AX 958 PSM 744 PSM busbar 744 PSM measurement bar – for CMC III 747 PSM measurement modules – with CAN bus 749, 750 PSM socket modules 748 Punched rail – 18 x 39 mm 993 – 23 x 23 mm 994 – Cover, distribution busbar 416 Punched section with mounting flange – 14 x 39 mm 952, 990 – 17 x 73 mm 992 – 18 x 64 mm 990 – 23 x 64 mm 991 – 23 x 89 mm 991 Punched section without mounting flange, 23 x 64 mm 993 Punching tools 592 – 603 Q Quick-assembly block Quick-change frame – for roof-mounted cooling units Quick-fit baying clamp, one-piece 1186 1001 556 913 R S Rack-mounted fans – for 482.6 mm (19") 466 Radio comfort handle VX 947 Rail mounting bracket 1002 Rails – Base configuration rail for TP 995 – for EMC shielding bracket and strain relief 1029 – for interior installation AX 989 – for interior installation HD 225 – for interior installation TP, HD 995 RCM measurement module for CMC III 753 Refrigerant lines – for LCU DX 785 Reinforcement – for enclosure 214 Retaining plate – for cable connection space 410 Ride-up roller – for busbars 645 – for door VX, VX SE, PC 956 RiDiag 559 RiLine busbar systems – Flat busbars 300 – PLS busbars 302 RiLine Compact – Board 284 – Circuit-breaker component adaptors 289 – Component adaptors 286, 287 – Connection adaptors 285 – Motor controller 291 – NH fuse-switch disconnectors 290 – Positioner 293 – Power pack 292 RiMatrix S 850 – Efficiency package 850, 851 RiMatrix S Selector 874 Rittal Configuration System 272 RiZone 830, 831 RJ45 – Installation module and extension 1117 Roller conveyor – for assembly frame 609 Roof plate – for cable entry glands, for VX, VX IT 961 – IP 2X, with louvres, for VX, VX IT 961 – IP 55, solid, for VX, VX IT 961 – Two-piece, for VX, VX IT 963 – with mounting cut-out 784 Roof vent 464 Roof-mounted cooling unit Blue e+ IT bundle 764, 765 Roof-mounted cooling units – Blue e+ 504 – TopTherm Blue e 498 Roof-mounted fans 464 – for the office sector 789 – with EC technology 465 Rubber cable clamp strip 1045 Safety lock 944 Scissors – Electrician 586 Screen, flat 1109 Screw adaptor – for spindle hoist 609 Screw connections – for Flat-PLS 400 Screw for interior installation 261 – for AX plastic 97 Screwdriver set 569 – insulated 567 – uninsulated 569 Screwdrivers – insulated 566 – uninsulated 568 Screws 602, 1004, 1098 – for connection brackets 405 – for connector kit 405 – M10 400, 405 – with ball bearing 602 Seal for support arm connection 1107 Seal inserts for plastic gland plate, modular and sealing frame, modular 1051 Sealing frame, modular 1048 Sealing kit – for VX IT 826 Secarex AC 18 cutting centre 650 Second pair of mounting angles – for Data Rack 1079 Sections for cable entry, centre – for VX, VX, SE, TP 1045 Sections for cable entry, rear – for VX, VX, SE, TP 1045 Selector – IT infrastructure 874 – RiMatrix S 874 Self-tapping screw 1004 Sensor – for speed control 548 Server racks 686 – 699 Server telescopic slides 1090 Service socket 1042 Set of brackets – for assembly frame 610 Shallow air duct system – for air/water heat exchanger, roof-mounted 541 – for roof-mounted cooling units 541 Sheet steel – Baying enclosure system VX25, basic enclosure 116 – 127 – Baying enclosure system VX25, basic enclosure with glazed door 128, 129 – Baying enclosure system VX25, electronic enclosure 130 – Baying enclosure system VX25, EMC enclosure 136 – Baying enclosure system VX25, IP 66/NEMA 4 131 – Bus enclosures KX 70 – Compact enclosures AX 84 – 91 – E-Box KX 64 – 67 – Free-standing enclosure system VX SE, basic enclosure 142 – 146 – Free-standing enclosure system VX SE, IP 66/NEMA 4 147 – Operating housings AX with handle strips 178, 179 – Terminal boxes KX, with gland plate 59, 60 – Terminal boxes KX, without gland plate 56 – 58 Rittal System Catalogue 36 Index Sheet steel door – with mounting cut-out 784 Sheet steel door, one-piece, solid – for VX IT 921 Sheet steel door, one-piece, vented – for VX IT 922 Sheet steel door, vertically divided, solid 921 Sheet steel door, vertically divided, vented – for VX IT 923 Shelf – for WS 540 621 Shield bus, EMC 1030 Shielding bracket 1029 Shielding seal – EMC for VX 1028 Shielding, vertical 786 Shipping brace – for door VX 957 Shunting ring 1064 Shunting ring fibre-optic 1065 Side cover – for bus-mounting fuse bases 356 Side cutter 585 Side panel – Compartment 410 – EMC for VX 1028 – for cable chamber 884 – for TE 8000 903 – for top-mounting module 960 – Horizontally divided, for VX IT 902, 903 – Screw-fastened, sheet steel for VX, VX IT 901 – Screw-fastened, stainless steel for VX 901 Signal pillar 1123 Signal pillar, 3-way LED 1122 Signal pillar, modular 1123 Slide rail – for mounting plate 974 – for swing frames 1078 Slide rail VX – for adaptor section 482.6 mm (19") 1089 Slide rail, heavy-duty 1087 Slide rails – Depth-variable 1088 – Depth-variable, 1 U 1089 – for Data Rack 1079 – for TE 8000 1088 – Static installation, VX IT 1086, 1087 Sliding blocks – for circuit-breaker component adaptors 355 – for Maxi-PLS 403 Sliding nut – for Maxi-PLS 404 Sliding plate – for VX, VX IT, VX SE 896 Slimline fuse-switch disconnectors – Size 00 335 – Sizes 00 to 3, 185 mm 374, 375 – with electronic fuse monitoring, 185 mm 376 – with electronic fuse monitoring 336 Slimline switch-disconnectors – Sizes 00 to 3, 185 mm 377, 378 – with electronic fuse monitoring, 185 mm 379 Slip-joint pliers 588 Slot cover – for C13 and C19 slots 752 Small enclosures – GA 48 – PK 44 – 46 – Switch housings 235 Small enclosures KX – Bus enclosures KX, sheet steel 70 – Bus enclosures KX, stainless steel 234 – E-Box KX, sheet steel 64 – E-Box KX, stainless steel 232, 233 Rittal System Catalogue 36 – Terminal boxes KX stainless steel, without gland plate 230, 231 – Terminal boxes KX, with gland plate 59, 60 – Terminal boxes KX, without gland plate 56 – 58 Small equipment box – 482.6 mm (19") 1091 Smart Lifter 616 Smart monitoring system 333, 334 Snap-in cable routing 1062 Socket 1042 Socket box – for LED system light 1022 Socket strip 1040 – for WS 540 625 Software – Blue e+ app 559 – Chiller app 558 – RiDiag 559 – Therm App 558 Spacers 953 – for roof plate 964 Spacers for busbar supports – RiLine 341 Spacing element for busbar supports 388 Spare battery – for assembly frame 609 Spare filter mats – for EMC fan-and-filter unit 535 – for fan-and-filter units 535 – for roof-mounted fans 535 – for Thermoelectric Cooler 535 Spare key 945 Special busbars – Mini-PLS 294 – PLS 344 Speed control – for air/air heat exchangers 549 – for EC fan-and-filter units 548 – for TopTherm fan-and-filter units 549 Splicing boxes and accessories 1099 Splitter hole punch – for sheet steel, round, with triple splitting 596 – for stainless steel, round, with triple splitting 599 Splitter hole punch set – for sheet steel, with triple splitting, M12 - M40 597 – for sheet steel, with triple splitting, M16 - M40 597 – for sheet steel, with triple splitting, PG 9 - PG 21 598 – for stainless steel, round, with triple splitting 600 Splitter hole punch set, metric – Splitter hole punch 600 Spring nut – M5 1003 – with screws M6 1099 Stabiliser – for connector kit 405 Stabiliser for VX IT 894 Stainless steel – Base/plinth corner pieces with base/plinth trim panels, front and rear for VX, VX SE, PC 886 – Base/plinth installation bracket for base/plinth VX 885 – Base/plinth trim panels, sides, for base/plinth VX 887 – Base/plinth, complete, for one-piece console, stainless steel 890 – Baying enclosure system VX25 242 – Bus enclosures KX 234 – Cable gland HD 1057 – Command panel housing with door 254 – – – – – – – – – – Compact enclosures AX 236 – 240 E-Box KX 232, 233 Ex enclosures 258, 259 Free-standing enclosure system VX SE 248 One-piece consoles 251 PC enclosure system 252 Premium Panel 253 Support arm system CP 40 188 Switch housings 235 Terminal boxes KX, without gland plate 230, 231 – Viewing window 931 – VX SE, IP 66/NEMA 4X 250 – VX25, IP 66/NEMA 4X 246 Stand systems 211 – 214 Standalone enclosure VX SE – IP 66/NEMA 4 147 – IP 66/NEMA 4X 250 – Sheet steel 142 – Stainless steel 248 Standard R-OCP V2 rack 870 Static base/plinth – for PC, IW 890 Stay – for door 956 – for door and escape routes 956 Stay for trim panel, hinged at the top 928 Steel blade – for deburring blade 590 Stepped collar 1048 Storage and transport trolley – LT 1000 611 Storage box 954 Storage box holder – for WS 540 624 Straps, earth straps 1033 Stripping machines – Crimping machine L8 635 – Crimping machine R8 E 634 – Crimping machine RC 636 – Stripping machine S22 633 Stripping machine console – for WS 540 628 Stripping machine S22 633 Stripping tool – for cables Ø 2.5 - 11 mm 583 – for cables Ø 4.5 - 40 mm 584 – for cables Ø 8 - 13 mm 583 Supports – for flat copper busbars 300, 388 – for keyboards 1115 – for mousepad 1112, 1115, 1116 – for PLS 302 – for small appliances 1097 – N conductor 1039 – Wall bracket for VX, VX SE, VX IT 967 Support arm configurator 273 Support arm system – CP 40, steel 184 – 187 – CP 40, stainless steel 188 – CP 60 192 – 195 – CP 120 196 – 199 – CP 180 200 – 203 – CP 40/60/120/180 207 Support frame – for DIN rail-mounted devices 414 Support panel – for cover section 348 Support rail cutter MC3 605 Support rail module ISV 422 1187 Index Support rails 997 – 48 x 26 mm 996 – 65 x 42 mm 997 – 75 x 20 mm 996 – for circuit-breaker component adaptors 353 – for circuit-breakers 412 – for Comfort component adaptor 293 – for Mini-PLS component adaptors 352, 353 – for OM adaptor/support 352 – for VX IT 1084 Support section, height-adjustable for support arm system CP 204 – 206 Support set (stabiliser) – for connector kit 405 Support strip 994 – for AX with cam lock 952 – for VX, VX SE, AX plastic, TP, PC, IW 952 Support unit, 3 U – for LSA strips 1102 Supports – for Mini-PLS 294 Surplus cable holder 1066 Swing frame – 180° hinges for VX 1078 – Large 1077 – Small 1075 – Stay 1078 Switch – for NH fuse-switch disconnectors 358 – for NH slimline fuse-switch disconnectors 358 Switch housings – Stainless steel 235 Switchgear assignment – Mini-PLS component adaptors 297 – OM adaptors 319 – 322 System attachment – 185 mm busbar systems 380 System cover – for connection clamps 350 System divider 895 System lights 1014 – 1027 System window 929 T T distributor for LED system light 1023 T handle HD – Hygienic Design 223 T handles 943 Tangential fans – for 482.6 mm (19") 468 T-connector kit 406 TE 8000 – Distributor racks 708 – Network racks 704 – 707 Technical information 1128 – 1131 Telescopic slide – for component shelves 1011 Temperature display and thermostat 546 Temperature sensor – for Blue e+ cooling units, Blue e+ chillers 549 Tension screw 602, 603 – with ball bearing 602 Terminal block ISV 423 Terminal block assembly centre – Athex TC 80 CS 658 Terminal box – for modular outgoing section 411 1188 Terminal boxes HD – Hygienic Design 220 Terminal boxes KX – Cover hinge 951 – Sheet steel, with gland plate 59, 60 – Sheet steel, without gland plate 56 – 58 – Stainless steel, without gland plate 230, 231 Terminal connection – for NH slimline fuse-switch disconnectors 358 Terminal studs – for Maxi-PLS 403 Terminals 349, 383, 398 – for laminated copper bars 350 – for Maxi-PLS 403 – for NH fuse-switch disconnectors 357 – for NH slimline fuse-switch disconnectors 358, 384 – for NH slimline switchdisconnectors 386, 387 – Push-in 349 TFT – Monitor 1109 – Operating housing AX for desktop TFT up to 24" 180 TFT holder 1110 Therm app 558 Therm software 558 Thermoelectric cooler 474 Thermostat – Enclosure internal thermostat 547 Threaded block 1003 Threaded bolts – for Maxi-PLS 404 Tilt coupler 210 Tilting adaptor – +100°/-60° 209 – +/-45° 209 Tool bag – Configured 565 – Unconfigured 565 Tool holder, round – for WS 540 627 TopConsole system TP 156 – 160 Top-mounting module 960 TopTherm – Air/air heat exchangers 469 – Chillers 519 – EMC fan-and-filter units 459 – Fan-and-filter units 456 – Fan-and-filter units with EC technology 461 – VX25 chillers 528 – Wall-mounted cooling units, horizontal format 475 – Wall-mounted cooling units 476 TopTherm Blue e – Roof-mounted cooling units 498 – Wall-mounted cooling units 477 – 482 – Wall-mounted cooling units, slimline 483 Toroidal transformer – for air/water heat exchanger, wall-mounted 550 Touchscreen 1109 TP – Aluminium strip 163, 1104 – Desk section 163 – One-piece consoles 161 – TopConsole 3-part 156 – Universal consoles 162 Transformer – for NH slimline fuse-switch disconnectors 385 – for NH slimline switch-disconnectors 385 Transponder card 814 Transponder reader 813 Transport and mounting handle for doors VX, VX SE 957 Transport bracket 915 Transport castors – for base/plinth VX 884 – for TE 895 Transport handle for mounting plate 981 Transport kit – for VX empty enclosures 894 Tray, drawer tray 1007 Trim frame – for slimline cooling units 556 Trim panel – Bottom 927 – for TP 163 – Hinged at the top 928 – Top 927 Trim strip – for NH slimline fuse-switch disconnectors 386 – for NH slimline switch-disconnectors 386 Twin castors 893 Twin cord – for OM adaptors 355 U U handle U nut UL Type 3R/4 – Wall-mounted cooling units Universal bracket – for AX plastic – for Ex enclosure, plastic Universal consoles TP – Sheet steel Universal support for laminated copper bars Universal utility shelf – for WS 540 USB extension Utility bar, vertically hinged Utility lectern for VX, VX SE, TP, PC 1105 1003 494 1004 97 97 162 346 628 1117 1112 953 V V connection terminal – for NH slimline fuse-switch disconnectors 384 Variable modular climate control concept 924 Vario rack-mounted fan – for 482.6 mm (19") 467 Vent cover 791 Vent trim panel, 482.6 mm (19") 1093 Ventilated front panels 1093 – Width 482.6 mm (19") 1094 VerticalBox 712 Viewing window 930 – Stainless steel 931 Voltage supply – Connection adaptor 610 – for assembly frame 610 VX IT network/server racks 686 – 699 Rittal System Catalogue 36 Index VX SE free-standing enclosure system – IP 66/NEMA 4 – IP 66/NEMA 4X – Sheet steel – Stainless steel VX25 – Basic enclosure with glazed door – Baying enclosure system, sheet steel – Baying enclosure system, stainless steel – Distribution enclosure – Electronic enclosure – EMC enclosure – Enclosure, sheet steel – Enclosure, stainless steel – Fuse-switch-disconnector enclosure – IP 66/NEMA 4 – IP 66/NEMA 4X VX25 Blue e+ integration solution – Baying plate VX25 chiller – TopTherm VX25 Power Engineering 147 250 142 248 128 116 242 135 130 136 116 242 134 131 246 556 528 446 W Wall angle – for AX, KX, AX IT 967 Wall bracket – for VX, VX SE, VX IT 967 Wall mounting brackets – for AX plastic 97 – for AX sheet steel, KX sheet steel, AX IT, EL 965, 966 – for AX stainless steel, KX stainless steel 967 – for AX stainless steel, KX stainless steel, stainless steel switch housing 965 – for cast aluminium enclosures 49 – for Ex 261 – for polycarbonate enclosures 47 – Vertically hinged 969 Wall spacer brackets – Hygienic Design HD 223 Wall-mounted cooling units – Blue e+ 486 – 489, 765 – Blue e, slimline, NEMA 4X 490 – TopTherm 476 – TopTherm Blue e 477 – 482 – TopTherm Blue e, slimline 483 – TopTherm, horizontal format 475 – UL Type 3R/4 494 Wall-mounted enclosures – EL, 3-part 715 – 718 Wall-mounted enclosures AX IT 719 Washer, contact washer 1033 Waste bin – for WS 540 624 Windows – System window 929 – Viewing window 930, 931 Wire coil holder – for WS 540 627 Wire dispenser – Wire routing 637 Wire end ferrules on reel – DIN colour code 578 – 580 – Multiple colour codes 578 – 580 – Rittal colour code 578 – 580 Rittal System Catalogue 36 Wire end ferrules, loose – DIN colour code 581, 582 – Rittal colour code 581, 582 Wire pack holder – for WS 540 626 Wire reel holder – for assembly frame 609 Wire routing – Component support, left 626 – for assembly frame 608 – Mounting braces, vertical 625 – Wire dispenser 637 Wire Station WS 540 620 Wire stripper 583 Wire Terminal WT 656 Wiring bracket ISV 428 Wiring duct – for D-Switch bus-mounting fuse base 356 Wiring duct cutter 604 Wiring plan lectern for VX, VX SE, TP, PC 954 Wiring plan pocket – Plastic 955 – Sheet steel for VX, VX SE, TP pedestal, PC 955 – Sheet steel, width-variable, for AX 954 – with transparent pouch 955 Wiring table – Wire Station WS 540 620 Wiring trim panel 417 RAL colours Colour RAL Designation Rittal Power Pink 5002 ultramarine blue 5018 turquoise blue 7001 silver grey 7015 slate grey 7016 anthracite grey 7022 umbra grey 7024 graphite grey 7030 stone grey 7035 pale grey 7045 telegrey 1 9003 signal white 9005 jet black 9006 white aluminium 9007 grey aluminium 9011 graphite black We reserve the right to further developments and technical modifications of our products. Such modifications, along with errors and printing errata, shall not constitute grounds for compensation. We refer customers to our Terms of Sale and Delivery. 1189 Rittal international Rittal is present around the globe. We are close at hand to assist you with innovative products and comprehensive services. Harness the power of “Rittal – The System.” ◾ 58 subsidiaries ◾ 85 sales and logistics centres with 270,000 m2 of storage space ◾ 8 production sites with 220,000 m2 of production space ◾ Approx. 1,800 patents and designs as a testimony to Rittal’s innovative strength 1190 Rittal System Catalogue 36 Germany www.rittal.com Greece www.rittal.gr Poland www.rittal.pl Argentina www.rittal.com.ar Hong Kong www.rittal.com.hk Portugal www.rittal.pt Australia www.rittal.com.au Hungary www.rittal.hu Romania www.rittal.ro Austria www.rittal.at India www.rittal-india.com Russia www.rittal.ru Belgium www.rittal.be Indonesia www.rittal.com Singapore www.rittal.com.sg Brazil www.rittal.com.br Ireland www.rittal.ie Slovakia www.rittal.sk Bulgaria www.rittal.bg Israel www.rittal.co.il Slovenia www.rittal.si Canada www.rittal.ca Italy www.rittal.it South Africa www.rittal.co.za Chile www.rittal.cl Japan www.rittal.co.jp Spain www.rittal.es China www.rittal.cn Korea www.rittal.co.kr Sweden www.rittal.se Colombia www.rittal.com.co Lithuania www.rittal.lt Switzerland www.rittal.ch Croatia www.rittal.hr Malaysia www.rittal.com.my Taiwan www.rittal.com.tw Czech Republic www.rittal.cz Mexico www.rittal.com.mx Thailand www.rittal.co.th Denmark www.rittal.dk Netherlands www.rittal.nl Turkey www.rittal.com.tr United Arab Emirates Dubai www.rittal-middle-east.com New Zealand www.rittal.co.nz Ukraine www.rittal.com.ua Norway www.rittal.no USA www.rittal.us Peru www.rittal.pe Vietnam www.rittal.com.vn Finland www.rittal.fi France www.rittal.fr Great Britain www.rittal.co.uk More international subsidiaries and agencies can be found at www.rittal.com Rittal System Catalogue 36 1191 Enclosures Power Distribution Climate Control IT Infrastructure Software & Services You can find the contact details of all Rittal companies throughout the world here. www.rittal.com/contact XWW00114EN2005 ◾ ◾ ◾ ◾ ◾
1611000
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装。
1611000 价格&库存
很抱歉,暂时无法提供与“1611000”相匹配的价格&库存,您可以联系我们找货
  • 1+3005.64165
  • 5+2921.42495
库存:2
