3688115
3688115
    RITTAL(威图)
    RITTAL - 3688115 - 19" Subrack, Ripac ECO, 3U, 84, 235 mm, 210 mm, 482.6 mm, 9.25 "
3688115 数据手册
  Ripac ECO 3 U, 6 U, sheet steel   B = Width T = Depth H1 H1                     1                                                 Subrack 2                                 Material/surface finish: Side panels: 1.5 mm sheet steel, zinc-plated, passivated Flanges/horizontal rails: Extruded aluminium section, clear-chromated B Subrack 3.5 Supply includes: Side panels, flanges, horizontal rails, threaded inserts Detailed parts lists, see page 1155. Tests: Vibration and shock-tested to: IEC 600-68-2-6 test Fc IEC 600-68-2-27 test Ea Standards: Ripac subracks are based on the system dimensions of IEC 60 297-3/-5.   A     Detailed drawing, see page 1155. A                                 A     C4     C4 A 1 for backplane     C4 D1 C4 2 for backplane     U (H1) 482.6 (19 2 3 B1 mm     Model No. RP 1 )   B2 HP Side panel (T1) mm T2 mm Max. PCB depth mm 84 175 235 150 210 160 220   For backplane 6   3688.114 3688.115 For backplane 3688.116 3688.117 Page         Accessories Trim section rear, 3 U 3688.112 497 Trim section rear, 6 U 3688.113 497 Z (connector) rail 3684.602 504 Insulating strips Cover, perforated, for 175 mm depth 3684.611 3688.105 505 518 Cover, perforated, for 210 mm depth 3688.106 518 Cover, solid, for 175 mm depth 3688.107 518 Cover, solid, for 210 mm depth Mounting clips for covers 3688.108 3688.109 518 518 9902.188 518 Assembly screw for mounting clips Guide rails Horizontal rails       509 498       Subrack components Page 495 Accessories Page 506 Assembly parts Page 576 Ripac Vario Page 489 Ripac Compact Page 493 Ripac Vario Mobil Page 494 488 Rittal Catalogue 31/Electronic packaging
3688115 价格&库存
很抱歉,暂时无法提供与“3688115”相匹配的价格&库存,您可以联系我们找货
    • 1+948.95049
    库存:2
