22.2618-22
22.2618-22
    OTHER
22.2618-22 数据手册
In-line, Ø 2 mm with spring-loaded MULTILAM for self-assembly of test leads.Solder connection. Technical data Diameter of plug system 2 mm Rated Values 30 VAC, 10 A / 60 VDC, 10 A Surface treatment electrical contact Au Base material electrical contact CuZn Colours * Test accessory acc. to IEC EN 61010-031 Component parts KT2-S; LS205-L Material insulating part PA Stäubli Electrical Connectors AG Stockbrunnenrain 8 4123 Allschwil/Switzerland Tel.: +41 61 306 55 55 Fax: +41 61 306 55 56 ec.ch@staubli.com www.staubli.com ©2018 Item number 22.2618-* Staubli is a trademark of Stäubli International AG, registered in Switzerland and other countries. We reserve the right to modify product specifications without prior notice. Data sheet SLS205-L 10.2018 SLS205-L
22.2618-22 价格&库存
很抱歉,暂时无法提供与“22.2618-22”相匹配的价格&库存,您可以联系我们找货
    • 5+21.15259
    • 25+20.77977
    • 50+20.26117
    • 100+19.75714
    库存:2580
