66.9040-22
66.9040-22
    OTHER
66.9040-22 数据手册
For mounting on printed circuit boards, touch-protected according Machined brass. Connection: Ø 2 mm round pin and contacts for to IEC/EN 61010-1. The socket is directly soldered onto printed mounting on printed circuit boards. circuit boards. The right-angled configuration minimizes the force transmitted to the printed circuit board through theplugged-in test lead. Right-angled Ø 4 mm rigid socket accepting spring-loaded Ø 4 mm plugs with rigid insulating sleeve. Technical data Diameter of plug system 4 mm Rated Values 1000 V, CAT III, 24 A Surface treatment electrical contact Au Base material electrical contact CuZn Colours * Test accessory acc. to IEC EN 61010-2-030 Approvals UR Stäubli Electrical Connectors AG Stockbrunnenrain 8 4123 Allschwil/Switzerland Tel.: +41 61 306 55 55 Fax: +41 61 306 55 56 ec.ch@staubli.com www.staubli.com ©2018 Item number 66.9040-* Staubli is a trademark of Stäubli International AG, registered in Switzerland and other countries. We reserve the right to modify product specifications without prior notice. Data sheet XELW-4 10.2018 XELW-4
66.9040-22 价格&库存
很抱歉,暂时无法提供与“66.9040-22”相匹配的价格&库存,您可以联系我们找货
    • 1+69.09581
    • 10+67.63788
    • 25+65.55511
    • 50+63.97220
    库存:487
