23.3000-21
23.3000-21
    OTHER
23.3000-21 数据手册
Insulated, rigid, Ø 4 mm, accepting spring-loaded Ø 4 mm plugs with rigid insulating sleeve. Machined brass. The socket is screwed into pre-drilled panels of plastic, metal, etc.Connection: Flat connecting tab 4,8 mm × 0,8 mm. Technical data Diameter of plug system 4 mm Rated Values 1000 V, CAT III, 24 A Surface treatment electrical contact Au Base material electrical contact CuZn Colours * Test accessory acc. to IEC EN 61010-2-030 Supplied assembly material MUR/M12x0,75; SSP4 Material insulating part PA Approvals UR Remarks Accessories: Flat connecting receptacle FSH4,8x0,8; Tube spanner SS2; Tube spanner SS425 Stäubli Electrical Connectors AG Stockbrunnenrain 8 4123 Allschwil/Switzerland Tel.: +41 61 306 55 55 Fax: +41 61 306 55 56 ec.ch@staubli.com www.staubli.com ©2018 Item number 23.3000-* Staubli is a trademark of Stäubli International AG, registered in Switzerland and other countries. We reserve the right to modify product specifications without prior notice. Data sheet SLB4-F 10.2018 SLB4-F
23.3000-21 价格&库存
很抱歉,暂时无法提供与“23.3000-21”相匹配的价格&库存,您可以联系我们找货
    • 2+41.16240
    • 30+39.09020
    • 100+37.13180
    • 250+35.26922
    库存:666
