23.0110-21
23.0110-21
    OTHER
23.0110-21 数据手册
Insulated, Ø 4 mm, rigid. Machined brass. Metal thread jacket on the insulation. The socket can be screw-mounted in predrilled panels. Available with hexagonal nut.Solder connection. Technical data Diameter of plug system 4 mm Rated Values 30 VAC, 25 A / 60 VDC, 25 A Surface treatment electrical contact Opt Base material electrical contact CuZn Colours * Thread M8x0,5 Test accessory acc. to IEC EN 61010-2-030 Component parts BI-LB-I4R; MU/M8x0,5; SP4 Stäubli Electrical Connectors AG Stockbrunnenrain 8 4123 Allschwil/Switzerland Tel.: +41 61 306 55 55 Fax: +41 61 306 55 56 ec.ch@staubli.com www.staubli.com ©2018 Item number 23.0110-* Staubli is a trademark of Stäubli International AG, registered in Switzerland and other countries. We reserve the right to modify product specifications without prior notice. Data sheet LB-I4R 10.2018 LB-I4R
23.0110-21 价格&库存
很抱歉,暂时无法提供与“23.0110-21”相匹配的价格&库存,您可以联系我们找货
