23.0450-23
23.0450-23
    OTHER
23.0450-23 数据手册
Insulated, Ø 4 mm, rigid. Rolled brass sheet. The socket can be screw-mounted in predrilled panels.Solder connection. Technical data Diameter of plug system 4 mm Rated Values 30 VAC, 25 A / 60 VDC, 25 A Surface treatment electrical contact Ni Base material electrical contact CuZn Colours * Test accessory acc. to IEC EN 61010-031 Component parts BI-LB-I4R-B; MU/M8x0,5 Stäubli Electrical Connectors AG Stockbrunnenrain 8 4123 Allschwil/Switzerland Tel.: +41 61 306 55 55 Fax: +41 61 306 55 56 ec.ch@staubli.com www.staubli.com ©2018 Item number 23.0450-* Staubli is a trademark of Stäubli International AG, registered in Switzerland and other countries. We reserve the right to modify product specifications without prior notice. Data sheet LB-I4R-B 10.2018 LB-I4R-B
23.0450-23 价格&库存
很抱歉,暂时无法提供与“23.0450-23”相匹配的价格&库存,您可以联系我们找货
