23.1015-22
23.1015-22
    OTHER
23.1015-22 数据手册
Insulated, Ø 4 mm, rigid. Brass sheet, punched and rolled. The socket is pressed into predrilled panels of plastic, metal etc.Flat connecting tab 4.8 mm x 0.8 mm, can be bent to 90°, once only. Technical data Diameter of plug system 4 mm Rated Values 30 VAC, 25 A / 60 VDC, 25 A Surface treatment electrical contact Ni Base material electrical contact CuZn Colours * Test accessory acc. to IEC EN 61010-2-030 Component parts I-EB4-B; B-EB4-B Remarks Accessories: Flat connecting receptacles FSH4,8x0,8; Press-in tool MB4 Stäubli Electrical Connectors AG Stockbrunnenrain 8 4123 Allschwil/Switzerland Tel.: +41 61 306 55 55 Fax: +41 61 306 55 56 ec.ch@staubli.com www.staubli.com ©2018 Item number 23.1015-* Staubli is a trademark of Stäubli International AG, registered in Switzerland and other countries. We reserve the right to modify product specifications without prior notice. Data sheet EB4-B 10.2018 EB4-B
23.1015-22 价格&库存
很抱歉,暂时无法提供与“23.1015-22”相匹配的价格&库存,您可以联系我们找货
