DS200UB-10V
DS200UB-10V
    DANISENSE
    DANISENSE - DS200UB-10V - Current Sensor, Voltage Output, 140 A AC, -200A DC to 200A DC, 14.25 V to ...
DS200UB-10V 数据手册
DS200UB-10V Ultra-stable, high precision (ppm class) fluxgate technology DS Series current transducer for non-intrusive, isolated DC and AC current measurement up to 220A Features Applications: Linearity error maximum ±50 ppm MPS for particles accelerators 10V BNC output connection Gradient amplifiers for MRI devices Fluxgate, closed loop compensated technology with fixed excitation frequency and second harmonic zero flux detection for best in class accuracy and stability Stable power supplies Green diode for normal operation indication Full aluminum body for superior EMI shielding and extended operating temperature range Precision drives Batteries testing and evaluation systems Power measurement and power analysis Current calibration purposes Large aperture 27.6mm for cables and bus bars Specification highlights Symbol Unit Nominal primary AC current IP N A C A rms Nominal primary DC current IP N DC A -200 200 ÎP M A -220 220 V/kA Measuring range Primary / secondary ratio Min Typ Max 140 50.000 50.000 Linearity error ƐL ppm -50 50 Offset current (including earth field) IOE ppm -35 35 accƐ ppm -85 85 AC Maximum gain error 10Hz to 3kHz ƐG % Operating temperature range Ta °C -40 85 Power supply voltages Uc V ±14.25 ±15.75 DC-10Hz Overall accuracy @23°C (= ƐL + IOE) All ppm (or %) values refer to nominal current page 1 - 2019-11-05 Precision – Innovation www.danisense.com ±0.01 DS200UB-10V Electrical specifications at Ta=23°C, supply voltage = ± 15V unless otherwise stated Parameter Symbol Unit Nominal primary AC current IPN AC Arms Nominal primary DC current -200 200 -220 220 IPN DC A Measuring range IPM A Overload capacity ÎOL A Nominal output voltage Min Typ. Max 140 1500 VSN Vout -10 10 Primary / secondary ratio Ratio V/kA 50.0000 50.0000 Bandwidth Amplitude error f (-3dB) kHz 500 ƐG % q º tr @ 90% µs Phase shift 10Hz –3kHz 3kHz -10kHz 10kHz - 100kHz 10Hz –3kHz 3kHz -10kHz 10kHz - 100kHz Response time to a step current IPN noise ppm rms f E xc kHz Induced rms voltage on primary conductor Refer to fig. 2 for derating Refer to fig. 2 for derating Non-measured, 100ms At nominal primary DC current Small signal, graphs figure 3 0.01% 0.20% % refers to nominal current 3.00% 0.30º 1.00º 9.00º 1 Noise 0 - 100Hz 0 - 1kHz 0 - 10kHz 0 - 100kHz Fluxgate excitation frequency Comment di/dt = 100A/µs 0.02 0.04 0.40 1.50 32.5 5 µV rms Power supply voltages Uc V ±14.25 Positive current consumption Ips mA 93 97 104 Add Is (if Is is positive) Negative current consumption Ins mA 85 91 96 Add Is (if Is is negative) Operating temperature range Ta °C -40 85 Linearity error ƐL ppm -50 50 ppm refers to nominal DC current IOE ppm -35 35 ppm refers to nominal DC current ppm/K -2 2 ppm refers to nominal DC current ppm/month -0.3 0.3 ppm refers to nominal DC current ppm/V -0.1 0.1 ppm refers to nominal DC current ppm -5 5 ppm refers to nominal DC current ±15.75 Offset error Initial Versus temperature Versus time Versus supply voltage Ratio Error Initial @23°C Versus temperature Versus time DC-10Hz Overall accuracy @23°C (= ƐL + IOE ) accƐ ppm/K 1 1 ppm refers to nominal DC current ppm/month -5 5 ppm refers to nominal DC current ppm -85 85 ppm refers to nominal DC current Indicate that caution is necessary when operating the device Caution: Intended use is to measure current, and the product should only be used for intended use. page 2 - 2019-11-05 Precision – Innovation www.danisense.com DS200UB-10V Frequency and ambient temperature derating (Fig. 2) Maximum primary current A rms Primary Current (A) 1000 100 10 1 10Hz 100Hz 1,000Hz 10,000Hz 100,000Hz 1,000,000Hz Primary Current (Hz) Max current (Arms) 85 deg Max current (Arms) 65 deg Max current (Arms) 45 deg Frequency characteristics (Fig. 3) Amplitude / Phase 20.00 10.00 0.00 -10.00 -20.00 -30.00 -40.00 10Hz 100Hz 1,000Hz Amplitude (%) page 3 - 2019-11-05 10,000Hz Phase Error (deg) Precision – Innovation www.danisense.com 100,000Hz DS200UB-10V Isolation specifications Parameter Unit Value Clearance mm 9.5 Creepage distance mm 10.5 Comparative tracking index (CTI) > 600 Rms voltage for AC isolation test, 50/60 Hz, 1 min - Between primary and (secondary and shield) - Between secondary and shield kV 5.7 0.2 Impulse withstand voltage (1.2/50µs) kV 10.4 V 1000 600 300 Continous working voltage with Uninsulated wire • Non mains • CAT II (DC and rms) • CAT III (DC and rms) Insulated wire • Non mains • CAT II (DC and rms) • CAT III (DC and rms) 2000 1000 1000 Transient voltage with Uninsulated wire • Non mains • CAT II • CAT III Insulated wire • Non mains • CAT II • CAT III V 4500 6000 6000 6000 6000 8000 Caution: Do not connect the transducer to signals or use for measurements within Measurement Category IV, or for measurements on MAINs circuits or on circuits derived from Overvoltage Category IV which may have transient overvoltages above what the product can withstand. The product must not be connected to circuits that have a maximum voltage above the continuous working voltage, relative to earth or to other channels, or this could damage and defeat the insulation. The product can only withstand transients up to the transient overvoltage rating without breakdown or damage to the insulation. An analysis of the working voltages, loop impedances, temporary overvoltages, and transient overvoltages in the system must be conducted prior to making measurements. Caution: When using insulated wires all wiring must be insulated for the highest voltage used. Absolute maximum ratings Parameter Unit Max Comment Primary kA 4.5 Maximum 100ms Power supply V ±16.5 page 4 - 2019-11-05 Precision – Innovation www.danisense.com DS200UB-10V Environmental, safety and mechanical specifications Parameter Unit Altitude m Min Typ Max Comment 2000 Usage Designed for indoor use Transient voltages Up to overvoltage category III Poution Degree 2 Ambient operating temperature range °C -40 85 Storage temperature range °C -40 85 Relative humidity % 20 80 Mass kg Connections DSUB9 male and BNC connector Standards IEC61010-2-30 IEC61326-1 EMC IEC61010-1:2010 3rd Edition External devices External devices connected to current transducers must comply with the standards IEC61010-1, IEC60950 or IEC62368-1 and be energy-limited circuitry Cleaning The transducer should only be cleaned with a damp cloth. No detergent or chemicals should be used. Temperature When multiple primary turns are used or high primary currents are applied the temperature around the transducer will increase, please monitor to ensure that the maximum ratisngs are not exceeded. It is recommended to have minimum 1mm2 per ampere in the primary busbar. Non-condensing 0.6 Advanced Sensor Protection Circuits “ASPC” Developed to protect the current transducer from typical fault conditions: • • Unit is un-powered and secondary circuit is open or closed Unit is powered and secondary circuit is open or interrupted Both DC and AC primary current up to 100% of nominal value can be applied to the current transducers in the above situations without damage to the electronics. Please notice that the transducer core can be magnetized in all above cases, leading to a small change in output offset current (less than 10ppm) Status pins When transducer is operating in normal condition, the status pins (3 and 8) are shorted. Status pins properties: - forward direction pin 8 to pin 3, maximum forward current 10mA - maximum forward voltage 60V, maximum reverse voltage 5V Accessories • • • 4-channel power supplies unit for connection up to 4 x DL2000 : 6-channel power supplies for connection of up to 6 x DL2000: Transducer cables in 4 lengths (2m - 5m - 10m –15m - 20m): Please visit the Danisense homepage for relevant datasheets. page 5 - 2019-11-05 Precision – Innovation www.danisense.com DSSIU-4-1U DSSIU-6-1U DSUB2 - DSUB5 - DSUB10 DSUB15 - DSUB20 DS200UB-10V (general tolerance 0.3mm unless otherwise stat- DSUB pin layout DSUB-9 pinout & BNC connection 5 4 3 2 1 When sensor is operating in normal condition the status pins are shorted. 9 8 7 6 5 9 4 8 3 7 2 6 1 Status pin properties. - Forward direction pin 8 to pin 3 - Maximum forward current 10mA - Maximum forward voltage 60V - Maximum reverse voltage 5V Positive current direction Is identified by an arrow on the transducer body page 6 - 2019-11-05 -Vc +Vc 0V Status Status NC NC Do not use Do not use Mounting instructions • Base plate mounting • Back side panel mounting Precision – Innovation www.danisense.com Impedance matching resistor 50Ω 10V 0V 2 holes 6.5 2 x M5 steel screws / 6N.m 3 holes 4.0 x 6H 3 x M4 steel screw / 4N.m 1 BNC DS200UB-10V Intended use: The DS200UB-10V is designed to measure current up to 200A, and be powered by a DSSIU-4-1U or DSSIU-6-1U. Instruction for use: 1. Do not power up the device before all cables are connected. 2. Only use cables supplied by Danisense 3. Place the primary conductor through the apperture of the transducer 4. If the DSSIU-4(6)-1U is intended for desk use, mount the rubber feet which are part of the package. 5. If the DSSIU-4(6)-1U is intended for Rack mounting, use the screw kit for mounting and do not mount the rubber feet. 6. Connect a DSUB cable between DSSIU-4(6)-1U and each sensor 7. Connect a Voltmeter, DMM or other sort of analyzer with a voltage input to the transducer BNC connector. 8. Ensure that no calibration connectors are attached when measuring primary current. Always avoid to create a calibration short circuit, between + and — calibration connection. 9. There is a risk of electrical shock if an uninsulated busbar with high voltages is touching the metal en- closure of the transducer. Please ensure before powering up the system that no primary busbar can touch the metal enclosure. 10. When all connection are secured - connect mains power 11. Apply primary current Safety Instructions: DO NOT TRY TO DISASSEMBLE THE UNIT. If the green transducer diode is not operating when the system is powered up, disconnect power and contact Danisense for further instruction. If the equipment is used in a manner not specified by the manufacturer, the protection provided by the page 7 - 2019-11-05 Precision – Innovation www.danisense.com
DS200UB-10V 价格&库存
很抱歉,暂时无法提供与“DS200UB-10V”相匹配的价格&库存,您可以联系我们找货
