DM1200ID
DM1200ID
    DANISENSE
    DANISENSE - DM1200ID - Current Sensor, Current Output, 1.2 kA AC, -1.5kA DC to 1.5kA DC, 14.25 V to ...
DM1200ID 数据手册
DM1200ID Ultra-stable, high precision (ppm class) fluxgate technology DM Series current transducer for non-intrusive, isolated DC and AC current measurement up to 1800A Applications: Features Ø45mm aperture enabling large isolated cables and the possibility to measure leakage current at high precision. 1 ppm linearity Power measurement and power analysis Stable power supplies MPS for particles accelerators Gradient amplifiers for MRI devices 10 ppm offset Precision drives Current output Fluxgate, closed loop compensated technology with crystal driven excitation frequency for increased stability Batteries testing and evaluation systems Current calibration purposes Industry standard DSUB 9 pin connection Full aluminum body for superior EMI shielding and extended operating temperature range Specification highlights Symbol Unit Nominal primary AC current IP N A C A rms Nominal primary DC current IP N DC A -1500 1500 ÎP M A -1800 1800 1:1500 1:1500 Measuring range Primary / secondary ratio n1: n2 Min Typ Max 1200 Linearity error ƐL ppm -1 1 Offset current (including earth field) IOE ppm -10 10 accƐ ppm -11 11 AC Maximum gain error 10Hz to 3kHz ƐG % Operating temperature range Ta °C -40 85 Power supply voltages Uc V ±14.25 ±15.75 DC-10Hz Overall accuracy @25°C (= ƐL + IOE) All ppm (or %) values refer to nominal current page 1 - 2020-04-27 Precision – Innovation www.danisense.com ±0.01 DM1200ID Electrical specifications at Ta=23°C, supply voltage = ± 15V unless otherwise stated Parameter Symbol Unit Nominal primary AC current IPN AC A rms Nominal primary DC current IPN DC A Measuring range IPM A Overload capacity ÎOL kA Nominal secondary current ISN mA Measuring resistance RM Ω Linearity error ƐL ppm Offset current IOE Refer to fig. 1 for derating 1800 Refer to fig. 1 & 2 for derating 5 Non-measured, 100ms µA 1 1 10 10 ppm refers to nominal current µA refers to secondary current ppm refers to nominal current µA refers to secondary current ppm -11 11 ppm refers to nominal DC current ppm/K µA /K -0.1 -0.1 0.1 0.1 ppm refers to nominal current µA refers to secondary current 400 ppm kHz ƐG % q º tr @ 90% µs no ise ppm rms f E xc kHz Induced rms voltage on primary conductor 1500 -1800 -1 -1 -10 -10 µA f(-3dB ) Fluxgate excitation frequency -1500 3 Bandwidth 0 - 100Hz 0 - 1kHz 0 - 10kHz 0 - 100kHz Refer to fig. 1 & 2 for derating 1:1500 TC IOE Noise 1200 0 Offset temperature coefficient Response time to a step current IP N Comment 1:1500 accƐ Phase shift Max 1000 DC-10Hz Overall accuracy @25°C (= ƐL + IOE ) 10Hz –3kHz 3kHz -50kHz 50kHz - 300kHz 10Hz –3kHz 3kHz -50kHz 50kHz - 300kHz Typ. -1000 Primary / secondary ratio Amplitude error Min At nominal primary DC current Refer to fig. 1 for details Small signal, graphs figure 3 0.01% 1.00% % refers to nominal current 20.0% 0.01º 0,5º 10º 1 di/dt = 100A/µs 0.05 0.06 0.70 2.0 Measured on secondary current 31.25 5 µV rms Power supply voltages Uc V ±14.25 Positive current consumption Ips mA 135 140 145 Add Is (if Is is positive) Negative current consumption Ins mA 120 130 135 Add Is (if Is is negative) Operating temperature range Ta °C -40 85 ppm/mo nth µA /mo nth -0.1 -0.1 0.1 0.1 Stability Offset stability over time ±15.75 ppm refers to nominal current µA refers to secondary current (perpendicular to bus bar) µA refers to secondary current (parallel to bus bar) µA refers to secondary current Offset change with vertical external magnetic field µA /mT 0.2 0.8 Offset change with horizontal external magnetic field µA /mT 0.8 2 Offset change with power supply voltage changes µA /V 0.004 0.04 µA refers to secondary current Offset change with absolute power supply voltages tracking µA /V 0.012 0.04 µA refers to secondary current page 2 - 2020-04-27 Precision – Innovation www.danisense.com DM1200ID Maximum external resistance value (Fig. 1) Maximum external resistance Value (Ohm) Rext (Rm plus Rcable) versus Load and Temperature 10.0 8.0 6.0 4.0 2.0 0.0 1200 1300 1400 1500 1600 1700 1800 Primary Current, DC or peak (A) R_max_25 R_max_40 R_max_65 R_max_85 Frequency and ambient temperature derating (Fig. 2) Primary Current (A) Maximum primary current Arms 1000 100 10 10Hz 100Hz 1,000Hz 10,000Hz 100,000Hz Primary Current (Hz) Max current (Arms) 25 deg Max current (Arms) 45 deg Max current (Arms) 65 deg Frequency characteristics (Fig. 3) Amplitude / Phase (Typical) 10.00 5.00 0.00 -5.00 -10.00 10Hz 100Hz 1,000Hz Amplitude (%) page 3 - 2020-04-27 10,000Hz Phase Error (deg) Precision – Innovation www.danisense.com 100,000Hz 1,000,000Hz DM1200ID Isolation specifications Parameter Unit Value Clearance mm 12 Creepage distance mm 12 Comparative tracking index (CTI) > 600 Rms voltage for AC isolation test, 50/60 Hz, 1 min - Between primary and (secondary and shield) - Between secondary and shield kV 5.7 0.2 Impulse withstand voltage (1.2/50µs) kV 10.4 Continous working voltage with uninsulated wire • • • Insulated wire • • • Non mains CAT II (DC and rms) CAT III (DC and rms) V 1000 600 300 Non mains 2000 1000 1000 CAT II (DC and rms) CAT III (DC and rms) Transient voltage with uninsulated wire • • • Insulated wire • • • Non mains CAT II CAT III V Non mains 4500 6000 6000 6000 6000 8000 CAT II CAT III Caution: Do not connect the transducer to signals or use for measurements within Measurement Category IV, or for measurements on MAINs circuits or on circuits derived from Overvoltage Category IV which may have transient overvoltages above what the product can withstand. The product must not be connected to circuits that have a maximum voltage above the continuous working voltage, relative to earth or to other channels, or this could damage and defeat the insulation. The product can only withstand transients up to the transient overvoltage rating without breakdown or damage to the insulation. An analysis of the working voltages, loop impedances, temporary overvoltages, and transient overvoltages in the system must be conducted prior to making measurements. Caution: When using insulated wires all wiring must be insulated for the highest voltage used. Absolute maximum ratings Parameter Unit Max Comment Primary kA 4.5 Maximum 100ms Power supply V ±16.5 page 4 - 2020-04-27 Precision – Innovation www.danisense.com DM1200ID Environmental, safety and mechanical specifications Parameter Unit Altitude m Min Typ Max Comment 2000 Usage Designed for indoor use Transient voltages Up to overvoltage category III Poution Degree 2 Ambient operating temperature range °C -40 85 Storage temperature range °C -40 85 Relative humidity % 20 80 Mass kg Connections DSUB9 male and BNC connector Standards IEC61010-2-30, IEC61326-1 EMC and EC61010-1:2010 3rd Edition External devices External devices connected to current transducers must comply with the standards IEC61010-1, IEC60950 or IEC62368-1 and be energy-limited circuitry Cleaning The transducer should only be cleaned with a damp cloth. No detergent or chemicals should be used. Temperature Non-condensing 2.0 When multiple primary turns are used or high primary currents are applied the temperature around the transducer will increase, please monitor to ensure that the maximum ratisngs are not exceeded. It is recommended to have minimum 1mm2 per ampere in the primary busbar. Advanced Sensor Protection Circuits “ASPC” Developed to protect the current transducer from typical fault conditions: • Unit is un-powered and secondary circuit is open or closed • Unit is powered and secondary circuit is open or interrupted Both DC and AC primary current up to 100% of nominal value can be applied to the current transducers in the above situations without damage to the electronics. Please notice that the transducer core can be magnetized in all above cases, leading to a small change in output offset current (less than 10ppm) Accessories • 4-channel power supplies unit for connection up to 4xDM1200 : DSSIU-4 • 6-channel power supplies unit for connection up to 6xDM1200 : DSSIU-6 • Transducer cables in 5 lengths (2m - 5m - 10m - 15m - 20m): DSUB15 - DSUB20 DSUB2 - DSUB5 - DSUB10 - • Transducer cable 3m for connection to end-user’s power supply: Transducer cable for lab PS (with access to current output via 4 banana jacks) page 5 - 2020-04-27 Precision – Innovation www.danisense.com DM1200ID Dimension in mm (general tolerance 0.3mm unless otherwise stated) Mounting instructions Positive current direction Is identified by an arrow on the transducer body page 6 - 2020-04-27 • Horizontal or vertical mounting Precision – Innovation www.danisense.com 4 holes 6 x 11 4 x M5 steel screws / 6N.m
DM1200ID 价格&库存
很抱歉,暂时无法提供与“DM1200ID”相匹配的价格&库存,您可以联系我们找货
