861-D04-113R004
861-D04-113R004
    NORCOMP
    861-D04-113R004
861-D04-113R004 数据手册
DESCRIPTION: M12 // M // 4P // PANEL REAR MOUNT // PCB // D-CODE SPECIFICATIONS: MATERIALS: HOUSING: CONTACTS: PBT, UL94 V-0, BLACK GOLD PLATED BRASS (SEE P/N KEY BELOW) (SEE P/N KEY BELOW) (SEE P/N KEY BELOW) EPDM, BLACK NUT: SHELL: ORING: ELECTRICAL: RATED CURRENT: RATED VOLTAGE: INSULATION RESISTANCE: CONTACT RESISTANCE: 100 MOhms MIN. 10 mOhms MAX. ENVIRONMENT: OPERATING TEMPERATURE: WATER PROOF: -40°C TO +85°C IP67 4A 250V 861-D04-113R00Y Full stainless steel variant successfully passes 96-hour salt spray testing per ASTM B117 RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inch[mm] DRAWN: M. SIGMON DATE: 07/26/2016 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 1 861-D04-113R00Y 4
861-D04-113R004 价格&库存
很抱歉,暂时无法提供与“861-D04-113R004”相匹配的价格&库存,您可以联系我们找货
861-D04-113R004
