684M5W5203L461
684M5W5203L461
    NORCOMP
    弯插
    CONN FEMALE 5W5 RA DIP
684M5W5203L461 数据手册
DESCRIPTION: POWER - RIGHT ANGLE - FEMALE - MACHINED SPECIFICATIONS: ELECTRICAL: INSULATOR RESISTANCE: 5 GOhms MIN. WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: POWER CONTACT AMPERAGE: 2.088 [53.04] 1.852 [47.05] 1.512 [38.40] 250V -55°C TO +125°C 2.0 mOhms MAX. SEE P/N KEY MECHANICAL: CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 4.5 Kg MAX. 0.3 Kg MIN. MATERIALS: CONTACTS: INSULATOR: COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED SHELL: BRACKET: BOARD LOCK: NICKEL PLATED STEEL NICKEL PLATED STEEL NICKEL PLATED BRASS 0.311 [7.90] A5 A4 A3 A2 A1 230°C PROCESS TEMP. 0.492 [12.50] 10° 0.228 [5.80] SWAGE HEIGHT 0.01 [0.24] REF 0.032 [0.80] 684M5W5203LYYY 46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS 62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS SEE SHEET 2 FOR CONTACT & BRACKET DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 1 = GOLD FLASH UNITS = inches [mm] DRAWN: M. SIGMON DATE: 12/06/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 684M5W5203L461 3 DESCRIPTION: POWER - RIGHT ANGLE - FEMALE - MACHINED RIGHT ANGLE BRACKET DIMENSIONS(in/mm) OPTION #4-40 INSERT 1.852 [47.04] 46 CL 62 0.570 [14.48] 0.570 [14.48] 0.300 [7.62] P 0.185 4.70 0.087 2.22 0.420 [10.67] 0.240 [6.10] 0.520 [13.20] POWER CONTACTS 0.030 [0.76] Ø0.165 [Ø4.20] 5-PLACES 0.420 [10.67] Ø0.130 [3.30] 2-PLACES PCB EDGE Ø 0.148 [Ø 3.75] P 0.520 [13.20] RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: M. SIGMON DATE: 12/06/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 684M5W5203L461 3
684M5W5203L461 价格&库存
很抱歉,暂时无法提供与“684M5W5203L461”相匹配的价格&库存,您可以联系我们找货
684M5W5203L461
    684M5W5203L461
    • 1+166.197191+21.57510
