DESCRIPTION:
QUIK-LOQ - FEMALE - VERTICAL - PANEL MOUNT - PLASTIC
UNITS = MM [INCHES]
CHARACTERISTICS
MATERIALS
HOUSING : ABS+PC
HOUSING COLOR : GREY
NUT A : BRASS
NUT A PLATING : NICKEL
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
8P1P YYY 2 1 0 YR B 01
1 = GOLD FLASH
SERIES
14.00 [0.551]
RoHS COMPLIANT
NUT "B" COLOR
G = GREY
A = BLUE
J = YELLOW
N = BLACK
R = RED
V = GREEN
# OF POSITIONS
(Ex. 002)
**SEE CHART A**
2 = FEMALE
PLASTIC SHELL
VERTICAL (PANEL MOUNT)
MECHANICAL
DURABILITY: 2000 CYCLES
OPERATING TEMP. RANGE: -20 C ~ +120 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TORQUE VALUE : 0.7 Nm [6.19 IN/lbs]
0.797
20.25
0.157
4.00
IP RATING: 50
1]
55
[0.
NUT
A
0.496
12.60
0.728
18.50
0.669
17.00
M14*1.0
0.488
12.40
(ACROSS FLATS)
1
TOLERANCE = +0.10, -0.0
[+0.004, -0.00]
0.276
7.00
(MAX. PANEL THICKNESS)
1
1
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1200V
WORKING VOLTAGE = 400V
3 POSITION
10 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
4 POSITION
8 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
RoHS COMPLIANT
N
C
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 600V
WORKING VOLTAGE = 200V
= KEY LOCATION
1
2 POSITION
10 AMP MAX.
PIN
= 1.30 [0.051]
14 POSITION
2 AMP MAX.
PIN
= 0.50 [0.020]
PANEL CUTOUT
NUT
B
CHART A
1
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
1
1
1
1
1
1
5 POSITION
7 AMP MAX.
PIN
= 0.90 [0.035]
6 POSITION
6 AMP MAX.
PIN
= 0.70 [0.028]
7 POSITION
5 AMP MAX.
PIN
= 0.70 [0.028]
8 POSITION
5 AMP MAX.
PIN
= 0.70 [0.028]
9 POSITION
3 AMP MAX.
PIN
= 0.50 [0.020]
10 POSITION
3 AMP MAX.
PIN
= 0.50 [0.020]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1050V
WORKING VOLTAGE = 350V
CONTACT
RESISTANCE = 7.5 mΩ
CONTACT
RESISTANCE = 7.5 mΩ
CONTACT
RESISTANCE = 7.5 mΩ
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 850V
WORKING VOLTAGE = 280V
CONTACT
RESISTANCE = 10 mΩ
TEST VOLTAGE = 850V
NorComp
DRAWN:
M. SIGMON
DATE:
10-04-16
SCALE:
N.T.S.
SHEET
1
DWG NO.
OF
2
REV:
8P1PYYY210YRB01
2
DESCRIPTION: QUIK-LOQ - FEMALE - VERTICAL - PANEL MOUNT - PLASTIC
UNITS = MM [INCHES]
BOARD LAYOUTS
A
= KEY LOCATION
A
45° .
TYP
0°
12 P.
TY
72 P.
TY
A
A
B
B
60
TY °
P.
B
B
A
2 POS
3 POS
4 POS
5 POS
6 POS
A = 0.80 [0.031]
A = 0.80 [0.031]
A = 0.80 [0.031]
A = 0.80 [0.031]
A = 0.70 [0.028]
B = 2.80 [0.110]
B = 3.00 [0.118]
B = 3.40 [0.134]
B = 3.40 [0.134]
B = 3.70 [0.146]
3
TY 6°
P.
45 P.
TY
.43
A
A
.00
54
0°
.5
67
30°
TYP.
9°
0.075
1.90
154.2
45 P.
TY
51
B
A
7 POS
A = 0.70 [0.028]
B = 3.70 [0.146]
RoHS COMPLIANT
N
C
0.071
1.80
C
B
B
A
B
A
B
8 POS
A = 0.70 [0.028]
9 POS
10 POS
14 POS
A = 0.70 [0.028]
A = 0.70 [0.028]
A = 0.70 [0.028]
B = 3.85 [0.152]
B = 3.95 [0.156]
B = 4.40 [0.173]
C = 1.40 [0.055]
B = 3.80 [0.150]
NorComp
DRAWN:
M. SIGMON
DATE:
10-04-16
SCALE:
N.T.S.
SHEET
2
DWG NO.
OF
2
REV:
8P1PYYY210YRB01
2
很抱歉,暂时无法提供与“8P1P008210JRB01”相匹配的价格&库存,您可以联系我们找货
