5002-46-000
5002-46-000
    IMATRONIC
5002-46-000 数据手册
A G lobal Laser Bran d Versatile Laser Diode Module Versatile Module The VM (Versatile Module) from Imatronic provides a high quality and cost effect OEM solution to a wide range of applications including Machine Vision, Inspection, Alignment and Positioning. The module is a compact 11mm diameter and features output powers of 1 & 3 mW in both 650 & 635nm with the benefit of an isolated housing and reverse polarity protection as standard. An A/R coated user adjustable collimating lens produces an elliptical output beam which can be focussed to produce fine spots. A TTL enable input is also included as standard which allow the user to switch the laser on and off with a TTL logic level signal. Further versatility is provided by the wide range of external optics available which simply screws into the end of the laser module, allowing the user to quickly and efficiently switch from one projection to another. The range includes Homogeneous lines and cross’s and diffractive patterns. A optional heavy duty clamp (HDC) allows the user to secure the laser and has parallel and vertical adjustment which allows the user to aim the laser in any required direction or angle. The robust aluminium construction also assists in conducting heat away from the laser body as well as preventing movement due to shock and vibration. The base plate of the HDC has a series of threaded holes to allow the HDC to be securely fastened to stable surfaces. Specifications Product Specification Farnell Part Number 2065353 2065354 2065351 2065352 Imatronic Part Number 5002-47 5002-48 5002-45 5002-46 Model VM 650nm, 1mW VM 650nm, 3mW VM 635nm, 1mW VM 635nm, 3mW Output Power (mW) 0.9 3 0.9 3 Wavelength (nm) 650 650 635 635 2 3R 2 3R Laser Class Operating Voltage (Vdc) Operating Current (mA) 3.5 to 5.0 20-35 30-50 Operating Case Temperature (°C) -10 to +45 Storage Temperature (°C) -10 to +80 Beam Size At Aperture (mm) 3 by 1 Beam Divergence (mrad) 100,000 >29,000 6% 8 Dimensions (mm) Ø11 x 37 Housings Anodised Aluminum Isolated Body Yes Lead Length (mm) 230 Connector Type Input Leads Flying Leads Red Lead +Ve Black Lead 0V Blue Lead TTL Enable Frequency Range (Khz) ≤1 Typical Rise & Fall Time (µs) 1 NOTES All specifications are typical @ 25°C Modulation A common requirement for applications which use photo detectors, cameras and other non-visual sensing is the ability to rapidly switch the laser output ON and OFF. Simply applying and removing the supply voltage is rarely satisfactory and in certain cases can result in the destruction of the module. This is because laser diodes are very sensitive to spikes and surges, which are often the result of uncontrolled supply switching. To overcome this limitation, the VM is supplied with an additional inputs via a third input wire that controls the output of the laser module in a reliable and predictable way. TTL Enable Input Some applications require a simple, slow speed ON/OFF switching. The VM eliminates the requirement to provide an external switching device by providing a logic compatible enable input, capable of operating from low power logic and micro-processors. In this OFF condition, the module draws virtually no current and no light is emitted. Bandwidth is typically ≤1Khz. If not using this function connect the lead to supply or the laser will not switch on. Optional Projection Lenses A range of projection lens which convert the beam into a pattern are also available for the VM. The Interchangeable line and cross lens assembly’s consists of a moulded acrylic multi-rod lens element. The lens produces a cross/line with an intensity distribution is gaussian in the width and homogeneous in the line. The homogeneous line produces a line with high uniformity at shorter working distances, however due to the effects of divergence the uniformity levels will decrease over longer working distance. The Grid lens assembly consists of a diffractive optical element (DOE) lens. The lens produces a 4x4 grid pattern with typical full fan angle of 4.57° and the intensity distribution is Gaussian in the width and homogeneous in the line. The distance between each line in the grid pattern in typical 1.18°. The DOE produces a pattern with high uniformity at shorter working distances, however due to the effects of divergence the uniformity levels will decrease over longer working distance. The lens assembly to simply screw into the VM and converts the output beam into the listed pattern. Product Specification Farnell Part Number 2605361 2065362 2065363 2065364 2065365 Imatronic Part Number 1125-227 1125-225 1125-228 1125-226 1125-229 Interchangeable Interchangeable Interchangeable Interchangeable Interchangeable Line Lens Optic Line Lens Optic Line Lens Optic Cross Lens Optic 4x4 Grid Optic 33° 60° 105° 60° 4.57° Model Projection Line Typical Fan Angle (°) 33 Interbeam Angle (°) 60 Cross 4 x 4 Grid 60 4.57 100 N/A 1.18 Laser Safety IEC 60825-1:2014 Product Description & Name Product Code Serial Number Class 2 Laser Label www.globallasertech.com
5002-46-000 价格&库存
很抱歉,暂时无法提供与“5002-46-000”相匹配的价格&库存,您可以联系我们找货
