1125-227-000
1125-227-000
    IMATRONIC
1125-227-000 数据手册
A Glob a l La s er B ra n d Interchangeable Line Optic 33° Fan Angle 1. Product Overview. The Interchangeable line lens consists of a moulded acrylic multi rod lens element fitted with in an 11mm diameter lens holder with an M9 thread section for mounting. The lens produces a line with typical full fan angle of 33 degree with a 5mm by 1.5mm input beam. The intensity distribution is gaussian in the width and homogeneous in the line. The homogeneous line produces a high uniformity line at shorter working distances, however due to the effects of divergence the uniformity levels will decrease over longer working distance. An M9 threaded section allows the lens assembly to simply screw into any laser module with a M9 thread for lens assembly and a suitable focal length collimator. The lens assembly will fit into both VM range and Gated Cameo “A“ Lens model listed below and turn the output beam into the listed pattern. Imatronic Part Number Description 5002-45-000 Versatile Module 635nm 1mW TTL 5002-46-000 Versatile Module 635nm 3mW TTL 5002-47-000 Versatile Module 650nm 1mW TTL 5002-48-000 Versatile Module 650nm 3mW TTL 1266-01-000 Gated Cameo 635nm 0.8mW A Lens 1266-02-000 Gated Cameo 635nm 3mW A Lens 1266-03-000 Gated Cameo 650nm 0.8mW A Lens 1266-04-000 Gated Cameo 650nm 3mW A Lens 2. Specification. Lens Material Lens Type Exit Aperture A/R Coated Typical Input Beam Size Typical Fan Angle Typical Transmission Loss (650nm) Acrylic Moulded Multi Rod 5mm No 5 by 1.5mm 33° ≤25% A Glob a l La s er B ra n d Interchangeable Line Optic 33° Fan Angle 3. Diagram. Interchangeable Line Lens (33° Fan Angle) M9 x 0.5P Ø8.95 Ø8.90 Ø10.70 Ø10.75 7.85 7.90 Please note: Imatronic reserve the right to change descriptions and specifications without notice. Please Note: Global Laser reserve the right to change descriptions and specifications without notice. A Global L aser B ra n d ISO9001 Certified 9090-02-071 Rev 1 T: +44 (0)1495 212213 F:+44 (0)1495 214004 E: sales@globallasertech.com www.globallasertech.com Global Laser Ltd, Cwmtillery Industrial Estate Abertillery. Gwent NP13 1LZ UK
1125-227-000 价格&库存
很抱歉,暂时无法提供与“1125-227-000”相匹配的价格&库存,您可以联系我们找货
