1266-21-000
1266-21-000
    IMATRONIC
1266-21-000 数据手册
A G lobal Laser Bran d Gated Cameo Gated Cameo The Gated Cameo is a miniature laser diode module that has a threaded barrel for easy bulkhead mounting which ensures good thermal contact between module and heat sink. This new concept in laser module design allows a laser diode, an adjustable collimating lens and a drive circuit to be incorporated within a body which is just 23mm long and all without compromising the performance. The Gated Cameo offers high output power stability with transient and polarity protection, as well as electrical isolation between diode and case. It has a latching connector that improves reliability. An A/R coated user adjustable collimating lens produces an elliptical output beam which can by focused to produce fine spots. It also features a third TTL modulation input which allows the user to turn the input on and off with a bandwidth of ≥100Khz. A fourth wire which controls the slow speed enable input allows the user to switch the laser on and off from interlocks and switch’s Further versatility is provided by the wide range of external optics available which simply screws into the end of the laser module, allowing the user to quickly and efficiently switch from one projection to another. The range includes Homogeneous lines and cross’s and diffractive patterns. Specifications Product Specification Farnell Part Number 2065359 2065360 2065358 2065359 Imatronic Part Number 1266-03 1266-04 1266-01 1266-02 Gated Cameo 650nm 1mW, A Lens Gated Cameo 650nm 3mW, A Lens Gated Cameo 635nm 1mW, A Lens Gated Cameo 635nm 3mW, A Lens Output Power (mW) 0.8 2.8 0.8 2.8 Wavelength (nm) 650 650 635 635 2 3R 2 3R Model Laser Class Operating Voltage (Vdc) Operating Current (mA) 3.3 to 5.0 20-35 30-50 Operating Case Temperature (°C) -10 to +45 Storage Temperature (°C) -10 to +80 Beam Size At Aperture (mm) 3 by 1 Beam Divergence (mrad) 29,000 ±1.5% 12.6 Dimensions (mm) 14x14 Diameter by 24 Housings Brass M12 Threaded Front and Black Plastic Back Isolated Body Yes Connector Type JST PHR4 4 Pin Lead Length (mm) Input Leads >100,000 500 Red Lead +Ve Black Lead 0V Yellow Lead TTL Modulation: Off = 2V Blue Lead TTL Enable: Off = 2V TTL Modulation Frequency Range (Khz) (Yellow Lead) Typical Rise & Fall Time (µs) ≥100 TTL Enable Input Delay (ms) ≤5 2 NOTES All specifications are typical @ 25°C Specifications Product Specification Farnell Part Number Imatronic Part Number 1266-20 1266-21 1266-22 1266-23 Gated Cameo 785nm 1mW, A Lens Gated Cameo 785nm 3mW, A Lens Gated Cameo 850nm 1mW, A Lens Gated Cameo 850nm 3mW, A Lens Output Power (mW) 0.8 2.8 0.8 2.8 Wavelength (nm) 785 785 850 850 Laser Class 3R 3R 3R 3R Model Operating Voltage (Vdc) Operating Current (mA) 3.3 to 5.0 30-40 20-40 15-30 Operating Case Temperature (°C) -10 to +55 Storage Temperature (°C) -10 to +80 Beam Size At Aperture (mm) 3 by 1 Beam Divergence (mrad)
1266-21-000
物料型号: - Farnell部件编号:2065359, 2065360, 2065358, 2065361, 2065362, 2065363, 2065364, 2065365 - Imatronic部件编号:1266-03, 1266-04, 1266-01, 1266-02, 1266-20, 1266-21, 1266-22, 1266-23, 1125-227, 1125-225, 1125-228, 1125-226, 1125-229
器件简介: - Gated Cameo是一个微型激光二极管模块,具有螺纹桶,便于安装并确保与散热器之间的良好热接触。
引脚分配: - 红色线:+Ve - 黑色线:地 - 黄色线:TTL调制输入(频率范围≥100kHz) - 蓝色线:TTL使能输入
参数特性: - 输出功率:0.8mW至3mW - 波长:635nm至850nm - 激光类别:2类或3R类 - 工作电压:3.3至5.0Vdc - 工作温度:-10至+55°C - 光束尺寸:3mm x 1mm - 光束发散角:<0.5mrad - 用户可调焦距:是
功能详解: - TTL调制输入允许激光输出快速开关,带宽≥100kHz。 - TTL使能输入提供简单的慢速开关功能。
应用信息: - 适用于使用光电探测器、相机和其他非视觉传感的应用。
封装信息: - 尺寸:直径14mm x 24mm - 材料:黄铜M12螺纹前部和黑色塑料后部 - 连接器类型:JST PHR44针
激光安全: - 符合IEC60825-1 2007标准,根据功率、波长和扇角分为不同的类别。
质量和保修: - 提供12个月的零件和人工保修,制造业务符合ISO9001认证。
1266-21-000 价格&库存
很抱歉,暂时无法提供与“1266-21-000”相匹配的价格&库存,您可以联系我们找货
