70-125-40/6.3A
70-125-40/6.3A
    SIBA
    SIBA - 70-125-40/6.3A - Fuse, Cartridge, Very Fast Acting, 6.3 A, 600 V, 6.3mm x 32mm, 1/4" x 1-1/4"...
70-125-40/6.3A 数据手册
FUSES G MINIATURE FUSES SIBA Miniature Fuses Sizes: - Cylindrical fuses: 5 x 20 · 6.3 x 32 · 5 x 25 5 x 30 · 8 x 50 · 8 x 85 10 x 85 · 8 x 120 · 8 x 150 mm - Radial lead 2 pin fuses: KS, Ø 8.4 mm - SMD fuses: Voltage ratings: 65 V - 10 kV Operation class: F T M FF Standards: fast acting time lag medium time lag very fast acting IEC 60127 DIN VDE 0820 CEE4 UL 248-14 UL 512 CSA-C22.2 No. 248.14 Approvals: SEV, BEAB Features / Benefits  Very high interrupting rating up to 70 kA  High rated voltages up to 10 kV  High fuse ratings available for semiconductor protection  Fuse bases, clips and accessories are available G1 0 FUSES MINIATURE FUSES FF CERAMIC TUBE Part No. 160 mA 200 mA 250 mA 315 mA 400 mA 500 mA 630 mA 800 mA 1 A 1.25 A 1.6 A 2 A 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 Size 6.3 x 32 mm 1 Rated current Part No. 2.5 A 3.15 A 4 A 5 A 6.3 A 8 A1 10 A1 12.5 A 1 16 A1 20 A1 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 70 125 40 very fast acting Voltage Pre-arcing drop l2ts-value mV FUSES A2s 2000 1600 1500 1350 1030 950 860 760 1100 1000 900 800 0.004 0.008 0.024 0.035 0.07 0.14 0.14 0.22 0.14 0.22 0.31 0.64 Rated voltage 500 V Rated breaking capacity Power dissipation W Weight 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 0.5 0.6 0.7 0.7 0.8 0.8 0.9 1.0 1.3 1.6 1.9 2.4 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ 1.2 2 5 10 3 6.5 12 18 31 46 Pack (kg/100) 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 100 100 100 100 100 100 100 100 100 100 100 100 Standard not standardized very fast acting Voltage Pre-arcing drop l2ts-value mV FUSES A2s 800 700 500 400 400 350 350 300 300 300 Standard not standardized cURus Rated current Rated voltage 700 V Rated breaking capacity Power dissipation W cURus Size 6.3 x 32 mm G Weight 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 50 kA 2.7 3.0 3.2 3.6 4.0 4.5 5.0 7.0 9.0 13 ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ ✓ Pack (kg/100) 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 100 100 100 100 100 100 100 100 100 100 Consideration should be given to heat dissipation. G 31
70-125-40/6.3A 价格&库存
很抱歉,暂时无法提供与“70-125-40/6.3A”相匹配的价格&库存,您可以联系我们找货
