1601-10005-BTBQYA
1601-10005-BTBQYA
    INTERQUIP(应达利)
1601-10005-BTBQYA 数据手册
应达利电子股份有限公司 PAGE:1 INTERQUIP ELEC. ((SHENZHEN)) CO., LTD. 3-4/F Block A, 1-3/F Block D, No.2 Tengfeng Road, Fenghuang Community, Fuyong Town, Baoan District, Shenzhen, China Tel:+86-755-33251781. Fax:+86-755-29128486. Postal code:518103 Web:www.interquip.com Email: iqlsales@interquip-chinasz.com Customer Approval Sheets Product: Description: IQG P/N: Ref No: Customer P/N: Crystal Oscillator y SMD 5×3.2 XO 1601-10005-BTBQYA Approval Section A lS ti : Date: Customer: 0 DEPT. DEPT. prepared by By: DEPT. Checked by DEPT. Approved by RoHS IQL has been certified for the above management systems. Note: It is prohibited to use the "Environment-related Substances to be Controlled" in level 1 in Sony GP system. The resin, ink, paint and cable used in molded products must be purchased from the suppliers in the Sony GP supplier list. PAGE:2 INTERQUIP ELEC. (SHENZHEN) CO., LTD. D Description: i ti SMD 5 5×3.2 3 2 XO IQG P/N:1601-10005-BTBQYA P/N 1601 10005 BTBQYA Rev Revise page Revise contents 0 N/A Initial released Date Revis er PAGE:3 INTERQUIP ELEC. (SHENZHEN) CO., LTD. D Description: i ti SMD 5 5×3.2 3 2 XO IQG P/N:1601-10005-BTBQYA P/N 1601 10005 BTBQYA Specification PART NO 1601-10005-BTBQYA 1. Scope: 1.1 This specification applies to the RoHS crystal oscillator with a frequency of 10.000MHz which will be used in electronic equipment equipment. 2. Construction: 2.1 Oscillators series: SMD 5×3.2 XO 2.2 Package: SMD 5×3.2 2.3 Marks: 3. Electrical Characteristics 3.1 Nominal Frequency: 10.000MHz 3.2 Frequency Stability: ±50ppm Q+Freq+XO+DateCode+LotCode (incl. 25°C tolerance, tolerance over operating temperature range, input voltage change, load change, 1 year aging) 3.3 Aging: ±3ppm max / year 3.4 Operating Temperature Range: -40 ℃ to +85℃ 3.5 Storage Temperature Ran -55℃~+125℃ 3.6 Input Voltage (VDD): +3.3Vdc±10% 3.7 Input Current (IDD): 10mA max 3.8 Output Waveform: CMOS 3.9 Output Symmetry: 50±10% 3.10 Rise/Fall Time: 8ns max 3.11 Output Voltage VOL: 10%VDD VOH: 90%VDD 3.12 Output Load: 15pF 3.13 Output State Control: Enable/disable 3.14 Start-up Time: 10ms max 3.15 Standby current: 10µA max 3.16 Phase Jitter (rms): 1ps rms max 12kHz to 20MHz 3.17 Oscillation mode: Fundamental 3.18 Others: Not recommended for safety applications Ω
1601-10005-BTBQYA
1. 物料型号:1601-10005-BTBQYA 2. 器件简介:SMD 5×3.2 XO,即表面贴装的5×3.2毫米尺寸的晶体振荡器。 3. 引脚分配: - 1:使能/禁用(Enable/Disable) - 2:地(GND) - 3:输出(Output) - 4:电源(VDD) 4. 参数特性: - 标称频率:10.000MHz - 频率稳定性:±50ppm(包括25°C公差、工作温度范围、输入电压变化、负载变化、1年老化) - 老化:±3ppm/年 - 工作温度范围:-40°C至+85°C - 存储温度范围:-55°C至+125°C - 输入电压:+3.3Vdc±10% - 输入电流:最大10mA - 输出波形:CMOS - 输出对称性:50±10% - 上升/下降时间:最大8ns - 输出电压低电平:10%VDD - 输出电压高电平:90%VDD - 输出负载:15pF - 输出状态控制:使能/禁用 - 启动时间:最大10ms - 待机电流:最大10μA - 相位抖动(RMS):1ps RMS(12kHz至20MHz) - 振荡模式:基本模式 - 其他:不推荐用于安全应用 5. 功能详解:文档中提供了使能/禁用功能的描述,当引脚1低电平(<=0.3V)时,振荡器停止工作,输出(引脚3)变为高阻抗状态。 6. 应用信息:适用于电子设备中的RoHS晶体振荡器。 7. 封装信息:SMD 5x3.2封装,标记规格包括公司标志、型号、频率、日期代码和批号代码。
1601-10005-BTBQYA 价格&库存
很抱歉,暂时无法提供与“1601-10005-BTBQYA”相匹配的价格&库存,您可以联系我们找货
