35824856
35824856
    ULTIMAKER
    ULTIMAKER - 35824856 - 3D PRINTER, 24MM3/S, 2.85MM, CURA, 500W
35824856 数据手册
Ultimaker S5 Product data sheet Enhanced reliability Trust the Ultimaker S5 to do its job while you do yours. Its advanced active bed leveling ensures a perfect first layer, glass doors control the airflow, and dual filament flow sensors will pause your print and notify you if you run out of material. Open and connected system With the Ultimaker S5, you are not only getting a market-leading 3D printer – you gain access to the Ultimaker platfom. Access all the tools you need to start 3D printing – increased security, workflow management, and knowledge. Ultimaker brings it to your door, with features including a limited Digital Library for easy part storage and sharing, an IT knowledge base, and e-learning courses.  Hassle-free experience: Seamless integration with the Ultimaker platform of software, materials, and printers  High build volume to size ratio: Scale up with bigger parts or batch production  Touchscreen control: Effortless operation via an awardwinning user interface  Advanced active leveling: Reliable first-layer adhesion, enables unattended use without manual leveling  Wide material choice: Use almost any material with our open filament system, including composites (requires print core CC)  Easy setup and monitoring: With NFC material recognition and internal camera Network connectivity: Print via Wi-Fi, LAN, cloud, or USB  Minimal training required: Anyone can print after a 30-minute introduction  Ultimaker Essentials NEW : Unending access to security-assessed software – with remote printing, user management, and e-learning The Ultimaker platform 3D printers that simply work Software ready for Industry 4.0 Material choice like never before Support dedicated to your success Our award-winning 3D printers are robust, reliable, and easy to use. They deliver quality parts time and again. Designed and tested to run 24/7, they allow you to achieve the results you need more quickly and easily. Trusted by millions of users across 14 languages, Ultimaker Cura integrates with any workflow through Ultimaker Marketplace plugins. Then scale production and digital distribution with Ultimaker Digital Factory. Ultimaker offers the widest material choice on the market. Through our Material Alliance, choose the perfect filament for your application – from advanced polymers to carbon fiber composites. Wherever you are in the world, Ultimaker support is close by. Our global network of service partners offer professional installation, training, and maintenance in your language and time zone. Request a quote today at ultimaker.com/quote/request Ultimaker S5 specifications Printer and printing properties Physical dimensions Software Warranty Technology Fused filament fabrication (FFF) Print head Dual extrusion print head with a unique auto-nozzle lifting system and swappable print cores Build volume (XYZ) 330 x 240 x 300 mm (13 x 9.4 x 11.8 in) Layer resolution 0.25 mm nozzle: 150 - 60 micron 0.4 mm nozzle: 200 - 20 micron 0.6 mm nozzle: 300 - 20 micron 0.8 mm nozzle: 600 - 20 micron XYZ resolution 6.9, 6.9, 2.5 micron Build speed < 24 mm3/s Build plate Heated glass build plate (20 - 140 °C) Nozzle diameter 0.4 mm (included) 0.25 mm, 0.6 mm, 0.8 mm (sold separately) Operating sound < 50 dBA Connectivity Wi-Fi, LAN, USB port Dimensions (with Bowden tubes and spool holder) 495 x 585 x 780 mm (19.5 x 23 x 30.7 in) Net weight 20.6 kg (45.4 lbs) Free supplied software Ultimaker Personal (for individuals – includes Ultimaker Cura) Ultimaker Essentials (for organizations – includes Ultimaker Cura Enterprise) Find our full range of enterprise plans at ultimaker.com/software Supported OS MacOS, Windows, and Linux Warranty period 12 months Compatible accessories Air Manager EPA filter removes up to 95% of UFPs Material Station Simplify and automate material handling Print cores AA and BB Quick-swap nozzles for build and water-soluble support materials Print core CC Ruby-tipped for printing abrasive composites Compatible materials Easy to print • Ultimaker PLA • Ultimaker Tough PLA • Ultimaker PETG Mechanical strength • Ultimaker ABS • Ultimaker PC • Ultimaker CPE Reinforced composites • Owens Corning XSTRAND™ GF30-PA6 • DSM Novamid® ID1030 CF10 Support • Ultimaker PVA • Ultimaker Breakaway FM 686003 EMS 692523 Wear resistance • Ultimaker Nylon • Ultimaker PP • Igus Iglidur I180-PF Heat resistance • Ultimaker CPE+ • DSM Arnitel ID 2060 HT Flexibility • Ultimaker TPU 95A • DuPont™ Hytrel® 3D4100FL Specifications subject to change. EN 05/2021 v1.05 Unlock a wide range of applications with complete material choice. Use Ultimaker materials, any third-party filament, or access material profiles from leading brands. Choose from these materials and more. STORAGE XSTRAND™ filaments must be stored in a dry and temperate location. The product should remain in its original packaging, preferably closed, until beginning of use. WARNING When melted, XSTRAND™ filament can be abrasive due to its glass reinforcement. Printing with XSTRAND™ may reduce brass nozzles and extruder driving wheels’ lifetime. For a better experience, using hardened steel nozzles and extruder driving wheels is advised. Ensure sufficient ventilation in your 3D printing space and avoid inhaling extrusion fumes. CONTACT For any questions related to XSTRAND™ 3D products, contact us at: 3dprinting@owenscorning.com Material Safety Data Sheet available upon request. This information and data contained herein is offered solely as a guide in the selection of reinforcement. Rating contained in this publication is based on actual laboratory data, field test experience and observation of overall market use. We believe this information to be reliable, but do not guarantee its applicability to the user’s process or assume any responsibility or liability arising out of its use or performance. The user agrees to be responsible for thoroughly testing any application to determine its suitability before committing to production. It is important for the user to determine the properties of its own commercial compounds when using this or any other reinforcement. Because of numerous factors affecting results, we make no warranty of any kind, express or implied, including those of merchantability and fitness for a particular purpose. Statements in this publication shall not be construed as representations or warranties or as inducements to infringe any patent or violate any law safety code or insurance regulation. Owens Corning reserves the right to modify this document without prior notice. Copyright © 2018 Owens Corning. All Rights Reserved. Pub. 10022732. XSTRAND™ 3D GF30-PP Technical datasheet Rev2 January 2018 Revision date: January 22nd, 2018 MATERIAL DATASHEET Physical Properties Metric Imperial 0,94 g/cm3 Density Standard 7,85 lbs/gal ISO 1183-A Moisture Absorption Very low (
35824856 价格&库存
很抱歉,暂时无法提供与“35824856”相匹配的价格&库存,您可以联系我们找货
