1632-16S
1632-16S
    TECHSPRAY
    G3 CONTACT CLEANER
1632-16S 数据手册
Rev. B (10/19) Page 1 of 2 G3 Contact Cleaner Product# 1632 Product Description Nonflammable contact cleaner formulated to be powerful, yet economical. Eliminate brushing and scrubbing, saving time and materials. Clean oxidation, oil, and other contaminants from contacts, metal switches, relays, edge connectors, buss bars, and circuit breakers. Features / Benefits • • • • • • • Nonflammable Powerful cleaner Rapid evaporation Zero residue Non-ozone depleting Dielectric strength 36.2 kV NSF registered K1 and K2 Applications • All repair and maintenance contact cleaning • Cleaning of metal contacts, plugs and removing oxidized soils from switches, circuit breakers, motors and armatures Usage Instructions Hold can 6-8 inches away. When used as a general cleaner, start at top of area to be cleaned using a sweeping motion, and spray the area slowly, working towards the bottom. To clean in hard to reach areas, insert extension tube in spray head. Allow components to dry completely before applying current. Allow liquid to dry before supplying power. Material Compatibility ABS: Not Compatible Nylon: Excellent Lexan: Not Compatible HDPE: Excellent LDPE: Excellent C.E.Phenolic: Excellent PMMA: Not Compatible POM: Excellent PP: Excellent PS: Not Compatible PTFE: Excellent PVC: Excellent Typical Product Data and Physical Properties Physical state: Odor: Appearance: Percent volatile: Vapor pressure: Vapor density: Boiling point: Flashpoint and method: Evaporation rate: Density: Dielectric strength: VOC: Shelf life: Liquid Faint ethereal odor Clear, colorless liquid 100 180.43 mmHg@20ºC >1 (Air=1) 98.6ºF (37ºC) None to boiling point
1632-16S 价格&库存
很抱歉,暂时无法提供与“1632-16S”相匹配的价格&库存,您可以联系我们找货
1632-16S
    库存:7
    1632-16S
      库存:12
