1747-10S
1747-10S
    TECHSPRAY
    ANTI-STATIC FREEZER
1747-10S 数据手册
Precision Cleaning Technologies for the Electronics Industry TABLE OF CONTENTS CLEANING TOOLS BOARD PRODUCTION AND REWORK MAINTENANCE AND R E PA I R P R O D U C T S ELECTRONIC CLEANERS DUSTERS — FREEZE SPRAYS FLUX REMOVERS 2–4 FLUX REMOVERS — BULK 5 ISOPROPYL ALCOHOL (IPA) 5 SMT CLEANERS 6–7 MAINTENANCE CLEANERS 8–9 MAINTENANCE CLEANERS - BULK 10 MAINTENANCE AND FIELD SERVICE CLEANERS 10 CONTACT CLEANERS 13 HEAT SINK 13 DESOLDERING BRAID 14–15 CONFORMAL COATINGS 16–17 TEMPORARY SOLDER MASKS 18–19 ESD PRODUCTS 20–21 REWORK/REPAIR PENS 22–23 TECHCLEAN WIPES 24–25 TECHSWABS 26–27 TECHCLEAN BRUSHES All Techspray branded products are RoHS compliant. In addition, Techspray offers quality products that have been proven to withstand harsh, lead-free soldering conditions and enhance your productivity. The European and Chinese RoHS (Restriction of Hazardous Substances) regulations are forcing the electronics industry to transition to lead-free soldering. 11–12 PRECISION LUBRICANTS INDEX BY PRODUCT CATEGORY INDEX 1 28 29 INDEX BY PART NUMBER 29–30 CROSS REFERENCE INDEX 30–36 STANDARDS & SPECIFICATIONS 36 OXYGEN SPECS 36 The requirement for lead-free soldering has created challenges in many aspects of PCB manufacture and rework including: ■ Surface Mount Technology (SMT) ovens must heat PCBs over 600°F (316°C) compared to 500°F (260°C) for lead. ■ Hand solder tips must be heated over 750°F (399°C) versus 600°F (316°C). ■ PCBs must be heated for a longer period of time. ■ Fluxes often need to be more active, increasing the caustic nature of residues. Look for the lead-free tested symbol in this catalog for products ideally suited for lead-free process. Full RoHS documentation is available at www.techspray.com. This catalog is copyrighted material of Techspray. Copyright © 2007 by Techspray. Federally registered trademarks of Techspray include Techspray, Pro-Wick, Blue Shower, Zero Charge, Tech Hold, TechClean, G3 and WonderMASK. Other trademarks of Techspray include the Techspray logo, the G3 logo, the Trace Technologies logo, Vortex, Trace Technologies, Licron, Fine-L-Kote, Techswabs, ETC., Envi-Ro-Tech, Kleen-It, Ecoline, Purwipe, Rid-Ox, and Slic. Axarel is a registered trademark of Petroferm®. Unauthorized use of the trademarks and copyrights of Techspray, without the express, written permission of Techspray is strictly prohibited. All rights reserved. DUSTER — FREEZE SPRAY ELECTRONIC CLEANERS DUSTERS Techspray dusters blow away dust, microscopic contaminants, lint, metallic oxide deposits and other soils that can cause heat build up or shorts in sensitive electronics. • Moisture Free • Zero Residue • Safe on Plastics • Non-Ozone Depleting Freeze spray helps locate over-heating components and cold solder joints. 1673 ECONOMY DUSTER FREEZE SPRAY Economical HFC-152a based duster. • Best Value — 30% More Volume 1673-10S Rapidly evaporating liquid that super-chills isolated areas. Used as a troubleshooting aid for intermittently faulting capacitors, resistors, semiconductors, and other defective components. It also increases visibility of cold solder joints, cracks in printed circuit boards and oxidized junctions. 10 oz aerosol Note: not for use on powered electrical equipment, on hot surfaces, and around open flames or sparks. 1671 NON-FLAMMABLE DUSTER 100% non-flammable HFC-134a based duster. T BESLER! SEL • Safest Choice • Non-Flammable 1672 FREEZE SPRAY Specifications: GM HMA 12993-F, Chrysler Corp NPM# 85147-6381 (1671-10S), Ford Tox #142435, NSN# 6830-01335-9925 (1671-10S), Delco C00012555 1671-8S 1671-10S 1671-15S 1671-10RS 1928 8 oz aerosol 10 oz aerosol 15 oz aerosol 10 oz aerosol refill (for use with 1928) Chrome trigger • Non-Flammable • Moisture Free • Safe on Plastics • Non-Ozone Depleting • Zero Residue Pure HFC-134a freeze spray. • Chills down to -60°F (-51°C) Specifications: Ford Tox #1422434, GM HMA 120993-H, McDonnell-Douglas 558-1672-10S, NSN# 6850-01-406-1356 1672-10S 1672-15S 1671-10S 10 oz aerosol 15 oz aerosol 1671-8S 1672-10S 1697 VORTEX™ HIGH VELOCITY DUSTER 1747 ANTI-STATIC FREEZE SPRAY High velocity, non-flammable dusters blast away dust and dirt. Vortex 360° (1697-8S) can be sprayed while tilted in any direction without dispensing liquid. Contains additive that avoids static build-up, critical when working with ESD-sensitive components. • Avoids Static Build-up • Prevents Latent Failures • Chills down to -40°F (-40°C) • Most Powerful Blast • Non-Flammable • Vortex 360° Sprays Upside-down 1697-8S 1697-10S Specifications: NCR 603-8001308, Delco C00054786, HP - 8500-6344 1747-10S 1747-15S Vortex 360° 8 oz aerosol 10 oz aerosol 10 oz aerosol 15 oz aerosol 1647-10S 1697-8S 1697-10S See Full ESD Line — Pages 20-21 For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 1 FLUX REMOVERS Flux removers (defluxers) remove flux residues left by manufacture, rework, or repair of printed circuit boards. Residues from higher, lead-free temperatures are more baked on and harder to clean. G3® and Ecoline™ flux removers have been proven very effective at removing fluxes baked on at leadfree temperatures. All Techspray flux removers have the following advantages: • RoHS Compliant Micro-components and fine pitch leads are delicate and easily damaged, so brushing and scrubbing should be avoided if possible. Both G3 and Ecoline have a powerful spray and strong solvent that blasts off residues and cleans areas under components that a brush cannot touch. 1621 ECOLINE FLUX REMOVER The power of G3, but specifically formulated to avoid and clean white residues caused by no-clean fluxes. • • • • Specifications: GM H1013; USDA Accepted; Ford Tox #142431, USDA: Approved K-2 rated aerosol and bulk. FLUX REMOVER — BULK Powerful, non-flammable bulk cleaner that is ideal for manual cleaning of R, RA and noclean fluxes. FLUX REMOVER Patented defluxer formulated to be powerful and non-flammable, yet economical. Eliminates brushing and scrubbing, saving time and materials. • Non-Flammable • Powerful Cleaner • Proven Effective for Lead-Free Processes Non-Flammable Powerful Cleaner Proven Effective for Lead-Free Processes Non-Ozone Depleting 1638-G 1638-5G 1638-54G 1 gal in glass 50 lbs in 5 gallon metal drum 580 lbs in 54 gallon drum 1638-G Specifications: B-28680, Ford Tox #167834 10 oz aerosol 16 oz aerosol 1631-16S 2 12 oz aerosol 1638 1631 1631-10S 1631-16S Non-Flammable Ideal for No-Clean Fluxes Proven Effective for Lead-Free Processes Non-Ozone Depleting 1634-12S 10 oz aerosol 33 lbs in 5 gallon metal drum 340 lbs in 54 gallon metal drum 1621-10S • • • • • Non-Corrosive NO-CLEAN FLUX REMOVER Powerful Cleaner Proven Effective for Lead-Free Processes Ideal for Sensitive Plastics Non-Ozone Depleting 1621-10S 1621-5G 1621-54G • No Oily Residue 1634 Hydrocarbon-based defluxer formulated to be powerful, yet very economical. Eliminates brushing and scrubbing, saving time and materials. • • • • • Rapid Evaporation For more information: 800-858-4043 - tsales@techspray.com The use of G3 products for cleaning are subject to U.S. patent No. 5,902,412 and use is restricted by Techspray. MSDS / Specs: www.techspray.com FLUX REMOVERS 00:00:02 00:00:03 00:00:05 G3 and Ecoline defluxers easily clean tough baked-on rosin flux contaminants in 3-5 seconds. Key: z = Best FLUX REMOVERS NonFlammable Product } = Acceptable { = Not applicable / Not recommended Plastic Safe Lead-Free Recommended RA, RMA Flux Remover No-Clean Flux Remover Sales Highlights 1621 Ecoline Flux Remover { z z z z Economic & Powerful 1631 G3 Flux Remover z } z z z Strongest Non-flammable 1634 G3 No-Clean Flux Remover z } z z z Strongest Non-flammable 1638 G3 Bulk Flux Remover z } z z z Strongest Non-flammable 1660 AK-225 No-Clean Flux Remover z z } z z High Precision 1665 AK-225 Flux Remover AMS z z } z } High Precision 1679 Envi-Ro-Tech { z { z } Non-aerosol 1686 HFE Flux Remover z z { z } Highest Precision 1660 AK-225 NO-CLEAN FLUX REMOVER 1679 ENVI-RO-TECH™ 1679 Non-flammable, high precision, and specifically formulated to avoid and clean white residues caused by no-clean fluxes. Alcohol-based general duty defluxer and allpurpose cleaner for light oils, silicones, waxes, greases and contaminants found in electronics manufacturing. • • • • High Precision — Residue-Free Non-Flammable Ideal for No-Clean Fluxes Ideal for Sensitive Plastics 1660-6S 1660-12S • Non-Aerosol • Safe on Plastics • Non-Ozone Depleting 1679-PT 6 oz aerosol w/brush attachment 12 oz aerosol 1660-6S 1665 AK-225 FLUX REMOVER AMS 1 pint in plastic bottle w/trigger sprayer 1686 HFE FLUX REMOVER Rapid evaporation and lowest possible residue makes this ideal for high precision applications. Non-flammable, high precision flux remover that is ideally suited for sensitive plastics often used in packaging. • • • • • High Precision — Residue-Free • Non-Flammable • Ideal for Sensitive Plastics Highest Precision — Residue-Free Non-Flammable Ideal for Sensitive Plastic Non-Ozone Depleting 1686-18S 18 oz aerosol Specifications: Ford Tox #03025, USDA: approved K-2 rated bulk 1665-8S 1665-18S 1665-5G 1665-54G 8 oz aerosol 18 oz aerosol 50 lbs in 5 gallon metal drum 600 lbs in 54 gallon metal drum 1663 • 1664 1665-8S For more information: 800-858-4043 - tsales@techspray.com See page 9 for product listings for Asahiklin AK225 (1663) and Kleen ATMS (1664). MSDS / Specs: www.techspray.com 3 ELECTRONIC CLEANERS 00:00:01 ISOPROPYL ALCOHOL (IPA) ALL ALCOHOLS ARE NOT CREATED EQUAL 99.8% pure anhydrous (containing the least water possible) isopropyl alcohol is excellent for tape head cleaning, defluxing, stencil cleaning, and other light cleaning. Avoid "bargain" alcohols for critical electronic cleaning. Cheap alcohols contain much more water, which slows drying and can cause oxidation. 1610 PRE-SATURATED WIPES BULK PACKAGING Convenient, low-linting wipes are pre-saturated with 99.8% pure IPA. 1610-GS 1610-G4 1610-50PK 1610-5G 1610-54G 50 individually wrapped wipes in dispenser box 1610-100DSP 100 wipes in pop-up tub 1 gallon in bladder box 1 gallon in plastic bottle, 4 to a carton 1610-GS 32 lbs in 5 gallon plastic pail 340 lbs in 54 gallon plastic drum 1610-G4 1610-100DSP 1610-50PK 1981 TECHPUMP REFILLABLE DISPENSER SMALL DISPENSERS Portable, pre-packaged dispensers ideal for work station and field service cleaning. 1610-N 1610-PT 1610-P Cap is pressed down to pump fluid into the dish. Air-tight check valve prevents evaporation, spillage, and fluid from dripping back inside and contaminating contents. 10 ml pen 1 pint in plastic bottle with trigger sprayer 1 pint in plastic bottle 1981 1610-N 1 empty 8oz bottle 1610-PT FLUX REMOVERS — BULK 1669 ASAHIKLIN AK225 T Designed to prevent white residue and removes fluxes prone to white residue. Configured for vapor degreasing and coldbatch cleaning. Note: AK225 T is not an azeotrope, so density should be monitored and AES (1666) added to maintain consistent operating parameters. • • • • Ideal for No-Clean Fluxes Non-Flammable Safe on Plastics Used in Vapor Degreasers & Cold Cleaning 1669-5G 1669-54G 44 lbs in 5 gallon metal pail 550 lbs in 54 gallon metal drum 1641 VAPOR DEGREASER FLUX REMOVER nPB Economical, strong, and non-flammable defluxer designed for use in vapor degreasers. Not recommended for cold cleaning applications. • Non-Flammable • Used in Vapor Degreasers 1641-5G 1641-54G 50 lbs in 5 gallon metal pail 550 lbs in 54 gallon metal drum For more information: 800-858-4043 - tsales@techspray.com Solvents ideal for vapor degreasers. The highest precision cleaning method available. (Photo courtesy of Branson Ultrasonics) 1666 ASAHIKLIN AK225 AES AK-225 and ethanol blend combines cleaning performance with increased user safety. Configured for vapor degreasing and cold-batch cleaning. • Non-Flammable • Safe on Plastics • Used in Vapor Degreasers & Cold Cleaning Specifications: Ford Tox #143334S, USDA: Approved K-2 rated aerosol and bulk. 1666-5G 1666-54G 55 lbs in 5 gallon metal pail 660 lbs in 54 gallon metal drum MSDS / Specs: www.techspray.com 5 ELECTRONIC CLEANERS TECHNICAL GRADE IPA SMT CLEANERS SMT STENCIL CLEANING Effectively remove all types of solder paste (e.g. waterbased, RMA, no-clean, lead-free) and uncured adhesives from screens, misprinted boards, and equipment. • Completely removes pastes and adhesives • Effective on fine-pitch aperture stencils Thoroughly cleaning SMT (surface mount technology) stencils, tools and equipment is an important way to reduce misprints and increase throughput. Techspray SMT stencil cleaners are designed for rigorous production requirements. • Safe on metal parts and plastics • Non-ozone depleting 1692 WATER-BASED SMT STENCIL CLEANER Proprietary, water-based cleaner powered by Zestron, the leading precision cleaning services provider. Ideal replacement for IPA cleaners, which are often prohibited because of safety and environmental restrictions. 1608 IPA SMT STENCIL WIPES 70% IPA, 30% DI water blend for effective and economical stencil cleaning. • Low Linting • Convenient Packaging • • • • • Non-Flammable Non-Hazardous Biodegradable Low VOC Mild Odor 1692-G 1692-PT 1692-100DSP 1692-100DSP 100 wipes in a pop-up tub 1692-PT 1 pint in plastic bottle with trigger sprayer 1692-G 1 gallon in plastic jug 1608-100DSP 100 wipes in a pop-up tub 1693 SMT STENCIL WIPES Hydrocarbon based cleaner effectively removes dried and wet pastes and uncured adhesives. • Cleans Dried and Wet Paste • Low Linting 1693-100DSP 100 wipes in a pop-up tub 1693-PT 1 pint with trigger sprayer 6 Underside stencil cleaning 1693-100DSP For more information: 800-858-4043 - tsales@techspray.com One gallon container (1692-G) recommended for automatic underside stencil cleaning. Just pour into the designated reservoir of your SMT printer. MSDS / Specs: www.techspray.com SMT CLEANERS Cleans reflow ovens, wave soldering systems, and associated heat exchanger systems by removing all types of flux residues (e.g. water-based, RMA, no-clean, lead-free). Used for periodic preventative maintenance to keep equipment running at top performance levels. 1691 WATER-BASED SMT OVEN CLEANER Proprietary, water-based cleaner powered by Zestron, the leading precision cleaning services provider. Ideal replacement for IPA cleaners, which are often prohibited because of safety and environmental restrictions. • • • • • Non-Flammable Non-Hazardous Biodegradable Low VOC Mild Odor 1691-PT 1691-G 1691-G 1691-PT Wave solder finger cleaning 1 pint in plastic bottle with trigger sprayer 1 gallon in plastic jug One gallon container (1691-G) recommended for wave solder finger cleaning. Just pour into the designated reservoir of your wave soldering machine. Key: z = Best SMT CLEANERS NonStencil Flammable Cleaning Product } = Acceptable { = Not applicable / Not recommended Under Stencil Cleaning Oven/Finger Cleaning Tool/Surface Cleaning Sales Highlights 1608 IPA SMT Stencil Wipes { z { { z Economical 1693 SMT Stencil Wipes { z { { } Strongest Cleaner 1692 Water-based SMT Stencil Cleaner z z z { z Non-flammable 1691 Water-based SMT Oven Cleaner z { { z } Non-flammable WIPES IDEAL FOR SMT CLEANING Durable, high quality, and low linting wipes do not contaminate fine stencil aperatures, preventing board misprints. 2358 TECHCLEAN SMT WIPE • Fiber-Free Construction — No Linting • Will Not Snag on Stencils • Tear Resistant 2358-50 50 9"x9" (23cm x 23cm) flat wipes 2355 TECHCLEAN PUREWIPE 2350 TECHCLEAN WIPER • Class 100 Cleanroom Certified • High Absorbency • Very Low Particulate Count 2350-100 100 9"x9" c-fold wipes For more information: 800-858-4043 - tsales@techspray.com • Very Low Particulate Count • Tear Resistant 2355-100 100 9"x9" (23cm x 23cm) flat wipes See Full Wipe Line — Pages 24–25 MSDS / Specs: www.techspray.com 7 ELECTRONIC CLEANERS SMT OVEN CLEANING MAINTENANCE CLEANERS Maintenance cleaners clean oil and contaminants off of metal parts, printed circuit boards, barcode instruments, switch boxes, label boxes, and engines. All Techspray maintenance cleaners have the following advantages: • Safe on Electronics Techspray offers a variety of solvents that allow customers to match the right products with their cleaning needs. Choosing a strong, high quality cleaner saves time and money. Grease and oil flow right off, reducing the time and materials needed to scrub off stubborn soils. Review the solvent comparison chart to find the best product for your application. • Rapid Evaporation • Zero Residue • Non-Corrosive Techspray has produced Blue Shower® maintenance cleaners for over 30 years, making Blue Shower a staple in maintenance departments all over the world! • EPA SNAP Approved Techspray maintenance cleaners are ideal for: • Metal Cleaning • Transit Maintenance • Aviation Maintenance • Machine Shop Cleaning • General Degreasing 1620 ECOLINE™ BLUE SHOWER MAINTENANCE CLEANER 1630 Hydrocarbon-based cleaner formulated to be powerful, yet very economical. Eliminate brushing and scrubbing, saving time and materials. Patented non-flammable cleaner formulated to be powerful, yet economical. Eliminate brushing and scrubbing, saving time and materials. • Powerful Cleaner • Ideal for Sensitive Plastics • Non-Ozone Depleting • Non-Flammable • Powerful Cleaner • Non-Ozone Depleting Specifications: B-28678 = Blue Shower G3, Ford Tox #167818, Boeing spec D6-17487 rev. P Specifications: USDA: Approved K-2 rated aerosol. 1620-10S 1620-13S BEST SELLER! BLUE SHOWER MAINTENANCE CLEANER 10 oz aerosol 13 oz aerosol 1630-10S 1630-16S 1620-10S 10 oz aerosol 16 oz aerosol 1630-16S The use of G3 products for cleaning are subject to U.S. patent No. 5,902,412 and use is restricted by Techspray. 8 For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com MAINTENANCE CLEANERS Key: z = Best MAINTENANCE CLEANERS } = Acceptable { = Not applicable / Not recommended NonFlammable Plastic Safe Low VOC Heavy Grease Critical Cleaning 1620 Ecoline Blue Shower { z { z } Economical & Powerful 1630 G3 Blue Shower z } { z } Strongest Non-flammable 1637 G3 Bulk Universal Cleaner z } { z } Strongest Non-flammable 1667 AK-225 Blue Shower II z z z z z High Precision 1663 Asahiklin AK-225 z z z { z High Precision 1664 Kleen ATMS z } } z } Strong Non-flammable 1685 HFE Electronic Maintenance Cleaner z z } { z Highest Precision Product Sales Highlights 1664 KLEEN ATMS ELECTRONIC MAINTENANCE CLEANER Non-flammable, high precision cleaner that is ideally suited for sensitive plastics often used in seals and outer casings. Non-flammable, strong cleaner ideally suited for metal cleaning. Can also be used as a defluxer when soldering components. • • • • Non-Flammable High Precision — Residue Free Ideal for Sensitive Plastics Low VOC • Degreaser & Defluxer • Non-Flammable • Powerful Cleaner Specifications: Ford Tox #143333, USDA: approved K-2 rated aerosol and bulk Specifications: Ford Tox #031474, USDA: approved K-2 rated aerosol and bulk 1667-8S 1667-18S 1667-5G 8 oz aerosol 18 oz aerosol 50 lbs in 5 gallon metal drum 1667-18S 1663 ASAHIKLIN AK225 ELECTRONIC MAINTENANCE CLEANER Non-flammable, high precision cleaner that is ideally suited for the most sensitive rubbers and plastics that are prone to swelling. 100% AK225, which is a VOC exempt cleaner. • • • • 1664-8S 1664-18S 1664-G 1664-5G 1664-54G 8 oz aerosol 18 oz aerosol 1 gallon in glass bottle 50 lbs in 5 gallon metal drum 600 lbs in 54 gallon metal drum 1664-18S 1685 HFE ELECTRONIC MAINTENANCE CLEANER Rapid evaporation and lowest possible residue makes this idea for high precision applications. • Non-Flammable • Highest Precision — Residue Free • Non-Ozone Depleting Non-Flammable High Precision — Residue Free Ideal for Highly Sensitive Plastics VOC Exempt 1685-18S 18 oz aerosol Specifications: NASA SE-5-0073-Shuttle, (Aerosol) Ford Tox #036375, USDA: Approved K-2 rated aerosol and bulk. 1663-8S 1663-18S 1663-G 1663-5G 1663-54G 8 oz aerosol 18 oz aerosol 1 gallon in glass bottle 55 lbs in 5 gallon metal drum 660 lbs in 54 gallon metal drum 1663-8S For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 9 MAINTENANCE AND R E PA I R P R O D U C TS 1667 AK-225 BLUE SHOWER II MAINTENANCE CLEANER CLEANER/DEGREASERS — BULK 1637 MAINTENANCE CLEANER — BULK Powerful, non-flammable bulk cleaner that is ideal for manual degreasing and contact cleaning. • Non-Flammable • Powerful Cleaner 1637-G 1637-5G 1637-54G 1 gal in glass 50 lbs on 5 gallon metal drum 580 lbs in 54 gallon drum The use of G3 products for cleaning are subject to U.S. patent No. 5,902,412 and use is restricted by Techspray. 1640 VAPOR DEGREASER nPB Economical, strong, and non-flammable cleaner/degreaser designed for use in vapor degreasers. Not recommended for cold cleaning applications. • Non-Flammable • Used in Vapor Degreasers 1640-54G 1658 ASAHIKLIN AK225 ATE AK225-based cleaner/degreaser configured for vapor degreasing and cold-batch cleaning. • Non-Flammable • Safe on Plastics • Used in Vapor Degreasers & Cold Cleaning 1658-5G 1658-54G 55 lbs in 5 gallon metal pail 551 lbs in 54 gallon metal drum 1694 AXAREL® 2200 CLEANER/DEGREASER Aggressive and versatile cleaner with high flashpoint. Ideal for manual degreasing. • Safe on Plastics • Slower Evaporation Allows Soak Time • Non-Ozone Depleting 1694-54G 365 lbs in 54 gallon metal drum 550 lbs in 54 gallon metal drum MAINTENANCE AND FIELD SERVICE CLEANERS 1625 GLASS CLEANER 1612 RUBBER REJUVENATOR & PLATEN CLEANER Foaming, non-streaking glass, plastic, and surface cleaner. Citrus-based solvent designed to clean and revitalize rubber rollers and platens. Improves rubber roller grip and reduces misfeeds and jams. • • • • • Foaming Action Non-Streaking Safe on Glass & Plastics Non-Flammable Non-Ozone Depleting • • • • Improves Roller Grip Natural Citrus-Based Solvent Safe on Most Plastics Non-Ozone Depleting Specifications: GM H1018, Ford Tox #142432 Specifications: Ford Tox #142415 1625-18S 1612-2SQ 18 oz aerosol 2 oz plastic bottle 1603 TECHCLEAN® CARD READER CLEANER 1613 LABEL & ADHESIVE REMOVER Credit card size (2 1/8" x 3 3/8" / 5.4cm x 8.6cm) paper card pre-saturated with IPA. Removes dirt, magnetic oxides, and other contaminants from credit card readers, ATM terminals, hotel doors, slot machines, and other types of readers. Citrus-based solvent safely and effectively removes labels and adhesive gums off equipment and products. Penetrates quickly and allows label to be peeled off without gummy residue. • • • • • Increases Reliability of Readers Convenient Pre-Saturated Card Safe on Plastics Non-Corrosive Non-Ozone Depleting 1603-50PK 50 individually wrapped cards • • • • • Removes Labels and Adhesive Without Scraping Penetrates Rapidly Natural Citrus-Based Solvent Safe on Most Plastics Non-Ozone Depleting Specifications: 1613-2SQ - Ford Tox #142422 1613-N 1613-6S 1613-G 10ml pen 4.5 oz aerosol 1 gallon in metal pail 1613-6S 10 For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com CONTACT CLEANERS All Techspray contact cleaners have the following advantages: • Rapid Evaporation • Zero Residue Techspray offers a variety of solvents, allowing users to match the right products with their cleaning needs. Choosing a strong, high quality cleaner saves time and money. Grease, oil, carbon deposits, and other contaminants flow right off, reducing the time and materials needed to scrub off stubborn soils. Review the solvent comparison chart to find the best product for your application. • Non-Corrosive • EPA SNAP Approved Key: z = Best CONTACT CLEANERS } = Acceptable { = Not applicable / Not recommended NonFlammable Plastic Safe Heavy Grease Prevents Oxidation 1622 Ecoline Contact Cleaner { z z { Economical & Powerful 1632 G3 Contact Cleaner z } z { Strongest Non-flammable 1637 G3 Bulk Universal Cleaner z } z { Strongest Non-flammable 1668 AK-225 Contact Cleaner II z z } { High Precision 1687 HFE Contact Cleaner z z { { Highest Precision 2111/2112 Contact Protector/Enhancer { z { z Cleans & Protects Product 1622 ECOLINE™ CONTACT CLEANER CONTACT CLEANER Patented contact cleaner formulated to be powerful, yet economical. Eliminate brushing and scrubbing, saving time and materials. • Powerful Cleaner • Ideal for Sensitive Plastics • Non-Ozone Depleting • Non-Flammable • Powerful Cleaner • Non-Ozone Depleting Specifications: (Aerosol) GM H1017; USDA Approved K-2 rated aerosol and bulk 10 oz aerosol 13 oz aerosol 340 lbs in 54 gal metal drum Sales Highlights 1632 Hydrocarbon-based contact cleaner formulated to be powerful, yet very economical. Eliminate brushing and scrubbing, saving time and materials. 1622-10S 1622-13S 1622-54G MAINTENANCE AND R E PA I R P R O D U C TS Contact cleaners remove oxidation, oil, and other contaminants off of contacts, metal switches, motors, relays, generators, edge connectors, buss bars, circuit breakers, scales and sensors. Contact cleaners are used in electrical maintenance and repair to repair faulty contacts by removing insulative contamination. Specifications: B-28681 = Contact Cleaner G3, Ford Tox #167835, Boeing spec D6-17487 rev. P 1622-10S 1632-10S 1632-16S 10 oz aerosol 16 oz aerosol 1632-16S The use of G3 products for cleaning are subject to U.S. patent No. 5,902,412 and use is restricted by Techspray. For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 11 CONTACT CLEANERS Techspray contact cleaners are ideal for… • Utility Maintenance • Transit Maintenance • Aviation Maintenance • Control Panel and Junction Box Cleaning 1668 AK-225 CONTACT CLEANER II 1687 HFE CONTACT CLEANER Non-flammable, high precision contact cleaner that is ideally suited for sensitive plastics often used in seals and outer casings. Rapid evaporation and lowest possible residue makes this ideal for high precision applications. • • • • • Non-Flammable • Highest Precision — Residue Free • Non-Ozone Depleting Non-Flammable High Precision — Residue Free Ideal for Sensitive Plastics Low VOC 1685-18S 18 oz aerosol Specifications: Ford Tox #143516, USDA: approved K-2 rated aerosol 1668-8S 1668-18S 8 oz aerosol 18 oz aerosol 1668-8S CONTACT ENHANCERS Contact Enhancers increase conductivity of electronic and electrical contacts and lay down a protective layer to prevent future oxidation. Used to remove oxides and sulfides, major causes of contact degradation. The non-insulative protective layer remains stable even under harsh conditions. Safe on most plastic and rubber seals. 2111 • 2112 RID-OX™ CONTACT PROTECTOR / ENHANCER Available in aerosol or pen dispenser, for quick, easy repair and maintenance. • • • • • Cleans & Protects Contacts Lubricates for Easy Insertion Prevents Oxidation Non-Corrosive Safe on Gold and Platinum Connectors Specifications: Pen - Meets Belcore standards, Alcatel 005-0214-060 2111-N 2112-6S 10 ml Pen 6 oz aerosol 2111-N 12 For more information: 800-858-4043 - tsales@techspray.com 2112-6S MSDS / Specs: www.techspray.com PRECISION LUBRICANTS Unlike common industrial lubricants, Techpray's precision lubricants are specifically designed to clean, lubricate, and protect electronic and electromechanical devices. Both are silicone based and can be used as a general light lubricant, displace water, and waterproof. 2420 SLIC™ SILICONE LUBRICANT Hydrocarbon based lubricant is an effective and economical solution. • Plastic Safe • Displaces Water • Waterproofs 2420-10S 10 oz aerosol 2421 MAINTENANCE AND R E PA I R P R O D U C TS KLEEN-IT™ SILICONE LUBRICANT Patented, non-flammable G3 formula cleans oxides, grease, and other contamination as it lubricates. The use of G3® products for cleaning are subject to U.S. patent No. 5,902,412 and use is restricted by Techspray. • • • • Non-Flammable Cleans as it Lubricates Displaces Water Waterproofs 2421-12S 12 oz aerosol HEAT SINK/TRANSISTOR GREASE Heat sink draws heat away when applied to a component. In electronics, heat sink compound is generally used to thermally bond a component with a mechanical heat sink. For electrical applications, it is used with thermocouple wells, thermistors, and calrods, or wherever efficient cooling is required. 1977 SILICONE HEAT SINK COMPOUND Ideal for electrical applications. • Functional Temperature Range -67°F to 401°F (-55°C to 205°C) • Easy Application • Will Not Harden and Crack 1977-DP 4 oz squeeze tube 1978 SILICONE-FREE HEAT SINK COMPOUND Ideal for electronic applications where silicone contamination hurts solderability and increase solder defects. • Functional Temperature Range -40°F to 392°F (-40°C to 200°C) • Avoid Solder Defects Due to Silicon Contamination • Easy Application • Will Not Separate • Will Not Harden and Crack 1978-DP 1978-1 4 oz squeeze tube 1 lb jar 1978-DP For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 13 DESOLDERING BRAID CLEANEST NO-CLEAN WICK IN THE INDUSTRY! Desoldering braid (wick) is pre-fluxed copper braid that is used to remove solder, which allows components to be replaced and excess solder to be removed. Techspray wick is available in static dissipative bobbins (identified by their blue color) for static sensitive environments. Techspray Brand C Techspray No-Clean wick is coated with proprietary flux that only leaves a slight clear residue, which does not cause service issues. Cleaning after using Techspray No-Clean wick is strictly optional. No-Clean Wick quickly removes solder without leaving harmful residues. DESOLDERING BRAID SELECTION CHART #0 Gray #1 White #2 Yellow #3 Green #4 Blue #5 Brown #6 Red .025 (0.7mm) .035" (0.9mm) .055" (1.4mm) .075" (1.9mm) .098" (2.5mm) .130" (3.3mm) .193" (4.9mm) Match width to contact area Wick in selection chart shown actual size. Pro-Wick® Rosin For the fastest wicking action, rosin flux coated braid is ideal for high volume PCB production/repair environments. Size/Color 5' 10' 25' 50' 100' 500' 1801 #1 White 1801-5F 1801-10F — — — — 1802 #2 Yellow 1802-5F 1802-10F 1802-25F — 1802-100F 1802-500F 1803 #3 Green 1803-5F 1803-10F 1803-25F — 1803-100F 1803-500F 1804 #4 Blue 1804-5F 1804-10F 1804-25F 1804-50F 1804-100F 1804-500F 1805 #5 Brown 1805-5F — 1805-25F — — — 1806 #6 Red 1806-5F — 1806-25F — 1806-100F — Pro-Wick Rosin — ESD-Safe Bobbin 14 1826 #0 Gray 1826-5F — — — — — 1808 #1 White 1808-5F 1808-10F — — 1808-100F — 1809 #2 Yellow 1809-5F 1809-10F 1809-25F — — — 1810 #3 Green 1810-5F 1810-10F 1810-25F — 1810-100F — 1811 #4 Blue 1811-5F 1811-10F 1811-25F — 1811-100F — 1812 #5 Brown 1812-5F 1812-10F — — — — 1813 #6 Red 1813-5F — — — — — For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com DESOLDERING BRAID PREVENT LATENT FAILURES Techspray No-Clean wick does not leave behind ionic flux residues that can collect and form branches called “dendrites”. Other fluxes, if not cleaned properly, can cause dendrites that grow over time (see A, B) and eventually cause short circuits between traces or leads (C). Latent failures lead to costly returns and lower the quality perception of your products. A B Dendrite C No-Clean Wick The cleanest No-Clean braid in the industry. The proprietary flux formula is specially designed to avoid catastrophic and latent PCB failures caused by ionic flux residue. Size/Color 5' 10' 25' 50' 100' 500' #1 White 1814-5F 1814-10F 1814-25F — 1814-100F — 1815 #2 Yellow 1815-5F 1815-10F 1815-25F 1815-50F 1815-100F 1815-500F 1816 #3 Green 1816-5F 1816-10F 1816-25F 1816-50F 1816-100F 1816-500F 1817 #4 Blue 1817-5F 1817-10F 1817-25F 1817-50F 1817-100F 1817-500F 1818 #5 Brown 1818-5F — 1818-25F — — 1818-500F 1819 #6 Red 1819-5F — — — 1819-100F — No-Clean Wick — ESD-Safe Bobbin 1827 #0 Gray 1827-5F 1827-10F — — — — 1820 #1 White 1820-5F 1820-10F 1820-25F 1820-50F — — 1821 #2 Yellow 1821-5F 1821-10F 1821-25F 1821-50F — — 1822 #3 Green 1822-5F 1822-10F — 1822-50F 1810-100F — 1823 #4 Blue 1823-5F 1823-10F 1823-25F — 1823-100F — 1824 #5 Brown 1824-5F — 1824-25F — — — 1825 #6 Red 1825-5F — — — — — BOARD PRODUCTION AND REWORK 1814 Unfluxed Wick — ESD-Safe Bobbin For customers who use water-soluble flux, or their own flux for aqueous processes. Size/Color 5' 10' 1830 #1 White — 1830-10F 1831 #2 Yellow — 1831-10F 1832 #3 Green 1832-5F — 1833 #4 Blue — 1833-10F Specifications: Meets or Exceeds MIL-F-14256, Type R; NASA NHB 5300, 4 (34-1); NASA NPC 200-4; NASA SP5002; 1821:HP 8690-0588; 1823: HP 8690-0577; IPC Standard-J-STD-004 For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 15 CONFORMAL COATINGS Protect printed circuit boards (PCB) with Fine-L-Kote™ conformal coatings. Coating can either be sprayed or brushed, or boards can be dipped directly into the conformal coating for a thick layer of protection. All Techspray conformal coatings have the following advantages: Techspray offers a variety of coating formulas to match field and engineering requirements. Specifications generally depend on the type of protection needed: e.g. thermal, moisture, and static resistance. • Designed to Protect PCB's • Can Be Removed for Rework or Repair Fine-L-Kote coatings can be thinned to meet production requirements using Conformal Coating Remover (2105). Conformal Coating Remover (2510) is available for rework and repair, although coating is generally just burnt through in the soldering process for spot repairs. • Contain Opti/Scan for UV Inspection • Non-Ozone Depleting Key: z = Best CONFORMAL COATINGS Thermal Resistant 16 Moisture Resistant Chemical Resistant } = Acceptable { = Not applicable / Not recommended Static Resistant Full Cure Time Dry To Touch Sale Highlights Product Type 2102 SR Silicone } z z z 72 Hours 1 Hour UL Recognized 2106 HT Silicone z z { } 24 hours 45 Min. High Temperature 2103 AR Acrylic } } { { 24 hours 15 Min. Economical 2104 UR Urethane } } z { 24 hours 15 Min. For Harsh Conditions For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com CONFORMAL COATINGS Opti/Scan for UV Inspection Fine-L-Kote coatings contain Opti/Scan to allow quality control inspection of coverage and evenness of the coating on a PCB. A coated board can be passed under a standard, low-cost UV (black) light, and the coated areas glow. The brighter the glow, the thicker the coating. Poor Coverage 2102 FINE-L-KOTE SR 2103 FINE-L-KOTE AR Silicone Conformal Coating Acrylic Conformal Coating Silicone Conformal Coating is the most universal coating, offering protection for a wide variety of environments. Acrylic Conformal Coating is an economical choice that provides a hard protective surface. Commonly used on aviation components. UL Recognized Thermal Resistance — to 392°F (200°C) Dielectric Strength — 1100 volts/mil Moisture Resistant Chemically Resistant Vibration Resistant — Flexible • Thermal Resistance — to 392°F (200°C) • Dielectric Strength — 640 volts/mil • Rigid, Hard Coating Specifications: Meets or exceeds MIL-I-46058C Type AR and IPC-CC-830. 2103-12S 2103-G 2103-5G Specifications: Meets or exceeds MIL-I-46058C Type SR and IPC-CC-830. UL File Number UL746C. Standard Viscosity — 4-10 CPS 2102-12S 12 oz aerosol 2102-P 1 pint in glass bottle 2102-G 1 gallon in metal pail 2102-5G 5 gallons in metal pail High Viscosity — 60-90 CPS 2102-GHV 1 gallon in metal pail 2103-12S 2104 FINE-L-KOTE UR Urethane Conformal Coating 2102-12S 2106 FINE-L-KOTE HT High-Temperature Silicone Conformal Coating High-Temperature Silicone Coating is designed to prevent thermal shock with high temperatures. Silicone Conformal Coating is the most universal coating, offering protection for a wide variety of environments. • • • • • • 12 oz aerosol 1 gallon in metal pail 5 gallons in metal pail Designed for High Temperature Environments Fast-drying Silicone — 1-Step Process Thermal Resistance — to 662°F (350°C) Dielectric Strength — 560 volts/mil Moisture Resistant Vibration Resistant — Flexible BOARD PRODUCTION AND REWORK • • • • • • Urethane Conformal Coating is widely used in harsh chemical environments. • • • • • Thermal Resistance — to 248°F (120°C) Dielectric Strength — 380 volts/mil Moisture Resistant Chemically Resistant Abrasion Resistant Specifications: Meets or exceeds MIL-I-46058C Type UR and IPC-CC-830. 2104-12S 2104-G 2104-5G 12 oz aerosol 1 gallon in metal pail 5 gallons in metal pail 2104-12S 2105 CONFORMAL COATING THINNER 2105-G 1 gallon in metal pail Specifications: Meets or exceeds MIL-I-46058C Type SR and IPC-CC-830. 2106-12S 2106-G 12 oz aerosol 1 gallon in metal pail 2106-12S 2510 CONFORMAL COATING REMOVER 2510-N 2510-P For more information: 800-858-4043 - tsales@techspray.com 10ml Pen 1 pint in metal bottle MSDS / Specs: www.techspray.com 17 TEMPORARY SOLDER MASK Prevent soldering protected areas in a wave soldering process by applying WonderMASK®. Designed to apply smoothly, dry quickly, withstand high, lead-free process temperatures, and then be removed easily. All Techspray WonderMASK products have the following advantages: • Can be cured in pre-heat • Great for lead-free and tin/lead solders • RoHS compliant WASHABLE MASKS Used with aqueous cleaning processes. 2205 • 2006 • 2207 WONDERMASK W Quick drying water-washable mask. Quickly and easily removed with in-line and batch cleaning systems. 2204 WONDERMASK WSOL FILTER-SAFE Ideal water-washable mask for closed-loop systems. Quickly and easily removed with in-line and batch cleaning system Hand Applications 2205-8SQ 8 oz. (237mL) squeeze bottle 2205-G 1 gal. (3.8L) in plastic jug Robotic & Pneumatic Applications 2206-G 1 gal. (3.8L) in plastic jug 8 oz. (237mL) squeeze bottle 1 gal. (3.8L) in plastic pail Silk and Template Screening Applications 2207-G 1 gal. (3.8L) in plastic pail 2207-5G 5 gal. (18.9L) in plastic pail 2204-8SQ 18 Water Washable Non-Corrosive Low Odor Non-Flammable Specifications: Meets MIL-STD-2000 paragraph 5.3.18 parts a, b, and d. (2206) HP 8500-4214 • Safe on Ion Beds & Filters in Closed-Loop Cleaning Systems • 100% Water-Soluble • Non-Corrosive • Low Odors. 2204-8SQ 2204-G • • • • For more information: 800-858-4043 - tsales@techspray.com 2205-8SQ MSDS / Specs: www.techspray.com TEMPORARY SOLDER MASK Key: z = Best TEMPORARY SOLDER MASK } = Acceptable { = Not applicable / Not recommended Full Cure Ready to Solder No-Clean/ Solvent Water Washable Filter Safe Pneumatic Application Stencil Printed 2204 WonderMASK WSOL z } { z z } { 2205 WonderMASK W } } { z { } { 2206 WonderMASK W } } { z { z { 2207 WonderMASK W } } { z { { z 2211 WonderMASK P { } z { { { { 2220 WonderMASK P2 } z z { { z { 2218 WonderMASK PL z } z { { z { Product PEELABLE MASKS Used with solvent cleaning and no-clean processes. 2220 WONDERMASK P2 FASTEST TO WAVE 2218 WONDERMASK PL FASTEST FULL CURE Natural latex peelable solder mask with fasted cure time. • • • • DER NT! SCE MIL Fastest Full Cure Easily Peelable Highest Strength to Avoid Breakage Non-Flammable Fastest Throughput Easily Peelable Low Odor Cure Indicator – Darkens As It Cures Compatible with Gold and Copper Leads Non-Corrosive Non-Flammable Specifications: Meets MIL-STD-2000 paragraph 5.3.18 parts a, b, and d. Specifications: Meets MIL-STD-2000 paragraph 5.3.18 parts a, b, and d. 2218-8SQ 2218-G 2218-54G • • • • • • • BOARD PRODUCTION AND REWORK New synthetic latex peelable solder mask with the fastest drytime from application to soldering. 2220-8SQ 2220-G 2220-5G 2220-54G 8 oz. (237mL) squeeze bottle 1 gal. (3.8L) in plastic jug 50 gal. (189.4L) in plastic drum 8 oz. (237mL) squeeze bottle 1 gal. (3.8L) in plastic jug 5 gal. (18.9L) in plastic pail 50 gal. (189.4L) in plastic drum 2220-8SQ 2218-8SQ 2211 WONDERMASK P Techspray's original synthetic latex peelable solder mask. • • • • • • Easily Peelable Low Odor Cure Indicator – Darkens As It Cures Compatible with Gold and Copper Leads Non-Corrosive Non-Flammable WonderMASK P2 goes from masking to wave solder faster than any other mask! It can run through the wave after curing 20-30 minutes* and removes cleanly and easily. Specifications: MIL-STD-2000 paragraph 5.3.18 parts a,b, and d. Ford Tox #039772. 2211-8SQ 2211-G 2211-5G 2211-54G 8 oz. (237mL) squeeze bottle 1 gal. (3.8L) in plastic pail 5 gal. (18.9L) in plastic pail 54 gal. (204.4L) in plastic drum * Times may vary 2211-8SQ For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 19 ESD PRODUCTS TECHSPRAY'S VALUE IN ESD PROTECTED AREAS Techspray ESD-safe products can help maintain work areas within the ANSI/ESD-S20.20 standards set by the ESD Association (www.esda.com). In a static-free environment, the work area, tools and personnel form an electronic circuit (see diagram). Cleaners, lotions, and coatings are an integral part of an ESD control program. Electrostatic Discharge (ESD) occurs when the charges of two surfaces with a large electronic potential (difference) equalize instantaneously. The resulting current or spark can cause catastrophic or latent damage to electronic components. ESD programs maintain an equal potential by maintaining continuous contact with ground, avoiding ESD damage. ESD-safe freeze spray (1747), used for diagnostic testing, can be found on page 1. FLOOR CARE 1721 ZERO CHARGE FLOOR STRIPPER Alkaline, non-ammoniated floor stripper which removes builtup wax, synthetic floor finishes, and embedded soils. Intended for use to prepare a floor for Zero Charge ESD-Safe Floor Coating (1720). 1721-5G 1720-G 1722-G • • • • • Removes Waxes Concentrated Non-Ammoniated No Phosphates Effective with Hard and Soft Water Specifications: USDA Approved, NFPA 56A 1721-5G 1720 ZERO CHARGE® ESD-SAFE FLOOR COATING Converts any sealed floor to an ESD-safe surface with resistivity between 106 to 1010. High gloss finished for use in electronic production areas, computer rooms, hospitals, and other areas with static sensitive equipment. • • • • • Resistivity between 106 to 1010 High Gloss Polymer Slip Resistant Effective in Low Humidity Zinc Free Specifications: General Dynamics, Boeing Aircraft (BAC5485), Unisys, NFPA 56A, USDA Approved. 1720-G 1720-5G 1720-54G 20 1 gallon in plastic jug (coats @1,200 ft2) 5 gallons in plastic pail (coats @6,000 ft2) 54 gallons in plastic drum (coats @64,800 ft2) For more information: 800-858-4043 - tsales@techspray.com 5 gallons in plastic pail (strips @25,000 ft2) 1722 ZERO CHARGE FLOOR CLEANER/NEUTRALIZER Cleans scuffs, dirt, and other contamination without leaving insulative waxes and brighteners. Also neutralizes floor surface to prepare for Zero Charge ESD-Safe Floor Coating (1720). • • • • • Does not leave insulative waxes or brighteners Non-Corrosive Neutral pH No Phosphates Leaves No Soap Scum Specifications: USDA Approved, NFPA 56A 1722-G 1722-54G 1 gallon in plastic jug (cleans @10,000 ft2) 54 gallons in plastic drum (cleans @540,000 ft2) MSDS / Specs: www.techspray.com ESD PRODUCTS 1743 ZERO CHARGE SCREEN & KEYBOARD CLEANER PERSONAL AND EQUIPMENT CARE 1702 ZERO CHARGE HAND LOTION Improves contact between personnel and grounding devices such as wrist straps and heel straps. Does not contain silicone, lanolin, and other materials found in conventional hand lotions that can interfere with PCB manufacturing. Blend of moisturizers, aloe vera, and vitamins A and E penetrate rapidly leaving skin soft without a greasy film. • Improves Wrist and Heel Strap Contact • Does Not Contain Silicone or Lanolin • Non-Contaminating — Does Not Interfere with Soldering • Non-Greasy 8 oz plastic bottle with finger pump 1 gallon plastic bottle • • • • • • Cleans Plastic & Glass Leaves ESD-Safe Coating Non-Streaking Leaves No Insulative Film Non-Flammable Non-Corrosive Specifications: Meets or exceeds MIL-B-81705B, NFPA 56A 1743-50PK 1743-DSP 1743-QT Specifications: Desco C00038201S 1702-8FP - HP9300-1731 1702-G - HP9300-6148, AT&T Com Code #406359406 1702-8FP 1702-G Removes hand oils, ink marks, dust, and other contaminants from computer equipment. With regular use, cleaner will eliminate static charge from sensitive surfaces and provide long-term static protection. 1743-50PK 50 pre-saturated wipes in packets 48 pre-saturated wipes in pop-up tub 1 quart in plastic bottle w/trigger sprayer 1702-8FP ESD COATINGS 1733 ZERO CHARGE MAT & TABLETOP CLEANER • • • • • • Rejuvenates ESD-Safe Mats Will Not Dry Out Surfaces Leaves No Insulative Film Non-Flammable No Ammonia Non-Corrosive • • • • 1 quart in plastic bottle w/trigger sprayer 1 gallon in plastic jug 5 gallons in plastic pail 1626-QT 1733-QT 1742 ETC™ GLASS & PLASTIC CLEANER Water-based, non-streaking cleaner and removes heavy contamination from glass, plastic and metal enclosures. Leaves light, ESD-safe coating. Does not contain insulative additives. • • • • • • Leaves ESD-Safe Coating Non-Streaking Leaves No Insulative Film Non-Flammable No Ammonia Non-Corrosive Specifications: General Dynamics HSDS 080516-01 1742-QT All-purpose static control For Plastics, Fabrics, and Carpet Fast Drying Non-Flammable Specifications: Meets or exceeds MIL-B-81705B, NSN 6850-01-324-4682, Delco C00013781, NFPA 56A. USDA: approved A-4 rated. Specifications: 1733-QT - AT&T Com Code #406359414 1733-G - HP 9300-1921 1733-QT 1733-G 1733-5G Fast drying, anti-static coating eliminates static charge and reduces triboelectric generation from flexible surfaces. Ideal for plastics, fabrics, and carpet. 1 quart in plastic bottle w/trigger sprayer For more information: 800-858-4043 - tsales@techspray.com BOARD PRODUCTION AND REWORK Clean flux and other residues off of ESD-Safe mats and tabletops. Will not dry out surfaces (i.e. IPA) or leave insulative waxes (i.e. household cleaners). 1726 ZERO CHARGE ANTI-STAT COATING 1 quart in plastic bottle with trigger sprayer 1755 LICRON™ PERMANENT ESD-SAFE COATING Permanent static dissipative coating that adheres to metal, plastic, and most other surfaces. Ideal for changing standard bumpers, bins, tools, and surfaces to ESD-safe, saving expensive replacement cost. One can of Licron coats 200 ft2. • Permanently Static Dissipative • Resistivity between 106 to 108 ohms • Humidity Independent — Maintains Resistivity • Superior Adhesion • Translucent Specifications: Meets or exceeds the EOS/ESD Association Test Methods ANSI/EOS/ESD-S11.11-1993 and ESD STM4.2-1998 1755-10S 10 oz aerosol (coats @200ft2) MSDS / Specs: www.techspray.com 21 REWORK/REPAIR PENS EASY 3 STEP PROCESS FOR BOARD REPAIR Step 1 Flux Remover Pen Work tip over the area to be cleaned until fluxes, contaminants and soils are removed. Step 2 Conductive Pen Step 3 Overcoat Pen Repairs traces, links components, and makes smooth jumpers with simple pen strokes. After conductive trace is cured use the Overcoat Pen for the protection of repaired trace. TraceTech board repair system allows any level of technician to quickly perform quality board repairs in-house without the use of expensive equipment or time-consuming and unsightly jumpers. Meets IPC board repair standards. Other TraceTech pens are available to allow quick, convenient, and high quality board repair and rework. 2506 FLUX REMOVER PEN 2509 OVERCOAT PEN Provides convenient touch-up cleaning of flux residues. Cleans R, RMA, SA, and no-clean fluxes. Green acrylic conformal coating insulates circuit board traces and components against high voltage arcing. Provides excellent protection from moisture and fungus. • Safe on Plastics • Rapid Evaporation • Pen Tip Allows Controlled Application Specifications: Meets IPC Standard 7711 and ANSI J Standard 001C for circuit board repair and rework 2506-N 2506-N100 Single-pack of 11.5 ml pen 100 pack of 11.5 ml pens Also available: 1610-N • • • • Repairs Solder Resist Green to Match Resist Prevents Shorting and Arcing Contain Opti/Scan for UV Inspection Specifications: Meets IPC Standard 7711 and ANSI J Standard 001C for circuit board repair and rework. 2509-GN Single-pack of 5 ml pen 10ml IPA pen — see pg 5 for details 2507 NO-CLEAN FLUX DISPENSING PEN 2505 CONDUCTIVE PEN Contains a fast drying, silver filled ink designed to quickly make highly conductive silver traces. • Repairs Traces • Makes Smooth Jumpers Specifications: Meets IPC Standard 7711 and ANSI J Standard 001C for circuit board repair and rework. 2505-N Single-pack of 4.9 ml pen Resin and halide-free no-clean flux has excellent wetting abilities and leave no problematic residues. Excellent for prototyping, rework, and repair and to provide extra wetting for lead-free wire solder. • • • • Excellent Wetting Works with Lead and Lead-Free Solders No Cleaning Necessary Boost Wetting for Lead-Free Wire Solder Specifications: Meets IPC Standard 7711 and ANSI J Standard 001C for circuit board repair and rework. 2507-N 2507-N100 22 For more information: 800-858-4043 - tsales@techspray.com Single-pack of 11.5 ml pen 100 pack of 11.5 ml pens MSDS / Specs: www.techspray.com REWORK/REPAIR PENS 2510 CONFORMAL COATING REMOVER PEN 1613 LABEL & ADHESIVE REMOVER PEN Quickly and precisely removes most conformal coatings including acrylic, urethane, and silicone. Quickly removes labels and adhesive residues from PCB's, components, packaging, and casings. • Fast Stripping Action • Non-Corrosive • Rapid Evaporation 2510-N Single-pack of 10 ml pen • Natural Solvent • Safe on Most Plastics 1613-N 10 ml pen Other packaging available — see page 10 for details. Also available: 2510-P 1 pint in metal bottle 1850-O SOLDER FAULT MARKER 1850-O General purpose, single component cyanoacrylate adhesive exhibits high strength, fast bonding and high impact holding. Having a medium viscosity, Tech Hold flows into small openings (up to .004 inches). • High Strength • Durable Bonding • Fast Acting 2503-DP 3 grams in plastic bottle 10 ml Pen BOARD PRODUCTION AND REWORK Required electronic rework is conveniently marked with highly visible orange coloring combined with a black light indicator ensures quick recognition. Marking agent is quick drying and can be removed with warm water or IPA. • Inert • Quick Drying • Easily Removed with Water or IPA • Contains Opti/Scan™ 2503 TECH HOLD® ADHESIVE 2515 INSTANT LEAD TESTING SWABS Fast, easy-to-use method of testing components and solder joints for lead solder. Incoming components and boards, in addition to existing inventories, can be checked for RoHS compliance. This avoids mixed lead and lead-free inventories, lead contamination in RoHS compliant work areas, and potential penalties for shipping non-compliant products. The test is totally self-contained! Just rub the solder joint or tinned component… Ideal For… • Incoming inspection of components & PCB boards • Inspecting existing inventories • Preventing lead contamination • Spot checking poorly marked components 2515-N 8 Lead-Check Swabs If the swab tip is pink, the solder contains lead. For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 23 ® TECHCLEAN WIPES Techspray offers a large array of wipes for a variety of applications, including cleanroom, PCB rework, polishing, and maintenance. A large number of different materials are available to meet each unique requirement. All Techspray wipes have the following advantages: • Low Linting • Double-Bagged to Avoid Contamination • No Chemical Extractables 2350 TECHCLEAN WIPER BEST SELLER! General Purpose Wipe 2359 TECHCLEAN MAINTENANCE WIPE Hydroentangled cellulose/polyester wipe with high absorbency and extra low particulate count and no chemical extractables. Hydroentangled cellulose/polyester wipe with high absorbency. Economical, but very high quality wipes are ideal for production and maintenance applications. • High Absorbency • Economical • Class 100 Cleanroom Certified • High Absorbency • Very Low Particulate Count 2359-300 300 9"x9" (23cm x 23cm) flat wipes Specifications: Exceeds U.S. Air Force requirements for surface contamination, HP 9300-1618 2350-100 100 9"x9" c-fold wipes Key: z = Best TECHCLEAN WIPES { = Not applicable / Not recommended Low Linting Class 100 Cleanroom Stencil Cleaning General Maintenance Reusable Optics 2350 Wiper z z z z { { 2351• 2352 Absorbwipe z { { { { z 2354 Ultrawipe } { { z { { 2355 Purwipe z { z } z z 2357 Twill Wipe } { { } z { 2358 SMT Wipe z { z { { { 2359 Maintenance Wipe } { } z { { 2362 Anti-Static Wipe z { { { z z 2366 • 2367 Roll Wipes z { z { { { Product 24 } = Acceptable For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com ® TECHCLEAN WIPES 2351 • 2352 TECHCLEAN ABSORBWIPE™ 2358 TECHCLEAN SMT WIPE For Sensitive Surfaces Lint-Free Foam Very soft and absorbent hydroentangled polyester wipe for cleaning optical equipment, fiber optics, and other sensitive surfaces. Polyurethane foam wipe designed for cleaning surface mount stencils and screening equipment. Fiber-free foam does not generate lint, which can clog fine pitched stencils and cause misprints. • Non-abrasive • Extremely soft • Highly absorbent 2351-100 2352-100 100 4"x4" (10cm x 10cm) flat wipes 100 9"x9" (23cm x 23cm) flat wipes • Fiber-Free Construction — No Linting • Will Not Snag on Stencils • Tear Resistant 2358-50 50 9"x9" (23cm x 23cm) flat wipes Also available: See page 5 and 6 for other great SMT cleaners including water, IPA, or Hydrocarbon based pre-saturated wipes. 2362 ANTI-STATIC WIPE 2354 TECHCLEAN ULTRAWIPE™ Textured Scrubbing Wipe Patterned, hydroentangled cellulose/polyester wipe is designed for aggressive scrubbing. Texture provides abrasive surface, but will not scratch most sensitive surfaces. • Textured Surface Scrubs Without Scratching • Tear Resistant 2354-100 100 12"x12" (30.5cm x 30.5cm) flat wipes Polyester wipe that is interwoven with DuPont's NEGA-STAT carbon yarn. NEGA-STAT dissipates static charge, preventing static build-up and allowing dissipation. Perfect for dry wiping ESD-sensitive components and boards. Tear resistant to allow cleaning around through-hole leads without fraying. • • • • Anti-Static — Will Not Generate Charge ESD-Safe Very Low Particulate Count Tear Resistant 2361-150 2355 TECHCLEAN PURWIPE™ Low-Linting Poly Wipe • Very Low Particulate Count • Tear Resistant 2355-100 100 9"x9" (23cm x 23cm) flat wipes 2366 • 2367 ROLL WIPES for DEK and MPM SMT Printers Made from low lint fabric and designed for vacuum operation. • • • • • Maximum Absorbency Strong Both Wet & Dry Textured Non-Woven Fabric Low Linting – Prevents Misprints Density 68 GSM Fits DEK 265 and 288 SMT printers. 2366-DEK 2357 TECHCLEAN TWILL WIPE 39' (11.9M) L Roll x 20.3" (51.5cm) W, .79" (20mm) ID Fits MPM AP23, AP24, AP25, and AP27 SMT printers. 2367-MPM 39' (11.9M) L Roll x 17.5"(44.5cm) W, .75" (19mm) ID Tear Resistant Cotton 100% cotton twill weave designed for wiping abrasive surfaces. Tear resistant to allow cleaning around leads without fraying. Low static generation, so good for static sensitive areas. • Tightly Woven 100% Cotton • Tear Resistant • Low Static Generation 2357-100 100 6"x6" (15cm x 15cm) flat wipes For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 25 CLEANING TOOLS 100% polyester wipe is a strong, lowlinting wipe that is idea for SMT stencil cleaning and PCB rework. Tear resistant to allow cleaning around leads without fraying. 150 9"x9" (23cm x 23cm) flat wipes TECHSWABS ™ Precisely designed, manufactured and packaged to serve a wide variety of cleaning and maintenance needs. TechSwabs are manufactured in accordance with Techspray's rigid specifications, using specialized materials to ensure low particle generation. Cotton swabs are the most economical choice for high volume usage. Foam swabs are ideal for more precision cleaning where linting needs to be avoided. All swabs shown actual size COTTON TECHSWABS Tightly wrapped, pre-cleaned cotton ensures the least amount of extractable contaminants. Product Tip Width Attachment of Tip Handle Length Handle Material 30 Pack Bag 100 Pack Bag 1000 Pack Bag 2300 3/16" Wrapped 6" Wood — 2300-100 2300-1000 2301 3/16" Wrapped 6" Wood — 2301-100 2301-1000 2313 1/8" Wrapped 3 1/4"" Paper 2313-30 — — CHAMOIS TECHSWABS Synthetic chamois tip offers soft, durable, and low linting tape-head cleaning. Heat bonding prevents adhesive residues on sensitive surfaces. Product 2314 26 Tip Width Attachment of Tip Handle Length Handle Material Pliable Handle 50 Pack Bag 1000 Pack Bag 3/8" Heat Sealed 4 3/4" Polypropylene Yes 2314-50 — For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com TECHSWABS ™ FOAM TECHSWABS All foam swabs are manufactured with 100 pores per inch reticulated polyurethane foam, which ensures excellent absorbency while minimizing contamination. Tips are affixed by heat seal to prevent tip loss, even while saturated with solvent. Flexible tips provide versatility and softer touch, while rigid heads allow for more aggressive cleaning. Product Tip Width Attachment of Tip Handle Length Handle Material Pliable Handle 50 Pack Bag 1000 Pack Bag 2302 7/16" Heat Sealed 6" Polypropylene Yes 2302-50 2302-1000 Cotton Bud Wrapped in Foam, Rigid Head 2303 1/4" Heat Sealed 6" Polypropylene Yes 2303-50 2303-1000 5" Polypropylene Yes 2306-50 2306-1000 4" Polypropylene Yes 2307-50 2307-1000 3" Polypropylene Yes 2309-50 2309-1000 2 5/8" Polypropylene Yes — 2311-1000 Rigid Head 2306 1/2" Heat Sealed Rigid Head 2307 3/16" Heat Sealed Flexible Tip 2309 1/8" Heat Sealed Flexible Tip 2311 1/8" Heat Sealed FIBER OPTIC TECHSWABS Foam fiber optic swabs are ideal for removing transmission disrupting contaminants in bulkhead connectors. The head conforms to the various connector shapes, cleaning the conductor bulkhead corners inside the bulkhead pocket. Foam fiber optic swabs are an economic choice over wrapped swabs. Tips are heat bonded, so no contaminating glues have been used. Product 2316 Tip Width Attachment of Tip Handle Length Handle Material Pliable Handle 50 Pack Bag 1000 Pack Bag 1.25mm Heat Sealed 6 1/4" Polypropylene Yes 2316-50 2316-1000 6 1/4 " Polypropylene Yes 2317-50 2317-1000 Flexible Tip 2317 2.5mm Heat Sealed Flexible Tip For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 27 CLEANING TOOLS Flexible Tip ® TECHCLEAN BRUSHES Choose the Right Bristle Material for Your Needs: Natural — Soft, resilient and long lasting. Hog bristles are stiffer than horsehair. Metal — For burnishing, polishing, nonsparking static dissipation and deburring. Brass is a softer bristle than stainless steel. ESD-Safe — Prevents static build-up on brush. Ideal for dry brushing. Bristles approximately 108. L Bristle Length W Bristle Width T Bristle Trim 2020-1 1 3/8" 1/4"` 2021-1 1 3/8" 2022-1 A 28 W-Bristle Width D-Diameter Bristle Material Handle Material Handle Length 7/6" Horse Hair Wood Laminate 7 3/4" 1/4" 7/16" Hog Bristle Wood Laminate 7 3/4" 2 1/8" 7/8" 3/4" Hog Bristle Wood Laminate 8 3/8" 2025-1 1 3/8" 1/4" 7/16" Soft Brass .003" Wood Laminate 7 3/4" 2027-1 7/8" 3/8" 1/2" Hog Bristle Wood 4 15/16" 2030-1 1/8" 1/16" 1/8" Goat Hair Stainless Steel 3 1/2" 2031-1 1/4" 3/16" A-1/2" B-1/4" Horse Hair Stainless Steel 4 1/2" 2032-1 1/2" 3/8" A-1/4" B-3/16" Horse Hair Zinc Plated Steel 4 1/2" 2033-1 7/16" 3/8" 3/4" Horse Hair Zinc Plated Steel 4 1/2" 2040-1 1 3/16" 1/8" 7/16" Horse Hair Anodized Aluminum 6 7/16" 2042-1 1 3/16" 3/8" 7/16" Horse Hair Anodized Aluminum 6 7/16" 2043-1 1 3/16" 3/8" 7/16" Stainless Steel .003" Anodized Aluminum 6 7/16" 2061-1 1 3/16" 3/8" 7/16" ESD-Safe Aluminum 6 7/16" Product A T-Bristle Trim L-Bristle Length B B For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com INDEX INDEX BY PRODUCT CATEGORY A Adhesives B C 23 5, 6 6, 10 8-9 22-23 5 28 1 Alcohols Axarel Blue Shower Board repair pens Bottles, Empty Brushes Chrome trigger Cleaners Adhesive 6, 10 Contacts 11-12 Credit card reader 10 Dust 1 Floor 20 Flux Residues 2-5 Glass 10, 21 Glass & Plastic 21 Grease 5, 8-10 Mat 21 Oven, SMT 7 Stencil, SMT 6 Vapor Degreaser 4-5, 9-10 Conformal coatings 16-17, 23 Conformal coating removers 17, 23 Contact Cleaners Contact enhancers 11-12 12 D Defluxers E F G 3-5, 22 Degreasers 5, 8-10 Desoldering Braid 14-15 Dusters 1 Econoline 3, 8, 11 ESD Coating 21 Floor Cleaner 20 Floor Coating 20 Floor Stripper 20 Glass & Plastic Cleaner 21 Hand lotion 21 Mat Cleaner 21 Screen & Keyboard Cleaner 21 Floor Cleaner 20 Floor Coating 20 Floor Stripper 20 Flux pen 22 Freeze Sprays 1 G3 3, 8, 11, 13 Glass Cleaner 10, 21 H Hand lotion I L M O P R Heat sink IPA Label Remover LeadCheck swabs Lubricants Masks Oven cleaner, SMT Pens Rubber Rejuvenator S Stencil cleaners, SMT V W Solder masks Swabs Vapor degreaser cleaners Wick Wipes Dry Pre-saturated Roll 21 13 5 10, 23 23 13 18-19 7 5, 10, 22-23 10 6 18-19 26-27 4-5, 9-10 14-15 7, 24-25 5-6, 10 25 INDEX BY PART NUMBER Description 1603 1608 1610 1612 1613 1620 1621 1622 1625 1630 1631 1632 1634 1637 1638 1640 1641 1658 1660 1663 1664 1665 1666 1667 1668 1669 1671 1672 1673 1679 1685 1686 1687 1691 1692 1693 1694 1697 Techclean Card. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 SMT Stencil Wipes . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Isopropyl Alcohol . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Rubber Rejuvenator . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Label & Adhesive Remover Pen . . . . . . . . . . . . . 10, 23 Ecoline Blue Shower . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Ecoline Flux Remover . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ecoline Contact Cleaner. . . . . . . . . . . . . . . . . . . . . . . 11 Glass Cleaner. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 G3 Blue Shower . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 G3 Flux Remover . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 G3 Contact Cleaner . . . . . . . . . . . . . . . . . . . . . . . . . . 11 G3 No-Clean Flux Remover G3 . . . . . . . . . . . . . . . . . . 2 G3 Maintenance Cleaner – Bulk . . . . . . . . . . . . . . . . 10 G3 Flux Remover – Bulk . . . . . . . . . . . . . . . . . . . . . . . 2 Vapor Degreaser nPB . . . . . . . . . . . . . . . . . . . . . . . . 10 Vapor Degreaser Flux Remover nPB . . . . . . . . . . . . . . 5 Asahiklin AK225 ATE . . . . . . . . . . . . . . . . . . . . . . . . . 10 No Clean Flux Remover . . . . . . . . . . . . . . . . . . . . . . . . 3 Asahiklin AK-225 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Kleen ATMS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Flux Remover AMS . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Asahiklin AK-225 AES . . . . . . . . . . . . . . . . . . . . . . . . . 5 Blue Shower II . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Contact Cleaner II . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Asahiklin AK-225 T . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Duster . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Freezer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Economy Duster . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Envi-Ro-Tech 1679 . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 HFE Cleaner. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 HFE Flux Remover . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 HFE Contact Cleaner . . . . . . . . . . . . . . . . . . . . . . . . . 12 Water-Based SMT Oven Cleaner. . . . . . . . . . . . . . . . . 7 Water-Based SMT Stencil Cleaner Wipes . . . . . . . . . . 6 SMT Stencil Cleaner Wipes . . . . . . . . . . . . . . . . . . . . . 6 Axarel 2200 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Vortex Duster . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Page For more information: 800-858-4043 - tsales@techspray.com Product Description 1702 1720 1721 1722 1726 1733 1742 1743 1747 1755 1801 1802 1803 1804 1805 1806 1808 1809 1810 1811 1812 1813 1814 1815 1816 1817 1818 1819 1820 1821 1822 1823 1824 1825 1826 1827 1830 1831 Zero Charge Hand Lotion. . . . . . . . . . . . . . . . . . . . . . 21 Zero Charge Static Dissipative. . . . . . . . . . . . . . . . . . 20 Zero Charge Floor Stripper . . . . . . . . . . . . . . . . . . . . 20 Zero Charge Cleaner/Neutralizer . . . . . . . . . . . . . . . . 20 Zero Charge Anti-Stat . . . . . . . . . . . . . . . . . . . . . . . . 21 Zero Charge Mat & Table Top Cleaner . . . . . . . . . . . . 21 Etc. Glass & Plastic Cleaner . . . . . . . . . . . . . . . . . . . 21 Zero Charge Screen & Keyboard Cleaner . . . . . . . . . 21 Anti-Static Freezer . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Licron ESD-Safe Coating . . . . . . . . . . . . . . . . . . . . . . 21 Pro Wick White #1 Braid. . . . . . . . . . . . . . . . . . . . . . . 14 Pro Wick Yellow #2 Braid . . . . . . . . . . . . . . . . . . . . . . 14 Pro Wick Green #3 Braid . . . . . . . . . . . . . . . . . . . . . . 14 Pro Wick Blue #4 Braid . . . . . . . . . . . . . . . . . . . . . . . 14 Pro Wick Brown #5 Braid . . . . . . . . . . . . . . . . . . . . . . 14 Pro Wick Red #6 Braid . . . . . . . . . . . . . . . . . . . . . . . . 14 Pro Wick White #1 Braid – AS . . . . . . . . . . . . . . . . . . 14 Pro Wick Yellow #2 Braid – AS . . . . . . . . . . . . . . . . . . 14 Pro Wick Green #3 Braid – AS. . . . . . . . . . . . . . . . . . 14 Pro Wick Blue #4 Braid – AS . . . . . . . . . . . . . . . . . . . 14 Pro Wick Brown #5 Braid – AS . . . . . . . . . . . . . . . . . 14 Pro Wick Red #6 Braid – AS . . . . . . . . . . . . . . . . . . . 14 No-Clean White #1 Braid . . . . . . . . . . . . . . . . . . . . . . 15 No-Clean Yellow #2 Braid . . . . . . . . . . . . . . . . . . . . . . 15 No-Clean Green #3 Braid. . . . . . . . . . . . . . . . . . . . . . 15 No-Clean Blue #4 Braid . . . . . . . . . . . . . . . . . . . . . . . 15 No-Clean Brown #5 Braid. . . . . . . . . . . . . . . . . . . . . . 15 No-Clean Red #6 Braid . . . . . . . . . . . . . . . . . . . . . . . 15 No-Clean White #1 Braid – AS. . . . . . . . . . . . . . . . . . 15 No-Clean Yellow #2 Braid – AS . . . . . . . . . . . . . . . . . 15 No-Clean Green #3 Braid – AS . . . . . . . . . . . . . . . . . 15 No-Clean Blue #4 Braid – AS. . . . . . . . . . . . . . . . . . . 15 No-Clean Brown #5 Braid – AS . . . . . . . . . . . . . . . . . 15 No-Clean Red #6 Braid – AS . . . . . . . . . . . . . . . . . . . 15 Pro Wick Grey Braid – AS . . . . . . . . . . . . . . . . . . . . . 14 No-Clean Grey Braid – AS . . . . . . . . . . . . . . . . . . . . . 15 Unfluxed White #1 Braid – AS . . . . . . . . . . . . . . . . . . 15 Unfluxed Yellow #2 Braid – AS . . . . . . . . . . . . . . . . . . 15 Page MSDS / Specs: www.techspray.com 29 INDEX Product INDEX Product Description Page 1832 1833 1850-O 1928 1977 1978 1981 2020-1 2021-1 2022-1 2025-1 2027-1 2030-1 2031-1 2032-1 2033-1 2040-1 2042-1 2043-1 2061-1 2102 2103 2104 2105 2106 2111-N 2112-6S 2204 2205 2206 2207 2211 2218 2220 Unfluxed Green #3 Braid – AS. . . . . . . . . . . . . . . . . . 15 Unfluxed Blue #4 Braid – AS . . . . . . . . . . . . . . . . . . . 15 Solder Fault Marker – Orange . . . . . . . . . . . . . . . . . . 23 Chrome Trigger Valve . . . . . . . . . . . . . . . . . . . . . . . . . 1 Transistor Silicone Grease . . . . . . . . . . . . . . . . . . . . . 13 Silicone Free Heat Sink Comp. . . . . . . . . . . . . . . . . . 13 Techpump Bottle. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Brush 1 3/8 x 1/4" Horse Hair . . . . . . . . . . . . . . . . . . 28 Brush 1 3/8 x 1/4" Hog Hair . . . . . . . . . . . . . . . . . . . 28 Brush 2 1/8 x 7/8" Hog Hair . . . . . . . . . . . . . . . . . . . 28 Brush 1 3/8 x 1/4" Soft Brass . . . . . . . . . . . . . . . . . . . 28 Brush HB Wood General Cleaning. . . . . . . . . . . . . . . 28 Brush 1/8 x 1/8" Goat Hair . . . . . . . . . . . . . . . . . . . . . 28 Brush 1/8 x 3/16" Horse Hair . . . . . . . . . . . . . . . . . . . 28 Brush 1/4 x 3/8" Horse Hair . . . . . . . . . . . . . . . . . . . . 28 Brush 7/16 x 3/8" Horse Hair . . . . . . . . . . . . . . . . . . . 28 Brush 13/16 x 3/16" Horse Hair . . . . . . . . . . . . . . . . . 28 Brush 1-3/16 X 5/16" Horse Hair . . . . . . . . . . . . . . . 28 Brush 1 3/16 x 5/16" Stainless Steel . . . . . . . . . . . . . 28 Brush 1 3/16 x 5/16" Static Dissipative Nylon . . . . . . 28 Fine-L-Kote SR Conformal Coating . . . . . . . . . . . . . . 17 Fine-L-Kote AR Conformal Coating . . . . . . . . . . . . . . 17 Fine-L-Kote UR Conformal Coating . . . . . . . . . . . . . . 17 Fine-L-Kote UR Thinner . . . . . . . . . . . . . . . . . . . . . . . 17 Fine-L-Kote HT Conformal Coating . . . . . . . . . . . . . . 17 Contact Enhancer. . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Rid-Ox Contact Protector . . . . . . . . . . . . . . . . . . . . . . 12 WonderMASK WSOL . . . . . . . . . . . . . . . . . . . . . . . . . 18 WonderMASK W. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 WonderMASKWA . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 WonderMASK WS . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 WonderMASK P . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 WonderMASK PL Latex . . . . . . . . . . . . . . . . . . . . . . . 19 WonderMASK P2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Product Description Page 2300 2301 2302 2303 2306 2307 2309 2311 2313 2314 2316 2317 2350-100 2351-100 2352-100 2354-100 2355-100 2357-100 2358-50 2359-300 2362-150 2365-300 2366-DEK 2367-MPM 2420-10S 2421-12S 2503-DP 2505 2506 2507 2509 2510 2515-N Double-Tip Cotton Stick . . . . . . . . . . . . . . . . . . . . . . . 26 Single-Tip Cotton Stick. . . . . . . . . . . . . . . . . . . . . . . . 26 Absorb-Tip Foam Swab . . . . . . . . . . . . . . . . . . . . . . . 27 Tip Foam Swab . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Super-Tip Foam Swab . . . . . . . . . . . . . . . . . . . . . . . . 27 Mini-Tip Foam Swab. . . . . . . . . . . . . . . . . . . . . . . . . . 27 Foam Arrow Tip Swab . . . . . . . . . . . . . . . . . . . . . . . . 27 Micro Foam Swab. . . . . . . . . . . . . . . . . . . . . . . . . . . . 27 Double-Tip Pointed Cotton Stick . . . . . . . . . . . . . . . . 26 Straight-Shaft Chamois Swab . . . . . . . . . . . . . . . . . . 26 1.25mm Fiber Optic Swab . . . . . . . . . . . . . . . . . . . . . 27 2.5mm Fiber Optic Swab . . . . . . . . . . . . . . . . . . . . . . 27 Techclean Wiper . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24 Techclean Absorbwipe . . . . . . . . . . . . . . . . . . . . . . . . 25 Techclean Absorbwipe . . . . . . . . . . . . . . . . . . . . . . . . 25 Techclean Ultrawipe . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Techclean Purwipe . . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Techclean Twillwipe . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Techclean SMT Foam Wipe . . . . . . . . . . . . . . . . . . . . 25 Techclean Blue Wipe . . . . . . . . . . . . . . . . . . . . . . . . . 24 Techclean Anti-Static Wipe. . . . . . . . . . . . . . . . . . . . . 25 Economy Blue Wipe . . . . . . . . . . . . . . . . . . . . . . . . . . 25 Tech Roll Ultra DEK Printers . . . . . . . . . . . . . . . . . . . 25 Tech Roll Ultra MPM Printers . . . . . . . . . . . . . . . . . . . 25 Slic Silicone Lubricant . . . . . . . . . . . . . . . . . . . . . . . . 13 G3 Kleen-It Lubricant . . . . . . . . . . . . . . . . . . . . . . . . . 13 Tech Hold Adhesive . . . . . . . . . . . . . . . . . . . . . . . . . . 23 Trace Tech Conductive Pen . . . . . . . . . . . . . . . . . . . . 22 Trace Tech Flux Remover Pen . . . . . . . . . . . . . . . . . . 22 Trace Tech No-Clean Flux Pen. . . . . . . . . . . . . . . . . . 22 Trace Tech Overcoat Pen – Green . . . . . . . . . . . . . . . 22 Conformal Coating Remover . . . . . . . . . . . . . . . . . . . 23 LeadCheck Swabs . . . . . . . . . . . . . . . . . . . . . . . . . . . 23 CROSS-REFERENCE INDEX K2680 Water Soluable Spot Mask 2205-G WonderMASK W 18 CT100 Cottontip Swabs (100/bag) 2301-100 Single-Tip Cotton Stick 26 CT200 Double Tip Cotton Swab (100/bag) 2300-100 Double-Tip Cotton Stick 26 CT2000 Double Tip Cotton Swab (1000/box) 2300-1000 Double-Tip Cotton Stick 26 K2683 Water Soluable Spot Mask 2206-G WonderMASK WA 18 K2685 Water Soluable Spot Mask 2207-G WonderMASK WS 18 CHEMTRONICS TECHSPRAY PG. CC50 Chamois Swabs (50/bag) 2314-50 Straight-Shaft Chamois Swab 26 CT40-5 Heat Sink Grease 142g tube 1977-DP Transistor Silicone Grease 13 CF2050 Foamtip Swabs (50/bag) 2306-50 Super-Tip Foam Swab 27 CT5000 Cottontip Swabs (1000 low-lint/box) 2300-1000 Double-Tip Cotton Stick 26 CF3050 Foamtip Swabs (50/bag) 2303-50 Tip Foam Swab 27 CW1 Chemask W (1gal) 2205-G WonderMASK W 18 CW2200STP CircuitWorks Conductive Pen 2505-N Trace Tech Conductive Pen 22 Trace Tech Overcoat Pen – Green 22 2510-N Conf Ctg Rmvr Pen 1613-N Label & Adhesive Rmvr Pen 10, 23 CF4050 Foamtip Swabs (50/bag) 2311-50 Micro Foam Swab 27 CW3300G CF50 Foamtip Swabs (50/bag) 2302-50 Absorb-Tip Foam Swab 27 CW3500 CircuitWorks Overcoat Pen – Green Conf Ctg Rmvr Pen CW3700 The Mighty Pen (11.5g) 2509-GN 23 CM1 Chemask (1gal) 2218-G WonderMASK PL Latex 19 CW8 Chemask W 8oz (sqz bttl) 2205-8SQ WonderMASK W 18 CM8 Chemask 8oz (sqz bttl) 2218-8SQ WonderMASK PL Latex 19 CW8100 2507-N Trace Tech No-Clean Flux Pen 22 CP400 Chempad (50/4"x3") 1610-50PK Isopropyl Alcohol Wipes CircuitWorks Flux Dispensing Pen CSP20 ScreenPrep (25 twin packs) 1743-50PK Zero Charge Screen Wipes & Keyboard Clnr 21 CW9100 CircuitWorks Flux Rmvr Pen 2506-N Trace Tech Flux Rmvr Pen 22 CW9200 CircuitWorks Flux Rmvr Pen 2506-N Trace Tech Flux Rmvr Pen 22 2103-G Fine-L-Kote AR Conf Ctg 17 CXM50 Flextip Swabs (50/bag) 2307-50 Mini-Tip Foam Swab 27 25 5 CTAR-1 Konform AR (1 gal) CTAR-12 Konform AR 11.5 oz 2103-12S Fine-L-Kote AR Conf Ctg 17 C600 Twillwipes (300/6"x6") 2357-100 Techclean Twillwipe CTSR-1 Konform SR (1gal) 2102-G Fine-L-Kote SR Conf Ctg 17 C805 Static Free Hand Guard 8oz 1702-8FP Zero Charge Hand Lotion 21 CTSR-5 Konform SR (5G) 2102-5G Fine-L-Kote SR Conf Ctg 17 C900 Twillwipes (150/9"x9") 2357-100 Techclean Twillwipe 25 CTSR-12 Konform SR 10oz 2102-12S Fine-L-Kote SR Conf Ctg 17 C910 Controlwipes (150/9"x9") 2350-100 Techclean Wiper 24 CTSR-HV1 Konform SR High Viscosity (1gal) 2102-GHV Fine-L-Kote SR Conf Ctg 17 C920 Opticwipes (500/9"x9") 2352-100 Techclean Absorbwipe 25 ES101 Electro-Wash NX (1gal) 1637-G G3 Maintenance Clnr – Bulk 10 30 For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com INDEX ES111 Electro-Wash NX *New & Impr (1gal) 1664-G 1638-G Kleen ATMS ES131 Flux-Off HD (1gal) ES179 Max-Kleen Lectro-Solv (1gal) 1637-G ES184 Max-Kleen Xtreme (1gal) ES192 Flux-Off No Clean (1gal) 141b 1638-G G3 Flux Rmvr – Bulk 2 ES195 Flux-Off No Clean *New & Impr (1gal) Kleen ATMS 9 1637-G 1664-G G3 Flux Rmvr – Bulk 9 1664-18S Kleen ATMS 9 2 ES1681 Pow-R-Wash (12oz) 141b 1632-16S G3 Contact Clnr 10 ES1692 1634-12S G3 No-Clean Flux Rmvr 2 G3 Maintenance Clnr – Bulk 10 Flux-Off No Clean (14.5 oz) 141b ES1695 Flux-Off No Clean *New & Impr (12oz) 1634-12S G3 No-Clean Flux Rmvr 2 ES1696 Flux-Off No-Clean Plus (12oz) 1621-10S Ecoline Flux Rmvr 2 ES2201 Electro-Wash NX (18oz) 141b 1630-16S G3 Blue Shower 8 ES2202 Pow-R-Wash NX (18oz) 141b 1632-16S G3 Contact Clnr 11 ES2211 Electro-Wash NX *New & Impr (18oz) 1667-18S Blue Shower II 9 ES2212 Pow-R-Wash NX *New & Impr (18oz) 1632-16S G3 Contact Clnr 11 ES2400 Tun-O-Wash (12.5 oz) 1622-10S Ecoline Contact Clnr 11 ES5501 Electro-Wash NX (55G) 141b 1637-54G G3 Maintenance Clnr – Bulk 10 ES5511 Electro-Wash NX *New & Impr (55G) 1664-54G Kleen ATMS ES5514 Electro-Wash NR *New & Impr (55G) nPB 1640-54G Vapor Degreaser nPB Flux-Off Lead Free Flux Rmvr (1gal) 1638-G G3 Flux Rmvr – Bulk 2 ES535 Flux-Off Rosin (5G) 1621-5G Ecoline Flux Rmvr 2 ES710V Ultrajet Duster System Trigger 1928 Chrome Trigger Valve 1 ES805 Label Adhesive Rmvr (6oz) Label & Adhesive Rmvr ES892B Flux-Off No Clean (7oz) 141b 1631-5S G3 Flux Rmvr 2 ES895B Flux-Off No Clean *New & Impr (6oz) No Clean Flux Rmvr 2 1660-6S Electro-Wash PN *New & Impr (12oz) G3 Maintenance Clnr – Bulk ES197 1613-6S ES1678 10 11 9 ES1015 Ultrajet 70 (10oz) 1671-10S Duster 1 ES1017 Duster 10oz 1671-10S Duster 1 ES1020 Ultrajet 10oz 1697-10S Vortex Duster 1 ES1020R Ultrajet Refills (10oz) 1671-10RS Duster/Refill 1 ES5535 Flux-Off Rosin (55G) 1621-54G Ecoline Flux Rmvr 2 ES1021 Electro-Wash MX (10oz) 1620-10S Ecoline Blue Shower 8 ES6100 Electro-Wash VZ (12oz) 1630-16S G3 Blue Shower 8 ES1035 Flux-Off Rosin (10oz) 1621-10S Ecoline Flux Rmvr 2 ES6200 Flux-Off VZ (12oz) 1631-16S G3 Flux Rmvr ES1050 Freez-It (10oz) 1672-10S Freezer 1 ES6300 Pow-R-Wash VZ (12oz) 1632-16S G3 Contact Clnr ES1051 Freez-It Anti-Stat (10oz) 1747-10S Anti-Static Freezer 1 ES7100 Electro-Wash CZ (12oz) 1685-18S HFE Clnr ES1052 Freeze Spray (10oz) 1672-10S Freezer 1 ES7200 Flux-Off CZ (12oz) 1686-18S HFE Flux Rmvr ES1210 Electro-Wash PX (12.5oz) 1620-10S Ecoline Blue Shower 8 ES7300 Pow-R-Wash CZ (12oz) 1687-18S HFE Contact Clnr ES1217 Duster (8oz) 1671-10S Duster 1 SIP100P Isopropyl Alcohol Wipes Flux-Off Wtr Sol (13.5oz) 1621-10S Ecoline Flux Rmvr 2 StencilWorks IPA Stencil Wipes 1610-100DSP ES1530 SRDK02 DEK Roll Wipes 2366-DEK Tech Roll Ultra DEK Printers SRMP01 MPM Roll Wipes 2367-MPM Tech Roll Ultra MPM Printers 25 SVDK02 DEK Roll Wipes 2366-DEK Tech Roll Ultra DEK Printers 25 SVMP01 MPM Roll Wipes 2367-MPM Tech Roll Ultra MPM Printers 25 2-5L Chem-Wik Rosin 5' 1801-5F Pro Wick White #1 Braid 14 ES1550 Freez-It(15oz) 1672-15S Freezer 1 ES1551 Freez-It Anti-Stat (15oz) 1747-15S Anti-Static Freezer 1 ES1601 Electro-Wash NX (14.5oz) 141b 1630-16S G3 Blue Shower 8 ES1602 Pow-R-Wash NX (14.5oz) 141b 1632-16S G3 Contact Clnr 11 ES1603 Electro-Wash PR (10oz) 1620-10S ES1604 Electro-Wash NR (12oz) 141b 1630-16S ES1605 Pow-R-Wash PR (10oz) 1622-10S Ecoline Contact Clnr ES1607 Electro-Wash NXO (12oz) 1685-18S HFE Clnr ES1612 Pow-R-Wash *New & Impr (12oz) 1632-16S G3 Contact Clnr Electro-Wash NX *New & Impr (12oz) 1667-8S Pow-R-Wash NR *New & Impr (12oz) nPB 1632-16S ES1611 ES1613 ES1614 Electro-Wash NR *New & Impr (12oz) nPB 1630-16S 10 2 11 9 3 12 5 25 Ecoline Blue Shower 8 5-5L Chem-Wik Rosin 5' 1802-5F Pro Wick Yellow #2 Braid 14 G3 Blue Shower 8 5-25L Chem-Wik Rosin 25' 1802-25F Pro Wick Yellow #2 Braid 14 11 5-100L Chem-Wik Rosin 100' 1802-100F Pro Wick Yellow #2 Braid 14 9 5-500L Chem-Wik Rosin 500' 1802-500F Pro Wick Yellow #2 Braid 14 7-5L Chem-Wik Rosin 5' 1803-5F Pro Wick Green #3 Braid 14 7-25L Chem-Wik Rosin 25' 1803-25F Pro Wick Green #3 Braid 14 7-100L Chem-Wik Rosin 100' 1803-100F Pro Wick Green #3 Braid 14 7-500L Chem-Wik Rosin 500' 1803-500F Pro Wick Green #3 Braid 14 10-5L Chem-Wik Rosin 5' 1804-5F Pro Wick Blue #4 Braid 14 10-25L Chem-Wik Rosin 25' 1804-25F Pro Wick Blue #4 Braid 14 10-50L Chem-Wik Rosin 50' 1804-50F Pro Wick Blue #4 Braid 14 Blue Shower II G3 Contact Clnr G3 Blue Shower 11 9 11 8 Duster (12oz) 1671-15S Duster 15 Oz Fill 1 10-100L Chem-Wik Rosin 100' 1804-100F Pro Wick Blue #4 Braid 14 Ultrajet All-Way (8oz) 1697-8S Vortex 360 Duster 1 50-2-25 Soder-Wick Rosin 25' 1802-25F Pro Wick Yellow #2 Braid 14 ES1629 Kontact Restorer *New & Impr (12oz) nPB 2421-12S G3 Kleen-It 13 50-2-100 Soder-Wick Rosin 100' 1802-100F Pro Wick Yellow #2 Braid 14 50-2-500 Soder-Wick Rosin 500' 1802-500F Pro Wick Yellow #2 Braid 14 ES1631 Flux-Off HD (12oz.) 1686-12S 3 50-3-25 Soder-Wick Rosin 25' 1803-25F Pro Wick Green #3 Braid 14 ES1664T Mat&Benchtop Recond (16oz) 1733-PT Zero Charge Mat Clnr 21 50-3-100 Soder-Wick Rosin 100' 1803-100F Pro Wick Green #3 Braid 14 ES1668 Static Free Plast-N-Glass (16oz) 1625-18S Glass Clnr 10 50-3-500 Soder-Wick Rosin 500' 1803-500F Pro Wick Green #3 Braid 14 50-4-25 Soder-Wick Rosin 25' 1804-25F Pro Wick Blue #4 Braid 14 ES1677 Pow-R-Wash PN *New & Impr (12oz) 1668-18S Contact Clnr II 12 50-4-100 Soder-Wick Rosin 100' 1804-100F Pro Wick Blue #4 Braid 14 50-4-500 Soder-Wick Rosin 500' 1804-500F Pro Wick Blue #4 Braid 14 ES1675 Electro-Wash PN (12oz) 1630-16S G3 Blue Shower 8 50-5-25 Soder-Wick Rosin 25' 1805-25F Pro Wick Brown #5 Braid 14 50-6-25 Soder-Wick Rosin 25' 1806-25F Pro Wick Red #6 Braid 14 HFE Flux Rmvr For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 31 INDEX ES1617 ES1620 INDEX 60-1-5 Soder-Wick No Clean SD 5' 1820-5F No-Clean White #1 Braid – AS 15 60-1-10 Soder-Wick No Clean SD 10' 1820-10F No-Clean White #1 Braid – AS 15 60-2-5 Soder-Wick No Clean SD 5' 1821-5F No-Clean Yellow #2 Braid – AS 15 60-2-10 Soder-Wick No Clean SD 10' 1821-10F No-Clean Yellow #2 Braid – AS 15 60-3-5 Soder-Wick No Clean SD 5' 1822-5F No-Clean Green #3 Braid – AS 15 60-3-10 Soder-Wick No Clean SD 10' 1822-10F No-Clean Green #3 Braid – AS 15 60-4-5 Soder-Wick No Clean SD 5' 1823-5F No-Clean Blue #4 Braid – AS 15 60-4-10 Soder-Wick No Clean SD 10' 1823-10F No-Clean Blue #4 Braid – AS 15 60-5-5 Soder-Wick No Clean SD 5' 1824-5F No-Clean Brown #5 Braid – AS 15 60-6-5 Soder-Wick No Clean SD 5' 1825-5F No-Clean Red #6 Braid – AS 15 75-2-10 Soder-Wick Unfluxed SD 10' 1831-10F Unfluxed Yellow #2 Braid – AS 15 75-4-10 Soder-Wick Unfluxed SD 10' 1833-10F Unfluxed Blue #4 Braid – AS 15 80-1-5 Soder-Wick Rosin SD 5' 1808-5F Pro Wick White #1 Braid – AS 14 80-1-10 Soder-Wick Rosin SD 10' 1808-10F Pro Wick White #1 Braid – AS 14 80-2-5 Soder-Wick Rosin SD 5' 1809-5F Pro Wick Yellow #2 Braid – AS 14 80-2-10 Soder-Wick Rosin SD 10' 1809-10F Pro Wick Yellow #2 Braid – AS 14 80-3-5 Soder-Wick Rosin SD 5' 1810-5F Pro Wick Green #3 Braid – AS 14 80-3-10 Soder-Wick Rosin SD 10' 1810-10F Pro Wick Green #3 Braid – AS 14 80-4-5 Soder-Wick Rosin SD 5' 1811-5F Pro Wick Blue #4 Braid – AS 14 80-4-10 Soder-Wick Rosin SD 10' 1811-10F Pro Wick Blue #4 Braid – AS 14 80-5-5 Soder-Wick Rosin SD 5' 1812-5F Pro Wick Brown #5 Braid – AS 14 80-5-10 Soder-Wick Rosin SD 10' 1812-10F Pro Wick Brown #5 Braid – AS 14 80-6-5 Soder-Wick Rosin SD 5' 1813-5F Pro Wick Red #6 Braid – AS 14 COVENTRY TECHSPRAY PG. 41050 Sealed Foam Swab 2311-1000 Micro Foam Swab 27 44070 Sealed Foam Swab 2309-1000 Foam Arrow Tip Swab 27 49280 Swab 0.2"x4" 2311-1000 Micro Foam Swab 27 6259 Polyester Wipe Knit 9"x9" 2355-100 Techclean Purwipe 25 6709 Econowipe cellulose/ polyester 9"x9" 2359-300 Techclean Blue Wipe 24 Cotton Wipe twill 9"x9" 2357-100 6809 CRC Techclean Twillwipe TECHSPRAY 0S-A-25 One-Step No-Clean Braid 25ft/0.025" 1814-25F No-Clean White #1 Braid 15 0S-A-100 One-Step No-Clean Braid 100ft/0.025" 1814-100F No-Clean White #1 Braid 15 0S-B-5 One-Step No-Clean Braid 5ft/0.50" 1815-5F No-Clean Yellow #2 Braid 15 0S-B-5AS One-Step No-Clean A/S 5ft/0.050" 1821-5F No-Clean Yellow #2 Braid – AS 15 0S-B-10 One-Step No-Clean Braid 10ft/0.050" 1815-10F No-Clean Yellow #2 Braid 15 0S-B-10AS One-Step No-Clean A/S 10ft/0.050" 1821-10F No-Clean Yellow #2 Braid – AS 15 0S-B-25 One-Step No-Clean Braid 25ft/0.050" 1815-25F No-Clean Yellow #2 Braid 15 0S-B-100 One-Step No-Clean Braid 100ft/0.050" 1815-100F No-Clean Yellow #2 Braid 15 0S-C-5 One-Step No-Clean Braid 5ft/0.075" 1816-5F No-Clean Green #3 Braid 15 0S-C-5AS One-Step No-Clean A/S 5ft/0.075" 1822-5F No-Clean Green #3 Braid – AS 15 0S-C-10 One-Step No-Clean Braid 10ft/0.075" 1816-10F No-Clean Green #3 Braid 15 0S-C-10AS One-Step No-Clean A/S 10ft/0.075" 1822-10F No-Clean Green #3 Braid – AS 15 0S-C-25 One-Step No-Clean Braid 25ft/0.075" 1816-25F No-Clean Green #3 Braid 15 0S-C-100 One-Step No-Clean Braid 100ft/0.075" 1816-100F No-Clean Green #3 Braid 15 0S-D-5 One-Step No-Clean Braid 5ft/0.100" 1817-5F No-Clean Blue #4 Braid 15 0S-D-5AS One-Step No-Clean A/S 5ft/0.100" 1823-5F No-Clean Blue #4 Braid – AS 15 0S-D-10 One-Step No-Clean Braid 10ft/0.100" 1817-10F No-Clean Blue #4 Braid 15 0S-D-10AS One-Step No-Clean A/S 10ft/0.100" 1823-10F No-Clean Blue #4 Braid – AS 15 0S-D-25 One-Step No-Clean Braid 25ft/0.100" 1817-25F No-Clean Blue #4 Braid 15 0S-D-100 One-Step No-Clean Braid 100ft/0.100" 1817-100F No-Clean Blue #4 Braid 15 0S-E-5 One-Step No-Clean Braid 5ft/0.125" 1818-5F No-Clean Brown #5 Braid 15 0S-E-5AS One-Step No-Clean A/S 5ft/0.125" 1824-5F No-Clean Brown #5 Braid – AS 15 0S-E-25 One-Step No-Clean Braid 25ft/0.125" 1818-25F No-Clean Brown #5 Braid 15 No-Clean Braid 0.025" 5 ft. 1814-5F No-Clean A/S Braid 0.025" 5 ft. 1827-5F No-Clean White #1 Braid No-Clean Grey Braid – AS 15 15 25 PG. 02016 CO Contact Clnr (16oz) 1687-18S HFE Contact Clnr 12 02140 Contact Clnr 2000 (16oz) 1632-16S G3 Contact Clnr 11 02180 Electrical Parts Clnr (20oz) 1630-16S G3 Blue Shower Clnr 7 02183 Electrical Parts Clnr (5gal) 1637-5G G3 Universal Clnr – Bulk 7 02184 Electrical Parts Clnr (55 gal) 1637-54G G3 Universal Clnr – Bulk 7 02210 225 Precision Clnr (16oz) 1668-18S Contact Clnr II 03110 Super Degreaser (20oz) 1630-16S G3 Blue Shower Clnr 03113 Super Dgrsr (55gal) 1640-54G Vapor Degreaser nPB 03150 Contact Clnr 2000 (16oz) 1632-16S G3 Contact Clnr 03152 Contact Clnr 2000 (5gal) 1637-5G G3 Universal Clnr – Bulk 7 03153 Contact Clnr 2000 (55gal) 1637-54G G3 Universal Clnr – Bulk 7 0S2-A-5 0S2-A-5AS 03070 Contact Clnr (16oz) 1687-18S HFE Contact Clnr 11 0S2-A-10 No-Clean Braid 0.025" 10 ft. 1814-10F No-Clean White #1 Braid 15 03210 225 Precision Clnr (16oz) 1668-18S Contact Clnr II 11 0S2-A-10AS No-Clean A/S Braid 0.025" 10 ft. 1827-10F No-Clean Gray Braid – AS 15 0S2-A-25 No-Clean Braid 0.025" 25 ft. 1814-25F No-Clean White #1 Braid 15 0S2-B-5 No-Clean Braid 0.050" 5 ft. 1815-5F No-Clean Yellow #2 Braid 15 0S2-B-5AS No-Clean A/S Braid 0.050" 5 ft. 1821-5F No-Clean Yellow #2 Braid – AS 15 0S2-B-10 No-Clean Braid 0.050" 10 ft. 1815-10F No-Clean Yellow #2 Braid 15 No-Clean A/S Braid 0.050" 10 ft. 1820-10F No-Clean White #1 Braid – AS 15 1816-5F No-Clean Green #3 Braid 15 No-Clean Green #3 Braid – AS 15 EASY BRAID 0S-A-5 0S-A-5AS TECHSPRAY One-Step No-Clean Braid 5ft/0.025" 1814-5F One-Step No-Clean A/S 5ft/0.025" 1820-5F 11 7 9 11 PG. No-Clean White #1 Braid No-Clean White #1 Braid – AS 15 15 0S-A-10 One-Step No-Clean Braid 10ft/0.025" 1814-10F No-Clean White #1 Braid 15 0S2-B-10AS 0S-A-10AS One-Step No-Clean A/S 10ft/0.025" 1820-10F No-Clean White #1 Braid – AS 15 0S2-C-5 No-Clean Braid 0.075" 5 ft. 0S2-C-5AS No-Clean A/S Braid 0.075" 5 ft. 1822-5F 32 For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com INDEX 0S2-C-10 No-Clean Braid 0.075" 10 ft. 1816-10F No-Clean Green #3 Braid 15 0S2-C-10AS No-Clean A/S Braid 0.075" 10 ft. 1822-10F No-Clean Green #3 Braid – AS 15 0S2-C-100 0S2-D-5 0S2-D-5AS 0S2-D-10 0S2-D-10AS No-Clean A/S Braid 0.075" 100 ft. 1823-100F No-Clean Braid 0.100" 5 ft. 1817-5F No-Clean A/S Braid 0.100" 5 ft. 1823-5F No-Clean Braid 0.100" 10 ft. 1817-10F No-Clean Blue #4 Braid – AS No-Clean Blue #4 Braid No-Clean Blue #4 Braid – AS No-Clean Blue #4 Braid No-Clean Blue #4 Braid – AS 15 SW6WC-100 Cotton Tip Swab 2301-100 GC ELECTRONICS Single-Tip Cotton Stick TECHSPRAY 26 PG. 19-0270 Extra Strengh Flux Solv (16oz) 1631-16S G3 Flux Rmvr 2 19-271 Flux Solv GC3 (12oz) 1631-10S G3 Flux Rmvr 2 15 19-272 Flux Solv GC3 (16oz) 1631-16S G3 Flux Rmvr 2 15 19-328-12 General Use Flux Solv (12oz) 1631-10S G3 Flux Rmvr 2 19-328-16 General Use Flux Solv (16oz) 1631-16S G3 Flux Rmvr 2 15 19-901 Component Bath (16oz) 1630-16S G3 Blue Shower 8 15 19-636 Jif-Action Clnr & Dgrsr (16oz) 1630-16S G3 Blue Shower 19-0725 GC Bath (10oz) 1622-10S Ecoline Contact Clnr 11 19-0725-0016 19-8508-0000 GC Bath (16oz) Air Jet (8oz) 1622-13S 1671-8S Ecoline Contact Clnr Duster 11 1 19-8475-0010 Air Jet (10oz) 1671-10S Duster 1 19-8475-0000 Air Jet (12oz) 1671-15S Duster 15 Oz Fill 1 8 No-Clean A/S Braid 0.100" 10 ft. 1823-10F 0S2-E-5 No-Clean Braid 0.125" 5 ft. 1818-5F No-Clean Brown #5 Braid 15 0S2-E-5AS No-Clean A/S Braid 0.125" 5 ft. 1824-5F No-Clean Brown #5 Braid – AS 15 EBIPA100 IPA/DI Wipes 1608-100DSP SMT Stencil Wipes EB41D2116 DEK roll wipe 39 ft. 2366-DEK Tech Roll Ultra DEK Printers 25 19-8410-0010 Freeze Mist (10oz) 1672-10S Freezer 1 EB41D2120 DEK roll wipe 39 ft. 2366-DEK Tech Roll Ultra DEK Printers 25 19-8410-0000 Freeze Mist (12oz) 1672-15S Freezer 1 EB41W1212 Stencil Wipes 12x12 2354-100 Techclean Ultrawipe 25 19-8410-00SF Freeze Mist (12oz) 1747-10S Anti-Static Freezer 1 EB41W99 Stencil Wipe 9x9 2359-300 Techclean Blue Wipe 24 19-0904-0000 Big Bath ISO (9oz) 1620-10S Ecoline Blue Shower 8 K30Y14 Flux Away – Flux Rmvr (14 oz) 1621-10S Ecoline Flux Rmvr Q-A-5 Quick Braid 5ft/0.025" 1801-5F Pro Wick White #1 Braid 14 Q-A-5AS Quick Braid A/S 5ft/0.025" 1808-5F Pro Wick White #1 Braid – AS 14 JnJ INDUSTRIES TECHSPRAY Q-A-10 Quick Braid 10ft/0.025" 1801-10F Pro Wick White #1 Braid 14 SW100SMT SmartWipes 1693-100DSP SMT Stencil Clnr Wipes 6 Q-A-10AS Quick Braid 10ft/0.025" 1808-10F Pro Wick White #1 Braid – AS 14 SW100SMA Aqua Sonic (Wipes) 1692-100DSP Q-B-5 Quick Braid 5ft/0.050" 1802-5F Pro Wick Yellow #2 Braid 14 Water-Based SMT Stencil Clnr Wipes 6 Q-B-5AS Quick Braid A/S 5ft/0.050" 1809-5F Pro Wick Yellow #2 Braid – AS 14 SB6SMA Aqua Sonic (PT) 1692-PT Water-Based SMT Stencil Clnr 6 Q-B-10 Quick Braid 10ft/0.050" 1802-10F Pro Wick Yellow #2 Braid 14 GA6SMA Aqua Sonic (Gal) 1692-G Water-Based SMT Stencil Clnr 6 Q-B-10AS Quick Braid A/S 10ft/0.050" 1809-10F Pro Wick Yellow #2 Braid – AS 14 SB6AFR SmartSpray (PT) 1692-PT Water-Based SMT Stencil Clnr 6 Q-B-25 Quick Braid 25ft/0.050" 1802-25F Pro Wick Yellow #2 Braid 14 SB6SMT SmartSpray Bttl 1692-PT Water-Based SMT Stencil Clnr 6 Q-B-100 Quick Braid 100ft/0.050" 1802-100F Pro Wick Yellow #2 Braid 14 SW100IPA/DI SuperSaturated SmartWipes 1608-100DSP SMT Stencil Wipes 6 Q-B-500 Quick Braid 500ft/0.050" 1802-500F Pro Wick Yellow #2 Braid 14 SW100IPA Isopropyl Alcohol Wipes 1610-100DSP Isopropyl Alcohol Wipes 5 Q-C-5 Quick Braid 5ft/0.075" 1803-5F Pro Wick Green #3 Braid 14 SB6IPA Isopropyl Alcohol (PT) 1610-PT Isopropyl Alcohol 5 Q-C-5AS Quick Braid A/S 5ft/0.075" 1810-5F Pro Wick Green #3 Braid – AS 14 GA6IPA Isopropyl Alcohol (Gal) 1610-G4 Isopropyl Alcohol 5 Q-C-10 Quick Braid 10ft/0.075" 1803-10F Pro Wick Green #3 Braid 14 DR55IPA Isopropyl Alcohol (55 Gal) 1610-54G Isopropyl Alcohol 5 Q-C-10AS Quick Braid A/S 10ft/0.075" 1810-10F Pro Wick Green #3 Braid – AS 14 SW100AFR SuperSaturated SmartWipes 1692-100DSP Q-C-25 Quick Braid 25ft/0.075" 1803-25F Pro Wick Green #3 Braid 14 Water-Based SMT Stencil Clnr Wipes 6 SWS901HC SmartWipes Benchtop 1608-100DSP Electronic Hand Clnr (Wipes) Ultraclean Wipe 9x9 2355-100 Foam Wipe 6x9 2358-50 SMT Stencil Wipes 6 6 2 Quick Braid 100ft/0.075" 1803-100F Pro Wick Green #3 Braid 14 Q-C-500 Quick Braid 500ft/0.075" 1803-500F Pro Wick Green #3 Braid 14 Q-D-5 Quick Braid 5ft/0.100" 1804-5F Pro Wick Blue #4 Braid 14 Q-D-5AS Quick Braid A/S 5ft/0.100" 1811-5F Pro Wick Blue #4 Braid – AS 14 Q-D-10 Quick Braid 10ft/0.100" 1804-10F Pro Wick Blue #4 Braid 14 Q-D-10AS Quick Braid 10ft/0.100" 1811-10F Pro Wick Blue #4 Braid – AS 14 Q-D-25 Quick Braid 25ft/0.100" 1804-25F Pro Wick Blue #4 Braid 14 Q-D-100 Quick Braid 100ft/0.100" 1804-100F Pro Wick Blue #4 Braid 14 Q-D-500 Quick Braid 500ft/0.100" 1804-500F Pro Wick Blue #4 Braid 14 Q-E-5 Quick Braid 5ft/0.125" 1805-5F Pro Wick Brown #5 Braid 14 Q-E-5AS Quick Braid A/S 5ft/0.125" 1812-5F Pro Wick Brown #5 Braid – AS 14 Q-E-10AS Quick Braid A/S 10ft/0.125" 1812-10F Pro Wick Brown #5 Braid – AS 14 Q-E-25 Quick Braid 25ft/0.125" 1805-25F Pro Wick Brown #5 Braid 14 S-A-10 Sea Braid/ Unfluxed 10ft/0.025" 1830-10F Unfluxed White #1 Braid – AS 15 S-B-10 Sea Braid/ Unfluxed 10ft/0.050" 1831-10F Unfluxed Yellow #2 Braid – AS 15 Big Bath HFE (8oz) 1685-18S HFE Clnr 9 Big Bath (12oz) 1630-16S G3 Blue Shower 8 810 443 Techclean Purwipe Techclean SMT Foam Wipe 25 25 412 Optismart Wipe 9x9 Techclean Absorbwipe 25 0923C 529 130 Stratus Blue Comet Wipe 12.5 x 13 2359-300 White Tornado Wipe 12.5 x 13 2350-100 Stratus Wipe 8 x 9 2355-100 Techclean Blue Wipe Techclean Wiper Techclean Purwipe 25 24 25 4104MP Standard MPM#1485 Smart Roll 2367-MPM Tech Roll Ultra MPM Printers 25 4202DK Standard DEK#265GS Smart Roll 2366-DEK Tech Roll Ultra DEK Printers 25 5101MP SmartWeave MPM#1485 Smart Roll 2367-MPM Tech Roll Ultra MPM Printers 25 5202DK SmartWeave DEK#265GS Smart Roll 2366-DEK Tech Roll Ultra DEK Printers 25 KESTER 2352-100 PG. TECHSPRAY PG. TC-527 Hi-Temp Flexable Mask 2218-G WonderMASK PL Latex 19 TC-533 Flexable Mask 2218-8SQ WonderMASK PL Latex 19 S-C-5 Sea Braid/ Unfluxed 5ft/0.075" 1832-5F Unfluxed Green #3 Braid – AS 15 TC-533 Flexable Mask 2218-G WonderMASK PL Latex 19 S-D-10 Sea Braid/ Unfluxed Unfluxed Blue #4 Braid – AS 15 TC-564-1 Water Soluble Mask 2204-G WonderMASK WSOL 18 1833-10F For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 33 INDEX Q-C-100 19-2903-0008 19-0902-0000 INDEX LPS INDUSTRIES TECHSPRAY 00416 02816 1687-18S 1668-18S HFE Contact Clnr Contact Clnr II 1632-16S G3 Contact Clnr 1671-10S Duster Elecro Contact Clnr (14oz) High Purity NoFlash Clnr (15oz) NoFlash Electro Contact Clnr (15oz) QB Precision Duster (10oz) 04016 05710 444 1811-5F Pro Wick Blue #4 Braid – AS 14 12 12 Fine Braid Super Wick 0.100"/25ft. 453-NS No-Clean Super Wick 0.075"/50ft. 1822-50F No-Clean Green #3 Braid – AS 15 11 461 Fine Braid Super Wick 0.025"/100ft. 1808-100F Pro Wick White #1 Braid - AS 14 1 463 Fine Braid Super Wick 0.075"/100ft. 1810-100F Pro Wick Green #3 Braid - AS 14 PG. MG CHEMICAL TECHSPRAY 402A-285G 402A-450G 402AR 1671-10S 1671-15S 1671-10RS Duster Duster 15 Oz Fill Duster/Refill 1 1 1 464 Fine Braid Super Wick 0.100"/100ft. 1811-100F Pro Wick Blue #4 Braid - AS 14 472 Fine Braid Super Wick 0.050"/500ft. 1802-500F Pro Wick Yellow #2 Braid 14 1928 1672-10S 1672-15S 1620-10S Chrome Trigger Valve Freezer Freezer Ecoline Blue Shower 1 1 1 8 473 Fine Braid Super Wick 0.075"/500ft. 1803-500F Pro Wick Green #3 Braid 14 474 Fine Braid Super Wick 0.100"/500ft. 1804-500F Pro Wick Blue #4 Braid 14 801B-100ML Super Contact Clnr (3.5oz) 2111-N Contact Enhancer 12 1612-2SQ 1622-10S Rubber Rejuvenator Ecoline Contact Clnr 10 11 810-50 Chamois Swab/ Single Head 50ct 2314-50 Straight-Shaft Chamois Swab 26 1622-13S Ecoline Contact Clnr 11 811-100 Cotton Swab/ Double Headed 100ct 2300-100 Double-Tip Cotton Stick 26 1685-18S 1685-18S 1630-10S HFE Clnr HFE Clnr G3 Blue Shower 9 9 8 812-50 Foam over Cotton Swab 50ct 2302-50 Absorb-Tip Foam Swab 27 813-50 Foam Swabs 50ct Tip Foam Swab 27 814-50 Foam Swabs/rectangular 50ct 2306-50 Super-Tip Foam Swab 27 824-350ML Isopropanol Clnr (12oz) Pump 1610-PT Isopropyl Alcohol 5 402T 403A-285G 403A-400G 406B-450G 408A-100ML 409B-140G 409B-340G 411-300G 411-300G 412-300G Super Duster 134 (10oz) Super Duster 134 (15oz) Super Duster 134 Refill (10oz) Chrome Trigger Valve Super Cold 134 (10oz) Super Cold 134 (14oz) Super Wash Clnr Degrsr (16oz) Rubber Renue (3.5oz) Electrosolve Contact Clnr (5oz) Electrosolve Contact Clnr (12oz) HFE Solvent (10.5oz) Aerosol HFE Solvent (10.5oz) Aerosol Super Clnr Dgrsr (10.5oz) 2303-50 412-450G Super Clnr Dgrsr (16oz) G3 Blue Shower 8 413B-400G HD Flux Rmvr (15oz) Aerosol 1621-10S Ecoline Flux Rmvr 2 419B-340G Acrylic Laquer Conf Ctg (12oz) Aerosol 2103-12S Fine-L-Kote AR Conf Ctg 17 824-1G Isopropanol Clnr (1 gal) Liquid 4 per carton 1610-G4 Isopropyl Alcohol 5 419B-4L Acrylic Laquer Conf Ctg (1gal) Liquid 2103-G Fine-L-Kote AR Conf Ctg 17 824-1L Isopropanol Clnr (35oz) Liquid 1610-P Isopropyl Alcohol 5 419B-20L Acrylic Laquer Conf Ctg (5gal) Liquid 2103-5G Fine-L-Kote AR Conf Ctg 17 824-20L Isopropanol Clnr (5.8 gal) Liquid 1610-5G Isopropyl Alcohol 5 422-1L Silicone Conf Ctg (35oz) Liquid 2102-P Fine-L-Kote SR Conf Ctg 17 824W PreSaturated IPA Wipe 1610-50PK Isopropyl Alcohol Wipes 825-500G Glass Clnr (15oz) 1625-18S Glass Clnr Silicone Conf Ctg (1gal) Liquid Silicone Conf Ctg (5gal) Liquid Silicone Conf Ctg (12oz) Aerosol Silicone Conf Ctg Pen (5ml) Fine Braid Super Wick 0.025"/5ft. Fine Braid Super Wick 0.050"/5ft. No-Clean Super Wick 0.050"/5ft. Fine Braid Super Wick 0.075"/5ft. 2102-G Fine-L-Kote SR Conf Ctg 17 827B-425G HD Clnr Dgrsr (15 oz) Aerosol 1620-10S Ecoline Blue Shower 2102-5G Fine-L-Kote SR Conf Ctg 17 829-4x4 836-140G 2357-100 1613-6S Techclean Twillwipe Label & Adhesive Rmvr 25 10 2102-12S Fine-L-Kote SR Conf Ctg 17 2510-N 1808-5F Conf Ctg Rmvr Pen Pro Wick White #1 Braid – AS 23 14 1809-5F Pro Wick Yellow #2 Braid – AS 14 851 852 853 855-5 856 2025-1 2021-1 2022-1 2033-1 2032-1 Brush 1 3/8 x 1/4 Soft Brass Brush 1 3/8 x 1/4" Hog Hair Brush 2 1/8 x 7/8" Hog Hair Brush 7/16 x 3/8" Horse Hair Brush 1/4 x 3/8" Horse Hair 28 28 28 28 28 1821-5F No-Clean Yellow #2 Braid – AS 15 857 2027-1 Pro Wick Green #3 Braid – AS 14 858 Horse Hair Brush 3 row bristles Silicone Compound (5oz) Tube Solder Mask – Latex Peelable (6oz) Tube Solder Mask – Latex Peelable (1gal) Safety Wash (14oz) Aerosol Safety Wash (18.5 oz) Aerosol NPB HD (12oz) NPB HD (50gal) 2020-1 Brush HB Wood General Cleaning Brush 1 3/16 x 5/16" Stainless Steel Brush 1 3/8 x 1/4" Horse Hair 28 1810-5F Twillwipe 4"x4" Label and Adhesive Rmvr (5oz) Brush Brass Brush Hog Hair Brush Hog Hair Horse Hair Brush Tin Handle Horse Hair Brush Double Ended Hog Hair Brush 4.5" wooden handle Stainless Steel Brush 1977-DP Transistor Silicone Grease 13 2211-8SQ WonderMASK P 19 2211-G WonderMASK P 19 1620-10S 1620-10S 1630-16S 1640-54G Ecoline Blue Shower Ecoline Blue Shower G3 Blue Shower Vapor Dgrsr nPB 8 8 8 10 422-4L 422-20L 422A-340G 422A-P 423 424 424-NS 425 1630-16S PG. 425-NS No-Clean Super Wick 0.075"/5ft. 1822-5F No-Clean Green #3 Braid – AS 15 859 426 Fine Braid Super Wick 0.100"/5ft. 1811-5F Pro Wick Blue #4 Braid – AS 14 860-150G 426-NS No-Clean Super Wick 0.100"/5ft. 1823-5F No-Clean Blue #4 Braid – AS 15 862-150ML 427 Fine Braid Super Wick 0.125"/5ft4 1812-5F Pro Wick Brown #5 Braid – AS 14 862-4L 442 Fine Braid Super Wickk 0.050"/25ft. 1809-25F Pro Wick Yellow #2 Braid – AS 14 443 Fine Braid Super Wick 0.075"/25ft. 1810-25F Pro Wick Green #3 Braid – AS 14 4050-400G 4050-525G 4112-340G 4112-200L 34 For more information: 800-858-4043 - tsales@techspray.com 2043-1 5 10 8 28 28 MSDS / Specs: www.techspray.com INDEX HD Flux Rmvr (14oz) Aerosol 1621-10S Ecoline Flux Rmvr 2 MCC-MATG StatMat ESD Clnr (1gal) 4140-20L HD Flux Rmvr (5gal) Liquid 1621-5G Ecoline Flux Rmvr 2 MCC-MATP 4142-300G Flux Rmvr-HFE Plastic Safe 1686-18S HFE Flux Rmvr 3 MCC-MLCW 4190-GP Green Overcoat Pen (5ml) 2509-GN Trace Tech Overcoat Pen – Green 22 8112-100 Tapered Cotton Swab 100ct 2313-30 Double-Tip Pointed Cotton Stick 26 8420-P Silver Print Microtip Pen (8.5ml) 2505-N Trace Tech Conductive Pen 4140-400G MICROCARE TECHSPRAY 1733-G Zero Chrg Mat Clnr 21 StatMat ESD Clnr 1733-5G Zero Chrg Mat Clnr 21 MultiClean OA (100 wipes) 1608-100DSP SMT Stencil Wipes 6 MCC-P01 TidyPen (14ml) 10 pens/box 1613-N Label & Adhesive Rmvr Pen 10, 23 MCC-PC2 Precision Contact Clnr II (16oz) 1632-16S G3 Contact Clnr 11 MCC-PC3 Precision Contact Clnr III (16oz) 1687-18S HFE Contact Clnr 12 MCC-PEC Precision Electronics Clnr 141b1630-16S (12oz) G3 Blue Shower 8 MCC-PECD Precision Electronics Clnr (55gal) 1637-54G G3 Maintenance Clnr – Bulk 10 MCC-PECG Precision Electronics Cnr (1gal) 141b 1637-G G3 Maintenance Clnr – Bulk 10 MCC-PECP Precision Electronics Clnr (5gal) 1637-5G G3 Maintenance Clnr – Bulk 10 MCC-PMG Plastic, Metal Glass Clnr (12oz) 1625-18S Glass Clnr 10 MCC-PRO ProClean Flux Rmvr (12oz) 1621-10S Ecoline Flux Rmvr 2 MCC-PROD ProClean Flux Rmvr (360 lbs) 1621-54G Ecoline Flux Rmvr 2 MCC-PROP ProClean Flux Rmvr (32 lbs) 1621-5G Ecoline Flux Rmvr 2 MCC-SPR SuprClean Defluxer (12oz) 1631-16S G3 Flux Rmvr 2 MCC-SPRD SuprClean Defluxer (55 gal) 1638-54G G3 Flux Rmvr - Bulk 2 2 22 PG. MCC-2004 Genesolv 2004 (12oz) 1631-16S G3 Flux Rmvr 2 MCC-2004D Genesolv 2004 (55gal) 1638-54G G3 Flux Rmvr – Bulk 2 MCC-2004G Genesolv 2004 (1gal) 1638-G G3 Flux Rmvr – Bulk 2 MCC-2004P Genesolv 2004 (5gal) 1638-5G G3 Flux Rmvr – Bulk 2 MCC-AIR Big Blast Canned Air (14oz) 1671-15S Duster 15 Oz Fill 1 MCC-AXLD Axarel 2200 (55gal) 1694-54G Axarel 2200 MCC-AXLW Axarel 2200 (1lbs) 1693-100DSP SMT Stencil Clnr Wipes 6 MCC-BAC16 Isoclean, Isopropyl Alcohol (16oz) 1610-PT Isopropyl Alcohol 5 MCC-BACD Isoclean, Isopropyl Alcohol (55gal) 1610-54G Isopropyl Alcohol 5 MCC-BACG Isoclean, Isopropyl Alcohol (1gal) 1610-GS Isopropyl Alcohol 5 MCC-BACP Isoclean, Isopropyl Alcohol (5gal) 1610-5G Isopropyl Alcohol 5 MCC-SPRG SuprClean Defluxer (1 gal) 1638-G G3 Flux Rmvr - Bulk MCC-BGA BGA Stencil Clnr (12oz) 1692-PT Water-Based SMT Stencil Clnr 6 MCC-SPRP SuprClean Defluxer (5 gal) 1638-5G G3 Flux Rmvr - Bulk 2 MCC-BGAG BGA Stencil Clnr (1gal) 1692-G Water-Based SMT Stencil Clnr 6 MCC-W12 Economy Wipe 12"x16" 50/bag 2354-100 Techclean Ultrawipe 25 MCC-CCC Contact Clnr C (10oz) 1632-10S G3 Contact Clnr 11 MCC-W69MA Foam Wipes 6"X9" 25/bag Techclean SMT Foam Wipe 25 MCC-CCCD Contact Clnr C (55gal) 1637-54G G3 Maintenance Clnr – Bulk 10 MCC-W99 Economy Wipe 9"x9" 300/bag 2359-300 Techclean Blue Wipe 24 MCC-CCCG Contact Clnr C (1gal) 1637-G G3 Maintenance Clnr – Bulk 10 MCC-W9950 Economy Wipe 9"x9" 50/bag 2350-100 Techclean Wiper 24 MCC-CCCP Contact Clnr C (5gal) 1637-5G G3 Maintenance Clnr – Bulk 10 MCC-W99CP Optical Wipes 9"x9" 300/bag 2352-100 Techclean Absorbwipe 25 MCC-W99PP Cleanroom Wipe Light 9"x9" 150/bag 2362-150 Techclean Anti-Static Wipe 25 10 2358-50 MCC-DC1 VeriClean Defluxer (10oz) 1621-10S Ecoline Flux Rmvr 2 MCC-DC1D Vericlean Defluxer (55gal) 1621-54G Ecoline Flux Rmvr 2 MCC-DC1P VeriClean Defluxer (5gal) 1621-5G Ecoline Flux Rmvr 2 MCC-W99TJ Cotton Flat Wipes 9x9 300/bag 2357-100 Techclean Twillwipe 25 MCC-DST Big Blast Canned Air (10oz) 1671-10S Duster 1 MCC-WS202 Foam Swab 50/bag Super-Tip Foam Swab 27 MCC-EPXD ExPoxy Rmvr (55gal) 1694-54G Axarel 2200 10 MCC-WS501 Cotton Swab Large 1000/bag 2301-1000 Single-Tip Cotton Stick 26 MCC-EPXW ExPoxy Rmvr (100 wipes) 1693-100DSP SMT Stencil Clnr Wipes 6 MCC-WS502 Cotton Swab Small 1000/bag 2300-1000 Double-Tip Cotton Stick 26 MCC-FRC Flux Rmvr C (10oz) 1631-10S G3 Flux Rmvr 2 L80881 TidyPen (14ml) 3 pens/box Label & Adhesive Rmvr Pen 10, 23 MCC-FRCD Flux Rmvr C (55Gal) 1638-54G G3 Flux Rmvr – Bulk 2 MCC-FRCG Flux Rmvr C (1Gal) 1638-G G3 Flux Rmvr – Bulk 2 MCC-FRCP Flux Rmvr C (5Gal) 1638-5G G3 Flux Rmvr – Bulk 2 MCC-FRZ Micro Freeze Circuit Chiller (10oz) 1672-10S Freezer 1 2306-50 1613-N MILLER STEPHENSON TECHSPRAY MS-114N Conf Ctg Stripper 2510-P Conf Ctg Rmvr PG. 23 MS-222N Aero-Duster (14oz) 1671-15S Duster 15 Oz Fill 1 MS-222T Aero-Duster (10oz) 1671-10S Duster 1 MS-222F Aero-Duster (6oz) 1671-8S Duster 1 MS-242N Quik-Freeze (14oz) 1672-10S Freezer 1 1747-10S Anti-Static Freezer MCC-FRZA Anti-Stat Micro Freeze (10oz) 1747-10S Anti-Static Freezer 1 MCC-HD3 HD Flux Rmvr III (12oz) 1686-18S HFE Flux Rmvr 3 MS-242N-AS Quik-Freeze Antistatic (14oz) MCC-HDC HD Degreaser C (10oz) 1630-10S G3 Blue Shower 7 MS-260 MCC-HDCD HD Degreaser C (55Gal) 1637-54G G3 Maintenance Clnr – Bulk Safezone Clnr for 1625-18S Plastic, Glass & Metal (16oz) MCC-HDCG HD Degreaser C (1gal) 1637-G G3 Maintenance Clnr – Bulk 10 MS-381HM Connector Lubricant (8oz) 2112-6S Rid-Ox Contact Protector 12 MCC-HDCP HD Degreaser C (5gal) 1637-5G G3 Maintenance Clnr – Bulk 10 MS-460N Silicone Conf Ctg (16oz) 2102-12S Fine-L-Kote SR Conf Ctg 17 MCC-HYP HyperClean Flux Rmvr (12oz) 141b 1631-16S G3 Flux Rmvr 2 MS-462N Silicone Conf Ctg – Qt, G, 5G, 55G 2102-G Fine-L-Kote SR Conf Ctg 17 MCC-HYPD HyperClean Flux Rmvr (55Gal) 141b 1638-54G G3 Flux Rmvr – Bulk 2 MS-465N Acrylic Conf Ctg (16oz) 2103-12S Fine-L-Kote AR Conf Ctg 17 MS-467N 2103-G Fine-L-Kote AR Conf Ctg 17 MCC-HYPG HyperClean Flux Rmvr (9lbs) 141b 1638-G G3 Flux Rmvr – Bulk 2 Acrylic Conf Ctg – Qt, G, 5G, 55G MS-470N Urethane Conf Ctg (16oz) 2104-12S Fine-L-Kote UR Conf Ctg 17 MCC-HYPP HyperClean Flux Rmvr (45lbs) 141b 1638-5G G3 Flux Rmvr – Bulk 2 MS-472N Urethane Conf Ctg – Qt, G, 5G, 55G 2104-G Fine-L-Kote UR Conf Ctg 17 MCC-MAT StatMat ESD Clnr (12oz) 1733-PT Zero Chrg Mat Clnr 21 MS-475N Acrylic Conf Ctg (16oz) 2103-12S Fine-L-Kote AR Conf Ctg 17 1 10 MSDS / Specs: www.techspray.com 35 INDEX For more information: 800-858-4043 - tsales@techspray.com 10 Glass Clnr INDEX MS-477N Acrylic Conf Ctg – Qt, G, 5G, 55G 2103-G Fine-L-Kote AR Conf Ctg MS-725 HD Solvent & Flux Rmvr (16oz) 1631-16S G3 Flux Rmvr 2 MS-725M HD Solvent & Flux Rmvr (8oz) 1631-10S G3 Flux Rmvr 2 MS-730 Contact Re-Nu (16oz) 1687-18S HFE Contact Clnr 11 MS-750 Vertrel MCA Cleaning Agent (16oz) 1630-16S G3 Blue Shower 8 MS-930 Safezone Contact Re-Nu (16oz) 1632-16S G3 Contact Clnr MS-938/CO2 Safezone Contact Re-Nu & Lube (16oz) 2421-12S G3 Kleen-It Lubricant MS-990/CO2 Safezone Solvent & Flux Rmvr (16oz) 1631-16S G3 Flux Rmvr Safezone Solvent & Flux 1638-G MS-992 17 RAWN 11 1613-6S 1630-16S 2112-6S 1671-10S 1672-10S 1671-15S 2421-12S 1610-P Label & Adhesive Rmvr G3 Blue Shower Rid-Ox Contact Protector Duster Freezer Duster 15 Oz Fill G3 Kleen-It Lubricant Isopropyl Alcohol 10 8 12 1 1 1 13 5 13 51251 C.R.T. Screen & Plastic Clnr (12oz) 1743-6S Zero Charge Screen & Keyboard Clnr 21 2 51292 Versi-Clean HFE (12oz) 1685-18S HFE Clnr 9 51637 Flux Clean NR (16oz) Aerosol 1631-16S G3 Flux Rmvr 2 51667 Contact Clean (16oz) 1632-16S G3 Contact Clnr 11 51689 Generation 2000 – Electro-Clean 1630-16S G3 Blue Shower 8 51851 Plasti-Glass (18oz) 1625-18S Glass Clnr 52133 Flux Clean (21 oz) 1631-16S G3 Flux Rmvr 2 52489 Electro-Clean (24 oz) 1630-16S G3 Blue Shower 8 2 PG. Transistor Silicone Grease PG. Label Off (4oz) Safety Solvent (21oz) Ox-Off (5oz) Air Blast (10oz) Arctic Air II (10oz) Smart Duster (10oz) Contact Clean & Lube (16oz) Isopropyl Alcohol (12oz) Liquid G3 Flux Rmvr – Bulk TECHSPRAY TECHSPRAY 5416 6310 6520 51021 51022 51024 51083 51212L Rmvr – Qt,G, 5G, 55G 10004 RITE-OFF 13 10 Silicone Heat Sink (1oz syringe) 1977-DP 10006 Re-Grip (6.5oz) 1612-2SQ Rubber Rejuvenator 10 10008 Re-Grip (1oz) 1612-2SQ Rubber Rejuvenator 10 10130 Dust-A-Way (10oz) 1671-10S Duster 1 91164 Invisible Glass (19 oz) 1625-18S Glass Clnr 10210 Budget Dust-A-Way (8oz) 1673-10S Economy Duster 1 93234 Cut Clnr Dgrsr (12oz) 1620-10S Ecoline Blue Shower 8 11015 11017 11101 11109 11118 11170 13109 Fluxsolv II (9oz) Fluxsolv II (14oz) Contact Clnr (12oz) Flux Rmvr (12oz) Universal Contact Clnr (9oz) Circuit Wash (12oz) Super Freeze (10oz) 1621-10S 1621-10S 1632-16S 1631-10S 1622-10S 1685-18S 1672-10S Ecoline Flux Rmvr Ecoline Flux Rmvr G3 Contact Clnr G3 Flux Rmvr Ecoline Contact Clnr HFE Clnr Freezer 2 2 11 2 11 9 1 94052 HD Electro Klene (12oz) 1630-16S G3 Blue Shower 8 94072 Multi-Purpose Flux Rmvr (12oz) 1631-16S G3 Flux Rmvr 2 94142 Freeze Spray (10oz) 1672-10S Freezer 1 94151 Gust Premium Air Duster (10oz.) 1697-10S Vortex Duster 1 94153 Duster 15 Oz Fill 1 Anti-Static Glass & Plastic Clnr (14oz) 1625-18S Glass Clnr 10 Gust Premium Air Duster (15oz.) 1671-15S 27150 94201 Vortex 360 Duster 1 VpCI/Acrylic-based Conf Ctg (12oz) 2103-12S Fine-L-Kote AR Conf Ctg 17 Gust Spray Anyway 360 Duster (8oz) 1697-8S 34011 94202 Duster 1 Super Glue (3 gm) 2503-DP Tech Hold Adhesive 23 Gust Compact Size Easy Duster (8oz) 1671-8S 35010 35315 Spray Adhesive (16oz) 3500-11S HD Adhesive 94203 Duster 15 Oz Fill 1 Rawn Propyl (1pt) 1610-P Isopropyl Alcohol 5 Gust Time Saving Easy Duster (12oz) 1671-15S 62305 62306 Rawn Propyl (1gal) 1610-GS Isopropyl Alcohol 5 94213 XENIT Clnr/Rmvr (10oz) 1613-6S Label & Adhesive Rmvr STONER TECHSPRAY PG. 10 10 INDUSTRY APPROVALS CALL OUT Alcatel 005-0214-060 AT&T Com Code #406359406 AT&T Com Code #406359414 Boeing Aircraft (127713) Boeing Aircraft (BAC5485) Celestica 8500-4214 Celestica 8500-6386 Celestica 8500-6416 Celestica 8690-0576 Celestica 8690-0577 Celestica 8690-0588 Celestica 8710-2129 Celestica 9300-0468 Celestica 9300-0468 Celestica 9300-1618 Celestica 9300-1731 Celestica 9300-1921 36 PART # 2111-N 1702-G w/1912 1733-QT 1632 1720 2206 2111 1610-DSP 1821 1823 1822 2025-1 2302-1000 2303-1000 2350-100 1702-8FP 1733-G PAGE 12 21 21 11 20 18 12 5 15 15 15 28 27 27 24 21 21 For more information: 800-858-4043 - tsales@techspray.com CALL OUT Celestica 9300-6148 Chrysler Corp. NPM #85-147-6381 Delco C00012555 Delco C00013781 Delco C00038201 Delco C00054786 FORD TOX #030255 FORD TOX #031474 FORD TOX #036375 FORD TOX #039772 FORD TOX #139832 FORD TOX #142415 FORD TOX #142422 FORD TOX #142430 FORD TOX #142431 FORD TOX #142435 PART # 1702-G 1671 1671-15S 1726 1702 1747 1665 (aerosol) 1667 (aerosol) 1663 (aerosol) 2211 1726-PT 1612-2SQ 1613-2SQ 1620 (aerosol) 1621 (aerosol) 1671-10S PAGE 21 1 1 21 21 1 4 9 9 19 21 10 10 8 2 1 MSDS / Specs: www.techspray.com INDEX CALL OUT FORD TOX #142434 FORD TOX #142436 FORD TOX #142487 FORD TOX #143333 FORD TOX #143334 FORD TOX #143516 FORD TOX #167818 FORD TOX #167834 FORD TOX #167835 General Dynamics General Dynamics mHSDS 080516-01 GM Cadillac-Flint H1013 GM Cadillac-Flint H1015 GM Cadillac-Flint H1017 GM Powertrain Flint HMA 120993-F GM Powertrain Flint HMA 120993-H Hewlett Packard 8500-4214 Hewlett Packard 8500-6344 Hewlett Packard 8500-6386 Hewlett Packard 8500-6416 Hewlett Packard 8690-0576 Hewlett Packard 8690-0577 Hewlett Packard 8690-0588 Hewlett Packard 8710-2129 Hewlett Packard 9300-0468 Hewlett Packard 9300-0468 Hewlett Packard 9300-1618 Hewlett Packard 9300-1731 PART # 1672 1742-PT 1743-PT 1664 (aerosol) 1666 (aerosol) 1668 (aerosol) 1630-16S 1631-16S 1632-16S 1720 1742-QT PAGE 1 21 21 9 5 12 8 2 11 20 21 1621 (aerosol) 1620 (aerosol) 1622 (aerosol) 1671 2 8 11 1 1672 1 2206 1747-10S 2111 1610-DSP 1821 1823 1822 2025-1 2302-1000 2303-1000 2350-100 1702-8FP 18 1 12 5 15 15 15 28 27 27 24 21 CALL OUT Hewlett Packard 9300-1921 Hewlett Packard 9300-6148 John Deere McDonnell Douglas 558-1672-10S Motorola Service Centers NCR 603-8001308 NSN 6830-01-335-9925 NSN 6850-01-324-4682 NSN 6850-01-406-1356 Unisys USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted K2 USDA Accepted A4 PART # 1733-G 1702-G 1663-18S 1672 PAGE 21 21 9 1 2211-G 1747 1671-10S 1726 1672 1720 1620 (aerosol) 1620 (bulk) 1621 (aerosol) 1621 (bulk) 1622 (aerosol) 1622 (bulk) 1663 (aerosol) 1663 (bulk) 1664 (aerosol) 1664 (bulk) 1665 (bulk) 1666 (aerosol) 1666 (bulk) 1667 (aerosol) 1667 (bulk) 1668 (aerosol) 1668 (bulk) 1669 (bulk) 1670 (bulk) 1726 (aerosol) 19 1 1 21 1 20 8 8 2 2 11 11 9 9 9 9 3 5 5 9 9 12 12 5 21 STANDARDS & SPECIFICATIONS SPECS PART # PG. SPECS PART # Bell Core Standards Bell Labs KS 21343 Boeing: O2 Tool & System Cleaning Spec. BAC 5402 Boeing: Solvent Metal Cleaning Spec. BAC 5750 Hughes/Raytheon HMS 2360, HMS 2350 Kearfott Y102A034 MIL-B-81705B MIL-B-81705B MIL-B-81705B MIL-C-47113 MIL-F-142560D Type R MIL-I-46058C Type AR MIL-I-46058C Type SR MIL-I-46058C Type SR MIL-I-46058C Type UR 2111-N 1978 1663 12 13 9 Temporary Mask 18-19 9 9 21 21 21 13 14 17 17 17 17 MIL-STD-2000 Para 5.3.18 parts a, b, & d NASA NHB 5300.4(3A-1) NASA NPC 200-4 NASA SE-5-0073 Shuttle NASA SP5002 Navy-Trident SCD6721469 NFPA 56A NFPA 56A NFPA 56A NFPA 56A NFPA 56A TRW: Space & Electronics Group Part ID Number (PIN) 225: PIN-C822281-1, AES-C822281-2, 225T-C822281-3 USAF requirements (for surface contamination) 1801-1813 1801-1813 1663 1801-1813 1663 1720 1721 1722 1726 1743 1663, 1665, 1669 14 14 9 14 9 20 20 20 21 21 3, 5, 9 PG. 9 9 9 9 TEST TYPE Space Shuttle Spec. Fluid Procurement & Use Control 0SE-S-0073, Change #61 Compressed Gas Assn. 1663 9 1663 1663 1726 1742 1743 1978 1801-1813 2103 2102 2106 2104 PG. 2350 24 OXYGEN SPECS TEST METHOD ASTM G72-82 ASTM D2512 S064675 PART # 1663 1663 1663 1663 EDTF-1R-95-0048 1663 TEST METHOD PART # 1663 ASTM G-121 ASTM G-122 1663 PG. 9 9 9 LO-MSD-1C For more information: 800-858-4043 - tsales@techspray.com MSDS / Specs: www.techspray.com 37 INDEX TEST TYPE Autogenous Ignition LOX Impact Cleaning Applications Gauge & Precision Instrument Cleaning Precision Cleaning & Verification
1747-10S 价格&库存
很抱歉,暂时无法提供与“1747-10S”相匹配的价格&库存,您可以联系我们找货
1747-10S
    库存:68
