1815-5F
1815-5F
    TECHSPRAY
    NO-CLEAN YELLOW #2 BRAID
1815-5F 数据手册
No-Clean Desoldering Braid 1814-1825 Desoldering braid (wick) is pre-fluxed copper braid that is used to remove solder, which allows components to be replaced and excess solder to be removed. Techspray wick is available in static dissipative bobbins (except where indicated) for static sensitive environments. No-clean flux coated braid -- cleanest in the industry! Techspray NoClean wick does not leave behind ionic flux residues that can collect and form branches called “dendrites”. Other fluxes, if not cleaned properly, can cause dendrites that grow over time (see A, B) and eventually cause short circuits between traces or leads (C). Latent failures lead to costly returns and lower the quality perception of your products. Effective on both lead and lead-free solders. Size chart: Braid # #1 #2 #3 #4 #5 #6 Color Code White Yellow Green Blue Brown Red Width (in) 0.035 0.055 0.075 0.098 0.130 0.193 Width (mm) 0.9 1.4 1.9 2.5 3.3 4.9 No-clean flux coated braid Effective on both lead and lead-free solders Cleanest wick -- clear, non-reactive residues Will not leave ionic residue -- avoid dendrite failure Exceeds MIL-F-14256, Type Anti-static spool (except where indicated) Product Packaging 1814-100F No-Clean White #1 Braid 100' 1 units/case 1815-5F No-Clean Yellow #2 Braid 5' 25 units/case 1815-10F No-Clean Yellow #2 Braid 10' 25 units/case 1815-100F 1815-500F 1816-5F Techspray - US office, P.O. Box 949, Amarillo, TX 79105-0949, Tel. 806-372-8523, Toll-free 800-858-4043 Fax 806-372-8750, tsales@techspray.com page 1 / 5 No-Clean Yellow #2 Braid 100' 1 units/case No-Clean Yellow #2 Braid 500' 1 units/case No-Clean Green #3 Braid 5' 25 units/case 1816-10F No-Clean Green #3 Braid 10' 25 units/case 1816-50F No-Clean Green #3 Braid 50' 1 units/case 1816-100F No-Clean Green #3 Braid 100' 1 units/case 1816-500F No-Clean Green #3 Braid 500' 1 units/case 1817-5F No-Clean Blue #4 Braid 5' 25 units/case 1817-10F No-Clean Blue #4 Braid 10' 25 units/case 1817-100F No-Clean Blue #4 Braid 100' 1 units/case 1817-500F No-Clean Blue #4 Braid 500' 1 units/case 1820-5F No-Clean White #1 Braid - AS 5' 25 units/case Techspray - US office, P.O. Box 949, Amarillo, TX 79105-0949, Tel. 806-372-8523, Toll-free 800-858-4043 Fax 806-372-8750, tsales@techspray.com page 2 / 5 1820-10F No-Clean White #1 Braid - AS 10' 25 units/case 1820-50F No-Clean White #1 Braid - AS 50' 1 units/case 1821-5F No-Clean Yellow #2 Braid - AS 5' 25 units/case 1821-10F No-Clean Yellow #2 Braid - AS 10' 25 units/case 1821-25F No-Clean Yellow #2 Braid - AS 25' 1 units/case 1821-50F No-Clean Yellow #2 Braid - AS 50' 1 units/case 1822-5F No-Clean Green #3 Braid - AS 5' 25 units/case 1822-10F No-Clean Green #3 Braid - AS 10' 25 units/case 1822-50F No-Clean Green #3 Braid - AS 50' 1 units/case Techspray - US office, P.O. Box 949, Amarillo, TX 79105-0949, Tel. 806-372-8523, Toll-free 800-858-4043 Fax 806-372-8750, tsales@techspray.com page 3 / 5 1822-100F No-Clean Green #3 Braid - AS 100' 1 units/case 1823-5F No-Clean Blue #4 Braid - AS 5' 25 units/case 1823-10F No-Clean Blue #4 Braid - AS 10' 25 units/case 1823-25F No-Clean Blue #4 Braid - AS 25' 1 units/case 1823-100F No-Clean Blue #4 Braid - AS 100' 1 units/case 1824-5F No-Clean Brown #5 Braid - AS 5' 25 units/case 1824-25F No-Clean Brown #5 Braid - AS 25' 1 units/case 1825-5F No-Clean Red #6 Braid - AS 5' 25 units/case Techspray - US office, P.O. Box 949, Amarillo, TX 79105-0949, Tel. 806-372-8523, Toll-free 800-858-4043 Fax 806-372-8750, tsales@techspray.com page 4 / 5 Chemical & Physical Properties Appearance Odor Flash Point VOC (EPA) VOC (CARB) Boiling Point Density Chemical Composition CHEMICAL NAME CAS # Non-ionic flux mixture (Proprietary non-hazardous blend) 7440-50-8 Copper Environmental Policy Techspray is committed to developing products to ensure a safer and cleaner environment. We will continue to meet and sustain the regulations of all federal, state and local government agencies. Resources Techspray products are supported by a global sales, technical and customer services resources. For additional technical information on this product or other Techspray products in the United States, call the technical sales department at 800-858-4043, email tsales@techspray.com or visit our web site at: www.techspray.com. North America Techspray P.O. Box 949 Amarillo, TX 79105 800-858-4043 email: tsales@techspray.com Europe ITW Contamination Control BV Saffierlaan 5 2132 VZ Hoofddorp The Netherlands +31 88 1307 400 email: info@itw-cc.com Countries Outside US Call to locate a distributor in your country Important Notice to Purchaser/User: The information in this publication is based on tests that we believe are reliable. The results may vary due to differences in tests type and conditions. We recommend that each user evaluate the product to determine its suitability for the intended application. Conditions of use are outside our control and vary widely. Techspray's only obligation and your only solution is replacement of product that is shown to be defective when you receive it. In no case will Techspray be liable for any special, incidental, or consequential damages based on breach of warranty, negligence or any other theory. Techspray - US office, P.O. Box 949, Amarillo, TX 79105-0949, Tel. 806-372-8523, Toll-free 800-858-4043 Fax 806-372-8750, tsales@techspray.com page 5 / 5
1815-5F 价格&库存
很抱歉,暂时无法提供与“1815-5F”相匹配的价格&库存,您可以联系我们找货
