2222-G
2222-G
    TECHSPRAY
    2222-G
2222-G 数据手册
Product Information WonderMASK® PX Fast-Dry Peelable Solder Mask 2222 Introduction ® WonderMASK PX is a temporary, peelable, latex solder mask designed to dry in half the time of standard peelable solder masks. It is hand applied and can withstand fluxing, wave soldering and cleaning operations. It effectively masks and protects open through-holes and underside components in a wave soldering process, and can be used as a conformal coatings mask. WonderMASK PX can remain on all areas of the board until ready for test, and then, be easily peeled away. In addition, WonderMASK PX is ideally suited for situations where a thick coat of mask is required. WonderMASK PX has been specially formulated to cure homogenously, virtually eliminating any limit on the deposition thickness. Features / Benefits • • • • • • • • Fast Drying – dries in half the time of standard peelable masks Ideal for situations where a thick coat of mask is required Peelable Mask Able to withstand temperatures up to 650°F / 343°C Prevents solder from flowing into contacts, terminals, screw heads, and plated through holes Mask for conformal coating Will not tarnish gold or phosphor bronze Protects delicate components Dry Time (Minutes)* WonderMASK PX is not recommended for use on bare copper as it contains a sufficient concentration of ammonia to cause discoloration. For use on bare copper, WonderMASK PL (part # 2211) is recommended. Dry Time Comparison 140 120 100 80 60 40 20 0 15 40 2222 80 Mil Thickness of Mask Standard Peelable Mask *Dry time is the time until the mask could be easily removed, in one piece, from the substrate. Beads of mask were approximately 4 inches in length. 1 Copyright 2013 Techspray. For Commercial Use Only Directions • • • • Apply mask to areas that you do not want soldered Allow mask to cure (cure time is dependent on thickness of mask applied and environmental conditions, e.g. temperature, humidity) Send board onto solder stage (solder pot, wave solder) Easily peel mask off board Chemical Properties For Chemical Composition, refer to MSDS. • • • • • • • PHYSICAL STATE: Liquid ODOR: Slight APPEARANCE: White viscous liquid pH: 9.5 to 11.0 SOLUBILITY IN WATER: Fully miscible DENSITY: 1.09 to 1.17 g/mL VISCOSITY: 9,000 to 16,000 cps Chemical Components CHEMICAL NAME CAS # Titanium Dioxide……………………………………………….13463-67-7 Application Hand Cure Type Thermal Cure Time Removal Viscosity Peel off. Dried mask is 9,000-16,000 5 min. Ambient not soluble in cps liquids. Suggested Thickness Thinner 15 mils D.I. Water Environmental Policy ® Techspray is committed to developing products to ensure a safer and cleaner environment. We will continue to meet and sustain the regulations of all federal, state and local government agencies. Packaging and Availability 2222-16SQ 2222-G 16 Ounce Squeeze Bottle 1 Gallon in Plastic Jug Resources Techspray® products are supported by a global sales, technical and customer services resources. For additional technical information on this product or other Techspray® products in the United States, call the technical sales department at 800-858-4043, email tsales@techspray.com or visit our web site at: www.techspray.com. North America Techspray P.O. Box 949 Amarillo, TX 79105 800-858-4043 email: tsales@techspray.com 2 Europe ITW Contamination Control BV Saffierlaan 5 2132 VZ Hoofddorp The Netherlands +31 88 1307 400 info@itw-cc.com Countries Outside US Call to locate a distributor in your country. Copyright 2013 Techspray. For Commercial Use Only Important Notice to Purchaser/User: The information in this publication is based on tests that we believe are reliable. The results may vary due to differences in tests type and conditions. We recommend that each user evaluate the product to determine its suitability for the intended application. Conditions of use are outside our control and vary widely. Techspray’s only obligation and your only solution is replacement of product that is shown to be defective when you receive it. In no case will Techspray® be liable for any special, incidental, or consequential damages based on breach of warranty, negligence or any other theory. 3 Copyright 2013 Techspray. For Commercial Use Only
2222-G 价格&库存
很抱歉,暂时无法提供与“2222-G”相匹配的价格&库存,您可以联系我们找货
