1868708
1868708
    DYMO
    DYMO - 1868708 - Label Printer Tape, XTL, Thermal Transfer, Black on White, 39 mm
1868708 数据手册
XTL Labels TM Laminated Wire/Cable Wrap • Pre-sized wire/cable wraps with laminated overwrap protect printed areas from oil, chemicals, moisture, abrasion and fading • Improve your productivity by printing batches of cable wraps at once • Simply take them with you, peel and apply • Easy-to-peel pre-sized labels makes applying labels quick and easy • Durable thermal transfer printing technology – label text won’t smear or fade • RoHS Compliant Quick Specs Item Number Width (mm) Length (mm) Colour Quantity of Pre-Sized Labels Unit 1868704 1868705 21 21 DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM 21 39 A A 250 150 Label Widths Varied Tape Platform XTL Printer Compatibility XTL 300: Up to 21 mm XTL 500: Up to 51 mm Printing System Thermal Transfer Temperature Rating -40° to 60°C UL Recognized Component to UL 969 Country of Origin Belgium Material Vinyl Length (mm) Width (mm) Height (mm) Weight (kg) QTY EAN 72 35 120 0.091 1 071701000668 Shelf 215 76 126 0.59 6 30071701000669 Case 400 230 145 3.25 30 50071701000663 Pallet 1200 800 1165 230.06 63 - Unit 72 35 120 0.09 1 071701000675 Shelf 215 76 126 0.59 6 30071701000676 Case 400 230 145 3.25 30 50071701000670 Pallet 1200 800 1165 230.06 63 - This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. 1363856_WDY_SS_RD_LAMINATED_WIRE_CABLE_WRAP_EMEA_v1.indd 1 ©2015 Newell Europe LLC 29/07/2015 11:17 XTL Labels TM Item Number 1868706 1868707 1868708 1868709 1868710 1868711 1868712 Width 21 38 38 38 51 51 51 DISTRIBUTED BY: Newell Europe Sàrl Chemin de Blandonnet 10 1214 Vernier – Switzerland WWW.DYMO.COM Length 102 21 39 102 21 39 102 Colour A A A A A A A Quantity of Pre-Sized Labels 75 250 150 75 250 100 70 Length (mm) Width (mm) Height (mm) Weight (kg) EAN Unit 72 35 120 0.09 1 071701000682 Shelf 215 76 126 0.59 6 30071701000683 50071701000687 Case 400 230 145 3.25 30 Pallet 1200 800 1165 230.06 63 - Unit 72 65 120 0.13 1 071701000699 Shelf 215 76 126 0.46 3 30071701000690 Case 400 230 145 2.61 15 50071701000694 Pallet 1200 800 1165 189.43 63 - Unit 72 65 120 0.13 1 071701000705 Shelf 215 76 126 0.46 3 30071701000706 50071701000700 Case 400 230 145 2.61 15 Pallet 1200 800 1165 189.43 63 - Unit 72 65 120 0.13 1 071701000712 Shelf 215 76 126 0.46 3 30071701000713 Case 400 230 145 2.61 15 50071701000717 Pallet 1200 800 1165 189.43 63 - Unit 72 65 120 0.173 1 071701000729 Shelf 215 76 126 0.56 3 30071701000720 50071701000724 Case 400 230 145 3.12 15 Pallet 1200 800 1165 221.56 63 - Unit 72 65 120 0.173 1 071701000736 Shelf 215 76 126 0.56 3 30071701000737 Case 400 230 145 3.12 15 50071701000731 Pallet 1200 800 1165 221.56 63 - Unit 72 65 120 0.173 1 071701000743 Shelf 215 76 126 0.56 3 30071701000744 Case 400 230 145 3.12 15 50071701000748 Pallet 1200 800 1165 221.56 63 - This information is being provided for general information purposes and the compliance standards and certifications referenced herein are based on current standards which are subject to change. 1363856_WDY_SS_RD_LAMINATED_WIRE_CABLE_WRAP_EMEA_v1.indd 2 QTY ©2015 Newell Europe LLC 29/07/2015 11:17
1868708 价格&库存
很抱歉,暂时无法提供与“1868708”相匹配的价格&库存,您可以联系我们找货
